[U-Boot-Users] DTC 1.2.0-rc1 Tagged
Folks,
I've pushed out a freshly tagged DTC 1.2.0-rc1 to jdl.com.
Please feel free to test it!
Thanks, jdl
David Gibson (34): libfdt: Add and use a node iteration helper function. libfdt: Fix NOP handling bug in fdt_add_subnode_namelen() dtc: Fold comment handling test into testsuite libfdt: More tests of NOP handling behaviour libfdt: Trivial cleanup for CHECK_HEADER) libfdt: Remove no longer used code from fdt_node_offset_by_compatible() dtc: Fix error reporting in push_input_file() dtc: Implement checks for the format of node and property names dtc: Fix indentation of fixup_phandle_references dtc: Strip redundant "name" properties dtc: Test and fix conversion to/from old dtb versions dtc: Use for_each_marker_of_type in asm_emit_data() dtc: Make -I dtb mode use fill_fullpaths() dtc: Make eval_literal() static dtc: Assorted improvements to test harness dtc: Testcases for input handling dtc: Make dtc_open_file() die() if unable to open requested file dtc: Remove ugly include stack abuse dtc: Abolish asize field of struct data dtc: Add some documentation for the dts formta dtc: Cleanup \nnn and \xNN string escape handling dtc: Change exit code for usage message dtc: Simplify error handling for unparseable input dtc: Clean up included Makefile fragments dtc: Trivial formatting fixes dtc: Make dt_from_blob() open its own input file, like the other input formats dtc: Rework handling of boot_cpuid_phys dtc: Add program to convert dts files from v0 to v1 dtc: Remove reference to dead Makefile variables libfdt: Several cleanups to parameter checking dtc: Remove some small bashisms from test scripts dtc: Fix some printf() format warnings when compiling 64-bit dtc: Add a testcase for 'reg' or 'ranges' in / dtc: Add support for binary includes.
Jon Loeliger (1): Tag Version 1.2.0-rc1
Jon Loeliger
