[U-Boot] [PATCH 18/22] ppc4xx: cleanup CPCI4052 board
- remove some obsolete code - switch to generic board
Signed-off-by: Matthias Fuchs matthias.fuchs@esd.eu --- board/esd/common/auto_update.c | 478 ------ board/esd/common/auto_update.h | 40 - board/esd/cpci405/Makefile | 2 +- board/esd/cpci405/cpci405.c | 276 +--- board/esd/cpci405/fpgadata_cpci405.c | 683 --------- board/esd/cpci405/fpgadata_cpci405ab.c | 2569 -------------------------------- include/configs/CPCI4052.h | 2 + 7 files changed, 4 insertions(+), 4046 deletions(-) delete mode 100644 board/esd/common/auto_update.c delete mode 100644 board/esd/common/auto_update.h delete mode 100644 board/esd/cpci405/fpgadata_cpci405.c delete mode 100644 board/esd/cpci405/fpgadata_cpci405ab.c
diff --git a/board/esd/common/auto_update.c b/board/esd/common/auto_update.c deleted file mode 100644 index f3f70ff..0000000 --- a/board/esd/common/auto_update.c +++ /dev/null @@ -1,478 +0,0 @@ -/* - * (C) Copyright 2003-2004 - * Gary Jennejohn, DENX Software Engineering, garyj@denx.de. - * Stefan Roese, esd gmbh germany, stefan.roese@esd-electronics.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> - -#include <command.h> -#include <image.h> -#include <asm/byteorder.h> -#include <fat.h> -#include <flash.h> -#include <part.h> - -#include "auto_update.h" - -#ifdef CONFIG_AUTO_UPDATE - -#if !defined(CONFIG_CMD_FAT) -#error "must define CONFIG_CMD_FAT" -#endif - -extern au_image_t au_image[]; -extern int N_AU_IMAGES; - -/* where to load files into memory */ -#define LOAD_ADDR ((unsigned char *)0x100000) -#define MAX_LOADSZ 0x1c00000 - -/* externals */ -long do_fat_read (const char *filename, void *buffer, - unsigned long maxsize, int dols); - -extern block_dev_desc_t ide_dev_desc[CONFIG_SYS_IDE_MAXDEVICE]; - -int au_check_cksum_valid(int i, long nbytes) -{ - image_header_t *hdr; - - hdr = (image_header_t *)LOAD_ADDR; -#if defined(CONFIG_FIT) - if (genimg_get_format ((void *)hdr) != IMAGE_FORMAT_LEGACY) { - puts ("Non legacy image format not supported\n"); - return -1; - } -#endif - - if ((au_image[i].type == AU_FIRMWARE) && - (au_image[i].size != image_get_data_size (hdr))) { - printf ("Image %s has wrong size\n", au_image[i].name); - return -1; - } - - if (nbytes != (image_get_image_size (hdr))) { - printf ("Image %s bad total SIZE\n", au_image[i].name); - return -1; - } - - /* check the data CRC */ - if (!image_check_dcrc (hdr)) { - printf ("Image %s bad data checksum\n", au_image[i].name); - return -1; - } - return 0; -} - -int au_check_header_valid(int i, long nbytes) -{ - image_header_t *hdr; - - hdr = (image_header_t *)LOAD_ADDR; -#if defined(CONFIG_FIT) - if (genimg_get_format ((void *)hdr) != IMAGE_FORMAT_LEGACY) { - puts ("Non legacy image format not supported\n"); - return -1; - } -#endif - - /* check the easy ones first */ - if (nbytes < image_get_header_size ()) { - printf ("Image %s bad header SIZE\n", au_image[i].name); - return -1; - } - if (!image_check_magic (hdr) || !image_check_arch (hdr, IH_ARCH_PPC)) { - printf ("Image %s bad MAGIC or ARCH\n", au_image[i].name); - return -1; - } - if (!image_check_hcrc (hdr)) { - printf ("Image %s bad header checksum\n", au_image[i].name); - return -1; - } - - /* check the type - could do this all in one gigantic if() */ - if (((au_image[i].type & AU_TYPEMASK) == AU_FIRMWARE) && - !image_check_type (hdr, IH_TYPE_FIRMWARE)) { - printf ("Image %s wrong type\n", au_image[i].name); - return -1; - } - if (((au_image[i].type & AU_TYPEMASK) == AU_SCRIPT) && - !image_check_type (hdr, IH_TYPE_SCRIPT)) { - printf ("Image %s wrong type\n", au_image[i].name); - return -1; - } - - return 0; -} - -int au_do_update(int i, long sz) -{ - image_header_t *hdr; - char *addr; - long start, end; - int off, rc; - uint nbytes; - int k; - - hdr = (image_header_t *)LOAD_ADDR; -#if defined(CONFIG_FIT) - if (genimg_get_format ((void *)hdr) != IMAGE_FORMAT_LEGACY) { - puts ("Non legacy image format not supported\n"); - return -1; - } -#endif - - switch (au_image[i].type & AU_TYPEMASK) { - case AU_SCRIPT: - printf("Executing script %s\n", au_image[i].name); - - /* execute a script */ - if (image_check_type (hdr, IH_TYPE_SCRIPT)) { - addr = (char *)((char *)hdr + image_get_header_size ()); - /* stick a NULL at the end of the script, otherwise */ - /* parse_string_outer() runs off the end. */ - addr[image_get_data_size (hdr)] = 0; - addr += 8; - - /* - * Replace cr/lf with ; - */ - k = 0; - while (addr[k] != 0) { - if ((addr[k] == 10) || (addr[k] == 13)) { - addr[k] = ';'; - } - k++; - } - - run_command(addr, 0); - return 0; - } - - break; - - case AU_FIRMWARE: - case AU_NOR: - case AU_NAND: - start = au_image[i].start; - end = au_image[i].start + au_image[i].size - 1; - - /* - * do not update firmware when image is already in flash. - */ - if (au_image[i].type == AU_FIRMWARE) { - char *orig = (char*)start; - char *new = (char *)((char *)hdr + - image_get_header_size ()); - nbytes = image_get_data_size (hdr); - - while (--nbytes) { - if (*orig++ != *new++) { - break; - } - } - if (!nbytes) { - printf ("Skipping firmware update - " - "images are identical\n"); - break; - } - } - - /* unprotect the address range */ - if (((au_image[i].type & AU_FLAGMASK) == AU_PROTECT) || - (au_image[i].type == AU_FIRMWARE)) { - flash_sect_protect (0, start, end); - } - - /* - * erase the address range. - */ - if (au_image[i].type != AU_NAND) { - printf ("Updating NOR FLASH with image %s\n", - au_image[i].name); - debug ("flash_sect_erase(%lx, %lx);\n", start, end); - flash_sect_erase (start, end); - } - - udelay(10000); - - /* strip the header - except for the kernel and ramdisk */ - if (au_image[i].type != AU_FIRMWARE) { - addr = (char *)hdr; - off = image_get_header_size (); - nbytes = image_get_image_size (hdr); - } else { - addr = (char *)((char *)hdr + image_get_header_size ()); - off = 0; - nbytes = image_get_data_size (hdr); - } - - /* - * copy the data from RAM to FLASH - */ - if (au_image[i].type != AU_NAND) { - debug ("flash_write(%p, %lx, %x)\n", - addr, start, nbytes); - rc = flash_write ((char *)addr, start, - (nbytes + 1) & ~1); - } else { - rc = -1; - } - if (rc != 0) { - printf ("Flashing failed due to error %d\n", rc); - return -1; - } - - /* - * check the dcrc of the copy - */ - if (au_image[i].type != AU_NAND) { - rc = crc32 (0, (uchar *)(start + off), - image_get_data_size (hdr)); - } - if (rc != image_get_dcrc (hdr)) { - printf ("Image %s Bad Data Checksum After COPY\n", - au_image[i].name); - return -1; - } - - /* protect the address range */ - /* this assumes that ONLY the firmware is protected! */ - if (((au_image[i].type & AU_FLAGMASK) == AU_PROTECT) || - (au_image[i].type == AU_FIRMWARE)) { - flash_sect_protect (1, start, end); - } - - break; - - default: - printf("Wrong image type selected!\n"); - } - - return 0; -} - -static void process_macros (const char *input, char *output) -{ - char c, prev; - const char *varname_start = NULL; - int inputcnt = strlen (input); - int outputcnt = CONFIG_SYS_CBSIZE; - int state = 0; /* 0 = waiting for '$' */ - /* 1 = waiting for '(' or '{' */ - /* 2 = waiting for ')' or '}' */ - /* 3 = waiting for ''' */ -#ifdef DEBUG_PARSER - char *output_start = output; - - printf ("[PROCESS_MACROS] INPUT len %d: "%s"\n", - strlen(input), input); -#endif - - prev = '\0'; /* previous character */ - - while (inputcnt && outputcnt) { - c = *input++; - inputcnt--; - - if (state != 3) { - /* remove one level of escape characters */ - if ((c == '\') && (prev != '\')) { - if (inputcnt-- == 0) - break; - prev = c; - c = *input++; - } - } - - switch (state) { - case 0: /* Waiting for (unescaped) $ */ - if ((c == ''') && (prev != '\')) { - state = 3; - break; - } - if ((c == '$') && (prev != '\')) { - state++; - } else { - *(output++) = c; - outputcnt--; - } - break; - case 1: /* Waiting for ( */ - if (c == '(' || c == '{') { - state++; - varname_start = input; - } else { - state = 0; - *(output++) = '$'; - outputcnt--; - - if (outputcnt) { - *(output++) = c; - outputcnt--; - } - } - break; - case 2: /* Waiting for ) */ - if (c == ')' || c == '}') { - int i; - char envname[CONFIG_SYS_CBSIZE], *envval; - /* Varname # of chars */ - int envcnt = input - varname_start - 1; - - /* Get the varname */ - for (i = 0; i < envcnt; i++) { - envname[i] = varname_start[i]; - } - envname[i] = 0; - - /* Get its value */ - envval = getenv (envname); - - /* Copy into the line if it exists */ - if (envval != NULL) - while ((*envval) && outputcnt) { - *(output++) = *(envval++); - outputcnt--; - } - /* Look for another '$' */ - state = 0; - } - break; - case 3: /* Waiting for ' */ - if ((c == ''') && (prev != '\')) { - state = 0; - } else { - *(output++) = c; - outputcnt--; - } - break; - } - prev = c; - } - - if (outputcnt) - *output = 0; - -#ifdef DEBUG_PARSER - printf ("[PROCESS_MACROS] OUTPUT len %d: "%s"\n", - strlen (output_start), output_start); -#endif -} - -/* - * this is called from board_init() after the hardware has been set up - * and is usable. That seems like a good time to do this. - * Right now the return value is ignored. - */ -int do_auto_update(void) -{ - block_dev_desc_t *stor_dev = NULL; - long sz; - int i, res, old_ctrlc; - char buffer[32]; - char str[80]; - int n; - - if (ide_dev_desc[0].type != DEV_TYPE_UNKNOWN) { - stor_dev = get_dev ("ide", 0); - if (stor_dev == NULL) { - debug ("ide: unknown device\n"); - return -1; - } - } - - if (fat_register_device (stor_dev, 1) != 0) { - debug ("Unable to register ide disk 0:1\n"); - return -1; - } - - /* - * Check if magic file is present - */ - if ((n = do_fat_read (AU_MAGIC_FILE, buffer, - sizeof(buffer), LS_NO)) <= 0) { - debug ("No auto_update magic file (n=%d)\n", n); - return -1; - } - -#ifdef CONFIG_AUTO_UPDATE_SHOW - board_auto_update_show (1); -#endif - puts("\nAutoUpdate Disk detected! Trying to update system...\n"); - - /* make sure that we see CTRL-C and save the old state */ - old_ctrlc = disable_ctrlc (0); - - /* just loop thru all the possible files */ - for (i = 0; i < N_AU_IMAGES; i++) { - /* - * Try to expand the environment var in the fname - */ - process_macros (au_image[i].name, str); - strcpy (au_image[i].name, str); - - printf("Reading %s ...", au_image[i].name); - /* just read the header */ - sz = do_fat_read (au_image[i].name, LOAD_ADDR, - image_get_header_size (), LS_NO); - debug ("read %s sz %ld hdr %d\n", - au_image[i].name, sz, image_get_header_size ()); - if (sz <= 0 || sz < image_get_header_size ()) { - puts(" not found\n"); - continue; - } - if (au_check_header_valid (i, sz) < 0) { - puts(" header not valid\n"); - continue; - } - sz = do_fat_read (au_image[i].name, LOAD_ADDR, - MAX_LOADSZ, LS_NO); - debug ("read %s sz %ld hdr %d\n", - au_image[i].name, sz, image_get_header_size ()); - if (sz <= 0 || sz <= image_get_header_size ()) { - puts(" not found\n"); - continue; - } - if (au_check_cksum_valid (i, sz) < 0) { - puts(" checksum not valid\n"); - continue; - } - puts(" done\n"); - - do { - res = au_do_update (i, sz); - /* let the user break out of the loop */ - if (ctrlc() || had_ctrlc ()) { - clear_ctrlc (); - break; - } - } while (res < 0); - } - - /* restore the old state */ - disable_ctrlc (old_ctrlc); - - puts("AutoUpdate finished\n\n"); -#ifdef CONFIG_AUTO_UPDATE_SHOW - board_auto_update_show (0); -#endif - - return 0; -} - -int auto_update(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - do_auto_update(); - - return 0; -} -U_BOOT_CMD( - autoupd, 1, 1, auto_update, - "Automatically update images", - "" -); -#endif /* CONFIG_AUTO_UPDATE */ diff --git a/board/esd/common/auto_update.h b/board/esd/common/auto_update.h deleted file mode 100644 index be8f439..0000000 --- a/board/esd/common/auto_update.h +++ /dev/null @@ -1,40 +0,0 @@ -/* - * (C) Copyright 2004 - * Stefan Roese, esd gmbh germany, stefan.roese@esd-electronics.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef _AUTO_UPDATE_H_ -#define _AUTO_UPDATE_H_ - -#define MBR_MAGIC 0x07081967 -#define MBR_MAGIC_ADDR 0x100 /* offset 0x100 should be free space */ - -#define AU_MAGIC_FILE "__auto_update" - -#define AU_TYPEMASK 0x000000ff -#define AU_FLAGMASK 0xffff0000 - -#define AU_PROTECT 0x80000000 - -#define AU_SCRIPT 0x01 -#define AU_FIRMWARE (0x02 | AU_PROTECT) -#define AU_NOR 0x03 -#define AU_NAND 0x04 - -struct au_image_s { - char name[80]; - ulong start; - ulong size; - ulong type; -}; - -typedef struct au_image_s au_image_t; - -int do_auto_update(void); -#ifdef CONFIG_AUTO_UPDATE_SHOW -void board_auto_update_show(int au_active); -#endif - -#endif /* #ifndef _AUTO_UPDATE_H_ */ diff --git a/board/esd/cpci405/Makefile b/board/esd/cpci405/Makefile index b140571..7490b78 100644 --- a/board/esd/cpci405/Makefile +++ b/board/esd/cpci405/Makefile @@ -5,5 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y = cpci405.o flash.o ../common/misc.o ../common/auto_update.o +obj-y = cpci405.o flash.o ../common/misc.o obj-y += ../common/cmd_loadpci.o diff --git a/board/esd/cpci405/cpci405.c b/board/esd/cpci405/cpci405.c index e23ec55..bf5a4cb 100644 --- a/board/esd/cpci405/cpci405.c +++ b/board/esd/cpci405/cpci405.c @@ -24,13 +24,7 @@ extern void __ft_board_setup(void *blob, bd_t *bd); const unsigned char fpgadata[] = { #if defined(CONFIG_CPCI405_VER2) -# if defined(CONFIG_CPCI405AB) -# include "fpgadata_cpci405ab.c" -# else -# include "fpgadata_cpci4052.c" -# endif -#else -# include "fpgadata_cpci405.c" +# include "fpgadata_cpci4052.c" #endif };
@@ -38,37 +32,6 @@ const unsigned char fpgadata[] = * include common fpga code (for esd boards) */ #include "../common/fpga.c" -#include "../common/auto_update.h" - -#if defined(CONFIG_CPCI405AB) -au_image_t au_image[] = { - {"cpci405ab/preinst.img", 0, -1, AU_SCRIPT}, - {"cpci405ab/pImage", 0xffc00000, 0x000c0000, AU_NOR}, - {"cpci405ab/pImage.initrd", 0xffcc0000, 0x00300000, AU_NOR}, - {"cpci405ab/u-boot.img", 0xfffc0000, 0x00040000, AU_FIRMWARE}, - {"cpci405ab/postinst.img", 0, 0, AU_SCRIPT}, -}; -#else -#if defined(CONFIG_CPCI405_VER2) -au_image_t au_image[] = { - {"cpci4052/preinst.img", 0, -1, AU_SCRIPT}, - {"cpci4052/pImage", 0xffc00000, 0x000c0000, AU_NOR}, - {"cpci4052/pImage.initrd", 0xffcc0000, 0x00300000, AU_NOR}, - {"cpci4052/u-boot.img", 0xfffc0000, 0x00040000, AU_FIRMWARE}, - {"cpci4052/postinst.img", 0, 0, AU_SCRIPT}, -}; -#else -au_image_t au_image[] = { - {"cpci405/preinst.img", 0, -1, AU_SCRIPT}, - {"cpci405/pImage", 0xffc00000, 0x000c0000, AU_NOR}, - {"cpci405/pImage.initrd", 0xffcc0000, 0x00310000, AU_NOR}, - {"cpci405/u-boot.img", 0xfffd0000, 0x00030000, AU_FIRMWARE}, - {"cpci405/postinst.img", 0, 0, AU_SCRIPT}, -}; -#endif -#endif - -int N_AU_IMAGES = (sizeof(au_image) / sizeof(au_image[0]));
/* Prototypes */ int cpci405_version(void); @@ -530,240 +493,3 @@ int ft_board_setup(void *blob, bd_t *bd) return 0; } #endif /* defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) */ - -#if defined(CONFIG_CPCI405AB) -#define ONE_WIRE_CLEAR out_be16((void*)(CONFIG_SYS_FPGA_BASE_ADDR + \ - CONFIG_SYS_FPGA_MODE), \ - in_be16((void*)(CONFIG_SYS_FPGA_BASE_ADDR + \ - CONFIG_SYS_FPGA_MODE)) | \ - CONFIG_SYS_FPGA_MODE_1WIRE_DIR) - -#define ONE_WIRE_SET out_be16((void*)(CONFIG_SYS_FPGA_BASE_ADDR + \ - CONFIG_SYS_FPGA_MODE), \ - in_be16((void*)(CONFIG_SYS_FPGA_BASE_ADDR + \ - CONFIG_SYS_FPGA_MODE)) & \ - ~CONFIG_SYS_FPGA_MODE_1WIRE_DIR) - -#define ONE_WIRE_GET (in_be16((void*)(CONFIG_SYS_FPGA_BASE_ADDR + \ - CONFIG_SYS_FPGA_STATUS)) & \ - CONFIG_SYS_FPGA_MODE_1WIRE) - -/* - * Generate a 1-wire reset, return 1 if no presence detect was found, - * return 0 otherwise. - * (NOTE: Does not handle alarm presence from DS2404/DS1994) - */ -int OWTouchReset(void) -{ - int result; - - ONE_WIRE_CLEAR; - udelay(480); - ONE_WIRE_SET; - udelay(70); - - result = ONE_WIRE_GET; - - udelay(410); - return result; -} - -/* - * Send 1 a 1-wire write bit. - * Provide 10us recovery time. - */ -void OWWriteBit(int bit) -{ - if (bit) { - /* - * write '1' bit - */ - ONE_WIRE_CLEAR; - udelay(6); - ONE_WIRE_SET; - udelay(64); - } else { - /* - * write '0' bit - */ - ONE_WIRE_CLEAR; - udelay(60); - ONE_WIRE_SET; - udelay(10); - } -} - -/* - * Read a bit from the 1-wire bus and return it. - * Provide 10us recovery time. - */ -int OWReadBit(void) -{ - int result; - - ONE_WIRE_CLEAR; - udelay(6); - ONE_WIRE_SET; - udelay(9); - - result = ONE_WIRE_GET; - - udelay(55); - return result; -} - -void OWWriteByte(int data) -{ - int loop; - - for (loop = 0; loop < 8; loop++) { - OWWriteBit(data & 0x01); - data >>= 1; - } -} - -int OWReadByte(void) -{ - int loop, result = 0; - - for (loop = 0; loop < 8; loop++) { - result >>= 1; - if (OWReadBit()) - result |= 0x80; - } - - return result; -} - -int do_onewire(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - unsigned short val; - int result; - int i; - unsigned char ow_id[6]; - char str[32]; - - /* - * Clear 1-wire bit (open drain with pull-up) - */ - val = in_be16((void*)(CONFIG_SYS_FPGA_BASE_ADDR + - CONFIG_SYS_FPGA_MODE)); - val &= ~CONFIG_SYS_FPGA_MODE_1WIRE; /* clear 1-wire bit */ - out_be16((void*)(CONFIG_SYS_FPGA_BASE_ADDR + - CONFIG_SYS_FPGA_MODE), val); - - result = OWTouchReset(); - if (result != 0) - puts("No 1-wire device detected!\n"); - - OWWriteByte(0x33); /* send read rom command */ - OWReadByte(); /* skip family code ( == 0x01) */ - for (i = 0; i < 6; i++) - ow_id[i] = OWReadByte(); - OWReadByte(); /* read crc */ - - sprintf(str, "%02X%02X%02X%02X%02X%02X", - ow_id[0], ow_id[1], ow_id[2], ow_id[3], ow_id[4], ow_id[5]); - printf("Setting environment variable 'ow_id' to %s\n", str); - setenv("ow_id", str); - - return 0; -} -U_BOOT_CMD( - onewire, 1, 1, do_onewire, - "Read 1-write ID", - "" -); - -#define CONFIG_SYS_I2C_EEPROM_ADDR_2 0x51 /* EEPROM CAT24WC32 */ -#define CONFIG_ENV_SIZE_2 0x800 /* 2048 bytes may be used for env vars */ - -/* - * Write backplane ip-address... - */ -int do_get_bpip(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - char *buf; - ulong crc; - char str[32]; - char *ptr; - IPaddr_t ipaddr; - - buf = malloc(CONFIG_ENV_SIZE_2); - if (eeprom_read(CONFIG_SYS_I2C_EEPROM_ADDR_2, 0, - (uchar *)buf, CONFIG_ENV_SIZE_2)) - puts("\nError reading backplane EEPROM!\n"); - else { - crc = crc32(0, (uchar *)(buf+4), CONFIG_ENV_SIZE_2 - 4); - if (crc != *(ulong *)buf) { - printf("ERROR: crc mismatch %08lx %08lx\n", - crc, *(ulong *)buf); - return -1; - } - - /* - * Find bp_ip - */ - ptr = strstr(buf+4, "bp_ip="); - if (ptr == NULL) { - printf("ERROR: bp_ip not found!\n"); - return -1; - } - ptr += 6; - ipaddr = string_to_ip(ptr); - - /* - * Update whole ip-addr - */ - sprintf(str, "%pI4", &ipaddr); - setenv("ipaddr", str); - printf("Updated ip_addr from bp_eeprom to %s!\n", str); - } - - free(buf); - - return 0; -} -U_BOOT_CMD( - getbpip, 1, 1, do_get_bpip, - "Update IP-Address with Backplane IP-Address", - "" -); - -/* - * Set and print backplane ip... - */ -int do_set_bpip(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - char *buf; - char str[32]; - ulong crc; - - if (argc < 2) { - puts("ERROR!\n"); - return -1; - } - - printf("Setting bp_ip to %s\n", argv[1]); - buf = malloc(CONFIG_ENV_SIZE_2); - memset(buf, 0, CONFIG_ENV_SIZE_2); - sprintf(str, "bp_ip=%s", argv[1]); - strcpy(buf+4, str); - crc = crc32(0, (uchar *)(buf+4), CONFIG_ENV_SIZE_2 - 4); - *(ulong *)buf = crc; - - if (eeprom_write(CONFIG_SYS_I2C_EEPROM_ADDR_2, - 0, (uchar *)buf, CONFIG_ENV_SIZE_2)) - puts("\nError writing backplane EEPROM!\n"); - - free(buf); - - return 0; -} -U_BOOT_CMD( - setbpip, 2, 1, do_set_bpip, - "Write Backplane IP-Address", - "" -); - -#endif /* CONFIG_CPCI405AB */ diff --git a/board/esd/cpci405/fpgadata_cpci405.c b/board/esd/cpci405/fpgadata_cpci405.c deleted file mode 100644 index 46c2fed..0000000 --- a/board/esd/cpci405/fpgadata_cpci405.c +++ /dev/null @@ -1,683 +0,0 @@ -0x00, 0x09, 0x0f, 0xf0, 0x0f, 0xf0, 0x0f, 0xf0, -0x0f, 0xf0, 0x00, 0x00, 0x01, 0x61, 0x00, 0x0d, -0x63, 0x70, 0x63, 0x69, 0x34, 0x30, 0x35, 0x32, -0x2e, 0x6e, 0x63, 0x64, 0x00, 0x62, 0x00, 0x0b, -0x73, 0x30, 0x35, 0x78, 0x6c, 0x76, 0x71, 0x31, -0x30, 0x30, 0x00, 0x63, 0x00, 0x0b, 0x32, 0x30, -0x30, 0x31, 0x2f, 0x30, 0x35, 0x2f, 0x31, 0x30, -0x00, 0x64, 0x00, 0x09, 0x31, 0x35, 0x3a, 0x31, -0x35, 0x3a, 0x32, 0x33, 0x00, 0x65, 0xe2, 0x01, -0x00, 0x00, 0x15, 0x08, 0xff, 0x30, 0xe8, 0x01, -0x01, 0x01, 0x01, 0xe7, 0xe6, 0x04, 0x01, 0x02, -0x11, 0x05, 0x03, 0x05, 0x03, 0x05, 0x03, 0x05, -0x03, 0x04, 0x04, 0x0b, 0x02, 0x02, 0x01, 0x04, -0x02, 0x01, 0x0b, 0x07, 0x01, 0x01, 0x0d, 0x03, -0x05, 0x09, 0x03, 0x05, 0x03, 0x05, 0x03, 0x0b, -0x13, 0x01, 0x06, 0xe5, 0xe5, 0x02, 0x03, 0x0c, -0x01, 0xe6, 0x11, 0x08, 0x13, 0x16, 0x08, 0x1e, -0x0b, 0xe5, 0xe6, 0x0e, 0x09, 0x09, 0x09, 0x09, -0x0b, 0x07, 0xe6, 0x08, 0x02, 0xe5, 0x04, 0x01, -0xe6, 0x04, 0x0e, 0x01, 0x01, 0x14, 0x09, 0x09, -0x09, 0x09, 0x05, 0x05, 0xe5, 0xe6, 0x04, 0x03, -0x05, 0xe5, 0x01, 0x05, 0xe5, 0x07, 0x0c, 0xe5, -0x5b, 0x01, 0x01, 0x05, 0x01, 0x11, 0x02, 0xe5, -0xe5, 0x48, 0x13, 0x1a, 0x01, 0xe6, 0x3e, 0x0b, -0x10, 0x03, 0x05, 0x13, 0x03, 0x01, 0x28, 0x14, -0x11, 0x24, 0x03, 0xe5, 0xe6, 0xe5, 0x5d, 0x01, -0x17, 0xe5, 0x01, 0x01, 0x0b, 0xe5, 0x12, 0x09, -0x49, 0x03, 0x01, 0x01, 0x0d, 0x31, 0x0a, 0x2f, -0x01, 0xe6, 0x28, 0x15, 0x1e, 0x1b, 0xe5, 0x01, -0x10, 0x09, 0x09, 0x09, 0x09, 0x0b, 0x09, 0x09, -0x09, 0x09, 0x05, 0x02, 0x04, 0x03, 0x10, 0x09, -0x09, 0x04, 0x04, 0x09, 0x01, 0x05, 0x03, 0x09, -0x13, 0x05, 0x03, 0x0e, 0x01, 0xe5, 0x0c, 0xe5, -0x07, 0xe5, 0x04, 0x02, 0xe5, 0x04, 0x02, 0xe5, -0x04, 0x02, 0xe5, 0x04, 0x03, 0xe6, 0x07, 0xe5, -0x04, 0x02, 0xe5, 0x05, 0x01, 0xe5, 0xe5, 0x05, -0xe5, 0x0e, 0x03, 0x10, 0x09, 0x09, 0x09, 0x09, -0x06, 0x0d, 0x0a, 0xe5, 0x06, 0x0a, 0x0e, 0x01, -0xe5, 0x05, 0x06, 0xe5, 0x07, 0xe5, 0x07, 0xe5, -0x01, 0x05, 0xe5, 0x07, 0xe5, 0x09, 0xe5, 0x07, -0xe5, 0x02, 0x04, 0xe5, 0xe5, 0x01, 0x03, 0xe5, -0x07, 0xe5, 0x07, 0x02, 0x05, 0xe6, 0x0e, 0x09, -0x09, 0x09, 0x09, 0x0d, 0x13, 0x03, 0x05, 0x02, -0xe5, 0x02, 0x08, 0x05, 0xe8, 0x0c, 0x07, 0x01, -0x09, 0x09, 0x06, 0x02, 0x05, 0x03, 0x01, 0x02, -0x02, 0x01, 0x01, 0x06, 0x02, 0x02, 0x06, 0x02, -0x06, 0x0a, 0x06, 0xe5, 0xe5, 0x0c, 0x02, 0x06, -0x02, 0x06, 0x02, 0x04, 0x01, 0x02, 0x06, 0x02, -0x06, 0x01, 0x02, 0x06, 0x02, 0x06, 0x01, 0xe6, -0x02, 0xe6, 0xe6, 0x05, 0x02, 0x0d, 0x02, 0xe5, -0x02, 0x2b, 0x01, 0x06, 0x0b, 0x0c, 0x06, 0x01, -0x01, 0xe5, 0x14, 0x02, 0x03, 0xe5, 0xe6, 0x13, -0x23, 0x0a, 0x14, 0x04, 0x1c, 0xe5, 0xe6, 0x27, -0x01, 0x0e, 0x0a, 0x03, 0x13, 0x1d, 0x02, 0xe5, -0x0d, 0x04, 0xe7, 0x14, 0x0e, 0x05, 0xe5, 0x05, -0x0c, 0x03, 0x0a, 0x01, 0x09, 0x0a, 0x01, 0x10, -0x04, 0xe5, 0x02, 0x09, 0x09, 0x09, 0x09, 0xe6, -0x08, 0x09, 0x09, 0xe5, 0x07, 0x0e, 0xe5, 0xe5, -0x32, 0x0d, 0x10, 0x02, 0x02, 0x03, 0x02, 0x02, -0x03, 0x15, 0xe6, 0x47, 0x09, 0x02, 0x09, 0x07, -0x12, 0xe5, 0xe6, 0x24, 0x1c, 0x12, 0x09, 0x16, -0x03, 0xe5, 0x01, 0x06, 0x27, 0x16, 0x04, 0x08, -0x22, 0x05, 0x01, 0x47, 0x15, 0x09, 0x05, 0x0c, -0x02, 0xe5, 0x40, 0xe5, 0x11, 0xe6, 0x06, 0x01, -0x18, 0xe8, 0x05, 0x3e, 0x0f, 0x0c, 0x18, 0x01, -0xe5, 0x2f, 0x0f, 0x13, 0x08, 0xe6, 0x19, 0xe6, -0xe5, 0x0b, 0x2b, 0x15, 0x14, 0x05, 0x10, 0x01, -0xe6, 0x3f, 0x28, 0x07, 0x0a, 0xe6, 0x09, 0x2e, -0x2d, 0x12, 0xe8, 0x59, 0x08, 0x0f, 0xe5, 0x04, -0x01, 0x01, 0x23, 0x07, 0x01, 0x01, 0x17, 0x2c, -0x05, 0xe8, 0x22, 0x09, 0x02, 0x28, 0x0a, 0x15, -0xe6, 0xe5, 0x12, 0x0d, 0xe5, 0x01, 0x06, 0x2e, -0x09, 0x16, 0xe8, 0x74, 0xe5, 0xe5, 0xe7, 0x01, -0x01, 0x50, 0xe5, 0x1d, 0x01, 0x02, 0x01, 0x01, -0x04, 0x52, 0x18, 0x01, 0x02, 0x01, 0x03, 0xe7, -0x01, 0x52, 0x1a, 0x06, 0x02, 0x03, 0x57, 0x11, -0x01, 0x05, 0x06, 0xe5, 0x03, 0x02, 0x52, 0x03, -0x01, 0x02, 0x0a, 0x01, 0x01, 0x06, 0x02, 0x02, -0x01, 0xe7, 0x55, 0x11, 0x01, 0x0b, 0x02, 0xe5, -0x01, 0x55, 0x13, 0x01, 0x0e, 0xe5, 0xe6, 0x04, -0xe5, 0x01, 0x02, 0x6c, 0xe7, 0xe5, 0x04, 0x04, -0x6f, 0xe6, 0xe6, 0x09, 0x03, 0x09, 0x09, 0x09, -0x09, 0x0b, 0x09, 0x09, 0x09, 0x09, 0x06, 0x06, -0xe6, 0xe6, 0x01, 0x6c, 0x02, 0x09, 0xe6, 0x6e, -0x08, 0x01, 0xe5, 0xe6, 0x22, 0x09, 0x4e, 0x01, -0x23, 0xe5, 0x07, 0xe5, 0x4a, 0xe9, 0x1e, 0x02, -0x09, 0x4d, 0x01, 0xe5, 0x14, 0xe5, 0x07, 0xe5, -0x01, 0x05, 0xe5, 0x01, 0x05, 0xe5, 0x07, 0xe5, -0x09, 0xe5, 0x07, 0xe5, 0x07, 0xe5, 0x07, 0xe5, -0x07, 0xe5, 0x05, 0x01, 0x02, 0x09, 0x19, 0x09, -0x50, 0x23, 0x09, 0x4c, 0xe5, 0x01, 0x23, 0x09, -0x4c, 0x02, 0xe5, 0x08, 0x19, 0x09, 0x4c, 0xe5, -0xe6, 0x1e, 0x59, 0x02, 0xe6, 0x10, 0x01, 0x01, -0x04, 0xe5, 0xe5, 0x06, 0x01, 0x01, 0x05, 0x01, -0x07, 0x01, 0x09, 0x01, 0x02, 0x04, 0x01, 0x07, -0x01, 0x07, 0x01, 0x07, 0x01, 0x0a, 0xe6, 0xe5, -0x77, 0x02, 0x02, 0xe5, 0x28, 0x04, 0x03, 0x08, -0x03, 0x13, 0x24, 0xe6, 0xe6, 0x3e, 0x3b, 0xe5, -0xe6, 0x22, 0x1a, 0x39, 0x02, 0xe6, 0x3e, 0x3a, -0x01, 0x01, 0xe5, 0x11, 0x2b, 0x1b, 0x1d, 0xe5, -0x02, 0x3f, 0x32, 0x07, 0xe5, 0xe6, 0x07, 0x36, -0x3c, 0x01, 0x1a, 0x24, 0xe5, 0x38, 0xe6, 0xe5, -0x0a, 0x0a, 0x28, 0x3c, 0x01, 0x1b, 0x5f, 0xe7, -0x7a, 0xe7, 0x7a, 0x02, 0x01, 0x01, 0x73, 0xe5, -0x02, 0xe6, 0x01, 0x72, 0x01, 0x03, 0xe7, 0x03, -0x6b, 0x01, 0x02, 0x01, 0x02, 0x01, 0xe7, 0xe5, -0x6b, 0xe5, 0x05, 0x02, 0x03, 0xe5, 0x77, 0x02, -0xe7, 0xe5, 0x73, 0x03, 0xe8, 0x77, 0x01, 0xe8, -0x78, 0xe6, 0xe5, 0x78, 0xe5, 0x01, 0xe5, 0x7a, -0xe8, 0x0d, 0x09, 0x09, 0x09, 0x09, 0x0b, 0x09, -0x09, 0x09, 0x09, 0x0d, 0xe5, 0xe7, 0x01, 0x77, -0xe8, 0x77, 0x01, 0x02, 0xe5, 0x6f, 0x0d, 0x7a, -0x01, 0xe6, 0x78, 0xe5, 0xe5, 0xe5, 0x14, 0xe5, -0x07, 0xe5, 0x07, 0xe5, 0x07, 0xe5, 0x07, 0xe5, -0x09, 0xe5, 0x07, 0xe5, 0x07, 0xe5, 0x07, 0xe5, -0x07, 0xe5, 0x09, 0xe5, 0x7a, 0xe5, 0xe5, 0x79, -0x01, 0xe6, 0x79, 0x01, 0x01, 0x7e, 0x7c, 0xe6, -0x10, 0x01, 0x07, 0x01, 0x07, 0x01, 0x07, 0x01, -0x07, 0x01, 0x01, 0x07, 0x01, 0x01, 0x05, 0x01, -0x02, 0x04, 0x01, 0x01, 0x05, 0x01, 0x07, 0x01, -0x02, 0x05, 0x04, 0xe5, 0x7b, 0xe7, 0x1e, 0x29, -0x08, 0x25, 0xe9, 0x3e, 0x3c, 0x01, 0x03, 0xe5, -0x39, 0x3d, 0xe7, 0x3c, 0x3b, 0x02, 0xe5, 0x2f, -0x0d, 0x3b, 0xe5, 0xe6, 0x3d, 0x3a, 0x01, 0x01, -0x3f, 0x3c, 0xe7, 0x03, 0x25, 0xe6, 0x10, 0x1f, -0xe6, 0x1a, 0xe5, 0x2d, 0x10, 0x21, 0x18, 0xe5, -0xe6, 0x15, 0x63, 0xe6, 0xe5, 0x13, 0x22, 0x41, -0xe7, 0xe5, 0x36, 0x42, 0x01, 0x01, 0x01, 0x76, -0xe5, 0x01, 0xe6, 0x01, 0x01, 0x70, 0x01, 0x06, -0x01, 0xe5, 0xe5, 0x6f, 0x04, 0xe5, 0x01, 0x02, -0x74, 0x06, 0xe5, 0x0a, 0x6e, 0x01, 0xe5, 0xe6, -0x06, 0xe6, 0x69, 0x04, 0x01, 0x02, 0x76, 0xe9, -0x79, 0xe5, 0xe7, 0x7a, 0x01, 0x63, 0x16, 0xe9, -0x0d, 0x09, 0x09, 0x09, 0x09, 0x0b, 0x09, 0x09, -0x09, 0x09, 0x04, 0x01, 0x06, 0x02, 0xe6, 0x71, -0x04, 0x02, 0x02, 0xe5, 0xe5, 0x60, 0x0b, 0x0b, -0xe5, 0xe5, 0x36, 0x27, 0x01, 0x16, 0x03, 0x01, -0x37, 0xe5, 0x25, 0x01, 0x01, 0x16, 0x01, 0xe7, -0x26, 0x0e, 0x27, 0x01, 0x03, 0x14, 0xe5, 0x01, -0x15, 0xe5, 0x07, 0xe5, 0x07, 0xe5, 0x07, 0xe5, -0x01, 0x05, 0xe5, 0x09, 0xe5, 0x07, 0xe5, 0x07, -0xe6, 0xe5, 0x04, 0xe5, 0x07, 0xe5, 0x09, 0xe5, -0x2d, 0x08, 0x2a, 0x17, 0xe6, 0xe5, 0x2d, 0x08, -0x2a, 0x18, 0xe5, 0xe5, 0x08, 0x2d, 0x08, 0x39, -0x02, 0xe5, 0x2d, 0x08, 0x2c, 0x19, 0xe5, 0x12, -0xe5, 0x63, 0x01, 0xe6, 0x05, 0x0a, 0x01, 0x07, -0x01, 0x07, 0x01, 0x02, 0x04, 0x01, 0x07, 0x01, -0x01, 0x02, 0x04, 0x01, 0x07, 0x01, 0x07, 0x01, -0x07, 0x01, 0x07, 0x01, 0x0a, 0xe5, 0xe6, 0xe5, -0x06, 0x4a, 0x0e, 0x16, 0xe9, 0x32, 0x09, 0x13, -0x13, 0x12, 0xe5, 0x02, 0x0a, 0x33, 0xe6, 0x12, -0x09, 0x1b, 0x01, 0x01, 0xe5, 0x07, 0x06, 0x03, -0x1a, 0x1a, 0x16, 0x17, 0x01, 0x02, 0x13, 0x2b, -0xe5, 0x0e, 0x2b, 0x01, 0xe5, 0x0a, 0x32, 0x03, -0x17, 0x03, 0xe6, 0x16, 0x02, 0x01, 0x26, 0x02, -0x01, 0x07, 0x0b, 0x01, 0xe6, 0x04, 0x15, 0x01, -0x18, 0xe8, 0x08, 0x1e, 0x02, 0x13, 0x3a, 0x03, -0x05, 0x02, 0x36, 0x15, 0xe5, 0x06, 0xe7, 0x17, -0xe5, 0xe6, 0x38, 0x05, 0x15, 0x02, 0x07, 0x1a, -0x02, 0x02, 0x13, 0x16, 0x2a, 0x0e, 0x03, 0x12, -0x19, 0x04, 0x0d, 0x03, 0x0b, 0x2d, 0xe5, 0x11, -0x19, 0x20, 0x2f, 0x11, 0x01, 0x01, 0x49, 0x02, -0xe6, 0x0d, 0x02, 0xe5, 0x04, 0x0e, 0x03, 0x01, -0x02, 0x01, 0x41, 0x04, 0x03, 0xe5, 0x0d, 0x02, -0x06, 0x0b, 0x01, 0x03, 0x02, 0x01, 0xe5, 0xe5, -0x22, 0xe5, 0x05, 0x1a, 0x10, 0x01, 0xe5, 0xe5, -0x01, 0x04, 0x02, 0x08, 0x04, 0x01, 0x01, 0x02, -0x48, 0x10, 0xe5, 0xe5, 0xe5, 0x06, 0xe6, 0xe5, -0xe6, 0x05, 0x02, 0xe9, 0x04, 0x05, 0x20, 0x04, -0x01, 0x0c, 0x01, 0x07, 0x0e, 0x04, 0x01, 0xe5, -0x05, 0x02, 0x03, 0x01, 0x06, 0xe5, 0xe5, 0xe5, -0xe6, 0x07, 0x23, 0x01, 0x02, 0x0c, 0x01, 0x01, -0x05, 0x03, 0x0f, 0x01, 0xe5, 0x05, 0x03, 0x04, -0x04, 0x02, 0xe8, 0x01, 0x3e, 0x01, 0x07, 0x0d, -0x02, 0x01, 0xe5, 0xe5, 0x06, 0x05, 0xe6, 0x06, -0xe7, 0xe5, 0x40, 0x01, 0x07, 0x10, 0x01, 0xe5, -0xe6, 0x05, 0x01, 0xe5, 0x02, 0x0a, 0x01, 0xe6, -0x1b, 0x02, 0x10, 0x26, 0x09, 0x09, 0x04, 0x07, -0x01, 0xe7, 0x01, 0x1b, 0xe5, 0x13, 0x23, 0xe5, -0x0b, 0x09, 0xe5, 0x09, 0x01, 0xe5, 0x0d, 0x09, -0x09, 0x04, 0x01, 0x02, 0x09, 0x0b, 0x09, 0x09, -0xe6, 0x06, 0xe5, 0x02, 0xe6, 0x01, 0xe5, 0xe5, -0xe5, 0xe5, 0x05, 0x01, 0x02, 0x16, 0x13, 0x33, -0x13, 0x04, 0x02, 0xe5, 0xe6, 0xe5, 0x10, 0x14, -0x32, 0x14, 0x0b, 0xe6, 0x16, 0x01, 0x11, 0x01, -0x24, 0x05, 0xe5, 0x04, 0x01, 0xe5, 0x05, 0x01, -0xe6, 0x0d, 0x01, 0x16, 0xe5, 0xe6, 0x0f, 0x01, -0xe5, 0x29, 0x05, 0x01, 0x07, 0x01, 0x0f, 0xe8, -0x15, 0x01, 0x11, 0x01, 0x2a, 0x08, 0x07, 0x01, -0x01, 0x0c, 0xe5, 0xe6, 0x03, 0x10, 0xe6, 0xe5, -0x04, 0x09, 0xe6, 0xe5, 0x04, 0xe5, 0x07, 0xe5, -0x07, 0x02, 0x06, 0x01, 0xe5, 0x06, 0xe7, 0xe5, -0x02, 0x01, 0xe6, 0xe5, 0x04, 0xe5, 0x08, 0x01, -0x17, 0x01, 0x05, 0x0b, 0x01, 0x0f, 0x09, 0x0b, -0x04, 0xe5, 0x04, 0x01, 0x09, 0x0f, 0xe5, 0xe5, -0x16, 0x01, 0x06, 0x0a, 0x01, 0x30, 0xe5, 0xe5, -0x05, 0xe5, 0xe5, 0x0d, 0x01, 0xe7, 0x17, 0x05, -0x0b, 0x01, 0x0f, 0x02, 0x08, 0x07, 0x01, 0x08, -0x04, 0x03, 0x01, 0x16, 0x17, 0x01, 0x03, 0xe5, -0x0d, 0x0d, 0x15, 0x08, 0x01, 0x01, 0xe5, 0xe5, -0x03, 0xe6, 0x10, 0xe6, 0xe5, 0x10, 0x1c, 0x03, -0x18, 0x13, 0xe5, 0xe5, 0x05, 0x14, 0x11, 0x01, -0x01, 0x05, 0x01, 0x02, 0x04, 0x01, 0x01, 0x05, -0x01, 0x07, 0x01, 0x01, 0x02, 0x04, 0x01, 0x04, -0x02, 0x01, 0x07, 0x01, 0x03, 0x03, 0x01, 0x03, -0x03, 0x01, 0x0b, 0xe7, 0xe5, 0x12, 0x15, 0x05, -0x0a, 0x10, 0xe5, 0x17, 0x03, 0xe5, 0x0c, 0x01, -0xe7, 0x48, 0x03, 0x0e, 0x0c, 0x03, 0x01, 0x08, -0x04, 0x05, 0x02, 0x0b, 0x0b, 0x09, 0x08, 0xe5, -0x03, 0x05, 0x0b, 0x01, 0x02, 0x0b, 0x0e, 0x01, -0x0c, 0x01, 0xe6, 0xe5, 0x01, 0x0f, 0x02, 0xe6, -0x03, 0x0e, 0x03, 0x18, 0x0d, 0x20, 0xea, 0x01, -0x06, 0x20, 0x03, 0x0f, 0x05, 0x21, 0x14, 0x01, -0xe5, 0x15, 0x1f, 0x07, 0x09, 0x1b, 0x13, 0x04, -0xe5, 0x06, 0x04, 0x0c, 0x0a, 0xe5, 0x09, 0x04, -0x06, 0xe6, 0x24, 0x03, 0x01, 0x0e, 0x01, 0xe6, -0x0a, 0x03, 0x17, 0xe5, 0x15, 0x11, 0x11, 0x09, -0x0c, 0x02, 0xe6, 0x06, 0x02, 0x0b, 0xe6, 0x17, -0x09, 0x02, 0x07, 0x12, 0x04, 0xe6, 0x06, 0xe5, -0xe6, 0x0c, 0xe7, 0x18, 0x15, 0xe5, 0x0d, 0x10, -0x11, 0x06, 0x01, 0x0e, 0x01, 0xe6, 0x3c, 0x06, -0x03, 0x22, 0x0e, 0x01, 0xe6, 0x09, 0x04, 0x58, -0x11, 0x02, 0xe5, 0x08, 0x05, 0x2a, 0x01, 0x1c, -0x0f, 0x10, 0xe6, 0xe5, 0xe5, 0x01, 0x05, 0xe5, -0xe5, 0x01, 0xe5, 0x01, 0x01, 0x03, 0xe5, 0x11, -0x09, 0x02, 0xe5, 0x06, 0xe5, 0x22, 0x0e, 0x01, -0x03, 0x02, 0x06, 0xe5, 0x01, 0xe6, 0x21, 0xe5, -0xe5, 0x2f, 0x01, 0xe5, 0x0a, 0x01, 0x06, 0x01, -0xe5, 0xe5, 0x04, 0x01, 0xe5, 0xe5, 0xe5, 0x08, -0x1b, 0x02, 0x0a, 0x23, 0x06, 0xe5, 0x02, 0x06, -0x01, 0xe5, 0xe5, 0x06, 0x02, 0x27, 0x33, 0x05, -0xe5, 0x05, 0x02, 0x02, 0xe6, 0x09, 0x01, 0x01, -0x27, 0x06, 0x25, 0x04, 0x01, 0x02, 0x09, 0xe5, -0xe6, 0xe8, 0x09, 0x01, 0x01, 0x02, 0x01, 0x1e, -0x03, 0x02, 0xe6, 0x29, 0x01, 0x01, 0x09, 0x02, -0x03, 0x02, 0x0a, 0x01, 0x18, 0x01, 0x07, 0x01, -0x02, 0x04, 0x01, 0x07, 0x01, 0x20, 0x01, 0x01, -0x06, 0x02, 0x04, 0x01, 0xe5, 0xe5, 0x09, 0x01, -0x18, 0x01, 0x0a, 0x12, 0xe5, 0x18, 0x05, 0x01, -0x0e, 0xe8, 0xe5, 0x10, 0x02, 0x24, 0xe5, 0x0b, -0x07, 0xe5, 0x07, 0x06, 0x02, 0xe5, 0x04, 0x02, -0x02, 0x06, 0xe7, 0xe5, 0x13, 0x3d, 0x09, 0x01, -0x03, 0xe5, 0x01, 0x05, 0xe5, 0x01, 0xe5, 0x0b, -0xe5, 0x0a, 0x02, 0x02, 0xe6, 0xe5, 0x01, 0x09, -0x09, 0x04, 0x01, 0x02, 0x0b, 0x09, 0x03, 0x05, -0x05, 0x03, 0xe5, 0x01, 0x05, 0xe6, 0x03, 0x06, -0x01, 0xe5, 0xe5, 0x0a, 0xe5, 0x08, 0x27, 0x32, -0xe5, 0x03, 0x03, 0x01, 0xe5, 0xe5, 0x08, 0x07, -0x27, 0x27, 0x0b, 0x0b, 0xe5, 0xe5, 0x0c, 0x01, -0x04, 0x04, 0x1a, 0xe5, 0xe5, 0x08, 0x01, 0x07, -0x01, 0x07, 0x01, 0x04, 0x02, 0x01, 0xe5, 0x05, -0x01, 0xe6, 0x0f, 0x02, 0x0a, 0x01, 0xe5, 0x05, -0x02, 0x1a, 0x01, 0xe5, 0x07, 0x01, 0xe5, 0x05, -0x01, 0xe5, 0x05, 0x01, 0xe5, 0x05, 0x01, 0xe6, -0x01, 0x01, 0xe5, 0xe7, 0x0b, 0xe5, 0x01, 0xe5, -0x0a, 0xe5, 0xe5, 0x08, 0x03, 0x13, 0x05, 0x03, -0xe5, 0x03, 0x01, 0x25, 0x01, 0xe5, 0x07, 0x04, -0x03, 0x0d, 0x01, 0x05, 0xe6, 0x04, 0xe5, 0xe5, -0x07, 0xe5, 0x07, 0xe6, 0x04, 0x01, 0xe5, 0x01, -0x01, 0x05, 0xe5, 0x07, 0xe5, 0x06, 0xe6, 0x05, -0xe5, 0xe6, 0xe5, 0x04, 0xe5, 0x0a, 0x09, 0x05, -0x09, 0xe5, 0x02, 0x05, 0xe5, 0x07, 0x08, 0x05, -0x05, 0xe6, 0x02, 0x01, 0x01, 0x05, 0x01, 0x01, -0xe5, 0x02, 0x02, 0x01, 0xe5, 0x02, 0x02, 0x01, -0x0e, 0xe8, 0x03, 0x08, 0x01, 0x07, 0x02, 0x05, -0x14, 0x05, 0x05, 0x09, 0x01, 0x07, 0x01, 0x06, -0xe5, 0xe6, 0x04, 0xe5, 0xe5, 0x0f, 0xe6, 0x08, -0x03, 0x01, 0x09, 0x03, 0x01, 0xe5, 0x0c, 0x08, -0x05, 0x02, 0x02, 0x05, 0x09, 0x04, 0x05, 0x06, -0x01, 0xe5, 0x01, 0x0e, 0x03, 0x04, 0x08, 0x01, -0x07, 0x02, 0x02, 0xe5, 0x04, 0x09, 0x06, 0x02, -0x02, 0x05, 0x02, 0x13, 0x03, 0x07, 0xe6, 0x01, -0x01, 0x02, 0x0b, 0x02, 0xe6, 0x02, 0x08, 0x01, -0xe5, 0x0c, 0x19, 0x0f, 0x1a, 0x05, 0x01, 0xe5, -0x0b, 0x01, 0x01, 0xe5, 0x02, 0x02, 0x07, 0x02, -0x01, 0x07, 0x01, 0x01, 0x05, 0x01, 0x07, 0x01, -0x01, 0x05, 0x01, 0x04, 0x04, 0x01, 0x07, 0x01, -0x07, 0x01, 0x01, 0x05, 0x01, 0x01, 0x02, 0x02, -0x01, 0x0b, 0x02, 0x01, 0x01, 0x07, 0x14, 0x0c, -0x01, 0x05, 0x07, 0xe5, 0x06, 0x03, 0x0c, 0xe6, -0x06, 0xe6, 0x13, 0x01, 0x02, 0xe6, 0x06, 0x24, -0xe5, 0x01, 0x02, 0x04, 0x02, 0x12, 0x01, 0x02, -0xe5, 0xe5, 0x06, 0x08, 0x07, 0x08, 0xe6, 0xe6, -0x08, 0x14, 0x01, 0x07, 0x01, 0x0e, 0x02, 0xe7, -0x0f, 0x0f, 0x19, 0xe5, 0xe6, 0x03, 0x08, 0x06, -0x10, 0x0e, 0xe5, 0x03, 0x08, 0x01, 0x1f, 0xe6, -0xe5, 0x03, 0x0a, 0x02, 0x01, 0xe5, 0x01, 0x0c, -0x16, 0xe5, 0x07, 0xe5, 0x03, 0x05, 0x01, 0xe6, -0x03, 0x01, 0x15, 0x08, 0x04, 0x0e, 0xe5, 0xe6, -0x11, 0x01, 0x02, 0xe5, 0x1b, 0xe5, 0x06, 0x03, -0x05, 0x05, 0x0b, 0x1d, 0xe7, 0xe6, 0x06, 0x03, -0x0d, 0x0e, 0x0b, 0x01, 0x01, 0xe6, 0x02, 0x01, -0xe7, 0x05, 0x1d, 0x11, 0x02, 0x28, 0x06, 0x03, -0x07, 0xe5, 0x01, 0x0b, 0x18, 0x06, 0x06, 0x07, -0x03, 0xe5, 0x1e, 0x01, 0x07, 0x07, 0x0c, 0x07, -0x02, 0xe5, 0xe5, 0x02, 0x02, 0xe6, 0x06, 0x15, -0x05, 0x02, 0xe5, 0x1c, 0x05, 0x10, 0x05, 0x04, -0x05, 0x12, 0x01, 0x15, 0x09, 0x02, 0xe5, 0x0b, -0x07, 0x0e, 0x04, 0xe5, 0x02, 0x02, 0x10, 0x01, -0xe5, 0xe5, 0xe5, 0x0b, 0xe6, 0x01, 0x01, 0x1d, -0xe6, 0xe5, 0xe5, 0x0f, 0x09, 0x05, 0xe6, 0x06, -0xe5, 0x04, 0x03, 0x0b, 0x0b, 0x07, 0xe5, 0x03, -0x0a, 0x02, 0x01, 0x07, 0x04, 0xe8, 0x11, 0x01, -0x0d, 0x05, 0x04, 0x09, 0x02, 0x01, 0x05, 0x03, -0xe5, 0x0e, 0x04, 0x0e, 0x03, 0x0a, 0xe5, 0xe6, -0x01, 0x0e, 0x06, 0xe5, 0xe5, 0x0f, 0x02, 0x12, -0x03, 0x10, 0x08, 0xe6, 0x10, 0x02, 0x03, 0xe5, -0xe5, 0x03, 0x01, 0xe6, 0x02, 0x03, 0x07, 0x0b, -0x07, 0x01, 0x12, 0x02, 0x09, 0xe5, 0x04, 0x0a, -0x08, 0x05, 0x0b, 0xe5, 0xe7, 0x17, 0xe5, 0x07, -0xe5, 0x07, 0xe5, 0x04, 0x02, 0x02, 0xe5, 0x06, -0xe5, 0x04, 0x02, 0xe5, 0x07, 0xe5, 0x04, 0x17, -0xe5, 0x01, 0xe5, 0xe5, 0x01, 0x01, 0x01, 0x06, -0xe5, 0x0a, 0x08, 0xe5, 0x05, 0xe5, 0x01, 0x05, -0xe6, 0x09, 0xe5, 0x09, 0x09, 0x10, 0x0b, 0x01, -0x02, 0x01, 0xe6, 0x03, 0x01, 0x08, 0x0e, 0x01, -0x0c, 0x07, 0x01, 0x02, 0x08, 0x01, 0x05, 0x13, -0x06, 0x01, 0xe5, 0xe5, 0x03, 0x01, 0x02, 0x01, -0x03, 0x01, 0xe5, 0x0c, 0x1d, 0x05, 0xe5, 0x01, -0x01, 0x0b, 0x09, 0x1b, 0x01, 0x04, 0x06, 0x02, -0x03, 0x0f, 0x06, 0xe5, 0xe5, 0x09, 0x08, 0x06, -0xe5, 0xe6, 0x04, 0x02, 0x08, 0x03, 0x03, 0x01, -0x0a, 0x08, 0xe5, 0xe5, 0x03, 0xe6, 0x04, 0xe5, -0x02, 0xe5, 0x01, 0x02, 0x07, 0x03, 0x03, 0x01, -0x01, 0x01, 0x07, 0x01, 0x05, 0x03, 0x03, 0x01, -0x01, 0xe5, 0x03, 0xe5, 0x03, 0x01, 0x03, 0xe5, -0x05, 0x02, 0x11, 0xe7, 0xe5, 0xe5, 0x01, 0x01, -0x01, 0x02, 0x06, 0x01, 0x0d, 0x07, 0x01, 0x03, -0xe5, 0x0d, 0x07, 0x01, 0x04, 0xe6, 0x01, 0x07, -0x15, 0x09, 0x01, 0x0b, 0x02, 0xe5, 0x01, 0x0d, -0x09, 0x01, 0x04, 0x01, 0x03, 0x06, 0x09, 0x02, -0x03, 0x06, 0x25, 0x01, 0x10, 0xe6, 0x08, 0x1d, -0x02, 0x06, 0x06, 0x02, 0x01, 0xe5, 0x11, 0x02, -0x10, 0x02, 0x06, 0xe5, 0x01, 0xe5, 0x03, 0x04, -0x0a, 0x01, 0x1b, 0x09, 0x01, 0x13, 0xe5, 0x07, -0x10, 0xe5, 0xe5, 0x08, 0x03, 0x06, 0x02, 0xe5, -0x07, 0x05, 0x09, 0x06, 0x02, 0x02, 0x02, 0x03, -0x03, 0x05, 0xe5, 0x04, 0x04, 0x09, 0x04, 0xe6, -0x01, 0x04, 0x01, 0x02, 0x03, 0x05, 0x03, 0x02, -0x06, 0x01, 0xe7, 0x01, 0x1a, 0x02, 0x13, 0x08, -0xe5, 0x1e, 0x09, 0x06, 0x0a, 0x01, 0xe6, 0x1e, -0x13, 0x07, 0x21, 0x07, 0x12, 0x02, 0xe7, 0xe5, -0x0a, 0x01, 0x15, 0x05, 0x01, 0x07, 0x01, 0xe5, -0x07, 0x01, 0x13, 0x04, 0x02, 0x01, 0x07, 0x01, -0x0f, 0xe5, 0xe5, 0x0c, 0x01, 0xe5, 0x16, 0x02, -0x01, 0x01, 0x04, 0xe5, 0xe5, 0x05, 0x02, 0x01, -0xe5, 0x08, 0x06, 0x01, 0xe5, 0x05, 0x01, 0x01, -0x01, 0x02, 0xe5, 0xe6, 0x0c, 0xe5, 0xe6, 0x0c, -0x01, 0x0d, 0x07, 0x0c, 0x04, 0x09, 0x01, 0x13, -0x09, 0x07, 0x01, 0x0d, 0xe6, 0x01, 0x0d, 0x01, -0x03, 0xe7, 0x05, 0xe7, 0x05, 0xe6, 0xe5, 0x04, -0xe8, 0xe5, 0x03, 0xe6, 0x01, 0x01, 0x03, 0x02, -0x06, 0xe5, 0xe6, 0xe5, 0x02, 0xe8, 0x06, 0xe5, -0x01, 0x05, 0xe5, 0x07, 0x02, 0x13, 0xe5, 0xe5, -0x02, 0xe5, 0xe5, 0x05, 0x04, 0x01, 0x01, 0x04, -0x02, 0x01, 0xe5, 0x07, 0x01, 0xe5, 0x08, 0xe5, -0x0e, 0x01, 0x07, 0x01, 0x0e, 0xe5, 0xe6, 0x14, -0xe5, 0x06, 0x01, 0x07, 0x01, 0xe5, 0xe5, 0x05, -0xe5, 0xe5, 0x05, 0x04, 0x03, 0x02, 0x07, 0x01, -0x09, 0xe5, 0xe5, 0x08, 0x0e, 0xe5, 0x01, 0xe5, -0x0a, 0x08, 0x09, 0x01, 0x02, 0x02, 0x01, 0x07, -0x01, 0xe6, 0xe6, 0x02, 0xe5, 0x01, 0xe5, 0xe6, -0x03, 0xe6, 0xe5, 0x02, 0x01, 0x07, 0xe6, 0x0a, -0x01, 0x0e, 0xe8, 0x13, 0x05, 0x03, 0xe6, 0x02, -0x03, 0x02, 0x04, 0xe5, 0xe5, 0xe5, 0xe6, 0x01, -0x01, 0xe5, 0x01, 0x01, 0xe5, 0x01, 0xe5, 0x01, -0x01, 0xe5, 0x02, 0x01, 0x07, 0xe6, 0x04, 0x06, -0x0e, 0x02, 0xe5, 0x01, 0x07, 0x16, 0x0d, 0xe5, -0x03, 0x02, 0xe5, 0x08, 0xe5, 0x05, 0x02, 0x10, -0x02, 0x06, 0x02, 0x0c, 0xe6, 0xe6, 0x10, 0x01, -0xe5, 0x05, 0x01, 0xe5, 0x02, 0x02, 0x01, 0x01, -0x05, 0x01, 0x04, 0x02, 0x01, 0x04, 0x04, 0x01, -0x02, 0x01, 0x01, 0xe7, 0x06, 0x01, 0x03, 0x03, -0x01, 0x04, 0x02, 0x01, 0xe5, 0x0a, 0xe6, 0xe5, -0x20, 0xe5, 0x07, 0xe5, 0x05, 0x02, 0x05, 0x04, -0xe5, 0xe5, 0x03, 0x01, 0x11, 0x09, 0x0e, 0x05, -0xe5, 0x0a, 0x07, 0x0a, 0x03, 0x01, 0x01, 0x03, -0x01, 0x06, 0xe5, 0x01, 0x0a, 0x0e, 0x13, 0x12, -0xe9, 0x03, 0x05, 0x16, 0x05, 0x02, 0x11, 0x02, -0x01, 0x03, 0x07, 0x02, 0x03, 0x11, 0x13, 0x03, -0xe5, 0x0a, 0xe7, 0x03, 0x0e, 0x04, 0x0b, 0xe7, -0xe5, 0x05, 0xe7, 0x03, 0x02, 0x01, 0x07, 0x01, -0x05, 0x01, 0xe5, 0x16, 0xe5, 0x02, 0xe5, 0x35, -0x08, 0x01, 0x03, 0x05, 0x01, 0x08, 0xe5, 0x03, -0x1e, 0xe8, 0x07, 0x03, 0x05, 0x04, 0xe5, 0x02, -0x02, 0xe7, 0x01, 0x05, 0xe5, 0x02, 0xe6, 0x06, -0x01, 0xe6, 0x02, 0x0d, 0x05, 0x0f, 0x11, 0xe9, -0x20, 0x09, 0x0c, 0x06, 0x01, 0x01, 0x02, 0x0b, -0x02, 0x05, 0x11, 0x0c, 0x02, 0xe5, 0x0b, 0x16, -0x02, 0x03, 0x02, 0x05, 0x0a, 0xe5, 0x03, 0x01, -0x0a, 0x05, 0xe6, 0xe5, 0x07, 0x15, 0x02, 0xe5, -0x0c, 0xe5, 0x15, 0x02, 0x07, 0x03, 0xe5, 0x08, -0x07, 0x02, 0x0b, 0x02, 0x15, 0x0a, 0xe6, 0xe5, -0x03, 0x05, 0x05, 0x24, 0x06, 0xe5, 0xe6, 0x03, -0x09, 0x03, 0x04, 0x25, 0x0e, 0x05, 0x02, 0x01, -0x02, 0x07, 0x02, 0x0f, 0x02, 0x08, 0x04, 0x02, -0x01, 0x04, 0xe5, 0x03, 0xe5, 0x20, 0xe7, 0x08, -0x0f, 0x01, 0x0d, 0x01, 0x01, 0x03, 0x04, 0xe5, -0xe5, 0x01, 0x03, 0xe5, 0xe5, 0x08, 0x09, 0x23, -0x01, 0xe5, 0x01, 0x15, 0x1d, 0x04, 0x05, 0x0a, -0x03, 0x06, 0x22, 0xe6, 0xe5, 0x0c, 0x09, 0x09, -0x18, 0xe6, 0x03, 0x02, 0xe6, 0xe5, 0xe5, 0x02, -0x03, 0xe5, 0x05, 0x07, 0xe6, 0x06, 0x01, 0x08, -0xe5, 0xe5, 0x01, 0xe5, 0x03, 0x08, 0x09, 0xe5, -0x07, 0xe5, 0x17, 0xe5, 0x03, 0x05, 0xe5, 0x06, -0x01, 0xe5, 0x0e, 0x05, 0xe5, 0x02, 0x06, 0x01, -0x02, 0xe5, 0xe6, 0x03, 0x08, 0x05, 0xe5, 0x03, -0x04, 0xe5, 0x02, 0x03, 0xe5, 0x08, 0x01, 0x02, -0x04, 0x01, 0x02, 0x01, 0x01, 0xe5, 0xe6, 0xe5, -0x0b, 0x12, 0x04, 0xe5, 0x02, 0x01, 0x02, 0x01, -0x01, 0x02, 0x0a, 0x06, 0xe5, 0xe5, 0x05, 0xe5, -0xe5, 0x05, 0x09, 0x02, 0x06, 0x04, 0x01, 0x07, -0x0a, 0x01, 0x10, 0x0d, 0x03, 0xe8, 0x04, 0x05, -0xe5, 0x08, 0x01, 0x06, 0x02, 0x03, 0x01, 0xe6, -0xe6, 0xe6, 0xe6, 0x04, 0x02, 0xe5, 0x01, 0x01, -0x11, 0x04, 0x10, 0x06, 0x05, 0xe6, 0x01, 0xe5, -0x01, 0x07, 0xe7, 0x02, 0x05, 0x01, 0x01, 0x01, -0x01, 0xe6, 0x05, 0x01, 0xe5, 0x01, 0x05, 0x05, -0x01, 0xe6, 0x01, 0x01, 0x01, 0x09, 0x07, 0x04, -0x01, 0x0a, 0x03, 0x03, 0xe5, 0x03, 0x02, 0xe5, -0x01, 0xe5, 0x0b, 0x09, 0x01, 0x09, 0x07, 0x01, -0x02, 0x01, 0xe5, 0x02, 0x09, 0x01, 0x07, 0x06, -0x01, 0xe5, 0x02, 0x02, 0x0e, 0x05, 0x05, 0x02, -0x02, 0xe5, 0x0c, 0x09, 0x01, 0x07, 0x09, 0x01, -0xe6, 0x01, 0xe5, 0xe5, 0x0a, 0x01, 0x07, 0x05, -0xe5, 0x03, 0x03, 0xe6, 0x0a, 0x05, 0xe5, 0x08, -0x03, 0xe5, 0x07, 0x13, 0x09, 0xe5, 0x04, 0x04, -0x04, 0x02, 0x0b, 0x09, 0x09, 0x02, 0x1a, 0xe9, -0x0b, 0x13, 0x04, 0x0a, 0x01, 0xe5, 0x07, 0xe6, -0x08, 0xe6, 0x06, 0xe6, 0x03, 0x20, 0x01, 0xe7, -0x0d, 0x09, 0x09, 0x06, 0x02, 0xe5, 0x07, 0x06, -0x04, 0x09, 0x04, 0x01, 0x02, 0xe5, 0xe5, 0x05, -0x09, 0x0d, 0x04, 0x27, 0x0c, 0x08, 0xe5, 0x0a, -0x09, 0x1d, 0x08, 0x01, 0xe5, 0xe5, 0x2e, 0x0b, -0x09, 0x0b, 0x1b, 0x08, 0x01, 0x01, 0x01, 0x1e, -0x0c, 0x01, 0xe5, 0x05, 0x01, 0xe5, 0x07, 0x01, -0x06, 0xe5, 0xe5, 0x08, 0x01, 0x16, 0x01, 0x09, -0xe6, 0x19, 0x0a, 0x01, 0x03, 0x01, 0x01, 0x02, -0x01, 0xe5, 0xe7, 0x06, 0x01, 0xe5, 0x05, 0x01, -0xe5, 0x08, 0xe5, 0xe5, 0x1e, 0x01, 0xe6, 0x07, -0x0c, 0xe5, 0x05, 0x08, 0x03, 0x01, 0x09, 0x06, -0x02, 0x01, 0x07, 0x01, 0x04, 0x01, 0x04, 0x1f, -0x03, 0xe6, 0x12, 0xe7, 0x06, 0x09, 0xe6, 0xe5, -0x03, 0xe7, 0xe5, 0x02, 0xe5, 0xe5, 0x01, 0x01, -0x04, 0xe7, 0xe5, 0x02, 0xe7, 0x05, 0x02, 0x08, -0xe5, 0x07, 0xe5, 0x06, 0xe8, 0x0f, 0x03, 0x01, -0x08, 0x01, 0x01, 0x06, 0x03, 0xe5, 0x02, 0xe6, -0xe6, 0x09, 0xe5, 0x04, 0xe5, 0xe5, 0x09, 0x22, -0xe5, 0xe5, 0x0f, 0x04, 0xe5, 0x08, 0xe5, 0xe5, -0x04, 0xe5, 0x06, 0x01, 0xe5, 0xe6, 0x04, 0x02, -0x01, 0x04, 0xe7, 0xe5, 0x03, 0xe6, 0x02, 0x05, -0x1b, 0x01, 0x01, 0x15, 0x01, 0x07, 0x09, 0x09, -0x01, 0x01, 0x03, 0xe7, 0xe6, 0xe6, 0x03, 0x03, -0x03, 0x01, 0xe5, 0x05, 0x01, 0xe5, 0x1a, 0xe5, -0x01, 0x10, 0x02, 0x03, 0x05, 0xe5, 0x06, 0xe6, -0x01, 0x02, 0x01, 0xe6, 0x01, 0x01, 0xe5, 0xe7, -0x03, 0x01, 0xe5, 0x01, 0xe5, 0x01, 0x01, 0xe5, -0x02, 0x07, 0xe6, 0x1c, 0xe5, 0x01, 0x0d, 0x01, -0xe5, 0x05, 0x02, 0x09, 0x07, 0x01, 0x12, 0x01, -0xe5, 0x05, 0xe5, 0xe5, 0x1d, 0x0b, 0xe5, 0xe5, -0xe5, 0x08, 0xe5, 0x02, 0x02, 0x01, 0x03, 0x03, -0x01, 0x07, 0x01, 0x07, 0x01, 0x07, 0x01, 0x04, -0x01, 0x02, 0x01, 0x01, 0x05, 0x01, 0x01, 0x05, -0x01, 0x01, 0x05, 0x01, 0x07, 0x01, 0x0b, 0x02, -0x0b, 0x09, 0x01, 0x09, 0x0f, 0x05, 0xe5, 0x09, -0xe5, 0x06, 0x03, 0x08, 0x08, 0x15, 0x03, 0x01, -0xe5, 0x06, 0x15, 0x17, 0x07, 0x02, 0x02, 0x09, -0xe5, 0x0d, 0x01, 0x05, 0x12, 0x03, 0xe5, 0x02, -0x0f, 0xe5, 0x05, 0x0b, 0xe5, 0x05, 0x06, 0x08, -0x03, 0x15, 0x0e, 0x04, 0x08, 0x04, 0x01, 0xe6, -0x08, 0x12, 0x03, 0x01, 0x07, 0x01, 0x04, 0x02, -0x01, 0xe5, 0x07, 0xe7, 0x0e, 0xe7, 0x03, 0x12, -0xe5, 0x07, 0x01, 0xe5, 0xe5, 0x0a, 0x05, 0x0d, -0x01, 0x01, 0x08, 0x01, 0x07, 0xe5, 0x06, 0xe5, -0xe5, 0x02, 0x0e, 0x27, 0xe6, 0x07, 0x09, 0x04, -0xe5, 0x02, 0xe5, 0x0c, 0xe5, 0x01, 0x0a, 0x03, -0xe5, 0x01, 0x04, 0x0a, 0x03, 0x05, 0x11, 0x09, -0xe5, 0x02, 0x24, 0x16, 0x03, 0x02, 0x01, 0x0a, -0x05, 0x01, 0x1d, 0x05, 0xe5, 0xe5, 0x02, 0x22, -0x09, 0x0e, 0xe5, 0x03, 0x03, 0x06, 0x07, 0x21, -0xe5, 0x01, 0x08, 0x0f, 0x0e, 0x0b, 0x0a, 0xe5, -0x04, 0x02, 0x01, 0x09, 0x03, 0x19, 0x01, 0x06, -0x02, 0x13, 0x04, 0x19, 0xe5, 0x04, 0x02, 0x02, -0x19, 0x1b, 0x05, 0xe7, 0x04, 0x22, 0x12, 0x09, -0xe5, 0x05, 0x0e, 0x21, 0x06, 0x03, 0x1a, 0x1d, -0x03, 0x05, 0x01, 0xe5, 0x11, 0x04, 0x13, 0x01, -0x05, 0x0b, 0x13, 0x1c, 0x08, 0x01, 0x26, 0x05, -0xe6, 0xe5, 0xe5, 0x17, 0xe6, 0xe5, 0xe5, 0x02, -0xe5, 0x15, 0x01, 0x05, 0xe5, 0x01, 0xe5, 0x03, -0xe5, 0x0e, 0x05, 0xe5, 0x01, 0x02, 0xe5, 0x09, -0xe8, 0xe5, 0x01, 0x01, 0x15, 0x02, 0xe5, 0x01, -0xe5, 0x01, 0x02, 0xe5, 0x10, 0xe5, 0x03, 0xe5, -0x11, 0xe5, 0x07, 0x06, 0x01, 0xe5, 0x0a, 0x01, -0x02, 0xe5, 0x01, 0x04, 0x05, 0xe5, 0xe5, 0xe5, -0x12, 0x1d, 0x01, 0x01, 0x01, 0xe5, 0x03, 0x01, -0x05, 0x01, 0x07, 0x09, 0x03, 0x07, 0x08, 0x02, -0x0a, 0x01, 0x11, 0x1f, 0x01, 0x09, 0x07, 0x01, -0x07, 0x09, 0x0d, 0x03, 0x02, 0xe5, 0x08, 0x01, -0x0a, 0x01, 0x09, 0x06, 0xe5, 0xe5, 0x12, 0x01, -0x03, 0x02, 0xe5, 0xe6, 0x05, 0x01, 0x06, 0xe5, -0x08, 0x0a, 0x06, 0x01, 0xe5, 0x01, 0x06, 0x02, -0x04, 0x05, 0x01, 0x01, 0x05, 0x03, 0x03, 0xe6, -0xe5, 0xe5, 0x10, 0x03, 0x05, 0x01, 0x07, 0x01, -0x01, 0x02, 0xe7, 0x02, 0x05, 0x03, 0x06, 0x02, -0x02, 0x01, 0x01, 0xe5, 0x0b, 0x01, 0x07, 0x01, -0x04, 0x04, 0x05, 0x01, 0x01, 0x13, 0x01, 0x07, -0x01, 0x07, 0x01, 0x07, 0x06, 0x02, 0x0a, 0x04, -0x02, 0xe6, 0x0c, 0x01, 0x07, 0x01, 0x04, 0xe5, -0xe5, 0x08, 0x01, 0x13, 0x01, 0x07, 0x01, 0x07, -0x01, 0x07, 0x05, 0xe6, 0xe5, 0x0f, 0xe5, 0xe7, -0x07, 0xe5, 0x13, 0x2e, 0x02, 0x02, 0x06, 0x22, -0x02, 0x4f, 0x09, 0x01, 0x1b, 0xe5, 0x01, 0xe5, -0x0a, 0x02, 0x09, 0x06, 0x02, 0x09, 0x09, 0x04, -0x01, 0x04, 0x02, 0x01, 0x01, 0x02, 0x04, 0xe6, -0x01, 0x03, 0x05, 0x09, 0x0d, 0xe5, 0xe7, 0x01, -0x06, 0x02, 0x12, 0xe5, 0x1c, 0x0b, 0x2c, 0x04, -0xe6, 0x08, 0x13, 0x1d, 0x0b, 0x32, 0x01, 0x01, -0x0f, 0x10, 0x02, 0x1f, 0x07, 0x01, 0xe5, 0x05, -0x01, 0x04, 0x1d, 0xe5, 0x01, 0x0d, 0x02, 0x10, -0x02, 0x19, 0x02, 0x02, 0x06, 0x01, 0xe5, 0x04, -0xe5, 0xe6, 0x24, 0x0f, 0x04, 0x0e, 0x18, 0x01, -0x04, 0x07, 0x01, 0x09, 0x21, 0xe5, 0x01, 0xe5, -0x0c, 0x05, 0xe5, 0xe5, 0x07, 0xe6, 0x04, 0xe5, -0xe5, 0x06, 0xe6, 0x07, 0xe5, 0x01, 0x05, 0x02, -0xe5, 0x04, 0x02, 0xe5, 0x06, 0xe5, 0x07, 0xe5, -0x07, 0xe5, 0x05, 0xe6, 0xe6, 0x0e, 0x03, 0xe5, -0x04, 0xe5, 0x06, 0x1d, 0x01, 0xe6, 0x04, 0x01, -0x07, 0x01, 0x0a, 0xe5, 0x15, 0xe5, 0x01, 0x0d, -0x08, 0x0a, 0x05, 0x02, 0x09, 0x0c, 0x08, 0xe5, -0xe5, 0x06, 0x01, 0x22, 0x03, 0x0f, 0x05, 0xe5, -0x0b, 0x04, 0xe6, 0x06, 0x01, 0x0c, 0x01, 0x03, -0x01, 0xe6, 0xe5, 0x02, 0x01, 0x01, 0x01, 0x22, -0xe6, 0xe5, 0x0c, 0x06, 0x05, 0x06, 0x02, 0x02, -0x06, 0x03, 0x0e, 0x02, 0x02, 0xe5, 0x01, 0x01, -0x07, 0x01, 0x0a, 0x1a, 0xe5, 0x40, 0xe5, 0xe5, -0x19, 0x01, 0xe5, 0x05, 0x01, 0xe5, 0x0b, 0x01, -0x01, 0xe5, 0x10, 0x01, 0x07, 0x01, 0x07, 0x01, -0x07, 0x01, 0x07, 0x01, 0x09, 0x01, 0xe5, 0x04, -0xe7, 0x06, 0x01, 0x03, 0x03, 0x01, 0x07, 0x01, -0x0b, 0x01, 0xe5, 0x22, 0x0d, 0x01, 0xe5, 0x08, -0x03, 0x07, 0x02, 0xe5, 0x18, 0x01, 0x0a, 0x05, -0xe8, 0x0a, 0x16, 0xe5, 0x21, 0xe5, 0x01, 0x26, -0x06, 0x01, 0x01, 0xe5, 0x30, 0x06, 0x03, 0x02, -0x0d, 0x0b, 0x24, 0xe5, 0x03, 0x2c, 0x05, 0x06, -0x03, 0x04, 0x02, 0xe5, 0x01, 0x05, 0x01, 0x18, -0x09, 0xe8, 0x04, 0x05, 0x07, 0x0b, 0x1f, 0xe5, -0x0f, 0x06, 0x03, 0x1b, 0x01, 0x03, 0xe5, 0xe5, -0x19, 0x07, 0x0b, 0x09, 0x03, 0xe6, 0x07, 0x04, -0x03, 0x01, 0x24, 0x03, 0x01, 0x03, 0x1a, 0x17, -0x06, 0x12, 0x1c, 0x0a, 0xe6, 0xe5, 0x05, 0x0e, -0x06, 0x01, 0x07, 0x09, 0x0d, 0xe5, 0x10, 0x16, -0x12, 0xe7, 0x12, 0x02, 0x09, 0x09, 0x08, 0xe5, -0x09, 0xe5, 0x08, 0x04, 0x2c, 0xe6, 0x27, 0x13, -0xe5, 0xe6, 0x05, 0x33, 0x02, 0x09, 0x01, 0x05, -0x01, 0x09, 0xe5, 0x07, 0x1b, 0x02, 0x06, 0x09, -0x22, 0xe8, 0x31, 0x10, 0x08, 0xe5, 0x07, 0xe5, -0x05, 0x0e, 0x0b, 0xe5, 0xe7, 0x07, 0x15, 0x10, -0x0e, 0x02, 0xe5, 0x09, 0x09, 0x17, 0x0a, 0xe5, -0x01, 0xe6, 0x48, 0x09, 0x22, 0xe5, 0x01, 0xe6, -0x01, 0x01, 0x46, 0xe6, 0x01, 0x04, 0x1f, 0x01, -0x02, 0x03, 0x04, 0x43, 0x01, 0x02, 0x04, 0x01, -0x02, 0x0e, 0xe5, 0xe5, 0xe5, 0x08, 0x04, 0x02, -0xe5, 0x01, 0x45, 0x04, 0x09, 0x0e, 0x02, 0x01, -0x0b, 0x02, 0xe6, 0xe5, 0x48, 0x01, 0x01, 0x07, -0x11, 0x14, 0x01, 0x02, 0x48, 0x01, 0x01, 0x05, -0x03, 0x13, 0x09, 0x02, 0x02, 0xe6, 0x4b, 0x09, -0x04, 0x0c, 0x01, 0x08, 0x04, 0xe6, 0x01, 0x31, -0xe5, 0x19, 0x09, 0x05, 0x0b, 0x01, 0x10, 0xe6, -0x08, 0x47, 0x02, 0x06, 0x02, 0x15, 0x06, 0xe7, -0x09, 0x01, 0x45, 0xe5, 0x07, 0x1d, 0x03, 0xe5, -0x07, 0x05, 0x09, 0x09, 0x09, 0x09, 0x0b, 0x04, -0x01, 0x02, 0x09, 0x05, 0x03, 0x09, 0x0d, 0x01, -0xe7, 0x01, 0x47, 0x09, 0x22, 0x04, 0xe6, 0x46, -0x09, 0x28, 0xe5, 0xe6, 0x42, 0x06, 0x02, 0x07, -0x01, 0x20, 0x03, 0x01, 0x43, 0xe5, 0x08, 0x08, -0xe5, 0x20, 0x03, 0xe5, 0x41, 0x06, 0x07, 0x02, -0x28, 0x15, 0xe5, 0x07, 0xe5, 0x07, 0xe5, 0x07, -0xe5, 0x07, 0xe5, 0x03, 0x05, 0xe5, 0x01, 0x05, -0xe5, 0x01, 0x05, 0xe5, 0x07, 0xe5, 0x07, 0xe5, -0x06, 0xe6, 0xe5, 0x2d, 0xe5, 0x12, 0x13, 0xe6, -0x1f, 0x02, 0xe5, 0x42, 0x11, 0x01, 0x22, 0xe5, -0x01, 0x43, 0x13, 0x21, 0xe7, 0xe5, 0x2d, 0x14, -0x11, 0x02, 0x1c, 0xe5, 0x03, 0x02, 0x4b, 0x01, -0xe5, 0x05, 0x23, 0xe7, 0xe5, 0x10, 0x01, 0x07, -0x01, 0x07, 0x01, 0x07, 0xe6, 0x06, 0x01, 0x09, -0x01, 0x02, 0xe5, 0x02, 0x01, 0x04, 0x02, 0x01, -0x07, 0x01, 0x07, 0x01, 0x01, 0x03, 0xe5, 0x06, -0x2f, 0x2e, 0x1c, 0x02, 0xe5, 0x1e, 0x28, 0x1e, -0x10, 0xe6, 0xe6, 0x1a, 0x14, 0x0e, 0x09, 0xe5, -0x2a, 0x03, 0x02, 0xe6, 0x08, 0x14, 0x19, 0x05, -0x07, 0x03, 0xe6, 0x06, 0x06, 0x17, 0x06, 0xe7, -0x3e, 0x0b, 0x0b, 0x22, 0xe9, 0x07, 0x09, 0x09, -0x10, 0x09, 0x04, 0x01, 0x04, 0xe6, 0x27, 0x0a, -0x02, 0xe5, 0x29, 0x14, 0x0a, 0x2a, 0x04, 0x02, -0xe5, 0x0a, 0x12, 0x20, 0x3a, 0xe5, 0xe6, 0x0a, -0x07, 0x10, 0x18, 0x01, 0x05, 0x0b, 0x08, 0x19, -0x06, 0xe5, 0xe5, 0x1b, 0x13, 0x0e, 0xe5, 0x0d, -0x09, 0x21, 0x02, 0x32, 0x1c, 0x2a, 0x01, 0x01, -0x0a, 0x2f, 0x15, 0x0b, 0x1c, 0xe5, 0xe7, 0x09, -0x27, 0x41, 0x06, 0xe9, 0x4f, 0xe5, 0xe5, 0x02, -0xe5, 0x1c, 0xe5, 0x01, 0x01, 0x02, 0x01, 0x4c, -0xe5, 0x21, 0x01, 0x03, 0xe5, 0xe5, 0x03, 0x0e, -0xe5, 0x01, 0x01, 0x17, 0xe5, 0x01, 0x01, 0x1d, -0x03, 0x1b, 0x05, 0x01, 0xe5, 0x01, 0x11, 0xe5, -0xe5, 0xe5, 0x17, 0xe5, 0xe5, 0xe5, 0x3e, 0x02, -0xe8, 0x54, 0x04, 0x03, 0x1c, 0x02, 0x02, 0x18, -0x1d, 0x20, 0x01, 0xe6, 0x17, 0x03, 0x01, 0xe6, -0x15, 0x01, 0x1b, 0x01, 0x1d, 0x23, 0xe5, 0x01, -0xe5, 0x16, 0x01, 0x1b, 0x01, 0x22, 0x1f, 0x03, -0x09, 0x02, 0x4e, 0x1e, 0xe8, 0xe5, 0x59, 0x01, -0x1d, 0xe7, 0x0d, 0x09, 0x09, 0x09, 0x09, 0x0b, -0x09, 0x09, 0x03, 0x05, 0x09, 0x0d, 0x01, 0x01, -0xe5, 0x01, 0x74, 0x04, 0xe6, 0x7a, 0xe5, 0xe5, -0x79, 0xe5, 0xe6, 0x53, 0x03, 0xe5, 0x1f, 0xe9, -0x53, 0x01, 0x21, 0xe5, 0x01, 0xe5, 0x08, 0x0b, -0xe5, 0x07, 0xe5, 0x07, 0xe5, 0x07, 0xe5, 0x07, -0xe5, 0x09, 0xe5, 0x07, 0xe6, 0xe5, 0x04, 0xe5, -0x07, 0xe5, 0x07, 0xe5, 0x05, 0x01, 0x02, 0x55, -0x01, 0x26, 0x55, 0x01, 0x22, 0x03, 0x40, 0x14, -0x01, 0x23, 0x02, 0x04, 0x50, 0x01, 0x02, 0x22, -0xe5, 0x01, 0x0e, 0x43, 0x1b, 0x0b, 0xe5, 0x02, -0xe5, 0x0b, 0x01, 0x07, 0x01, 0x07, 0x01, 0xe5, -0x05, 0x01, 0x07, 0x01, 0x04, 0x04, 0x01, 0x01, -0x05, 0x01, 0x07, 0x01, 0x01, 0x04, 0xe5, 0xe5, -0x06, 0x01, 0x02, 0x05, 0x04, 0xe5, 0x53, 0x01, -0x27, 0xe5, 0x72, 0x04, 0xe7, 0xe5, 0x2f, 0x0e, -0xe5, 0x11, 0x0a, 0x09, 0x11, 0x03, 0xe5, 0x1b, -0x1b, 0x1b, 0x01, 0x01, 0x14, 0x0e, 0xe5, 0x1c, -0x13, 0x07, 0x05, 0xe5, 0x16, 0x15, 0x0b, 0xe5, -0x01, 0xe5, 0x0c, 0xe5, 0xe5, 0x17, 0x02, 0x0a, -0x06, 0xe5, 0x05, 0x0d, 0x1a, 0x0a, 0x01, 0xe5, -0x12, 0x17, 0xe5, 0x11, 0x0f, 0x17, 0x12, 0x01, -0xe6, 0x1b, 0x10, 0x11, 0x19, 0x20, 0xe5, 0x01, -0x1e, 0x20, 0x3e, 0x3f, 0x24, 0x19, 0x02, 0x0a, -0x01, 0x30, 0xe5, 0xe5, 0x28, 0x0d, 0xe5, 0xe5, -0x0e, 0x33, 0x2c, 0x08, 0x02, 0xe6, 0x0e, 0x17, -0x1a, 0x37, 0xe5, 0xe6, 0x02, 0x0b, 0xe5, 0x07, -0xe5, 0x07, 0xe5, 0x05, 0xe7, 0x07, 0xe5, 0x06, -0xe8, 0x05, 0xe7, 0x05, 0xe7, 0x07, 0xe5, 0x07, -0xe5, 0x0b, 0xe6, 0xe6, 0x0f, 0x09, 0x09, 0x07, -0x01, 0x09, 0x09, 0x01, 0x05, 0x01, 0x01, 0x07, -0x01, 0x09, 0x07, 0x01, 0x01, 0x0b, 0xe6, 0xe5, -0x0e, 0x0a, 0x03, 0x04, 0xe5, 0x07, 0x0a, 0x07, -0x02, 0x01, 0x02, 0x04, 0x09, 0x05, 0xe5, 0x01, -0x04, 0x04, 0x10, 0x01, 0x11, 0x4b, 0x1c, 0xe6, -0xe5, 0x18, 0x09, 0x04, 0x06, 0x07, 0x01, 0x09, -0x09, 0x09, 0x09, 0x09, 0x02, 0x0b, 0x02, 0xe5, -0x0c, 0xe6, 0x05, 0xe6, 0x01, 0x05, 0xe5, 0x07, -0xe6, 0x06, 0xe5, 0x09, 0xe5, 0x07, 0xe5, 0x07, -0xe5, 0x05, 0x01, 0xe5, 0x07, 0xe5, 0x06, 0x04, -0x03, 0x02, 0x03, 0x09, 0x09, 0x01, 0x07, 0x01, -0x07, 0x09, 0x01, 0x05, 0x03, 0x09, 0x09, 0x09, -0x09, 0x11, 0x02, 0x0e, 0xe5, 0x07, 0x09, 0x09, -0xe5, 0x07, 0x0b, 0x02, 0x06, 0xe5, 0xe5, 0x05, -0xe5, 0xe5, 0x05, 0xe5, 0xe5, 0x05, 0xe5, 0xe5, -0x0e, 0xe5, 0x0d, 0x09, 0x09, 0x09, 0x09, 0x0b, -0x09, 0x09, 0x09, 0x09, 0x0f, 0xe5, 0x01, 0x12, -0x06, 0x09, 0xe5, 0x11, 0x05, 0x05, 0xe5, 0x37, -0xe5, 0x0d, 0x06, 0x02, 0x09, 0x09, 0x09, 0x08, -0x02, 0x09, 0x09, 0x09, 0x09, 0x0f, 0xe8, 0x3e, -0x1d, 0x20, 0x10, 0x09, 0x09, 0x09, 0x09, 0x0b, -0x09, 0x09, 0x09, 0x09, 0x0d, 0x02, 0xe5, 0x03, -0x04, 0x1f, 0x33, 0x20, 0x3f, 0x3b, 0xe5, 0xe5, -0x17, 0x1d, 0x08, 0x02, 0x33, 0x05, 0xe6, 0x03, -0x13, 0x06, 0x02, 0x13, 0x06, 0x0b, 0x16, 0x06, -0x13, 0x01, 0xe5, 0x03, 0x4c, 0x0c, 0x1b, 0xe5, -0x01, 0x17, 0x08, 0x14, 0x08, 0xe5, 0x1e, 0x13, -0x06, 0x01, 0xe6, 0x20, 0x1d, 0x34, 0x06, 0xe5, -0xe5, 0x48, 0x15, 0x07, 0x12, 0xe8, 0x13, 0x02, -0xe5, 0x04, 0xe8, 0x04, 0x09, 0x02, 0xe5, 0x04, -0xe6, 0x08, 0xe6, 0x06, 0x09, 0x02, 0xe5, 0x04, -0xe6, 0x06, 0x09, 0xe8, 0x0d, 0xe5, 0x06, 0xe6, -0x05, 0xe7, 0x08, 0x07, 0xe6, 0x05, 0xe5, 0x01, -0xe5, 0x05, 0x02, 0x09, 0x07, 0xe6, 0x05, 0x02, -0x0e, 0xe8, 0x25, 0x18, 0x3b, 0x01, 0xe5, 0x14, -0x05, 0x03, 0x09, 0x01, 0x07, 0x05, 0x03, 0x07, -0x03, 0x01, 0x03, 0x05, 0x03, 0x0d, 0x01, 0x03, -0x0c, 0x01, 0xe6, 0x0a, 0x03, 0x02, 0x01, 0x06, -0xe5, 0x07, 0x02, 0x03, 0x03, 0x01, 0x07, 0x08, -0x0b, 0x04, 0x05, 0x03, 0x0e, 0x04, 0xe9, 0x03, -0xe6, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, -0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, -0xff, 0xff, 0xff, 0xff, diff --git a/board/esd/cpci405/fpgadata_cpci405ab.c b/board/esd/cpci405/fpgadata_cpci405ab.c deleted file mode 100644 index acbc696..0000000 --- a/board/esd/cpci405/fpgadata_cpci405ab.c +++ /dev/null @@ -1,2569 +0,0 @@ -0x1f, 0x8b, 0x08, 0x08, 0x73, 0xed, 0xb5, 0x40, -0x00, 0x03, 0x63, 0x70, 0x63, 0x69, 0x34, 0x30, -0x35, 0x5f, 0x32, 0x5f, 0x30, 0x35, 0x2e, 0x62, -0x69, 0x74, 0x00, 0xed, 0xbd, 0x0b, 0x74, 0x1c, -0xd5, 0x95, 0x36, 0xba, 0xeb, 0x54, 0xb5, 0x54, -0xea, 0x6e, 0xa9, 0x4b, 0x2d, 0x89, 0x08, 0xfc, -0xa0, 0xd4, 0x92, 0x8d, 0xec, 0xb4, 0xe4, 0x76, -0xdb, 0x18, 0x23, 0x84, 0x54, 0x6e, 0x09, 0xa7, -0x01, 0x83, 0x15, 0x1e, 0x09, 0x33, 0xc3, 0xcd, -0xb4, 0xc1, 0x99, 0xf1, 0xcc, 0x72, 0x66, 0x84, -0x93, 0x95, 0x31, 0x24, 0x93, 0x39, 0x7a, 0xd8, -0x16, 0x96, 0xc1, 0x6d, 0xe3, 0x99, 0x98, 0xc0, -0xe5, 0x6f, 0x3f, 0x48, 0x0c, 0x71, 0xf2, 0xb7, -0x65, 0xc0, 0xe2, 0x31, 0x50, 0x12, 0xc2, 0xb4, -0x1f, 0xd8, 0x0a, 0xf0, 0xcf, 0x98, 0xc7, 0x98, -0x36, 0x51, 0x88, 0x00, 0x01, 0xf2, 0xe3, 0x27, -0x32, 0x96, 0xad, 0xbb, 0xcf, 0x39, 0x55, 0xd5, -0x2d, 0xc9, 0x64, 0x32, 0x6b, 0xcd, 0xba, 0x8f, -0x75, 0xe9, 0xac, 0x95, 0xec, 0x94, 0x8e, 0xab, -0xcf, 0xa9, 0x53, 0x67, 0x7f, 0xfb, 0xdb, 0xfb, -0x3b, 0xa7, 0x21, 0xcf, 0x37, 0x2c, 0xfe, 0x03, -0x20, 0x2d, 0x83, 0xc2, 0xbb, 0x9b, 0xef, 0xfe, -0x9b, 0xf9, 0xa1, 0x2b, 0xff, 0x32, 0xfc, 0x97, -0xa1, 0x2b, 0xab, 0xff, 0xee, 0xee, 0xe5, 0x70, -0x17, 0xb8, 0xc3, 0xdf, 0x9f, 0x17, 0xfa, 0xc1, -0x3d, 0x73, 0xe7, 0xcf, 0x87, 0xbb, 0xc1, 0x13, -0x0e, 0x85, 0xe6, 0xcf, 0x09, 0x5d, 0x39, 0x27, -0x7c, 0x15, 0x2c, 0x87, 0xbc, 0xb9, 0x57, 0xd6, -0xcc, 0x9b, 0x5b, 0x13, 0x5a, 0x08, 0xdf, 0x05, -0xd8, 0xd9, 0x3c, 0x86, 0x9f, 0x27, 0x1f, 0xbe, -0xfd, 0xaf, 0x42, 0x40, 0x25, 0x00, 0xc8, 0x0d, -0x49, 0x31, 0xf6, 0xbf, 0x6a, 0x48, 0xd2, 0x25, -0xa0, 0xf5, 0x55, 0x21, 0x30, 0xd9, 0xff, 0x07, -0xeb, 0xef, 0x79, 0x21, 0xd0, 0xb3, 0xff, 0xbf, -0x14, 0x02, 0x03, 0x9a, 0xa0, 0xe2, 0x6e, 0xf0, -0x87, 0xe0, 0xcb, 0x3e, 0x12, 0x28, 0x94, 0x1b, -0x7f, 0x4a, 0x1b, 0xf2, 0xa5, 0x4d, 0xd8, 0xe7, -0x4f, 0x6f, 0xe3, 0xff, 0x63, 0x4d, 0x94, 0xff, -0xae, 0x36, 0xfc, 0xbf, 0xc7, 0xfc, 0x50, 0x8c, -0xa6, 0xc4, 0x9e, 0x44, 0x31, 0xb8, 0xc6, 0x1b, -0xf5, 0x7d, 0xfc, 0x3e, 0xa6, 0xeb, 0x82, 0x31, -0x46, 0xeb, 0x0e, 0xfb, 0x4e, 0xc9, 0xaf, 0x47, -0x8e, 0x42, 0x67, 0xff, 0xd2, 0xb3, 0x72, 0xd0, -0x3c, 0x0a, 0xf3, 0x52, 0xdf, 0x1b, 0x69, 0x18, -0x86, 0x66, 0xde, 0x71, 0x6d, 0xc8, 0xfb, 0x7c, -0x7b, 0xd5, 0x6b, 0x9e, 0x93, 0x24, 0x4d, 0x37, -0xf6, 0x95, 0xf7, 0x79, 0x36, 0x93, 0x6b, 0x8d, -0x8d, 0xfd, 0x5f, 0xff, 0xdf, 0x4b, 0xba, 0x49, -0x5a, 0xe1, 0x0f, 0xaf, 0xc3, 0x75, 0xb8, 0x63, -0x2f, 0x04, 0x53, 0x9e, 0x50, 0xdc, 0xec, 0x68, -0x33, 0x2a, 0x53, 0xd8, 0x66, 0x09, 0x6d, 0x83, -0x4a, 0x53, 0x0d, 0x45, 0xde, 0x97, 0xf8, 0x7d, -0xcc, 0xc2, 0xdd, 0xca, 0xf3, 0x50, 0x6d, 0x7a, -0x92, 0xe4, 0x03, 0xe8, 0x24, 0x01, 0xd3, 0x13, -0x9f, 0xbd, 0x12, 0x3c, 0x78, 0x45, 0x4d, 0x92, -0x61, 0x25, 0xc6, 0x3b, 0x5d, 0x38, 0x04, 0xe7, -0x48, 0x9d, 0xe9, 0x4b, 0xca, 0xbf, 0x85, 0x43, -0x50, 0x63, 0xfa, 0x34, 0x79, 0x25, 0x74, 0xa2, -0x31, 0x35, 0x19, 0xe8, 0x57, 0xf8, 0x7d, 0xd2, -0xd2, 0x0b, 0x30, 0x46, 0xea, 0xcd, 0x8d, 0xc3, -0x0d, 0xc3, 0xa5, 0xcc, 0xf0, 0xf5, 0xcb, 0xbb, -0xe1, 0x0f, 0x70, 0xb5, 0x79, 0xf9, 0xb0, 0x3c, -0x02, 0xfc, 0x3e, 0x86, 0xb6, 0x1b, 0xce, 0x49, -0x75, 0x66, 0x30, 0x29, 0x97, 0xc1, 0x3b, 0x6a, -0xd8, 0xf4, 0x26, 0xe5, 0xc3, 0xea, 0x21, 0x8d, -0xdf, 0xb9, 0x5f, 0xd1, 0x59, 0x9b, 0x94, 0x2b, -0x08, 0xcf, 0xc3, 0x1c, 0xb3, 0x74, 0x38, 0x37, -0x56, 0xfc, 0xea, 0xe1, 0x72, 0x53, 0x8d, 0x93, -0x51, 0xf5, 0x28, 0x9d, 0xc2, 0x7a, 0x78, 0x0a, -0x5f, 0x20, 0xf6, 0x5d, 0xae, 0x25, 0x80, 0xe3, -0xc2, 0x51, 0x04, 0x74, 0xf2, 0x50, 0xaf, 0x6e, -0x96, 0x86, 0xc8, 0x61, 0xd8, 0x01, 0xde, 0x1e, -0x4f, 0x88, 0x8c, 0xe0, 0xf3, 0xc4, 0x8f, 0x2e, -0x4d, 0x5f, 0xb4, 0x8f, 0x56, 0xa5, 0xd5, 0xd5, -0x64, 0x15, 0xb4, 0x6d, 0x59, 0x96, 0x56, 0xff, -0x2c, 0x70, 0x1c, 0xf0, 0xca, 0xa0, 0xe7, 0x3e, -0x72, 0x4c, 0xdc, 0x27, 0xaa, 0x16, 0xd0, 0xd3, -0x50, 0x3b, 0xa8, 0x3e, 0x1b, 0x20, 0xbd, 0x6f, -0x48, 0xe1, 0xc1, 0xe0, 0x14, 0xf9, 0x48, 0xde, -0x6f, 0x1f, 0xaf, 0x3d, 0xe1, 0xab, 0x91, 0x5f, -0x17, 0x2f, 0x8e, 0x31, 0xed, 0x05, 0x63, 0x0c, -0xea, 0xdf, 0xf4, 0xe1, 0xb8, 0x60, 0x4c, 0xad, -0xff, 0x37, 0xdf, 0x26, 0x79, 0x14, 0x0e, 0x69, -0xd7, 0xf4, 0x5e, 0x8e, 0x7d, 0xf6, 0xf3, 0x71, -0xed, 0x72, 0x7d, 0x8a, 0x8f, 0xa5, 0xee, 0x4d, -0xfa, 0x54, 0x5b, 0x1a, 0xce, 0x41, 0x78, 0xb8, -0x63, 0x2b, 0xf9, 0xac, 0xfd, 0xe3, 0x9e, 0xf0, -0x01, 0x1c, 0xd7, 0x47, 0x62, 0xbe, 0xa2, 0x85, -0x8f, 0xc2, 0x3a, 0xa5, 0x2a, 0xa5, 0xfe, 0x80, -0xf4, 0xc3, 0xbe, 0x70, 0x59, 0x4a, 0x6d, 0x22, -0xb5, 0x46, 0x5b, 0xa8, 0xec, 0xa0, 0xa7, 0x99, -0xbc, 0x2e, 0x9e, 0xb3, 0x09, 0x8f, 0xc1, 0x4f, -0x69, 0x30, 0xad, 0xde, 0x17, 0x78, 0x5d, 0xdf, -0x4b, 0x13, 0x69, 0xf7, 0xea, 0xc8, 0xf4, 0xd4, -0x2f, 0x92, 0x65, 0x83, 0x9e, 0xd5, 0x64, 0x18, -0xf8, 0xf3, 0x89, 0x16, 0x1f, 0x86, 0x87, 0x70, -0xec, 0xd1, 0x10, 0x39, 0xd0, 0xbe, 0x17, 0x74, -0xd3, 0xad, 0x91, 0x25, 0xd0, 0x06, 0x31, 0xd3, -0x13, 0xf2, 0xbf, 0x2e, 0xe6, 0x7d, 0xb0, 0x70, -0x17, 0xbc, 0x0d, 0x75, 0x74, 0x49, 0x42, 0x3e, -0x0b, 0xa7, 0x20, 0x4c, 0x1f, 0x4c, 0xb4, 0x55, -0xc2, 0x47, 0x68, 0x5c, 0x9e, 0x90, 0xbf, 0x10, -0xdf, 0x15, 0x85, 0x34, 0x0c, 0x42, 0x2d, 0xf8, -0xa8, 0x9c, 0x56, 0x47, 0x8c, 0x3a, 0x90, 0xa8, -0x9c, 0x80, 0x11, 0xa8, 0x83, 0xa5, 0x54, 0x7e, -0x1d, 0xf8, 0x7d, 0x54, 0x6d, 0x00, 0xce, 0xc2, -0x4f, 0x0c, 0x6f, 0xbc, 0xa8, 0x02, 0xde, 0xd2, -0xc2, 0xc6, 0xd1, 0xb8, 0x3c, 0xa0, 0x9d, 0x85, -0x3a, 0xc3, 0x13, 0x97, 0x7b, 0xc5, 0x77, 0x51, -0x74, 0x13, 0xcf, 0x42, 0xb5, 0x91, 0x1f, 0x2f, -0x5a, 0xae, 0xdc, 0xbf, 0x3d, 0xc0, 0xfe, 0xb4, -0x13, 0x9e, 0xa5, 0xd5, 0x68, 0x90, 0x18, 0x68, -0xac, 0x4d, 0xa9, 0xab, 0x42, 0x62, 0x6d, 0x54, -0x8d, 0x78, 0xf3, 0x1e, 0x26, 0xac, 0x0d, 0x19, -0x80, 0x67, 0x75, 0xd6, 0x26, 0xb2, 0x5f, 0xcc, -0x85, 0x5a, 0xdc, 0x0e, 0x7b, 0x94, 0x60, 0x34, -0xcf, 0x4f, 0x1a, 0x41, 0xaa, 0xd0, 0xa3, 0x1e, -0x8d, 0xf4, 0xd1, 0x3d, 0x7a, 0x90, 0x19, 0x11, -0xee, 0x46, 0xa0, 0x3b, 0x7f, 0x91, 0x31, 0x02, -0xd5, 0xc5, 0xde, 0x35, 0x72, 0x99, 0x71, 0x07, -0x74, 0x95, 0xf8, 0x5c, 0x77, 0x9f, 0x30, 0x46, -0x48, 0x1d, 0x6c, 0xa4, 0xf2, 0xa7, 0x32, 0x9f, -0xf7, 0xad, 0x25, 0xd8, 0x67, 0xa5, 0xee, 0x3a, -0xdf, 0xa6, 0x79, 0xa3, 0x70, 0x56, 0xab, 0x6b, -0xc4, 0xf7, 0x70, 0xa7, 0xc1, 0x8d, 0xb8, 0xfc, -0x41, 0x4e, 0xb3, 0xe8, 0xcf, 0x00, 0xbc, 0x45, -0xea, 0x22, 0xbe, 0xf8, 0x26, 0x05, 0x7e, 0xa5, -0x2e, 0x88, 0x6c, 0xc0, 0x71, 0x55, 0x9e, 0xd7, -0xeb, 0xae, 0x67, 0x6d, 0xc4, 0x7c, 0x2d, 0xd4, -0xd2, 0xd0, 0x4d, 0xaa, 0xc1, 0x43, 0xdd, 0xba, -0xd6, 0xdd, 0x58, 0x59, 0xaa, 0xb6, 0x12, 0xbc, -0x62, 0x54, 0x6b, 0x1e, 0x4a, 0x8e, 0x88, 0xb1, -0xab, 0xae, 0x3e, 0x7d, 0x13, 0x04, 0x23, 0x1e, -0x7f, 0xab, 0x92, 0xd8, 0x06, 0x15, 0x11, 0x55, -0xdb, 0xde, 0xa7, 0xef, 0xd5, 0x82, 0x8d, 0xd8, -0xe7, 0x5e, 0xb1, 0xbe, 0x4a, 0x4b, 0xf0, 0x69, -0x28, 0xfc, 0x69, 0xec, 0xa4, 0xec, 0x21, 0xac, -0xd8, 0x44, 0x06, 0x14, 0x66, 0xb0, 0xb1, 0x8b, -0xb9, 0x48, 0x14, 0xef, 0x84, 0xb7, 0xa0, 0x6e, -0x91, 0x2f, 0x2e, 0xcd, 0x80, 0x0f, 0x61, 0x81, -0xa1, 0x6c, 0x15, 0xcf, 0x19, 0xaf, 0xc8, 0x83, -0x62, 0x5d, 0x54, 0xc2, 0x4e, 0xfe, 0xe4, 0x71, -0xe9, 0x2d, 0xc7, 0x01, 0x3e, 0x67, 0xf8, 0xb0, -0x0d, 0xf0, 0x2b, 0x71, 0xf9, 0xa0, 0x78, 0x37, -0x2a, 0xb5, 0x04, 0xa4, 0x70, 0x06, 0x7d, 0xb4, -0xa1, 0x4c, 0x19, 0x41, 0xb7, 0xec, 0xc5, 0xc9, -0x85, 0x11, 0xb5, 0x0e, 0xd0, 0x38, 0x68, 0xdd, -0x47, 0xa9, 0x24, 0x6e, 0xa8, 0xa6, 0x9e, 0x04, -0xa9, 0x84, 0xb5, 0xad, 0x01, 0xaa, 0x26, 0xc8, -0x60, 0xf1, 0x8b, 0x46, 0x41, 0x4b, 0x47, 0x82, -0x1c, 0x14, 0x9e, 0xaa, 0xd2, 0xb5, 0x44, 0x91, -0xf1, 0x1d, 0xf3, 0x84, 0xb4, 0x0d, 0xb0, 0x07, -0xf4, 0x1e, 0x37, 0x5b, 0x5f, 0x49, 0xf0, 0x9a, -0xb3, 0x42, 0xd8, 0xc6, 0x5e, 0x5f, 0x34, 0x17, -0xaa, 0x52, 0x9e, 0x7b, 0xc8, 0x8b, 0xb4, 0xdd, -0xd8, 0xd6, 0xe7, 0x6e, 0xce, 0x79, 0x97, 0x3e, -0x03, 0xf9, 0xe9, 0xbc, 0x66, 0x92, 0x12, 0x73, -0x5a, 0xa9, 0xd6, 0xd3, 0x57, 0xe9, 0xb5, 0x43, -0xbe, 0x6b, 0xe4, 0xc7, 0xf4, 0xcf, 0xe9, 0xdc, -0xc1, 0x99, 0x3f, 0x92, 0x8f, 0xc3, 0xe7, 0x74, -0x6a, 0xfa, 0xa6, 0xd5, 0xe5, 0x07, 0xc5, 0xfa, -0x52, 0xf3, 0x77, 0xeb, 0xe7, 0xa0, 0xee, 0x5d, -0xdf, 0x53, 0xf2, 0xca, 0xd4, 0x30, 0xd4, 0xbd, -0x95, 0xbf, 0x57, 0x1e, 0x82, 0x2f, 0xa0, 0xce, -0x2c, 0x48, 0xca, 0xbd, 0x39, 0xc2, 0x6f, 0xb8, -0x2e, 0x68, 0x63, 0xb4, 0x3e, 0xed, 0x7d, 0x56, -0xfe, 0xd4, 0x38, 0x13, 0x0f, 0x9f, 0xd9, 0x38, -0xf2, 0x8d, 0xba, 0xd8, 0x1f, 0xe8, 0xbc, 0x13, -0xbe, 0x11, 0xb9, 0x5f, 0xcc, 0xd7, 0x2e, 0x69, -0x03, 0xec, 0x43, 0xbf, 0x51, 0xb9, 0x90, 0x1c, -0xa1, 0x4f, 0xcd, 0xad, 0x1c, 0xf4, 0x74, 0xb7, -0x4e, 0x35, 0xf6, 0x26, 0x57, 0x98, 0x9e, 0xab, -0x8b, 0x9e, 0xb4, 0xfc, 0x18, 0x3c, 0x8a, 0x6d, -0xaa, 0x4c, 0xec, 0xe1, 0xbb, 0xf0, 0x14, 0x2c, -0xeb, 0xf3, 0x34, 0x47, 0xee, 0x54, 0xf7, 0x41, -0x99, 0xe9, 0xb9, 0x27, 0xd2, 0x27, 0x9e, 0x61, -0x0c, 0xd7, 0xd7, 0x5e, 0x29, 0x68, 0xe6, 0x85, -0x70, 0x59, 0x25, 0xa5, 0x4a, 0xb3, 0x33, 0x14, -0x59, 0x89, 0x57, 0x2a, 0xf1, 0x69, 0x90, 0x9f, -0x89, 0x79, 0xdf, 0x55, 0xf2, 0x02, 0x2e, 0xf3, -0x7a, 0x33, 0x7f, 0x58, 0x1e, 0x33, 0x86, 0x61, -0x5e, 0x8f, 0x6f, 0xf8, 0xeb, 0x3f, 0xc6, 0x3e, -0x87, 0xd1, 0x47, 0xc9, 0x1f, 0xb5, 0xc7, 0xc4, -0xba, 0x18, 0x52, 0x70, 0x5c, 0xe6, 0x83, 0xc9, -0xf2, 0x21, 0x03, 0xd7, 0x17, 0x73, 0x71, 0xbb, -0xe1, 0x0b, 0x99, 0x1b, 0x3b, 0xc5, 0xfa, 0x92, -0xb4, 0x51, 0x40, 0xdf, 0x62, 0xfa, 0x86, 0xd1, -0xa5, 0x8c, 0x2a, 0x57, 0x09, 0xe3, 0x88, 0xb8, -0x12, 0x5b, 0xce, 0xdb, 0xb4, 0x28, 0x2b, 0xe1, -0x11, 0xf4, 0xc6, 0x9d, 0x49, 0x9c, 0x82, 0x63, -0xe6, 0x76, 0xe6, 0x06, 0x87, 0x60, 0x3d, 0xe5, -0x1e, 0x3b, 0x6d, 0xf0, 0xf5, 0x45, 0xa5, 0x95, -0x20, 0x7c, 0xb8, 0x7f, 0x08, 0xba, 0x3b, 0x7e, -0x6e, 0xb5, 0xe9, 0xa8, 0xee, 0x59, 0x8f, 0x6d, -0xc4, 0x7c, 0xa9, 0xc5, 0xf9, 0xdc, 0x6f, 0x4c, -0x09, 0xfb, 0x87, 0x22, 0x71, 0xd0, 0x8f, 0x79, -0x42, 0xad, 0x87, 0xa1, 0xd5, 0xc0, 0x91, 0x2e, -0x20, 0xbd, 0x02, 0x9b, 0x40, 0xfa, 0x31, 0x1f, -0x97, 0xef, 0xe4, 0x43, 0xa3, 0x74, 0x04, 0xb0, -0x3f, 0x67, 0xe4, 0x21, 0xe5, 0xe0, 0xca, 0xba, -0x37, 0x1f, 0x7c, 0xa6, 0x2d, 0x46, 0xf8, 0x77, -0x25, 0x4a, 0x46, 0xe1, 0x3d, 0xa8, 0xef, 0xf5, -0x9c, 0x92, 0x47, 0xcd, 0x51, 0xa8, 0xff, 0x8d, -0xaf, 0xab, 0x6d, 0x74, 0xfb, 0x17, 0x50, 0x8f, -0xbe, 0xae, 0x68, 0x50, 0x60, 0x01, 0xc3, 0xaf, -0xcf, 0x8c, 0x79, 0x87, 0x0b, 0x4e, 0xb6, 0xfd, -0x6b, 0xeb, 0xd1, 0xbf, 0x99, 0xf7, 0x56, 0xfe, -0x9e, 0xa2, 0x5a, 0xe3, 0x63, 0x6d, 0xde, 0xd1, -0x60, 0x97, 0xdc, 0x2c, 0x59, 0xf8, 0x75, 0xb8, -0x7d, 0x9d, 0x51, 0xfe, 0xa6, 0xf7, 0x8c, 0x31, -0xd5, 0xd8, 0x68, 0xec, 0xe8, 0xf7, 0xfc, 0x90, -0xfc, 0x2b, 0x7d, 0xa9, 0xf9, 0xeb, 0xfd, 0xea, -0x19, 0xaa, 0xdb, 0xf8, 0x35, 0x04, 0x3b, 0x42, -0xe8, 0xe2, 0x42, 0xb0, 0x81, 0xb6, 0xe9, 0xfa, -0x31, 0xec, 0xaa, 0xd7, 0xdc, 0xab, 0xe8, 0xa9, -0xe8, 0x3c, 0x08, 0x88, 0x67, 0x68, 0x96, 0x6c, -0x40, 0x24, 0xd2, 0xcd, 0xbc, 0x24, 0x09, 0xaa, -0x9d, 0x4a, 0x80, 0x4d, 0xd3, 0x6e, 0x78, 0xde, -0x35, 0x9b, 0xe1, 0x57, 0xb3, 0x98, 0x77, 0xa3, -0x64, 0x08, 0x3e, 0x26, 0x61, 0x7c, 0xa3, 0xf0, -0x4f, 0x87, 0x70, 0x9a, 0xf2, 0x93, 0x0d, 0xc1, -0xfc, 0x8f, 0x25, 0x3f, 0x02, 0x90, 0x47, 0xcb, -0xe0, 0xd7, 0x1f, 0xe0, 0x25, 0xb3, 0x60, 0xb8, -0x61, 0x54, 0xfd, 0x83, 0x3d, 0x29, 0x63, 0xae, -0x7a, 0x36, 0x5f, 0xdd, 0x0e, 0x7e, 0xd1, 0x43, -0x6a, 0xf8, 0x70, 0x7e, 0x52, 0xde, 0x00, 0x1f, -0x2b, 0x0b, 0xf0, 0x9f, 0x17, 0x05, 0xb5, 0x73, -0x7a, 0xb8, 0x77, 0x43, 0x72, 0x47, 0xdc, 0xc6, -0xaf, 0x39, 0xda, 0x46, 0xd8, 0x31, 0xdc, 0x31, -0xea, 0xae, 0xa5, 0x1b, 0xf5, 0xf2, 0x94, 0xeb, -0x14, 0xa9, 0xa5, 0x2f, 0x99, 0xe5, 0x3d, 0xea, -0x30, 0x09, 0xdb, 0xf8, 0xb5, 0x14, 0xda, 0x34, -0xbd, 0x3f, 0xef, 0x39, 0xe2, 0x6b, 0xdf, 0x71, -0xa2, 0x62, 0x84, 0x84, 0x89, 0xb7, 0xe5, 0x97, -0xe6, 0xec, 0x3e, 0x75, 0x0f, 0xe9, 0x76, 0xd6, -0x17, 0xac, 0x4b, 0x94, 0x9d, 0xc8, 0xbb, 0x26, -0x67, 0x7a, 0xd3, 0x3a, 0x3a, 0x6b, 0x90, 0xdc, -0x47, 0xa6, 0xc3, 0xde, 0x44, 0xde, 0x40, 0xe5, -0x7d, 0x44, 0xd5, 0x2c, 0xfc, 0xf2, 0x26, 0xda, -0x70, 0x38, 0x55, 0x0b, 0x77, 0x14, 0x74, 0x60, -0x7f, 0xd2, 0xb3, 0x6b, 0x3c, 0x5e, 0x38, 0x7d, -0xff, 0xcf, 0x5e, 0xf1, 0xd6, 0xc8, 0x9b, 0x6d, -0xfc, 0xda, 0x4d, 0xc6, 0x56, 0xd4, 0xf7, 0x15, -0x74, 0xc9, 0xdf, 0xd3, 0xff, 0x49, 0x5d, 0x80, -0x63, 0xc7, 0x71, 0x9d, 0x83, 0x05, 0x6f, 0x32, -0xcc, 0x25, 0x16, 0x7e, 0x0d, 0xc1, 0xa1, 0x45, -0x5d, 0x47, 0xbd, 0x7b, 0xa5, 0x5f, 0xc1, 0xc7, -0xee, 0x05, 0x47, 0xf2, 0x9f, 0xe9, 0xac, 0x32, -0x0e, 0x11, 0x7f, 0xbf, 0xb7, 0xcb, 0x33, 0xdb, -0xc1, 0x2f, 0xd5, 0x07, 0x7a, 0x4a, 0x5d, 0xd5, -0x3a, 0x95, 0xae, 0xab, 0x28, 0x33, 0x1f, 0x58, -0x45, 0xa6, 0xea, 0x1b, 0x57, 0x94, 0xf5, 0xab, -0x73, 0xc9, 0x66, 0x07, 0xbf, 0x4a, 0xaf, 0x48, -0x94, 0x0d, 0x22, 0xe6, 0x3e, 0x86, 0x50, 0xbb, -0x6c, 0x50, 0xbd, 0xd7, 0xf8, 0x0e, 0xac, 0xa3, -0x55, 0x27, 0x3a, 0x7e, 0x44, 0xac, 0x70, 0x2e, -0x5a, 0x3c, 0x04, 0xbf, 0xc4, 0xf9, 0x2a, 0x4d, -0x92, 0x0d, 0xf8, 0x42, 0x26, 0xd8, 0x42, 0x5b, -0x49, 0xda, 0x60, 0xb7, 0x59, 0x99, 0xc4, 0xfb, -0x08, 0xfc, 0x2a, 0xd9, 0x45, 0x18, 0x5a, 0xad, -0x4c, 0xc8, 0xbb, 0xd8, 0xb2, 0xa2, 0xde, 0x84, -0xbc, 0x42, 0x3a, 0xa8, 0xd4, 0xa1, 0x51, 0x54, -0x63, 0xe3, 0xd7, 0x09, 0xa5, 0x14, 0xea, 0x34, -0x5f, 0xbb, 0xb4, 0x4c, 0x1b, 0x84, 0x1a, 0x74, -0xd4, 0x0c, 0xbf, 0x0c, 0xc2, 0x10, 0xcd, 0xc1, -0xaf, 0x0f, 0xe2, 0x07, 0x12, 0x0b, 0x1a, 0xf3, -0x7f, 0x76, 0x45, 0x8e, 0xf1, 0x56, 0x3c, 0xdc, -0xf8, 0x77, 0xf1, 0x45, 0x3f, 0xa7, 0x07, 0x34, -0xfd, 0xbb, 0x4b, 0xb6, 0x36, 0xb4, 0x5a, 0xf8, -0xa5, 0xfc, 0x35, 0xdc, 0x4f, 0x03, 0x4d, 0xea, -0xa3, 0x39, 0x33, 0xe0, 0x7e, 0x23, 0xd0, 0x54, -0x1a, 0x27, 0x57, 0xc0, 0xfd, 0xe6, 0x82, 0x66, -0xf5, 0x51, 0xb7, 0xee, 0xe0, 0x17, 0xdc, 0x0f, -0x15, 0x46, 0x5e, 0x3c, 0x52, 0xa1, 0x6e, 0xca, -0x4b, 0x7c, 0x53, 0xf5, 0xf7, 0xee, 0xd4, 0x5b, -0x60, 0x76, 0x43, 0xe5, 0xbf, 0x90, 0xb5, 0x16, -0x7e, 0x29, 0x8a, 0x82, 0xaf, 0xe8, 0xf5, 0xaa, -0xdf, 0xaf, 0xb4, 0xb4, 0x04, 0xf4, 0xa8, 0xdb, -0xff, 0x57, 0x4a, 0xbc, 0x45, 0xf7, 0x46, 0x55, -0x7f, 0x84, 0xd8, 0xf8, 0x75, 0x7d, 0x24, 0xd5, -0xf4, 0xcc, 0x96, 0xfc, 0x19, 0xee, 0x3c, 0xa3, -0xbf, 0x29, 0x54, 0xec, 0x76, 0xc9, 0x2d, 0x91, -0x83, 0xb7, 0x96, 0x32, 0x44, 0xfb, 0xb5, 0xcc, -0xbf, 0x6b, 0xeb, 0x34, 0xf4, 0xfc, 0xc5, 0x75, -0x8d, 0x4b, 0x37, 0xc1, 0x80, 0x71, 0xb6, 0xb0, -0xae, 0xf1, 0xa6, 0x4d, 0xf2, 0x72, 0xe3, 0xde, -0xe2, 0x05, 0x8d, 0xb9, 0x9b, 0xe4, 0x0f, 0x72, -0x63, 0x16, 0x7e, 0x91, 0x03, 0x95, 0xe1, 0x1b, -0xbc, 0xf1, 0xb6, 0x81, 0xfd, 0x6f, 0xdd, 0xd5, -0xd5, 0x98, 0xbf, 0x45, 0xae, 0xa8, 0x3c, 0xb0, -0x28, 0xdc, 0x84, 0x57, 0x72, 0x6c, 0xfc, 0x32, -0xa1, 0x23, 0xa6, 0x97, 0xaa, 0x4a, 0xa4, 0x07, -0x3a, 0xf4, 0x40, 0x71, 0x55, 0x3b, 0xd9, 0x46, -0xa8, 0x9e, 0x00, 0x75, 0xbf, 0xbb, 0xc0, 0x7a, -0x3e, 0xae, 0x37, 0x13, 0x6b, 0xd4, 0xb2, 0x88, -0x7a, 0x4b, 0xeb, 0x9b, 0xe6, 0x3f, 0x2f, 0x2b, -0x8b, 0x96, 0x7e, 0x8b, 0x4c, 0x4d, 0xac, 0x31, -0xca, 0x9a, 0xf2, 0x9a, 0xb6, 0x13, 0x97, 0x85, -0x5f, 0x4f, 0xc1, 0x03, 0x52, 0xb9, 0xa1, 0xf6, -0x93, 0x33, 0xf0, 0x00, 0x94, 0x2d, 0xba, 0xb4, -0x3f, 0x8c, 0x57, 0xe0, 0x6e, 0xe3, 0x89, 0x26, -0x92, 0x63, 0xe1, 0x17, 0x62, 0xee, 0x01, 0x08, -0x1b, 0xc1, 0x78, 0x39, 0x02, 0xab, 0x14, 0x36, -0x36, 0xb0, 0x80, 0x81, 0x5d, 0xb9, 0x29, 0x1e, -0xa8, 0x14, 0xeb, 0xab, 0x52, 0xda, 0x89, 0x68, -0xf5, 0x02, 0xa2, 0x55, 0xd1, 0x00, 0x61, 0xb0, -0xb5, 0x54, 0x2b, 0xef, 0xd3, 0x4e, 0xa2, 0xf1, -0x60, 0xdc, 0x73, 0x50, 0xac, 0xaf, 0x4a, 0x2d, -0x59, 0xd8, 0x07, 0xd7, 0xc0, 0x06, 0xb3, 0x21, -0xa4, 0x1e, 0x26, 0xdf, 0x47, 0xc0, 0xf9, 0x7a, -0x08, 0x0e, 0xc3, 0x5c, 0x28, 0x30, 0x65, 0xb7, -0x85, 0x5f, 0xae, 0x59, 0xb7, 0xac, 0xd7, 0x03, -0x5b, 0x2a, 0x13, 0xee, 0xca, 0x9c, 0xf5, 0x52, -0x80, 0x6e, 0x78, 0x3c, 0x52, 0x89, 0xd1, 0xce, -0xf6, 0x7f, 0x56, 0xb7, 0xcb, 0x6e, 0x0b, 0x77, -0x5c, 0x3f, 0x86, 0x75, 0xed, 0xb3, 0x4c, 0xb5, -0x39, 0xa7, 0x16, 0x36, 0xc2, 0x32, 0x74, 0xf8, -0xee, 0xa9, 0xda, 0x4f, 0xe9, 0x0c, 0xd3, 0xdd, -0x8c, 0xe0, 0xc7, 0xd7, 0x57, 0x42, 0x9a, 0x0a, -0xeb, 0xd0, 0xf3, 0xab, 0xab, 0x2f, 0xb1, 0x0c, -0xde, 0xc6, 0x98, 0x81, 0x06, 0x59, 0x21, 0xee, -0xb3, 0x4b, 0x9d, 0x8e, 0x91, 0xc5, 0xd5, 0x18, -0x43, 0x16, 0x4d, 0x87, 0x97, 0x5b, 0xf4, 0xf4, -0x4d, 0x23, 0xb7, 0x16, 0xc0, 0xbf, 0xd3, 0x2b, -0xd3, 0x05, 0x23, 0xb8, 0x2e, 0x04, 0x7e, 0x4d, -0x13, 0x51, 0xd3, 0x46, 0x5a, 0xc4, 0x02, 0x86, -0x17, 0xa5, 0x39, 0xb4, 0x1c, 0x31, 0x17, 0x5f, -0x48, 0x5f, 0x3b, 0xbe, 0x63, 0x02, 0x77, 0x5c, -0x5f, 0x18, 0xaf, 0xd1, 0x05, 0x09, 0x44, 0xab, -0xba, 0xbe, 0xcf, 0x5a, 0xaf, 0x3a, 0x91, 0x3f, -0xe8, 0x9f, 0xa9, 0xbe, 0xb6, 0xa9, 0x3e, 0xf1, -0xc0, 0x7f, 0x78, 0xc0, 0xc2, 0xaf, 0xc2, 0x17, -0xb5, 0x75, 0x1a, 0x46, 0x7a, 0x35, 0x45, 0x7f, -0x0f, 0x1b, 0x0d, 0x3d, 0xad, 0xde, 0x9b, 0x33, -0xdd, 0xfc, 0x03, 0x9d, 0x33, 0xa8, 0xfe, 0x88, -0x38, 0xf8, 0xb5, 0x95, 0xae, 0x81, 0x19, 0x1d, -0x0d, 0xb8, 0xf4, 0x52, 0xbf, 0x80, 0xb2, 0x14, -0x9b, 0x57, 0xba, 0x46, 0xaf, 0xea, 0xc8, 0xbb, -0x05, 0x57, 0x3b, 0x7f, 0x3e, 0x7a, 0x71, 0x9a, -0x50, 0x7c, 0x54, 0x1e, 0xc8, 0x31, 0xa0, 0x03, -0xb6, 0xc3, 0x9f, 0x51, 0xbf, 0xae, 0x24, 0x94, -0x20, 0xec, 0x02, 0xd2, 0x61, 0xe3, 0xd7, 0x4e, -0x38, 0x88, 0x61, 0x06, 0x46, 0x4d, 0x3a, 0x0c, -0x2a, 0x61, 0xf0, 0xc6, 0x3d, 0x95, 0xb0, 0x1e, -0x23, 0xbd, 0xfc, 0x44, 0xf9, 0x6c, 0xc5, 0xb0, -0xf0, 0x0b, 0x63, 0xfe, 0x17, 0x4d, 0xdf, 0x7c, -0x84, 0xe3, 0x73, 0x18, 0xea, 0x23, 0x1c, 0xa3, -0xe1, 0x62, 0xf8, 0x85, 0x23, 0xb5, 0xf0, 0xeb, -0x0c, 0x39, 0x02, 0xf3, 0x0c, 0x5f, 0x87, 0xbc, -0xaa, 0xfd, 0xb0, 0x14, 0xae, 0x5c, 0xd9, 0x4f, -0x16, 0x32, 0xfc, 0x32, 0xbc, 0x31, 0x99, 0x36, -0x5a, 0xf8, 0x15, 0xc3, 0xf7, 0x30, 0x00, 0x97, -0x3e, 0x48, 0xca, 0xa1, 0x63, 0x51, 0xc0, 0xef, -0x66, 0xfd, 0x39, 0x76, 0x7d, 0x35, 0xac, 0x6f, -0x6f, 0xd5, 0x2d, 0xfc, 0x72, 0xe9, 0x06, 0x85, -0xed, 0x8a, 0xa7, 0x85, 0x18, 0xa4, 0x83, 0x06, -0x24, 0xb5, 0x85, 0x24, 0xb0, 0xbf, 0x41, 0x45, -0xa5, 0x68, 0x58, 0xeb, 0xcb, 0x8b, 0xcc, 0x45, -0x4f, 0x79, 0xc2, 0x7e, 0x34, 0x14, 0xfd, 0x35, -0x77, 0x98, 0x3c, 0xa8, 0x3e, 0xa4, 0x06, 0x4d, -0xf7, 0xfc, 0x56, 0x6b, 0x7d, 0x41, 0x7e, 0x0c, -0x7d, 0x50, 0x18, 0x6e, 0xa4, 0x2f, 0xc7, 0x62, -0x29, 0x34, 0xbc, 0xed, 0x32, 0xa5, 0x29, 0xa3, -0x4e, 0xf5, 0xe6, 0xc8, 0x54, 0xc4, 0x87, 0x89, -0x69, 0x69, 0x03, 0x61, 0xcb, 0x95, 0x4f, 0x31, -0x56, 0x1f, 0x85, 0x67, 0xbc, 0xbe, 0xb5, 0x9d, -0xcd, 0xc6, 0xb1, 0xca, 0x6a, 0x65, 0x69, 0xab, -0x3c, 0x28, 0xe2, 0x43, 0x53, 0xba, 0x00, 0xef, -0xd1, 0x6b, 0x2b, 0xaa, 0xee, 0x97, 0x5a, 0xe1, -0xf7, 0x14, 0xfd, 0xfc, 0x48, 0xf9, 0x05, 0x18, -0xa3, 0xf3, 0xd2, 0xbe, 0x93, 0xf2, 0xb0, 0x85, -0x5f, 0xa5, 0x9f, 0xc2, 0xf3, 0xb4, 0x5a, 0x55, -0xa9, 0x3b, 0x00, 0x9d, 0xb4, 0x7c, 0x58, 0xed, -0xda, 0x3e, 0x94, 0x78, 0xbe, 0x22, 0xd0, 0xeb, -0xf9, 0x9c, 0x0c, 0xe7, 0x58, 0xf8, 0xb5, 0x01, -0x79, 0x4a, 0x35, 0xa8, 0xad, 0x39, 0x54, 0xdb, -0xa1, 0x54, 0xf4, 0xe7, 0x85, 0x02, 0x87, 0xe9, -0x5e, 0x15, 0x47, 0x31, 0x8f, 0x9c, 0x92, 0x84, -0xcf, 0x44, 0xdf, 0x8b, 0xd8, 0x1d, 0x50, 0x29, -0x22, 0x5a, 0x67, 0x2c, 0x80, 0x6e, 0x30, 0x87, -0x5d, 0x09, 0x30, 0x10, 0xb7, 0x62, 0x7e, 0xa3, -0x64, 0x25, 0xbc, 0x03, 0xc1, 0x90, 0x17, 0xe4, -0xed, 0x65, 0x1f, 0x9b, 0x0b, 0xcc, 0x07, 0x18, -0xbe, 0x23, 0xd1, 0xe8, 0x59, 0x9a, 0x6c, 0xe8, -0x6f, 0x74, 0xf0, 0xeb, 0x9f, 0xa0, 0x5e, 0xf2, -0x1d, 0xc0, 0x1e, 0x8e, 0xd1, 0x6b, 0x4d, 0x0f, -0xc7, 0x2f, 0xa8, 0xef, 0xf1, 0x25, 0xcb, 0xb3, -0xf9, 0x17, 0x46, 0x95, 0x0f, 0x52, 0x79, 0x99, -0x76, 0xd0, 0x60, 0xf7, 0x41, 0x1e, 0xc7, 0xa2, -0x14, 0xc4, 0x02, 0x2d, 0x9b, 0x7f, 0x61, 0x9f, -0x13, 0x01, 0x13, 0x51, 0xf9, 0x2a, 0x16, 0xd2, -0xec, 0x16, 0xd1, 0xc5, 0x30, 0x59, 0x20, 0xe6, -0xc2, 0x54, 0x38, 0xff, 0x02, 0x37, 0x90, 0x08, -0xb4, 0x35, 0xed, 0x14, 0xc1, 0xd2, 0xf3, 0xb0, -0x92, 0x81, 0x6f, 0x48, 0xf8, 0x4c, 0x5d, 0xfb, -0x0e, 0x42, 0xc0, 0x1c, 0x5d, 0xbd, 0x9e, 0x9c, -0x4a, 0xcc, 0xa1, 0x8f, 0x0f, 0x7a, 0xee, 0x0d, -0x20, 0x28, 0x24, 0xaa, 0xd2, 0xf2, 0x7d, 0xa4, -0x5a, 0xd1, 0x04, 0x7e, 0x2d, 0x81, 0xd3, 0x78, -0x9f, 0x02, 0x8f, 0x1c, 0xf1, 0xbe, 0x0c, 0xf3, -0x07, 0xa5, 0x1a, 0x79, 0x89, 0x7a, 0x9a, 0xd6, -0x9a, 0xbe, 0x85, 0xb2, 0x5f, 0xc4, 0x1b, 0x46, -0xc9, 0x0b, 0xae, 0x31, 0xb6, 0xbe, 0x4c, 0xc6, -0xbf, 0xa0, 0xbe, 0x1f, 0x71, 0x79, 0x88, 0x19, -0x7d, 0x1b, 0x4f, 0xb6, 0xf5, 0x8b, 0x75, 0xa1, -0xba, 0xf8, 0x2b, 0x0a, 0xc1, 0x38, 0xae, 0xa6, -0xd3, 0x10, 0x3e, 0xe6, 0xeb, 0x6e, 0x08, 0x12, -0x64, 0x64, 0x66, 0xf0, 0xc5, 0x4e, 0x62, 0xf1, -0xa6, 0x4b, 0x59, 0xec, 0x37, 0x07, 0x54, 0x13, -0xef, 0xfb, 0xef, 0xf0, 0x44, 0x0a, 0x87, 0x83, -0x8c, 0x0c, 0xa3, 0x41, 0xf5, 0x14, 0x09, 0xe7, -0x88, 0xb5, 0x83, 0xfc, 0x6b, 0x5f, 0x4b, 0xd5, -0xb6, 0x8e, 0xe8, 0x4c, 0x3f, 0x3c, 0x4d, 0xcb, -0x06, 0x90, 0x76, 0x21, 0x0a, 0xb7, 0x54, 0x9d, -0x50, 0x57, 0xe7, 0xa8, 0xe2, 0x3e, 0x2b, 0x94, -0xc3, 0x6c, 0xec, 0x9a, 0xaa, 0xac, 0x2d, 0x30, -0x1e, 0x52, 0x59, 0x58, 0x98, 0xb3, 0x1b, 0xf9, -0x17, 0xf2, 0xe5, 0x10, 0xa9, 0x11, 0x6d, 0x10, -0xbf, 0x10, 0xb6, 0xea, 0xe9, 0xd4, 0x58, 0xee, -0xd5, 0xf0, 0x79, 0x6f, 0x98, 0xfa, 0x58, 0xb0, -0x7d, 0x10, 0x18, 0x7e, 0xc9, 0x35, 0xc2, 0x1f, -0x32, 0xfe, 0x85, 0x7e, 0xc3, 0x7b, 0x79, 0x4b, -0x6e, 0x5a, 0x19, 0x29, 0x14, 0x44, 0x8c, 0x7b, -0x12, 0x8e, 0x5f, 0x62, 0x5c, 0x9a, 0x88, 0xf0, -0xbd, 0xf1, 0xf2, 0x99, 0xa1, 0x03, 0xda, 0x73, -0x68, 0xc8, 0xcc, 0xd3, 0xd6, 0xa1, 0x83, 0x45, -0xfe, 0xa5, 0x0b, 0xfc, 0x5a, 0xae, 0x72, 0x6e, -0x15, 0x27, 0x8a, 0xf1, 0x04, 0x0d, 0x18, 0x1d, -0x8c, 0x5b, 0xdd, 0x2f, 0xae, 0xa4, 0xc5, 0x5c, -0x2c, 0x44, 0xfc, 0x7a, 0x16, 0x82, 0x06, 0x46, -0x44, 0x15, 0xfa, 0xfd, 0x79, 0xb3, 0xd9, 0x9f, -0xec, 0x36, 0x81, 0x23, 0x96, 0xcf, 0x2c, 0x56, -0x30, 0xd4, 0x0f, 0xe2, 0x3f, 0x77, 0x57, 0xc0, -0x36, 0xd0, 0xa3, 0x95, 0xc8, 0xbf, 0xa0, 0x05, -0xaf, 0xe8, 0x7e, 0x72, 0xd0, 0x65, 0xe1, 0x57, -0x0c, 0x46, 0xa4, 0xba, 0xe2, 0xe0, 0x1a, 0xf4, -0x1b, 0x29, 0x1c, 0xad, 0x77, 0x4d, 0x51, 0x0f, -0x22, 0x5a, 0x6d, 0xb1, 0xb2, 0x46, 0xbe, 0x90, -0xc5, 0xbf, 0xd0, 0x03, 0x78, 0xfa, 0xf1, 0xf5, -0xfb, 0x47, 0xe0, 0xb4, 0xcb, 0xe2, 0x29, 0x9b, -0xe4, 0xf7, 0xc1, 0xe1, 0x5f, 0x67, 0xa1, 0xd6, -0xc8, 0x2d, 0x96, 0xe7, 0xc3, 0x7f, 0x40, 0x17, -0xa3, 0x30, 0x33, 0xe0, 0xac, 0x51, 0x63, 0xf8, -0x36, 0xb7, 0xe6, 0x88, 0xf5, 0xb5, 0xb0, 0x34, -0xad, 0x76, 0xf3, 0xf7, 0x10, 0x51, 0xb8, 0x03, -0x02, 0xc5, 0x9e, 0x56, 0xa2, 0xd3, 0x6e, 0xa9, -0xda, 0xe3, 0x59, 0xeb, 0x2e, 0x20, 0x62, 0x4e, -0x5d, 0xc8, 0x19, 0xa1, 0xfa, 0x06, 0xb7, 0xdf, -0x5f, 0x21, 0x3f, 0x44, 0x2b, 0x8c, 0x47, 0xb4, -0xd6, 0xc6, 0x8e, 0x3d, 0x65, 0x95, 0xc6, 0x8d, -0x5a, 0xab, 0xdf, 0xc5, 0xdb, 0x94, 0x2a, 0x3b, -0xd9, 0xf3, 0x69, 0x52, 0xfd, 0xa4, 0xc2, 0xb8, -0x9f, 0xce, 0x34, 0x3c, 0xda, 0x0d, 0x82, 0xb1, -0x7a, 0xb4, 0xc8, 0x4c, 0x31, 0x5f, 0x09, 0xce, -0x19, 0x6b, 0x9b, 0x0b, 0xb6, 0xc8, 0x0a, 0x12, -0xb1, 0x05, 0xac, 0x3f, 0x48, 0xb2, 0xa0, 0x86, -0x19, 0x16, 0x7e, 0x45, 0x39, 0x7e, 0xd5, 0x35, -0xb3, 0xe1, 0x84, 0xac, 0x3f, 0xed, 0xe4, 0xec, -0x18, 0x0d, 0x67, 0xbe, 0x12, 0xec, 0xf9, 0x40, -0x3e, 0x2d, 0x8a, 0xa9, 0x23, 0xe8, 0x7f, 0xac, -0x39, 0xe5, 0x06, 0xb1, 0xf1, 0xab, 0x12, 0x9e, -0x43, 0xfe, 0x15, 0x4d, 0x90, 0x1a, 0x7d, 0xad, -0x32, 0xbb, 0x05, 0x89, 0xd8, 0x20, 0x5e, 0x09, -0x30, 0x46, 0xb6, 0xde, 0xc6, 0x2f, 0x91, 0xdf, -0x28, 0x0d, 0xf9, 0x6f, 0xd0, 0xb6, 0xeb, 0x8c, -0x88, 0x11, 0xf6, 0xd6, 0xe9, 0x68, 0xdc, 0xb5, -0x5e, 0xcc, 0x29, 0x2d, 0x9c, 0xaa, 0xe1, 0xfb, -0x9c, 0xaa, 0x3c, 0xe5, 0xd7, 0x10, 0xe3, 0xaa, -0xcc, 0x29, 0xab, 0xc8, 0xbb, 0xf1, 0xab, 0xe8, -0x32, 0xd3, 0xb3, 0x0a, 0x7d, 0xa6, 0xf0, 0x3f, -0x88, 0x5f, 0x7f, 0xa0, 0xd7, 0x0e, 0x7a, 0x7f, -0x24, 0xdf, 0x82, 0x7e, 0xec, 0xda, 0xb4, 0x07, -0xf9, 0x97, 0xf1, 0x4f, 0xe9, 0xb9, 0x83, 0x4b, -0x6b, 0xda, 0x02, 0x3a, 0xbf, 0x8f, 0x5a, 0xb2, -0x9b, 0xf1, 0x94, 0x63, 0xe8, 0xde, 0x4d, 0xf2, -0x5b, 0xf4, 0xf3, 0x4b, 0x9f, 0x29, 0x1a, 0x32, -0xce, 0xc1, 0x63, 0xff, 0xb6, 0x74, 0x8f, 0x1c, -0xb1, 0x70, 0x47, 0xf9, 0x35, 0x8c, 0x6d, 0xba, -0xfc, 0x54, 0xde, 0x73, 0xeb, 0x7b, 0xe1, 0xb3, -0xd6, 0x9a, 0xb4, 0xaf, 0xbb, 0xed, 0x02, 0x9c, -0x8b, 0xd7, 0xa4, 0x37, 0x3e, 0x2b, 0x9b, 0xe2, -0x19, 0xee, 0x2a, 0x7d, 0xcc, 0xdc, 0xa7, 0x55, -0xa5, 0x11, 0xad, 0xfc, 0xb8, 0xbe, 0xb6, 0x0d, -0xde, 0xb8, 0x90, 0x1c, 0x47, 0xfe, 0x55, 0x35, -0xe8, 0x5b, 0x48, 0x3e, 0x12, 0xeb, 0x8b, 0xf3, -0x2f, 0x69, 0x8e, 0x99, 0x37, 0x1c, 0x88, 0xc3, -0xff, 0x34, 0x66, 0xf5, 0x21, 0x11, 0x7b, 0xd4, -0xd8, 0xa7, 0x23, 0x8b, 0x6c, 0xce, 0x31, 0x75, -0xb1, 0x06, 0x95, 0x0d, 0x22, 0xb7, 0x73, 0xb5, -0x1b, 0xf4, 0x87, 0xf8, 0x90, 0xd9, 0xd8, 0x09, -0x7b, 0x08, 0x81, 0x94, 0xf5, 0x5d, 0x25, 0xcc, -0x8f, 0xd5, 0x7f, 0x90, 0x3f, 0x4c, 0xb6, 0xb5, -0x3e, 0xd9, 0x57, 0x83, 0x37, 0x94, 0x5f, 0x40, -0x9f, 0x70, 0x0d, 0xcb, 0x35, 0x7d, 0x24, 0xe6, -0x8b, 0xe3, 0x17, 0x7a, 0x80, 0x8d, 0x49, 0x79, -0x1b, 0x9c, 0xa3, 0x75, 0xe6, 0xe5, 0x48, 0xc4, -0x78, 0xf6, 0x09, 0x47, 0x9a, 0x16, 0xf3, 0x55, -0x86, 0xfc, 0xeb, 0x33, 0x0c, 0xf5, 0xbd, 0xc3, -0x6d, 0xcd, 0xf8, 0x1e, 0xce, 0x33, 0x5f, 0x1b, -0x5e, 0xf5, 0x63, 0x75, 0x4c, 0x99, 0xc3, 0x98, -0x5d, 0xaa, 0x91, 0x7f, 0xd7, 0x36, 0x60, 0xdc, -0x2a, 0x68, 0x56, 0x86, 0xe4, 0x48, 0xeb, 0x1b, -0x2d, 0x01, 0xc1, 0xad, 0x1e, 0x81, 0x99, 0x8c, -0x6d, 0x0d, 0x5a, 0x73, 0x21, 0x71, 0x9f, 0xc9, -0x18, 0xc7, 0x5f, 0xb9, 0x1f, 0xa1, 0x01, 0xd3, -0x9d, 0xcc, 0x59, 0xa9, 0x3e, 0x0f, 0x7f, 0xc7, -0x58, 0x5b, 0xda, 0xc1, 0xaf, 0x16, 0xc4, 0x02, -0x33, 0xba, 0x27, 0x10, 0x33, 0xf9, 0xb8, 0xc2, -0x39, 0x87, 0xd5, 0x87, 0xa2, 0x4a, 0xca, 0xb3, -0x00, 0x7a, 0xc5, 0xfa, 0x82, 0xfc, 0x95, 0x89, -0x8f, 0xa1, 0x3e, 0xe5, 0xfd, 0x5c, 0x8e, 0xd1, -0x77, 0x20, 0x9c, 0xca, 0x3f, 0x25, 0x23, 0x23, -0x8b, 0x5d, 0x9e, 0xca, 0x3f, 0xd3, 0x60, 0xda, -0xf8, 0xc5, 0xbc, 0x7a, 0x6d, 0xbf, 0xef, 0x87, -0x53, 0x86, 0x4d, 0xe4, 0x29, 0x47, 0x96, 0x7e, -0xde, 0x36, 0x14, 0x65, 0xfe, 0x10, 0xc9, 0xda, -0x60, 0xbb, 0x85, 0x5f, 0xe9, 0xd4, 0x50, 0xac, -0xde, 0x9b, 0xbf, 0x56, 0xd6, 0xe9, 0xe1, 0x50, -0x5d, 0xbe, 0xb7, 0x45, 0x0e, 0x19, 0x29, 0x3d, -0x5c, 0x8a, 0x0e, 0x24, 0x64, 0xe7, 0x0f, 0x4f, -0x98, 0x1d, 0xa1, 0xea, 0x62, 0x75, 0x0d, 0x29, -0x83, 0x8e, 0x6f, 0x56, 0x17, 0xbb, 0xd7, 0x92, -0xb2, 0x78, 0xc7, 0xea, 0x40, 0x9f, 0xba, 0x80, -0x38, 0xfc, 0xeb, 0x30, 0xdd, 0xa1, 0x07, 0x53, -0x53, 0xc2, 0x24, 0x5f, 0x6f, 0xd3, 0x83, 0x07, -0x2e, 0x9b, 0xef, 0x7f, 0xa0, 0xa3, 0xad, 0x4c, -0x4f, 0x75, 0x94, 0xb5, 0xde, 0x65, 0xe5, 0x0f, -0x4b, 0x12, 0xd0, 0xa1, 0xfc, 0x9d, 0x74, 0x03, -0xf8, 0xd1, 0x40, 0x67, 0x5e, 0x49, 0x73, 0x12, -0x1a, 0x2e, 0x58, 0x7c, 0x1a, 0x11, 0x8b, 0x7f, -0x41, 0xc9, 0x09, 0x18, 0x64, 0x3e, 0x7c, 0x43, -0x5b, 0xb9, 0x91, 0x22, 0x75, 0xe4, 0xe6, 0x96, -0xa2, 0x04, 0xa4, 0xb4, 0x2e, 0x0c, 0x3c, 0xe4, -0x26, 0x85, 0x8f, 0x2b, 0x2d, 0x75, 0xa8, 0x8c, -0x0b, 0x57, 0x6d, 0xf0, 0x34, 0x91, 0x0b, 0x50, -0x3f, 0xc3, 0x77, 0xc7, 0x5f, 0x2c, 0x21, 0x67, -0x5b, 0x6b, 0xcd, 0x39, 0xcd, 0x1e, 0x87, 0x7f, -0x21, 0x3d, 0x61, 0x68, 0xf5, 0x54, 0x79, 0x15, -0x02, 0x22, 0x23, 0x74, 0x72, 0x10, 0x5e, 0x46, -0x03, 0xfd, 0xaa, 0x83, 0x5f, 0x95, 0xc8, 0x07, -0x11, 0xad, 0x68, 0x20, 0xa1, 0x3c, 0x07, 0x35, -0x92, 0x1c, 0x47, 0x62, 0x78, 0xbf, 0xc2, 0xf9, -0xa0, 0xc3, 0xbf, 0x0c, 0x48, 0xa0, 0x6f, 0xf1, -0xb0, 0xd7, 0x24, 0x09, 0x15, 0x08, 0x64, 0x61, -0x93, 0x50, 0xe4, 0x5c, 0xaa, 0x86, 0x01, 0x8c, -0xe0, 0x5f, 0x85, 0x97, 0x40, 0x3b, 0xad, 0xaa, -0xe8, 0x64, 0x5c, 0x66, 0x4f, 0xeb, 0xac, 0xf4, -0x8d, 0xb3, 0xc9, 0x2d, 0x8d, 0x6b, 0xdb, 0x67, -0x0d, 0xa9, 0xf7, 0x91, 0x52, 0x27, 0x7f, 0x08, -0xbf, 0x25, 0xb5, 0x43, 0xbe, 0x1a, 0x79, 0x23, -0x7d, 0xa3, 0x71, 0xfe, 0x60, 0x4e, 0x8d, 0x7c, -0xb3, 0xf9, 0x72, 0x8b, 0x36, 0x14, 0xac, 0x44, -0xfc, 0xe2, 0x43, 0x37, 0x30, 0x7e, 0xc6, 0x78, -0x03, 0x7c, 0x7b, 0xc8, 0x10, 0x3d, 0xaf, 0xd5, -0xf5, 0xf9, 0xd2, 0x9e, 0x24, 0x5c, 0x60, 0xf3, -0x75, 0x56, 0xee, 0x17, 0xf9, 0x8d, 0x5d, 0x25, -0x69, 0x48, 0x21, 0x7e, 0x79, 0x69, 0x03, 0xf3, -0x75, 0x61, 0x58, 0x82, 0x81, 0x99, 0x92, 0x52, -0xc2, 0x12, 0x3e, 0x1f, 0x9b, 0x7f, 0x5d, 0x3a, -0x15, 0x59, 0x92, 0xde, 0x53, 0x39, 0x2c, 0xdf, -0x09, 0xbf, 0x40, 0x6e, 0xae, 0x86, 0xe4, 0x25, -0xf0, 0x06, 0xcc, 0x37, 0xf3, 0x43, 0xb2, 0x5f, -0x3c, 0x1f, 0x91, 0x3f, 0x9c, 0xc5, 0x72, 0x9e, -0x37, 0x4b, 0x0f, 0xb5, 0x73, 0x03, 0xf1, 0x8b, -0xce, 0x48, 0xe7, 0xad, 0x40, 0x5c, 0x16, 0x3e, -0x53, 0x79, 0x17, 0x7e, 0x0a, 0xcb, 0x06, 0x30, -0xca, 0xbd, 0x93, 0xa5, 0x43, 0x4d, 0xf5, 0x07, -0xe4, 0xce, 0xca, 0x9f, 0xc6, 0x66, 0xb0, 0xac, -0x88, 0xdf, 0xe6, 0x5f, 0x1f, 0xc1, 0x9f, 0x0f, -0xd7, 0x6c, 0xf1, 0x26, 0xae, 0xa8, 0x54, 0xdf, -0xd6, 0x6b, 0x10, 0xb6, 0x72, 0x2b, 0x2b, 0x0e, -0x36, 0x2e, 0xa0, 0xf9, 0x09, 0x8f, 0xc3, 0xbf, -0x92, 0xc6, 0x10, 0x1b, 0x97, 0x99, 0x1b, 0x87, -0x01, 0x98, 0x01, 0x4b, 0x8d, 0xdc, 0x7e, 0x6d, -0x54, 0xb9, 0x16, 0x7c, 0x86, 0xbc, 0xd9, 0xe6, -0x5f, 0x7d, 0x6a, 0x0f, 0xcc, 0x5f, 0xe4, 0xd5, -0xe4, 0x0a, 0xe5, 0x80, 0x12, 0x36, 0xf2, 0xe3, -0x0f, 0x2d, 0x87, 0x1e, 0xe4, 0x05, 0x4b, 0xe2, -0xe8, 0x0f, 0x2d, 0xfe, 0xb5, 0x1c, 0xee, 0x57, -0x02, 0x46, 0x34, 0x7e, 0x17, 0x23, 0x59, 0x01, -0xe3, 0x86, 0x38, 0xa9, 0x50, 0x9e, 0x90, 0x66, -0x2f, 0x52, 0xe3, 0xf8, 0x46, 0x59, 0xfc, 0xab, -0x16, 0x19, 0xc7, 0x1c, 0xc6, 0x41, 0xe6, 0x93, -0x5f, 0xc1, 0x0e, 0x23, 0xaf, 0xdf, 0x3d, 0x1f, -0x59, 0xc9, 0x0e, 0xa3, 0xb4, 0x9f, 0xe4, 0xd8, -0xeb, 0xab, 0xb8, 0x75, 0x8d, 0xfe, 0xc4, 0xf5, -0x95, 0xb7, 0xcc, 0x2e, 0xa6, 0x8f, 0xeb, 0x65, -0x51, 0xf7, 0x2d, 0xee, 0xe2, 0xf6, 0xc7, 0xf5, -0x59, 0xd1, 0xca, 0x5b, 0xdc, 0xad, 0x99, 0xfc, -0x61, 0xaa, 0xa9, 0x0e, 0xd9, 0x56, 0x79, 0x99, -0x31, 0xd8, 0x14, 0x2e, 0xce, 0x5f, 0xd3, 0x50, -0x86, 0x57, 0xc2, 0xc5, 0x4b, 0x5e, 0x91, 0xab, -0x25, 0x81, 0x5f, 0xd3, 0x90, 0x76, 0x69, 0x97, -0x34, 0x22, 0x5a, 0x0d, 0x19, 0xef, 0x20, 0xff, -0xca, 0xdf, 0xd4, 0x30, 0x10, 0x65, 0xf9, 0xc3, -0x8d, 0xc8, 0xbf, 0x2e, 0xb1, 0xf1, 0xcb, 0xf8, -0x10, 0xa1, 0xcd, 0xbb, 0xb9, 0xed, 0x77, 0xfa, -0x01, 0x35, 0xbc, 0xf8, 0xe6, 0xb8, 0x67, 0xa7, -0x71, 0x20, 0xba, 0xaa, 0x69, 0xc9, 0x26, 0x79, -0xa6, 0xcd, 0xbf, 0x3e, 0x34, 0x3a, 0x9a, 0xaa, -0xb7, 0xe4, 0xaf, 0x25, 0x88, 0xef, 0x80, 0x8f, -0x6e, 0x9d, 0x7f, 0x56, 0xe3, 0xdb, 0xfa, 0x6c, -0x4d, 0xa5, 0xfe, 0x02, 0x27, 0x7f, 0x48, 0xb7, -0xa9, 0xc1, 0xa8, 0xaa, 0x6d, 0xee, 0x93, 0xb6, -0xa9, 0x7a, 0xf4, 0x46, 0x6d, 0x73, 0x7b, 0x7b, -0x0b, 0xc4, 0x9a, 0xd4, 0x4b, 0x48, 0xab, 0x93, -0x3f, 0xec, 0xb8, 0x3f, 0x16, 0x8c, 0x3e, 0xbc, -0x39, 0x32, 0x80, 0xb0, 0x35, 0xf3, 0xfa, 0xbc, -0x2d, 0xa4, 0x02, 0x1e, 0x96, 0x66, 0x37, 0xa9, -0x5b, 0xc8, 0x5a, 0x3b, 0x7f, 0xf8, 0x38, 0x60, -0x7f, 0x9a, 0xbc, 0x9b, 0x8b, 0x3e, 0xd0, 0x3e, -0x84, 0x70, 0xd3, 0xf4, 0xad, 0xf2, 0x2f, 0xe0, -0x80, 0x41, 0x62, 0x4b, 0xb6, 0x7a, 0x76, 0xd9, -0xf9, 0xc3, 0x76, 0xaf, 0xc8, 0x16, 0x16, 0x0d, -0xd0, 0xb3, 0xdb, 0x5f, 0x88, 0x15, 0xf8, 0x8b, -0xfa, 0xe8, 0xd9, 0xc6, 0xda, 0xe8, 0x1c, 0xbf, -0x7c, 0x83, 0x9d, 0x3f, 0xdc, 0x46, 0x8e, 0x19, -0x5d, 0x5a, 0xb0, 0xfd, 0x6b, 0x94, 0x98, 0x39, -0x61, 0xad, 0x9a, 0xca, 0x65, 0x24, 0x65, 0x74, -0xb1, 0x44, 0xa2, 0xdb, 0xc9, 0x1f, 0x22, 0x53, -0x08, 0xd0, 0x1b, 0x90, 0x7f, 0xe1, 0xba, 0x61, -0xf9, 0x43, 0x46, 0xc4, 0x90, 0xa4, 0x57, 0x26, -0x22, 0x6e, 0xe1, 0xc6, 0x18, 0x7e, 0x31, 0x17, -0x87, 0x61, 0xa1, 0x97, 0x1b, 0x51, 0x66, 0x74, -0x42, 0xa5, 0xe9, 0x0e, 0xe9, 0x6e, 0x3b, 0xbf, -0x31, 0xd5, 0x58, 0x47, 0xcb, 0xfa, 0x3c, 0xf7, -0x92, 0xa9, 0xc6, 0x43, 0xe1, 0x32, 0x33, 0xda, -0x4c, 0xa6, 0xd2, 0x75, 0xd2, 0xac, 0x94, 0x7a, -0x0f, 0xe9, 0xb0, 0xf3, 0x87, 0x05, 0xe6, 0x7b, -0xc3, 0xa1, 0xc1, 0xfc, 0x85, 0xee, 0x3a, 0xfa, -0xef, 0xc9, 0x64, 0x1a, 0xe3, 0xf0, 0x82, 0xc4, -0xcb, 0xe9, 0x6b, 0x86, 0x0a, 0x46, 0xda, 0xdc, -0x56, 0xfe, 0x70, 0xda, 0xaf, 0xd0, 0xcf, 0x57, -0xf7, 0x3f, 0xf8, 0x54, 0xf9, 0x4a, 0xfd, 0x63, -0xa3, 0xee, 0xb0, 0xef, 0x19, 0xf9, 0x93, 0xfe, -0x73, 0xb0, 0xe0, 0x5d, 0x8c, 0x7b, 0x23, 0x22, -0xbf, 0x61, 0xb8, 0x2e, 0xc0, 0x51, 0x7a, 0xcd, -0xb0, 0xf7, 0xbc, 0xfc, 0x13, 0xe3, 0x28, 0xdd, -0x31, 0xa2, 0xbc, 0xb8, 0xa3, 0xce, 0x38, 0xd4, -0x7f, 0x15, 0xcb, 0x28, 0x6a, 0x36, 0xff, 0x7a, -0x41, 0x5b, 0xa7, 0xe8, 0x66, 0xfe, 0x6a, 0xf9, -0x3b, 0x4d, 0xc8, 0xad, 0x3e, 0x89, 0xde, 0x4b, -0xbc, 0xe6, 0xba, 0x9d, 0x48, 0x0c, 0xef, 0x25, -0xb3, 0x33, 0xf9, 0x43, 0x5e, 0x3d, 0x59, 0x15, -0x99, 0xda, 0xb2, 0x4e, 0x9b, 0x61, 0x5e, 0x7f, -0x0f, 0x79, 0xb4, 0xe0, 0xa7, 0xfa, 0x77, 0xfb, -0xdc, 0xcd, 0x9a, 0x62, 0xe7, 0x0f, 0x5f, 0xc3, -0x90, 0x58, 0x1f, 0xce, 0x9b, 0x4b, 0x96, 0x34, -0xfe, 0x52, 0xab, 0x38, 0x35, 0x65, 0x61, 0xc1, -0xee, 0xf8, 0x43, 0x6e, 0xbd, 0x77, 0x76, 0xa8, -0xf5, 0x32, 0x9b, 0x7f, 0xfd, 0x2b, 0x3d, 0x0a, -0xcf, 0xef, 0xf7, 0x0e, 0x97, 0xd7, 0xc2, 0x51, -0x5c, 0xcb, 0x55, 0x67, 0xe4, 0x97, 0xe8, 0x7b, -0xd2, 0x55, 0xc3, 0x05, 0xa3, 0xee, 0x4a, 0xf1, -0x5d, 0x88, 0x5f, 0xeb, 0x39, 0x7e, 0x85, 0xda, -0x86, 0x2a, 0xce, 0xa9, 0x0b, 0xfb, 0x3a, 0xf6, -0xca, 0x2b, 0xb5, 0x8f, 0x8b, 0x6b, 0xfa, 0x5c, -0x7b, 0x1a, 0xac, 0xb8, 0x4e, 0xd2, 0xde, 0x85, -0xf7, 0xd4, 0xb9, 0x18, 0xc6, 0x97, 0xaf, 0x84, -0xa5, 0x2c, 0xaf, 0xd5, 0xfc, 0xfd, 0x5a, 0xf5, -0x55, 0x98, 0x6b, 0x7a, 0x43, 0xb2, 0x6e, 0xf3, -0x2f, 0x56, 0xa9, 0x61, 0x90, 0x44, 0x76, 0x43, -0x27, 0xd9, 0xce, 0x0d, 0xc2, 0x12, 0x65, 0xeb, -0x93, 0x72, 0x22, 0x66, 0xf1, 0xaf, 0x95, 0x38, -0x4d, 0x01, 0x73, 0x56, 0xd2, 0xef, 0x85, 0x5f, -0x72, 0xd7, 0x1d, 0x08, 0xaa, 0x9d, 0xc0, 0x7d, -0xa6, 0x6e, 0xe5, 0x0f, 0x21, 0xd8, 0xd8, 0x06, -0x09, 0xf3, 0x86, 0xf9, 0x64, 0x43, 0xeb, 0x0e, -0x88, 0xa5, 0x2e, 0x9b, 0x0b, 0x1b, 0xa4, 0x36, -0x18, 0x34, 0xdd, 0xf3, 0x9c, 0xfc, 0xa1, 0xfa, -0x63, 0x78, 0x4f, 0x9a, 0xf7, 0x4a, 0xfe, 0x19, -0xb9, 0x56, 0xff, 0x3d, 0x94, 0xbf, 0x7b, 0xd3, -0x2a, 0x79, 0xaa, 0xf1, 0xea, 0xdd, 0x57, 0xff, -0x2f, 0xef, 0x70, 0x83, 0x6e, 0xe5, 0x0f, 0xa7, -0x8d, 0xd2, 0x31, 0xb8, 0x2a, 0xe5, 0xdb, 0x2b, -0x0f, 0xe9, 0xef, 0x01, 0xfa, 0xc3, 0xd3, 0x32, -0x5e, 0x59, 0x71, 0x85, 0xb9, 0xf1, 0xb4, 0xbc, -0xcb, 0xce, 0x1f, 0x62, 0xbc, 0x41, 0xeb, 0xd3, -0xd3, 0xbb, 0xe5, 0xf7, 0x8d, 0x23, 0x10, 0x8a, -0x79, 0xbb, 0x65, 0x16, 0x6f, 0x84, 0xd3, 0xde, -0x6e, 0xa7, 0xfe, 0x25, 0xf8, 0x57, 0xba, 0xb3, -0xdb, 0x9f, 0x56, 0xdf, 0xa2, 0x81, 0x88, 0xda, -0x4d, 0xf0, 0x8a, 0xbe, 0xa0, 0x57, 0xed, 0x8e, -0x0c, 0x5b, 0xf1, 0x8f, 0x88, 0xd5, 0xcd, 0xcb, -0x42, 0x24, 0xcd, 0xc8, 0x63, 0x14, 0x43, 0xf4, -0xc3, 0xae, 0x3d, 0x44, 0x4f, 0xa1, 0x71, 0xca, -0x65, 0x7d, 0x97, 0x60, 0x37, 0x53, 0x92, 0xe4, -0x7d, 0x78, 0x84, 0xea, 0x4d, 0x08, 0x5b, 0x43, -0xda, 0xb3, 0x5a, 0x85, 0x19, 0x75, 0xea, 0x5f, -0x2c, 0x7f, 0x78, 0x4e, 0x64, 0xa4, 0x5f, 0x86, -0x43, 0x2d, 0xe1, 0xc6, 0x20, 0xe3, 0xc2, 0x67, -0x61, 0x15, 0xab, 0x64, 0x65, 0xd7, 0xbf, 0x18, -0xdb, 0x1a, 0x6e, 0x1b, 0x66, 0x01, 0x70, 0x8c, -0xe7, 0x0f, 0xcf, 0x03, 0xab, 0x88, 0xc9, 0xe3, -0xf9, 0x97, 0x99, 0x9f, 0xbc, 0x75, 0x19, 0x4b, -0xc1, 0x35, 0x09, 0x4e, 0xcd, 0xf9, 0x57, 0xc3, -0x9b, 0x59, 0xfc, 0x8b, 0x54, 0x0f, 0xba, 0x5f, -0xf8, 0x73, 0x1d, 0xf6, 0x1a, 0x01, 0x16, 0xb4, -0x0f, 0x59, 0xd9, 0x5d, 0xbb, 0xfe, 0x65, 0xf1, -0xaf, 0x5e, 0xf5, 0x6a, 0x62, 0x40, 0x17, 0xbe, -0x77, 0x3c, 0x3f, 0xff, 0x2c, 0xcf, 0xd8, 0x93, -0x2f, 0xac, 0xf5, 0xc5, 0xf9, 0x57, 0xd5, 0xa0, -0xfb, 0x3e, 0x8c, 0xc7, 0xf6, 0x99, 0x3b, 0x74, -0x84, 0xad, 0xe3, 0x2d, 0x4f, 0xb7, 0x54, 0xb1, -0x5a, 0xd2, 0x90, 0x9d, 0x3f, 0xbc, 0x19, 0x58, -0xfd, 0xcb, 0x7b, 0x8d, 0xdc, 0x80, 0xc6, 0x7c, -0xbd, 0xa0, 0x46, 0x3e, 0x42, 0x4f, 0xc6, 0x6b, -0x07, 0x7d, 0xd7, 0x60, 0x4c, 0x6b, 0xe1, 0x17, -0xab, 0x7f, 0x5d, 0x6b, 0x16, 0x84, 0xe4, 0x34, -0x1a, 0x2f, 0x2a, 0x48, 0x81, 0xc5, 0xb8, 0x70, -0x80, 0xe3, 0xf8, 0x17, 0x67, 0x91, 0xef, 0xc3, -0x21, 0x98, 0x4f, 0xf9, 0xb8, 0xce, 0x92, 0x3a, -0x56, 0xe0, 0xb3, 0xeb, 0x5f, 0x97, 0x8a, 0xdc, -0xbb, 0xa7, 0xf9, 0xae, 0x7e, 0x8c, 0x0f, 0xcb, -0xa8, 0x9b, 0x25, 0xe1, 0x9f, 0xce, 0x99, 0x63, -0xaa, 0xcd, 0xb7, 0x9c, 0x12, 0xf7, 0xe1, 0xfc, -0x8b, 0x56, 0xa5, 0xdd, 0xab, 0xc9, 0xe7, 0xda, -0x3a, 0x7a, 0x45, 0x02, 0x8d, 0xe3, 0xf0, 0xb4, -0xc9, 0xab, 0x78, 0xe9, 0x71, 0xfc, 0x8b, 0x8d, -0x34, 0xc5, 0x7c, 0x4b, 0xe2, 0x67, 0x6c, 0xec, -0x7b, 0x04, 0xff, 0x7a, 0xdd, 0xc9, 0x1f, 0xb2, -0x0a, 0x02, 0x2d, 0x48, 0xe4, 0x9e, 0xa5, 0x47, -0xe0, 0xaa, 0x6d, 0x05, 0x09, 0x79, 0x10, 0xbe, -0xa0, 0x75, 0x34, 0x98, 0xa9, 0x7f, 0x49, 0x36, -0xdb, 0xca, 0x45, 0x83, 0xd6, 0x28, 0xb9, 0xe3, -0xf8, 0x97, 0x85, 0x5f, 0xbc, 0x2e, 0x63, 0x14, -0x3c, 0x2c, 0xef, 0x5c, 0x78, 0x16, 0x61, 0xab, -0x20, 0x7e, 0x37, 0x63, 0x2e, 0x0b, 0x18, 0x11, -0xeb, 0xcd, 0xe0, 0x17, 0xb2, 0x89, 0x66, 0x4f, -0x31, 0xba, 0xe5, 0x3d, 0x24, 0xc1, 0xb9, 0x95, -0xf2, 0x2c, 0x99, 0xcc, 0xbf, 0xaa, 0x17, 0x7b, -0x10, 0xda, 0xd0, 0xb8, 0xcb, 0x70, 0xf3, 0xfa, -0x17, 0xcc, 0x64, 0x6d, 0xf6, 0x8f, 0xe7, 0x5f, -0x1e, 0xcd, 0x8d, 0x86, 0x1e, 0x60, 0xc5, 0xb2, -0x3e, 0x7e, 0x45, 0x65, 0xb5, 0x24, 0x0b, 0xbf, -0x62, 0xa2, 0x87, 0x09, 0xb9, 0xcc, 0x40, 0x5a, -0x51, 0xfc, 0x20, 0xef, 0xf3, 0x2d, 0x0b, 0x8a, -0x83, 0xe3, 0xeb, 0x5f, 0xd8, 0xe7, 0xcb, 0xe3, -0xf2, 0x9b, 0xf0, 0xbf, 0xb5, 0x7a, 0x63, 0x23, -0x12, 0x16, 0xf5, 0xbc, 0xa8, 0x13, 0x65, 0xd5, -0xbf, 0x18, 0x47, 0xf3, 0xf5, 0x37, 0xcc, 0x80, -0xdf, 0x55, 0x86, 0x9b, 0xf2, 0x39, 0x47, 0x33, -0xc2, 0x4d, 0x2b, 0xe3, 0xf2, 0x7e, 0xb0, 0xf9, -0x97, 0xc2, 0xf8, 0x97, 0x87, 0xa2, 0x9f, 0x5d, -0x6f, 0xcc, 0x06, 0x95, 0xb2, 0xfa, 0x97, 0x1e, -0x40, 0xa3, 0xc8, 0xaa, 0x7f, 0x45, 0xa1, 0xdd, -0xee, 0x73, 0x23, 0xdd, 0x83, 0x20, 0x9e, 0xc7, -0xfa, 0xbc, 0xad, 0x0c, 0x17, 0x9a, 0x46, 0x5e, -0xb7, 0xf0, 0x4b, 0xd9, 0xc9, 0xc6, 0xbe, 0x08, -0xdf, 0xde, 0xef, 0xc2, 0xc3, 0xda, 0x6c, 0xa3, -0x34, 0x6e, 0xe0, 0xd8, 0x5b, 0x75, 0x1c, 0xbb, -0x53, 0xff, 0xb2, 0xfa, 0x9c, 0x1b, 0x97, 0xbf, -0x0b, 0x27, 0x0d, 0x16, 0x27, 0x60, 0x7f, 0x3e, -0xc4, 0x07, 0xe5, 0x65, 0xf5, 0xaf, 0x6c, 0xfe, -0xc5, 0x46, 0xf1, 0x0b, 0xf8, 0x90, 0x72, 0x83, -0xfd, 0xab, 0x0b, 0x8b, 0x7c, 0xf1, 0x86, 0x9f, -0x65, 0xf1, 0x2f, 0xe0, 0xd5, 0xae, 0x18, 0x86, -0x97, 0x0b, 0x90, 0x88, 0x59, 0x73, 0x1a, 0xcc, -0xd4, 0xbf, 0x38, 0xff, 0x9a, 0x93, 0x74, 0xc7, -0x90, 0x92, 0x3f, 0x08, 0x3a, 0x23, 0x62, 0x83, -0x9c, 0x91, 0xa9, 0xac, 0xfe, 0x25, 0xe6, 0x42, -0xf0, 0x2f, 0xd5, 0x3d, 0x9b, 0xac, 0x04, 0x9a, -0xaa, 0x10, 0xf5, 0xe5, 0xe7, 0x79, 0xc5, 0xd9, -0xae, 0x7f, 0x21, 0xff, 0x82, 0xab, 0xa0, 0x2a, -0xe4, 0x36, 0x36, 0x4f, 0x35, 0xd7, 0x80, 0xc4, -0xd2, 0x86, 0xef, 0xb2, 0x37, 0xbc, 0xaf, 0xa3, -0x19, 0x6f, 0xc8, 0xef, 0xd3, 0xa1, 0x3e, 0xc6, -0xf8, 0x57, 0xa2, 0x20, 0x2a, 0x7f, 0x87, 0xf6, -0xd1, 0xab, 0x86, 0xbd, 0xab, 0xe5, 0xe3, 0xf0, -0x87, 0x74, 0xfd, 0xc0, 0x86, 0xd5, 0xf2, 0x47, -0x16, 0x7e, 0x95, 0xec, 0xd6, 0xce, 0xb1, 0x3a, -0x2c, 0xc8, 0x9f, 0x28, 0x38, 0xc0, 0x63, 0xd5, -0xb8, 0x76, 0xf0, 0x4a, 0x5d, 0x3f, 0xae, 0xa6, -0x5e, 0x81, 0x5f, 0xa0, 0xbc, 0x88, 0xfe, 0xf0, -0x5a, 0xdd, 0x1b, 0x95, 0x5f, 0x32, 0x2e, 0xd0, -0x3d, 0x67, 0x5c, 0xdd, 0xe5, 0x17, 0xd0, 0xfb, -0xd5, 0x23, 0x45, 0x2e, 0x32, 0x35, 0x81, 0x5f, -0xa5, 0xc8, 0xa4, 0x30, 0xfc, 0xce, 0xbf, 0xc1, -0x3f, 0x1d, 0x3e, 0xd7, 0xaf, 0x1c, 0x54, 0xef, -0x93, 0x37, 0xc0, 0xbe, 0x78, 0x95, 0x99, 0x7f, -0x2f, 0xf9, 0x48, 0x3c, 0x1f, 0xab, 0xfe, 0x65, -0xa8, 0x8b, 0xc8, 0xa3, 0xf0, 0x0c, 0x29, 0x4f, -0xe5, 0xad, 0x12, 0x7d, 0x66, 0x9d, 0x37, 0xc5, -0xf3, 0xb1, 0xf8, 0x17, 0xe4, 0x01, 0xf1, 0xd1, -0xed, 0xfd, 0x15, 0x0c, 0xc4, 0xf1, 0x8a, 0x8b, -0x57, 0xc4, 0x52, 0x36, 0x7e, 0x31, 0x3f, 0x56, -0x0b, 0x5e, 0x90, 0x5f, 0xd0, 0xbb, 0xcd, 0xbd, -0xe8, 0xd0, 0xca, 0x59, 0x4e, 0xe6, 0x9f, 0xf8, -0x7a, 0x77, 0xf0, 0x8b, 0xf9, 0x04, 0xed, 0x28, -0xfd, 0xfa, 0x6e, 0x60, 0xf5, 0x2f, 0xe1, 0xeb, -0x24, 0x46, 0xc4, 0x64, 0x2b, 0x7f, 0x58, 0x26, -0xea, 0x5f, 0xe0, 0xed, 0x41, 0x9a, 0x73, 0x78, -0xeb, 0x3c, 0x24, 0x62, 0x3c, 0x67, 0x35, 0x0f, -0x7d, 0x4b, 0x83, 0x29, 0xf0, 0x4b, 0xf0, 0xaf, -0xea, 0x79, 0xee, 0x76, 0xcf, 0x12, 0x25, 0x81, -0x00, 0x94, 0xcf, 0xfc, 0xe1, 0x5e, 0x91, 0x1f, -0xb3, 0xd6, 0x17, 0x15, 0x39, 0x2b, 0x1d, 0x5f, -0xd1, 0x95, 0xca, 0x56, 0x95, 0xf3, 0xaf, 0x21, -0xf8, 0x25, 0xc7, 0xb8, 0x9c, 0x0c, 0xff, 0x52, -0x70, 0x5c, 0x8a, 0xbb, 0x18, 0xe7, 0x34, 0xa1, -0x6c, 0x7f, 0x79, 0x4a, 0x38, 0x8c, 0x73, 0x7a, -0x7d, 0xc2, 0xf4, 0xcc, 0xdd, 0xdc, 0x6b, 0xe7, -0x0f, 0xd9, 0x77, 0xd5, 0x69, 0xde, 0xb5, 0xf2, -0x3f, 0x9a, 0xc7, 0xa4, 0x79, 0xef, 0x16, 0xec, -0x91, 0x3f, 0x81, 0x8f, 0x8d, 0x42, 0x56, 0x2b, -0x31, 0x25, 0x9b, 0x7f, 0x25, 0xb0, 0xcf, 0xaa, -0x6f, 0x6d, 0xd1, 0x50, 0xe3, 0x19, 0xa8, 0x4b, -0xe5, 0x7f, 0xde, 0xc0, 0xaf, 0x98, 0x4b, 0x87, -0xe5, 0x4c, 0xfd, 0x8b, 0xe3, 0x97, 0xef, 0x59, -0xf9, 0x20, 0x0c, 0xd1, 0x9a, 0x3e, 0xef, 0x88, -0x3c, 0xda, 0x3e, 0x16, 0xb8, 0xb2, 0x02, 0x0d, -0x47, 0xbf, 0x21, 0xf0, 0xeb, 0xc6, 0x2e, 0xed, -0x23, 0x38, 0x46, 0xb7, 0xbd, 0xab, 0x76, 0xb5, -0x8e, 0xc6, 0x5e, 0x8a, 0xe3, 0x42, 0x4b, 0xb6, -0x66, 0xf4, 0x1b, 0xc2, 0xd7, 0x85, 0xf5, 0xc1, -0x4b, 0x76, 0x41, 0x65, 0x8f, 0x1a, 0x0a, 0x6c, -0xa0, 0x7b, 0x61, 0xb9, 0xda, 0x11, 0xce, 0xb1, -0xf5, 0x1b, 0x25, 0xac, 0xda, 0xc5, 0xd0, 0x21, -0x32, 0xa8, 0x6e, 0xd5, 0x03, 0xe6, 0x8a, 0x24, -0x0c, 0x15, 0x5e, 0x03, 0x95, 0xd7, 0x67, 0xe9, -0x37, 0x4a, 0x9c, 0x2c, 0xdf, 0x21, 0x33, 0xad, -0xd6, 0xb0, 0x69, 0xda, 0xad, 0x9e, 0x23, 0x0b, -0x12, 0xde, 0x89, 0xf8, 0x25, 0xd0, 0x6a, 0x94, -0xda, 0xf5, 0x2f, 0x0c, 0x4e, 0xe6, 0x4c, 0xc2, -0xaf, 0xa5, 0xc9, 0xa2, 0x0f, 0x03, 0xa9, 0x45, -0x4c, 0xc8, 0xc1, 0x38, 0x35, 0x59, 0xc0, 0x1c, -0xfe, 0x38, 0xfd, 0x46, 0xb5, 0x79, 0x63, 0x32, -0x30, 0x88, 0x5c, 0xe6, 0xef, 0x7b, 0xb0, 0x1b, -0xa3, 0xea, 0x3e, 0x3d, 0xd0, 0x93, 0x9f, 0x94, -0xbb, 0xc6, 0xe9, 0x37, 0x7a, 0x3a, 0xd9, 0x1b, -0x45, 0x85, 0xeb, 0xc6, 0x91, 0xa6, 0x39, 0x90, -0x65, 0xf4, 0x1b, 0x1c, 0x0b, 0x30, 0x3e, 0xbc, -0xd0, 0x84, 0x44, 0x8c, 0x15, 0x95, 0x8e, 0xc3, -0xde, 0x96, 0xf2, 0x0a, 0x69, 0xb5, 0xb6, 0xd5, -0xe6, 0x5f, 0x5e, 0x86, 0x5f, 0x26, 0xf2, 0xaf, -0x83, 0x09, 0x80, 0x60, 0x1a, 0x81, 0xec, 0xb0, -0x7a, 0x3a, 0x19, 0x82, 0x82, 0x6c, 0xfd, 0x06, -0x8e, 0x02, 0xc7, 0x7e, 0x52, 0x1e, 0xa1, 0xa3, -0xc0, 0x6b, 0xac, 0x9f, 0xe8, 0x63, 0xe4, 0x79, -0x03, 0xaf, 0xd8, 0xfc, 0xcb, 0x35, 0x54, 0xca, -0x9f, 0x4f, 0xb7, 0x5c, 0x09, 0x27, 0xa0, 0xeb, -0x30, 0x3e, 0xa8, 0x4f, 0xe0, 0x5c, 0xf4, 0x27, -0x65, 0x18, 0x78, 0x64, 0xea, 0x5f, 0x16, 0x7e, -0x45, 0x4a, 0xb5, 0x76, 0x28, 0xeb, 0xf5, 0xe0, -0x7a, 0xa7, 0xfb, 0xf4, 0xbf, 0x37, 0xd4, 0x61, -0xe4, 0x4d, 0xfc, 0x3e, 0xa6, 0x85, 0x5f, 0x88, -0xb0, 0x61, 0x78, 0xa1, 0xbd, 0xec, 0x43, 0x46, -0x1e, 0x29, 0xae, 0xc1, 0xb9, 0x95, 0xab, 0x1d, -0xfe, 0x55, 0xec, 0xe0, 0x57, 0x5e, 0xac, 0x95, -0xb2, 0xfc, 0xc6, 0x62, 0x7e, 0xa5, 0x19, 0x1f, -0x82, 0xc3, 0xbf, 0x06, 0x39, 0x7e, 0xf9, 0x12, -0xb9, 0xa5, 0x70, 0xc1, 0x64, 0xf9, 0x43, 0x59, -0x64, 0x14, 0x97, 0x24, 0xca, 0x1d, 0xfe, 0x95, -0x50, 0x58, 0xae, 0x69, 0x29, 0x95, 0x4f, 0x68, -0x23, 0xa1, 0x1f, 0xc3, 0x4d, 0xb4, 0x88, 0x11, -0x8d, 0x3a, 0x75, 0x29, 0xcd, 0x1d, 0xa7, 0xdf, -0xe0, 0x7e, 0xf5, 0x03, 0xe3, 0x00, 0xc2, 0xd6, -0x91, 0x78, 0xa4, 0x0f, 0x79, 0x41, 0x98, 0x39, -0xcf, 0xf1, 0xf8, 0x65, 0xe4, 0xc5, 0xc9, 0x07, -0xb4, 0x05, 0xf9, 0x57, 0x20, 0x1e, 0x58, 0xae, -0xb4, 0x98, 0x81, 0x45, 0x1e, 0x07, 0xbf, 0x4a, -0x05, 0x7e, 0x09, 0xd9, 0xc6, 0xfd, 0x1c, 0xb6, -0xfc, 0x03, 0x9c, 0xac, 0x79, 0x1c, 0xfc, 0x52, -0x15, 0x81, 0x05, 0x08, 0x01, 0x03, 0x24, 0x8f, -0xe8, 0x51, 0xb7, 0x46, 0x1a, 0x1f, 0x6a, 0xab, -0xd0, 0x0d, 0x4f, 0x06, 0xbf, 0xbc, 0x16, 0xc2, -0xba, 0xd0, 0x03, 0x44, 0x61, 0x41, 0x71, 0xc1, -0x1a, 0xf9, 0x44, 0x53, 0x0a, 0xba, 0x8a, 0x7d, -0x6b, 0x1c, 0xfc, 0x9a, 0x66, 0xfb, 0xf9, 0xc2, -0x37, 0xe1, 0xbc, 0x82, 0xfc, 0x0b, 0xfd, 0x3c, -0x32, 0x32, 0x44, 0xab, 0x78, 0x79, 0xb6, 0x7e, -0x43, 0x70, 0x99, 0x1f, 0x28, 0x3d, 0x24, 0xdc, -0x58, 0x80, 0xa4, 0xc6, 0x38, 0x9f, 0x17, 0x32, -0x36, 0x60, 0x1b, 0x47, 0xbf, 0xa1, 0x75, 0x2b, -0xd5, 0x92, 0xa7, 0x95, 0xa4, 0x55, 0x96, 0x3f, -0xac, 0x84, 0x48, 0xcf, 0x6d, 0xdd, 0x46, 0x40, -0xca, 0x6f, 0x85, 0x8c, 0x7e, 0xc3, 0xc2, 0xaf, -0xd6, 0x3e, 0xf2, 0x04, 0xc6, 0x87, 0x51, 0x34, -0xe8, 0x1e, 0x08, 0xdc, 0x80, 0x46, 0xb6, 0x7e, -0xc3, 0x1a, 0x3b, 0x7d, 0xa2, 0x69, 0xbb, 0x01, -0x02, 0xbb, 0x03, 0xac, 0x1a, 0x98, 0xd1, 0x6f, -0x28, 0x6f, 0x91, 0x3a, 0x63, 0x69, 0xfc, 0xd6, -0xef, 0x6e, 0x3d, 0x21, 0x85, 0x8d, 0x9c, 0xf8, -0xad, 0x03, 0xca, 0x59, 0xe2, 0xbf, 0xc5, 0x1b, -0x2f, 0xca, 0xe8, 0x37, 0xf0, 0x5f, 0xb1, 0x3e, -0x13, 0xd6, 0xf9, 0x5a, 0x36, 0x9c, 0x01, 0xed, -0x24, 0xfc, 0x7a, 0xd1, 0xe5, 0xf1, 0xdc, 0x2c, -0xfd, 0x86, 0x15, 0x81, 0x24, 0xd4, 0x54, 0x4e, -0x98, 0xe1, 0x97, 0x8e, 0x2b, 0xca, 0xd2, 0x6f, -0xf0, 0x67, 0xc8, 0xf8, 0x17, 0xa2, 0x15, 0x4b, -0x1b, 0x4e, 0x31, 0x9f, 0x14, 0x69, 0x43, 0x04, -0xb2, 0x74, 0x10, 0xf1, 0xcb, 0x9f, 0xd1, 0x6f, -0xd8, 0xef, 0x98, 0xa4, 0xc9, 0x36, 0x11, 0x6b, -0x29, 0xe3, 0x8a, 0x29, 0x47, 0xbf, 0x31, 0x55, -0xbc, 0xcf, 0xab, 0x49, 0x29, 0xbc, 0x04, 0x33, -0xfa, 0xe4, 0xfb, 0x10, 0x38, 0xda, 0xc9, 0x9c, -0xbe, 0xca, 0x55, 0x19, 0xfd, 0x06, 0xcf, 0x1f, -0xa6, 0x7d, 0x23, 0x6d, 0x9b, 0xe1, 0x55, 0x3a, -0x77, 0xc8, 0x75, 0x5f, 0xdb, 0x74, 0x63, 0x3f, -0x9d, 0x96, 0xf6, 0xde, 0x2b, 0xdb, 0xfa, 0x8d, -0x69, 0xc2, 0x27, 0xf8, 0x9e, 0x92, 0x4d, 0xf5, -0x63, 0x78, 0x0e, 0x61, 0xcb, 0xf3, 0x49, 0x74, -0x44, 0xa9, 0xeb, 0xf7, 0xec, 0xcd, 0xe8, 0x37, -0x3e, 0xb5, 0xfc, 0x61, 0xdb, 0x7e, 0xe3, 0x3d, -0x5a, 0x33, 0xb0, 0xf1, 0xd9, 0x1d, 0x75, 0x8d, -0xa9, 0xd6, 0xf0, 0x30, 0xae, 0x2f, 0x87, 0x7f, -0x3d, 0xc6, 0xfa, 0x83, 0xd1, 0xa9, 0xff, 0x75, -0x58, 0xa7, 0xcf, 0x4a, 0x7b, 0x9e, 0x0b, 0x3c, -0xa6, 0xd1, 0xe4, 0xac, 0xc1, 0xfc, 0x1a, 0xb7, -0xcd, 0xbf, 0x0c, 0xbe, 0x06, 0x53, 0xb8, 0xf4, -0xfa, 0xe9, 0xff, 0x50, 0x66, 0x31, 0x63, 0x89, -0xb1, 0x65, 0xee, 0x15, 0xa9, 0x4b, 0x57, 0x91, -0xf6, 0x2c, 0xfd, 0x86, 0x18, 0x7b, 0x0f, 0xec, -0xe0, 0xf9, 0x79, 0xc4, 0x8b, 0x38, 0xd9, 0xdd, -0x8f, 0x0f, 0x61, 0x6b, 0x36, 0x7e, 0xd5, 0x31, -0x57, 0x60, 0xde, 0xf5, 0x4e, 0xfa, 0x1a, 0x66, -0xfc, 0x98, 0x1c, 0xc3, 0x30, 0x79, 0xc9, 0xb0, -0xfc, 0xeb, 0x71, 0xf8, 0x85, 0x3e, 0xb3, 0xfc, -0x84, 0xfa, 0x08, 0xbc, 0x88, 0x4e, 0x4f, 0xde, -0x0d, 0x83, 0x50, 0x83, 0xf8, 0x25, 0x2d, 0x9b, -0xa4, 0xdf, 0x18, 0x86, 0xf7, 0xd0, 0xb7, 0x5c, -0x3e, 0x0c, 0xa3, 0x70, 0x18, 0xe6, 0xf5, 0x22, -0x90, 0xa5, 0x33, 0xfc, 0xcb, 0x8a, 0xde, 0xdf, -0xd7, 0xdf, 0x80, 0x05, 0xe6, 0x23, 0x88, 0x5f, -0xe8, 0xf4, 0x76, 0x99, 0x1d, 0x88, 0x5f, 0xb1, -0x09, 0xfa, 0x0d, 0xc6, 0x41, 0x24, 0x4b, 0xbf, -0xb1, 0x2b, 0xc6, 0x88, 0x98, 0xdf, 0xd6, 0x6f, -0x20, 0xda, 0xce, 0x63, 0xfa, 0x8d, 0x05, 0xc4, -0x8c, 0x3c, 0x02, 0x15, 0x08, 0x0a, 0xfe, 0xc3, -0x89, 0x04, 0xcc, 0xee, 0xc5, 0xbe, 0x38, 0xfc, -0x8b, 0xfb, 0xf9, 0x94, 0xef, 0x94, 0x9c, 0x6e, -0x7d, 0x07, 0xae, 0x3a, 0xe6, 0x19, 0x2e, 0x1a, -0x6d, 0x1d, 0x5c, 0x3d, 0x2f, 0xe5, 0xfd, 0x07, -0x39, 0x6d, 0xf1, 0xaf, 0x4b, 0xcf, 0x33, 0x7f, -0xd8, 0xef, 0xfb, 0xbc, 0x68, 0xb8, 0xef, 0x1f, -0xa0, 0xfe, 0x88, 0xe7, 0xf3, 0x97, 0x87, 0x94, -0x37, 0x03, 0xd7, 0x9a, 0x7f, 0xff, 0xb9, 0x3c, -0xe8, 0xca, 0xc6, 0xaf, 0x01, 0xdf, 0x08, 0xd2, -0xae, 0x31, 0x13, 0x27, 0x8e, 0xf3, 0x2f, 0x6d, -0x1e, 0x33, 0xc6, 0xe3, 0x57, 0xca, 0x83, 0xb4, -0x4b, 0x79, 0x5e, 0xaf, 0x4e, 0x7b, 0x92, 0x9b, -0x87, 0xf4, 0x97, 0x20, 0x90, 0xf6, 0x64, 0xeb, -0x0f, 0xed, 0xb9, 0xb0, 0x81, 0x8c, 0x1c, 0xa6, -0x7b, 0x2b, 0x78, 0x52, 0x37, 0x1b, 0xbf, 0x2c, -0xed, 0x8a, 0x2d, 0x44, 0xcc, 0xd4, 0xbf, 0xc6, -0xf3, 0x2f, 0x1f, 0x0b, 0x21, 0x9e, 0x17, 0x49, -0x5d, 0x5e, 0xff, 0x12, 0xba, 0xc1, 0x71, 0xf8, -0x65, 0xc1, 0xd6, 0x78, 0x63, 0x02, 0x7e, 0xb1, -0xfb, 0x28, 0xe7, 0x94, 0xe9, 0xe2, 0x86, 0xa7, -0x99, 0xa0, 0x71, 0x12, 0x7e, 0x21, 0x9e, 0x3a, -0xb4, 0x6b, 0x08, 0x17, 0xc8, 0xf6, 0x8b, 0xe8, -0x0f, 0x33, 0xe3, 0xca, 0xe4, 0xe7, 0x27, 0xe0, -0xd7, 0x89, 0xce, 0x7b, 0xc9, 0x71, 0xca, 0x65, -0x87, 0x0c, 0xbf, 0x5e, 0x8a, 0x97, 0xa5, 0x3d, -0xf7, 0xd9, 0xeb, 0xcb, 0xc1, 0xaf, 0xab, 0x1b, -0x8e, 0x30, 0x21, 0x62, 0xda, 0xb7, 0x50, 0x3e, -0x0c, 0xe7, 0x12, 0x0b, 0xcd, 0x6c, 0xfd, 0xe1, -0x6e, 0x31, 0x8a, 0x64, 0xc3, 0x90, 0x31, 0x26, -0x3a, 0x3f, 0x6a, 0x9c, 0xb3, 0x34, 0x93, 0x0e, -0x7e, 0x89, 0x71, 0x2d, 0xcc, 0x0d, 0x66, 0x1e, -0xd4, 0xb9, 0x8e, 0x1f, 0xa2, 0xb1, 0xe8, 0xa3, -0x89, 0xf8, 0x95, 0x63, 0x2d, 0x7c, 0x16, 0xaf, -0xbe, 0x64, 0x2c, 0x33, 0xc7, 0xeb, 0x0f, 0x2d, -0xfc, 0x9a, 0xae, 0x59, 0xc6, 0x71, 0xd8, 0xd7, -0x5e, 0x76, 0x62, 0xbc, 0xfe, 0x70, 0xaf, 0x12, -0x34, 0x65, 0xe6, 0x52, 0xf8, 0xd8, 0x93, 0x99, -0xb1, 0x4f, 0xe0, 0x5f, 0xbe, 0x84, 0xa7, 0xd2, -0x32, 0x18, 0xff, 0x82, 0x05, 0xcc, 0xc8, 0xd2, -0x1f, 0x5a, 0x6a, 0x43, 0x87, 0x76, 0x4d, 0xe6, -0x5f, 0x8e, 0xc2, 0x4d, 0x18, 0x88, 0x05, 0x15, -0xaa, 0x75, 0x65, 0x02, 0x7e, 0x09, 0x49, 0xa1, -0xc4, 0x65, 0x75, 0x15, 0x9a, 0x75, 0xe5, 0x62, -0xf8, 0x65, 0x19, 0xce, 0x15, 0x07, 0xbf, 0x6c, -0xfe, 0x45, 0xfa, 0xb2, 0x89, 0x58, 0x30, 0x1b, -0xbf, 0x04, 0xff, 0x2a, 0x16, 0x5d, 0x6d, 0xaa, -0x83, 0x07, 0x98, 0x10, 0x71, 0xe4, 0x36, 0xde, -0x67, 0x07, 0xbf, 0x26, 0xf4, 0xf9, 0x26, 0x6e, -0x68, 0x13, 0xf9, 0x17, 0xc7, 0xaf, 0x7e, 0xf6, -0x27, 0xc2, 0x4b, 0x63, 0x68, 0xdc, 0xcc, 0xdb, -0xec, 0xcf, 0xd2, 0x1f, 0x42, 0xb5, 0xea, 0x61, -0xb4, 0x2b, 0xc9, 0x93, 0xd5, 0x18, 0xa2, 0x27, -0x0d, 0xc6, 0xc8, 0x26, 0xe0, 0x57, 0x44, 0xf4, -0x59, 0x45, 0xf0, 0xf5, 0x47, 0xfa, 0x12, 0xd6, -0x28, 0x26, 0xe1, 0x17, 0x0c, 0x64, 0x3d, 0x04, -0xa5, 0x80, 0x8f, 0x3d, 0xc3, 0xbf, 0xde, 0xca, -0xee, 0xb3, 0x65, 0x4c, 0x67, 0x62, 0xce, 0xc1, -0x8c, 0x7e, 0xe3, 0xde, 0xf1, 0x6d, 0x8a, 0xb2, -0xf4, 0x87, 0xb1, 0x6c, 0xfc, 0xe2, 0xfc, 0x6b, -0x04, 0x16, 0xb0, 0xc7, 0xc2, 0xf3, 0xd8, 0x50, -0x30, 0x81, 0x7f, 0x31, 0xb6, 0x15, 0x11, 0x65, -0xaf, 0x1b, 0x19, 0x7e, 0xad, 0x17, 0x46, 0x16, -0xff, 0x7a, 0x48, 0xb0, 0x2d, 0xb6, 0xd0, 0x2a, -0x98, 0xac, 0xd7, 0x0b, 0x2c, 0xfb, 0xed, 0x71, -0xf8, 0x57, 0x42, 0xe0, 0x57, 0x5a, 0xd0, 0x2e, -0x5a, 0x66, 0xca, 0xf7, 0x92, 0xe9, 0xdf, 0x5c, -0x97, 0x98, 0xc5, 0xde, 0xe7, 0xc1, 0x8c, 0x7e, -0xe3, 0x0f, 0xe8, 0xc7, 0x90, 0x76, 0x7d, 0x07, -0xfe, 0xd0, 0x71, 0x65, 0xda, 0xb7, 0x5a, 0x9e, -0xae, 0xbf, 0x9a, 0x98, 0x9b, 0xde, 0x98, 0xe1, -0x5f, 0xd3, 0x76, 0x4b, 0xb8, 0x64, 0x0e, 0x0b, -0x9f, 0xa0, 0xe3, 0xda, 0xe9, 0x92, 0x87, 0xda, -0xcf, 0x2d, 0x7f, 0x86, 0x2d, 0x22, 0x0b, 0xbf, -0x40, 0xe8, 0xb1, 0x07, 0xbc, 0x67, 0x65, 0x34, -0x3a, 0xe6, 0x0d, 0xf8, 0xce, 0xcb, 0x9f, 0x1a, -0x47, 0x53, 0xf3, 0xd2, 0x9d, 0x23, 0xb2, 0xe9, -0xe0, 0x17, 0xe5, 0xfd, 0x61, 0xfa, 0xc3, 0x97, -0xca, 0x74, 0xb6, 0xde, 0x2f, 0x18, 0xeb, 0xda, -0xcb, 0x06, 0x0b, 0x7e, 0x44, 0x3e, 0x72, 0xf2, -0x87, 0x06, 0xd7, 0x1f, 0x72, 0xda, 0x45, 0x66, -0x88, 0x35, 0xf8, 0x53, 0x28, 0x43, 0x20, 0x0b, -0x98, 0xb6, 0x7e, 0x43, 0xb8, 0x94, 0xbc, 0x2c, -0x97, 0x72, 0x98, 0x27, 0x51, 0x71, 0xa1, 0x8d, -0xe3, 0x5f, 0xf5, 0x66, 0x55, 0x92, 0x97, 0xc2, -0xbb, 0x58, 0xd0, 0x3e, 0x4a, 0xde, 0x53, 0xfc, -0x5c, 0x7f, 0x38, 0x1e, 0xbf, 0x0a, 0xd0, 0x6f, -0x30, 0xa3, 0x87, 0xfb, 0x84, 0x8f, 0xc1, 0xaa, -0x7f, 0x65, 0xf0, 0x4b, 0x72, 0x5c, 0xe5, 0x3f, -0xa1, 0x51, 0x34, 0x2a, 0x14, 0x80, 0xc3, 0x32, -0x8c, 0xc7, 0xaf, 0x1b, 0xd1, 0x3f, 0x4b, 0xcf, -0x2b, 0x75, 0xb6, 0x7f, 0xae, 0x36, 0x6f, 0x4e, -0xca, 0x09, 0x5b, 0xbf, 0x11, 0xb4, 0x73, 0x68, -0xb6, 0xcf, 0x9c, 0xe9, 0x38, 0x4f, 0x3d, 0xa3, -0xdf, 0x10, 0x5a, 0xf4, 0x08, 0x2b, 0xe7, 0x55, -0xa6, 0x0e, 0x31, 0xfd, 0xe1, 0x5e, 0x3d, 0x98, -0x72, 0x77, 0xf9, 0x5b, 0x33, 0xfc, 0xeb, 0x1c, -0x5c, 0xdb, 0xeb, 0xdb, 0x27, 0x7f, 0x42, 0x5f, -0x82, 0xea, 0x37, 0x59, 0x6e, 0x10, 0xc6, 0x98, -0x78, 0xf2, 0x69, 0x19, 0xac, 0xfa, 0xd7, 0xa5, -0xcc, 0x0d, 0x62, 0x0f, 0x9f, 0x91, 0x87, 0xd2, -0x63, 0x4a, 0x5d, 0x9f, 0xaf, 0xab, 0x01, 0xfd, -0xe1, 0xc2, 0xba, 0xbe, 0x82, 0x67, 0xe4, 0x5d, -0x96, 0x7e, 0xc3, 0xf5, 0x22, 0x7c, 0xb6, 0xb6, -0x0e, 0xe3, 0x16, 0xf9, 0x45, 0x72, 0x34, 0x30, -0xaf, 0x1f, 0x8d, 0x21, 0x38, 0xea, 0xaa, 0x4f, -0x2d, 0x3d, 0xeb, 0x71, 0xea, 0x5f, 0x9f, 0xba, -0x18, 0xff, 0x42, 0xd8, 0xfa, 0x54, 0xdb, 0x78, -0x5f, 0x79, 0x3f, 0x76, 0x75, 0x0c, 0x3a, 0xfb, -0xe7, 0x0c, 0xdc, 0xd8, 0x15, 0xb0, 0xeb, 0x5f, -0x56, 0xae, 0xc9, 0x1d, 0x66, 0x14, 0x18, 0x2a, -0x8e, 0xb1, 0xb9, 0x88, 0xb6, 0x09, 0x20, 0xdb, -0x3e, 0x11, 0xbf, 0xf8, 0xd8, 0x67, 0x73, 0x20, -0xcb, 0xe9, 0x84, 0xea, 0x1e, 0x4f, 0x32, 0x27, -0x64, 0xe1, 0x57, 0xa1, 0x93, 0x3f, 0xdc, 0xed, -0x3d, 0x07, 0xab, 0xd8, 0x34, 0x0d, 0x31, 0xc5, -0x38, 0x7b, 0xc7, 0xe2, 0x13, 0xf1, 0xeb, 0xee, -0x51, 0xfd, 0x55, 0x0c, 0x45, 0xbe, 0x21, 0x74, -0x0e, 0x75, 0x93, 0xf0, 0x2b, 0x6c, 0x3a, 0x69, -0x43, 0x37, 0x1a, 0xe4, 0x90, 0xc2, 0xf3, 0x6c, -0xe3, 0xf0, 0x8b, 0xa1, 0xa7, 0xfc, 0x20, 0xad, -0x87, 0x39, 0xc8, 0xbf, 0x02, 0xc7, 0x61, 0x23, -0xcc, 0x61, 0xb9, 0xdc, 0x71, 0xf8, 0x65, 0x97, -0x56, 0x61, 0xa5, 0x79, 0x03, 0x1a, 0xc6, 0x0e, -0x12, 0x34, 0xa3, 0x49, 0x25, 0x83, 0x5f, 0xd2, -0x4b, 0x09, 0xae, 0x3c, 0x7f, 0xac, 0x1d, 0xb1, -0x60, 0x88, 0xf3, 0x2f, 0xae, 0xa8, 0xbf, 0x2f, -0xe2, 0xe0, 0x57, 0x81, 0x79, 0x2e, 0x91, 0xfc, -0xf0, 0xc1, 0x1a, 0xf9, 0x08, 0x9c, 0xa6, 0x75, -0x43, 0x05, 0x0b, 0x1b, 0x8e, 0x98, 0xbf, 0x5d, -0x53, 0x3b, 0x14, 0xac, 0x91, 0xb2, 0xf9, 0x97, -0x56, 0xdf, 0xc7, 0xd2, 0x86, 0xaa, 0x90, 0xa3, -0xc8, 0xe7, 0xe1, 0x46, 0x36, 0xd2, 0x3d, 0xd9, -0xfa, 0x43, 0x36, 0x9c, 0xcb, 0xbb, 0x65, 0xc4, -0xaf, 0x85, 0x75, 0x29, 0x36, 0x40, 0x7a, 0x8e, -0xd4, 0xbd, 0xee, 0x9b, 0xcc, 0xbf, 0x86, 0x09, -0x5b, 0xf8, 0xc1, 0x37, 0xec, 0x7c, 0xcb, 0x31, -0x4f, 0xb3, 0x3b, 0xab, 0xfe, 0x25, 0x60, 0x6b, -0xd5, 0xf4, 0xd2, 0x5f, 0xec, 0x14, 0x9c, 0xd1, -0xdc, 0x97, 0xe4, 0x40, 0x96, 0x54, 0x6c, 0xfc, -0x52, 0x04, 0x64, 0x47, 0xbc, 0xd6, 0x26, 0x02, -0x01, 0xe2, 0xcc, 0xb7, 0x6c, 0x9e, 0x88, 0x5f, -0xc8, 0x07, 0x3f, 0x92, 0x58, 0xda, 0xb0, 0x41, -0x30, 0xb2, 0xa5, 0x09, 0xf9, 0xb9, 0xf1, 0xf8, -0xe5, 0xc0, 0xd6, 0x37, 0x28, 0x2f, 0xf4, 0xb0, -0x2b, 0xd2, 0x2d, 0x93, 0xf1, 0x8b, 0xe5, 0x76, -0x8c, 0x95, 0x68, 0xd0, 0x93, 0xca, 0xc5, 0xf8, -0x17, 0x7a, 0xe3, 0xe5, 0x29, 0x2b, 0x6d, 0xf8, -0x01, 0xe2, 0xd7, 0xec, 0x2f, 0xc5, 0x2f, 0x29, -0xb8, 0x48, 0xb5, 0x39, 0xc8, 0x45, 0xf1, 0xab, -0x11, 0xf6, 0x04, 0x82, 0xd1, 0x94, 0xd0, 0xcf, -0x57, 0x46, 0x27, 0xe1, 0x17, 0x20, 0xdb, 0xe2, -0xf8, 0x55, 0xbc, 0x61, 0x8d, 0xad, 0x4f, 0x70, -0xc9, 0x9f, 0x4a, 0xe3, 0xf1, 0xab, 0xbf, 0x68, -0xb9, 0xd0, 0xcf, 0x23, 0x4f, 0x71, 0xf4, 0xf3, -0xe2, 0x5d, 0x2d, 0x95, 0x44, 0x9b, 0xa5, 0x71, -0xf9, 0x07, 0x70, 0x00, 0x6a, 0xd8, 0x9f, 0xce, -0xc0, 0x59, 0x7d, 0x15, 0xc7, 0x2f, 0x25, 0x1b, -0xbf, 0xc0, 0x43, 0x70, 0x14, 0xbb, 0xf4, 0x00, -0x20, 0x11, 0x3b, 0xb1, 0xa8, 0x5b, 0x5a, 0xa0, -0xa1, 0xe1, 0xe0, 0x57, 0xa3, 0xc3, 0xbf, 0xa0, -0x25, 0xaa, 0xdf, 0xc1, 0x8d, 0x3d, 0x86, 0xde, -0xe4, 0xb9, 0x28, 0xff, 0x92, 0x9e, 0x90, 0x02, -0x86, 0xcc, 0xc6, 0x7e, 0x35, 0x99, 0x29, 0xc6, -0xee, 0xe0, 0x97, 0xc5, 0x73, 0x07, 0xe0, 0x80, -0x54, 0x23, 0x40, 0x8a, 0x3d, 0x1f, 0xa6, 0x9f, -0x07, 0x07, 0xbf, 0x32, 0xd0, 0x46, 0x5e, 0xe4, -0x79, 0x51, 0x38, 0x79, 0x51, 0xfc, 0x62, 0xb4, -0xcb, 0x1c, 0x86, 0x9f, 0xb0, 0xb2, 0x97, 0x6e, -0xcf, 0xb2, 0xcd, 0xd1, 0x38, 0x7e, 0x15, 0x30, -0xda, 0x35, 0x05, 0x8d, 0x9f, 0xb0, 0xb4, 0xa1, -0x40, 0xb4, 0x86, 0x44, 0xc3, 0x04, 0xfd, 0xc6, -0xc3, 0x21, 0x92, 0xc3, 0x5f, 0x36, 0x77, 0x88, -0x28, 0x3c, 0x6a, 0x62, 0xf8, 0xa5, 0x64, 0xe3, -0x97, 0x89, 0xd1, 0xa0, 0x06, 0xfb, 0x34, 0x95, -0x25, 0xbd, 0xd9, 0x95, 0x7c, 0xb3, 0xb3, 0x99, -0xec, 0xca, 0xc6, 0xaf, 0x6b, 0xd3, 0x37, 0xdd, -0xd7, 0x76, 0x19, 0x1a, 0xf9, 0xe9, 0xe9, 0x67, -0xe5, 0x4b, 0xf2, 0x38, 0x23, 0x5b, 0x2d, 0x7d, -0x94, 0xcd, 0xbf, 0xa6, 0xb3, 0xd5, 0x94, 0x86, -0x73, 0xee, 0xba, 0xfe, 0xfc, 0xae, 0xaf, 0x0f, -0x88, 0x20, 0xf0, 0x99, 0xb6, 0x0c, 0x7e, 0x01, -0xc3, 0x2f, 0xdf, 0xb3, 0x32, 0x31, 0x8e, 0xb6, -0x84, 0x3f, 0x47, 0x42, 0xf7, 0xb9, 0x71, 0x94, -0x29, 0xea, 0xcf, 0x3e, 0xe4, 0xe0, 0xd7, 0x83, -0xb0, 0x77, 0x3b, 0x86, 0xa9, 0x0b, 0x67, 0x13, -0xfa, 0x06, 0xe8, 0xe9, 0x29, 0x0b, 0x71, 0x7d, -0xed, 0x48, 0x06, 0xcd, 0xca, 0x1a, 0x7f, 0x06, -0xbf, 0xb4, 0x7d, 0x7a, 0x95, 0xe9, 0x1e, 0x26, -0x4d, 0xb0, 0x4e, 0x2b, 0x33, 0x6f, 0x6c, 0x26, -0x7d, 0xca, 0x3a, 0x7f, 0x90, 0xe7, 0x0f, 0xb3, -0xf1, 0x8b, 0x2b, 0xc1, 0x0c, 0xe4, 0x32, 0xdc, -0xc9, 0xf4, 0xc1, 0x0e, 0xae, 0x66, 0xc9, 0xc2, -0x2f, 0x0c, 0xbf, 0xd1, 0x1f, 0x0e, 0xcb, 0x06, -0x1c, 0x85, 0xbd, 0xe8, 0xe2, 0x70, 0x4e, 0x99, -0x3f, 0xf4, 0x0e, 0x4f, 0xc4, 0x2f, 0x0c, 0xf5, -0x13, 0x3c, 0x6d, 0x88, 0x7e, 0xc3, 0x1a, 0x17, -0xe3, 0x44, 0x13, 0xf8, 0x57, 0xf9, 0x30, 0x7c, -0x06, 0xf3, 0x18, 0x0e, 0x2e, 0x00, 0x91, 0x8b, -0x0b, 0x98, 0x93, 0xf8, 0xd7, 0x6f, 0x95, 0x4e, -0x0c, 0xe3, 0x0b, 0x92, 0xe4, 0xd7, 0xf6, 0x95, -0xf4, 0x78, 0xfc, 0xc2, 0x98, 0xff, 0x7d, 0x9d, -0xd5, 0xbf, 0xb0, 0xcf, 0x15, 0xd4, 0x6e, 0xe3, -0xe0, 0x97, 0xbe, 0x57, 0x0d, 0xf6, 0x79, 0xe6, -0x13, 0xd3, 0xc4, 0x50, 0xe4, 0xf0, 0xc1, 0x30, -0x59, 0xa3, 0xe2, 0x15, 0xd3, 0x33, 0x8f, 0x38, -0xf9, 0xc3, 0xef, 0x99, 0xcf, 0x37, 0x23, 0xff, -0xfa, 0x5c, 0x4e, 0xd3, 0xdf, 0x37, 0x21, 0xee, -0x7c, 0xfe, 0xb5, 0x19, 0xda, 0xb9, 0x50, 0xdd, -0x9b, 0x4b, 0x87, 0xcb, 0x1d, 0xfd, 0x06, 0x1b, -0x57, 0xfd, 0x31, 0xdf, 0x0f, 0x1b, 0x86, 0xcd, -0x31, 0x7d, 0xce, 0x2b, 0x05, 0x7b, 0xdb, 0x46, -0xe3, 0xe7, 0xca, 0xea, 0x0f, 0x20, 0xa2, 0xd9, -0xfa, 0x43, 0x31, 0x5f, 0x69, 0xce, 0xbf, 0x5e, -0x12, 0x44, 0xec, 0xd7, 0xf0, 0x39, 0x63, 0xd0, -0x4e, 0xfe, 0xd0, 0xb4, 0xf2, 0x87, 0x9e, 0xae, -0x56, 0x87, 0x88, 0x0d, 0xd1, 0xe7, 0xf0, 0x4a, -0x1e, 0xf2, 0x2f, 0xf1, 0x7c, 0xa2, 0x4e, 0xfe, -0x90, 0x6c, 0x50, 0xe7, 0x59, 0x3c, 0x45, 0xef, -0x12, 0xc6, 0x47, 0x93, 0xf9, 0x57, 0x06, 0xc8, -0x9e, 0x13, 0x86, 0xc5, 0xbf, 0x68, 0x86, 0x7f, -0x09, 0x02, 0x75, 0x79, 0xd2, 0xda, 0xa3, 0x81, -0x57, 0x2c, 0x4d, 0x4e, 0x06, 0xbf, 0x1a, 0x46, -0xad, 0x29, 0x40, 0xec, 0xbe, 0xc0, 0x77, 0x49, -0x34, 0x8c, 0x08, 0x2d, 0x0d, 0xc3, 0xaf, 0x8f, -0x1d, 0xfe, 0x05, 0x82, 0x7f, 0x15, 0x7f, 0x41, -0xfd, 0x59, 0xfc, 0xab, 0xc3, 0x15, 0xa4, 0x59, -0x78, 0xea, 0xf4, 0x67, 0x22, 0xff, 0xda, 0x31, -0x89, 0x7f, 0x75, 0x09, 0x44, 0x1b, 0x16, 0x53, -0x91, 0x68, 0x99, 0x4e, 0x05, 0x16, 0xe4, 0xd8, -0xfc, 0x2b, 0x70, 0x9c, 0xbe, 0x48, 0xcb, 0x18, -0x16, 0x1c, 0xa3, 0xbc, 0x0d, 0xdb, 0xff, 0xf5, -0x5b, 0xe0, 0xfa, 0x8d, 0x23, 0xc6, 0x69, 0xad, -0x76, 0xd0, 0x87, 0xf8, 0x45, 0x4f, 0xc5, 0x43, -0x8c, 0x88, 0xbd, 0x9d, 0xc3, 0xdb, 0x88, 0xfc, -0x21, 0xdb, 0x13, 0x51, 0x64, 0xbd, 0x6c, 0x7b, -0x70, 0x5c, 0x5f, 0x48, 0x88, 0x68, 0x88, 0x5f, -0x42, 0xd7, 0xb4, 0xcb, 0x75, 0x58, 0x3d, 0x24, -0xf2, 0x87, 0x41, 0xce, 0x4f, 0x79, 0xac, 0x75, -0x50, 0x18, 0xbd, 0x16, 0x7e, 0x6d, 0x12, 0x6a, -0x43, 0x0b, 0xbf, 0x2c, 0xfe, 0xb5, 0x56, 0x18, -0xaf, 0xdb, 0xef, 0xfc, 0x63, 0x4c, 0x2d, 0xcf, -0xf9, 0x17, 0x38, 0xfc, 0x6b, 0x2d, 0x1a, 0x37, -0xae, 0xb6, 0xe3, 0x43, 0xc4, 0x2f, 0xd2, 0x26, -0x86, 0xec, 0x95, 0xac, 0xb1, 0x0f, 0x41, 0x2b, -0x78, 0xb3, 0xf9, 0x57, 0x61, 0x07, 0x30, 0xb5, -0x3c, 0x97, 0x1d, 0x7e, 0x81, 0xae, 0x29, 0x37, -0x41, 0x06, 0xc9, 0x83, 0x84, 0xef, 0xfa, 0xf9, -0x42, 0xf8, 0xba, 0x49, 0xf8, 0x35, 0x8e, 0x7f, -0x89, 0xb9, 0x60, 0xf8, 0x75, 0x60, 0x22, 0x2f, -0x50, 0x0e, 0xc4, 0x2d, 0xfe, 0xc5, 0xdb, 0x20, -0x7e, 0x11, 0xa6, 0x24, 0xf4, 0xc5, 0xc3, 0x36, -0xbf, 0xf0, 0x0f, 0x28, 0x6f, 0x91, 0x1a, 0x81, -0x5f, 0xfc, 0x23, 0xf4, 0xf3, 0x36, 0x7e, 0x11, -0x27, 0x91, 0x68, 0xf1, 0x2f, 0xe1, 0xc7, 0x14, -0x45, 0x6b, 0xc9, 0xf0, 0xaf, 0x95, 0x8b, 0x1e, -0x41, 0x43, 0xdb, 0x24, 0xae, 0x44, 0x44, 0x1b, -0x86, 0x5f, 0x6c, 0x7f, 0x93, 0x67, 0x0d, 0x87, -0xda, 0x9f, 0x14, 0x6f, 0xa4, 0x72, 0xcf, 0xa2, -0x14, 0xfc, 0x04, 0x2e, 0x47, 0xfe, 0x25, 0xf2, -0x1b, 0xa9, 0x7c, 0xd1, 0xd5, 0x02, 0xab, 0xcf, -0x8b, 0x38, 0x36, 0x9d, 0x17, 0x82, 0xbd, 0x4f, -0x2d, 0xfe, 0x25, 0x21, 0x5a, 0x49, 0xfc, 0x4f, -0x03, 0xd2, 0x59, 0xa9, 0xfa, 0x9b, 0x68, 0x3c, -0x2e, 0xbd, 0x06, 0x1c, 0x97, 0x2d, 0xbe, 0xbc, -0xda, 0xc2, 0xaf, 0xcb, 0x81, 0x58, 0x40, 0x46, -0x89, 0xde, 0xda, 0x01, 0x01, 0x66, 0xec, 0xb7, -0xf5, 0xf3, 0x99, 0xfc, 0x21, 0x1a, 0x15, 0x62, -0x93, 0x57, 0x0b, 0xf0, 0x9c, 0xe7, 0xeb, 0x62, -0xbe, 0x4a, 0x6f, 0x17, 0xf8, 0xb5, 0x3e, 0xc3, -0x3d, 0xfd, 0x15, 0xca, 0x2c, 0xc4, 0xa6, 0x97, -0xe3, 0xe1, 0xfd, 0xe2, 0x19, 0x26, 0x8a, 0x77, -0x7a, 0x59, 0x7f, 0x3c, 0x02, 0xb6, 0x18, 0xb4, -0xc9, 0xed, 0xf8, 0x7c, 0x78, 0x7f, 0x06, 0x85, -0x2e, 0x6e, 0x85, 0x93, 0x3f, 0x74, 0xe6, 0x82, -0x89, 0xed, 0xe1, 0x45, 0x76, 0xe5, 0x6d, 0x8b, -0x5b, 0x39, 0xfb, 0xbf, 0x8a, 0x74, 0xc5, 0x9e, -0x53, 0x6e, 0x60, 0x9f, 0x33, 0xfb, 0xbf, 0x40, -0xec, 0xff, 0x8a, 0x30, 0xd8, 0xaa, 0x61, 0xb4, -0x6b, 0x50, 0xeb, 0xa2, 0xec, 0x4a, 0xb8, 0x57, -0x3c, 0xe7, 0x4a, 0x57, 0xa3, 0xc4, 0xde, 0xb1, -0x29, 0xe3, 0x38, 0xfe, 0x1e, 0x1a, 0x34, 0x6f, -0x0c, 0xf9, 0x7b, 0xed, 0xf8, 0xf0, 0x12, 0xfe, -0x3e, 0x77, 0xde, 0x97, 0xf5, 0x3e, 0xd3, 0xa7, -0x55, 0x66, 0xe8, 0x29, 0x83, 0xaf, 0xd3, 0x4a, -0xf5, 0x12, 0xf2, 0x2a, 0x43, 0xab, 0x7f, 0x92, -0xa7, 0x2b, 0x7f, 0x68, 0x67, 0xb0, 0x25, 0x1f, -0x4f, 0x0a, 0xfc, 0x92, 0x0f, 0x8a, 0xf5, 0xa5, -0x4e, 0x6b, 0xcf, 0x4a, 0x59, 0x48, 0x97, 0xf5, -0x31, 0x83, 0x71, 0xfc, 0x2c, 0xfe, 0x65, 0x94, -0x7c, 0x6e, 0xd7, 0x53, 0x3e, 0xe5, 0x8e, 0xd1, -0x8b, 0x8e, 0x51, 0x7f, 0x1a, 0x1f, 0x00, 0xfa, -0xc3, 0x63, 0x96, 0x26, 0xf0, 0xd2, 0x76, 0xd1, -0x8d, 0x85, 0x91, 0x23, 0x48, 0xc4, 0xaa, 0x19, -0x11, 0x7b, 0x17, 0xf6, 0x3c, 0x85, 0x3e, 0x61, -0x21, 0xf9, 0x58, 0xb4, 0x01, 0xba, 0x25, 0xd3, -0xd5, 0x7d, 0x1a, 0xdb, 0x08, 0x16, 0x79, 0xd7, -0xf8, 0x57, 0x9d, 0x03, 0xd9, 0x4e, 0x2b, 0x7f, -0xa8, 0xf4, 0x65, 0xa7, 0x74, 0xaa, 0x33, 0x44, -0xec, 0x91, 0x10, 0xfc, 0x46, 0xb1, 0xd6, 0xfb, -0x4e, 0xde, 0x67, 0xcf, 0x30, 0x07, 0x29, 0x46, -0xc4, 0xa4, 0x51, 0xec, 0x33, 0xcf, 0x47, 0x3d, -0x09, 0xd6, 0x5a, 0x1e, 0xb2, 0x6a, 0x25, 0x56, -0xac, 0xfe, 0xa0, 0xd0, 0x0c, 0x58, 0xde, 0x4f, -0xe0, 0x17, 0x7c, 0xce, 0x5d, 0x4a, 0x81, 0x90, -0x2f, 0xd6, 0xdb, 0xf5, 0x2f, 0x46, 0xc4, 0xe4, -0xf4, 0x72, 0x2b, 0x3e, 0x5c, 0x99, 0x71, 0x83, -0x1f, 0x4b, 0xd5, 0xa2, 0xb6, 0x85, 0x2f, 0x52, -0x0f, 0x02, 0xd9, 0x49, 0x7b, 0xff, 0xd7, 0xf2, -0xf1, 0x3e, 0xb3, 0x94, 0x19, 0xcf, 0x72, 0x32, -0x42, 0xd2, 0x12, 0x9f, 0x0b, 0x15, 0xf2, 0xd9, -0xb8, 0xfa, 0x59, 0xda, 0x90, 0xee, 0x50, 0x56, -0x9a, 0xee, 0x05, 0x6c, 0x4e, 0xb5, 0x60, 0x9f, -0x3b, 0xec, 0xb7, 0xe6, 0x1d, 0xd4, 0xe5, 0x62, -0x2e, 0x4e, 0xb7, 0x0d, 0xc5, 0xd0, 0x8f, 0x1d, -0xf3, 0x3e, 0x45, 0xce, 0xc3, 0xd9, 0x15, 0x78, -0x65, 0xaf, 0x9c, 0xce, 0xb5, 0xf5, 0x1b, 0xac, -0xab, 0x29, 0xce, 0x19, 0x3f, 0x23, 0xf5, 0x47, -0x98, 0x3f, 0xdc, 0x75, 0x4e, 0xaf, 0x4f, 0x15, -0xec, 0x2d, 0x72, 0xf0, 0xeb, 0xd7, 0xf0, 0x0e, -0xce, 0x57, 0xfe, 0x88, 0xa7, 0x8e, 0x1c, 0x5e, -0x36, 0xcf, 0xfb, 0xe0, 0xb3, 0x2c, 0x7f, 0x48, -0xeb, 0xb3, 0xf2, 0x87, 0x66, 0xe9, 0xa7, 0xda, -0xf3, 0xb4, 0x86, 0x65, 0x0b, 0xab, 0xbd, 0xeb, -0x43, 0x7a, 0xbe, 0xda, 0x55, 0xf4, 0x6b, 0x51, -0x11, 0x43, 0xfc, 0x12, 0xfa, 0xf9, 0x54, 0xe3, -0x61, 0xe5, 0x21, 0xc2, 0x5f, 0xbf, 0x0d, 0xb0, -0x0d, 0x2a, 0x4c, 0x77, 0x96, 0xc3, 0x7f, 0xdf, -0xd6, 0xcf, 0x3b, 0xfc, 0x2b, 0xa8, 0x26, 0x20, -0x07, 0x2a, 0x93, 0x11, 0xbc, 0x22, 0x15, 0x30, -0x34, 0xb7, 0xb4, 0xfa, 0x80, 0xf8, 0xf5, 0x0e, -0x86, 0x10, 0xf9, 0x21, 0xf4, 0xcf, 0x83, 0xf0, -0xb9, 0xb6, 0x38, 0xa3, 0xbb, 0x18, 0x9f, 0x3f, -0xbc, 0x06, 0xe7, 0x54, 0x1a, 0x85, 0x77, 0xe0, -0x6a, 0xea, 0x63, 0xc6, 0xf8, 0xfc, 0xe1, 0x6d, -0x9c, 0x7f, 0xfd, 0xc4, 0xf4, 0x76, 0x31, 0x7a, -0x82, 0xbc, 0x3b, 0xdf, 0xbe, 0xcf, 0xc6, 0x49, -0xf9, 0x43, 0xf5, 0xa9, 0xd6, 0xa3, 0x8c, 0x88, -0x51, 0x95, 0xd5, 0xc8, 0x26, 0xe9, 0x37, 0x34, -0xce, 0xf1, 0x6b, 0xc9, 0x51, 0xf4, 0x24, 0x95, -0xe0, 0x61, 0xbb, 0x5c, 0xac, 0xa8, 0x69, 0x58, -0xc4, 0xfc, 0xc3, 0xda, 0x77, 0x38, 0x6c, 0xe5, -0xdd, 0x47, 0x8e, 0x97, 0x3d, 0x43, 0x67, 0x2d, -0x6f, 0x65, 0x42, 0xc4, 0xab, 0x12, 0x55, 0x3c, -0x7f, 0x68, 0xeb, 0xe7, 0x6f, 0xa6, 0xa7, 0x93, -0xc1, 0xc1, 0x7c, 0xc4, 0x2f, 0xf3, 0x24, 0x2c, -0x1c, 0xfc, 0xcb, 0x85, 0xc8, 0x4f, 0x4f, 0x27, -0x6a, 0x45, 0xfe, 0x50, 0x13, 0x6b, 0x67, 0x37, -0xd3, 0x6f, 0xf4, 0x55, 0xef, 0xc1, 0xae, 0x8e, -0x4a, 0x3f, 0x34, 0xc4, 0xfe, 0x2f, 0x96, 0x3f, -0xdc, 0x93, 0xa5, 0xdf, 0x50, 0x7e, 0xa4, 0xd4, -0xf0, 0x1c, 0x23, 0xa7, 0x03, 0xf9, 0xc9, 0x22, -0x5e, 0x83, 0xc6, 0x2b, 0x77, 0xf7, 0x8a, 0xe7, -0x93, 0x72, 0xf4, 0x1b, 0x2c, 0x6d, 0x08, 0x7a, -0x5f, 0x47, 0xb3, 0xec, 0x5c, 0x79, 0x3d, 0x5b, -0xbf, 0x31, 0x8b, 0x63, 0x2e, 0xcb, 0xc9, 0xbc, -0xbf, 0x62, 0xb5, 0xd8, 0x73, 0xcd, 0x80, 0x2c, -0xe5, 0xe8, 0x37, 0x34, 0x31, 0x83, 0x39, 0x87, -0xf1, 0x9f, 0x97, 0xa7, 0x3b, 0x78, 0x7d, 0x59, -0xcc, 0xe9, 0xdb, 0x90, 0x55, 0xff, 0xaa, 0x41, -0xfc, 0x2a, 0x4a, 0xc1, 0x17, 0xc3, 0x7c, 0xff, -0x97, 0x5d, 0x11, 0x93, 0xbf, 0xb0, 0xf0, 0x54, -0x4a, 0x64, 0x60, 0xeb, 0x0c, 0xf6, 0xe8, 0x66, -0x7b, 0xff, 0xf2, 0xe5, 0x59, 0xfa, 0x79, 0x2b, -0xe6, 0x7f, 0x38, 0xf7, 0xf7, 0x7c, 0x3b, 0x92, -0x37, 0x0b, 0xc8, 0x7a, 0x45, 0x7f, 0x1c, 0xfe, -0xf5, 0x33, 0xc2, 0x38, 0xda, 0x76, 0xa3, 0x52, -0x38, 0xea, 0xba, 0x2c, 0xfe, 0xb5, 0x50, 0xca, -0xf0, 0x2f, 0xfd, 0x61, 0xe0, 0x7b, 0xd2, 0x9d, -0x64, 0xda, 0x11, 0xb1, 0x5f, 0xc6, 0xd6, 0x6f, -0x1c, 0x62, 0xf8, 0xf5, 0xb4, 0x5e, 0x16, 0x55, -0x33, 0x89, 0xc4, 0x71, 0xfa, 0x79, 0xde, 0x67, -0xbc, 0x73, 0xea, 0x96, 0x79, 0x36, 0xff, 0x1a, -0x97, 0x3f, 0x2c, 0xb1, 0xf9, 0x17, 0x76, 0xf5, -0x2d, 0x26, 0x3b, 0x14, 0x7d, 0xae, 0x61, 0x84, -0xc5, 0xe2, 0x5f, 0x5b, 0x1d, 0xfd, 0x06, 0x42, -0xdb, 0x81, 0xca, 0xf0, 0xe2, 0x9b, 0x37, 0x65, -0xc6, 0xe5, 0xe8, 0x37, 0x62, 0x36, 0x6c, 0xa5, -0x61, 0x7d, 0x0c, 0xdf, 0xc3, 0xd6, 0x0c, 0x90, -0x1d, 0x11, 0x71, 0x0b, 0xd7, 0x6f, 0x10, 0x81, -0xb9, 0xa4, 0x45, 0xd5, 0xc7, 0xf5, 0xf9, 0x75, -0x89, 0xb7, 0xb1, 0xf4, 0x1b, 0x36, 0x64, 0xb3, -0xfd, 0x05, 0x81, 0x81, 0x4c, 0xee, 0x94, 0xb7, -0xb1, 0xf9, 0x17, 0xc7, 0xa6, 0x03, 0x66, 0xe0, -0x07, 0xd9, 0xcf, 0x39, 0xa3, 0xdf, 0x28, 0xb5, -0xdb, 0x90, 0x93, 0xfe, 0x17, 0x8d, 0xaa, 0xac, -0x36, 0xaf, 0x4f, 0xd0, 0x6f, 0xb4, 0x20, 0xed, -0x3a, 0x66, 0x24, 0xb5, 0x20, 0x95, 0x18, 0x90, -0x4d, 0x67, 0xcf, 0xa7, 0xd7, 0xc9, 0x1f, 0x2a, -0x3c, 0x7f, 0x38, 0x80, 0xfc, 0x6b, 0xbd, 0x12, -0xc8, 0xf0, 0x2f, 0xcf, 0x44, 0xfd, 0x86, 0xa9, -0x56, 0xb4, 0x4a, 0xe1, 0x87, 0x90, 0x83, 0x48, -0x0e, 0x90, 0x8d, 0xd3, 0x6f, 0xf0, 0x7c, 0x5d, -0xd4, 0x5d, 0xa8, 0xae, 0x2b, 0x2b, 0x4b, 0xe5, -0xad, 0xce, 0x24, 0xc6, 0xd3, 0x62, 0x4e, 0x2d, -0xfd, 0x7c, 0xda, 0x7b, 0x87, 0x7c, 0x19, 0xdc, -0x9a, 0x48, 0x0e, 0x56, 0x8d, 0x78, 0xac, 0x8a, -0xd8, 0x6a, 0xf9, 0x7d, 0xb1, 0x07, 0x41, 0x15, -0x5a, 0x08, 0xd3, 0x07, 0xb2, 0x09, 0xe7, 0x6e, -0xa9, 0xfb, 0x5f, 0x05, 0x4f, 0x89, 0x84, 0x9b, -0x99, 0x8b, 0xf8, 0x65, 0xe5, 0x7f, 0xae, 0x7b, -0xb1, 0x71, 0xac, 0x15, 0xf9, 0x57, 0x54, 0xf6, -0xc3, 0x7b, 0xe9, 0x79, 0xa3, 0x1b, 0xce, 0xb7, -0x59, 0x15, 0xb1, 0x11, 0x47, 0x3f, 0x7f, 0xe9, -0x63, 0x74, 0x5f, 0x22, 0x98, 0x9e, 0x52, 0x20, -0x47, 0x3a, 0x5e, 0xdd, 0xaa, 0x7f, 0x52, 0x70, -0x9f, 0x5d, 0x38, 0xb8, 0xcf, 0xd6, 0xcf, 0xab, -0x4c, 0xbf, 0x81, 0xfc, 0xcb, 0x13, 0x21, 0x9a, -0xf9, 0x53, 0xa5, 0x2c, 0x25, 0xaf, 0x62, 0x40, -0x06, 0xdf, 0x4b, 0x79, 0x56, 0xd9, 0xfc, 0x2b, -0xc6, 0xf4, 0x1b, 0x8c, 0x69, 0x82, 0xdb, 0x80, -0xb6, 0x25, 0x89, 0xbe, 0x6c, 0x9f, 0x99, 0xd1, -0xcf, 0x8b, 0xd5, 0x0d, 0x32, 0xc0, 0x7b, 0x74, -0xef, 0x70, 0xd5, 0x30, 0x62, 0x2e, 0xf3, 0x6c, -0xbe, 0x64, 0xf9, 0x47, 0x62, 0xec, 0x71, 0x18, -0x92, 0xb8, 0x67, 0x63, 0xeb, 0xeb, 0xb4, 0x52, -0xd7, 0x6b, 0xf9, 0x3a, 0xd6, 0xc6, 0xce, 0x1f, -0x26, 0x34, 0x0b, 0xad, 0xcc, 0xa2, 0x66, 0xf5, -0x1d, 0x08, 0x99, 0xc1, 0x61, 0xb9, 0x16, 0xde, -0x83, 0x39, 0x8c, 0x88, 0xa5, 0xc6, 0xe9, 0x37, -0x4c, 0xcf, 0x86, 0x29, 0x77, 0x6b, 0x4c, 0x52, -0xa8, 0xb1, 0x3d, 0x47, 0x96, 0x3f, 0x1c, 0x74, -0xf8, 0x97, 0xf2, 0xbc, 0x54, 0xdd, 0xe3, 0xe9, -0xf0, 0xdf, 0x15, 0x7a, 0x04, 0xf9, 0x97, 0x14, -0x82, 0x20, 0x4f, 0xa6, 0xc9, 0x19, 0xfe, 0x55, -0x8c, 0xe1, 0xee, 0xa2, 0xe0, 0x6f, 0x3c, 0xd0, -0x6a, 0xb0, 0x23, 0x2c, 0x0e, 0x5c, 0xb6, 0xc0, -0xbd, 0x84, 0xee, 0x35, 0x56, 0xa6, 0x3c, 0x73, -0x89, 0xa5, 0x9f, 0xa7, 0xf9, 0x2b, 0x53, 0xe7, -0x62, 0xd5, 0x6f, 0xf9, 0xda, 0xe4, 0xe5, 0x03, -0xef, 0xe9, 0xf3, 0x0e, 0x7b, 0x87, 0xdb, 0x82, -0xf4, 0x9d, 0x15, 0xc8, 0xc8, 0x92, 0xb2, 0xcd, -0xbf, 0xfe, 0x79, 0xa8, 0xff, 0x5c, 0xac, 0xfe, -0xf0, 0xd2, 0xd6, 0xc2, 0x74, 0xfc, 0x5c, 0x71, -0xdd, 0xe1, 0x9b, 0xba, 0xe4, 0x17, 0x8c, 0x73, -0x65, 0x75, 0x7d, 0x8c, 0x7f, 0x59, 0xd8, 0xe4, -0x1a, 0xad, 0x3c, 0xa2, 0xcf, 0x8d, 0x79, 0xb6, -0x62, 0xbc, 0x31, 0x0a, 0x75, 0xe9, 0xa5, 0x23, -0xe5, 0x0b, 0x00, 0x6f, 0x98, 0x2e, 0x40, 0xfe, -0x45, 0x2d, 0xfc, 0x1a, 0x62, 0xdb, 0x45, 0x6d, -0xcc, 0x9d, 0xc9, 0x01, 0x08, 0xfe, 0xa7, 0x31, -0x3b, 0x3d, 0xa5, 0xdb, 0xae, 0x95, 0xa4, 0x5c, -0x1b, 0x80, 0x6a, 0xfa, 0x38, 0x9e, 0x12, 0x84, -0x36, 0x7f, 0x0c, 0x81, 0x2c, 0x72, 0x4a, 0xac, -0x2f, 0x53, 0xd9, 0x4d, 0x3a, 0x0d, 0x64, 0x37, -0x7b, 0xd8, 0x7d, 0x4c, 0x7c, 0x2c, 0x21, 0x77, -0x10, 0x7e, 0x29, 0xb0, 0x7b, 0x44, 0xbc, 0xf3, -0x52, 0xc9, 0x60, 0xef, 0x41, 0x8c, 0xaf, 0x3d, -0xdd, 0x6c, 0x0a, 0x4c, 0x0e, 0x5b, 0x05, 0x06, -0xdb, 0xc8, 0x3c, 0x1d, 0xc7, 0x65, 0xf0, 0x36, -0x69, 0xe9, 0x49, 0x38, 0xcf, 0x8e, 0xdd, 0x18, -0x61, 0x21, 0x84, 0xbd, 0x97, 0x5c, 0x6c, 0x64, -0x6e, 0x18, 0x11, 0x6d, 0x0c, 0xad, 0x83, 0xa4, -0x0c, 0x76, 0xec, 0x86, 0x27, 0x08, 0x1f, 0x1b, -0xfc, 0x20, 0x8e, 0x21, 0xbe, 0x21, 0x1a, 0x6f, -0xf8, 0x1b, 0xd1, 0xe7, 0x63, 0xae, 0x85, 0xd0, -0x09, 0x0b, 0x58, 0xb6, 0xd0, 0xd9, 0xd4, 0x30, -0x04, 0x1b, 0x69, 0x80, 0x15, 0x2e, 0x3f, 0xe7, -0x8f, 0x19, 0x4c, 0x88, 0x92, 0x0e, 0x8c, 0x88, -0x54, 0xb6, 0xac, 0x76, 0x28, 0x95, 0x22, 0x87, -0xd6, 0xa6, 0x55, 0x70, 0xfc, 0x12, 0x79, 0xa4, -0x11, 0xed, 0x16, 0xf2, 0x00, 0xbd, 0x82, 0x4b, -0xd0, 0x0d, 0x91, 0x36, 0x24, 0xc7, 0xa5, 0x75, -0xfd, 0x33, 0x18, 0x16, 0x8c, 0x52, 0x7e, 0x9f, -0xa8, 0x1a, 0x25, 0xbd, 0xf8, 0xda, 0x78, 0xbb, -0x65, 0x24, 0x62, 0x04, 0xe3, 0xba, 0x1a, 0x96, -0xcf, 0x4c, 0x3c, 0x65, 0x7a, 0xae, 0x71, 0xf8, -0x57, 0x49, 0x37, 0x8e, 0xa2, 0xce, 0xbc, 0xe2, -0xa4, 0x3c, 0xaa, 0x8d, 0xc1, 0xe5, 0x7d, 0x9e, -0x93, 0x3c, 0x2f, 0xca, 0x8b, 0xb6, 0x16, 0xff, -0x52, 0x95, 0xdd, 0xea, 0x01, 0xb6, 0x0b, 0x20, -0x59, 0x54, 0xad, 0x1c, 0xa2, 0x4c, 0x26, 0x8a, -0x40, 0x7f, 0xd4, 0xe0, 0xe3, 0x3a, 0x28, 0xd6, -0x69, 0xaa, 0xf4, 0xb1, 0xd6, 0x35, 0x7c, 0x9b, -0x27, 0x99, 0xaa, 0xae, 0xb3, 0x0c, 0x58, 0xa7, -0x96, 0xb1, 0xf5, 0x7e, 0xca, 0xca, 0x5d, 0x60, -0x34, 0xbd, 0x96, 0x96, 0x0d, 0x5b, 0xb2, 0xf9, -0x32, 0x4b, 0x3f, 0x9f, 0xe4, 0x9c, 0xd1, 0x5a, -0x5f, 0x83, 0xca, 0x03, 0x46, 0x1b, 0xb2, 0xd1, -0xca, 0x85, 0x6e, 0xaf, 0xdc, 0x66, 0x26, 0xcc, -0xca, 0x90, 0xbb, 0x20, 0xc2, 0x94, 0xb1, 0x1c, -0xbf, 0x44, 0x9b, 0x92, 0x2f, 0xe0, 0x88, 0x81, -0xb0, 0xf5, 0xa4, 0x5c, 0x09, 0x47, 0x68, 0x18, -0x7d, 0x94, 0xcc, 0xf6, 0x7f, 0x71, 0x21, 0x87, -0xf5, 0x5d, 0x51, 0x89, 0xea, 0x23, 0xba, 0x4d, -0xbb, 0x34, 0xcb, 0x18, 0xb6, 0xeb, 0x5f, 0x62, -0x5c, 0x88, 0x5f, 0x3d, 0xd0, 0xc5, 0x60, 0xab, -0x02, 0xce, 0xaa, 0xac, 0xfe, 0xd5, 0x20, 0x76, -0xda, 0x8e, 0xc3, 0x2f, 0x85, 0x6d, 0x5b, 0x56, -0xb7, 0x90, 0x19, 0xf0, 0x6c, 0xa4, 0xba, 0xc9, -0xb3, 0x25, 0xf0, 0x3b, 0xf6, 0x66, 0x72, 0xfc, -0x12, 0x75, 0x61, 0xa6, 0x3f, 0xbc, 0x5f, 0x0d, -0x44, 0x54, 0xad, 0xb5, 0x42, 0x7f, 0x56, 0xad, -0x8e, 0x78, 0xe2, 0xad, 0x7d, 0x3a, 0x5e, 0xc9, -0xe2, 0x5f, 0x88, 0x5f, 0xb4, 0x45, 0xd7, 0x99, -0xda, 0xd0, 0x29, 0x7b, 0x21, 0x28, 0xe8, 0x42, -0xbf, 0x21, 0xbe, 0x6b, 0x24, 0x7f, 0x99, 0x61, -0x36, 0x85, 0x8a, 0xbd, 0x2e, 0x8f, 0x64, 0x0c, -0x7f, 0xb3, 0xb6, 0x78, 0xa3, 0x4b, 0xee, 0x69, -0x34, 0x9b, 0xba, 0x58, 0x9f, 0x3f, 0x17, 0x58, -0xd9, 0x51, 0xf2, 0x66, 0xe4, 0xbc, 0x56, 0x6f, -0xcc, 0x61, 0xf8, 0xc5, 0x8c, 0x8d, 0x0c, 0xa4, -0xce, 0x6a, 0x8c, 0x21, 0x16, 0xbd, 0x6f, 0xe3, -0x17, 0xc2, 0x31, 0x0d, 0x1b, 0xca, 0x16, 0x79, -0x06, 0x1b, 0x4e, 0x53, 0x70, 0x8b, 0xfc, 0x3b, -0xa6, 0x3f, 0x64, 0xe3, 0xda, 0x4e, 0x2c, 0xfc, -0xea, 0x31, 0x3b, 0xf4, 0x80, 0xaa, 0x22, 0xed, -0x82, 0x0e, 0x9d, 0xe9, 0x0f, 0x03, 0x69, 0x78, -0xca, 0xd8, 0x9e, 0xc5, 0xbf, 0x10, 0xbf, 0xe8, -0x9a, 0x68, 0x59, 0x83, 0xfa, 0x3a, 0x29, 0x5e, -0xbb, 0x26, 0x5a, 0x6e, 0xa8, 0xb7, 0x90, 0x37, -0xe9, 0xd3, 0x31, 0xd6, 0xe7, 0x9c, 0x9f, 0x89, -0x36, 0x5b, 0x95, 0x9d, 0xc6, 0x9a, 0xd8, 0x36, -0xa3, 0xf2, 0x75, 0x77, 0x31, 0x3c, 0x40, 0xbf, -0xce, 0x37, 0x32, 0xd3, 0x7f, 0x15, 0xb9, 0xd3, -0x4f, 0x45, 0x0c, 0x89, 0xf8, 0x45, 0x78, 0x78, -0xa0, 0xe1, 0x73, 0x3e, 0xa0, 0x86, 0x0c, 0x95, -0x27, 0x6c, 0x45, 0x9e, 0x76, 0x97, 0x3d, 0x5f, -0x3f, 0x87, 0xb3, 0x54, 0xec, 0xff, 0xb2, 0xd3, -0x86, 0x8e, 0xf1, 0x3a, 0xb5, 0xe6, 0x8b, 0x76, -0xb0, 0x6d, 0xa7, 0x1b, 0xd8, 0x16, 0xe0, 0x94, -0xd1, 0x05, 0x5e, 0x9a, 0xab, 0x63, 0x64, 0xc7, -0xf7, 0x7f, 0xf5, 0x8a, 0x36, 0x2c, 0x7f, 0xb8, -0x9e, 0xcb, 0xe6, 0x73, 0x06, 0xc9, 0x7a, 0x1a, -0x68, 0xe1, 0xf8, 0xf5, 0x6b, 0xba, 0x00, 0x89, -0x98, 0xdc, 0x5a, 0x21, 0xe6, 0x42, 0xb9, 0x09, -0xda, 0x68, 0x65, 0x1a, 0x97, 0xd5, 0x11, 0x56, -0xf6, 0x62, 0x5c, 0xa6, 0x00, 0x5a, 0x5b, 0x99, -0x27, 0xb1, 0x63, 0x75, 0xaa, 0xbd, 0x5b, 0x9c, -0x6b, 0xcc, 0xfa, 0x0d, 0xbe, 0xc6, 0xff, 0xa1, -0xe1, 0x6b, 0xdc, 0xaf, 0xfe, 0x98, 0x5c, 0x2e, -0xfd, 0x3c, 0x8f, 0x17, 0x95, 0x52, 0xdc, 0x65, -0x42, 0x47, 0xc7, 0x77, 0xc8, 0x11, 0xfa, 0x7c, -0x22, 0xb8, 0x22, 0xf0, 0x05, 0xb9, 0x99, 0x96, -0x27, 0x82, 0x83, 0xee, 0x1a, 0xf2, 0x6a, 0xeb, -0x5c, 0xce, 0xbf, 0x78, 0x77, 0x38, 0x7e, 0xb1, -0xca, 0xec, 0xfd, 0x59, 0x21, 0xd6, 0x20, 0x06, -0xc0, 0xdc, 0xc9, 0xb4, 0xb6, 0x0b, 0xbf, 0xa1, -0x3c, 0x49, 0x5f, 0x6b, 0x99, 0xb7, 0xfc, 0x86, -0x67, 0xe5, 0x0f, 0xe0, 0x3c, 0x5d, 0xb0, 0xdc, -0xbb, 0xd5, 0xb3, 0x00, 0x46, 0xe2, 0x61, 0x16, -0xcf, 0xf7, 0x6f, 0xe7, 0x6d, 0x9e, 0x2c, 0xfd, -0x99, 0xb9, 0x06, 0xca, 0x57, 0xe2, 0x92, 0xf9, -0x37, 0xf3, 0x69, 0x28, 0x5b, 0xa1, 0x5e, 0x46, -0x2e, 0x89, 0x77, 0x27, 0xca, 0x4e, 0x78, 0x6a, -0xc8, 0x47, 0xe2, 0x19, 0x6a, 0xb0, 0x35, 0xb4, -0x05, 0xca, 0xd5, 0x47, 0xee, 0x6a, 0xed, 0xcf, -0x7b, 0x4a, 0x2d, 0x83, 0xbc, 0x5e, 0xd2, 0x14, -0x7b, 0x9a, 0x96, 0xb1, 0xcd, 0x6b, 0x03, 0x36, -0x7e, 0x75, 0x40, 0x7c, 0x58, 0xd7, 0x0b, 0x77, -0xe1, 0x8a, 0xeb, 0xc6, 0x67, 0x26, 0x51, 0x02, -0xc5, 0x7b, 0x44, 0x6e, 0xa7, 0x5f, 0xb4, 0xe9, -0x2e, 0xf9, 0x14, 0xde, 0x30, 0xba, 0xde, 0xf7, -0x6d, 0x65, 0xdb, 0x60, 0x7b, 0xc2, 0xe6, 0xaf, -0x92, 0x9e, 0x95, 0x85, 0xcf, 0x61, 0x40, 0x8e, -0xf1, 0xea, 0x07, 0xd6, 0xba, 0x90, 0x76, 0x13, -0x96, 0x6b, 0xba, 0x39, 0x9e, 0xd9, 0xbf, 0xbc, -0x1b, 0x4e, 0xf1, 0x58, 0x3d, 0xd7, 0xd2, 0x12, -0x27, 0xb4, 0x47, 0x71, 0x55, 0xee, 0xa5, 0xbe, -0x9e, 0xdc, 0x85, 0x70, 0x41, 0xbd, 0x8a, 0xfa, -0xd2, 0xf2, 0x42, 0x5b, 0x7f, 0x98, 0x16, 0x3e, -0x73, 0x27, 0xe2, 0x17, 0x9b, 0x2f, 0x0f, 0x95, -0x59, 0x98, 0x11, 0x16, 0x7a, 0x9b, 0xe7, 0xd1, -0x43, 0xde, 0x98, 0x24, 0x67, 0x96, 0x8b, 0xb9, -0xc0, 0x39, 0x65, 0xa1, 0x91, 0x9b, 0x95, 0x95, -0x9f, 0x80, 0xd9, 0xc6, 0x8d, 0x68, 0x48, 0xbb, -0x78, 0x15, 0xc6, 0x9f, 0x16, 0xf3, 0xe5, 0x2e, -0x56, 0xe9, 0xfd, 0xa0, 0xdf, 0xe0, 0xb9, 0xc4, -0x7d, 0x5d, 0x7c, 0x0f, 0x54, 0xde, 0xe1, 0x29, -0x9e, 0xad, 0x24, 0x92, 0xa1, 0x8a, 0x14, 0x46, -0xc2, 0xf6, 0x9c, 0xe6, 0x47, 0x13, 0x29, 0x29, -0xac, 0x16, 0xe0, 0x3b, 0x4f, 0xd3, 0xb0, 0x50, -0xf5, 0xb5, 0xb6, 0xe9, 0x70, 0x36, 0x16, 0x4e, -0xf9, 0xf6, 0xc9, 0x56, 0x2c, 0x9a, 0xd8, 0x34, -0x42, 0x46, 0x99, 0x97, 0x78, 0x39, 0x37, 0x69, -0x8c, 0xc2, 0xbc, 0x52, 0x9f, 0x81, 0x7f, 0x3a, -0xbf, 0xac, 0xfe, 0x95, 0x8d, 0xa7, 0x8b, 0xd2, -0x15, 0x16, 0x7e, 0xf1, 0xe8, 0x22, 0x96, 0xbf, -0x55, 0x0e, 0x08, 0xbe, 0xcc, 0x62, 0xfe, 0x43, -0x2c, 0xa3, 0x88, 0xfc, 0xcb, 0x15, 0x13, 0x3e, -0x9c, 0xa7, 0x0d, 0x63, 0x6a, 0x77, 0x20, 0xa1, -0x74, 0x42, 0x75, 0xaf, 0x3a, 0x4c, 0x2e, 0x60, -0x9b, 0x6a, 0x64, 0x64, 0x72, 0x52, 0xf0, 0xd3, -0x14, 0xcf, 0x1f, 0x72, 0x6d, 0x58, 0x0e, 0xec, -0xa8, 0x0c, 0xa6, 0xf2, 0x42, 0x7e, 0x8b, 0x91, -0x85, 0xc8, 0x29, 0x89, 0xb7, 0xb1, 0xf2, 0x87, -0x51, 0x75, 0xab, 0xff, 0xe7, 0x78, 0x9f, 0x20, -0x3b, 0xc6, 0x61, 0x48, 0xec, 0xc0, 0x4a, 0x92, -0xa4, 0xa5, 0x3b, 0xe5, 0xf5, 0x9d, 0xda, 0x58, -0xfe, 0x54, 0x39, 0x47, 0xf9, 0x58, 0xaa, 0xeb, -0xf1, 0x32, 0xdc, 0xb1, 0xde, 0x31, 0x2b, 0xff, -0x9c, 0x2e, 0xe4, 0xe7, 0x47, 0xa5, 0x59, 0x4c, -0xab, 0x7f, 0xc6, 0x05, 0x0f, 0xf2, 0x50, 0x60, -0x3c, 0xff, 0x6a, 0xd2, 0x76, 0x63, 0x94, 0x52, -0x17, 0x29, 0x88, 0x7b, 0x2a, 0x08, 0x23, 0x74, -0x1b, 0x11, 0xc8, 0x88, 0x75, 0x9f, 0xdf, 0xd8, -0x98, 0x1b, 0xd4, 0xb0, 0x3f, 0x23, 0x18, 0xa2, -0xcf, 0x0c, 0xb1, 0x6e, 0xf8, 0x86, 0xc9, 0xb4, -0x38, 0x1a, 0x1f, 0xf2, 0xfd, 0xd4, 0x7c, 0x61, -0x98, 0x0a, 0x8f, 0x06, 0x9b, 0xdd, 0xa5, 0x24, -0x8f, 0x17, 0x9a, 0x71, 0x38, 0xaf, 0x81, 0x95, -0x55, 0x1b, 0x11, 0xf9, 0x79, 0x16, 0x75, 0x22, -0x6c, 0xad, 0x50, 0xcf, 0xaf, 0xbd, 0x8c, 0xae, -0x8b, 0x33, 0x21, 0x7d, 0xc1, 0x71, 0x63, 0x1d, -0xc6, 0x63, 0xf2, 0xea, 0x9c, 0x51, 0xab, 0xfe, -0x55, 0x5a, 0x00, 0x7b, 0x93, 0xb5, 0x2b, 0x0a, -0x2e, 0x6b, 0xa8, 0x86, 0x37, 0xa0, 0x76, 0xd0, -0xc3, 0x88, 0xd8, 0xcb, 0x49, 0xa6, 0x9f, 0xcf, -0xb5, 0xeb, 0x5f, 0x53, 0xd9, 0xbe, 0xec, 0x5a, -0xc3, 0x17, 0xc2, 0x65, 0x25, 0xca, 0x79, 0x6d, -0xb5, 0x7c, 0xff, 0x32, 0xc7, 0x2f, 0x3e, 0x2e, -0xd5, 0x75, 0x84, 0x3d, 0x0d, 0xc3, 0xa7, 0x7a, -0x2a, 0x70, 0x0a, 0xc2, 0xac, 0x06, 0x1d, 0x34, -0x0f, 0x01, 0x9f, 0x38, 0x2b, 0x1f, 0x95, 0x92, -0x78, 0xfe, 0xd0, 0xf0, 0x18, 0xe4, 0x29, 0x7e, -0x5e, 0x41, 0xde, 0x3d, 0xc4, 0x6b, 0xfc, 0x54, -0x68, 0x77, 0xb3, 0xf4, 0xf3, 0xd8, 0xc3, 0x98, -0x27, 0x45, 0x2e, 0xe1, 0xf8, 0x85, 0xa1, 0xe3, -0x74, 0xfa, 0x53, 0x04, 0xdf, 0xbc, 0xd5, 0x11, -0x5b, 0x3f, 0x5f, 0x7c, 0x58, 0x8c, 0x34, 0x8f, -0xac, 0x41, 0x23, 0xc0, 0xb5, 0x61, 0x84, 0x3d, -0x84, 0x59, 0x99, 0xfc, 0xa1, 0xb4, 0x0b, 0xc3, -0xe4, 0x5a, 0x5c, 0x0e, 0xb9, 0x0b, 0x23, 0x02, -0xb6, 0xf8, 0xfe, 0xe5, 0x6a, 0x9a, 0x97, 0xd1, -0x6f, 0x68, 0xec, 0xfc, 0xa8, 0xba, 0x62, 0xdf, -0x06, 0x5c, 0x29, 0x23, 0xf0, 0x22, 0xba, 0x65, -0x0f, 0xdf, 0xe5, 0xa7, 0x15, 0x8c, 0xd3, 0xcf, -0x63, 0x84, 0x1f, 0x43, 0xfc, 0xfa, 0x80, 0x1e, -0x40, 0x0a, 0x73, 0x38, 0xfe, 0xfd, 0xe5, 0xd1, -0x03, 0x62, 0x53, 0xf0, 0xf8, 0xfa, 0x57, 0x34, -0xff, 0x5f, 0xc8, 0x07, 0xf6, 0xb6, 0xe5, 0x5c, -0x5c, 0x29, 0xd5, 0xcd, 0x93, 0xea, 0x5f, 0x8d, -0x6a, 0xd2, 0xdf, 0x07, 0xf7, 0x4b, 0xec, 0x20, -0x29, 0x77, 0x85, 0xf4, 0xf0, 0x44, 0xfd, 0x46, -0xa9, 0xa5, 0x3f, 0x44, 0xd8, 0x42, 0xa3, 0xd2, -0x4f, 0x94, 0xd6, 0x4d, 0x30, 0x4e, 0xbf, 0x31, -0x2d, 0x66, 0xe9, 0x13, 0x8a, 0x4e, 0x44, 0xcc, -0x5b, 0x6a, 0x8a, 0x97, 0xb8, 0x1a, 0x90, 0x68, -0x30, 0xa7, 0xe7, 0xf0, 0xaf, 0xee, 0x69, 0x8c, -0xdd, 0x30, 0x6e, 0x55, 0x78, 0xc6, 0xde, 0xb6, -0xcc, 0x76, 0x7b, 0xd5, 0x66, 0xe9, 0x37, 0xba, -0x4b, 0xce, 0xd8, 0xfc, 0xeb, 0x07, 0x3c, 0x41, -0xba, 0x71, 0x73, 0xdb, 0x99, 0xc4, 0x01, 0x76, -0xc5, 0x39, 0x3f, 0xaa, 0x14, 0x32, 0x69, 0x43, -0x65, 0x17, 0x13, 0x72, 0xac, 0x25, 0x27, 0xa0, -0xc3, 0xe2, 0x5f, 0x13, 0xf5, 0xf3, 0x64, 0xb9, -0xde, 0xa2, 0x32, 0x21, 0x47, 0xab, 0xd8, 0x73, -0xed, 0x99, 0xa8, 0x9f, 0x37, 0x3d, 0xf1, 0xc8, -0x4e, 0xfd, 0x09, 0x1c, 0xb2, 0x6c, 0xe5, 0x4e, -0xcd, 0x2c, 0xfd, 0x06, 0xf0, 0xe7, 0xdc, 0xe8, -0xd3, 0xe4, 0x46, 0xec, 0xcf, 0xdf, 0x09, 0x92, -0x65, 0x65, 0x6e, 0x07, 0xc5, 0x3e, 0xe8, 0x15, -0xa2, 0x4d, 0xcc, 0xf7, 0xa8, 0xbc, 0xdc, 0x96, -0xd0, 0xf4, 0xd9, 0xfc, 0xeb, 0x6d, 0xab, 0xfe, -0x05, 0x8e, 0x7e, 0xa3, 0xcc, 0x4a, 0x24, 0x32, -0xfd, 0x21, 0xd4, 0x29, 0x3e, 0x47, 0xbf, 0xa1, -0x02, 0xd7, 0xcf, 0x6f, 0xcf, 0xff, 0xa4, 0x68, -0xb5, 0xb6, 0x5e, 0xd0, 0xae, 0x85, 0xd2, 0x7a, -0x32, 0x27, 0x91, 0xe1, 0x5f, 0x6a, 0x09, 0xe7, -0x5f, 0x46, 0xa9, 0xa6, 0xa9, 0x0a, 0x7b, 0xd9, -0xe4, 0x10, 0xc9, 0xc9, 0x69, 0x53, 0xb2, 0xf9, -0x97, 0x2e, 0x4d, 0x95, 0xf6, 0xc1, 0x9c, 0xf4, -0xfd, 0x3f, 0x20, 0x77, 0xc2, 0x3a, 0x9d, 0x17, -0xc2, 0x4a, 0xf5, 0x75, 0x42, 0xa1, 0x64, 0xe9, -0x37, 0x2a, 0x4b, 0xb9, 0x7e, 0x23, 0x81, 0xfc, -0x2b, 0x1c, 0x79, 0x95, 0xfe, 0xe3, 0x80, 0xaf, -0xc6, 0x73, 0x19, 0xbe, 0xd8, 0x9c, 0x7f, 0x8d, -0xab, 0x7f, 0xe1, 0x32, 0x0f, 0xc9, 0x9f, 0xd0, -0x73, 0x35, 0x75, 0xfd, 0xbe, 0x3d, 0x9d, 0x29, -0x3b, 0xb7, 0x63, 0xe9, 0xe7, 0x63, 0x5c, 0x3f, -0x5f, 0x9f, 0xf2, 0xdd, 0x5b, 0x5e, 0x43, 0xdf, -0x8b, 0xd7, 0xbf, 0xbf, 0xf1, 0x59, 0x79, 0x3a, -0x1c, 0x8a, 0xf3, 0x8c, 0xa2, 0x7d, 0x7e, 0x14, -0x72, 0x2b, 0x1e, 0xa2, 0xaf, 0x76, 0xff, 0x0f, -0xb6, 0xd0, 0xd2, 0x9e, 0x11, 0xa2, 0x1a, 0xbf, -0xa0, 0x55, 0x66, 0xc1, 0x6a, 0x5b, 0xbf, 0xe1, -0x17, 0xfa, 0xf9, 0x76, 0x64, 0x5b, 0xa1, 0xc6, -0x9f, 0x92, 0x2a, 0xb6, 0xd5, 0xfa, 0x0e, 0xd1, -0xf9, 0x55, 0xa4, 0xcf, 0xce, 0xcf, 0x6f, 0x60, -0xf9, 0x8d, 0xb4, 0x67, 0x21, 0x79, 0x40, 0xed, -0xe4, 0xb9, 0x53, 0x77, 0x94, 0x55, 0x2b, 0x0c, -0x24, 0x62, 0x6f, 0x8b, 0x79, 0xdf, 0x2e, 0x71, -0xce, 0xd8, 0xea, 0x83, 0xce, 0x59, 0xec, 0x30, -0x25, 0xe6, 0xe2, 0x56, 0xa0, 0xcf, 0xfc, 0xb1, -0xe1, 0x73, 0xf4, 0x1b, 0x09, 0x6d, 0x48, 0x39, -0x47, 0xea, 0xe2, 0x1b, 0x93, 0x45, 0x1f, 0xda, -0xc3, 0xb9, 0x9f, 0x9d, 0xc2, 0xc7, 0x36, 0x0d, -0x0d, 0x88, 0xf5, 0xd5, 0x22, 0xea, 0x5f, 0x74, -0x49, 0xbf, 0xdc, 0x5c, 0xf9, 0x1e, 0x61, 0xb0, -0x25, 0x2f, 0x8c, 0x1c, 0x85, 0x7a, 0x3d, 0x7f, -0xb8, 0xc8, 0xd2, 0xe0, 0x59, 0xf5, 0xaf, 0x64, -0xd5, 0x53, 0x97, 0xe5, 0xa1, 0xab, 0xe4, 0x65, -0x94, 0x59, 0xcc, 0x3f, 0x2b, 0x97, 0x65, 0xf4, -0xf3, 0x42, 0x7f, 0x98, 0xb8, 0xfe, 0x29, 0xb2, -0x82, 0x6f, 0x16, 0xb3, 0xdb, 0xb0, 0xcd, 0x47, -0x16, 0xff, 0x72, 0x17, 0x7b, 0x8d, 0xbd, 0xb0, -0xb2, 0xe5, 0xe1, 0xb0, 0xbb, 0x32, 0x86, 0x9c, -0xba, 0xdf, 0x13, 0x46, 0xe7, 0xd9, 0x36, 0x33, -0xd8, 0xe4, 0x9e, 0x6b, 0xaf, 0x2f, 0x76, 0x1f, -0xec, 0x6a, 0x7b, 0xfe, 0x3e, 0xb9, 0x59, 0x3d, -0xaa, 0xcc, 0x33, 0x37, 0x9e, 0x6a, 0xab, 0x84, -0x43, 0xa1, 0x3a, 0xcd, 0x9b, 0x6c, 0x4b, 0x8b, -0xf5, 0xb5, 0xbd, 0x64, 0x34, 0xfe, 0xd2, 0xac, -0xfa, 0x0e, 0xdf, 0x9e, 0xa2, 0x54, 0x7c, 0x0c, -0xa6, 0xff, 0xc6, 0x77, 0xaa, 0x73, 0x84, 0x8e, -0x85, 0xea, 0x01, 0x39, 0xa3, 0x73, 0xfe, 0x86, -0xc5, 0x8e, 0xbb, 0x91, 0x7f, 0x7d, 0x82, 0xf1, -0x3c, 0x2f, 0x84, 0x7d, 0x6c, 0xe1, 0x97, 0xa5, -0xdf, 0x80, 0x21, 0x51, 0xff, 0x62, 0xdb, 0xbe, -0x3a, 0x69, 0x40, 0x18, 0xe2, 0x4a, 0x64, 0x70, -0x92, 0xfe, 0x90, 0x71, 0xb4, 0x0a, 0x41, 0xc4, -0x76, 0xd8, 0xf9, 0xc3, 0xc9, 0xfa, 0x8d, 0x47, -0xe8, 0xcc, 0x71, 0x85, 0xa7, 0x11, 0xab, 0xee, -0x59, 0x9c, 0xd1, 0x0d, 0xc2, 0x69, 0x84, 0x7e, -0x47, 0x4b, 0xe3, 0x41, 0xfc, 0x12, 0xeb, 0xe2, -0x04, 0x64, 0xe9, 0x0f, 0x3f, 0x13, 0xf4, 0xc4, -0x29, 0x84, 0x8d, 0xc4, 0x78, 0x9b, 0x6c, 0xfd, -0xe1, 0x24, 0xc3, 0xce, 0x1f, 0x2a, 0x41, 0xc8, -0xca, 0xe5, 0xd6, 0x65, 0xf7, 0x47, 0xee, 0xe2, -0xbd, 0x41, 0x7c, 0x5f, 0x92, 0x19, 0xd7, 0x44, -0x21, 0xa2, 0xa5, 0xdf, 0x88, 0x49, 0x59, 0x25, -0x24, 0x91, 0x94, 0x63, 0x46, 0xa2, 0xea, 0x84, -0xbc, 0x9a, 0x58, 0xfa, 0xf9, 0x15, 0x50, 0xa0, -0x59, 0xb2, 0xc3, 0x23, 0xe6, 0x69, 0x2d, 0x98, -0xc6, 0x45, 0x74, 0x18, 0x4e, 0x27, 0xf8, 0x15, -0x1b, 0xbf, 0xfe, 0x8f, 0x17, 0x84, 0xde, 0xe6, -0x24, 0x1f, 0x4e, 0x5d, 0x96, 0xae, 0xf2, 0xe4, -0x78, 0xfd, 0x61, 0x6d, 0xda, 0x6b, 0x0f, 0xc7, -0x23, 0x0c, 0x76, 0xa5, 0xe1, 0x7d, 0x47, 0xbf, -0x21, 0x59, 0x3b, 0x4d, 0xde, 0x55, 0x9c, 0x44, -0xe2, 0x3e, 0xb8, 0x9a, 0x5d, 0xc9, 0xd6, 0x1f, -0xb6, 0xb3, 0xdd, 0x5e, 0xdf, 0x3a, 0x6e, 0xe9, -0x0f, 0x23, 0xc7, 0x8b, 0xf7, 0xb5, 0x7f, 0x0f, -0xf1, 0xcb, 0xe6, 0xd4, 0x2b, 0x2c, 0x7d, 0x94, -0x6a, 0xe7, 0xe7, 0xad, 0xb1, 0x57, 0x32, 0x20, -0x9b, 0xa0, 0x3f, 0x0c, 0x5a, 0x31, 0x6d, 0x8b, -0xcf, 0x36, 0xaa, 0x26, 0xe9, 0x0f, 0x27, 0xd7, -0xbf, 0x32, 0xf8, 0xd5, 0x31, 0x59, 0x7f, 0x98, -0x9b, 0xc9, 0x1f, 0x7e, 0x89, 0xfe, 0x30, 0x3b, -0x37, 0x68, 0xe3, 0x97, 0x32, 0x41, 0x7f, 0x98, -0x97, 0xd5, 0x66, 0xbf, 0x9d, 0x9f, 0xcf, 0xd6, -0x1f, 0x92, 0x6a, 0x6b, 0xff, 0x97, 0x22, 0xf0, -0x4b, 0xcc, 0x7b, 0xb7, 0xba, 0xcc, 0x18, 0xd7, -0xd5, 0x07, 0x58, 0x72, 0xcf, 0xc9, 0x1f, 0xf2, -0xef, 0xda, 0x3a, 0xed, 0x4c, 0xa6, 0xcf, 0xe7, -0xc9, 0xf8, 0xe2, 0x9d, 0x85, 0x5f, 0x1d, 0xec, -0xfc, 0x28, 0x8e, 0x5f, 0x18, 0x6f, 0x9c, 0x73, -0x12, 0x77, 0xe2, 0x4a, 0xc0, 0xd1, 0x1f, 0xea, -0x16, 0x5a, 0xe9, 0x4e, 0x22, 0x91, 0x74, 0x48, -0xdc, 0x70, 0xf6, 0x2f, 0x0f, 0xd0, 0x16, 0x91, -0x3f, 0xcc, 0xea, 0xbc, 0x85, 0x5f, 0x11, 0x47, -0xbf, 0x21, 0x3d, 0x31, 0x5e, 0x72, 0x19, 0x71, -0x6a, 0x7f, 0x8b, 0x2d, 0x5f, 0xb7, 0xa5, 0x1d, -0x0e, 0xb8, 0x78, 0x3d, 0xae, 0x82, 0x91, 0x2c, -0x81, 0x4d, 0x16, 0x7e, 0xad, 0xc8, 0xe8, 0xe7, -0x85, 0x46, 0xd1, 0x83, 0xc3, 0x89, 0x8f, 0x1b, -0x97, 0x67, 0xbd, 0xc5, 0xad, 0xb4, 0xc4, 0x97, -0xd7, 0x34, 0x33, 0xf5, 0x2f, 0xe5, 0x23, 0x06, -0x5b, 0x3a, 0x19, 0x54, 0xac, 0xb4, 0xe1, 0x88, -0xfa, 0x9c, 0xb8, 0x62, 0x71, 0x22, 0x96, 0x3f, -0x9c, 0x37, 0x61, 0x59, 0xa5, 0x26, 0xe4, 0x0f, -0xcb, 0xa4, 0xa9, 0xf0, 0x8b, 0xcc, 0x6b, 0x5c, -0x65, 0xca, 0xcd, 0x4c, 0x41, 0x2e, 0xae, 0x38, -0xf5, 0x2f, 0x27, 0x5b, 0x78, 0xdc, 0x36, 0xde, -0xb6, 0x8c, 0xf2, 0x83, 0xe2, 0xb0, 0x58, 0xf5, -0xd2, 0x17, 0x8c, 0x8c, 0x26, 0x59, 0x18, 0x83, -0x0e, 0x7e, 0x39, 0xe7, 0x1f, 0xda, 0xd9, 0xc2, -0x17, 0x8d, 0xb1, 0x38, 0x77, 0x8c, 0x5f, 0xc0, -0xb9, 0xf8, 0xb5, 0xe9, 0xfc, 0x6e, 0x62, 0xe3, -0x17, 0xd7, 0x47, 0x61, 0x0f, 0xbf, 0xc0, 0x90, -0x8f, 0x77, 0xe3, 0x47, 0xac, 0x3f, 0x09, 0x5c, -0x71, 0x3f, 0xca, 0xb5, 0xce, 0x8f, 0xda, 0x6c, -0x9d, 0x7f, 0xe8, 0x39, 0x49, 0xd0, 0xe0, 0xa5, -0x3a, 0x74, 0x05, 0xfb, 0x34, 0x76, 0x52, 0x96, -0xcd, 0xbf, 0xfe, 0xb6, 0x78, 0xc8, 0xd2, 0x47, -0xb1, 0x94, 0x29, 0x15, 0x63, 0xe7, 0x19, 0x7b, -0x08, 0x05, 0x2c, 0xfd, 0xfc, 0x93, 0x25, 0x2f, -0xc0, 0x8f, 0xc4, 0xae, 0xd5, 0xdd, 0xfc, 0x6c, -0x0d, 0xec, 0xea, 0xae, 0x62, 0x46, 0xb2, 0x2a, -0x92, 0xc4, 0x3a, 0xff, 0x30, 0x0e, 0x19, 0x17, -0x27, 0x8d, 0x1b, 0xd7, 0xd2, 0xa4, 0xfc, 0xb8, -0x58, 0x5f, 0x54, 0x1b, 0xd5, 0x8e, 0x5a, 0x3e, -0x53, 0x75, 0x42, 0x7d, 0xcb, 0xb0, 0xea, 0x5f, -0x3d, 0x7c, 0xff, 0xb2, 0xd0, 0x1f, 0x3a, 0x69, -0x43, 0x78, 0x5e, 0x12, 0xfa, 0x84, 0x8c, 0x7e, -0xa3, 0x73, 0x82, 0x66, 0x60, 0x90, 0x1b, 0xee, -0xa4, 0x5d, 0x83, 0x66, 0xfa, 0x79, 0x11, 0xe1, -0xb7, 0x1e, 0x66, 0x42, 0xc4, 0x3e, 0xc4, 0x2f, -0x9c, 0x53, 0xdd, 0x6b, 0xe6, 0x85, 0xed, 0xf5, -0x45, 0xbd, 0x2b, 0x8d, 0x43, 0x6c, 0x4b, 0xf2, -0x3e, 0xf9, 0x13, 0x33, 0xd3, 0x67, 0xa3, 0xee, -0xcd, 0x82, 0xa7, 0x1d, 0xfd, 0xbc, 0xa8, 0x7f, -0x1d, 0xf0, 0x75, 0x15, 0x0d, 0xf5, 0xf3, 0x42, -0xd8, 0x49, 0xd6, 0xe7, 0x15, 0xdc, 0xc8, 0xd2, -0x6f, 0x70, 0x75, 0x4d, 0xb7, 0x67, 0x17, 0x1a, -0x75, 0xe9, 0xaa, 0x11, 0x9c, 0x2f, 0x7e, 0x65, -0x44, 0x6e, 0x56, 0x1c, 0xfd, 0x46, 0x27, 0xa2, -0x95, 0x1a, 0x2a, 0x5f, 0x29, 0x8c, 0x6e, 0x32, -0xa4, 0x58, 0x86, 0x9e, 0xe1, 0x5f, 0xac, 0xcf, -0x6a, 0x32, 0xa7, 0x43, 0x6b, 0x83, 0x95, 0xac, -0xfe, 0x75, 0x90, 0x5f, 0x41, 0x5f, 0x17, 0xc8, -0xe0, 0x17, 0x1b, 0xfb, 0xd6, 0x4d, 0x05, 0x2b, -0x75, 0x66, 0xf8, 0x93, 0xd8, 0x86, 0x19, 0x79, -0x49, 0x12, 0xb2, 0x78, 0x53, 0x89, 0x50, 0x1b, -0x7a, 0x43, 0xf2, 0x36, 0x6e, 0x14, 0x24, 0x1b, -0x06, 0xb9, 0x91, 0x9f, 0xcc, 0xb5, 0xf6, 0x5f, -0xa4, 0xa5, 0x17, 0x08, 0x7b, 0xf2, 0x73, 0x46, -0x3c, 0xc3, 0xdc, 0x08, 0xda, 0x73, 0x51, 0x3d, -0xec, 0x99, 0xa4, 0x9f, 0xf7, 0x54, 0x72, 0x4e, -0xcd, 0x53, 0xc1, 0x16, 0xff, 0xea, 0xb7, 0xf3, -0x87, 0x5e, 0xbe, 0x53, 0xb2, 0x33, 0x1e, 0xf9, -0x7a, 0xf4, 0x79, 0x51, 0x3b, 0x1e, 0x84, 0x4e, -0xf1, 0x46, 0x4d, 0xd4, 0xcf, 0x2f, 0x24, 0x7f, -0xcb, 0x5d, 0x77, 0x03, 0xbe, 0x63, 0x92, 0x45, -0xc4, 0x86, 0x45, 0x6d, 0x2b, 0x29, 0xf0, 0x6b, -0x00, 0xc3, 0xc2, 0xef, 0x58, 0x42, 0x8e, 0xc0, -0x05, 0x69, 0x1d, 0xcd, 0xe7, 0xb5, 0x24, 0xbb, -0xfe, 0xe5, 0x35, 0xc4, 0xfe, 0xaf, 0xce, 0x1b, -0x12, 0xa7, 0x61, 0x21, 0x83, 0xad, 0x14, 0xbc, -0x21, 0xce, 0x8f, 0xb2, 0xeb, 0x5f, 0xd3, 0x5e, -0xd0, 0x18, 0x6c, 0x6d, 0xec, 0x2f, 0xe7, 0x40, -0xc6, 0x68, 0x57, 0xca, 0xc1, 0x2f, 0x65, 0x1c, -0x7e, 0x05, 0x93, 0x18, 0xee, 0x1e, 0xb2, 0x71, -0xf9, 0x65, 0x1a, 0xce, 0xd2, 0x6f, 0xa4, 0x70, -0x7d, 0x5d, 0x25, 0xf0, 0x4b, 0x21, 0xbc, 0xf0, -0xdd, 0x4c, 0x46, 0x09, 0x23, 0x62, 0xac, 0xfe, -0x25, 0xd6, 0x29, 0x85, 0xc7, 0x54, 0x71, 0xe6, -0xb0, 0x7f, 0x8a, 0x64, 0x09, 0x39, 0xde, 0x11, -0x44, 0xcc, 0xa9, 0x7f, 0xd9, 0xfb, 0xbf, 0x3a, -0xf6, 0xdc, 0x10, 0xb4, 0x29, 0xe7, 0x20, 0xdb, -0x9c, 0x3e, 0xae, 0xfe, 0x25, 0xf0, 0xcb, 0xbb, -0x4b, 0x5e, 0xc8, 0x8f, 0x8d, 0xf2, 0xb1, 0x83, -0x7c, 0x0f, 0x42, 0x97, 0xd0, 0xcf, 0x37, 0x4f, -0xc4, 0x2f, 0x6a, 0x89, 0xd6, 0x6c, 0xfd, 0xe1, -0xc4, 0xf3, 0xa3, 0x7c, 0x9b, 0xe5, 0x0a, 0x6a, -0x0b, 0x39, 0x6c, 0x5e, 0x90, 0xd1, 0x6f, 0x08, -0xb7, 0xbc, 0x35, 0x30, 0x93, 0x0b, 0x39, 0xe4, -0x2c, 0x6d, 0xc6, 0x24, 0xfd, 0xa1, 0x3b, 0x4b, -0xc8, 0x61, 0x19, 0x47, 0x26, 0xea, 0x0f, 0xdd, -0x0a, 0x6d, 0x99, 0x80, 0x05, 0x13, 0xeb, 0x5f, -0x2e, 0xb9, 0xcc, 0xb0, 0xf8, 0xc5, 0x09, 0xdb, -0x98, 0xa8, 0x9f, 0xef, 0x97, 0xcf, 0x18, 0x42, -0x64, 0xd8, 0xe0, 0x20, 0x9a, 0xcd, 0xad, 0x5c, -0x67, 0x38, 0x5a, 0xe5, 0xf7, 0xcb, 0x4f, 0xab, -0xcc, 0x08, 0xc6, 0xe5, 0xdf, 0xc1, 0x6b, 0x02, -0xbf, 0xec, 0xf3, 0xa3, 0x90, 0x9f, 0x32, 0xfc, -0xea, 0x6c, 0x25, 0x09, 0x6e, 0xb0, 0xfd, 0xcb, -0xad, 0x02, 0xd1, 0xe4, 0x82, 0x1c, 0x4b, 0x1f, -0x25, 0x7a, 0x98, 0xa7, 0xad, 0x5f, 0xc3, 0x0d, -0x86, 0xb9, 0x5b, 0xac, 0x3e, 0xfb, 0x33, 0xfa, -0x43, 0x36, 0xd2, 0x4e, 0x7f, 0x60, 0x27, 0xb1, -0xf8, 0x69, 0x5f, 0xc2, 0x1a, 0x7b, 0x8e, 0x93, -0x3f, 0xe4, 0x68, 0x95, 0x1f, 0x2f, 0xfa, 0x39, -0x7f, 0xbc, 0x5e, 0xd6, 0x1f, 0xeb, 0x39, 0x5b, -0xe7, 0x47, 0xad, 0x90, 0x76, 0x12, 0x9b, 0x76, -0x51, 0x66, 0xcc, 0x61, 0xe5, 0xbc, 0xf1, 0xf5, -0xaf, 0x0c, 0x7e, 0x15, 0xe9, 0xad, 0x29, 0x1b, -0xbf, 0x52, 0xa4, 0x6e, 0x5c, 0xfd, 0x4b, 0xd5, -0x18, 0x5a, 0xc9, 0xef, 0x93, 0x6b, 0x2a, 0xd7, -0x43, 0x90, 0x4e, 0x61, 0xfb, 0x97, 0xd7, 0x5b, -0xf8, 0x35, 0xbe, 0xfe, 0xe5, 0x09, 0xbb, 0x0b, -0x94, 0x36, 0xc9, 0x02, 0xb2, 0x87, 0x14, 0xae, -0xe8, 0x18, 0xaf, 0x9f, 0xef, 0xf1, 0x34, 0x91, -0x52, 0x21, 0x4c, 0x42, 0x20, 0x33, 0x7f, 0x0a, -0xf9, 0x59, 0xf5, 0xaf, 0x5d, 0xce, 0xfe, 0x2f, -0xb9, 0x00, 0x98, 0x90, 0x83, 0x69, 0xda, 0xc9, -0xb7, 0xed, 0xfa, 0x97, 0xf0, 0xab, 0xd3, 0x76, -0x0b, 0xc9, 0x53, 0x1c, 0x23, 0x73, 0xcb, 0x67, -0x7e, 0x92, 0xb0, 0x54, 0x5e, 0xbd, 0xf6, 0xf9, -0x87, 0x9f, 0x8a, 0xd3, 0xf3, 0xba, 0xcb, 0x67, -0x1b, 0x47, 0x45, 0x18, 0x7f, 0xc1, 0x78, 0xb9, -0x3d, 0x3c, 0xe0, 0x5b, 0xe8, 0xb1, 0xce, 0x2d, -0x64, 0xfa, 0xf9, 0x97, 0x68, 0xd9, 0x90, 0xe7, -0x2f, 0x88, 0x1f, 0xd6, 0x91, 0xaa, 0x21, 0x4f, -0x0d, 0x39, 0x4e, 0xdf, 0x48, 0x6c, 0x1b, 0xf4, -0xd4, 0xb8, 0x67, 0x3b, 0xe7, 0x47, 0x19, 0x2f, -0x49, 0x65, 0xa9, 0x29, 0xcd, 0x44, 0xa5, 0xbc, -0xcf, 0xf7, 0x90, 0x51, 0xe4, 0x5f, 0x33, 0x18, -0xff, 0x72, 0xce, 0x3f, 0xb4, 0x64, 0xf3, 0x5b, -0x89, 0x44, 0xac, 0x50, 0xff, 0x88, 0xfe, 0x90, -0xd8, 0x44, 0xa0, 0x3a, 0xf5, 0x2f, 0x95, 0x95, -0xef, 0x71, 0x5d, 0x54, 0x19, 0xd6, 0x7a, 0x1f, -0x6b, 0x39, 0x04, 0x4c, 0xf3, 0xef, 0x99, 0x3d, -0x61, 0xff, 0x57, 0xfc, 0xeb, 0x83, 0xf0, 0x17, -0x99, 0x58, 0xbd, 0x26, 0xab, 0xfe, 0xe5, 0xe8, -0x0f, 0xcf, 0xc8, 0xc5, 0xc0, 0x80, 0xec, 0xf2, -0x61, 0xe2, 0x68, 0x06, 0xac, 0xfa, 0x17, 0xb5, -0xeb, 0x5f, 0x5b, 0xe4, 0xbb, 0x26, 0x83, 0xd4, -0x78, 0xfd, 0xa1, 0x3b, 0xd1, 0x3a, 0x7b, 0x52, -0x9b, 0x6c, 0xfd, 0x21, 0x3b, 0x0a, 0x0c, 0xb6, -0x1b, 0xbd, 0x6d, 0x24, 0xd8, 0xcb, 0xf6, 0x52, -0xc1, 0xde, 0x90, 0xd0, 0x1f, 0x3a, 0xe7, 0x47, -0xd1, 0x73, 0x7a, 0xdd, 0xc1, 0x82, 0x32, 0x59, -0xa7, 0x38, 0xae, 0x63, 0x9e, 0x3d, 0xf2, 0x68, -0x07, 0xdb, 0x11, 0xb6, 0xb4, 0x6b, 0x87, 0x29, -0x83, 0x85, 0x5f, 0x2a, 0xaf, 0xfe, 0xf7, 0xca, -0x49, 0x73, 0x4c, 0xa9, 0x3f, 0xe8, 0x3b, 0x5d, -0x7e, 0xd8, 0x18, 0x8b, 0xa1, 0x63, 0x3c, 0x25, -0x0f, 0x4a, 0x0e, 0x7e, 0xbd, 0x27, 0xe2, 0x8d, -0x5a, 0xf8, 0x8c, 0xe2, 0xb2, 0xa2, 0x3c, 0x7f, -0x58, 0x3f, 0x6e, 0xff, 0xd7, 0x10, 0x87, 0x2d, -0xec, 0x61, 0x05, 0xeb, 0x33, 0x45, 0x63, 0xd4, -0xf8, 0xa5, 0x35, 0x2e, 0x87, 0x7f, 0x69, 0x0f, -0xd9, 0xb1, 0xc4, 0x0e, 0x09, 0x97, 0x15, 0x10, -0x81, 0x68, 0x53, 0x32, 0xfc, 0xeb, 0xf6, 0x0d, -0xd6, 0x90, 0xdd, 0x15, 0x84, 0xdf, 0x67, 0x1b, -0x61, 0x27, 0xc4, 0x4e, 0xe4, 0x5f, 0x1c, 0x65, -0x42, 0x72, 0xb5, 0x81, 0xaf, 0xd6, 0x4a, 0xdf, -0x7a, 0xc9, 0xd1, 0xcf, 0x4f, 0xe6, 0x5f, 0x7d, -0xcc, 0xe8, 0x15, 0x3c, 0x85, 0x8c, 0xaf, 0x7f, -0x65, 0xf4, 0x87, 0xfa, 0xa1, 0x52, 0x1e, 0xea, -0x1f, 0x86, 0x73, 0x6a, 0x5d, 0x6f, 0x36, 0xff, -0xaa, 0x32, 0xac, 0x29, 0x18, 0x80, 0x4e, 0xa3, -0xba, 0x5b, 0x7d, 0x1c, 0xe7, 0x14, 0x79, 0xe5, -0x29, 0x24, 0x98, 0xa7, 0xc4, 0x63, 0x46, 0xfc, -0x32, 0xac, 0x57, 0xeb, 0x15, 0x36, 0x9c, 0x10, -0xbe, 0x6a, 0xaf, 0xc5, 0x70, 0xc5, 0x9d, 0xf4, -0x2c, 0x6c, 0x1d, 0xc9, 0xec, 0xaf, 0x5c, 0x27, -0xf6, 0x2f, 0x1f, 0x4f, 0xac, 0xa3, 0xc1, 0x98, -0x7a, 0x07, 0xe3, 0x5f, 0xad, 0xfc, 0xfc, 0xc3, -0x63, 0x94, 0xcf, 0x69, 0x54, 0x0d, 0x1a, 0xbf, -0xe5, 0xf8, 0x55, 0xbe, 0x9f, 0xbe, 0x0c, 0xb5, -0x89, 0x02, 0xb6, 0xff, 0xeb, 0x74, 0x47, 0xad, -0x99, 0x5b, 0xd3, 0x36, 0xfe, 0xfc, 0x79, 0xa6, -0x71, 0x1d, 0xcd, 0x19, 0x13, 0x42, 0xdf, 0xf3, -0xb1, 0x89, 0xfc, 0xeb, 0x53, 0xb0, 0xf4, 0x87, -0x3f, 0x67, 0xe7, 0x93, 0x80, 0xb7, 0x43, 0xfe, -0x35, 0x65, 0x85, 0xb0, 0x25, 0xdd, 0x72, 0xc0, -0xe6, 0x5f, 0x2f, 0x64, 0xf4, 0x87, 0x08, 0x5b, -0xa0, 0xf6, 0xb3, 0xf3, 0x76, 0x08, 0x2f, 0x84, -0x39, 0xfb, 0x97, 0x5f, 0x14, 0x7d, 0x1e, 0x21, -0xff, 0x86, 0x86, 0x94, 0x76, 0x8f, 0x90, 0xc7, -0xe0, 0x17, 0x74, 0xc6, 0x09, 0x75, 0x35, 0x49, -0x66, 0xf0, 0xcb, 0x82, 0xad, 0x25, 0xa4, 0x0d, -0xb6, 0xbf, 0x3e, 0x9b, 0xe5, 0x0f, 0x77, 0xc0, -0x4e, 0x56, 0x08, 0xf3, 0x67, 0xf8, 0xd7, 0x41, -0xbb, 0x94, 0xb0, 0x1e, 0xe6, 0xc5, 0x0b, 0xd2, -0xe5, 0xbb, 0xe0, 0x23, 0x58, 0xc0, 0x84, 0x1c, -0x93, 0xf5, 0xf3, 0xc2, 0xe9, 0xe5, 0x31, 0x5f, -0xb7, 0x95, 0x9d, 0x9b, 0x9a, 0xd1, 0xcf, 0x37, -0x4d, 0xe0, 0x5f, 0x1d, 0xb6, 0xe1, 0xb9, 0x08, -0xff, 0x0a, 0xfc, 0x8e, 0xd7, 0xbf, 0xa6, 0x6d, -0xb1, 0x0c, 0xcf, 0x96, 0x0c, 0xff, 0x9a, 0x99, -0xd1, 0x6f, 0xb0, 0xfa, 0xd7, 0xdf, 0x6e, 0xb1, -0x0c, 0x4f, 0xbc, 0xd5, 0xd6, 0x1f, 0x66, 0xf1, -0x2f, 0xba, 0x07, 0xaa, 0xa3, 0x6e, 0x3f, 0x37, -0xc6, 0xe5, 0x0f, 0x91, 0x7f, 0x75, 0x0b, 0xfd, -0x7c, 0x8f, 0x31, 0xdc, 0x54, 0x5b, 0xbc, 0xde, -0x36, 0x98, 0x7e, 0x9e, 0x8c, 0xc7, 0xaf, 0x38, -0xc7, 0xaf, 0xfa, 0xc6, 0xfc, 0xdf, 0x14, 0x0d, -0x18, 0x36, 0x7e, 0xe5, 0xf2, 0xb9, 0x50, 0x5d, -0x0e, 0xa2, 0xcd, 0x48, 0x88, 0x83, 0x9b, 0xda, -0x2a, 0xf8, 0x09, 0x4e, 0x78, 0xe5, 0x7d, 0xe7, -0xfc, 0x5e, 0x7d, 0x50, 0xe8, 0xe7, 0x59, 0xfd, -0xab, 0x1a, 0x3a, 0x7e, 0xee, 0xd6, 0x15, 0x66, -0xe4, 0xf5, 0x66, 0x9d, 0x3f, 0xdf, 0x61, 0xe9, -0x0f, 0xb7, 0xc0, 0xe3, 0x6a, 0x55, 0xb3, 0xda, -0xd4, 0x5a, 0xa2, 0xa3, 0x61, 0x78, 0x9a, 0x1c, -0xfd, 0xbc, 0xa5, 0x3f, 0x44, 0x5c, 0x7e, 0x0a, -0x7e, 0x05, 0x73, 0xf0, 0x3d, 0xcc, 0x99, 0xcf, -0x4f, 0xd3, 0xca, 0xeb, 0x77, 0xf2, 0x87, 0x5b, -0x1c, 0x6d, 0xfc, 0x4e, 0xd6, 0x0d, 0x23, 0xb8, -0x45, 0xe2, 0xfd, 0xc1, 0x2b, 0x52, 0xd6, 0xfe, -0x65, 0x71, 0x45, 0x6e, 0xb4, 0xf6, 0x2f, 0x67, -0xf2, 0x87, 0x07, 0x6d, 0xfe, 0xb5, 0x9d, 0x9f, -0xf3, 0xe6, 0x6b, 0x95, 0x99, 0xa0, 0x69, 0x1e, -0x82, 0x89, 0x2c, 0x94, 0x4d, 0x5e, 0xb3, 0xcc, -0x2d, 0x6a, 0x49, 0x95, 0xca, 0x42, 0x9e, 0x49, -0xf6, 0xd8, 0xdb, 0xbe, 0x78, 0xfd, 0xeb, 0x6d, -0x8a, 0x46, 0x9a, 0x64, 0x9d, 0x1f, 0x55, 0xce, -0xde, 0xb1, 0xf9, 0x50, 0x00, 0x6d, 0x94, 0xd7, -0xbf, 0xf0, 0xad, 0x23, 0xdc, 0x58, 0xaf, 0x5b, -0xfc, 0x6b, 0xba, 0x0d, 0x5b, 0x85, 0xd0, 0x6e, -0x2e, 0xd3, 0xd4, 0x46, 0x62, 0xc2, 0x96, 0x8e, -0xb2, 0x90, 0xba, 0x84, 0x74, 0x38, 0xfa, 0x43, -0x71, 0xec, 0xe1, 0x6a, 0x04, 0x93, 0x23, 0x74, -0x6f, 0x22, 0x38, 0xe8, 0x79, 0x1b, 0x8e, 0xd0, -0x79, 0xcc, 0x58, 0x6f, 0xe1, 0xd7, 0xa5, 0x6c, -0xff, 0xd7, 0x74, 0x21, 0x2f, 0x17, 0xc3, 0xc1, -0xb1, 0x5b, 0xc2, 0xd1, 0x88, 0xcd, 0xbf, 0xbe, -0x30, 0xb8, 0x1e, 0xfb, 0x43, 0xf9, 0x73, 0xe3, -0x93, 0x96, 0xab, 0x62, 0xca, 0x5b, 0x72, 0x35, -0xbc, 0x46, 0xeb, 0x97, 0x7b, 0xdf, 0x72, 0xf2, -0x87, 0x62, 0xff, 0xd7, 0x60, 0x67, 0x25, 0xf9, -0x88, 0xae, 0x45, 0x5c, 0x56, 0xff, 0x96, 0xf8, -0xcd, 0x9f, 0x27, 0xe7, 0xec, 0x42, 0xc3, 0xd1, -0xb4, 0xc7, 0x29, 0xdf, 0xbf, 0x7c, 0x17, 0x19, -0xd6, 0x77, 0x42, 0x95, 0xa6, 0x46, 0x48, 0x94, -0xb6, 0xc3, 0x1c, 0x55, 0x8d, 0x92, 0x01, 0xf1, -0x0c, 0x9d, 0xfd, 0xcb, 0x3a, 0xaf, 0xfd, 0x61, -0xf0, 0x3f, 0xbf, 0x75, 0xb9, 0x5a, 0x2e, 0x32, -0x1e, 0xc7, 0x26, 0xec, 0x5f, 0x4e, 0xca, 0x9f, -0xaa, 0xbf, 0x64, 0x81, 0x7d, 0xb2, 0x68, 0x39, -0xf7, 0x00, 0xd1, 0x64, 0xf9, 0xe0, 0xc4, 0xfd, -0xcb, 0x82, 0x02, 0xeb, 0x3e, 0x55, 0xde, 0xc5, -0x17, 0x5a, 0x3d, 0xcd, 0x3a, 0xbf, 0xd7, 0xf6, -0x99, 0xc7, 0xe0, 0x38, 0xe1, 0x0b, 0x36, 0x64, -0x3c, 0x88, 0x2d, 0x7c, 0xe9, 0x72, 0x6b, 0xff, -0x72, 0x4f, 0x46, 0x7f, 0x28, 0x42, 0xbe, 0xce, -0x38, 0x09, 0x5a, 0xb1, 0xdf, 0x2d, 0xb6, 0xfe, -0x50, 0xa9, 0x14, 0x6d, 0x12, 0xd8, 0xc6, 0x4a, -0xcb, 0xef, 0x84, 0x27, 0xec, 0x18, 0xd2, 0x5a, -0x5f, 0xbc, 0xe6, 0x92, 0xc2, 0x71, 0xa5, 0x62, -0xad, 0x24, 0x48, 0x3b, 0xf5, 0xb5, 0x1d, 0x81, -0xed, 0x52, 0xb0, 0x55, 0xae, 0x88, 0x5b, 0xfc, -0xcb, 0x50, 0x63, 0xed, 0xe7, 0x08, 0x7a, 0xe3, -0x6d, 0x18, 0xd3, 0x1e, 0x63, 0x87, 0x7b, 0xaf, -0xf5, 0x24, 0xe8, 0xa0, 0x56, 0xa7, 0xfa, 0xd6, -0x96, 0x3b, 0xfc, 0xcb, 0xda, 0xff, 0xb5, 0x4d, -0x1e, 0xa2, 0x63, 0x70, 0xf9, 0x41, 0x5f, 0x57, -0xdb, 0x8f, 0xe1, 0x1d, 0x44, 0xb4, 0x8d, 0x5d, -0x45, 0x93, 0xf4, 0xf3, 0x77, 0x3b, 0xc4, 0xf9, -0x7d, 0x72, 0x94, 0x45, 0x20, 0x23, 0xf2, 0xb0, -0xa5, 0x1b, 0xb4, 0xf5, 0xf3, 0xdd, 0x60, 0x1b, -0xd8, 0xd5, 0x4e, 0x98, 0xcd, 0x8d, 0x1c, 0x9b, -0x7f, 0xa9, 0xec, 0xb7, 0x00, 0x6e, 0x0c, 0x19, -0x68, 0x08, 0xa7, 0x97, 0x06, 0x2b, 0x56, 0x7f, -0x7f, 0x5c, 0xfd, 0x8b, 0x43, 0xb6, 0xe6, 0x40, -0x76, 0xa7, 0xd0, 0x6f, 0x0c, 0x5b, 0xbc, 0xa9, -0x64, 0x72, 0xba, 0xef, 0x65, 0x7e, 0x6e, 0xe1, -0x1f, 0xdf, 0xbf, 0x7c, 0xfa, 0x8f, 0xec, 0x5f, -0xb6, 0x8d, 0x13, 0xfc, 0x20, 0xc4, 0x0c, 0x7e, -0x1d, 0x63, 0x5a, 0x1a, 0x71, 0xfe, 0x86, 0x08, -0x21, 0x7c, 0x9c, 0x7f, 0xd1, 0x40, 0x96, 0xfe, -0x70, 0xd0, 0xc9, 0x1f, 0xe6, 0x38, 0xf9, 0x8d, -0x57, 0xe9, 0x43, 0x54, 0xcf, 0xd2, 0x1f, 0x22, -0xff, 0xb2, 0xd4, 0x47, 0x77, 0xf1, 0x5c, 0xdc, -0x20, 0x3b, 0x94, 0x89, 0xae, 0xa3, 0xcb, 0xf0, -0x4a, 0x8e, 0xc3, 0xbf, 0x0a, 0xde, 0xdc, 0x0b, -0xb5, 0x83, 0x4c, 0x3f, 0x6f, 0xb2, 0x83, 0xa4, -0x3c, 0x0b, 0xe5, 0xfd, 0x15, 0xef, 0x74, 0x24, -0x07, 0xb3, 0xf4, 0x87, 0xd3, 0x76, 0x73, 0xda, -0x75, 0x39, 0x8e, 0x4b, 0xe1, 0xfc, 0x6b, 0x0f, -0x2e, 0x99, 0x73, 0x96, 0x91, 0xcd, 0xbf, 0xd8, -0xfe, 0x65, 0x8f, 0xf8, 0x81, 0x98, 0xdc, 0xcc, -0x00, 0x17, 0x65, 0xf1, 0x2f, 0x2b, 0xbb, 0x92, -0xa5, 0x9f, 0xb7, 0xf5, 0x87, 0x39, 0x86, 0x78, -0xe7, 0x99, 0xfe, 0xf0, 0x7b, 0x2c, 0x4c, 0xfd, -0x0e, 0x3b, 0xc8, 0x37, 0x2d, 0xaf, 0x46, 0x20, -0x1b, 0xaf, 0x3f, 0x44, 0xfc, 0xb2, 0xa7, 0x72, -0x89, 0xb5, 0xd1, 0x32, 0xf0, 0xe9, 0x24, 0xfd, -0xa1, 0xb3, 0xff, 0x6b, 0x85, 0x6d, 0x9c, 0x35, -0x85, 0x41, 0x26, 0xe7, 0x0f, 0x9d, 0x9f, 0x4d, -0x49, 0xb3, 0x83, 0x6e, 0x04, 0xff, 0x12, 0x7e, -0x5e, 0x1b, 0x90, 0xc6, 0xe1, 0x17, 0x13, 0x78, -0x4b, 0x07, 0xec, 0xfd, 0x5f, 0xba, 0x8d, 0x5f, -0x0f, 0x67, 0xe7, 0x06, 0xf9, 0x01, 0x11, 0x2d, -0x46, 0x80, 0x15, 0x91, 0xd3, 0xd2, 0x04, 0xfe, -0x95, 0x49, 0x1b, 0x0e, 0x11, 0xeb, 0xfc, 0x8d, -0x49, 0xfc, 0xcb, 0x92, 0xf0, 0xb9, 0x99, 0x71, -0x3f, 0x24, 0x26, 0xf0, 0xaf, 0xee, 0xec, 0xb4, -0x98, 0x87, 0xf1, 0xaf, 0xf5, 0x4d, 0x4c, 0x9f, -0x90, 0xfb, 0xa9, 0x88, 0x0f, 0x19, 0x7e, 0x4d, -0xdc, 0x0b, 0xcc, 0xf4, 0xf3, 0x02, 0xbf, 0x2c, -0x4c, 0xb1, 0xf6, 0x7f, 0x6d, 0xec, 0x97, 0x2b, -0x2c, 0xb2, 0xe6, 0x99, 0x6f, 0x9c, 0xd7, 0xf8, -0xb8, 0xf6, 0xbb, 0x1c, 0xfe, 0x25, 0xd2, 0x86, -0x6e, 0x3d, 0xdb, 0x08, 0x67, 0xd7, 0xbf, 0x1c, -0xfd, 0x7c, 0x26, 0x7f, 0x98, 0x43, 0xf7, 0x08, -0xcd, 0xc9, 0xeb, 0x62, 0x9d, 0x66, 0xed, 0xff, -0x72, 0x1e, 0x02, 0x43, 0xf3, 0xed, 0x17, 0xd7, -0x1f, 0x56, 0x64, 0x8c, 0x93, 0x96, 0x7e, 0x1e, -0x6c, 0xfe, 0x35, 0x3e, 0x96, 0xf0, 0xd9, 0xba, -0xca, 0x8b, 0xf1, 0xaf, 0xec, 0xfc, 0x61, 0x4a, -0x15, 0xfa, 0x8d, 0xec, 0xfd, 0x5f, 0x22, 0x7f, -0xc8, 0xf5, 0xf3, 0x68, 0x9c, 0x55, 0x1f, 0xec, -0x09, 0x5c, 0x44, 0x7f, 0xf8, 0x48, 0x56, 0xfe, -0xf0, 0x28, 0x6d, 0xd3, 0x62, 0xe6, 0x45, 0xf6, -0x7f, 0x89, 0xd7, 0x98, 0x6f, 0x5b, 0x7e, 0x0f, -0xd6, 0x88, 0x7c, 0xc2, 0x44, 0xfe, 0x65, 0xe7, -0x0f, 0xa7, 0xac, 0x96, 0x2f, 0x20, 0x90, 0xed, -0xc9, 0xd6, 0x1f, 0x4e, 0x9b, 0xec, 0x13, 0x46, -0x59, 0xe7, 0x59, 0x12, 0x3e, 0xc3, 0xbf, 0x8c, -0x73, 0x6c, 0x1b, 0x51, 0xb7, 0xfc, 0x29, 0xdf, -0xc8, 0xec, 0x3b, 0x2b, 0x7f, 0xc1, 0x70, 0x30, -0x5b, 0x7f, 0x58, 0xf8, 0x20, 0xdd, 0xb7, 0x9d, -0xe9, 0xe7, 0xf1, 0x8d, 0xda, 0x27, 0x0a, 0x58, -0x6f, 0x42, 0x6b, 0x02, 0x7d, 0x42, 0x8d, 0xfc, -0x64, 0xd6, 0xf9, 0xbd, 0x7a, 0x55, 0xcf, 0x8d, -0x5c, 0x3f, 0xcf, 0x80, 0x6c, 0x15, 0x39, 0x06, -0x3f, 0xd7, 0xcb, 0xcc, 0x8c, 0xfe, 0x50, 0xcf, -0x9c, 0xbf, 0x61, 0x1f, 0xdb, 0x8b, 0x71, 0xd4, -0x76, 0xe1, 0x33, 0x3b, 0xb2, 0xcf, 0xef, 0xe5, -0x27, 0xc9, 0x33, 0xd9, 0x21, 0xef, 0xf3, 0xef, -0x31, 0x32, 0x67, 0xfa, 0x8d, 0x89, 0xfb, 0xbf, -0xb2, 0xc7, 0xf5, 0x01, 0xfc, 0x99, 0x30, 0x12, -0xe3, 0xf6, 0x2f, 0xf7, 0x64, 0xfb, 0xcc, 0x33, -0xca, 0x85, 0xf1, 0xfc, 0xcb, 0xc1, 0xaf, 0x00, -0x2b, 0xd9, 0x70, 0xff, 0xfc, 0x7b, 0xf6, 0x42, -0x66, 0xf3, 0x2f, 0x29, 0xab, 0xe6, 0x62, 0x51, -0x8f, 0x4f, 0xf5, 0xe7, 0xec, 0xfc, 0xa1, 0xb5, -0xbe, 0xbc, 0x74, 0xaf, 0xca, 0xf4, 0xf3, 0xa2, -0x84, 0xd4, 0xdf, 0x19, 0xda, 0xfe, 0x0a, 0xf0, -0xbd, 0x54, 0x73, 0xb3, 0xf8, 0x57, 0x9a, 0x6d, -0xb5, 0x5e, 0xfa, 0x4c, 0xf9, 0x27, 0x26, 0x27, -0x1a, 0x5d, 0x6c, 0x9f, 0xd4, 0x7d, 0xec, 0x2c, -0xaf, 0xb6, 0x71, 0xe7, 0xf7, 0xd6, 0xa7, 0x7c, -0xa7, 0x5f, 0x1e, 0x35, 0x3f, 0x63, 0xe7, 0x99, -0x77, 0x3d, 0xf4, 0x26, 0x3d, 0xa5, 0xd7, 0x33, -0x0e, 0xe2, 0x9c, 0x1f, 0x35, 0x0a, 0xaf, 0xea, -0x7b, 0x79, 0xd9, 0x4b, 0xb2, 0x0e, 0xfe, 0x5a, -0x50, 0x7a, 0xd8, 0x98, 0xd7, 0xe4, 0x1d, 0x2c, -0x67, 0x67, 0x15, 0x83, 0x38, 0xff, 0xb0, 0x33, -0x96, 0x29, 0x7b, 0xe9, 0x6a, 0x47, 0x60, 0x26, -0x3b, 0x77, 0xd7, 0xe8, 0x48, 0xb4, 0xda, 0xe7, -0x1f, 0xc2, 0x06, 0x68, 0x2d, 0x75, 0xf4, 0x87, -0x18, 0x43, 0xc6, 0x91, 0x02, 0x53, 0x5d, 0x8f, -0xaa, 0x81, 0x88, 0x7d, 0xfe, 0x3c, 0xec, 0x56, -0xd7, 0xab, 0x01, 0x67, 0xff, 0x57, 0x40, 0xdd, -0x4a, 0x2a, 0x49, 0x87, 0xba, 0xdd, 0xc0, 0xc0, -0x6c, 0x44, 0xcc, 0x97, 0x74, 0x3b, 0xb2, 0x2d, -0xa3, 0xcb, 0xb4, 0xce, 0xdf, 0xe0, 0x07, 0x7f, -0x29, 0xca, 0x81, 0xfe, 0xc0, 0x80, 0x37, 0x51, -0x9e, 0xb2, 0xf5, 0x87, 0x8f, 0xc2, 0x1f, 0xb4, -0x97, 0x1c, 0xfc, 0x02, 0x9f, 0x59, 0x7e, 0x06, -0x9d, 0x79, 0x6d, 0x4f, 0x7d, 0xfa, 0xee, 0x2c, -0xfe, 0x75, 0x50, 0xcc, 0xf2, 0x90, 0xfa, 0xb1, -0xab, 0x8e, 0x1d, 0x6f, 0x5b, 0x89, 0x6b, 0xb0, -0xcb, 0x40, 0x5e, 0xd0, 0x6f, 0xeb, 0x37, 0x6a, -0xe9, 0x83, 0x60, 0xe9, 0x2a, 0x3f, 0x26, 0xd5, -0xa0, 0xc6, 0x31, 0x3e, 0xdc, 0x8b, 0xe3, 0x52, -0x77, 0x6f, 0xfe, 0x5c, 0xe8, 0xd9, 0xd8, 0xf9, -0x87, 0xad, 0x6a, 0x96, 0xae, 0x52, 0xd5, 0x89, -0xa2, 0x74, 0x81, 0xde, 0x83, 0x86, 0xc5, 0xd1, -0x62, 0xda, 0x77, 0x8c, 0x07, 0xe9, 0x32, 0xbb, -0xfe, 0x55, 0x95, 0x56, 0x57, 0x90, 0x4b, 0xe0, -0x19, 0xbc, 0xa2, 0xae, 0x8c, 0x38, 0xfa, 0xc3, -0x25, 0xd0, 0x03, 0x21, 0xd3, 0x37, 0x97, 0xd1, -0x2e, 0xa8, 0xed, 0x53, 0xc3, 0xb2, 0x0a, 0xa7, -0xf5, 0x90, 0x19, 0xd4, 0xe5, 0xb7, 0xc5, 0x7d, -0x8c, 0x92, 0x0d, 0xc4, 0x3a, 0xa1, 0x71, 0xc8, -0x26, 0x8f, 0x1f, 0x89, 0x8c, 0x7d, 0xc2, 0xc6, -0x5c, 0x55, 0x79, 0x4c, 0x3d, 0x28, 0x50, 0x78, -0x08, 0x4e, 0xd3, 0x1a, 0xd3, 0xa7, 0xcb, 0x39, -0x90, 0x62, 0xf9, 0xc3, 0x84, 0xec, 0x2e, 0xe6, -0x6d, 0xa2, 0xa5, 0xff, 0x27, 0xb4, 0x9a, 0xdb, -0xec, 0xf5, 0x8e, 0x4b, 0x26, 0x16, 0x29, 0x86, -0x56, 0x66, 0xa4, 0x49, 0x58, 0xac, 0x65, 0x1d, -0x1e, 0xa3, 0xeb, 0x12, 0xdb, 0xb2, 0x6a, 0x76, -0x23, 0xe4, 0x32, 0x58, 0x63, 0x96, 0xc5, 0x3c, -0x2b, 0xdc, 0x60, 0xeb, 0xe7, 0x19, 0x5f, 0x4e, -0xd8, 0x63, 0xe7, 0x0f, 0x41, 0x85, 0xb6, 0x98, -0x1e, 0x43, 0x47, 0xe4, 0xb7, 0xf5, 0x87, 0x83, -0x70, 0x44, 0xa8, 0x0d, 0x85, 0x8f, 0xc2, 0xfe, -0x54, 0xc2, 0x11, 0xb3, 0xab, 0xd5, 0x97, 0x96, -0xc3, 0xb6, 0x9e, 0x0d, 0xa7, 0x57, 0x1b, 0xe7, -0xeb, 0xa6, 0x0c, 0x93, 0x89, 0xfb, 0xbf, 0xd0, -0x67, 0xc6, 0xc3, 0xe3, 0xf6, 0x1c, 0xcd, 0x6c, -0xb7, 0x4e, 0x81, 0xb0, 0xce, 0x33, 0x37, 0x19, -0xff, 0xe2, 0x6a, 0x43, 0x3f, 0xc7, 0x26, 0xa4, -0x5d, 0x91, 0x2b, 0xc4, 0x26, 0xaf, 0x52, 0xb7, -0xe5, 0x35, 0x16, 0x5e, 0x57, 0xa1, 0x3d, 0xab, -0x06, 0xb2, 0xf0, 0xab, 0x9f, 0xcc, 0x17, 0xbf, -0x81, 0xb5, 0x89, 0x08, 0x99, 0x27, 0xd7, 0x1f, -0xee, 0xd1, 0x13, 0x36, 0x7e, 0x55, 0xc5, 0x3c, -0xc7, 0xc8, 0x25, 0xca, 0x9e, 0xb2, 0x60, 0x14, -0xff, 0x95, 0xf5, 0x1b, 0x7e, 0x23, 0x2c, 0x7f, -0xd8, 0x24, 0x8e, 0x55, 0xcf, 0xb3, 0xba, 0x1a, -0xe2, 0x1b, 0x99, 0x91, 0x91, 0x2d, 0xb0, 0xf5, -0x87, 0x03, 0x88, 0x44, 0x59, 0x7e, 0x7e, 0x69, -0xd2, 0xc3, 0x85, 0x88, 0xd7, 0xf9, 0xfa, 0xe5, -0xf7, 0x73, 0x2c, 0xfd, 0xe1, 0x19, 0x7a, 0x3e, -0xdd, 0xc5, 0xe1, 0x98, 0x43, 0x1b, 0xd7, 0xab, -0x5f, 0x5f, 0xc9, 0x7e, 0x3f, 0x45, 0x0e, 0x08, -0xcd, 0xc0, 0xc2, 0x52, 0xc4, 0x2f, 0x1a, 0x10, -0xfa, 0x79, 0x86, 0x5f, 0x1d, 0xcc, 0x60, 0xbf, -0x64, 0xa1, 0x9a, 0xd8, 0x67, 0x4b, 0xbf, 0xb1, -0x86, 0xed, 0x56, 0xb6, 0xfb, 0x5c, 0x6d, 0xa8, -0x4d, 0xe4, 0x0c, 0xac, 0x51, 0xcb, 0x9a, 0xd4, -0x5b, 0x5a, 0x2f, 0x93, 0xf8, 0xe8, 0xb7, 0x2a, -0x3b, 0xe1, 0x79, 0x3d, 0x20, 0xca, 0x5e, 0xec, -0x20, 0x44, 0xa6, 0x3f, 0x0c, 0xac, 0x6b, 0x64, -0xbc, 0xdb, 0x5f, 0x6d, 0xed, 0xff, 0xba, 0x7d, -0x80, 0xa9, 0xbc, 0x32, 0x7d, 0xf6, 0x6e, 0x69, -0xe8, 0x33, 0x0e, 0x40, 0x38, 0xe6, 0xc5, 0x97, -0x5f, 0xb7, 0xe6, 0x6b, 0xa7, 0x72, 0x52, 0x79, -0x31, 0xd3, 0x86, 0xe5, 0x0f, 0xd1, 0x78, 0x31, -0x3a, 0x27, 0xee, 0x71, 0xf4, 0x87, 0x88, 0x5f, -0xba, 0x75, 0xec, 0xfc, 0xa0, 0x10, 0x72, 0x9c, -0x80, 0x11, 0x05, 0x0d, 0xb3, 0x88, 0xd8, 0xfa, -0xc3, 0xd9, 0xfa, 0x8b, 0x94, 0xa3, 0xd5, 0xa0, -0xf6, 0x1c, 0x04, 0x99, 0xfe, 0xd0, 0x3a, 0xff, -0x30, 0x4d, 0x88, 0x26, 0xda, 0x28, 0x8d, 0xb0, -0xd7, 0x4c, 0x64, 0xad, 0x2f, 0x16, 0x28, 0x22, -0x40, 0xa7, 0x71, 0x7d, 0x59, 0x73, 0x41, 0xb5, -0xdb, 0xe0, 0x19, 0xa1, 0x9e, 0x65, 0x67, 0x59, -0xcc, 0xe1, 0x85, 0x5d, 0x78, 0x5a, 0xaa, 0xea, -0xc7, 0xfb, 0x08, 0x97, 0x09, 0x1d, 0x1d, 0xdf, -0xc2, 0xf0, 0x7b, 0x8f, 0xc0, 0x2f, 0x24, 0x62, -0x09, 0xef, 0x0a, 0x84, 0xda, 0xff, 0x8d, 0x01, -0x79, 0x30, 0x25, 0x8b, 0x57, 0x1e, 0xd4, 0x92, -0x9d, 0xd9, 0x7e, 0xbe, 0x96, 0xce, 0x49, 0x60, -0xe7, 0xd9, 0x3e, 0xa9, 0x5c, 0xea, 0x39, 0x68, -0xeb, 0x0f, 0xff, 0xe5, 0x16, 0x2b, 0x7a, 0x47, -0x7f, 0x18, 0xaf, 0x1f, 0xdc, 0xb8, 0x3a, 0xb7, -0xce, 0x38, 0x4f, 0xeb, 0x63, 0xbe, 0x41, 0xb9, -0x5f, 0x8c, 0xeb, 0xc9, 0xd2, 0x2d, 0xb0, 0x56, -0xb3, 0xfa, 0xf3, 0x07, 0x0e, 0xac, 0xf2, 0x9d, -0xc6, 0xd3, 0x5a, 0x55, 0x63, 0x5e, 0x8c, 0x7c, -0xb4, 0x98, 0xb7, 0xd1, 0x60, 0x8b, 0xd6, 0x02, -0x76, 0x9f, 0xa5, 0xaa, 0x8e, 0xce, 0x65, 0x6e, -0x2d, 0xfa, 0x34, 0xe3, 0xcb, 0xd7, 0xa3, 0xb7, -0xe1, 0x6d, 0x62, 0x4a, 0x3b, 0x62, 0x8f, 0xe5, -0x5b, 0x90, 0x76, 0x31, 0x7c, 0x27, 0xf0, 0x2c, -0x0d, 0x1a, 0x79, 0x10, 0xb6, 0xbe, 0x6b, 0x17, -0xcb, 0xf7, 0xea, 0x5d, 0xa2, 0xcc, 0xcd, 0x63, -0xec, 0x38, 0xa9, 0xd2, 0xbf, 0x68, 0xab, 0xa3, -0x1e, 0x76, 0x02, 0x2a, 0x7f, 0x37, 0xe2, 0x18, -0x6f, 0x58, 0x3f, 0xfb, 0x65, 0xd5, 0xf5, 0xe2, -0x48, 0x58, 0xbe, 0x30, 0xea, 0xe2, 0xb9, 0x4f, -0xc9, 0x03, 0xb6, 0xfe, 0xf0, 0x29, 0x38, 0x6f, -0xec, 0x75, 0x7c, 0x26, 0xf5, 0xa5, 0xca, 0x87, -0xd5, 0x0b, 0xbd, 0x73, 0xa9, 0xb7, 0x5f, 0xb6, -0xf4, 0x87, 0x8f, 0xe3, 0xfa, 0x4a, 0x1a, 0xdb, -0x9d, 0x94, 0x20, 0xf5, 0x74, 0x60, 0x58, 0xf8, -0x9c, 0x11, 0x88, 0xab, 0x5b, 0x22, 0x27, 0x97, -0x59, 0xf9, 0x43, 0x16, 0x11, 0x05, 0xb2, 0xd2, -0x86, 0x9b, 0x91, 0x8c, 0x3c, 0x07, 0x01, 0x88, -0x26, 0x03, 0x69, 0x31, 0x5f, 0x88, 0x5f, 0x90, -0x84, 0x6c, 0x2d, 0xba, 0x86, 0xc6, 0x73, 0xf8, -0x92, 0x22, 0xaf, 0x74, 0xf4, 0x87, 0xcb, 0xed, -0x53, 0x95, 0x38, 0xe6, 0x32, 0x59, 0x54, 0xba, -0xf4, 0x39, 0x29, 0x0c, 0xc1, 0xb8, 0x9c, 0x6e, -0x75, 0xea, 0x5f, 0x17, 0xb2, 0x78, 0x0a, 0xdd, -0x68, 0xde, 0x35, 0x8c, 0x98, 0xfb, 0x12, 0xf8, -0xfa, 0xbf, 0x9f, 0x9e, 0x69, 0xe9, 0x37, 0x1c, -0xda, 0x75, 0xc1, 0x16, 0x72, 0x4c, 0xdc, 0xff, -0x45, 0x1d, 0xfe, 0x45, 0xec, 0x83, 0x7c, 0xc9, -0xa7, 0xda, 0xf3, 0xed, 0xd5, 0x27, 0x3c, 0xdd, -0x91, 0xec, 0xf3, 0xa3, 0x64, 0x7e, 0x32, 0xc3, -0x61, 0x76, 0x04, 0x25, 0x1a, 0x77, 0x65, 0xed, -0xff, 0x12, 0xdf, 0x55, 0x28, 0xf8, 0x57, 0xa7, -0xcd, 0xbf, 0xa6, 0x64, 0x1d, 0xdc, 0xe4, 0x9c, -0x7f, 0x38, 0xb9, 0x16, 0x29, 0xce, 0xa2, 0x5c, -0x9a, 0x2c, 0x9a, 0x74, 0x7e, 0xaf, 0x3c, 0x7a, -0xe9, 0x38, 0x22, 0xe6, 0xb9, 0x08, 0xff, 0x6a, -0x18, 0x1a, 0xf7, 0xa0, 0xb2, 0xf5, 0x1b, 0x56, -0x2e, 0x57, 0x16, 0x3f, 0xd1, 0xb2, 0x20, 0x3b, -0x97, 0x1b, 0xb9, 0xf8, 0xf9, 0x51, 0xe3, 0x37, -0x08, 0x64, 0xf4, 0x1b, 0x71, 0x06, 0x5b, 0x53, -0xee, 0x23, 0xc7, 0xe3, 0x2f, 0xd1, 0x19, 0xe2, -0xfc, 0xa8, 0x7d, 0xdb, 0xaa, 0x4e, 0x70, 0x2e, -0xc3, 0xef, 0xc3, 0x7f, 0xbf, 0x32, 0x59, 0xdb, -0xc7, 0xf9, 0xd7, 0x39, 0x08, 0x0d, 0xfa, 0xae, -0x66, 0x40, 0x46, 0x6b, 0xcd, 0x8d, 0xd7, 0x64, -0x9d, 0x1f, 0xd5, 0x78, 0x4e, 0x6c, 0x5b, 0x1e, -0x6a, 0xfa, 0x98, 0x15, 0x37, 0x93, 0xdf, 0x18, -0xb5, 0x37, 0xd4, 0x67, 0xeb, 0x37, 0x14, 0x8c, -0x5b, 0xf8, 0x71, 0x8e, 0xca, 0xb8, 0xa0, 0xab, -0x61, 0xd2, 0xf9, 0x51, 0x19, 0xda, 0xf5, 0xee, -0x84, 0xfd, 0x5f, 0xb6, 0x7e, 0xc3, 0xc1, 0x5c, -0xc7, 0x98, 0x32, 0xfe, 0xfc, 0xa8, 0x49, 0x7b, -0xb7, 0xf7, 0x8a, 0x22, 0xc5, 0xa4, 0xf3, 0xa3, -0x2c, 0x4d, 0xf2, 0xc6, 0x44, 0xd1, 0xa0, 0xf7, -0x0b, 0x91, 0xa0, 0xf8, 0x4f, 0xf5, 0x1b, 0x7f, -0xe4, 0xfc, 0xa8, 0xa5, 0xd9, 0xfb, 0xbf, 0x2e, -0xa6, 0xdf, 0xc8, 0x18, 0x35, 0x7f, 0xec, 0xfc, -0xa8, 0x22, 0xcb, 0x58, 0xf4, 0x65, 0xe7, 0x47, -0x29, 0x0e, 0x11, 0xab, 0xcc, 0xce, 0x1f, 0x66, -0xef, 0xff, 0x9a, 0xd8, 0xe7, 0x8b, 0x9e, 0x1f, -0x45, 0xc6, 0xf3, 0x14, 0x4b, 0xbf, 0xb1, 0x55, -0x1a, 0xb8, 0x28, 0x97, 0xb9, 0xc8, 0xf9, 0x51, -0x92, 0x83, 0x5f, 0xd9, 0xc6, 0x11, 0xc1, 0xdf, -0x33, 0xfb, 0x97, 0x2d, 0xce, 0xd8, 0xa6, 0x45, -0x9c, 0x2b, 0x17, 0x39, 0x7f, 0x63, 0xb2, 0x76, -0xc5, 0xca, 0x1f, 0x16, 0xda, 0xdf, 0xde, 0x30, -0xb9, 0x3f, 0x59, 0xe7, 0x47, 0x89, 0x29, 0xb8, -0x48, 0xe7, 0x0f, 0xfe, 0x31, 0xfe, 0x35, 0x41, -0xbf, 0x61, 0xf3, 0x2f, 0x76, 0x24, 0xe6, 0x73, -0x8a, 0xd8, 0xbf, 0xfc, 0x25, 0xfb, 0xbf, 0xa6, -0x4c, 0x38, 0x9f, 0x2d, 0x5b, 0xbf, 0x91, 0xc5, -0xbf, 0x1e, 0xb5, 0xf9, 0x97, 0xf3, 0x3e, 0x0f, -0x8a, 0xf3, 0xb1, 0x33, 0xfc, 0xeb, 0xd6, 0xe3, -0x59, 0x44, 0xac, 0x7d, 0xb2, 0xfe, 0x90, 0xad, -0x14, 0xc9, 0x3e, 0x67, 0xa9, 0xc8, 0xf1, 0x09, -0x19, 0xfd, 0x86, 0xc8, 0x1f, 0xf2, 0xf3, 0xa3, -0x18, 0x11, 0x3b, 0xcb, 0x89, 0x18, 0x37, 0x32, -0xe7, 0x6f, 0xd0, 0xbd, 0xec, 0xfc, 0xc3, 0x6b, -0x08, 0xdb, 0xbf, 0x1c, 0xe4, 0xeb, 0x9d, 0xb2, -0xdf, 0x4b, 0xf2, 0xac, 0x8e, 0x58, 0x9c, 0xa8, -0x14, 0xac, 0xf3, 0x0f, 0xad, 0x63, 0x7b, 0xb9, -0x21, 0xed, 0xd3, 0xaa, 0xb2, 0xf7, 0x7f, 0x39, -0xeb, 0xcb, 0x9f, 0x19, 0xbb, 0xad, 0xe8, 0xb0, -0xce, 0xdf, 0x48, 0x38, 0xfc, 0xab, 0x7c, 0x32, -0xc9, 0xfa, 0x23, 0xfc, 0x2b, 0x2b, 0xa3, 0x68, -0xeb, 0x37, 0x60, 0x4c, 0x19, 0xcf, 0xbf, 0x18, -0x23, 0xfb, 0x11, 0x3f, 0x59, 0x71, 0xe2, 0xf9, -0x1b, 0x19, 0xfe, 0x35, 0xa4, 0xb2, 0x8a, 0x61, -0x27, 0x62, 0xd3, 0x45, 0xf8, 0xd7, 0x44, 0xc3, -0xe1, 0x5f, 0xf9, 0x99, 0xa9, 0x44, 0xfe, 0x75, -0x50, 0xd4, 0xbf, 0x58, 0x45, 0x6c, 0xbe, 0xa3, -0x3f, 0xcc, 0x5f, 0xc9, 0xab, 0x5d, 0x1b, 0x9f, -0xf1, 0x73, 0xfd, 0x06, 0x3f, 0x64, 0x3e, 0x71, -0xae, 0xb6, 0x06, 0xb9, 0x55, 0xe6, 0xf7, 0x53, -0x86, 0x8c, 0xb1, 0x59, 0xf5, 0x7d, 0xbe, 0xbd, -0x6d, 0x43, 0x7d, 0x9f, 0x41, 0xdd, 0x41, 0xdf, -0x33, 0x6c, 0x3f, 0x6c, 0xa0, 0x86, 0x9d, 0x60, -0x39, 0xe8, 0xe7, 0x73, 0x01, 0xaf, 0x2c, 0x92, -0x9b, 0x8d, 0x3b, 0xb5, 0xab, 0x94, 0xfc, 0x1e, -0x89, 0x19, 0x5f, 0xcb, 0xc9, 0x7f, 0x45, 0xba, -0x27, 0xef, 0x4e, 0xf5, 0xaa, 0xb2, 0x7c, 0x73, -0x2e, 0x88, 0x36, 0x8d, 0xb9, 0xf7, 0x48, 0x77, -0x1a, 0x5f, 0xd3, 0x4a, 0xfa, 0xb8, 0xf1, 0x6d, -0xad, 0xc4, 0x54, 0xe6, 0xc2, 0x06, 0xe3, 0x1b, -0xc5, 0x8a, 0x59, 0xd8, 0x24, 0x3a, 0x44, 0x24, -0x9d, 0x46, 0x75, 0xbf, 0xaa, 0xb4, 0x0a, 0xc3, -0x8b, 0xc6, 0x3d, 0x54, 0xd5, 0x8b, 0x54, 0x97, -0x08, 0x25, 0xd8, 0x83, 0x46, 0x22, 0x76, 0x07, -0x5c, 0x02, 0x2e, 0x2a, 0xc5, 0xa4, 0x3b, 0xe0, -0x36, 0x34, 0x1e, 0x8f, 0xa9, 0x51, 0x7e, 0xc5, -0x6a, 0xf3, 0x4a, 0xd4, 0xb5, 0x4a, 0xba, 0x93, -0x7e, 0x4d, 0x2f, 0x49, 0x71, 0xe3, 0xdb, 0xdf, -0x2d, 0x4e, 0xb9, 0x7e, 0x50, 0x1b, 0xed, 0xfb, -0xf6, 0x32, 0xe7, 0xbb, 0x5e, 0x69, 0xc2, 0x45, -0x54, 0x0a, 0x8b, 0x15, 0xa9, 0x85, 0x1b, 0x39, -0x12, 0x6d, 0x85, 0xd8, 0x26, 0x15, 0x8d, 0x38, -0xb5, 0xfb, 0x6c, 0x28, 0x01, 0x49, 0x85, 0x88, -0xae, 0x51, 0x45, 0xe7, 0x46, 0x21, 0x2d, 0xc6, -0x2b, 0x66, 0x04, 0x34, 0xa7, 0xcd, 0xad, 0x52, -0xa4, 0xa7, 0x49, 0xbf, 0x2d, 0x58, 0x42, 0x24, -0x83, 0x36, 0x95, 0x15, 0x2f, 0xbc, 0x3d, 0x22, -0x45, 0xa0, 0x29, 0x79, 0x5b, 0x69, 0x09, 0xd8, -0xe3, 0xf2, 0x4a, 0x45, 0x70, 0x9d, 0xa9, 0x35, -0xbb, 0x96, 0x48, 0x5f, 0x33, 0x6e, 0x33, 0x4b, -0x7e, 0xa0, 0x78, 0xa5, 0xdb, 0x4d, 0xa3, 0xbf, -0xb0, 0xd9, 0xfa, 0x19, 0x04, 0x36, 0x2e, 0x74, -0x9e, 0x8c, 0xaf, 0x49, 0xa0, 0xf8, 0xf1, 0xf6, -0x4a, 0x1c, 0x54, 0xb8, 0x1e, 0x54, 0x43, 0xda, -0x0a, 0x92, 0x3d, 0xae, 0x18, 0x29, 0x85, 0xb5, -0x10, 0xc3, 0x27, 0x42, 0x4a, 0x8d, 0x56, 0xd0, -0xdb, 0xd1, 0x50, 0x0d, 0x02, 0x65, 0xb4, 0x54, -0x72, 0xc6, 0xe5, 0x8a, 0x49, 0x6f, 0xc1, 0xb7, -0x8c, 0x19, 0xd4, 0xb5, 0x5c, 0x3a, 0x06, 0x3f, -0x34, 0x8a, 0x69, 0xee, 0x72, 0x29, 0x85, 0x57, -0x8a, 0x33, 0xe3, 0xca, 0x8b, 0xc1, 0x31, 0x7c, -0x62, 0xf9, 0x54, 0xba, 0x0b, 0xee, 0xa0, 0x97, -0xc0, 0xb4, 0x0e, 0xa9, 0x59, 0x8a, 0xc2, 0x02, -0x98, 0xe6, 0xb4, 0x89, 0xe4, 0x84, 0x5a, 0xbc, -0x7a, 0x83, 0xaa, 0xbd, 0x7c, 0x49, 0xe8, 0x15, -0x66, 0x94, 0xbe, 0xac, 0xb0, 0x6f, 0x6e, 0xf0, -0x82, 0x39, 0xd7, 0x1a, 0x97, 0x6a, 0x84, 0x58, -0xd0, 0x8c, 0x30, 0x8e, 0x6f, 0xb8, 0x17, 0xbb, -0x8e, 0x98, 0xc6, 0x72, 0xd7, 0x78, 0xc5, 0xb0, -0xc7, 0xe5, 0x91, 0x42, 0x74, 0x49, 0xb2, 0x48, -0x55, 0x0e, 0x4a, 0xa1, 0x96, 0x25, 0xa1, 0x5b, -0x55, 0xa5, 0xd7, 0x15, 0xc2, 0xc9, 0x2d, 0x52, -0x8b, 0x4d, 0xf1, 0x9b, 0x4a, 0xf0, 0x4a, 0xc3, -0x8c, 0xe6, 0x96, 0x3b, 0x42, 0x7e, 0xb5, 0xa4, -0xcd, 0xd5, 0xdc, 0x73, 0x87, 0xfe, 0x2d, 0xd5, -0xd5, 0xe6, 0x8a, 0xd1, 0x52, 0x34, 0x4a, 0xa8, -0xf5, 0x5d, 0xaf, 0x44, 0x40, 0xc7, 0x6f, 0x8f, -0xa8, 0x48, 0x02, 0x63, 0xac, 0x30, 0xa6, 0x6a, -0x14, 0x42, 0x12, 0x7b, 0x00, 0x40, 0x43, 0x56, -0x9f, 0x6f, 0x51, 0xe6, 0xb7, 0x5c, 0x8a, 0x6d, -0x0a, 0x37, 0x2b, 0x7a, 0x8b, 0x37, 0xd9, 0xb0, -0xe2, 0x9b, 0xeb, 0xf1, 0x4a, 0x9e, 0xbe, 0x38, -0xaa, 0xd1, 0x42, 0xfb, 0x19, 0x4a, 0xa5, 0xd2, -0xb7, 0xa0, 0x89, 0x96, 0xa0, 0x01, 0x8b, 0xa1, -0x90, 0xba, 0xd8, 0x95, 0x08, 0xdc, 0x4e, 0x15, -0xc3, 0x9e, 0xaf, 0x1c, 0x69, 0x11, 0x6d, 0x8a, -0x15, 0x97, 0xba, 0x2c, 0x63, 0xab, 0x6b, 0xb1, -0x74, 0x3d, 0x8d, 0x30, 0x03, 0xac, 0x0f, 0xf5, -0xbb, 0x14, 0xba, 0x48, 0x6f, 0x52, 0x15, 0xbf, -0x0b, 0xa8, 0xa1, 0x6b, 0x51, 0x85, 0x14, 0x2a, -0x2d, 0x8b, 0xd0, 0x60, 0x73, 0x28, 0xbe, 0x6b, -0xb1, 0xfc, 0x4d, 0xfa, 0x66, 0xec, 0xca, 0x52, -0xaf, 0x6d, 0xa8, 0x39, 0x68, 0x28, 0x68, 0x94, -0x1a, 0x21, 0x6b, 0x5c, 0x8b, 0x5d, 0xf7, 0xd0, -0x3b, 0x63, 0xdf, 0x2e, 0x75, 0xad, 0x45, 0xe3, -0xdd, 0xf4, 0x3f, 0xa8, 0x25, 0xfb, 0x73, 0xf1, -0x69, 0xe8, 0xdf, 0x56, 0x4b, 0xec, 0xb5, 0x73, -0x5d, 0x04, 0x57, 0xc1, 0xbb, 0xb1, 0xaf, 0x95, -0xe6, 0xef, 0x47, 0xe3, 0xce, 0x13, 0x57, 0xa9, -0x68, 0x34, 0xb7, 0xdc, 0x19, 0x43, 0xc3, 0xb4, -0xc6, 0x75, 0xdd, 0xe2, 0x9c, 0xb9, 0x78, 0xa5, -0xa1, 0xf4, 0xf6, 0xfd, 0x68, 0x78, 0x97, 0xc9, -0x77, 0x14, 0xee, 0x57, 0xae, 0x6c, 0xcf, 0x8b, -0x7d, 0xfb, 0x0e, 0xa0, 0xd6, 0xb8, 0x80, 0x48, -0xcd, 0xf8, 0xe4, 0x09, 0xae, 0x2f, 0x7c, 0x98, -0x77, 0xea, 0x5f, 0xc3, 0xb9, 0xe0, 0x57, 0x70, -0xc5, 0x51, 0x6b, 0x5c, 0x52, 0x8e, 0xb4, 0x8c, -0xde, 0x81, 0x2f, 0x1a, 0x8e, 0xbd, 0xac, 0xe5, -0x8e, 0xe1, 0x6f, 0x2d, 0x74, 0x6d, 0x74, 0x2d, -0x6b, 0x89, 0xc6, 0x2e, 0x29, 0xc5, 0x36, 0x86, -0xf8, 0x2e, 0xa3, 0xa4, 0x59, 0xba, 0x13, 0x8a, -0xa0, 0xd8, 0x74, 0x35, 0x4b, 0x4b, 0xe2, 0xdf, -0xe6, 0x06, 0xc6, 0x18, 0xdf, 0x26, 0xce, 0xfa, -0x72, 0x45, 0x80, 0xcd, 0xa0, 0x35, 0x5f, 0xaa, -0x9e, 0xe3, 0x66, 0xc6, 0x36, 0x34, 0x0a, 0x9c, -0xb9, 0xb8, 0x2e, 0x82, 0xd3, 0xa4, 0xea, 0x8b, -0xd5, 0xc2, 0x56, 0x34, 0xb0, 0xf1, 0x6c, 0x66, -0x6c, 0x63, 0xb3, 0x5c, 0x98, 0x69, 0x53, 0x66, -0xb4, 0x34, 0x85, 0x6e, 0xf7, 0x96, 0x44, 0x24, -0xc3, 0xbc, 0xad, 0xac, 0x58, 0x65, 0x46, 0x87, -0xc1, 0xde, 0x0d, 0xc3, 0x19, 0x17, 0xce, 0xe7, -0x6d, 0x7a, 0x89, 0xd7, 0x15, 0x91, 0x9a, 0xcc, -0xdb, 0x42, 0x25, 0x95, 0xed, 0x0d, 0x52, 0x13, -0x6d, 0xd4, 0x0b, 0xbd, 0x0a, 0x88, 0x98, 0x84, -0x7d, 0xee, 0xe2, 0x2b, 0x4c, 0x52, 0x15, 0x43, -0xc1, 0xf5, 0x25, 0xe1, 0x7b, 0x6a, 0x14, 0xa3, -0x33, 0x95, 0xec, 0xbf, 0xe3, 0x77, 0x11, 0x9d, -0x52, 0x5d, 0xaf, 0x54, 0x09, 0x21, 0x68, 0x80, -0xda, 0xe1, 0x27, 0x4a, 0x07, 0x04, 0xca, 0xbc, -0x5b, 0xed, 0xb5, 0x7c, 0x9d, 0x91, 0xcb, 0xdc, -0xce, 0x0f, 0xd1, 0xdb, 0xe0, 0x8b, 0x73, 0x0c, -0xbe, 0x95, 0x53, 0x4c, 0xbf, 0x11, 0x9b, 0x9b, -0x52, 0xbf, 0x05, 0xc5, 0x76, 0x9f, 0xd7, 0x18, -0x12, 0xdb, 0x27, 0xc1, 0x0e, 0x24, 0x46, 0xdf, -0x72, 0x27, 0x7c, 0x8d, 0xe4, 0x51, 0xb9, 0xf9, -0xea, 0xa8, 0xfa, 0x2d, 0x32, 0x95, 0x3a, 0xdf, -0x96, 0xa3, 0x4b, 0x5e, 0xec, 0xb9, 0x66, 0xa2, -0x81, 0x6f, 0x62, 0x85, 0x96, 0xd2, 0x63, 0xd1, -0x8e, 0x52, 0x99, 0xa8, 0x4e, 0x1b, 0x0d, 0xbd, -0x43, 0x3e, 0xb6, 0x81, 0x7e, 0xa8, 0x60, 0x47, -0xcc, 0xfb, 0x69, 0x3f, 0xcc, 0xd0, 0x54, 0x76, -0xb6, 0x9f, 0xd3, 0x46, 0x91, 0xca, 0x60, 0x89, -0xe1, 0x2f, 0x56, 0xfa, 0xa4, 0xb2, 0x45, 0x4b, -0x9a, 0x6e, 0x2d, 0x56, 0x7e, 0x37, 0xe3, 0xea, -0xd4, 0x92, 0xa6, 0xa2, 0xcb, 0x9c, 0x39, 0x85, -0x72, 0xd7, 0x8a, 0x9e, 0x3f, 0x0f, 0x5d, 0xb2, -0xa1, 0x64, 0x07, 0x37, 0xbe, 0xb5, 0xa1, 0x64, -0xbb, 0xeb, 0x6f, 0xe8, 0x0d, 0xa1, 0x4b, 0x1e, -0x93, 0x9c, 0x36, 0xa5, 0xf8, 0x5d, 0x79, 0xe8, -0xe2, 0x20, 0x0e, 0x33, 0xd9, 0x77, 0x69, 0x68, -0xcc, 0x47, 0xa7, 0x47, 0x0c, 0xcd, 0x69, 0xa3, -0x2a, 0x77, 0x15, 0x96, 0x2a, 0x8b, 0xa5, 0xc2, -0x8e, 0xc6, 0x58, 0x61, 0x69, 0xfb, 0xe2, 0x42, -0x34, 0x42, 0x85, 0x6a, 0x7b, 0x8e, 0xb4, 0x29, -0x33, 0xae, 0x45, 0x4d, 0x85, 0xb7, 0x29, 0xb7, -0x4b, 0x25, 0xc6, 0xa2, 0x26, 0xed, 0x36, 0xa5, -0x84, 0x19, 0x9a, 0x66, 0xe0, 0x15, 0x97, 0xe1, -0xdc, 0xa7, 0x2c, 0xc2, 0x6b, 0xaf, 0x6b, 0xa2, -0x68, 0xdc, 0x46, 0x8a, 0xd1, 0x91, 0x6d, 0x8b, -0xa0, 0x47, 0x43, 0xc3, 0xb9, 0x8d, 0xdb, 0x45, -0xa8, 0x91, 0x44, 0x72, 0xcd, 0x0c, 0xe4, 0x7e, -0xb3, 0xc1, 0xbd, 0x08, 0x8d, 0x5d, 0x5a, 0xa5, -0xd3, 0x04, 0xbc, 0xf2, 0xad, 0xf0, 0xa6, 0xb9, -0x2c, 0xa4, 0x32, 0xa3, 0xdd, 0xbc, 0x32, 0xac, -0x36, 0x7e, 0xe3, 0x56, 0x5d, 0x49, 0x95, 0x84, -0xb6, 0x66, 0xbe, 0x8b, 0x41, 0x40, 0xfc, 0xdb, -0xba, 0x2b, 0x25, 0xad, 0x82, 0x77, 0xe1, 0x1f, -0x94, 0x7f, 0x46, 0x50, 0x28, 0x7b, 0xb7, 0xfd, -0xaf, 0xf5, 0x12, 0xd3, 0x6e, 0x23, 0x43, 0xb4, -0x57, 0x0b, 0x29, 0xde, 0x65, 0xe5, 0x60, 0xf4, -0xf9, 0xe7, 0x2a, 0xde, 0xb2, 0x72, 0xcd, 0x30, -0xfd, 0xa1, 0x76, 0x6f, 0xe6, 0xe5, 0xa8, 0x1f, -0x5b, 0x3a, 0xf6, 0xc6, 0xd8, 0x99, 0xb1, 0xf3, -0x93, 0x0d, 0xf8, 0xaf, 0x7c, 0x16, 0xbc, 0xe3, -0x59, 0xd0, 0xfb, 0x5a, 0x72, 0xef, 0xca, 0xa0, -0x30, 0xc6, 0x86, 0x82, 0xef, 0x2d, 0x1d, 0x7b, -0xfd, 0x3d, 0x34, 0x9c, 0x36, 0x57, 0xd4, 0x2e, -0x39, 0x5a, 0x34, 0xaf, 0xef, 0xf0, 0xc9, 0x79, -0xc2, 0x18, 0x3b, 0x39, 0xaf, 0x1e, 0xbf, 0xab, -0x1e, 0x8d, 0x4c, 0x7f, 0x4a, 0x6f, 0x7e, 0x75, -0xf3, 0xdc, 0xf6, 0x07, 0xce, 0x5e, 0x53, 0x1a, -0x3d, 0x5e, 0xb4, 0xaf, 0x7d, 0xc3, 0xbd, 0xd7, -0xac, 0x8e, 0xee, 0x2f, 0xda, 0x33, 0xb0, 0x61, -0x99, 0xd3, 0xc6, 0x45, 0x9a, 0x8d, 0xa9, 0xcd, -0x57, 0x28, 0x79, 0xaf, 0xc0, 0x3d, 0x68, 0x2c, -0xb0, 0x0c, 0xed, 0x8a, 0xe2, 0x4b, 0x9d, 0xb1, -0x2b, 0x36, 0x1c, 0xf7, 0x7d, 0x8d, 0x19, 0x45, -0xda, 0xed, 0x7d, 0xae, 0x7b, 0xa4, 0x77, 0xf1, -0xca, 0x34, 0xa7, 0x0d, 0xc7, 0x65, 0xc8, 0xe0, -0xb2, 0xaa, 0xac, 0x15, 0x06, 0x28, 0xd4, 0xb9, -0x8f, 0x80, 0x51, 0x90, 0xda, 0x61, 0x99, 0x54, -0x6a, 0x2c, 0x06, 0x89, 0x2a, 0xcb, 0xd8, 0x15, -0x35, 0xf3, 0x8e, 0xb9, 0x95, 0x55, 0xd2, 0x54, -0xfa, 0x0d, 0x5d, 0x3b, 0x64, 0x19, 0x85, 0x29, -0x65, 0xd5, 0x22, 0x66, 0x48, 0xce, 0x77, 0x81, -0x05, 0xc7, 0xf8, 0x86, 0xa3, 0x03, 0x61, 0x37, -0x6c, 0xb5, 0xef, 0xec, 0xdc, 0xa7, 0x50, 0x29, -0x97, 0xf2, 0x4c, 0x84, 0xe3, 0x2d, 0x4a, 0x85, -0xc4, 0x5e, 0x5a, 0x2d, 0xae, 0xcc, 0x68, 0x51, -0x69, 0xa4, 0x39, 0xb3, 0x2e, 0xca, 0xe1, 0x86, -0x1e, 0x7f, 0xa2, 0x71, 0x57, 0xe1, 0xdd, 0x10, -0xe5, 0xbf, 0xe9, 0x5a, 0x88, 0xfc, 0xde, 0xf4, -0x0f, 0x37, 0xee, 0xb2, 0xe7, 0x54, 0x35, 0x55, -0x28, 0xa2, 0x8a, 0x89, 0x30, 0xb2, 0x44, 0x38, -0x33, 0x06, 0x62, 0xb7, 0x82, 0x62, 0x4a, 0xf3, -0x25, 0xc3, 0x72, 0x1b, 0x66, 0x31, 0x14, 0x02, -0xdb, 0x03, 0x28, 0x15, 0x23, 0x60, 0x16, 0xd2, -0x9c, 0x52, 0xec, 0xcb, 0x75, 0x2e, 0x05, 0x9d, -0x80, 0x24, 0xc2, 0x3a, 0xbc, 0x8f, 0x81, 0xab, -0xa5, 0x5d, 0x42, 0x7f, 0xc1, 0x96, 0x0d, 0xeb, -0x81, 0xca, 0x16, 0x6d, 0x3b, 0x94, 0x29, 0x6a, -0xa6, 0x4d, 0x71, 0xcc, 0xb5, 0x15, 0x22, 0xec, -0x16, 0x31, 0xb2, 0x95, 0x23, 0x4f, 0x8e, 0x80, -0xa0, 0x32, 0x0b, 0xbf, 0x34, 0xc9, 0xc0, 0x91, -0x6e, 0x65, 0xcb, 0x8f, 0x92, 0xbb, 0xa0, 0x94, -0xe6, 0x40, 0x5e, 0x87, 0xc2, 0xc6, 0x3e, 0x13, -0x2e, 0x6d, 0x15, 0x31, 0xb6, 0x71, 0x9d, 0x83, -0xcb, 0xbd, 0x8e, 0xa1, 0x84, 0x5a, 0x36, 0x30, -0xc3, 0xf2, 0xf3, 0x06, 0xa8, 0x1c, 0x8e, 0x1d, -0x5c, 0x96, 0x81, 0xff, 0xce, 0xab, 0x30, 0xc4, -0xb8, 0x0c, 0xf0, 0x40, 0x88, 0x7a, 0xcb, 0x64, -0x15, 0x0e, 0x41, 0xa8, 0xc7, 0x1b, 0x6a, 0x50, -0x0d, 0xfe, 0xcb, 0x70, 0xba, 0xac, 0x2a, 0x20, -0xfc, 0x98, 0x71, 0x5d, 0x83, 0xd2, 0x8c, 0x6e, -0x19, 0xfd, 0x73, 0x9b, 0xd2, 0xdc, 0x53, 0x1a, -0x62, 0x06, 0xc4, 0x7a, 0xd8, 0x15, 0x89, 0x8a, -0x7d, 0xeb, 0x86, 0x14, 0x11, 0xf1, 0x88, 0x85, -0xcb, 0xf8, 0xcf, 0xd1, 0x08, 0xa1, 0xe7, 0x67, -0xb8, 0x2c, 0xda, 0x34, 0x49, 0x11, 0xee, 0xde, -0x2d, 0x3f, 0xcf, 0xfa, 0x5c, 0x88, 0x6d, 0xb8, -0xe7, 0xb7, 0xe7, 0xd4, 0xb8, 0xce, 0xc0, 0xf1, -0x17, 0xc3, 0x75, 0x50, 0x68, 0x08, 0x37, 0x0d, -0xc5, 0x80, 0xb4, 0xcb, 0xc0, 0x5b, 0x14, 0x46, -0xc4, 0xb8, 0xa2, 0xf8, 0x0e, 0x2c, 0xa2, 0x5a, -0x4c, 0x29, 0x95, 0xf6, 0xdb, 0x86, 0x73, 0xc5, -0x9a, 0xd3, 0x28, 0x10, 0x01, 0xc7, 0x38, 0x03, -0x92, 0x30, 0x10, 0x97, 0xa1, 0x85, 0x1b, 0x16, -0x2e, 0x1b, 0xd7, 0x39, 0x70, 0xbc, 0x9f, 0x1b, -0x57, 0x95, 0xe6, 0xdb, 0x57, 0xf2, 0x6d, 0x4c, -0x91, 0x16, 0x2b, 0xf7, 0xb4, 0x4c, 0x8d, 0xe5, -0x96, 0x22, 0x8c, 0xde, 0x43, 0x1f, 0x8d, 0xfd, -0x35, 0x7e, 0x29, 0x61, 0x57, 0xbe, 0x51, 0x2a, -0x99, 0xa2, 0xce, 0x68, 0x48, 0x8b, 0x81, 0xfd, -0xe9, 0x0a, 0x35, 0x4f, 0xb4, 0xc9, 0x2d, 0xcd, -0xe3, 0x00, 0x1d, 0xbb, 0xa2, 0x34, 0xcf, 0x7a, -0x9f, 0x9b, 0x2c, 0x5c, 0xfe, 0x76, 0x69, 0xc9, -0x7e, 0x05, 0x71, 0x19, 0x01, 0x1a, 0x8d, 0x7b, -0x5a, 0x1e, 0x65, 0x57, 0x7a, 0xed, 0xf9, 0xf2, -0x43, 0x05, 0xbd, 0x9e, 0x2d, 0xab, 0xcd, 0x88, -0xcb, 0x77, 0xe8, 0x5f, 0x8b, 0xe2, 0x42, 0x9b, -0xcf, 0xae, 0x44, 0x15, 0x6a, 0xf5, 0x19, 0xc7, -0x8e, 0x51, 0x5e, 0x2c, 0xa7, 0x54, 0x5a, 0xab, -0x94, 0x21, 0x1c, 0x2f, 0x66, 0xc6, 0x32, 0x71, -0xc5, 0x7e, 0xe7, 0xaf, 0x8b, 0x29, 0xab, 0xa5, -0xe9, 0x52, 0x43, 0xab, 0x96, 0x46, 0xe3, 0x06, -0x68, 0xa0, 0xdc, 0x98, 0x0e, 0xdf, 0xa0, 0x9a, -0x85, 0xcb, 0x86, 0x74, 0x0b, 0x2c, 0xa7, 0x97, -0xb2, 0xd9, 0xd9, 0x2c, 0x26, 0x2e, 0x8a, 0xf3, -0xc5, 0xae, 0xe4, 0x44, 0xed, 0xb5, 0x63, 0xf0, -0xf9, 0x52, 0x13, 0x62, 0xbe, 0xd6, 0xe0, 0xc4, -0x55, 0xf2, 0x89, 0x13, 0xb8, 0x6c, 0xcf, 0x57, -0x04, 0x8c, 0x16, 0x2d, 0x74, 0x9d, 0xb7, 0x10, -0x0d, 0x53, 0x0b, 0xb9, 0xb8, 0x41, 0x35, 0xbd, -0xd1, 0x5b, 0x68, 0xd8, 0xe3, 0x62, 0xb8, 0x5c, -0x9c, 0x70, 0x79, 0x59, 0x40, 0x6c, 0x16, 0x87, -0x5c, 0x95, 0x52, 0x03, 0xbb, 0xa2, 0xe3, 0x15, -0xc3, 0xba, 0x0f, 0x62, 0x4a, 0x04, 0xe7, 0x59, -0x91, 0x18, 0x2e, 0x5b, 0x00, 0x0d, 0x11, 0x09, -0x01, 0x1a, 0x67, 0xcb, 0x9e, 0xaf, 0x08, 0x81, -0x2c, 0x5c, 0x4e, 0xe8, 0xaa, 0xda, 0x8a, 0x57, -0x3a, 0xd8, 0x15, 0xb0, 0xc7, 0x65, 0x28, 0x76, -0x40, 0xc7, 0x8d, 0xbf, 0xca, 0xac, 0xaf, 0x42, -0x6a, 0xcf, 0x17, 0x2b, 0x0a, 0x3c, 0x0c, 0x33, -0x8d, 0x3c, 0x8a, 0x78, 0x3a, 0x0d, 0x72, 0xd1, -0x50, 0x7e, 0x80, 0xab, 0x65, 0xa6, 0x71, 0xbd, -0x33, 0xae, 0x58, 0x4e, 0xa5, 0x54, 0xc0, 0x1f, -0x5d, 0x4e, 0xa5, 0xeb, 0x32, 0x58, 0x8c, 0x46, -0xf1, 0x0a, 0x69, 0xbd, 0xd6, 0xe0, 0x3c, 0xc3, -0x26, 0x8c, 0x1d, 0x74, 0xc3, 0xdb, 0x24, 0x6f, -0x81, 0x1e, 0x28, 0x6b, 0x42, 0x00, 0x2b, 0x61, -0x86, 0xa1, 0x6a, 0x72, 0x09, 0x98, 0xf6, 0xb8, -0x14, 0x28, 0x83, 0xfc, 0x45, 0xf2, 0x6d, 0xd0, -0x07, 0x33, 0x16, 0xe5, 0x37, 0x35, 0x34, 0xc1, -0x2b, 0x70, 0x25, 0xa8, 0x4d, 0x78, 0xa5, 0xd7, -0x5e, 0xcb, 0x0d, 0x0a, 0xae, 0xa6, 0xe6, 0xc5, -0x5e, 0x5c, 0x5f, 0xdc, 0x98, 0x2a, 0xd6, 0x57, -0x08, 0x0d, 0xea, 0x8c, 0x0b, 0xb8, 0x5f, 0x09, -0xe1, 0xec, 0x94, 0x1b, 0x2a, 0xfb, 0x79, 0x21, -0xca, 0xe4, 0x68, 0x40, 0x2a, 0x90, 0x50, 0x5a, -0xf3, 0x15, 0x6d, 0xe4, 0xb8, 0xac, 0x09, 0x5c, -0x56, 0x18, 0x2e, 0x1b, 0x77, 0x49, 0x08, 0xd0, -0x52, 0xa1, 0xdd, 0xe6, 0x3a, 0xc3, 0x68, 0x2a, -0x2c, 0x5e, 0x7c, 0xdd, 0xa2, 0x4d, 0x86, 0xd9, -0xa4, 0x15, 0x17, 0xbb, 0xa4, 0x42, 0xe3, 0x3a, -0x68, 0x2a, 0x56, 0xd8, 0x8a, 0x73, 0xfc, 0x46, -0x22, 0x82, 0x5e, 0xc4, 0xc5, 0x03, 0xed, 0xd2, -0xe2, 0xb5, 0x2e, 0x1d, 0x5f, 0xb4, 0x48, 0xa9, -0x86, 0x93, 0x8f, 0xfe, 0x50, 0xcc, 0x98, 0xe1, -0xee, 0x41, 0x5c, 0x4e, 0x08, 0x5c, 0x6e, 0x81, -0x84, 0x81, 0x86, 0x44, 0x5a, 0x8c, 0x04, 0xc7, -0x65, 0xf1, 0x9c, 0xaf, 0xbb, 0xe9, 0xe5, 0x5b, -0x63, 0x6f, 0xf6, 0x97, 0xcd, 0x57, 0xf3, 0x8b, -0x6e, 0x35, 0xda, 0xd1, 0xc8, 0xbb, 0x49, 0xbe, -0xd5, 0x78, 0xb3, 0xff, 0xca, 0xf9, 0xaa, 0xe1, -0x8c, 0x6b, 0x6d, 0xf3, 0x8c, 0xa9, 0xad, 0xb9, -0x4a, 0xa1, 0x59, 0x81, 0x58, 0x00, 0xdf, 0x28, -0x2b, 0x49, 0x91, 0x55, 0x85, 0x53, 0xdb, 0x11, -0x14, 0x4c, 0x7b, 0x35, 0x97, 0x0b, 0x5c, 0x5e, -0xb2, 0xac, 0xbc, 0x34, 0xba, 0xdf, 0x3f, 0xb7, -0x7d, 0x03, 0x1a, 0x06, 0x37, 0xfe, 0xfb, 0x71, -0xb9, 0x6a, 0xec, 0xc6, 0x9f, 0xbc, 0x3c, 0x76, -0xe6, 0xdc, 0xca, 0xaa, 0xb1, 0xa5, 0xfb, 0xde, -0xf8, 0xe4, 0x4c, 0x06, 0x97, 0x33, 0xf7, 0x99, -0x37, 0xb6, 0x64, 0xac, 0x68, 0xec, 0xcc, 0xe8, -0xc9, 0x79, 0x63, 0x4b, 0x8f, 0xbe, 0x71, 0xfa, -0x4c, 0x06, 0x97, 0x33, 0x6d, 0xae, 0xe1, 0xb8, -0x3c, 0x20, 0x70, 0xd9, 0x7f, 0x15, 0xc7, 0xe5, -0x9b, 0x19, 0x2e, 0x3f, 0x70, 0xd6, 0x69, 0x43, -0xda, 0x61, 0x1b, 0x54, 0x1a, 0xee, 0xa9, 0xbd, -0x96, 0xa1, 0xb1, 0x2b, 0x87, 0x99, 0xe1, 0xb4, -0x41, 0xbf, 0xe5, 0x38, 0xb0, 0x09, 0x46, 0xa6, -0xd3, 0xed, 0xec, 0x55, 0xe0, 0xe8, 0x33, 0xc9, -0x70, 0x3e, 0xdc, 0xed, 0x19, 0x30, 0xd5, 0xb4, -0x0c, 0xbe, 0xc6, 0x0e, 0x73, 0xc3, 0xf9, 0x50, -0xf1, 0x92, 0x4d, 0x36, 0xbc, 0xa6, 0xd3, 0xe7, -0x2f, 0x6f, 0x65, 0xf7, 0x98, 0x31, 0x78, 0xfe, -0xeb, 0xc3, 0x20, 0x8e, 0xa1, 0xc8, 0x6e, 0x4a, -0xec, 0x36, 0x17, 0xfd, 0x1a, 0x6e, 0x78, 0x7b, -0xed, 0x36, 0xee, 0x76, 0xb2, 0x0d, 0x76, 0x19, -0xb3, 0x35, 0xf7, 0xba, 0x30, 0x37, 0xa6, 0x1e, -0xb4, 0xaf, 0x90, 0x3f, 0xfd, 0xf9, 0xa8, 0x93, -0x9f, 0x4f, 0xe6, 0x8a, 0xdd, 0x1f, 0x0d, 0x72, -0x43, 0xf8, 0x34, 0xbe, 0x8f, 0xcf, 0x87, 0x1b, -0xce, 0xf3, 0xf9, 0x3e, 0x30, 0x99, 0x85, 0x75, -0x9f, 0x75, 0xa1, 0x2f, 0x7b, 0xce, 0x4e, 0x7f, -0xb0, 0xf1, 0x7f, 0xf2, 0x7c, 0xf8, 0x7c, 0x7d, -0xc9, 0x73, 0x76, 0x5a, 0x68, 0xac, 0x46, 0xf7, -0x65, 0x1f, 0x91, 0xd3, 0xfb, 0x53, 0x3e, 0xb5, -0xb5, 0x7f, 0xe4, 0x8f, 0x3e, 0xdf, 0x9f, 0x7a, -0x9b, 0xff, 0xc6, 0x4f, 0xfd, 0xd8, 0xd8, 0x98, -0x79, 0x71, 0xe3, 0xff, 0xd3, 0x6d, 0x48, 0xf6, -0x12, 0x1e, 0x6f, 0x64, 0x1a, 0x89, 0xa5, 0x37, -0xf1, 0x5d, 0x1d, 0xbf, 0x06, 0xff, 0x0b, 0x6b, -0x59, 0xbb, 0x88, 0xe1, 0x7c, 0xbe, 0x74, 0x2d, -0xdb, 0x0d, 0xbe, 0x7c, 0x05, 0x66, 0x5a, 0xa9, -0x99, 0x25, 0xac, 0x4e, 0x58, 0xd4, 0x81, 0x3f, -0x65, 0x2d, 0x67, 0xda, 0x88, 0xb5, 0xfc, 0x7d, -0x5c, 0xcb, 0xd6, 0x12, 0x9e, 0xb4, 0x96, 0xd5, -0x3f, 0xb6, 0x96, 0x9d, 0x36, 0x7f, 0xe4, 0xf9, -0x8c, 0x5b, 0xcb, 0xc0, 0xd7, 0xb2, 0xb5, 0x84, -0xad, 0x45, 0x8d, 0x46, 0xaf, 0xf2, 0x27, 0xdf, -0xe7, 0x4f, 0xf1, 0x75, 0x7f, 0xca, 0x73, 0x86, -0x0c, 0x71, 0xbe, 0xc8, 0xe7, 0xab, 0xb5, 0xfc, -0xff, 0xbe, 0x36, 0xff, 0xf9, 0x27, 0x04, 0xba, -0x44, 0xf8, 0xff, 0x46, 0xae, 0xff, 0x2f, 0xfe, -0xd3, 0xaf, 0x3e, 0x5f, 0x7d, 0xbe, 0xfa, 0x7c, -0xf5, 0xf9, 0xea, 0xf3, 0xd5, 0xe7, 0xab, 0xcf, -0x57, 0x9f, 0xff, 0x5f, 0x7c, 0x78, 0xbc, 0x44, -0x78, 0xbc, 0x64, 0xfc, 0x3f, 0xdd, 0x97, 0xaf, -0x3e, 0x5f, 0x7d, 0xbe, 0xfa, 0x7c, 0xf5, 0xf9, -0xea, 0xf3, 0xd5, 0xe7, 0xab, 0xcf, 0x57, 0x9f, -0xff, 0xbb, 0x3f, 0x21, 0x2e, 0x0c, 0x7b, 0xa3, -0x36, 0x04, 0xbc, 0xa8, 0x2b, 0x87, 0xc0, 0xc8, -0xfb, 0xd3, 0xfe, 0x1d, 0x6f, 0xef, 0x0a, 0x41, -0x42, 0xca, 0xdc, 0xa7, 0xe7, 0x1f, 0x27, 0xf6, -0xf5, 0xff, 0x02, 0xd6, 0x2c, 0x67, 0x26, 0xbd, -0xa4, 0x00, 0x00, diff --git a/include/configs/CPCI4052.h b/include/configs/CPCI4052.h index bf85439..ceddd7a 100644 --- a/include/configs/CPCI4052.h +++ b/include/configs/CPCI4052.h @@ -23,6 +23,8 @@ #undef CONFIG_CPCI405_6U /* enable this for 6U boards */
#define CONFIG_SYS_TEXT_BASE 0xFFFC0000 +#define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_DISPLAY_BOARDINFO
#define CONFIG_BOARD_EARLY_INIT_F 1 /* call board_early_init_f() */ #define CONFIG_MISC_INIT_R 1 /* call misc_init_r() */
On Mon, Jan 12, 2015 at 10:47:31PM +0100, Matthias Fuchs wrote:
- remove some obsolete code
- switch to generic board
Signed-off-by: Matthias Fuchs matthias.fuchs@esd.eu
Matthias Fuchs
