[PATCH 1/1] config: qemu: relax print and console buffer size
QEMU print and console buffer sizes have been restricted on QEMU below their default values.
One of the side effects of the print buffer size restriction is output truncation of the 'efidebug dh' command.
As QEMU does not have special memory size restrictions remove the settings from the defconfig files and go with the generic defaults.
Fixes: d0ee7f295d74 ("Convert CONFIG_SYS_PBSIZE to Kconfig") Fixes: d31466b382dd ("Convert CONFIG_SYS_CBSIZE to Kconfig") Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- configs/qemu-ppce500_defconfig | 1 - configs/qemu-riscv32_defconfig | 2 -- configs/qemu-riscv32_smode_defconfig | 2 -- configs/qemu-riscv32_spl_defconfig | 2 -- configs/qemu-riscv64_defconfig | 2 -- configs/qemu-riscv64_smode_defconfig | 2 -- configs/qemu-riscv64_spl_defconfig | 2 -- configs/qemu-x86_64_defconfig | 1 - configs/qemu-x86_defconfig | 1 - configs/qemu_arm64_defconfig | 2 -- configs/qemu_arm_defconfig | 2 -- 11 files changed, 19 deletions(-)
diff --git a/configs/qemu-ppce500_defconfig b/configs/qemu-ppce500_defconfig index fbe84d5702..de7267e228 100644 --- a/configs/qemu-ppce500_defconfig +++ b/configs/qemu-ppce500_defconfig @@ -21,7 +21,6 @@ CONFIG_BOOTCOMMAND="test -n "$qemu_kernel_addr" && bootm $qemu_kernel_addr - $ # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_LAST_STAGE_INIT=y CONFIG_HUSH_PARSER=y -CONFIG_SYS_PBSIZE=276 CONFIG_CMD_REGINFO=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/qemu-riscv32_defconfig b/configs/qemu-riscv32_defconfig index 9ace68e73f..cf74a48ea2 100644 --- a/configs/qemu-riscv32_defconfig +++ b/configs/qemu-riscv32_defconfig @@ -12,8 +12,6 @@ CONFIG_FIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y -CONFIG_SYS_CBSIZE=256 -CONFIG_SYS_PBSIZE=276 CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_BOOTEFI_SELFTEST=y CONFIG_CMD_NVEDIT_EFI=y diff --git a/configs/qemu-riscv32_smode_defconfig b/configs/qemu-riscv32_smode_defconfig index 0c7389e2f9..aeef2f35b0 100644 --- a/configs/qemu-riscv32_smode_defconfig +++ b/configs/qemu-riscv32_smode_defconfig @@ -13,8 +13,6 @@ CONFIG_FIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y -CONFIG_SYS_CBSIZE=256 -CONFIG_SYS_PBSIZE=276 CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_BOOTEFI_SELFTEST=y CONFIG_CMD_NVEDIT_EFI=y diff --git a/configs/qemu-riscv32_spl_defconfig b/configs/qemu-riscv32_spl_defconfig index e63d6fd934..db9c971c2f 100644 --- a/configs/qemu-riscv32_spl_defconfig +++ b/configs/qemu-riscv32_spl_defconfig @@ -19,8 +19,6 @@ CONFIG_DISPLAY_BOARDINFO=y CONFIG_SPL_MAX_SIZE=0x100000 CONFIG_SPL_BSS_START_ADDR=0x84000000 CONFIG_SPL_SYS_MALLOC=y -CONFIG_SYS_CBSIZE=256 -CONFIG_SYS_PBSIZE=276 CONFIG_SYS_BOOTM_LEN=0x4000000 # CONFIG_CMD_MII is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/qemu-riscv64_defconfig b/configs/qemu-riscv64_defconfig index 9a8bbef192..9fb40b22f9 100644 --- a/configs/qemu-riscv64_defconfig +++ b/configs/qemu-riscv64_defconfig @@ -12,8 +12,6 @@ CONFIG_FIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y -CONFIG_SYS_CBSIZE=256 -CONFIG_SYS_PBSIZE=276 CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_BOOTEFI_SELFTEST=y CONFIG_CMD_NVEDIT_EFI=y diff --git a/configs/qemu-riscv64_smode_defconfig b/configs/qemu-riscv64_smode_defconfig index 1d0f021ade..e3b123ca4d 100644 --- a/configs/qemu-riscv64_smode_defconfig +++ b/configs/qemu-riscv64_smode_defconfig @@ -15,8 +15,6 @@ CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="setenv fdt_addr ${fdtcontroladdr}; fdt addr ${fdtcontroladdr};" CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y -CONFIG_SYS_CBSIZE=256 -CONFIG_SYS_PBSIZE=276 CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_BOOTEFI_SELFTEST=y CONFIG_CMD_NVEDIT_EFI=y diff --git a/configs/qemu-riscv64_spl_defconfig b/configs/qemu-riscv64_spl_defconfig index b048bb8aed..d6bf3130fe 100644 --- a/configs/qemu-riscv64_spl_defconfig +++ b/configs/qemu-riscv64_spl_defconfig @@ -18,8 +18,6 @@ CONFIG_DISPLAY_BOARDINFO=y CONFIG_SPL_MAX_SIZE=0x100000 CONFIG_SPL_BSS_START_ADDR=0x84000000 CONFIG_SPL_SYS_MALLOC=y -CONFIG_SYS_CBSIZE=256 -CONFIG_SYS_PBSIZE=276 CONFIG_SYS_BOOTM_LEN=0x4000000 # CONFIG_CMD_MII is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/qemu-x86_64_defconfig b/configs/qemu-x86_64_defconfig index f02e9125a6..2ff49fbd6a 100644 --- a/configs/qemu-x86_64_defconfig +++ b/configs/qemu-x86_64_defconfig @@ -46,7 +46,6 @@ CONFIG_SPL_NET=y CONFIG_SPL_PCI=y CONFIG_SPL_PCH=y CONFIG_SPL_RTC=y -CONFIG_SYS_PBSIZE=532 CONFIG_CMD_CPU=y CONFIG_CMD_BOOTEFI_SELFTEST=y CONFIG_CMD_NVEDIT_EFI=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 4b2787d4aa..246ac6b6b8 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -24,7 +24,6 @@ CONFIG_LOG=y CONFIG_LOGF_FUNC=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_PCI_INIT_R=y -CONFIG_SYS_PBSIZE=532 CONFIG_CMD_CPU=y CONFIG_CMD_BOOTEFI_SELFTEST=y CONFIG_CMD_NVEDIT_EFI=y diff --git a/configs/qemu_arm64_defconfig b/configs/qemu_arm64_defconfig index 5fdf496a45..c010c25a92 100644 --- a/configs/qemu_arm64_defconfig +++ b/configs/qemu_arm64_defconfig @@ -27,8 +27,6 @@ CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_PCI_INIT_R=y -CONFIG_SYS_CBSIZE=512 -CONFIG_SYS_PBSIZE=532 CONFIG_CMD_BOOTZ=y CONFIG_CMD_BOOTEFI_SELFTEST=y CONFIG_CMD_NVEDIT_EFI=y diff --git a/configs/qemu_arm_defconfig b/configs/qemu_arm_defconfig index 1347b86f34..9cc1f5f7c4 100644 --- a/configs/qemu_arm_defconfig +++ b/configs/qemu_arm_defconfig @@ -28,8 +28,6 @@ CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_PCI_INIT_R=y -CONFIG_SYS_CBSIZE=512 -CONFIG_SYS_PBSIZE=532 CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_BOOTEFI_SELFTEST=y CONFIG_CMD_NVEDIT_EFI=y
On Mon, 16 Oct 2023 at 15:55, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Fixes: d0ee7f295d74 ("Convert CONFIG_SYS_PBSIZE to Kconfig") Fixes: d31466b382dd ("Convert CONFIG_SYS_CBSIZE to Kconfig") Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Reviewed-by: Simon Glass sjg@chromium.org
