[PATCH] rockchip: rk3399: Add EAIDK-610 support
Specification - Rockchip RK3399 - LPDDR3 4GB - TF sd scard slot - eMMC - AP6255 for WiFi + BT - Gigabit ethernet - HDMI out - 40 pin header - USB 2.0 x 2 - USB 3.0 x 1 - USB 3.0 Type-C x 1 work in otg mode - 12V DC Power supply
The dts file is sync from linux-next[0].
[0]:https://git.kernel.org/pub/scm/linux/kernel/git/next/linux-next.git/tree/arc...
Signed-off-by: Andy Yan andyshrk@163.com ---
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3399-eaidk-610-u-boot.dtsi | 18 + arch/arm/dts/rk3399-eaidk-610.dts | 939 ++++++++++++++++++++++ board/rockchip/evb_rk3399/MAINTAINERS | 6 + configs/eaidk-610-rk3399_defconfig | 61 ++ 5 files changed, 1025 insertions(+) create mode 100644 arch/arm/dts/rk3399-eaidk-610-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-eaidk-610.dts create mode 100644 configs/eaidk-610-rk3399_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 7330121dba..98a336e88e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -137,6 +137,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3368) += \
dtb-$(CONFIG_ROCKCHIP_RK3399) += \ rk3399-evb.dtb \ + rk3399-eaidk-610.dtb \ rk3399-ficus.dtb \ rk3399-firefly.dtb \ rk3399-gru-bob.dtb \ diff --git a/arch/arm/dts/rk3399-eaidk-610-u-boot.dtsi b/arch/arm/dts/rk3399-eaidk-610-u-boot.dtsi new file mode 100644 index 0000000000..a3f27566e4 --- /dev/null +++ b/arch/arm/dts/rk3399-eaidk-610-u-boot.dtsi @@ -0,0 +1,18 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2022 Andy Yan andy.yan@gmail.com + */ + +#include "rk3399-u-boot.dtsi" +#include "rk3399-sdram-lpddr3-4GB-1600.dtsi" + +/ { + chosen { + stdout-path = "serial2:1500000n8"; + u-boot,spl-boot-order = "same-as-spl", &sdhci, &sdmmc; + }; +}; + +&vdd_log { + regulator-init-microvolt = <950000>; +}; diff --git a/arch/arm/dts/rk3399-eaidk-610.dts b/arch/arm/dts/rk3399-eaidk-610.dts new file mode 100644 index 0000000000..d1f343345f --- /dev/null +++ b/arch/arm/dts/rk3399-eaidk-610.dts @@ -0,0 +1,939 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2022 Fuzhou Rockchip Electronics Co., Ltd. + */ + +/dts-v1/; +#include <dt-bindings/input/linux-event-codes.h> +#include <dt-bindings/pwm/pwm.h> +#include <dt-bindings/usb/pd.h> +#include "rk3399.dtsi" +#include "rk3399-opp.dtsi" + +/ { + model = "OPEN AI LAB EAIDK-610"; + compatible = "openailab,eaidk-610", "rockchip,rk3399"; + + aliases { + mmc0 = &sdio0; + mmc1 = &sdmmc; + mmc2 = &sdhci; + }; + + backlight: backlight { + compatible = "pwm-backlight"; + pwms = <&pwm0 0 25000 0>; + brightness-levels = < + 0 1 2 3 4 5 6 7 + 8 9 10 11 12 13 14 15 + 16 17 18 19 20 21 22 23 + 24 25 26 27 28 29 30 31 + 32 33 34 35 36 37 38 39 + 40 41 42 43 44 45 46 47 + 48 49 50 51 52 53 54 55 + 56 57 58 59 60 61 62 63 + 64 65 66 67 68 69 70 71 + 72 73 74 75 76 77 78 79 + 80 81 82 83 84 85 86 87 + 88 89 90 91 92 93 94 95 + 96 97 98 99 100 101 102 103 + 104 105 106 107 108 109 110 111 + 112 113 114 115 116 117 118 119 + 120 121 122 123 124 125 126 127 + 128 129 130 131 132 133 134 135 + 136 137 138 139 140 141 142 143 + 144 145 146 147 148 149 150 151 + 152 153 154 155 156 157 158 159 + 160 161 162 163 164 165 166 167 + 168 169 170 171 172 173 174 175 + 176 177 178 179 180 181 182 183 + 184 185 186 187 188 189 190 191 + 192 193 194 195 196 197 198 199 + 200 201 202 203 204 205 206 207 + 208 209 210 211 212 213 214 215 + 216 217 218 219 220 221 222 223 + 224 225 226 227 228 229 230 231 + 232 233 234 235 236 237 238 239 + 240 241 242 243 244 245 246 247 + 248 249 250 251 252 253 254 255>; + default-brightness-level = <200>; + }; + + clkin_gmac: external-gmac-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "clkin_gmac"; + #clock-cells = <0>; + }; + + dc_12v: dc-12v { + compatible = "regulator-fixed"; + regulator-name = "dc_12v"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + + gpio-keys { + compatible = "gpio-keys"; + autorepeat; + pinctrl-names = "default"; + pinctrl-0 = <&pwrbtn>; + + key-power { + debounce-interval = <100>; + gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; + label = "GPIO Key Power"; + linux,code = <KEY_POWER>; + wakeup-source; + }; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&work_led_pin>, <&user_led_pin>, + <&heartbeat_led_pin>, <&wlan_active_led_pin>, + <&bt_active_led_pin>; + + work_led: led-0 { + label = "blue:work"; + default-state = "on"; + gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>; + }; + + user_led: led-1 { + label = "read:user"; + default-state = "off"; + gpios = <&gpio0 RK_PB4 GPIO_ACTIVE_HIGH>; + }; + + heartbeat_led: led-2 { + label = "green:heartbeat"; + linux,default-trigger = "heartbeat"; + gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>; + }; + + wlan_active_led: led-3 { + label = "yellow:wlan"; + gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "phy0tx"; + default-state = "off"; + }; + + bt_active_led: led-4 { + label = "blue:bt"; + gpios = <&gpio2 RK_PD4 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "hci0-power"; + default-state = "off"; + }; + }; + + rt5651-sound { + compatible = "simple-audio-card"; + simple-audio-card,name = "realtek,rt5651-codec"; + simple-audio-card,format = "i2s"; + simple-audio-card,mclk-fs = <256>; + simple-audio-card,widgets = + "Microphone", "Mic Jack", + "Headphone", "Headphone Jack"; + simple-audio-card,routing = + "Mic Jack", "MICBIAS1", + "IN1P", "Mic Jack", + "Headphone Jack", "HPOL", + "Headphone Jack", "HPOR"; + simple-audio-card,cpu { + sound-dai = <&i2s1>; + }; + simple-audio-card,codec { + sound-dai = <&rt5651>; + }; + }; + + sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rk808 1>; + clock-names = "ext_clock"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_enable_h>; + + /* + * On the module itself this is one of these (depending + * on the actual card populated): + * - SDIO_RESET_L_WL_REG_ON + * - PDN (power down when low) + */ + reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; + }; + + /* switched by pmic_sleep */ + vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 { + compatible = "regulator-fixed"; + regulator-name = "vcc1v8_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_1v8>; + }; + + vcc3v3_sys: vcc3v3-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&dc_12v>; + }; + + vcc5v0_sys: vcc5v0-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&dc_12v>; + }; + + /* For USB3.0 Port1/2 */ + vcc5v0_host1: vcc5v0-host1-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_host1_en>; + regulator-name = "vcc5v0_host1"; + regulator-always-on; + vin-supply = <&vcc5v0_sys>; + }; + + /* For USB2.0 Port1/2 */ + vcc5v0_host3: vcc5v0-host3-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PB0 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_host3_en>; + regulator-name = "vcc5v0_host3"; + regulator-always-on; + vin-supply = <&vcc5v0_sys>; + }; + + vcc5v0_typec: vcc5v0-typec-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio4 RK_PC5 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_typec_en>; + regulator-name = "vcc5v0_typec"; + regulator-always-on; + vin-supply = <&vcc3v3_sys>; + }; + + vdd_log: vdd-log { + compatible = "regulator-fixed"; + regulator-name = "vdd_log"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + }; +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l1 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l2 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l3 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_b0 { + cpu-supply = <&vdd_cpu_b>; +}; + +&cpu_b1 { + cpu-supply = <&vdd_cpu_b>; +}; + +&emmc_phy { + status = "okay"; +}; + +&gmac { + assigned-clocks = <&cru SCLK_RMII_SRC>; + assigned-clock-parents = <&clkin_gmac>; + clock_in_out = "input"; + phy-supply = <&vcc_lan>; + phy-mode = "rgmii"; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 50000>; + tx_delay = <0x28>; + rx_delay = <0x11>; + status = "okay"; +}; + +&gpu { + mali-supply = <&vdd_gpu>; + status = "okay"; +}; + +&hdmi { + ddc-i2c-bus = <&i2c3>; + pinctrl-names = "default"; + pinctrl-0 = <&hdmi_cec>; + status = "okay"; +}; + +&i2c0 { + status = "okay"; + + rk808: pmic@1b { + compatible = "rockchip,rk808"; + reg = <0x1b>; + interrupt-parent = <&gpio1>; + interrupts = <21 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + #clock-cells = <1>; + clock-output-names = "xin32k", "rk808-clkout2"; + + vcc1-supply = <&vcc3v3_sys>; + vcc2-supply = <&vcc3v3_sys>; + vcc3-supply = <&vcc3v3_sys>; + vcc4-supply = <&vcc3v3_sys>; + vcc6-supply = <&vcc3v3_sys>; + vcc7-supply = <&vcc3v3_sys>; + vcc8-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc3v3_sys>; + vcc10-supply = <&vcc3v3_sys>; + vcc11-supply = <&vcc3v3_sys>; + vcc12-supply = <&vcc3v3_sys>; + vddio-supply = <&vcc_3v0>; + + regulators { + vdd_center: DCDC_REG1 { + regulator-name = "vdd_center"; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_l: DCDC_REG2 { + regulator-name = "vdd_cpu_l"; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_1v8: DCDC_REG4 { + regulator-name = "vcc_1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc1v8_dvp: LDO_REG1 { + regulator-name = "vcc1v8_dvp"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc2v8_dvp: LDO_REG2 { + regulator-name = "vcc2v8_dvp"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc1v8_pmu: LDO_REG3 { + regulator-name = "vcc1v8_pmu"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_sdio: LDO_REG4 { + regulator-name = "vcc_sdio"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3000000>; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcca3v0_codec: LDO_REG5 { + regulator-name = "vcca3v0_codec"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v5: LDO_REG6 { + regulator-name = "vcc_1v5"; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1500000>; + }; + }; + + vcca1v8_codec: LDO_REG7 { + regulator-name = "vcca1v8_codec"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v0: LDO_REG8 { + regulator-name = "vcc_3v0"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcc3v3_s3: vcc_lan: SWITCH_REG1 { + regulator-name = "vcc3v3_s3"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_s0: SWITCH_REG2 { + regulator-name = "vcc3v3_s0"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; + + vdd_cpu_b: regulator@40 { + compatible = "silergy,syr827"; + reg = <0x40>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_b"; + pinctrl-names = "default"; + pinctrl-0 = <&vsel1_pin>; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc3v3_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: regulator@41 { + compatible = "silergy,syr828"; + reg = <0x41>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_gpu"; + pinctrl-names = "default"; + pinctrl-0 = <&vsel2_pin>; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc3v3_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2c1 { + i2c-scl-rising-time-ns = <300>; + i2c-scl-falling-time-ns = <15>; + status = "okay"; + + rt5651: audio-codec@1a { + compatible = "rockchip,rt5651"; + reg = <0x1a>; + clocks = <&cru SCLK_I2S_8CH_OUT>; + clock-names = "mclk"; + hp-det-gpio = <&gpio4 RK_PD4 GPIO_ACTIVE_LOW>; + spk-con-gpio = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>; + #sound-dai-cells = <0>; + }; + +}; + +&i2c3 { + i2c-scl-rising-time-ns = <450>; + i2c-scl-falling-time-ns = <15>; + status = "okay"; +}; + +&i2c4 { + i2c-scl-rising-time-ns = <600>; + i2c-scl-falling-time-ns = <20>; + status = "okay"; + + fusb0: typec-portc@22 { + compatible = "fcs,fusb302"; + reg = <0x22>; + interrupt-parent = <&gpio1>; + interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&fusb0_int>; + vbus-supply = <&vcc5v0_typec>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + usbc0_role_sw: endpoint@0 { + remote-endpoint = <&dwc3_0_role_switch>; + }; + }; + }; + + connector { + compatible = "usb-c-connector"; + data-role = "dual"; + label = "USB-C"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + usbc_hs: endpoint { + remote-endpoint = <&u2phy0_typec_hs>; + }; + }; + + port@1 { + reg = <1>; + + usbc_ss: endpoint { + remote-endpoint = <&tcphy0_typec_ss>; + }; + }; + }; + }; + }; +}; + +&i2s1 { + rockchip,playback-channels = <2>; + rockchip,capture-channels = <2>; + status = "okay"; +}; + +&i2s2 { + status = "okay"; +}; + +&io_domains { + status = "okay"; + + audio-supply = <&vcca1v8_codec>; + bt656-supply = <&vcc_3v0>; + gpio1830-supply = <&vcc_3v0>; + sdmmc-supply = <&vcc_sdio>; +}; + +&pmu_io_domains { + status = "okay"; + + pmu1830-supply = <&vcc_3v0>; +}; + +&pinctrl { + buttons { + pwrbtn: pwrbtn { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + bt { + bt_enable_h: bt-enable-h { + rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + bt_host_wake_l: bt-host-wake-l { + rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + bt_wake_l: bt-wake-l { + rockchip,pins = <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + fusb302x { + fusb0_int: fusb0-int { + rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + lcd-panel { + lcd_panel_reset: lcd-panel-reset { + rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + leds { + work_led_pin: work-led-pin { + rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + user_led_pin: user-led-pin { + rockchip,pins = <0 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + heartbeat_led_pin: heartbeat-led-pin { + rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + wlan_active_led_pin: wlan-led-pin { + rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + bt_active_led_pin: bt-led-pin { + rockchip,pins = <2 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + + }; + + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + vsel1_pin: vsel1-pin { + rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + vsel2_pin: vsel2-pin { + rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; + }; + }; + + rt5651 { + rt5651_hpcon: rt5640-hpcon { + rockchip,pins = <4 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + sdio-pwrseq { + wifi_enable_h: wifi-enable-h { + rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb-typec { + vcc5v0_typec_en: vcc5v0_typec_en { + rockchip,pins = <4 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + usb2 { + vcc5v0_host3_en: vcc5v0-host3-en { + rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + vcc5v0_host1_en: vcc5v0-host1-en { + rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + wifi { + wifi_host_wake_l: wifi-host-wake-l { + rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pwm0 { + status = "okay"; +}; + +&saradc { + vref-supply = <&vcca1v8_s3>; + status = "okay"; +}; + +&sdio0 { + /* WiFi & BT combo module AMPAK AP6255 */ + #address-cells = <1>; + #size-cells = <0>; + bus-width = <4>; + clock-frequency = <50000000>; + cap-sdio-irq; + cap-sd-highspeed; + keep-power-in-suspend; + mmc-pwrseq = <&sdio_pwrseq>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; + sd-uhs-sdr104; + status = "okay"; + + brcmf: wifi@1 { + compatible = "brcm,bcm4329-fmac"; + reg = <1>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PA3 GPIO_ACTIVE_HIGH>; + interrupt-names = "host-wake"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_host_wake_l>; + }; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; + disable-wp; + max-frequency = <150000000>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>; + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + non-removable; + status = "okay"; +}; + +&tcphy0 { + status = "okay"; +}; + +&tcphy0_usb3 { + orientation-switch; + port { + tcphy0_typec_ss: endpoint { + remote-endpoint = <&usbc_ss>; + }; + }; +}; + +&tcphy1 { + status = "okay"; +}; + +&tsadc { + /* tshut mode 0:CRU 1:GPIO */ + rockchip,hw-tshut-mode = <1>; + /* tshut polarity 0:LOW 1:HIGH */ + rockchip,hw-tshut-polarity = <1>; + status = "okay"; +}; + +&u2phy0 { + status = "okay"; + + u2phy0_otg: otg-port { + status = "okay"; + }; + + u2phy0_host: host-port { + phy-supply = <&vcc5v0_host3>; + status = "okay"; + }; + + port { + u2phy0_typec_hs: endpoint { + remote-endpoint = <&usbc_hs>; + }; + }; +}; + +&u2phy1 { + status = "okay"; + + u2phy1_otg: otg-port { + status = "okay"; + }; + + u2phy1_host: host-port { + phy-supply = <&vcc5v0_host3>; + status = "okay"; + }; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; + status = "okay"; + + bluetooth { + compatible = "brcm,bcm4345c5"; + clocks = <&rk808 1>; + clock-names = "lpo"; + device-wakeup-gpios = <&gpio2 RK_PD2 GPIO_ACTIVE_HIGH>; + host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>; + shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>; + max-speed = <1500000>; + pinctrl-names = "default"; + pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_enable_h>; + vbat-supply = <&vcc3v3_sys>; + vddio-supply = <&vcc_1v8>; + }; +}; + +&uart2 { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +&usbdrd3_0 { + status = "okay"; +}; + +&usbdrd_dwc3_0 { + status = "okay"; + usb-role-switch; + + port { + #address-cells = <1>; + #size-cells = <0>; + dwc3_0_role_switch: endpoint@0 { + reg = <0>; + remote-endpoint = <&usbc0_role_sw>; + }; + }; +}; + +&usbdrd3_1 { + status = "okay"; +}; + +&usbdrd_dwc3_1 { + status = "okay"; + dr_mode = "host"; +}; + +&vopb { + status = "okay"; +}; + +&vopb_mmu { + status = "okay"; +}; + +&vopl { + status = "okay"; +}; + +&vopl_mmu { + status = "okay"; +}; diff --git a/board/rockchip/evb_rk3399/MAINTAINERS b/board/rockchip/evb_rk3399/MAINTAINERS index 25e308d186..5be58f80f9 100644 --- a/board/rockchip/evb_rk3399/MAINTAINERS +++ b/board/rockchip/evb_rk3399/MAINTAINERS @@ -6,6 +6,12 @@ F: include/configs/evb_rk3399.h F: configs/evb-rk3399_defconfig F: configs/firefly-rk3399_defconfig
+EAIDK-610 +M: Andy Yan andy.yan@rock-chips.com +S: Maintained +F: configs/eaidk-610-rk3399_defconfig +F: arch/arm/dts/rk3399-eaidk-610-u-boot.dtsi + KHADAS-EDGE M: Nick Xie nick@khadas.com S: Maintained diff --git a/configs/eaidk-610-rk3399_defconfig b/configs/eaidk-610-rk3399_defconfig new file mode 100644 index 0000000000..b41a66fe53 --- /dev/null +++ b/configs/eaidk-610-rk3399_defconfig @@ -0,0 +1,61 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_OFFSET=0x3F8000 +CONFIG_DEFAULT_DEVICE_TREE="rk3399-eaidk-610" +CONFIG_ROCKCHIP_RK3399=y +CONFIG_TARGET_EVB_RK3399=y +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0x800800 +CONFIG_DEBUG_UART=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x300000 +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-eaidk-610.dtb" +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x400000 +CONFIG_SPL_BSS_MAX_SIZE=0x2000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK=0x400000 +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 +CONFIG_TPL=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_ERRNO_STR=y
On 2022/9/18 19:30, andyshrk@163.com wrote:
Specification
- Rockchip RK3399
- LPDDR3 4GB
- TF sd scard slot
- eMMC
- Gigabit ethernet
- HDMI out
- 40 pin header
- USB 2.0 x 2
- USB 3.0 x 1
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- rk3399-eaidk-610.dtb \ rk3399-ficus.dtb \ rk3399-firefly.dtb \ rk3399-gru-bob.dtb \
- Copyright (c) 2022 Andy Yan andy.yan@gmail.com
- chosen {
+&vdd_log {
- regulator-init-microvolt = <950000>;
- Copyright (c) 2022 Fuzhou Rockchip Electronics Co., Ltd.
- model = "OPEN AI LAB EAIDK-610";
- compatible = "openailab,eaidk-610", "rockchip,rk3399";
- aliases {
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
- backlight: backlight {
0 1 2 3 4 5 6 7
- clkin_gmac: external-gmac-clock {
#clock-cells = <0>;
- dc_12v: dc-12v {
regulator-boot-on;
- gpio-keys {
autorepeat;
key-power {
wakeup-source;
- leds {
work_led: led-0 {
user_led: led-1 {
label = "blue:bt";
- rt5651-sound {
"IN1P", "Mic Jack",
- sdio_pwrseq: sdio-pwrseq {
- /* switched by pmic_sleep */
- vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 {
regulator-boot-on;
- vcc3v3_sys: vcc3v3-sys {
regulator-boot-on;
- vcc5v0_sys: vcc5v0-sys {
regulator-boot-on;
- /* For USB3.0 Port1/2 */
- vcc5v0_host1: vcc5v0-host1-regulator {
enable-active-high;
- /* For USB2.0 Port1/2 */
- vcc5v0_host3: vcc5v0-host3-regulator {
enable-active-high;
- vcc5v0_typec: vcc5v0-typec-regulator {
enable-active-high;
- vdd_log: vdd-log {
regulator-boot-on;
+&cpu_l0 {
- cpu-supply = <&vdd_cpu_l>;
+&cpu_l1 {
+&cpu_l2 {
+&cpu_l3 {
+&cpu_b0 {
- cpu-supply = <&vdd_cpu_b>;
+&cpu_b1 {
+&emmc_phy {
- status = "okay";
+&gmac {
- assigned-clocks = <&cru SCLK_RMII_SRC>;
- assigned-clock-parents = <&clkin_gmac>;
- clock_in_out = "input";
- phy-supply = <&vcc_lan>;
- phy-mode = "rgmii";
- pinctrl-names = "default";
- pinctrl-0 = <&rgmii_pins>;
- snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>;
- snps,reset-active-low;
- snps,reset-delays-us = <0 10000 50000>;
- tx_delay = <0x28>;
- rx_delay = <0x11>;
- status = "okay";
+&gpu {
- mali-supply = <&vdd_gpu>;
- status = "okay";
+&hdmi {
- ddc-i2c-bus = <&i2c3>;
- pinctrl-0 = <&hdmi_cec>;
- status = "okay";
+&i2c0 {
- status = "okay";
- rk808: pmic@1b {
reg = <0x1b>;
wakeup-source;
#clock-cells = <1>;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v5: LDO_REG6 {
regulator-boot-on;
regulator-boot-on;
vcc_3v0: LDO_REG8 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
- vdd_cpu_b: regulator@40 {
reg = <0x40>;
regulator-boot-on;
- vdd_gpu: regulator@41 {
reg = <0x41>;
regulator-boot-on;
+&i2c1 {
- i2c-scl-rising-time-ns = <300>;
- i2c-scl-falling-time-ns = <15>;
- status = "okay";
- rt5651: audio-codec@1a {
reg = <0x1a>;
+&i2c3 {
- i2c-scl-rising-time-ns = <450>;
- status = "okay";
+&i2c4 {
- i2c-scl-rising-time-ns = <600>;
- i2c-scl-falling-time-ns = <20>;
- status = "okay";
- fusb0: typec-portc@22 {
reg = <0x22>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
connector {
data-role = "dual";
label = "USB-C";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
usbc_hs: endpoint {
port@1 {
reg = <1>;
usbc_ss: endpoint {
+&i2s1 {
- rockchip,playback-channels = <2>;
- rockchip,capture-channels = <2>;
- status = "okay";
+&i2s2 {
- status = "okay";
+&io_domains {
- status = "okay";
- audio-supply = <&vcca1v8_codec>;
- bt656-supply = <&vcc_3v0>;
- gpio1830-supply = <&vcc_3v0>;
- sdmmc-supply = <&vcc_sdio>;
+&pmu_io_domains {
- status = "okay";
- pmu1830-supply = <&vcc_3v0>;
+&pinctrl {
- buttons {
pwrbtn: pwrbtn {
- bt {
- fusb302x {
- lcd-panel {
- leds {
- pmic {
- rt5651 {
- sdio-pwrseq {
- usb-typec {
- usb2 {
- wifi {
+&pwm0 {
- status = "okay";
+&saradc {
- vref-supply = <&vcca1v8_s3>;
- status = "okay";
+&sdio0 {
- /* WiFi & BT combo module AMPAK AP6255 */
- #address-cells = <1>;
- #size-cells = <0>;
- bus-width = <4>;
- clock-frequency = <50000000>;
- cap-sdio-irq;
- cap-sd-highspeed;
- keep-power-in-suspend;
- mmc-pwrseq = <&sdio_pwrseq>;
- non-removable;
- pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>;
- sd-uhs-sdr104;
- status = "okay";
- brcmf: wifi@1 {
reg = <1>;
+&sdmmc {
- bus-width = <4>;
- cap-mmc-highspeed;
- cap-sd-highspeed;
- cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>;
- disable-wp;
- max-frequency = <150000000>;
- pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>;
- status = "okay";
+&sdhci {
- bus-width = <8>;
- non-removable;
- status = "okay";
+&tcphy0 {
- status = "okay";
+&tcphy0_usb3 {
- orientation-switch;
- port {
+&tcphy1 {
- status = "okay";
+&tsadc {
- /* tshut mode 0:CRU 1:GPIO */
- rockchip,hw-tshut-mode = <1>;
- /* tshut polarity 0:LOW 1:HIGH */
- rockchip,hw-tshut-polarity = <1>;
- status = "okay";
+&u2phy0 {
- status = "okay";
- u2phy0_otg: otg-port {
status = "okay";
- u2phy0_host: host-port {
status = "okay";
- port {
+&u2phy1 {
- status = "okay";
- u2phy1_otg: otg-port {
status = "okay";
- u2phy1_host: host-port {
status = "okay";
+&uart0 {
- pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>;
- status = "okay";
- bluetooth {
+&uart2 {
- status = "okay";
+&usb_host0_ehci {
- status = "okay";
+&usb_host0_ohci {
- status = "okay";
+&usb_host1_ehci {
- status = "okay";
+&usb_host1_ohci {
- status = "okay";
+&usbdrd3_0 {
- status = "okay";
+&usbdrd_dwc3_0 {
- status = "okay";
- usb-role-switch;
- port {
#size-cells = <0>;
reg = <0>;
+&usbdrd3_1 {
- status = "okay";
+&usbdrd_dwc3_1 {
- status = "okay";
- dr_mode = "host";
+&vopb {
- status = "okay";
+&vopb_mmu {
- status = "okay";
+&vopl {
- status = "okay";
+&vopl_mmu {
- status = "okay";
- KHADAS-EDGE M: Nick Xie nick@khadas.com S: Maintained
andyshrk@163.com
Kever Yang
