[U-Boot] [PATCH v6 00/12] MIPS Boston Development Board Support
This series introduces initial support for the MIPS Boston, and FPGA based development board & successor to the older Malta board. Further peripheral work is needed but this introduces the basics.
This can be tested in a currently out-of-tree QEMU port if desired. Please see the included doc/README.boston for details about how to do so.
Paul Burton (12): clk: Use dummy clk_get_by_* functions when CONFIG_CLK is disabled serial: ns16550: Support clocks via phandle dt-bindings: Add interrupt-controller/mips-gic.h header pci: xilinx: Add a driver for Xilinx AXI to PCIe bridge pci: Flip condition for detecting non-PCI parent devices net: pch_gbe: Use dm_pci_map_bar to discover MMIO base net: pch_gbe: Make 64 bit safe dm: regmap: Implement simple regmap_read & regmap_write dm: core: Match compatible strings in order of priority dm: syscon: Provide a generic syscon driver clk: boston: Providea simple driver for Boston board clocks boston: Introduce support for the MIPS Boston development board
arch/mips/Kconfig | 16 ++ arch/mips/dts/Makefile | 1 + arch/mips/dts/img,boston.dts | 216 ++++++++++++++++++++ board/imgtec/boston/Kconfig | 16 ++ board/imgtec/boston/MAINTAINERS | 6 + board/imgtec/boston/Makefile | 9 + board/imgtec/boston/boston-lcd.h | 21 ++ board/imgtec/boston/boston-regs.h | 26 +++ board/imgtec/boston/checkboard.c | 30 +++ board/imgtec/boston/ddr.c | 30 +++ board/imgtec/boston/lowlevel_init.S | 56 ++++++ configs/boston32r2_defconfig | 40 ++++ configs/boston32r2el_defconfig | 41 ++++ configs/boston64r2_defconfig | 40 ++++ configs/boston64r2el_defconfig | 41 ++++ doc/README.boston | 58 ++++++ drivers/clk/Kconfig | 8 + drivers/clk/Makefile | 1 + drivers/clk/clk_boston.c | 97 +++++++++ drivers/core/lists.c | 83 ++++---- drivers/core/regmap.c | 20 ++ drivers/core/syscon-uclass.c | 11 ++ drivers/net/pch_gbe.c | 28 ++- drivers/pci/Kconfig | 7 + drivers/pci/Makefile | 1 + drivers/pci/pci-uclass.c | 2 +- drivers/pci/pcie_xilinx.c | 220 +++++++++++++++++++++ drivers/serial/ns16550.c | 19 +- include/clk.h | 2 +- include/configs/boston.h | 68 +++++++ include/dt-bindings/clock/boston-clock.h | 13 ++ .../dt-bindings/interrupt-controller/mips-gic.h | 9 + 32 files changed, 1174 insertions(+), 62 deletions(-) create mode 100644 arch/mips/dts/img,boston.dts create mode 100644 board/imgtec/boston/Kconfig create mode 100644 board/imgtec/boston/MAINTAINERS create mode 100644 board/imgtec/boston/Makefile create mode 100644 board/imgtec/boston/boston-lcd.h create mode 100644 board/imgtec/boston/boston-regs.h create mode 100644 board/imgtec/boston/checkboard.c create mode 100644 board/imgtec/boston/ddr.c create mode 100644 board/imgtec/boston/lowlevel_init.S create mode 100644 configs/boston32r2_defconfig create mode 100644 configs/boston32r2el_defconfig create mode 100644 configs/boston64r2_defconfig create mode 100644 configs/boston64r2el_defconfig create mode 100644 doc/README.boston create mode 100644 drivers/clk/clk_boston.c create mode 100644 drivers/pci/pcie_xilinx.c create mode 100644 include/configs/boston.h create mode 100644 include/dt-bindings/clock/boston-clock.h create mode 100644 include/dt-bindings/interrupt-controller/mips-gic.h
The implementations of clk_get_by_index & clk_get_by_name are only available when CONFIG_CLK is enabled. Provide the dummies when this is not the case in order to avoid build failures.
Signed-off-by: Paul Burton paul.burton@imgtec.com
Changes in v6: - New patch
Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: None
include/clk.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/clk.h b/include/clk.h index 161bc28..27b1d2c 100644 --- a/include/clk.h +++ b/include/clk.h @@ -59,7 +59,7 @@ struct clk { unsigned long id; };
-#if CONFIG_IS_ENABLED(OF_CONTROL) +#if CONFIG_IS_ENABLED(OF_CONTROL) && CONFIG_IS_ENABLED(CLK) struct phandle_2_cell; int clk_get_by_index_platdata(struct udevice *dev, int index, struct phandle_2_cell *cells, struct clk *clk);
Hi Paul,
Where are the dummies?
Changes in v6:
- New patch
-#if CONFIG_IS_ENABLED(OF_CONTROL) +#if CONFIG_IS_ENABLED(OF_CONTROL) && CONFIG_IS_ENABLED(CLK) struct phandle_2_cell; int clk_get_by_index_platdata(struct udevice *dev, int index, struct phandle_2_cell *cells, struct clk *clk); -- 2.9.2
On 05/08/16 02:36, Simon Glass wrote:
Hi Paul,
Hi Simon,
I mean the static inline versions which just return -ENOSYS, which already exist in clk.h but weren't provided before unless CONFIG_OF_CONTROL wasn't set.
Thanks, Paul
Changes in v6:
- New patch
Hi Paul,
Hi Simon,
Thanks, Paul
Previously ns16550 compatible UARTs probed via device tree have needed their device tree nodes to contain a clock-frequency property. An alternative to this commonly used with Linux is to reference a clock via a phandle. This patch allows U-Boot to support that, retrieving the clock frequency by probing the appropriate clock device.
For example, a system might choose to provide the UART base clock as a reference to a clock common to multiple devices:
sys_clk: clock { compatible = "fixed-clock"; #clock-cells = <0>; clock-frequency = <10000000>; };
uart0: uart@10000000 { compatible = "ns16550a"; reg = <0x10000000 0x1000>; clocks = <&sys_clk>; };
uart1: uart@10000000 { compatible = "ns16550a"; reg = <0x10001000 0x1000>; clocks = <&sys_clk>; };
This removes the need for the frequency information to be duplicated in multiple nodes and allows the device tree to be more descriptive of the system.
Signed-off-by: Paul Burton paul.burton@imgtec.com Reviewed-by: Simon Glass sjg@chromium.org
Changes in v6: - Ignore -ENOSYS from clk_get_by_index too, for systems with CONFIG_CLK=n
Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: - Propogate non-ENODEV errors from clk_get_by_index
drivers/serial/ns16550.c | 19 ++++++++++++++++--- 1 file changed, 16 insertions(+), 3 deletions(-)
diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index 88fca15..af317cb 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <clk.h> #include <dm.h> #include <errno.h> #include <fdtdec.h> @@ -352,6 +353,8 @@ int ns16550_serial_ofdata_to_platdata(struct udevice *dev) { struct ns16550_platdata *plat = dev->platdata; fdt_addr_t addr; + struct clk clk; + int err;
/* try Processor Local Bus device first */ addr = dev_get_addr(dev); @@ -397,9 +400,19 @@ int ns16550_serial_ofdata_to_platdata(struct udevice *dev) "reg-offset", 0); plat->reg_shift = fdtdec_get_int(gd->fdt_blob, dev->of_offset, "reg-shift", 0); - plat->clock = fdtdec_get_int(gd->fdt_blob, dev->of_offset, - "clock-frequency", - CONFIG_SYS_NS16550_CLK); + + err = clk_get_by_index(dev, 0, &clk); + if (!err) { + plat->clock = clk_get_rate(&clk); + } else if (err != -ENODEV && err != -ENOSYS) { + debug("ns16550 failed to get clock\n"); + return err; + } + + if (!plat->clock) + plat->clock = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "clock-frequency", + CONFIG_SYS_NS16550_CLK); if (!plat->clock) { debug("ns16550 clock not defined\n"); return -EINVAL;
Hi Paul,
Changes in v6:
struct clk clk;
int err; /* try Processor Local Bus device first */ addr = dev_get_addr(dev);
"clock-frequency",
if (!err) {
While I think this is a good change, it breaks boards which have a clock in the device tree but don't support it in their driver.
I think you can fix it by checking the error value from clk_get_rate(), i.e. something like:
if (!err) { err = clk_get_rate(&clk); if (!IS_ERR_VALUE(err)) plat->clock = err; } else if ...
return err;
if (!plat->clock)
"clock-frequency",
-- 2.9.2
Import a copy of the dt-bindings/interrupt-controller/mips-gic.h header from Linux, such that we can use device trees which include it without modification.
Signed-off-by: Paul Burton paul.burton@imgtec.com ---
Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: None
include/dt-bindings/interrupt-controller/mips-gic.h | 9 +++++++++ 1 file changed, 9 insertions(+) create mode 100644 include/dt-bindings/interrupt-controller/mips-gic.h
diff --git a/include/dt-bindings/interrupt-controller/mips-gic.h b/include/dt-bindings/interrupt-controller/mips-gic.h new file mode 100644 index 0000000..cf35a57 --- /dev/null +++ b/include/dt-bindings/interrupt-controller/mips-gic.h @@ -0,0 +1,9 @@ +#ifndef _DT_BINDINGS_INTERRUPT_CONTROLLER_MIPS_GIC_H +#define _DT_BINDINGS_INTERRUPT_CONTROLLER_MIPS_GIC_H + +#include <dt-bindings/interrupt-controller/irq.h> + +#define GIC_SHARED 0 +#define GIC_LOCAL 1 + +#endif
This patch adds a driver for the Xilinx AXI bridge for PCI express, an IP block which can be used on some generations of Xilinx FPGAs. This is mostly a case of implementing PCIe ECAM specification, but with some quirks about what devices are valid to access.
Changes in v6: - Use map_physmem instead of ioremap_nocache
Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: - Clean up error returns & documentation
drivers/pci/Kconfig | 7 ++ drivers/pci/Makefile | 1 + drivers/pci/pcie_xilinx.c | 220 ++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 228 insertions(+) create mode 100644 drivers/pci/pcie_xilinx.c
diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 26aa2b0..1f9ea66 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -38,4 +38,11 @@ config PCI_TEGRA with a total of 5 lanes. Some boards require this for Ethernet support to work (e.g. beaver, jetson-tk1).
+config PCI_XILINX + bool "Xilinx AXI Bridge for PCI Express" + depends on DM_PCI + help + Enable support for the Xilinx AXI bridge for PCI express, an IP block + which can be used on some generations of Xilinx FPGAs. + endmenu diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index f8be9bf..9583e91 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -31,3 +31,4 @@ obj-$(CONFIG_PCI_TEGRA) += pci_tegra.o obj-$(CONFIG_TSI108_PCI) += tsi108_pci.o obj-$(CONFIG_WINBOND_83C553) += w83c553f.o obj-$(CONFIG_PCIE_LAYERSCAPE) += pcie_layerscape.o +obj-$(CONFIG_PCI_XILINX) += pcie_xilinx.o diff --git a/drivers/pci/pcie_xilinx.c b/drivers/pci/pcie_xilinx.c new file mode 100644 index 0000000..5216001 --- /dev/null +++ b/drivers/pci/pcie_xilinx.c @@ -0,0 +1,220 @@ +/* + * Xilinx AXI Bridge for PCI Express Driver + * + * Copyright (C) 2016 Imagination Technologies + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <dm.h> +#include <pci.h> + +#include <asm/io.h> + +/** + * struct xilinx_pcie - Xilinx PCIe controller state + * @hose: The parent classes PCI controller state + * @cfg_base: The base address of memory mapped configuration space + */ +struct xilinx_pcie { + struct pci_controller hose; + void *cfg_base; +}; + +/* Register definitions */ +#define XILINX_PCIE_REG_PSCR 0x144 +#define XILINX_PCIE_REG_PSCR_LNKUP BIT(11) + +/** + * pcie_xilinx_link_up() - Check whether the PCIe link is up + * @pcie: Pointer to the PCI controller state + * + * Checks whether the PCIe link for the given device is up or down. + * + * Return: true if the link is up, else false + */ +static bool pcie_xilinx_link_up(struct xilinx_pcie *pcie) +{ + uint32_t pscr = __raw_readl(pcie->cfg_base + XILINX_PCIE_REG_PSCR); + + return pscr & XILINX_PCIE_REG_PSCR_LNKUP; +} + +/** + * pcie_xilinx_config_address() - Calculate the address of a config access + * @pcie: Pointer to the PCI controller state + * @bdf: Identifies the PCIe device to access + * @offset: The offset into the device's configuration space + * @paddress: Pointer to the pointer to write the calculates address to + * + * Calculates the address that should be accessed to perform a PCIe + * configuration space access for a given device identified by the PCIe + * controller device @pcie and the bus, device & function numbers in @bdf. If + * access to the device is not valid then the function will return an error + * code. Otherwise the address to access will be written to the pointer pointed + * to by @paddress. + * + * Return: 0 on success, else -ENODEV + */ +static int pcie_xilinx_config_address(struct xilinx_pcie *pcie, pci_dev_t bdf, + uint offset, void **paddress) +{ + unsigned int bus = PCI_BUS(bdf); + unsigned int dev = PCI_DEV(bdf); + unsigned int func = PCI_FUNC(bdf); + void *addr; + + if ((bus > 0) && !pcie_xilinx_link_up(pcie)) + return -ENODEV; + + /* + * Busses 0 (host-PCIe bridge) & 1 (its immediate child) are + * limited to a single device each. + */ + if ((bus < 2) && (dev > 0)) + return -ENODEV; + + addr = pcie->cfg_base; + addr += bus << 20; + addr += dev << 15; + addr += func << 12; + addr += offset; + *paddress = addr; + + return 0; +} + +/** + * pcie_xilinx_read_config() - Read from configuration space + * @pcie: Pointer to the PCI controller state + * @bdf: Identifies the PCIe device to access + * @offset: The offset into the device's configuration space + * @valuep: A pointer at which to store the read value + * @size: Indicates the size of access to perform + * + * Read a value of size @size from offset @offset within the configuration + * space of the device identified by the bus, device & function numbers in @bdf + * on the PCI bus @bus. + * + * Return: 0 on success, else -ENODEV or -EINVAL + */ +static int pcie_xilinx_read_config(struct udevice *bus, pci_dev_t bdf, + uint offset, ulong *valuep, + enum pci_size_t size) +{ + struct xilinx_pcie *pcie = dev_get_priv(bus); + void *address; + int err; + + err = pcie_xilinx_config_address(pcie, bdf, offset, &address); + if (err < 0) { + *valuep = pci_get_ff(size); + return 0; + } + + switch (size) { + case PCI_SIZE_8: + *valuep = __raw_readb(address); + return 0; + case PCI_SIZE_16: + *valuep = __raw_readw(address); + return 0; + case PCI_SIZE_32: + *valuep = __raw_readl(address); + return 0; + default: + return -EINVAL; + } +} + +/** + * pcie_xilinx_write_config() - Write to configuration space + * @pcie: Pointer to the PCI controller state + * @bdf: Identifies the PCIe device to access + * @offset: The offset into the device's configuration space + * @value: The value to write + * @size: Indicates the size of access to perform + * + * Write the value @value of size @size from offset @offset within the + * configuration space of the device identified by the bus, device & function + * numbers in @bdf on the PCI bus @bus. + * + * Return: 0 on success, else -ENODEV or -EINVAL + */ +static int pcie_xilinx_write_config(struct udevice *bus, pci_dev_t bdf, + uint offset, ulong value, + enum pci_size_t size) +{ + struct xilinx_pcie *pcie = dev_get_priv(bus); + void *address; + int err; + + err = pcie_xilinx_config_address(pcie, bdf, offset, &address); + if (err < 0) + return 0; + + switch (size) { + case PCI_SIZE_8: + __raw_writeb(value, address); + return 0; + case PCI_SIZE_16: + __raw_writew(value, address); + return 0; + case PCI_SIZE_32: + __raw_writel(value, address); + return 0; + default: + return -EINVAL; + } +} + +/** + * pcie_xilinx_ofdata_to_platdata() - Translate from DT to device state + * @dev: A pointer to the device being operated on + * + * Translate relevant data from the device tree pertaining to device @dev into + * state that the driver will later make use of. This state is stored in the + * device's private data structure. + * + * Return: 0 on success, else -EINVAL + */ +static int pcie_xilinx_ofdata_to_platdata(struct udevice *dev) +{ + struct xilinx_pcie *pcie = dev_get_priv(dev); + struct fdt_resource reg_res; + DECLARE_GLOBAL_DATA_PTR; + int err; + + err = fdt_get_resource(gd->fdt_blob, dev->of_offset, "reg", + 0, ®_res); + if (err < 0) { + error(""reg" resource not found\n"); + return err; + } + + pcie->cfg_base = map_physmem(reg_res.start, + fdt_resource_size(®_res), + MAP_NOCACHE); + + return 0; +} + +static const struct dm_pci_ops pcie_xilinx_ops = { + .read_config = pcie_xilinx_read_config, + .write_config = pcie_xilinx_write_config, +}; + +static const struct udevice_id pcie_xilinx_ids[] = { + { .compatible = "xlnx,axi-pcie-host-1.00.a" }, + { } +}; + +U_BOOT_DRIVER(pcie_xilinx) = { + .name = "pcie_xilinx", + .id = UCLASS_PCI, + .of_match = pcie_xilinx_ids, + .ops = &pcie_xilinx_ops, + .ofdata_to_platdata = pcie_xilinx_ofdata_to_platdata, + .priv_auto_alloc_size = sizeof(struct xilinx_pcie), +};
In pci_uclass_pre_probe an attempt is made to detect whether the parent of a device is a PCI device and that the device is thus a bridge. This was being done by checking whether the parent of the device is of the UCLASS_ROOT class. This causes problems if the PCI controller is a child of some other non-PCI node, for example a simple-bus node.
For example, if the device tree contains something like the following then pci_uclass_pre_probe would incorrectly believe that the PCI controller is a bridge, with a PCI parent:
/ { some_child { compatible = "simple-bus"; #address-cells = <1>; #size-cells = <1>; ranges = <>;
pci_controller: pci@10000000 { compatible = "my-pci-controller"; device_type = "pci"; reg = <0x10000000 0x2000000>; }; }; };
Avoid this incorrect detection of bridges by instead checking whether the parent devices class is UCLASS_PCI and treating a device as a bridge when this is true, making use of device_is_on_pci_bus to perform this test.
Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: - Use device_is_on_pci_bus instead of effectively open-coding it
drivers/pci/pci-uclass.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 32590ce..b9b55e2 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -859,7 +859,7 @@ static int pci_uclass_pre_probe(struct udevice *bus) hose = bus->uclass_priv;
/* For bridges, use the top-level PCI controller */ - if (device_get_uclass_id(bus->parent) == UCLASS_ROOT) { + if (!device_is_on_pci_bus(bus)) { hose->ctlr = bus; ret = decode_regions(hose, gd->fdt_blob, bus->parent->of_offset, bus->of_offset);
Reading the PCI BAR & converting the result to a physical address is not safe across all architectures. For example on MIPS the virtual:physical mapping is not 1:1, so we cannot directly make use of the physical address.
Use the more generic BAR-mapping function dm_pci_map_bar to discover the MMIO base address, which should work across architectures.
drivers/net/pch_gbe.c | 8 +++----- 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/drivers/net/pch_gbe.c b/drivers/net/pch_gbe.c index 137818b..2d0a700 100644 --- a/drivers/net/pch_gbe.c +++ b/drivers/net/pch_gbe.c @@ -421,7 +421,7 @@ int pch_gbe_probe(struct udevice *dev) { struct pch_gbe_priv *priv; struct eth_pdata *plat = dev_get_platdata(dev); - u32 iobase; + void *iobase;
/* * The priv structure contains the descriptors and frame buffers which @@ -432,11 +432,9 @@ int pch_gbe_probe(struct udevice *dev)
priv->dev = dev;
- dm_pci_read_config32(dev, PCI_BASE_ADDRESS_1, &iobase); - iobase &= PCI_BASE_ADDRESS_MEM_MASK; - iobase = dm_pci_mem_to_phys(dev, iobase); + iobase = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_1, PCI_REGION_MEM);
- plat->iobase = iobase; + plat->iobase = (ulong)iobase; priv->mac_regs = (struct pch_gbe_regs *)iobase;
/* Read MAC address from SROM and initialize dev->enetaddr with it */
The pch_gbe driver previously casted pointers to & from unsigned 32 bit integers in many locations. This breaks the driver on 64 bit systems, producing streams of compiler warnings about mismatched pointer & integer sizes and then failing to keep track of addresses correctly at runtime.
Fix the driver for 64 bit systems by using unsigned longs in place of the previously used 32 bit integers.
drivers/net/pch_gbe.c | 20 ++++++++++---------- 1 file changed, 10 insertions(+), 10 deletions(-)
diff --git a/drivers/net/pch_gbe.c b/drivers/net/pch_gbe.c index 2d0a700..d40fff0 100644 --- a/drivers/net/pch_gbe.c +++ b/drivers/net/pch_gbe.c @@ -118,14 +118,14 @@ static void pch_gbe_rx_descs_init(struct udevice *dev) memset(rx_desc, 0, sizeof(struct pch_gbe_rx_desc) * PCH_GBE_DESC_NUM); for (i = 0; i < PCH_GBE_DESC_NUM; i++) rx_desc->buffer_addr = dm_pci_phys_to_mem(priv->dev, - (u32)(priv->rx_buff[i])); + (ulong)(priv->rx_buff[i]));
- writel(dm_pci_phys_to_mem(priv->dev, (u32)rx_desc), + writel(dm_pci_phys_to_mem(priv->dev, (ulong)rx_desc), &mac_regs->rx_dsc_base); writel(sizeof(struct pch_gbe_rx_desc) * (PCH_GBE_DESC_NUM - 1), &mac_regs->rx_dsc_size);
- writel(dm_pci_phys_to_mem(priv->dev, (u32)(rx_desc + 1)), + writel(dm_pci_phys_to_mem(priv->dev, (ulong)(rx_desc + 1)), &mac_regs->rx_dsc_sw_p); }
@@ -137,11 +137,11 @@ static void pch_gbe_tx_descs_init(struct udevice *dev)
memset(tx_desc, 0, sizeof(struct pch_gbe_tx_desc) * PCH_GBE_DESC_NUM);
- writel(dm_pci_phys_to_mem(priv->dev, (u32)tx_desc), + writel(dm_pci_phys_to_mem(priv->dev, (ulong)tx_desc), &mac_regs->tx_dsc_base); writel(sizeof(struct pch_gbe_tx_desc) * (PCH_GBE_DESC_NUM - 1), &mac_regs->tx_dsc_size); - writel(dm_pci_phys_to_mem(priv->dev, (u32)(tx_desc + 1)), + writel(dm_pci_phys_to_mem(priv->dev, (ulong)(tx_desc + 1)), &mac_regs->tx_dsc_sw_p); }
@@ -251,7 +251,7 @@ static int pch_gbe_send(struct udevice *dev, void *packet, int length) if (length < 64) frame_ctrl |= PCH_GBE_TXD_CTRL_APAD;
- tx_desc->buffer_addr = dm_pci_phys_to_mem(priv->dev, (u32)packet); + tx_desc->buffer_addr = dm_pci_phys_to_mem(priv->dev, (ulong)packet); tx_desc->length = length; tx_desc->tx_words_eob = length + 3; tx_desc->tx_frame_ctrl = frame_ctrl; @@ -262,7 +262,7 @@ static int pch_gbe_send(struct udevice *dev, void *packet, int length) if (++priv->tx_idx >= PCH_GBE_DESC_NUM) priv->tx_idx = 0;
- writel(dm_pci_phys_to_mem(priv->dev, (u32)(tx_head + priv->tx_idx)), + writel(dm_pci_phys_to_mem(priv->dev, (ulong)(tx_head + priv->tx_idx)), &mac_regs->tx_dsc_sw_p);
start = get_timer(0); @@ -283,7 +283,7 @@ static int pch_gbe_recv(struct udevice *dev, int flags, uchar **packetp) struct pch_gbe_priv *priv = dev_get_priv(dev); struct pch_gbe_regs *mac_regs = priv->mac_regs; struct pch_gbe_rx_desc *rx_desc; - u32 hw_desc, buffer_addr, length; + ulong hw_desc, buffer_addr, length;
rx_desc = &priv->rx_desc[priv->rx_idx];
@@ -291,7 +291,7 @@ static int pch_gbe_recv(struct udevice *dev, int flags, uchar **packetp) hw_desc = readl(&mac_regs->rx_dsc_hw_p_hld);
/* Just return if not receiving any packet */ - if ((u32)rx_desc == hw_desc) + if ((ulong)rx_desc == hw_desc) return -EAGAIN;
buffer_addr = dm_pci_mem_to_phys(priv->dev, rx_desc->buffer_addr); @@ -315,7 +315,7 @@ static int pch_gbe_free_pkt(struct udevice *dev, uchar *packet, int length) if (++rx_swp >= PCH_GBE_DESC_NUM) rx_swp = 0;
- writel(dm_pci_phys_to_mem(priv->dev, (u32)(rx_head + rx_swp)), + writel(dm_pci_phys_to_mem(priv->dev, (ulong)(rx_head + rx_swp)), &mac_regs->rx_dsc_sw_p);
Hi Paul,
It seems you are not collecting the acks you get and including them in the commit message of the next version.
I Acked v2, but it's been dropped in all later versions.
On 04/08/16 17:23, Joe Hershberger wrote:
Hi Paul,
Hi Joe,
Apologies, I overlooked your email. I'll include your ack if there's a v7.
Thanks, Paul
The regmap_read & regmap_write functions were previously declared in regmap.h but not implemented anywhere. The regmap implementation & commit message of 6f98b7504f70 ("dm: Add support for register maps (regmap)") indicate that only memory mapped accesses are supported for now, so providing simple implementations of regmap_read & regmap_write is trivial. The access size is presumed to be 4 bytes & endianness is presumed native, which are the defaults for the regmap code in Linux.
Changes in v6: None Changes in v5: None Changes in v4: - Tweak whitespace
Changes in v3: None Changes in v2: - New patch
drivers/core/regmap.c | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/drivers/core/regmap.c b/drivers/core/regmap.c index 0299ff0..3177515 100644 --- a/drivers/core/regmap.c +++ b/drivers/core/regmap.c @@ -13,6 +13,8 @@ #include <mapmem.h> #include <regmap.h>
+#include <asm/io.h> + DECLARE_GLOBAL_DATA_PTR;
static struct regmap *regmap_alloc_count(int count) @@ -117,3 +119,21 @@ int regmap_uninit(struct regmap *map)
return 0; } + +int regmap_read(struct regmap *map, uint offset, uint *valp) +{ + uint32_t *ptr = ioremap(map->base + offset, 4); + + *valp = __raw_readl(ptr); + + return 0; +} + +int regmap_write(struct regmap *map, uint offset, uint val) +{ + uint32_t *ptr = ioremap(map->base + offset, 4); + + __raw_writel(val, ptr); + + return 0; +}
Device model drivers have previously been matched to FDT nodes by virtue of being the first driver in the driver list to be compatible with the node. This ignores the fact that compatible strings in the device tree are listed in order of priority - that is, if we have a node with 2 compatible strings & a driver that matches each then we should always probe the driver that matches the first compatible string.
Fix this by looping through the compatible strings for a node when attempting to bind it in lists_bind_fdt and checking each driver for a match of the first string, then each driver for a match of the second string etc. Effectively this inverts the loops over compatible strings & drivers.
drivers/core/lists.c | 83 ++++++++++++++++++++++++++-------------------------- 1 file changed, 41 insertions(+), 42 deletions(-)
diff --git a/drivers/core/lists.c b/drivers/core/lists.c index 6a634e6..bde6ec1 100644 --- a/drivers/core/lists.c +++ b/drivers/core/lists.c @@ -101,37 +101,21 @@ int device_bind_driver_to_node(struct udevice *parent, const char *drv_name,
#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) /** - * driver_check_compatible() - Check if a driver is compatible with this node + * driver_check_compatible() - Check if a driver matches a compatible string * - * @param blob: Device tree pointer - * @param offset: Offset of node in device tree * @param of_match: List of compatible strings to match - * @param of_idp: Returns the match that was found - * @return 0 if there is a match, -ENOENT if no match, -ENODEV if the node - * does not have a compatible string, other error <0 if there is a device - * tree error + * @param compat: The compatible string to search for + * @return 0 if there is a match, -ENOENT if no match */ -static int driver_check_compatible(const void *blob, int offset, - const struct udevice_id *of_match, - const struct udevice_id **of_idp) +static int driver_check_compatible(const struct udevice_id *of_match, + const char *compat) { - int ret; - - *of_idp = NULL; if (!of_match) return -ENOENT;
while (of_match->compatible) { - ret = fdt_node_check_compatible(blob, offset, - of_match->compatible); - if (!ret) { - *of_idp = of_match; + if (!strcmp(of_match->compatible, compat)) return 0; - } else if (ret == -FDT_ERR_NOTFOUND) { - return -ENODEV; - } else if (ret < 0) { - return -EINVAL; - } of_match++; }
@@ -143,35 +127,52 @@ int lists_bind_fdt(struct udevice *parent, const void *blob, int offset, { struct driver *driver = ll_entry_start(struct driver, driver); const int n_ents = ll_entry_count(struct driver, driver); - const struct udevice_id *id; struct driver *entry; struct udevice *dev; bool found = false; - const char *name; + const char *name, *compat_list, *compat; + int compat_length, i; int result = 0; int ret = 0;
- dm_dbg("bind node %s\n", fdt_get_name(blob, offset, NULL)); + name = fdt_get_name(blob, offset, NULL); + dm_dbg("bind node %s\n", name); if (devp) *devp = NULL; - for (entry = driver; entry != driver + n_ents; entry++) { - ret = driver_check_compatible(blob, offset, entry->of_match, - &id); - name = fdt_get_name(blob, offset, NULL); - if (ret == -ENOENT) { - continue; - } else if (ret == -ENODEV) { + + compat_list = fdt_getprop(blob, offset, "compatible", &compat_length); + if (!compat_list) { + if (compat_length == -FDT_ERR_NOTFOUND) { dm_dbg("Device '%s' has no compatible string\n", name); - break; - } else if (ret) { - dm_warn("Device tree error at offset %d\n", offset); - result = ret; - break; + return 0; }
+ dm_warn("Device tree error at offset %d\n", offset); + return compat_length; + } + + /* + * Walk through the compatible string list, attempting to match each + * compatible string in order such that we match in order of priority + * from the first string to the last. + */ + for (i = 0; i < compat_length; i += strlen(compat) + 1) { + compat = compat_list + i; + dm_dbg(" - attempt to match compatible string '%s'\n", + compat); + + for (entry = driver; entry != driver + n_ents; entry++) { + ret = driver_check_compatible(entry->of_match, compat); + if (!ret) + break; + } + if (entry == driver + n_ents) + continue; + dm_dbg(" - found match at '%s'\n", entry->name); ret = device_bind_with_driver_data(parent, entry, name, - id->data, offset, &dev); + entry->of_match->data, + offset, &dev); if (ret == -ENODEV) { dm_dbg("Driver '%s' refuses to bind\n", entry->name); continue; @@ -188,10 +189,8 @@ int lists_bind_fdt(struct udevice *parent, const void *blob, int offset, break; }
- if (!found && !result && ret != -ENODEV) { - dm_dbg("No match for node '%s'\n", - fdt_get_name(blob, offset, NULL)); - } + if (!found && !result && ret != -ENODEV) + dm_dbg("No match for node '%s'\n", name);
return result; }
Hi Paul,
This looks generally OK, but please make sure that the tests pass (./test/run) and see below.
- driver_check_compatible() - Check if a driver is compatible with this node
- driver_check_compatible() - Check if a driver matches a compatible string
- @param blob: Device tree pointer
- @param offset: Offset of node in device tree
- @param of_match: List of compatible strings to match
- @param of_idp: Returns the match that was found
- @return 0 if there is a match, -ENOENT if no match, -ENODEV if the node
- does not have a compatible string, other error <0 if there is a device
- tree error
- @param compat: The compatible string to search for
const char *compat)
int ret;
*of_idp = NULL; if (!of_match) return -ENOENT; while (of_match->compatible) {
if (!ret) {
*of_idp = of_match;
return -ENODEV;
return -EINVAL;
} of_match++; }
const char *name;
&id);
continue;
if (!compat_list) {
break;
} else if (ret) {
result = ret;
break;
return 0; }
compat);
if (!ret)
break;
continue;
This uses the data from teh first matching compatible string. The point of this field is to tell the driver which of its strings matched. So you might need to put the parameter back to driver_check_compatible().
dm_dbg("No match for node '%s'\n", name); return result;
2.9.2
Provide a trivial syscon driver matching the generic "syscon" compatible string, allowing for simple system controllers to be used without a custom driver just as in Linux.
Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: - New patch
drivers/core/syscon-uclass.c | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/drivers/core/syscon-uclass.c b/drivers/core/syscon-uclass.c index 01bd968..2148469 100644 --- a/drivers/core/syscon-uclass.c +++ b/drivers/core/syscon-uclass.c @@ -95,3 +95,14 @@ UCLASS_DRIVER(syscon) = { .per_device_auto_alloc_size = sizeof(struct syscon_uc_info), .pre_probe = syscon_pre_probe, }; + +static const struct udevice_id generic_syscon_ids[] = { + { .compatible = "syscon" }, + { } +}; + +U_BOOT_DRIVER(generic_syscon) = { + .name = "syscon", + .id = UCLASS_SYSCON, + .of_match = generic_syscon_ids, +};
Add a simple driver for the clocks provided by the MIPS Boston development board. The system provides information about 2 clocks whose rates are fixed by the bitfile flashed in the boards FPGA, and this driver simply reads the rates of these 2 clocks.
Changes in v6: None Changes in v5: None Changes in v4: - Replace EXT macro with ext_field function
drivers/clk/Kconfig | 8 +++ drivers/clk/Makefile | 1 + drivers/clk/clk_boston.c | 97 ++++++++++++++++++++++++++++++++ include/dt-bindings/clock/boston-clock.h | 13 +++++ 4 files changed, 119 insertions(+) create mode 100644 drivers/clk/clk_boston.c create mode 100644 include/dt-bindings/clock/boston-clock.h
diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index 6eee8eb..85eea0d 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -20,6 +20,14 @@ config SPL_CLK setting up clocks within SPL, and allows the same drivers to be used as U-Boot proper.
+config CLK_BOSTON + def_bool y if TARGET_BOSTON + depends on CLK + select REGMAP + select SYSCON + help + Enable this to support the clocks + source "drivers/clk/uniphier/Kconfig" source "drivers/clk/exynos/Kconfig"
diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index f7a8891..9d14122 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -13,3 +13,4 @@ obj-$(CONFIG_SANDBOX) += clk_sandbox_test.o obj-$(CONFIG_MACH_PIC32) += clk_pic32.o obj-$(CONFIG_CLK_UNIPHIER) += uniphier/ obj-$(CONFIG_CLK_EXYNOS) += exynos/ +obj-$(CONFIG_CLK_BOSTON) += clk_boston.o diff --git a/drivers/clk/clk_boston.c b/drivers/clk/clk_boston.c new file mode 100644 index 0000000..78f1b75 --- /dev/null +++ b/drivers/clk/clk_boston.c @@ -0,0 +1,97 @@ +/* + * Copyright (C) 2016 Imagination Technologies + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <dt-bindings/clock/boston-clock.h> +#include <regmap.h> +#include <syscon.h> + +struct clk_boston { + struct regmap *regmap; +}; + +#define BOSTON_PLAT_MMCMDIV 0x30 +# define BOSTON_PLAT_MMCMDIV_CLK0DIV (0xff << 0) +# define BOSTON_PLAT_MMCMDIV_INPUT (0xff << 8) +# define BOSTON_PLAT_MMCMDIV_MUL (0xff << 16) +# define BOSTON_PLAT_MMCMDIV_CLK1DIV (0xff << 24) + +static uint32_t ext_field(uint32_t val, uint32_t mask) +{ + return (val & mask) >> (ffs(mask) - 1); +} + +static ulong clk_boston_get_rate(struct clk *clk) +{ + struct clk_boston *state = dev_get_platdata(clk->dev); + uint32_t in_rate, mul, div; + uint mmcmdiv; + int err; + + err = regmap_read(state->regmap, BOSTON_PLAT_MMCMDIV, &mmcmdiv); + if (err) + return 0; + + in_rate = ext_field(mmcmdiv, BOSTON_PLAT_MMCMDIV_INPUT); + mul = ext_field(mmcmdiv, BOSTON_PLAT_MMCMDIV_MUL); + + switch (clk->id) { + case BOSTON_CLK_SYS: + div = ext_field(mmcmdiv, BOSTON_PLAT_MMCMDIV_CLK0DIV); + break; + case BOSTON_CLK_CPU: + div = ext_field(mmcmdiv, BOSTON_PLAT_MMCMDIV_CLK1DIV); + break; + default: + return 0; + } + + return (in_rate * mul * 1000000) / div; +} + +const struct clk_ops clk_boston_ops = { + .get_rate = clk_boston_get_rate, +}; + +static int clk_boston_ofdata_to_platdata(struct udevice *dev) +{ + struct clk_boston *state = dev_get_platdata(dev); + struct udevice *syscon; + int err; + + err = uclass_get_device_by_phandle(UCLASS_SYSCON, dev, + "regmap", &syscon); + if (err) { + error("unable to find syscon device\n"); + return err; + } + + state->regmap = syscon_get_regmap(syscon); + if (!state->regmap) { + error("unable to find regmap\n"); + return -ENODEV; + } + + return 0; +} + +static const struct udevice_id clk_boston_match[] = { + { + .compatible = "img,boston-clock", + }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(clk_boston) = { + .name = "boston_clock", + .id = UCLASS_CLK, + .of_match = clk_boston_match, + .ofdata_to_platdata = clk_boston_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct clk_boston), + .ops = &clk_boston_ops, +}; diff --git a/include/dt-bindings/clock/boston-clock.h b/include/dt-bindings/clock/boston-clock.h new file mode 100644 index 0000000..25f9cd2 --- /dev/null +++ b/include/dt-bindings/clock/boston-clock.h @@ -0,0 +1,13 @@ +/* + * Copyright (C) 2016 Imagination Technologies + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __DT_BINDINGS_CLOCK_BOSTON_CLOCK_H__ +#define __DT_BINDINGS_CLOCK_BOSTON_CLOCK_H__ + +#define BOSTON_CLK_SYS 0 +#define BOSTON_CLK_CPU 1 + +#endif /* __DT_BINDINGS_CLOCK_BOSTON_CLOCK_H__ */
This patch introduces support for building U-Boot to run on the MIPS Boston development board. This is a board built around an FPGA & an Intel EG20T Platform Controller Hub, used largely as part of the development of new CPUs and their software support. It is essentially the successor to the older MIPS Malta board.
Changes in v6: - Correct 32 bit text base address in defconfigs
Changes in v5: - Mention arch revision & toolchain in README.boston - Drop platform register access now only 2 are used since clock changes
Changes in v4: - Add README.boston
Changes in v3: - Add defconfigs for 32b & 64b, big & little endian, switch to MIPSr2
Changes in v2: - Use AT instead of $1 - Use a clock driver instead of patching the DT
arch/mips/Kconfig | 16 +++ arch/mips/dts/Makefile | 1 + arch/mips/dts/img,boston.dts | 216 ++++++++++++++++++++++++++++++++++++ board/imgtec/boston/Kconfig | 16 +++ board/imgtec/boston/MAINTAINERS | 6 + board/imgtec/boston/Makefile | 9 ++ board/imgtec/boston/boston-lcd.h | 21 ++++ board/imgtec/boston/boston-regs.h | 26 +++++ board/imgtec/boston/checkboard.c | 30 +++++ board/imgtec/boston/ddr.c | 30 +++++ board/imgtec/boston/lowlevel_init.S | 56 ++++++++++ configs/boston32r2_defconfig | 40 +++++++ configs/boston32r2el_defconfig | 41 +++++++ configs/boston64r2_defconfig | 40 +++++++ configs/boston64r2el_defconfig | 41 +++++++ doc/README.boston | 58 ++++++++++ include/configs/boston.h | 68 ++++++++++++ 17 files changed, 715 insertions(+) create mode 100644 arch/mips/dts/img,boston.dts create mode 100644 board/imgtec/boston/Kconfig create mode 100644 board/imgtec/boston/MAINTAINERS create mode 100644 board/imgtec/boston/Makefile create mode 100644 board/imgtec/boston/boston-lcd.h create mode 100644 board/imgtec/boston/boston-regs.h create mode 100644 board/imgtec/boston/checkboard.c create mode 100644 board/imgtec/boston/ddr.c create mode 100644 board/imgtec/boston/lowlevel_init.S create mode 100644 configs/boston32r2_defconfig create mode 100644 configs/boston32r2el_defconfig create mode 100644 configs/boston64r2_defconfig create mode 100644 configs/boston64r2el_defconfig create mode 100644 doc/README.boston create mode 100644 include/configs/boston.h
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 21066f0..7ba0ef2 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -73,9 +73,25 @@ config MACH_PIC32 select OF_CONTROL select DM
+config TARGET_BOSTON + bool "Support Boston" + select DM + select DM_SERIAL + select OF_CONTROL + select MIPS_L1_CACHE_SHIFT_6 + select SUPPORTS_BIG_ENDIAN + select SUPPORTS_LITTLE_ENDIAN + select SUPPORTS_CPU_MIPS32_R1 + select SUPPORTS_CPU_MIPS32_R2 + select SUPPORTS_CPU_MIPS32_R6 + select SUPPORTS_CPU_MIPS64_R1 + select SUPPORTS_CPU_MIPS64_R2 + select SUPPORTS_CPU_MIPS64_R6 + endchoice
source "board/dbau1x00/Kconfig" +source "board/imgtec/boston/Kconfig" source "board/imgtec/malta/Kconfig" source "board/micronas/vct/Kconfig" source "board/pb1x00/Kconfig" diff --git a/arch/mips/dts/Makefile b/arch/mips/dts/Makefile index 2f04d73..6a5e43e 100644 --- a/arch/mips/dts/Makefile +++ b/arch/mips/dts/Makefile @@ -4,6 +4,7 @@
dtb-$(CONFIG_TARGET_AP121) += ap121.dtb dtb-$(CONFIG_TARGET_AP143) += ap143.dtb +dtb-$(CONFIG_TARGET_BOSTON) += img,boston.dtb dtb-$(CONFIG_TARGET_MALTA) += mti,malta.dtb dtb-$(CONFIG_TARGET_PIC32MZDASK) += pic32mzda_sk.dtb dtb-$(CONFIG_BOARD_TPLINK_WDR4300) += tplink_wdr4300.dtb diff --git a/arch/mips/dts/img,boston.dts b/arch/mips/dts/img,boston.dts new file mode 100644 index 0000000..2fbcb93 --- /dev/null +++ b/arch/mips/dts/img,boston.dts @@ -0,0 +1,216 @@ +/dts-v1/; + +#include <dt-bindings/clock/boston-clock.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/interrupt-controller/mips-gic.h> + +/ { + #address-cells = <1>; + #size-cells = <1>; + compatible = "img,boston"; + + chosen { + stdout-path = &uart0; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + device_type = "cpu"; + compatible = "img,mips"; + reg = <0>; + clocks = <&clk_boston BOSTON_CLK_CPU>; + }; + }; + + memory@0 { + device_type = "memory"; + reg = <0x00000000 0x10000000>; + }; + + gic: interrupt-controller { + compatible = "mti,gic"; + + interrupt-controller; + #interrupt-cells = <3>; + + timer { + compatible = "mti,gic-timer"; + interrupts = <GIC_LOCAL 1 IRQ_TYPE_NONE>; + clocks = <&clk_boston BOSTON_CLK_CPU>; + }; + }; + + pci0: pci@10000000 { + status = "disabled"; + compatible = "xlnx,axi-pcie-host-1.00.a"; + device_type = "pci"; + reg = <0x10000000 0x2000000>; + + #address-cells = <3>; + #size-cells = <2>; + #interrupt-cells = <1>; + + interrupt-parent = <&gic>; + interrupts = <GIC_SHARED 2 IRQ_TYPE_LEVEL_HIGH>; + + ranges = <0x02000000 0 0x40000000 + 0x40000000 0 0x40000000>; + + interrupt-map-mask = <0 0 0 7>; + interrupt-map = <0 0 0 1 &pci0_intc 0>, + <0 0 0 2 &pci0_intc 1>, + <0 0 0 3 &pci0_intc 2>, + <0 0 0 4 &pci0_intc 3>; + + pci0_intc: interrupt-controller { + interrupt-controller; + #address-cells = <0>; + #interrupt-cells = <1>; + }; + }; + + pci1: pci@12000000 { + status = "disabled"; + compatible = "xlnx,axi-pcie-host-1.00.a"; + device_type = "pci"; + reg = <0x12000000 0x2000000>; + + #address-cells = <3>; + #size-cells = <2>; + #interrupt-cells = <1>; + + interrupt-parent = <&gic>; + interrupts = <GIC_SHARED 1 IRQ_TYPE_LEVEL_HIGH>; + + ranges = <0x02000000 0 0x20000000 + 0x20000000 0 0x20000000>; + + interrupt-map-mask = <0 0 0 7>; + interrupt-map = <0 0 0 1 &pci1_intc 0>, + <0 0 0 2 &pci1_intc 1>, + <0 0 0 3 &pci1_intc 2>, + <0 0 0 4 &pci1_intc 3>; + + pci1_intc: interrupt-controller { + interrupt-controller; + #address-cells = <0>; + #interrupt-cells = <1>; + }; + }; + + pci2: pci@14000000 { + compatible = "xlnx,axi-pcie-host-1.00.a"; + device_type = "pci"; + reg = <0x14000000 0x2000000>; + + #address-cells = <3>; + #size-cells = <2>; + #interrupt-cells = <1>; + + interrupt-parent = <&gic>; + interrupts = <GIC_SHARED 0 IRQ_TYPE_LEVEL_HIGH>; + + ranges = <0x02000000 0 0x16000000 + 0x16000000 0 0x100000>; + + interrupt-map-mask = <0 0 0 7>; + interrupt-map = <0 0 0 1 &pci2_intc 0>, + <0 0 0 2 &pci2_intc 1>, + <0 0 0 3 &pci2_intc 2>, + <0 0 0 4 &pci2_intc 3>; + + pci2_intc: interrupt-controller { + interrupt-controller; + #address-cells = <0>; + #interrupt-cells = <1>; + }; + + pci2_root@0,0,0 { + compatible = "pci10ee,7021"; + reg = <0x00000000 0 0 0 0>; + + #address-cells = <3>; + #size-cells = <2>; + #interrupt-cells = <1>; + + eg20t_bridge@1,0,0 { + compatible = "pci8086,8800"; + reg = <0x00010000 0 0 0 0>; + + #address-cells = <3>; + #size-cells = <2>; + #interrupt-cells = <1>; + + eg20t_mac@2,0,1 { + compatible = "pci8086,8802"; + reg = <0x00020100 0 0 0 0>; + phy-reset-gpios = <&eg20t_gpio 6 GPIO_ACTIVE_LOW>; + }; + + eg20t_gpio: eg20t_gpio@2,0,2 { + compatible = "pci8086,8803"; + reg = <0x00020200 0 0 0 0>; + + gpio-controller; + #gpio-cells = <2>; + }; + + eg20t_i2c@2,12,2 { + compatible = "pci8086,8817"; + reg = <0x00026200 0 0 0 0>; + + #address-cells = <1>; + #size-cells = <0>; + + rtc@0x68 { + compatible = "st,m41t81s"; + reg = <0x68>; + }; + }; + }; + }; + }; + + plat_regs: system-controller@17ffd000 { + compatible = "img,boston-platform-regs", "syscon"; + reg = <0x17ffd000 0x1000>; + u-boot,dm-pre-reloc; + }; + + clk_boston: clock { + compatible = "img,boston-clock"; + #clock-cells = <1>; + regmap = <&plat_regs>; + u-boot,dm-pre-reloc; + }; + + reboot: syscon-reboot { + compatible = "syscon-reboot"; + regmap = <&plat_regs>; + offset = <0x10>; + mask = <0x10>; + }; + + uart0: uart@17ffe000 { + compatible = "ns16550a"; + reg = <0x17ffe000 0x1000>; + reg-shift = <2>; + reg-io-width = <4>; + + interrupt-parent = <&gic>; + interrupts = <GIC_SHARED 3 IRQ_TYPE_LEVEL_HIGH>; + + clocks = <&clk_boston BOSTON_CLK_SYS>; + + u-boot,dm-pre-reloc; + }; + + lcd: lcd@17fff000 { + compatible = "img,boston-lcd"; + reg = <0x17fff000 0x8>; + }; +}; diff --git a/board/imgtec/boston/Kconfig b/board/imgtec/boston/Kconfig new file mode 100644 index 0000000..ab76a3c --- /dev/null +++ b/board/imgtec/boston/Kconfig @@ -0,0 +1,16 @@ +if TARGET_BOSTON + +config SYS_BOARD + default "boston" + +config SYS_VENDOR + default "imgtec" + +config SYS_CONFIG_NAME + default "boston" + +config SYS_TEXT_BASE + default 0x9fc00000 if 32BIT + default 0xffffffff9fc00000 if 64BIT + +endif diff --git a/board/imgtec/boston/MAINTAINERS b/board/imgtec/boston/MAINTAINERS new file mode 100644 index 0000000..30dd481 --- /dev/null +++ b/board/imgtec/boston/MAINTAINERS @@ -0,0 +1,6 @@ +BOSTON BOARD +M: Paul Burton paul.burton@imgtec.com +S: Maintained +F: board/imgtec/boston/ +F: include/configs/boston.h +F: configs/boston_defconfig diff --git a/board/imgtec/boston/Makefile b/board/imgtec/boston/Makefile new file mode 100644 index 0000000..deda457 --- /dev/null +++ b/board/imgtec/boston/Makefile @@ -0,0 +1,9 @@ +# +# Copyright (C) 2016 Imagination Technologies +# +# SPDX-License-Identifier: GPL-2.0 +# + +obj-y += checkboard.o +obj-y += ddr.o +obj-y += lowlevel_init.o diff --git a/board/imgtec/boston/boston-lcd.h b/board/imgtec/boston/boston-lcd.h new file mode 100644 index 0000000..9f5c1b9 --- /dev/null +++ b/board/imgtec/boston/boston-lcd.h @@ -0,0 +1,21 @@ +/* + * Copyright (C) 2016 Imagination Technologies + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __BOARD_BOSTON_LCD_H__ +#define __BOARD_BOSTON_LCD_H__ + +/** + * lowlevel_display() - Display a message on Boston's LCD + * @msg: The string to display + * + * Display the string @msg on the 7 character LCD display of the Boston board. + * This is typically used for debug or to present some form of status + * indication to the user, allowing faults to be identified when things go + * wrong early enough that the UART isn't up. + */ +void lowlevel_display(const char msg[static 8]); + +#endif /* __BOARD_BOSTON_LCD_H__ */ diff --git a/board/imgtec/boston/boston-regs.h b/board/imgtec/boston/boston-regs.h new file mode 100644 index 0000000..b9dfbb4 --- /dev/null +++ b/board/imgtec/boston/boston-regs.h @@ -0,0 +1,26 @@ +/* + * Copyright (C) 2016 Imagination Technologies + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __BOARD_BOSTON_REGS_H__ +#define __BOARD_BOSTON_REGS_H__ + +#include <asm/addrspace.h> + +#define BOSTON_PLAT_BASE CKSEG1ADDR(0x17ffd000) +#define BOSTON_LCD_BASE CKSEG1ADDR(0x17fff000) + +/* + * Platform Register Definitions + */ +#define BOSTON_PLAT_CORE_CL (BOSTON_PLAT_BASE + 0x04) + +#define BOSTON_PLAT_DDR3STAT (BOSTON_PLAT_BASE + 0x14) +# define BOSTON_PLAT_DDR3STAT_CALIB (1 << 2) + +#define BOSTON_PLAT_DDRCONF0 (BOSTON_PLAT_BASE + 0x38) +# define BOSTON_PLAT_DDRCONF0_SIZE (0xf << 0) + +#endif /* __BOARD_BOSTON_REGS_H__ */ diff --git a/board/imgtec/boston/checkboard.c b/board/imgtec/boston/checkboard.c new file mode 100644 index 0000000..93eae7f --- /dev/null +++ b/board/imgtec/boston/checkboard.c @@ -0,0 +1,30 @@ +/* + * Copyright (C) 2016 Imagination Technologies + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> + +#include <asm/io.h> +#include <asm/mipsregs.h> + +#include "boston-lcd.h" +#include "boston-regs.h" + +int checkboard(void) +{ + u32 changelist; + + lowlevel_display("U-boot "); + + printf("Board: MIPS Boston\n"); + + printf("CPU: 0x%08x", read_c0_prid()); + changelist = __raw_readl((uint32_t *)BOSTON_PLAT_CORE_CL); + if (changelist > 1) + printf(" cl%x", changelist); + putc('\n'); + + return 0; +} diff --git a/board/imgtec/boston/ddr.c b/board/imgtec/boston/ddr.c new file mode 100644 index 0000000..ceffef6 --- /dev/null +++ b/board/imgtec/boston/ddr.c @@ -0,0 +1,30 @@ +/* + * Copyright (C) 2016 Imagination Technologies + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> + +#include <asm/io.h> + +#include "boston-regs.h" + +phys_size_t initdram(int board_type) +{ + u32 ddrconf0 = __raw_readl((uint32_t *)BOSTON_PLAT_DDRCONF0); + + return (phys_size_t)(ddrconf0 & BOSTON_PLAT_DDRCONF0_SIZE) << 30; +} + +ulong board_get_usable_ram_top(ulong total_size) +{ + DECLARE_GLOBAL_DATA_PTR; + + if (gd->ram_top < CONFIG_SYS_SDRAM_BASE) { + /* 2GB wrapped around to 0 */ + return CKSEG0ADDR(256 << 20); + } + + return min_t(unsigned long, gd->ram_top, CKSEG0ADDR(256 << 20)); +} diff --git a/board/imgtec/boston/lowlevel_init.S b/board/imgtec/boston/lowlevel_init.S new file mode 100644 index 0000000..0c01aa9 --- /dev/null +++ b/board/imgtec/boston/lowlevel_init.S @@ -0,0 +1,56 @@ +/* + * Copyright (C) 2016 Imagination Technologies + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <config.h> + +#include <asm/addrspace.h> +#include <asm/asm.h> +#include <asm/mipsregs.h> +#include <asm/regdef.h> + +#include "boston-regs.h" + +.data + +msg_ddr_cal: .ascii "DDR Cal " +msg_ddr_ok: .ascii "DDR OK " + +.text + +LEAF(lowlevel_init) + move s0, ra + + PTR_LA a0, msg_ddr_cal + bal lowlevel_display + + PTR_LI t0, BOSTON_PLAT_DDR3STAT +1: lw t1, 0(t0) + andi t1, t1, BOSTON_PLAT_DDR3STAT_CALIB + beqz t1, 1b + + PTR_LA a0, msg_ddr_ok + bal lowlevel_display + + move v0, zero + jr s0 + END(lowlevel_init) + +LEAF(lowlevel_display) + .set push + .set noat + PTR_LI AT, BOSTON_LCD_BASE +#ifdef CONFIG_64BIT + ld k1, 0(a0) + sd k1, 0(AT) +#else + lw k1, 0(a0) + sw k1, 0(AT) + lw k1, 4(a0) + sw k1, 4(AT) +#endif + .set pop +1: jr ra + END(lowlevel_display) diff --git a/configs/boston32r2_defconfig b/configs/boston32r2_defconfig new file mode 100644 index 0000000..8dad22e --- /dev/null +++ b/configs/boston32r2_defconfig @@ -0,0 +1,40 @@ +CONFIG_MIPS=y +CONFIG_TARGET_BOSTON=y +CONFIG_SYS_TEXT_BASE=0x9fc00000 +# CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set +# CONFIG_MIPS_BOOT_ENV_LEGACY is not set +CONFIG_MIPS_BOOT_FDT=y +CONFIG_DEFAULT_DEVICE_TREE="img,boston" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_BEST_MATCH=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_SYS_NO_FLASH=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="boston # " +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MEMTEST=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y +CONFIG_CMD_LINK_LOCAL=y +CONFIG_CMD_TIME=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_EMBED=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_CLK=y +CONFIG_DM_ETH=y +CONFIG_PCH_GBE=y +CONFIG_DM_PCI=y +CONFIG_PCI_XILINX=y +CONFIG_SYS_NS16550=y +CONFIG_LZ4=y diff --git a/configs/boston32r2el_defconfig b/configs/boston32r2el_defconfig new file mode 100644 index 0000000..6a74961 --- /dev/null +++ b/configs/boston32r2el_defconfig @@ -0,0 +1,41 @@ +CONFIG_MIPS=y +CONFIG_TARGET_BOSTON=y +CONFIG_SYS_TEXT_BASE=0x9fc00000 +CONFIG_SYS_LITTLE_ENDIAN=y +# CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set +# CONFIG_MIPS_BOOT_ENV_LEGACY is not set +CONFIG_MIPS_BOOT_FDT=y +CONFIG_DEFAULT_DEVICE_TREE="img,boston" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_BEST_MATCH=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_SYS_NO_FLASH=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="boston # " +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MEMTEST=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y +CONFIG_CMD_LINK_LOCAL=y +CONFIG_CMD_TIME=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_EMBED=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_CLK=y +CONFIG_DM_ETH=y +CONFIG_PCH_GBE=y +CONFIG_DM_PCI=y +CONFIG_PCI_XILINX=y +CONFIG_SYS_NS16550=y +CONFIG_LZ4=y diff --git a/configs/boston64r2_defconfig b/configs/boston64r2_defconfig new file mode 100644 index 0000000..fdbb505 --- /dev/null +++ b/configs/boston64r2_defconfig @@ -0,0 +1,40 @@ +CONFIG_MIPS=y +CONFIG_TARGET_BOSTON=y +CONFIG_CPU_MIPS64_R2=y +# CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set +# CONFIG_MIPS_BOOT_ENV_LEGACY is not set +CONFIG_MIPS_BOOT_FDT=y +CONFIG_DEFAULT_DEVICE_TREE="img,boston" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_BEST_MATCH=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_SYS_NO_FLASH=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="boston # " +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MEMTEST=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y +CONFIG_CMD_LINK_LOCAL=y +CONFIG_CMD_TIME=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_EMBED=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_CLK=y +CONFIG_DM_ETH=y +CONFIG_PCH_GBE=y +CONFIG_DM_PCI=y +CONFIG_PCI_XILINX=y +CONFIG_SYS_NS16550=y +CONFIG_LZ4=y diff --git a/configs/boston64r2el_defconfig b/configs/boston64r2el_defconfig new file mode 100644 index 0000000..69368e9 --- /dev/null +++ b/configs/boston64r2el_defconfig @@ -0,0 +1,41 @@ +CONFIG_MIPS=y +CONFIG_TARGET_BOSTON=y +CONFIG_SYS_LITTLE_ENDIAN=y +CONFIG_CPU_MIPS64_R2=y +# CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set +# CONFIG_MIPS_BOOT_ENV_LEGACY is not set +CONFIG_MIPS_BOOT_FDT=y +CONFIG_DEFAULT_DEVICE_TREE="img,boston" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_BEST_MATCH=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_SYS_NO_FLASH=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="boston # " +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MEMTEST=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y +CONFIG_CMD_LINK_LOCAL=y +CONFIG_CMD_TIME=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_EMBED=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_CLK=y +CONFIG_DM_ETH=y +CONFIG_PCH_GBE=y +CONFIG_DM_PCI=y +CONFIG_PCI_XILINX=y +CONFIG_SYS_NS16550=y +CONFIG_LZ4=y diff --git a/doc/README.boston b/doc/README.boston new file mode 100644 index 0000000..38f6710 --- /dev/null +++ b/doc/README.boston @@ -0,0 +1,58 @@ +MIPS Boston Development Board + +--------- + About +--------- + +The MIPS Boston development board is built around an FPGA & 3 PCIe controllers, +one of which is connected to an Intel EG20T Platform Controller Hub which +provides most connectivity to the board. It is used during the development & +testing of both new CPUs and the software support for them. It is essentially +the successor of the older MIPS Malta board. + +-------- + QEMU +-------- + +U-Boot can be run on a currently out-of-tree branch of QEMU with support for +the Boston board added. This QEMU code can currently be found in the "boston" +branch of git://git.linux-mips.org/pub/scm/paul/qemu.git and used like so: + + $ git clone git://git.linux-mips.org/pub/scm/paul/qemu.git -b boston + $ cd qemu + $ ./configure --target-list=mips64el-softmmu + $ make + $ ./mips64el-softmmu/qemu-system-mips64el -M boston -m 2G \ + -bios u-boot.bin -serial stdio + +Please note that QEMU will default to emulating the I6400 CPU which implements +the MIPS64r6 ISA, and at the time of writing doesn't implement any earlier CPUs +with support for the CPS features the Boston board relies upon. You will +therefore need to configure U-Boot to build for MIPSr6 in order to obtain a +binary that will work in QEMU. + +------------- + Toolchain +------------- + +If building for MIPSr6 then you will need a toolchain including GCC 5.x or +newer, or the Codescape toolchain available for download from Imagination +Technologies: + + http://codescape-mips-sdk.imgtec.com/components/toolchain/2015.06-05/ + +The "IMG GNU Linux Toolchain" is capable of building for all current MIPS ISAs, +architecture revisions & both endiannesses. + +-------- + TODO +-------- + + - AHCI support + - CPU driver + - Exception handling (+UHI?) + - Flash support + - IOCU support + - L2 cache support + - More general LCD display driver + - Multi-arch-variant multi-endian fat binary diff --git a/include/configs/boston.h b/include/configs/boston.h new file mode 100644 index 0000000..e25c8d5 --- /dev/null +++ b/include/configs/boston.h @@ -0,0 +1,68 @@ +/* + * Copyright (C) 2016 Imagination Technologies + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __CONFIGS_BOSTON_H__ +#define __CONFIGS_BOSTON_H__ + +/* + * General board configuration + */ +#define CONFIG_DISPLAY_BOARDINFO + +/* + * CPU + */ +#define CONFIG_SYS_MIPS_TIMER_FREQ 30000000 + +/* + * PCI + */ +#define CONFIG_PCI +#define CONFIG_PCI_PNP +#define CONFIG_CMD_PCI + +/* + * Environment + */ +#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_ENV_SIZE 1024 + +/* + * Memory map + */ +#ifdef CONFIG_64BIT +# define CONFIG_SYS_SDRAM_BASE 0xffffffff80000000 +#else +# define CONFIG_SYS_SDRAM_BASE 0x80000000 +#endif + +#define CONFIG_SYS_INIT_SP_OFFSET 0x400000 + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x100000) + +#define CONFIG_SYS_MEMTEST_START (CONFIG_SYS_SDRAM_BASE + 0) +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x10000000) + +#define CONFIG_SYS_MALLOC_LEN (256 * 1024) + +/* + * Console + */ +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP +#define CONFIG_BAUDRATE 115200 + +/* + * Flash + */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 + +#endif /* __CONFIGS_BOSTON_H__ */
Joe Hershberger
Paul Burton
