[U-Boot] [PATCH] microblaze: defconfig: Enable devtmps and tmpfs
From: Manjukumar Matha manjukumar.harthikote-matha@xilinx.com
Currently dropbear does not run in background because devtmps and tmpfs is not enabled by default. Enable devtmps and tmpfs to fix this issue.
Signed-off-by: Manjukumar Matha manjukumar.harthikote-matha@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/microblaze/configs/mmu_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/microblaze/configs/mmu_defconfig b/arch/microblaze/configs/mmu_defconfig index 654edfdc7867..b3b433db89d8 100644 --- a/arch/microblaze/configs/mmu_defconfig +++ b/arch/microblaze/configs/mmu_defconfig @@ -33,6 +33,8 @@ CONFIG_INET=y # CONFIG_IPV6 is not set CONFIG_BRIDGE=m CONFIG_PCI=y +CONFIG_DEVTMPFS=y +CONFIG_DEVTMPFS_MOUNT=y CONFIG_MTD=y CONFIG_MTD_CFI=y CONFIG_MTD_CFI_INTELEXT=y @@ -73,6 +75,7 @@ CONFIG_UIO_PDRV_GENIRQ=y CONFIG_UIO_DMEM_GENIRQ=y CONFIG_EXT2_FS=y # CONFIG_DNOTIFY is not set +CONFIG_TMPFS=y CONFIG_CRAMFS=y CONFIG_ROMFS_FS=y CONFIG_NFS_FS=y
Ășt 8. 10. 2019 v 12:03 odesĂlatel Michal Simek michal.simek@xilinx.com napsal:
diff --git a/arch/microblaze/configs/mmu_defconfig b/arch/microblaze/configs/mmu_defconfig index 654edfdc7867..b3b433db89d8 100644 --- a/arch/microblaze/configs/mmu_defconfig +++ b/arch/microblaze/configs/mmu_defconfig @@ -33,6 +33,8 @@ CONFIG_INET=y # CONFIG_IPV6 is not set CONFIG_BRIDGE=m CONFIG_PCI=y +CONFIG_DEVTMPFS=y +CONFIG_DEVTMPFS_MOUNT=y CONFIG_MTD=y CONFIG_MTD_CFI=y CONFIG_MTD_CFI_INTELEXT=y @@ -73,6 +75,7 @@ CONFIG_UIO_PDRV_GENIRQ=y CONFIG_UIO_DMEM_GENIRQ=y CONFIG_EXT2_FS=y # CONFIG_DNOTIFY is not set +CONFIG_TMPFS=y CONFIG_CRAMFS=y CONFIG_ROMFS_FS=y CONFIG_NFS_FS=y -- 2.17.1
Applied. M
Michal Simek
Michal Simek
