Re: [U-Boot] [PATCH v2 1/8] armv8: Add workaround for USB erratum A-009008
On 01/30/2017 05:42 AM, Suresh Gupta wrote:
USB High Speed (HS) EYE Height Adjustment USB HS speed eye diagram fails with the default value at many corners, particularly at a high temperature
Optimal eye at TXVREFTUNE value to 1001 is observed, change set the same vale.
Signed-off-by: Sriram Dash sriram.dash@nxp.com Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com Signed-off-by: Suresh Gupta suresh.gupta@nxp.com
Changes in v2: None
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 6 ++++++ arch/arm/cpu/armv8/fsl-layerscape/soc.c | 25 ++++++++++++++++++++++ .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 6 ++++++ .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 1 + 4 files changed, 38 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index de0b580..666a3d1 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -18,6 +18,7 @@ config ARCH_LS1043A select SYS_FSL_ERRATUM_A009942 select SYS_FSL_ERRATUM_A010315 select SYS_FSL_ERRATUM_A010539
- select SYS_FSL_ERRATUM_A009008 select SYS_FSL_HAS_DDR3 select SYS_FSL_HAS_DDR4
@@ -33,6 +34,7 @@ config ARCH_LS1046A select SYS_FSL_ERRATUM_A009942 select SYS_FSL_ERRATUM_A010165 select SYS_FSL_ERRATUM_A010539
- select SYS_FSL_ERRATUM_A009008 select SYS_FSL_HAS_DDR4 select SYS_FSL_SRDS_2
@@ -58,6 +60,7 @@ config ARCH_LS2080A select SYS_FSL_ERRATUM_A009803 select SYS_FSL_ERRATUM_A009942 select SYS_FSL_ERRATUM_A010165
config FSL_LSCH2 bool @@ -102,6 +105,9 @@ config SYS_FSL_ERRATUM_A010315 config SYS_FSL_ERRATUM_A010539 bool "Workaround for PIN MUX erratum A010539"
+config SYS_FSL_ERRATUM_A009008
- bool "Workaround for USB PHY erratum A009008"
config MAX_CPUS int "Maximum number of CPUs permitted for Layerscape" default 4 if ARCH_LS1043A diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 2f54625..951ccba 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -52,6 +52,29 @@ bool soc_has_aiop(void) return false; }
+static void erratum_a009008(void) +{ +#ifdef CONFIG_SYS_FSL_ERRATUM_A009008 +#if defined(CONFIG_LS1043A) || defined(CONFIG_LS1046A)
Should this be CONFIG_FSL_LSCH2? If it has to be SoC name, use CONFIG_ARCH_LS1043A. Same comment goes to other patches in this set.
York
york sun
