[U-Boot] [PATCH 2/3 v2] net: sh-eth: add support for SH7753
SH7753 has two fast ethernet controllers and two gigabit ethernet controllers. It is similar to SH7757.
Signed-off-by: Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com --- about v2: - The patch doesn't remove the CONFIG_CPU_SH7752.
drivers/net/sh_eth.h | 8 ++++++-- 1 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/drivers/net/sh_eth.h b/drivers/net/sh_eth.h index 8aa7109..331c07c 100644 --- a/drivers/net/sh_eth.h +++ b/drivers/net/sh_eth.h @@ -287,7 +287,9 @@ static const u16 sh_eth_offset_fast_sh4[SH_ETH_MAX_REGISTER_OFFSET] = { #if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) #define SH_ETH_TYPE_GETHER #define BASE_IO_ADDR 0xfee00000 -#elif defined(CONFIG_CPU_SH7757) || defined(CONFIG_CPU_SH7752) +#elif defined(CONFIG_CPU_SH7757) || \ + defined(CONFIG_CPU_SH7752) || \ + defined(CONFIG_CPU_SH7753) #if defined(CONFIG_SH_ETHER_USE_GETHER) #define SH_ETH_TYPE_GETHER #define BASE_IO_ADDR 0xfee00000 @@ -356,7 +358,9 @@ enum DMAC_T_BIT {
/* GECMR */ enum GECMR_BIT { -#if defined(CONFIG_CPU_SH7757) || defined(CONFIG_CPU_SH7752) +#if defined(CONFIG_CPU_SH7757) || \ + defined(CONFIG_CPU_SH7752) || \ + defined(CONFIG_CPU_SH7753) GECMR_1000B = 0x20, GECMR_100B = 0x01, GECMR_10B = 0x00, #else GECMR_1000B = 0x01, GECMR_100B = 0x04, GECMR_10B = 0x00,
Applied, thanks.
Nobuhiro
2013/12/18 Shimoda, Yoshihiro yoshihiro.shimoda.uh@renesas.com:
about v2:
#else GECMR_1000B = 0x01, GECMR_100B = 0x04, GECMR_10B = 0x00, -- 1.7.1
Nobuhiro Iwamatsu
Shimoda, Yoshihiro
