[PATCH] Kconfig: Fix SYS_MALLOC_F_LEN for i.MX8MQ
i.MX8MQ use SYS_MALLOC_F_LEN 0x2000, not 0x10000. The OCRAM_S only has 32KB memory, use 0x10000 will make SPL not bootable.
Signed-off-by: Peng Fan peng.fan@nxp.com --- Kconfig | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/Kconfig b/Kconfig index 6b1ddfc549e..3e95ec9d7b9 100644 --- a/Kconfig +++ b/Kconfig @@ -251,8 +251,10 @@ config SYS_MALLOC_F_LEN default 0x4000 if SANDBOX || RISCV default 0x2000 if (ARCH_MX7 || ARCH_MX7ULP || ARCH_MX6 || ARCH_MX5 || \ ARCH_QEMU || ARCH_SUNXI || ARCH_OWL) - default 0x10000 if (ARCH_IMX8 || ARCH_IMX8M || ARCH_LS1012A || \ - ARCH_LS1021A || ARCH_LS1043A || ARCH_LS1046A) + default 0x10000 if (ARCH_IMX8 || (ARCH_IMX8M && !IMX8MQ) || \ + ARCH_LS1012A || ARCH_LS1021A || ARCH_LS1043A || \ + ARCH_LS1046A) + default 0x2000 if IMX8MQ default 0x400 help Before relocation, memory is very limited on many platforms. Still,
Hi
ARCH_LS1046A)
-- 2.35.1
Reviewed-by: Michael Trimarchi michael@amarulasolutions.com
Hi Peng,
- default 0x10000 if (ARCH_IMX8 || (ARCH_IMX8M && !IMX8MQ) || \
ARCH_LS1046A)
- default 0x2000 if IMX8MQ
Thanks for the fix:
Reviewed-by: Fabio Estevam festevam@denx.de
Signed-off-by: Peng Fan peng.fan@nxp.com Reviewed-by: Michael Trimarchi michael@amarulasolutions.com Reviewed-by: Fabio Estevam festevam@denx.de
ARCH_LS1046A)
- default 0x2000 if IMX8MQ default 0x400 help Before relocation, memory is very limited on many platforms. Still,
Note that we can put this with the rest of the 0x2000 default instances. And as an aside, imx8mq_phanbell_defconfig sets this to 0x4000. That said, I've applied this to master (with the location change I noted), thanks!
Hi all,
Am Mo., 11. Apr. 2022 um 14:29 Uhr schrieb Tom Rini trini@konsulko.com:
ARCH_LS1046A)
-- Tom
I just tested v2022.07-rc6 and noticed that by reducing the value the kontron pitx-imx8m (imx8mq) board does not start anymore. I locally increased the value to 0xc000 and the board works again.
So should I increase the value just for this board or should I increase the default value for the IMX8MQ?
On Tue, Jul 05, 2022 at 12:19:54PM +0200, Heiko Thiery wrote:
Hi all,
ARCH_LS1046A)
-- Tom
I would _really_ like to see defaults per SoC. Even if that means saying "default 0xc000 if IMX8Q && SPL_FEAT_X" as I know with tight constraints on memory AND the need to have some of the bigger feature knobs enabled it can be tricky to get usable defaults. But what I really want to avoid are both the problem of everyone copy/pasting a value that's too big or too small and also avoid the problem of N boards needing the same fix because they all failed due to the same problem.
Hi Tom,
Am Di., 5. Juli 2022 um 15:35 Uhr schrieb Tom Rini trini@konsulko.com:
Hi all,
ARCH_LS1046A)
-- Tom
I understand your concerns but the value that has to be adjusted is not SPL_SYS_MALLOC_F_LEN. Therefore I'm not sure if the '&& SPL_FEAT_X' would be correct here.
-- Tom
On Tue, Jul 05, 2022 at 05:20:46PM +0200, Heiko Thiery wrote:
Hi Tom,
Hi all,
ARCH_LS1046A)
-- Tom
Ah right, sorry. So yes, it's even more likely we should be able to come up with one default for the family.
Hi Peng
Am Di., 5. Juli 2022 um 18:04 Uhr schrieb Tom Rini trini@konsulko.com:
Hi Tom,
Hi all,
It is strange. You said the i.MX8MQ has 32KB OCRAM memory. That means a value of 0x8000 should be the max usable value. But I see when setting to this value my board does not start. Only when I set the value to 0xc000 the board starts.
In the RM I see: - On-Chip RAM - OCRAM (128 KB) - On-Chip RAM for State Retention - OCRAM_S (32 KB)
ARCH_LS1046A)
-- Tom
-- Tom
-- Heiko
On 7/6/2022 5:01 PM, Heiko Thiery wrote:
Hi Peng
Hi Tom,
Hi all,
> From: Peng Fan peng.fan@nxp.com > > i.MX8MQ use SYS_MALLOC_F_LEN 0x2000, not 0x10000. The OCRAM_S only has > 32KB memory, use 0x10000 will make SPL not bootable.
In the RM I see:
Yes. I said OCRAM_S only has 32KB. The MALLOC BASE is set in OCRAM_S.
If your board has other settings, you could change that for your requirement. I think I have checked all boards, When I worked out this patch, I may overlook your board.
Regards, Peng.
> > Signed-off-by: Peng Fan peng.fan@nxp.com > Reviewed-by: Michael Trimarchi michael@amarulasolutions.com > Reviewed-by: Fabio Estevam festevam@denx.de > --- > Kconfig | 6 ++++-- > 1 file changed, 4 insertions(+), 2 deletions(-) > > diff --git a/Kconfig b/Kconfig > index 6b1ddfc549e..3e95ec9d7b9 100644 > --- a/Kconfig > +++ b/Kconfig > @@ -251,8 +251,10 @@ config SYS_MALLOC_F_LEN > default 0x4000 if SANDBOX || RISCV > default 0x2000 if (ARCH_MX7 || ARCH_MX7ULP || ARCH_MX6 || ARCH_MX5 || \ > ARCH_QEMU || ARCH_SUNXI || ARCH_OWL) > - default 0x10000 if (ARCH_IMX8 || ARCH_IMX8M || ARCH_LS1012A || \ > - ARCH_LS1021A || ARCH_LS1043A || ARCH_LS1046A) > + default 0x10000 if (ARCH_IMX8 || (ARCH_IMX8M && !IMX8MQ) || \ > + ARCH_LS1012A || ARCH_LS1021A || ARCH_LS1043A || \ > + ARCH_LS1046A) > + default 0x2000 if IMX8MQ > default 0x400 > help > Before relocation, memory is very limited on many platforms. Still,
-- Tom
-- Tom
-- Heiko
participants (6)
Fabio Estevam
Heiko Thiery
Michael Nazzareno Trimarchi
Peng Fan
Peng Fan (OSS)
