[PATCH 1/2] cmd: mvebu/bubt: Check for A38x image data checksum
Currently for A38x image is checked only header checksum. So check also for image data checksum to prevent flashing broken image.
Signed-off-by: Pali Rohár pali@kernel.org --- cmd/mvebu/bubt.c | 45 ++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 44 insertions(+), 1 deletion(-)
diff --git a/cmd/mvebu/bubt.c b/cmd/mvebu/bubt.c index ffa05bc20181..615234e41897 100644 --- a/cmd/mvebu/bubt.c +++ b/cmd/mvebu/bubt.c @@ -689,9 +689,24 @@ static uint8_t image_checksum8(const void *start, size_t len) return csum; }
+static uint32_t image_checksum32(const void *start, size_t len) +{ + u32 csum = 0; + const u32 *p = start; + + while (len) { + csum += *p; + ++p; + len -= sizeof(u32); + } + + return csum; +} + static int check_image_header(void) { u8 checksum; + u32 checksum32, exp_checksum32; const struct a38x_main_hdr_v1 *hdr = (struct a38x_main_hdr_v1 *)get_load_addr(); const size_t image_size = a38x_header_size(hdr); @@ -702,11 +717,39 @@ static int check_image_header(void) checksum = image_checksum8(hdr, image_size); checksum -= hdr->checksum; if (checksum != hdr->checksum) { - printf("Error: Bad A38x image checksum. 0x%x != 0x%x\n", + printf("Error: Bad A38x image header checksum. 0x%x != 0x%x\n", checksum, hdr->checksum); return -ENOEXEC; }
+ offset = le32_to_cpu(hdr->srcaddr); + size = le32_to_cpu(hdr->blocksize); + + if (hdr->blockid == 0x78) { /* SATA id */ + if (offset < 1) { + printf("Error: Bad A38x image srcaddr.\n"); + return -ENOEXEC; + } + offset -= 1; + offset *= 512; + } + + if (hdr->blockid == 0xAE) /* SDIO id */ + offset *= 512; + + if (offset % 4 != 0 || size < 4 || size % 4 != 0) { + printf("Error: Bad A38x image blocksize.\n"); + return -ENOEXEC; + } + + checksum32 = image_checksum32((u8 *)hdr + offset, size - 4); + exp_checksum32 = *(u32 *)((u8 *)ptr + offset + size - 4); + if (checksum32 != exp_checksum32) { + printf("Error: Bad A38x image data checksum. 0x%08x != 0x%08x\n", + checksum32, exp_checksum32); + return -ENOEXEC; + } + printf("Image checksum...OK!\n"); return 0; }
For obvious reasons BootROMS rejects unsigned images when secure boot is enabled in OTP secure bits. So check for OPT secure bits and do not allow flashing unsigned images when secure boot is enabled.
Additionally Armada 3700 BootROM rejects signed trusted image when secure boot is not enabled in OTP. So add also check for this case.
OTP secure bits may have burned also boot device source. Check it also and reject flashing images to target storage which does not match OTP.
Signed-off-by: Pali Rohár pali@kernel.org --- cmd/mvebu/bubt.c | 123 +++++++++++++++++++++++++++++++++++++++++++---- 1 file changed, 114 insertions(+), 9 deletions(-)
diff --git a/cmd/mvebu/bubt.c b/cmd/mvebu/bubt.c index 615234e41897..ac98154fb759 100644 --- a/cmd/mvebu/bubt.c +++ b/cmd/mvebu/bubt.c @@ -14,6 +14,8 @@ #include <vsprintf.h> #include <errno.h> #include <dm.h> +#include <fuse.h> +#include <mach/efuse.h>
#include <spi_flash.h> #include <spi.h> @@ -122,6 +124,17 @@ struct a38x_main_hdr_v1 { u8 checksum; /* 0x1F */ };
+/* + * Header for the optional headers, version 1 (Armada 370/XP/375/38x/39x) + */ +struct a38x_opt_hdr_v1 { + u8 headertype; + u8 headersz_msb; + u16 headersz_lsb; + u8 data[0]; +}; +#define A38X_OPT_HDR_V1_SECURE_TYPE 0x1 + struct a38x_boot_mode { unsigned int id; const char *name; @@ -707,6 +720,7 @@ static int check_image_header(void) { u8 checksum; u32 checksum32, exp_checksum32; + u32 offset, size; const struct a38x_main_hdr_v1 *hdr = (struct a38x_main_hdr_v1 *)get_load_addr(); const size_t image_size = a38x_header_size(hdr); @@ -743,7 +757,7 @@ static int check_image_header(void) }
checksum32 = image_checksum32((u8 *)hdr + offset, size - 4); - exp_checksum32 = *(u32 *)((u8 *)ptr + offset + size - 4); + exp_checksum32 = *(u32 *)((u8 *)hdr + offset + size - 4); if (checksum32 != exp_checksum32) { printf("Error: Bad A38x image data checksum. 0x%08x != 0x%08x\n", checksum32, exp_checksum32); @@ -753,6 +767,36 @@ static int check_image_header(void) printf("Image checksum...OK!\n"); return 0; } + +static int a38x_image_is_secure(const struct a38x_main_hdr_v1 *hdr) +{ + u32 image_size = a38x_header_size(hdr); + struct a38x_opt_hdr_v1 *ohdr; + u32 ohdr_size; + + if (hdr->version != 1) + return 0; + + if (!hdr->ext) + return 0; + + ohdr = (struct a38x_opt_hdr_v1 *)(hdr + 1); + do { + if (ohdr->headertype == A38X_OPT_HDR_V1_SECURE_TYPE) + return 1; + + ohdr_size = (ohdr->headersz_msb << 16) | le16_to_cpu(ohdr->headersz_lsb); + + if (!*((u8 *)ohdr + ohdr_size - 4)) + break; + + ohdr = (struct a38x_opt_hdr_v1 *)((u8 *)ohdr + ohdr_size); + if ((u8 *)ohdr >= (u8 *)hdr + image_size) + break; + } while (1); + + return 0; +} #else /* Not ARMADA? */ static int check_image_header(void) { @@ -761,20 +805,56 @@ static int check_image_header(void) } #endif
+static u64 fuse_read_u64(u32 bank) +{ + u32 val[2]; + int ret; + + ret = fuse_read(bank, 0, &val[0]); + if (ret < 0) + return -1; + + ret = fuse_read(bank, 1, &val[1]); + if (ret < 0) + return -1; + + return ((u64)val[1] << 32) | val[0]; +} + +#if defined(CONFIG_ARMADA_3700) +static inline u8 maj3(u8 val) +{ + /* return majority vote of 3 bits */ + return ((val & 0x7) == 3 || (val & 0x7) > 4) ? 1 : 0; +} +#endif + static int bubt_check_boot_mode(const struct bubt_dev *dst) { #if defined(CONFIG_ARMADA_3700) || defined(CONFIG_ARMADA_32BIT) - int mode; + int mode, secure_mode; #if defined(CONFIG_ARMADA_3700) const struct tim_boot_flash_sign *boot_modes = tim_boot_flash_signs; const struct common_tim_data *hdr = (struct common_tim_data *)get_load_addr(); u32 id = hdr->boot_flash_sign; + int is_secure = hdr->trusted != 0; + u64 otp_secure_bits = fuse_read_u64(1); + int otp_secure_boot = ((maj3(otp_secure_bits >> 0) << 0) | + (maj3(otp_secure_bits >> 4) << 1)) == 2; + unsigned int otp_boot_device = (maj3(otp_secure_bits >> 48) << 0) | + (maj3(otp_secure_bits >> 52) << 1) | + (maj3(otp_secure_bits >> 56) << 2) | + (maj3(otp_secure_bits >> 60) << 3); #elif defined(CONFIG_ARMADA_32BIT) const struct a38x_boot_mode *boot_modes = a38x_boot_modes; const struct a38x_main_hdr_v1 *hdr = (struct a38x_main_hdr_v1 *)get_load_addr(); u32 id = hdr->blockid; + int is_secure = a38x_image_is_secure(hdr); + u64 otp_secure_bits = fuse_read_u64(EFUSE_LINE_SECURE_BOOT); + int otp_secure_boot = otp_secure_bits & 0x1; + unsigned int otp_boot_device = (otp_secure_bits >> 8) & 0x7; #endif
for (mode = 0; boot_modes[mode].name; mode++) { @@ -787,15 +867,40 @@ static int bubt_check_boot_mode(const struct bubt_dev *dst) return -ENOEXEC; }
- if (strcmp(boot_modes[mode].name, dst->name) == 0) - return 0; + if (strcmp(boot_modes[mode].name, dst->name) != 0) { + printf("Error: image meant to be booted from "%s", not "%s"!\n", + boot_modes[mode].name, dst->name); + return -ENOEXEC; + }
- printf("Error: image meant to be booted from "%s", not "%s"!\n", - boot_modes[mode].name, dst->name); - return -ENOEXEC; -#else - return 0; + if (otp_secure_bits == (u64)-1) { + printf("Error: cannot read OTP secure bits\n"); + return -ENOEXEC; + } else { + if (otp_secure_boot && !is_secure) { + printf("Error: secure boot is enabled in OTP but image does not have secure boot header!\n"); + return -ENOEXEC; + } else if (!otp_secure_boot && is_secure) { +#if defined(CONFIG_ARMADA_3700) + /* + * Armada 3700 BootROM rejects trusted image when secure boot is not enabled. + * Armada 385 BootROM accepts image with secure boot header also when secure boot is not enabled. + */ + printf("Error: secure boot is disabled in OTP but image has secure boot header!\n"); + return -ENOEXEC; +#endif + } else if (otp_boot_device && otp_boot_device != id) { + for (secure_mode = 0; boot_modes[secure_mode].name; secure_mode++) { + if (boot_modes[secure_mode].id == otp_boot_device) + break; + } + printf("Error: boot source is set to "%s" in OTP but image is for "%s"!\n", + boot_modes[secure_mode].name ?: "unknown", dst->name); + return -ENOEXEC; + } + } #endif + return 0; }
static int bubt_verify(const struct bubt_dev *dst)
--- Changes in v2: * Compile fix (move code chunk from patch 2/2 to 1/2) --- cmd/mvebu/bubt.c | 45 ++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 44 insertions(+), 1 deletion(-)
diff --git a/cmd/mvebu/bubt.c b/cmd/mvebu/bubt.c index 2136af64163c..3b6ffb7ffd1f 100644 --- a/cmd/mvebu/bubt.c +++ b/cmd/mvebu/bubt.c @@ -688,9 +688,24 @@ static uint8_t image_checksum8(const void *start, size_t len) return csum; }
+static uint32_t image_checksum32(const void *start, size_t len) +{ + u32 csum = 0; + const u32 *p = start; + + while (len) { + csum += *p; + ++p; + len -= sizeof(u32); + } + + return csum; +} + static int check_image_header(void) { u8 checksum; + u32 checksum32, exp_checksum32; const struct a38x_main_hdr_v1 *hdr = (struct a38x_main_hdr_v1 *)get_load_addr(); const size_t image_size = a38x_header_size(hdr); @@ -701,11 +716,39 @@ static int check_image_header(void) checksum = image_checksum8(hdr, image_size); checksum -= hdr->checksum; if (checksum != hdr->checksum) { - printf("Error: Bad A38x image checksum. 0x%x != 0x%x\n", + printf("Error: Bad A38x image header checksum. 0x%x != 0x%x\n", checksum, hdr->checksum); return -ENOEXEC; }
+ offset = le32_to_cpu(hdr->srcaddr); + size = le32_to_cpu(hdr->blocksize); + + if (hdr->blockid == 0x78) { /* SATA id */ + if (offset < 1) { + printf("Error: Bad A38x image srcaddr.\n"); + return -ENOEXEC; + } + offset -= 1; + offset *= 512; + } + + if (hdr->blockid == 0xAE) /* SDIO id */ + offset *= 512; + + if (offset % 4 != 0 || size < 4 || size % 4 != 0) { + printf("Error: Bad A38x image blocksize.\n"); + return -ENOEXEC; + } + + checksum32 = image_checksum32((u8 *)hdr + offset, size - 4); + exp_checksum32 = *(u32 *)((u8 *)hdr + offset + size - 4); + if (checksum32 != exp_checksum32) { + printf("Error: Bad A38x image data checksum. 0x%08x != 0x%08x\n", + checksum32, exp_checksum32); + return -ENOEXEC; + } + printf("Image checksum...OK!\n"); return 0; }
For obvious reasons BootROMS rejects unsigned images when secure boot is enabled in OTP secure bits. So check for OPT secure bits and do not allow flashing unsigned images when secure boot is enabled. Access to OTP via U-Boot fuse API is currently implemented only for A38x and A37xx SoCs.
Additionally Armada 3700 BootROM rejects signed trusted image when secure boot is not enabled in OTP. So add also check for this case. On the other hand Armada 38x BootROM acceps images with secure boot header when secure boot is not enabled in OTP.
--- Changes in v2: * Add missing dependency on MVEBU_EFUSE * Use only for A38x and A37xx --- cmd/mvebu/Kconfig | 1 + cmd/mvebu/bubt.c | 127 +++++++++++++++++++++++++++++++++++++++++++--- 2 files changed, 120 insertions(+), 8 deletions(-)
diff --git a/cmd/mvebu/Kconfig b/cmd/mvebu/Kconfig index 120397d6d4d0..9ec3aa983a51 100644 --- a/cmd/mvebu/Kconfig +++ b/cmd/mvebu/Kconfig @@ -5,6 +5,7 @@ config CMD_MVEBU_BUBT bool "bubt" select SHA256 if ARMADA_3700 select SHA512 if ARMADA_3700 + select MVEBU_EFUSE if ARMADA_38X || ARMADA_3700 help bubt - Burn a u-boot image to flash For details about bubt command please see the documentation diff --git a/cmd/mvebu/bubt.c b/cmd/mvebu/bubt.c index 3b6ffb7ffd1f..feb1e778a98c 100644 --- a/cmd/mvebu/bubt.c +++ b/cmd/mvebu/bubt.c @@ -13,6 +13,8 @@ #include <vsprintf.h> #include <errno.h> #include <dm.h> +#include <fuse.h> +#include <mach/efuse.h>
#include <spi_flash.h> #include <spi.h> @@ -121,6 +123,17 @@ struct a38x_main_hdr_v1 { u8 checksum; /* 0x1F */ };
+/* + * Header for the optional headers, version 1 (Armada 370/XP/375/38x/39x) + */ +struct a38x_opt_hdr_v1 { + u8 headertype; + u8 headersz_msb; + u16 headersz_lsb; + u8 data[0]; +}; +#define A38X_OPT_HDR_V1_SECURE_TYPE 0x1 + struct a38x_boot_mode { unsigned int id; const char *name; @@ -706,6 +719,7 @@ static int check_image_header(void) { u8 checksum; u32 checksum32, exp_checksum32; + u32 offset, size; const struct a38x_main_hdr_v1 *hdr = (struct a38x_main_hdr_v1 *)get_load_addr(); const size_t image_size = a38x_header_size(hdr); @@ -752,6 +766,38 @@ static int check_image_header(void) printf("Image checksum...OK!\n"); return 0; } + +#if defined(CONFIG_ARMADA_38X) +static int a38x_image_is_secure(const struct a38x_main_hdr_v1 *hdr) +{ + u32 image_size = a38x_header_size(hdr); + struct a38x_opt_hdr_v1 *ohdr; + u32 ohdr_size; + + if (hdr->version != 1) + return 0; + + if (!hdr->ext) + return 0; + + ohdr = (struct a38x_opt_hdr_v1 *)(hdr + 1); + do { + if (ohdr->headertype == A38X_OPT_HDR_V1_SECURE_TYPE) + return 1; + + ohdr_size = (ohdr->headersz_msb << 16) | le16_to_cpu(ohdr->headersz_lsb); + + if (!*((u8 *)ohdr + ohdr_size - 4)) + break; + + ohdr = (struct a38x_opt_hdr_v1 *)((u8 *)ohdr + ohdr_size); + if ((u8 *)ohdr >= (u8 *)hdr + image_size) + break; + } while (1); + + return 0; +} +#endif #else /* Not ARMADA? */ static int check_image_header(void) { @@ -760,20 +806,58 @@ static int check_image_header(void) } #endif
+static u64 fuse_read_u64(u32 bank) +{ + u32 val[2]; + int ret; + + ret = fuse_read(bank, 0, &val[0]); + if (ret < 0) + return -1; + + ret = fuse_read(bank, 1, &val[1]); + if (ret < 0) + return -1; + + return ((u64)val[1] << 32) | val[0]; +} + +#if defined(CONFIG_ARMADA_3700) +static inline u8 maj3(u8 val) +{ + /* return majority vote of 3 bits */ + return ((val & 0x7) == 3 || (val & 0x7) > 4) ? 1 : 0; +} +#endif + static int bubt_check_boot_mode(const struct bubt_dev *dst) { #if defined(CONFIG_ARMADA_3700) || defined(CONFIG_ARMADA_32BIT) - int mode; + int mode, secure_mode; #if defined(CONFIG_ARMADA_3700) const struct tim_boot_flash_sign *boot_modes = tim_boot_flash_signs; const struct common_tim_data *hdr = (struct common_tim_data *)get_load_addr(); u32 id = hdr->boot_flash_sign; + int is_secure = hdr->trusted != 0; + u64 otp_secure_bits = fuse_read_u64(1); + int otp_secure_boot = ((maj3(otp_secure_bits >> 0) << 0) | + (maj3(otp_secure_bits >> 4) << 1)) == 2; + unsigned int otp_boot_device = (maj3(otp_secure_bits >> 48) << 0) | + (maj3(otp_secure_bits >> 52) << 1) | + (maj3(otp_secure_bits >> 56) << 2) | + (maj3(otp_secure_bits >> 60) << 3); #elif defined(CONFIG_ARMADA_32BIT) const struct a38x_boot_mode *boot_modes = a38x_boot_modes; const struct a38x_main_hdr_v1 *hdr = (struct a38x_main_hdr_v1 *)get_load_addr(); u32 id = hdr->blockid; +#if defined(CONFIG_ARMADA_38X) + int is_secure = a38x_image_is_secure(hdr); + u64 otp_secure_bits = fuse_read_u64(EFUSE_LINE_SECURE_BOOT); + int otp_secure_boot = otp_secure_bits & 0x1; + unsigned int otp_boot_device = (otp_secure_bits >> 8) & 0x7; +#endif #endif
for (mode = 0; boot_modes[mode].name; mode++) { @@ -786,15 +870,42 @@ static int bubt_check_boot_mode(const struct bubt_dev *dst) return -ENOEXEC; }
- printf("Error: image meant to be booted from "%s", not "%s"!\n", - boot_modes[mode].name, dst->name); - return -ENOEXEC; -#else - return 0; +#if defined(CONFIG_ARMADA_38X) || defined(CONFIG_ARMADA_3700) + if (otp_secure_bits == (u64)-1) { + printf("Error: cannot read OTP secure bits\n"); + return -ENOEXEC; + } else { + if (otp_secure_boot && !is_secure) { + printf("Error: secure boot is enabled in OTP but image does not have secure boot header!\n"); + return -ENOEXEC; + } else if (!otp_secure_boot && is_secure) { +#if defined(CONFIG_ARMADA_3700) + /* + * Armada 3700 BootROM rejects trusted image when secure boot is not enabled. + * Armada 385 BootROM accepts image with secure boot header also when secure boot is not enabled. + */ + printf("Error: secure boot is disabled in OTP but image has secure boot header!\n"); + return -ENOEXEC; #endif + } else if (otp_boot_device && otp_boot_device != id) { + for (secure_mode = 0; boot_modes[secure_mode].name; secure_mode++) { + if (boot_modes[secure_mode].id == otp_boot_device) + break; + } + printf("Error: boot source is set to "%s" in OTP but image is for "%s"!\n", + boot_modes[secure_mode].name ?: "unknown", dst->name); + return -ENOEXEC; + } + } +#endif +#endif + return 0; }
Thanks, Stefan
Changes in v2:
- Add missing dependency on MVEBU_EFUSE
- Use only for A38x and A37xx
- select MVEBU_EFUSE if ARMADA_38X || ARMADA_3700 help bubt - Burn a u-boot image to flash For details about bubt command please see the documentation
- Header for the optional headers, version 1 (Armada 370/XP/375/38x/39x)
- u8 headertype;
- u8 headersz_msb;
- u16 headersz_lsb;
- u8 data[0];
- struct a38x_boot_mode { unsigned int id; const char *name;
- u32 offset, size; const struct a38x_main_hdr_v1 *hdr = (struct a38x_main_hdr_v1 *)get_load_addr(); const size_t image_size = a38x_header_size(hdr);
- u32 image_size = a38x_header_size(hdr);
- struct a38x_opt_hdr_v1 *ohdr;
- u32 ohdr_size;
- if (hdr->version != 1)
- if (!hdr->ext)
- ohdr = (struct a38x_opt_hdr_v1 *)(hdr + 1);
- do {
return 1;
break;
break;
- } while (1);
- u32 val[2];
- int ret;
- ret = fuse_read(bank, 0, &val[0]);
- if (ret < 0)
return -1;
- ret = fuse_read(bank, 1, &val[1]);
- if (ret < 0)
return -1;
- return ((u64)val[1] << 32) | val[0];
- /* return majority vote of 3 bits */
- return ((val & 0x7) == 3 || (val & 0x7) > 4) ? 1 : 0;
+} +#endif
- static int bubt_check_boot_mode(const struct bubt_dev *dst) { #if defined(CONFIG_ARMADA_3700) || defined(CONFIG_ARMADA_32BIT)
- int mode;
- int mode, secure_mode; #if defined(CONFIG_ARMADA_3700) const struct tim_boot_flash_sign *boot_modes = tim_boot_flash_signs; const struct common_tim_data *hdr = (struct common_tim_data *)get_load_addr(); u32 id = hdr->boot_flash_sign;
- int is_secure = hdr->trusted != 0;
- u64 otp_secure_bits = fuse_read_u64(1);
- int otp_secure_boot = ((maj3(otp_secure_bits >> 0) << 0) |
- unsigned int otp_boot_device = (maj3(otp_secure_bits >> 48) << 0) |
#elif defined(CONFIG_ARMADA_32BIT) const struct a38x_boot_mode *boot_modes = a38x_boot_modes; const struct a38x_main_hdr_v1 *hdr = (struct a38x_main_hdr_v1 *)get_load_addr(); u32 id = hdr->blockid;(maj3(otp_secure_bits >> 60) << 3);
- int is_secure = a38x_image_is_secure(hdr);
- u64 otp_secure_bits = fuse_read_u64(EFUSE_LINE_SECURE_BOOT);
- int otp_secure_boot = otp_secure_bits & 0x1;
- unsigned int otp_boot_device = (otp_secure_bits >> 8) & 0x7;
+#endif #endif
- if (strcmp(boot_modes[mode].name, dst->name) != 0) {
printf("Error: image meant to be booted from \"%s\", not \"%s\"!\n",
return -ENOEXEC;
- return -ENOEXEC;
-#else
- if (otp_secure_bits == (u64)-1) {
return -ENOEXEC;
- } else {
return -ENOEXEC;
#endifreturn -ENOEXEC;
break;
printf("Error: boot source is set to \"%s\" in OTP but image is for \"%s\"!\n",
return -ENOEXEC;
+#endif +#endif
return 0; }
Viele Grüße, Stefan Roese
Hi Pali,
Changes in v2:
Running a world CI build leads to these errors:
$ make clearfog_gt_8k_defconfig ... $ make -sj cmd/mvebu/bubt.c:809:12: warning: 'fuse_read_u64' defined but not used [-Wunused-function] 809 | static u64 fuse_read_u64(u32 bank) | ^~~~~~~~~~~~~
Could you please please take a look and fix this issue?
Thanks, Stefan
- u8 headertype;
- u8 headersz_msb;
- u16 headersz_lsb;
- u8 data[0];
- u32 ohdr_size;
- if (!hdr->ext)
- do {
return 1;
break;
break;
- } while (1);
- u32 val[2];
- int ret;
- if (ret < 0)
return -1;
- if (ret < 0)
return -1;
+} +#endif
- int mode;
+#endif #endif
return -ENOEXEC;
- return -ENOEXEC;
-#else
return -ENOEXEC;
- } else {
return -ENOEXEC;
break;
return -ENOEXEC;
+#endif +#endif
return 0; }
On Tuesday 23 August 2022 07:05:33 Stefan Roese wrote:
Hi Pali,
Changes in v2:
There is missing guard to not compile that function for A7k/A8k. I will fix it in v3.
Thanks, Stefan
diff --git a/cmd/mvebu/bubt.c b/cmd/mvebu/bubt.c index 3b6ffb7ffd1f..feb1e778a98c 100644 --- a/cmd/mvebu/bubt.c +++ b/cmd/mvebu/bubt.c @@ -13,6 +13,8 @@ #include <vsprintf.h> #include <errno.h> #include <dm.h> +#include <fuse.h> +#include <mach/efuse.h> #include <spi_flash.h> #include <spi.h> @@ -121,6 +123,17 @@ struct a38x_main_hdr_v1 { u8 checksum; /* 0x1F */ }; +/*
- u8 headertype;
- u8 headersz_msb;
- u16 headersz_lsb;
- u8 data[0];
- u32 ohdr_size;
- if (!hdr->ext)
- do {
return 1;
break;
break;
- } while (1);
+} +#endif #else /* Not ARMADA? */ static int check_image_header(void) { @@ -760,20 +806,58 @@ static int check_image_header(void) } #endif +static u64 fuse_read_u64(u32 bank) +{
- u32 val[2];
- int ret;
- if (ret < 0)
return -1;
- if (ret < 0)
return -1;
+} +#endif
- int mode;
+#endif #endif for (mode = 0; boot_modes[mode].name; mode++) { @@ -786,15 +870,42 @@ static int bubt_check_boot_mode(const struct bubt_dev *dst) return -ENOEXEC; }
return -ENOEXEC;
- return -ENOEXEC;
-#else
return -ENOEXEC;
- } else {
return -ENOEXEC;
break;
return -ENOEXEC;
+#endif +#endif
- return 0; } static int bubt_verify(const struct bubt_dev *dst)
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-51 Fax: (+49)-8142-66989-80 Email: sr@denx.de
Hi Pali,
Changes in v2:
Thanks for fixing this. I'll probably skip v3 in the next pull request, as I've everything ready with the other patches now.
Thanks, Stefan
Thanks, Stefan
- u8 headertype;
- u8 headersz_msb;
- u16 headersz_lsb;
- u8 data[0];
- u32 ohdr_size;
- if (!hdr->ext)
- do {
return 1;
break;
break;
- } while (1);
- u32 val[2];
- int ret;
- if (ret < 0)
return -1;
- if (ret < 0)
return -1;
+} +#endif
- int mode;
return -ENOEXEC;
- return -ENOEXEC;
-#else
return -ENOEXEC;
- } else {
return -ENOEXEC;
break;
return -ENOEXEC;
+#endif +#endif
Thanks, Stefan
Changes in v2:
- Compile fix (move code chunk from patch 2/2 to 1/2)
- u32 csum = 0;
- const u32 *p = start;
- while (len) {
csum += *p;
++p;
len -= sizeof(u32);
- return csum;
- static int check_image_header(void) { u8 checksum;
- u32 checksum32, exp_checksum32; const struct a38x_main_hdr_v1 *hdr = (struct a38x_main_hdr_v1 *)get_load_addr(); const size_t image_size = a38x_header_size(hdr);
return -ENOEXEC; }
if (offset < 1) {
return -ENOEXEC;
offset -= 1;
offset *= 512;
offset *= 512;
return -ENOEXEC;
return -ENOEXEC;
Hi Pali,
Changes in v2:
- u32 csum = 0;
- while (len) {
csum += *p;
++p;
len -= sizeof(u32);
- return csum;
return -ENOEXEC; }
While running a world Azure CI build, I get these errors:
$ make clearfog_defconfig $ make -sj ... cmd/mvebu/bubt.c: In function 'check_image_header': cmd/mvebu/bubt.c:724:9: error: 'offset' undeclared (first use in this function); did you mean 'off_t'? 724 | offset = le32_to_cpu(hdr->srcaddr); | ^~~~~~ | off_t cmd/mvebu/bubt.c:724:9: note: each undeclared identifier is reported only once for each function it appears in cmd/mvebu/bubt.c:725:9: error: 'size' undeclared (first use in this function); did you mean 'size_t'? 725 | size = le32_to_cpu(hdr->blocksize); | ^~~~ | size_t make[2]: *** [scripts/Makefile.build:258: cmd/mvebu/bubt.o] Error 1 make[1]: *** [scripts/Makefile.build:398: cmd/mvebu] Error 2 make[1]: *** Waiting for unfinished jobs.... make: *** [Makefile:1916: cmd] Error 2 make: *** Waiting for unfinished jobs....
Could you please take a look and fix these issues?
Thanks, Stefan
- if (hdr->blockid == 0x78) { /* SATA id */
if (offset < 1) {
return -ENOEXEC;
offset -= 1;
offset *= 512;
- if (hdr->blockid == 0xAE) /* SDIO id */
offset *= 512;
- if (offset % 4 != 0 || size < 4 || size % 4 != 0) {
return -ENOEXEC;
- checksum32 = image_checksum32((u8 *)hdr + offset, size - 4);
- exp_checksum32 = *(u32 *)((u8 *)hdr + offset + size - 4);
- if (checksum32 != exp_checksum32) {
return -ENOEXEC;
- printf("Image checksum...OK!\n"); return 0; }
On Tuesday 23 August 2022 12:28:48 Stefan Roese wrote:
Hi Pali,
Changes in v2:
diff --git a/cmd/mvebu/bubt.c b/cmd/mvebu/bubt.c index 2136af64163c..3b6ffb7ffd1f 100644 --- a/cmd/mvebu/bubt.c +++ b/cmd/mvebu/bubt.c @@ -688,9 +688,24 @@ static uint8_t image_checksum8(const void *start, size_t len) return csum; } +static uint32_t image_checksum32(const void *start, size_t len) +{
- u32 csum = 0;
- while (len) {
csum += *p;
++p;
len -= sizeof(u32);
- return csum;
return -ENOEXEC; }printf("Error: Bad A38x image header checksum. 0x%x != 0x%x\n", checksum, hdr->checksum);
- offset = le32_to_cpu(hdr->srcaddr);
- size = le32_to_cpu(hdr->blocksize);
It took me some time to find where is the issue, because I was not able to reproduce it. But finally I was able to trigger it. The issue is that changes are incorrectly split into patch 1/2 and 2/2. So if you apply both patches, there is no issue.
I will try to fix it and send a v3.
Thanks, Stefan
if (offset < 1) {
return -ENOEXEC;
offset -= 1;
offset *= 512;
offset *= 512;
return -ENOEXEC;
return -ENOEXEC;
Signed-off-by: Pali Rohár pali@kernel.org Reviewed-by: Stefan Roese sr@denx.de
--- Changes in v3: * Compile fix (move another code chunk from patch 2/2 to 1/2)
Changes in v2: * Compile fix (move code chunk from patch 2/2 to 1/2) --- cmd/mvebu/bubt.c | 46 +++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 45 insertions(+), 1 deletion(-)
diff --git a/cmd/mvebu/bubt.c b/cmd/mvebu/bubt.c index 2136af64163c..a97e5ce38a5e 100644 --- a/cmd/mvebu/bubt.c +++ b/cmd/mvebu/bubt.c @@ -688,9 +688,25 @@ static uint8_t image_checksum8(const void *start, size_t len) return csum; }
+static uint32_t image_checksum32(const void *start, size_t len) +{ + u32 csum = 0; + const u32 *p = start; + + while (len) { + csum += *p; + ++p; + len -= sizeof(u32); + } + + return csum; +} + static int check_image_header(void) { u8 checksum; + u32 checksum32, exp_checksum32; + u32 offset, size; const struct a38x_main_hdr_v1 *hdr = (struct a38x_main_hdr_v1 *)get_load_addr(); const size_t image_size = a38x_header_size(hdr); @@ -701,11 +717,39 @@ static int check_image_header(void) checksum = image_checksum8(hdr, image_size); checksum -= hdr->checksum; if (checksum != hdr->checksum) { - printf("Error: Bad A38x image checksum. 0x%x != 0x%x\n", + printf("Error: Bad A38x image header checksum. 0x%x != 0x%x\n", checksum, hdr->checksum); return -ENOEXEC; }
--- Changes in v3: * Guard fuse_read_u64() function
Changes in v2: * Add missing dependency on MVEBU_EFUSE * Use only for A38x and A37xx --- cmd/mvebu/Kconfig | 1 + cmd/mvebu/bubt.c | 128 +++++++++++++++++++++++++++++++++++++++++++--- 2 files changed, 121 insertions(+), 8 deletions(-)
diff --git a/cmd/mvebu/Kconfig b/cmd/mvebu/Kconfig index 120397d6d4d0..9ec3aa983a51 100644 --- a/cmd/mvebu/Kconfig +++ b/cmd/mvebu/Kconfig @@ -5,6 +5,7 @@ config CMD_MVEBU_BUBT bool "bubt" select SHA256 if ARMADA_3700 select SHA512 if ARMADA_3700 + select MVEBU_EFUSE if ARMADA_38X || ARMADA_3700 help bubt - Burn a u-boot image to flash For details about bubt command please see the documentation diff --git a/cmd/mvebu/bubt.c b/cmd/mvebu/bubt.c index a97e5ce38a5e..7e6e47f40d6e 100644 --- a/cmd/mvebu/bubt.c +++ b/cmd/mvebu/bubt.c @@ -13,6 +13,8 @@ #include <vsprintf.h> #include <errno.h> #include <dm.h> +#include <fuse.h> +#include <mach/efuse.h>
+/* + * Header for the optional headers, version 1 (Armada 370/XP/375/38x/39x) + */ +struct a38x_opt_hdr_v1 { + u8 headertype; + u8 headersz_msb; + u16 headersz_lsb; + u8 data[0]; +}; +#define A38X_OPT_HDR_V1_SECURE_TYPE 0x1 + struct a38x_boot_mode { unsigned int id; const char *name; @@ -753,6 +766,38 @@ static int check_image_header(void) printf("Image checksum...OK!\n"); return 0; } + +#if defined(CONFIG_ARMADA_38X) +static int a38x_image_is_secure(const struct a38x_main_hdr_v1 *hdr) +{ + u32 image_size = a38x_header_size(hdr); + struct a38x_opt_hdr_v1 *ohdr; + u32 ohdr_size; + + if (hdr->version != 1) + return 0; + + if (!hdr->ext) + return 0; + + ohdr = (struct a38x_opt_hdr_v1 *)(hdr + 1); + do { + if (ohdr->headertype == A38X_OPT_HDR_V1_SECURE_TYPE) + return 1; + + ohdr_size = (ohdr->headersz_msb << 16) | le16_to_cpu(ohdr->headersz_lsb); + + if (!*((u8 *)ohdr + ohdr_size - 4)) + break; + + ohdr = (struct a38x_opt_hdr_v1 *)((u8 *)ohdr + ohdr_size); + if ((u8 *)ohdr >= (u8 *)hdr + image_size) + break; + } while (1); + + return 0; +} +#endif #else /* Not ARMADA? */ static int check_image_header(void) { @@ -761,20 +806,60 @@ static int check_image_header(void) } #endif
+#if defined(CONFIG_ARMADA_3700) || defined(CONFIG_ARMADA_32BIT) +static u64 fuse_read_u64(u32 bank) +{ + u32 val[2]; + int ret; + + ret = fuse_read(bank, 0, &val[0]); + if (ret < 0) + return -1; + + ret = fuse_read(bank, 1, &val[1]); + if (ret < 0) + return -1; + + return ((u64)val[1] << 32) | val[0]; +} +#endif + +#if defined(CONFIG_ARMADA_3700) +static inline u8 maj3(u8 val) +{ + /* return majority vote of 3 bits */ + return ((val & 0x7) == 3 || (val & 0x7) > 4) ? 1 : 0; +} +#endif + static int bubt_check_boot_mode(const struct bubt_dev *dst) { #if defined(CONFIG_ARMADA_3700) || defined(CONFIG_ARMADA_32BIT) - int mode; + int mode, secure_mode; #if defined(CONFIG_ARMADA_3700) const struct tim_boot_flash_sign *boot_modes = tim_boot_flash_signs; const struct common_tim_data *hdr = (struct common_tim_data *)get_load_addr(); u32 id = hdr->boot_flash_sign; + int is_secure = hdr->trusted != 0; + u64 otp_secure_bits = fuse_read_u64(1); + int otp_secure_boot = ((maj3(otp_secure_bits >> 0) << 0) | + (maj3(otp_secure_bits >> 4) << 1)) == 2; + unsigned int otp_boot_device = (maj3(otp_secure_bits >> 48) << 0) | + (maj3(otp_secure_bits >> 52) << 1) | + (maj3(otp_secure_bits >> 56) << 2) | + (maj3(otp_secure_bits >> 60) << 3); #elif defined(CONFIG_ARMADA_32BIT) const struct a38x_boot_mode *boot_modes = a38x_boot_modes; const struct a38x_main_hdr_v1 *hdr = (struct a38x_main_hdr_v1 *)get_load_addr(); u32 id = hdr->blockid; +#if defined(CONFIG_ARMADA_38X) + int is_secure = a38x_image_is_secure(hdr); + u64 otp_secure_bits = fuse_read_u64(EFUSE_LINE_SECURE_BOOT); + int otp_secure_boot = otp_secure_bits & 0x1; + unsigned int otp_boot_device = (otp_secure_bits >> 8) & 0x7; +#endif #endif
for (mode = 0; boot_modes[mode].name; mode++) { @@ -787,15 +872,42 @@ static int bubt_check_boot_mode(const struct bubt_dev *dst) return -ENOEXEC; }
Applied to u-boot-marvell/master
Thanks, Stefan
Changes in v3:
- Guard fuse_read_u64() function
Changes in v2:
- u8 headertype;
- u8 headersz_msb;
- u16 headersz_lsb;
- u8 data[0];
- u32 ohdr_size;
- if (!hdr->ext)
- do {
return 1;
break;
break;
- } while (1);
- u32 val[2];
- int ret;
- if (ret < 0)
return -1;
- if (ret < 0)
return -1;
+} +#endif
+} +#endif
- int mode;
+#endif #endif
return -ENOEXEC;
- return -ENOEXEC;
-#else
return -ENOEXEC;
- } else {
return -ENOEXEC;
break;
return -ENOEXEC;
+#endif +#endif
return 0; }
Changes in v3:
- Compile fix (move another code chunk from patch 2/2 to 1/2)
Changes in v2:
Hello Stefan! Is V3 version OK now?
- u32 csum = 0;
- while (len) {
csum += *p;
++p;
len -= sizeof(u32);
- return csum;
return -ENOEXEC; }
if (offset < 1) {
return -ENOEXEC;
offset -= 1;
offset *= 512;
offset *= 512;
return -ENOEXEC;
return -ENOEXEC;
2.20.1
Changes in v3:
Changes in v2:
Looks good.
Thanks, Stefan
- u32 csum = 0;
- while (len) {
csum += *p;
++p;
len -= sizeof(u32);
- return csum;
return -ENOEXEC; }
if (offset < 1) {
return -ENOEXEC;
offset -= 1;
offset *= 512;
offset *= 512;
return -ENOEXEC;
return -ENOEXEC;
-- 2.20.1
Thanks, Stefan
Changes in v3:
Changes in v2:
- u32 csum = 0;
- while (len) {
csum += *p;
++p;
len -= sizeof(u32);
- return csum;
return -ENOEXEC; }
if (offset < 1) {
return -ENOEXEC;
offset -= 1;
offset *= 512;
offset *= 512;
return -ENOEXEC;
return -ENOEXEC;
Pali Rohár
Stefan Roese
