[PATCH v1] ARM: dts: imx: imx8qm-rom7720: Fix AR8031 phy-mode
Fixed wrong PHY Interface Mode
As per kernel commit 0672d22a1924 ("ARM: dts: imx: Fix the AR803X phy-mode) the correct phy-mode should be "rgmii-id", so fix it accordingly to fix the Ethernet regression.
This problem has been exposed by commit:
commit 13114f38e2ccea9386726d8b9831dfc310589548
Fix the phy-mode accordingly to fix the regression.
Signed-off-by: Oliver Graute oliver.graute@kococonnector.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: Peng Fan peng.fan@nxp.com Cc: Vladimir Oltean vladimir.oltean@nxp.com --- arch/arm/dts/imx8qm-rom7720-a1.dts | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/imx8qm-rom7720-a1.dts b/arch/arm/dts/imx8qm-rom7720-a1.dts index 5f9ac955ed..d1f2fff869 100644 --- a/arch/arm/dts/imx8qm-rom7720-a1.dts +++ b/arch/arm/dts/imx8qm-rom7720-a1.dts @@ -293,7 +293,7 @@ &fec1 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_fec1>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; phy-handle = <ðphy0>; fsl,ar8031-phy-fixup; fsl,magic-packet; @@ -318,7 +318,7 @@ &fec2 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_fec2>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; phy-handle = <ðphy1>; fsl,ar8031-phy-fixup; fsl,magic-packet;
Fixed wrong PHY Interface Mode As per kernel commit 0672d22a1924 ("ARM: dts: imx: Fix the AR803X phy-mode) the correct phy-mode should be "rgmii-id", so fix it accordingly to fix the Ethernet regression. This problem has been exposed by commit: commit 13114f38e2ccea9386726d8b9831dfc310589548 Fix the phy-mode accordingly to fix the regression. Signed-off-by: Oliver Graute oliver.graute@kococonnector.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: Peng Fan peng.fan@nxp.com Cc: Vladimir Oltean vladimir.oltean@nxp.com
Best regards, Stefano Babic
Oliver Graute
sbabic@denx.de
