[RFC PATCH 1/2] efi: arm: do not overlap non ram memory on efi allocation
This commit fixes qemu boot of armv7 where reserving memory for fdt is failed due to reserving region outside of the system RAM.
=> bdinfo boot_params = 0x00000000 DRAM bank = 0x00000000 -> start = 0x40000000 -> size = 0x40000000 memstart = 0x40000000 memsize = 0x40000000 flashstart = 0x04000000 flashsize = 0x04000000 flashoffset = 0x00000000 baudrate = 115200 bps relocaddr = 0x7ff57000 reloc off = 0x1ff57000 Build = 32-bit current eth = virtio-net#32 ethaddr = 52:52:52:52:52:52 IP addr = <NULL> fdt_blob = 0x7ef35f20 new_fdt = 0x7ef35f20 fdt_size = 0x00001fa0 ERROR: reserving fdt memory region failed (addr=7fe00000 size=200000) lmb_dump_all: memory.cnt = 0x1 memory.size = 0x0 memory.reg[0x0].base = 0x40000000 .size = 0x40000000
reserved.cnt = 0x2 reserved.size = 0x0 reserved.reg[0x0].base = 0xe100000 .size = 0xf00000 reserved.reg[0x1].base = 0x7ef34d04 .size = 0x10cb2fc arch_number = 0x00000000 TLB addr = 0x7fff0000 irq_sp = 0x7ef35f10 sp start = 0x7ef35f00 Early malloc usage: 1fc / 400
=> efidebug memmap Type Start End Attributes ================ ================ ================ ========== RESERVED 000000000e100000-000000000f000000 WB <---- outside of RAM CONVENTIONAL 0000000040000000-0000000047f00000 WB ACPI RECLAIM MEM 0000000047f00000-0000000047f05000 WB CONVENTIONAL 0000000047f05000-000000007d475000 WB RESERVED 000000007d475000-000000007d477000 WB CONVENTIONAL 000000007d477000-000000007df17000 WB LOADER DATA 000000007df17000-000000007df18000 WB
Signed-off-by: Maxim Uvarov maxim.uvarov@linaro.org ---
I'm really not sure that this is correct way to fix. Current code state is that uboot fails to boot kernel on armv7 if memory was reserved at 0xe100000. I.e. in current code it does not work. Qemu target has memory started at 0x40000000 and this chunk is outside that memory. Flag overlap_only_ram had very confusing naming, I corrected it in separate path. This patch fixes booting with removing region from efi memmap. I send this as RFC for now.
BR, Maxim.
lib/efi_loader/efi_memory.c | 8 ++++++-- 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index 7be756e370..637c6c67ed 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -360,11 +360,15 @@ static efi_status_t efi_add_memory_map_pg(u64 start, u64 pages, efi_status_t efi_add_memory_map(u64 start, u64 size, int memory_type) { u64 pages; + bool overlap_only_ram = false;
pages = efi_size_in_pages(size + (start & EFI_PAGE_MASK)); start &= ~EFI_PAGE_MASK; - - return efi_add_memory_map_pg(start, pages, memory_type, false); +#if defined(CONFIG_ARM) + overlap_only_ram = true; +#endif + return efi_add_memory_map_pg(start, pages, memory_type, + overlap_only_ram); }
Refine text for overlap_only_ram description to match to what exactly flag does and aling description with other functions.
Signed-off-by: Maxim Uvarov maxim.uvarov@linaro.org --- lib/efi_loader/efi_memory.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index 637c6c67ed..6dbe9ba756 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -235,7 +235,7 @@ static s64 efi_mem_carve_out(struct efi_mem_list *map, * @start: start address, must be a multiple of EFI_PAGE_SIZE * @pages: number of pages to add * @memory_type: type of memory added - * @overlap_only_ram: the memory area must overlap existing + * @overlap_only_ram: region may only overlap RAM * Return: status code */ static efi_status_t efi_add_memory_map_pg(u64 start, u64 pages,
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
- @start: start address, must be a multiple of EFI_PAGE_SIZE
- @pages: number of pages to add
- @memory_type: type of memory added
- @overlap_only_ram: the memory area must overlap existing
- @overlap_only_ram: region may only overlap RAM
- Return: status code
From our prior communication I took this refers to incorrect allocation
in Linux.
Ard Biesheuvel is addressing this in a Linux kernel patch series:
[PATCH RFC/RFT 0/3] efi/libstub: arm32: Remove dependency on dram_base https://lore.kernel.org/linux-efi/CAMj1kXECRr+E4=r+7fuaRAXQUyLi5Z1_HgNWgLGZV...
Best regards
Heinrich
Maxim Uvarov
