[PATCH] bootstd: cros: store partition type in an efi_guid_t
The scan_part() function uses a struct uuid to store the little-endian partition type GUID, but this structure should be used only to contain a big-endian UUID. Use an efi_guid_t instead.
Signed-off-by: Vincent Stehlé vincent.stehle@arm.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- boot/bootmeth_cros.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/boot/bootmeth_cros.c b/boot/bootmeth_cros.c index f015f2e1c75..1f83c14aeab 100644 --- a/boot/bootmeth_cros.c +++ b/boot/bootmeth_cros.c @@ -148,7 +148,7 @@ static int scan_part(struct udevice *blk, int partnum, { struct blk_desc *desc = dev_get_uclass_plat(blk); struct vb2_keyblock *hdr; - struct uuid type; + efi_guid_t type; ulong num_blks; int ret;
@@ -161,7 +161,7 @@ static int scan_part(struct udevice *blk, int partnum,
/* Check for kernel partition type */ log_debug("part %x: type=%s\n", partnum, info->type_guid); - if (uuid_str_to_bin(info->type_guid, (u8 *)&type, UUID_STR_FORMAT_GUID)) + if (uuid_str_to_bin(info->type_guid, type.b, UUID_STR_FORMAT_GUID)) return log_msg_ret("typ", -EINVAL);
if (memcmp(&cros_kern_type, &type, sizeof(type)))
Am 27. Juni 2024 19:06:29 MESZ schrieb "Vincent Stehlé" vincent.stehle@arm.com:
- struct uuid type;
- efi_guid_t type;
Does Chrome OS only support GPT partitioning?
- if (uuid_str_to_bin(info->type_guid, type.b, UUID_STR_FORMAT_GUID)) return log_msg_ret("typ", -EINVAL);
struct disk_partition containing a string which is only needed in the CLI instead of the 16 byte GUID was a bad idea to start with. Shouldn't we replace it or add least add a GUID field instead of first converting to string and than back to GUID?
You could use the guidcmp() macro here.
Best regards
Heinrich
struct uuid type;
efi_guid_t type;
Indeed.
Yes I agree, it would be nice to fix that.
On Thu, Jun 27, 2024 at 09:28:04PM +0200, Heinrich Schuchardt wrote:
Hi Heinrich,
Thanks for your review. My comments below.
Best regards, Vincent.
- struct uuid type;
- efi_guid_t type;
I had a quick look and it seems that converting all those UUIDs from strings to binary would indeed impact many places; let's separate this longer-term effort from this change if you agree.
Thanks for the tip; I will send a v2 series.
Best regards
Heinrich
This is a respin of this patch [1] after discussion [2]. Thanks to Simon and Heinrich for their reviews.
To use the guidcmp() function, as suggested by Heinrich, we need to make it available to bootmeth_cros.c and I think that the cleanest way to do that is (arguably) to move the guid helper functions to efi.h near the efi_guid_t definition; this is why the original patch has now become a series of two patches.
The alternative would be to include efi_loader.h from bootmeth_cros.c but I think this does not sound "right". If this is in fact the preferred approach just let me know and I will respin.
There is no difference in the sandbox binaries before/after this series on Arm and on PC, and all the tests I have run on the sandbox are unchanged.
[1] https://patchwork.ozlabs.org/project/uboot/patch/20240627170629.2696427-1-vi... [2] https://lists.denx.de/pipermail/u-boot/2024-June/557588.html
Vincent Stehlé (2): efi: move guid helper functions to efi.h bootstd: cros: store partition type in an efi_guid_t
boot/bootmeth_cros.c | 6 +++--- include/efi.h | 10 ++++++++++ include/efi_loader.h | 10 ---------- 3 files changed, 13 insertions(+), 13 deletions(-)
Move the guidcmp() and guidcpy() functions to efi.h, near the definition of the efi_guid_t type those functions deal with.
Signed-off-by: Vincent Stehlé vincent.stehle@arm.com Cc: Heinrich Schuchardt xypron.glpk@gmx.de Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Tom Rini trini@konsulko.com --- include/efi.h | 10 ++++++++++ include/efi_loader.h | 10 ---------- 2 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/include/efi.h b/include/efi.h index c3c4b93f860..d5af2139946 100644 --- a/include/efi.h +++ b/include/efi.h @@ -78,6 +78,16 @@ typedef struct { u8 b[16]; } efi_guid_t __attribute__((aligned(4)));
+static inline int guidcmp(const void *g1, const void *g2) +{ + return memcmp(g1, g2, sizeof(efi_guid_t)); +} + +static inline void *guidcpy(void *dst, const void *src) +{ + return memcpy(dst, src, sizeof(efi_guid_t)); +} + #define EFI_BITS_PER_LONG (sizeof(long) * 8)
/* Bit mask for EFI status code with error */ diff --git a/include/efi_loader.h b/include/efi_loader.h index 6c993e1a694..ca8fc0820f6 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -21,16 +21,6 @@ struct blk_desc; struct jmp_buf_data;
-static inline int guidcmp(const void *g1, const void *g2) -{ - return memcmp(g1, g2, sizeof(efi_guid_t)); -} - -static inline void *guidcpy(void *dst, const void *src) -{ - return memcpy(dst, src, sizeof(efi_guid_t)); -} - #if CONFIG_IS_ENABLED(EFI_LOADER)
The scan_part() function uses a struct uuid to store the little-endian partition type GUID, but this structure should be used only to contain a big-endian UUID. Use an efi_guid_t instead and use guidcmp() for the comparison.
Suggested-by: Heinrich Schuchardt xypron.glpk@gmx.de Signed-off-by: Vincent Stehlé vincent.stehle@arm.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com ---
Changes for v2: - Use guidcmp() for the comparison, as suggested by Heinrich.
boot/bootmeth_cros.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/boot/bootmeth_cros.c b/boot/bootmeth_cros.c index 645b8bed102..676f550ca25 100644 --- a/boot/bootmeth_cros.c +++ b/boot/bootmeth_cros.c @@ -147,7 +147,7 @@ static int scan_part(struct udevice *blk, int partnum, { struct blk_desc *desc = dev_get_uclass_plat(blk); struct vb2_keyblock *hdr; - struct uuid type; + efi_guid_t type; ulong num_blks; int ret;
@@ -160,10 +160,10 @@ static int scan_part(struct udevice *blk, int partnum,
- if (memcmp(&cros_kern_type, &type, sizeof(type))) + if (guidcmp(&cros_kern_type, &type)) return log_msg_ret("typ", -ENOEXEC);
/* Make a buffer for the header information */
Vincent Stehlé
