[U-Boot] [PATCH 0/5] am335x_evm: Misc environment enhancements
Hey all,
The bulk of this series adds environemnt variables to better support working with NAND, SPI or ethernet. In the case of SPI we also add a spiboot target which will change environment to be looked for on SPI rather than NAND. This also documents how to use the network SPL options.
* Added support to the default environment variables for NAND boot. * Add nandboot to the default bootcmd.
Signed-off-by: Chase Maupin Chase.Maupin@ti.com Signed-off-by: Tom Rini trini@ti.com --- include/configs/am335x_evm.h | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 72459d8..8e01574 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -60,12 +60,20 @@ "mmcdev=0\0" \ "mmcroot=/dev/mmcblk0p2 ro\0" \ "mmcrootfstype=ext4 rootwait\0" \ + "nandroot=ubi0:rootfs rw ubi.mtd=7,2048\0" \ + "nandrootfstype=ubifs rootwait=1\0" \ + "nandsrcaddr=0x280000\0" \ + "nandimgsize=0x500000\0" \ "ramroot=/dev/ram0 rw ramdisk_size=65536 initrd=${rdaddr},64M\0" \ "ramrootfstype=ext2\0" \ "mmcargs=setenv bootargs console=${console} " \ "${optargs} " \ "root=${mmcroot} " \ "rootfstype=${mmcrootfstype}\0" \ + "nandargs=setenv bootargs console=${console} " \ + "${optargs} " \ + "root=${nandroot} " \ + "rootfstype=${nandrootfstype}\0" \ "bootenv=uEnv.txt\0" \ "loadbootenv=fatload mmc ${mmcdev} ${loadaddr} ${bootenv}\0" \ "importbootenv=echo Importing environment from mmc ...; " \ @@ -80,6 +88,10 @@ "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ "bootm ${loadaddr}\0" \ + "nandboot=echo Booting from nand ...; " \ + "run nandargs; " \ + "nand read ${loadaddr} ${nandsrcaddr} ${nandimgsize}; " \ + "bootm ${loadaddr}\0" \ "ramboot=echo Booting from ramdisk ...; " \ "run ramargs; " \ "bootm ${loadaddr}\0" \ @@ -105,6 +117,8 @@ "if run loaduimage; then " \ "run mmcboot;" \ "fi;" \ + "else " \ + "run nandboot;" \ "fi;" \
/* Clock Defines */
* Added variables to support SPI booting * Note that the first 512KiB are reserved for 4 copies of SPL.
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 8e01574..d9e8264 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -74,6 +74,15 @@ "${optargs} " \ "root=${nandroot} " \ "rootfstype=${nandrootfstype}\0" \ + "spiroot=/dev/mtdblock4 rw\0" \ + "spirootfstype=jffs2\0" \ + "spisrcaddr=0xe0000\0" \ + "spiimgsize=0x362000\0" \ + "spibusno=0\0" \ + "spiargs=setenv bootargs console=${console} " \ + "${optargs} " \ + "root=${spiroot} " \ + "rootfstype=${spirootfstype}\0" \ "bootenv=uEnv.txt\0" \ "loadbootenv=fatload mmc ${mmcdev} ${loadaddr} ${bootenv}\0" \ "importbootenv=echo Importing environment from mmc ...; " \ @@ -92,6 +101,11 @@ "run nandargs; " \ "nand read ${loadaddr} ${nandsrcaddr} ${nandimgsize}; " \ "bootm ${loadaddr}\0" \ + "spiboot=echo Booting from spi ...; " \ + "run spiargs; " \ + "sf probe ${spibusno}:0; " \ + "sf read ${loadaddr} ${spisrcaddr} ${spiimgsize}; " \ + "bootm ${loadaddr}\0" \ "ramboot=echo Booting from ramdisk ...; " \ "run ramargs; " \ "bootm ${loadaddr}\0" \
* Add environment variables to support network booting
Signed-off-by: Chase Maupin Chase.Maupin@ti.com Signed-off-by: Tom Rini trini@ti.com --- include/configs/am335x_evm.h | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index d9e8264..61607a5 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -64,6 +64,10 @@ "nandrootfstype=ubifs rootwait=1\0" \ "nandsrcaddr=0x280000\0" \ "nandimgsize=0x500000\0" \ + "rootpath=/export/rootfs\0" \ + "nfsopts=nolock\0" \ + "static_ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}" \ + "::off\0" \ "ramroot=/dev/ram0 rw ramdisk_size=65536 initrd=${rdaddr},64M\0" \ "ramrootfstype=ext2\0" \ "mmcargs=setenv bootargs console=${console} " \ @@ -83,6 +87,11 @@ "${optargs} " \ "root=${spiroot} " \ "rootfstype=${spirootfstype}\0" \ + "netargs=setenv bootargs console=${console} " \ + "${optargs} " \ + "root=/dev/nfs " \ + "nfsroot=${serverip}:${rootpath},${nfsopts} rw " \ + "ip=dhcp\0" \ "bootenv=uEnv.txt\0" \ "loadbootenv=fatload mmc ${mmcdev} ${loadaddr} ${bootenv}\0" \ "importbootenv=echo Importing environment from mmc ...; " \ @@ -106,6 +115,12 @@ "sf probe ${spibusno}:0; " \ "sf read ${loadaddr} ${spisrcaddr} ${spiimgsize}; " \ "bootm ${loadaddr}\0" \ + "netboot=echo Booting from network ...; " \ + "setenv autoload no; " \ + "dhcp; " \ + "tftp ${loadaddr} ${bootfile}; " \ + "run netargs; " \ + "bootm ${loadaddr}\0" \ "ramboot=echo Booting from ramdisk ...; " \ "run ramargs; " \ "bootm ${loadaddr}\0" \
Added README file with the description of required options and host configuration to use network SPL with am335x targets. Briefly discuss how to use this configuration to program empty boards.
Signed-off-by: Ilya Yanok ilya.yanok@cogentembedded.com Signed-off-by: Tom Rini trini@ti.com --- doc/SPL/README.am335x-network | 93 +++++++++++++++++++++++++++++++++++++++++ 1 file changed, 93 insertions(+) create mode 100644 doc/SPL/README.am335x-network
diff --git a/doc/SPL/README.am335x-network b/doc/SPL/README.am335x-network new file mode 100644 index 0000000..77f5d4d --- /dev/null +++ b/doc/SPL/README.am335x-network @@ -0,0 +1,93 @@ +USING AM335x NETBOOT FEATURE + + Some boards (like TI AM335x based ones) have quite big on-chip RAM and +have support for booting via network in ROM. The following describes +how to setup network booting and then optionally use this support to flash +NAND and bricked (empty) board with only a network cable. + + I. Building the required images + 1. You have to enable generic SPL configuration options (see +docs/README.SPL) as well as CONFIG_SPL_NET_SUPPORT, +CONFIG_ETH_SUPPORT, CONFIG_SPL_LIBGENERIC_SUPPORT and +CONFIG_SPL_LIBCOMMON_SUPPORT in your board configuration file to build +SPL with support for booting over the network. Also you have to enable +the driver for the NIC used and CONFIG_SPL_BOARD_INIT option if your +board needs some board-specific initialization (TI AM335x EVM does). +If you want SPL to use some Vendor Class Identifier (VCI) you can set +one with CONFIG_SPL_NET_VCI_STRING option. am335x_evm configuration +comes with support for network booting preconfigured. + 2. Define CONFIG_BOOTCOMMAND for your board to load and run debrick +script after boot: +#define CONFIG_BOOTCOMMAND \ + "setenv autoload no; " \ + "bootp; " \ + "if tftp 80000000 debrick.scr; then " \ + "source 80000000; " \ + "fi" +(Or create additional board configuration with such option). + 3. Build U-Boot as usual + $ make <your_board_name> + You will need u-boot.img and spl/u-boot.bin images to perform +network boot. Copy them to u-boot-restore.img and +u-boot-spl-restore.bin respectively to distinguish this version +(with automatic restore running) from the main one. + + II. Host configuration. + 1. Setup DHCP server (recommended server is ISC DHCPd). + - Install DHCP server and setup it to listen on the interface you +chose to connect to the board (usually configured in +/etc/default/dhcpd or /etc/default/isc-dhcp-server). Make sure there +are no other active DHCP servers in the same network segment. + - Edit your dhcpd.conf and subnet declaration matching the address +on the interface. Specify the range of assigned addresses and bootfile +to use. IMPORTANT! Both RBL and SPL use the image filename provided +in the BOOTP reply but obviously they need different images (RBL needs +raw SPL image -- u-boot-spl-restore.bin while SPL needs main U-Boot +image -- u-boot-restore.img). So you have to configure DHCP server to +provide different image filenames to RBL and SPL (and possibly another +one to main U-Boot). This can be done by checking Vendor Class +Identifier (VCI) set by BOOTP client (RBL sets VCI to "DM814x ROM v1.0" +and you can set VCI used by SPL with CONFIG_SPL_NET_VCI_STRING option, +see above). + - If you plan to use TFTP server on another machine you have to set +server-name option to point to it. + - Here is sample configuration for ISC DHCPd, assuming the interface +used to connect to the board is eth0, and it has address 192.168.8.1: + +subnet 192.168.8.0 netmask 255.255.255.0 { + range dynamic-bootp 192.168.8.100 192.168.8.199; + + if substring (option vendor-class-identifier, 0, 10) = "DM814x ROM" { + filename "u-boot-spl-restore.bin"; + } elsif substring (option vendor-class-identifier, 0, 17) = "AM335x U-Boot SPL" { + filename "u-boot-restore.img"; + } else { + filename "uImage"; + } +} + + 2. Setup TFTP server. + Install TFTP server and put image files to it's root directory +(likely /tftpboot or /var/lib/tftpboot or /srv/tftp). You will need +u-boot.img and spl/u-boot-spl-bin files from U-Boot build directory. + + III. Reflashing (debricking) the board. + 1. Write debrick script. You will need to write a script that will +be executed after network boot to perform actual rescue actions. You +can use usual U-Boot commands from this script: tftp to load additional +files, nand erase/nand write to erase/write the NAND flash. + + 2. Create script image from your script. From U-Boot build directory: + +$ ./tools/mkimage -A arm -O U-Boot -C none -T script -d <your script> debrick.scr + +This will create debrick.scr file with your script inside. + + 3. Copy debrick.scr to TFTP root directory. You also need to copy +there all the files your script tries to load via TFTP. Example script +loads u-boot.img and MLO. You have to create these files doing regular +(not restore_flash) build and copy them to tftpboot directory. + + 4. Boot the board from the network, U-Boot will load debrick script +and run it after boot. +
This target will move the environment into SPI flash and documents the expected layout. We correct the SPL define for where U-Boot is and remove an unused define.
Signed-off-by: Tom Rini trini@ti.com --- boards.cfg | 1 + include/configs/am335x_evm.h | 25 +++++++++++++++++++++++-- 2 files changed, 24 insertions(+), 2 deletions(-)
diff --git a/boards.cfg b/boards.cfg index 98f7a14..73195eb 100644 --- a/boards.cfg +++ b/boards.cfg @@ -231,6 +231,7 @@ integratorap_cm946es arm arm946es integrator armltd integratorcp_cm946es arm arm946es integrator armltd - integratorcp:CM946ES ca9x4_ct_vxp arm armv7 vexpress armltd am335x_evm arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1 +am335x_evm_spiboot arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,SPI_BOOT am335x_evm_uart1 arm armv7 am335x ti am33xx am335x_evm:SERIAL2,CONS_INDEX=2 am335x_evm_uart2 arm armv7 am335x ti am33xx am335x_evm:SERIAL3,CONS_INDEX=3 am335x_evm_uart3 arm armv7 am335x ti am33xx am335x_evm:SERIAL4,CONS_INDEX=4 diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 61607a5..1316a44 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -279,8 +279,7 @@ #define CONFIG_SPL_SPI_LOAD #define CONFIG_SPL_SPI_BUS 0 #define CONFIG_SPL_SPI_CS 0 -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 -#define CONFIG_SYS_SPI_U_BOOT_SIZE 0x40000 +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x80000 #define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/omap-common/u-boot-spl.lds"
#define CONFIG_SPL_BOARD_INIT @@ -356,6 +355,26 @@ #define CONFIG_USB_ETH_RNDIS #endif /* CONFIG_MUSB_GADGET */
+/* + * Default to using SPI for environment, etc. We have multiple copies + * of SPL as the ROM will check these locations. + * 0x0 - 0x20000 : First copy of SPL + * 0x20000 - 0x40000 : Second copy of SPL + * 0x40000 - 0x60000 : Third copy of SPL + * 0x60000 - 0x80000 : Fourth copy of SPL + * 0x80000 - 0xDF000 : U-Boot + * 0xDF000 - 0xE0000 : U-Boot Environment + * 0xE0000 - 0x442000 : Linux Kernel + * 0x442000 - 0x800000 : Userland + */ +#if defined(CONFIG_SPI_BOOT) +# undef CONFIG_ENV_IS_NOWHERE +# define CONFIG_ENV_IS_IN_SPI_FLASH +# define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED +# define CONFIG_ENV_OFFSET (892 << 10) /* 892 KiB in */ +# define CONFIG_ENV_SECT_SIZE (4 << 10) /* 4 KB sectors */ +#endif /* SPI support */ + /* Unsupported features */ #undef CONFIG_USE_IRQ
@@ -388,10 +407,12 @@ /* CS0 */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ +#if !defined(CONFIG_SPI_BOOT) #undef CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x260000 /* environment starts here */ #define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ #endif +#endif
#endif /* ! __CONFIG_AM335X_EVM_H */
On Fri, Feb 08, 2013 at 04:20:10PM -0500, Tom Rini wrote:
Hey all,
Applied to u-boot-ti/master.
