[U-Boot] [PATCHv2 0/2] ARM: OMAP3: Revamp IGEP default configuration
This is the second version of patch series to revamp the default configuration for all IGEP boards. The purpose of these patches is use the boot script used in others OMAP3-based boards.
Tested on IGEP v2 board and IGEP module.
* changes since version 1: * Fix nandboot: should be 'onenand read' instead of 'nand read' * Also revamp default configuration on IGEP module
Enric Balletbo i Serra (2): ARM: OMAP3: Revamp IGEP v2 default configuration ARM: OMAP3: Revamp IGEP module default configuration
include/configs/igep0020.h | 57 ++++++++++++++++++++++++++++++++++++++++---- include/configs/igep0030.h | 57 ++++++++++++++++++++++++++++++++++++++++---- 2 files changed, 104 insertions(+), 10 deletions(-)
The default IGEP configuration doesn't do anything useful; using some boot.scr search logic like BeagleBoard is much more useful.
Signed-off-by: Loïc Minier loic.minier@linaro.org Signed-off-by: Enric Balletbo i Serra eballetbo@iseebcn.com --- include/configs/igep0020.h | 57 ++++++++++++++++++++++++++++++++++++++++---- 1 files changed, 52 insertions(+), 5 deletions(-)
diff --git a/include/configs/igep0020.h b/include/configs/igep0020.h index c19ecc0..fc15a9c 100644 --- a/include/configs/igep0020.h +++ b/include/configs/igep0020.h @@ -129,14 +129,61 @@ */ #define CONFIG_TWL4030_POWER 1
-/* Environment information */ -#define CONFIG_BOOTCOMMAND \ - "mmc init 0 ; fatload mmc 0 0x80000000 setup.ini ; source \0" - #define CONFIG_BOOTDELAY 3
#define CONFIG_EXTRA_ENV_SETTINGS \ - "usbtty=cdc_acm\0" + "usbtty=cdc_acm\0" \ + "loadaddr=0x82000000\0" \ + "usbtty=cdc_acm\0" \ + "console=ttyS2,115200n8\0" \ + "mpurate=500\0" \ + "vram=12M\0" \ + "dvimode=1024x768MR-16@60\0" \ + "defaultdisplay=dvi\0" \ + "mmcdev=0\0" \ + "mmcroot=/dev/mmcblk0p2 rw\0" \ + "mmcrootfstype=ext3 rootwait\0" \ + "nandroot=/dev/mtdblock4 rw\0" \ + "nandrootfstype=jffs2\0" \ + "mmcargs=setenv bootargs console=${console} " \ + "mpurate=${mpurate} " \ + "vram=${vram} " \ + "omapfb.mode=dvi:${dvimode} " \ + "omapfb.debug=y " \ + "omapdss.def_disp=${defaultdisplay} " \ + "root=${mmcroot} " \ + "rootfstype=${mmcrootfstype}\0" \ + "nandargs=setenv bootargs console=${console} " \ + "mpurate=${mpurate} " \ + "vram=${vram} " \ + "omapfb.mode=dvi:${dvimode} " \ + "omapfb.debug=y " \ + "omapdss.def_disp=${defaultdisplay} " \ + "root=${nandroot} " \ + "rootfstype=${nandrootfstype}\0" \ + "loadbootscript=fatload mmc ${mmcdev} ${loadaddr} boot.scr\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source ${loadaddr}\0" \ + "loaduimage=fatload mmc ${mmcdev} ${loadaddr} uImage\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "bootm ${loadaddr}\0" \ + "nandboot=echo Booting from onenand ...; " \ + "run nandargs; " \ + "onenand read ${loadaddr} 280000 400000; " \ + "bootm ${loadaddr}\0" \ + +#define CONFIG_BOOTCOMMAND \ + "if mmc rescan ${mmcdev}; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run nandboot; " \ + "fi; " \ + "fi; " \ + "else run nandboot; fi"
#define CONFIG_AUTO_COMPLETE 1
Signed-off-by: Enric Balletbo i Serra eballetbo@iseebcn.com --- include/configs/igep0030.h | 57 ++++++++++++++++++++++++++++++++++++++++---- 1 files changed, 52 insertions(+), 5 deletions(-)
diff --git a/include/configs/igep0030.h b/include/configs/igep0030.h index 1325bfa..713b1b9 100644 --- a/include/configs/igep0030.h +++ b/include/configs/igep0030.h @@ -127,14 +127,61 @@ */ #define CONFIG_TWL4030_POWER 1
- changes since version 1:
- Fix nandboot: should be 'onenand read' instead of 'nand read'
- Also revamp default configuration on IGEP module
Thanks
Pushed to u-boot-ti
--Sandeep
Paulraj, Sandeep
