[PATCH] arm: kirkwood: nas220: Add DM Ethernet, SATA, GPIO
Bring the NAS220 board up to current standards. This is basically an adaptation of the changes Tony Dinh implemented for the Dockstar board.
- Add CONFIG_DM_ETH and associated configs - Remove CONFIG_CMD_IDE, add CONFIG_CMD_SATA and associated configs - Add CONFIG_CMD_GPIO to have a handy way to to respond to button presses during boot phase - Some minor changes to the comments - Tested with my NAS220 hardware: ETH/USB/SATA/GPIO ok
- Note: I am collecting various information and patches for the family of Blackarmor NAS boards at https://github.com/hn/seagate-blackarmor-nas
Signed-off-by: Hajo Noerenberg hajo-uboot@noerenberg.de --- board/Seagate/nas220/nas220.c | 67 +++++++++++------------------------ configs/nas220_defconfig | 13 ++++++- include/configs/nas220.h | 39 ++++++++------------ 3 files changed, 48 insertions(+), 71 deletions(-)
diff --git a/board/Seagate/nas220/nas220.c b/board/Seagate/nas220/nas220.c index cd2bbdad1c..7b159d113e 100644 --- a/board/Seagate/nas220/nas220.c +++ b/board/Seagate/nas220/nas220.c @@ -10,17 +10,21 @@
#include <common.h> #include <init.h> -#include <miiphy.h> -#include <net.h> -#include <asm/global_data.h> -#include <asm/mach-types.h> +#include <netdev.h> +#include <asm/arch/cpu.h> #include <asm/arch/soc.h> #include <asm/arch/mpp.h> -#include <asm/arch/cpu.h> -#include <asm/io.h> +#include <asm/global_data.h> +#include <asm/mach-types.h>
DECLARE_GLOBAL_DATA_PTR;
+/* blue power led, board power, sata0, sata1 */ +#define NAS220_GE_OE_LOW (~((1 << 12)|(1 << 14)|(1 << 24)|(1 << 28))) +#define NAS220_GE_OE_HIGH (~(0)) +#define NAS220_GE_OE_VAL_LOW ((1 << 12)|(1 << 14)|(1 << 24)|(1 << 28)) +#define NAS220_GE_OE_VAL_HIGH (0) + int board_early_init_f(void) { /* @@ -43,9 +47,9 @@ int board_early_init_f(void) MPP9_TW_SCK, MPP10_UART0_TXD, MPP11_UART0_RXD, - MPP12_GPO, + MPP12_GPO, /* blue power led */ MPP13_GPIO, - MPP14_GPIO, + MPP14_GPIO, /* board power */ MPP15_SATA0_ACTn, MPP16_SATA1_ACTn, MPP17_SATA0_PRESENTn, @@ -55,12 +59,12 @@ int board_early_init_f(void) MPP21_GPIO, MPP22_GPIO, MPP23_GPIO, - MPP24_GPIO, + MPP24_GPIO, /* sata0 power */ MPP25_GPIO, - MPP26_GPIO, + MPP26_GPIO, /* power button */ MPP27_GPIO, - MPP28_GPIO, - MPP29_GPIO, + MPP28_GPIO, /* sata1 power */ + MPP29_GPIO, /* reset button */ MPP30_GPIO, MPP31_GPIO, MPP32_GPIO, @@ -73,6 +77,11 @@ int board_early_init_f(void) return 0; }
+int board_eth_init(struct bd_info *bis) +{ + return cpu_eth_init(bis); +} + int board_init(void) { /* @@ -85,37 +94,3 @@ int board_init(void)
return 0; } - -#ifdef CONFIG_RESET_PHY_R -/* Configure and enable MV88E1116 PHY */ -void reset_phy(void) -{ - u16 reg; - u16 devadr; - char *name = "egiga0"; - - if (miiphy_set_current_dev(name)) - return; - - /* command to read PHY dev address */ - if (miiphy_read(name, 0xEE, 0xEE, (u16 *)&devadr)) { - printf("Err..%s could not read PHY dev address\n", __func__); - return; - } - - /* - * Enable RGMII delay on Tx and Rx for CPU port - * Ref: sec 4.7.2 of chip datasheet - */ - miiphy_write(name, devadr, MV88E1116_PGADR_REG, 2); - miiphy_read(name, devadr, MV88E1116_MAC_CTRL_REG, ®); - reg |= (MV88E1116_RGMII_RXTM_CTRL | MV88E1116_RGMII_TXTM_CTRL); - miiphy_write(name, devadr, MV88E1116_MAC_CTRL_REG, reg); - miiphy_write(name, devadr, MV88E1116_PGADR_REG, 0); - - /* reset the phy */ - miiphy_reset(name, devadr); - - printf("88E1116 Initialized on %s\n", name); -} -#endif /* CONFIG_RESET_PHY_R */ diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index f6a1dcbee0..ab6f47d3a9 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -20,7 +20,7 @@ CONFIG_USE_PREBOOT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="nas220> " # CONFIG_CMD_FLASH is not set -CONFIG_CMD_IDE=y +CONFIG_CMD_SATA=y CONFIG_CMD_NAND=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set @@ -32,6 +32,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_CMD_MTDPARTS=y +CONFIG_MTDPARTS_DEFAULT="mtdparts=orion_nand:0xa0000@0x0(uboot),0x010000@0xa0000(env),0x500000@0xc0000(uimage),0x1a40000@0x5c0000(rootfs)" CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y @@ -47,11 +48,21 @@ CONFIG_SYS_ATA_DATA_OFFSET=0x100 CONFIG_SYS_ATA_REG_OFFSET=0x100 CONFIG_SYS_ATA_ALT_OFFSET=0x100 CONFIG_KIRKWOOD_GPIO=y +CONFIG_MVEBU_GPIO=y +CONFIG_GPIO_EXTRA_HEADER=y +CONFIG_DM_GPIO=y +CONFIG_CMD_GPIO=y +CONFIG_GPIO=y +CONFIG_DM_GPIO_LOOKUP_LABEL=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_PHY_MARVELL=y +CONFIG_DM_ETH=y CONFIG_MVGBE=y CONFIG_MII=y +CONFIG_SATA_MV=y +CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_DM_RTC=y CONFIG_RTC_MV=y CONFIG_SYS_NS16550=y diff --git a/include/configs/nas220.h b/include/configs/nas220.h index 815f81f649..27b8484c7b 100644 --- a/include/configs/nas220.h +++ b/include/configs/nas220.h @@ -11,50 +11,41 @@ #ifndef _CONFIG_NAS220_H #define _CONFIG_NAS220_H
-/* power-on led, regulator, sata0, sata1 */ -#define NAS220_GE_OE_VAL_LOW ((1 << 12)|(1 << 14)|(1 << 24)|(1 << 28)) -#define NAS220_GE_OE_VAL_HIGH (0) -#define NAS220_GE_OE_LOW (~((1 << 12)|(1 << 14)|(1 << 24)|(1 << 28))) -#define NAS220_GE_OE_HIGH (~(0)) - -/* PHY related */ -#define MV88E1116_LED_FCTRL_REG 10 -#define MV88E1116_CPRSP_CR3_REG 21 -#define MV88E1116_MAC_CTRL_REG 21 -#define MV88E1116_PGADR_REG 22 -#define MV88E1116_RGMII_TXTM_CTRL (1 << 4) -#define MV88E1116_RGMII_RXTM_CTRL (1 << 5) - -#include "mv-common.h" - /* - * Environment variables configurations + * mv-common.h should be defined after CMD configs since it used them + * to enable certain macros */
+#include "mv-common.h" + /* * Default environment variables */
#define CONFIG_EXTRA_ENV_SETTINGS \ "bootargs=console=ttyS0,115200\0" \ - "mtdparts=mtdparts=orion_nand:0xa0000@0x0(uboot),"\ - "0x010000@0xa0000(env),"\ - "0x500000@0xc0000(uimage),"\ - "0x1a40000@0x5c0000(rootfs)\0" \ "mtdids=nand0=orion_nand\0"\ + "mtdparts=" CONFIG_MTDPARTS_DEFAULT \ "autostart=no\0"\ "autoload=no\0"
/* * Ethernet Driver configuration */ -#ifdef CONFIG_CMD_NET +#ifdef CONFIG_MVGBE #define CONFIG_MVGBE_PORTS {1, 0} /* enable port 0 only */ #define CONFIG_PHY_BASE_ADR 8 -#endif /* CONFIG_CMD_NET */ +#ifdef CONFIG_RESET_PHY_R +#undef CONFIG_RESET_PHY_R /* remove legacy reset_phy() */ +#endif +#endif /* CONFIG_MVGBE */
/* - * EFI partition + * SATA driver configuration */ +#ifdef CONFIG_SATA +#define CONFIG_SYS_SATA_MAX_DEVICE 2 +#define CONFIG_LBA48 +#endif /* CONFIG_SATA */
#endif /* _CONFIG_NAS220_H */
Hi Hajo,
I've added Stefan to the reviewers. And please see a couple of minor comments below.
On Thu, Feb 24, 2022 at 5:48 AM Hajo Noerenberg hajo-uboot@noerenberg.de wrote:
We can use BIT macro for better style here (e.g. BIT(12)).
MPP12_GPO,
MPP14_GPIO,
MPP24_GPIO,
MPP26_GPIO,
MPP28_GPIO,
MPP29_GPIO,
u16 reg;
u16 devadr;
return;
return;
/* reset the phy */
- Environment variables configurations
- mv-common.h should be defined after CMD configs since it used them
- to enable certain macros
- Default environment variables
- Ethernet Driver configuration
- EFI partition
- SATA driver configuration
No need for #ifdef CONFIG_SATA. This box is a 2-SATA-bay NAS so CONFIG_SATA is probably not ever going to be deselected.
Other than that,
Reviewed-by: Tony Dinh mibodhi@gmail.com
Thanks, Tony
2.20.1
On 02/25/2022 00:19 Tony Dinh wrote:
Hi Hajo,
Patch v2: - implemented the changes suggested by Tony Dinh - Remove CONFIG_SYS_SATA_MAX_DEVICE from nas220.h, got there by mistake - add DTS file to MAINTAINERS
- Thanks, Tony
Signed-off-by: Hajo Noerenberg hajo-uboot@noerenberg.de --- board/Seagate/nas220/MAINTAINERS | 1 + board/Seagate/nas220/nas220.c | 68 +++++++++++--------------------- configs/nas220_defconfig | 13 +++++- include/configs/nas220.h | 36 ++++++----------- 4 files changed, 47 insertions(+), 71 deletions(-)
diff --git a/board/Seagate/nas220/MAINTAINERS b/board/Seagate/nas220/MAINTAINERS index f2df7ea64f..6033f93cf4 100644 --- a/board/Seagate/nas220/MAINTAINERS +++ b/board/Seagate/nas220/MAINTAINERS @@ -4,3 +4,4 @@ S: Maintained F: board/Seagate/nas220/ F: include/configs/nas220.h F: configs/nas220_defconfig +F: arch/arm/dts/kirkwood-blackarmor-nas220.dts diff --git a/board/Seagate/nas220/nas220.c b/board/Seagate/nas220/nas220.c index cd2bbdad1c..fdbf321ff9 100644 --- a/board/Seagate/nas220/nas220.c +++ b/board/Seagate/nas220/nas220.c @@ -10,17 +10,22 @@
#include <common.h> #include <init.h> -#include <miiphy.h> -#include <net.h> -#include <asm/global_data.h> -#include <asm/mach-types.h> +#include <netdev.h> +#include <asm/arch/cpu.h> #include <asm/arch/soc.h> #include <asm/arch/mpp.h> -#include <asm/arch/cpu.h> -#include <asm/io.h> +#include <asm/global_data.h> +#include <asm/mach-types.h> +#include <linux/bitops.h>
+/* blue power led, board power, sata0, sata1 */ +#define NAS220_GE_OE_LOW (~(BIT(12) | BIT(14) | BIT(24) | BIT(28))) +#define NAS220_GE_OE_HIGH (~(0)) +#define NAS220_GE_OE_VAL_LOW (BIT(12) | BIT(14) | BIT(24) | BIT(28)) +#define NAS220_GE_OE_VAL_HIGH (0) + int board_early_init_f(void) { /* @@ -43,9 +48,9 @@ int board_early_init_f(void) MPP9_TW_SCK, MPP10_UART0_TXD, MPP11_UART0_RXD, - MPP12_GPO, + MPP12_GPO, /* blue power led */ MPP13_GPIO, - MPP14_GPIO, + MPP14_GPIO, /* board power */ MPP15_SATA0_ACTn, MPP16_SATA1_ACTn, MPP17_SATA0_PRESENTn, @@ -55,12 +60,12 @@ int board_early_init_f(void) MPP21_GPIO, MPP22_GPIO, MPP23_GPIO, - MPP24_GPIO, + MPP24_GPIO, /* sata0 power */ MPP25_GPIO, - MPP26_GPIO, + MPP26_GPIO, /* power button */ MPP27_GPIO, - MPP28_GPIO, - MPP29_GPIO, + MPP28_GPIO, /* sata1 power */ + MPP29_GPIO, /* reset button */ MPP30_GPIO, MPP31_GPIO, MPP32_GPIO, @@ -73,6 +78,11 @@ int board_early_init_f(void) return 0; }
+int board_eth_init(struct bd_info *bis) +{ + return cpu_eth_init(bis); +} + int board_init(void) { /* @@ -85,37 +95,3 @@ int board_init(void)
return 0; } - -#ifdef CONFIG_RESET_PHY_R -/* Configure and enable MV88E1116 PHY */ -void reset_phy(void) -{ - u16 reg; - u16 devadr; - char *name = "egiga0"; - - if (miiphy_set_current_dev(name)) - return; - - /* command to read PHY dev address */ - if (miiphy_read(name, 0xEE, 0xEE, (u16 *)&devadr)) { - printf("Err..%s could not read PHY dev address\n", __func__); - return; - } - - /* - * Enable RGMII delay on Tx and Rx for CPU port - * Ref: sec 4.7.2 of chip datasheet - */ - miiphy_write(name, devadr, MV88E1116_PGADR_REG, 2); - miiphy_read(name, devadr, MV88E1116_MAC_CTRL_REG, ®); - reg |= (MV88E1116_RGMII_RXTM_CTRL | MV88E1116_RGMII_TXTM_CTRL); - miiphy_write(name, devadr, MV88E1116_MAC_CTRL_REG, reg); - miiphy_write(name, devadr, MV88E1116_PGADR_REG, 0); - - /* reset the phy */ - miiphy_reset(name, devadr); - - printf("88E1116 Initialized on %s\n", name); -} -#endif /* CONFIG_RESET_PHY_R */ diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index f6a1dcbee0..ab6f47d3a9 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -20,7 +20,7 @@ CONFIG_USE_PREBOOT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="nas220> " # CONFIG_CMD_FLASH is not set -CONFIG_CMD_IDE=y +CONFIG_CMD_SATA=y CONFIG_CMD_NAND=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set @@ -32,6 +32,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_CMD_MTDPARTS=y +CONFIG_MTDPARTS_DEFAULT="mtdparts=orion_nand:0xa0000@0x0(uboot),0x010000@0xa0000(env),0x500000@0xc0000(uimage),0x1a40000@0x5c0000(rootfs)" CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y @@ -47,11 +48,21 @@ CONFIG_SYS_ATA_DATA_OFFSET=0x100 CONFIG_SYS_ATA_REG_OFFSET=0x100 CONFIG_SYS_ATA_ALT_OFFSET=0x100 CONFIG_KIRKWOOD_GPIO=y +CONFIG_MVEBU_GPIO=y +CONFIG_GPIO_EXTRA_HEADER=y +CONFIG_DM_GPIO=y +CONFIG_CMD_GPIO=y +CONFIG_GPIO=y +CONFIG_DM_GPIO_LOOKUP_LABEL=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_PHY_MARVELL=y +CONFIG_DM_ETH=y CONFIG_MVGBE=y CONFIG_MII=y +CONFIG_SATA_MV=y +CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_DM_RTC=y CONFIG_RTC_MV=y CONFIG_SYS_NS16550=y diff --git a/include/configs/nas220.h b/include/configs/nas220.h index 815f81f649..4eb58d783d 100644 --- a/include/configs/nas220.h +++ b/include/configs/nas220.h @@ -11,50 +11,38 @@ #ifndef _CONFIG_NAS220_H #define _CONFIG_NAS220_H
/* - * EFI partition + * SATA driver configuration */ +#define CONFIG_LBA48
Hi Hajo,
Hi Hajo,
Patch v2:
Thanks, Tony
Please send the next patch version as a new mail instead of replying to the old thread.
Looks good in general. Please find some more comments below.
- int board_early_init_f(void) { /*
MPP12_GPO,
MPP13_GPIO,MPP12_GPO, /* blue power led */
MPP14_GPIO,
MPP15_SATA0_ACTn, MPP16_SATA1_ACTn, MPP17_SATA0_PRESENTn,MPP14_GPIO, /* board power */
MPP24_GPIO,
MPP25_GPIO,MPP24_GPIO, /* sata0 power */
MPP26_GPIO,
MPP27_GPIO,MPP26_GPIO, /* power button */
MPP28_GPIO,
MPP29_GPIO,
MPP30_GPIO, MPP31_GPIO, MPP32_GPIO,MPP29_GPIO, /* reset button */
- return cpu_eth_init(bis);
- int board_init(void) { /*
return 0; }
- u16 reg;
- u16 devadr;
return;
return;
Is CONFIG_MVGBE ever un-defined? If not, please remove the #ifdef here.
Thanks, Stefan
- EFI partition
Viele Grüße, Stefan Roese
Hajo Noerenberg
Stefan Roese
Tony Dinh
