[PATCH v2] arm64: zynqmp: Introduce kria SOM defconfig
Enable the initial kria SOM specific configurations like pinctrl, pinconf etc. Also add the environment file.
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com --- Changes in v2: - Updated the CONFIG_ENV_OFFSET_REDUND - Updated the CONFIG_SF_DEFAULT_SPEED to 30000000 - Enabled the CONFIG_VIDEO_ZYNQMP_DPSUB - Fixed minor changes in zynqmp_kria.env --- board/xilinx/zynqmp/zynqmp_kria.env | 67 ++++++++ configs/xilinx_zynqmp_kria_defconfig | 227 +++++++++++++++++++++++++++ 2 files changed, 294 insertions(+) create mode 100644 board/xilinx/zynqmp/zynqmp_kria.env create mode 100644 configs/xilinx_zynqmp_kria_defconfig
diff --git a/board/xilinx/zynqmp/zynqmp_kria.env b/board/xilinx/zynqmp/zynqmp_kria.env new file mode 100644 index 0000000000..9140694d41 --- /dev/null +++ b/board/xilinx/zynqmp/zynqmp_kria.env @@ -0,0 +1,67 @@ +autoload=no +baudrate=115200 +boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr} +boot_efi_binary=if fdt addr ${fdt_addr_r}; then bootefi bootmgr ${fdt_addr_r};else bootefi bootmgr ${fdtcontroladdr};fi;load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootaa64.efi; if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi +boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}${boot_syslinux_conf} +boot_net_usb_start=usb start +boot_prefixes=/ /boot/ +boot_script_dhcp=boot.scr.uimg +boot_scripts=boot.scr.uimg boot.scr +boot_syslinux_conf=extlinux/extlinux.conf +bootcmd_dhcp=run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; setenv efi_old_vci ${bootp_vci};setenv efi_old_arch ${bootp_arch};setenv bootp_vci PXEClient:Arch:00011:UNDI:003000;setenv bootp_arch 0xb;if dhcp ${kernel_addr_r}; then tftpboot ${fdt_addr_r} dtb/${efi_fdtfile};if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi;fi;setenv bootp_vci ${efi_old_vci};setenv bootp_arch ${efi_old_arch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci; +bootcmd_jtag=echo JTAG: Trying to boot script at ${scriptaddr} && source ${scriptaddr}; echo JTAG: SCRIPT FAILED: continuing...; +bootcmd_mmc0=devnum=0; run mmc_boot +bootcmd_mmc1=devnum=1; run mmc_boot +bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi +bootcmd_usb0=devnum=0; run usb_boot +bootcmd_usb1=devnum=1; run usb_boot +bootcmd_usb2=devnum=2; run usb_boot +bootcmd_usb3=devnum=3; run usb_boot +bootdelay=2 +bootfstype=fat +bootm_low=0 +bootm_size=0x80000000 +distro_bootcmd=scsi_need_init=; for target in ${boot_targets}; do run bootcmd_${target}; done +efi_dtb_prefixes=/ /dtb/ /dtb/current/ +fdt_addr_r=0x40000000 +fdt_high=0x10000000 +fileaddr=0x18000000 +initrd_high=0x79000000 +kernel_addr_r=0x18000000 +load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile} +mmc_boot=if mmc dev ${devnum}; then devtype=mmc; run scan_dev_for_boot_part; fi +pxefile_addr_r=0x10000000 +ramdisk_addr_r=0x02100000 +scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;run scan_dev_for_efi; +scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done; setenv devplist +scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${efi_fdtfile}; then run load_efi_dtb; fi;done;if test -e ${devtype} ${devnum}:${distro_bootpart} efi/boot/bootaa64.efi; then echo Found EFI removable media binary efi/boot/bootaa64.efi; run boot_efi_binary; echo EFI LOAD FAILED: continuing...; fi; setenv efi_fdtfile +scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${boot_syslinux_conf}; then echo Found ${prefix}${boot_syslinux_conf}; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi +scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done +script_offset_f=0x3e80000 +script_size_f=0x80000 +scriptaddr=0x20000000 +usb_boot=usb start; if usb dev ${devnum}; then devtype=usb; run scan_dev_for_boot_part; fi +preboot=setenv boot_targets; setenv modeboot; run board_setup + +# SOM specific boot methods +som_cc_boot=if test ${card1_name} = SCK-KV-G; then setenv boot_targets mmc1 usb0 usb1 usb2 usb3 pxe dhcp && run distro_bootcmd; elif test ${card1_name} = SCK-KR-G; then setenv boot_targets usb0 usb1 usb2 usb3 pxe dhcp && run distro_bootcmd; else test ${card1_name} = SCK-KD-G; setenv boot_targets usb0 usb1 usb2 usb3 pxe dhcp && run distro_bootcmd; fi;" +som_mmc_boot=setenv boot_targets mmc0 && run distro_bootcmd + +k26_starter=SMK-K26-XCL2G +k24_starter=SMK-K24-XCL2G +bootcmd=setenv model $board_name && if setexpr model gsub .*$k24_starter* $k24_starter || setexpr model gsub .*$k26_starter* $k26_starter; then run som_cc_boot; else run som_mmc_boot; run som_cc_boot; fi + +usb_hub_init=mw 1000 0056 && sleep 1 && i2c write 1000 2d aa 2 -s + +# usb hub init +kv260_setup=i2c dev 1 && run usb_hub_init +# usb hub init +kr260_setup=i2c dev 1 && run usb_hub_init; i2c dev 2 && run usb_hub_init; +# usb hub init with enabling PM nodes for ... +kd240_setup=i2c dev 0 && run usb_hub_init;zynqmp pmufw node 33; zynqmp pmufw node 47 + +board_setup=\ +if test ${card1_name} = SCK-KV-G; then run kv260_setup; fi;\ +if test ${card1_name} = SCK-KR-G; then run kr260_setup; fi;\ +if test ${card1_name} = SCK-KD-G; then run kd240_setup; fi; + diff --git a/configs/xilinx_zynqmp_kria_defconfig b/configs/xilinx_zynqmp_kria_defconfig new file mode 100644 index 0000000000..68232cbadd --- /dev/null +++ b/configs/xilinx_zynqmp_kria_defconfig @@ -0,0 +1,227 @@ +CONFIG_ARM=y +CONFIG_POSITION_INDEPENDENT=y +CONFIG_ARCH_ZYNQMP=y +CONFIG_TEXT_BASE=0x8000000 +CONFIG_SYS_MALLOC_LEN=0x4040000 +CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_ENV_SOURCE_FILE="zynqmp_kria" +CONFIG_SF_DEFAULT_SPEED=30000000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_SECT_SIZE=0x20000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="zynqmp-smk-k26-revA" +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_DM_RESET=y +CONFIG_SPL_STACK_R_ADDR=0x18000000 +CONFIG_SPL_STACK=0xfffffffc +CONFIG_SPL_SIZE_LIMIT=0x2a000 +CONFIG_SPL=y +CONFIG_ENV_OFFSET_REDUND=0x2220000 +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y +CONFIG_CMD_FRU=y +CONFIG_SYS_LOAD_ADDR=0x8000000 +CONFIG_ENV_ADDR=0x2200000 +CONFIG_AHCI=y +CONFIG_SYS_MEMTEST_START=0x00000000 +CONFIG_SYS_MEMTEST_END=0x00001000 +CONFIG_REMAKE_ELF=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x10000000 +CONFIG_DISTRO_DEFAULTS=y +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_USE_PREBOOT=y +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_CLOCKS=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_BSS_MAX_SIZE=0x80000 +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_FS_LOAD_KERNEL_NAME="" +CONFIG_SPL_FS_LOAD_ARGS_NAME="" +CONFIG_SPL_FPGA=y +CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x8000000 +CONFIG_SPL_RAM_SUPPORT=y +CONFIG_SPL_RAM_DEVICE=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0xF80000 +CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_SYS_MAXARGS=64 +CONFIG_SYS_PBSIZE=2073 +CONFIG_SYS_BOOTM_LEN=0x6400000 +CONFIG_CMD_BOOTMENU=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_NVEDIT_EFI=y +CONFIG_CMD_MEMTEST=y +CONFIG_SYS_ALT_MEMTEST=y +CONFIG_CMD_SHA1SUM=y +CONFIG_CMD_CLK=y +CONFIG_CMD_DFU=y +CONFIG_CMD_FPGA_LOADBP=y +CONFIG_CMD_FPGA_LOADP=y +CONFIG_CMD_FPGA_LOAD_SECURE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_PWM=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_POWEROFF=y +CONFIG_CMD_SDRAM=y +CONFIG_CMD_SF_TEST=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_BOOTP_MAY_FAIL=y +CONFIG_BOOTP_BOOTFILESIZE=y +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_BMP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EFIDEBUG=y +CONFIG_CMD_RTC=y +CONFIG_CMD_TIME=y +CONFIG_CMD_GETTIME=y +CONFIG_CMD_RNG=y +CONFIG_CMD_KASLRSEED=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_SMC=y +CONFIG_CMD_TPM=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_SQUASHFS=y +CONFIG_CMD_MTDPARTS=y +CONFIG_CMD_MTDPARTS_SPREAD=y +CONFIG_CMD_MTDPARTS_SHOW_NET_SIZES=y +CONFIG_CMD_UBI=y +CONFIG_PARTITION_TYPE_GUID=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_BOARD=y +CONFIG_OF_LIST="" +CONFIG_DTB_RESELECT=y +CONFIG_MULTI_DTB_FIT=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names interrupt-parent interrupts iommus power-domains" +CONFIG_ENV_IS_NOWHERE=y +CONFIG_ENV_IS_IN_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_SPI_MAX_HZ=1000000 +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_ENV_FAT_DEVICE_AND_PART=":auto" +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_NETCONSOLE=y +CONFIG_SYS_FAULT_ECHO_LINK_DOWN=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SATA=y +CONFIG_SCSI_AHCI=y +CONFIG_SATA_CEVA=y +CONFIG_BUTTON=y +CONFIG_BUTTON_GPIO=y +CONFIG_CLK_ZYNQMP=y +CONFIG_DFU_TFTP=y +CONFIG_DFU_TIMEOUT=y +CONFIG_DFU_MMC=y +CONFIG_DFU_MTD=y +CONFIG_DFU_RAM=y +CONFIG_DFU_SF=y +CONFIG_SYS_DFU_DATA_BUF_SIZE=0x1800000 +CONFIG_DMA=y +CONFIG_XILINX_DPDMA=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_FPGA_XILINX=y +CONFIG_FPGA_ZYNQMPPL=y +CONFIG_GPIO_HOG=y +CONFIG_XILINX_GPIO=y +CONFIG_DM_PCA953X=y +CONFIG_SLG7XL45106_I2C_GPO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_CADENCE=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_MISC=y +CONFIG_I2C_EEPROM=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS200_SUPPORT=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ZYNQ=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_SPI_FLASH_MTD=y +CONFIG_PHY_ADIN=y +CONFIG_PHY_TI_DP83867=y +CONFIG_PHY_XILINX_GMII2RGMII=y +CONFIG_PHY_FIXED=y +CONFIG_DM_ETH_PHY=y +CONFIG_PHY_GIGE=y +CONFIG_XILINX_AXIEMAC=y +CONFIG_ZYNQ_GEM=y +CONFIG_PHY=y +CONFIG_PHY_XILINX_ZYNQMP=y +CONFIG_PINCTRL=y +CONFIG_PINCONF=y +CONFIG_POWER_DOMAIN=y +CONFIG_ZYNQMP_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_PWM=y +CONFIG_PWM_CADENCE_TTC=y +CONFIG_RESET_ZYNQMP=y +CONFIG_DM_RTC=y +CONFIG_RTC_EMULATION=y +CONFIG_RTC_ZYNQMP=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y +CONFIG_ARM_DCC=y +CONFIG_XILINX_UARTLITE=y +CONFIG_ZYNQ_SERIAL=y +CONFIG_SOC_XILINX_ZYNQMP=y +CONFIG_SPI=y +CONFIG_ZYNQ_SPI=y +CONFIG_ZYNQMP_GQSPI=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_CMD_POWEROFF=y +CONFIG_SYSRESET_PSCI=y +CONFIG_TPM2_TIS_SPI=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_ULPI_VIEWPORT=y +CONFIG_USB_ULPI=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Xilinx" +CONFIG_USB_GADGET_VENDOR_NUM=0x03FD +CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 +CONFIG_USB_ETHER=y +CONFIG_USB_ETH_CDC=y +CONFIG_VIDEO=y +# CONFIG_VIDEO_LOGO is not set +CONFIG_VIDEO_COPY=y +CONFIG_I2C_EDID=y +CONFIG_VIDEO_ZYNQMP_DPSUB=y +CONFIG_VIRTIO_MMIO=y +CONFIG_VIRTIO_NET=y +CONFIG_VIRTIO_BLK=y +CONFIG_PANIC_HANG=y +CONFIG_TPM=y +CONFIG_SPL_GZIP=y +CONFIG_EFI_SET_TIME=y +CONFIG_EFI_RUNTIME_UPDATE_CAPSULE=y +CONFIG_EFI_CAPSULE_ON_DISK=y +CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y
Changes in v2:
CONFIG_ENV_OFFSET=0x2200000
please change this to
CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000
remove this line completely. We should be on 30MHz instead.
Thanks, Michal
Michal Simek
