[U-Boot] [PATCH v3] bootvx_fdt: fix missing 'fdt_fixup_ethernet(...)' on vxWorks boot
Before commit 26d6119 (fdt: Move fdt_fixup_ethernet to a common place) the fdt_fixup_ethernet(...) was called during do_bootvx_fdt(...).
Afterwards the only (common) place for this fixup is during image_setup_libfdt(...) and this is only called, at least on ARM platform, from image_setup_linux(...).
All this ends up in the fact, that the fdt_fixup_ethernet(...) is only called on booting a linux image and not on booting a vxWorks image.
We fix this with adding the fdt_fixup_ethernet(...) call again to do_bootvx_fdt(...)
Signed-off-by: Hannes Schmelzer oe5hpm@oevsv.at
Changes in v3: - cosmetic changes (coding style)
Changes in v2: - restore original behaviour from b3b522f247d3f19c4f2309ab0e6a02b3dd82de45 with moving the fdt_fixup_ethernet(...) call after boot_relocate_fdt(...)
common/bootm_os.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/common/bootm_os.c b/common/bootm_os.c index 1feea8a..31b1878 100644 --- a/common/bootm_os.c +++ b/common/bootm_os.c @@ -276,6 +276,9 @@ void do_bootvx_fdt(bootm_headers_t *images) if (ret) return;
+ /* Update ethernet nodes */ + fdt_fixup_ethernet(*of_flat_tree); + ret = fdt_add_subnode(*of_flat_tree, 0, "chosen"); if ((ret >= 0 || ret == -FDT_ERR_EXISTS)) { bootline = env_get("bootargs");
Changes in v3:
Changes in v2:
Signed-off-by: Hannes Schmelzer oe5hpm@oevsv.at Reviewed-by: Bin Meng bmeng.cn@gmail.com
Bin Meng
Hannes Schmelzer
