[U-Boot] [PATCH v7 0/4] Board support series for the eXMeritus HWW-1U-1A
This is the final respin of the eXMeritus HWW-1U-1A board support patches, rebased onto the 'next' branch of git://git.denx.de/u-boot-mpc85xx.git
This code conforms to the Linux kernel coding style. It passes checkpatch with only a few false positives.
I believe these 4 patches are ready to be merged.
Cheers, Kyle Moffett
The numeric constants in the switch statements are replaced by #defines added to the common ddr_spd.h header. This dramatically improves the readability of the switch statments.
In addition, a few of the longer lines were cleaned up, and the DDR2 type for an SO-RDIMM module was added to the DDR2 switch statement.
Signed-off-by: Kyle Moffett Kyle.D.Moffett@boeing.com Cc: Andy Fleming afleming@gmail.com Cc: Kumar Gala kumar.gala@freescale.com Cc: Kim Phillips kim.phillips@freescale.com
-- Changelog: v2: Moved the constants to include/ddr_spd.h and also fixed DDR3 v4: Fixed up excessively long lines v6: Rebased onto the 'next' branch of git://git.denx.de/u-boot-mpc85xx.git
arch/powerpc/cpu/mpc8xxx/ddr/ddr2_dimm_params.c | 23 +++++++----- arch/powerpc/cpu/mpc8xxx/ddr/ddr3_dimm_params.c | 43 ++++++++++------------ common/ddr_spd.c | 2 +- include/ddr_spd.h | 28 ++++++++++----- 4 files changed, 53 insertions(+), 43 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/ddr2_dimm_params.c b/arch/powerpc/cpu/mpc8xxx/ddr/ddr2_dimm_params.c index dcb37ce..b565e33 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/ddr2_dimm_params.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/ddr2_dimm_params.c @@ -250,24 +250,27 @@ ddr_compute_dimm_parameters(const ddr2_spd_eeprom_t *spd, pdimm->primary_sdram_width = spd->primw; pdimm->ec_sdram_width = spd->ecw;
- /* FIXME: what about registered SO-DIMM? */ + /* These are all the types defined by the JEDEC DDR2 SPD 1.3 spec */ switch (spd->dimm_type) { - case 0x01: /* RDIMM */ - case 0x10: /* Mini-RDIMM */ - pdimm->registered_dimm = 1; /* register buffered */ + case DDR2_SPD_DIMMTYPE_RDIMM: + case DDR2_SPD_DIMMTYPE_72B_SO_RDIMM: + case DDR2_SPD_DIMMTYPE_MINI_RDIMM: + /* Registered/buffered DIMMs */ + pdimm->registered_dimm = 1; break;
- case 0x02: /* UDIMM */ - case 0x04: /* SO-DIMM */ - case 0x08: /* Micro-DIMM */ - case 0x20: /* Mini-UDIMM */ - pdimm->registered_dimm = 0; /* unbuffered */ + case DDR2_SPD_DIMMTYPE_UDIMM: + case DDR2_SPD_DIMMTYPE_SO_DIMM: + case DDR2_SPD_DIMMTYPE_MICRO_DIMM: + case DDR2_SPD_DIMMTYPE_MINI_UDIMM: + /* Unbuffered DIMMs */ + pdimm->registered_dimm = 0; break;
+ case DDR2_SPD_DIMMTYPE_72B_SO_CDIMM: default: printf("unknown dimm_type 0x%02X\n", spd->dimm_type); return 1; - break; }
/* SDRAM device parameters */ diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/ddr3_dimm_params.c b/arch/powerpc/cpu/mpc8xxx/ddr/ddr3_dimm_params.c index 29cea53..756b15f 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/ddr3_dimm_params.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/ddr3_dimm_params.c @@ -128,24 +128,32 @@ ddr_compute_dimm_parameters(const ddr3_spd_eeprom_t *spd, pdimm->data_width = pdimm->primary_sdram_width + pdimm->ec_sdram_width;
- switch (spd->module_type & 0xf) { - case 0x01: /* RDIMM */ - case 0x05: /* Mini-RDIMM */ - pdimm->registered_dimm = 1; /* register buffered */ + /* These are the types defined by the JEDEC DDR3 SPD spec */ + pdimm->mirrored_dimm = 0; + pdimm->registered_dimm = 0; + switch (spd->module_type & DDR3_SPD_MODULETYPE_MASK) { + case DDR3_SPD_MODULETYPE_RDIMM: + case DDR3_SPD_MODULETYPE_MINI_RDIMM: + /* Registered/buffered DIMMs */ + pdimm->registered_dimm = 1; for (i = 0; i < 16; i += 2) { - pdimm->rcw[i] = spd->mod_section.registered.rcw[i/2] & 0x0F; - pdimm->rcw[i+1] = (spd->mod_section.registered.rcw[i/2] >> 4) & 0x0F; + u8 rcw = spd->mod_section.registered.rcw[i/2]; + pdimm->rcw[i] = (rcw >> 0) & 0x0F; + pdimm->rcw[i+1] = (rcw >> 4) & 0x0F; } break; - case 0x02: /* UDIMM */ - case 0x03: /* SO-DIMM */ - case 0x04: /* Micro-DIMM */ - case 0x06: /* Mini-UDIMM */ - pdimm->registered_dimm = 0; /* unbuffered */ + + case DDR3_SPD_MODULETYPE_UDIMM: + case DDR3_SPD_MODULETYPE_SO_DIMM: + case DDR3_SPD_MODULETYPE_MICRO_DIMM: + case DDR3_SPD_MODULETYPE_MINI_UDIMM: + /* Unbuffered DIMMs */ + if (spd->mod_section.unbuffered.addr_mapping & 0x1) + pdimm->mirrored_dimm = 1; break;
default: - printf("unknown dimm_type 0x%02X\n", spd->module_type); + printf("unknown module_type 0x%02X\n", spd->module_type); return 1; }
@@ -303,16 +311,5 @@ ddr_compute_dimm_parameters(const ddr3_spd_eeprom_t *spd, pdimm->tFAW_ps = (((spd->tFAW_msb & 0xf) << 8) | spd->tFAW_min) * mtb_ps;
- /* - * We need check the address mirror for unbuffered DIMM - * If SPD indicate the address map mirror, The DDR controller - * need care it. - */ - if ((spd->module_type == SPD_MODULETYPE_UDIMM) || - (spd->module_type == SPD_MODULETYPE_SODIMM) || - (spd->module_type == SPD_MODULETYPE_MICRODIMM) || - (spd->module_type == SPD_MODULETYPE_MINIUDIMM)) - pdimm->mirrored_dimm = spd->mod_section.unbuffered.addr_mapping & 0x1; - return 0; } diff --git a/common/ddr_spd.c b/common/ddr_spd.c index a7a30de..7a388bb 100644 --- a/common/ddr_spd.c +++ b/common/ddr_spd.c @@ -18,7 +18,7 @@ spd_check(const u8 *buf, u8 spd_rev, u8 spd_cksum)
/* * Check SPD revision supported - * Rev 1.2 or less supported by this code + * Rev 1.X or less supported by this code */ if (spd_rev >= 0x20) { printf("SPD revision %02X not supported by this code\n", diff --git a/include/ddr_spd.h b/include/ddr_spd.h index 710e528..e895d61 100644 --- a/include/ddr_spd.h +++ b/include/ddr_spd.h @@ -304,14 +304,24 @@ extern unsigned int ddr3_spd_check(const ddr3_spd_eeprom_t *spd); #define SPD_MEMTYPE_DDR2_FBDIMM_PROBE (0x0A) #define SPD_MEMTYPE_DDR3 (0x0B)
-/* - * Byte 3 Key Byte / Module Type for DDR3 SPD - */ -#define SPD_MODULETYPE_RDIMM (0x01) -#define SPD_MODULETYPE_UDIMM (0x02) -#define SPD_MODULETYPE_SODIMM (0x03) -#define SPD_MODULETYPE_MICRODIMM (0x04) -#define SPD_MODULETYPE_MINIRDIMM (0x05) -#define SPD_MODULETYPE_MINIUDIMM (0x06) +/* DIMM Type for DDR2 SPD (according to v1.3) */ +#define DDR2_SPD_DIMMTYPE_UNDEFINED (0x00) +#define DDR2_SPD_DIMMTYPE_RDIMM (0x01) +#define DDR2_SPD_DIMMTYPE_UDIMM (0x02) +#define DDR2_SPD_DIMMTYPE_SO_DIMM (0x04) +#define DDR2_SPD_DIMMTYPE_72B_SO_CDIMM (0x06) +#define DDR2_SPD_DIMMTYPE_72B_SO_RDIMM (0x07) +#define DDR2_SPD_DIMMTYPE_MICRO_DIMM (0x08) +#define DDR2_SPD_DIMMTYPE_MINI_RDIMM (0x10) +#define DDR2_SPD_DIMMTYPE_MINI_UDIMM (0x20) + +/* Byte 3 Key Byte / Module Type for DDR3 SPD */ +#define DDR3_SPD_MODULETYPE_MASK (0x0f) +#define DDR3_SPD_MODULETYPE_RDIMM (0x01) +#define DDR3_SPD_MODULETYPE_UDIMM (0x02) +#define DDR3_SPD_MODULETYPE_SO_DIMM (0x03) +#define DDR3_SPD_MODULETYPE_MICRO_DIMM (0x04) +#define DDR3_SPD_MODULETYPE_MINI_RDIMM (0x05) +#define DDR3_SPD_MODULETYPE_MINI_UDIMM (0x06)
#endif /* _DDR_SPD_H_ */
applied to 85xx next
- k
To ease the implementation of other MPC85xx board ports, several common GPIO helpers are added to <asm/mpc85xx_gpio.h>.
Since each of these compiles to no more than 4-5 instructions it would be very inefficient to call them out of line, therefore we put them entirely in the header file.
The HWW-1U-1A board port which these were written for strongly prefers to set multiple GPIOs as a single batch operation, so the API is designed around that basis.
To assist other board ports, a small set of wrappers are used which provides a standard gpio_request() interface around the MPC85xx-specific functions. This can be enabled with CONFIG_MPC85XX_GENERIC_GPIO.
Signed-off-by: Kyle Moffett Kyle.D.Moffett@boeing.com Cc: Andy Fleming afleming@gmail.com Cc: Kumar Gala kumar.gala@freescale.com Cc: Peter Tyser ptyser@xes-inc.com
-- Changelog: v2: Moved the inline functions to a non-board-specific header v3: Added generic Linux-standard GPIO wrappers v4: Improved comments and fixed minor bugs in the wrapper functions v6: Rebased onto the 'next' branch of git://git.denx.de/u-boot-mpc85xx.git
arch/powerpc/include/asm/mpc85xx_gpio.h | 120 +++++++++++++++++++++++++++++++ 1 files changed, 120 insertions(+), 0 deletions(-) create mode 100644 arch/powerpc/include/asm/mpc85xx_gpio.h
diff --git a/arch/powerpc/include/asm/mpc85xx_gpio.h b/arch/powerpc/include/asm/mpc85xx_gpio.h new file mode 100644 index 0000000..ad54b4e --- /dev/null +++ b/arch/powerpc/include/asm/mpc85xx_gpio.h @@ -0,0 +1,120 @@ +/* + * Copyright 2010 eXMeritus, A Boeing Company + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm/immap_85xx.h> + +/* + * The following internal functions are an MPC85XX-specific GPIO API which + * allows setting and querying multiple GPIOs in a single operation. + * + * All of these look relatively large, but the arguments are almost always + * constants, so they compile down to just a few instructions and a + * memory-mapped IO operation or two. + */ +static inline void mpc85xx_gpio_set(unsigned int mask, + unsigned int dir, unsigned int val) +{ + ccsr_gpio_t *gpio = (void *)(CONFIG_SYS_MPC85xx_GPIO_ADDR + 0xc00); + + /* First mask off the unwanted parts of "dir" and "val" */ + dir &= mask; + val &= mask; + + /* Now read in the values we're supposed to preserve */ + dir |= (in_be32(&gpio->gpdir) & ~mask); + val |= (in_be32(&gpio->gpdat) & ~mask); + + /* + * Poke the new output values first, then set the direction. This + * helps to avoid transient data when switching from input to output + * and vice versa. + */ + out_be32(&gpio->gpdat, val); + out_be32(&gpio->gpdir, dir); +} + +static inline void mpc85xx_gpio_set_in(unsigned int gpios) +{ + mpc85xx_gpio_set(gpios, 0x00000000, 0x00000000); +} + +static inline void mpc85xx_gpio_set_low(unsigned int gpios) +{ + mpc85xx_gpio_set(gpios, 0xFFFFFFFF, 0x00000000); +} + +static inline void mpc85xx_gpio_set_high(unsigned int gpios) +{ + mpc85xx_gpio_set(gpios, 0xFFFFFFFF, 0xFFFFFFFF); +} + +static inline unsigned int mpc85xx_gpio_get(unsigned int mask) +{ + ccsr_gpio_t *gpio = (void *)(CONFIG_SYS_MPC85xx_GPIO_ADDR + 0xc00); + + /* Read the requested values */ + return in_be32(&gpio->gpdat) & mask; +} + +/* + * These implement the generic Linux GPIO API on top of the other functions + * in this header. + */ +#ifdef CONFIG_MPC85XX_GENERIC_GPIO +static inline int gpio_request(unsigned gpio, const char *label) +{ + /* Compatibility shim */ + return 0; +} + +static inline void gpio_free(unsigned gpio) +{ + /* Compatibility shim */ +} + +static inline int gpio_direction_input(unsigned gpio) +{ + mpc85xx_gpio_set_in(1U << gpio); + return 0; +} + +static inline int gpio_direction_output(unsigned gpio, int value) +{ + mpc85xx_gpio_set_low(1U << gpio); + return 0; +} + +static inline int gpio_get_value(unsigned gpio) +{ + return !!mpc85xx_gpio_get(1U << gpio) +} + +static inline void gpio_set_value(unsigned gpio, int value) +{ + if (value) + mpc85xx_gpio_set_high(1U << gpio); + else + mpc85xx_gpio_set_low(1U << gpio); +} + +static inline int gpio_is_valid(int gpio) +{ + return (gpio >= 0) && (gpio < 32); +} +#endif /* CONFIG_MPC85XX_GENERIC_GPIO */
Please update the README for new #define
- k
The HWW-1U-1A board needs to be able to override the "reset" command due to hardware design limitations.
-- Changelog: v2: Removed in favor of more involved reset rework v6: Resurrected again (the more involved rework was NAKed) v7: Fixed remaining checkpatch errors
arch/powerpc/cpu/mpc85xx/cpu.c | 27 ++++++++++++++++++++++----- 1 files changed, 22 insertions(+), 5 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu.c b/arch/powerpc/cpu/mpc85xx/cpu.c index 49ea6cc..6776468 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu.c +++ b/arch/powerpc/cpu/mpc85xx/cpu.c @@ -203,11 +203,17 @@ int checkcpu (void)
-int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +/* Board-specific reset stub */ +__attribute__((__weak__)) +int __board_restart(void) { -/* Everything after the first generation of PQ3 parts has RSTCR */ + return 0; +} + #if defined(CONFIG_MPC8540) || defined(CONFIG_MPC8541) || \ defined(CONFIG_MPC8555) || defined(CONFIG_MPC8560) +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ unsigned long val, msr;
/* @@ -221,14 +227,25 @@ int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) val = mfspr(DBCR0); val |= 0x70000000; mtspr(DBCR0,val); +} #else - volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + /* Everything after the first generation of PQ3 parts has RSTCR */ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + + /* Allow boards to override the reset */ + int err = __board_restart(); + if (err) + return err; + out_be32(&gur->rstcr, 0x2); /* HRESET_REQ */ udelay(100); -#endif - return 1; } +#endif + +
What happened to more generic reset cleanup?
This concerns me because it means those cpu's don't support __board_restart(), we should be consistent.
- /* Everything after the first generation of PQ3 parts has RSTCR */
- ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR);
- /* Allow boards to override the reset */
- int err = __board_restart();
- if (err)
return err;
- out_be32(&gur->rstcr, 0x2); /* HRESET_REQ */ udelay(100);
-#endif
- return 1;
} +#endif
1.7.2.5
The eXMeritus HWW-1U-1A unit is a DO-160-certified 13lb 1U chassis with 3 independent TEMPEST zones. Two independent P2020 computers may be found inside each zone. Complete hardware support is included.
High-level hardware overview: * DO-160 certified for passenger aircraft (noncritical) * TEMPEST ceritified for RED/BLACK separation * 3 zones per chassis, 2 computers per zone (total of 6) * Dual-core 1.066GHz P2020 per computer * One 2GB DDR2 SO-RDIMM module per computer (upgradable to 4GB) * Removable 80GB or 160GB Intel X18-M SSD per computer * Front-accessible dual-port E1000E per computer * Front-accessible serial console per computer * Front-accessible USB port per computer * Internal Gigabit crossover within each TEMPEST zone * Internal unidirectional fiber links across TEMPEST zones * Battery-backed DS1339 I2C RTC on each CPU.
Combined, each 13lb 1U chassis contains 12GB RAM, 12 cores @ 1.066GHz, 12 front-accessible Gigabit Ethernet ports and 960GB of solid-state storage with a total power consumption of ~200W.
Additional notes: * SPD detection is only known to work with the DO-160-certified DIMMs
* A U-Boot built with 36-bit address-space seems to work, but I don't yet have a usable 36-bit kernel or DTB, so it's mostly untested.
* CPU reset is a little quirky due to hardware misfeature, see the extensive comments in the board_reset() function in hww1u1a.c
Signed-off-by: Kyle Moffett Kyle.D.Moffett@boeing.com Cc: Andy Fleming afleming@gmail.com Cc: Kumar Gala kumar.gala@freescale.com --- Changes since v6: Moved a #define to the hww1u1a/gpios.h header. Removed an unnecessary empty comment. Added braces for a multiline statement. Converted an infinite loop into a hang(). Disabled buggy memtest.
MAINTAINERS | 4 + board/exmeritus/hww1u1a/Makefile | 54 ++++ board/exmeritus/hww1u1a/ddr.c | 34 +++ board/exmeritus/hww1u1a/gpios.h | 69 +++++ board/exmeritus/hww1u1a/hww1u1a.c | 543 +++++++++++++++++++++++++++++++++++++ board/exmeritus/hww1u1a/law.c | 34 +++ board/exmeritus/hww1u1a/tlb.c | 106 +++++++ boards.cfg | 2 + include/configs/HWW1U1A.h | 470 ++++++++++++++++++++++++++++++++ 9 files changed, 1316 insertions(+), 0 deletions(-) create mode 100644 board/exmeritus/hww1u1a/Makefile create mode 100644 board/exmeritus/hww1u1a/ddr.c create mode 100644 board/exmeritus/hww1u1a/gpios.h create mode 100644 board/exmeritus/hww1u1a/hww1u1a.c create mode 100644 board/exmeritus/hww1u1a/law.c create mode 100644 board/exmeritus/hww1u1a/tlb.c create mode 100644 include/configs/HWW1U1A.h
diff --git a/MAINTAINERS b/MAINTAINERS index 4756f14..6644baf 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -320,6 +320,10 @@ Reinhard Meyer reinhard.meyer@emk-elektronik.de TOP5200 MPC5200 TOP9000 ARM926EJS (AT91SAM9xxx SoC)
+Kyle Moffett Kyle.D.Moffett@boeing.com + + HWW1U1A P2020 + Tolunay Orkun torkun@nextio.com
csb272 PPC405GP diff --git a/board/exmeritus/hww1u1a/Makefile b/board/exmeritus/hww1u1a/Makefile new file mode 100644 index 0000000..b927f59 --- /dev/null +++ b/board/exmeritus/hww1u1a/Makefile @@ -0,0 +1,54 @@ +# +# Copyright 2007-2009 Freescale Semiconductor, Inc. +# (C) Copyright 2001-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += $(BOARD).o +COBJS-y += law.o +COBJS-y += tlb.o +COBJS-$(CONFIG_DDR_SPD) += ddr.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS)) + +clean: + rm -f $(OBJS) $(SOBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/exmeritus/hww1u1a/ddr.c b/board/exmeritus/hww1u1a/ddr.c new file mode 100644 index 0000000..36d02ad --- /dev/null +++ b/board/exmeritus/hww1u1a/ddr.c @@ -0,0 +1,34 @@ +/* + * Copyright 2009-2010 eXMeritus, A Boeing Company + * Copyright 2008-2009 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * Version 2 as published by the Free Software Foundation. + */ + +#include <common.h> + +#include <asm/fsl_ddr_sdram.h> +#include <asm/fsl_ddr_dimm_params.h> + +void fsl_ddr_board_options(memctl_options_t *popts, + dimm_params_t *pdimm, + unsigned int ctrl_num) +{ + /* + * We only support one DIMM, so according to the P2020 docs we should + * set the options as follows: + */ + popts->cs_local_opts[0].odt_rd_cfg = 0; + popts->cs_local_opts[0].odt_wr_cfg = 4; + popts->cs_local_opts[1].odt_rd_cfg = 0; + popts->cs_local_opts[1].odt_wr_cfg = 0; + popts->half_strength_driver_enable = 0; + + /* Manually configured for our static clock rate */ + popts->clk_adjust = 4; + popts->cpo_override = 4; + popts->write_data_delay = 2; + popts->twoT_en = 0; +} diff --git a/board/exmeritus/hww1u1a/gpios.h b/board/exmeritus/hww1u1a/gpios.h new file mode 100644 index 0000000..ac56d42 --- /dev/null +++ b/board/exmeritus/hww1u1a/gpios.h @@ -0,0 +1,69 @@ +/* + * Copyright 2010 eXMeritus, A Boeing Company + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm/mpc85xx_gpio.h> + +/* Common CPU A/B GPIOs (GPIO8-GPIO15 and IRQ4-IRQ6) */ +#define GPIO_CPU_ID (1UL << (31 - 8)) +#define GPIO_BLUE_LED (1UL << (31 - 9)) +#define GPIO_DIMM_RESET (1UL << (31 - 10)) +#define GPIO_USB_RESET (1UL << (31 - 11)) +#define GPIO_UNUSED_12 (1UL << (31 - 12)) +#define GPIO_GETH0_RESET (1UL << (31 - 13)) +#define GPIO_RS422_RE (1UL << (31 - 14)) +#define GPIO_RS422_DE (1UL << (31 - 15)) +#define IRQ_I2CINT (1UL << (31 - 20)) +#define IRQ_FANINT (1UL << (31 - 21)) +#define IRQ_DIMM_EVENT (1UL << (31 - 22)) + +#define GPIO_RESETS (GPIO_DIMM_RESET|GPIO_USB_RESET|GPIO_GETH0_RESET) + +/* CPU A GPIOS (GPIO0-GPIO7 and IRQ0-IRQ3) */ +#define GPIO_CPUA_UNUSED_0 (1UL << (31 - 0)) +#define GPIO_CPUA_CPU_READY (1UL << (31 - 1)) +#define GPIO_CPUA_DEBUG_LED2 (1UL << (31 - 2)) +#define GPIO_CPUA_DEBUG_LED1 (1UL << (31 - 3)) +#define GPIO_CPUA_TDIS2B (1UL << (31 - 4)) /* MAC 2 TX B */ +#define GPIO_CPUA_TDIS2A (1UL << (31 - 5)) /* MAC 2 TX A */ +#define GPIO_CPUA_TDIS1B (1UL << (31 - 6)) /* MAC 1 TX B */ +#define GPIO_CPUA_TDIS1A (1UL << (31 - 7)) /* MAC 1 TX A */ +#define IRQ_CPUA_UNUSED_0 (1UL << (31 - 16)) +#define IRQ_CPUA_UNUSED_1 (1UL << (31 - 17)) +#define IRQ_CPUA_UNUSED_2 (1UL << (31 - 18)) +#define IRQ_CPUA_UNUSED_3 (1UL << (31 - 19)) + +/* CPU B GPIOS (GPIO0-GPIO7 and IRQ0-IRQ3) */ +#define GPIO_CPUB_RMUX_SEL1B (1UL << (31 - 0)) +#define GPIO_CPUB_RMUX_SEL0B (1UL << (31 - 1)) +#define GPIO_CPUB_RMUX_SEL1A (1UL << (31 - 2)) +#define GPIO_CPUB_RMUX_SEL0A (1UL << (31 - 3)) +#define GPIO_CPUB_UNUSED_4 (1UL << (31 - 4)) +#define GPIO_CPUB_CPU_READY (1UL << (31 - 5)) +#define GPIO_CPUB_DEBUG_LED2 (1UL << (31 - 6)) +#define GPIO_CPUB_DEBUG_LED1 (1UL << (31 - 7)) +#define IRQ_CPUB_SD_1A (1UL << (31 - 16)) +#define IRQ_CPUB_SD_2B (1UL << (31 - 17)) +#define IRQ_CPUB_SD_2A (1UL << (31 - 18)) +#define IRQ_CPUB_SD_1B (1UL << (31 - 19)) + +/* If it isn't CPU A then it's CPU B */ +static inline unsigned int hww1u1a_is_cpu_a(void) +{ + return !mpc85xx_gpio_get(GPIO_CPU_ID); +} diff --git a/board/exmeritus/hww1u1a/hww1u1a.c b/board/exmeritus/hww1u1a/hww1u1a.c new file mode 100644 index 0000000..95160d9 --- /dev/null +++ b/board/exmeritus/hww1u1a/hww1u1a.c @@ -0,0 +1,542 @@ +/* + * Copyright 2009-2011 eXMeritus, A Boeing Company + * Copyright 2007-2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <pci.h> +#include <asm/processor.h> +#include <asm/mmu.h> +#include <asm/cache.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_pci.h> +#include <asm/fsl_ddr_sdram.h> +#include <asm/io.h> +#include <miiphy.h> +#include <libfdt.h> +#include <linux/ctype.h> +#include <fdt_support.h> +#include <tsec.h> +#include <asm/fsl_law.h> +#include <netdev.h> +#include <malloc.h> +#include <i2c.h> +#include <pca953x.h> + +#include "gpios.h" + +DECLARE_GLOBAL_DATA_PTR; + +int checkboard(void) +{ + unsigned int gpio_high = 0; + unsigned int gpio_low = 0; + unsigned int gpio_in = 0; + unsigned int i; + + puts("Board: HWW-1U-1A "); +#ifdef CONFIG_PHYS_64BIT + puts("(36-bit addrmap) "); +#endif + + /* + * First just figure out which CPU we're on, then use that to + * configure the lists of other GPIOs to be programmed. + */ + mpc85xx_gpio_set_in(GPIO_CPU_ID); + if (hww1u1a_is_cpu_a()) { + puts("CPU A\n"); + + /* We want to turn on some LEDs */ + gpio_high |= GPIO_CPUA_CPU_READY; + gpio_low |= GPIO_CPUA_DEBUG_LED1; + gpio_low |= GPIO_CPUA_DEBUG_LED2; + + /* Disable the unused transmitters */ + gpio_low |= GPIO_CPUA_TDIS1A; + gpio_high |= GPIO_CPUA_TDIS1B; + gpio_low |= GPIO_CPUA_TDIS2A; + gpio_high |= GPIO_CPUA_TDIS2B; + } else { + puts("CPU B\n"); + + /* We want to turn on some LEDs */ + gpio_high |= GPIO_CPUB_CPU_READY; + gpio_low |= GPIO_CPUB_DEBUG_LED1; + gpio_low |= GPIO_CPUB_DEBUG_LED2; + + /* Enable the appropriate receivers */ + gpio_high |= GPIO_CPUB_RMUX_SEL0A; + gpio_high |= GPIO_CPUB_RMUX_SEL0B; + gpio_low |= GPIO_CPUB_RMUX_SEL1A; + gpio_low |= GPIO_CPUB_RMUX_SEL1B; + } + + /* These GPIOs are common */ + gpio_in |= IRQ_I2CINT | IRQ_FANINT | IRQ_DIMM_EVENT; + gpio_low |= GPIO_RS422_RE; + gpio_high |= GPIO_RS422_DE; + + /* Ok, now go ahead and program all of those in one go */ + mpc85xx_gpio_set( gpio_high|gpio_low|gpio_in, + gpio_high|gpio_low, + gpio_high); + + /* + * If things have been taken out of reset early (for example, by one + * of the BDI3000 debuggers), then we need to put them back in reset + * and delay a while before we continue. + */ + if (mpc85xx_gpio_get(GPIO_RESETS)) { + ccsr_ddr_t *ddr = (ccsr_ddr_t *)CONFIG_SYS_MPC85xx_DDR_ADDR; + + puts("Debugger detected... extra device reset enabled!\n"); + + /* Put stuff into reset and disable the DDR controller */ + mpc85xx_gpio_set_low(GPIO_RESETS); + out_be32(&ddr->sdram_cfg, 0x00000000); + + puts(" Waiting 1 sec for reset..."); + for (i = 0; i < 10; i++) { + udelay(100000); + puts("."); + } + puts("\n"); + } + + /* Now bring everything back out of reset again */ + mpc85xx_gpio_set_high(GPIO_RESETS); + return 0; +} + +/* + * This little shell function just returns whether or not it's CPU A. + * It can be used to select the right device-tree when booting, etc. + */ +int do_hww1u1a_test_cpu_a(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + if (argc > 1) + cmd_usage(cmdtp); + + if (hww1u1a_is_cpu_a()) + return 0; + else + return 1; +} +U_BOOT_CMD( + hww1u1a_test_cpu_a, 1, 0, do_hww1u1a_test_cpu_a, + "Test if this is CPU A (versus B) on the eXMeritus HWW-1U-1A board", + " && <command-if-true>\n" + "hww1u1a_test_cpu_a || <command-if-false>\n" +); + +/* Create a prompt-like string: "uboot@HOSTNAME% " */ +#define PROMPT_PREFIX "uboot@exm" +#define PROMPT_SUFFIX "% " + +/* This function returns a PS1 prompt based on the serial number */ +static char *hww1u1a_prompt; +const char *hww1u1a_get_ps1(void) +{ + unsigned long len, i, j; + const char *serialnr; + + /* If our prompt was already set, just use that */ + if (hww1u1a_prompt) + return hww1u1a_prompt; + + /* Use our serial number if present, otherwise "UNPROGRAMMED-[AB]" */ + serialnr = getenv("serial#"); + if (!serialnr || !serialnr[0]) { + if (hww1u1a_is_cpu_a()) + serialnr = "999999-XA"; + else + serialnr = "999999-XB"; + } + + /* + * We will turn the serial number into a hostname by: + * (A) Delete all non-alphanumerics. + * (B) Lowercase all letters + * (C) Prefix "exm" + */ + for (i = 0, len = 0; serialnr[i]; i++) { + if (isalnum(serialnr[i])) + len++; + } + + len += sizeof(PROMPT_PREFIX PROMPT_SUFFIX); /* Includes NUL */ + hww1u1a_prompt = malloc(len); + if (!hww1u1a_prompt) + return PROMPT_PREFIX "UNKNOWN(ENOMEM)" PROMPT_SUFFIX; + + /* Now actually fill it in */ + i = 0; + + /* Handle the prefix */ + for (j = 0; j < sizeof(PROMPT_PREFIX) - 1; j++) + hww1u1a_prompt[i++] = PROMPT_PREFIX[j]; + + /* Now the serial# part of the hostname */ + for (j = 0; serialnr[j]; j++) + if (isalnum(serialnr[j])) + hww1u1a_prompt[i++] = tolower(serialnr[j]); + + /* Finally the suffix */ + for (j = 0; j < sizeof(PROMPT_SUFFIX); j++) + hww1u1a_prompt[i++] = PROMPT_SUFFIX[j]; + + /* This should all have added up, but just in case */ + hww1u1a_prompt[len - 1] = '\0'; + + /* Now we're done */ + return hww1u1a_prompt; +} + +void pci_init_board(void) +{ + fsl_pcie_init_board(0); +} + +int board_early_init_r(void) +{ + const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; + const u8 flash_esel = find_tlb_idx((void *)flashbase, 1); + + /* + * Remap bootflash region to caching-inhibited + * so that flash can be erased properly. + */ + + /* Flush d-cache and invalidate i-cache of any FLASH data */ + flush_dcache(); + invalidate_icache(); + + /* invalidate existing TLB entry for FLASH */ + disable_tlb(flash_esel); + + set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, flash_esel, BOOKE_PAGESZ_256M, 1); + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + struct tsec_info_struct tsec_info[4]; + + SET_STD_TSEC_INFO(tsec_info[0], 1); + SET_STD_TSEC_INFO(tsec_info[1], 2); + SET_STD_TSEC_INFO(tsec_info[2], 3); + + if (hww1u1a_is_cpu_a()) + tsec_info[2].phyaddr = TSEC3_PHY_ADDR_CPUA; + else + tsec_info[2].phyaddr = TSEC3_PHY_ADDR_CPUB; + + tsec_eth_init(bis, tsec_info, 3); + return pci_eth_init(bis); +} + +void ft_board_setup(void *blob, bd_t *bd) +{ + phys_addr_t base; + phys_size_t size; + + ft_cpu_setup(blob, bd); + + base = getenv_bootm_low(); + size = getenv_bootm_size(); + + fdt_fixup_memory(blob, (u64)base, (u64)size); + + FT_FSL_PCI_SETUP; +} + +/* + * Unfortunately we have a bit of a problem with our reset line wiring on the + * HWW-1U-1A boards. + * + * Specifically the "CPU A" reset controls all of the PCI devices on the + * IO/backplane card, which means ethernet and SATA controllers for both + * CPU A *and* CPU B. + * + * This is somewhat of a problem if the CPUs are reset independently... CPU B + * might fail to come up because his PCI devices are confused, or CPU B might + * die because CPU A just reset the SATA controller for his root filesystem. + * + * Since in practice the CPUs never need to reboot independently we will go + * ahead and require GPIO cross-communication between them before either one + * will reset. + * + * The communication protocol uses GPIOs 4-7 on the PCA9554 GPIO expander + * found on I2C-2 at address 0x3f. CPU A uses 4,5 as TX and 6,7 as RX; for + * CPU B we use the exact opposite. + * + * The GPIOs initialize as inputs during poweron, and are pulled high; the + * PCA9554 expanders will maintain valid outputs over soft-reset allowing for + * reliable operation. + * + * To avoid duplication, we will assign names to the GPIOs: + * ,---------------------------------------. + * | GPIO4 | GPIO5 | GPIO6 | GPIO7 | + * ,---------|=========|=========|=========|=========| + * | CPU A | tx1 | tx2 | rx1 | rx2 | + * |---------|---------|---------|---------|---------| + * | CPU B | rx1 | rx2 | tx1 | tx2 | + * `-------------------------------------------------' + * + * The state machine for each CPU is below. In simplistic terms, each CPU + * waits until the other has cleared its GPIOs, then cause a tx1 high=>low + * transition. Upon seeing the other CPU do the same, it will perform a + * tx2 high=>low transition and again wait. + * + * Once both CPUs have performed and seen both transitions, they will each + * set tx1 high (to create an "invalid" state) and then reset. + * + * ,--------------. + * | START/ERROR: |<==-. + * ,-==>| tx2 = 1; | || (rx2 == 0) + * || | tx1 = 1; | ==-' + * || `--------------' + * || || + * || || (rx2 == 1) + * || / + * || ,--------------. + * || | WAITING: |<==-. + * |== | tx1 = 0; | || (rx1 == 1) && (rx2 == 1) + * || | | ==-' + * || `--------------' + * || || + * || || (rx1 == 0) && (rx2 == 1) + * || / + * || ,--------------. + * || | BOTH_READY: |<==-. + * `-== | tx2 = 0; | || (rx1 == 0) && (rx2 == 1) + * | | ==-' + * `--------------' + * || + * || (rx2 == 0) + * / + * ,--------------. + * | RESETTING: | + * | tx1 = 1; | + * | reset(); | + * `--------------' + * + * While in the "BOTH_READY" state a high-to-low rx2 transition must be + * followed within 50ms by activation of the HRESET_REQ signal. That + * state MUST NOT be interrupted by any event other than the observed + * event (rx1 == high) && (rx2 == high). + */ + +/* + * These tiny wrappers hardcode the I2C bus and the chip address to make the + * state-machine function easier to read and understand. + */ +#define PCA9554 CONFIG_SYS_I2C_PCA953X_ADDR +static int pca9554_set_low(u8 gpio) +{ + i2c_set_bus_num(1); + return pca953x_set_val(PCA9554, (1U << gpio), 0x00); +} + +static int pca9554_set_high(u8 gpio) +{ + i2c_set_bus_num(1); + return pca953x_set_val(PCA9554, (1U << gpio), 0xff); +} + +static int pca9554_set_output(u8 gpio) +{ + i2c_set_bus_num(1); + return pca953x_set_dir(PCA9554, (1U << gpio), 0x00); +} + +static int pca9554_set_input(u8 gpio) +{ + i2c_set_bus_num(1); + return pca953x_set_dir(PCA9554, (1U << gpio), 0xff); +} + +int __board_restart(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u8 tx1, tx2, rx1, rx2, rxmask; + int ret; + + /* Our state-machine state */ + enum { + START_ERROR = 0, + WAITING, + BOTH_READY, + } state; + + /* Check what CPU we are and configure accordingly. */ + if (hww1u1a_is_cpu_a()) { + tx1 = 4; tx2 = 5; rx1 = 6; rx2 = 7; + } else { + rx1 = 4; rx2 = 5; tx1 = 6; tx2 = 7; + } + rxmask = (1U << rx1) | (1U << rx2); + + printf("RESET: Preparing..."); + + /* First clear the "INVERT" setting on all relevant GPIOs */ + i2c_set_bus_num(1); + if (pca953x_set_pol(PCA9554, 0xf0, 0x00) < 0) + goto err; + + /* Configure both inputs */ + if (pca9554_set_input(rx1) < 0) + goto err; + if (pca9554_set_input(rx2) < 0) + goto err; + + /* Make sure the very first thing we do is set the "tx2" GPIO high */ + if (pca9554_set_high(tx2) < 0) + goto err; + if (pca9554_set_output(tx2) < 0) + goto err; + + /* Now reset our other transmit pin */ + if (pca9554_set_high(tx1) < 0) + goto err; + if (pca9554_set_output(tx1) < 0) + goto err; + + /* Enter the state machine */ + state = START_ERROR; + +poll_state: + i2c_set_bus_num(1); + ret = pca953x_get_val(PCA9554); + switch (state) { + case START_ERROR: + if (ctrlc()) + goto intr; + + if (ret < 0) + goto err; + + /* Wait for (rx2 == high) */ + if (ret & (1U << rx2)) { + /* Success! */ + state = WAITING; + goto enter_state; + } + + goto poll_state; + + case WAITING: + if (ctrlc()) + goto intr; + + if (ret < 0) + goto err; + + /* Wait for (rx1 == low) && (rx2 == high) */ + ret &= rxmask; + if (ret == (1U << rx2)) { + /* Success! */ + state = BOTH_READY; + goto enter_state; + } + if (ret != rxmask) { + /* Oops, error */ + state = START_ERROR; + goto enter_state; + } + + goto poll_state; + + case BOTH_READY: + /* + * Non-interruptable wait for (rx2 == low), however if we + * see (rx1 == high) and (rx2 == high) we should go back + * to START_ERROR. + */ + if (ret < 0) + goto poll_state; + + ret &= rxmask; + if (ret == rxmask) { + /* Oops, error */ + state = START_ERROR; + goto enter_state; + } + if (ret & (1U << rx2)) + goto poll_state; + + /* Success, we have to reset quick now! */ + (void)pca9554_set_high(tx1); + + /* Turn on the "HRESET_REQ" pin (hard-reset request) */ + printf("\nRESET: Hardware reset triggered, waiting...\n"); + out_be32(&gur->rstcr, 0x2); + hang(); + } + +enter_state: + switch (state) { + case START_ERROR: + printf("\nRESET: Negotiation error!"); + printf("\nRESET: Starting over..."); + /* Clear both GPIOs high in the right order */ + if (pca9554_set_high(tx2) < 0) + goto err; + if (pca9554_set_high(tx1) < 0) + goto err; + if (ctrlc()) + goto intr; + + goto poll_state; + + case WAITING: + printf("\nRESET: Waiting for peer..."); + /* Set tx1 low */ + if (pca9554_set_low(tx1) < 0) + goto err; + if (ctrlc()) + goto intr; + + goto poll_state; + + case BOTH_READY: + printf("\nRESET: Both ready, point of no return..."); + /* Point of no return: set tx2 low */ + if (pca9554_set_low(tx2) < 0) + goto err; + + goto poll_state; + } + + /* We only get here through gotos */ +err: + printf("\nRESET: I2C communication error!\n"); +intr: + printf("\nRESET: Aborted!\n"); + (void)pca9554_set_high(tx1); + (void)pca9554_set_high(tx2); + return -1; +} diff --git a/board/exmeritus/hww1u1a/law.c b/board/exmeritus/hww1u1a/law.c new file mode 100644 index 0000000..1281c56 --- /dev/null +++ b/board/exmeritus/hww1u1a/law.c @@ -0,0 +1,34 @@ +/* + * Copyright 2008-2009 Freescale Semiconductor, Inc. + * + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_law.h> +#include <asm/mmu.h> + +struct law_entry law_table[] = { + SET_LAW(CONFIG_SYS_FLASH_BASE_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_LBC), +}; + +int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/exmeritus/hww1u1a/tlb.c b/board/exmeritus/hww1u1a/tlb.c new file mode 100644 index 0000000..6c65206 --- /dev/null +++ b/board/exmeritus/hww1u1a/tlb.c @@ -0,0 +1,106 @@ +/* + * Copyright 2009-2010 eXMeritus, A Boeing Company + * Copyright 2008-2009 Freescale Semiconductor, Inc. + * + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/mmu.h> + +struct fsl_e_tlb_entry tlb_table[] = { + /* TLB 0 - for temp stack in cache */ + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 0 * 1024, + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 0 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 4 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 8 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 12 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + + /* TLB 1 */ + /* *I*** - Boot page */ + SET_TLB_ENTRY(1, CONFIG_BPTR_VIRT_ADDR, + CONFIG_BPTR_VIRT_ADDR, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_4K, 1), + + /* *I*G* - CCSRBAR */ + SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, + CONFIG_SYS_CCSRBAR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 1, BOOKE_PAGESZ_1M, 1), + + /* + * W**G* - FLASH (Will be *I*G* after relocation to RAM) + * + * This maps both SPI FLASH chips (128MByte per chip) + */ + SET_TLB_ENTRY(1, CONFIG_SYS_FLASH_BASE, + CONFIG_SYS_FLASH_BASE_PHYS, + MAS3_SX|MAS3_SR, MAS2_W|MAS2_G, + 0, 2, BOOKE_PAGESZ_256M, 1), + + /* + * *I*G* - PCI memory + * + * We have 1.5GB total PCI-E memory space to map and we want to use + * the minimum possible number of TLB entries. Since Book-E TLB + * entries are sized in powers of 4, we use 1GB + 256MB + 256MB. + */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_MEM_VIRT, + CONFIG_SYS_PCIE3_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 3, BOOKE_PAGESZ_1G, 1), + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_MEM_VIRT + 0x40000000, + CONFIG_SYS_PCIE3_MEM_PHYS + 0x40000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 4, BOOKE_PAGESZ_256M, 1), + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_MEM_VIRT + 0x50000000, + CONFIG_SYS_PCIE3_MEM_PHYS + 0x50000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 5, BOOKE_PAGESZ_256M, 1), + + /* + * *I*G* - PCI I/O + * + * This one entry covers all 3 64k PCI-E I/O windows + */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_IO_VIRT, + CONFIG_SYS_PCIE3_IO_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 6, BOOKE_PAGESZ_256K, 1), +}; + +int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/boards.cfg b/boards.cfg index 45c3102..743e016 100644 --- a/boards.cfg +++ b/boards.cfg @@ -487,6 +487,8 @@ sbc8560 powerpc mpc85xx sbc8560 - sbc8560_33 powerpc mpc85xx sbc8560 - - sbc8560 sbc8560_66 powerpc mpc85xx sbc8560 - - sbc8560 socrates powerpc mpc85xx socrates +HWW1U1A powerpc mpc85xx hww1u1a exmeritus +HWW1U1A_36BIT powerpc mpc85xx hww1u1a exmeritus - HWW1U1A:36BIT MPC8536DS powerpc mpc85xx mpc8536ds freescale - MPC8536DS MPC8536DS_36BIT powerpc mpc85xx mpc8536ds freescale - MPC8536DS:36BIT MPC8536DS_NAND powerpc mpc85xx mpc8536ds freescale - MPC8536DS:NAND diff --git a/include/configs/HWW1U1A.h b/include/configs/HWW1U1A.h new file mode 100644 index 0000000..a7af4a7 --- /dev/null +++ b/include/configs/HWW1U1A.h @@ -0,0 +1,470 @@ +/* + * Copyright 2009-2010 eXMeritus, A Boeing Company + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * HardwareWall HWW-1U-1A airborne unit configuration file + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +/* High-level system configuration options */ +#define CONFIG_BOOKE /* Power/PowerPC Book-E */ +#define CONFIG_E500 /* e500 (Power ISA v2.03 with SPE) */ +#define CONFIG_MPC85xx /* MPC8540/60/55/41/48 family */ +#define CONFIG_FSL_ELBC /* FreeScale Enhanced LocalBus Cntlr */ +#define CONFIG_FSL_LAW /* FreeScale Local Access Window */ +#define CONFIG_P2020 /* FreeScale P2020 */ +#define CONFIG_HWW1U1A /* eXMeritus HardwareWall HWW-1U-1A */ +#define CONFIG_MP /* Multiprocessing support */ +#define CONFIG_HWCONFIG /* Use hwconfig from environment */ + +#define CONFIG_L2_CACHE /* L2 cache enabled */ +#define CONFIG_BTB /* Branch predition enabled */ + +#define CONFIG_PANIC_HANG /* No board reset on panic */ +#define CONFIG_BOARD_EARLY_INIT_R /* Call board_early_init_r() */ +#define CONFIG_CMD_REGINFO /* Dump various CPU regs */ + +/* + * Allow the use of 36-bit physical addresses in "HWW_1U_1A_36BIT" mode. + * NOTE: This is only very minimally tested and has known compatibility + * issues with the existing kernel images. + */ +#define CONFIG_ENABLE_36BIT_PHYS +#ifdef CONFIG_36BIT +# define CONFIG_PHYS_64BIT +# define CONFIG_ADDR_MAP +# define CONFIG_SYS_NUM_ADDR_MAP 16 /* Number of entries in TLB1 */ +#endif + +/* Reserve plenty of RAM for malloc (we have 2GB+) */ +#define CONFIG_SYS_MALLOC_LEN (1024 * 1024) + +/* How much L2 cache do we map so we can use it as RAM */ +#define CONFIG_SYS_INIT_RAM_LOCK +#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 + +/* This is our temporary global data area just above the stack */ +#define CONFIG_SYS_GBL_DATA_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) + +/* The stack grows down from the global data area */ +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +/* Enable IRQs and watchdog with a 1000Hz system decrementer */ +#define CONFIG_CMD_IRQ +#define CONFIG_SYS_HZ 1000 + + +/* -------------------------------------------------------------------- */ + +/* + * Clock crystal configuration: + * (1) SYS: 66.666MHz +/- 50ppm (drives CPU/PCI/DDR) + * (2) CCB: Multiplier from SYS_CLK + * (3) RTC: 25.000MHz +/- 50ppm (sampled against CCB clock) + */ +#define CONFIG_SYS_CLK_FREQ 66666000/*Hz*/ +#define CONFIG_DDR_CLK_FREQ 66666000/*Hz*/ + + +/* -------------------------------------------------------------------- */ + +/* + * Memory map + * + * 0x0000_0000 0x7fff_ffff 2G DDR2 ECC SDRAM + * 0x8000_0000 0x9fff_ffff 512M PCI-E Bus 1 + * 0xa000_0000 0xbfff_ffff 512M PCI-E Bus 2 (unused) + * 0xc000_0000 0xdfff_ffff 512M PCI-E Bus 3 + * 0xe000_0000 0xe7ff_ffff 128M Spansion FLASH + * 0xe800_0000 0xefff_ffff 128M Spansion FLASH + * 0xffd0_0000 0xffd0_3fff 16K L1 boot stack (TLB0) + * 0xffe0_0000 0xffef_ffff 1M CCSR + * 0xffe0_5000 0xffe0_5fff 4K Enhanced LocalBus Controller + */ + +/* Virtual Memory Map */ +#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_PCIE3_MEM_VIRT 0x80000000 +#define CONFIG_SYS_PCIE2_MEM_VIRT 0xa0000000 +#define CONFIG_SYS_PCIE1_MEM_VIRT 0xc0000000 +#define CONFIG_SYS_FLASH_BASE 0xe0000000 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 /* CCSRBAR @ reset */ +#define CONFIG_SYS_PCIE3_IO_VIRT 0xffc00000 +#define CONFIG_SYS_PCIE2_IO_VIRT 0xffc10000 +#define CONFIG_SYS_PCIE1_IO_VIRT 0xffc20000 +#define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 +#define CONFIG_SYS_CCSRBAR 0xffe00000 /* CCSRBAR @ runtime */ + +#define CONFIG_SYS_PCIE3_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ +#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ +#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ + +/* Physical Memory Map */ +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE3_MEM_PHYS 0xc00000000ull +#define CONFIG_SYS_PCIE2_MEM_PHYS 0xc20000000ull +#define CONFIG_SYS_PCIE1_MEM_PHYS 0xc40000000ull +#define CONFIG_SYS_FLASH_BASE_PHYS 0xfe0000000ull +#define CONFIG_SYS_PCIE3_IO_PHYS 0xfffc00000ull +#define CONFIG_SYS_PCIE2_IO_PHYS 0xfffc10000ull +#define CONFIG_SYS_PCIE1_IO_PHYS 0xfffc20000ull +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS 0xfffd00000ull +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0xf /* for ASM code */ +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW 0xffd00000 /* for ASM code */ +#define CONFIG_SYS_CCSRBAR_PHYS 0xfffe00000ull +#else +#define CONFIG_SYS_PCIE3_MEM_PHYS 0x80000000ul +#define CONFIG_SYS_PCIE2_MEM_PHYS 0xa0000000ul +#define CONFIG_SYS_PCIE1_MEM_PHYS 0xc0000000ul +#define CONFIG_SYS_FLASH_BASE_PHYS 0xe0000000ul +#define CONFIG_SYS_PCIE3_IO_PHYS 0xffc00000ul +#define CONFIG_SYS_PCIE2_IO_PHYS 0xffc10000ul +#define CONFIG_SYS_PCIE1_IO_PHYS 0xffc20000ul +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS 0xffd00000ul +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0x0 /* for ASM code */ +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW 0xffd00000 /* for ASM code */ +#define CONFIG_SYS_CCSRBAR_PHYS 0xffe00000ul +#endif + +/* Legacy code needs this */ +#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR + + +/* -------------------------------------------------------------------- */ + +/* U-Boot image (MONITOR_BASE == TEXT_BASE) */ +#define CONFIG_RESET_VECTOR_ADDRESS 0xeffffffc /* Top address in flash */ +#define CONFIG_SYS_TEXT_BASE 0xeff80000 /* Start of U-Boot image */ +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_MONITOR_LEN 0x80000 /* 512kB (4 flash sectors) */ + +/* + * U-Boot Environment Image: The two sectors immediately below U-Boot + * form the U-Boot environment (regular and redundant). + */ +#define CONFIG_ENV_IS_IN_FLASH /* The environment image is stored in FLASH */ +#define CONFIG_ENV_OVERWRITE /* Allow "protected" variables to be erased */ +#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128kB (1 flash sector) */ +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR - CONFIG_ENV_SECT_SIZE) + +/* Only use 8kB of each environment sector for data */ +#define CONFIG_ENV_SIZE 0x2000 /* 8kB */ +#define CONFIG_ENV_SIZE_REDUND 0x2000 /* 8kB */ + + +/* -------------------------------------------------------------------- */ + +/* Serial Console Configuration */ +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK get_bus_freq(0) + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200} + +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600) + +/* Echo back characters received during a serial download */ +#define CONFIG_LOADS_ECHO + +/* Allow a serial-download to temporarily change baud */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE + + +/* -------------------------------------------------------------------- */ + +/* PCI and PCI-Express Support */ +#define CONFIG_PCI /* Enable PCI/PCIE */ +#define CONFIG_PCI_PNP /* Scan PCI busses */ +#define CONFIG_CMD_PCI /* Enable the "pci" command */ +#define CONFIG_FSL_PCI_INIT /* Common FreeScale PCI initialization */ +#define CONFIG_FSL_PCIE_RESET /* We have PCI-E reset errata */ +#define CONFIG_SYS_PCI_64BIT /* PCI resources are 64-bit */ +#define CONFIG_PCI_SCAN_SHOW /* Display PCI scan during boot */ + +/* Enable 2 of the 3 PCI-E controllers */ +#define CONFIG_PCIE3 +#undef CONFIG_PCIE2 +#define CONFIG_PCIE1 + +/* Display human-readable names when initializing */ +#define CONFIG_SYS_PCIE3_NAME "Intel 82571EB" +#define CONFIG_SYS_PCIE2_NAME "Unused" +#define CONFIG_SYS_PCIE1_NAME "Silicon Image SIL3531" + +/* + * PCI bus addresses + * Memory space is mapped 1-1, but I/O space must start from 0. + */ +#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 +#else +#define CONFIG_SYS_PCIE3_MEM_BUS 0x80000000 +#define CONFIG_SYS_PCIE2_MEM_BUS 0xa0000000 +#define CONFIG_SYS_PCIE1_MEM_BUS 0xc0000000 +#endif + + +/* -------------------------------------------------------------------- */ + +/* Generic FreeScale hardware I2C support */ +#define CONFIG_HARD_I2C +#define CONFIG_FSL_I2C +#define CONFIG_CMD_I2C +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C2_OFFSET 0x3100 + +/* I2C bus configuration */ +#define CONFIG_SYS_I2C_SPEED 400000 +#define CONFIG_SYS_I2C_SLAVE 0x7F + +/* DDR2 SO-RDIMM SPD EEPROM is at I2C0-0x51 */ +#define CONFIG_SYS_SPD_BUS_NUM 0 +#define SPD_EEPROM_ADDRESS 0x51 + +/* DS1339 RTC is at I2C0-0x68 (I know it says "DS1337", it's a DS1339) */ +#define CONFIG_CMD_DATE +#define CONFIG_RTC_DS1337 +#define CONFIG_SYS_RTC_BUS_NUM 0 +#define CONFIG_SYS_I2C_RTC_ADDR 0x68 +/* Turn off RTC square-wave output to save battery */ +#define CONFIG_SYS_RTC_DS1337_NOOSC + +/* PCA9554 is at I2C1-0x3f (I know it says "PCA953X", it's a PCA9554) */ +#define CONFIG_PCA953X +#define CONFIG_CMD_PCA953X +#define CONFIG_CMD_PCA953X_INFO +#define CONFIG_SYS_I2C_PCA953X_ADDR 0x3f + + +/* -------------------------------------------------------------------- */ + +/* FreeScale DDR2/3 SDRAM Controller */ +#define CONFIG_FSL_DDR2 /* Our SDRAM slot is DDR2 */ +#define CONFIG_DDR_ECC /* Enable ECC by default */ +#define CONFIG_DDR_SPD /* Detect DDR config from SPD EEPROM */ +#define CONFIG_SPD_EEPROM /* ...why 2 config variables for this? */ +#define CONFIG_VERY_BIG_RAM /* Allow 2GB+ of RAM */ +#define CONFIG_CMD_SDRAM + +/* Standard P2020 DDR controller parameters */ +#define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +#define CONFIG_CHIP_SELECTS_PER_CTRL 2 + +/* Make sure to tell the DDR controller to preinitialze all of RAM */ +#define CONFIG_MEM_INIT_VALUE 0xDEADBEEF +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER + + +/* -------------------------------------------------------------------- */ + +/* FLASH Memory Configuration (2x 128MB SPANSION FLASH) */ +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_AMD_CHECK_DQ7 + +/* Flash banks (2x 128MB) */ +#define FLASH0_PHYS (CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000ull) +#define FLASH1_PHYS (CONFIG_SYS_FLASH_BASE_PHYS + 0x0000000ull) +#define CONFIG_SYS_MAX_FLASH_BANKS 2 +#define CONFIG_SYS_MAX_FLASH_SECT 1024 +#define CONFIG_SYS_FLASH_BANKS_LIST { FLASH0_PHYS, FLASH1_PHYS } + +/* + * Flash access modes and timings (values are the defaults after a RESET). + * + * NOTE: These could probably be optimized but are more than sufficient for + * this particular system for the moment. + */ +#define FLASH_BRx (BR_PS_16 | BR_MS_GPCM | BR_V) +#define FLASH_ORx (OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 | OR_GPCM_TRLX | OR_GPCM_EHTR | OR_GPCM_EAD) + +/* Configure both flash banks */ +#define CONFIG_SYS_BR0_PRELIM (FLASH_BRx | BR_PHYS_ADDR(FLASH0_PHYS)) +#define CONFIG_SYS_BR1_PRELIM (FLASH_BRx | BR_PHYS_ADDR(FLASH1_PHYS)) +#define CONFIG_SYS_OR0_PRELIM (FLASH_ORx | OR_AM_128MB) +#define CONFIG_SYS_OR1_PRELIM (FLASH_ORx | OR_AM_128MB) + +/* Flash timeouts (in ms) */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000UL /* Erase (60s) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500UL /* Write (0.5s) */ + +/* Quiet flash testing */ +#define CONFIG_SYS_FLASH_QUIET_TEST + +/* Make program/erase count down from 45/5 (9....8....7....) */ +#define CONFIG_FLASH_SHOW_PROGRESS 45 + + +/* -------------------------------------------------------------------- */ + +/* Ethernet Device Support */ +#define CONFIG_NET_MULTI /* We have multiple devices */ +#define CONFIG_MII /* Enable MII PHY code */ +#define CONFIG_MII_DEFAULT_TSEC /* ??? Copied from P2020DS */ +#define CONFIG_PHY_GIGE /* Support Gigabit PHYs */ +#define CONFIG_ETHPRIME "e1000#0" /* Default to external ports */ + +/* Turn on various helpful networking commands */ +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET +#define CONFIG_CMD_PING + +/* On-chip FreeScale P2020 "tsec" Ethernet (oneway fibers and peer) */ +#define CONFIG_TSEC_ENET +#define CONFIG_TSEC1 +#define CONFIG_TSEC2 +#define CONFIG_TSEC3 +#define CONFIG_TSEC1_NAME "owt0" +#define CONFIG_TSEC2_NAME "owt1" +#define CONFIG_TSEC3_NAME "peer" +#define TSEC1_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) +#define TSEC2_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) +#define TSEC3_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) +#define TSEC1_PHYIDX 0 +#define TSEC2_PHYIDX 0 +#define TSEC3_PHYIDX 0 +#define TSEC1_PHY_ADDR 2 +#define TSEC2_PHY_ADDR 3 +#define TSEC3_PHY_ADDR 4 +#define TSEC3_PHY_ADDR_CPUA 4 +#define TSEC3_PHY_ADDR_CPUB 5 + +/* PCI-E dual-port E1000 (external ethernet ports) */ +#define CONFIG_E1000 +#define CONFIG_E1000_SPI +#define CONFIG_CMD_E1000 + +/* We need the SPI infrastructure to poke the E1000's EEPROM */ +#define CONFIG_SPI +#define CONFIG_SPI_X +#define CONFIG_CMD_SPI +#define MAX_SPI_BYTES 32 + + +/* -------------------------------------------------------------------- */ + +/* USB Thumbdrive Device Support */ +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_FSL +#define CONFIG_USB_STORAGE +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET +#define CONFIG_CMD_USB + +/* Partition and Filesystem support */ +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT + + +/* -------------------------------------------------------------------- */ + +/* Command line configuration. */ +#define CONFIG_CMDLINE_EDITING /* Enable command editing */ +#define CONFIG_COMMAND_HISTORY /* Enable command history */ +#define CONFIG_AUTO_COMPLETE /* Enable command completion */ +#define CONFIG_SYS_LONGHELP /* Enable detailed command help */ +#define CONFIG_SYS_MAXARGS 128 /* Up to 128 command-line args */ +#define CONFIG_SYS_PBSIZE 8192 /* Allow up to 8k printed lines */ +#define CONFIG_SYS_CBSIZE 4096 /* Allow up to 4k command lines */ +#define CONFIG_SYS_BARGSIZE 4096 /* Allow up to 4k boot args */ +#define CONFIG_SYS_HUSH_PARSER /* Enable a fancier shell */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " /* Command-line continuation */ + +/* A little extra magic here for the prompt */ +#define CONFIG_SYS_PROMPT hww1u1a_get_ps1() +#ifndef __ASSEMBLY__ +const char *hww1u1a_get_ps1(void); +#endif + +/* Include a bunch of default commands we probably want */ +#include <config_cmd_default.h> + +/* Other helpful shell-like commands */ +#define CONFIG_MD5 +#define CONFIG_SHA1 +#define CONFIG_CMD_MD5SUM +#define CONFIG_CMD_SHA1 +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_SETEXPR + + +/* -------------------------------------------------------------------- */ + +/* Image manipulation and booting */ + +/* We use the OpenFirmware-esque "Flattened Device Tree" */ +#define CONFIG_OF_LIBFDT +#define CONFIG_OF_BOARD_SETUP +#define CONFIG_OF_STDOUT_VIA_ALIAS + +/* + * For booting Linux, the board info and command line data + * have to be in the first 16 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_CMD_ELF +#define CONFIG_SYS_BOOTMAPSZ 0x1000000 /* Maximum kernel memory map */ +#define CONFIG_SYS_BOOTM_LEN 0x1000000 /* Maximum kernel size of 16MB */ + +/* This is the default address for commands with an optional address arg */ +#define CONFIG_LOADADDR 100000 +#define CONFIG_SYS_LOAD_ADDR 0x100000 + +#define CONFIG_BOOTDELAY 20 +#define CONFIG_BOOTCOMMAND "echo Not yet flashed" +#define CONFIG_BOOTARGS "" +#define CONFIG_BOOTARGS_DYNAMIC "console=ttyS0,${baudrate}n1" + +/* Extra environment parameters */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "preboot=setenv bootargs "${bootargs} "CONFIG_BOOTARGS_DYNAMIC""\0" \ + "perf_mode=stable\0" \ + "memctl_intlv_ctl=2\0" \ + "flkernel=0xe8020000\0" \ + "flinitramfs=0xe8800000\0" \ + "fldevicetree=0xeff20000\0" \ + "flbootm=bootm ${flkernel} ${flinitramfs} ${fldevicetree}\0" \ + "flboot=run preboot; run flbootm\0" + +#endif /* __CONFIG_H */
- DO-160 certified for passenger aircraft (noncritical)
- TEMPEST ceritified for RED/BLACK separation
- 3 zones per chassis, 2 computers per zone (total of 6)
- Dual-core 1.066GHz P2020 per computer
- One 2GB DDR2 SO-RDIMM module per computer (upgradable to 4GB)
- Removable 80GB or 160GB Intel X18-M SSD per computer
- Front-accessible dual-port E1000E per computer
- Front-accessible serial console per computer
- Front-accessible USB port per computer
- Internal Gigabit crossover within each TEMPEST zone
- Internal unidirectional fiber links across TEMPEST zones
- Battery-backed DS1339 I2C RTC on each CPU.
Additional notes:
1. pending other dependent patches 2. re-spin against latest HEAD
- k
Kumar Gala
Kyle Moffett
