[U-Boot] ARM relocation, board_init() now called AFTER relocation
4 Oct
2010
4 Oct
'10
6:44 p.m.
Hello,
before the relocation patches, and if relocation is disabled (CONFIG_SYS_ARM_WITHOUT_RELOC) board_init() is called _very_ early, before relocation.
With relocation enabled, board_init() is called after relocation and when BSS is available.
--->> Board maintainers should look at their board_init() and check that they do not do "early init" stuff there. Most AT91 boards, as I can see do high level inits (requiring bss), which is NOW ok to do (with relocation) and actually was WRONG before that. (Or you might say, board_init() was until now called in the wrong place)
Reinhard
PS: realizing that solved my ENV READ CRC issue ;) - the GPIO pins were initialized in board_init() which is too late now.
5333
Reinhard Meyer
