[U-Boot] [PATCH v2 2/2] arm: rmobile: Add support koelsch board
The koelsch board has R8A7791, 2GB DDR3-SDRAM, USB, Quad SPI, Ethernet, and more.
This patch supports the following functions: - DDR3-SDRAM - SCIF
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com Signed-off-by: Hisashi Nakamura hisashi.nakamura.ak@renesas.com CC: Nobuhiro Iwamatsu iwamatsu@nigauri.org CC: Albert Aribaud albert.u.boot@aribaud.net --- Note: This requires latest commit of u-boot/master.
v2: Remove config of QSPI and Ethernet.
board/renesas/koelsch/Makefile | 34 +++++ board/renesas/koelsch/koelsch.c | 283 ++++++++++++++++++++++++++++++++++++++++ board/renesas/koelsch/qos.c | 148 +++++++++++++++++++++ board/renesas/koelsch/qos.h | 12 ++ boards.cfg | 2 + include/configs/koelsch.h | 134 +++++++++++++++++++ 6 files changed, 613 insertions(+) create mode 100644 board/renesas/koelsch/Makefile create mode 100644 board/renesas/koelsch/koelsch.c create mode 100644 board/renesas/koelsch/qos.c create mode 100644 board/renesas/koelsch/qos.h create mode 100644 include/configs/koelsch.h
diff --git a/board/renesas/koelsch/Makefile b/board/renesas/koelsch/Makefile new file mode 100644 index 0000000..e0efbc4 --- /dev/null +++ b/board/renesas/koelsch/Makefile @@ -0,0 +1,34 @@ +# +# board/renesas/koelsch/Makefile +# +# Copyright (C) 2013 Renesas Electronics Corporation +# +# SPDX-License-Identifier: GPL-2.0 +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := koelsch.o qos.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/renesas/koelsch/koelsch.c b/board/renesas/koelsch/koelsch.c new file mode 100644 index 0000000..7153f65 --- /dev/null +++ b/board/renesas/koelsch/koelsch.c @@ -0,0 +1,283 @@ +/* + * board/renesas/koelsch/koelsch.c + * + * Copyright (C) 2013 Renesas Electronics Corporation + * + * SPDX-License-Identifier: GPL-2.0 + * + */ + +#include <common.h> +#include <malloc.h> +#include <asm/processor.h> +#include <asm/mach-types.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/arch/rmobile.h> +#include <i2c.h> +#include "qos.h" + +DECLARE_GLOBAL_DATA_PTR; + +#define s_init_wait(cnt) \ + ({ \ + u32 i = 0x10000 * cnt; \ + while (i > 0) \ + i--; \ + }) + + +#define dbpdrgd_check(bsc) \ + ({ \ + while ((readl(&bsc->dbpdrgd) & 0x1) != 0x1) \ + ; \ + }) + +#if defined(CONFIG_NORFLASH) +static void bsc_init(void) +{ + struct r8a7791_lbsc *lbsc = (struct r8a7791_lbsc *)LBSC_BASE; + struct r8a7791_dbsc3 *dbsc3_0 = (struct r8a7791_dbsc3 *)DBSC3_0_BASE; + + /* LBSC */ + writel(0x00000020, &lbsc->cs0ctrl); + writel(0x00000020, &lbsc->cs1ctrl); + writel(0x00002020, &lbsc->ecs0ctrl); + writel(0x00002020, &lbsc->ecs1ctrl); + + writel(0x077F077F, &lbsc->cswcr0); + writel(0x077F077F, &lbsc->cswcr1); + writel(0x077F077F, &lbsc->ecswcr0); + writel(0x077F077F, &lbsc->ecswcr1); + + /* DBSC3 */ + s_init_wait(10); + + writel(0x0000A55A, &dbsc3_0->dbpdlck); + writel(0x00000001, &dbsc3_0->dbpdrga); + writel(0x80000000, &dbsc3_0->dbpdrgd); + writel(0x00000004, &dbsc3_0->dbpdrga); + dbpdrgd_check(dbsc3_0); + + writel(0x00000006, &dbsc3_0->dbpdrga); + writel(0x0001C000, &dbsc3_0->dbpdrgd); + + writel(0x00000023, &dbsc3_0->dbpdrga); + writel(0x00FD2480, &dbsc3_0->dbpdrgd); + + writel(0x00000010, &dbsc3_0->dbpdrga); + writel(0xF004649B, &dbsc3_0->dbpdrgd); + + writel(0x0000000F, &dbsc3_0->dbpdrga); + writel(0x00181EE4, &dbsc3_0->dbpdrgd); + + writel(0x0000000E, &dbsc3_0->dbpdrga); + writel(0x33C03812, &dbsc3_0->dbpdrgd); + + writel(0x00000003, &dbsc3_0->dbpdrga); + writel(0x0300C481, &dbsc3_0->dbpdrgd); + + writel(0x00000007, &dbsc3_0->dbkind); + writel(0x10030A02, &dbsc3_0->dbconf0); + writel(0x00000001, &dbsc3_0->dbphytype); + writel(0x00000000, &dbsc3_0->dbbl); + writel(0x0000000B, &dbsc3_0->dbtr0); + writel(0x00000008, &dbsc3_0->dbtr1); + writel(0x00000000, &dbsc3_0->dbtr2); + writel(0x0000000B, &dbsc3_0->dbtr3); + writel(0x000C000B, &dbsc3_0->dbtr4); + writel(0x00000027, &dbsc3_0->dbtr5); + writel(0x0000001C, &dbsc3_0->dbtr6); + writel(0x00000005, &dbsc3_0->dbtr7); + writel(0x00000018, &dbsc3_0->dbtr8); + writel(0x00000008, &dbsc3_0->dbtr9); + writel(0x0000000C, &dbsc3_0->dbtr10); + writel(0x00000009, &dbsc3_0->dbtr11); + writel(0x00000012, &dbsc3_0->dbtr12); + writel(0x000000D0, &dbsc3_0->dbtr13); + writel(0x00140005, &dbsc3_0->dbtr14); + writel(0x00050004, &dbsc3_0->dbtr15); + writel(0x70233005, &dbsc3_0->dbtr16); + writel(0x000C0000, &dbsc3_0->dbtr17); + writel(0x00000300, &dbsc3_0->dbtr18); + writel(0x00000040, &dbsc3_0->dbtr19); + writel(0x00000001, &dbsc3_0->dbrnk0); + writel(0x00020001, &dbsc3_0->dbadj0); + writel(0x20082008, &dbsc3_0->dbadj2); + writel(0x00020002, &dbsc3_0->dbwt0cnf0); + writel(0x0000000F, &dbsc3_0->dbwt0cnf4); + + writel(0x00000015, &dbsc3_0->dbpdrga); + writel(0x00000D70, &dbsc3_0->dbpdrgd); + + writel(0x00000016, &dbsc3_0->dbpdrga); + writel(0x00000006, &dbsc3_0->dbpdrgd); + + writel(0x00000017, &dbsc3_0->dbpdrga); + writel(0x00000018, &dbsc3_0->dbpdrgd); + + writel(0x00000012, &dbsc3_0->dbpdrga); + writel(0x9D5CBB66, &dbsc3_0->dbpdrgd); + + writel(0x00000013, &dbsc3_0->dbpdrga); + writel(0x1A868300, &dbsc3_0->dbpdrgd); + + writel(0x00000023, &dbsc3_0->dbpdrga); + writel(0x00FDB6C0, &dbsc3_0->dbpdrgd); + + writel(0x00000014, &dbsc3_0->dbpdrga); + writel(0x300214D8, &dbsc3_0->dbpdrgd); + + writel(0x0000001A, &dbsc3_0->dbpdrga); + writel(0x930035C7, &dbsc3_0->dbpdrgd); + + writel(0x00000060, &dbsc3_0->dbpdrga); + writel(0x330657B2, &dbsc3_0->dbpdrgd); + + writel(0x00000011, &dbsc3_0->dbpdrga); + writel(0x1000040B, &dbsc3_0->dbpdrgd); + + writel(0x0000FA00, &dbsc3_0->dbcmd); + writel(0x00000001, &dbsc3_0->dbpdrga); + writel(0x00000071, &dbsc3_0->dbpdrgd); + + writel(0x00000004, &dbsc3_0->dbpdrga); + dbpdrgd_check(dbsc3_0); + + writel(0x0000FA00, &dbsc3_0->dbcmd); + writel(0x2100FA00, &dbsc3_0->dbcmd); + writel(0x0000FA00, &dbsc3_0->dbcmd); + writel(0x0000FA00, &dbsc3_0->dbcmd); + writel(0x0000FA00, &dbsc3_0->dbcmd); + writel(0x0000FA00, &dbsc3_0->dbcmd); + writel(0x0000FA00, &dbsc3_0->dbcmd); + writel(0x0000FA00, &dbsc3_0->dbcmd); + writel(0x0000FA00, &dbsc3_0->dbcmd); + + writel(0x110000DB, &dbsc3_0->dbcmd); + + writel(0x00000001, &dbsc3_0->dbpdrga); + writel(0x00000181, &dbsc3_0->dbpdrgd); + + writel(0x00000004, &dbsc3_0->dbpdrga); + dbpdrgd_check(dbsc3_0); + + writel(0x00000001, &dbsc3_0->dbpdrga); + writel(0x0000FE01, &dbsc3_0->dbpdrgd); + + writel(0x00000004, &dbsc3_0->dbpdrga); + dbpdrgd_check(dbsc3_0); + + writel(0x00000000, &dbsc3_0->dbbs0cnt1); + writel(0x01004C20, &dbsc3_0->dbcalcnf); + writel(0x014000AA, &dbsc3_0->dbcaltr); + writel(0x00000140, &dbsc3_0->dbrfcnf0); + writel(0x00081860, &dbsc3_0->dbrfcnf1); + writel(0x00010000, &dbsc3_0->dbrfcnf2); + writel(0x00000001, &dbsc3_0->dbrfen); + writel(0x00000001, &dbsc3_0->dbacen); +} +#else +#define bsc_init() do {} while (0) +#endif /* CONFIG_NORFLASH */ + +void s_init(void) +{ + struct r8a7791_rwdt *rwdt = (struct r8a7791_rwdt *)RWDT_BASE; + struct r8a7791_swdt *swdt = (struct r8a7791_swdt *)SWDT_BASE; + + /* Watchdog init */ + writel(0xA5A5A500, &rwdt->rwtcsra); + writel(0xA5A5A500, &swdt->swtcsra); + + /* QoS */ + qos_init(); + + /* BSC */ + bsc_init(); +} + +#define MSTPSR1 0xE6150038 +#define SMSTPCR1 0xE6150134 +#define TMU0_MSTP125 (1 << 25) + +#define MSTPSR7 0xE61501C4 +#define SMSTPCR7 0xE615014C +#define SCIF0_MSTP721 (1 << 21) + +#define PMMR 0xE6060000 +#define GPSR4 0xE6060014 +#define IPSR14 0xE6060058 + +#define set_guard_reg(addr, mask, value) \ +{ \ + u32 val; \ + val = (readl(addr) & ~(mask)) | (value); \ + writel(~val, PMMR); \ + writel(val, addr); \ +} + +#define mstp_setbits(type, addr, saddr, set) \ + out_##type((saddr), in_##type(addr) | (set)) +#define mstp_clrbits(type, addr, saddr, clear) \ + out_##type((saddr), in_##type(addr) & ~(clear)) +#define mstp_setbits_le32(addr, saddr, set) \ + mstp_setbits(le32, addr, saddr, set) +#define mstp_clrbits_le32(addr, saddr, clear) \ + mstp_clrbits(le32, addr, saddr, clear) + +int board_early_init_f(void) +{ + mstp_clrbits_le32(MSTPSR1, SMSTPCR1, TMU0_MSTP125); + +#if defined(CONFIG_NORFLASH) + /* SCIF0 */ + set_guard_reg(GPSR4, 0x34000000, 0x00000000); + set_guard_reg(IPSR14, 0x00000FC7, 0x00000481); + set_guard_reg(GPSR4, 0x00000000, 0x34000000); +#endif + + mstp_clrbits_le32(MSTPSR7, SMSTPCR7, SCIF0_MSTP721); + + return 0; +} + +int board_init(void) +{ + /* adress of boot parameters */ + gd->bd->bi_boot_params = KOELSCH_SDRAM_BASE + 0x100; + + /* Init PFC controller */ + r8a7791_pinmux_init(); + + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + gd->ram_size = CONFIG_SYS_SDRAM_SIZE; + + return 0; +} + +const struct rmobile_sysinfo sysinfo = { + CONFIG_RMOBILE_BOARD_STRING +}; + +void dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = KOELSCH_SDRAM_BASE; + gd->bd->bi_dram[0].size = KOELSCH_SDRAM_SIZE; +} + +int board_late_init(void) +{ + return 0; +} + +void reset_cpu(ulong addr) +{ +} diff --git a/board/renesas/koelsch/qos.c b/board/renesas/koelsch/qos.c new file mode 100644 index 0000000..88b33c6 --- /dev/null +++ b/board/renesas/koelsch/qos.c @@ -0,0 +1,148 @@ +/* + * board/renesas/koelsch/qos.c + * + * Copyright (C) 2013 Renesas Electronics Corporation + * + * SPDX-License-Identifier: GPL-2.0 + * + */ + +#include <common.h> +#include <asm/processor.h> +#include <asm/mach-types.h> +#include <asm/io.h> +#include <asm/arch/rmobile.h> + +enum { + DBSC3_R00, DBSC3_R01, DBSC3_R02, DBSC3_R03, DBSC3_R04, + DBSC3_R05, DBSC3_R06, DBSC3_R07, DBSC3_R08, DBSC3_R09, + DBSC3_R10, DBSC3_R11, DBSC3_R12, DBSC3_R13, DBSC3_R14, + DBSC3_R15, + DBSC3_W00, DBSC3_W01, DBSC3_W02, DBSC3_W03, DBSC3_W04, + DBSC3_W05, DBSC3_W06, DBSC3_W07, DBSC3_W08, DBSC3_W09, + DBSC3_W10, DBSC3_W11, DBSC3_W12, DBSC3_W13, DBSC3_W14, + DBSC3_W15, + DBSC3_NR, +}; + +static u32 dbsc3_qos_addr[DBSC3_NR] = { + [DBSC3_R00] = DBSC3_0_QOS_R0_BASE, + [DBSC3_R01] = DBSC3_0_QOS_R1_BASE, + [DBSC3_R02] = DBSC3_0_QOS_R2_BASE, + [DBSC3_R03] = DBSC3_0_QOS_R3_BASE, + [DBSC3_R04] = DBSC3_0_QOS_R4_BASE, + [DBSC3_R05] = DBSC3_0_QOS_R5_BASE, + [DBSC3_R06] = DBSC3_0_QOS_R6_BASE, + [DBSC3_R07] = DBSC3_0_QOS_R7_BASE, + [DBSC3_R08] = DBSC3_0_QOS_R8_BASE, + [DBSC3_R09] = DBSC3_0_QOS_R9_BASE, + [DBSC3_R10] = DBSC3_0_QOS_R10_BASE, + [DBSC3_R11] = DBSC3_0_QOS_R11_BASE, + [DBSC3_R12] = DBSC3_0_QOS_R12_BASE, + [DBSC3_R13] = DBSC3_0_QOS_R13_BASE, + [DBSC3_R14] = DBSC3_0_QOS_R14_BASE, + [DBSC3_R15] = DBSC3_0_QOS_R15_BASE, + [DBSC3_W00] = DBSC3_0_QOS_W0_BASE, + [DBSC3_W01] = DBSC3_0_QOS_W1_BASE, + [DBSC3_W02] = DBSC3_0_QOS_R2_BASE, + [DBSC3_W03] = DBSC3_0_QOS_R3_BASE, + [DBSC3_W04] = DBSC3_0_QOS_R4_BASE, + [DBSC3_W05] = DBSC3_0_QOS_R5_BASE, + [DBSC3_W06] = DBSC3_0_QOS_R6_BASE, + [DBSC3_W07] = DBSC3_0_QOS_R7_BASE, + [DBSC3_W08] = DBSC3_0_QOS_R8_BASE, + [DBSC3_W09] = DBSC3_0_QOS_R9_BASE, + [DBSC3_W10] = DBSC3_0_QOS_W10_BASE, + [DBSC3_W11] = DBSC3_0_QOS_W11_BASE, + [DBSC3_W12] = DBSC3_0_QOS_W12_BASE, + [DBSC3_W13] = DBSC3_0_QOS_W13_BASE, + [DBSC3_W14] = DBSC3_0_QOS_W14_BASE, + [DBSC3_W15] = DBSC3_0_QOS_W15_BASE, +}; + +void qos_init(void) +{ + int i; + struct r8a7791_s3c *s3c; + struct r8a7791_s3c_qos *s3c_qos; + struct r8a7791_dbsc3_qos *qos_addr; + struct r8a7791_mxi *mxi; + + /* S3C -QoS */ + s3c = (struct r8a7791_s3c *)S3C_BASE; + writel(0x00000000, &s3c->s3cadsplcr); + writel(0x1F1F0C0C, &s3c->s3crorr); + writel(0x1F1F0C0C, &s3c->s3cworr); + + /* QoS Control Registers */ + s3c_qos = (struct r8a7791_s3c_qos *)S3C_QOS_CCI0_BASE; + writel(0x00810081, &s3c_qos->s3cqos0); + writel(0x20410001, &s3c_qos->s3cqos1); + writel(0x200A2023, &s3c_qos->s3cqos2); + writel(0x205020E2, &s3c_qos->s3cqos3); + writel(0x20142032, &s3c_qos->s3cqos4); + writel(0x20410001, &s3c_qos->s3cqos5); + writel(0x200A2023, &s3c_qos->s3cqos6); + writel(0x205020E2, &s3c_qos->s3cqos7); + writel(0x20142032, &s3c_qos->s3cqos8); + + s3c_qos = (struct r8a7791_s3c_qos *)S3C_QOS_CCI1_BASE; + writel(0x00810081, &s3c_qos->s3cqos0); + writel(0x20410001, &s3c_qos->s3cqos1); + writel(0x200A2023, &s3c_qos->s3cqos2); + writel(0x205020E2, &s3c_qos->s3cqos3); + writel(0x20142032, &s3c_qos->s3cqos4); + writel(0x20410001, &s3c_qos->s3cqos5); + writel(0x200A2023, &s3c_qos->s3cqos6); + writel(0x205020E2, &s3c_qos->s3cqos7); + writel(0x20142032, &s3c_qos->s3cqos8); + + s3c_qos = (struct r8a7791_s3c_qos *)S3C_QOS_MXI_BASE; + writel(0x00820082, &s3c_qos->s3cqos0); + writel(0x20410001, &s3c_qos->s3cqos1); + writel(0x200A2023, &s3c_qos->s3cqos2); + writel(0x2050205F, &s3c_qos->s3cqos3); + writel(0x20142032, &s3c_qos->s3cqos4); + writel(0x20410001, &s3c_qos->s3cqos5); + writel(0x200A2023, &s3c_qos->s3cqos6); + writel(0x2050205F, &s3c_qos->s3cqos7); + writel(0x20142032, &s3c_qos->s3cqos8); + + s3c_qos = (struct r8a7791_s3c_qos *)S3C_QOS_AXI_BASE; + writel(0x00820082, &s3c_qos->s3cqos0); + writel(0x20410001, &s3c_qos->s3cqos1); + writel(0x200A2023, &s3c_qos->s3cqos2); + writel(0x2050205F, &s3c_qos->s3cqos3); + writel(0x20142032, &s3c_qos->s3cqos4); + writel(0x20410001, &s3c_qos->s3cqos5); + writel(0x200A2023, &s3c_qos->s3cqos6); + writel(0x2050205F, &s3c_qos->s3cqos7); + writel(0x20142032, &s3c_qos->s3cqos8); + + /* DBSC -QoS */ + /* DBSC0 - Read/Write */ + for (i = DBSC3_R00; i < DBSC3_NR; i++) { + qos_addr = (struct r8a7791_dbsc3_qos *)dbsc3_qos_addr[i]; + writel(0x00000000, &qos_addr->dblgcnt); + writel(0x00002064, &qos_addr->dbtmval0); + writel(0x00002048, &qos_addr->dbtmval1); + writel(0x00002032, &qos_addr->dbtmval2); + writel(0x00002019, &qos_addr->dbtmval3); + writel(0x00000001, &qos_addr->dbrqctr); + writel(0x00002019, &qos_addr->dbthres0); + writel(0x00002019, &qos_addr->dbthres1); + writel(0x00002019, &qos_addr->dbthres2); + writel(0x00000001, &qos_addr->dblgqon); + } + /* CCI-400 -OoS */ + writel(0x20001000, CCI_400_MAXOT_1); + writel(0x20001000, CCI_400_MAXOT_2); + writel(0x0000000C, CCI_400_QOSCNTL_1); + writel(0x0000000C, CCI_400_QOSCNTL_2); + + /* MXI -OoS */ + /* Transaction Control (MXI) */ + mxi = (struct r8a7791_mxi *)MXI_BASE; + writel(0x00000013, &mxi->mxrtcr); + writel(0x00000013, &mxi->mxrtcr); +} diff --git a/board/renesas/koelsch/qos.h b/board/renesas/koelsch/qos.h new file mode 100644 index 0000000..9a6c046 --- /dev/null +++ b/board/renesas/koelsch/qos.h @@ -0,0 +1,12 @@ +/* + * Copyright (C) 2013 Renesas Electronics Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __QOS_H__ +#define __QOS_H__ + +void qos_init(void); + +#endif diff --git a/boards.cfg b/boards.cfg index f5c1140..795e68d 100644 --- a/boards.cfg +++ b/boards.cfg @@ -339,6 +339,8 @@ Active arm armv7 rmobile atmark-techno armadillo-800eva Active arm armv7 rmobile kmc kzm9g kzm9g - Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com:Tetsuyuki Kobayashi koba@kmckk.co.jp Active arm armv7 rmobile renesas lager lager - Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com Active arm armv7 rmobile renesas lager lager_nor lager:NORFLASH Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com +Active arm armv7 rmobile renesas koelsch koelsch - Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com +Active arm armv7 rmobile renesas koelsch koelsch_nor koelsch:NORFLASH Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com Active arm armv7 s5pc1xx samsung goni s5p_goni - Minkyu Kang mk7.kang@samsung.com Active arm armv7 s5pc1xx samsung smdkc100 smdkc100 - Minkyu Kang mk7.kang@samsung.com Active arm armv7 socfpga altera socfpga socfpga_cyclone5 - - diff --git a/include/configs/koelsch.h b/include/configs/koelsch.h new file mode 100644 index 0000000..c2aca8f --- /dev/null +++ b/include/configs/koelsch.h @@ -0,0 +1,134 @@ +/* + * include/configs/koelsch.h + * + * Copyright (C) 2013 Renesas Electronics Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __KOELSCH_H +#define __KOELSCH_H + +#undef DEBUG +#define CONFIG_ARMV7 +#define CONFIG_R8A7791 +#define CONFIG_RMOBILE +#define CONFIG_RMOBILE_BOARD_STRING "Koelsch" +#define CONFIG_SH_GPIO_PFC + +#include <asm/arch/rmobile.h> + +#define CONFIG_CMD_EDITENV +#define CONFIG_CMD_SAVEENV +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_DFL +#define CONFIG_CMD_SDRAM +#define CONFIG_CMD_RUN +#define CONFIG_CMD_LOADS +#define CONFIG_CMD_BOOTZ +#define CONFIG_CMD_FLASH + +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_CMDLINE_EDITING + +#define CONFIG_OF_LIBFDT +#define BOARD_LATE_INIT + +#define CONFIG_BAUDRATE 38400 +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTARGS "" + +#define CONFIG_VERSION_VARIABLE +#undef CONFIG_SHOW_BOOT_PROGRESS + +#define CONFIG_ARCH_CPU_INIT +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_USE_ARCH_MEMSET +#define CONFIG_USE_ARCH_MEMCPY +#define CONFIG_TMU_TIMER + +/* STACK */ +#define CONFIG_SYS_INIT_SP_ADDR 0xE633fffc +#define STACK_AREA_SIZE 0xC000 +#define LOW_LEVEL_MERAM_STACK \ + (CONFIG_SYS_INIT_SP_ADDR + STACK_AREA_SIZE - 4) + +/* MEMORY */ +#define KOELSCH_SDRAM_BASE 0x40000000 +#define KOELSCH_SDRAM_SIZE (2048u * 1024 * 1024) +#define KOELSCH_UBOOT_SDRAM_SIZE (512 * 1024 * 1024) + +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_PROMPT "=> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE 512 +#define CONFIG_SYS_BAUDRATE_TABLE { 38400, 115200 } + +/* SCIF */ +#define CONFIG_SCIF_CONSOLE +#define CONFIG_CONS_SCIF0 +#define SCIF0_BASE 0xe6e60000 +#undef CONFIG_SYS_CONSOLE_INFO_QUIET +#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE +#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE + +#define CONFIG_SYS_MEMTEST_START (KOELSCH_SDRAM_BASE) +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ + 504 * 1024 * 1024) +#undef CONFIG_SYS_ALT_MEMTEST +#undef CONFIG_SYS_MEMTEST_SCRATCH +#undef CONFIG_SYS_LOADS_BAUD_CHANGE + +#define CONFIG_SYS_SDRAM_BASE (KOELSCH_SDRAM_BASE) +#define CONFIG_SYS_SDRAM_SIZE (KOELSCH_UBOOT_SDRAM_SIZE) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x7fc0) +#define CONFIG_NR_DRAM_BANKS 1 + +#define CONFIG_SYS_MONITOR_BASE 0x00000000 +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) +#define CONFIG_SYS_MALLOC_LEN (1 * 1024 * 1024) +#define CONFIG_SYS_GBL_DATA_SIZE (256) +#define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024) + +/* FLASH */ +#define CONFIG_SYS_TEXT_BASE 0x00000000 +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS +#define CONFIG_FLASH_SHOW_PROGRESS 45 +#define CONFIG_SYS_FLASH_BASE 0x00000000 +#define CONFIG_SYS_FLASH_SIZE 0x04000000 /* 64 MB */ +#define CONFIG_SYS_MAX_FLASH_SECT 1024 +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_FLASH_BANKS_LIST { (CONFIG_SYS_FLASH_BASE) } +#define CONFIG_SYS_FLASH_BANKS_SIZES { (CONFIG_SYS_FLASH_SIZE) } +#define CONFIG_SYS_FLASH_ERASE_TOUT 3000 +#define CONFIG_SYS_FLASH_WRITE_TOUT 3000 +#define CONFIG_SYS_FLASH_LOCK_TOUT 3000 +#define CONFIG_SYS_FLASH_UNLOCK_TOUT 3000 + +/* ENV setting */ +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_OVERWRITE 1 +#define CONFIG_ENV_SECT_SIZE (256 * 1024) +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + \ + CONFIG_SYS_MONITOR_LEN) +#define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) +#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND (CONFIG_SYS_MONITOR_LEN) + +/* Board Clock */ +#define CONFIG_SYS_CLK_FREQ 10000000 +#define CONFIG_SH_TMU_CLK_FREQ CONFIG_SYS_CLK_FREQ +#define CONFIG_SH_SCIF_CLK_FREQ 14745600 +#define CONFIG_SYS_TMU_CLK_DIV 4 +#define CONFIG_SYS_HZ 1000 + +#endif /* __KOELSCH_H */
Nobuhiro Iwamatsu
