[U-Boot] [PATCH v2 0/9] Add STM32H7 SoC, Discovery and Evaluation board support
This series adds support for STM32H7 SoCs series and its Discovery and Evaluation board
For more detailed information please visit: www.st.com/en/microcontrollers/stm32h7-series.html
v2:_ add stm32h743 Evaluation board support _ squash all DTS patches which did specific adpatation for U-boot _ reword the board description in patches 6 and 7 _ use separate file stm32h7-u-boot.dtsi for "u-boot,dm-pre-reloc" property _ get memory address and size from DT in board file _ rework clock driver for stm32h743: _ merge peripheral and kernel clocks arrays _ add voltage scaling support needed for evaluation board
Christophe Kerello (1): dm: misc: add stm32 rcc driver
Patrice Chotard (8): pinctrl: stm32: add stm32h743-pinctrl compatible serial: stm32x7: add STM32H7 support dm: clk: add clk driver support for stm32h7 SoCs dm: reset: add stm32 reset driver ARM: DTS: stm32: add stm32h743i-disco files ARM: DTS: stm32: add stm32h743i-eval files ARM: DTS: stm32: adapt stm32h7 dts files for U-boot board: Add stm32h7 SoC, discovery and evaluation boards support
arch/arm/dts/Makefile | 2 + arch/arm/dts/stm32h7-u-boot.dtsi | 88 ++ arch/arm/dts/stm32h743-pinctrl.dtsi | 249 ++++ arch/arm/dts/stm32h743.dtsi | 129 ++ arch/arm/dts/stm32h743i-disco.dts | 100 ++ arch/arm/dts/stm32h743i-eval.dts | 100 ++ arch/arm/include/asm/arch-stm32h7/gpio.h | 126 ++ arch/arm/include/asm/arch-stm32h7/stm32.h | 21 + arch/arm/mach-stm32/Kconfig | 17 + arch/arm/mach-stm32/Makefile | 1 + arch/arm/mach-stm32/stm32h7/Kconfig | 12 + arch/arm/mach-stm32/stm32h7/Makefile | 8 + arch/arm/mach-stm32/stm32h7/soc.c | 59 + board/st/stm32h743-disco/Kconfig | 19 + board/st/stm32h743-disco/MAINTAINERS | 7 + board/st/stm32h743-disco/Makefile | 8 + board/st/stm32h743-disco/stm32h743-disco.c | 56 + board/st/stm32h743-eval/Kconfig | 19 + board/st/stm32h743-eval/MAINTAINERS | 6 + board/st/stm32h743-eval/Makefile | 8 + board/st/stm32h743-eval/stm32h743-eval.c | 56 + configs/stm32h743-disco_defconfig | 30 + configs/stm32h743-eval_defconfig | 30 + doc/device-tree-bindings/clock/st,stm32h7-rcc.txt | 152 ++ doc/device-tree-bindings/reset/st,stm32-rcc.txt | 6 + drivers/clk/Makefile | 1 + drivers/clk/clk_stm32h7.c | 802 ++++++++++ drivers/misc/Kconfig | 9 + drivers/misc/Makefile | 1 + drivers/misc/stm32_rcc.c | 45 + drivers/pinctrl/pinctrl_stm32.c | 1 + drivers/reset/Kconfig | 7 + drivers/reset/Makefile | 1 + drivers/reset/stm32-reset.c | 80 + drivers/serial/Kconfig | 7 +- drivers/serial/serial_stm32x7.c | 2 + include/configs/stm32h743-disco.h | 51 + include/configs/stm32h743-eval.h | 51 + include/dt-bindings/clock/stm32h7-clks.h | 167 +++ include/dt-bindings/memory/stm32-sdram.h | 7 + include/dt-bindings/mfd/stm32h7-rcc.h | 138 ++ include/dt-bindings/pinctrl/stm32h7-pinfunc.h | 1612 +++++++++++++++++++++ 42 files changed, 4288 insertions(+), 3 deletions(-) create mode 100644 arch/arm/dts/stm32h7-u-boot.dtsi create mode 100644 arch/arm/dts/stm32h743-pinctrl.dtsi create mode 100644 arch/arm/dts/stm32h743.dtsi create mode 100644 arch/arm/dts/stm32h743i-disco.dts create mode 100644 arch/arm/dts/stm32h743i-eval.dts create mode 100644 arch/arm/include/asm/arch-stm32h7/gpio.h create mode 100644 arch/arm/include/asm/arch-stm32h7/stm32.h create mode 100644 arch/arm/mach-stm32/stm32h7/Kconfig create mode 100644 arch/arm/mach-stm32/stm32h7/Makefile create mode 100644 arch/arm/mach-stm32/stm32h7/soc.c create mode 100644 board/st/stm32h743-disco/Kconfig create mode 100644 board/st/stm32h743-disco/MAINTAINERS create mode 100644 board/st/stm32h743-disco/Makefile create mode 100644 board/st/stm32h743-disco/stm32h743-disco.c create mode 100644 board/st/stm32h743-eval/Kconfig create mode 100644 board/st/stm32h743-eval/MAINTAINERS create mode 100644 board/st/stm32h743-eval/Makefile create mode 100644 board/st/stm32h743-eval/stm32h743-eval.c create mode 100644 configs/stm32h743-disco_defconfig create mode 100644 configs/stm32h743-eval_defconfig create mode 100644 doc/device-tree-bindings/clock/st,stm32h7-rcc.txt create mode 100644 doc/device-tree-bindings/reset/st,stm32-rcc.txt create mode 100644 drivers/clk/clk_stm32h7.c create mode 100644 drivers/misc/stm32_rcc.c create mode 100644 drivers/reset/stm32-reset.c create mode 100644 include/configs/stm32h743-disco.h create mode 100644 include/configs/stm32h743-eval.h create mode 100644 include/dt-bindings/clock/stm32h7-clks.h create mode 100644 include/dt-bindings/mfd/stm32h7-rcc.h create mode 100644 include/dt-bindings/pinctrl/stm32h7-pinfunc.h
STM32H7 SoCs uses the same pinctrl block as found into STM32F7 SoCs
Signed-off-by: Patrice Chotard patrice.chotard@st.com --- drivers/pinctrl/pinctrl_stm32.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/pinctrl/pinctrl_stm32.c b/drivers/pinctrl/pinctrl_stm32.c index fb2593c..bf2a86c 100644 --- a/drivers/pinctrl/pinctrl_stm32.c +++ b/drivers/pinctrl/pinctrl_stm32.c @@ -183,6 +183,7 @@ static struct pinctrl_ops stm32_pinctrl_ops = {
static const struct udevice_id stm32_pinctrl_ids[] = { { .compatible = "st,stm32f746-pinctrl" }, + { .compatible = "st,stm32h743-pinctrl" }, { } };
Reviewed-by: Vikas Manocha vikas.manocha@st.com
- { .compatible = "st,stm32h743-pinctrl" }, { }
Signed-off-by: Patrice Chotard patrice.chotard@st.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Vikas Manocha vikas.manocha@st.com
STM32F7 and STM32H7 shares the same UART block, add STM32H7 compatible string.
Signed-off-by: Patrice Chotard patrice.chotard@st.com --- drivers/serial/Kconfig | 7 ++++--- drivers/serial/serial_stm32x7.c | 2 ++ 2 files changed, 6 insertions(+), 3 deletions(-)
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index aeed538..0775d95 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -524,10 +524,11 @@ config STI_ASC_SERIAL
config STM32X7_SERIAL bool "STMicroelectronics STM32 SoCs on-chip UART" - depends on DM_SERIAL && STM32F7 + depends on DM_SERIAL && (STM32F7 || STM32H7) help - If you have a machine based on a STM32 F7 you can enable its - onboard serial ports, say Y to this option. If unsure, say N. + If you have a machine based on a STM32 F7 or H7 SoC you can + enable its onboard serial ports, say Y to this option. + If unsure, say N.
config MPC8XX_CONS bool "Console driver for MPC8XX" diff --git a/drivers/serial/serial_stm32x7.c b/drivers/serial/serial_stm32x7.c index bf118a7..2f4eafa 100644 --- a/drivers/serial/serial_stm32x7.c +++ b/drivers/serial/serial_stm32x7.c @@ -112,6 +112,8 @@ static int stm32_serial_probe(struct udevice *dev) static const struct udevice_id stm32_serial_id[] = { {.compatible = "st,stm32f7-usart"}, {.compatible = "st,stm32f7-uart"}, + {.compatible = "st,stm32h7-usart"}, + {.compatible = "st,stm32h7-uart"}, {} };
Hi Patrice,
- depends on DM_SERIAL && (STM32F7 || STM32H7) help
If unsure, say N.
- {.compatible = "st,stm32h7-usart"},
- {.compatible = "st,stm32h7-uart"},
two compatibles are consuming space & time without adding any value.
Cheers, Vikas
Hi Vikas
On 09/19/2017 12:40 AM, Vikas Manocha wrote:
Hi Patrice,
If unsure, say N.
Agree, i will send a series to remove the "usart" compatible as this series has been already merged in u-boot/master
Thanks
Patrice
Cheers, Vikas
This driver implements basic clock setup, only clock gating is implemented.
This driver doesn't implement .of_match as it's binded by MFD RCC driver.
Files include/dt-bindings/clock/stm32h7-clks.h and doc/device-tree-bindings/clock/st,stm32h7-rcc.txt will be available soon in a kernel tag, as all the bindings have been acked by Rob Herring [1].
[1] http://lkml.iu.edu/hypermail/linux/kernel/1704.0/00935.html
Signed-off-by: Patrice Chotard patrice.chotard@st.com --- doc/device-tree-bindings/clock/st,stm32h7-rcc.txt | 152 ++++ drivers/clk/Makefile | 1 + drivers/clk/clk_stm32h7.c | 802 ++++++++++++++++++++++ include/dt-bindings/clock/stm32h7-clks.h | 167 +++++ 4 files changed, 1122 insertions(+) create mode 100644 doc/device-tree-bindings/clock/st,stm32h7-rcc.txt create mode 100644 drivers/clk/clk_stm32h7.c create mode 100644 include/dt-bindings/clock/stm32h7-clks.h
diff --git a/doc/device-tree-bindings/clock/st,stm32h7-rcc.txt b/doc/device-tree-bindings/clock/st,stm32h7-rcc.txt new file mode 100644 index 0000000..9d4b587 --- /dev/null +++ b/doc/device-tree-bindings/clock/st,stm32h7-rcc.txt @@ -0,0 +1,152 @@ +STMicroelectronics STM32H7 Reset and Clock Controller +===================================================== + +The RCC IP is both a reset and a clock controller. + +Please refer to clock-bindings.txt for common clock controller binding usage. +Please also refer to reset.txt for common reset controller binding usage. + +Required properties: +- compatible: Should be: + "st,stm32h743-rcc" + +- reg: should be register base and length as documented in the + datasheet + +- #reset-cells: 1, see below + +- #clock-cells : from common clock binding; shall be set to 1 + +- clocks: External oscillator clock phandle + - high speed external clock signal (HSE) + - low speed external clock signal (LSE) + - external I2S clock (I2S_CKIN) + +- st,syscfg: phandle for pwrcfg, mandatory to disable/enable backup domain + write protection (RTC clock). + +- pll x node: Allow to register a pll with specific parameters. + Please see PLL section below. + +Example: + + rcc: rcc@58024400 { + #reset-cells = <1>; + #clock-cells = <2> + compatible = "st,stm32h743-rcc", "st,stm32-rcc"; + reg = <0x58024400 0x400>; + clocks = <&clk_hse>, <&clk_lse>, <&clk_i2s_ckin>; + + st,syscfg = <&pwrcfg>; + + #address-cells = <1>; + #size-cells = <0>; + + vco1@58024430 { + #clock-cells = <0>; + compatible = "stm32,pll"; + reg = <0>; + }; + + vco2@58024438 { + #clock-cells = <0>; + compatible = "stm32,pll"; + reg = <1>; + st,clock-div = <2>; + st,clock-mult = <40>; + st,frac-status = <0>; + st,frac = <0>; + st,vcosel = <1>; + st,pllrge = <2>; + }; + }; + + +STM32H7 PLL +----------- + +The VCO of STM32 PLL could be reprensented like this: + + Vref --------- -------- + ---->| / DIVM |---->| x DIVN | ------> VCO + --------- -------- + ^ + | + ------- + | FRACN | + ------- + +When the PLL is configured in integer mode: +- VCO = ( Vref / DIVM ) * DIVN + +When the PLL is configured in fractional mode: +- VCO = ( Vref / DIVM ) * ( DIVN + FRACN / 2^13) + + +Required properties for pll node: +- compatible: Should be: + "stm32,pll" + +- #clock-cells: from common clock binding; shall be set to 0 +- reg: Should be the pll number. + +Optional properties: +- st,clock-div: DIVM division factor : <1..63> +- st,clock-mult: DIVN multiplication factor : <4..512> + +- st,frac-status: + - 0 Pll is configured in integer mode + - 1 Pll is configure in fractional mode + +- st,frac: Fractional part of the multiplication factor : <0..8191> + +- st,vcosel: VCO selection + - 0: Wide VCO range:192 to 836 MHz + - 1: Medium VCO range:150 to 420 MHz + +- st,pllrge: PLL input frequency range + - 0: The PLL input (Vref / DIVM) clock range frequency is between 1 and 2 MHz + - 1: The PLL input (Vref / DIVM) clock range frequency is between 2 and 4 MHz + - 2: The PLL input (Vref / DIVM) clock range frequency is between 4 and 8 MHz + - 3: The PLL input (Vref / DIVM) clock range frequency is between 8 and 16 MHz + + +The peripheral clock consumer should specify the desired clock by +having the clock ID in its "clocks" phandle cell. + +All available clocks are defined as preprocessor macros in +dt-bindings/clock/stm32h7-clks.h header and can be used in device +tree sources. + +Example: + + timer5: timer@40000c00 { + compatible = "st,stm32-timer"; + reg = <0x40000c00 0x400>; + interrupts = <50>; + clocks = <&rcc TIM5_CK>; + + }; + +Specifying softreset control of devices +======================================= + +Device nodes should specify the reset channel required in their "resets" +property, containing a phandle to the reset device node and an index specifying +which channel to use. +The index is the bit number within the RCC registers bank, starting from RCC +base address. +It is calculated as: index = register_offset / 4 * 32 + bit_offset. +Where bit_offset is the bit offset within the register. + +For example, for CRC reset: + crc = AHB4RSTR_offset / 4 * 32 + CRCRST_bit_offset = 0x88 / 4 * 32 + 19 = 1107 + +All available preprocessor macros for reset are defined dt-bindings//mfd/stm32h7-rcc.h +header and can be used in device tree sources. + +example: + + timer2 { + resets = <&rcc STM32H7_APB1L_RESET(TIM2)>; + }; diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index b773593..83fe88c 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -22,3 +22,4 @@ obj-$(CONFIG_CLK_BCM6345) += clk_bcm6345.o obj-$(CONFIG_CLK_BOSTON) += clk_boston.o obj-$(CONFIG_ARCH_ASPEED) += aspeed/ obj-$(CONFIG_STM32F7) += clk_stm32f7.o +obj-$(CONFIG_STM32H7) += clk_stm32h7.o diff --git a/drivers/clk/clk_stm32h7.c b/drivers/clk/clk_stm32h7.c new file mode 100644 index 0000000..fd0e3ab --- /dev/null +++ b/drivers/clk/clk_stm32h7.c @@ -0,0 +1,802 @@ +/* + * Copyright (C) STMicroelectronics SA 2017 + * Author(s): Patrice CHOTARD, patrice.chotard@st.com for STMicroelectronics. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <regmap.h> +#include <syscon.h> +#include <asm/io.h> +#include <dm/root.h> + +#include <dt-bindings/clock/stm32h7-clks.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* RCC CR specific definitions */ +#define RCC_CR_HSION BIT(0) +#define RCC_CR_HSIRDY BIT(2) + +#define RCC_CR_HSEON BIT(16) +#define RCC_CR_HSERDY BIT(17) +#define RCC_CR_HSEBYP BIT(18) +#define RCC_CR_PLL1ON BIT(24) +#define RCC_CR_PLL1RDY BIT(25) + +#define RCC_CR_HSIDIV_MASK GENMASK(4, 3) +#define RCC_CR_HSIDIV_SHIFT 3 + +#define RCC_CFGR_SW_MASK GENMASK(2, 0) +#define RCC_CFGR_SW_HSI 0 +#define RCC_CFGR_SW_CSI 1 +#define RCC_CFGR_SW_HSE 2 +#define RCC_CFGR_SW_PLL1 3 + +#define RCC_PLLCKSELR_PLLSRC_HSI 0 +#define RCC_PLLCKSELR_PLLSRC_CSI 1 +#define RCC_PLLCKSELR_PLLSRC_HSE 2 +#define RCC_PLLCKSELR_PLLSRC_NO_CLK 3 + +#define RCC_PLLCKSELR_PLLSRC_MASK GENMASK(1, 0) + +#define RCC_PLLCKSELR_DIVM1_SHIFT 4 +#define RCC_PLLCKSELR_DIVM1_MASK GENMASK(9, 4) + +#define RCC_PLL1DIVR_DIVN1_MASK GENMASK(8, 0) + +#define RCC_PLL1DIVR_DIVP1_SHIFT 9 +#define RCC_PLL1DIVR_DIVP1_MASK GENMASK(15, 9) + +#define RCC_PLL1DIVR_DIVQ1_SHIFT 16 +#define RCC_PLL1DIVR_DIVQ1_MASK GENMASK(22, 16) + +#define RCC_PLL1DIVR_DIVR1_SHIFT 24 +#define RCC_PLL1DIVR_DIVR1_MASK GENMASK(30, 24) + +#define RCC_PLL1FRACR_FRACN1_SHIFT 3 +#define RCC_PLL1FRACR_FRACN1_MASK GENMASK(15, 3) + +#define RCC_PLLCFGR_PLL1RGE_SHIFT 2 +#define PLL1RGE_1_2_MHZ 0 +#define PLL1RGE_2_4_MHZ 1 +#define PLL1RGE_4_8_MHZ 2 +#define PLL1RGE_8_16_MHZ 3 +#define RCC_PLLCFGR_DIVP1EN BIT(16) +#define RCC_PLLCFGR_DIVQ1EN BIT(17) +#define RCC_PLLCFGR_DIVR1EN BIT(18) + +#define RCC_D1CFGR_HPRE_MASK GENMASK(3, 0) +#define RCC_D1CFGR_HPRE_DIVIDED BIT(3) +#define RCC_D1CFGR_HPRE_DIVIDER GENMASK(2, 0) + +#define RCC_D1CFGR_HPRE_DIV2 8 + +#define RCC_D1CFGR_D1PPRE_SHIFT 4 +#define RCC_D1CFGR_D1PPRE_DIVIDED BIT(6) +#define RCC_D1CFGR_D1PPRE_DIVIDER GENMASK(5, 4) + +#define RCC_D1CFGR_D1CPRE_SHIFT 8 +#define RCC_D1CFGR_D1CPRE_DIVIDER GENMASK(10, 8) +#define RCC_D1CFGR_D1CPRE_DIVIDED BIT(11) + +#define RCC_D2CFGR_D2PPRE1_SHIFT 4 +#define RCC_D2CFGR_D2PPRE1_DIVIDED BIT(6) +#define RCC_D2CFGR_D2PPRE1_DIVIDER GENMASK(5, 4) + +#define RCC_D2CFGR_D2PPRE2_SHIFT 8 +#define RCC_D2CFGR_D2PPRE2_DIVIDED BIT(10) +#define RCC_D2CFGR_D2PPRE2_DIVIDER GENMASK(9, 8) + +#define RCC_D3CFGR_D3PPRE_SHIFT 4 +#define RCC_D3CFGR_D3PPRE_DIVIDED BIT(6) +#define RCC_D3CFGR_D3PPRE_DIVIDER GENMASK(5, 4) + +#define RCC_D1CCIPR_FMCSRC_MASK GENMASK(1, 0) +#define FMCSRC_HCLKD1 0 +#define FMCSRC_PLL1_Q_CK 1 +#define FMCSRC_PLL2_R_CK 2 +#define FMCSRC_PER_CK 3 + +#define RCC_D1CCIPR_QSPISRC_MASK GENMASK(5, 4) +#define RCC_D1CCIPR_QSPISRC_SHIFT 4 +#define QSPISRC_HCLKD1 0 +#define QSPISRC_PLL1_Q_CK 1 +#define QSPISRC_PLL2_R_CK 2 +#define QSPISRC_PER_CK 3 + +#define PWR_CR3 0x0c +#define PWR_CR3_SDEN BIT(2) +#define PWR_D3CR 0x18 +#define PWR_D3CR_VOS_MASK GENMASK(15, 14) +#define PWR_D3CR_VOS_SHIFT 14 +#define VOS_SCALE_3 1 +#define VOS_SCALE_2 2 +#define VOS_SCALE_1 3 +#define PWR_D3CR_VOSREADY BIT(13) + +struct stm32_rcc_regs { + u32 cr; /* 0x00 Source Control Register */ + u32 icscr; /* 0x04 Internal Clock Source Calibration Register */ + u32 crrcr; /* 0x08 Clock Recovery RC Register */ + u32 reserved1; /* 0x0c reserved */ + u32 cfgr; /* 0x10 Clock Configuration Register */ + u32 reserved2; /* 0x14 reserved */ + u32 d1cfgr; /* 0x18 Domain 1 Clock Configuration Register */ + u32 d2cfgr; /* 0x1c Domain 2 Clock Configuration Register */ + u32 d3cfgr; /* 0x20 Domain 3 Clock Configuration Register */ + u32 reserved3; /* 0x24 reserved */ + u32 pllckselr; /* 0x28 PLLs Clock Source Selection Register */ + u32 pllcfgr; /* 0x2c PLLs Configuration Register */ + u32 pll1divr; /* 0x30 PLL1 Dividers Configuration Register */ + u32 pll1fracr; /* 0x34 PLL1 Fractional Divider Register */ + u32 pll2divr; /* 0x38 PLL2 Dividers Configuration Register */ + u32 pll2fracr; /* 0x3c PLL2 Fractional Divider Register */ + u32 pll3divr; /* 0x40 PLL3 Dividers Configuration Register */ + u32 pll3fracr; /* 0x44 PLL3 Fractional Divider Register */ + u32 reserved4; /* 0x48 reserved */ + u32 d1ccipr; /* 0x4c Domain 1 Kernel Clock Configuration Register */ + u32 d2ccip1r; /* 0x50 Domain 2 Kernel Clock Configuration Register */ + u32 d2ccip2r; /* 0x54 Domain 2 Kernel Clock Configuration Register */ + u32 d3ccipr; /* 0x58 Domain 3 Kernel Clock Configuration Register */ + u32 reserved5; /* 0x5c reserved */ + u32 cier; /* 0x60 Clock Source Interrupt Enable Register */ + u32 cifr; /* 0x64 Clock Source Interrupt Flag Register */ + u32 cicr; /* 0x68 Clock Source Interrupt Clear Register */ + u32 reserved6; /* 0x6c reserved */ + u32 bdcr; /* 0x70 Backup Domain Control Register */ + u32 csr; /* 0x74 Clock Control and Status Register */ + u32 reserved7; /* 0x78 reserved */ + + u32 ahb3rstr; /* 0x7c AHB3 Peripheral Reset Register */ + u32 ahb1rstr; /* 0x80 AHB1 Peripheral Reset Register */ + u32 ahb2rstr; /* 0x84 AHB2 Peripheral Reset Register */ + u32 ahb4rstr; /* 0x88 AHB4 Peripheral Reset Register */ + + u32 apb3rstr; /* 0x8c APB3 Peripheral Reset Register */ + u32 apb1lrstr; /* 0x90 APB1 low Peripheral Reset Register */ + u32 apb1hrstr; /* 0x94 APB1 high Peripheral Reset Register */ + u32 apb2rstr; /* 0x98 APB2 Clock Register */ + u32 apb4rstr; /* 0x9c APB4 Clock Register */ + + u32 gcr; /* 0xa0 Global Control Register */ + u32 reserved8; /* 0xa4 reserved */ + u32 d3amr; /* 0xa8 D3 Autonomous mode Register */ + u32 reserved9[9];/* 0xac to 0xcc reserved */ + u32 rsr; /* 0xd0 Reset Status Register */ + u32 ahb3enr; /* 0xd4 AHB3 Clock Register */ + u32 ahb1enr; /* 0xd8 AHB1 Clock Register */ + u32 ahb2enr; /* 0xdc AHB2 Clock Register */ + u32 ahb4enr; /* 0xe0 AHB4 Clock Register */ + + u32 apb3enr; /* 0xe4 APB3 Clock Register */ + u32 apb1lenr; /* 0xe8 APB1 low Clock Register */ + u32 apb1henr; /* 0xec APB1 high Clock Register */ + u32 apb2enr; /* 0xf0 APB2 Clock Register */ + u32 apb4enr; /* 0xf4 APB4 Clock Register */ +}; + +#define RCC_AHB3ENR offsetof(struct stm32_rcc_regs, ahb3enr) +#define RCC_AHB1ENR offsetof(struct stm32_rcc_regs, ahb1enr) +#define RCC_AHB2ENR offsetof(struct stm32_rcc_regs, ahb2enr) +#define RCC_AHB4ENR offsetof(struct stm32_rcc_regs, ahb4enr) +#define RCC_APB3ENR offsetof(struct stm32_rcc_regs, apb3enr) +#define RCC_APB1LENR offsetof(struct stm32_rcc_regs, apb1lenr) +#define RCC_APB1HENR offsetof(struct stm32_rcc_regs, apb1henr) +#define RCC_APB2ENR offsetof(struct stm32_rcc_regs, apb2enr) +#define RCC_APB4ENR offsetof(struct stm32_rcc_regs, apb4enr) + +struct clk_cfg { + u32 gate_offset; + u8 gate_bit_idx; + const char *name; +}; + +#define CLK(_gate_offset, _bit_idx, _name) \ +{ \ + .gate_offset = _gate_offset,\ + .gate_bit_idx = _bit_idx,\ + .name = _name,\ +} + +/* + * the way all these entries are sorted in this array could seem + * unlogical, but we are dependant of kernel DT_bindings, + * where clocks are separate in 2 banks, peripheral clocks and + * kernel clocks. + */ + +static const struct clk_cfg clk_map[] = { + CLK(RCC_AHB3ENR, 31, "d1sram1"), /* peripheral clocks */ + CLK(RCC_AHB3ENR, 30, "itcm"), + CLK(RCC_AHB3ENR, 29, "dtcm2"), + CLK(RCC_AHB3ENR, 28, "dtcm1"), + CLK(RCC_AHB3ENR, 8, "flitf"), + CLK(RCC_AHB3ENR, 5, "jpgdec"), + CLK(RCC_AHB3ENR, 4, "dma2d"), + CLK(RCC_AHB3ENR, 0, "mdma"), + CLK(RCC_AHB1ENR, 28, "usb2ulpi"), + CLK(RCC_AHB1ENR, 17, "eth1rx"), + CLK(RCC_AHB1ENR, 16, "eth1tx"), + CLK(RCC_AHB1ENR, 15, "eth1mac"), + CLK(RCC_AHB1ENR, 14, "art"), + CLK(RCC_AHB1ENR, 26, "usb1ulpi"), + CLK(RCC_AHB1ENR, 1, "dma2"), + CLK(RCC_AHB1ENR, 0, "dma1"), + CLK(RCC_AHB2ENR, 31, "d2sram3"), + CLK(RCC_AHB2ENR, 30, "d2sram2"), + CLK(RCC_AHB2ENR, 29, "d2sram1"), + CLK(RCC_AHB2ENR, 5, "hash"), + CLK(RCC_AHB2ENR, 4, "crypt"), + CLK(RCC_AHB2ENR, 0, "camitf"), + CLK(RCC_AHB4ENR, 28, "bkpram"), + CLK(RCC_AHB4ENR, 25, "hsem"), + CLK(RCC_AHB4ENR, 21, "bdma"), + CLK(RCC_AHB4ENR, 19, "crc"), + CLK(RCC_AHB4ENR, 10, "gpiok"), + CLK(RCC_AHB4ENR, 9, "gpioj"), + CLK(RCC_AHB4ENR, 8, "gpioi"), + CLK(RCC_AHB4ENR, 7, "gpioh"), + CLK(RCC_AHB4ENR, 6, "gpiog"), + CLK(RCC_AHB4ENR, 5, "gpiof"), + CLK(RCC_AHB4ENR, 4, "gpioe"), + CLK(RCC_AHB4ENR, 3, "gpiod"), + CLK(RCC_AHB4ENR, 2, "gpioc"), + CLK(RCC_AHB4ENR, 1, "gpiob"), + CLK(RCC_AHB4ENR, 0, "gpioa"), + CLK(RCC_APB3ENR, 6, "wwdg1"), + CLK(RCC_APB1LENR, 29, "dac12"), + CLK(RCC_APB1LENR, 11, "wwdg2"), + CLK(RCC_APB1LENR, 8, "tim14"), + CLK(RCC_APB1LENR, 7, "tim13"), + CLK(RCC_APB1LENR, 6, "tim12"), + CLK(RCC_APB1LENR, 5, "tim7"), + CLK(RCC_APB1LENR, 4, "tim6"), + CLK(RCC_APB1LENR, 3, "tim5"), + CLK(RCC_APB1LENR, 2, "tim4"), + CLK(RCC_APB1LENR, 1, "tim3"), + CLK(RCC_APB1LENR, 0, "tim2"), + CLK(RCC_APB1HENR, 5, "mdios"), + CLK(RCC_APB1HENR, 4, "opamp"), + CLK(RCC_APB1HENR, 1, "crs"), + CLK(RCC_APB2ENR, 18, "tim17"), + CLK(RCC_APB2ENR, 17, "tim16"), + CLK(RCC_APB2ENR, 16, "tim15"), + CLK(RCC_APB2ENR, 1, "tim8"), + CLK(RCC_APB2ENR, 0, "tim1"), + CLK(RCC_APB4ENR, 26, "tmpsens"), + CLK(RCC_APB4ENR, 16, "rtcapb"), + CLK(RCC_APB4ENR, 15, "vref"), + CLK(RCC_APB4ENR, 14, "comp12"), + CLK(RCC_APB4ENR, 1, "syscfg"), + CLK(RCC_AHB3ENR, 16, "sdmmc1"), /* kernel clocks */ + CLK(RCC_AHB3ENR, 14, "quadspi"), + CLK(RCC_AHB3ENR, 12, "fmc"), + CLK(RCC_AHB1ENR, 27, "usb2otg"), + CLK(RCC_AHB1ENR, 25, "usb1otg"), + CLK(RCC_AHB1ENR, 5, "adc12"), + CLK(RCC_AHB2ENR, 9, "sdmmc2"), + CLK(RCC_AHB2ENR, 6, "rng"), + CLK(RCC_AHB4ENR, 24, "adc3"), + CLK(RCC_APB3ENR, 4, "dsi"), + CLK(RCC_APB3ENR, 3, "ltdc"), + CLK(RCC_APB1LENR, 31, "usart8"), + CLK(RCC_APB1LENR, 30, "usart7"), + CLK(RCC_APB1LENR, 27, "hdmicec"), + CLK(RCC_APB1LENR, 23, "i2c3"), + CLK(RCC_APB1LENR, 22, "i2c2"), + CLK(RCC_APB1LENR, 21, "i2c1"), + CLK(RCC_APB1LENR, 20, "uart5"), + CLK(RCC_APB1LENR, 19, "uart4"), + CLK(RCC_APB1LENR, 18, "usart3"), + CLK(RCC_APB1LENR, 17, "usart2"), + CLK(RCC_APB1LENR, 16, "spdifrx"), + CLK(RCC_APB1LENR, 15, "spi3"), + CLK(RCC_APB1LENR, 14, "spi2"), + CLK(RCC_APB1LENR, 9, "lptim1"), + CLK(RCC_APB1HENR, 8, "fdcan"), + CLK(RCC_APB1HENR, 2, "swp"), + CLK(RCC_APB2ENR, 29, "hrtim"), + CLK(RCC_APB2ENR, 28, "dfsdm1"), + CLK(RCC_APB2ENR, 24, "sai3"), + CLK(RCC_APB2ENR, 23, "sai2"), + CLK(RCC_APB2ENR, 22, "sai1"), + CLK(RCC_APB2ENR, 20, "spi5"), + CLK(RCC_APB2ENR, 13, "spi4"), + CLK(RCC_APB2ENR, 12, "spi1"), + CLK(RCC_APB2ENR, 5, "usart6"), + CLK(RCC_APB2ENR, 4, "usart1"), + CLK(RCC_APB4ENR, 21, "sai4a"), + CLK(RCC_APB4ENR, 21, "sai4b"), + CLK(RCC_APB4ENR, 12, "lptim5"), + CLK(RCC_APB4ENR, 11, "lptim4"), + CLK(RCC_APB4ENR, 10, "lptim3"), + CLK(RCC_APB4ENR, 9, "lptim2"), + CLK(RCC_APB4ENR, 7, "i2c4"), + CLK(RCC_APB4ENR, 5, "spi6"), + CLK(RCC_APB4ENR, 3, "lpuart1"), +}; + +struct stm32_clk { + struct stm32_rcc_regs *rcc_base; + struct regmap *pwr_regmap; +}; + +struct pll_psc { + u8 divm; + u16 divn; + u8 divp; + u8 divq; + u8 divr; +}; + +/* + * OSC_HSE = 25 MHz + * VCO = 500MHz + * pll1_p = 250MHz / pll1_q = 250MHz pll1_r = 250Mhz + */ +struct pll_psc sys_pll_psc = { + .divm = 4, + .divn = 80, + .divp = 2, + .divq = 2, + .divr = 2, +}; + +int configure_clocks(struct udevice *dev) +{ + struct stm32_clk *priv = dev_get_priv(dev); + struct stm32_rcc_regs *regs = priv->rcc_base; + uint8_t *pwr_base = (uint8_t *)regmap_get_range(priv->pwr_regmap, 0); + uint32_t pllckselr = 0; + uint32_t pll1divr = 0; + uint32_t pllcfgr = 0; + + /* Switch on HSI */ + setbits_le32(®s->cr, RCC_CR_HSION); + while (!(readl(®s->cr) & RCC_CR_HSIRDY)) + ; + + /* Reset CFGR, now HSI is the default system clock */ + writel(0, ®s->cfgr); + + /* Set all kernel domain clock registers to reset value*/ + writel(0x0, ®s->d1ccipr); + writel(0x0, ®s->d2ccip1r); + writel(0x0, ®s->d2ccip2r); + + /* Set voltage scaling at scale 1 */ + clrsetbits_le32(pwr_base + PWR_D3CR, PWR_D3CR_VOS_MASK, + VOS_SCALE_1 << PWR_D3CR_VOS_SHIFT); + /* disable step down converter */ + clrbits_le32(pwr_base + PWR_CR3, PWR_CR3_SDEN); + while (!(readl(pwr_base + PWR_D3CR) & PWR_D3CR_VOSREADY)) + ; + + /* disable HSE to configure it */ + clrbits_le32(®s->cr, RCC_CR_HSEON); + while ((readl(®s->cr) & RCC_CR_HSERDY)) + ; + + /* clear HSE bypass and set it ON */ + clrbits_le32(®s->cr, RCC_CR_HSEBYP); + /* Switch on HSE */ + setbits_le32(®s->cr, RCC_CR_HSEON); + while (!(readl(®s->cr) & RCC_CR_HSERDY)) + ; + + /* pll setup, disable it */ + clrbits_le32(®s->cr, RCC_CR_PLL1ON); + while ((readl(®s->cr) & RCC_CR_PLL1RDY)) + ; + + /* Select HSE as PLL clock source */ + pllckselr |= RCC_PLLCKSELR_PLLSRC_HSE; + pllckselr |= sys_pll_psc.divm << RCC_PLLCKSELR_DIVM1_SHIFT; + writel(pllckselr, ®s->pllckselr); + + pll1divr |= (sys_pll_psc.divr - 1) << RCC_PLL1DIVR_DIVR1_SHIFT; + pll1divr |= (sys_pll_psc.divq - 1) << RCC_PLL1DIVR_DIVQ1_SHIFT; + pll1divr |= (sys_pll_psc.divp - 1) << RCC_PLL1DIVR_DIVP1_SHIFT; + pll1divr |= (sys_pll_psc.divn - 1); + writel(pll1divr, ®s->pll1divr); + + pllcfgr |= PLL1RGE_4_8_MHZ << RCC_PLLCFGR_PLL1RGE_SHIFT; + pllcfgr |= RCC_PLLCFGR_DIVP1EN; + pllcfgr |= RCC_PLLCFGR_DIVQ1EN; + pllcfgr |= RCC_PLLCFGR_DIVR1EN; + writel(pllcfgr, ®s->pllcfgr); + + /* pll setup, enable it */ + setbits_le32(®s->cr, RCC_CR_PLL1ON); + + /* set HPRE (/2) DI clk --> 125MHz */ + clrsetbits_le32(®s->d1cfgr, RCC_D1CFGR_HPRE_MASK, + RCC_D1CFGR_HPRE_DIV2); + + /* select PLL1 as system clock source (sys_ck)*/ + clrsetbits_le32(®s->cfgr, RCC_CFGR_SW_MASK, RCC_CFGR_SW_PLL1); + while ((readl(®s->cfgr) & RCC_CFGR_SW_MASK) != RCC_CFGR_SW_PLL1) + ; + + /* sdram: use pll1_q as fmc_k clk */ + clrsetbits_le32(®s->d1ccipr, RCC_D1CCIPR_FMCSRC_MASK, + FMCSRC_PLL1_Q_CK); + + return 0; +} + +static u32 stm32_get_HSI_divider(struct stm32_rcc_regs *regs) +{ + u32 divider; + + /* get HSI divider value */ + divider = readl(®s->cr) & RCC_CR_HSIDIV_MASK; + divider = divider >> RCC_CR_HSIDIV_SHIFT; + + return divider; +}; + +enum pllsrc { + HSE, + LSE, + HSI, + CSI, + I2S, + TIMER, + PLLSRC_NB, +}; + +static const char * const pllsrc_name[PLLSRC_NB] = { + [HSE] = "clk-hse", + [LSE] = "clk-lse", + [HSI] = "clk-hsi", + [CSI] = "clk-csi", + [I2S] = "clk-i2s", + [TIMER] = "timer-clk" +}; + +static ulong stm32_get_rate(struct stm32_rcc_regs *regs, enum pllsrc pllsrc) +{ + struct clk clk; + struct udevice *fixed_clock_dev = NULL; + u32 divider; + int ret; + const char *name = pllsrc_name[pllsrc]; + + debug("%s name %s\n", __func__, name); + + clk.id = 0; + ret = uclass_get_device_by_name(UCLASS_CLK, name, &fixed_clock_dev); + if (ret) { + error("Can't find clk %s (%d)", name, ret); + return 0; + } + + ret = clk_request(fixed_clock_dev, &clk); + if (ret) { + error("Can't request %s clk (%d)", name, ret); + return 0; + } + + divider = 0; + if (pllsrc == HSI) + divider = stm32_get_HSI_divider(regs); + + debug("%s divider %d rate %ld\n", __func__, + divider, clk_get_rate(&clk)); + + return clk_get_rate(&clk) >> divider; +}; + +enum pll1_output { + PLL1_P_CK, + PLL1_Q_CK, + PLL1_R_CK, +}; + +static u32 stm32_get_PLL1_rate(struct stm32_rcc_regs *regs, + enum pll1_output output) +{ + ulong pllsrc = 0; + u32 divm1, divn1, divp1, divq1, divr1, fracn1; + ulong vco, rate; + + /* get the PLLSRC */ + switch (readl(®s->pllckselr) & RCC_PLLCKSELR_PLLSRC_MASK) { + case RCC_PLLCKSELR_PLLSRC_HSI: + pllsrc = stm32_get_rate(regs, HSI); + break; + case RCC_PLLCKSELR_PLLSRC_CSI: + pllsrc = stm32_get_rate(regs, CSI); + break; + case RCC_PLLCKSELR_PLLSRC_HSE: + pllsrc = stm32_get_rate(regs, HSE); + break; + case RCC_PLLCKSELR_PLLSRC_NO_CLK: + /* shouldn't happen */ + error("wrong value for RCC_PLLCKSELR register\n"); + pllsrc = 0; + break; + } + + /* pllsrc = 0 ? no need to go ahead */ + if (!pllsrc) + return pllsrc; + + /* get divm1, divp1, divn1 and divr1 */ + divm1 = readl(®s->pllckselr) & RCC_PLLCKSELR_DIVM1_MASK; + divm1 = divm1 >> RCC_PLLCKSELR_DIVM1_SHIFT; + + divn1 = (readl(®s->pll1divr) & RCC_PLL1DIVR_DIVN1_MASK) + 1; + + divp1 = readl(®s->pll1divr) & RCC_PLL1DIVR_DIVP1_MASK; + divp1 = (divp1 >> RCC_PLL1DIVR_DIVP1_SHIFT) + 1; + + divq1 = readl(®s->pll1divr) & RCC_PLL1DIVR_DIVQ1_MASK; + divq1 = (divq1 >> RCC_PLL1DIVR_DIVQ1_SHIFT) + 1; + + divr1 = readl(®s->pll1divr) & RCC_PLL1DIVR_DIVR1_MASK; + divr1 = (divr1 >> RCC_PLL1DIVR_DIVR1_SHIFT) + 1; + + fracn1 = readl(®s->pll1fracr) & RCC_PLL1DIVR_DIVR1_MASK; + fracn1 = fracn1 & RCC_PLL1DIVR_DIVR1_SHIFT; + + vco = (pllsrc / divm1) * divn1; + rate = (pllsrc * fracn1) / (divm1 * 8192); + + debug("%s divm1 = %d divn1 = %d divp1 = %d divq1 = %d divr1 = %d\n", + __func__, divm1, divn1, divp1, divq1, divr1); + debug("%s fracn1 = %d vco = %ld rate = %ld\n", + __func__, fracn1, vco, rate); + + switch (output) { + case PLL1_P_CK: + return (vco + rate) / divp1; + break; + case PLL1_Q_CK: + return (vco + rate) / divq1; + break; + + case PLL1_R_CK: + return (vco + rate) / divr1; + break; + } + + return -EINVAL; +} + +static ulong stm32_clk_get_rate(struct clk *clk) +{ + struct stm32_clk *priv = dev_get_priv(clk->dev); + struct stm32_rcc_regs *regs = priv->rcc_base; + ulong sysclk = 0; + u32 gate_offset; + u32 d1cfgr; + /* prescaler table lookups for clock computation */ + u16 prescaler_table[8] = {2, 4, 8, 16, 64, 128, 256, 512}; + u8 source, idx; + + /* + * get system clock (sys_ck) source + * can be HSI_CK, CSI_CK, HSE_CK or pll1_p_ck + */ + source = readl(®s->cfgr) & RCC_CFGR_SW_MASK; + switch (source) { + case RCC_CFGR_SW_PLL1: + sysclk = stm32_get_PLL1_rate(regs, PLL1_P_CK); + break; + case RCC_CFGR_SW_HSE: + sysclk = stm32_get_rate(regs, HSE); + break; + + case RCC_CFGR_SW_CSI: + sysclk = stm32_get_rate(regs, CSI); + break; + + case RCC_CFGR_SW_HSI: + sysclk = stm32_get_rate(regs, HSI); + break; + } + + /* sysclk = 0 ? no need to go ahead */ + if (!sysclk) + return sysclk; + + debug("%s system clock: source = %d freq = %ld\n", + __func__, source, sysclk); + + d1cfgr = readl(®s->d1cfgr); + + if (d1cfgr & RCC_D1CFGR_D1CPRE_DIVIDED) { + /* get D1 domain Core prescaler */ + idx = (d1cfgr & RCC_D1CFGR_D1CPRE_DIVIDER) >> + RCC_D1CFGR_D1CPRE_SHIFT; + sysclk = sysclk / prescaler_table[idx]; + } + + if (d1cfgr & RCC_D1CFGR_HPRE_DIVIDED) { + /* get D1 domain AHB prescaler */ + idx = d1cfgr & RCC_D1CFGR_HPRE_DIVIDER; + sysclk = sysclk / prescaler_table[idx]; + } + + gate_offset = clk_map[clk->id].gate_offset; + + debug("%s clk->id=%ld gate_offset=0x%x sysclk=%ld\n", + __func__, clk->id, gate_offset, sysclk); + + switch (gate_offset) { + case RCC_AHB3ENR: + case RCC_AHB1ENR: + case RCC_AHB2ENR: + case RCC_AHB4ENR: + return sysclk; + break; + + case RCC_APB3ENR: + if (d1cfgr & RCC_D1CFGR_D1PPRE_DIVIDED) { + /* get D1 domain APB3 prescaler */ + idx = (d1cfgr & RCC_D1CFGR_D1PPRE_DIVIDER) >> + RCC_D1CFGR_D1PPRE_SHIFT; + sysclk = sysclk / prescaler_table[idx]; + } + + debug("%s system clock: freq after APB3 prescaler = %ld\n", + __func__, sysclk); + + return sysclk; + break; + + case RCC_APB4ENR: + if (d1cfgr & RCC_D3CFGR_D3PPRE_DIVIDED) { + /* get D3 domain APB4 prescaler */ + idx = (d1cfgr & RCC_D3CFGR_D3PPRE_DIVIDER) >> + RCC_D3CFGR_D3PPRE_SHIFT; + sysclk = sysclk / prescaler_table[idx]; + } + + debug("%s system clock: freq after APB4 prescaler = %ld\n", + __func__, sysclk); + + return sysclk; + break; + + case RCC_APB1LENR: + case RCC_APB1HENR: + if (d1cfgr & RCC_D2CFGR_D2PPRE1_DIVIDED) { + /* get D2 domain APB1 prescaler */ + idx = (d1cfgr & RCC_D2CFGR_D2PPRE1_DIVIDER) >> + RCC_D2CFGR_D2PPRE1_SHIFT; + sysclk = sysclk / prescaler_table[idx]; + } + + debug("%s system clock: freq after APB1 prescaler = %ld\n", + __func__, sysclk); + + return sysclk; + break; + + case RCC_APB2ENR: + if (d1cfgr & RCC_D2CFGR_D2PPRE2_DIVIDED) { + /* get D2 domain APB1 prescaler */ + idx = (d1cfgr & RCC_D2CFGR_D2PPRE2_DIVIDER) >> + RCC_D2CFGR_D2PPRE2_SHIFT; + sysclk = sysclk / prescaler_table[idx]; + } + + debug("%s system clock: freq after APB2 prescaler = %ld\n", + __func__, sysclk); + + return sysclk; + break; + + default: + error("unexpected gate_offset value (0x%x)\n", gate_offset); + return -EINVAL; + break; + } +} + +static int stm32_clk_enable(struct clk *clk) +{ + struct stm32_clk *priv = dev_get_priv(clk->dev); + struct stm32_rcc_regs *regs = priv->rcc_base; + u32 gate_offset; + u32 gate_bit_index; + unsigned long clk_id = clk->id; + + gate_offset = clk_map[clk_id].gate_offset; + gate_bit_index = clk_map[clk_id].gate_bit_idx; + + debug("%s: clkid=%ld gate offset=0x%x bit_index=%d name=%s\n", + __func__, clk->id, gate_offset, gate_bit_index, + clk_map[clk_id].name); + + setbits_le32(®s->cr + (gate_offset / 4), BIT(gate_bit_index)); + + return 0; +} + +static int stm32_clk_probe(struct udevice *dev) +{ + struct stm32_clk *priv = dev_get_priv(dev); + struct udevice *syscon; + fdt_addr_t addr; + int err; + + addr = dev_read_addr(dev); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + priv->rcc_base = (struct stm32_rcc_regs *)addr; + + /* get corresponding syscon phandle */ + err = uclass_get_device_by_phandle(UCLASS_SYSCON, dev, + "st,syscfg", &syscon); + + if (err) { + error("unable to find syscon device\n"); + return err; + } + + priv->pwr_regmap = syscon_get_regmap(syscon); + if (!priv->pwr_regmap) { + error("unable to find regmap\n"); + return -ENODEV; + } + + configure_clocks(dev); + + return 0; +} + +static int stm32_clk_of_xlate(struct clk *clk, + struct ofnode_phandle_args *args) +{ + if (args->args_count != 1) { + debug("Invaild args_count: %d\n", args->args_count); + return -EINVAL; + } + + if (args->args_count) { + clk->id = args->args[0]; + /* + * this computation convert DT clock index which is used to + * point into 2 separate clock arrays (peripheral and kernel + * clocks bank) (see include/dt-bindings/clock/stm32h7-clks.h) + * into index to point into only one array where peripheral + * and kernel clocks are consecutive + */ + if (clk->id >= KERN_BANK) { + clk->id -= KERN_BANK; + clk->id += LAST_PERIF_BANK - PERIF_BANK + 1; + } else { + clk->id -= PERIF_BANK; + } + } else { + clk->id = 0; + } + + debug("%s clk->id %ld\n", __func__, clk->id); + + return 0; +} + +static struct clk_ops stm32_clk_ops = { + .of_xlate = stm32_clk_of_xlate, + .enable = stm32_clk_enable, + .get_rate = stm32_clk_get_rate, +}; + +U_BOOT_DRIVER(stm32h7_clk) = { + .name = "stm32h7_rcc_clock", + .id = UCLASS_CLK, + .ops = &stm32_clk_ops, + .probe = stm32_clk_probe, + .priv_auto_alloc_size = sizeof(struct stm32_clk), + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/include/dt-bindings/clock/stm32h7-clks.h b/include/dt-bindings/clock/stm32h7-clks.h new file mode 100644 index 0000000..4d87e7e --- /dev/null +++ b/include/dt-bindings/clock/stm32h7-clks.h @@ -0,0 +1,167 @@ +/* SYS, CORE AND BUS CLOCKS */ +#define SYS_D1CPRE 0 +#define HCLK 1 +#define PCLK1 2 +#define PCLK2 3 +#define PCLK3 4 +#define PCLK4 5 +#define HSI_DIV 6 +#define HSE_1M 7 +#define I2S_CKIN 8 +#define CK_DSI_PHY 9 +#define HSE_CK 10 +#define LSE_CK 11 +#define CSI_KER_DIV122 12 +#define RTC_CK 13 +#define CPU_SYSTICK 14 + +/* OSCILLATOR BANK */ +#define OSC_BANK 18 +#define HSI_CK 18 +#define HSI_KER_CK 19 +#define CSI_CK 20 +#define CSI_KER_CK 21 +#define RC48_CK 22 +#define LSI_CK 23 + +/* MCLOCK BANK */ +#define MCLK_BANK 28 +#define PER_CK 28 +#define PLLSRC 29 +#define SYS_CK 30 +#define TRACEIN_CK 31 + +/* ODF BANK */ +#define ODF_BANK 32 +#define PLL1_P 32 +#define PLL1_Q 33 +#define PLL1_R 34 +#define PLL2_P 35 +#define PLL2_Q 36 +#define PLL2_R 37 +#define PLL3_P 38 +#define PLL3_Q 39 +#define PLL3_R 40 + +/* MCO BANK */ +#define MCO_BANK 41 +#define MCO1 41 +#define MCO2 42 + +/* PERIF BANK */ +#define PERIF_BANK 50 +#define D1SRAM1_CK 50 +#define ITCM_CK 51 +#define DTCM2_CK 52 +#define DTCM1_CK 53 +#define FLITF_CK 54 +#define JPGDEC_CK 55 +#define DMA2D_CK 56 +#define MDMA_CK 57 +#define USB2ULPI_CK 58 +#define USB1ULPI_CK 59 +#define ETH1RX_CK 60 +#define ETH1TX_CK 61 +#define ETH1MAC_CK 62 +#define ART_CK 63 +#define DMA2_CK 64 +#define DMA1_CK 65 +#define D2SRAM3_CK 66 +#define D2SRAM2_CK 67 +#define D2SRAM1_CK 68 +#define HASH_CK 69 +#define CRYPT_CK 70 +#define CAMITF_CK 71 +#define BKPRAM_CK 72 +#define HSEM_CK 73 +#define BDMA_CK 74 +#define CRC_CK 75 +#define GPIOK_CK 76 +#define GPIOJ_CK 77 +#define GPIOI_CK 78 +#define GPIOH_CK 79 +#define GPIOG_CK 80 +#define GPIOF_CK 81 +#define GPIOE_CK 82 +#define GPIOD_CK 83 +#define GPIOC_CK 84 +#define GPIOB_CK 85 +#define GPIOA_CK 86 +#define WWDG1_CK 87 +#define DAC12_CK 88 +#define WWDG2_CK 89 +#define TIM14_CK 90 +#define TIM13_CK 91 +#define TIM12_CK 92 +#define TIM7_CK 93 +#define TIM6_CK 94 +#define TIM5_CK 95 +#define TIM4_CK 96 +#define TIM3_CK 97 +#define TIM2_CK 98 +#define MDIOS_CK 99 +#define OPAMP_CK 100 +#define CRS_CK 101 +#define TIM17_CK 102 +#define TIM16_CK 103 +#define TIM15_CK 104 +#define TIM8_CK 105 +#define TIM1_CK 106 +#define TMPSENS_CK 107 +#define RTCAPB_CK 108 +#define VREF_CK 109 +#define COMP12_CK 110 +#define SYSCFG_CK 111 +/* must be equal to last peripheral clock index */ +#define LAST_PERIF_BANK SYSCFG_CK + +/* KERNEL BANK */ +#define KERN_BANK 120 +#define SDMMC1_CK 120 +#define QUADSPI_CK 121 +#define FMC_CK 122 +#define USB2OTG_CK 123 +#define USB1OTG_CK 124 +#define ADC12_CK 125 +#define SDMMC2_CK 126 +#define RNG_CK 127 +#define ADC3_CK 128 +#define DSI_CK 129 +#define LTDC_CK 130 +#define USART8_CK 131 +#define USART7_CK 132 +#define HDMICEC_CK 133 +#define I2C3_CK 134 +#define I2C2_CK 135 +#define I2C1_CK 136 +#define UART5_CK 137 +#define UART4_CK 138 +#define USART3_CK 139 +#define USART2_CK 140 +#define SPDIFRX_CK 141 +#define SPI3_CK 142 +#define SPI2_CK 143 +#define LPTIM1_CK 144 +#define FDCAN_CK 145 +#define SWP_CK 146 +#define HRTIM_CK 147 +#define DFSDM1_CK 148 +#define SAI3_CK 149 +#define SAI2_CK 150 +#define SAI1_CK 151 +#define SPI5_CK 152 +#define SPI4_CK 153 +#define SPI1_CK 154 +#define USART6_CK 155 +#define USART1_CK 156 +#define SAI4B_CK 157 +#define SAI4A_CK 158 +#define LPTIM5_CK 159 +#define LPTIM4_CK 160 +#define LPTIM3_CK 161 +#define LPTIM2_CK 162 +#define I2C4_CK 163 +#define SPI6_CK 164 +#define LPUART1_CK 165 + +#define STM32H7_MAX_CLKS 166
Hi Patrice,
- "st,stm32h743-rcc"
- datasheet
- write protection (RTC clock).
st,syscfg is confusing if we are using it for PWR or SYSCFG peripheral of the device. Also why company name to reference the phandle, it can just be syscfg or better something like pwr_xxx as we it pointing to pwrcfg phandle.
- Please see PLL section below.
+Example:
- rcc: rcc@58024400 {
#reset-cells = <1>;
#clock-cells = <2>
see above.
#size-cells = <0>;
vco1@58024430 {
#clock-cells = <0>;
reg = <0>;
vco2@58024438 {
#clock-cells = <0>;
reg = <1>;
st,clock-div = <2>;
st,frac = <0>;
st,vcosel = <1>;
st,pllrge = <2>;
- Vref --------- --------
- ---->| / DIVM |---->| x DIVN | ------> VCO
| FRACN |
- "stm32,pll"
+- st,frac-status:
+Example:
interrupts = <50>;
- crc = AHB4RSTR_offset / 4 * 32 + CRCRST_bit_offset = 0x88 / 4 * 32 + 19 = 1107
+example:
- timer2 {
- Copyright (C) STMicroelectronics SA 2017
- Author(s): Patrice CHOTARD, patrice.chotard@st.com for STMicroelectronics.
Can we use SCUEN suffix to match the Ref Manual.
- u32 cr; /* 0x00 Source Control Register */
- u32 icscr; /* 0x04 Internal Clock Source Calibration Register */
- u32 crrcr; /* 0x08 Clock Recovery RC Register */
- u32 reserved1; /* 0x0c reserved */
- u32 cfgr; /* 0x10 Clock Configuration Register */
- u32 reserved2; /* 0x14 reserved */
- u32 d1cfgr; /* 0x18 Domain 1 Clock Configuration Register */
- u32 d2cfgr; /* 0x1c Domain 2 Clock Configuration Register */
- u32 d3cfgr; /* 0x20 Domain 3 Clock Configuration Register */
- u32 reserved3; /* 0x24 reserved */
- u32 pllckselr; /* 0x28 PLLs Clock Source Selection Register */
- u32 pllcfgr; /* 0x2c PLLs Configuration Register */
- u32 pll1divr; /* 0x30 PLL1 Dividers Configuration Register */
- u32 pll1fracr; /* 0x34 PLL1 Fractional Divider Register */
- u32 pll2divr; /* 0x38 PLL2 Dividers Configuration Register */
- u32 pll2fracr; /* 0x3c PLL2 Fractional Divider Register */
- u32 pll3divr; /* 0x40 PLL3 Dividers Configuration Register */
- u32 pll3fracr; /* 0x44 PLL3 Fractional Divider Register */
- u32 reserved4; /* 0x48 reserved */
- u32 d1ccipr; /* 0x4c Domain 1 Kernel Clock Configuration Register */
- u32 d2ccip1r; /* 0x50 Domain 2 Kernel Clock Configuration Register */
- u32 d2ccip2r; /* 0x54 Domain 2 Kernel Clock Configuration Register */
- u32 d3ccipr; /* 0x58 Domain 3 Kernel Clock Configuration Register */
- u32 reserved5; /* 0x5c reserved */
- u32 cier; /* 0x60 Clock Source Interrupt Enable Register */
- u32 cifr; /* 0x64 Clock Source Interrupt Flag Register */
- u32 cicr; /* 0x68 Clock Source Interrupt Clear Register */
- u32 reserved6; /* 0x6c reserved */
- u32 bdcr; /* 0x70 Backup Domain Control Register */
- u32 csr; /* 0x74 Clock Control and Status Register */
- u32 reserved7; /* 0x78 reserved */
- u32 ahb3rstr; /* 0x7c AHB3 Peripheral Reset Register */
- u32 ahb1rstr; /* 0x80 AHB1 Peripheral Reset Register */
- u32 ahb2rstr; /* 0x84 AHB2 Peripheral Reset Register */
- u32 ahb4rstr; /* 0x88 AHB4 Peripheral Reset Register */
- u32 apb3rstr; /* 0x8c APB3 Peripheral Reset Register */
- u32 apb1lrstr; /* 0x90 APB1 low Peripheral Reset Register */
- u32 apb1hrstr; /* 0x94 APB1 high Peripheral Reset Register */
- u32 apb2rstr; /* 0x98 APB2 Clock Register */
- u32 apb4rstr; /* 0x9c APB4 Clock Register */
- u32 gcr; /* 0xa0 Global Control Register */
- u32 reserved8; /* 0xa4 reserved */
- u32 d3amr; /* 0xa8 D3 Autonomous mode Register */
- u32 reserved9[9];/* 0xac to 0xcc reserved */
- u32 rsr; /* 0xd0 Reset Status Register */
- u32 ahb3enr; /* 0xd4 AHB3 Clock Register */
- u32 ahb1enr; /* 0xd8 AHB1 Clock Register */
- u32 ahb2enr; /* 0xdc AHB2 Clock Register */
- u32 ahb4enr; /* 0xe0 AHB4 Clock Register */
- u32 apb3enr; /* 0xe4 APB3 Clock Register */
- u32 apb1lenr; /* 0xe8 APB1 low Clock Register */
- u32 apb1henr; /* 0xec APB1 high Clock Register */
- u32 apb2enr; /* 0xf0 APB2 Clock Register */
- u32 apb4enr; /* 0xf4 APB4 Clock Register */
+struct clk_cfg {
- u32 gate_offset;
- u8 gate_bit_idx;
- const char *name;
- .gate_offset = _gate_offset,\
- .gate_bit_idx = _bit_idx,\
- .name = _name,\
- the way all these entries are sorted in this array could seem
- unlogical, but we are dependant of kernel DT_bindings,
- where clocks are separate in 2 banks, peripheral clocks and
- kernel clocks.
it destroys the purpose of device tree if we are embedding all the info in the structure array. In addition expensive in terms of memory usage.
- CLK(RCC_AHB3ENR, 31, "d1sram1"), /* peripheral clocks */
Do we need CLK Macro, {RCC_AHB3ENR, 31, "d1sram1"} should work fine.
- CLK(RCC_AHB3ENR, 30, "itcm"),
- CLK(RCC_AHB3ENR, 29, "dtcm2"),
- CLK(RCC_AHB3ENR, 28, "dtcm1"),
- CLK(RCC_AHB3ENR, 8, "flitf"),
- CLK(RCC_AHB3ENR, 5, "jpgdec"),
- CLK(RCC_AHB3ENR, 4, "dma2d"),
- CLK(RCC_AHB3ENR, 0, "mdma"),
- CLK(RCC_AHB1ENR, 28, "usb2ulpi"),
- CLK(RCC_AHB1ENR, 17, "eth1rx"),
- CLK(RCC_AHB1ENR, 16, "eth1tx"),
- CLK(RCC_AHB1ENR, 15, "eth1mac"),
- CLK(RCC_AHB1ENR, 14, "art"),
- CLK(RCC_AHB1ENR, 26, "usb1ulpi"),
- CLK(RCC_AHB1ENR, 1, "dma2"),
- CLK(RCC_AHB1ENR, 0, "dma1"),
- CLK(RCC_AHB2ENR, 31, "d2sram3"),
- CLK(RCC_AHB2ENR, 30, "d2sram2"),
- CLK(RCC_AHB2ENR, 29, "d2sram1"),
- CLK(RCC_AHB2ENR, 5, "hash"),
- CLK(RCC_AHB2ENR, 4, "crypt"),
- CLK(RCC_AHB2ENR, 0, "camitf"),
- CLK(RCC_AHB4ENR, 28, "bkpram"),
- CLK(RCC_AHB4ENR, 25, "hsem"),
- CLK(RCC_AHB4ENR, 21, "bdma"),
- CLK(RCC_AHB4ENR, 19, "crc"),
- CLK(RCC_AHB4ENR, 10, "gpiok"),
- CLK(RCC_AHB4ENR, 9, "gpioj"),
- CLK(RCC_AHB4ENR, 8, "gpioi"),
- CLK(RCC_AHB4ENR, 7, "gpioh"),
- CLK(RCC_AHB4ENR, 6, "gpiog"),
- CLK(RCC_AHB4ENR, 5, "gpiof"),
- CLK(RCC_AHB4ENR, 4, "gpioe"),
- CLK(RCC_AHB4ENR, 3, "gpiod"),
- CLK(RCC_AHB4ENR, 2, "gpioc"),
- CLK(RCC_AHB4ENR, 1, "gpiob"),
- CLK(RCC_AHB4ENR, 0, "gpioa"),
- CLK(RCC_APB3ENR, 6, "wwdg1"),
- CLK(RCC_APB1LENR, 29, "dac12"),
- CLK(RCC_APB1LENR, 11, "wwdg2"),
- CLK(RCC_APB1LENR, 8, "tim14"),
- CLK(RCC_APB1LENR, 7, "tim13"),
- CLK(RCC_APB1LENR, 6, "tim12"),
- CLK(RCC_APB1LENR, 5, "tim7"),
- CLK(RCC_APB1LENR, 4, "tim6"),
- CLK(RCC_APB1LENR, 3, "tim5"),
- CLK(RCC_APB1LENR, 2, "tim4"),
- CLK(RCC_APB1LENR, 1, "tim3"),
- CLK(RCC_APB1LENR, 0, "tim2"),
- CLK(RCC_APB1HENR, 5, "mdios"),
- CLK(RCC_APB1HENR, 4, "opamp"),
- CLK(RCC_APB1HENR, 1, "crs"),
- CLK(RCC_APB2ENR, 18, "tim17"),
- CLK(RCC_APB2ENR, 17, "tim16"),
- CLK(RCC_APB2ENR, 16, "tim15"),
- CLK(RCC_APB2ENR, 1, "tim8"),
- CLK(RCC_APB2ENR, 0, "tim1"),
- CLK(RCC_APB4ENR, 26, "tmpsens"),
- CLK(RCC_APB4ENR, 16, "rtcapb"),
- CLK(RCC_APB4ENR, 15, "vref"),
- CLK(RCC_APB4ENR, 14, "comp12"),
- CLK(RCC_APB4ENR, 1, "syscfg"),
- CLK(RCC_AHB3ENR, 16, "sdmmc1"), /* kernel clocks */
- CLK(RCC_AHB3ENR, 14, "quadspi"),
- CLK(RCC_AHB3ENR, 12, "fmc"),
- CLK(RCC_AHB1ENR, 27, "usb2otg"),
- CLK(RCC_AHB1ENR, 25, "usb1otg"),
- CLK(RCC_AHB1ENR, 5, "adc12"),
- CLK(RCC_AHB2ENR, 9, "sdmmc2"),
- CLK(RCC_AHB2ENR, 6, "rng"),
- CLK(RCC_AHB4ENR, 24, "adc3"),
- CLK(RCC_APB3ENR, 4, "dsi"),
- CLK(RCC_APB3ENR, 3, "ltdc"),
- CLK(RCC_APB1LENR, 31, "usart8"),
- CLK(RCC_APB1LENR, 30, "usart7"),
- CLK(RCC_APB1LENR, 27, "hdmicec"),
- CLK(RCC_APB1LENR, 23, "i2c3"),
- CLK(RCC_APB1LENR, 22, "i2c2"),
- CLK(RCC_APB1LENR, 21, "i2c1"),
- CLK(RCC_APB1LENR, 20, "uart5"),
- CLK(RCC_APB1LENR, 19, "uart4"),
- CLK(RCC_APB1LENR, 18, "usart3"),
- CLK(RCC_APB1LENR, 17, "usart2"),
- CLK(RCC_APB1LENR, 16, "spdifrx"),
- CLK(RCC_APB1LENR, 15, "spi3"),
- CLK(RCC_APB1LENR, 14, "spi2"),
- CLK(RCC_APB1LENR, 9, "lptim1"),
- CLK(RCC_APB1HENR, 8, "fdcan"),
- CLK(RCC_APB1HENR, 2, "swp"),
- CLK(RCC_APB2ENR, 29, "hrtim"),
- CLK(RCC_APB2ENR, 28, "dfsdm1"),
- CLK(RCC_APB2ENR, 24, "sai3"),
- CLK(RCC_APB2ENR, 23, "sai2"),
- CLK(RCC_APB2ENR, 22, "sai1"),
- CLK(RCC_APB2ENR, 20, "spi5"),
- CLK(RCC_APB2ENR, 13, "spi4"),
- CLK(RCC_APB2ENR, 12, "spi1"),
- CLK(RCC_APB2ENR, 5, "usart6"),
- CLK(RCC_APB2ENR, 4, "usart1"),
- CLK(RCC_APB4ENR, 21, "sai4a"),
- CLK(RCC_APB4ENR, 21, "sai4b"),
- CLK(RCC_APB4ENR, 12, "lptim5"),
- CLK(RCC_APB4ENR, 11, "lptim4"),
- CLK(RCC_APB4ENR, 10, "lptim3"),
- CLK(RCC_APB4ENR, 9, "lptim2"),
- CLK(RCC_APB4ENR, 7, "i2c4"),
- CLK(RCC_APB4ENR, 5, "spi6"),
- CLK(RCC_APB4ENR, 3, "lpuart1"),
+struct stm32_clk {
- struct stm32_rcc_regs *rcc_base;
- struct regmap *pwr_regmap;
+struct pll_psc {
- u8 divm;
- u16 divn;
- u8 divp;
- u8 divq;
- u8 divr;
- OSC_HSE = 25 MHz
- VCO = 500MHz
- pll1_p = 250MHz / pll1_q = 250MHz pll1_r = 250Mhz
- .divm = 4,
- .divn = 80,
- .divp = 2,
- .divq = 2,
- .divr = 2,
- struct stm32_clk *priv = dev_get_priv(dev);
- struct stm32_rcc_regs *regs = priv->rcc_base;
- uint8_t *pwr_base = (uint8_t *)regmap_get_range(priv->pwr_regmap, 0);
- uint32_t pllckselr = 0;
- uint32_t pll1divr = 0;
- uint32_t pllcfgr = 0;
- /* Switch on HSI */
- setbits_le32(®s->cr, RCC_CR_HSION);
- while (!(readl(®s->cr) & RCC_CR_HSIRDY))
- /* Reset CFGR, now HSI is the default system clock */
- writel(0, ®s->cfgr);
- /* Set all kernel domain clock registers to reset value*/
- writel(0x0, ®s->d1ccipr);
- writel(0x0, ®s->d2ccip1r);
- writel(0x0, ®s->d2ccip2r);
- /* Set voltage scaling at scale 1 */
pls add info what is scale1
- clrsetbits_le32(pwr_base + PWR_D3CR, PWR_D3CR_VOS_MASK,
- /* disable step down converter */
is this comment correct ?
- clrbits_le32(pwr_base + PWR_CR3, PWR_CR3_SDEN);
- while (!(readl(pwr_base + PWR_D3CR) & PWR_D3CR_VOSREADY))
- /* disable HSE to configure it */
- clrbits_le32(®s->cr, RCC_CR_HSEON);
- while ((readl(®s->cr) & RCC_CR_HSERDY))
- /* clear HSE bypass and set it ON */
- clrbits_le32(®s->cr, RCC_CR_HSEBYP);
- /* Switch on HSE */
- setbits_le32(®s->cr, RCC_CR_HSEON);
- while (!(readl(®s->cr) & RCC_CR_HSERDY))
- /* pll setup, disable it */
- clrbits_le32(®s->cr, RCC_CR_PLL1ON);
- while ((readl(®s->cr) & RCC_CR_PLL1RDY))
- /* Select HSE as PLL clock source */
- pllckselr |= RCC_PLLCKSELR_PLLSRC_HSE;
- pllckselr |= sys_pll_psc.divm << RCC_PLLCKSELR_DIVM1_SHIFT;
- writel(pllckselr, ®s->pllckselr);
- pll1divr |= (sys_pll_psc.divr - 1) << RCC_PLL1DIVR_DIVR1_SHIFT;
- pll1divr |= (sys_pll_psc.divq - 1) << RCC_PLL1DIVR_DIVQ1_SHIFT;
- pll1divr |= (sys_pll_psc.divp - 1) << RCC_PLL1DIVR_DIVP1_SHIFT;
- pll1divr |= (sys_pll_psc.divn - 1);
- writel(pll1divr, ®s->pll1divr);
- pllcfgr |= PLL1RGE_4_8_MHZ << RCC_PLLCFGR_PLL1RGE_SHIFT;
- pllcfgr |= RCC_PLLCFGR_DIVP1EN;
- pllcfgr |= RCC_PLLCFGR_DIVQ1EN;
- pllcfgr |= RCC_PLLCFGR_DIVR1EN;
- writel(pllcfgr, ®s->pllcfgr);
- /* pll setup, enable it */
- setbits_le32(®s->cr, RCC_CR_PLL1ON);
- /* set HPRE (/2) DI clk --> 125MHz */
- clrsetbits_le32(®s->d1cfgr, RCC_D1CFGR_HPRE_MASK,
- /* select PLL1 as system clock source (sys_ck)*/
- clrsetbits_le32(®s->cfgr, RCC_CFGR_SW_MASK, RCC_CFGR_SW_PLL1);
- while ((readl(®s->cfgr) & RCC_CFGR_SW_MASK) != RCC_CFGR_SW_PLL1)
- /* sdram: use pll1_q as fmc_k clk */
- clrsetbits_le32(®s->d1ccipr, RCC_D1CCIPR_FMCSRC_MASK,
FMCSRC_PLL1_Q_CK);
- u32 divider;
- /* get HSI divider value */
- divider = readl(®s->cr) & RCC_CR_HSIDIV_MASK;
- divider = divider >> RCC_CR_HSIDIV_SHIFT;
- return divider;
+enum pllsrc {
- HSE,
- LSE,
- HSI,
- CSI,
- I2S,
- TIMER,
- PLLSRC_NB,
- [HSE] = "clk-hse",
- [LSE] = "clk-lse",
- [HSI] = "clk-hsi",
- [CSI] = "clk-csi",
- [I2S] = "clk-i2s",
- [TIMER] = "timer-clk"
- struct clk clk;
- struct udevice *fixed_clock_dev = NULL;
- u32 divider;
- int ret;
- const char *name = pllsrc_name[pllsrc];
- debug("%s name %s\n", __func__, name);
- clk.id = 0;
- ret = uclass_get_device_by_name(UCLASS_CLK, name, &fixed_clock_dev);
- if (ret) {
- ret = clk_request(fixed_clock_dev, &clk);
- if (ret) {
- divider = 0;
- if (pllsrc == HSI)
- debug("%s divider %d rate %ld\n", __func__,
- return clk_get_rate(&clk) >> divider;
+enum pll1_output {
- PLL1_P_CK,
- PLL1_Q_CK,
- PLL1_R_CK,
- ulong pllsrc = 0;
- u32 divm1, divn1, divp1, divq1, divr1, fracn1;
- ulong vco, rate;
- /* get the PLLSRC */
- switch (readl(®s->pllckselr) & RCC_PLLCKSELR_PLLSRC_MASK) {
- case RCC_PLLCKSELR_PLLSRC_HSI:
break;
- case RCC_PLLCKSELR_PLLSRC_CSI:
break;
- case RCC_PLLCKSELR_PLLSRC_HSE:
break;
- case RCC_PLLCKSELR_PLLSRC_NO_CLK:
pllsrc = 0;
break;
- /* pllsrc = 0 ? no need to go ahead */
- if (!pllsrc)
return pllsrc;
- /* get divm1, divp1, divn1 and divr1 */
- divm1 = readl(®s->pllckselr) & RCC_PLLCKSELR_DIVM1_MASK;
- divm1 = divm1 >> RCC_PLLCKSELR_DIVM1_SHIFT;
- divn1 = (readl(®s->pll1divr) & RCC_PLL1DIVR_DIVN1_MASK) + 1;
- divp1 = readl(®s->pll1divr) & RCC_PLL1DIVR_DIVP1_MASK;
- divp1 = (divp1 >> RCC_PLL1DIVR_DIVP1_SHIFT) + 1;
- divq1 = readl(®s->pll1divr) & RCC_PLL1DIVR_DIVQ1_MASK;
- divq1 = (divq1 >> RCC_PLL1DIVR_DIVQ1_SHIFT) + 1;
- divr1 = readl(®s->pll1divr) & RCC_PLL1DIVR_DIVR1_MASK;
- divr1 = (divr1 >> RCC_PLL1DIVR_DIVR1_SHIFT) + 1;
- fracn1 = readl(®s->pll1fracr) & RCC_PLL1DIVR_DIVR1_MASK;
- fracn1 = fracn1 & RCC_PLL1DIVR_DIVR1_SHIFT;
- vco = (pllsrc / divm1) * divn1;
- rate = (pllsrc * fracn1) / (divm1 * 8192);
- debug("%s divm1 = %d divn1 = %d divp1 = %d divq1 = %d divr1 = %d\n",
- debug("%s fracn1 = %d vco = %ld rate = %ld\n",
- switch (output) {
- case PLL1_P_CK:
break;
- case PLL1_Q_CK:
break;
- case PLL1_R_CK:
break;
- return -EINVAL;
- struct stm32_clk *priv = dev_get_priv(clk->dev);
- ulong sysclk = 0;
- u32 gate_offset;
- u32 d1cfgr;
- /* prescaler table lookups for clock computation */
- u16 prescaler_table[8] = {2, 4, 8, 16, 64, 128, 256, 512};
- u8 source, idx;
- source = readl(®s->cfgr) & RCC_CFGR_SW_MASK;
- switch (source) {
- case RCC_CFGR_SW_PLL1:
break;
- case RCC_CFGR_SW_HSE:
break;
- case RCC_CFGR_SW_CSI:
break;
- case RCC_CFGR_SW_HSI:
break;
- /* sysclk = 0 ? no need to go ahead */
- if (!sysclk)
return sysclk;
- debug("%s system clock: source = %d freq = %ld\n",
- d1cfgr = readl(®s->d1cfgr);
- if (d1cfgr & RCC_D1CFGR_D1CPRE_DIVIDED) {
- if (d1cfgr & RCC_D1CFGR_HPRE_DIVIDED) {
- gate_offset = clk_map[clk->id].gate_offset;
- debug("%s clk->id=%ld gate_offset=0x%x sysclk=%ld\n",
- switch (gate_offset) {
- case RCC_AHB3ENR:
- case RCC_AHB1ENR:
- case RCC_AHB2ENR:
- case RCC_AHB4ENR:
return sysclk;
break;
- case RCC_APB3ENR:
__func__, sysclk);
return sysclk;
break;
- case RCC_APB4ENR:
__func__, sysclk);
return sysclk;
break;
- case RCC_APB1LENR:
- case RCC_APB1HENR:
__func__, sysclk);
return sysclk;
break;
- case RCC_APB2ENR:
__func__, sysclk);
return sysclk;
break;
- default:
return -EINVAL;
break;
- u32 gate_offset;
- u32 gate_bit_index;
- unsigned long clk_id = clk->id;
- gate_offset = clk_map[clk_id].gate_offset;
- gate_bit_index = clk_map[clk_id].gate_bit_idx;
- debug("%s: clkid=%ld gate offset=0x%x bit_index=%d name=%s\n",
- setbits_le32(®s->cr + (gate_offset / 4), BIT(gate_bit_index));
- struct udevice *syscon;
- fdt_addr_t addr;
- int err;
- addr = dev_read_addr(dev);
- if (addr == FDT_ADDR_T_NONE)
return -EINVAL;
- priv->rcc_base = (struct stm32_rcc_regs *)addr;
- /* get corresponding syscon phandle */
- err = uclass_get_device_by_phandle(UCLASS_SYSCON, dev,
- if (err) {
return err;
- priv->pwr_regmap = syscon_get_regmap(syscon);
why SYSCON_UCLASS...It is used just to get the base address of power control block ? It can be done directly from the phandle also, e.g. fdt_node_offset_by_phandle() or similar.
Cheers, Vikas
- if (!priv->pwr_regmap) {
return -ENODEV;
- configure_clocks(dev);
- if (args->args_count != 1) {
return -EINVAL;
- if (args->args_count) {
} else {
- } else {
clk->id = 0;
- debug("%s clk->id %ld\n", __func__, clk->id);
- .of_xlate = stm32_clk_of_xlate,
- .enable = stm32_clk_enable,
- .get_rate = stm32_clk_get_rate,
- .name = "stm32h7_rcc_clock",
- .id = UCLASS_CLK,
- .ops = &stm32_clk_ops,
- .probe = stm32_clk_probe,
- .priv_auto_alloc_size = sizeof(struct stm32_clk),
- .flags = DM_FLAG_PRE_RELOC,
Hi Vikas
On 09/20/2017 03:39 AM, Vikas Manocha wrote:
Hi Patrice,
- datasheet
I didn't get the history of this compatible string, we heritate it from kernel.
+Example:
#reset-cells = <1>;
#clock-cells = <2>
see above.
#size-cells = <0>;
vco1@58024430 {
#clock-cells = <0>;
reg = <0>;
vco2@58024438 {
#clock-cells = <0>;
reg = <1>;
st,clock-div = <2>;
st,frac = <0>;
st,vcosel = <1>;
st,pllrge = <2>;
| FRACN |
- "stm32,pll"
+- st,frac-status:
+Example:
interrupts = <50>;
+example:
- timer2 {
Which version of reference manual do you use ? in mine its SDEN, but i propably use a too old ref manual.
+struct clk_cfg {
- u32 gate_offset;
- u8 gate_bit_idx;
- const char *name;
- .name = _name,\
- kernel clocks.
Agree, it's a residue of my rework, i will send a fix for this
+struct stm32_clk {
+struct pll_psc {
- u8 divm;
- u16 divn;
- u8 divp;
- u8 divq;
- u8 divr;
- OSC_HSE = 25 MHz
- VCO = 500MHz
- .divm = 4,
- .divn = 80,
- .divp = 2,
- .divq = 2,
- .divr = 2,
ok
Yes, in ref manual, SDEN bit description is for "Step down converter"
FMCSRC_PLL1_Q_CK);
- u32 divider;
- return divider;
+enum pllsrc {
- HSE,
- LSE,
- HSI,
- CSI,
- I2S,
- TIMER,
- PLLSRC_NB,
- struct clk clk;
- u32 divider;
- int ret;
- clk.id = 0;
- if (ret) {
- if (ret) {
- divider = 0;
+enum pll1_output {
- PLL1_P_CK,
- PLL1_Q_CK,
- PLL1_R_CK,
- ulong pllsrc = 0;
- ulong vco, rate;
break;
break;
break;
pllsrc = 0;
break;
- if (!pllsrc)
return pllsrc;
- switch (output) {
- case PLL1_P_CK:
break;
- case PLL1_Q_CK:
break;
- case PLL1_R_CK:
break;
- return -EINVAL;
- ulong sysclk = 0;
- u32 gate_offset;
- u32 d1cfgr;
- u8 source, idx;
- switch (source) {
break;
break;
break;
break;
- if (!sysclk)
return sysclk;
- case RCC_AHB3ENR:
- case RCC_AHB1ENR:
- case RCC_AHB2ENR:
- case RCC_AHB4ENR:
return sysclk;
break;
- case RCC_APB3ENR:
__func__, sysclk);
return sysclk;
break;
- case RCC_APB4ENR:
__func__, sysclk);
return sysclk;
break;
__func__, sysclk);
return sysclk;
break;
- case RCC_APB2ENR:
__func__, sysclk);
return sysclk;
break;
- default:
return -EINVAL;
break;
- u32 gate_offset;
- fdt_addr_t addr;
- int err;
return -EINVAL;
- if (err) {
return err;
Agree, i will fix this too
Thanks
Patrice
Cheers, Vikas
return -ENODEV;
return -EINVAL;
} else {
- } else {
clk->id = 0;
- .id = UCLASS_CLK,
Hi Vikas
On 09/25/2017 09:51 AM, Patrice CHOTARD wrote:
Hi Vikas
Hi Patrice,
I have found the last version of STM32H7 ref manual, mine was too old, ok i will update the PWR_CR3_SDEN to PWR_CR3_SCUEN
thanks
Patrice
Hi Vikas
On 09/26/2017 10:51 AM, Patrice CHOTARD wrote:
Hi Vikas
Hi Vikas
Hi Patrice,
After double check, in the STM32H7x3 reference manual available on st.com (DocID029587 Rev 2), bit 2 of PWR_CR3 reg is described as following:
"Bit 2 SCUEN: Supply configuration update enable This bit is read-only: 0: Supply configuration update locked. 1: Single write enabled to Supply configuration (LDOEN and BYPASS)"
Whereas in the one i used, bit 2 of PWR_CR3 is described as:
"Bit 2 SDEN (1)(2) : SD converter Enable 0: Step down converter disabled 1: Step down converter enabled. (Default)"
If i follow ref manual DocID029587 Rev 2, this bit is read-only, so the write access of PWR_CR3 bit(2) in clk_stm32h7.c is useless. But after write access removal, the both STM32H7 disco and eval board doesn't boot.
The reference manual is wrong regarding with at least this bit. I will contact PWR architect to solve this point.
Patrice
thanks
Patrice
Thanks Patrice,
-----Original Message----- From: Patrice CHOTARD Sent: Tuesday, September 26, 2017 5:27 AM To: Vikas MANOCHA vikas.manocha@st.com; u-boot@lists.denx.de; albert.u.boot@aribaud.net; sjg@chromium.org Cc: Patrick DELAUNAY patrick.delaunay@st.com; Christophe KERELLO christophe.kerello@st.com Subject: Re: [PATCH v2 3/9] dm: clk: add clk driver support for stm32h7 SoCs
Hi Vikas
Hi Vikas
Hi Vikas
Hi Patrice,
+#define PWR_CR3 0x0c #define PWR_CR3_SDEN +BIT(2)
Ok, By the Rev3 of the Ref manual is also available online but does not matter for this bit. Even the explanation for this bit does not make sense if system does not boot without it.
Cheers, Vikas
Patrice
thanks
Patrice
+#define PWR_D3CR 0x18 +#define PWR_D3CR_VOS_MASK GENMASK(15, 14) #define +PWR_D3CR_VOS_SHIFT 14 #define VOS_SCALE_3 1 +#define VOS_SCALE_2 2 #define VOS_SCALE_1 +3 #define PWR_D3CR_VOSREADY BIT(13)
This driver is adapted from linux drivers/reset/reset-stm32.c It's compatible with STM32 F4/F7/H7 SoCs.
To add support for each SoC family, a SoC's specific include/dt-binfings/mfd/stm32xx-rcc.h file must be added.
This patch only includes stm32h7-rcc.h dedicated for STM32H7 SoCs. Other SoCs support will be added in the future.
Signed-off-by: Patrice Chotard patrice.chotard@st.com --- doc/device-tree-bindings/reset/st,stm32-rcc.txt | 6 ++ drivers/reset/Kconfig | 7 ++ drivers/reset/Makefile | 1 + drivers/reset/stm32-reset.c | 80 ++++++++++++++ include/dt-bindings/mfd/stm32h7-rcc.h | 138 ++++++++++++++++++++++++ 5 files changed, 232 insertions(+) create mode 100644 doc/device-tree-bindings/reset/st,stm32-rcc.txt create mode 100644 drivers/reset/stm32-reset.c create mode 100644 include/dt-bindings/mfd/stm32h7-rcc.h
diff --git a/doc/device-tree-bindings/reset/st,stm32-rcc.txt b/doc/device-tree-bindings/reset/st,stm32-rcc.txt new file mode 100644 index 0000000..01db343 --- /dev/null +++ b/doc/device-tree-bindings/reset/st,stm32-rcc.txt @@ -0,0 +1,6 @@ +STMicroelectronics STM32 Peripheral Reset Controller +==================================================== + +The RCC IP is both a reset and a clock controller. + +Please see Documentation/devicetree/bindings/clock/st,stm32-rcc.txt diff --git a/drivers/reset/Kconfig b/drivers/reset/Kconfig index e6af7da..ce46e27 100644 --- a/drivers/reset/Kconfig +++ b/drivers/reset/Kconfig @@ -28,6 +28,13 @@ config STI_RESET Say Y if you want to control reset signals provided by system config block.
+config STM32_RESET + bool "Enable the STM32 reset" + depends on STM32 + help + Support for reset controllers on STMicroelectronics STM32 family SoCs. + This resset driver is compatible with STM32 F4/F7 and H7 SoCs. + config TEGRA_CAR_RESET bool "Enable Tegra CAR-based reset driver" depends on TEGRA_CAR diff --git a/drivers/reset/Makefile b/drivers/reset/Makefile index d5e06c2..252cefe 100644 --- a/drivers/reset/Makefile +++ b/drivers/reset/Makefile @@ -6,6 +6,7 @@ obj-$(CONFIG_DM_RESET) += reset-uclass.o obj-$(CONFIG_SANDBOX_MBOX) += sandbox-reset.o obj-$(CONFIG_SANDBOX_MBOX) += sandbox-reset-test.o obj-$(CONFIG_STI_RESET) += sti-reset.o +obj-$(CONFIG_STM32_RESET) += stm32-reset.o obj-$(CONFIG_TEGRA_CAR_RESET) += tegra-car-reset.o obj-$(CONFIG_TEGRA186_RESET) += tegra186-reset.o obj-$(CONFIG_RESET_BCM6345) += reset-bcm6345.o diff --git a/drivers/reset/stm32-reset.c b/drivers/reset/stm32-reset.c new file mode 100644 index 0000000..9c627d8 --- /dev/null +++ b/drivers/reset/stm32-reset.c @@ -0,0 +1,80 @@ +/* + * Copyright (C) STMicroelectronics SA 2017 + * Author(s): Patrice CHOTARD, patrice.chotard@st.com for STMicroelectronics. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <reset-uclass.h> +#include <asm/io.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct stm32_reset_priv { + fdt_addr_t base; +}; + +static int stm32_reset_request(struct reset_ctl *reset_ctl) +{ + return 0; +} + +static int stm32_reset_free(struct reset_ctl *reset_ctl) +{ + return 0; +} + +static int stm32_reset_assert(struct reset_ctl *reset_ctl) +{ + struct stm32_reset_priv *priv = dev_get_priv(reset_ctl->dev); + int bank = (reset_ctl->id / BITS_PER_LONG) * 4; + int offset = reset_ctl->id % BITS_PER_LONG; + debug("%s: reset id = %ld bank = %d offset = %d)\n", __func__, + reset_ctl->id, bank, offset); + + setbits_le32(priv->base + bank, BIT(offset)); + + return 0; +} + +static int stm32_reset_deassert(struct reset_ctl *reset_ctl) +{ + struct stm32_reset_priv *priv = dev_get_priv(reset_ctl->dev); + int bank = (reset_ctl->id / BITS_PER_LONG) * 4; + int offset = reset_ctl->id % BITS_PER_LONG; + debug("%s: reset id = %ld bank = %d offset = %d)\n", __func__, + reset_ctl->id, bank, offset); + + clrbits_le32(priv->base + bank, BIT(offset)); + + return 0; +} + +static const struct reset_ops stm32_reset_ops = { + .request = stm32_reset_request, + .free = stm32_reset_free, + .rst_assert = stm32_reset_assert, + .rst_deassert = stm32_reset_deassert, +}; + +static int stm32_reset_probe(struct udevice *dev) +{ + struct stm32_reset_priv *priv = dev_get_priv(dev); + + priv->base = devfdt_get_addr(dev); + if (priv->base == FDT_ADDR_T_NONE) + return -EINVAL; + + return 0; +} + +U_BOOT_DRIVER(stm32_rcc_reset) = { + .name = "stm32_rcc_reset", + .id = UCLASS_RESET, + .probe = stm32_reset_probe, + .priv_auto_alloc_size = sizeof(struct stm32_reset_priv), + .ops = &stm32_reset_ops, +}; diff --git a/include/dt-bindings/mfd/stm32h7-rcc.h b/include/dt-bindings/mfd/stm32h7-rcc.h new file mode 100644 index 0000000..b96b3c3 --- /dev/null +++ b/include/dt-bindings/mfd/stm32h7-rcc.h @@ -0,0 +1,138 @@ +/* + * This header provides constants for the STM32H7 RCC IP + */ + +#ifndef _DT_BINDINGS_MFD_STM32H7_RCC_H +#define _DT_BINDINGS_MFD_STM32H7_RCC_H + +/* AHB3 */ +#define STM32H7_RCC_AHB3_MDMA 0 +#define STM32H7_RCC_AHB3_DMA2D 4 +#define STM32H7_RCC_AHB3_JPGDEC 5 +#define STM32H7_RCC_AHB3_FMC 12 +#define STM32H7_RCC_AHB3_QUADSPI 14 +#define STM32H7_RCC_AHB3_SDMMC1 16 +#define STM32H7_RCC_AHB3_CPU1 31 + +#define STM32H7_AHB3_RESET(bit) (STM32H7_RCC_AHB3_##bit + (0x7C * 8)) + +/* AHB1 */ +#define STM32H7_RCC_AHB1_DMA1 0 +#define STM32H7_RCC_AHB1_DMA2 1 +#define STM32H7_RCC_AHB1_ADC12 5 +#define STM32H7_RCC_AHB1_ART 14 +#define STM32H7_RCC_AHB1_ETH1MAC 15 +#define STM32H7_RCC_AHB1_USB1OTG 25 +#define STM32H7_RCC_AHB1_USB2OTG 27 +#define STM32H7_RCC_AHB1_CPU2 31 + +#define STM32H7_AHB1_RESET(bit) (STM32H7_RCC_AHB1_##bit + (0x80 * 8)) + +/* AHB2 */ +#define STM32H7_RCC_AHB2_CAMITF 0 +#define STM32H7_RCC_AHB2_CRYPT 4 +#define STM32H7_RCC_AHB2_HASH 5 +#define STM32H7_RCC_AHB2_RNG 6 +#define STM32H7_RCC_AHB2_SDMMC2 9 + +#define STM32H7_AHB2_RESET(bit) (STM32H7_RCC_AHB2_##bit + (0x84 * 8)) + +/* AHB4 */ +#define STM32H7_RCC_AHB4_GPIOA 0 +#define STM32H7_RCC_AHB4_GPIOB 1 +#define STM32H7_RCC_AHB4_GPIOC 2 +#define STM32H7_RCC_AHB4_GPIOD 3 +#define STM32H7_RCC_AHB4_GPIOE 4 +#define STM32H7_RCC_AHB4_GPIOF 5 +#define STM32H7_RCC_AHB4_GPIOG 6 +#define STM32H7_RCC_AHB4_GPIOH 7 +#define STM32H7_RCC_AHB4_GPIOI 8 +#define STM32H7_RCC_AHB4_GPIOJ 9 +#define STM32H7_RCC_AHB4_GPIOK 10 +#define STM32H7_RCC_AHB4_CRC 19 +#define STM32H7_RCC_AHB4_BDMA 21 +#define STM32H7_RCC_AHB4_ADC3 24 +#define STM32H7_RCC_AHB4_HSEM 25 + +#define STM32H7_AHB4_RESET(bit) (STM32H7_RCC_AHB4_##bit + (0x88 * 8)) + + +/* APB3 */ +#define STM32H7_RCC_APB3_LTDC 3 +#define STM32H7_RCC_APB3_DSI 4 + +#define STM32H7_APB3_RESET(bit) (STM32H7_RCC_APB3_##bit + (0x8C * 8)) + +/* APB1L */ +#define STM32H7_RCC_APB1L_TIM2 0 +#define STM32H7_RCC_APB1L_TIM3 1 +#define STM32H7_RCC_APB1L_TIM4 2 +#define STM32H7_RCC_APB1L_TIM5 3 +#define STM32H7_RCC_APB1L_TIM6 4 +#define STM32H7_RCC_APB1L_TIM7 5 +#define STM32H7_RCC_APB1L_TIM12 6 +#define STM32H7_RCC_APB1L_TIM13 7 +#define STM32H7_RCC_APB1L_TIM14 8 +#define STM32H7_RCC_APB1L_LPTIM1 9 +#define STM32H7_RCC_APB1L_SPI2 14 +#define STM32H7_RCC_APB1L_SPI3 15 +#define STM32H7_RCC_APB1L_SPDIF_RX 16 +#define STM32H7_RCC_APB1L_USART2 17 +#define STM32H7_RCC_APB1L_USART3 18 +#define STM32H7_RCC_APB1L_UART4 19 +#define STM32H7_RCC_APB1L_UART5 20 +#define STM32H7_RCC_APB1L_I2C1 21 +#define STM32H7_RCC_APB1L_I2C2 22 +#define STM32H7_RCC_APB1L_I2C3 23 +#define STM32H7_RCC_APB1L_HDMICEC 27 +#define STM32H7_RCC_APB1L_DAC12 29 +#define STM32H7_RCC_APB1L_USART7 30 +#define STM32H7_RCC_APB1L_USART8 31 + +#define STM32H7_APB1L_RESET(bit) (STM32H7_RCC_APB1L_##bit + (0x90 * 8)) + +/* APB1H */ +#define STM32H7_RCC_APB1H_CRS 1 +#define STM32H7_RCC_APB1H_SWP 2 +#define STM32H7_RCC_APB1H_OPAMP 4 +#define STM32H7_RCC_APB1H_MDIOS 5 +#define STM32H7_RCC_APB1H_FDCAN 8 + +#define STM32H7_APB1H_RESET(bit) (STM32H7_RCC_APB1H_##bit + (0x94 * 8)) + +/* APB2 */ +#define STM32H7_RCC_APB2_TIM1 0 +#define STM32H7_RCC_APB2_TIM8 1 +#define STM32H7_RCC_APB2_USART1 4 +#define STM32H7_RCC_APB2_USART6 5 +#define STM32H7_RCC_APB2_SPI1 12 +#define STM32H7_RCC_APB2_SPI4 13 +#define STM32H7_RCC_APB2_TIM15 16 +#define STM32H7_RCC_APB2_TIM16 17 +#define STM32H7_RCC_APB2_TIM17 18 +#define STM32H7_RCC_APB2_SPI5 20 +#define STM32H7_RCC_APB2_SAI1 22 +#define STM32H7_RCC_APB2_SAI2 23 +#define STM32H7_RCC_APB2_SAI3 24 +#define STM32H7_RCC_APB2_DFSDM1 28 +#define STM32H7_RCC_APB2_HRTIM 29 + +#define STM32H7_APB2_RESET(bit) (STM32H7_RCC_APB2_##bit + (0x98 * 8)) + +/* APB4 */ +#define STM32H7_RCC_APB4_SYSCFG 1 +#define STM32H7_RCC_APB4_LPUART1 3 +#define STM32H7_RCC_APB4_SPI6 5 +#define STM32H7_RCC_APB4_I2C4 7 +#define STM32H7_RCC_APB4_LPTIM2 9 +#define STM32H7_RCC_APB4_LPTIM3 10 +#define STM32H7_RCC_APB4_LPTIM4 11 +#define STM32H7_RCC_APB4_LPTIM5 12 +#define STM32H7_RCC_APB4_COMP12 14 +#define STM32H7_RCC_APB4_VREF 15 +#define STM32H7_RCC_APB4_SAI4 21 +#define STM32H7_RCC_APB4_TMPSENS 26 + +#define STM32H7_APB4_RESET(bit) (STM32H7_RCC_APB4_##bit + (0x9C * 8)) + +#endif /* _DT_BINDINGS_MFD_STM32H7_RCC_H */
This driver doesn't implement .of_match as it's binded by MFD RCC driver.
Signed-off-by: Patrice Chotard patrice.chotard@st.com Reviewed-by: Simon Glass sjg@chromium.org
This patch adds the support of reset and clock control block (rcc) found on STM32 SoCs. This driver is similar to a MFD linux driver.
This driver supports currently STM32H7 only. STM32F4 and STM32F7 will be migrated to this rcc MFD driver in the future to uniformize all STM32 SoCs already upstreamed.
Signed-off-by: Christophe Kerello christophe.kerello@st.com Signed-off-by: Patrice Chotard patrice.chotard@st.com Reviewed-by: Vikas Manocha vikas.manocha@st.com ---
v2: _ merge peripheral and kernel clocks arrays _ add voltage scaling support needed for Evaluation board
drivers/misc/Kconfig | 9 +++++++++ drivers/misc/Makefile | 1 + drivers/misc/stm32_rcc.c | 45 +++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 55 insertions(+) create mode 100644 drivers/misc/stm32_rcc.c
diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 4133017..f1c15cb 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -158,6 +158,15 @@ config PCA9551_I2C_ADDR help The I2C address of the PCA9551 LED controller.
+config STM32_RCC + bool "Enable RCC driver for the STM32 SoC's family" + depends on STM32 && MISC + help + Enable the STM32 RCC driver. The RCC block (Reset and Clock Control + block) is responsible of the management of the clock and reset + generation. + This driver is similar to an MFD driver in the Linux kernel. + config TEGRA_CAR bool "Enable support for the Tegra CAR driver" depends on TEGRA_NO_BPMP diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index 21f7e6c..ada7624 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -52,3 +52,4 @@ obj-$(CONFIG_FSL_DEVICE_DISABLE) += fsl_devdis.o obj-$(CONFIG_WINBOND_W83627) += winbond_w83627.o obj-$(CONFIG_QFW) += qfw.o obj-$(CONFIG_ROCKCHIP_EFUSE) += rockchip-efuse.o +obj-$(CONFIG_STM32_RCC) += stm32_rcc.o diff --git a/drivers/misc/stm32_rcc.c b/drivers/misc/stm32_rcc.c new file mode 100644 index 0000000..a6c2a75 --- /dev/null +++ b/drivers/misc/stm32_rcc.c @@ -0,0 +1,45 @@ +/* + * Copyright (C) STMicroelectronics SA 2017 + * Author(s): Patrice CHOTARD, patrice.chotard@st.com for STMicroelectronics. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <misc.h> +#include <dm/lists.h> + +static int stm32_rcc_bind(struct udevice *dev) +{ + int ret; + struct udevice *child; + + debug("%s(dev=%p)\n", __func__, dev); + + ret = device_bind_driver_to_node(dev, "stm32h7_rcc_clock", + "stm32h7_rcc_clock", + dev_ofnode(dev), &child); + if (ret) + return ret; + + return device_bind_driver_to_node(dev, "stm32_rcc_reset", + "stm32_rcc_reset", + dev_ofnode(dev), &child); +} + +static const struct misc_ops stm32_rcc_ops = { +}; + +static const struct udevice_id stm32_rcc_ids[] = { + {.compatible = "st,stm32h743-rcc"}, + { } +}; + +U_BOOT_DRIVER(stm32_rcc) = { + .name = "stm32-rcc", + .id = UCLASS_MISC, + .of_match = stm32_rcc_ids, + .bind = stm32_rcc_bind, + .ops = &stm32_rcc_ops, +};
Signed-off-by: Christophe Kerello christophe.kerello@st.com Signed-off-by: Patrice Chotard patrice.chotard@st.com Reviewed-by: Vikas Manocha vikas.manocha@st.com Reviewed-by: Simon Glass sjg@chromium.org
All these files are imported from linux kernel v4.13
Add device tree support for STM32H743 SoC and discovery board. This board offers : _ STM32H743XIH6 microcontroller with 2 Mbytes of Flash memory and 1 Mbyte of RAM in TFBGA240+25 package _ 5.7” 640x480 TFT color LCD with touch screen _ Ethernet compliant with IEEE-802.3-2002 _ USB OTG HS _ I2 C compatible serial interface _ ST-MEMS digital microphones _ 8-Gbyte (or more) SDIO3.0 interface microSD™ card _ 8Mx32bit SDRAM _ 1-Gbit Twin Quad-SPI NOR Flash _ Reset, wakeup, or key buttons _ Joystick with 4-direction control and selector _ Board connectors : 1 USB with Micro-AB Ethernet RJ45 Stereo headset jack including analog microphone input microSD™ card RCA connector JTAG/SWD and ETM trace _ Expansion connectors: Arduino Uno compatible Connectors 2 x PIO connectors (PMOD and PMOD+) _ On-board ST-LINK/V2-1 debugger/programmer with USB re-enumeration capability: mass storage, virtual COM port and debug port
v2: _ reword the board description
arch/arm/dts/Makefile | 1 + arch/arm/dts/stm32h743-pinctrl.dtsi | 169 +++ arch/arm/dts/stm32h743.dtsi | 91 ++ arch/arm/dts/stm32h743i-disco.dts | 73 ++ include/dt-bindings/pinctrl/stm32h7-pinfunc.h | 1612 +++++++++++++++++++++++++ 5 files changed, 1946 insertions(+) create mode 100644 arch/arm/dts/stm32h743-pinctrl.dtsi create mode 100644 arch/arm/dts/stm32h743.dtsi create mode 100644 arch/arm/dts/stm32h743i-disco.dts create mode 100644 include/dt-bindings/pinctrl/stm32h7-pinfunc.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 10d397d7..fb7ae82 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -205,6 +205,7 @@ dtb-$(CONFIG_ARCH_SNAPDRAGON) += dragonboard410c.dtb
dtb-$(CONFIG_STM32F7) += stm32f746-disco.dtb \ stm32f769-disco.dtb +dtb-$(CONFIG_STM32H7) += stm32h743i-disco.dtb
dtb-$(CONFIG_MACH_SUN4I) += \ sun4i-a10-a1000.dtb \ diff --git a/arch/arm/dts/stm32h743-pinctrl.dtsi b/arch/arm/dts/stm32h743-pinctrl.dtsi new file mode 100644 index 0000000..76bbd65 --- /dev/null +++ b/arch/arm/dts/stm32h743-pinctrl.dtsi @@ -0,0 +1,169 @@ +/* + * Copyright 2017 - Alexandre Torgue alexandre.torgue@st.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#include <dt-bindings/pinctrl/stm32h7-pinfunc.h> + +/ { + soc { + pin-controller { + #address-cells = <1>; + #size-cells = <1>; + compatible = "st,stm32h743-pinctrl"; + ranges = <0 0x58020000 0x3000>; + pins-are-numbered; + + gpioa: gpio@58020000 { + gpio-controller; + #gpio-cells = <2>; + reg = <0x0 0x400>; + clocks = <&timer_clk>; + st,bank-name = "GPIOA"; + }; + + gpiob: gpio@58020400 { + gpio-controller; + #gpio-cells = <2>; + reg = <0x400 0x400>; + clocks = <&timer_clk>; + st,bank-name = "GPIOB"; + }; + + gpioc: gpio@58020800 { + gpio-controller; + #gpio-cells = <2>; + reg = <0x800 0x400>; + clocks = <&timer_clk>; + st,bank-name = "GPIOC"; + }; + + gpiod: gpio@58020c00 { + gpio-controller; + #gpio-cells = <2>; + reg = <0xc00 0x400>; + clocks = <&timer_clk>; + st,bank-name = "GPIOD"; + }; + + gpioe: gpio@58021000 { + gpio-controller; + #gpio-cells = <2>; + reg = <0x1000 0x400>; + clocks = <&timer_clk>; + st,bank-name = "GPIOE"; + }; + + gpiof: gpio@58021400 { + gpio-controller; + #gpio-cells = <2>; + reg = <0x1400 0x400>; + clocks = <&timer_clk>; + st,bank-name = "GPIOF"; + }; + + gpiog: gpio@58021800 { + gpio-controller; + #gpio-cells = <2>; + reg = <0x1800 0x400>; + clocks = <&timer_clk>; + st,bank-name = "GPIOG"; + }; + + gpioh: gpio@58021c00 { + gpio-controller; + #gpio-cells = <2>; + reg = <0x1c00 0x400>; + clocks = <&timer_clk>; + st,bank-name = "GPIOH"; + }; + + gpioi: gpio@58022000 { + gpio-controller; + #gpio-cells = <2>; + reg = <0x2000 0x400>; + clocks = <&timer_clk>; + st,bank-name = "GPIOI"; + }; + + gpioj: gpio@58022400 { + gpio-controller; + #gpio-cells = <2>; + reg = <0x2400 0x400>; + clocks = <&timer_clk>; + st,bank-name = "GPIOJ"; + }; + + gpiok: gpio@58022800 { + gpio-controller; + #gpio-cells = <2>; + reg = <0x2800 0x400>; + clocks = <&timer_clk>; + st,bank-name = "GPIOK"; + }; + + usart1_pins: usart1@0 { + pins1 { + pinmux = <STM32H7_PB14_FUNC_USART1_TX>; + bias-disable; + drive-push-pull; + slew-rate = <0>; + }; + pins2 { + pinmux = <STM32H7_PB15_FUNC_USART1_RX>; + bias-disable; + }; + }; + + usart2_pins: usart2@0 { + pins1 { + pinmux = <STM32H7_PD5_FUNC_USART2_TX>; + bias-disable; + drive-push-pull; + slew-rate = <0>; + }; + pins2 { + pinmux = <STM32H7_PD6_FUNC_USART2_RX>; + bias-disable; + }; + }; + }; + }; +}; diff --git a/arch/arm/dts/stm32h743.dtsi b/arch/arm/dts/stm32h743.dtsi new file mode 100644 index 0000000..36a99db --- /dev/null +++ b/arch/arm/dts/stm32h743.dtsi @@ -0,0 +1,91 @@ +/* + * Copyright 2017 - Alexandre Torgue alexandre.torgue@st.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#include "skeleton.dtsi" +#include "armv7-m.dtsi" + +/ { + clocks { + clk_hse: clk-hse { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <0>; + }; + + timer_clk: timer-clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <125000000>; + }; + }; + + soc { + usart1: serial@40011000 { + compatible = "st,stm32f7-usart", "st,stm32f7-uart"; + reg = <0x40011000 0x400>; + interrupts = <37>; + status = "disabled"; + clocks = <&timer_clk>; + + }; + + usart2: serial@40004400 { + compatible = "st,stm32f7-usart", "st,stm32f7-uart"; + reg = <0x40004400 0x400>; + interrupts = <38>; + status = "disabled"; + clocks = <&timer_clk>; + }; + + timer5: timer@40000c00 { + compatible = "st,stm32-timer"; + reg = <0x40000c00 0x400>; + interrupts = <50>; + clocks = <&timer_clk>; + }; + }; +}; + +&systick { + clock-frequency = <250000000>; + status = "okay"; +}; diff --git a/arch/arm/dts/stm32h743i-disco.dts b/arch/arm/dts/stm32h743i-disco.dts new file mode 100644 index 0000000..79e841d --- /dev/null +++ b/arch/arm/dts/stm32h743i-disco.dts @@ -0,0 +1,73 @@ +/* + * Copyright 2017 - Patrice Chotard patrice.chotard@st.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "stm32h743.dtsi" +#include "stm32h743-pinctrl.dtsi" + +/ { + model = "STMicroelectronics STM32H743i-Discovery board"; + compatible = "st,stm32h743i-disco", "st,stm32h743"; + + chosen { + bootargs = "root=/dev/ram"; + stdout-path = "serial0:115200n8"; + }; + + memory { + reg = <0xd0000000 0x2000000>; + }; + + aliases { + serial0 = &usart2; + }; +}; + +&clk_hse { + clock-frequency = <125000000>; +}; + +&usart2 { + pinctrl-0 = <&usart2_pins>; + pinctrl-names = "default"; + status = "okay"; +}; diff --git a/include/dt-bindings/pinctrl/stm32h7-pinfunc.h b/include/dt-bindings/pinctrl/stm32h7-pinfunc.h new file mode 100644 index 0000000..cb673b5 --- /dev/null +++ b/include/dt-bindings/pinctrl/stm32h7-pinfunc.h @@ -0,0 +1,1612 @@ +#ifndef _DT_BINDINGS_STM32H7_PINFUNC_H +#define _DT_BINDINGS_STM32H7_PINFUNC_H + +#define STM32H7_PA0_FUNC_GPIO 0x0 +#define STM32H7_PA0_FUNC_TIM2_CH1_TIM2_ETR 0x2 +#define STM32H7_PA0_FUNC_TIM5_CH1 0x3 +#define STM32H7_PA0_FUNC_TIM8_ETR 0x4 +#define STM32H7_PA0_FUNC_TIM15_BKIN 0x5 +#define STM32H7_PA0_FUNC_USART2_CTS_NSS 0x8 +#define STM32H7_PA0_FUNC_UART4_TX 0x9 +#define STM32H7_PA0_FUNC_SDMMC2_CMD 0xa +#define STM32H7_PA0_FUNC_SAI2_SD_B 0xb +#define STM32H7_PA0_FUNC_ETH_MII_CRS 0xc +#define STM32H7_PA0_FUNC_EVENTOUT 0x10 +#define STM32H7_PA0_FUNC_ANALOG 0x11 + +#define STM32H7_PA1_FUNC_GPIO 0x100 +#define STM32H7_PA1_FUNC_TIM2_CH2 0x102 +#define STM32H7_PA1_FUNC_TIM5_CH2 0x103 +#define STM32H7_PA1_FUNC_LPTIM3_OUT 0x104 +#define STM32H7_PA1_FUNC_TIM15_CH1N 0x105 +#define STM32H7_PA1_FUNC_USART2_RTS 0x108 +#define STM32H7_PA1_FUNC_UART4_RX 0x109 +#define STM32H7_PA1_FUNC_QUADSPI_BK1_IO3 0x10a +#define STM32H7_PA1_FUNC_SAI2_MCK_B 0x10b +#define STM32H7_PA1_FUNC_ETH_MII_RX_CLK_ETH_RMII_REF_CLK 0x10c +#define STM32H7_PA1_FUNC_LCD_R2 0x10f +#define STM32H7_PA1_FUNC_EVENTOUT 0x110 +#define STM32H7_PA1_FUNC_ANALOG 0x111 + +#define STM32H7_PA2_FUNC_GPIO 0x200 +#define STM32H7_PA2_FUNC_TIM2_CH3 0x202 +#define STM32H7_PA2_FUNC_TIM5_CH3 0x203 +#define STM32H7_PA2_FUNC_LPTIM4_OUT 0x204 +#define STM32H7_PA2_FUNC_TIM15_CH1 0x205 +#define STM32H7_PA2_FUNC_USART2_TX 0x208 +#define STM32H7_PA2_FUNC_SAI2_SCK_B 0x209 +#define STM32H7_PA2_FUNC_ETH_MDIO 0x20c +#define STM32H7_PA2_FUNC_MDIOS_MDIO 0x20d +#define STM32H7_PA2_FUNC_LCD_R1 0x20f +#define STM32H7_PA2_FUNC_EVENTOUT 0x210 +#define STM32H7_PA2_FUNC_ANALOG 0x211 + +#define STM32H7_PA3_FUNC_GPIO 0x300 +#define STM32H7_PA3_FUNC_TIM2_CH4 0x302 +#define STM32H7_PA3_FUNC_TIM5_CH4 0x303 +#define STM32H7_PA3_FUNC_LPTIM5_OUT 0x304 +#define STM32H7_PA3_FUNC_TIM15_CH2 0x305 +#define STM32H7_PA3_FUNC_USART2_RX 0x308 +#define STM32H7_PA3_FUNC_LCD_B2 0x30a +#define STM32H7_PA3_FUNC_OTG_HS_ULPI_D0 0x30b +#define STM32H7_PA3_FUNC_ETH_MII_COL 0x30c +#define STM32H7_PA3_FUNC_LCD_B5 0x30f +#define STM32H7_PA3_FUNC_EVENTOUT 0x310 +#define STM32H7_PA3_FUNC_ANALOG 0x311 + +#define STM32H7_PA4_FUNC_GPIO 0x400 +#define STM32H7_PA4_FUNC_TIM5_ETR 0x403 +#define STM32H7_PA4_FUNC_SPI1_NSS_I2S1_WS 0x406 +#define STM32H7_PA4_FUNC_SPI3_NSS_I2S3_WS 0x407 +#define STM32H7_PA4_FUNC_USART2_CK 0x408 +#define STM32H7_PA4_FUNC_SPI6_NSS 0x409 +#define STM32H7_PA4_FUNC_OTG_HS_SOF 0x40d +#define STM32H7_PA4_FUNC_DCMI_HSYNC 0x40e +#define STM32H7_PA4_FUNC_LCD_VSYNC 0x40f +#define STM32H7_PA4_FUNC_EVENTOUT 0x410 +#define STM32H7_PA4_FUNC_ANALOG 0x411 + +#define STM32H7_PA5_FUNC_GPIO 0x500 +#define STM32H7_PA5_FUNC_TIM2_CH1_TIM2_ETR 0x502 +#define STM32H7_PA5_FUNC_TIM8_CH1N 0x504 +#define STM32H7_PA5_FUNC_SPI1_SCK_I2S1_CK 0x506 +#define STM32H7_PA5_FUNC_SPI6_SCK 0x509 +#define STM32H7_PA5_FUNC_OTG_HS_ULPI_CK 0x50b +#define STM32H7_PA5_FUNC_LCD_R4 0x50f +#define STM32H7_PA5_FUNC_EVENTOUT 0x510 +#define STM32H7_PA5_FUNC_ANALOG 0x511 + +#define STM32H7_PA6_FUNC_GPIO 0x600 +#define STM32H7_PA6_FUNC_TIM1_BKIN 0x602 +#define STM32H7_PA6_FUNC_TIM3_CH1 0x603 +#define STM32H7_PA6_FUNC_TIM8_BKIN 0x604 +#define STM32H7_PA6_FUNC_SPI1_MISO_I2S1_SDI 0x606 +#define STM32H7_PA6_FUNC_SPI6_MISO 0x609 +#define STM32H7_PA6_FUNC_TIM13_CH1 0x60a +#define STM32H7_PA6_FUNC_TIM8_BKIN_COMP12 0x60b +#define STM32H7_PA6_FUNC_MDIOS_MDC 0x60c +#define STM32H7_PA6_FUNC_TIM1_BKIN_COMP12 0x60d +#define STM32H7_PA6_FUNC_DCMI_PIXCLK 0x60e +#define STM32H7_PA6_FUNC_LCD_G2 0x60f +#define STM32H7_PA6_FUNC_EVENTOUT 0x610 +#define STM32H7_PA6_FUNC_ANALOG 0x611 + +#define STM32H7_PA7_FUNC_GPIO 0x700 +#define STM32H7_PA7_FUNC_TIM1_CH1N 0x702 +#define STM32H7_PA7_FUNC_TIM3_CH2 0x703 +#define STM32H7_PA7_FUNC_TIM8_CH1N 0x704 +#define STM32H7_PA7_FUNC_SPI1_MOSI_I2S1_SDO 0x706 +#define STM32H7_PA7_FUNC_SPI6_MOSI 0x709 +#define STM32H7_PA7_FUNC_TIM14_CH1 0x70a +#define STM32H7_PA7_FUNC_ETH_MII_RX_DV_ETH_RMII_CRS_DV 0x70c +#define STM32H7_PA7_FUNC_FMC_SDNWE 0x70d +#define STM32H7_PA7_FUNC_EVENTOUT 0x710 +#define STM32H7_PA7_FUNC_ANALOG 0x711 + +#define STM32H7_PA8_FUNC_GPIO 0x800 +#define STM32H7_PA8_FUNC_MCO1 0x801 +#define STM32H7_PA8_FUNC_TIM1_CH1 0x802 +#define STM32H7_PA8_FUNC_HRTIM_CHB2 0x803 +#define STM32H7_PA8_FUNC_TIM8_BKIN2 0x804 +#define STM32H7_PA8_FUNC_I2C3_SCL 0x805 +#define STM32H7_PA8_FUNC_USART1_CK 0x808 +#define STM32H7_PA8_FUNC_OTG_FS_SOF 0x80b +#define STM32H7_PA8_FUNC_UART7_RX 0x80c +#define STM32H7_PA8_FUNC_TIM8_BKIN2_COMP12 0x80d +#define STM32H7_PA8_FUNC_LCD_B3 0x80e +#define STM32H7_PA8_FUNC_LCD_R6 0x80f +#define STM32H7_PA8_FUNC_EVENTOUT 0x810 +#define STM32H7_PA8_FUNC_ANALOG 0x811 + +#define STM32H7_PA9_FUNC_GPIO 0x900 +#define STM32H7_PA9_FUNC_TIM1_CH2 0x902 +#define STM32H7_PA9_FUNC_HRTIM_CHC1 0x903 +#define STM32H7_PA9_FUNC_LPUART1_TX 0x904 +#define STM32H7_PA9_FUNC_I2C3_SMBA 0x905 +#define STM32H7_PA9_FUNC_SPI2_SCK_I2S2_CK 0x906 +#define STM32H7_PA9_FUNC_USART1_TX 0x908 +#define STM32H7_PA9_FUNC_CAN1_RXFD 0x90a +#define STM32H7_PA9_FUNC_ETH_TX_ER 0x90c +#define STM32H7_PA9_FUNC_DCMI_D0 0x90e +#define STM32H7_PA9_FUNC_LCD_R5 0x90f +#define STM32H7_PA9_FUNC_EVENTOUT 0x910 +#define STM32H7_PA9_FUNC_ANALOG 0x911 + +#define STM32H7_PA10_FUNC_GPIO 0xa00 +#define STM32H7_PA10_FUNC_TIM1_CH3 0xa02 +#define STM32H7_PA10_FUNC_HRTIM_CHC2 0xa03 +#define STM32H7_PA10_FUNC_LPUART1_RX 0xa04 +#define STM32H7_PA10_FUNC_USART1_RX 0xa08 +#define STM32H7_PA10_FUNC_CAN1_TXFD 0xa0a +#define STM32H7_PA10_FUNC_OTG_FS_ID 0xa0b +#define STM32H7_PA10_FUNC_MDIOS_MDIO 0xa0c +#define STM32H7_PA10_FUNC_LCD_B4 0xa0d +#define STM32H7_PA10_FUNC_DCMI_D1 0xa0e +#define STM32H7_PA10_FUNC_LCD_B1 0xa0f +#define STM32H7_PA10_FUNC_EVENTOUT 0xa10 +#define STM32H7_PA10_FUNC_ANALOG 0xa11 + +#define STM32H7_PA11_FUNC_GPIO 0xb00 +#define STM32H7_PA11_FUNC_TIM1_CH4 0xb02 +#define STM32H7_PA11_FUNC_HRTIM_CHD1 0xb03 +#define STM32H7_PA11_FUNC_LPUART1_CTS 0xb04 +#define STM32H7_PA11_FUNC_SPI2_NSS_I2S2_WS 0xb06 +#define STM32H7_PA11_FUNC_UART4_RX 0xb07 +#define STM32H7_PA11_FUNC_USART1_CTS_NSS 0xb08 +#define STM32H7_PA11_FUNC_CAN1_RX 0xb0a +#define STM32H7_PA11_FUNC_OTG_FS_DM 0xb0b +#define STM32H7_PA11_FUNC_LCD_R4 0xb0f +#define STM32H7_PA11_FUNC_EVENTOUT 0xb10 +#define STM32H7_PA11_FUNC_ANALOG 0xb11 + +#define STM32H7_PA12_FUNC_GPIO 0xc00 +#define STM32H7_PA12_FUNC_TIM1_ETR 0xc02 +#define STM32H7_PA12_FUNC_HRTIM_CHD2 0xc03 +#define STM32H7_PA12_FUNC_LPUART1_RTS 0xc04 +#define STM32H7_PA12_FUNC_SPI2_SCK_I2S2_CK 0xc06 +#define STM32H7_PA12_FUNC_UART4_TX 0xc07 +#define STM32H7_PA12_FUNC_USART1_RTS 0xc08 +#define STM32H7_PA12_FUNC_SAI2_FS_B 0xc09 +#define STM32H7_PA12_FUNC_CAN1_TX 0xc0a +#define STM32H7_PA12_FUNC_OTG_FS_DP 0xc0b +#define STM32H7_PA12_FUNC_LCD_R5 0xc0f +#define STM32H7_PA12_FUNC_EVENTOUT 0xc10 +#define STM32H7_PA12_FUNC_ANALOG 0xc11 + +#define STM32H7_PA13_FUNC_GPIO 0xd00 +#define STM32H7_PA13_FUNC_JTMS_SWDIO 0xd01 +#define STM32H7_PA13_FUNC_EVENTOUT 0xd10 +#define STM32H7_PA13_FUNC_ANALOG 0xd11 + +#define STM32H7_PA14_FUNC_GPIO 0xe00 +#define STM32H7_PA14_FUNC_JTCK_SWCLK 0xe01 +#define STM32H7_PA14_FUNC_EVENTOUT 0xe10 +#define STM32H7_PA14_FUNC_ANALOG 0xe11 + +#define STM32H7_PA15_FUNC_GPIO 0xf00 +#define STM32H7_PA15_FUNC_JTDI 0xf01 +#define STM32H7_PA15_FUNC_TIM2_CH1_TIM2_ETR 0xf02 +#define STM32H7_PA15_FUNC_HRTIM_FLT1 0xf03 +#define STM32H7_PA15_FUNC_HDMI_CEC 0xf05 +#define STM32H7_PA15_FUNC_SPI1_NSS_I2S1_WS 0xf06 +#define STM32H7_PA15_FUNC_SPI3_NSS_I2S3_WS 0xf07 +#define STM32H7_PA15_FUNC_SPI6_NSS 0xf08 +#define STM32H7_PA15_FUNC_UART4_RTS 0xf09 +#define STM32H7_PA15_FUNC_UART7_TX 0xf0c +#define STM32H7_PA15_FUNC_DSI_TE 0xf0e +#define STM32H7_PA15_FUNC_EVENTOUT 0xf10 +#define STM32H7_PA15_FUNC_ANALOG 0xf11 + +#define STM32H7_PB0_FUNC_GPIO 0x1000 +#define STM32H7_PB0_FUNC_TIM1_CH2N 0x1002 +#define STM32H7_PB0_FUNC_TIM3_CH3 0x1003 +#define STM32H7_PB0_FUNC_TIM8_CH2N 0x1004 +#define STM32H7_PB0_FUNC_DFSDM_CKOUT 0x1007 +#define STM32H7_PB0_FUNC_UART4_CTS 0x1009 +#define STM32H7_PB0_FUNC_LCD_R3 0x100a +#define STM32H7_PB0_FUNC_OTG_HS_ULPI_D1 0x100b +#define STM32H7_PB0_FUNC_ETH_MII_RXD2 0x100c +#define STM32H7_PB0_FUNC_LCD_G1 0x100f +#define STM32H7_PB0_FUNC_EVENTOUT 0x1010 +#define STM32H7_PB0_FUNC_ANALOG 0x1011 + +#define STM32H7_PB1_FUNC_GPIO 0x1100 +#define STM32H7_PB1_FUNC_TIM1_CH3N 0x1102 +#define STM32H7_PB1_FUNC_TIM3_CH4 0x1103 +#define STM32H7_PB1_FUNC_TIM8_CH3N 0x1104 +#define STM32H7_PB1_FUNC_DFSDM_DATIN1 0x1107 +#define STM32H7_PB1_FUNC_LCD_R6 0x110a +#define STM32H7_PB1_FUNC_OTG_HS_ULPI_D2 0x110b +#define STM32H7_PB1_FUNC_ETH_MII_RXD3 0x110c +#define STM32H7_PB1_FUNC_LCD_G0 0x110f +#define STM32H7_PB1_FUNC_EVENTOUT 0x1110 +#define STM32H7_PB1_FUNC_ANALOG 0x1111 + +#define STM32H7_PB2_FUNC_GPIO 0x1200 +#define STM32H7_PB2_FUNC_SAI1_D1 0x1203 +#define STM32H7_PB2_FUNC_DFSDM_CKIN1 0x1205 +#define STM32H7_PB2_FUNC_SAI1_SD_A 0x1207 +#define STM32H7_PB2_FUNC_SPI3_MOSI_I2S3_SDO 0x1208 +#define STM32H7_PB2_FUNC_SAI4_SD_A 0x1209 +#define STM32H7_PB2_FUNC_QUADSPI_CLK 0x120a +#define STM32H7_PB2_FUNC_SAI4_D1 0x120b +#define STM32H7_PB2_FUNC_ETH_TX_ER 0x120c +#define STM32H7_PB2_FUNC_EVENTOUT 0x1210 +#define STM32H7_PB2_FUNC_ANALOG 0x1211 + +#define STM32H7_PB3_FUNC_GPIO 0x1300 +#define STM32H7_PB3_FUNC_JTDO_TRACESWO 0x1301 +#define STM32H7_PB3_FUNC_TIM2_CH2 0x1302 +#define STM32H7_PB3_FUNC_HRTIM_FLT4 0x1303 +#define STM32H7_PB3_FUNC_SPI1_SCK_I2S1_CK 0x1306 +#define STM32H7_PB3_FUNC_SPI3_SCK_I2S3_CK 0x1307 +#define STM32H7_PB3_FUNC_SPI6_SCK 0x1309 +#define STM32H7_PB3_FUNC_SDMMC2_D2 0x130a +#define STM32H7_PB3_FUNC_UART7_RX 0x130c +#define STM32H7_PB3_FUNC_EVENTOUT 0x1310 +#define STM32H7_PB3_FUNC_ANALOG 0x1311 + +#define STM32H7_PB4_FUNC_GPIO 0x1400 +#define STM32H7_PB4_FUNC_NJTRST 0x1401 +#define STM32H7_PB4_FUNC_TIM16_BKIN 0x1402 +#define STM32H7_PB4_FUNC_TIM3_CH1 0x1403 +#define STM32H7_PB4_FUNC_HRTIM_EEV6 0x1404 +#define STM32H7_PB4_FUNC_SPI1_MISO_I2S1_SDI 0x1406 +#define STM32H7_PB4_FUNC_SPI3_MISO_I2S3_SDI 0x1407 +#define STM32H7_PB4_FUNC_SPI2_NSS_I2S2_WS 0x1408 +#define STM32H7_PB4_FUNC_SPI6_MISO 0x1409 +#define STM32H7_PB4_FUNC_SDMMC2_D3 0x140a +#define STM32H7_PB4_FUNC_UART7_TX 0x140c +#define STM32H7_PB4_FUNC_EVENTOUT 0x1410 +#define STM32H7_PB4_FUNC_ANALOG 0x1411 + +#define STM32H7_PB5_FUNC_GPIO 0x1500 +#define STM32H7_PB5_FUNC_TIM17_BKIN 0x1502 +#define STM32H7_PB5_FUNC_TIM3_CH2 0x1503 +#define STM32H7_PB5_FUNC_HRTIM_EEV7 0x1504 +#define STM32H7_PB5_FUNC_I2C1_SMBA 0x1505 +#define STM32H7_PB5_FUNC_SPI1_MOSI_I2S1_SDO 0x1506 +#define STM32H7_PB5_FUNC_I2C4_SMBA 0x1507 +#define STM32H7_PB5_FUNC_SPI3_MOSI_I2S3_SDO 0x1508 +#define STM32H7_PB5_FUNC_SPI6_MOSI 0x1509 +#define STM32H7_PB5_FUNC_CAN2_RX 0x150a +#define STM32H7_PB5_FUNC_OTG_HS_ULPI_D7 0x150b +#define STM32H7_PB5_FUNC_ETH_PPS_OUT 0x150c +#define STM32H7_PB5_FUNC_FMC_SDCKE1 0x150d +#define STM32H7_PB5_FUNC_DCMI_D10 0x150e +#define STM32H7_PB5_FUNC_UART5_RX 0x150f +#define STM32H7_PB5_FUNC_EVENTOUT 0x1510 +#define STM32H7_PB5_FUNC_ANALOG 0x1511 + +#define STM32H7_PB6_FUNC_GPIO 0x1600 +#define STM32H7_PB6_FUNC_TIM16_CH1N 0x1602 +#define STM32H7_PB6_FUNC_TIM4_CH1 0x1603 +#define STM32H7_PB6_FUNC_HRTIM_EEV8 0x1604 +#define STM32H7_PB6_FUNC_I2C1_SCL 0x1605 +#define STM32H7_PB6_FUNC_HDMI_CEC 0x1606 +#define STM32H7_PB6_FUNC_I2C4_SCL 0x1607 +#define STM32H7_PB6_FUNC_USART1_TX 0x1608 +#define STM32H7_PB6_FUNC_LPUART1_TX 0x1609 +#define STM32H7_PB6_FUNC_CAN2_TX 0x160a +#define STM32H7_PB6_FUNC_QUADSPI_BK1_NCS 0x160b +#define STM32H7_PB6_FUNC_DFSDM_DATIN5 0x160c +#define STM32H7_PB6_FUNC_FMC_SDNE1 0x160d +#define STM32H7_PB6_FUNC_DCMI_D5 0x160e +#define STM32H7_PB6_FUNC_UART5_TX 0x160f +#define STM32H7_PB6_FUNC_EVENTOUT 0x1610 +#define STM32H7_PB6_FUNC_ANALOG 0x1611 + +#define STM32H7_PB7_FUNC_GPIO 0x1700 +#define STM32H7_PB7_FUNC_TIM17_CH1N 0x1702 +#define STM32H7_PB7_FUNC_TIM4_CH2 0x1703 +#define STM32H7_PB7_FUNC_HRTIM_EEV9 0x1704 +#define STM32H7_PB7_FUNC_I2C1_SDA 0x1705 +#define STM32H7_PB7_FUNC_I2C4_SDA 0x1707 +#define STM32H7_PB7_FUNC_USART1_RX 0x1708 +#define STM32H7_PB7_FUNC_LPUART1_RX 0x1709 +#define STM32H7_PB7_FUNC_CAN2_TXFD 0x170a +#define STM32H7_PB7_FUNC_DFSDM_CKIN5 0x170c +#define STM32H7_PB7_FUNC_FMC_NL 0x170d +#define STM32H7_PB7_FUNC_DCMI_VSYNC 0x170e +#define STM32H7_PB7_FUNC_EVENTOUT 0x1710 +#define STM32H7_PB7_FUNC_ANALOG 0x1711 + +#define STM32H7_PB8_FUNC_GPIO 0x1800 +#define STM32H7_PB8_FUNC_TIM16_CH1 0x1802 +#define STM32H7_PB8_FUNC_TIM4_CH3 0x1803 +#define STM32H7_PB8_FUNC_DFSDM_CKIN7 0x1804 +#define STM32H7_PB8_FUNC_I2C1_SCL 0x1805 +#define STM32H7_PB8_FUNC_I2C4_SCL 0x1807 +#define STM32H7_PB8_FUNC_SDMMC1_CKIN 0x1808 +#define STM32H7_PB8_FUNC_UART4_RX 0x1809 +#define STM32H7_PB8_FUNC_CAN1_RX 0x180a +#define STM32H7_PB8_FUNC_SDMMC2_D4 0x180b +#define STM32H7_PB8_FUNC_ETH_MII_TXD3 0x180c +#define STM32H7_PB8_FUNC_SDMMC1_D4 0x180d +#define STM32H7_PB8_FUNC_DCMI_D6 0x180e +#define STM32H7_PB8_FUNC_LCD_B6 0x180f +#define STM32H7_PB8_FUNC_EVENTOUT 0x1810 +#define STM32H7_PB8_FUNC_ANALOG 0x1811 + +#define STM32H7_PB9_FUNC_GPIO 0x1900 +#define STM32H7_PB9_FUNC_TIM17_CH1 0x1902 +#define STM32H7_PB9_FUNC_TIM4_CH4 0x1903 +#define STM32H7_PB9_FUNC_DFSDM_DATIN7 0x1904 +#define STM32H7_PB9_FUNC_I2C1_SDA 0x1905 +#define STM32H7_PB9_FUNC_SPI2_NSS_I2S2_WS 0x1906 +#define STM32H7_PB9_FUNC_I2C4_SDA 0x1907 +#define STM32H7_PB9_FUNC_SDMMC1_CDIR 0x1908 +#define STM32H7_PB9_FUNC_UART4_TX 0x1909 +#define STM32H7_PB9_FUNC_CAN1_TX 0x190a +#define STM32H7_PB9_FUNC_SDMMC2_D5 0x190b +#define STM32H7_PB9_FUNC_I2C4_SMBA 0x190c +#define STM32H7_PB9_FUNC_SDMMC1_D5 0x190d +#define STM32H7_PB9_FUNC_DCMI_D7 0x190e +#define STM32H7_PB9_FUNC_LCD_B7 0x190f +#define STM32H7_PB9_FUNC_EVENTOUT 0x1910 +#define STM32H7_PB9_FUNC_ANALOG 0x1911 + +#define STM32H7_PB10_FUNC_GPIO 0x1a00 +#define STM32H7_PB10_FUNC_TIM2_CH3 0x1a02 +#define STM32H7_PB10_FUNC_HRTIM_SCOUT 0x1a03 +#define STM32H7_PB10_FUNC_LPTIM2_IN1 0x1a04 +#define STM32H7_PB10_FUNC_I2C2_SCL 0x1a05 +#define STM32H7_PB10_FUNC_SPI2_SCK_I2S2_CK 0x1a06 +#define STM32H7_PB10_FUNC_DFSDM_DATIN7 0x1a07 +#define STM32H7_PB10_FUNC_USART3_TX 0x1a08 +#define STM32H7_PB10_FUNC_QUADSPI_BK1_NCS 0x1a0a +#define STM32H7_PB10_FUNC_OTG_HS_ULPI_D3 0x1a0b +#define STM32H7_PB10_FUNC_ETH_MII_RX_ER 0x1a0c +#define STM32H7_PB10_FUNC_LCD_G4 0x1a0f +#define STM32H7_PB10_FUNC_EVENTOUT 0x1a10 +#define STM32H7_PB10_FUNC_ANALOG 0x1a11 + +#define STM32H7_PB11_FUNC_GPIO 0x1b00 +#define STM32H7_PB11_FUNC_TIM2_CH4 0x1b02 +#define STM32H7_PB11_FUNC_HRTIM_SCIN 0x1b03 +#define STM32H7_PB11_FUNC_LPTIM2_ETR 0x1b04 +#define STM32H7_PB11_FUNC_I2C2_SDA 0x1b05 +#define STM32H7_PB11_FUNC_DFSDM_CKIN7 0x1b07 +#define STM32H7_PB11_FUNC_USART3_RX 0x1b08 +#define STM32H7_PB11_FUNC_OTG_HS_ULPI_D4 0x1b0b +#define STM32H7_PB11_FUNC_ETH_MII_TX_EN_ETH_RMII_TX_EN 0x1b0c +#define STM32H7_PB11_FUNC_DSI_TE 0x1b0e +#define STM32H7_PB11_FUNC_LCD_G5 0x1b0f +#define STM32H7_PB11_FUNC_EVENTOUT 0x1b10 +#define STM32H7_PB11_FUNC_ANALOG 0x1b11 + +#define STM32H7_PB12_FUNC_GPIO 0x1c00 +#define STM32H7_PB12_FUNC_TIM1_BKIN 0x1c02 +#define STM32H7_PB12_FUNC_I2C2_SMBA 0x1c05 +#define STM32H7_PB12_FUNC_SPI2_NSS_I2S2_WS 0x1c06 +#define STM32H7_PB12_FUNC_DFSDM_DATIN1 0x1c07 +#define STM32H7_PB12_FUNC_USART3_CK 0x1c08 +#define STM32H7_PB12_FUNC_CAN2_RX 0x1c0a +#define STM32H7_PB12_FUNC_OTG_HS_ULPI_D5 0x1c0b +#define STM32H7_PB12_FUNC_ETH_MII_TXD0_ETH_RMII_TXD0 0x1c0c +#define STM32H7_PB12_FUNC_OTG_HS_ID 0x1c0d +#define STM32H7_PB12_FUNC_TIM1_BKIN_COMP12 0x1c0e +#define STM32H7_PB12_FUNC_UART5_RX 0x1c0f +#define STM32H7_PB12_FUNC_EVENTOUT 0x1c10 +#define STM32H7_PB12_FUNC_ANALOG 0x1c11 + +#define STM32H7_PB13_FUNC_GPIO 0x1d00 +#define STM32H7_PB13_FUNC_TIM1_CH1N 0x1d02 +#define STM32H7_PB13_FUNC_LPTIM2_OUT 0x1d04 +#define STM32H7_PB13_FUNC_SPI2_SCK_I2S2_CK 0x1d06 +#define STM32H7_PB13_FUNC_DFSDM_CKIN1 0x1d07 +#define STM32H7_PB13_FUNC_USART3_CTS_NSS 0x1d08 +#define STM32H7_PB13_FUNC_CAN2_TX 0x1d0a +#define STM32H7_PB13_FUNC_OTG_HS_ULPI_D6 0x1d0b +#define STM32H7_PB13_FUNC_ETH_MII_TXD1_ETH_RMII_TXD1 0x1d0c +#define STM32H7_PB13_FUNC_UART5_TX 0x1d0f +#define STM32H7_PB13_FUNC_EVENTOUT 0x1d10 +#define STM32H7_PB13_FUNC_ANALOG 0x1d11 + +#define STM32H7_PB14_FUNC_GPIO 0x1e00 +#define STM32H7_PB14_FUNC_TIM1_CH2N 0x1e02 +#define STM32H7_PB14_FUNC_TIM8_CH2N 0x1e04 +#define STM32H7_PB14_FUNC_USART1_TX 0x1e05 +#define STM32H7_PB14_FUNC_SPI2_MISO_I2S2_SDI 0x1e06 +#define STM32H7_PB14_FUNC_DFSDM_DATIN2 0x1e07 +#define STM32H7_PB14_FUNC_USART3_RTS 0x1e08 +#define STM32H7_PB14_FUNC_UART4_RTS 0x1e09 +#define STM32H7_PB14_FUNC_SDMMC2_D0 0x1e0a +#define STM32H7_PB14_FUNC_OTG_HS_DM 0x1e0d +#define STM32H7_PB14_FUNC_EVENTOUT 0x1e10 +#define STM32H7_PB14_FUNC_ANALOG 0x1e11 + +#define STM32H7_PB15_FUNC_GPIO 0x1f00 +#define STM32H7_PB15_FUNC_RTC_REFIN 0x1f01 +#define STM32H7_PB15_FUNC_TIM1_CH3N 0x1f02 +#define STM32H7_PB15_FUNC_TIM8_CH3N 0x1f04 +#define STM32H7_PB15_FUNC_USART1_RX 0x1f05 +#define STM32H7_PB15_FUNC_SPI2_MOSI_I2S2_SDO 0x1f06 +#define STM32H7_PB15_FUNC_DFSDM_CKIN2 0x1f07 +#define STM32H7_PB15_FUNC_UART4_CTS 0x1f09 +#define STM32H7_PB15_FUNC_SDMMC2_D1 0x1f0a +#define STM32H7_PB15_FUNC_OTG_HS_DP 0x1f0d +#define STM32H7_PB15_FUNC_EVENTOUT 0x1f10 +#define STM32H7_PB15_FUNC_ANALOG 0x1f11 + +#define STM32H7_PC0_FUNC_GPIO 0x2000 +#define STM32H7_PC0_FUNC_DFSDM_CKIN0 0x2004 +#define STM32H7_PC0_FUNC_DFSDM_DATIN4 0x2007 +#define STM32H7_PC0_FUNC_SAI2_FS_B 0x2009 +#define STM32H7_PC0_FUNC_OTG_HS_ULPI_STP 0x200b +#define STM32H7_PC0_FUNC_FMC_SDNWE 0x200d +#define STM32H7_PC0_FUNC_LCD_R5 0x200f +#define STM32H7_PC0_FUNC_EVENTOUT 0x2010 +#define STM32H7_PC0_FUNC_ANALOG 0x2011 + +#define STM32H7_PC1_FUNC_GPIO 0x2100 +#define STM32H7_PC1_FUNC_TRACED0 0x2101 +#define STM32H7_PC1_FUNC_SAI1_D1 0x2103 +#define STM32H7_PC1_FUNC_DFSDM_DATIN0 0x2104 +#define STM32H7_PC1_FUNC_DFSDM_CKIN4 0x2105 +#define STM32H7_PC1_FUNC_SPI2_MOSI_I2S2_SDO 0x2106 +#define STM32H7_PC1_FUNC_SAI1_SD_A 0x2107 +#define STM32H7_PC1_FUNC_SAI4_SD_A 0x2109 +#define STM32H7_PC1_FUNC_SDMMC2_CK 0x210a +#define STM32H7_PC1_FUNC_SAI4_D1 0x210b +#define STM32H7_PC1_FUNC_ETH_MDC 0x210c +#define STM32H7_PC1_FUNC_MDIOS_MDC 0x210d +#define STM32H7_PC1_FUNC_EVENTOUT 0x2110 +#define STM32H7_PC1_FUNC_ANALOG 0x2111 + +#define STM32H7_PC2_FUNC_GPIO 0x2200 +#define STM32H7_PC2_FUNC_DFSDM_CKIN1 0x2204 +#define STM32H7_PC2_FUNC_SPI2_MISO_I2S2_SDI 0x2206 +#define STM32H7_PC2_FUNC_DFSDM_CKOUT 0x2207 +#define STM32H7_PC2_FUNC_OTG_HS_ULPI_DIR 0x220b +#define STM32H7_PC2_FUNC_ETH_MII_TXD2 0x220c +#define STM32H7_PC2_FUNC_FMC_SDNE0 0x220d +#define STM32H7_PC2_FUNC_EVENTOUT 0x2210 +#define STM32H7_PC2_FUNC_ANALOG 0x2211 + +#define STM32H7_PC3_FUNC_GPIO 0x2300 +#define STM32H7_PC3_FUNC_DFSDM_DATIN1 0x2304 +#define STM32H7_PC3_FUNC_SPI2_MOSI_I2S2_SDO 0x2306 +#define STM32H7_PC3_FUNC_OTG_HS_ULPI_NXT 0x230b +#define STM32H7_PC3_FUNC_ETH_MII_TX_CLK 0x230c +#define STM32H7_PC3_FUNC_FMC_SDCKE0 0x230d +#define STM32H7_PC3_FUNC_EVENTOUT 0x2310 +#define STM32H7_PC3_FUNC_ANALOG 0x2311 + +#define STM32H7_PC4_FUNC_GPIO 0x2400 +#define STM32H7_PC4_FUNC_DFSDM_CKIN2 0x2404 +#define STM32H7_PC4_FUNC_I2S1_MCK 0x2406 +#define STM32H7_PC4_FUNC_SPDIFRX_IN2 0x240a +#define STM32H7_PC4_FUNC_ETH_MII_RXD0_ETH_RMII_RXD0 0x240c +#define STM32H7_PC4_FUNC_FMC_SDNE0 0x240d +#define STM32H7_PC4_FUNC_EVENTOUT 0x2410 +#define STM32H7_PC4_FUNC_ANALOG 0x2411 + +#define STM32H7_PC5_FUNC_GPIO 0x2500 +#define STM32H7_PC5_FUNC_SAI1_D3 0x2503 +#define STM32H7_PC5_FUNC_DFSDM_DATIN2 0x2504 +#define STM32H7_PC5_FUNC_SPDIFRX_IN3 0x250a +#define STM32H7_PC5_FUNC_SAI4_D3 0x250b +#define STM32H7_PC5_FUNC_ETH_MII_RXD1_ETH_RMII_RXD1 0x250c +#define STM32H7_PC5_FUNC_FMC_SDCKE0 0x250d +#define STM32H7_PC5_FUNC_COMP_1_OUT 0x250e +#define STM32H7_PC5_FUNC_EVENTOUT 0x2510 +#define STM32H7_PC5_FUNC_ANALOG 0x2511 + +#define STM32H7_PC6_FUNC_GPIO 0x2600 +#define STM32H7_PC6_FUNC_HRTIM_CHA1 0x2602 +#define STM32H7_PC6_FUNC_TIM3_CH1 0x2603 +#define STM32H7_PC6_FUNC_TIM8_CH1 0x2604 +#define STM32H7_PC6_FUNC_DFSDM_CKIN3 0x2605 +#define STM32H7_PC6_FUNC_I2S2_MCK 0x2606 +#define STM32H7_PC6_FUNC_USART6_TX 0x2608 +#define STM32H7_PC6_FUNC_SDMMC1_D0DIR 0x2609 +#define STM32H7_PC6_FUNC_FMC_NWAIT 0x260a +#define STM32H7_PC6_FUNC_SDMMC2_D6 0x260b +#define STM32H7_PC6_FUNC_SDMMC1_D6 0x260d +#define STM32H7_PC6_FUNC_DCMI_D0 0x260e +#define STM32H7_PC6_FUNC_LCD_HSYNC 0x260f +#define STM32H7_PC6_FUNC_EVENTOUT 0x2610 +#define STM32H7_PC6_FUNC_ANALOG 0x2611 + +#define STM32H7_PC7_FUNC_GPIO 0x2700 +#define STM32H7_PC7_FUNC_TRGIO 0x2701 +#define STM32H7_PC7_FUNC_HRTIM_CHA2 0x2702 +#define STM32H7_PC7_FUNC_TIM3_CH2 0x2703 +#define STM32H7_PC7_FUNC_TIM8_CH2 0x2704 +#define STM32H7_PC7_FUNC_DFSDM_DATIN3 0x2705 +#define STM32H7_PC7_FUNC_I2S3_MCK 0x2707 +#define STM32H7_PC7_FUNC_USART6_RX 0x2708 +#define STM32H7_PC7_FUNC_SDMMC1_D123DIR 0x2709 +#define STM32H7_PC7_FUNC_FMC_NE1 0x270a +#define STM32H7_PC7_FUNC_SDMMC2_D7 0x270b +#define STM32H7_PC7_FUNC_SWPMI_TX 0x270c +#define STM32H7_PC7_FUNC_SDMMC1_D7 0x270d +#define STM32H7_PC7_FUNC_DCMI_D1 0x270e +#define STM32H7_PC7_FUNC_LCD_G6 0x270f +#define STM32H7_PC7_FUNC_EVENTOUT 0x2710 +#define STM32H7_PC7_FUNC_ANALOG 0x2711 + +#define STM32H7_PC8_FUNC_GPIO 0x2800 +#define STM32H7_PC8_FUNC_TRACED1 0x2801 +#define STM32H7_PC8_FUNC_HRTIM_CHB1 0x2802 +#define STM32H7_PC8_FUNC_TIM3_CH3 0x2803 +#define STM32H7_PC8_FUNC_TIM8_CH3 0x2804 +#define STM32H7_PC8_FUNC_USART6_CK 0x2808 +#define STM32H7_PC8_FUNC_UART5_RTS 0x2809 +#define STM32H7_PC8_FUNC_FMC_NE2_FMC_NCE 0x280a +#define STM32H7_PC8_FUNC_SWPMI_RX 0x280c +#define STM32H7_PC8_FUNC_SDMMC1_D0 0x280d +#define STM32H7_PC8_FUNC_DCMI_D2 0x280e +#define STM32H7_PC8_FUNC_EVENTOUT 0x2810 +#define STM32H7_PC8_FUNC_ANALOG 0x2811 + +#define STM32H7_PC9_FUNC_GPIO 0x2900 +#define STM32H7_PC9_FUNC_MCO2 0x2901 +#define STM32H7_PC9_FUNC_TIM3_CH4 0x2903 +#define STM32H7_PC9_FUNC_TIM8_CH4 0x2904 +#define STM32H7_PC9_FUNC_I2C3_SDA 0x2905 +#define STM32H7_PC9_FUNC_I2S_CKIN 0x2906 +#define STM32H7_PC9_FUNC_UART5_CTS 0x2909 +#define STM32H7_PC9_FUNC_QUADSPI_BK1_IO0 0x290a +#define STM32H7_PC9_FUNC_LCD_G3 0x290b +#define STM32H7_PC9_FUNC_SWPMI_SUSPEND 0x290c +#define STM32H7_PC9_FUNC_SDMMC1_D1 0x290d +#define STM32H7_PC9_FUNC_DCMI_D3 0x290e +#define STM32H7_PC9_FUNC_LCD_B2 0x290f +#define STM32H7_PC9_FUNC_EVENTOUT 0x2910 +#define STM32H7_PC9_FUNC_ANALOG 0x2911 + +#define STM32H7_PC10_FUNC_GPIO 0x2a00 +#define STM32H7_PC10_FUNC_HRTIM_EEV1 0x2a03 +#define STM32H7_PC10_FUNC_DFSDM_CKIN5 0x2a04 +#define STM32H7_PC10_FUNC_SPI3_SCK_I2S3_CK 0x2a07 +#define STM32H7_PC10_FUNC_USART3_TX 0x2a08 +#define STM32H7_PC10_FUNC_UART4_TX 0x2a09 +#define STM32H7_PC10_FUNC_QUADSPI_BK1_IO1 0x2a0a +#define STM32H7_PC10_FUNC_SDMMC1_D2 0x2a0d +#define STM32H7_PC10_FUNC_DCMI_D8 0x2a0e +#define STM32H7_PC10_FUNC_LCD_R2 0x2a0f +#define STM32H7_PC10_FUNC_EVENTOUT 0x2a10 +#define STM32H7_PC10_FUNC_ANALOG 0x2a11 + +#define STM32H7_PC11_FUNC_GPIO 0x2b00 +#define STM32H7_PC11_FUNC_HRTIM_FLT2 0x2b03 +#define STM32H7_PC11_FUNC_DFSDM_DATIN5 0x2b04 +#define STM32H7_PC11_FUNC_SPI3_MISO_I2S3_SDI 0x2b07 +#define STM32H7_PC11_FUNC_USART3_RX 0x2b08 +#define STM32H7_PC11_FUNC_UART4_RX 0x2b09 +#define STM32H7_PC11_FUNC_QUADSPI_BK2_NCS 0x2b0a +#define STM32H7_PC11_FUNC_SDMMC1_D3 0x2b0d +#define STM32H7_PC11_FUNC_DCMI_D4 0x2b0e +#define STM32H7_PC11_FUNC_EVENTOUT 0x2b10 +#define STM32H7_PC11_FUNC_ANALOG 0x2b11 + +#define STM32H7_PC12_FUNC_GPIO 0x2c00 +#define STM32H7_PC12_FUNC_TRACED3 0x2c01 +#define STM32H7_PC12_FUNC_HRTIM_EEV2 0x2c03 +#define STM32H7_PC12_FUNC_SPI3_MOSI_I2S3_SDO 0x2c07 +#define STM32H7_PC12_FUNC_USART3_CK 0x2c08 +#define STM32H7_PC12_FUNC_UART5_TX 0x2c09 +#define STM32H7_PC12_FUNC_SDMMC1_CK 0x2c0d +#define STM32H7_PC12_FUNC_DCMI_D9 0x2c0e +#define STM32H7_PC12_FUNC_EVENTOUT 0x2c10 +#define STM32H7_PC12_FUNC_ANALOG 0x2c11 + +#define STM32H7_PC13_FUNC_GPIO 0x2d00 +#define STM32H7_PC13_FUNC_EVENTOUT 0x2d10 +#define STM32H7_PC13_FUNC_ANALOG 0x2d11 + +#define STM32H7_PC14_FUNC_GPIO 0x2e00 +#define STM32H7_PC14_FUNC_EVENTOUT 0x2e10 +#define STM32H7_PC14_FUNC_ANALOG 0x2e11 + +#define STM32H7_PC15_FUNC_GPIO 0x2f00 +#define STM32H7_PC15_FUNC_EVENTOUT 0x2f10 +#define STM32H7_PC15_FUNC_ANALOG 0x2f11 + +#define STM32H7_PD0_FUNC_GPIO 0x3000 +#define STM32H7_PD0_FUNC_DFSDM_CKIN6 0x3004 +#define STM32H7_PD0_FUNC_SAI3_SCK_A 0x3007 +#define STM32H7_PD0_FUNC_UART4_RX 0x3009 +#define STM32H7_PD0_FUNC_CAN1_RX 0x300a +#define STM32H7_PD0_FUNC_FMC_D2_FMC_DA2 0x300d +#define STM32H7_PD0_FUNC_EVENTOUT 0x3010 +#define STM32H7_PD0_FUNC_ANALOG 0x3011 + +#define STM32H7_PD1_FUNC_GPIO 0x3100 +#define STM32H7_PD1_FUNC_DFSDM_DATIN6 0x3104 +#define STM32H7_PD1_FUNC_SAI3_SD_A 0x3107 +#define STM32H7_PD1_FUNC_UART4_TX 0x3109 +#define STM32H7_PD1_FUNC_CAN1_TX 0x310a +#define STM32H7_PD1_FUNC_FMC_D3_FMC_DA3 0x310d +#define STM32H7_PD1_FUNC_EVENTOUT 0x3110 +#define STM32H7_PD1_FUNC_ANALOG 0x3111 + +#define STM32H7_PD2_FUNC_GPIO 0x3200 +#define STM32H7_PD2_FUNC_TRACED2 0x3201 +#define STM32H7_PD2_FUNC_TIM3_ETR 0x3203 +#define STM32H7_PD2_FUNC_UART5_RX 0x3209 +#define STM32H7_PD2_FUNC_SDMMC1_CMD 0x320d +#define STM32H7_PD2_FUNC_DCMI_D11 0x320e +#define STM32H7_PD2_FUNC_EVENTOUT 0x3210 +#define STM32H7_PD2_FUNC_ANALOG 0x3211 + +#define STM32H7_PD3_FUNC_GPIO 0x3300 +#define STM32H7_PD3_FUNC_DFSDM_CKOUT 0x3304 +#define STM32H7_PD3_FUNC_SPI2_SCK_I2S2_CK 0x3306 +#define STM32H7_PD3_FUNC_USART2_CTS_NSS 0x3308 +#define STM32H7_PD3_FUNC_FMC_CLK 0x330d +#define STM32H7_PD3_FUNC_DCMI_D5 0x330e +#define STM32H7_PD3_FUNC_LCD_G7 0x330f +#define STM32H7_PD3_FUNC_EVENTOUT 0x3310 +#define STM32H7_PD3_FUNC_ANALOG 0x3311 + +#define STM32H7_PD4_FUNC_GPIO 0x3400 +#define STM32H7_PD4_FUNC_HRTIM_FLT3 0x3403 +#define STM32H7_PD4_FUNC_SAI3_FS_A 0x3407 +#define STM32H7_PD4_FUNC_USART2_RTS 0x3408 +#define STM32H7_PD4_FUNC_CAN1_RXFD 0x340a +#define STM32H7_PD4_FUNC_FMC_NOE 0x340d +#define STM32H7_PD4_FUNC_EVENTOUT 0x3410 +#define STM32H7_PD4_FUNC_ANALOG 0x3411 + +#define STM32H7_PD5_FUNC_GPIO 0x3500 +#define STM32H7_PD5_FUNC_HRTIM_EEV3 0x3503 +#define STM32H7_PD5_FUNC_USART2_TX 0x3508 +#define STM32H7_PD5_FUNC_CAN1_TXFD 0x350a +#define STM32H7_PD5_FUNC_FMC_NWE 0x350d +#define STM32H7_PD5_FUNC_EVENTOUT 0x3510 +#define STM32H7_PD5_FUNC_ANALOG 0x3511 + +#define STM32H7_PD6_FUNC_GPIO 0x3600 +#define STM32H7_PD6_FUNC_SAI1_D1 0x3603 +#define STM32H7_PD6_FUNC_DFSDM_CKIN4 0x3604 +#define STM32H7_PD6_FUNC_DFSDM_DATIN1 0x3605 +#define STM32H7_PD6_FUNC_SPI3_MOSI_I2S3_SDO 0x3606 +#define STM32H7_PD6_FUNC_SAI1_SD_A 0x3607 +#define STM32H7_PD6_FUNC_USART2_RX 0x3608 +#define STM32H7_PD6_FUNC_SAI4_SD_A 0x3609 +#define STM32H7_PD6_FUNC_CAN2_RXFD 0x360a +#define STM32H7_PD6_FUNC_SAI4_D1 0x360b +#define STM32H7_PD6_FUNC_SDMMC2_CK 0x360c +#define STM32H7_PD6_FUNC_FMC_NWAIT 0x360d +#define STM32H7_PD6_FUNC_DCMI_D10 0x360e +#define STM32H7_PD6_FUNC_LCD_B2 0x360f +#define STM32H7_PD6_FUNC_EVENTOUT 0x3610 +#define STM32H7_PD6_FUNC_ANALOG 0x3611 + +#define STM32H7_PD7_FUNC_GPIO 0x3700 +#define STM32H7_PD7_FUNC_DFSDM_DATIN4 0x3704 +#define STM32H7_PD7_FUNC_SPI1_MOSI_I2S1_SDO 0x3706 +#define STM32H7_PD7_FUNC_DFSDM_CKIN1 0x3707 +#define STM32H7_PD7_FUNC_USART2_CK 0x3708 +#define STM32H7_PD7_FUNC_SPDIFRX_IN0 0x370a +#define STM32H7_PD7_FUNC_SDMMC2_CMD 0x370c +#define STM32H7_PD7_FUNC_FMC_NE1 0x370d +#define STM32H7_PD7_FUNC_EVENTOUT 0x3710 +#define STM32H7_PD7_FUNC_ANALOG 0x3711 + +#define STM32H7_PD8_FUNC_GPIO 0x3800 +#define STM32H7_PD8_FUNC_DFSDM_CKIN3 0x3804 +#define STM32H7_PD8_FUNC_SAI3_SCK_B 0x3807 +#define STM32H7_PD8_FUNC_USART3_TX 0x3808 +#define STM32H7_PD8_FUNC_SPDIFRX_IN1 0x380a +#define STM32H7_PD8_FUNC_FMC_D13_FMC_DA13 0x380d +#define STM32H7_PD8_FUNC_EVENTOUT 0x3810 +#define STM32H7_PD8_FUNC_ANALOG 0x3811 + +#define STM32H7_PD9_FUNC_GPIO 0x3900 +#define STM32H7_PD9_FUNC_DFSDM_DATIN3 0x3904 +#define STM32H7_PD9_FUNC_SAI3_SD_B 0x3907 +#define STM32H7_PD9_FUNC_USART3_RX 0x3908 +#define STM32H7_PD9_FUNC_CAN2_RXFD 0x390a +#define STM32H7_PD9_FUNC_FMC_D14_FMC_DA14 0x390d +#define STM32H7_PD9_FUNC_EVENTOUT 0x3910 +#define STM32H7_PD9_FUNC_ANALOG 0x3911 + +#define STM32H7_PD10_FUNC_GPIO 0x3a00 +#define STM32H7_PD10_FUNC_DFSDM_CKOUT 0x3a04 +#define STM32H7_PD10_FUNC_SAI3_FS_B 0x3a07 +#define STM32H7_PD10_FUNC_USART3_CK 0x3a08 +#define STM32H7_PD10_FUNC_CAN2_TXFD 0x3a0a +#define STM32H7_PD10_FUNC_FMC_D15_FMC_DA15 0x3a0d +#define STM32H7_PD10_FUNC_LCD_B3 0x3a0f +#define STM32H7_PD10_FUNC_EVENTOUT 0x3a10 +#define STM32H7_PD10_FUNC_ANALOG 0x3a11 + +#define STM32H7_PD11_FUNC_GPIO 0x3b00 +#define STM32H7_PD11_FUNC_LPTIM2_IN2 0x3b04 +#define STM32H7_PD11_FUNC_I2C4_SMBA 0x3b05 +#define STM32H7_PD11_FUNC_USART3_CTS_NSS 0x3b08 +#define STM32H7_PD11_FUNC_QUADSPI_BK1_IO0 0x3b0a +#define STM32H7_PD11_FUNC_SAI2_SD_A 0x3b0b +#define STM32H7_PD11_FUNC_FMC_A16 0x3b0d +#define STM32H7_PD11_FUNC_EVENTOUT 0x3b10 +#define STM32H7_PD11_FUNC_ANALOG 0x3b11 + +#define STM32H7_PD12_FUNC_GPIO 0x3c00 +#define STM32H7_PD12_FUNC_LPTIM1_IN1 0x3c02 +#define STM32H7_PD12_FUNC_TIM4_CH1 0x3c03 +#define STM32H7_PD12_FUNC_LPTIM2_IN1 0x3c04 +#define STM32H7_PD12_FUNC_I2C4_SCL 0x3c05 +#define STM32H7_PD12_FUNC_USART3_RTS 0x3c08 +#define STM32H7_PD12_FUNC_QUADSPI_BK1_IO1 0x3c0a +#define STM32H7_PD12_FUNC_SAI2_FS_A 0x3c0b +#define STM32H7_PD12_FUNC_FMC_A17 0x3c0d +#define STM32H7_PD12_FUNC_EVENTOUT 0x3c10 +#define STM32H7_PD12_FUNC_ANALOG 0x3c11 + +#define STM32H7_PD13_FUNC_GPIO 0x3d00 +#define STM32H7_PD13_FUNC_LPTIM1_OUT 0x3d02 +#define STM32H7_PD13_FUNC_TIM4_CH2 0x3d03 +#define STM32H7_PD13_FUNC_I2C4_SDA 0x3d05 +#define STM32H7_PD13_FUNC_QUADSPI_BK1_IO3 0x3d0a +#define STM32H7_PD13_FUNC_SAI2_SCK_A 0x3d0b +#define STM32H7_PD13_FUNC_FMC_A18 0x3d0d +#define STM32H7_PD13_FUNC_EVENTOUT 0x3d10 +#define STM32H7_PD13_FUNC_ANALOG 0x3d11 + +#define STM32H7_PD14_FUNC_GPIO 0x3e00 +#define STM32H7_PD14_FUNC_TIM4_CH3 0x3e03 +#define STM32H7_PD14_FUNC_SAI3_MCLK_B 0x3e07 +#define STM32H7_PD14_FUNC_UART8_CTS 0x3e09 +#define STM32H7_PD14_FUNC_FMC_D0_FMC_DA0 0x3e0d +#define STM32H7_PD14_FUNC_EVENTOUT 0x3e10 +#define STM32H7_PD14_FUNC_ANALOG 0x3e11 + +#define STM32H7_PD15_FUNC_GPIO 0x3f00 +#define STM32H7_PD15_FUNC_TIM4_CH4 0x3f03 +#define STM32H7_PD15_FUNC_SAI3_MCLK_A 0x3f07 +#define STM32H7_PD15_FUNC_UART8_RTS 0x3f09 +#define STM32H7_PD15_FUNC_FMC_D1_FMC_DA1 0x3f0d +#define STM32H7_PD15_FUNC_EVENTOUT 0x3f10 +#define STM32H7_PD15_FUNC_ANALOG 0x3f11 + +#define STM32H7_PE0_FUNC_GPIO 0x4000 +#define STM32H7_PE0_FUNC_LPTIM1_ETR 0x4002 +#define STM32H7_PE0_FUNC_TIM4_ETR 0x4003 +#define STM32H7_PE0_FUNC_HRTIM_SCIN 0x4004 +#define STM32H7_PE0_FUNC_LPTIM2_ETR 0x4005 +#define STM32H7_PE0_FUNC_UART8_RX 0x4009 +#define STM32H7_PE0_FUNC_CAN1_RXFD 0x400a +#define STM32H7_PE0_FUNC_SAI2_MCK_A 0x400b +#define STM32H7_PE0_FUNC_FMC_NBL0 0x400d +#define STM32H7_PE0_FUNC_DCMI_D2 0x400e +#define STM32H7_PE0_FUNC_EVENTOUT 0x4010 +#define STM32H7_PE0_FUNC_ANALOG 0x4011 + +#define STM32H7_PE1_FUNC_GPIO 0x4100 +#define STM32H7_PE1_FUNC_LPTIM1_IN2 0x4102 +#define STM32H7_PE1_FUNC_HRTIM_SCOUT 0x4104 +#define STM32H7_PE1_FUNC_UART8_TX 0x4109 +#define STM32H7_PE1_FUNC_CAN1_TXFD 0x410a +#define STM32H7_PE1_FUNC_FMC_NBL1 0x410d +#define STM32H7_PE1_FUNC_DCMI_D3 0x410e +#define STM32H7_PE1_FUNC_EVENTOUT 0x4110 +#define STM32H7_PE1_FUNC_ANALOG 0x4111 + +#define STM32H7_PE2_FUNC_GPIO 0x4200 +#define STM32H7_PE2_FUNC_TRACECLK 0x4201 +#define STM32H7_PE2_FUNC_SAI1_CK1 0x4203 +#define STM32H7_PE2_FUNC_SPI4_SCK 0x4206 +#define STM32H7_PE2_FUNC_SAI1_MCLK_A 0x4207 +#define STM32H7_PE2_FUNC_SAI4_MCLK_A 0x4209 +#define STM32H7_PE2_FUNC_QUADSPI_BK1_IO2 0x420a +#define STM32H7_PE2_FUNC_SAI4_CK1 0x420b +#define STM32H7_PE2_FUNC_ETH_MII_TXD3 0x420c +#define STM32H7_PE2_FUNC_FMC_A23 0x420d +#define STM32H7_PE2_FUNC_EVENTOUT 0x4210 +#define STM32H7_PE2_FUNC_ANALOG 0x4211 + +#define STM32H7_PE3_FUNC_GPIO 0x4300 +#define STM32H7_PE3_FUNC_TRACED0 0x4301 +#define STM32H7_PE3_FUNC_TIM15_BKIN 0x4305 +#define STM32H7_PE3_FUNC_SAI1_SD_B 0x4307 +#define STM32H7_PE3_FUNC_SAI4_SD_B 0x4309 +#define STM32H7_PE3_FUNC_FMC_A19 0x430d +#define STM32H7_PE3_FUNC_EVENTOUT 0x4310 +#define STM32H7_PE3_FUNC_ANALOG 0x4311 + +#define STM32H7_PE4_FUNC_GPIO 0x4400 +#define STM32H7_PE4_FUNC_TRACED1 0x4401 +#define STM32H7_PE4_FUNC_SAI1_D2 0x4403 +#define STM32H7_PE4_FUNC_DFSDM_DATIN3 0x4404 +#define STM32H7_PE4_FUNC_TIM15_CH1N 0x4405 +#define STM32H7_PE4_FUNC_SPI4_NSS 0x4406 +#define STM32H7_PE4_FUNC_SAI1_FS_A 0x4407 +#define STM32H7_PE4_FUNC_SAI4_FS_A 0x4409 +#define STM32H7_PE4_FUNC_SAI4_D2 0x440b +#define STM32H7_PE4_FUNC_FMC_A20 0x440d +#define STM32H7_PE4_FUNC_DCMI_D4 0x440e +#define STM32H7_PE4_FUNC_LCD_B0 0x440f +#define STM32H7_PE4_FUNC_EVENTOUT 0x4410 +#define STM32H7_PE4_FUNC_ANALOG 0x4411 + +#define STM32H7_PE5_FUNC_GPIO 0x4500 +#define STM32H7_PE5_FUNC_TRACED2 0x4501 +#define STM32H7_PE5_FUNC_SAI1_CK2 0x4503 +#define STM32H7_PE5_FUNC_DFSDM_CKIN3 0x4504 +#define STM32H7_PE5_FUNC_TIM15_CH1 0x4505 +#define STM32H7_PE5_FUNC_SPI4_MISO 0x4506 +#define STM32H7_PE5_FUNC_SAI1_SCK_A 0x4507 +#define STM32H7_PE5_FUNC_SAI4_SCK_A 0x4509 +#define STM32H7_PE5_FUNC_SAI4_CK2 0x450b +#define STM32H7_PE5_FUNC_FMC_A21 0x450d +#define STM32H7_PE5_FUNC_DCMI_D6 0x450e +#define STM32H7_PE5_FUNC_LCD_G0 0x450f +#define STM32H7_PE5_FUNC_EVENTOUT 0x4510 +#define STM32H7_PE5_FUNC_ANALOG 0x4511 + +#define STM32H7_PE6_FUNC_GPIO 0x4600 +#define STM32H7_PE6_FUNC_TRACED3 0x4601 +#define STM32H7_PE6_FUNC_TIM1_BKIN2 0x4602 +#define STM32H7_PE6_FUNC_SAI1_D1 0x4603 +#define STM32H7_PE6_FUNC_TIM15_CH2 0x4605 +#define STM32H7_PE6_FUNC_SPI4_MOSI 0x4606 +#define STM32H7_PE6_FUNC_SAI1_SD_A 0x4607 +#define STM32H7_PE6_FUNC_SAI4_SD_A 0x4609 +#define STM32H7_PE6_FUNC_SAI4_D1 0x460a +#define STM32H7_PE6_FUNC_SAI2_MCK_B 0x460b +#define STM32H7_PE6_FUNC_TIM1_BKIN2_COMP12 0x460c +#define STM32H7_PE6_FUNC_FMC_A22 0x460d +#define STM32H7_PE6_FUNC_DCMI_D7 0x460e +#define STM32H7_PE6_FUNC_LCD_G1 0x460f +#define STM32H7_PE6_FUNC_EVENTOUT 0x4610 +#define STM32H7_PE6_FUNC_ANALOG 0x4611 + +#define STM32H7_PE7_FUNC_GPIO 0x4700 +#define STM32H7_PE7_FUNC_TIM1_ETR 0x4702 +#define STM32H7_PE7_FUNC_DFSDM_DATIN2 0x4704 +#define STM32H7_PE7_FUNC_UART7_RX 0x4708 +#define STM32H7_PE7_FUNC_QUADSPI_BK2_IO0 0x470b +#define STM32H7_PE7_FUNC_FMC_D4_FMC_DA4 0x470d +#define STM32H7_PE7_FUNC_EVENTOUT 0x4710 +#define STM32H7_PE7_FUNC_ANALOG 0x4711 + +#define STM32H7_PE8_FUNC_GPIO 0x4800 +#define STM32H7_PE8_FUNC_TIM1_CH1N 0x4802 +#define STM32H7_PE8_FUNC_DFSDM_CKIN2 0x4804 +#define STM32H7_PE8_FUNC_UART7_TX 0x4808 +#define STM32H7_PE8_FUNC_QUADSPI_BK2_IO1 0x480b +#define STM32H7_PE8_FUNC_FMC_D5_FMC_DA5 0x480d +#define STM32H7_PE8_FUNC_COMP_2_OUT 0x480e +#define STM32H7_PE8_FUNC_EVENTOUT 0x4810 +#define STM32H7_PE8_FUNC_ANALOG 0x4811 + +#define STM32H7_PE9_FUNC_GPIO 0x4900 +#define STM32H7_PE9_FUNC_TIM1_CH1 0x4902 +#define STM32H7_PE9_FUNC_DFSDM_CKOUT 0x4904 +#define STM32H7_PE9_FUNC_UART7_RTS 0x4908 +#define STM32H7_PE9_FUNC_QUADSPI_BK2_IO2 0x490b +#define STM32H7_PE9_FUNC_FMC_D6_FMC_DA6 0x490d +#define STM32H7_PE9_FUNC_EVENTOUT 0x4910 +#define STM32H7_PE9_FUNC_ANALOG 0x4911 + +#define STM32H7_PE10_FUNC_GPIO 0x4a00 +#define STM32H7_PE10_FUNC_TIM1_CH2N 0x4a02 +#define STM32H7_PE10_FUNC_DFSDM_DATIN4 0x4a04 +#define STM32H7_PE10_FUNC_UART7_CTS 0x4a08 +#define STM32H7_PE10_FUNC_QUADSPI_BK2_IO3 0x4a0b +#define STM32H7_PE10_FUNC_FMC_D7_FMC_DA7 0x4a0d +#define STM32H7_PE10_FUNC_EVENTOUT 0x4a10 +#define STM32H7_PE10_FUNC_ANALOG 0x4a11 + +#define STM32H7_PE11_FUNC_GPIO 0x4b00 +#define STM32H7_PE11_FUNC_TIM1_CH2 0x4b02 +#define STM32H7_PE11_FUNC_DFSDM_CKIN4 0x4b04 +#define STM32H7_PE11_FUNC_SPI4_NSS 0x4b06 +#define STM32H7_PE11_FUNC_SAI2_SD_B 0x4b0b +#define STM32H7_PE11_FUNC_FMC_D8_FMC_DA8 0x4b0d +#define STM32H7_PE11_FUNC_LCD_G3 0x4b0f +#define STM32H7_PE11_FUNC_EVENTOUT 0x4b10 +#define STM32H7_PE11_FUNC_ANALOG 0x4b11 + +#define STM32H7_PE12_FUNC_GPIO 0x4c00 +#define STM32H7_PE12_FUNC_TIM1_CH3N 0x4c02 +#define STM32H7_PE12_FUNC_DFSDM_DATIN5 0x4c04 +#define STM32H7_PE12_FUNC_SPI4_SCK 0x4c06 +#define STM32H7_PE12_FUNC_SAI2_SCK_B 0x4c0b +#define STM32H7_PE12_FUNC_FMC_D9_FMC_DA9 0x4c0d +#define STM32H7_PE12_FUNC_COMP_1_OUT 0x4c0e +#define STM32H7_PE12_FUNC_LCD_B4 0x4c0f +#define STM32H7_PE12_FUNC_EVENTOUT 0x4c10 +#define STM32H7_PE12_FUNC_ANALOG 0x4c11 + +#define STM32H7_PE13_FUNC_GPIO 0x4d00 +#define STM32H7_PE13_FUNC_TIM1_CH3 0x4d02 +#define STM32H7_PE13_FUNC_DFSDM_CKIN5 0x4d04 +#define STM32H7_PE13_FUNC_SPI4_MISO 0x4d06 +#define STM32H7_PE13_FUNC_SAI2_FS_B 0x4d0b +#define STM32H7_PE13_FUNC_FMC_D10_FMC_DA10 0x4d0d +#define STM32H7_PE13_FUNC_COMP_2_OUT 0x4d0e +#define STM32H7_PE13_FUNC_LCD_DE 0x4d0f +#define STM32H7_PE13_FUNC_EVENTOUT 0x4d10 +#define STM32H7_PE13_FUNC_ANALOG 0x4d11 + +#define STM32H7_PE14_FUNC_GPIO 0x4e00 +#define STM32H7_PE14_FUNC_TIM1_CH4 0x4e02 +#define STM32H7_PE14_FUNC_SPI4_MOSI 0x4e06 +#define STM32H7_PE14_FUNC_SAI2_MCK_B 0x4e0b +#define STM32H7_PE14_FUNC_FMC_D11_FMC_DA11 0x4e0d +#define STM32H7_PE14_FUNC_LCD_CLK 0x4e0f +#define STM32H7_PE14_FUNC_EVENTOUT 0x4e10 +#define STM32H7_PE14_FUNC_ANALOG 0x4e11 + +#define STM32H7_PE15_FUNC_GPIO 0x4f00 +#define STM32H7_PE15_FUNC_TIM1_BKIN 0x4f02 +#define STM32H7_PE15_FUNC_HDMI__TIM1_BKIN 0x4f06 +#define STM32H7_PE15_FUNC_FMC_D12_FMC_DA12 0x4f0d +#define STM32H7_PE15_FUNC_TIM1_BKIN_COMP12 0x4f0e +#define STM32H7_PE15_FUNC_LCD_R7 0x4f0f +#define STM32H7_PE15_FUNC_EVENTOUT 0x4f10 +#define STM32H7_PE15_FUNC_ANALOG 0x4f11 + +#define STM32H7_PF0_FUNC_GPIO 0x5000 +#define STM32H7_PF0_FUNC_I2C2_SDA 0x5005 +#define STM32H7_PF0_FUNC_FMC_A0 0x500d +#define STM32H7_PF0_FUNC_EVENTOUT 0x5010 +#define STM32H7_PF0_FUNC_ANALOG 0x5011 + +#define STM32H7_PF1_FUNC_GPIO 0x5100 +#define STM32H7_PF1_FUNC_I2C2_SCL 0x5105 +#define STM32H7_PF1_FUNC_FMC_A1 0x510d +#define STM32H7_PF1_FUNC_EVENTOUT 0x5110 +#define STM32H7_PF1_FUNC_ANALOG 0x5111 + +#define STM32H7_PF2_FUNC_GPIO 0x5200 +#define STM32H7_PF2_FUNC_I2C2_SMBA 0x5205 +#define STM32H7_PF2_FUNC_FMC_A2 0x520d +#define STM32H7_PF2_FUNC_EVENTOUT 0x5210 +#define STM32H7_PF2_FUNC_ANALOG 0x5211 + +#define STM32H7_PF3_FUNC_GPIO 0x5300 +#define STM32H7_PF3_FUNC_FMC_A3 0x530d +#define STM32H7_PF3_FUNC_EVENTOUT 0x5310 +#define STM32H7_PF3_FUNC_ANALOG 0x5311 + +#define STM32H7_PF4_FUNC_GPIO 0x5400 +#define STM32H7_PF4_FUNC_FMC_A4 0x540d +#define STM32H7_PF4_FUNC_EVENTOUT 0x5410 +#define STM32H7_PF4_FUNC_ANALOG 0x5411 + +#define STM32H7_PF5_FUNC_GPIO 0x5500 +#define STM32H7_PF5_FUNC_FMC_A5 0x550d +#define STM32H7_PF5_FUNC_EVENTOUT 0x5510 +#define STM32H7_PF5_FUNC_ANALOG 0x5511 + +#define STM32H7_PF6_FUNC_GPIO 0x5600 +#define STM32H7_PF6_FUNC_TIM16_CH1 0x5602 +#define STM32H7_PF6_FUNC_SPI5_NSS 0x5606 +#define STM32H7_PF6_FUNC_SAI1_SD_B 0x5607 +#define STM32H7_PF6_FUNC_UART7_RX 0x5608 +#define STM32H7_PF6_FUNC_SAI4_SD_B 0x5609 +#define STM32H7_PF6_FUNC_QUADSPI_BK1_IO3 0x560a +#define STM32H7_PF6_FUNC_EVENTOUT 0x5610 +#define STM32H7_PF6_FUNC_ANALOG 0x5611 + +#define STM32H7_PF7_FUNC_GPIO 0x5700 +#define STM32H7_PF7_FUNC_TIM17_CH1 0x5702 +#define STM32H7_PF7_FUNC_SPI5_SCK 0x5706 +#define STM32H7_PF7_FUNC_SAI1_MCLK_B 0x5707 +#define STM32H7_PF7_FUNC_UART7_TX 0x5708 +#define STM32H7_PF7_FUNC_SAI4_MCLK_B 0x5709 +#define STM32H7_PF7_FUNC_QUADSPI_BK1_IO2 0x570a +#define STM32H7_PF7_FUNC_EVENTOUT 0x5710 +#define STM32H7_PF7_FUNC_ANALOG 0x5711 + +#define STM32H7_PF8_FUNC_GPIO 0x5800 +#define STM32H7_PF8_FUNC_TIM16_CH1N 0x5802 +#define STM32H7_PF8_FUNC_SPI5_MISO 0x5806 +#define STM32H7_PF8_FUNC_SAI1_SCK_B 0x5807 +#define STM32H7_PF8_FUNC_UART7_RTS 0x5808 +#define STM32H7_PF8_FUNC_SAI4_SCK_B 0x5809 +#define STM32H7_PF8_FUNC_TIM13_CH1 0x580a +#define STM32H7_PF8_FUNC_QUADSPI_BK1_IO0 0x580b +#define STM32H7_PF8_FUNC_EVENTOUT 0x5810 +#define STM32H7_PF8_FUNC_ANALOG 0x5811 + +#define STM32H7_PF9_FUNC_GPIO 0x5900 +#define STM32H7_PF9_FUNC_TIM17_CH1N 0x5902 +#define STM32H7_PF9_FUNC_SPI5_MOSI 0x5906 +#define STM32H7_PF9_FUNC_SAI1_FS_B 0x5907 +#define STM32H7_PF9_FUNC_UART7_CTS 0x5908 +#define STM32H7_PF9_FUNC_SAI4_FS_B 0x5909 +#define STM32H7_PF9_FUNC_TIM14_CH1 0x590a +#define STM32H7_PF9_FUNC_QUADSPI_BK1_IO1 0x590b +#define STM32H7_PF9_FUNC_EVENTOUT 0x5910 +#define STM32H7_PF9_FUNC_ANALOG 0x5911 + +#define STM32H7_PF10_FUNC_GPIO 0x5a00 +#define STM32H7_PF10_FUNC_TIM16_BKIN 0x5a02 +#define STM32H7_PF10_FUNC_SAI1_D3 0x5a03 +#define STM32H7_PF10_FUNC_QUADSPI_CLK 0x5a0a +#define STM32H7_PF10_FUNC_SAI4_D3 0x5a0b +#define STM32H7_PF10_FUNC_DCMI_D11 0x5a0e +#define STM32H7_PF10_FUNC_LCD_DE 0x5a0f +#define STM32H7_PF10_FUNC_EVENTOUT 0x5a10 +#define STM32H7_PF10_FUNC_ANALOG 0x5a11 + +#define STM32H7_PF11_FUNC_GPIO 0x5b00 +#define STM32H7_PF11_FUNC_SPI5_MOSI 0x5b06 +#define STM32H7_PF11_FUNC_SAI2_SD_B 0x5b0b +#define STM32H7_PF11_FUNC_FMC_SDNRAS 0x5b0d +#define STM32H7_PF11_FUNC_DCMI_D12 0x5b0e +#define STM32H7_PF11_FUNC_EVENTOUT 0x5b10 +#define STM32H7_PF11_FUNC_ANALOG 0x5b11 + +#define STM32H7_PF12_FUNC_GPIO 0x5c00 +#define STM32H7_PF12_FUNC_FMC_A6 0x5c0d +#define STM32H7_PF12_FUNC_EVENTOUT 0x5c10 +#define STM32H7_PF12_FUNC_ANALOG 0x5c11 + +#define STM32H7_PF13_FUNC_GPIO 0x5d00 +#define STM32H7_PF13_FUNC_DFSDM_DATIN6 0x5d04 +#define STM32H7_PF13_FUNC_I2C4_SMBA 0x5d05 +#define STM32H7_PF13_FUNC_FMC_A7 0x5d0d +#define STM32H7_PF13_FUNC_EVENTOUT 0x5d10 +#define STM32H7_PF13_FUNC_ANALOG 0x5d11 + +#define STM32H7_PF14_FUNC_GPIO 0x5e00 +#define STM32H7_PF14_FUNC_DFSDM_CKIN6 0x5e04 +#define STM32H7_PF14_FUNC_I2C4_SCL 0x5e05 +#define STM32H7_PF14_FUNC_FMC_A8 0x5e0d +#define STM32H7_PF14_FUNC_EVENTOUT 0x5e10 +#define STM32H7_PF14_FUNC_ANALOG 0x5e11 + +#define STM32H7_PF15_FUNC_GPIO 0x5f00 +#define STM32H7_PF15_FUNC_I2C4_SDA 0x5f05 +#define STM32H7_PF15_FUNC_FMC_A9 0x5f0d +#define STM32H7_PF15_FUNC_EVENTOUT 0x5f10 +#define STM32H7_PF15_FUNC_ANALOG 0x5f11 + +#define STM32H7_PG0_FUNC_GPIO 0x6000 +#define STM32H7_PG0_FUNC_FMC_A10 0x600d +#define STM32H7_PG0_FUNC_EVENTOUT 0x6010 +#define STM32H7_PG0_FUNC_ANALOG 0x6011 + +#define STM32H7_PG1_FUNC_GPIO 0x6100 +#define STM32H7_PG1_FUNC_FMC_A11 0x610d +#define STM32H7_PG1_FUNC_EVENTOUT 0x6110 +#define STM32H7_PG1_FUNC_ANALOG 0x6111 + +#define STM32H7_PG2_FUNC_GPIO 0x6200 +#define STM32H7_PG2_FUNC_TIM8_BKIN 0x6204 +#define STM32H7_PG2_FUNC_TIM8_BKIN_COMP12 0x620c +#define STM32H7_PG2_FUNC_FMC_A12 0x620d +#define STM32H7_PG2_FUNC_EVENTOUT 0x6210 +#define STM32H7_PG2_FUNC_ANALOG 0x6211 + +#define STM32H7_PG3_FUNC_GPIO 0x6300 +#define STM32H7_PG3_FUNC_TIM8_BKIN2 0x6304 +#define STM32H7_PG3_FUNC_TIM8_BKIN2_COMP12 0x630c +#define STM32H7_PG3_FUNC_FMC_A13 0x630d +#define STM32H7_PG3_FUNC_EVENTOUT 0x6310 +#define STM32H7_PG3_FUNC_ANALOG 0x6311 + +#define STM32H7_PG4_FUNC_GPIO 0x6400 +#define STM32H7_PG4_FUNC_TIM1_BKIN2 0x6402 +#define STM32H7_PG4_FUNC_TIM1_BKIN2_COMP12 0x640c +#define STM32H7_PG4_FUNC_FMC_A14_FMC_BA0 0x640d +#define STM32H7_PG4_FUNC_EVENTOUT 0x6410 +#define STM32H7_PG4_FUNC_ANALOG 0x6411 + +#define STM32H7_PG5_FUNC_GPIO 0x6500 +#define STM32H7_PG5_FUNC_TIM1_ETR 0x6502 +#define STM32H7_PG5_FUNC_FMC_A15_FMC_BA1 0x650d +#define STM32H7_PG5_FUNC_EVENTOUT 0x6510 +#define STM32H7_PG5_FUNC_ANALOG 0x6511 + +#define STM32H7_PG6_FUNC_GPIO 0x6600 +#define STM32H7_PG6_FUNC_TIM17_BKIN 0x6602 +#define STM32H7_PG6_FUNC_HRTIM_CHE1 0x6603 +#define STM32H7_PG6_FUNC_QUADSPI_BK1_NCS 0x660b +#define STM32H7_PG6_FUNC_FMC_NE3 0x660d +#define STM32H7_PG6_FUNC_DCMI_D12 0x660e +#define STM32H7_PG6_FUNC_LCD_R7 0x660f +#define STM32H7_PG6_FUNC_EVENTOUT 0x6610 +#define STM32H7_PG6_FUNC_ANALOG 0x6611 + +#define STM32H7_PG7_FUNC_GPIO 0x6700 +#define STM32H7_PG7_FUNC_HRTIM_CHE2 0x6703 +#define STM32H7_PG7_FUNC_SAI1_MCLK_A 0x6707 +#define STM32H7_PG7_FUNC_USART6_CK 0x6708 +#define STM32H7_PG7_FUNC_FMC_INT 0x670d +#define STM32H7_PG7_FUNC_DCMI_D13 0x670e +#define STM32H7_PG7_FUNC_LCD_CLK 0x670f +#define STM32H7_PG7_FUNC_EVENTOUT 0x6710 +#define STM32H7_PG7_FUNC_ANALOG 0x6711 + +#define STM32H7_PG8_FUNC_GPIO 0x6800 +#define STM32H7_PG8_FUNC_TIM8_ETR 0x6804 +#define STM32H7_PG8_FUNC_SPI6_NSS 0x6806 +#define STM32H7_PG8_FUNC_USART6_RTS 0x6808 +#define STM32H7_PG8_FUNC_SPDIFRX_IN2 0x6809 +#define STM32H7_PG8_FUNC_ETH_PPS_OUT 0x680c +#define STM32H7_PG8_FUNC_FMC_SDCLK 0x680d +#define STM32H7_PG8_FUNC_LCD_G7 0x680f +#define STM32H7_PG8_FUNC_EVENTOUT 0x6810 +#define STM32H7_PG8_FUNC_ANALOG 0x6811 + +#define STM32H7_PG9_FUNC_GPIO 0x6900 +#define STM32H7_PG9_FUNC_SPI1_MISO_I2S1_SDI 0x6906 +#define STM32H7_PG9_FUNC_USART6_RX 0x6908 +#define STM32H7_PG9_FUNC_SPDIFRX_IN3 0x6909 +#define STM32H7_PG9_FUNC_QUADSPI_BK2_IO2 0x690a +#define STM32H7_PG9_FUNC_SAI2_FS_B 0x690b +#define STM32H7_PG9_FUNC_FMC_NE2_FMC_NCE 0x690d +#define STM32H7_PG9_FUNC_DCMI_VSYNC 0x690e +#define STM32H7_PG9_FUNC_EVENTOUT 0x6910 +#define STM32H7_PG9_FUNC_ANALOG 0x6911 + +#define STM32H7_PG10_FUNC_GPIO 0x6a00 +#define STM32H7_PG10_FUNC_HRTIM_FLT5 0x6a03 +#define STM32H7_PG10_FUNC_SPI1_NSS_I2S1_WS 0x6a06 +#define STM32H7_PG10_FUNC_LCD_G3 0x6a0a +#define STM32H7_PG10_FUNC_SAI2_SD_B 0x6a0b +#define STM32H7_PG10_FUNC_FMC_NE3 0x6a0d +#define STM32H7_PG10_FUNC_DCMI_D2 0x6a0e +#define STM32H7_PG10_FUNC_LCD_B2 0x6a0f +#define STM32H7_PG10_FUNC_EVENTOUT 0x6a10 +#define STM32H7_PG10_FUNC_ANALOG 0x6a11 + +#define STM32H7_PG11_FUNC_GPIO 0x6b00 +#define STM32H7_PG11_FUNC_HRTIM_EEV4 0x6b03 +#define STM32H7_PG11_FUNC_SPI1_SCK_I2S1_CK 0x6b06 +#define STM32H7_PG11_FUNC_SPDIFRX_IN0 0x6b09 +#define STM32H7_PG11_FUNC_SDMMC2_D2 0x6b0b +#define STM32H7_PG11_FUNC_ETH_MII_TX_EN_ETH_RMII_TX_EN 0x6b0c +#define STM32H7_PG11_FUNC_DCMI_D3 0x6b0e +#define STM32H7_PG11_FUNC_LCD_B3 0x6b0f +#define STM32H7_PG11_FUNC_EVENTOUT 0x6b10 +#define STM32H7_PG11_FUNC_ANALOG 0x6b11 + +#define STM32H7_PG12_FUNC_GPIO 0x6c00 +#define STM32H7_PG12_FUNC_LPTIM1_IN1 0x6c02 +#define STM32H7_PG12_FUNC_HRTIM_EEV5 0x6c03 +#define STM32H7_PG12_FUNC_SPI6_MISO 0x6c06 +#define STM32H7_PG12_FUNC_USART6_RTS 0x6c08 +#define STM32H7_PG12_FUNC_SPDIFRX_IN1 0x6c09 +#define STM32H7_PG12_FUNC_LCD_B4 0x6c0a +#define STM32H7_PG12_FUNC_ETH_MII_TXD1_ETH_RMII_TXD1 0x6c0c +#define STM32H7_PG12_FUNC_FMC_NE4 0x6c0d +#define STM32H7_PG12_FUNC_LCD_B1 0x6c0f +#define STM32H7_PG12_FUNC_EVENTOUT 0x6c10 +#define STM32H7_PG12_FUNC_ANALOG 0x6c11 + +#define STM32H7_PG13_FUNC_GPIO 0x6d00 +#define STM32H7_PG13_FUNC_TRACED0 0x6d01 +#define STM32H7_PG13_FUNC_LPTIM1_OUT 0x6d02 +#define STM32H7_PG13_FUNC_HRTIM_EEV10 0x6d03 +#define STM32H7_PG13_FUNC_SPI6_SCK 0x6d06 +#define STM32H7_PG13_FUNC_USART6_CTS_NSS 0x6d08 +#define STM32H7_PG13_FUNC_ETH_MII_TXD0_ETH_RMII_TXD0 0x6d0c +#define STM32H7_PG13_FUNC_FMC_A24 0x6d0d +#define STM32H7_PG13_FUNC_LCD_R0 0x6d0f +#define STM32H7_PG13_FUNC_EVENTOUT 0x6d10 +#define STM32H7_PG13_FUNC_ANALOG 0x6d11 + +#define STM32H7_PG14_FUNC_GPIO 0x6e00 +#define STM32H7_PG14_FUNC_TRACED1 0x6e01 +#define STM32H7_PG14_FUNC_LPTIM1_ETR 0x6e02 +#define STM32H7_PG14_FUNC_SPI6_MOSI 0x6e06 +#define STM32H7_PG14_FUNC_USART6_TX 0x6e08 +#define STM32H7_PG14_FUNC_QUADSPI_BK2_IO3 0x6e0a +#define STM32H7_PG14_FUNC_ETH_MII_TXD1_ETH_RMII_TXD1 0x6e0c +#define STM32H7_PG14_FUNC_FMC_A25 0x6e0d +#define STM32H7_PG14_FUNC_LCD_B0 0x6e0f +#define STM32H7_PG14_FUNC_EVENTOUT 0x6e10 +#define STM32H7_PG14_FUNC_ANALOG 0x6e11 + +#define STM32H7_PG15_FUNC_GPIO 0x6f00 +#define STM32H7_PG15_FUNC_USART6_CTS_NSS 0x6f08 +#define STM32H7_PG15_FUNC_FMC_SDNCAS 0x6f0d +#define STM32H7_PG15_FUNC_DCMI_D13 0x6f0e +#define STM32H7_PG15_FUNC_EVENTOUT 0x6f10 +#define STM32H7_PG15_FUNC_ANALOG 0x6f11 + +#define STM32H7_PH0_FUNC_GPIO 0x7000 +#define STM32H7_PH0_FUNC_EVENTOUT 0x7010 +#define STM32H7_PH0_FUNC_ANALOG 0x7011 + +#define STM32H7_PH1_FUNC_GPIO 0x7100 +#define STM32H7_PH1_FUNC_EVENTOUT 0x7110 +#define STM32H7_PH1_FUNC_ANALOG 0x7111 + +#define STM32H7_PH2_FUNC_GPIO 0x7200 +#define STM32H7_PH2_FUNC_LPTIM1_IN2 0x7202 +#define STM32H7_PH2_FUNC_QUADSPI_BK2_IO0 0x720a +#define STM32H7_PH2_FUNC_SAI2_SCK_B 0x720b +#define STM32H7_PH2_FUNC_ETH_MII_CRS 0x720c +#define STM32H7_PH2_FUNC_FMC_SDCKE0 0x720d +#define STM32H7_PH2_FUNC_LCD_R0 0x720f +#define STM32H7_PH2_FUNC_EVENTOUT 0x7210 +#define STM32H7_PH2_FUNC_ANALOG 0x7211 + +#define STM32H7_PH3_FUNC_GPIO 0x7300 +#define STM32H7_PH3_FUNC_QUADSPI_BK2_IO1 0x730a +#define STM32H7_PH3_FUNC_SAI2_MCK_B 0x730b +#define STM32H7_PH3_FUNC_ETH_MII_COL 0x730c +#define STM32H7_PH3_FUNC_FMC_SDNE0 0x730d +#define STM32H7_PH3_FUNC_LCD_R1 0x730f +#define STM32H7_PH3_FUNC_EVENTOUT 0x7310 +#define STM32H7_PH3_FUNC_ANALOG 0x7311 + +#define STM32H7_PH4_FUNC_GPIO 0x7400 +#define STM32H7_PH4_FUNC_I2C2_SCL 0x7405 +#define STM32H7_PH4_FUNC_LCD_G5 0x740a +#define STM32H7_PH4_FUNC_OTG_HS_ULPI_NXT 0x740b +#define STM32H7_PH4_FUNC_LCD_G4 0x740f +#define STM32H7_PH4_FUNC_EVENTOUT 0x7410 +#define STM32H7_PH4_FUNC_ANALOG 0x7411 + +#define STM32H7_PH5_FUNC_GPIO 0x7500 +#define STM32H7_PH5_FUNC_I2C2_SDA 0x7505 +#define STM32H7_PH5_FUNC_SPI5_NSS 0x7506 +#define STM32H7_PH5_FUNC_FMC_SDNWE 0x750d +#define STM32H7_PH5_FUNC_EVENTOUT 0x7510 +#define STM32H7_PH5_FUNC_ANALOG 0x7511 + +#define STM32H7_PH6_FUNC_GPIO 0x7600 +#define STM32H7_PH6_FUNC_I2C2_SMBA 0x7605 +#define STM32H7_PH6_FUNC_SPI5_SCK 0x7606 +#define STM32H7_PH6_FUNC_ETH_MII_RXD2 0x760c +#define STM32H7_PH6_FUNC_FMC_SDNE1 0x760d +#define STM32H7_PH6_FUNC_DCMI_D8 0x760e +#define STM32H7_PH6_FUNC_EVENTOUT 0x7610 +#define STM32H7_PH6_FUNC_ANALOG 0x7611 + +#define STM32H7_PH7_FUNC_GPIO 0x7700 +#define STM32H7_PH7_FUNC_I2C3_SCL 0x7705 +#define STM32H7_PH7_FUNC_SPI5_MISO 0x7706 +#define STM32H7_PH7_FUNC_ETH_MII_RXD3 0x770c +#define STM32H7_PH7_FUNC_FMC_SDCKE1 0x770d +#define STM32H7_PH7_FUNC_DCMI_D9 0x770e +#define STM32H7_PH7_FUNC_EVENTOUT 0x7710 +#define STM32H7_PH7_FUNC_ANALOG 0x7711 + +#define STM32H7_PH8_FUNC_GPIO 0x7800 +#define STM32H7_PH8_FUNC_TIM5_ETR 0x7803 +#define STM32H7_PH8_FUNC_I2C3_SDA 0x7805 +#define STM32H7_PH8_FUNC_FMC_D16 0x780d +#define STM32H7_PH8_FUNC_DCMI_HSYNC 0x780e +#define STM32H7_PH8_FUNC_LCD_R2 0x780f +#define STM32H7_PH8_FUNC_EVENTOUT 0x7810 +#define STM32H7_PH8_FUNC_ANALOG 0x7811 + +#define STM32H7_PH9_FUNC_GPIO 0x7900 +#define STM32H7_PH9_FUNC_I2C3_SMBA 0x7905 +#define STM32H7_PH9_FUNC_FMC_D17 0x790d +#define STM32H7_PH9_FUNC_DCMI_D0 0x790e +#define STM32H7_PH9_FUNC_LCD_R3 0x790f +#define STM32H7_PH9_FUNC_EVENTOUT 0x7910 +#define STM32H7_PH9_FUNC_ANALOG 0x7911 + +#define STM32H7_PH10_FUNC_GPIO 0x7a00 +#define STM32H7_PH10_FUNC_TIM5_CH1 0x7a03 +#define STM32H7_PH10_FUNC_I2C4_SMBA 0x7a05 +#define STM32H7_PH10_FUNC_FMC_D18 0x7a0d +#define STM32H7_PH10_FUNC_DCMI_D1 0x7a0e +#define STM32H7_PH10_FUNC_LCD_R4 0x7a0f +#define STM32H7_PH10_FUNC_EVENTOUT 0x7a10 +#define STM32H7_PH10_FUNC_ANALOG 0x7a11 + +#define STM32H7_PH11_FUNC_GPIO 0x7b00 +#define STM32H7_PH11_FUNC_TIM5_CH2 0x7b03 +#define STM32H7_PH11_FUNC_I2C4_SCL 0x7b05 +#define STM32H7_PH11_FUNC_FMC_D19 0x7b0d +#define STM32H7_PH11_FUNC_DCMI_D2 0x7b0e +#define STM32H7_PH11_FUNC_LCD_R5 0x7b0f +#define STM32H7_PH11_FUNC_EVENTOUT 0x7b10 +#define STM32H7_PH11_FUNC_ANALOG 0x7b11 + +#define STM32H7_PH12_FUNC_GPIO 0x7c00 +#define STM32H7_PH12_FUNC_TIM5_CH3 0x7c03 +#define STM32H7_PH12_FUNC_I2C4_SDA 0x7c05 +#define STM32H7_PH12_FUNC_FMC_D20 0x7c0d +#define STM32H7_PH12_FUNC_DCMI_D3 0x7c0e +#define STM32H7_PH12_FUNC_LCD_R6 0x7c0f +#define STM32H7_PH12_FUNC_EVENTOUT 0x7c10 +#define STM32H7_PH12_FUNC_ANALOG 0x7c11 + +#define STM32H7_PH13_FUNC_GPIO 0x7d00 +#define STM32H7_PH13_FUNC_TIM8_CH1N 0x7d04 +#define STM32H7_PH13_FUNC_UART4_TX 0x7d09 +#define STM32H7_PH13_FUNC_CAN1_TX 0x7d0a +#define STM32H7_PH13_FUNC_FMC_D21 0x7d0d +#define STM32H7_PH13_FUNC_LCD_G2 0x7d0f +#define STM32H7_PH13_FUNC_EVENTOUT 0x7d10 +#define STM32H7_PH13_FUNC_ANALOG 0x7d11 + +#define STM32H7_PH14_FUNC_GPIO 0x7e00 +#define STM32H7_PH14_FUNC_TIM8_CH2N 0x7e04 +#define STM32H7_PH14_FUNC_UART4_RX 0x7e09 +#define STM32H7_PH14_FUNC_CAN1_RX 0x7e0a +#define STM32H7_PH14_FUNC_FMC_D22 0x7e0d +#define STM32H7_PH14_FUNC_DCMI_D4 0x7e0e +#define STM32H7_PH14_FUNC_LCD_G3 0x7e0f +#define STM32H7_PH14_FUNC_EVENTOUT 0x7e10 +#define STM32H7_PH14_FUNC_ANALOG 0x7e11 + +#define STM32H7_PH15_FUNC_GPIO 0x7f00 +#define STM32H7_PH15_FUNC_TIM8_CH3N 0x7f04 +#define STM32H7_PH15_FUNC_CAN1_TXFD 0x7f0a +#define STM32H7_PH15_FUNC_FMC_D23 0x7f0d +#define STM32H7_PH15_FUNC_DCMI_D11 0x7f0e +#define STM32H7_PH15_FUNC_LCD_G4 0x7f0f +#define STM32H7_PH15_FUNC_EVENTOUT 0x7f10 +#define STM32H7_PH15_FUNC_ANALOG 0x7f11 + +#define STM32H7_PI0_FUNC_GPIO 0x8000 +#define STM32H7_PI0_FUNC_TIM5_CH4 0x8003 +#define STM32H7_PI0_FUNC_SPI2_NSS_I2S2_WS 0x8006 +#define STM32H7_PI0_FUNC_CAN1_RXFD 0x800a +#define STM32H7_PI0_FUNC_FMC_D24 0x800d +#define STM32H7_PI0_FUNC_DCMI_D13 0x800e +#define STM32H7_PI0_FUNC_LCD_G5 0x800f +#define STM32H7_PI0_FUNC_EVENTOUT 0x8010 +#define STM32H7_PI0_FUNC_ANALOG 0x8011 + +#define STM32H7_PI1_FUNC_GPIO 0x8100 +#define STM32H7_PI1_FUNC_TIM8_BKIN2 0x8104 +#define STM32H7_PI1_FUNC_SPI2_SCK_I2S2_CK 0x8106 +#define STM32H7_PI1_FUNC_TIM8_BKIN2_COMP12 0x810c +#define STM32H7_PI1_FUNC_FMC_D25 0x810d +#define STM32H7_PI1_FUNC_DCMI_D8 0x810e +#define STM32H7_PI1_FUNC_LCD_G6 0x810f +#define STM32H7_PI1_FUNC_EVENTOUT 0x8110 +#define STM32H7_PI1_FUNC_ANALOG 0x8111 + +#define STM32H7_PI2_FUNC_GPIO 0x8200 +#define STM32H7_PI2_FUNC_TIM8_CH4 0x8204 +#define STM32H7_PI2_FUNC_SPI2_MISO_I2S2_SDI 0x8206 +#define STM32H7_PI2_FUNC_FMC_D26 0x820d +#define STM32H7_PI2_FUNC_DCMI_D9 0x820e +#define STM32H7_PI2_FUNC_LCD_G7 0x820f +#define STM32H7_PI2_FUNC_EVENTOUT 0x8210 +#define STM32H7_PI2_FUNC_ANALOG 0x8211 + +#define STM32H7_PI3_FUNC_GPIO 0x8300 +#define STM32H7_PI3_FUNC_TIM8_ETR 0x8304 +#define STM32H7_PI3_FUNC_SPI2_MOSI_I2S2_SDO 0x8306 +#define STM32H7_PI3_FUNC_FMC_D27 0x830d +#define STM32H7_PI3_FUNC_DCMI_D10 0x830e +#define STM32H7_PI3_FUNC_EVENTOUT 0x8310 +#define STM32H7_PI3_FUNC_ANALOG 0x8311 + +#define STM32H7_PI4_FUNC_GPIO 0x8400 +#define STM32H7_PI4_FUNC_TIM8_BKIN 0x8404 +#define STM32H7_PI4_FUNC_SAI2_MCK_A 0x840b +#define STM32H7_PI4_FUNC_TIM8_BKIN_COMP12 0x840c +#define STM32H7_PI4_FUNC_FMC_NBL2 0x840d +#define STM32H7_PI4_FUNC_DCMI_D5 0x840e +#define STM32H7_PI4_FUNC_LCD_B4 0x840f +#define STM32H7_PI4_FUNC_EVENTOUT 0x8410 +#define STM32H7_PI4_FUNC_ANALOG 0x8411 + +#define STM32H7_PI5_FUNC_GPIO 0x8500 +#define STM32H7_PI5_FUNC_TIM8_CH1 0x8504 +#define STM32H7_PI5_FUNC_SAI2_SCK_A 0x850b +#define STM32H7_PI5_FUNC_FMC_NBL3 0x850d +#define STM32H7_PI5_FUNC_DCMI_VSYNC 0x850e +#define STM32H7_PI5_FUNC_LCD_B5 0x850f +#define STM32H7_PI5_FUNC_EVENTOUT 0x8510 +#define STM32H7_PI5_FUNC_ANALOG 0x8511 + +#define STM32H7_PI6_FUNC_GPIO 0x8600 +#define STM32H7_PI6_FUNC_TIM8_CH2 0x8604 +#define STM32H7_PI6_FUNC_SAI2_SD_A 0x860b +#define STM32H7_PI6_FUNC_FMC_D28 0x860d +#define STM32H7_PI6_FUNC_DCMI_D6 0x860e +#define STM32H7_PI6_FUNC_LCD_B6 0x860f +#define STM32H7_PI6_FUNC_EVENTOUT 0x8610 +#define STM32H7_PI6_FUNC_ANALOG 0x8611 + +#define STM32H7_PI7_FUNC_GPIO 0x8700 +#define STM32H7_PI7_FUNC_TIM8_CH3 0x8704 +#define STM32H7_PI7_FUNC_SAI2_FS_A 0x870b +#define STM32H7_PI7_FUNC_FMC_D29 0x870d +#define STM32H7_PI7_FUNC_DCMI_D7 0x870e +#define STM32H7_PI7_FUNC_LCD_B7 0x870f +#define STM32H7_PI7_FUNC_EVENTOUT 0x8710 +#define STM32H7_PI7_FUNC_ANALOG 0x8711 + +#define STM32H7_PI8_FUNC_GPIO 0x8800 +#define STM32H7_PI8_FUNC_EVENTOUT 0x8810 +#define STM32H7_PI8_FUNC_ANALOG 0x8811 + +#define STM32H7_PI9_FUNC_GPIO 0x8900 +#define STM32H7_PI9_FUNC_UART4_RX 0x8909 +#define STM32H7_PI9_FUNC_CAN1_RX 0x890a +#define STM32H7_PI9_FUNC_FMC_D30 0x890d +#define STM32H7_PI9_FUNC_LCD_VSYNC 0x890f +#define STM32H7_PI9_FUNC_EVENTOUT 0x8910 +#define STM32H7_PI9_FUNC_ANALOG 0x8911 + +#define STM32H7_PI10_FUNC_GPIO 0x8a00 +#define STM32H7_PI10_FUNC_CAN1_RXFD 0x8a0a +#define STM32H7_PI10_FUNC_ETH_MII_RX_ER 0x8a0c +#define STM32H7_PI10_FUNC_FMC_D31 0x8a0d +#define STM32H7_PI10_FUNC_LCD_HSYNC 0x8a0f +#define STM32H7_PI10_FUNC_EVENTOUT 0x8a10 +#define STM32H7_PI10_FUNC_ANALOG 0x8a11 + +#define STM32H7_PI11_FUNC_GPIO 0x8b00 +#define STM32H7_PI11_FUNC_LCD_G6 0x8b0a +#define STM32H7_PI11_FUNC_OTG_HS_ULPI_DIR 0x8b0b +#define STM32H7_PI11_FUNC_EVENTOUT 0x8b10 +#define STM32H7_PI11_FUNC_ANALOG 0x8b11 + +#define STM32H7_PI12_FUNC_GPIO 0x8c00 +#define STM32H7_PI12_FUNC_ETH_TX_ER 0x8c0c +#define STM32H7_PI12_FUNC_LCD_HSYNC 0x8c0f +#define STM32H7_PI12_FUNC_EVENTOUT 0x8c10 +#define STM32H7_PI12_FUNC_ANALOG 0x8c11 + +#define STM32H7_PI13_FUNC_GPIO 0x8d00 +#define STM32H7_PI13_FUNC_LCD_VSYNC 0x8d0f +#define STM32H7_PI13_FUNC_EVENTOUT 0x8d10 +#define STM32H7_PI13_FUNC_ANALOG 0x8d11 + +#define STM32H7_PI14_FUNC_GPIO 0x8e00 +#define STM32H7_PI14_FUNC_LCD_CLK 0x8e0f +#define STM32H7_PI14_FUNC_EVENTOUT 0x8e10 +#define STM32H7_PI14_FUNC_ANALOG 0x8e11 + +#define STM32H7_PI15_FUNC_GPIO 0x8f00 +#define STM32H7_PI15_FUNC_LCD_G2 0x8f0a +#define STM32H7_PI15_FUNC_LCD_R0 0x8f0f +#define STM32H7_PI15_FUNC_EVENTOUT 0x8f10 +#define STM32H7_PI15_FUNC_ANALOG 0x8f11 + +#define STM32H7_PJ0_FUNC_GPIO 0x9000 +#define STM32H7_PJ0_FUNC_LCD_R7 0x900a +#define STM32H7_PJ0_FUNC_LCD_R1 0x900f +#define STM32H7_PJ0_FUNC_EVENTOUT 0x9010 +#define STM32H7_PJ0_FUNC_ANALOG 0x9011 + +#define STM32H7_PJ1_FUNC_GPIO 0x9100 +#define STM32H7_PJ1_FUNC_LCD_R2 0x910f +#define STM32H7_PJ1_FUNC_EVENTOUT 0x9110 +#define STM32H7_PJ1_FUNC_ANALOG 0x9111 + +#define STM32H7_PJ2_FUNC_GPIO 0x9200 +#define STM32H7_PJ2_FUNC_DSI_TE 0x920e +#define STM32H7_PJ2_FUNC_LCD_R3 0x920f +#define STM32H7_PJ2_FUNC_EVENTOUT 0x9210 +#define STM32H7_PJ2_FUNC_ANALOG 0x9211 + +#define STM32H7_PJ3_FUNC_GPIO 0x9300 +#define STM32H7_PJ3_FUNC_LCD_R4 0x930f +#define STM32H7_PJ3_FUNC_EVENTOUT 0x9310 +#define STM32H7_PJ3_FUNC_ANALOG 0x9311 + +#define STM32H7_PJ4_FUNC_GPIO 0x9400 +#define STM32H7_PJ4_FUNC_LCD_R5 0x940f +#define STM32H7_PJ4_FUNC_EVENTOUT 0x9410 +#define STM32H7_PJ4_FUNC_ANALOG 0x9411 + +#define STM32H7_PJ5_FUNC_GPIO 0x9500 +#define STM32H7_PJ5_FUNC_LCD_R6 0x950f +#define STM32H7_PJ5_FUNC_EVENTOUT 0x9510 +#define STM32H7_PJ5_FUNC_ANALOG 0x9511 + +#define STM32H7_PJ6_FUNC_GPIO 0x9600 +#define STM32H7_PJ6_FUNC_TIM8_CH2 0x9604 +#define STM32H7_PJ6_FUNC_LCD_R7 0x960f +#define STM32H7_PJ6_FUNC_EVENTOUT 0x9610 +#define STM32H7_PJ6_FUNC_ANALOG 0x9611 + +#define STM32H7_PJ7_FUNC_GPIO 0x9700 +#define STM32H7_PJ7_FUNC_TRGIN 0x9701 +#define STM32H7_PJ7_FUNC_TIM8_CH2N 0x9704 +#define STM32H7_PJ7_FUNC_LCD_G0 0x970f +#define STM32H7_PJ7_FUNC_EVENTOUT 0x9710 +#define STM32H7_PJ7_FUNC_ANALOG 0x9711 + +#define STM32H7_PJ8_FUNC_GPIO 0x9800 +#define STM32H7_PJ8_FUNC_TIM1_CH3N 0x9802 +#define STM32H7_PJ8_FUNC_TIM8_CH1 0x9804 +#define STM32H7_PJ8_FUNC_UART8_TX 0x9809 +#define STM32H7_PJ8_FUNC_LCD_G1 0x980f +#define STM32H7_PJ8_FUNC_EVENTOUT 0x9810 +#define STM32H7_PJ8_FUNC_ANALOG 0x9811 + +#define STM32H7_PJ9_FUNC_GPIO 0x9900 +#define STM32H7_PJ9_FUNC_TIM1_CH3 0x9902 +#define STM32H7_PJ9_FUNC_TIM8_CH1N 0x9904 +#define STM32H7_PJ9_FUNC_UART8_RX 0x9909 +#define STM32H7_PJ9_FUNC_LCD_G2 0x990f +#define STM32H7_PJ9_FUNC_EVENTOUT 0x9910 +#define STM32H7_PJ9_FUNC_ANALOG 0x9911 + +#define STM32H7_PJ10_FUNC_GPIO 0x9a00 +#define STM32H7_PJ10_FUNC_TIM1_CH2N 0x9a02 +#define STM32H7_PJ10_FUNC_TIM8_CH2 0x9a04 +#define STM32H7_PJ10_FUNC_SPI5_MOSI 0x9a06 +#define STM32H7_PJ10_FUNC_LCD_G3 0x9a0f +#define STM32H7_PJ10_FUNC_EVENTOUT 0x9a10 +#define STM32H7_PJ10_FUNC_ANALOG 0x9a11 + +#define STM32H7_PJ11_FUNC_GPIO 0x9b00 +#define STM32H7_PJ11_FUNC_TIM1_CH2 0x9b02 +#define STM32H7_PJ11_FUNC_TIM8_CH2N 0x9b04 +#define STM32H7_PJ11_FUNC_SPI5_MISO 0x9b06 +#define STM32H7_PJ11_FUNC_LCD_G4 0x9b0f +#define STM32H7_PJ11_FUNC_EVENTOUT 0x9b10 +#define STM32H7_PJ11_FUNC_ANALOG 0x9b11 + +#define STM32H7_PJ12_FUNC_GPIO 0x9c00 +#define STM32H7_PJ12_FUNC_TRGOUT 0x9c01 +#define STM32H7_PJ12_FUNC_LCD_G3 0x9c0a +#define STM32H7_PJ12_FUNC_LCD_B0 0x9c0f +#define STM32H7_PJ12_FUNC_EVENTOUT 0x9c10 +#define STM32H7_PJ12_FUNC_ANALOG 0x9c11 + +#define STM32H7_PJ13_FUNC_GPIO 0x9d00 +#define STM32H7_PJ13_FUNC_LCD_B4 0x9d0a +#define STM32H7_PJ13_FUNC_LCD_B1 0x9d0f +#define STM32H7_PJ13_FUNC_EVENTOUT 0x9d10 +#define STM32H7_PJ13_FUNC_ANALOG 0x9d11 + +#define STM32H7_PJ14_FUNC_GPIO 0x9e00 +#define STM32H7_PJ14_FUNC_LCD_B2 0x9e0f +#define STM32H7_PJ14_FUNC_EVENTOUT 0x9e10 +#define STM32H7_PJ14_FUNC_ANALOG 0x9e11 + +#define STM32H7_PJ15_FUNC_GPIO 0x9f00 +#define STM32H7_PJ15_FUNC_LCD_B3 0x9f0f +#define STM32H7_PJ15_FUNC_EVENTOUT 0x9f10 +#define STM32H7_PJ15_FUNC_ANALOG 0x9f11 + +#define STM32H7_PK0_FUNC_GPIO 0xa000 +#define STM32H7_PK0_FUNC_TIM1_CH1N 0xa002 +#define STM32H7_PK0_FUNC_TIM8_CH3 0xa004 +#define STM32H7_PK0_FUNC_SPI5_SCK 0xa006 +#define STM32H7_PK0_FUNC_LCD_G5 0xa00f +#define STM32H7_PK0_FUNC_EVENTOUT 0xa010 +#define STM32H7_PK0_FUNC_ANALOG 0xa011 + +#define STM32H7_PK1_FUNC_GPIO 0xa100 +#define STM32H7_PK1_FUNC_TIM1_CH1 0xa102 +#define STM32H7_PK1_FUNC_TIM8_CH3N 0xa104 +#define STM32H7_PK1_FUNC_SPI5_NSS 0xa106 +#define STM32H7_PK1_FUNC_LCD_G6 0xa10f +#define STM32H7_PK1_FUNC_EVENTOUT 0xa110 +#define STM32H7_PK1_FUNC_ANALOG 0xa111 + +#define STM32H7_PK2_FUNC_GPIO 0xa200 +#define STM32H7_PK2_FUNC_TIM1_BKIN 0xa202 +#define STM32H7_PK2_FUNC_TIM8_BKIN 0xa204 +#define STM32H7_PK2_FUNC_TIM8_BKIN_COMP12 0xa20b +#define STM32H7_PK2_FUNC_TIM1_BKIN_COMP12 0xa20c +#define STM32H7_PK2_FUNC_LCD_G7 0xa20f +#define STM32H7_PK2_FUNC_EVENTOUT 0xa210 +#define STM32H7_PK2_FUNC_ANALOG 0xa211 + +#define STM32H7_PK3_FUNC_GPIO 0xa300 +#define STM32H7_PK3_FUNC_LCD_B4 0xa30f +#define STM32H7_PK3_FUNC_EVENTOUT 0xa310 +#define STM32H7_PK3_FUNC_ANALOG 0xa311 + +#define STM32H7_PK4_FUNC_GPIO 0xa400 +#define STM32H7_PK4_FUNC_LCD_B5 0xa40f +#define STM32H7_PK4_FUNC_EVENTOUT 0xa410 +#define STM32H7_PK4_FUNC_ANALOG 0xa411 + +#define STM32H7_PK5_FUNC_GPIO 0xa500 +#define STM32H7_PK5_FUNC_LCD_B6 0xa50f +#define STM32H7_PK5_FUNC_EVENTOUT 0xa510 +#define STM32H7_PK5_FUNC_ANALOG 0xa511 + +#define STM32H7_PK6_FUNC_GPIO 0xa600 +#define STM32H7_PK6_FUNC_LCD_B7 0xa60f +#define STM32H7_PK6_FUNC_EVENTOUT 0xa610 +#define STM32H7_PK6_FUNC_ANALOG 0xa611 + +#define STM32H7_PK7_FUNC_GPIO 0xa700 +#define STM32H7_PK7_FUNC_LCD_DE 0xa70f +#define STM32H7_PK7_FUNC_EVENTOUT 0xa710 +#define STM32H7_PK7_FUNC_ANALOG 0xa711 + +#endif /* _DT_BINDINGS_STM32H7_PINFUNC_H */
On 13 September 2017 at 10:00, patrice.chotard@st.com wrote:
All these files are imported from linux kernel v4.13
Add device tree support for STM32H743 SoC and discovery board. This board offers : _ STM32H743XIH6 microcontroller with 2 Mbytes of Flash memory and 1 Mbyte of RAM in TFBGA240+25 package _ 5.7” 640x480 TFT color LCD with touch screen _ Ethernet compliant with IEEE-802.3-2002 _ USB OTG HS _ I2 C compatible serial interface _ ST-MEMS digital microphones _ 8-Gbyte (or more) SDIO3.0 interface microSD™ card _ 8Mx32bit SDRAM _ 1-Gbit Twin Quad-SPI NOR Flash _ Reset, wakeup, or key buttons _ Joystick with 4-direction control and selector _ Board connectors : 1 USB with Micro-AB Ethernet RJ45 Stereo headset jack including analog microphone input microSD™ card RCA connector JTAG/SWD and ETM trace _ Expansion connectors: Arduino Uno compatible Connectors 2 x PIO connectors (PMOD and PMOD+) _ On-board ST-LINK/V2-1 debugger/programmer with USB re-enumeration capability: mass storage, virtual COM port and debug port
Signed-off-by: Patrice Chotard patrice.chotard@st.com Reviewed-by: Vikas Manocha vikas.manocha@st.com
v2: _ reword the board description
arch/arm/dts/Makefile | 1 + arch/arm/dts/stm32h743-pinctrl.dtsi | 169 +++ arch/arm/dts/stm32h743.dtsi | 91 ++ arch/arm/dts/stm32h743i-disco.dts | 73 ++ include/dt-bindings/pinctrl/stm32h7-pinfunc.h | 1612 +++++++++++++++++++++++++ 5 files changed, 1946 insertions(+) create mode 100644 arch/arm/dts/stm32h743-pinctrl.dtsi create mode 100644 arch/arm/dts/stm32h743.dtsi create mode 100644 arch/arm/dts/stm32h743i-disco.dts create mode 100644 include/dt-bindings/pinctrl/stm32h7-pinfunc.h
Signed-off-by: Patrice Chotard patrice.chotard@st.com Reviewed-by: Vikas Manocha vikas.manocha@st.com Reviewed-by: Simon Glass sjg@chromium.org
This file is imported from linux kernel v4.13
Add device tree support for STM32H743 evaluation board. This board offers : _ STM32H743XIH6 microcontroller with 2 Mbytes of Flash memory and 1 Mbyte of RAM in TFBGA240+25 package _ 5.7” 640x480 TFT color LCD with touch screen _ Ethernet compliant with IEEE-802.3-2002 _ USB OTG HS and FS _ I2 C compatible serial interface _ RTC with rechargeable backup battery _ SAI Audio DAC _ ST-MEMS digital microphones _ 8-Gbyte (or more) SDIO3.0 interface microSD™ card _ 8Mx32bit SDRAM, 1Mx16bit SRAM and 8Mx16bit NOR Flash _ 1-Gbit Twin Quad-SPI NOR Flash _ Potentiometer _ 4 colored user LEDs _ Reset, wakeup, tamper or key buttons _ Joystick with 4-direction control and selector _ Board connectors : Power jack 3 USB with Micro-AB RS-232 communications Ethernet RJ45 FD-CAN compliant connection Stereo headset jack including analog microphone input 2 audio jacks for external speakers microSD™ card JTAG/SWD and ETM trace _ Expansion connectors: Extension connectors and memory connectors for daughterboard or wire-wrap board _ Flexible power-supply options: ST-LINK USB VBUS or external sources _ On-board ST-LINK/V2-1 debugger/programmer with USB re-enumeration capability: mass storage, virtual COM port and debug port
Signed-off-by: Patrice Chotard patrice.chotard@st.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/stm32h743i-eval.dts | 74 ++++++++++++++++++++++++++++++++++++++++ 2 files changed, 76 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/stm32h743i-eval.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index fb7ae82..38cb66b 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -205,7 +205,8 @@ dtb-$(CONFIG_ARCH_SNAPDRAGON) += dragonboard410c.dtb
dtb-$(CONFIG_STM32F7) += stm32f746-disco.dtb \ stm32f769-disco.dtb -dtb-$(CONFIG_STM32H7) += stm32h743i-disco.dtb +dtb-$(CONFIG_STM32H7) += stm32h743i-disco.dtb \ + stm32h743i-eval.dtb
dtb-$(CONFIG_MACH_SUN4I) += \ sun4i-a10-a1000.dtb \ diff --git a/arch/arm/dts/stm32h743i-eval.dts b/arch/arm/dts/stm32h743i-eval.dts new file mode 100644 index 0000000..c6effbb --- /dev/null +++ b/arch/arm/dts/stm32h743i-eval.dts @@ -0,0 +1,74 @@ +/* + * Copyright 2017 - Alexandre Torgue alexandre.torgue@st.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "stm32h743.dtsi" +#include "stm32h743-pinctrl.dtsi" + +/ { + model = "STMicroelectronics STM32H743i-EVAL board"; + compatible = "st,stm32h743i-eval", "st,stm32h743"; + + chosen { + bootargs = "root=/dev/ram"; + stdout-path = "serial0:115200n8"; + }; + + memory { + reg = <0xd0000000 0x2000000>; + }; + + aliases { + serial0 = &usart1; + }; +}; + +&clk_hse { + clock-frequency = <125000000>; +}; + +&usart1 { + pinctrl-0 = <&usart1_pins>; + pinctrl-names = "default"; + status = "okay"; +}; +
Signed-off-by: Patrice Chotard patrice.chotard@st.com Reviewed-by: Simon Glass sjg@chromium.org
This patch adapts stm32h743 disco and eval dts files to match with U-boot requirements or add features wich are not yet upstreamed on kernel side :
_ Add RCC clock driver node and update all clocks phandle accordingly.
By default, on kernel side, all clocks was temporarly configured as a phandle to timer_clk waiting for a RCC clock driver to be available. On U-boot side, we now have a dedicated RCC clock driver, we can configured all clocks as phandle to this driver.
All this binding update will be available soon in a kernel tag, as all the bindings have been acked by Rob Herring [1].
[1] http://lkml.iu.edu/hypermail/linux/kernel/1704.0/00935.html
_ Align STM32H7 serial compatible string with the one which will be available in next kernel tag. The bindings has been acked by Rob Herring [2]. This compatible string will be usefull to add stm32h7 specific feature for this serial driver.
[2] https://lkml.org/lkml/2017/7/17/739
_ Add gpio compatible and aliases for stm32h743
_ Add FMC sdram node with associated new bindings value to manage second bank (ie bank 1).
_ Add missing HSI and CSI oscillators nodes needed by STM32H7 RCC clock driver.
Clock sources could be: _ HSE (High Speed External) _ HSI (High Speed Internal) _ CSI (Low Power Internal)
These clocks can be used as clocksource in some configuration. By default, HSE is selected as clock source.
_ Set HSE to 25Mhz for stm32h743i-disco and eval board
By default, the external oscillator frequency is defined at 25 Mhz in SoC stm32h743.dtsi file. It has been set at 125 Mhz in kernel DT temporarly waiting for RCC clock driver becomes available.
As in U-boot we got a RCC clock driver, the real value of HSE clock can be used.
_ Add "u-boot,dm-pre-reloc" for rcc, fmc, fixed-clock, pinctrl, pwrcfg and gpio nodes.
Signed-off-by: Patrice Chotard patrice.chotard@st.com --- arch/arm/dts/stm32h7-u-boot.dtsi | 88 ++++++++++++++++++++++++++ arch/arm/dts/stm32h743-pinctrl.dtsi | 102 +++++++++++++++++++++++++++---- arch/arm/dts/stm32h743.dtsi | 56 ++++++++++++++--- arch/arm/dts/stm32h743i-disco.dts | 35 +++++++++-- arch/arm/dts/stm32h743i-eval.dts | 34 +++++++++-- include/dt-bindings/memory/stm32-sdram.h | 7 +++ 6 files changed, 294 insertions(+), 28 deletions(-) create mode 100644 arch/arm/dts/stm32h7-u-boot.dtsi
diff --git a/arch/arm/dts/stm32h7-u-boot.dtsi b/arch/arm/dts/stm32h7-u-boot.dtsi new file mode 100644 index 0000000..2525035 --- /dev/null +++ b/arch/arm/dts/stm32h7-u-boot.dtsi @@ -0,0 +1,88 @@ +/{ + clocks { + u-boot,dm-pre-reloc; + }; + + soc { + u-boot,dm-pre-reloc; + pin-controller { + u-boot,dm-pre-reloc; + }; + }; +}; + +&clk_hse { + u-boot,dm-pre-reloc; +}; + +&clk_lse { + u-boot,dm-pre-reloc; +}; + +&clk_i2s { + u-boot,dm-pre-reloc; +}; + +&pwrcfg { + u-boot,dm-pre-reloc; +}; + +&rcc { + u-boot,dm-pre-reloc; +}; + +&fmc { + u-boot,dm-pre-reloc; +}; + +&clk_hsi { + u-boot,dm-pre-reloc; +}; + +&clk_csi { + u-boot,dm-pre-reloc; +}; + +&gpioa { + u-boot,dm-pre-reloc; +}; + +&gpiob { + u-boot,dm-pre-reloc; +}; + +&gpioc { + u-boot,dm-pre-reloc; +}; + +&gpiod { + u-boot,dm-pre-reloc; +}; + +&gpioe { + u-boot,dm-pre-reloc; +}; + +&gpiof { + u-boot,dm-pre-reloc; +}; + +&gpiog { + u-boot,dm-pre-reloc; +}; + +&gpioh { + u-boot,dm-pre-reloc; +}; + +&gpioi { + u-boot,dm-pre-reloc; +}; + +&gpioj { + u-boot,dm-pre-reloc; +}; + +&gpiok { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/stm32h743-pinctrl.dtsi b/arch/arm/dts/stm32h743-pinctrl.dtsi index 76bbd65..d3e11d5 100644 --- a/arch/arm/dts/stm32h743-pinctrl.dtsi +++ b/arch/arm/dts/stm32h743-pinctrl.dtsi @@ -54,88 +54,99 @@ gpioa: gpio@58020000 { gpio-controller; #gpio-cells = <2>; + compatible = "st,stm32-gpio"; reg = <0x0 0x400>; - clocks = <&timer_clk>; + clocks = <&rcc GPIOA_CK>; st,bank-name = "GPIOA"; };
gpiob: gpio@58020400 { gpio-controller; #gpio-cells = <2>; + compatible = "st,stm32-gpio"; reg = <0x400 0x400>; - clocks = <&timer_clk>; + clocks = <&rcc GPIOB_CK>; st,bank-name = "GPIOB"; };
gpioc: gpio@58020800 { gpio-controller; #gpio-cells = <2>; + compatible = "st,stm32-gpio"; reg = <0x800 0x400>; - clocks = <&timer_clk>; + clocks = <&rcc GPIOC_CK>; st,bank-name = "GPIOC"; };
gpiod: gpio@58020c00 { gpio-controller; #gpio-cells = <2>; + compatible = "st,stm32-gpio"; reg = <0xc00 0x400>; - clocks = <&timer_clk>; + clocks = <&rcc GPIOD_CK>; st,bank-name = "GPIOD"; };
gpioe: gpio@58021000 { gpio-controller; #gpio-cells = <2>; + compatible = "st,stm32-gpio"; reg = <0x1000 0x400>; - clocks = <&timer_clk>; + clocks = <&rcc GPIOE_CK>; st,bank-name = "GPIOE"; };
gpiof: gpio@58021400 { gpio-controller; #gpio-cells = <2>; + compatible = "st,stm32-gpio"; reg = <0x1400 0x400>; - clocks = <&timer_clk>; + clocks = <&rcc GPIOF_CK>; st,bank-name = "GPIOF"; };
gpiog: gpio@58021800 { gpio-controller; #gpio-cells = <2>; + compatible = "st,stm32-gpio"; reg = <0x1800 0x400>; - clocks = <&timer_clk>; + clocks = <&rcc GPIOG_CK>; st,bank-name = "GPIOG"; };
gpioh: gpio@58021c00 { gpio-controller; #gpio-cells = <2>; + compatible = "st,stm32-gpio"; reg = <0x1c00 0x400>; - clocks = <&timer_clk>; + clocks = <&rcc GPIOH_CK>; st,bank-name = "GPIOH"; };
gpioi: gpio@58022000 { gpio-controller; #gpio-cells = <2>; + compatible = "st,stm32-gpio"; reg = <0x2000 0x400>; - clocks = <&timer_clk>; + clocks = <&rcc GPIOI_CK>; st,bank-name = "GPIOI"; };
gpioj: gpio@58022400 { gpio-controller; #gpio-cells = <2>; + compatible = "st,stm32-gpio"; reg = <0x2400 0x400>; - clocks = <&timer_clk>; + clocks = <&rcc GPIOJ_CK>; st,bank-name = "GPIOJ"; };
gpiok: gpio@58022800 { gpio-controller; #gpio-cells = <2>; + compatible = "st,stm32-gpio"; reg = <0x2800 0x400>; - clocks = <&timer_clk>; + clocks = <&rcc GPIOK_CK>; st,bank-name = "GPIOK"; };
@@ -164,6 +175,75 @@ bias-disable; }; }; + + fmc_pins: fmc@0 { + pins { + pinmux = <STM32H7_PD0_FUNC_FMC_D2_FMC_DA2>, + <STM32H7_PD1_FUNC_FMC_D3_FMC_DA3>, + <STM32H7_PD8_FUNC_FMC_D13_FMC_DA13>, + <STM32H7_PD9_FUNC_FMC_D14_FMC_DA14>, + <STM32H7_PD10_FUNC_FMC_D15_FMC_DA15>, + <STM32H7_PD14_FUNC_FMC_D0_FMC_DA0>, + <STM32H7_PD15_FUNC_FMC_D1_FMC_DA1>, + + <STM32H7_PE0_FUNC_FMC_NBL0>, + <STM32H7_PE1_FUNC_FMC_NBL1>, + <STM32H7_PE7_FUNC_FMC_D4_FMC_DA4>, + <STM32H7_PE8_FUNC_FMC_D5_FMC_DA5>, + <STM32H7_PE9_FUNC_FMC_D6_FMC_DA6>, + <STM32H7_PE10_FUNC_FMC_D7_FMC_DA7>, + <STM32H7_PE11_FUNC_FMC_D8_FMC_DA8>, + <STM32H7_PE12_FUNC_FMC_D9_FMC_DA9>, + <STM32H7_PE13_FUNC_FMC_D10_FMC_DA10>, + <STM32H7_PE14_FUNC_FMC_D11_FMC_DA11>, + <STM32H7_PE15_FUNC_FMC_D12_FMC_DA12>, + + <STM32H7_PF0_FUNC_FMC_A0>, + <STM32H7_PF1_FUNC_FMC_A1>, + <STM32H7_PF2_FUNC_FMC_A2>, + <STM32H7_PF3_FUNC_FMC_A3>, + <STM32H7_PF4_FUNC_FMC_A4>, + <STM32H7_PF5_FUNC_FMC_A5>, + <STM32H7_PF11_FUNC_FMC_SDNRAS>, + <STM32H7_PF12_FUNC_FMC_A6>, + <STM32H7_PF13_FUNC_FMC_A7>, + <STM32H7_PF14_FUNC_FMC_A8>, + <STM32H7_PF15_FUNC_FMC_A9>, + + <STM32H7_PG0_FUNC_FMC_A10>, + <STM32H7_PG1_FUNC_FMC_A11>, + <STM32H7_PG2_FUNC_FMC_A12>, + <STM32H7_PG4_FUNC_FMC_A14_FMC_BA0>, + <STM32H7_PG5_FUNC_FMC_A15_FMC_BA1>, + <STM32H7_PG8_FUNC_FMC_SDCLK>, + <STM32H7_PG15_FUNC_FMC_SDNCAS>, + + <STM32H7_PH5_FUNC_FMC_SDNWE>, + <STM32H7_PH6_FUNC_FMC_SDNE1>, + <STM32H7_PH7_FUNC_FMC_SDCKE1>, + <STM32H7_PH8_FUNC_FMC_D16>, + <STM32H7_PH9_FUNC_FMC_D17>, + <STM32H7_PH10_FUNC_FMC_D18>, + <STM32H7_PH11_FUNC_FMC_D19>, + <STM32H7_PH12_FUNC_FMC_D20>, + <STM32H7_PH13_FUNC_FMC_D21>, + <STM32H7_PH14_FUNC_FMC_D22>, + <STM32H7_PH15_FUNC_FMC_D23>, + + <STM32H7_PI0_FUNC_FMC_D24>, + <STM32H7_PI1_FUNC_FMC_D25>, + <STM32H7_PI2_FUNC_FMC_D26>, + <STM32H7_PI3_FUNC_FMC_D27>, + <STM32H7_PI4_FUNC_FMC_NBL2>, + <STM32H7_PI5_FUNC_FMC_NBL3>, + <STM32H7_PI6_FUNC_FMC_D28>, + <STM32H7_PI7_FUNC_FMC_D29>, + <STM32H7_PI9_FUNC_FMC_D30>, + <STM32H7_PI10_FUNC_FMC_D31>; + + slew-rate = <3>; + }; + }; }; }; }; diff --git a/arch/arm/dts/stm32h743.dtsi b/arch/arm/dts/stm32h743.dtsi index 36a99db..16e9308 100644 --- a/arch/arm/dts/stm32h743.dtsi +++ b/arch/arm/dts/stm32h743.dtsi @@ -42,45 +42,83 @@
#include "skeleton.dtsi" #include "armv7-m.dtsi" +#include <dt-bindings/clock/stm32h7-clks.h>
/ { clocks { clk_hse: clk-hse { #clock-cells = <0>; compatible = "fixed-clock"; - clock-frequency = <0>; + clock-frequency = <25000000>; + }; + + clk_lse: clk-lse { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <32768>; };
- timer_clk: timer-clk { + clk_i2s: i2s_ckin { #clock-cells = <0>; compatible = "fixed-clock"; - clock-frequency = <125000000>; + clock-frequency = <0>; }; };
soc { + rcc: rcc@58024400 { + #clock-cells = <1>; + #reset-cells = <1>; + compatible = "st,stm32h743-rcc", "st,stm32-rcc"; + reg = <0x58024400 0x400>; + clocks = <&clk_hse>, <&clk_lse>, <&clk_i2s>, <&clk_hsi>, <&clk_csi>; + st,syscfg = <&pwrcfg>; + }; + usart1: serial@40011000 { - compatible = "st,stm32f7-usart", "st,stm32f7-uart"; + compatible = "st,stm32h7-usart", "st,stm32h7-uart"; reg = <0x40011000 0x400>; interrupts = <37>; status = "disabled"; - clocks = <&timer_clk>; - + clocks = <&rcc USART1_CK>; };
usart2: serial@40004400 { - compatible = "st,stm32f7-usart", "st,stm32f7-uart"; + compatible = "st,stm32h7-usart", "st,stm32h7-uart"; reg = <0x40004400 0x400>; interrupts = <38>; status = "disabled"; - clocks = <&timer_clk>; + clocks = <&rcc USART2_CK>; };
timer5: timer@40000c00 { compatible = "st,stm32-timer"; reg = <0x40000c00 0x400>; interrupts = <50>; - clocks = <&timer_clk>; + clocks = <&rcc TIM5_CK>; + }; + + pwrcfg: power-config@58024800 { + compatible = "syscon"; + reg = <0x58024800 0x400>; + }; + + fmc: fmc@52004000 { + compatible = "st,stm32h7-fmc"; + reg = <0x52004000 0x1000>; + clocks = <&rcc FMC_CK>; + }; + + clk_hsi: clk-hsi { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <64000000>; + }; + + clk_csi: clk-csi { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <4000000>; }; }; }; diff --git a/arch/arm/dts/stm32h743i-disco.dts b/arch/arm/dts/stm32h743i-disco.dts index 79e841d..bef7e90 100644 --- a/arch/arm/dts/stm32h743i-disco.dts +++ b/arch/arm/dts/stm32h743i-disco.dts @@ -43,6 +43,7 @@ /dts-v1/; #include "stm32h743.dtsi" #include "stm32h743-pinctrl.dtsi" +#include <dt-bindings/memory/stm32-sdram.h>
/ { model = "STMicroelectronics STM32H743i-Discovery board"; @@ -59,15 +60,41 @@
aliases { serial0 = &usart2; + gpio0 = &gpioa; + gpio1 = &gpiob; + gpio2 = &gpioc; + gpio3 = &gpiod; + gpio4 = &gpioe; + gpio5 = &gpiof; + gpio6 = &gpiog; + gpio7 = &gpioh; + gpio8 = &gpioi; + gpio9 = &gpioj; + gpio10 = &gpiok; }; };
-&clk_hse { - clock-frequency = <125000000>; -}; - &usart2 { pinctrl-0 = <&usart2_pins>; pinctrl-names = "default"; status = "okay"; }; + +&fmc { + pinctrl-0 = <&fmc_pins>; + pinctrl-names = "default"; + status = "okay"; + + /* + * Memory configuration from sdram datasheet IS42S32800G-6BLI + * firsct bank is bank@0 + * second bank is bank@1 + */ + bank1: bank@1 { + st,sdram-control = /bits/ 8 <NO_COL_9 NO_ROW_12 MWIDTH_32 BANKS_4 + CAS_2 SDCLK_3 RD_BURST_EN RD_PIPE_DL_0>; + st,sdram-timing = /bits/ 8 <TMRD_1 TXSR_1 TRAS_1 TRC_6 TRP_2 + TWR_1 TRCD_1>; + st,sdram-refcount = <1539>; + }; +}; diff --git a/arch/arm/dts/stm32h743i-eval.dts b/arch/arm/dts/stm32h743i-eval.dts index c6effbb..0e01ce5 100644 --- a/arch/arm/dts/stm32h743i-eval.dts +++ b/arch/arm/dts/stm32h743i-eval.dts @@ -43,6 +43,7 @@ /dts-v1/; #include "stm32h743.dtsi" #include "stm32h743-pinctrl.dtsi" +#include <dt-bindings/memory/stm32-sdram.h>
/ { model = "STMicroelectronics STM32H743i-EVAL board"; @@ -59,16 +60,41 @@
aliases { serial0 = &usart1; + gpio0 = &gpioa; + gpio1 = &gpiob; + gpio2 = &gpioc; + gpio3 = &gpiod; + gpio4 = &gpioe; + gpio5 = &gpiof; + gpio6 = &gpiog; + gpio7 = &gpioh; + gpio8 = &gpioi; + gpio9 = &gpioj; + gpio10 = &gpiok; }; };
-&clk_hse { - clock-frequency = <125000000>; -}; - &usart1 { pinctrl-0 = <&usart1_pins>; pinctrl-names = "default"; status = "okay"; };
+&fmc { + pinctrl-0 = <&fmc_pins>; + pinctrl-names = "default"; + status = "okay"; + + /* + * Memory configuration from sdram datasheet IS42S32800G-6BLI + * firsct bank is bank@0 + * second bank is bank@1 + */ + bank2: bank@1 { + st,sdram-control = /bits/ 8 <NO_COL_9 NO_ROW_12 MWIDTH_32 BANKS_4 + CAS_2 SDCLK_3 RD_BURST_EN RD_PIPE_DL_0>; + st,sdram-timing = /bits/ 8 <TMRD_1 TXSR_1 TRAS_1 TRC_6 TRP_2 + TWR_1 TRCD_1>; + st,sdram-refcount = <1539>; + }; +}; diff --git a/include/dt-bindings/memory/stm32-sdram.h b/include/dt-bindings/memory/stm32-sdram.h index 89b719a..c2b911f 100644 --- a/include/dt-bindings/memory/stm32-sdram.h +++ b/include/dt-bindings/memory/stm32-sdram.h @@ -18,7 +18,9 @@ #define CAS_1 0x1 #define CAS_2 0x2 #define CAS_3 0x3 +#define SDCLK_DIS 0x0 #define SDCLK_2 0x2 +#define SDCLK_3 0x3 #define RD_BURST_EN 0x1 #define RD_BURST_DIS 0x0 #define RD_PIPE_DL_0 0x0 @@ -26,12 +28,17 @@ #define RD_PIPE_DL_2 0x2
/* Timing = value +1 cycles */ +#define TMRD_1 (1 - 1) #define TMRD_2 (2 - 1) +#define TXSR_1 (1 - 1) #define TXSR_6 (6 - 1) +#define TRAS_1 (1 - 1) #define TRAS_4 (4 - 1) #define TRC_6 (6 - 1) +#define TWR_1 (1 - 1) #define TWR_2 (2 - 1) #define TRP_2 (2 - 1) +#define TRCD_1 (1 - 1) #define TRCD_2 (2 - 1)
#endif
U-Boot (and below)
This patch adds support for stm32h7 soc family, stm32h743 discovery and evaluation boards.
For more information about STM32H7 series, please visit: http://www.st.com/en/microcontrollers/stm32h7-series.html
v2: _ get memory address and size from DT in board file
arch/arm/include/asm/arch-stm32h7/gpio.h | 126 +++++++++++++++++++++++++++++ arch/arm/include/asm/arch-stm32h7/stm32.h | 21 +++++ arch/arm/mach-stm32/Kconfig | 17 ++++ arch/arm/mach-stm32/Makefile | 1 + arch/arm/mach-stm32/stm32h7/Kconfig | 12 +++ arch/arm/mach-stm32/stm32h7/Makefile | 8 ++ arch/arm/mach-stm32/stm32h7/soc.c | 59 ++++++++++++++ board/st/stm32h743-disco/Kconfig | 19 +++++ board/st/stm32h743-disco/MAINTAINERS | 7 ++ board/st/stm32h743-disco/Makefile | 8 ++ board/st/stm32h743-disco/stm32h743-disco.c | 56 +++++++++++++ board/st/stm32h743-eval/Kconfig | 19 +++++ board/st/stm32h743-eval/MAINTAINERS | 6 ++ board/st/stm32h743-eval/Makefile | 8 ++ board/st/stm32h743-eval/stm32h743-eval.c | 56 +++++++++++++ configs/stm32h743-disco_defconfig | 30 +++++++ configs/stm32h743-eval_defconfig | 30 +++++++ include/configs/stm32h743-disco.h | 51 ++++++++++++ include/configs/stm32h743-eval.h | 51 ++++++++++++ 19 files changed, 585 insertions(+) create mode 100644 arch/arm/include/asm/arch-stm32h7/gpio.h create mode 100644 arch/arm/include/asm/arch-stm32h7/stm32.h create mode 100644 arch/arm/mach-stm32/stm32h7/Kconfig create mode 100644 arch/arm/mach-stm32/stm32h7/Makefile create mode 100644 arch/arm/mach-stm32/stm32h7/soc.c create mode 100644 board/st/stm32h743-disco/Kconfig create mode 100644 board/st/stm32h743-disco/MAINTAINERS create mode 100644 board/st/stm32h743-disco/Makefile create mode 100644 board/st/stm32h743-disco/stm32h743-disco.c create mode 100644 board/st/stm32h743-eval/Kconfig create mode 100644 board/st/stm32h743-eval/MAINTAINERS create mode 100644 board/st/stm32h743-eval/Makefile create mode 100644 board/st/stm32h743-eval/stm32h743-eval.c create mode 100644 configs/stm32h743-disco_defconfig create mode 100644 configs/stm32h743-eval_defconfig create mode 100644 include/configs/stm32h743-disco.h create mode 100644 include/configs/stm32h743-eval.h
diff --git a/arch/arm/include/asm/arch-stm32h7/gpio.h b/arch/arm/include/asm/arch-stm32h7/gpio.h new file mode 100644 index 0000000..450784c --- /dev/null +++ b/arch/arm/include/asm/arch-stm32h7/gpio.h @@ -0,0 +1,126 @@ +/* + * Copyright (C) STMicroelectronics SA 2017 + * Author(s): Patrice CHOTARD, patrice.chotard@st.com for STMicroelectronics. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _STM32_GPIO_H_ +#define _STM32_GPIO_H_ +#include <asm/gpio.h> + +enum stm32_gpio_port { + STM32_GPIO_PORT_A = 0, + STM32_GPIO_PORT_B, + STM32_GPIO_PORT_C, + STM32_GPIO_PORT_D, + STM32_GPIO_PORT_E, + STM32_GPIO_PORT_F, + STM32_GPIO_PORT_G, + STM32_GPIO_PORT_H, + STM32_GPIO_PORT_I +}; + +enum stm32_gpio_pin { + STM32_GPIO_PIN_0 = 0, + STM32_GPIO_PIN_1, + STM32_GPIO_PIN_2, + STM32_GPIO_PIN_3, + STM32_GPIO_PIN_4, + STM32_GPIO_PIN_5, + STM32_GPIO_PIN_6, + STM32_GPIO_PIN_7, + STM32_GPIO_PIN_8, + STM32_GPIO_PIN_9, + STM32_GPIO_PIN_10, + STM32_GPIO_PIN_11, + STM32_GPIO_PIN_12, + STM32_GPIO_PIN_13, + STM32_GPIO_PIN_14, + STM32_GPIO_PIN_15 +}; + +enum stm32_gpio_mode { + STM32_GPIO_MODE_IN = 0, + STM32_GPIO_MODE_OUT, + STM32_GPIO_MODE_AF, + STM32_GPIO_MODE_AN +}; + +enum stm32_gpio_otype { + STM32_GPIO_OTYPE_PP = 0, + STM32_GPIO_OTYPE_OD +}; + +enum stm32_gpio_speed { + STM32_GPIO_SPEED_2M = 0, + STM32_GPIO_SPEED_25M, + STM32_GPIO_SPEED_50M, + STM32_GPIO_SPEED_100M +}; + +enum stm32_gpio_pupd { + STM32_GPIO_PUPD_NO = 0, + STM32_GPIO_PUPD_UP, + STM32_GPIO_PUPD_DOWN +}; + +enum stm32_gpio_af { + STM32_GPIO_AF0 = 0, + STM32_GPIO_AF1, + STM32_GPIO_AF2, + STM32_GPIO_AF3, + STM32_GPIO_AF4, + STM32_GPIO_AF5, + STM32_GPIO_AF6, + STM32_GPIO_AF7, + STM32_GPIO_AF8, + STM32_GPIO_AF9, + STM32_GPIO_AF10, + STM32_GPIO_AF11, + STM32_GPIO_AF12, + STM32_GPIO_AF13, + STM32_GPIO_AF14, + STM32_GPIO_AF15 +}; + +struct stm32_gpio_dsc { + enum stm32_gpio_port port; + enum stm32_gpio_pin pin; +}; + +struct stm32_gpio_ctl { + enum stm32_gpio_mode mode; + enum stm32_gpio_otype otype; + enum stm32_gpio_speed speed; + enum stm32_gpio_pupd pupd; + enum stm32_gpio_af af; +}; + +struct stm32_gpio_regs { + u32 moder; /* GPIO port mode */ + u32 otyper; /* GPIO port output type */ + u32 ospeedr; /* GPIO port output speed */ + u32 pupdr; /* GPIO port pull-up/pull-down */ + u32 idr; /* GPIO port input data */ + u32 odr; /* GPIO port output data */ + u32 bsrr; /* GPIO port bit set/reset */ + u32 lckr; /* GPIO port configuration lock */ + u32 afr[2]; /* GPIO alternate function */ +}; + +struct stm32_gpio_priv { + struct stm32_gpio_regs *regs; +}; + +static inline unsigned stm32_gpio_to_port(unsigned gpio) +{ + return gpio / 16; +} + +static inline unsigned stm32_gpio_to_pin(unsigned gpio) +{ + return gpio % 16; +} + +#endif /* _STM32_GPIO_H_ */ diff --git a/arch/arm/include/asm/arch-stm32h7/stm32.h b/arch/arm/include/asm/arch-stm32h7/stm32.h new file mode 100644 index 0000000..9ff1f13 --- /dev/null +++ b/arch/arm/include/asm/arch-stm32h7/stm32.h @@ -0,0 +1,21 @@ +/* + * Copyright (C) STMicroelectronics SA 2017 + * Author(s): Patrice CHOTARD, patrice.chotard@st.com for STMicroelectronics. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ASM_ARCH_HARDWARE_H +#define _ASM_ARCH_HARDWARE_H + +/* + * This empty files is needed to not break compilation + * Some common drivers to STM32F4/F7 and H7 include a stm32.h file + * Some cleanup need to be done to communalize all the following + * stm32.h files: + * + * arch/arm/include/asm/arch-stm32f1/stm32.h + * arch/arm/include/asm/arch-stm32f4/stm32.h + * arch/arm/include/asm/arch-stm32f7/stm32.h + */ +#endif /* _ASM_ARCH_HARDWARE_H */ diff --git a/arch/arm/mach-stm32/Kconfig b/arch/arm/mach-stm32/Kconfig index 947ce5f..b618b60 100644 --- a/arch/arm/mach-stm32/Kconfig +++ b/arch/arm/mach-stm32/Kconfig @@ -25,7 +25,24 @@ config STM32F7 select SPL_SYS_MALLOC_SIMPLE select SPL_XIP_SUPPORT
+config STM32H7 + bool "stm32h7 family" + select CLK + select DM_GPIO + select DM_RESET + select MISC + select PINCTRL + select PINCTRL_STM32 + select RAM + select REGMAP + select STM32_SDRAM + select STM32_RCC + select STM32_RESET + select STM32X7_SERIAL + select SYSCON + source "arch/arm/mach-stm32/stm32f4/Kconfig" source "arch/arm/mach-stm32/stm32f7/Kconfig" +source "arch/arm/mach-stm32/stm32h7/Kconfig"
endif diff --git a/arch/arm/mach-stm32/Makefile b/arch/arm/mach-stm32/Makefile index 6b76944..0f5ac37 100644 --- a/arch/arm/mach-stm32/Makefile +++ b/arch/arm/mach-stm32/Makefile @@ -7,3 +7,4 @@
obj-$(CONFIG_STM32F4) += stm32f4/ obj-$(CONFIG_STM32F7) += stm32f7/ +obj-$(CONFIG_STM32H7) += stm32h7/ diff --git a/arch/arm/mach-stm32/stm32h7/Kconfig b/arch/arm/mach-stm32/stm32h7/Kconfig new file mode 100644 index 0000000..55e6217 --- /dev/null +++ b/arch/arm/mach-stm32/stm32h7/Kconfig @@ -0,0 +1,12 @@ +if STM32H7 + +config TARGET_STM32H743_DISCO + bool "STM32H743 Discovery board" + +config TARGET_STM32H743_EVAL + bool "STM32H743 Evaluation board" + +source "board/st/stm32h743-eval/Kconfig" +source "board/st/stm32h743-disco/Kconfig" + +endif diff --git a/arch/arm/mach-stm32/stm32h7/Makefile b/arch/arm/mach-stm32/stm32h7/Makefile new file mode 100644 index 0000000..97f92f7 --- /dev/null +++ b/arch/arm/mach-stm32/stm32h7/Makefile @@ -0,0 +1,8 @@ +# +# Copyright (c) 2017 +# Patrice Chotard patrice.chotard@st.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += soc.o diff --git a/arch/arm/mach-stm32/stm32h7/soc.c b/arch/arm/mach-stm32/stm32h7/soc.c new file mode 100644 index 0000000..a65fab6 --- /dev/null +++ b/arch/arm/mach-stm32/stm32h7/soc.c @@ -0,0 +1,59 @@ +/* + * Copyright (C) STMicroelectronics SA 2017 + * Author(s): Patrice CHOTARD, patrice.chotard@st.com for STMicroelectronics. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/armv7m_mpu.h> + +u32 get_cpu_rev(void) +{ + return 0; +} + +int arch_cpu_init(void) +{ + int i; + + struct mpu_region_config stm32_region_config[] = { + /* + * Make all 4GB cacheable & executable. We are overriding it + * with next region for any requirement. e.g. below region1, + * 2 etc. + * In other words, the area not coming in following + * regions configuration is the one configured here in region_0 + * (cacheable & executable). + */ + { 0x00000000, REGION_0, XN_DIS, PRIV_RW_USR_RW, + O_I_WB_RD_WR_ALLOC, REGION_4GB }, + + /* Code area, executable & strongly ordered */ + { 0xD0000000, REGION_1, XN_EN, PRIV_RW_USR_RW, + STRONG_ORDER, REGION_8MB }, + + /* Device area in all H7 : Not executable */ + { 0x40000000, REGION_2, XN_EN, PRIV_RW_USR_RW, + DEVICE_NON_SHARED, REGION_512MB }, + + /* + * Armv7m fixed configuration: strongly ordered & not + * executable, not cacheable + */ + { 0xE0000000, REGION_4, XN_EN, PRIV_RW_USR_RW, + STRONG_ORDER, REGION_512MB }, + }; + + disable_mpu(); + for (i = 0; i < ARRAY_SIZE(stm32_region_config); i++) + mpu_config(&stm32_region_config[i]); + enable_mpu(); + + return 0; +} + +void s_init(void) +{ +} diff --git a/board/st/stm32h743-disco/Kconfig b/board/st/stm32h743-disco/Kconfig new file mode 100644 index 0000000..7d6ec1d --- /dev/null +++ b/board/st/stm32h743-disco/Kconfig @@ -0,0 +1,19 @@ +if TARGET_STM32H743_DISCO + +config SYS_BOARD + string + default "stm32h743-disco" + +config SYS_VENDOR + string + default "st" + +config SYS_SOC + string + default "stm32h7" + +config SYS_CONFIG_NAME + string + default "stm32h743-disco" + +endif diff --git a/board/st/stm32h743-disco/MAINTAINERS b/board/st/stm32h743-disco/MAINTAINERS new file mode 100644 index 0000000..e5e0b5a --- /dev/null +++ b/board/st/stm32h743-disco/MAINTAINERS @@ -0,0 +1,7 @@ +STM32H743 DISCOVERY BOARD +M: Patrice Chotard patrice.chotard@st.com +S: Maintained +F: board/st/stm32h743-disco +F: include/configs/stm32h743-disco.h +F: configs/stm32h743-disco_defconfig +F: arch/arm/dts/stm32h7* diff --git a/board/st/stm32h743-disco/Makefile b/board/st/stm32h743-disco/Makefile new file mode 100644 index 0000000..778fe1c --- /dev/null +++ b/board/st/stm32h743-disco/Makefile @@ -0,0 +1,8 @@ +# +# Copyright (C) STMicroelectronics SA 2017 +# Author(s): Patrice CHOTARD, patrice.chotard@st.com for STMicroelectronics.# +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := stm32h743-disco.o diff --git a/board/st/stm32h743-disco/stm32h743-disco.c b/board/st/stm32h743-disco/stm32h743-disco.c new file mode 100644 index 0000000..625b3a0 --- /dev/null +++ b/board/st/stm32h743-disco/stm32h743-disco.c @@ -0,0 +1,56 @@ +/* + * Copyright (C) STMicroelectronics SA 2017 + * Author(s): Patrice CHOTARD, patrice.chotard@st.com for STMicroelectronics. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + struct udevice *dev; + int ret; + + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) { + debug("DRAM init failed: %d\n", ret); + return ret; + } + + if (fdtdec_setup_memory_size() != 0) + ret = -EINVAL; + + return ret; +} + +int dram_init_banksize(void) +{ + fdtdec_setup_memory_banksize(); + + return 0; +} + +int board_early_init_f(void) +{ + return 0; +} + +u32 get_board_rev(void) +{ + return 0; +} + +int board_late_init(void) +{ + return 0; +} + +int board_init(void) +{ + gd->bd->bi_boot_params = gd->bd->bi_dram[0].start + 0x100; + return 0; +} diff --git a/board/st/stm32h743-eval/Kconfig b/board/st/stm32h743-eval/Kconfig new file mode 100644 index 0000000..ea879b1 --- /dev/null +++ b/board/st/stm32h743-eval/Kconfig @@ -0,0 +1,19 @@ +if TARGET_STM32H743_EVAL + +config SYS_BOARD + string + default "stm32h743-eval" + +config SYS_VENDOR + string + default "st" + +config SYS_SOC + string + default "stm32h7" + +config SYS_CONFIG_NAME + string + default "stm32h743-eval" + +endif diff --git a/board/st/stm32h743-eval/MAINTAINERS b/board/st/stm32h743-eval/MAINTAINERS new file mode 100644 index 0000000..3029c56 --- /dev/null +++ b/board/st/stm32h743-eval/MAINTAINERS @@ -0,0 +1,6 @@ +STM32H743 EVALUATION BOARD +M: Patrice Chotard patrice.chotard@st.com +S: Maintained +F: board/st/stm32h743-eval +F: include/configs/stm32h743-eval.h +F: configs/stm32h743-eval_defconfig diff --git a/board/st/stm32h743-eval/Makefile b/board/st/stm32h743-eval/Makefile new file mode 100644 index 0000000..4f25b2d --- /dev/null +++ b/board/st/stm32h743-eval/Makefile @@ -0,0 +1,8 @@ +# +# (C) Copyright 2017 +# Patrice Chotard, patrice.chotard@st.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := stm32h743-eval.o diff --git a/board/st/stm32h743-eval/stm32h743-eval.c b/board/st/stm32h743-eval/stm32h743-eval.c new file mode 100644 index 0000000..625b3a0 --- /dev/null +++ b/board/st/stm32h743-eval/stm32h743-eval.c @@ -0,0 +1,56 @@ +/* + * Copyright (C) STMicroelectronics SA 2017 + * Author(s): Patrice CHOTARD, patrice.chotard@st.com for STMicroelectronics. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + struct udevice *dev; + int ret; + + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) { + debug("DRAM init failed: %d\n", ret); + return ret; + } + + if (fdtdec_setup_memory_size() != 0) + ret = -EINVAL; + + return ret; +} + +int dram_init_banksize(void) +{ + fdtdec_setup_memory_banksize(); + + return 0; +} + +int board_early_init_f(void) +{ + return 0; +} + +u32 get_board_rev(void) +{ + return 0; +} + +int board_late_init(void) +{ + return 0; +} + +int board_init(void) +{ + gd->bd->bi_boot_params = gd->bd->bi_dram[0].start + 0x100; + return 0; +} diff --git a/configs/stm32h743-disco_defconfig b/configs/stm32h743-disco_defconfig new file mode 100644 index 0000000..eed921d2 --- /dev/null +++ b/configs/stm32h743-disco_defconfig @@ -0,0 +1,30 @@ +CONFIG_ARM=y +CONFIG_STM32=y +CONFIG_SYS_MALLOC_F_LEN=0xF00 +CONFIG_STM32H7=y +CONFIG_TARGET_STM32H743_DISCO=y +CONFIG_DEFAULT_DEVICE_TREE="stm32h743i-disco" +CONFIG_BOOTDELAY=3 +CONFIG_DEFAULT_FDT_FILE="stm32h743i-disco" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="U-Boot > " +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit SPACE in %d seconds to stop autoboot.\n" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_NET is not set +# CONFIG_CMD_NFS is not set +CONFIG_CMD_TIMER=y +CONFIG_OF_CONTROL=y +CONFIG_OF_EMBED=y +# CONFIG_PINCTRL_FULL is not set +# CONFIG_SPL_SERIAL_PRESENT is not set +CONFIG_REGEX=y +CONFIG_LIB_RAND=y +CONFIG_OF_LIBFDT_OVERLAY=y +# CONFIG_EFI_LOADER is not set diff --git a/configs/stm32h743-eval_defconfig b/configs/stm32h743-eval_defconfig new file mode 100644 index 0000000..61e702e --- /dev/null +++ b/configs/stm32h743-eval_defconfig @@ -0,0 +1,30 @@ +CONFIG_ARM=y +CONFIG_STM32=y +CONFIG_SYS_MALLOC_F_LEN=0xF00 +CONFIG_STM32H7=y +CONFIG_TARGET_STM32H743_EVAL=y +CONFIG_DEFAULT_DEVICE_TREE="stm32h743i-eval" +CONFIG_BOOTDELAY=3 +CONFIG_DEFAULT_FDT_FILE="stm32h743i-eval" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="U-Boot > " +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit SPACE in %d seconds to stop autoboot.\n" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_NET is not set +# CONFIG_CMD_NFS is not set +CONFIG_CMD_TIMER=y +CONFIG_OF_CONTROL=y +CONFIG_OF_EMBED=y +# CONFIG_PINCTRL_FULL is not set +# CONFIG_SPL_SERIAL_PRESENT is not set +CONFIG_REGEX=y +CONFIG_LIB_RAND=y +CONFIG_OF_LIBFDT_OVERLAY=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/stm32h743-disco.h b/include/configs/stm32h743-disco.h new file mode 100644 index 0000000..b0061cd --- /dev/null +++ b/include/configs/stm32h743-disco.h @@ -0,0 +1,51 @@ +/* + * Copyright (C) STMicroelectronics SA 2017 + * Author(s): Patrice CHOTARD, patrice.chotard@st.com for STMicroelectronics. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <config.h> + +#define CONFIG_SYS_FLASH_BASE 0x08000000 +#define CONFIG_SYS_INIT_SP_ADDR 0x30020000 +#define CONFIG_SYS_TEXT_BASE 0x08000000 + +/* + * Configuration of the external SDRAM memory + */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_RAM_BASE 0xD0000000 +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_RAM_BASE +#define CONFIG_SYS_LOAD_ADDR 0xD0400000 +#define CONFIG_LOADADDR 0xD0400000 + +#define CONFIG_ENV_SIZE (8 << 10) + +#define CONFIG_SYS_ARCH_TIMER +#define CONFIG_SYS_HZ_CLOCK 250000000 + +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG + +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_MALLOC_LEN (1 * 1024 * 1024) + +#define CONFIG_BOOTARGS \ + "console=ttyS0,115200 earlyprintk consoleblank=0 ignore_loglevel" + +/* + * Command line configuration. + */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_AUTO_COMPLETE +#define CONFIG_CMDLINE_EDITING +#define CONFIG_CMD_CACHE +#define CONFIG_BOARD_LATE_INIT + +#endif /* __CONFIG_H */ diff --git a/include/configs/stm32h743-eval.h b/include/configs/stm32h743-eval.h new file mode 100644 index 0000000..b0061cd --- /dev/null +++ b/include/configs/stm32h743-eval.h @@ -0,0 +1,51 @@ +/* + * Copyright (C) STMicroelectronics SA 2017 + * Author(s): Patrice CHOTARD, patrice.chotard@st.com for STMicroelectronics. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <config.h> + +#define CONFIG_SYS_FLASH_BASE 0x08000000 +#define CONFIG_SYS_INIT_SP_ADDR 0x30020000 +#define CONFIG_SYS_TEXT_BASE 0x08000000 + +/* + * Configuration of the external SDRAM memory + */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_RAM_BASE 0xD0000000 +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_RAM_BASE +#define CONFIG_SYS_LOAD_ADDR 0xD0400000 +#define CONFIG_LOADADDR 0xD0400000 + +#define CONFIG_ENV_SIZE (8 << 10) + +#define CONFIG_SYS_ARCH_TIMER +#define CONFIG_SYS_HZ_CLOCK 250000000 + +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG + +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_MALLOC_LEN (1 * 1024 * 1024) + +#define CONFIG_BOOTARGS \ + "console=ttyS0,115200 earlyprintk consoleblank=0 ignore_loglevel" + +/* + * Command line configuration. + */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_AUTO_COMPLETE +#define CONFIG_CMDLINE_EDITING +#define CONFIG_CMD_CACHE +#define CONFIG_BOARD_LATE_INIT + +#endif /* __CONFIG_H */
participants (6)
Patrice CHOTARD
Vikas MANOCHA
Vikas Manocha
