[U-Boot] [PATCH] arm: socfpga: Move generated files into qts subdir
Move all the files generated by Quartus into the qts/ subdir of the board/altera/socfpga dir to make them explicitly separate from the generic U-Boot code.
Signed-off-by: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com --- board/altera/socfpga/Makefile | 2 +- board/altera/socfpga/qts/Makefile | 7 +++++++ board/altera/socfpga/{ => qts}/iocsr_config.c | 0 board/altera/socfpga/{ => qts}/iocsr_config.h | 0 board/altera/socfpga/{ => qts}/pinmux_config.c | 0 board/altera/socfpga/{ => qts}/pinmux_config.h | 0 board/altera/socfpga/{ => qts}/pll_config.h | 0 include/configs/socfpga_arria5.h | 6 +++--- include/configs/socfpga_cyclone5.h | 6 +++--- 9 files changed, 14 insertions(+), 7 deletions(-) create mode 100644 board/altera/socfpga/qts/Makefile rename board/altera/socfpga/{ => qts}/iocsr_config.c (100%) rename board/altera/socfpga/{ => qts}/iocsr_config.h (100%) rename board/altera/socfpga/{ => qts}/pinmux_config.c (100%) rename board/altera/socfpga/{ => qts}/pinmux_config.h (100%) rename board/altera/socfpga/{ => qts}/pll_config.h (100%)
diff --git a/board/altera/socfpga/Makefile b/board/altera/socfpga/Makefile index c867f73..d960394 100644 --- a/board/altera/socfpga/Makefile +++ b/board/altera/socfpga/Makefile @@ -7,4 +7,4 @@ #
obj-y := socfpga.o -obj-$(CONFIG_SPL_BUILD) += pinmux_config.o iocsr_config.o +obj-$(CONFIG_SPL_BUILD) += qts/ diff --git a/board/altera/socfpga/qts/Makefile b/board/altera/socfpga/qts/Makefile new file mode 100644 index 0000000..dbcedd8 --- /dev/null +++ b/board/altera/socfpga/qts/Makefile @@ -0,0 +1,7 @@ +# +# (C) Copyright 2015 Marek Vasut marex@denx.de +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += pinmux_config.o iocsr_config.o diff --git a/board/altera/socfpga/iocsr_config.c b/board/altera/socfpga/qts/iocsr_config.c similarity index 100% rename from board/altera/socfpga/iocsr_config.c rename to board/altera/socfpga/qts/iocsr_config.c diff --git a/board/altera/socfpga/iocsr_config.h b/board/altera/socfpga/qts/iocsr_config.h similarity index 100% rename from board/altera/socfpga/iocsr_config.h rename to board/altera/socfpga/qts/iocsr_config.h diff --git a/board/altera/socfpga/pinmux_config.c b/board/altera/socfpga/qts/pinmux_config.c similarity index 100% rename from board/altera/socfpga/pinmux_config.c rename to board/altera/socfpga/qts/pinmux_config.c diff --git a/board/altera/socfpga/pinmux_config.h b/board/altera/socfpga/qts/pinmux_config.h similarity index 100% rename from board/altera/socfpga/pinmux_config.h rename to board/altera/socfpga/qts/pinmux_config.h diff --git a/board/altera/socfpga/pll_config.h b/board/altera/socfpga/qts/pll_config.h similarity index 100% rename from board/altera/socfpga/pll_config.h rename to board/altera/socfpga/qts/pll_config.h diff --git a/include/configs/socfpga_arria5.h b/include/configs/socfpga_arria5.h index 5a4417f..48744bc 100644 --- a/include/configs/socfpga_arria5.h +++ b/include/configs/socfpga_arria5.h @@ -7,9 +7,9 @@ #define __CONFIG_SOCFPGA_ARRIA5_H__
#include <asm/arch/socfpga_base_addrs.h> -#include "../../board/altera/socfpga/pinmux_config.h" -#include "../../board/altera/socfpga/iocsr_config.h" -#include "../../board/altera/socfpga/pll_config.h" +#include "../../board/altera/socfpga/qts/pinmux_config.h" +#include "../../board/altera/socfpga/qts/iocsr_config.h" +#include "../../board/altera/socfpga/qts/pll_config.h"
/* U-Boot Commands */ #define CONFIG_SYS_NO_FLASH diff --git a/include/configs/socfpga_cyclone5.h b/include/configs/socfpga_cyclone5.h index 9a9c85a..e8cd11d 100644 --- a/include/configs/socfpga_cyclone5.h +++ b/include/configs/socfpga_cyclone5.h @@ -7,9 +7,9 @@ #define __CONFIG_SOCFPGA_CYCLONE5_H__
Applied to u-boot-socfpga/master .
Best regards, Marek Vasut
