[U-Boot] errno confusion for fw_env?
with current master I tried to cross-compile a fw_env tool for the da850evm configuration. So I tried the "standard scheme" (means it worked a few years ago)
make distclean make da850evm_config make env
Doing this I noticed that commit abd315a1357ab05e82f0d61ebad666bc0d5378c3 disabled cross-compilation. So I reverted the commit locally on my tree to enable cross-compilation again, but now I get:
[dzu@pollux u-boot-testing (master)]$ make env make -C tools/env all MTD_VERSION= make[1]: Entering directory `/work/dzu/git/u-boot-testing/tools/env' arm-linux-gcc -Wall -DUSE_HOSTCC -I/work/dzu/git/u-boot-testing/include crc32.c fw_env.c fw_env_main.c -o fw_printenv /opt/eldk-4.2-2008-11-24/usr/bin/../lib/gcc/arm-linux-gnueabi/4.2.2/../../../../arm-linux-gnueabi/bin/ld: errno: TLS definition in /opt/eldk-4.2-2008-11-24/usr/../arm/lib/libc.so.6 section .tbss mismatches non-TLS reference in /tmp/cc45c402.o /opt/eldk-4.2-2008-11-24/usr/../arm/lib/libc.so.6: could not read symbols: Bad value collect2: ld returned 1 exit status make[1]: *** [fw_printenv] Error 1 make[1]: Leaving directory `/work/dzu/git/u-boot-testing/tools/env' make: *** [env] Error 2
The cross-compilation and the "-DUSE_HOSTCC" doesn't look right somehow. And moreover we now pull in the "U-Boot errno" stuff for a regular user-space tool through "-I$(SRCTREE)/include".
The latter comes from this commit:
commit f3b6d528e4dd719640a4bfcd954f4e4c7f5db0d6 Author: Grant Erickson gerickson@nuovations.com Date: Tue May 6 16:18:00 2008 -0700
Fix Compilation Errors with 'tools/env/fw_printenv'
In the current top-of-tree, 1.3.3.-rc2, the optional tool 'tools/env/fw_printenv' fails to compile for two reasons:
1) The header watchdog.h cannot be found. 2) The header zlib.h is picked up from the tool chain rather than the project causing a prototype conflict for crc32.
This patch addresses both of these issues.
Platforms Tested On: - AMCC "Kilauea"
Signed-off-by: Grant Erickson gerickson@nuovations.com
It was probably not anticipated that this now picks up errno.h from the project as well.
Does anybody have a good idea on how to tackle this?
Thanks Detlev
Detlev Zundel <dzu <at> denx.de> writes:
Thanks Detlev
Hi Detlev,
Did you ever find a solution to this problem?
Best Regards,
Rob
Detlev Zundel
Robert McCullough
