[U-Boot] [PATCH 1/2] gpio: Add DW APB GPIO driver
Add driver for the DesignWare APB GPIO IP block. This driver is DM capable and probes from DT.
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org --- drivers/gpio/Makefile | 1 + drivers/gpio/dwapb_gpio.c | 167 ++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 168 insertions(+) create mode 100644 drivers/gpio/dwapb_gpio.c
diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 67c6374..603c96b 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -6,6 +6,7 @@ #
ifndef CONFIG_SPL_BUILD +obj-$(CONFIG_DWAPB_GPIO) += dwapb_gpio.o obj-$(CONFIG_AXP_GPIO) += axp_gpio.o endif obj-$(CONFIG_DM_GPIO) += gpio-uclass.o diff --git a/drivers/gpio/dwapb_gpio.c b/drivers/gpio/dwapb_gpio.c new file mode 100644 index 0000000..cdb6e78 --- /dev/null +++ b/drivers/gpio/dwapb_gpio.c @@ -0,0 +1,167 @@ +/* + * (C) Copyright 2015 Marek Vasut marex@denx.de + * + * DesignWare APB GPIO driver + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <malloc.h> +#include <asm/arch/gpio.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/lists.h> +#include <dm/root.h> +#include <errno.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define GPIO_SWPORTA_DR 0x00 +#define GPIO_SWPORTA_DDR 0x04 +#define GPIO_INTEN 0x30 +#define GPIO_INTMASK 0x34 +#define GPIO_INTTYPE_LEVEL 0x38 +#define GPIO_INT_POLARITY 0x3c +#define GPIO_INTSTATUS 0x40 +#define GPIO_PORTA_DEBOUNCE 0x48 +#define GPIO_PORTA_EOI 0x4c +#define GPIO_EXT_PORTA 0x50 + +struct gpio_dwapb_platdata { + char name[24]; + int bank; + int pins; + fdt_addr_t base; +}; + +static int dwapb_gpio_direction_input(struct udevice *dev, unsigned pin) +{ + struct gpio_dwapb_platdata *plat = dev_get_platdata(dev); + clrbits_le32(plat->base + GPIO_SWPORTA_DDR, 1 << pin); + return 0; +} + +static int dwapb_gpio_direction_output(struct udevice *dev, unsigned pin, + int val) +{ + struct gpio_dwapb_platdata *plat = dev_get_platdata(dev); + + setbits_le32(plat->base + GPIO_SWPORTA_DDR, 1 << pin); + + if (val) + setbits_le32(plat->base + GPIO_SWPORTA_DR, 1 << pin); + else + clrbits_le32(plat->base + GPIO_SWPORTA_DR, 1 << pin); + + return 0; +} + +static int dwapb_gpio_get_value(struct udevice *dev, unsigned pin) +{ + struct gpio_dwapb_platdata *plat = dev_get_platdata(dev); + return !!(readl(plat->base + GPIO_EXT_PORTA) & (1 << pin)); +} + + +static int dwapb_gpio_set_value(struct udevice *dev, unsigned pin, int val) +{ + struct gpio_dwapb_platdata *plat = dev_get_platdata(dev); + + if (val) + setbits_le32(plat->base + GPIO_SWPORTA_DR, 1 << pin); + else + clrbits_le32(plat->base + GPIO_SWPORTA_DR, 1 << pin); + + return 0; +} + +static const struct dm_gpio_ops gpio_dwapb_ops = { + .direction_input = dwapb_gpio_direction_input, + .direction_output = dwapb_gpio_direction_output, + .get_value = dwapb_gpio_get_value, + .set_value = dwapb_gpio_set_value, +}; + +static int gpio_dwapb_probe(struct udevice *dev) +{ + struct gpio_dev_priv *priv = dev_get_uclass_priv(dev); + struct gpio_dwapb_platdata *plat = dev->platdata; + + if (!plat) + return 0; + + priv->gpio_count = plat->pins; + priv->bank_name = plat->name; + + return 0; +} + +static int gpio_dwapb_bind(struct udevice *dev) +{ + struct gpio_dwapb_platdata *plat = dev_get_platdata(dev); + const void *blob = gd->fdt_blob; + struct udevice *subdev; + fdt_addr_t base; + int node, bank = 0; + const char *name; + + /* If this is a child device, there is nothing to do here */ + if (plat) + return 0; + + base = fdtdec_get_addr(blob, dev->of_offset, "reg"); + if (base == FDT_ADDR_T_NONE) { + debug("Can't get the GPIO register base address\n"); + return -ENXIO; + } + + name = fdt_get_name(blob, dev->of_offset, NULL); + + for (node = fdt_first_subnode(blob, dev->of_offset); + node > 0; + node = fdt_next_subnode(blob, node)) { + int ret; + + if (!fdtdec_get_bool(blob, node, "gpio-controller")) + continue; + + plat = NULL; + plat = calloc(1, sizeof(*plat)); + if (!plat) + return -ENOMEM; + + plat->base = base; + plat->bank = bank; + plat->pins = fdtdec_get_int(blob, node, "snps,nr-gpios", 0); + snprintf(plat->name, sizeof(plat->name) - 1, "%s-bank%i-", + name, bank); + + ret = device_bind(dev, dev->driver, plat->name, + plat, -1, &subdev); + if (ret) + return ret; + + subdev->of_offset = node; + bank++; + } + + + return 0; +} + +static const struct udevice_id gpio_dwapb_ids[] = { + { .compatible = "snps,dw-apb-gpio" }, + { } +}; + +U_BOOT_DRIVER(gpio_dwapb) = { + .name = "gpio-dwapb", + .id = UCLASS_GPIO, + .of_match = gpio_dwapb_ids, + .ops = &gpio_dwapb_ops, + .bind = gpio_dwapb_bind, + .probe = gpio_dwapb_probe, +};
Enable the DWAPB GPIO driver for SoCFPGA Cyclone V and Arria V.
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Cc: Dinh Nguyen dinguyen@opensource.altera.com --- include/configs/socfpga_arria5.h | 2 +- include/configs/socfpga_common.h | 6 ++++++ include/configs/socfpga_cyclone5.h | 2 +- 3 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/include/configs/socfpga_arria5.h b/include/configs/socfpga_arria5.h index 7aee1ce..5a4417f 100644 --- a/include/configs/socfpga_arria5.h +++ b/include/configs/socfpga_arria5.h @@ -26,6 +26,7 @@ #define CONFIG_CMD_EXT4_WRITE #define CONFIG_CMD_FAT #define CONFIG_CMD_FS_GENERIC +#define CONFIG_CMD_GPIO #define CONFIG_CMD_GREPENV #define CONFIG_CMD_MII #define CONFIG_CMD_MMC @@ -33,7 +34,6 @@ #define CONFIG_CMD_USB #define CONFIG_CMD_USB_MASS_STORAGE
- /* Memory configurations */ #define PHYS_SDRAM_1_SIZE 0x40000000 /* 1GiB on SoCDK */
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index e8473b8..0298360 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -114,6 +114,12 @@ #endif
/* + * GPIO Driver + */ +#define CONFIG_DM_GPIO +#define CONFIG_DWAPB_GPIO + +/* * L4 OSC1 Timer 0 */ /* This timer uses eosc1, whose clock frequency is fixed at any condition. */ diff --git a/include/configs/socfpga_cyclone5.h b/include/configs/socfpga_cyclone5.h index 33d04fd..9a9c85a 100644 --- a/include/configs/socfpga_cyclone5.h +++ b/include/configs/socfpga_cyclone5.h @@ -26,6 +26,7 @@ #define CONFIG_CMD_EXT4_WRITE #define CONFIG_CMD_FAT #define CONFIG_CMD_FS_GENERIC +#define CONFIG_CMD_GPIO #define CONFIG_CMD_GREPENV #define CONFIG_CMD_MII #define CONFIG_CMD_MMC @@ -33,7 +34,6 @@ #define CONFIG_CMD_USB #define CONFIG_CMD_USB_MASS_STORAGE
Hi Marek,
- GPIO Driver
Should use Kconfig.
- L4 OSC1 Timer 0
-- 2.1.4
Hi Marek,
- (C) Copyright 2015 Marek Vasut marex@denx.de
- DesignWare APB GPIO driver
Should use C structure, right?
char name[24];
int bank;
int pins;
fdt_addr_t base;
blank line after declarations
int val)
if (val)
else
if (val)
else
Do you want to implement .function?
if (!plat)
fdt_addr_t base;
int node, bank = 0;
const char *name;
if (plat)
return -ENXIO;
node > 0;
int ret;
continue;
plat = NULL;
I suppose this should use devm_alloc() now.
if (!plat)
return -ENOMEM;
plat->base = base;
plat->bank = bank;
name, bank);
Why such a long name? That's going to be a pain to type in the 'gpio' command.
plat, -1, &subdev);
if (ret)
return ret;
bank++;
.id = UCLASS_GPIO,
2.1.4
On Sunday, August 02, 2015 at 11:28:13 PM, Simon Glass wrote:
Hi Marek,
My understanding is that we no longer want C structs . Tom ?
No, the pinmuxing on SoCFPGA is still in a weird state.
if (!plat)
fdt_addr_t base;
int node, bank = 0;
const char *name;
if (plat)
return -ENXIO;
node > 0;
int ret;
continue;
plat = NULL;
Is that even in u-boot/master ? Also, I'm not sure it's a good idea to put this in if I use this driver in SPL.
if (!plat)
return -ENOMEM;
plat->base = base;
plat->bank = bank;
Do you have a suggestion please ?
Also, I can as well use "gpio <operation> N" , where N is a number.
plat, -1, &subdev);
if (ret)
return ret;
bank++;
.id = UCLASS_GPIO,
2.1.4
Hi Marek,
Hi Marek,
if (!plat)
fdt_addr_t base;
int node, bank = 0;
const char *name;
if (plat)
return -ENXIO;
node > 0;
int ret;
continue;
plat = NULL;
Yes it's very new. Only in dm/master.
It's only compiled in when enabled, so you can still use it in SPL.
Up to you. At some point I think we should convert all driver allocs to use devm so that we know what allocation is going on.
if (!plat)
return -ENOMEM;
plat->base = base;
plat->bank = bank;
A, B, C is good if you have <=26 banks. Tegra does that.
Exynos does PA0, PA1, PB0, PC0, PC1, etc.
plat, -1, &subdev);
if (ret)
return ret;
bank++;
.id = UCLASS_GPIO,
2.1.4
On Monday, August 03, 2015 at 01:38:28 AM, Simon Glass wrote:
Hi Marek,
Hi Simon,
continue;
plat = NULL;
When is this landing in master ? I don't mind either way, but I can do a linting pass on the socfpga when things settle down too.
if (!plat)
return -ENOMEM;
plat->base = base;
plat->bank = bank;
How do I identify which one is PA0/PA1/PA2 , shall I perform some transformation on the register address of the GPIO block or example ? But how can I assure that if the next SoCFPGA has these addresses completely different, these GPIO numbers will be stable ? Isn't it better to be explicit about the GPIO block ID then ?
Also, remember that I have an FPGA in the same package, which has a lot of I/O.
What about this ? How does indexing the GPIOs with plain number fit into the picture please ?
Hi Marek,
Hi Marek,
Hi Simon,
continue;
plat = NULL;
Hopefully I'll have a pull request out on Friday.
if (!plat)
return -ENOMEM;
plat->base = base;
plat->bank = bank;
It's up to you. Normally each bank has a name and the datasheet specifies it. In your case if not you could think about a naming scheme.
Driver model GPIO handles this automatically. If you can add different numbers of GPIO blocks you might consider adding them as different GPIO banks with their own names. The global number depends on the probe order which depends on the bind order (i.e. device tree node order). But names are safer than numbers - a small change can change all the numbers. There is a function to get the global number given a GPIO device and offset.
On Wednesday, August 05, 2015 at 04:39:33 PM, Simon Glass wrote:
Hi Marek,
Hi Simon,
Hi Marek,
Hi Simon,
plat = NULL;
Cool!
if (!plat)
return -ENOMEM;
plat->base = base;
plat->bank = bank;
Can you please take a look into arch/arm/dts/socfpga.dtsi ? The system has three GPIO controllers (look for gpio0, gpio1, gpio2) and each of these controllers has one bank (porta, portb, portc) .
I can name my gpios portxN , where x is either of a,b,c and N is the GPIO number. The problem is, I cannot determine in dwapb_gpio_bind() which one is "porta", "portb" and "portc" because all I have is the physical addess of the GPIO controller and the index of the bank in the namespace of that controller.
Sure, I can do some sort of global counting in the driver, but I would like to avoid that sort of thing. I can also add some kind of ad-hoc DT prop, but that's also not a good idea I think. Do you have any suggestion for me please ?
I see, thanks for clarifying!
Hi Marek,
Hi Marek,
Hi Simon,
Hi Marek,
Hi Simon,
> + if (!fdtdec_get_bool(blob, node, > "gpio-controller")) + continue; > + > + plat = NULL; > + plat = calloc(1, sizeof(*plat));
Cool!
> + if (!plat) > + return -ENOMEM; > + > + plat->base = base; > + plat->bank = bank; > + plat->pins = fdtdec_get_int(blob, node, > "snps,nr-gpios", 0); + snprintf(plat->name, > sizeof(plat->name) - 1, "%s-bank%i-", + > name, bank);
One option is to use the device tree node name but it isn't very friendly - gpio0@xxxxx. You could perhaps add a new property like 'bank-name'?
On Friday, August 07, 2015 at 09:13:45 PM, Simon Glass wrote:
Hi Marek,
Hi!
Hi Marek,
Hi Simon,
That's what I do now pretty much.
Do we want to add ad-hoc DT nodes which are a) Not describing hardware b) Not part of the official DT bindings for that platform ?
Is that really a way to go ?
Best regards, Marek Vasut
Hi Marek,
Hi Marek,
Hi!
Hi Marek,
Hi Simon,
It needs to be part of the official binding. Naming the hardware is part of the hardware definition - see for example the regulator-name property for regulators.
Another option is to use an alias:
aliases { gpio0 = &gpio_0; gpio1 = &gpio_1; gpio2 = &gpio_2; }
Then you can turn gpio0 into bank A, gpio1 into bank B, etc.
On Friday, August 07, 2015 at 10:37:54 PM, Simon Glass wrote:
Hi Marek,
Hi Simon,
Hi Marek,
Hi!
Hi Marek,
Hi Simon,
So what do you think about introducing a 'bank-name' property then ? I think this might work just fine ?
Is there a function which maps the udevice->dev->of_offset into an alias's seq ID ?
Hi Marek,
Hi Marek,
Hi Simon,
Hi Marek,
Hi!
Hi Marek,
Hi Simon,
I think it's OK - just make sure you send the GPIO binding change to Linux too.
dev->seq, once it is probed. Until it is probed it doesn't have a sequence number (by definition).
You can use fdtdec_get_alias_seq() but I don't recommend it. We're trying to drop fdtdec eventually.
On Monday, August 10, 2015 at 05:35:25 PM, Simon Glass wrote:
Hi Marek,
Hi Marek,
Hi Simon,
Hi Marek,
Hi!
On Wednesday, August 05, 2015 at 04:39:33 PM, Simon Glass wrote: > Hi Marek,
Hi Simon,
> It's up to you. Normally each bank has a name and the datasheet > specifies it. In your case if not you could think about a naming > scheme.
aliases {
OK. I sent a V2, so that should be OK now.
