[U-Boot] [PATCH] exynos: Set CNTFRQ
Commit 73a1cb27 moved the check whether we should set the architected timer frequency from CONFIG_SYS_CLK_FREQ to CONFIG_TIMER_CLK_FREQ, but did not update all users of it.
The one where I (finally) realized why KVM didn't work is the Arndale board, so this patch adds the respective define to it.
Signed-off-by: Alexander Graf agraf@suse.de Fixes: 73a1cb27 --- include/configs/exynos-common.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/exynos-common.h b/include/configs/exynos-common.h index 852829c..c4e731f 100644 --- a/include/configs/exynos-common.h +++ b/include/configs/exynos-common.h @@ -31,6 +31,7 @@
/* input clock of PLL: 24MHz input clock */ #define CONFIG_SYS_CLK_FREQ 24000000 +#define CONFIG_TIMER_CLK_FREQ 24000000
#define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_CMDLINE_TAG
+Minkyu
2.6.2
Dear Alexander Graf,
patch looks good but, Please make sure that it doesn't have a different value with system clock, always. (If you expected it)
#define CONFIG_TIMER_CLK_FREQ CONFIG_SYS_CLK_FREQ
Thanks, Minkyu Kang.
v1 -> v2:
- Map to CONFIG_SYS_CLK_FREQ instead of redefining to the same number --- include/configs/exynos-common.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/exynos-common.h b/include/configs/exynos-common.h index 852829c..b61f889 100644 --- a/include/configs/exynos-common.h +++ b/include/configs/exynos-common.h @@ -31,6 +31,7 @@
/* input clock of PLL: 24MHz input clock */ #define CONFIG_SYS_CLK_FREQ 24000000 +#define CONFIG_TIMER_CLK_FREQ CONFIG_SYS_CLK_FREQ
v1 -> v2:
This makes sense.
Xiubo,
Can you take another look to make sure nothing else is missed?
York
v1 -> v2:
Reviewed-by: York Sun york.sun@nxp.com
v1 -> v2:
Applied to u-boot-samsung.
Alexander Graf
Minkyu Kang
york sun
