[U-Boot] [PATCH] RFC: dfu: mmc: call fs functions instead of run_command
This unbreaks dfu mmc_file_op which is currently broken since using the load cmd on a buffer from heap is not allowed.
Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com ---
drivers/dfu/dfu_mmc.c | 67 ++++++++++++++++++++----------------------- 1 file changed, 31 insertions(+), 36 deletions(-)
diff --git a/drivers/dfu/dfu_mmc.c b/drivers/dfu/dfu_mmc.c index b45e6dc54c..2585b14328 100644 --- a/drivers/dfu/dfu_mmc.c +++ b/drivers/dfu/dfu_mmc.c @@ -108,17 +108,17 @@ static int mmc_file_buffer(struct dfu_entity *dfu, void *buf, long *len) static int mmc_file_op(enum dfu_op op, struct dfu_entity *dfu, void *buf, u64 *len) { - const char *fsname, *opname; - char cmd_buf[DFU_CMD_BUF_SIZE]; - char *str_env; + char dev_part_str[DFU_CMD_BUF_SIZE]; int ret; + int fstype; + loff_t size = 0;
switch (dfu->layout) { case DFU_FS_FAT: - fsname = "fat"; + fstype = FS_TYPE_FAT; break; case DFU_FS_EXT4: - fsname = "ext4"; + fstype = FS_TYPE_EXT; break; default: printf("%s: Layout (%s) not (yet) supported!\n", __func__, @@ -126,48 +126,43 @@ static int mmc_file_op(enum dfu_op op, struct dfu_entity *dfu, return -1; }
+ snprintf(dev_part_str, DFU_CMD_BUF_SIZE, "%d:%d", dfu->data.mmc.dev, + dfu->data.mmc.part); + + ret = fs_set_blk_dev("mmc", dev_part_str, fstype); + if (ret) { + puts("dfu: fs_set_blk_dev error!\n"); + return ret; + } + switch (op) { case DFU_OP_READ: - opname = "load"; + ret = fs_read(dfu->name, (size_t)buf, 0, 0, &size); + if (ret) { + puts("dfu: fs_read error!\n"); + return ret; + } + *len = size; break; case DFU_OP_WRITE: - opname = "write"; + ret = fs_write(dfu->name, (size_t)buf, 0, *len, &size); + if (ret) { + puts("dfu: fs_write error!\n"); + return ret; + } break; case DFU_OP_SIZE: - opname = "size"; + ret = fs_size(dfu->name, &size); + if (ret) { + puts("dfu: fs_size error!\n"); + return ret; + } + *len = size; break; default: return -1; }
- sprintf(cmd_buf, "%s%s mmc %d:%d", fsname, opname, - dfu->data.mmc.dev, dfu->data.mmc.part); - - if (op != DFU_OP_SIZE) - sprintf(cmd_buf + strlen(cmd_buf), " %p", buf); - - sprintf(cmd_buf + strlen(cmd_buf), " %s", dfu->name); - - if (op == DFU_OP_WRITE) - sprintf(cmd_buf + strlen(cmd_buf), " %llx", *len); - - debug("%s: %s 0x%p\n", __func__, cmd_buf, cmd_buf); - - ret = run_command(cmd_buf, 0); - if (ret) { - puts("dfu: Read error!\n"); - return ret; - } - - if (op != DFU_OP_WRITE) { - str_env = env_get("filesize"); - if (str_env == NULL) { - puts("dfu: Wrong file size!\n"); - return -1; - } - *len = simple_strtoul(str_env, NULL, 16); - } - return ret; }
Steven,
Am Do., 24. Jan. 2019, 19:39 hat Simon Goldschmidt < simon.k.r.goldschmidt@gmail.com> geschrieben:
I'd be very thankful if you could test this! It's RFC as I don't know to test DFU.
Thanks, Simon
char *str_env;
int fstype;
loff_t size = 0; switch (dfu->layout) { case DFU_FS_FAT:
fsname = "fat";
fsname = "ext4";
dfu->data.mmc.dev,
if (ret) {
return ret;
opname = "load";
if (ret) {
return ret;
opname = "write";
if (ret) {
return ret;
opname = "size";
if (ret) {
return ret;
if (ret) {
return ret;
return -1;
return ret;
-- 2.17.1
Tested-by: Stephen Warren swarren@nvidia.com
- char *str_env;
- char dev_part_str[DFU_CMD_BUF_SIZE];
This can be a lot smaller now, but I guess it's fine as is.
Am Do., 24. Jan. 2019, 21:05 hat Stephen Warren swarren@wwwdotorg.org geschrieben:
That was fast, thanks!
char *str_env;
This is why this is RFC. I wanted to find a way to prevent the conversion to string and back first.
Simon Goldschmidt
Stephen Warren
