[U-Boot] [PATCH] UEC PHY: Speed up initial PHY neg.
Instead of always performing an autoneg, check if the PHY already has a link and if it matches one of the requested modes. Initially only 100MbFD is optimized this way.
Signed-off-by: Joakim Tjernlund Joakim.Tjernlund@transmode.se --- drivers/qe/uec_phy.c | 9 +++++++++ 1 files changed, 9 insertions(+), 0 deletions(-)
diff --git a/drivers/qe/uec_phy.c b/drivers/qe/uec_phy.c index 3baffe4..5237960 100644 --- a/drivers/qe/uec_phy.c +++ b/drivers/qe/uec_phy.c @@ -351,6 +351,15 @@ static int marvell_config_aneg (struct uec_mii_info *mii_info) static int genmii_config_aneg (struct uec_mii_info *mii_info) { if (mii_info->autoneg) { + /* Speed up the common case, if link is already up, speed and + duplex match, skip auto neg as it already matches */ + if (!genmii_read_status(mii_info) && mii_info->link) + if (mii_info->duplex == DUPLEX_FULL && + mii_info->speed == SPEED_100) + if (mii_info->advertising & + ADVERTISED_100baseT_Full) + return 0; + config_genmii_advert (mii_info); genmii_restart_aneg (mii_info); } else
wish the common net/miiphy layer had similar functionality ... -mike
vapierfilter@gmail.com wrote on 2010/08/10 22:23:19:
Thanks, too bad that there is a long way left to common PHY code ..
Jocke
Hi Jocke,
Isn't it about time that we think about _not_ stopping the ethernet device after every transaction?
Why not initialize it for the first transfer and stop it once we boot a kernel? For USB for example we do just that.
Sorry for not providing a concrete patch, but I felt it is worthwhile to throw that thought into the discussion as it pops up more and more often nowadays. For example usb-cdc which currently deregisters the network device on the host side after _every_ transfer....
Cheers Detlev
Detlev Zundel dzu@denx.de wrote on 2010/08/12 14:58:47:
Hi Jocke,
Hi Detlev
UEC does this already, my patch was to address the initial delay you get for the first transaction. Now my PHY based boards gets the link up just as quick as Fixed PHY for the first transaction.
Jocke
Hi Jocke,
Hi Detlev
Forgive me to not look into this any deeper, but do I understand you correctly that you do this by essentially no-oping the eth_halt() function? Isn't this then effectively violating what net.c expects the device to do?
I was thinking that net.c itself should not do this continous start/stop thing as it has problems on many interfaces. On one ARM machine I've again seen problems with the MAC address programming because the eth_halt() resets the controller and so it forgets its address again. Also the USB-CDC example where the _whole interface_ on the host side is being torn down after each tftp transfer prompts me to think along this line.
So in effect I guess my response was rather a ping to Ben, sorry for that ;)
Cheers Detlev
Detlev Zundel dzu@denx.de wrote on 2010/08/13 10:20:46:
Hi Jocke,
Hi Detlev
uec_halt stops the controller as it should. Uec forces an auto_neg cycle on the PHY the first it is called, after that it just uses the result from the first auto neg. My patch simply skip the auto neg. pass iff the PHY already has a link and duplex&speed already matches what uec wants.
Jocke
Hi Detlev,
On 8/13/2010 1:20 AM, Detlev Zundel wrote:
Hi Jocke,
Hi Detlev
Sorry for the delay on this. I'm all for changing the existing behavior. It seems to me that the only time we would ever want to wind an interface down is if we switch the active one (even then, I'm not sure). My world view is limited, but I can't imagine that even changing interfaces happens much in real world U-boot usage, that is the non-lab, non-interactive use cases. What would you think about adding something like ifup and ifdown commands so that users could explicitly start/stop interfaces?
Cheers Detlev
regards, Ben
Ben Warren biggerbadderben@gmail.com wrote on 2010/08/23 09:08:17:
Hi Detlev,
Hi Jocke,
Hi Detlev
Sure, bringing I/F's up and down needlessly isn't a good thing. However my patch doesn't change that behaviour. It only optimizes the need for a PHY AN the first time one performs a eth transaction.
Jocke
Cheers Detlev
regards, Ben
Hi Jocke,
On Monday, August 23, 2010, Joakim Tjernlund joakim.tjernlund@transmode.se wrote:
Hi Detlev,
Hi Jocke,
Hi Detlev
I know. I guess my e-mail was more directed towards Detlev's musings.
Jocke
Regards, Ben
Ben Warren biggerbadderben@gmail.com wrote on 2010/08/23 16:12:07:
Hi Jocke,
Hi Detlev,
Hi Jocke,
> Instead of always performing an autoneg, check if the PHY > already has a link and if it matches one of the requested > modes. Initially only 100MbFD is optimized this way. Isn't it about time that we think about _not_ stopping the ethernet device after every transaction?
Hi Detlev
Ah, great. You will apply this patch then?
Jocke
Hi Ben,
[Jocke deleted from CC as this is not about the patch anymore]
Actually I was thinking of an automatic initialisiation once we do a network transfer. This would be more in line with the current command line interface. For this we would need a state variable per device and start the device if it is down.
The "ifdown" _may_ be implemented as a command, but I think this should be done automatically once we boot a kernel. For USB we already have to do something like this as USB host controllers tend to DMA frame numbers into memory as long as they are running. This was an especially difficult problem to diagnose back then. From this lesson I think we should learn and call "stop" methods for every initialized device.
What do you think?
Once more this is going into the "device" model dicussion that we already thought about a while ago [1]. Maybe someday somebody finds some time and starts to work on it ;)
Cheers Detlev
[1] http://www.denx.de/wiki/view/U-Boot/OLSUbootBOF
Hi Ben,
But I still want to know what will happen to it. I didn't send this patch to start another discussion :)
Jocke
Hi Jocke,
Signed-off-by: Joakim TjernlundJoakim.Tjernlund@transmode.se
if (!genmii_read_status(mii_info)&& mii_info->link)
if (mii_info->duplex == DUPLEX_FULL&&
if (mii_info->advertising&
- config_genmii_advert (mii_info); genmii_restart_aneg (mii_info); } else
Applied to net/next
regards, Ben
participants (5)
Ben Warren
Detlev Zundel
Joakim Tjernlund
Joakim Tjernlund
Mike Frysinger
