[PATCH v2 0/6] rk3399: Sync linux v5.7-rc1 dts(i)
This would help to add new boards along with new drivers like DWC3, PCIe on rk3399 platform.
So, add v5.7-rc1 linux-next dts(i) files on rk3399 platform.
Changes for v2: - keep roc-rk3399-pc dc_12v changes to -u-boot.dtsi
[1] https://patchwork.ozlabs.org/project/uboot/cover/20200425105319.12009-1-jaga...
Any inputs? Jagan.
Jagan Teki (5): arm64: dts: rk3399-puma: Move u-boot properties into -u-boot.dtsi arm64: dts: rk3399-evb: Move u-boot properties into -u-boot.dtsi clk: rk3399: Set empty for HCLK_SD assigned-clocks arm64: dts: rk3399: Sync v5.7-rc1 from Linux arm: dts: rk3399: Sync roc-pc-mezzanine from v5.7-rc1
Suniel Mahesh (1): rk3399: Add ROC-RK3399-PC Mezzanine board
arch/arm/dts/Makefile | 1 + arch/arm/dts/cros-ec-keyboard.dtsi | 10 +- arch/arm/dts/cros-ec-sbs.dtsi | 39 +- arch/arm/dts/rk3399-evb-u-boot.dtsi | 8 + arch/arm/dts/rk3399-evb.dts | 522 ++++++++---- arch/arm/dts/rk3399-ficus.dts | 6 + arch/arm/dts/rk3399-firefly.dts | 251 ++++-- arch/arm/dts/rk3399-gru-bob.dts | 16 +- arch/arm/dts/rk3399-gru-chromebook.dtsi | 40 +- arch/arm/dts/rk3399-gru-kevin.dts | 34 +- arch/arm/dts/rk3399-gru.dtsi | 90 +- arch/arm/dts/rk3399-khadas-edge.dtsi | 3 + arch/arm/dts/rk3399-leez-p710.dts | 36 +- arch/arm/dts/rk3399-nanopc-t4.dts | 47 +- arch/arm/dts/rk3399-nanopi4.dtsi | 66 +- arch/arm/dts/rk3399-orangepi.dts | 79 +- arch/arm/dts/rk3399-puma-u-boot.dtsi | 31 +- arch/arm/dts/rk3399-puma.dtsi | 578 +++++-------- .../dts/rk3399-roc-pc-mezzanine-u-boot.dtsi | 6 + arch/arm/dts/rk3399-roc-pc-mezzanine.dts | 93 ++ arch/arm/dts/rk3399-roc-pc-u-boot.dtsi | 36 + arch/arm/dts/rk3399-roc-pc.dts | 3 +- arch/arm/dts/rk3399-roc-pc.dtsi | 35 +- arch/arm/dts/rk3399-rock-pi-4.dts | 129 +++ arch/arm/dts/rk3399-rock960.dts | 49 ++ arch/arm/dts/rk3399-rock960.dtsi | 13 +- arch/arm/dts/rk3399-rockpro64.dts | 751 +---------------- arch/arm/dts/rk3399-rockpro64.dtsi | 797 ++++++++++++++++++ arch/arm/dts/rk3399-u-boot.dtsi | 1 + arch/arm/dts/rk3399.dtsi | 583 ++++++++----- board/firefly/roc-pc-rk3399/MAINTAINERS | 2 + configs/roc-pc-mezzanine-rk3399_defconfig | 67 ++ drivers/clk/rockchip/clk_rk3399.c | 1 + 33 files changed, 2763 insertions(+), 1660 deletions(-) create mode 100644 arch/arm/dts/rk3399-roc-pc-mezzanine-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-roc-pc-mezzanine.dts create mode 100644 arch/arm/dts/rk3399-rockpro64.dtsi create mode 100644 configs/roc-pc-mezzanine-rk3399_defconfig
Move U-Boot specific properties into rk3399-puma u-boot specific dtsi file.
This would help to sync the devicetrees from Linux whenever required instead of adding specific nodes.
Cc: Peter Robinson pbrobinson@gmail.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - none
arch/arm/dts/rk3399-puma-u-boot.dtsi | 16 ++++++++++++++++ arch/arm/dts/rk3399-puma.dtsi | 11 ----------- 2 files changed, 16 insertions(+), 11 deletions(-)
diff --git a/arch/arm/dts/rk3399-puma-u-boot.dtsi b/arch/arm/dts/rk3399-puma-u-boot.dtsi index 52f62b5d39..e664779227 100644 --- a/arch/arm/dts/rk3399-puma-u-boot.dtsi +++ b/arch/arm/dts/rk3399-puma-u-boot.dtsi @@ -22,3 +22,19 @@ };
}; + +&bios_enable { + u-boot,dm-pre-reloc; +}; + +&gpio1 { + u-boot,dm-pre-reloc; +}; + +&gpio3 { + u-boot,dm-pre-reloc; +}; + +&spiflash { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/rk3399-puma.dtsi b/arch/arm/dts/rk3399-puma.dtsi index 558b6337df..246a892cb7 100644 --- a/arch/arm/dts/rk3399-puma.dtsi +++ b/arch/arm/dts/rk3399-puma.dtsi @@ -91,7 +91,6 @@ */ bios_enable: bios_enable { compatible = "regulator-fixed"; - u-boot,dm-pre-reloc; regulator-name = "bios_enable"; enable-active-high; gpio = <&gpio3 RK_PD5 GPIO_ACTIVE_LOW>; @@ -520,14 +519,6 @@ status = "okay"; };
-&gpio1 { - u-boot,dm-pre-reloc; -}; - -&gpio3 { - u-boot,dm-pre-reloc; -}; - &pinctrl { /* Pins that are not explicitely used by any devices */ pinctrl-names = "default"; @@ -633,8 +624,6 @@ #size-cells = <0>;
spiflash: w25q32dw@0 { - u-boot,dm-pre-reloc; - compatible = "jedec,spi-nor"; reg = <0>; spi-max-frequency = <49500000>;
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changes for v2:
none
+&bios_enable {
+&gpio1 {
+&gpio3 {
+&spiflash {
regulator-name = "bios_enable"; enable-active-high; gpio = <&gpio3 RK_PD5 GPIO_ACTIVE_LOW>;u-boot,dm-pre-reloc;
-&gpio1 {
-&gpio3 {
Thanks, - Kever
Changes for v2:
none
+&bios_enable {
+&gpio1 {
+&gpio3 {
+&spiflash {
-&gpio1 {
-&gpio3 {
Move U-Boot specific properties into rk3399-evb u-boot specific dtsi file.
arch/arm/dts/rk3399-evb-u-boot.dtsi | 8 ++++++++ arch/arm/dts/rk3399-evb.dts | 2 -- 2 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/rk3399-evb-u-boot.dtsi b/arch/arm/dts/rk3399-evb-u-boot.dtsi index ccb33d34d1..a4d68f3b98 100644 --- a/arch/arm/dts/rk3399-evb-u-boot.dtsi +++ b/arch/arm/dts/rk3399-evb-u-boot.dtsi @@ -11,3 +11,11 @@ u-boot,spl-boot-order = &sdhci, &sdmmc; }; }; + +&i2c0 { + u-boot,dm-pre-reloc; +}; + +&rk808 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/rk3399-evb.dts b/arch/arm/dts/rk3399-evb.dts index 4129e902a8..c72719c0d3 100644 --- a/arch/arm/dts/rk3399-evb.dts +++ b/arch/arm/dts/rk3399-evb.dts @@ -199,7 +199,6 @@ clock-frequency = <400000>; i2c-scl-falling-time-ns = <50>; i2c-scl-rising-time-ns = <100>; - u-boot,dm-pre-reloc;
rk808: pmic@1b { compatible = "rockchip,rk808"; @@ -211,7 +210,6 @@ reg = <0x1b>; rockchip,system-power-controller; #clock-cells = <1>; - u-boot,dm-pre-reloc; status = "okay";
vcc12-supply = <&vcc3v3_sys>;
Thanks, - Kever
Changes for v2:
none
+&i2c0 {
+&rk808 {
status = "okay";
Due to v5.7-rc1 sync the SD controller nodes in rk3399.dtsi have HCLK_SD assigned-clocks which are usually required for Linux and don't require to handle them in U-Boot.
assigned-clocks = <&cru HCLK_SD>;
So, mark them as empty in clock otherwise device probe on those SD controllers would fail.
drivers/clk/rockchip/clk_rk3399.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index 1f62376595..d822acace1 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -996,6 +996,7 @@ static ulong rk3399_clk_set_rate(struct clk *clk, ulong rate) break; case ACLK_VOP1: case HCLK_VOP1: + case HCLK_SD: /** * assigned-clocks handling won't require for vopl, so * return 0 to satisfy clk_set_defaults during device probe.
Thanks, - Kever
Changes for v2:
none
- case HCLK_SD: /**
- assigned-clocks handling won't require for vopl, so
- return 0 to satisfy clk_set_defaults during device probe.
Sync rk3399 dts(i) files from v5.7-rc1 linux-next.
Reason: To get updated PCIe nodes and properties on respective dts(i) files.
Summary: - sync won't include new board dts(i) - sync will add required files used on respective dts(i) - rk3399-puma-u-boot.dtsi spiflash label changed to norflash - move puma.dtsi bios_enable into rk3399-puma-u-boot.dtsi - move legacy max-frequency of sdhci into rk3399-u-boot.dtsi - update cross-ec-[keyboard|sbs].dtsi path as per U-Boot - keep roc-rk3399-pc dc_12v changes to -u-boot.dtsi
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - keep roc-rk3399-pc dc_12v changes to -u-boot.dtsi
arch/arm/dts/cros-ec-keyboard.dtsi | 10 +- arch/arm/dts/cros-ec-sbs.dtsi | 39 +- arch/arm/dts/rk3399-evb.dts | 520 +++++++++++----- arch/arm/dts/rk3399-ficus.dts | 6 + arch/arm/dts/rk3399-firefly.dts | 251 ++++++-- arch/arm/dts/rk3399-gru-bob.dts | 16 +- arch/arm/dts/rk3399-gru-chromebook.dtsi | 40 +- arch/arm/dts/rk3399-gru-kevin.dts | 34 +- arch/arm/dts/rk3399-gru.dtsi | 90 ++- arch/arm/dts/rk3399-khadas-edge.dtsi | 3 + arch/arm/dts/rk3399-leez-p710.dts | 36 +- arch/arm/dts/rk3399-nanopc-t4.dts | 47 +- arch/arm/dts/rk3399-nanopi4.dtsi | 66 +- arch/arm/dts/rk3399-orangepi.dts | 79 ++- arch/arm/dts/rk3399-puma-u-boot.dtsi | 25 +- arch/arm/dts/rk3399-puma.dtsi | 567 +++++++---------- arch/arm/dts/rk3399-roc-pc-u-boot.dtsi | 36 ++ arch/arm/dts/rk3399-roc-pc.dts | 3 +- arch/arm/dts/rk3399-roc-pc.dtsi | 35 +- arch/arm/dts/rk3399-rock-pi-4.dts | 129 ++++ arch/arm/dts/rk3399-rock960.dts | 49 ++ arch/arm/dts/rk3399-rock960.dtsi | 13 +- arch/arm/dts/rk3399-rockpro64.dts | 751 +--------------------- arch/arm/dts/rk3399-rockpro64.dtsi | 797 ++++++++++++++++++++++++ arch/arm/dts/rk3399-u-boot.dtsi | 1 + arch/arm/dts/rk3399.dtsi | 583 ++++++++++------- 26 files changed, 2574 insertions(+), 1652 deletions(-) create mode 100644 arch/arm/dts/rk3399-rockpro64.dtsi
diff --git a/arch/arm/dts/cros-ec-keyboard.dtsi b/arch/arm/dts/cros-ec-keyboard.dtsi index 9c7fb0acae..4a0c1037fb 100644 --- a/arch/arm/dts/cros-ec-keyboard.dtsi +++ b/arch/arm/dts/cros-ec-keyboard.dtsi @@ -1,11 +1,8 @@ +// SPDX-License-Identifier: GPL-2.0-only /* * Keyboard dts fragment for devices that use cros-ec-keyboard * * Copyright (c) 2014 Google, Inc - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. */
#include <dt-bindings/input/input.h> @@ -22,6 +19,7 @@ MATRIX_KEY(0x00, 0x02, KEY_F1) MATRIX_KEY(0x00, 0x03, KEY_B) MATRIX_KEY(0x00, 0x04, KEY_F10) + MATRIX_KEY(0x00, 0x05, KEY_RO) MATRIX_KEY(0x00, 0x06, KEY_N) MATRIX_KEY(0x00, 0x08, KEY_EQUAL) MATRIX_KEY(0x00, 0x0a, KEY_RIGHTALT) @@ -34,6 +32,7 @@ MATRIX_KEY(0x01, 0x08, KEY_APOSTROPHE) MATRIX_KEY(0x01, 0x09, KEY_F9) MATRIX_KEY(0x01, 0x0b, KEY_BACKSPACE) + MATRIX_KEY(0x01, 0x0c, KEY_HENKAN)
MATRIX_KEY(0x02, 0x00, KEY_LEFTCTRL) MATRIX_KEY(0x02, 0x01, KEY_TAB) @@ -45,6 +44,7 @@ MATRIX_KEY(0x02, 0x07, KEY_102ND) MATRIX_KEY(0x02, 0x08, KEY_LEFTBRACE) MATRIX_KEY(0x02, 0x09, KEY_F8) + MATRIX_KEY(0x02, 0x0a, KEY_YEN)
MATRIX_KEY(0x03, 0x01, KEY_GRAVE) MATRIX_KEY(0x03, 0x02, KEY_F2) @@ -52,7 +52,9 @@ MATRIX_KEY(0x03, 0x04, KEY_F5) MATRIX_KEY(0x03, 0x06, KEY_6) MATRIX_KEY(0x03, 0x08, KEY_MINUS) + MATRIX_KEY(0x03, 0x09, KEY_F13) MATRIX_KEY(0x03, 0x0b, KEY_BACKSLASH) + MATRIX_KEY(0x03, 0x0c, KEY_MUHENKAN)
MATRIX_KEY(0x04, 0x00, KEY_RIGHTCTRL) MATRIX_KEY(0x04, 0x01, KEY_A) diff --git a/arch/arm/dts/cros-ec-sbs.dtsi b/arch/arm/dts/cros-ec-sbs.dtsi index dfe5ea6ca2..71f5c5ecce 100644 --- a/arch/arm/dts/cros-ec-sbs.dtsi +++ b/arch/arm/dts/cros-ec-sbs.dtsi @@ -1,8 +1,45 @@ -// SPDX-License-Identifier: GPL-2.0 /* * Smart battery dts fragment for devices that use cros-ec-sbs * * Copyright (c) 2015 Google, Inc + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. */
&i2c_tunnel { diff --git a/arch/arm/dts/rk3399-evb.dts b/arch/arm/dts/rk3399-evb.dts index c72719c0d3..694b0d08d6 100644 --- a/arch/arm/dts/rk3399-evb.dts +++ b/arch/arm/dts/rk3399-evb.dts @@ -1,86 +1,18 @@ -// SPDX-License-Identifier: GPL-2.0+ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* - * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * Copyright (c) 2016 Fuzhou Rockchip Electronics Co., Ltd */
/dts-v1/; #include <dt-bindings/pwm/pwm.h> -#include <dt-bindings/pinctrl/rockchip.h> #include "rk3399.dtsi"
/ { model = "Rockchip RK3399 Evaluation Board"; - compatible = "rockchip,rk3399-evb", "rockchip,rk3399", - "google,rk3399evb-rev2"; - - chosen { - stdout-path = &uart2; - }; - - vdd_center: vdd-center { - compatible = "pwm-regulator"; - pwms = <&pwm3 0 25000 1>; - regulator-name = "vdd_center"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1400000>; - regulator-init-microvolt = <950000>; - regulator-always-on; - regulator-boot-on; - status = "okay"; - }; - - vccsys: vccsys { - compatible = "regulator-fixed"; - regulator-name = "vccsys"; - regulator-boot-on; - regulator-always-on; - }; - - vcc3v3_sys: vcc3v3-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vcc_phy: vcc-phy-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_phy"; - regulator-always-on; - regulator-boot-on; - }; - - vcc5v0_host: vcc5v0-host-en { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_host"; - gpio = <&gpio4 25 GPIO_ACTIVE_HIGH>; - }; - - vcc5v0_typec0: vcc5v0-typec0-en { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_typec0"; - gpio = <&gpio1 3 GPIO_ACTIVE_HIGH>; - }; - - vcc5v0_typec1: vcc5v0-typec1-en { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_typec1"; - gpio = <&gpio1 4 GPIO_ACTIVE_HIGH>; - }; - - clkin_gmac: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "clkin_gmac"; - #clock-cells = <0>; - }; + compatible = "rockchip,rk3399-evb", "rockchip,rk3399";
backlight: backlight { compatible = "pwm-backlight"; - power-supply = <&vccsys>; - enable-gpios = <&gpio1 13 GPIO_ACTIVE_HIGH>; brightness-levels = < 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 @@ -116,18 +48,98 @@ 248 249 250 251 252 253 254 255>; default-brightness-level = <200>; pwms = <&pwm0 0 25000 0>; - pinctrl-names = "default"; - pinctrl-0 = <&pwm0_pin>; - pwm-delay-us = <10000>; - status = "disabled"; };
- panel:panel { - compatible = "simple-panel"; - power-supply = <&vcc33_lcd>; + edp_panel: edp-panel { + compatible ="lg,lp079qx1-sp0v"; backlight = <&backlight>; - /*enable-gpios = <&gpio4 18 GPIO_ACTIVE_HIGH>;*/ - status = "disabled"; + enable-gpios = <&gpio1 RK_PB5 GPIO_ACTIVE_HIGH>; + power-supply = <&vcc3v3_s0>; + + port { + panel_in_edp: endpoint { + remote-endpoint = <&edp_out_panel>; + }; + }; + }; + + clkin_gmac: external-gmac-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "clkin_gmac"; + #clock-cells = <0>; + }; + + vdd_center: vdd-center { + compatible = "pwm-regulator"; + pwms = <&pwm3 0 25000 0>; + regulator-name = "vdd_center"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1400000>; + regulator-always-on; + regulator-boot-on; + status = "okay"; + }; + + vcc3v3_sys: vcc3v3-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + vcc5v0_sys: vcc5v0-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vcc5v0_host: vcc5v0-host-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_host_en>; + regulator-name = "vcc5v0_host"; + vin-supply = <&vcc5v0_sys>; + }; + + vcc_phy: vcc-phy-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_phy"; + regulator-always-on; + regulator-boot-on; + }; + + vcc_phy: vcc-phy-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_phy"; + regulator-always-on; + regulator-boot-on; + }; + +}; + +&edp { + status = "okay"; + force-hpd; + + ports { + edp_out: port@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + + edp_out_panel: endpoint@0 { + reg = <0>; + remote-endpoint = <&panel_in_edp>; + }; + }; }; };
@@ -135,24 +147,253 @@ status = "okay"; };
-&pwm0 { +&gmac { + assigned-clocks = <&cru SCLK_RMII_SRC>; + assigned-clock-parents = <&clkin_gmac>; + clock_in_out = "input"; + phy-supply = <&vcc_phy>; + phy-mode = "rgmii"; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 50000>; + tx_delay = <0x28>; + rx_delay = <0x11>; status = "okay"; };
-&pwm2 { +&i2c0 { status = "okay"; + + rk808: pmic@1b { + compatible = "rockchip,rk808"; + reg = <0x1b>; + interrupt-parent = <&gpio1>; + interrupts = <21 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + #clock-cells = <1>; + clock-output-names = "rk808-clkout1", "rk808-clkout2"; + + vcc1-supply = <&vcc3v3_sys>; + vcc2-supply = <&vcc3v3_sys>; + vcc3-supply = <&vcc3v3_sys>; + vcc4-supply = <&vcc3v3_sys>; + vcc6-supply = <&vcc3v3_sys>; + vcc7-supply = <&vcc3v3_sys>; + vcc8-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc3v3_sys>; + vcc10-supply = <&vcc3v3_sys>; + vcc11-supply = <&vcc3v3_sys>; + vcc12-supply = <&vcc3v3_sys>; + vddio-supply = <&vcc1v8_pmu>; + + regulators { + vdd_log: DCDC_REG1 { + regulator-name = "vdd_log"; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <900000>; + }; + }; + + vdd_cpu_l: DCDC_REG2 { + regulator-name = "vdd_cpu_l"; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_1v8: DCDC_REG4 { + regulator-name = "vcc_1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc1v8_dvp: LDO_REG1 { + regulator-name = "vcc1v8_dvp"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v0_tp: LDO_REG2 { + regulator-name = "vcc3v0_tp"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc1v8_pmu: LDO_REG3 { + regulator-name = "vcc1v8_pmu"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_sd: LDO_REG4 { + regulator-name = "vcc_sd"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3000000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcca3v0_codec: LDO_REG5 { + regulator-name = "vcca3v0_codec"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v5: LDO_REG6 { + regulator-name = "vcc_1v5"; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1500000>; + }; + }; + + vcca1v8_codec: LDO_REG7 { + regulator-name = "vcca1v8_codec"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v0: LDO_REG8 { + regulator-name = "vcc_3v0"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcc3v3_s3: SWITCH_REG1 { + regulator-name = "vcc3v3_s3"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc3v3_s0: SWITCH_REG2 { + regulator-name = "vcc3v3_s0"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; + + vdd_cpu_b: regulator@40 { + compatible = "silergy,syr827"; + reg = <0x40>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_b"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: regulator@41 { + compatible = "silergy,syr828"; + reg = <0x41>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_gpu"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; };
-&pwm3 { +&pwm0 { status = "okay"; };
-&saradc { +&pwm2 { status = "okay"; };
-&sdmmc { - bus-width = <4>; +&pwm3 { status = "okay"; };
@@ -164,115 +405,76 @@ status = "okay"; };
-&uart2 { - status = "okay"; +&pcie_phy { + status = "disabled"; };
-&usb_host0_ehci { - status = "okay"; +&pcie0 { + ep-gpios = <&gpio3 RK_PB5 GPIO_ACTIVE_HIGH>; + num-lanes = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie_clkreqn_cpm>; + status = "disabled"; };
-&usb_host0_ohci { +&u2phy0 { status = "okay"; };
-&usbdrd3_0 { - vbus-supply = <&vcc5v0_typec0>; +&u2phy0_host { + phy-supply = <&vcc5v0_host>; status = "okay"; };
-&usb_host1_ehci { +&u2phy1 { status = "okay"; };
-&usb_host1_ohci { +&u2phy1_host { + phy-supply = <&vcc5v0_host>; status = "okay"; };
-&usbdrd3_1 { - vbus-supply = <&vcc5v0_typec1>; +&uart2 { status = "okay"; };
-&i2c0 { +&usb_host0_ehci { status = "okay"; - clock-frequency = <400000>; - i2c-scl-falling-time-ns = <50>; - i2c-scl-rising-time-ns = <100>; - - rk808: pmic@1b { - compatible = "rockchip,rk808"; - clock-output-names = "xin32k", "wifibt_32kin"; - interrupt-parent = <&gpio0>; - interrupts = <4 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - reg = <0x1b>; - rockchip,system-power-controller; - #clock-cells = <1>; - status = "okay"; +};
- vcc12-supply = <&vcc3v3_sys>; +&usb_host0_ohci { + status = "okay"; +};
- regulators { - vcc33_lcd: SWITCH_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-name = "vcc33_lcd"; - }; - }; - }; +&usb_host1_ehci { + status = "okay"; };
-&mipi_dsi { - status = "disabled"; - rockchip,panel = <&panel>; - display-timings { - timing0 { - bits-per-pixel = <24>; - clock-frequency = <160000000>; - hfront-porch = <120>; - hsync-len = <20>; - hback-porch = <21>; - hactive = <1200>; - vfront-porch = <21>; - vsync-len = <3>; - vback-porch = <18>; - vactive = <1920>; - hsync-active = <0>; - vsync-active = <0>; - de-active = <1>; - pixelclk-active = <0>; - }; - }; +&usb_host1_ohci { + status = "okay"; };
&pinctrl { pmic { pmic_int_l: pmic-int-l { rockchip,pins = - <1 21 RK_FUNC_GPIO &pcfg_pull_up>; + <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; }; + };
- pmic_dvs2: pmic-dvs2 { + usb2 { + vcc5v0_host_en: vcc5v0-host-en { rockchip,pins = - <1 18 RK_FUNC_GPIO &pcfg_pull_down>; + <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; }; }; };
-&gmac { - phy-supply = <&vcc_phy>; - phy-mode = "rgmii"; - clock_in_out = "input"; - snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 50000>; - assigned-clocks = <&cru SCLK_RMII_SRC>; - assigned-clock-parents = <&clkin_gmac>; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - tx_delay = <0x28>; - rx_delay = <0x11>; +&vopb { + status = "okay"; +}; + +&vopb_mmu { status = "okay"; }; diff --git a/arch/arm/dts/rk3399-ficus.dts b/arch/arm/dts/rk3399-ficus.dts index 6b059bd7a0..ebe2ee77ba 100644 --- a/arch/arm/dts/rk3399-ficus.dts +++ b/arch/arm/dts/rk3399-ficus.dts @@ -146,6 +146,12 @@ }; };
+&spi1 { + /* On both Low speed and High speed expansion */ + cs-gpios = <0>, <&gpio4 RK_PA6 0>, <&gpio4 RK_PA7 0>; + status = "okay"; +}; + &usbdrd_dwc3_0 { dr_mode = "host"; }; diff --git a/arch/arm/dts/rk3399-firefly.dts b/arch/arm/dts/rk3399-firefly.dts index 89c67fd24c..d63faf38cc 100644 --- a/arch/arm/dts/rk3399-firefly.dts +++ b/arch/arm/dts/rk3399-firefly.dts @@ -1,19 +1,20 @@ -// SPDX-License-Identifier: GPL-2.0+ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd. */
/dts-v1/; +#include <dt-bindings/input/linux-event-codes.h> #include <dt-bindings/pwm/pwm.h> -#include <dt-bindings/pinctrl/rockchip.h> #include "rk3399.dtsi" +#include "rk3399-opp.dtsi"
/ { model = "Firefly-RK3399 Board"; compatible = "firefly,firefly-rk3399", "rockchip,rk3399";
chosen { - stdout-path = &uart2; + stdout-path = "serial2:1500000n8"; };
backlight: backlight { @@ -63,6 +64,48 @@ #clock-cells = <0>; };
+ dc_12v: dc-12v { + compatible = "regulator-fixed"; + regulator-name = "dc_12v"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + + gpio-keys { + compatible = "gpio-keys"; + autorepeat; + pinctrl-names = "default"; + pinctrl-0 = <&pwrbtn>; + + power { + debounce-interval = <100>; + gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; + label = "GPIO Key Power"; + linux,code = <KEY_POWER>; + wakeup-source; + }; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&work_led_gpio>, <&diy_led_gpio>; + + work-led { + label = "work"; + default-state = "on"; + gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>; + }; + + diy-led { + label = "diy"; + default-state = "off"; + gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>; + }; + }; + rt5640-sound { compatible = "simple-audio-card"; simple-audio-card,name = "rockchip,rt5640-codec"; @@ -102,15 +145,27 @@ reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; };
+ /* switched by pmic_sleep */ + vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 { + compatible = "regulator-fixed"; + regulator-name = "vcc1v8_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_1v8>; + }; + vcc3v3_pcie: vcc3v3-pcie-regulator { compatible = "regulator-fixed"; enable-active-high; gpio = <&gpio1 RK_PC1 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; - pinctrl-0 = <&pcie_drv>; + pinctrl-0 = <&pcie_pwr_en>; regulator-name = "vcc3v3_pcie"; regulator-always-on; regulator-boot-on; + vin-supply = <&dc_12v>; };
vcc3v3_sys: vcc3v3-sys { @@ -120,32 +175,29 @@ regulator-boot-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; + vin-supply = <&vcc_sys>; };
+ /* Actually 3 regulators (host0, 1, 2) controlled by the same gpio */ vcc5v0_host: vcc5v0-host-regulator { compatible = "regulator-fixed"; enable-active-high; gpio = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; - pinctrl-0 = <&host_vbus_drv>; + pinctrl-0 = <&vcc5v0_host_en>; regulator-name = "vcc5v0_host"; regulator-always-on; + vin-supply = <&vcc_sys>; };
- vcc5v0_sys: vcc5v0-sys { + vcc_sys: vcc-sys { compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; + regulator-name = "vcc_sys"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; - }; - - vcc_phy: vcc-phy-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_phy"; - regulator-always-on; - regulator-boot-on; + vin-supply = <&dc_12v>; };
vdd_log: vdd-log { @@ -156,16 +208,7 @@ regulator-boot-on; regulator-min-microvolt = <430000>; regulator-max-microvolt = <1400000>; - regulator-init-microvolt = <950000>; - }; - - vccadc_ref: vccadc-ref { - compatible = "regulator-fixed"; - regulator-name = "vcc1v8_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_sys>; }; };
@@ -201,15 +244,22 @@ assigned-clocks = <&cru SCLK_RMII_SRC>; assigned-clock-parents = <&clkin_gmac>; clock_in_out = "input"; - phy-supply = <&vcc_phy>; + phy-supply = <&vcc_lan>; phy-mode = "rgmii"; pinctrl-names = "default"; pinctrl-0 = <&rgmii_pins>; snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; snps,reset-active-low; snps,reset-delays-us = <0 10000 50000>; - tx_delay = <0x33>; - rx_delay = <0x45>; + tx_delay = <0x28>; + rx_delay = <0x11>; + status = "okay"; +}; + +&hdmi { + ddc-i2c-bus = <&i2c3>; + pinctrl-names = "default"; + pinctrl-0 = <&hdmi_cec>; status = "okay"; };
@@ -231,16 +281,16 @@ rockchip,system-power-controller; wakeup-source;
- vcc1-supply = <&vcc3v3_sys>; - vcc2-supply = <&vcc3v3_sys>; - vcc3-supply = <&vcc3v3_sys>; - vcc4-supply = <&vcc3v3_sys>; - vcc6-supply = <&vcc3v3_sys>; - vcc7-supply = <&vcc3v3_sys>; + vcc1-supply = <&vcc_sys>; + vcc2-supply = <&vcc_sys>; + vcc3-supply = <&vcc_sys>; + vcc4-supply = <&vcc_sys>; + vcc6-supply = <&vcc_sys>; + vcc7-supply = <&vcc_sys>; vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc3v3_sys>; - vcc10-supply = <&vcc3v3_sys>; - vcc11-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc_sys>; + vcc10-supply = <&vcc_sys>; + vcc11-supply = <&vcc_sys>; vcc12-supply = <&vcc3v3_sys>; vddio-supply = <&vcc1v8_pmu>;
@@ -301,12 +351,12 @@ }; };
- vcc3v0_tp: LDO_REG2 { - regulator-name = "vcc3v0_tp"; + vcc2v8_dvp: LDO_REG2 { + regulator-name = "vcc2v8_dvp"; regulator-always-on; regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; regulator-state-mem { regulator-off-in-suspend; }; @@ -324,8 +374,8 @@ }; };
- vcc_sd: LDO_REG4 { - regulator-name = "vcc_sd"; + vcc_sdio: LDO_REG4 { + regulator-name = "vcc_sdio"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <1800000>; @@ -382,7 +432,7 @@ }; };
- vcc3v3_s3: SWITCH_REG1 { + vcc3v3_s3: vcc_lan: SWITCH_REG1 { regulator-name = "vcc3v3_s3"; regulator-always-on; regulator-boot-on; @@ -412,7 +462,7 @@ regulator-ramp-delay = <1000>; regulator-always-on; regulator-boot-on; - vin-supply = <&vcc5v0_sys>; + vin-supply = <&vcc_sys>;
regulator-state-mem { regulator-off-in-suspend; @@ -429,7 +479,7 @@ regulator-ramp-delay = <1000>; regulator-always-on; regulator-boot-on; - vin-supply = <&vcc5v0_sys>; + vin-supply = <&vcc_sys>;
regulator-state-mem { regulator-off-in-suspend; @@ -476,19 +526,16 @@ &i2s0 { rockchip,playback-channels = <8>; rockchip,capture-channels = <8>; - #sound-dai-cells = <0>; status = "okay"; };
&i2s1 { rockchip,playback-channels = <2>; rockchip,capture-channels = <2>; - #sound-dai-cells = <0>; status = "okay"; };
&i2s2 { - #sound-dai-cells = <0>; status = "okay"; };
@@ -497,7 +544,7 @@
bt656-supply = <&vcc1v8_dvp>; audio-supply = <&vcca1v8_codec>; - sdmmc-supply = <&vcc_sd>; + sdmmc-supply = <&vcc_sdio>; gpio1830-supply = <&vcc_3v0>; };
@@ -509,7 +556,7 @@ ep-gpios = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>; num-lanes = <4>; pinctrl-names = "default"; - pinctrl-0 = <&pcie_clkreqn>; + pinctrl-0 = <&pcie_clkreqn_cpm>; status = "okay"; };
@@ -532,7 +579,7 @@ };
pcie { - pcie_drv: pcie-drv { + pcie_pwr_en: pcie-pwr-en { rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>; };
@@ -570,10 +617,26 @@ };
usb2 { - host_vbus_drv: host-vbus-drv { + vcc5v0_host_en: vcc5v0-host-en { rockchip,pins = <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; }; }; + + wifi { + wifi_host_wake_l: wifi-host-wake-l { + rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + leds { + work_led_gpio: work_led-gpio { + rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + diy_led_gpio: diy_led-gpio { + rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; };
&pwm0 { @@ -585,24 +648,70 @@ };
&saradc { - vref-supply = <&vccadc_ref>; + vref-supply = <&vcca1v8_s3>; status = "okay"; };
+&sdio0 { + /* WiFi & BT combo module Ampak AP6356S */ + bus-width = <4>; + cap-sdio-irq; + cap-sd-highspeed; + keep-power-in-suspend; + mmc-pwrseq = <&sdio_pwrseq>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; + sd-uhs-sdr104; + + /* Power supply */ + vqmmc-supply = &vcc1v8_s3; /* IO line */ + vmmc-supply = &vcc_sdio; /* card's power */ + + #address-cells = <1>; + #size-cells = <0>; + status = "okay"; + + brcmf: wifi@1 { + reg = <1>; + compatible = "brcm,bcm4329-fmac"; + interrupt-parent = <&gpio0>; + interrupts = <RK_PA3 GPIO_ACTIVE_HIGH>; + interrupt-names = "host-wake"; + brcm,drive-strength = <5>; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_host_wake_l>; + }; +}; + &sdmmc { bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + cd-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>; + disable-wp; + max-frequency = <150000000>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>; status = "okay"; };
&sdhci { bus-width = <8>; - keep-power-in-suspend; mmc-hs400-1_8v; mmc-hs400-enhanced-strobe; non-removable; status = "okay"; };
+&tcphy0 { + status = "okay"; +}; + +&tcphy1 { + status = "okay"; +}; + &tsadc { /* tshut mode 0:CRU 1:GPIO */ rockchip,hw-tshut-mode = <1>; @@ -662,3 +771,37 @@ &usb_host1_ohci { status = "okay"; }; + +&usbdrd3_0 { + status = "okay"; +}; + +&usbdrd_dwc3_0 { + status = "okay"; + dr_mode = "otg"; +}; + +&usbdrd3_1 { + status = "okay"; +}; + +&usbdrd_dwc3_1 { + status = "okay"; + dr_mode = "host"; +}; + +&vopb { + status = "okay"; +}; + +&vopb_mmu { + status = "okay"; +}; + +&vopl { + status = "okay"; +}; + +&vopl_mmu { + status = "okay"; +}; diff --git a/arch/arm/dts/rk3399-gru-bob.dts b/arch/arm/dts/rk3399-gru-bob.dts index 1ee0dc0d9f..e6c1c94c8d 100644 --- a/arch/arm/dts/rk3399-gru-bob.dts +++ b/arch/arm/dts/rk3399-gru-bob.dts @@ -18,11 +18,11 @@ "google,bob", "google,gru", "rockchip,rk3399";
edp_panel: edp-panel { - compatible = "boe,nv101wxmn51", "simple-panel"; + compatible = "boe,nv101wxmn51"; backlight = <&backlight>; power-supply = <&pp3300_disp>;
- ports { + port { panel_in_edp: endpoint { remote-endpoint = <&edp_out_panel>; }; @@ -68,12 +68,22 @@
&spi0 { status = "okay"; + + cr50@0 { + compatible = "google,cr50"; + reg = <0>; + interrupt-parent = <&gpio0>; + interrupts = <5 IRQ_TYPE_EDGE_RISING>; + pinctrl-names = "default"; + pinctrl-0 = <&h1_int_od_l>; + spi-max-frequency = <800000>; + }; };
&pinctrl { tpm { h1_int_od_l: h1-int-od-l { - rockchip,pins = <0 5 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; }; }; }; diff --git a/arch/arm/dts/rk3399-gru-chromebook.dtsi b/arch/arm/dts/rk3399-gru-chromebook.dtsi index c6495adcca..1384dabbdf 100644 --- a/arch/arm/dts/rk3399-gru-chromebook.dtsi +++ b/arch/arm/dts/rk3399-gru-chromebook.dtsi @@ -194,20 +194,25 @@
backlight: backlight { compatible = "pwm-backlight"; - brightness-levels = <0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 - 17 18 19 20 21 22 23 24 25 26 27 28 29 30 - 31 32 33 34 35 36 37 38 39 40 41 42 43 44 - 45 46 47 48 49 50 51 52 53 54 55 56 57 58 - 59 60 61 62 63 64 65 66 67 68 69 70 71 72 - 73 74 75 76 77 78 79 80 81 82 83 84 85 86 - 87 88 89 90 91 92 93 94 95 96 97 98 99 100>; - default-brightness-level = <51>; enable-gpios = <&gpio1 17 GPIO_ACTIVE_HIGH>; power-supply = <&pp3300_disp>; pinctrl-names = "default"; pinctrl-0 = <&bl_en>; pwm-delay-us = <10000>; }; + + gpio_keys: gpio-keys { + compatible = "gpio-keys"; + pinctrl-names = "default"; + pinctrl-0 = <&bt_host_wake_l>; + + wake_on_bt: wake-on-bt { + label = "Wake-on-Bluetooth"; + gpios = <&gpio0 3 GPIO_ACTIVE_LOW>; + linux,code = <KEY_WAKEUP>; + wakeup-source; + }; + }; };
&ppvar_bigcpu { @@ -232,7 +237,6 @@ &edp { status = "okay";
- rockchip,panel = <&edp_panel>; ports { edp_out: port@1 { reg = <1>; @@ -287,11 +291,9 @@ ap_i2c_tp: &i2c5 { #pwm-cells = <1>; };
- usbc_extcon1: extcon@1 { + usbc_extcon1: extcon1 { compatible = "google,extcon-usbc-cros-ec"; google,usb-port-id = <1>; - - #extcon-cells = <0>; }; };
@@ -361,27 +363,27 @@ ap_i2c_tp: &i2c5 { &pinctrl { discrete-regulators { pp1500_en: pp1500-en { - rockchip,pins = <RK_GPIO0 10 RK_FUNC_GPIO + rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; };
pp1800_audio_en: pp1800-audio-en { - rockchip,pins = <RK_GPIO0 2 RK_FUNC_GPIO + rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_down>; };
pp3000_en: pp3000-en { - rockchip,pins = <RK_GPIO0 12 RK_FUNC_GPIO + rockchip,pins = <0 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>; };
pp3300_disp_en: pp3300-disp-en { - rockchip,pins = <RK_GPIO4 27 RK_FUNC_GPIO + rockchip,pins = <4 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; };
wlan_module_pd_l: wlan-module-pd-l { - rockchip,pins = <RK_GPIO0 4 RK_FUNC_GPIO + rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_down>; }; }; @@ -389,10 +391,10 @@ ap_i2c_tp: &i2c5 {
&wifi { wifi_perst_l: wifi-perst-l { - rockchip,pins = <2 27 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; };
wlan_host_wake_l: wlan-host-wake-l { - rockchip,pins = <0 8 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; }; }; diff --git a/arch/arm/dts/rk3399-gru-kevin.dts b/arch/arm/dts/rk3399-gru-kevin.dts index 2cc7c47d6a..2bbef9fcbe 100644 --- a/arch/arm/dts/rk3399-gru-kevin.dts +++ b/arch/arm/dts/rk3399-gru-kevin.dts @@ -39,11 +39,25 @@ };
edp_panel: edp-panel { - compatible = "sharp,lq123p1jx31", "simple-panel"; + compatible = "sharp,lq123p1jx31"; backlight = <&backlight>; power-supply = <&pp3300_disp>;
- ports { + panel-timing { + clock-frequency = <266666667>; + hactive = <2400>; + hfront-porch = <48>; + hback-porch = <84>; + hsync-len = <32>; + hsync-active = <0>; + vactive = <1600>; + vfront-porch = <3>; + vback-porch = <120>; + vsync-len = <10>; + vsync-active = <0>; + }; + + port { panel_in_edp: endpoint { remote-endpoint = <&edp_out_panel>; }; @@ -118,13 +132,17 @@ map0 { trip = <&ppvar_bigcpu_alert>; cooling-device = - <&cpu_l0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + <&cpu_l0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu_l1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu_l2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu_l3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; contribution = <4096>; }; map1 { trip = <&ppvar_bigcpu_alert>; cooling-device = - <&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + <&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu_b1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; contribution = <1024>; }; }; @@ -286,24 +304,24 @@ ap_i2c_dig: &i2c2 { digitizer { /* Has external pullup */ cpu1_dig_irq_l: cpu1-dig-irq-l { - rockchip,pins = <2 4 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <2 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; };
/* Has external pullup */ cpu1_dig_pdct_l: cpu1-dig-pdct-l { - rockchip,pins = <2 5 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <2 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; }; };
discrete-regulators { cpu3_pen_pwr_en: cpu3-pen-pwr-en { - rockchip,pins = <4 30 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>; }; };
pen { cpu1_pen_eject: cpu1-pen-eject { - rockchip,pins = <0 13 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_up>; }; }; }; diff --git a/arch/arm/dts/rk3399-gru.dtsi b/arch/arm/dts/rk3399-gru.dtsi index 0e2e047180..34f03cf92d 100644 --- a/arch/arm/dts/rk3399-gru.dtsi +++ b/arch/arm/dts/rk3399-gru.dtsi @@ -11,13 +11,7 @@
/ { chosen { - u-boot,dm-pre-reloc; stdout-path = "serial2:115200n8"; - u-boot,spl-boot-order = &spi_flash; - }; - - config { - u-boot,spl-payload-offset = <0x40000>; };
/* @@ -268,17 +262,11 @@ pp5000_usb_a_vbus: pp5000 { };
- gpio_keys: gpio-keys { - compatible = "gpio-keys"; - pinctrl-names = "default"; - pinctrl-0 = <&bt_host_wake_l>; - - wake_on_bt: wake-on-bt { - label = "Wake-on-Bluetooth"; - gpios = <&gpio0 3 GPIO_ACTIVE_LOW>; - linux,code = <KEY_WAKEUP>; - wakeup-source; - }; + ap_rtc_clk: ap-rtc-clk { + compatible = "fixed-clock"; + clock-frequency = <32768>; + clock-output-names = "xin32k"; + #clock-cells = <0>; };
max98357a: max98357a { @@ -354,6 +342,7 @@ cpu-supply = <&ppvar_bigcpu>; };
+ &cru { assigned-clocks = <&cru PLL_GPLL>, <&cru PLL_CPLL>, @@ -549,8 +538,7 @@ ap_i2c_audio: &i2c8 { pinctrl-names = "default", "sleep"; pinctrl-1 = <&spi1_sleep>;
- spi_flash: spiflash@0 { - u-boot,dm-pre-reloc; + spiflash@0 { compatible = "jedec,spi-nor"; reg = <0>;
@@ -565,16 +553,12 @@ ap_i2c_audio: &i2c8 {
&spi5 { status = "okay"; - spi-activate-delay = <100>; - spi-max-frequency = <3000000>; - spi-deactivate-delay = <200>;
cros_ec: ec@0 { compatible = "google,cros-ec-spi"; reg = <0>; interrupt-parent = <&gpio0>; interrupts = <1 IRQ_TYPE_LEVEL_LOW>; - ec-interrupt = <&gpio0 1 GPIO_ACTIVE_LOW>; pinctrl-names = "default"; pinctrl-0 = <&ec_ap_int_l>; spi-max-frequency = <3000000>; @@ -586,11 +570,9 @@ ap_i2c_audio: &i2c8 { #size-cells = <0>; };
- usbc_extcon0: extcon@0 { + usbc_extcon0: extcon0 { compatible = "google,extcon-usbc-cros-ec"; google,usb-port-id = <0>; - - #extcon-cells = <0>; }; }; }; @@ -692,29 +674,29 @@ ap_i2c_audio: &i2c8 {
backlight-enable { bl_en: bl-en { - rockchip,pins = <1 17 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>; }; };
cros-ec { ec_ap_int_l: ec-ap-int-l { - rockchip,pins = <RK_GPIO0 1 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <0 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up>; }; };
discrete-regulators { sd_io_pwr_en: sd-io-pwr-en { - rockchip,pins = <RK_GPIO2 2 RK_FUNC_GPIO + rockchip,pins = <2 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; };
sd_pwr_1800_sel: sd-pwr-1800-sel { - rockchip,pins = <RK_GPIO2 28 RK_FUNC_GPIO + rockchip,pins = <2 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; };
sd_slot_pwr_en: sd-slot-pwr-en { - rockchip,pins = <RK_GPIO4 29 RK_FUNC_GPIO + rockchip,pins = <4 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>; }; }; @@ -722,17 +704,17 @@ ap_i2c_audio: &i2c8 { codec { /* Has external pullup */ headset_int_l: headset-int-l { - rockchip,pins = <1 23 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <1 RK_PC7 RK_FUNC_GPIO &pcfg_pull_none>; };
mic_int: mic-int { - rockchip,pins = <1 13 RK_FUNC_GPIO &pcfg_pull_down>; + rockchip,pins = <1 RK_PB5 RK_FUNC_GPIO &pcfg_pull_down>; }; };
max98357a { sdmode_en: sdmode-en { - rockchip,pins = <1 2 RK_FUNC_GPIO &pcfg_pull_down>; + rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_down>; }; };
@@ -743,7 +725,7 @@ ap_i2c_audio: &i2c8 { * to hack this as gpio, so the EP could be able to * de-assert it along and make ClockPM(CPM) work. */ - rockchip,pins = <2 26 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; }; };
@@ -754,20 +736,20 @@ ap_i2c_audio: &i2c8 { */ sdmmc_bus4: sdmmc-bus4 { rockchip,pins = - <4 8 RK_FUNC_1 &pcfg_pull_none_8ma>, - <4 9 RK_FUNC_1 &pcfg_pull_none_8ma>, - <4 10 RK_FUNC_1 &pcfg_pull_none_8ma>, - <4 11 RK_FUNC_1 &pcfg_pull_none_8ma>; + <4 RK_PB0 1 &pcfg_pull_none_8ma>, + <4 RK_PB1 1 &pcfg_pull_none_8ma>, + <4 RK_PB2 1 &pcfg_pull_none_8ma>, + <4 RK_PB3 1 &pcfg_pull_none_8ma>; };
sdmmc_clk: sdmmc-clk { rockchip,pins = - <4 12 RK_FUNC_1 &pcfg_pull_none_8ma>; + <4 RK_PB4 1 &pcfg_pull_none_8ma>; };
sdmmc_cmd: sdmmc-cmd { rockchip,pins = - <4 13 RK_FUNC_1 &pcfg_pull_none_8ma>; + <4 RK_PB5 1 &pcfg_pull_none_8ma>; };
/* @@ -781,12 +763,12 @@ ap_i2c_audio: &i2c8 { */ sdmmc_cd: sdmmc-cd { rockchip,pins = - <0 7 RK_FUNC_1 &pcfg_pull_none>; + <0 RK_PA7 1 &pcfg_pull_none>; };
/* This is where we actually hook up CD; has external pull */ sdmmc_cd_gpio: sdmmc-cd-gpio { - rockchip,pins = <4 24 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; }; };
@@ -796,47 +778,47 @@ ap_i2c_audio: &i2c8 { * Pull down SPI1 CLK/CS/RX/TX during suspend, to * prevent leakage. */ - rockchip,pins = <1 9 RK_FUNC_GPIO &pcfg_pull_down>, - <1 10 RK_FUNC_GPIO &pcfg_pull_down>, - <1 7 RK_FUNC_GPIO &pcfg_pull_down>, - <1 8 RK_FUNC_GPIO &pcfg_pull_down>; + rockchip,pins = <1 RK_PB1 RK_FUNC_GPIO &pcfg_pull_down>, + <1 RK_PB2 RK_FUNC_GPIO &pcfg_pull_down>, + <1 RK_PA7 RK_FUNC_GPIO &pcfg_pull_down>, + <1 RK_PB0 RK_FUNC_GPIO &pcfg_pull_down>; }; };
touchscreen { touch_int_l: touch-int-l { - rockchip,pins = <3 13 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <3 RK_PB5 RK_FUNC_GPIO &pcfg_pull_up>; };
touch_reset_l: touch-reset-l { - rockchip,pins = <4 26 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; }; };
trackpad { ap_i2c_tp_pu_en: ap-i2c-tp-pu-en { - rockchip,pins = <3 12 RK_FUNC_GPIO &pcfg_output_high>; + rockchip,pins = <3 RK_PB4 RK_FUNC_GPIO &pcfg_output_high>; };
trackpad_int_l: trackpad-int-l { - rockchip,pins = <1 4 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <1 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>; }; };
wifi: wifi { wlan_module_reset_l: wlan-module-reset-l { - rockchip,pins = <1 11 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <1 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; };
bt_host_wake_l: bt-host-wake-l { /* Kevin has an external pull up, but Gru does not */ - rockchip,pins = <0 3 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; }; };
write-protect { ap_fw_wp: ap-fw-wp { - rockchip,pins = <1 18 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_up>; }; }; }; diff --git a/arch/arm/dts/rk3399-khadas-edge.dtsi b/arch/arm/dts/rk3399-khadas-edge.dtsi index 4944d78a0a..e87a044774 100644 --- a/arch/arm/dts/rk3399-khadas-edge.dtsi +++ b/arch/arm/dts/rk3399-khadas-edge.dtsi @@ -654,9 +654,12 @@ sd-uhs-sdr104; vqmmc-supply = <&vcc1v8_s3>; vmmc-supply = <&vccio_sd>; + #address-cells = <1>; + #size-cells = <0>; status = "okay";
brcmf: wifi@1 { + reg = <1>; compatible = "brcm,bcm4329-fmac"; interrupt-parent = <&gpio0>; interrupts = <RK_PA3 GPIO_ACTIVE_HIGH>; diff --git a/arch/arm/dts/rk3399-leez-p710.dts b/arch/arm/dts/rk3399-leez-p710.dts index 32baa57b94..73be38a537 100644 --- a/arch/arm/dts/rk3399-leez-p710.dts +++ b/arch/arm/dts/rk3399-leez-p710.dts @@ -42,14 +42,14 @@ regulator-max-microvolt = <5000000>; };
- vcc5v0_sys: vcc5v0-sys { + vcc3v3_lan: vcc3v3-lan { compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; + regulator-name = "vcc3v3_lan"; regulator-always-on; regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&dc5v_adp>; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vim-supply = <&vcc3v3_sys>; };
vcc3v3_sys: vcc3v3-sys { @@ -83,14 +83,14 @@ vin-supply = <&vcc5v0_sys>; };
- vcc3v3_lan: vcc3v3-lan { + vcc5v0_sys: vcc5v0-sys { compatible = "regulator-fixed"; - regulator-name = "vcc3v3_lan"; + regulator-name = "vcc5v0_sys"; regulator-always-on; regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vim-supply = <&vcc3v3_sys>; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&dc5v_adp>; };
vdd_log: vdd-log { @@ -510,6 +510,14 @@ }; };
+&sdhci { + bus-width = <8>; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + non-removable; + status = "okay"; +}; + &sdmmc { bus-width = <4>; cap-mmc-highspeed; @@ -522,14 +530,6 @@ status = "okay"; };
-&sdhci { - bus-width = <8>; - mmc-hs400-1_8v; - mmc-hs400-enhanced-strobe; - non-removable; - status = "okay"; -}; - &tcphy0 { status = "okay"; }; diff --git a/arch/arm/dts/rk3399-nanopc-t4.dts b/arch/arm/dts/rk3399-nanopc-t4.dts index 84433cf02b..e0d75617bb 100644 --- a/arch/arm/dts/rk3399-nanopc-t4.dts +++ b/arch/arm/dts/rk3399-nanopc-t4.dts @@ -52,13 +52,58 @@ pinctrl-names = "default"; pinctrl-0 = <&ir_rx>; }; + + fan: pwm-fan { + compatible = "pwm-fan"; + /* + * With 20KHz PWM and an EVERCOOL EC4007H12SA fan, these levels + * work out to 0, ~1200, ~3000, and 5000RPM respectively. + */ + cooling-levels = <0 12 18 255>; + #cooling-cells = <2>; + fan-supply = <&vcc12v0_sys>; + pwms = <&pwm1 0 50000 0>; + }; +}; + +&cpu_thermal { + trips { + cpu_warm: cpu_warm { + temperature = <55000>; + hysteresis = <2000>; + type = "active"; + }; + + cpu_hot: cpu_hot { + temperature = <65000>; + hysteresis = <2000>; + type = "active"; + }; + }; + + cooling-maps { + map2 { + trip = <&cpu_warm>; + cooling-device = <&fan THERMAL_NO_LIMIT 1>; + }; + + map3 { + trip = <&cpu_hot>; + cooling-device = <&fan 2 THERMAL_NO_LIMIT>; + }; + }; +}; + +&pcie0 { + num-lanes = <4>; + vpcie3v3-supply = <&vcc3v3_sys>; };
&pinctrl { ir { ir_rx: ir-rx { /* external pullup to VCC3V3_SYS, despite being 1.8V :/ */ - rockchip,pins = <0 RK_PA6 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PA6 1 &pcfg_pull_none>; }; }; }; diff --git a/arch/arm/dts/rk3399-nanopi4.dtsi b/arch/arm/dts/rk3399-nanopi4.dtsi index d325e11728..c88018a0ef 100644 --- a/arch/arm/dts/rk3399-nanopi4.dtsi +++ b/arch/arm/dts/rk3399-nanopi4.dtsi @@ -48,7 +48,7 @@ };
/* switched by pmic_sleep */ - vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 { + vcc1v8_s3: vcc1v8-s3 { compatible = "regulator-fixed"; regulator-always-on; regulator-boot-on; @@ -71,6 +71,27 @@ vin-supply = <&vcc3v3_sys>; };
+ /* + * Really, this is supplied by vcc_1v8, and vcc1v8_s3 only + * drives the enable pin, but we can't quite model that. + */ + vcca0v9_s3: vcca0v9-s3 { + compatible = "regulator-fixed"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-name = "vcca0v9_s3"; + vin-supply = <&vcc1v8_s3>; + }; + + /* As above, actually supplied by vcc3v3_sys */ + vcca1v8_s3: vcca1v8-s3 { + compatible = "regulator-fixed"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcca1v8_s3"; + vin-supply = <&vcc1v8_s3>; + }; + vbus_typec: vbus-typec { compatible = "regulator-fixed"; regulator-min-microvolt = <5000000>; @@ -148,15 +169,28 @@ assigned-clocks = <&cru SCLK_RMII_SRC>; clock_in_out = "input"; pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; + pinctrl-0 = <&rgmii_pins>, <&phy_intb>, <&phy_rstb>; + phy-handle = <&rtl8211e>; phy-mode = "rgmii"; phy-supply = <&vcc3v3_s3>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 50000>; - snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; tx_delay = <0x28>; rx_delay = <0x11>; status = "okay"; + + mdio { + compatible = "snps,dwmac-mdio"; + #address-cells = <1>; + #size-cells = <0>; + + rtl8211e: phy@1 { + reg = <1>; + interrupt-parent = <&gpio3>; + interrupts = <RK_PB2 IRQ_TYPE_LEVEL_LOW>; + reset-assert-us = <10000>; + reset-deassert-us = <30000>; + reset-gpios = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; + }; + }; };
&gpu { @@ -171,6 +205,10 @@ status = "okay"; };
+&hdmi_sound { + status = "okay"; +}; + &i2c0 { clock-frequency = <400000>; i2c-scl-rising-time-ns = <160>; @@ -446,6 +484,10 @@ status = "okay"; };
+&i2s2 { + status = "okay"; +}; + &io_domains { bt656-supply = <&vcc_1v8>; audio-supply = <&vcca1v8_codec>; @@ -464,7 +506,9 @@ &pcie0 { ep-gpios = <&gpio2 RK_PA4 GPIO_ACTIVE_HIGH>; max-link-speed = <2>; - num-lanes = <4>; + num-lanes = <2>; + vpcie0v9-supply = <&vcca0v9_s3>; + vpcie1v8-supply = <&vcca1v8_s3>; status = "okay"; };
@@ -481,6 +525,16 @@ }; };
+ phy { + phy_intb: phy-intb { + rockchip,pins = <3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + phy_rstb: phy-rstb { + rockchip,pins = <3 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + pmic { cpu_b_sleep: cpu-b-sleep { rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>; diff --git a/arch/arm/dts/rk3399-orangepi.dts b/arch/arm/dts/rk3399-orangepi.dts index cf37b96a6b..f9f7246d4d 100644 --- a/arch/arm/dts/rk3399-orangepi.dts +++ b/arch/arm/dts/rk3399-orangepi.dts @@ -136,13 +136,13 @@ vin-supply = <&vcc_sys>; };
- vcc5v0_typec0: vcc5v0-typec0-regulator { + vbus_typec: vbus-typec-regulator { compatible = "regulator-fixed"; enable-active-high; gpio = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_typec0_en>; - regulator-name = "vcc5v0_typec0"; + pinctrl-0 = <&vcc5v0_typec_en>; + regulator-name = "vbus_typec"; vin-supply = <&vcc_sys>; };
@@ -202,14 +202,27 @@ clock_in_out = "input"; phy-supply = <&vcc3v3_s3>; phy-mode = "rgmii"; + phy-handle = <&rtl8211e>; pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 50000>; + pinctrl-0 = <&rgmii_pins>, <&phy_intb>, <&phy_rstb>; tx_delay = <0x28>; rx_delay = <0x11>; status = "okay"; + + mdio { + compatible = "snps,dwmac-mdio"; + #address-cells = <1>; + #size-cells = <0>; + + rtl8211e: phy@1 { + reg = <1>; + interrupt-parent = <&gpio3>; + interrupts = <RK_PB2 IRQ_TYPE_LEVEL_LOW>; + reset-assert-us = <10000>; + reset-deassert-us = <30000>; + reset-gpios = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; + }; + }; };
&gpu { @@ -419,6 +432,8 @@ compatible = "silergy,syr827"; reg = <0x40>; fcs,suspend-voltage-selector = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&cpu_b_sleep>; regulator-name = "vdd_cpu_b"; regulator-min-microvolt = <712500>; regulator-max-microvolt = <1500000>; @@ -436,6 +451,8 @@ compatible = "silergy,syr828"; reg = <0x41>; fcs,suspend-voltage-selector = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&gpu_sleep>; regulator-name = "vdd_gpu"; regulator-min-microvolt = <712500>; regulator-max-microvolt = <1500000>; @@ -472,6 +489,7 @@ compatible = "asahi-kasei,ak09911"; reg = <0x0c>; vdd-supply = <&vcc3v3_s3>; + vid-supply = <&vcc3v3_s3>; };
mpu6500@68 { @@ -504,6 +522,16 @@ pinctrl-0 = <&light_int_l>; vdd-supply = <&vcc3v3_s3>; }; + + fusb302@22 { + compatible = "fcs,fusb302"; + reg = <0x22>; + interrupt-parent = <&gpio1>; + interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&chg_cc_int_l>; + vbus-supply = <&vbus_typec>; + }; };
&io_domains { @@ -526,7 +554,25 @@ }; };
+ phy { + phy_intb: phy-intb { + rockchip,pins = <3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + phy_rstb: phy-rstb { + rockchip,pins = <3 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + pmic { + cpu_b_sleep: cpu-b-sleep { + rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + gpu_sleep: gpu-sleep { + rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; + }; + pmic_int_l: pmic-int-l { rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; @@ -536,7 +582,7 @@ sd { sdmmc0_pwr_h: sdmmc0-pwr-h { rockchip,pins = - <RK_GPIO0 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; + <0 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; }; };
@@ -546,7 +592,7 @@ <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; };
- vcc5v0_typec0_en: vcc5v0-typec0-en { + vcc5v0_typec_en: vcc5v0-typec-en { rockchip,pins = <1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; }; @@ -595,6 +641,12 @@ rockchip,pins = <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; }; }; + + fusb302 { + chg_cc_int_l: chg-cc-int-l { + rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; };
&pwm0 { @@ -631,9 +683,12 @@ pinctrl-names = "default"; pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; sd-uhs-sdr104; + #address-cells = <1>; + #size-cells = <0>; status = "okay";
brcmf: wifi@1 { + reg = <1>; compatible = "brcm,bcm4329-fmac"; interrupt-parent = <&gpio0>; interrupts = <RK_PA3 GPIO_ACTIVE_HIGH>; @@ -676,7 +731,7 @@ status = "okay";
u2phy0_otg: otg-port { - phy-supply = <&vcc5v0_typec0>; + phy-supply = <&vbus_typec>; status = "okay"; };
@@ -707,12 +762,14 @@ bluetooth { compatible = "brcm,bcm43438-bt"; clocks = <&rk808 1>; - clock-names = "ext_clock"; + clock-names = "lpo"; device-wakeup-gpios = <&gpio2 RK_PD2 GPIO_ACTIVE_HIGH>; host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>; shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_reg_on_h>; + vbat-supply = <&vcc3v3_sys>; + vddio-supply = <&vcc_1v8>; }; };
diff --git a/arch/arm/dts/rk3399-puma-u-boot.dtsi b/arch/arm/dts/rk3399-puma-u-boot.dtsi index e664779227..0253c6525f 100644 --- a/arch/arm/dts/rk3399-puma-u-boot.dtsi +++ b/arch/arm/dts/rk3399-puma-u-boot.dtsi @@ -13,7 +13,7 @@ chosen { stdout-path = "serial0:115200n8"; u-boot,spl-boot-order = \ - "same-as-spl", &spiflash, &sdhci, &sdmmc; + "same-as-spl", &norflash, &sdhci, &sdmmc; };
aliases { @@ -21,10 +21,23 @@ spi1 = &spi5; };
-}; - -&bios_enable { - u-boot,dm-pre-reloc; + /* + * The Qseven BIOS_DISABLE signal on the RK3399-Q7 keeps the on-module + * eMMC and SPI flash powered-down initially (in fact it keeps the + * reset signal asserted). Even though it is an enable signal, we + * model this as a regulator. + */ + bios_enable: bios_enable { + compatible = "regulator-fixed"; + u-boot,dm-pre-reloc; + regulator-name = "bios_enable"; + enable-active-high; + gpio = <&gpio3 RK_PD5 GPIO_ACTIVE_LOW>; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; };
&gpio1 { @@ -35,6 +48,6 @@ u-boot,dm-pre-reloc; };
-&spiflash { +&norflash { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/rk3399-puma.dtsi b/arch/arm/dts/rk3399-puma.dtsi index 246a892cb7..07694b196f 100644 --- a/arch/arm/dts/rk3399-puma.dtsi +++ b/arch/arm/dts/rk3399-puma.dtsi @@ -1,30 +1,74 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* - * (C) Copyright 2017 Theobroma Systems Design und Consulting GmbH + * Copyright (c) 2017 Theobroma Systems Design und Consulting GmbH */
#include <dt-bindings/pwm/pwm.h> #include "rk3399.dtsi" +#include "rk3399-opp.dtsi"
/ { - model = "Theobroma Systems RK3399-Q7 SoM"; - compatible = "tsd,rk3399-q7", "tsd,puma", "rockchip,rk3399"; - leds { compatible = "gpio-leds"; pinctrl-names = "default"; - pinctrl-0 = <&leds_pins_puma>; + pinctrl-0 = <&led_pin_module>;
- module_led { + module-led { label = "module_led"; gpios = <&gpio2 RK_PD1 GPIO_ACTIVE_HIGH>; linux,default-trigger = "heartbeat"; + panic-indicator; }; + };
- sd_card_led { - label = "sd_card_led"; - gpios = <&gpio1 RK_PA2 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "mmc0"; + /* + * Overwrite the opp-table for CPUB as this board uses a different + * regulator (FAN53555) that only allows 10mV steps and therefore + * can't reach the operation point target voltages from rk3399-opp.dtsi + */ + /delete-node/ opp-table1; + cluster1_opp: opp-table1 { + compatible = "operating-points-v2"; + opp-shared; + + opp00 { + opp-hz = /bits/ 64 <408000000>; + opp-microvolt = <800000>; + clock-latency-ns = <40000>; + }; + opp01 { + opp-hz = /bits/ 64 <600000000>; + opp-microvolt = <800000>; + }; + opp02 { + opp-hz = /bits/ 64 <816000000>; + opp-microvolt = <830000>; + opp-suspend; + }; + opp03 { + opp-hz = /bits/ 64 <1008000000>; + opp-microvolt = <880000>; + }; + opp04 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <950000>; + }; + opp05 { + opp-hz = /bits/ 64 <1416000000>; + opp-microvolt = <1030000>; + }; + opp06 { + opp-hz = /bits/ 64 <1608000000>; + opp-microvolt = <1100000>; + }; + opp07 { + opp-hz = /bits/ 64 <1800000000>; + opp-microvolt = <1200000>; + }; + opp08 { + opp-hz = /bits/ 64 <1992000000>; + opp-microvolt = <1230000>; + turbo-mode; }; };
@@ -35,78 +79,14 @@ #clock-cells = <0>; };
- dw_hdmi_audio: dw-hdmi-audio { - status = "enabled"; - compatible = "rockchip,dw-hdmi-audio"; - #sound-dai-cells = <0>; - }; - - hdmi_codec: hdmi-codec { - compatible = "simple-audio-card"; - simple-audio-card,format = "i2s"; - simple-audio-card,mclk-fs = <256>; - simple-audio-card,name = "HDMI-CODEC"; - - simple-audio-card,cpu { - sound-dai = <&i2s2>; - }; - - simple-audio-card,codec { - sound-dai = <&hdmi>; - }; - }; - - hdmi_sound: hdmi-sound { - status = "disabled"; - compatible = "simple-audio-card"; - simple-audio-card,format = "i2s"; - simple-audio-card,mclk-fs = <256>; - simple-audio-card,name = "rockchip,hdmi"; - - simple-audio-card,cpu { - sound-dai = <&i2s2>; - }; - simple-audio-card,codec { - sound-dai = <&hdmi>; - }; - }; - - usbhub_enable: usbhub_enable { + vcc1v2_phy: vcc1v2-phy { compatible = "regulator-fixed"; - regulator-name = "usbhub_enable"; - enable-active-low; - gpio = <&gpio4 RK_PA3 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&host_vbus_drv>; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - /* - * The Qseven BIOS_DISABLE signal on the RK3399-Q7 keeps the on-module - * eMMC and SPI flash powered-down initially (in fact it keeps the - * reset signal asserted). Even though it is an enable signal, we - * model this as a regulator. - */ - bios_enable: bios_enable { - compatible = "regulator-fixed"; - regulator-name = "bios_enable"; - enable-active-high; - gpio = <&gpio3 RK_PD5 GPIO_ACTIVE_LOW>; + regulator-name = "vcc1v2_phy"; regulator-always-on; regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - vccadc_ref: vccadc-ref { - compatible = "regulator-fixed"; - regulator-name = "vcc1v8_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + vin-supply = <&vcc5v0_sys>; };
vcc3v3_sys: vcc3v3-sys { @@ -116,16 +96,18 @@ regulator-boot-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; + vin-supply = <&vcc5v0_sys>; };
- vcc5v0_otg: vcc5v0-otg-regulator { + vcc5v0_host: vcc5v0-host-regulator { compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>; + gpio = <&gpio4 RK_PA3 GPIO_ACTIVE_HIGH>; + enable-active-low; pinctrl-names = "default"; - pinctrl-0 = <&otg_vbus_drv>; - regulator-name = "vcc5v0_otg"; + pinctrl-0 = <&vcc5v0_host_en>; + regulator-name = "vcc5v0_host"; regulator-always-on; + vin-supply = <&vcc5v0_sys>; };
vcc5v0_sys: vcc5v0-sys { @@ -136,48 +118,55 @@ regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; }; +};
- vcc_phy: vcc-phy-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_phy"; - regulator-always-on; - regulator-boot-on; - }; +&cpu_b0 { + cpu-supply = <&vdd_cpu_b>; +};
- vdd_log: vdd-log { - compatible = "pwm-regulator"; - pwms = <&pwm2 0 25000 1>; - regulator-name = "vdd_log"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1400000>; - regulator-always-on; - regulator-boot-on; - regulator-init-microvolt = <950000>; - }; +&cpu_b1 { + cpu-supply = <&vdd_cpu_b>; +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l1 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l2 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l3 { + cpu-supply = <&vdd_cpu_l>; };
&emmc_phy { status = "okay"; + drive-impedance-ohm = <33>; };
&gmac { - phy-supply = <&vcc_phy>; - phy-mode = "rgmii"; - clock_in_out = "input"; - snps,reset-gpio = <&gpio3 RK_PC0 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <2 10000 50000>; assigned-clocks = <&cru SCLK_RMII_SRC>; assigned-clock-parents = <&clkin_gmac>; + clock_in_out = "input"; + phy-supply = <&vcc1v2_phy>; + phy-mode = "rgmii"; pinctrl-names = "default"; pinctrl-0 = <&rgmii_pins>; + snps,reset-gpio = <&gpio3 RK_PC0 GPIO_ACTIVE_HIGH>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 50000>; tx_delay = <0x10>; rx_delay = <0x10>; status = "okay"; };
-&hdmi { - #sound-dai-cells = <0>; +&gpu { + mali-supply = <&vdd_gpu>; status = "okay"; };
@@ -187,37 +176,17 @@ i2c-scl-falling-time-ns = <4>; clock-frequency = <400000>;
- vdd_gpu: vdd_gpu { - status = "okay"; - compatible = "fcs,fan53555"; - reg = <0x60>; - vsel-gpios = <&gpio1 RK_PB6 GPIO_ACTIVE_HIGH>; - vin-supply = <&vcc5v0_sys>; - regulator-compatible = "fan53555-reg"; - regulator-name = "vdd_gpu"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <1230000>; - regulator-ramp-delay = <1000>; - fcs,suspend-voltage-selector = <1>; - regulator-always-on; - regulator-boot-on; - regulator-initial-state = <3>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - rk808: pmic@1b { compatible = "rockchip,rk808"; reg = <0x1b>; interrupt-parent = <&gpio1>; - interrupts = <22 IRQ_TYPE_LEVEL_LOW>; // TODO check interrupt? + interrupts = <22 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <1>; + clock-output-names = "xin32k", "rk808-clkout2"; pinctrl-names = "default"; pinctrl-0 = <&pmic_int_l>; rockchip,system-power-controller; wakeup-source; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk808-clkout2";
vcc1-supply = <&vcc5v0_sys>; vcc2-supply = <&vcc5v0_sys>; @@ -234,44 +203,44 @@
regulators { vdd_center: DCDC_REG1 { - regulator-always-on; - regulator-boot-on; + regulator-name = "vdd_center"; regulator-min-microvolt = <750000>; regulator-max-microvolt = <1350000>; regulator-ramp-delay = <6001>; - regulator-name = "vdd_center"; + regulator-always-on; + regulator-boot-on; regulator-state-mem { regulator-off-in-suspend; }; };
vdd_cpu_l: DCDC_REG2 { - regulator-always-on; - regulator-boot-on; + regulator-name = "vdd_cpu_l"; regulator-min-microvolt = <750000>; regulator-max-microvolt = <1350000>; regulator-ramp-delay = <6001>; - regulator-name = "vdd_cpu_l"; + regulator-always-on; + regulator-boot-on; regulator-state-mem { regulator-off-in-suspend; }; };
vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; regulator-always-on; regulator-boot-on; - regulator-name = "vcc_ddr"; regulator-state-mem { regulator-on-in-suspend; }; };
vcc_1v8: DCDC_REG4 { - regulator-always-on; - regulator-boot-on; + regulator-name = "vcc_1v8"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; - regulator-name = "vcc_1v8"; + regulator-always-on; + regulator-boot-on; regulator-state-mem { regulator-on-in-suspend; regulator-suspend-microvolt = <1800000>; @@ -279,32 +248,32 @@ };
vcc_ldo1: LDO_REG1 { - regulator-boot-on; + regulator-name = "vcc_ldo1"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; - regulator-name = "vcc_ldo1"; + regulator-boot-on; regulator-state-mem { regulator-off-in-suspend; }; };
vcc1v8_hdmi: LDO_REG2 { - regulator-always-on; - regulator-boot-on; + regulator-name = "vcc1v8_hdmi"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; - regulator-name = "vcc1v8_hdmi"; + regulator-always-on; + regulator-boot-on; regulator-state-mem { regulator-off-in-suspend; }; };
vcc1v8_pmu: LDO_REG3 { - regulator-always-on; - regulator-boot-on; + regulator-name = "vcc1v8_pmu"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; - regulator-name = "vcc1v8_pmu"; + regulator-always-on; + regulator-boot-on; regulator-state-mem { regulator-on-in-suspend; regulator-suspend-microvolt = <1800000>; @@ -312,11 +281,11 @@ };
vcc_sd: LDO_REG4 { - regulator-always-on; - regulator-boot-on; + regulator-name = "vcc_sd"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <3000000>; - regulator-name = "vcc_sd"; + regulator-always-on; + regulator-boot-on; regulator-state-mem { regulator-on-in-suspend; regulator-suspend-microvolt = <3000000>; @@ -324,79 +293,105 @@ };
vcc_ldo5: LDO_REG5 { - regulator-boot-on; + regulator-name = "vcc_ldo5"; regulator-min-microvolt = <3000000>; regulator-max-microvolt = <3000000>; - regulator-name = "vcc_ldo5"; + regulator-boot-on; regulator-state-mem { regulator-off-in-suspend; }; };
vcc_ldo6: LDO_REG6 { - regulator-boot-on; + regulator-name = "vcc_ldo6"; regulator-min-microvolt = <1500000>; regulator-max-microvolt = <1500000>; - regulator-name = "vcc_ldo6"; + regulator-boot-on; regulator-state-mem { regulator-off-in-suspend; }; };
vcc0v9_hdmi: LDO_REG7 { - regulator-always-on; - regulator-boot-on; + regulator-name = "vcc0v9_hdmi"; regulator-min-microvolt = <900000>; regulator-max-microvolt = <900000>; - regulator-name = "vcc0v9_hdmi"; + regulator-always-on; + regulator-boot-on; regulator-state-mem { regulator-off-in-suspend; }; };
vcc_efuse: LDO_REG8 { - regulator-always-on; - regulator-boot-on; + regulator-name = "vcc_efuse"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; - regulator-name = "vcc_efuse"; + regulator-always-on; + regulator-boot-on; regulator-state-mem { regulator-off-in-suspend; }; };
vcc3v3_s3: SWITCH_REG1 { + regulator-name = "vcc3v3_s3"; regulator-always-on; regulator-boot-on; - regulator-name = "vcc3v3_s3"; regulator-state-mem { regulator-off-in-suspend; }; };
vcc3v3_s0: SWITCH_REG2 { + regulator-name = "vcc3v3_s0"; regulator-always-on; regulator-boot-on; - regulator-name = "vcc3v3_s0"; regulator-state-mem { regulator-off-in-suspend; }; }; }; }; + + vdd_gpu: regulator@60 { + compatible = "fcs,fan53555"; + reg = <0x60>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_gpu"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <1230000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc5v0_sys>; + }; +}; + +&i2c7 { + status = "okay"; + clock-frequency = <400000>; + + fan: fan@18 { + compatible = "ti,amc6821"; + reg = <0x18>; + #cooling-cells = <2>; + }; + + rtc_twi: rtc@6f { + compatible = "isil,isl1208"; + reg = <0x6f>; + }; };
&i2c8 { status = "okay"; clock-frequency = <400000>;
- vdd_cpu_b: vdd_cpu_b { - status = "okay"; + vdd_cpu_b: regulator@60 { compatible = "fcs,fan53555"; reg = <0x60>; - vsel-gpios = <&gpio1 RK_PA4 GPIO_ACTIVE_HIGH>; vin-supply = <&vcc5v0_sys>; - regulator-compatible = "fan53555-reg"; regulator-name = "vdd_cpu_b"; regulator-min-microvolt = <600000>; regulator-max-microvolt = <1230000>; @@ -404,48 +399,36 @@ fcs,suspend-voltage-selector = <1>; regulator-always-on; regulator-boot-on; - regulator-initial-state = <3>; - regulator-state-mem { - regulator-off-in-suspend; - }; }; };
&i2s0 { + pinctrl-0 = <&i2s0_2ch_bus>; + rockchip,playback-channels = <2>; + rockchip,capture-channels = <2>; status = "okay"; - rockchip,i2s-broken-burst-len; - rockchip,playback-channels = <8>; - rockchip,capture-channels = <8>; - #sound-dai-cells = <0>; };
-&i2s2 { - #sound-dai-cells = <0>; - status = "okay"; +/* + * As Q7 does not specify neither a global nor a RX clock for I2S these + * signals are not used. Furthermore I2S0_LRCK_RX is used as GPIO. + * Therefore we have to redefine the i2s0_2ch_bus definition to prevent + * conflicts. + */ +&i2s0_2ch_bus { + rockchip,pins = + <3 RK_PD0 1 &pcfg_pull_none>, + <3 RK_PD2 1 &pcfg_pull_none>, + <3 RK_PD3 1 &pcfg_pull_none>, + <3 RK_PD7 1 &pcfg_pull_none>; };
&io_domains { status = "okay"; - - bt656-supply = <&vcc_1v8>; /* bt656_gpio2ab_ms */ - audio-supply = <&vcc_1v8>; /* audio_gpio3d4a_ms */ - sdmmc-supply = <&vcc_sd>; /* sdmmc_gpio4b_ms */ - gpio1830-supply = <&vcc_1v8>; /* gpio1833_gpio4cd_ms */ -}; - -&pcie0 { - assigned-clocks = <&cru SCLK_PCIEPHY_REF>; - assigned-clock-parents = <&cru SCLK_PCIEPHY_REF100M>; - assigned-clock-rates = <100000000>; - ep-gpios = <&gpio4 RK_PC6 GPIO_ACTIVE_HIGH>; - num-lanes = <4>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie_clkreqn>; - status = "okay"; -}; - -&pcie_phy { - status = "okay"; + bt656-supply = <&vcc_1v8>; + audio-supply = <&vcc_1v8>; + sdmmc-supply = <&vcc_sd>; + gpio1830-supply = <&vcc_1v8>; };
&pmu_io_domains { @@ -453,185 +436,99 @@ pmu1830-supply = <&vcc_1v8>; };
-&pwm0 { - status = "okay"; -}; - &pwm2 { status = "okay"; };
-&sdhci { - bus-width = <8>; - mmc-hs400-1_8v; - supports-emmc; - non-removable; - keep-power-in-suspend; - mmc-hs400-enhanced-strobe; - status = "okay"; -}; - -&sdmmc { - clock-frequency = <150000000>; - max-frequency = <40000000>; - supports-sd; - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - disable-wp; - num-slots = <1>; - vqmmc-supply = <&vcc_sd>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&usb_host0_ehci { - status = "disabled"; -}; - -&usb_host0_ohci { - status = "disabled"; -}; - -&usbdrd3_0 { - status = "okay"; -}; - -&usb_host1_ehci { - status = "disabled"; -}; - -&usb_host1_ohci { - status = "disabled"; -}; - -&usbdrd3_1 { - status = "okay"; - tsd,usb-port-power = "usbhub_enable"; -}; - -&vopb { - status = "okay"; -}; - &pinctrl { - /* Pins that are not explicitely used by any devices */ - pinctrl-names = "default"; - pinctrl-0 = <&puma_pin_hog>; - - hog { - puma_pin_hog: puma_pin_hog { + i2c8 { + i2c8_xfer_a: i2c8-xfer { rockchip,pins = - /* We need pull-ups on Q7 buttons */ - <RK_GPIO0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>, /* LID_BTN# */ - <RK_GPIO0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>, /* BATLOW# */ - <RK_GPIO0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_up>, /* SLP_BTN# */ - <RK_GPIO0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>; /* BIOS_DISABLE# */ + <1 RK_PC4 1 &pcfg_pull_up>, + <1 RK_PC5 1 &pcfg_pull_up>; }; };
- pmic { - pmic_int_l: pmic-int-l { + leds { + led_pin_module: led-module-gpio { rockchip,pins = - <RK_GPIO1 RK_PC6 RK_FUNC_GPIO &pcfg_pull_up>; + <2 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; }; };
- leds_pins_puma: led_pins@0 { - rockchip,pins = - <RK_GPIO2 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>, - <RK_GPIO1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - usb2 { - otg_vbus_drv: otg-vbus-drv { - rockchip,pins = - <RK_GPIO0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - host_vbus_drv: host-vbus-drv { + pmic { + pmic_int_l: pmic-int-l { rockchip,pins = - <RK_GPIO4 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; + <1 RK_PC6 RK_FUNC_GPIO &pcfg_pull_up>; }; };
- i2c8 { - i2c8_xfer_a: i2c8-xfer { + usb2 { + vcc5v0_host_en: vcc5v0-host-en { rockchip,pins = - <RK_GPIO1 RK_PC5 RK_FUNC_1 &pcfg_pull_up>, - <RK_GPIO1 RK_PC4 RK_FUNC_1 &pcfg_pull_up>; + <4 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; }; }; };
-&i2c1 { +&sdhci { + bus-width = <8>; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + non-removable; status = "okay"; - clock-frequency = <400000>; }; -&i2c2 { - status = "okay"; - clock-frequency = <400000>; + +&sdmmc { + vqmmc-supply = <&vcc_sd>; }; -&i2c4 { + +&spi1 { status = "okay"; - clock-frequency = <400000>; + + norflash: flash@0 { + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <50000000>; + }; }; -&i2c6 { + +&tcphy1 { status = "okay"; - clock-frequency = <400000>; };
-&i2c6_xfer { - /* Enable pull-ups, the pins would float otherwise. */ - rockchip,pins = - <RK_GPIO2 RK_PB2 RK_FUNC_2 &pcfg_pull_up>, - <RK_GPIO2 RK_PB1 RK_FUNC_2 &pcfg_pull_up>; +&tsadc { + rockchip,hw-tshut-mode = <1>; + rockchip,hw-tshut-polarity = <1>; + status = "okay"; };
-&i2c7 { +&u2phy1 { status = "okay"; - clock-frequency = <400000>;
- rtc_twi: rtc@6f { - compatible = "isil,isl1208"; - reg = <0x6f>; + u2phy1_otg: otg-port { + status = "okay"; }; - fan: fan@18 { - compatible = "ti,amc6821"; - reg = <0x18>; - cooling-min-state = <0>; - cooling-max-state = <9>; - #cooling-cells = <2>; + + u2phy1_host: host-port { + phy-supply = <&vcc5v0_host>; + status = "okay"; }; };
-&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer &uart0_cts>; +&usbdrd3_1 { status = "okay"; };
- -&spi1 { +&usbdrd_dwc3_1 { status = "okay"; + dr_mode = "host"; +};
- #address-cells = <1>; - #size-cells = <0>; - - spiflash: w25q32dw@0 { - compatible = "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <49500000>; - spi-cpol; - spi-cpha; - }; +&usb_host1_ehci { + status = "okay"; };
-&spi5 { +&usb_host1_ohci { status = "okay"; }; diff --git a/arch/arm/dts/rk3399-roc-pc-u-boot.dtsi b/arch/arm/dts/rk3399-roc-pc-u-boot.dtsi index 5746442981..141dd0b306 100644 --- a/arch/arm/dts/rk3399-roc-pc-u-boot.dtsi +++ b/arch/arm/dts/rk3399-roc-pc-u-boot.dtsi @@ -14,9 +14,45 @@ chosen { u-boot,spl-boot-order = "same-as-spl", &sdhci, &sdmmc; }; + + vcc_hub_en: vcc_hub_en-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio2 RK_PA4 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&hub_rst>; + regulator-name = "vcc_hub_en"; + regulator-always-on; + }; +}; + +/* + * should be placed inside mp8859, but not until mp8859 has + * its own dt-binding. + */ +&dc_12v { + compatible = "regulator-fixed"; + regulator-name = "dc_12v"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + vin-supply = <&vcc_vbus_typec0>; };
&vdd_log { regulator-min-microvolt = <430000>; regulator-init-microvolt = <950000>; }; + +&vcc5v0_host { + regulator-always-on; +}; + +&vcc_sys { + regulator-always-on; +}; + +&vcc_sdio { + regulator-always-on; +}; diff --git a/arch/arm/dts/rk3399-roc-pc.dts b/arch/arm/dts/rk3399-roc-pc.dts index 6a909e4eef..cd41954253 100644 --- a/arch/arm/dts/rk3399-roc-pc.dts +++ b/arch/arm/dts/rk3399-roc-pc.dts @@ -8,6 +8,5 @@
/ { model = "Firefly ROC-RK3399-PC Board"; - compatible = "libretech,roc-rk3399-pc", "firefly,roc-rk3399-pc", - "rockchip,rk3399"; + compatible = "firefly,roc-rk3399-pc", "rockchip,rk3399"; }; diff --git a/arch/arm/dts/rk3399-roc-pc.dtsi b/arch/arm/dts/rk3399-roc-pc.dtsi index 9a1ce3a4ae..9f225e9c3d 100644 --- a/arch/arm/dts/rk3399-roc-pc.dtsi +++ b/arch/arm/dts/rk3399-roc-pc.dtsi @@ -110,20 +110,6 @@ regulator-max-microvolt = <5000000>; };
- /* - * should be placed inside mp8859, but not until mp8859 has - * its own dt-binding. - */ - dc_12v: mp8859-dcdc1 { - compatible = "regulator-fixed"; - regulator-name = "dc_12v"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - vin-supply = <&vcc_vbus_typec0>; - }; - /* switched by pmic_sleep */ vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 { compatible = "regulator-fixed"; @@ -176,7 +162,6 @@ pinctrl-names = "default"; pinctrl-0 = <&vcc5v0_host_en &hub_rst>; regulator-name = "vcc5v0_host"; - regulator-always-on; vin-supply = <&vcc_sys>; };
@@ -198,7 +183,6 @@ pinctrl-names = "default"; pinctrl-0 = <&vcc_sys_en>; regulator-name = "vcc_sys"; - regulator-always-on; regulator-boot-on; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; @@ -392,7 +376,6 @@
vcc_sdio: LDO_REG4 { regulator-name = "vcc_sdio"; - regulator-always-on; regulator-boot-on; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <3000000>; @@ -549,6 +532,24 @@ vbus-supply = <&vcc_vbus_typec0>; status = "okay"; }; + + mp8859: regulator@66 { + compatible = "mps,mp8859"; + reg = <0x66>; + dc_12v: mp8859_dcdc { + regulator-name = "dc_12v"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc_vbus_typec0>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <12000000>; + }; + }; + }; };
&i2s0 { diff --git a/arch/arm/dts/rk3399-rock-pi-4.dts b/arch/arm/dts/rk3399-rock-pi-4.dts index 4a543f2117..3923ec01ef 100644 --- a/arch/arm/dts/rk3399-rock-pi-4.dts +++ b/arch/arm/dts/rk3399-rock-pi-4.dts @@ -25,6 +25,15 @@ #clock-cells = <0>; };
+ sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rk808 1>; + clock-names = "ext_clock"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_enable_h>; + reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; + }; + vcc12v_dcin: dc-12v { compatible = "regulator-fixed"; regulator-name = "vcc12v_dcin"; @@ -44,6 +53,16 @@ vin-supply = <&vcc12v_dcin>; };
+ vcc_0v9: vcc-0v9 { + compatible = "regulator-fixed"; + regulator-name = "vcc_0v9"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + vin-supply = <&vcc3v3_sys>; + }; + vcc3v3_pcie: vcc3v3-pcie-regulator { compatible = "regulator-fixed"; enable-active-high; @@ -157,12 +176,22 @@ status = "okay"; };
+&gpu { + mali-supply = <&vdd_gpu>; + status = "okay"; +}; + &hdmi { + ddc-i2c-bus = <&i2c3>; pinctrl-names = "default"; pinctrl-0 = <&hdmi_cec>; status = "okay"; };
+&hdmi_sound { + status = "okay"; +}; + &i2c0 { clock-frequency = <400000>; i2c-scl-rising-time-ns = <168>; @@ -444,13 +473,60 @@ pmu1830-supply = <&vcc_3v0>; };
+&pcie_phy { + status = "okay"; +}; + +&pcie0 { + ep-gpios = <&gpio4 RK_PD3 GPIO_ACTIVE_HIGH>; + max-link-speed = <2>; + num-lanes = <4>; + pinctrl-0 = <&pcie_clkreqnb_cpm>; + pinctrl-names = "default"; + vpcie0v9-supply = <&vcc_0v9>; + vpcie1v8-supply = <&vcc_1v8>; + vpcie3v3-supply = <&vcc3v3_pcie>; + status = "okay"; +}; + &pinctrl { + bt { + bt_enable_h: bt-enable-h { + rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + bt_host_wake_l: bt-host-wake-l { + rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + bt_wake_l: bt-wake-l { + rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + pcie { pcie_pwr_en: pcie-pwr-en { rockchip,pins = <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; }; };
+ sdio0 { + sdio0_bus4: sdio0-bus4 { + rockchip,pins = <2 RK_PC4 1 &pcfg_pull_up_20ma>, + <2 RK_PC5 1 &pcfg_pull_up_20ma>, + <2 RK_PC6 1 &pcfg_pull_up_20ma>, + <2 RK_PC7 1 &pcfg_pull_up_20ma>; + }; + + sdio0_cmd: sdio0-cmd { + rockchip,pins = <2 RK_PD0 1 &pcfg_pull_up_20ma>; + }; + + sdio0_clk: sdio0-clk { + rockchip,pins = <2 RK_PD1 1 &pcfg_pull_none_20ma>; + }; + }; + pmic { pmic_int_l: pmic-int-l { rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; @@ -476,6 +552,16 @@ rockchip,pins = <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; }; }; + + wifi { + wifi_enable_h: wifi-enable-h { + rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + wifi_host_wake_l: wifi-host-wake-l { + rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; };
&pwm2 { @@ -488,6 +574,32 @@ vref-supply = <&vcc_1v8>; };
+&sdio0 { + #address-cells = <1>; + #size-cells = <0>; + bus-width = <4>; + clock-frequency = <50000000>; + cap-sdio-irq; + cap-sd-highspeed; + keep-power-in-suspend; + mmc-pwrseq = <&sdio_pwrseq>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; + sd-uhs-sdr104; + status = "okay"; + + brcmf: wifi@1 { + compatible = "brcm,bcm4329-fmac"; + reg = <1>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PA3 GPIO_ACTIVE_HIGH>; + interrupt-names = "host-wake"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_host_wake_l>; + }; +}; + &sdmmc { bus-width = <4>; cap-mmc-highspeed; @@ -551,6 +663,23 @@ }; };
+&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; + status = "okay"; + + bluetooth { + compatible = "brcm,bcm43438-bt"; + clocks = <&rk808 1>; + clock-names = "ext_clock"; + device-wakeup-gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>; + host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>; + shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_enable_h>; + }; +}; + &uart2 { status = "okay"; }; diff --git a/arch/arm/dts/rk3399-rock960.dts b/arch/arm/dts/rk3399-rock960.dts index 12285c51cc..437a75f31a 100644 --- a/arch/arm/dts/rk3399-rock960.dts +++ b/arch/arm/dts/rk3399-rock960.dts @@ -114,6 +114,55 @@ }; };
+&spi0 { + /* On Low speed expansion (LS-SPI0) */ + status = "okay"; +}; + +&spi4 { + /* On High speed expansion (HS-SPI1) */ + status = "okay"; +}; + +&thermal_zones { + cpu_thermal: cpu { + polling-delay-passive = <100>; + polling-delay = <1000>; + thermal-sensors = <&tsadc 0>; + sustainable-power = <1550>; + + trips { + cpu_alert0: cpu_alert0 { + temperature = <65000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu_alert1: cpu_alert1 { + temperature = <75000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu_crit: cpu_crit { + temperature = <95000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + + trip = <&cpu_alert1>; + cooling-device = + <&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu_b1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; +}; + &usbdrd_dwc3_0 { dr_mode = "otg"; }; diff --git a/arch/arm/dts/rk3399-rock960.dtsi b/arch/arm/dts/rk3399-rock960.dtsi index c7d48d41e1..ba7c75c9f2 100644 --- a/arch/arm/dts/rk3399-rock960.dtsi +++ b/arch/arm/dts/rk3399-rock960.dtsi @@ -76,6 +76,15 @@ regulator-always-on; vin-supply = <&vcc5v0_sys>; }; + + vcc_0v9: vcc-0v9 { + compatible = "regulator-fixed"; + regulator-name = "vcc_0v9"; + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + vin-supply = <&vcc3v3_sys>; + }; };
&cpu_l0 { @@ -384,6 +393,8 @@ num-lanes = <4>; pinctrl-names = "default"; pinctrl-0 = <&pcie_clkreqn_cpm>; + vpcie0v9-supply = <&vcc_0v9>; + vpcie1v8-supply = <&vcca_1v8>; vpcie3v3-supply = <&vcc3v3_pcie>; status = "okay"; }; @@ -531,7 +542,7 @@ cap-mmc-highspeed; cap-sd-highspeed; clock-frequency = <100000000>; - clock-freq-min-max = <100000 100000000>; + max-frequency = <100000000>; cd-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>; disable-wp; sd-uhs-sdr104; diff --git a/arch/arm/dts/rk3399-rockpro64.dts b/arch/arm/dts/rk3399-rockpro64.dts index e544deb61d..4b42717800 100644 --- a/arch/arm/dts/rk3399-rockpro64.dts +++ b/arch/arm/dts/rk3399-rockpro64.dts @@ -2,752 +2,29 @@ /* * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd. * Copyright (c) 2018 Akash Gajjar Akash_Gajjar@mentor.com + * Copyright (c) 2019 Katsuhiro Suzuki katsuhiro@katsuster.net */
/dts-v1/; -#include <dt-bindings/input/linux-event-codes.h> -#include <dt-bindings/pwm/pwm.h> -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi" +#include "rk3399-rockpro64.dtsi"
/ { - model = "Pine64 RockPro64"; - compatible = "pine64,rockpro64", "rockchip,rk3399"; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - clkin_gmac: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "clkin_gmac"; - #clock-cells = <0>; - }; - - gpio-keys { - compatible = "gpio-keys"; - autorepeat; - pinctrl-names = "default"; - pinctrl-0 = <&pwrbtn>; - - power { - debounce-interval = <100>; - gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; - label = "GPIO Key Power"; - linux,code = <KEY_POWER>; - wakeup-source; - }; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&work_led_gpio>, <&diy_led_gpio>; - - work-led { - label = "work"; - default-state = "on"; - gpios = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>; - }; - - diy-led { - label = "diy"; - default-state = "off"; - gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>; - }; - }; - - fan: pwm-fan { - compatible = "pwm-fan"; - #cooling-cells = <2>; - fan-supply = <&vcc12v_dcin>; - pwms = <&pwm1 0 50000 0>; - }; - - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - clocks = <&rk808 1>; - clock-names = "ext_clock"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_enable_h>; - - /* - * On the module itself this is one of these (depending - * on the actual card populated): - * - SDIO_RESET_L_WL_REG_ON - * - PDN (power down when low) - */ - reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; - }; - - vcc12v_dcin: vcc12v-dcin { - compatible = "regulator-fixed"; - regulator-name = "vcc12v_dcin"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - }; - - /* switched by pmic_sleep */ - vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 { - compatible = "regulator-fixed"; - regulator-name = "vcc1v8_s3"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_1v8>; - }; - - vcc3v3_pcie: vcc3v3-pcie-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio1 RK_PD0 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie_pwr_en>; - regulator-name = "vcc3v3_pcie"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc12v_dcin>; - }; - - vcc3v3_sys: vcc3v3-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc5v0_sys>; - }; - - /* Actually 3 regulators (host0, 1, 2) controlled by the same gpio */ - vcc5v0_host: vcc5v0-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_host_en>; - regulator-name = "vcc5v0_host"; - regulator-always-on; - vin-supply = <&vcc5v0_usb>; - }; - - vcc5v0_typec: vcc5v0-typec-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_typec_en>; - regulator-name = "vcc5v0_typec"; - regulator-always-on; - vin-supply = <&vcc5v0_usb>; - }; - - vcc5v0_sys: vcc5v0-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc12v_dcin>; - }; - - vcc5v0_usb: vcc5v0-usb { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_usb"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc12v_dcin>; - }; - - vdd_log: vdd-log { - compatible = "pwm-regulator"; - pwms = <&pwm2 0 25000 1>; - regulator-name = "vdd_log"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1700000>; - vin-supply = <&vcc5v0_sys>; - }; -}; - -&cpu_l0 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l1 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l2 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l3 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_b0 { - cpu-supply = <&vdd_cpu_b>; -}; - -&cpu_b1 { - cpu-supply = <&vdd_cpu_b>; -}; - -&emmc_phy { - status = "okay"; -}; - -&gmac { - assigned-clocks = <&cru SCLK_RMII_SRC>; - assigned-clock-parents = <&clkin_gmac>; - clock_in_out = "input"; - phy-supply = <&vcc_lan>; - phy-mode = "rgmii"; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 50000>; - tx_delay = <0x28>; - rx_delay = <0x11>; - status = "okay"; -}; - -&hdmi { - ddc-i2c-bus = <&i2c3>; - pinctrl-names = "default"; - pinctrl-0 = <&hdmi_cec>; - status = "okay"; -}; - -&hdmi_sound { - status = "okay"; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&i2c0 { - clock-frequency = <400000>; - i2c-scl-rising-time-ns = <168>; - i2c-scl-falling-time-ns = <4>; - status = "okay"; - - rk808: pmic@1b { - compatible = "rockchip,rk808"; - reg = <0x1b>; - interrupt-parent = <&gpio3>; - interrupts = <10 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk808-clkout2"; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc5v0_sys>; - vcc2-supply = <&vcc5v0_sys>; - vcc3-supply = <&vcc5v0_sys>; - vcc4-supply = <&vcc5v0_sys>; - vcc6-supply = <&vcc5v0_sys>; - vcc7-supply = <&vcc5v0_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc5v0_sys>; - vcc10-supply = <&vcc5v0_sys>; - vcc11-supply = <&vcc5v0_sys>; - vcc12-supply = <&vcc3v3_sys>; - vddio-supply = <&vcca_1v8>; - - regulators { - vdd_center: DCDC_REG1 { - regulator-name = "vdd_center"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_cpu_l: DCDC_REG2 { - regulator-name = "vdd_cpu_l"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_1v8: DCDC_REG4 { - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc1v8_dvp: LDO_REG1 { - regulator-name = "vcc1v8_dvp"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v0_touch: LDO_REG2 { - regulator-name = "vcc3v0_touch"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcca_1v8: LDO_REG3 { - regulator-name = "vcca_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc_sdio: LDO_REG4 { - regulator-name = "vcc_sdio"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3000000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcca3v0_codec: LDO_REG5 { - regulator-name = "vcca3v0_codec"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v5: LDO_REG6 { - regulator-name = "vcc_1v5"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1500000>; - }; - }; - - vcca1v8_codec: LDO_REG7 { - regulator-name = "vcca1v8_codec"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_3v0: LDO_REG8 { - regulator-name = "vcc_3v0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcc3v3_s3: vcc_lan: SWITCH_REG1 { - regulator-name = "vcc3v3_s3"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_s0: SWITCH_REG2 { - regulator-name = "vcc3v3_s0"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - }; - - vdd_cpu_b: regulator@40 { - compatible = "silergy,syr827"; - reg = <0x40>; - fcs,suspend-voltage-selector = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&vsel1_gpio>; - regulator-name = "vdd_cpu_b"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: regulator@41 { - compatible = "silergy,syr828"; - reg = <0x41>; - fcs,suspend-voltage-selector = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&vsel2_gpio>; - regulator-name = "vdd_gpu"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; + model = "Pine64 RockPro64 v2.1"; + compatible = "pine64,rockpro64-v2.1", "pine64,rockpro64", "rockchip,rk3399"; };
&i2c1 { - i2c-scl-rising-time-ns = <300>; - i2c-scl-falling-time-ns = <15>; - status = "okay"; -}; - -&i2c3 { - i2c-scl-rising-time-ns = <450>; - i2c-scl-falling-time-ns = <15>; - status = "okay"; -}; - -&i2c4 { - i2c-scl-rising-time-ns = <600>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; - - fusb0: typec-portc@22 { - compatible = "fcs,fusb302"; - reg = <0x22>; - interrupt-parent = <&gpio1>; - interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&fusb0_int>; - vbus-supply = <&vcc5v0_typec>; - status = "okay"; - }; -}; + es8316: codec@11 { + compatible = "everest,es8316"; + reg = <0x11>; + clocks = <&cru SCLK_I2S_8CH_OUT>; + clock-names = "mclk"; + #sound-dai-cells = <0>;
-&i2s0 { - rockchip,playback-channels = <8>; - rockchip,capture-channels = <8>; - status = "okay"; -}; - -&i2s1 { - rockchip,playback-channels = <2>; - rockchip,capture-channels = <2>; - status = "okay"; -}; - -&i2s2 { - status = "okay"; -}; - -&io_domains { - status = "okay"; - - bt656-supply = <&vcc1v8_dvp>; - audio-supply = <&vcc_3v0>; - sdmmc-supply = <&vcc_sdio>; - gpio1830-supply = <&vcc_3v0>; -}; - -&pcie0 { - ep-gpios = <&gpio2 RK_PD4 GPIO_ACTIVE_HIGH>; - num-lanes = <4>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie_perst>; - vpcie12v-supply = <&vcc12v_dcin>; - vpcie3v3-supply = <&vcc3v3_pcie>; - status = "okay"; -}; - -&pcie_phy { - status = "okay"; -}; - -&pmu_io_domains { - pmu1830-supply = <&vcc_3v0>; - status = "okay"; -}; - -&pinctrl { - buttons { - pwrbtn: pwrbtn { - rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - fusb302x { - fusb0_int: fusb0-int { - rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - leds { - work_led_gpio: work_led-gpio { - rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - diy_led_gpio: diy_led-gpio { - rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pcie { - pcie_perst: pcie-perst { - rockchip,pins = <2 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - pcie_pwr_en: pcie-pwr-en { - rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - vsel1_gpio: vsel1-gpio { - rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - vsel2_gpio: vsel2-gpio { - rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; - - sdio-pwrseq { - wifi_enable_h: wifi-enable-h { - rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb-typec { - vcc5v0_typec_en: vcc5v0_typec_en { - rockchip,pins = <1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - usb2 { - vcc5v0_host_en: vcc5v0-host-en { - rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; + port { + es8316_p0_0: endpoint { + remote-endpoint = <&i2s1_p0_0>; + }; }; }; }; - -&pwm0 { - status = "okay"; -}; - -&pwm1 { - status = "okay"; -}; - -&pwm2 { - status = "okay"; -}; - -&saradc { - vref-supply = <&vcca1v8_s3>; - status = "okay"; -}; - -&sdmmc { - bus-width = <4>; - cap-sd-highspeed; - cd-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>; - disable-wp; - max-frequency = <150000000>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>; - status = "okay"; -}; - -&sdhci { - bus-width = <8>; - mmc-hs200-1_8v; - non-removable; - status = "okay"; -}; - -&spi1 { - status = "okay"; - - flash@0 { - compatible = "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <10000000>; - }; -}; - -&tcphy0 { - status = "okay"; -}; - -&tcphy1 { - status = "okay"; -}; - -&tsadc { - /* tshut mode 0:CRU 1:GPIO */ - rockchip,hw-tshut-mode = <1>; - /* tshut polarity 0:LOW 1:HIGH */ - rockchip,hw-tshut-polarity = <1>; - status = "okay"; -}; - -&u2phy0 { - status = "okay"; - - u2phy0_otg: otg-port { - status = "okay"; - }; - - u2phy0_host: host-port { - phy-supply = <&vcc5v0_host>; - status = "okay"; - }; -}; - -&u2phy1 { - status = "okay"; - - u2phy1_otg: otg-port { - status = "okay"; - }; - - u2phy1_host: host-port { - phy-supply = <&vcc5v0_host>; - status = "okay"; - }; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer &uart0_cts>; - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&usbdrd3_0 { - status = "okay"; -}; - -&usbdrd_dwc3_0 { - status = "okay"; - dr_mode = "otg"; -}; - -&usbdrd3_1 { - status = "okay"; -}; - -&usbdrd_dwc3_1 { - status = "okay"; - dr_mode = "host"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3399-rockpro64.dtsi b/arch/arm/dts/rk3399-rockpro64.dtsi new file mode 100644 index 0000000000..9bca258012 --- /dev/null +++ b/arch/arm/dts/rk3399-rockpro64.dtsi @@ -0,0 +1,797 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd. + * Copyright (c) 2018 Akash Gajjar Akash_Gajjar@mentor.com + */ + +#include <dt-bindings/input/linux-event-codes.h> +#include <dt-bindings/pwm/pwm.h> +#include "rk3399.dtsi" +#include "rk3399-opp.dtsi" + +/ { + chosen { + stdout-path = "serial2:1500000n8"; + }; + + clkin_gmac: external-gmac-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "clkin_gmac"; + #clock-cells = <0>; + }; + + gpio-keys { + compatible = "gpio-keys"; + autorepeat; + pinctrl-names = "default"; + pinctrl-0 = <&pwrbtn>; + + power { + debounce-interval = <100>; + gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; + label = "GPIO Key Power"; + linux,code = <KEY_POWER>; + wakeup-source; + }; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&work_led_gpio>, <&diy_led_gpio>; + + work-led { + label = "work"; + default-state = "on"; + gpios = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>; + }; + + diy-led { + label = "diy"; + default-state = "off"; + gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>; + }; + }; + + fan: pwm-fan { + compatible = "pwm-fan"; + #cooling-cells = <2>; + fan-supply = <&vcc12v_dcin>; + pwms = <&pwm1 0 50000 0>; + }; + + sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rk808 1>; + clock-names = "ext_clock"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_enable_h>; + reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; + }; + + sound { + compatible = "audio-graph-card"; + label = "rockchip,rk3399"; + dais = <&i2s1_p0>; + }; + + vcc12v_dcin: vcc12v-dcin { + compatible = "regulator-fixed"; + regulator-name = "vcc12v_dcin"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + + /* switched by pmic_sleep */ + vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 { + compatible = "regulator-fixed"; + regulator-name = "vcc1v8_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_1v8>; + }; + + vcc3v3_pcie: vcc3v3-pcie-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio1 RK_PD0 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie_pwr_en>; + regulator-name = "vcc3v3_pcie"; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc12v_dcin>; + }; + + vcc3v3_sys: vcc3v3-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc5v0_sys>; + }; + + /* Actually 3 regulators (host0, 1, 2) controlled by the same gpio */ + vcc5v0_host: vcc5v0-host-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_host_en>; + regulator-name = "vcc5v0_host"; + regulator-always-on; + vin-supply = <&vcc5v0_usb>; + }; + + vcc5v0_typec: vcc5v0-typec-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_typec_en>; + regulator-name = "vcc5v0_typec"; + regulator-always-on; + vin-supply = <&vcc5v0_usb>; + }; + + vcc5v0_sys: vcc5v0-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc12v_dcin>; + }; + + vcc5v0_usb: vcc5v0-usb { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_usb"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc12v_dcin>; + }; + + vdd_log: vdd-log { + compatible = "pwm-regulator"; + pwms = <&pwm2 0 25000 1>; + regulator-name = "vdd_log"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1700000>; + vin-supply = <&vcc5v0_sys>; + }; +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l1 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l2 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l3 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_b0 { + cpu-supply = <&vdd_cpu_b>; +}; + +&cpu_b1 { + cpu-supply = <&vdd_cpu_b>; +}; + +&emmc_phy { + status = "okay"; +}; + +&gmac { + assigned-clocks = <&cru SCLK_RMII_SRC>; + assigned-clock-parents = <&clkin_gmac>; + clock_in_out = "input"; + phy-supply = <&vcc_lan>; + phy-mode = "rgmii"; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 50000>; + tx_delay = <0x28>; + rx_delay = <0x11>; + status = "okay"; +}; + +&hdmi { + ddc-i2c-bus = <&i2c3>; + pinctrl-names = "default"; + pinctrl-0 = <&hdmi_cec>; + status = "okay"; +}; + +&hdmi_sound { + status = "okay"; +}; + +&gpu { + mali-supply = <&vdd_gpu>; + status = "okay"; +}; + +&i2c0 { + clock-frequency = <400000>; + i2c-scl-rising-time-ns = <168>; + i2c-scl-falling-time-ns = <4>; + status = "okay"; + + rk808: pmic@1b { + compatible = "rockchip,rk808"; + reg = <0x1b>; + interrupt-parent = <&gpio3>; + interrupts = <10 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <1>; + clock-output-names = "xin32k", "rk808-clkout2"; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + + vcc1-supply = <&vcc5v0_sys>; + vcc2-supply = <&vcc5v0_sys>; + vcc3-supply = <&vcc5v0_sys>; + vcc4-supply = <&vcc5v0_sys>; + vcc6-supply = <&vcc5v0_sys>; + vcc7-supply = <&vcc5v0_sys>; + vcc8-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc5v0_sys>; + vcc10-supply = <&vcc5v0_sys>; + vcc11-supply = <&vcc5v0_sys>; + vcc12-supply = <&vcc3v3_sys>; + vddio-supply = <&vcca_1v8>; + + regulators { + vdd_center: DCDC_REG1 { + regulator-name = "vdd_center"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_l: DCDC_REG2 { + regulator-name = "vdd_cpu_l"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_1v8: DCDC_REG4 { + regulator-name = "vcc_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc1v8_dvp: LDO_REG1 { + regulator-name = "vcc1v8_dvp"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v0_touch: LDO_REG2 { + regulator-name = "vcc3v0_touch"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcca_1v8: LDO_REG3 { + regulator-name = "vcca_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_sdio: LDO_REG4 { + regulator-name = "vcc_sdio"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3000000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcca3v0_codec: LDO_REG5 { + regulator-name = "vcca3v0_codec"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v5: LDO_REG6 { + regulator-name = "vcc_1v5"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1500000>; + }; + }; + + vcca1v8_codec: LDO_REG7 { + regulator-name = "vcca1v8_codec"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v0: LDO_REG8 { + regulator-name = "vcc_3v0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcc3v3_s3: vcc_lan: SWITCH_REG1 { + regulator-name = "vcc3v3_s3"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_s0: SWITCH_REG2 { + regulator-name = "vcc3v3_s0"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; + + vdd_cpu_b: regulator@40 { + compatible = "silergy,syr827"; + reg = <0x40>; + fcs,suspend-voltage-selector = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&vsel1_gpio>; + regulator-name = "vdd_cpu_b"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: regulator@41 { + compatible = "silergy,syr828"; + reg = <0x41>; + fcs,suspend-voltage-selector = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&vsel2_gpio>; + regulator-name = "vdd_gpu"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2c1 { + i2c-scl-rising-time-ns = <300>; + i2c-scl-falling-time-ns = <15>; + status = "okay"; +}; + +&i2c3 { + i2c-scl-rising-time-ns = <450>; + i2c-scl-falling-time-ns = <15>; + status = "okay"; +}; + +&i2c4 { + i2c-scl-rising-time-ns = <600>; + i2c-scl-falling-time-ns = <20>; + status = "okay"; + + fusb0: typec-portc@22 { + compatible = "fcs,fusb302"; + reg = <0x22>; + interrupt-parent = <&gpio1>; + interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&fusb0_int>; + vbus-supply = <&vcc5v0_typec>; + status = "okay"; + }; +}; + +&i2s0 { + rockchip,playback-channels = <8>; + rockchip,capture-channels = <8>; + status = "okay"; +}; + +&i2s1 { + rockchip,playback-channels = <2>; + rockchip,capture-channels = <2>; + status = "okay"; + + i2s1_p0: port { + i2s1_p0_0: endpoint { + dai-format = "i2s"; + mclk-fs = <256>; + remote-endpoint = <&es8316_p0_0>; + }; + }; +}; + +&i2s2 { + status = "okay"; +}; + +&io_domains { + status = "okay"; + + bt656-supply = <&vcc1v8_dvp>; + audio-supply = <&vcc_3v0>; + sdmmc-supply = <&vcc_sdio>; + gpio1830-supply = <&vcc_3v0>; +}; + +&pcie0 { + ep-gpios = <&gpio2 RK_PD4 GPIO_ACTIVE_HIGH>; + num-lanes = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie_perst>; + vpcie12v-supply = <&vcc12v_dcin>; + vpcie3v3-supply = <&vcc3v3_pcie>; + status = "okay"; +}; + +&pcie_phy { + status = "okay"; +}; + +&pmu_io_domains { + pmu1830-supply = <&vcc_3v0>; + status = "okay"; +}; + +&pinctrl { + bt { + bt_enable_h: bt-enable-h { + rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + bt_host_wake_l: bt-host-wake-l { + rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + bt_wake_l: bt-wake-l { + rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + buttons { + pwrbtn: pwrbtn { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + fusb302x { + fusb0_int: fusb0-int { + rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + leds { + work_led_gpio: work_led-gpio { + rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + diy_led_gpio: diy_led-gpio { + rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pcie { + pcie_perst: pcie-perst { + rockchip,pins = <2 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + pcie_pwr_en: pcie-pwr-en { + rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = <3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + vsel1_gpio: vsel1-gpio { + rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + vsel2_gpio: vsel2-gpio { + rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; + }; + }; + + sdio-pwrseq { + wifi_enable_h: wifi-enable-h { + rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb-typec { + vcc5v0_typec_en: vcc5v0_typec_en { + rockchip,pins = <1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + usb2 { + vcc5v0_host_en: vcc5v0-host-en { + rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pwm0 { + status = "okay"; +}; + +&pwm1 { + status = "okay"; +}; + +&pwm2 { + status = "okay"; +}; + +&saradc { + vref-supply = <&vcca1v8_s3>; + status = "okay"; +}; + +&sdio0 { + bus-width = <4>; + cap-sd-highspeed; + cap-sdio-irq; + disable-wp; + keep-power-in-suspend; + mmc-pwrseq = <&sdio_pwrseq>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; + sd-uhs-sdr104; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-sd-highspeed; + cd-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>; + disable-wp; + max-frequency = <150000000>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>; + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + mmc-hs200-1_8v; + non-removable; + status = "okay"; +}; + +&spi1 { + status = "okay"; + + flash@0 { + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <10000000>; + }; +}; + +&tcphy0 { + status = "okay"; +}; + +&tcphy1 { + status = "okay"; +}; + +&tsadc { + /* tshut mode 0:CRU 1:GPIO */ + rockchip,hw-tshut-mode = <1>; + /* tshut polarity 0:LOW 1:HIGH */ + rockchip,hw-tshut-polarity = <1>; + status = "okay"; +}; + +&u2phy0 { + status = "okay"; + + u2phy0_otg: otg-port { + status = "okay"; + }; + + u2phy0_host: host-port { + phy-supply = <&vcc5v0_host>; + status = "okay"; + }; +}; + +&u2phy1 { + status = "okay"; + + u2phy1_otg: otg-port { + status = "okay"; + }; + + u2phy1_host: host-port { + phy-supply = <&vcc5v0_host>; + status = "okay"; + }; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; + status = "okay"; + + bluetooth { + compatible = "brcm,bcm43438-bt"; + clocks = <&rk808 1>; + clock-names = "lpo"; + device-wakeup-gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>; + host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>; + shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_enable_h>; + vbat-supply = <&vcc3v3_sys>; + vddio-supply = <&vcc_1v8>; + }; +}; + +&uart2 { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +&usbdrd3_0 { + status = "okay"; +}; + +&usbdrd_dwc3_0 { + status = "okay"; + dr_mode = "otg"; +}; + +&usbdrd3_1 { + status = "okay"; +}; + +&usbdrd_dwc3_1 { + status = "okay"; + dr_mode = "host"; +}; + +&vopb { + status = "okay"; +}; + +&vopb_mmu { + status = "okay"; +}; + +&vopl { + status = "okay"; +}; + +&vopl_mmu { + status = "okay"; +}; diff --git a/arch/arm/dts/rk3399-u-boot.dtsi b/arch/arm/dts/rk3399-u-boot.dtsi index 8b857ccfc7..ef57c36e73 100644 --- a/arch/arm/dts/rk3399-u-boot.dtsi +++ b/arch/arm/dts/rk3399-u-boot.dtsi @@ -79,6 +79,7 @@ };
&sdhci { + max-frequency = <200000000>; u-boot,dm-pre-reloc; };
diff --git a/arch/arm/dts/rk3399.dtsi b/arch/arm/dts/rk3399.dtsi index 6b7c136ab8..74f2c3d490 100644 --- a/arch/arm/dts/rk3399.dtsi +++ b/arch/arm/dts/rk3399.dtsi @@ -1,6 +1,6 @@ -// SPDX-License-Identifier: GPL-2.0+ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* - * Copyright (c) 2016-2017 Fuzhou Rockchip Electronics Co., Ltd. + * Copyright (c) 2016 Fuzhou Rockchip Electronics Co., Ltd */
#include <dt-bindings/clock/rk3399-cru.h> @@ -19,6 +19,7 @@ #size-cells = <2>;
aliases { + ethernet0 = &gmac; i2c0 = &i2c0; i2c1 = &i2c1; i2c2 = &i2c2; @@ -67,53 +68,102 @@
cpu_l0: cpu@0 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0x0 0x0>; enable-method = "psci"; - #cooling-cells = <2>; /* min followed by max */ + capacity-dmips-mhz = <485>; clocks = <&cru ARMCLKL>; + #cooling-cells = <2>; /* min followed by max */ + dynamic-power-coefficient = <100>; + cpu-idle-states = <&CPU_SLEEP &CLUSTER_SLEEP>; };
cpu_l1: cpu@1 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0x0 0x1>; enable-method = "psci"; + capacity-dmips-mhz = <485>; clocks = <&cru ARMCLKL>; + #cooling-cells = <2>; /* min followed by max */ + dynamic-power-coefficient = <100>; + cpu-idle-states = <&CPU_SLEEP &CLUSTER_SLEEP>; };
cpu_l2: cpu@2 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0x0 0x2>; enable-method = "psci"; + capacity-dmips-mhz = <485>; clocks = <&cru ARMCLKL>; + #cooling-cells = <2>; /* min followed by max */ + dynamic-power-coefficient = <100>; + cpu-idle-states = <&CPU_SLEEP &CLUSTER_SLEEP>; };
cpu_l3: cpu@3 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0x0 0x3>; enable-method = "psci"; + capacity-dmips-mhz = <485>; clocks = <&cru ARMCLKL>; + #cooling-cells = <2>; /* min followed by max */ + dynamic-power-coefficient = <100>; + cpu-idle-states = <&CPU_SLEEP &CLUSTER_SLEEP>; };
cpu_b0: cpu@100 { device_type = "cpu"; - compatible = "arm,cortex-a72", "arm,armv8"; + compatible = "arm,cortex-a72"; reg = <0x0 0x100>; enable-method = "psci"; - #cooling-cells = <2>; /* min followed by max */ + capacity-dmips-mhz = <1024>; clocks = <&cru ARMCLKB>; + #cooling-cells = <2>; /* min followed by max */ + dynamic-power-coefficient = <436>; + cpu-idle-states = <&CPU_SLEEP &CLUSTER_SLEEP>; };
cpu_b1: cpu@101 { device_type = "cpu"; - compatible = "arm,cortex-a72", "arm,armv8"; + compatible = "arm,cortex-a72"; reg = <0x0 0x101>; enable-method = "psci"; + capacity-dmips-mhz = <1024>; clocks = <&cru ARMCLKB>; + #cooling-cells = <2>; /* min followed by max */ + dynamic-power-coefficient = <436>; + cpu-idle-states = <&CPU_SLEEP &CLUSTER_SLEEP>; }; + + idle-states { + entry-method = "psci"; + + CPU_SLEEP: cpu-sleep { + compatible = "arm,idle-state"; + local-timer-stop; + arm,psci-suspend-param = <0x0010000>; + entry-latency-us = <120>; + exit-latency-us = <250>; + min-residency-us = <900>; + }; + + CLUSTER_SLEEP: cluster-sleep { + compatible = "arm,idle-state"; + local-timer-stop; + arm,psci-suspend-param = <0x1010000>; + entry-latency-us = <400>; + exit-latency-us = <500>; + min-residency-us = <2000>; + }; + }; + }; + + display-subsystem { + compatible = "rockchip,display-subsystem"; + ports = <&vopl_out>, <&vopb_out>; };
pmu_a53 { @@ -147,7 +197,7 @@ #clock-cells = <0>; };
- amba { + amba: bus { compatible = "simple-bus"; #address-cells = <2>; #size-cells = <2>; @@ -183,7 +233,7 @@ #size-cells = <2>; #interrupt-cells = <1>; aspm-no-l0s; - bus-range = <0x0 0x1>; + bus-range = <0x0 0x1f>; clocks = <&cru ACLK_PCIE>, <&cru ACLK_PERF_PCIE>, <&cru PCLK_PCIE>, <&cru SCLK_PCIE_PM>; clock-names = "aclk", "aclk-perf", @@ -200,10 +250,12 @@ linux,pci-domain = <0>; max-link-speed = <1>; msi-map = <0x0 &its 0x0 0x1000>; - phys = <&pcie_phy>; - phy-names = "pcie-phy"; - ranges = <0x83000000 0x0 0xfa000000 0x0 0xfa000000 0x0 0x600000 - 0x81000000 0x0 0xfa600000 0x0 0xfa600000 0x0 0x100000>; + phys = <&pcie_phy 0>, <&pcie_phy 1>, + <&pcie_phy 2>, <&pcie_phy 3>; + phy-names = "pcie-phy-0", "pcie-phy-1", + "pcie-phy-2", "pcie-phy-3"; + ranges = <0x83000000 0x0 0xfa000000 0x0 0xfa000000 0x0 0x1e00000 + 0x81000000 0x0 0xfbe00000 0x0 0xfbe00000 0x0 0x100000>; resets = <&cru SRST_PCIE_CORE>, <&cru SRST_PCIE_MGMT>, <&cru SRST_PCIE_MGMT_STICKY>, <&cru SRST_PCIE_PIPE>, <&cru SRST_PCIE_PM>, <&cru SRST_P_PCIE>, @@ -236,10 +288,11 @@ resets = <&cru SRST_A_GMAC>; reset-names = "stmmaceth"; rockchip,grf = <&grf>; + snps,txpbl = <0x4>; status = "disabled"; };
- sdio0: dwmmc@fe310000 { + sdio0: mmc@fe310000 { compatible = "rockchip,rk3399-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x0 0xfe310000 0x0 0x4000>; @@ -255,12 +308,14 @@ status = "disabled"; };
- sdmmc: dwmmc@fe320000 { + sdmmc: mmc@fe320000 { compatible = "rockchip,rk3399-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x0 0xfe320000 0x0 0x4000>; interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH 0>; max-frequency = <150000000>; + assigned-clocks = <&cru HCLK_SD>; + assigned-clock-rates = <200000000>; clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>; clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; @@ -278,7 +333,6 @@ arasan,soc-ctl-syscon = <&grf>; assigned-clocks = <&cru SCLK_EMMC>; assigned-clock-rates = <200000000>; - max-frequency = <200000000>; clocks = <&cru SCLK_EMMC>, <&cru ACLK_EMMC>; clock-names = "clk_xin", "clk_ahb"; clock-output-names = "emmc_cardclock"; @@ -286,6 +340,7 @@ phys = <&emmc_phy>; phy-names = "phy_arasan"; power-domains = <&power RK3399_PD_EMMC>; + disable-cqe-dcmd; status = "disabled"; };
@@ -295,11 +350,8 @@ interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH 0>; clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST0_ARB>, <&u2phy0>; - clock-names = "usbhost", "arbiter", - "utmi"; phys = <&u2phy0_host>; phy-names = "usb"; - power-domains = <&power RK3399_PD_PERIHP>; status = "disabled"; };
@@ -309,11 +361,8 @@ interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH 0>; clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST0_ARB>, <&u2phy0>; - clock-names = "usbhost", "arbiter", - "utmi"; phys = <&u2phy0_host>; phy-names = "usb"; - power-domains = <&power RK3399_PD_PERIHP>; status = "disabled"; };
@@ -323,11 +372,8 @@ interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH 0>; clocks = <&cru HCLK_HOST1>, <&cru HCLK_HOST1_ARB>, <&u2phy1>; - clock-names = "usbhost", "arbiter", - "utmi"; phys = <&u2phy1_host>; phy-names = "usb"; - power-domains = <&power RK3399_PD_PERIHP>; status = "disabled"; };
@@ -337,15 +383,12 @@ interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH 0>; clocks = <&cru HCLK_HOST1>, <&cru HCLK_HOST1_ARB>, <&u2phy1>; - clock-names = "usbhost", "arbiter", - "utmi"; phys = <&u2phy1_host>; phy-names = "usb"; - power-domains = <&power RK3399_PD_PERIHP>; status = "disabled"; };
- usbdrd3_0: dwc3_typec0: usb@fe800000 { + usbdrd3_0: usb@fe800000 { compatible = "rockchip,rk3399-dwc3"; #address-cells = <2>; #size-cells = <2>; @@ -364,6 +407,9 @@ compatible = "snps,dwc3"; reg = <0x0 0xfe800000 0x0 0x100000>; interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru SCLK_USB3OTG0_REF>, <&cru ACLK_USB3OTG0>, + <&cru SCLK_USB3OTG0_SUSPEND>; + clock-names = "ref", "bus_early", "suspend"; dr_mode = "otg"; phys = <&u2phy0_otg>, <&tcphy0_usb3>; phy-names = "usb2-phy", "usb3-phy"; @@ -378,7 +424,7 @@ }; };
- dwc3_typec1: usbdrd3_1: usb@fe900000 { + usbdrd3_1: usb@fe900000 { compatible = "rockchip,rk3399-dwc3"; #address-cells = <2>; #size-cells = <2>; @@ -397,6 +443,9 @@ compatible = "snps,dwc3"; reg = <0x0 0xfe900000 0x0 0x100000>; interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru SCLK_USB3OTG1_REF>, <&cru ACLK_USB3OTG1>, + <&cru SCLK_USB3OTG1_SUSPEND>; + clock-names = "ref", "bus_early", "suspend"; dr_mode = "otg"; phys = <&u2phy1_otg>, <&tcphy1_usb3>; phy-names = "usb2-phy", "usb3-phy"; @@ -464,6 +513,7 @@ its: interrupt-controller@fee20000 { compatible = "arm,gic-v3-its"; msi-controller; + #msi-cells = <1>; reg = <0x0 0xfee20000 0x0 0x20000>; };
@@ -612,7 +662,6 @@ clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; clock-names = "baudclk", "apb_pclk"; interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH 0>; - clock-frequency = <24000000>; reg-shift = <2>; reg-io-width = <4>; pinctrl-names = "default"; @@ -639,6 +688,8 @@ clocks = <&cru SCLK_SPI0>, <&cru PCLK_SPI0>; clock-names = "spiclk", "apb_pclk"; interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH 0>; + dmas = <&dmac_peri 10>, <&dmac_peri 11>; + dma-names = "tx", "rx"; pinctrl-names = "default"; pinctrl-0 = <&spi0_clk &spi0_tx &spi0_rx &spi0_cs0>; #address-cells = <1>; @@ -652,6 +703,8 @@ clocks = <&cru SCLK_SPI1>, <&cru PCLK_SPI1>; clock-names = "spiclk", "apb_pclk"; interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH 0>; + dmas = <&dmac_peri 12>, <&dmac_peri 13>; + dma-names = "tx", "rx"; pinctrl-names = "default"; pinctrl-0 = <&spi1_clk &spi1_tx &spi1_rx &spi1_cs0>; #address-cells = <1>; @@ -665,6 +718,8 @@ clocks = <&cru SCLK_SPI2>, <&cru PCLK_SPI2>; clock-names = "spiclk", "apb_pclk"; interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH 0>; + dmas = <&dmac_peri 14>, <&dmac_peri 15>; + dma-names = "tx", "rx"; pinctrl-names = "default"; pinctrl-0 = <&spi2_clk &spi2_tx &spi2_rx &spi2_cs0>; #address-cells = <1>; @@ -678,6 +733,8 @@ clocks = <&cru SCLK_SPI4>, <&cru PCLK_SPI4>; clock-names = "spiclk", "apb_pclk"; interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH 0>; + dmas = <&dmac_peri 18>, <&dmac_peri 19>; + dma-names = "tx", "rx"; pinctrl-names = "default"; pinctrl-0 = <&spi4_clk &spi4_tx &spi4_rx &spi4_cs0>; #address-cells = <1>; @@ -691,8 +748,11 @@ clocks = <&cru SCLK_SPI5>, <&cru PCLK_SPI5>; clock-names = "spiclk", "apb_pclk"; interrupts = <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH 0>; + dmas = <&dmac_bus 8>, <&dmac_bus 9>; + dma-names = "tx", "rx"; pinctrl-names = "default"; pinctrl-0 = <&spi5_clk &spi5_tx &spi5_rx &spi5_cs0>; + power-domains = <&power RK3399_PD_SDIOAUDIO>; #address-cells = <1>; #size-cells = <0>; status = "disabled"; @@ -727,13 +787,18 @@ map0 { trip = <&cpu_alert0>; cooling-device = - <&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + <&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu_b1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; }; map1 { trip = <&cpu_alert1>; cooling-device = <&cpu_l0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + <&cpu_l1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu_l2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu_l3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu_b1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; }; }; }; @@ -761,7 +826,7 @@ map0 { trip = <&gpu_alert0>; cooling-device = - <&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + <&gpu THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; }; }; }; @@ -980,22 +1045,11 @@ <&cru PCLK_GMAC>; pm_qos = <&qos_gmac>; }; - pd_perihp@RK3399_PD_PERIHP { - reg = <RK3399_PD_PERIHP>; - #address-cells = <1>; - #size-cells = <0>; - clocks = <&cru ACLK_PERIHP>; - pm_qos = <&qos_perihp>, - <&qos_pcie>, - <&qos_usb_host0>, - <&qos_usb_host1>; - - pd_sd@RK3399_PD_SD { - reg = <RK3399_PD_SD>; - clocks = <&cru HCLK_SDMMC>, - <&cru SCLK_SDMMC>; - pm_qos = <&qos_sd>; - }; + pd_sd@RK3399_PD_SD { + reg = <RK3399_PD_SD>; + clocks = <&cru HCLK_SDMMC>, + <&cru SCLK_SDMMC>; + pm_qos = <&qos_sd>; }; pd_sdioaudio@RK3399_PD_SDIOAUDIO { reg = <RK3399_PD_SDIOAUDIO>; @@ -1070,6 +1124,8 @@ pmugrf: syscon@ff320000 { compatible = "rockchip,rk3399-pmugrf", "syscon", "simple-mfd"; reg = <0x0 0xff320000 0x0 0x1000>; + #address-cells = <1>; + #size-cells = <1>;
pmu_io_domains: io-domains { compatible = "rockchip,rk3399-pmu-io-voltage-domain"; @@ -1192,6 +1248,62 @@ status = "disabled"; };
+ vpu: video-codec@ff650000 { + compatible = "rockchip,rk3399-vpu"; + reg = <0x0 0xff650000 0x0 0x800>; + interrupts = <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH 0>; + interrupt-names = "vepu", "vdpu"; + clocks = <&cru ACLK_VCODEC>, <&cru HCLK_VCODEC>; + clock-names = "aclk", "hclk"; + iommus = <&vpu_mmu>; + power-domains = <&power RK3399_PD_VCODEC>; + }; + + vpu_mmu: iommu@ff650800 { + compatible = "rockchip,iommu"; + reg = <0x0 0xff650800 0x0 0x40>; + interrupts = <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH 0>; + interrupt-names = "vpu_mmu"; + clocks = <&cru ACLK_VCODEC>, <&cru HCLK_VCODEC>; + clock-names = "aclk", "iface"; + #iommu-cells = <0>; + power-domains = <&power RK3399_PD_VCODEC>; + }; + + vdec_mmu: iommu@ff660480 { + compatible = "rockchip,iommu"; + reg = <0x0 0xff660480 0x0 0x40>, <0x0 0xff6604c0 0x0 0x40>; + interrupts = <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH 0>; + interrupt-names = "vdec_mmu"; + clocks = <&cru ACLK_VDU>, <&cru HCLK_VDU>; + clock-names = "aclk", "iface"; + #iommu-cells = <0>; + status = "disabled"; + }; + + iep_mmu: iommu@ff670800 { + compatible = "rockchip,iommu"; + reg = <0x0 0xff670800 0x0 0x40>; + interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH 0>; + interrupt-names = "iep_mmu"; + clocks = <&cru ACLK_IEP>, <&cru HCLK_IEP>; + clock-names = "aclk", "iface"; + #iommu-cells = <0>; + status = "disabled"; + }; + + rga: rga@ff680000 { + compatible = "rockchip,rk3399-rga"; + reg = <0x0 0xff680000 0x0 0x10000>; + interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru ACLK_RGA>, <&cru HCLK_RGA>, <&cru SCLK_RGA_CORE>; + clock-names = "aclk", "hclk", "sclk"; + resets = <&cru SRST_RGA_CORE>, <&cru SRST_A_RGA>, <&cru SRST_H_RGA>; + reset-names = "core", "axi", "ahb"; + power-domains = <&power RK3399_PD_RGA>; + }; + efuse0: efuse@ff690000 { compatible = "rockchip,rk3399-efuse"; reg = <0x0 0xff690000 0x0 0x80>; @@ -1342,8 +1454,9 @@ compatible = "rockchip,rk3399-pcie-phy"; clocks = <&cru SCLK_PCIEPHY_REF>; clock-names = "refclk"; - #phy-cells = <0>; + #phy-cells = <1>; resets = <&cru SRST_PCIEPHY>; + drive-impedance-ohm = <50>; reset-names = "phy"; status = "disabled"; }; @@ -1592,11 +1705,11 @@ reg = <0x0 0xff914000 0x0 0x100>, <0x0 0xff915000 0x0 0x100>; interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH 0>; interrupt-names = "isp0_mmu"; - clocks = <&cru ACLK_ISP0_NOC>, <&cru HCLK_ISP0_NOC>; + clocks = <&cru ACLK_ISP0_WRAPPER>, <&cru HCLK_ISP0_WRAPPER>; clock-names = "aclk", "iface"; #iommu-cells = <0>; + power-domains = <&power RK3399_PD_ISP0>; rockchip,disable-mmu-reset; - status = "disabled"; };
isp1_mmu: iommu@ff924000 { @@ -1604,11 +1717,11 @@ reg = <0x0 0xff924000 0x0 0x100>, <0x0 0xff925000 0x0 0x100>; interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH 0>; interrupt-names = "isp1_mmu"; - clocks = <&cru ACLK_ISP1_NOC>, <&cru HCLK_ISP1_NOC>; + clocks = <&cru ACLK_ISP1_WRAPPER>, <&cru HCLK_ISP1_WRAPPER>; clock-names = "aclk", "iface"; #iommu-cells = <0>; + power-domains = <&power RK3399_PD_ISP1>; rockchip,disable-mmu-reset; - status = "disabled"; };
hdmi_sound: hdmi-sound { @@ -1660,21 +1773,29 @@ };
mipi_dsi: mipi@ff960000 { - compatible = "rockchip,rk3399_mipi_dsi"; + compatible = "rockchip,rk3399-mipi-dsi", "snps,dw-mipi-dsi"; reg = <0x0 0xff960000 0x0 0x8000>; interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru SCLK_MIPIDPHY_REF>, <&cru PCLK_MIPI_DSI0>, - <&cru SCLK_DPHY_TX0_CFG>; - clock-names = "ref", "pclk", "phy_cfg"; + clocks = <&cru SCLK_DPHY_PLL>, <&cru PCLK_MIPI_DSI0>, + <&cru SCLK_DPHY_TX0_CFG>, <&cru PCLK_VIO_GRF>; + clock-names = "ref", "pclk", "phy_cfg", "grf"; + power-domains = <&power RK3399_PD_VIO>; + resets = <&cru SRST_P_MIPI_DSI0>; + reset-names = "apb"; rockchip,grf = <&grf>; #address-cells = <1>; #size-cells = <0>; status = "disabled"; + ports { - reg = <1>; - mipi_in: port { + #address-cells = <1>; + #size-cells = <0>; + + mipi_in: port@0 { + reg = <0>; #address-cells = <1>; #size-cells = <0>; + mipi_in_vopb: endpoint@0 { reg = <0>; remote-endpoint = <&vopb_out_mipi>; @@ -1698,6 +1819,8 @@ resets = <&cru SRST_P_MIPI_DSI1>; reset-names = "apb"; rockchip,grf = <&grf>; + #address-cells = <1>; + #size-cells = <0>; status = "disabled";
ports { @@ -1765,6 +1888,7 @@ <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH 0>; interrupt-names = "gpu", "job", "mmu"; clocks = <&cru ACLK_GPU>; + #cooling-cells = <2>; power-domains = <&power RK3399_PD_GPU>; status = "disabled"; }; @@ -1929,14 +2053,14 @@
clock { clk_32k: clk-32k { - rockchip,pins = <0 RK_PA0 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <0 RK_PA0 2 &pcfg_pull_none>; }; };
edp { edp_hpd: edp-hpd { rockchip,pins = - <4 RK_PC7 RK_FUNC_2 &pcfg_pull_none>; + <4 RK_PC7 2 &pcfg_pull_none>; }; };
@@ -1944,382 +2068,409 @@ rgmii_pins: rgmii-pins { rockchip,pins = /* mac_txclk */ - <3 RK_PC1 RK_FUNC_1 &pcfg_pull_none_13ma>, + <3 RK_PC1 1 &pcfg_pull_none_13ma>, /* mac_rxclk */ - <3 RK_PB6 RK_FUNC_1 &pcfg_pull_none>, + <3 RK_PB6 1 &pcfg_pull_none>, /* mac_mdio */ - <3 RK_PB5 RK_FUNC_1 &pcfg_pull_none>, + <3 RK_PB5 1 &pcfg_pull_none>, /* mac_txen */ - <3 RK_PB4 RK_FUNC_1 &pcfg_pull_none_13ma>, + <3 RK_PB4 1 &pcfg_pull_none_13ma>, /* mac_clk */ - <3 RK_PB3 RK_FUNC_1 &pcfg_pull_none>, + <3 RK_PB3 1 &pcfg_pull_none>, /* mac_rxdv */ - <3 RK_PB1 RK_FUNC_1 &pcfg_pull_none>, + <3 RK_PB1 1 &pcfg_pull_none>, /* mac_mdc */ - <3 RK_PB0 RK_FUNC_1 &pcfg_pull_none>, + <3 RK_PB0 1 &pcfg_pull_none>, /* mac_rxd1 */ - <3 RK_PA7 RK_FUNC_1 &pcfg_pull_none>, + <3 RK_PA7 1 &pcfg_pull_none>, /* mac_rxd0 */ - <3 RK_PA6 RK_FUNC_1 &pcfg_pull_none>, + <3 RK_PA6 1 &pcfg_pull_none>, /* mac_txd1 */ - <3 RK_PA5 RK_FUNC_1 &pcfg_pull_none_13ma>, + <3 RK_PA5 1 &pcfg_pull_none_13ma>, /* mac_txd0 */ - <3 RK_PA4 RK_FUNC_1 &pcfg_pull_none_13ma>, + <3 RK_PA4 1 &pcfg_pull_none_13ma>, /* mac_rxd3 */ - <3 RK_PA3 RK_FUNC_1 &pcfg_pull_none>, + <3 RK_PA3 1 &pcfg_pull_none>, /* mac_rxd2 */ - <3 RK_PA2 RK_FUNC_1 &pcfg_pull_none>, + <3 RK_PA2 1 &pcfg_pull_none>, /* mac_txd3 */ - <3 RK_PA1 RK_FUNC_1 &pcfg_pull_none_13ma>, + <3 RK_PA1 1 &pcfg_pull_none_13ma>, /* mac_txd2 */ - <3 RK_PA0 RK_FUNC_1 &pcfg_pull_none_13ma>; + <3 RK_PA0 1 &pcfg_pull_none_13ma>; };
rmii_pins: rmii-pins { rockchip,pins = /* mac_mdio */ - <3 RK_PB5 RK_FUNC_1 &pcfg_pull_none>, + <3 RK_PB5 1 &pcfg_pull_none>, /* mac_txen */ - <3 RK_PB4 RK_FUNC_1 &pcfg_pull_none_13ma>, + <3 RK_PB4 1 &pcfg_pull_none_13ma>, /* mac_clk */ - <3 RK_PB3 RK_FUNC_1 &pcfg_pull_none>, + <3 RK_PB3 1 &pcfg_pull_none>, /* mac_rxer */ - <3 RK_PB2 RK_FUNC_1 &pcfg_pull_none>, + <3 RK_PB2 1 &pcfg_pull_none>, /* mac_rxdv */ - <3 RK_PB1 RK_FUNC_1 &pcfg_pull_none>, + <3 RK_PB1 1 &pcfg_pull_none>, /* mac_mdc */ - <3 RK_PB0 RK_FUNC_1 &pcfg_pull_none>, + <3 RK_PB0 1 &pcfg_pull_none>, /* mac_rxd1 */ - <3 RK_PA7 RK_FUNC_1 &pcfg_pull_none>, + <3 RK_PA7 1 &pcfg_pull_none>, /* mac_rxd0 */ - <3 RK_PA6 RK_FUNC_1 &pcfg_pull_none>, + <3 RK_PA6 1 &pcfg_pull_none>, /* mac_txd1 */ - <3 RK_PA5 RK_FUNC_1 &pcfg_pull_none_13ma>, + <3 RK_PA5 1 &pcfg_pull_none_13ma>, /* mac_txd0 */ - <3 RK_PA4 RK_FUNC_1 &pcfg_pull_none_13ma>; + <3 RK_PA4 1 &pcfg_pull_none_13ma>; }; };
i2c0 { i2c0_xfer: i2c0-xfer { rockchip,pins = - <1 RK_PB7 RK_FUNC_2 &pcfg_pull_none>, - <1 RK_PC0 RK_FUNC_2 &pcfg_pull_none>; + <1 RK_PB7 2 &pcfg_pull_none>, + <1 RK_PC0 2 &pcfg_pull_none>; }; };
i2c1 { i2c1_xfer: i2c1-xfer { rockchip,pins = - <4 RK_PA2 RK_FUNC_1 &pcfg_pull_none>, - <4 RK_PA1 RK_FUNC_1 &pcfg_pull_none>; + <4 RK_PA2 1 &pcfg_pull_none>, + <4 RK_PA1 1 &pcfg_pull_none>; }; };
i2c2 { i2c2_xfer: i2c2-xfer { rockchip,pins = - <2 RK_PA1 RK_FUNC_2 &pcfg_pull_none_12ma>, - <2 RK_PA0 RK_FUNC_2 &pcfg_pull_none_12ma>; + <2 RK_PA1 2 &pcfg_pull_none_12ma>, + <2 RK_PA0 2 &pcfg_pull_none_12ma>; }; };
i2c3 { i2c3_xfer: i2c3-xfer { rockchip,pins = - <4 RK_PC1 RK_FUNC_1 &pcfg_pull_none>, - <4 RK_PC0 RK_FUNC_1 &pcfg_pull_none>; + <4 RK_PC1 1 &pcfg_pull_none>, + <4 RK_PC0 1 &pcfg_pull_none>; }; };
i2c4 { i2c4_xfer: i2c4-xfer { rockchip,pins = - <1 RK_PB4 RK_FUNC_1 &pcfg_pull_none>, - <1 RK_PB3 RK_FUNC_1 &pcfg_pull_none>; + <1 RK_PB4 1 &pcfg_pull_none>, + <1 RK_PB3 1 &pcfg_pull_none>; }; };
i2c5 { i2c5_xfer: i2c5-xfer { rockchip,pins = - <3 RK_PB3 RK_FUNC_2 &pcfg_pull_none>, - <3 RK_PB2 RK_FUNC_2 &pcfg_pull_none>; + <3 RK_PB3 2 &pcfg_pull_none>, + <3 RK_PB2 2 &pcfg_pull_none>; }; };
i2c6 { i2c6_xfer: i2c6-xfer { rockchip,pins = - <2 RK_PB2 RK_FUNC_2 &pcfg_pull_none>, - <2 RK_PB1 RK_FUNC_2 &pcfg_pull_none>; + <2 RK_PB2 2 &pcfg_pull_none>, + <2 RK_PB1 2 &pcfg_pull_none>; }; };
i2c7 { i2c7_xfer: i2c7-xfer { rockchip,pins = - <2 RK_PB0 RK_FUNC_2 &pcfg_pull_none>, - <2 RK_PA7 RK_FUNC_2 &pcfg_pull_none>; + <2 RK_PB0 2 &pcfg_pull_none>, + <2 RK_PA7 2 &pcfg_pull_none>; }; };
i2c8 { i2c8_xfer: i2c8-xfer { rockchip,pins = - <1 RK_PC5 RK_FUNC_1 &pcfg_pull_none>, - <1 RK_PC4 RK_FUNC_1 &pcfg_pull_none>; + <1 RK_PC5 1 &pcfg_pull_none>, + <1 RK_PC4 1 &pcfg_pull_none>; }; };
i2s0 { + i2s0_2ch_bus: i2s0-2ch-bus { + rockchip,pins = + <3 RK_PD0 1 &pcfg_pull_none>, + <3 RK_PD1 1 &pcfg_pull_none>, + <3 RK_PD2 1 &pcfg_pull_none>, + <3 RK_PD3 1 &pcfg_pull_none>, + <3 RK_PD7 1 &pcfg_pull_none>, + <4 RK_PA0 1 &pcfg_pull_none>; + }; + i2s0_8ch_bus: i2s0-8ch-bus { rockchip,pins = - <3 RK_PD0 RK_FUNC_1 &pcfg_pull_none>, - <3 RK_PD1 RK_FUNC_1 &pcfg_pull_none>, - <3 RK_PD2 RK_FUNC_1 &pcfg_pull_none>, - <3 RK_PD3 RK_FUNC_1 &pcfg_pull_none>, - <3 RK_PD4 RK_FUNC_1 &pcfg_pull_none>, - <3 RK_PD5 RK_FUNC_1 &pcfg_pull_none>, - <3 RK_PD6 RK_FUNC_1 &pcfg_pull_none>, - <3 RK_PD7 RK_FUNC_1 &pcfg_pull_none>, - <4 RK_PA0 RK_FUNC_1 &pcfg_pull_none>; + <3 RK_PD0 1 &pcfg_pull_none>, + <3 RK_PD1 1 &pcfg_pull_none>, + <3 RK_PD2 1 &pcfg_pull_none>, + <3 RK_PD3 1 &pcfg_pull_none>, + <3 RK_PD4 1 &pcfg_pull_none>, + <3 RK_PD5 1 &pcfg_pull_none>, + <3 RK_PD6 1 &pcfg_pull_none>, + <3 RK_PD7 1 &pcfg_pull_none>, + <4 RK_PA0 1 &pcfg_pull_none>; }; };
i2s1 { i2s1_2ch_bus: i2s1-2ch-bus { rockchip,pins = - <4 RK_PA3 RK_FUNC_1 &pcfg_pull_none>, - <4 RK_PA4 RK_FUNC_1 &pcfg_pull_none>, - <4 RK_PA5 RK_FUNC_1 &pcfg_pull_none>, - <4 RK_PA6 RK_FUNC_1 &pcfg_pull_none>, - <4 RK_PA7 RK_FUNC_1 &pcfg_pull_none>; + <4 RK_PA3 1 &pcfg_pull_none>, + <4 RK_PA4 1 &pcfg_pull_none>, + <4 RK_PA5 1 &pcfg_pull_none>, + <4 RK_PA6 1 &pcfg_pull_none>, + <4 RK_PA7 1 &pcfg_pull_none>; }; };
sdio0 { sdio0_bus1: sdio0-bus1 { rockchip,pins = - <2 RK_PC4 RK_FUNC_1 &pcfg_pull_up>; + <2 RK_PC4 1 &pcfg_pull_up>; };
sdio0_bus4: sdio0-bus4 { rockchip,pins = - <2 RK_PC4 RK_FUNC_1 &pcfg_pull_up>, - <2 RK_PC5 RK_FUNC_1 &pcfg_pull_up>, - <2 RK_PC6 RK_FUNC_1 &pcfg_pull_up>, - <2 RK_PC7 RK_FUNC_1 &pcfg_pull_up>; + <2 RK_PC4 1 &pcfg_pull_up>, + <2 RK_PC5 1 &pcfg_pull_up>, + <2 RK_PC6 1 &pcfg_pull_up>, + <2 RK_PC7 1 &pcfg_pull_up>; };
sdio0_cmd: sdio0-cmd { rockchip,pins = - <2 RK_PD0 RK_FUNC_1 &pcfg_pull_up>; + <2 RK_PD0 1 &pcfg_pull_up>; };
sdio0_clk: sdio0-clk { rockchip,pins = - <2 RK_PD1 RK_FUNC_1 &pcfg_pull_none>; + <2 RK_PD1 1 &pcfg_pull_none>; };
sdio0_cd: sdio0-cd { rockchip,pins = - <2 RK_PD2 RK_FUNC_1 &pcfg_pull_up>; + <2 RK_PD2 1 &pcfg_pull_up>; };
sdio0_pwr: sdio0-pwr { rockchip,pins = - <2 RK_PD3 RK_FUNC_1 &pcfg_pull_up>; + <2 RK_PD3 1 &pcfg_pull_up>; };
sdio0_bkpwr: sdio0-bkpwr { rockchip,pins = - <2 RK_PD4 RK_FUNC_1 &pcfg_pull_up>; + <2 RK_PD4 1 &pcfg_pull_up>; };
sdio0_wp: sdio0-wp { rockchip,pins = - <0 RK_PA3 RK_FUNC_1 &pcfg_pull_up>; + <0 RK_PA3 1 &pcfg_pull_up>; };
sdio0_int: sdio0-int { rockchip,pins = - <0 RK_PA4 RK_FUNC_1 &pcfg_pull_up>; + <0 RK_PA4 1 &pcfg_pull_up>; }; };
sdmmc { sdmmc_bus1: sdmmc-bus1 { rockchip,pins = - <4 RK_PB0 RK_FUNC_1 &pcfg_pull_up>; + <4 RK_PB0 1 &pcfg_pull_up>; };
sdmmc_bus4: sdmmc-bus4 { rockchip,pins = - <4 RK_PB0 RK_FUNC_1 &pcfg_pull_up>, - <4 RK_PB1 RK_FUNC_1 &pcfg_pull_up>, - <4 RK_PB2 RK_FUNC_1 &pcfg_pull_up>, - <4 RK_PB3 RK_FUNC_1 &pcfg_pull_up>; + <4 RK_PB0 1 &pcfg_pull_up>, + <4 RK_PB1 1 &pcfg_pull_up>, + <4 RK_PB2 1 &pcfg_pull_up>, + <4 RK_PB3 1 &pcfg_pull_up>; };
sdmmc_clk: sdmmc-clk { rockchip,pins = - <4 RK_PB4 RK_FUNC_1 &pcfg_pull_none>; + <4 RK_PB4 1 &pcfg_pull_none>; };
sdmmc_cmd: sdmmc-cmd { rockchip,pins = - <4 RK_PB5 RK_FUNC_1 &pcfg_pull_up>; + <4 RK_PB5 1 &pcfg_pull_up>; };
sdmmc_cd: sdmmc-cd { rockchip,pins = - <0 RK_PA7 RK_FUNC_1 &pcfg_pull_up>; + <0 RK_PA7 1 &pcfg_pull_up>; };
sdmmc_wp: sdmmc-wp { rockchip,pins = - <0 RK_PB0 RK_FUNC_1 &pcfg_pull_up>; + <0 RK_PB0 1 &pcfg_pull_up>; }; };
sleep { ap_pwroff: ap-pwroff { - rockchip,pins = <1 RK_PA5 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <1 RK_PA5 1 &pcfg_pull_none>; };
ddrio_pwroff: ddrio-pwroff { - rockchip,pins = <0 RK_PA1 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PA1 1 &pcfg_pull_none>; }; };
spdif { spdif_bus: spdif-bus { rockchip,pins = - <4 RK_PC5 RK_FUNC_1 &pcfg_pull_none>; + <4 RK_PC5 1 &pcfg_pull_none>; };
spdif_bus_1: spdif-bus-1 { rockchip,pins = - <3 RK_PC0 RK_FUNC_3 &pcfg_pull_none>; + <3 RK_PC0 3 &pcfg_pull_none>; }; };
spi0 { spi0_clk: spi0-clk { rockchip,pins = - <3 RK_PA6 RK_FUNC_2 &pcfg_pull_up>; + <3 RK_PA6 2 &pcfg_pull_up>; }; spi0_cs0: spi0-cs0 { rockchip,pins = - <3 RK_PA7 RK_FUNC_2 &pcfg_pull_up>; + <3 RK_PA7 2 &pcfg_pull_up>; }; spi0_cs1: spi0-cs1 { rockchip,pins = - <3 RK_PB0 RK_FUNC_2 &pcfg_pull_up>; + <3 RK_PB0 2 &pcfg_pull_up>; }; spi0_tx: spi0-tx { rockchip,pins = - <3 RK_PA5 RK_FUNC_2 &pcfg_pull_up>; + <3 RK_PA5 2 &pcfg_pull_up>; }; spi0_rx: spi0-rx { rockchip,pins = - <3 RK_PA4 RK_FUNC_2 &pcfg_pull_up>; + <3 RK_PA4 2 &pcfg_pull_up>; }; };
spi1 { spi1_clk: spi1-clk { rockchip,pins = - <1 RK_PB1 RK_FUNC_2 &pcfg_pull_up>; + <1 RK_PB1 2 &pcfg_pull_up>; }; spi1_cs0: spi1-cs0 { rockchip,pins = - <1 RK_PB2 RK_FUNC_2 &pcfg_pull_up>; + <1 RK_PB2 2 &pcfg_pull_up>; }; spi1_rx: spi1-rx { rockchip,pins = - <1 RK_PA7 RK_FUNC_2 &pcfg_pull_up>; + <1 RK_PA7 2 &pcfg_pull_up>; }; spi1_tx: spi1-tx { rockchip,pins = - <1 RK_PB0 RK_FUNC_2 &pcfg_pull_up>; + <1 RK_PB0 2 &pcfg_pull_up>; }; };
spi2 { spi2_clk: spi2-clk { rockchip,pins = - <2 RK_PB3 RK_FUNC_1 &pcfg_pull_up>; + <2 RK_PB3 1 &pcfg_pull_up>; }; spi2_cs0: spi2-cs0 { rockchip,pins = - <2 RK_PB4 RK_FUNC_1 &pcfg_pull_up>; + <2 RK_PB4 1 &pcfg_pull_up>; }; spi2_rx: spi2-rx { rockchip,pins = - <2 RK_PB1 RK_FUNC_1 &pcfg_pull_up>; + <2 RK_PB1 1 &pcfg_pull_up>; }; spi2_tx: spi2-tx { rockchip,pins = - <2 RK_PB2 RK_FUNC_1 &pcfg_pull_up>; + <2 RK_PB2 1 &pcfg_pull_up>; }; };
spi3 { spi3_clk: spi3-clk { rockchip,pins = - <1 RK_PC1 RK_FUNC_1 &pcfg_pull_up>; + <1 RK_PC1 1 &pcfg_pull_up>; }; spi3_cs0: spi3-cs0 { rockchip,pins = - <1 RK_PC2 RK_FUNC_1 &pcfg_pull_up>; + <1 RK_PC2 1 &pcfg_pull_up>; }; spi3_rx: spi3-rx { rockchip,pins = - <1 RK_PB7 RK_FUNC_1 &pcfg_pull_up>; + <1 RK_PB7 1 &pcfg_pull_up>; }; spi3_tx: spi3-tx { rockchip,pins = - <1 RK_PC0 RK_FUNC_1 &pcfg_pull_up>; + <1 RK_PC0 1 &pcfg_pull_up>; }; };
spi4 { spi4_clk: spi4-clk { rockchip,pins = - <3 RK_PA2 RK_FUNC_2 &pcfg_pull_up>; + <3 RK_PA2 2 &pcfg_pull_up>; }; spi4_cs0: spi4-cs0 { rockchip,pins = - <3 RK_PA3 RK_FUNC_2 &pcfg_pull_up>; + <3 RK_PA3 2 &pcfg_pull_up>; }; spi4_rx: spi4-rx { rockchip,pins = - <3 RK_PA0 RK_FUNC_2 &pcfg_pull_up>; + <3 RK_PA0 2 &pcfg_pull_up>; }; spi4_tx: spi4-tx { rockchip,pins = - <3 RK_PA1 RK_FUNC_2 &pcfg_pull_up>; + <3 RK_PA1 2 &pcfg_pull_up>; }; };
spi5 { spi5_clk: spi5-clk { rockchip,pins = - <2 RK_PC6 RK_FUNC_2 &pcfg_pull_up>; + <2 RK_PC6 2 &pcfg_pull_up>; }; spi5_cs0: spi5-cs0 { rockchip,pins = - <2 RK_PC7 RK_FUNC_2 &pcfg_pull_up>; + <2 RK_PC7 2 &pcfg_pull_up>; }; spi5_rx: spi5-rx { rockchip,pins = - <2 RK_PC4 RK_FUNC_2 &pcfg_pull_up>; + <2 RK_PC4 2 &pcfg_pull_up>; }; spi5_tx: spi5-tx { rockchip,pins = - <2 RK_PC5 RK_FUNC_2 &pcfg_pull_up>; + <2 RK_PC5 2 &pcfg_pull_up>; + }; + }; + + testclk { + test_clkout0: test-clkout0 { + rockchip,pins = + <0 RK_PA0 1 &pcfg_pull_none>; + }; + + test_clkout1: test-clkout1 { + rockchip,pins = + <2 RK_PD1 2 &pcfg_pull_none>; + }; + + test_clkout2: test-clkout2 { + rockchip,pins = + <0 RK_PB0 3 &pcfg_pull_none>; }; };
@@ -2329,168 +2480,168 @@ };
otp_out: otp-out { - rockchip,pins = <1 RK_PA6 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <1 RK_PA6 1 &pcfg_pull_none>; }; };
uart0 { uart0_xfer: uart0-xfer { rockchip,pins = - <2 RK_PC0 RK_FUNC_1 &pcfg_pull_up>, - <2 RK_PC1 RK_FUNC_1 &pcfg_pull_none>; + <2 RK_PC0 1 &pcfg_pull_up>, + <2 RK_PC1 1 &pcfg_pull_none>; };
uart0_cts: uart0-cts { rockchip,pins = - <2 RK_PC2 RK_FUNC_1 &pcfg_pull_none>; + <2 RK_PC2 1 &pcfg_pull_none>; };
uart0_rts: uart0-rts { rockchip,pins = - <2 RK_PC3 RK_FUNC_1 &pcfg_pull_none>; + <2 RK_PC3 1 &pcfg_pull_none>; }; };
uart1 { uart1_xfer: uart1-xfer { rockchip,pins = - <3 RK_PB4 RK_FUNC_2 &pcfg_pull_up>, - <3 RK_PB5 RK_FUNC_2 &pcfg_pull_none>; + <3 RK_PB4 2 &pcfg_pull_up>, + <3 RK_PB5 2 &pcfg_pull_none>; }; };
uart2a { uart2a_xfer: uart2a-xfer { rockchip,pins = - <4 RK_PB0 RK_FUNC_2 &pcfg_pull_up>, - <4 RK_PB1 RK_FUNC_2 &pcfg_pull_none>; + <4 RK_PB0 2 &pcfg_pull_up>, + <4 RK_PB1 2 &pcfg_pull_none>; }; };
uart2b { uart2b_xfer: uart2b-xfer { rockchip,pins = - <4 RK_PC0 RK_FUNC_2 &pcfg_pull_up>, - <4 RK_PC1 RK_FUNC_2 &pcfg_pull_none>; + <4 RK_PC0 2 &pcfg_pull_up>, + <4 RK_PC1 2 &pcfg_pull_none>; }; };
uart2c { uart2c_xfer: uart2c-xfer { rockchip,pins = - <4 RK_PC3 RK_FUNC_1 &pcfg_pull_up>, - <4 RK_PC4 RK_FUNC_1 &pcfg_pull_none>; + <4 RK_PC3 1 &pcfg_pull_up>, + <4 RK_PC4 1 &pcfg_pull_none>; }; };
uart3 { uart3_xfer: uart3-xfer { rockchip,pins = - <3 RK_PB6 RK_FUNC_2 &pcfg_pull_up>, - <3 RK_PB7 RK_FUNC_2 &pcfg_pull_none>; + <3 RK_PB6 2 &pcfg_pull_up>, + <3 RK_PB7 2 &pcfg_pull_none>; };
uart3_cts: uart3-cts { rockchip,pins = - <3 RK_PC2 RK_FUNC_2 &pcfg_pull_none>; + <3 RK_PC0 2 &pcfg_pull_none>; };
uart3_rts: uart3-rts { rockchip,pins = - <3 RK_PC3 RK_FUNC_2 &pcfg_pull_none>; + <3 RK_PC1 2 &pcfg_pull_none>; }; };
uart4 { uart4_xfer: uart4-xfer { rockchip,pins = - <1 RK_PA7 RK_FUNC_1 &pcfg_pull_up>, - <1 RK_PB0 RK_FUNC_1 &pcfg_pull_none>; + <1 RK_PA7 1 &pcfg_pull_up>, + <1 RK_PB0 1 &pcfg_pull_none>; }; };
uarthdcp { uarthdcp_xfer: uarthdcp-xfer { rockchip,pins = - <4 RK_PC5 RK_FUNC_2 &pcfg_pull_up>, - <4 RK_PC6 RK_FUNC_2 &pcfg_pull_none>; + <4 RK_PC5 2 &pcfg_pull_up>, + <4 RK_PC6 2 &pcfg_pull_none>; }; };
pwm0 { pwm0_pin: pwm0-pin { rockchip,pins = - <4 RK_PC2 RK_FUNC_1 &pcfg_pull_none>; + <4 RK_PC2 1 &pcfg_pull_none>; + }; + + pwm0_pin_pull_down: pwm0-pin-pull-down { + rockchip,pins = + <4 RK_PC2 1 &pcfg_pull_down>; };
vop0_pwm_pin: vop0-pwm-pin { rockchip,pins = - <4 RK_PC2 RK_FUNC_2 &pcfg_pull_none>; + <4 RK_PC2 2 &pcfg_pull_none>; + }; + + vop1_pwm_pin: vop1-pwm-pin { + rockchip,pins = + <4 RK_PC2 3 &pcfg_pull_none>; }; };
pwm1 { pwm1_pin: pwm1-pin { rockchip,pins = - <4 RK_PC6 RK_FUNC_1 &pcfg_pull_none>; + <4 RK_PC6 1 &pcfg_pull_none>; };
- vop1_pwm_pin: vop1-pwm-pin { + pwm1_pin_pull_down: pwm1-pin-pull-down { rockchip,pins = - <4 RK_PC2 RK_FUNC_3 &pcfg_pull_none>; + <4 RK_PC6 1 &pcfg_pull_down>; }; };
pwm2 { pwm2_pin: pwm2-pin { rockchip,pins = - <1 RK_PC3 RK_FUNC_1 &pcfg_pull_none>; + <1 RK_PC3 1 &pcfg_pull_none>; };
pwm2_pin_pull_down: pwm2-pin-pull-down { rockchip,pins = - <1 RK_PC3 RK_FUNC_1 &pcfg_pull_down>; + <1 RK_PC3 1 &pcfg_pull_down>; }; };
pwm3a { pwm3a_pin: pwm3a-pin { rockchip,pins = - <0 RK_PA6 RK_FUNC_1 &pcfg_pull_none>; + <0 RK_PA6 1 &pcfg_pull_none>; }; };
pwm3b { pwm3b_pin: pwm3b-pin { rockchip,pins = - <1 RK_PB6 RK_FUNC_1 &pcfg_pull_none>; + <1 RK_PB6 1 &pcfg_pull_none>; }; };
hdmi { hdmi_i2c_xfer: hdmi-i2c-xfer { rockchip,pins = - <4 RK_PC1 RK_FUNC_3 &pcfg_pull_none>, - <4 RK_PC0 RK_FUNC_3 &pcfg_pull_none>; + <4 RK_PC1 3 &pcfg_pull_none>, + <4 RK_PC0 3 &pcfg_pull_none>; };
hdmi_cec: hdmi-cec { rockchip,pins = - <4 RK_PC7 RK_FUNC_1 &pcfg_pull_none>; + <4 RK_PC7 1 &pcfg_pull_none>; }; };
pcie { - pcie_clkreqn: pci-clkreqn { - rockchip,pins = - <2 RK_PD2 RK_FUNC_2 &pcfg_pull_none>; - }; - - pcie_clkreqnb: pci-clkreqnb { - rockchip,pins = - <4 RK_PD0 RK_FUNC_1 &pcfg_pull_none>; - }; - pcie_clkreqn_cpm: pci-clkreqn-cpm { rockchip,pins = <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>;
On 2020/4/28 下午6:00, Jagan Teki wrote:
Sync rk3399 dts(i) files from v5.7-rc1 linux-next.
Reason: To get updated PCIe nodes and properties on respective dts(i) files.
Summary:
- sync won't include new board dts(i)
- sync will add required files used on respective dts(i)
- rk3399-puma-u-boot.dtsi spiflash label changed to norflash
- move puma.dtsi bios_enable into rk3399-puma-u-boot.dtsi
- move legacy max-frequency of sdhci into rk3399-u-boot.dtsi
- update cross-ec-[keyboard|sbs].dtsi path as per U-Boot
- keep roc-rk3399-pc dc_12v changes to -u-boot.dtsi
Signed-off-by: Jagan Teki jagan@amarulasolutions.com
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changes for v2:
arch/arm/dts/cros-ec-keyboard.dtsi | 10 +- arch/arm/dts/cros-ec-sbs.dtsi | 39 +- arch/arm/dts/rk3399-evb.dts | 520 +++++++++++----- arch/arm/dts/rk3399-ficus.dts | 6 + arch/arm/dts/rk3399-firefly.dts | 251 ++++++-- arch/arm/dts/rk3399-gru-bob.dts | 16 +- arch/arm/dts/rk3399-gru-chromebook.dtsi | 40 +- arch/arm/dts/rk3399-gru-kevin.dts | 34 +- arch/arm/dts/rk3399-gru.dtsi | 90 ++- arch/arm/dts/rk3399-khadas-edge.dtsi | 3 + arch/arm/dts/rk3399-leez-p710.dts | 36 +- arch/arm/dts/rk3399-nanopc-t4.dts | 47 +- arch/arm/dts/rk3399-nanopi4.dtsi | 66 +- arch/arm/dts/rk3399-orangepi.dts | 79 ++- arch/arm/dts/rk3399-puma-u-boot.dtsi | 25 +- arch/arm/dts/rk3399-puma.dtsi | 567 +++++++---------- arch/arm/dts/rk3399-roc-pc-u-boot.dtsi | 36 ++ arch/arm/dts/rk3399-roc-pc.dts | 3 +- arch/arm/dts/rk3399-roc-pc.dtsi | 35 +- arch/arm/dts/rk3399-rock-pi-4.dts | 129 ++++ arch/arm/dts/rk3399-rock960.dts | 49 ++ arch/arm/dts/rk3399-rock960.dtsi | 13 +- arch/arm/dts/rk3399-rockpro64.dts | 751 +--------------------- arch/arm/dts/rk3399-rockpro64.dtsi | 797 ++++++++++++++++++++++++ arch/arm/dts/rk3399-u-boot.dtsi | 1 + arch/arm/dts/rk3399.dtsi | 583 ++++++++++------- 26 files changed, 2574 insertions(+), 1652 deletions(-) create mode 100644 arch/arm/dts/rk3399-rockpro64.dtsi
diff --git a/arch/arm/dts/cros-ec-keyboard.dtsi b/arch/arm/dts/cros-ec-keyboard.dtsi index 9c7fb0acae..4a0c1037fb 100644 --- a/arch/arm/dts/cros-ec-keyboard.dtsi +++ b/arch/arm/dts/cros-ec-keyboard.dtsi @@ -1,11 +1,8 @@ +// SPDX-License-Identifier: GPL-2.0-only /*
- Keyboard dts fragment for devices that use cros-ec-keyboard
- Copyright (c) 2014 Google, Inc
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License version 2 as
- published by the Free Software Foundation.
#include <dt-bindings/input/input.h>
@@ -22,6 +19,7 @@ MATRIX_KEY(0x00, 0x02, KEY_F1) MATRIX_KEY(0x00, 0x03, KEY_B) MATRIX_KEY(0x00, 0x04, KEY_F10)
MATRIX_KEY(0x00, 0x05, KEY_RO) MATRIX_KEY(0x00, 0x06, KEY_N) MATRIX_KEY(0x00, 0x08, KEY_EQUAL) MATRIX_KEY(0x00, 0x0a, KEY_RIGHTALT)
@@ -34,6 +32,7 @@ MATRIX_KEY(0x01, 0x08, KEY_APOSTROPHE) MATRIX_KEY(0x01, 0x09, KEY_F9) MATRIX_KEY(0x01, 0x0b, KEY_BACKSPACE)
MATRIX_KEY(0x01, 0x0c, KEY_HENKAN) MATRIX_KEY(0x02, 0x00, KEY_LEFTCTRL) MATRIX_KEY(0x02, 0x01, KEY_TAB)
@@ -45,6 +44,7 @@ MATRIX_KEY(0x02, 0x07, KEY_102ND) MATRIX_KEY(0x02, 0x08, KEY_LEFTBRACE) MATRIX_KEY(0x02, 0x09, KEY_F8)
MATRIX_KEY(0x02, 0x0a, KEY_YEN) MATRIX_KEY(0x03, 0x01, KEY_GRAVE) MATRIX_KEY(0x03, 0x02, KEY_F2)
@@ -52,7 +52,9 @@ MATRIX_KEY(0x03, 0x04, KEY_F5) MATRIX_KEY(0x03, 0x06, KEY_6) MATRIX_KEY(0x03, 0x08, KEY_MINUS)
MATRIX_KEY(0x03, 0x09, KEY_F13) MATRIX_KEY(0x03, 0x0b, KEY_BACKSLASH)
MATRIX_KEY(0x03, 0x0c, KEY_MUHENKAN) MATRIX_KEY(0x04, 0x00, KEY_RIGHTCTRL) MATRIX_KEY(0x04, 0x01, KEY_A)
diff --git a/arch/arm/dts/cros-ec-sbs.dtsi b/arch/arm/dts/cros-ec-sbs.dtsi index dfe5ea6ca2..71f5c5ecce 100644 --- a/arch/arm/dts/cros-ec-sbs.dtsi +++ b/arch/arm/dts/cros-ec-sbs.dtsi @@ -1,8 +1,45 @@ -// SPDX-License-Identifier: GPL-2.0 /*
- Smart battery dts fragment for devices that use cros-ec-sbs
- Copyright (c) 2015 Google, Inc
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
- a) This file is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License as
published by the Free Software Foundation; either version 2 of the
License, or (at your option) any later version.
This file is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
- Or, alternatively,
- b) Permission is hereby granted, free of charge, to any person
obtaining a copy of this software and associated documentation
files (the "Software"), to deal in the Software without
restriction, including without limitation the rights to use,
copy, modify, merge, publish, distribute, sublicense, and/or
sell copies of the Software, and to permit persons to whom the
Software is furnished to do so, subject to the following
conditions:
The above copyright notice and this permission notice shall be
included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
OTHER DEALINGS IN THE SOFTWARE.
&i2c_tunnel {
diff --git a/arch/arm/dts/rk3399-evb.dts b/arch/arm/dts/rk3399-evb.dts index c72719c0d3..694b0d08d6 100644 --- a/arch/arm/dts/rk3399-evb.dts +++ b/arch/arm/dts/rk3399-evb.dts @@ -1,86 +1,18 @@ -// SPDX-License-Identifier: GPL-2.0+ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /*
- (C) Copyright 2016 Rockchip Electronics Co., Ltd
- Copyright (c) 2016 Fuzhou Rockchip Electronics Co., Ltd
/dts-v1/; #include <dt-bindings/pwm/pwm.h>
-#include <dt-bindings/pinctrl/rockchip.h> #include "rk3399.dtsi"
/ { model = "Rockchip RK3399 Evaluation Board";
- compatible = "rockchip,rk3399-evb", "rockchip,rk3399",
"google,rk3399evb-rev2";
- chosen {
stdout-path = &uart2;
- vdd_center: vdd-center {
pwms = <&pwm3 0 25000 1>;
regulator-max-microvolt = <1400000>;
regulator-init-microvolt = <950000>;
regulator-boot-on;
status = "okay";
- vccsys: vccsys {
regulator-name = "vccsys";
regulator-boot-on;
- vcc3v3_sys: vcc3v3-sys {
regulator-boot-on;
- vcc_phy: vcc-phy-regulator {
regulator-name = "vcc_phy";
regulator-boot-on;
- vcc5v0_host: vcc5v0-host-en {
gpio = <&gpio4 25 GPIO_ACTIVE_HIGH>;
- vcc5v0_typec0: vcc5v0-typec0-en {
regulator-name = "vcc5v0_typec0";
gpio = <&gpio1 3 GPIO_ACTIVE_HIGH>;
- vcc5v0_typec1: vcc5v0-typec1-en {
regulator-name = "vcc5v0_typec1";
gpio = <&gpio1 4 GPIO_ACTIVE_HIGH>;
- clkin_gmac: external-gmac-clock {
#clock-cells = <0>;
compatible = "rockchip,rk3399-evb", "rockchip,rk3399";
backlight: backlight { compatible = "pwm-backlight";
power-supply = <&vccsys>;
brightness-levels = < 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15enable-gpios = <&gpio1 13 GPIO_ACTIVE_HIGH>;
@@ -116,18 +48,98 @@ 248 249 250 251 252 253 254 255>; default-brightness-level = <200>; pwms = <&pwm0 0 25000 0>;
pinctrl-0 = <&pwm0_pin>;
pwm-delay-us = <10000>;
panel:panel {
compatible = "simple-panel";
power-supply = <&vcc33_lcd>;
- edp_panel: edp-panel {
backlight = <&backlight>;compatible ="lg,lp079qx1-sp0v";
/*enable-gpios = <&gpio4 18 GPIO_ACTIVE_HIGH>;*/
enable-gpios = <&gpio1 RK_PB5 GPIO_ACTIVE_HIGH>;
power-supply = <&vcc3v3_s0>;
port {
panel_in_edp: endpoint {
remote-endpoint = <&edp_out_panel>;
#clock-cells = <0>;
pwms = <&pwm3 0 25000 0>;
regulator-boot-on;
status = "okay";
regulator-boot-on;
- vcc5v0_sys: vcc5v0-sys {
regulator-boot-on;
- vcc5v0_host: vcc5v0-host-regulator {
enable-active-high;
gpio = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>;
regulator-boot-on;
regulator-boot-on;
+&edp {
- status = "okay";
- force-hpd;
- ports {
edp_out: port@1 {
reg = <1>;
#size-cells = <0>;
edp_out_panel: endpoint@0 {
reg = <0>;
remote-endpoint = <&panel_in_edp>;
@@ -135,24 +147,253 @@ status = "okay"; };
-&pwm0 { +&gmac {
- assigned-clocks = <&cru SCLK_RMII_SRC>;
- assigned-clock-parents = <&clkin_gmac>;
- clock_in_out = "input";
- phy-supply = <&vcc_phy>;
- phy-mode = "rgmii";
- pinctrl-0 = <&rgmii_pins>;
- snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>;
- snps,reset-active-low;
- snps,reset-delays-us = <0 10000 50000>;
- tx_delay = <0x28>;
- rx_delay = <0x11>; status = "okay"; };
-&pwm2 { +&i2c0 { status = "okay";
- rk808: pmic@1b {
reg = <0x1b>;
interrupts = <21 IRQ_TYPE_LEVEL_LOW>;
wakeup-source;
#clock-cells = <1>;
clock-output-names = "rk808-clkout1", "rk808-clkout2";
vcc1-supply = <&vcc3v3_sys>;
vcc2-supply = <&vcc3v3_sys>;
vcc3-supply = <&vcc3v3_sys>;
vcc4-supply = <&vcc3v3_sys>;
vcc6-supply = <&vcc3v3_sys>;
vcc7-supply = <&vcc3v3_sys>;
vcc9-supply = <&vcc3v3_sys>;
vcc10-supply = <&vcc3v3_sys>;
vcc11-supply = <&vcc3v3_sys>;
vddio-supply = <&vcc1v8_pmu>;
regulators {
vdd_log: DCDC_REG1 {
regulator-boot-on;
regulator-suspend-microvolt = <900000>;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc3v0_tp: LDO_REG2 {
regulator-name = "vcc3v0_tp";
regulator-boot-on;
vcc1v8_pmu: LDO_REG3 {
regulator-name = "vcc1v8_pmu";
regulator-boot-on;
vcc_sd: LDO_REG4 {
regulator-name = "vcc_sd";
regulator-boot-on;
regulator-boot-on;
vcc_1v5: LDO_REG6 {
regulator-boot-on;
regulator-boot-on;
vcc_3v0: LDO_REG8 {
regulator-boot-on;
vcc3v3_s3: SWITCH_REG1 {
regulator-boot-on;
regulator-boot-on;
- vdd_cpu_b: regulator@40 {
reg = <0x40>;
regulator-boot-on;
- vdd_gpu: regulator@41 {
reg = <0x41>;
regulator-boot-on;
-&pwm3 { +&pwm0 { status = "okay"; };
-&saradc { +&pwm2 { status = "okay"; };
-&sdmmc {
- bus-width = <4>;
+&pwm3 { status = "okay"; };
@@ -164,115 +405,76 @@ status = "okay"; };
-&uart2 {
- status = "okay";
+&pcie_phy {
-&usb_host0_ehci {
- status = "okay";
+&pcie0 {
- ep-gpios = <&gpio3 RK_PB5 GPIO_ACTIVE_HIGH>;
- num-lanes = <4>;
- pinctrl-0 = <&pcie_clkreqn_cpm>;
-&usb_host0_ohci { +&u2phy0 { status = "okay"; };
-&usbdrd3_0 {
- vbus-supply = <&vcc5v0_typec0>;
+&u2phy0_host {
- phy-supply = <&vcc5v0_host>; status = "okay"; };
-&usb_host1_ehci { +&u2phy1 { status = "okay"; };
-&usb_host1_ohci { +&u2phy1_host {
-&usbdrd3_1 {
- vbus-supply = <&vcc5v0_typec1>;
+&uart2 { status = "okay"; };
-&i2c0 { +&usb_host0_ehci { status = "okay";
- clock-frequency = <400000>;
- i2c-scl-falling-time-ns = <50>;
- i2c-scl-rising-time-ns = <100>;
- rk808: pmic@1b {
clock-output-names = "xin32k", "wifibt_32kin";
interrupt-parent = <&gpio0>;
interrupts = <4 IRQ_TYPE_LEVEL_LOW>;
reg = <0x1b>;
#clock-cells = <1>;
status = "okay";
+&usb_host0_ohci {
- status = "okay";
regulators {
vcc33_lcd: SWITCH_REG2 {
regulator-boot-on;
regulator-name = "vcc33_lcd";
+&usb_host1_ehci {
- status = "okay"; };
-&mipi_dsi {
- rockchip,panel = <&panel>;
- display-timings {
timing0 {
bits-per-pixel = <24>;
clock-frequency = <160000000>;
hfront-porch = <120>;
hsync-len = <20>;
hback-porch = <21>;
hactive = <1200>;
vfront-porch = <21>;
vsync-len = <3>;
vback-porch = <18>;
vactive = <1920>;
hsync-active = <0>;
vsync-active = <0>;
de-active = <1>;
pixelclk-active = <0>;
+&usb_host1_ohci {
status = "okay"; };
&pinctrl { pmic { pmic_int_l: pmic-int-l { rockchip,pins =
<1 21 RK_FUNC_GPIO &pcfg_pull_up>;
};<1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>;
pmic_dvs2: pmic-dvs2 {
- usb2 {
vcc5v0_host_en: vcc5v0-host-en { rockchip,pins =
<1 18 RK_FUNC_GPIO &pcfg_pull_down>;
}; }; };<4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>;
-&gmac {
- pinctrl-names = "default";
+&vopb {
- status = "okay";
+&vopb_mmu { status = "okay"; }; diff --git a/arch/arm/dts/rk3399-ficus.dts b/arch/arm/dts/rk3399-ficus.dts index 6b059bd7a0..ebe2ee77ba 100644 --- a/arch/arm/dts/rk3399-ficus.dts +++ b/arch/arm/dts/rk3399-ficus.dts @@ -146,6 +146,12 @@ }; };
+&spi1 {
- /* On both Low speed and High speed expansion */
- cs-gpios = <0>, <&gpio4 RK_PA6 0>, <&gpio4 RK_PA7 0>;
- status = "okay";
- &usbdrd_dwc3_0 { dr_mode = "host"; };
diff --git a/arch/arm/dts/rk3399-firefly.dts b/arch/arm/dts/rk3399-firefly.dts index 89c67fd24c..d63faf38cc 100644 --- a/arch/arm/dts/rk3399-firefly.dts +++ b/arch/arm/dts/rk3399-firefly.dts @@ -1,19 +1,20 @@ -// SPDX-License-Identifier: GPL-2.0+ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /*
- Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd.
/dts-v1/; +#include <dt-bindings/input/linux-event-codes.h> #include <dt-bindings/pwm/pwm.h> -#include <dt-bindings/pinctrl/rockchip.h> #include "rk3399.dtsi" +#include "rk3399-opp.dtsi"
/ { model = "Firefly-RK3399 Board"; compatible = "firefly,firefly-rk3399", "rockchip,rk3399";
chosen {
stdout-path = "serial2:1500000n8";
@@ -63,6 +64,48 @@ #clock-cells = <0>; };
- dc_12v: dc-12v {
regulator-name = "dc_12v";
regulator-boot-on;
- gpio-keys {
compatible = "gpio-keys";
autorepeat;
pinctrl-0 = <&pwrbtn>;
power {
debounce-interval = <100>;
gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>;
label = "GPIO Key Power";
linux,code = <KEY_POWER>;
wakeup-source;
- leds {
compatible = "gpio-leds";
pinctrl-0 = <&work_led_gpio>, <&diy_led_gpio>;
work-led {
label = "work";
default-state = "on";
diy-led {
label = "diy";
gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>;
- rt5640-sound { compatible = "simple-audio-card"; simple-audio-card,name = "rockchip,rt5640-codec";
@@ -102,15 +145,27 @@ reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; };
- /* switched by pmic_sleep */
- vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 {
regulator-boot-on;
- vcc3v3_pcie: vcc3v3-pcie-regulator { compatible = "regulator-fixed"; enable-active-high; gpio = <&gpio1 RK_PC1 GPIO_ACTIVE_HIGH>; pinctrl-names = "default";
pinctrl-0 = <&pcie_drv>;
regulator-name = "vcc3v3_pcie"; regulator-always-on; regulator-boot-on;
vin-supply = <&dc_12v>;
@@ -120,32 +175,29 @@ regulator-boot-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>;
vin-supply = <&vcc_sys>;
/* Actually 3 regulators (host0, 1, 2) controlled by the same gpio */ vcc5v0_host: vcc5v0-host-regulator { compatible = "regulator-fixed"; enable-active-high; gpio = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>; pinctrl-names = "default";
pinctrl-0 = <&host_vbus_drv>;
regulator-name = "vcc5v0_host"; regulator-always-on;pinctrl-0 = <&vcc5v0_host_en>;
};vin-supply = <&vcc_sys>;
- vcc_sys: vcc-sys { compatible = "regulator-fixed";
regulator-always-on; regulator-boot-on; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>;regulator-name = "vcc_sys";
regulator-boot-on;
vdd_log: vdd-log {
@@ -156,16 +208,7 @@ regulator-boot-on; regulator-min-microvolt = <430000>; regulator-max-microvolt = <1400000>;
- vccadc_ref: vccadc-ref {
regulator-name = "vcc1v8_sys";
regulator-boot-on;
}; };vin-supply = <&vcc_sys>;
@@ -201,15 +244,22 @@ assigned-clocks = <&cru SCLK_RMII_SRC>; assigned-clock-parents = <&clkin_gmac>; clock_in_out = "input";
- phy-supply = <&vcc_lan>; phy-mode = "rgmii"; pinctrl-names = "default"; pinctrl-0 = <&rgmii_pins>; snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; snps,reset-active-low; snps,reset-delays-us = <0 10000 50000>;
- tx_delay = <0x33>;
- rx_delay = <0x45>;
- status = "okay";
+&hdmi {
- ddc-i2c-bus = <&i2c3>;
- pinctrl-0 = <&hdmi_cec>; status = "okay"; };
@@ -231,16 +281,16 @@ rockchip,system-power-controller; wakeup-source;
vcc1-supply = <&vcc_sys>;
vcc2-supply = <&vcc_sys>;
vcc3-supply = <&vcc_sys>;
vcc4-supply = <&vcc_sys>;
vcc6-supply = <&vcc_sys>;
vcc8-supply = <&vcc3v3_sys>;vcc7-supply = <&vcc_sys>;
vcc9-supply = <&vcc_sys>;
vcc10-supply = <&vcc_sys>;
vcc12-supply = <&vcc3v3_sys>; vddio-supply = <&vcc1v8_pmu>;vcc11-supply = <&vcc_sys>;
@@ -301,12 +351,12 @@ }; };
vcc2v8_dvp: LDO_REG2 {
regulator-name = "vcc2v8_dvp"; regulator-always-on; regulator-boot-on;
regulator-min-microvolt = <2800000>;
regulator-max-microvolt = <2800000>; regulator-state-mem { regulator-off-in-suspend; };
@@ -324,8 +374,8 @@ }; };
vcc_sd: LDO_REG4 {
regulator-name = "vcc_sdio"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <1800000>;
@@ -382,7 +432,7 @@ }; };
vcc3v3_s3: vcc_lan: SWITCH_REG1 { regulator-name = "vcc3v3_s3"; regulator-always-on; regulator-boot-on;
@@ -412,7 +462,7 @@ regulator-ramp-delay = <1000>; regulator-always-on; regulator-boot-on;
@@ -429,7 +479,7 @@ regulator-ramp-delay = <1000>; regulator-always-on; regulator-boot-on;
@@ -476,19 +526,16 @@ &i2s0 { rockchip,playback-channels = <8>; rockchip,capture-channels = <8>;
#sound-dai-cells = <0>; status = "okay"; };
&i2s1 { rockchip,playback-channels = <2>; rockchip,capture-channels = <2>;
&i2s2 {
@@ -497,7 +544,7 @@
bt656-supply = <&vcc1v8_dvp>; audio-supply = <&vcca1v8_codec>;
- sdmmc-supply = <&vcc_sd>;
- sdmmc-supply = <&vcc_sdio>; gpio1830-supply = <&vcc_3v0>; };
@@ -509,7 +556,7 @@ ep-gpios = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>; num-lanes = <4>; pinctrl-names = "default";
- pinctrl-0 = <&pcie_clkreqn>;
- pinctrl-0 = <&pcie_clkreqn_cpm>; status = "okay"; };
@@ -532,7 +579,7 @@ };
pcie {
pcie_drv: pcie-drv {
};pcie_pwr_en: pcie-pwr-en { rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>;
@@ -570,10 +617,26 @@ };
usb2 {
host_vbus_drv: host-vbus-drv {
vcc5v0_host_en: vcc5v0-host-en { rockchip,pins = <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>;
wifi {
wifi_host_wake_l: wifi-host-wake-l {
rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>;
leds {
rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>;
&pwm0 {
@@ -585,24 +648,70 @@ };
&saradc {
- vref-supply = <&vccadc_ref>;
- vref-supply = <&vcca1v8_s3>; status = "okay"; };
+&sdio0 {
- /* WiFi & BT combo module Ampak AP6356S */
- bus-width = <4>;
- cap-sdio-irq;
- cap-sd-highspeed;
- keep-power-in-suspend;
- mmc-pwrseq = <&sdio_pwrseq>;
- non-removable;
- pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>;
- sd-uhs-sdr104;
- /* Power supply */
- vqmmc-supply = &vcc1v8_s3; /* IO line */
- vmmc-supply = &vcc_sdio; /* card's power */
- status = "okay";
- brcmf: wifi@1 {
reg = <1>;
compatible = "brcm,bcm4329-fmac";
interrupts = <RK_PA3 GPIO_ACTIVE_HIGH>;
interrupt-names = "host-wake";
brcm,drive-strength = <5>;
pinctrl-0 = <&wifi_host_wake_l>;
&sdmmc { bus-width = <4>;
cap-mmc-highspeed;
cap-sd-highspeed;
disable-wp;
pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>; status = "okay"; };
&sdhci { bus-width = <8>;
- keep-power-in-suspend; mmc-hs400-1_8v; mmc-hs400-enhanced-strobe; non-removable; status = "okay"; };
+&tcphy0 {
- status = "okay";
+&tcphy1 {
- status = "okay";
- &tsadc { /* tshut mode 0:CRU 1:GPIO */ rockchip,hw-tshut-mode = <1>;
@@ -662,3 +771,37 @@ &usb_host1_ohci { status = "okay"; };
+&usbdrd3_0 {
- status = "okay";
+&usbdrd_dwc3_0 {
- status = "okay";
- dr_mode = "otg";
+&usbdrd3_1 {
- status = "okay";
+&usbdrd_dwc3_1 {
- status = "okay";
- dr_mode = "host";
+&vopb {
- status = "okay";
+&vopb_mmu {
- status = "okay";
+&vopl {
- status = "okay";
+&vopl_mmu {
- status = "okay";
+}; diff --git a/arch/arm/dts/rk3399-gru-bob.dts b/arch/arm/dts/rk3399-gru-bob.dts index 1ee0dc0d9f..e6c1c94c8d 100644 --- a/arch/arm/dts/rk3399-gru-bob.dts +++ b/arch/arm/dts/rk3399-gru-bob.dts @@ -18,11 +18,11 @@ "google,bob", "google,gru", "rockchip,rk3399";
compatible = "boe,nv101wxmn51", "simple-panel";
backlight = <&backlight>; power-supply = <&pp3300_disp>;compatible = "boe,nv101wxmn51";
ports {
port { panel_in_edp: endpoint { remote-endpoint = <&edp_out_panel>; };
@@ -68,12 +68,22 @@
&spi0 { status = "okay";
cr50@0 {
compatible = "google,cr50";
reg = <0>;
interrupts = <5 IRQ_TYPE_EDGE_RISING>;
pinctrl-0 = <&h1_int_od_l>;
spi-max-frequency = <800000>;
&pinctrl { tpm { h1_int_od_l: h1-int-od-l {
rockchip,pins = <0 5 RK_FUNC_GPIO &pcfg_pull_up>;
}; }; };rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>;
diff --git a/arch/arm/dts/rk3399-gru-chromebook.dtsi b/arch/arm/dts/rk3399-gru-chromebook.dtsi index c6495adcca..1384dabbdf 100644 --- a/arch/arm/dts/rk3399-gru-chromebook.dtsi +++ b/arch/arm/dts/rk3399-gru-chromebook.dtsi @@ -194,20 +194,25 @@
brightness-levels = <0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
17 18 19 20 21 22 23 24 25 26 27 28 29 30
31 32 33 34 35 36 37 38 39 40 41 42 43 44
45 46 47 48 49 50 51 52 53 54 55 56 57 58
59 60 61 62 63 64 65 66 67 68 69 70 71 72
73 74 75 76 77 78 79 80 81 82 83 84 85 86
87 88 89 90 91 92 93 94 95 96 97 98 99 100>;
enable-gpios = <&gpio1 17 GPIO_ACTIVE_HIGH>; power-supply = <&pp3300_disp>; pinctrl-names = "default"; pinctrl-0 = <&bl_en>; pwm-delay-us = <10000>; };default-brightness-level = <51>;
gpio_keys: gpio-keys {
pinctrl-0 = <&bt_host_wake_l>;
wake_on_bt: wake-on-bt {
label = "Wake-on-Bluetooth";
gpios = <&gpio0 3 GPIO_ACTIVE_LOW>;
linux,code = <KEY_WAKEUP>;
wakeup-source;
&ppvar_bigcpu {
@@ -232,7 +237,6 @@ &edp { status = "okay";
- rockchip,panel = <&edp_panel>; ports { edp_out: port@1 { reg = <1>;
@@ -287,11 +291,9 @@ ap_i2c_tp: &i2c5 { #pwm-cells = <1>; };
- usbc_extcon1: extcon@1 {
- usbc_extcon1: extcon1 { compatible = "google,extcon-usbc-cros-ec"; google,usb-port-id = <1>;
}; };#extcon-cells = <0>;
@@ -361,27 +363,27 @@ ap_i2c_tp: &i2c5 { &pinctrl { discrete-regulators { pp1500_en: pp1500-en {
rockchip,pins = <RK_GPIO0 10 RK_FUNC_GPIO
pp1800_audio_en: pp1800-audio-en {
rockchip,pins = <RK_GPIO0 2 RK_FUNC_GPIO
rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_down>;
pp3000_en: pp3000-en {
rockchip,pins = <RK_GPIO0 12 RK_FUNC_GPIO
rockchip,pins = <0 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>;
pp3300_disp_en: pp3300-disp-en {
rockchip,pins = <RK_GPIO4 27 RK_FUNC_GPIO
rockchip,pins = <4 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>;
wlan_module_pd_l: wlan-module-pd-l {
rockchip,pins = <RK_GPIO0 4 RK_FUNC_GPIO
}; };rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_down>;
@@ -389,10 +391,10 @@ ap_i2c_tp: &i2c5 {
&wifi { wifi_perst_l: wifi-perst-l {
rockchip,pins = <2 27 RK_FUNC_GPIO &pcfg_pull_none>;
wlan_host_wake_l: wlan-host-wake-l {
rockchip,pins = <0 8 RK_FUNC_GPIO &pcfg_pull_none>;
}; };rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>;
diff --git a/arch/arm/dts/rk3399-gru-kevin.dts b/arch/arm/dts/rk3399-gru-kevin.dts index 2cc7c47d6a..2bbef9fcbe 100644 --- a/arch/arm/dts/rk3399-gru-kevin.dts +++ b/arch/arm/dts/rk3399-gru-kevin.dts @@ -39,11 +39,25 @@ };
compatible = "sharp,lq123p1jx31", "simple-panel";
backlight = <&backlight>; power-supply = <&pp3300_disp>;compatible = "sharp,lq123p1jx31";
ports {
panel-timing {
clock-frequency = <266666667>;
hactive = <2400>;
hfront-porch = <48>;
hback-porch = <84>;
hsync-len = <32>;
hsync-active = <0>;
vactive = <1600>;
vfront-porch = <3>;
vback-porch = <120>;
vsync-len = <10>;
vsync-active = <0>;
@@ -118,13 +132,17 @@ map0 { trip = <&ppvar_bigcpu_alert>; cooling-device =
<&cpu_l0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>;
<&cpu_l3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; contribution = <4096>; }; map1 { trip = <&ppvar_bigcpu_alert>; cooling-device =
};<&cpu_b1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; contribution = <1024>; };
@@ -286,24 +304,24 @@ ap_i2c_dig: &i2c2 { digitizer { /* Has external pullup */ cpu1_dig_irq_l: cpu1-dig-irq-l {
rockchip,pins = <2 4 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <2 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>;
/* Has external pullup */ cpu1_dig_pdct_l: cpu1-dig-pdct-l {
rockchip,pins = <2 5 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <2 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>;
discrete-regulators { cpu3_pen_pwr_en: cpu3-pen-pwr-en {
rockchip,pins = <4 30 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>;
pen { cpu1_pen_eject: cpu1-pen-eject {
rockchip,pins = <0 13 RK_FUNC_GPIO &pcfg_pull_up>;
}; }; };rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_up>;
diff --git a/arch/arm/dts/rk3399-gru.dtsi b/arch/arm/dts/rk3399-gru.dtsi index 0e2e047180..34f03cf92d 100644 --- a/arch/arm/dts/rk3399-gru.dtsi +++ b/arch/arm/dts/rk3399-gru.dtsi @@ -11,13 +11,7 @@
/ { chosen {
stdout-path = "serial2:115200n8";
u-boot,spl-boot-order = &spi_flash;
config {
u-boot,spl-payload-offset = <0x40000>;
@@ -268,17 +262,11 @@ pp5000_usb_a_vbus: pp5000 { };
- gpio_keys: gpio-keys {
wakeup-source;
ap_rtc_clk: ap-rtc-clk {
compatible = "fixed-clock";
clock-frequency = <32768>;
clock-output-names = "xin32k";
#clock-cells = <0>;
max98357a: max98357a {
@@ -354,6 +342,7 @@ cpu-supply = <&ppvar_bigcpu>; };
- &cru { assigned-clocks = <&cru PLL_GPLL>, <&cru PLL_CPLL>,
@@ -549,8 +538,7 @@ ap_i2c_audio: &i2c8 { pinctrl-names = "default", "sleep"; pinctrl-1 = <&spi1_sleep>;
- spi_flash: spiflash@0 {
- spiflash@0 { compatible = "jedec,spi-nor"; reg = <0>;
@@ -565,16 +553,12 @@ ap_i2c_audio: &i2c8 {
&spi5 { status = "okay";
spi-activate-delay = <100>;
spi-max-frequency = <3000000>;
spi-deactivate-delay = <200>;
cros_ec: ec@0 { compatible = "google,cros-ec-spi"; reg = <0>; interrupt-parent = <&gpio0>; interrupts = <1 IRQ_TYPE_LEVEL_LOW>;
ec-interrupt = <&gpio0 1 GPIO_ACTIVE_LOW>;
pinctrl-names = "default"; pinctrl-0 = <&ec_ap_int_l>; spi-max-frequency = <3000000>;
@@ -586,11 +570,9 @@ ap_i2c_audio: &i2c8 { #size-cells = <0>; };
usbc_extcon0: extcon@0 {
usbc_extcon0: extcon0 { compatible = "google,extcon-usbc-cros-ec"; google,usb-port-id = <0>;
}; }; };#extcon-cells = <0>;
@@ -692,29 +674,29 @@ ap_i2c_audio: &i2c8 {
backlight-enable { bl_en: bl-en {
rockchip,pins = <1 17 RK_FUNC_GPIO &pcfg_pull_none>;
cros-ec { ec_ap_int_l: ec-ap-int-l {
rockchip,pins = <RK_GPIO0 1 RK_FUNC_GPIO &pcfg_pull_up>;
rockchip,pins = <0 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up>;
discrete-regulators { sd_io_pwr_en: sd-io-pwr-en {
rockchip,pins = <RK_GPIO2 2 RK_FUNC_GPIO
rockchip,pins = <2 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>;
sd_pwr_1800_sel: sd-pwr-1800-sel {
rockchip,pins = <RK_GPIO2 28 RK_FUNC_GPIO
rockchip,pins = <2 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>;
sd_slot_pwr_en: sd-slot-pwr-en {
rockchip,pins = <RK_GPIO4 29 RK_FUNC_GPIO
}; };rockchip,pins = <4 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>;
@@ -722,17 +704,17 @@ ap_i2c_audio: &i2c8 { codec { /* Has external pullup */ headset_int_l: headset-int-l {
rockchip,pins = <1 23 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <1 RK_PC7 RK_FUNC_GPIO &pcfg_pull_none>;
mic_int: mic-int {
rockchip,pins = <1 13 RK_FUNC_GPIO &pcfg_pull_down>;
rockchip,pins = <1 RK_PB5 RK_FUNC_GPIO &pcfg_pull_down>;
max98357a { sdmode_en: sdmode-en {
rockchip,pins = <1 2 RK_FUNC_GPIO &pcfg_pull_down>;
}; };rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_down>;
@@ -743,7 +725,7 @@ ap_i2c_audio: &i2c8 { * to hack this as gpio, so the EP could be able to * de-assert it along and make ClockPM(CPM) work. */
rockchip,pins = <2 26 RK_FUNC_GPIO &pcfg_pull_none>;
}; };rockchip,pins = <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>;
@@ -754,20 +736,20 @@ ap_i2c_audio: &i2c8 { */ sdmmc_bus4: sdmmc-bus4 { rockchip,pins =
<4 8 RK_FUNC_1 &pcfg_pull_none_8ma>,
<4 9 RK_FUNC_1 &pcfg_pull_none_8ma>,
<4 10 RK_FUNC_1 &pcfg_pull_none_8ma>,
<4 11 RK_FUNC_1 &pcfg_pull_none_8ma>;
<4 RK_PB0 1 &pcfg_pull_none_8ma>,
<4 RK_PB1 1 &pcfg_pull_none_8ma>,
<4 RK_PB2 1 &pcfg_pull_none_8ma>,
<4 RK_PB3 1 &pcfg_pull_none_8ma>;
<4 12 RK_FUNC_1 &pcfg_pull_none_8ma>;
<4 RK_PB4 1 &pcfg_pull_none_8ma>;
<4 13 RK_FUNC_1 &pcfg_pull_none_8ma>;
<4 RK_PB5 1 &pcfg_pull_none_8ma>;
@@ -781,12 +763,12 @@ ap_i2c_audio: &i2c8 { */ sdmmc_cd: sdmmc-cd { rockchip,pins =
<0 7 RK_FUNC_1 &pcfg_pull_none>;
<0 RK_PA7 1 &pcfg_pull_none>;
/* This is where we actually hook up CD; has external pull */ sdmmc_cd_gpio: sdmmc-cd-gpio {
rockchip,pins = <4 24 RK_FUNC_GPIO &pcfg_pull_none>;
}; };rockchip,pins = <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>;
@@ -796,47 +778,47 @@ ap_i2c_audio: &i2c8 { * Pull down SPI1 CLK/CS/RX/TX during suspend, to * prevent leakage. */
rockchip,pins = <1 9 RK_FUNC_GPIO &pcfg_pull_down>,
<1 10 RK_FUNC_GPIO &pcfg_pull_down>,
<1 7 RK_FUNC_GPIO &pcfg_pull_down>,
<1 8 RK_FUNC_GPIO &pcfg_pull_down>;
rockchip,pins = <1 RK_PB1 RK_FUNC_GPIO &pcfg_pull_down>,
<1 RK_PB2 RK_FUNC_GPIO &pcfg_pull_down>,
<1 RK_PA7 RK_FUNC_GPIO &pcfg_pull_down>,
<1 RK_PB0 RK_FUNC_GPIO &pcfg_pull_down>;
touchscreen { touch_int_l: touch-int-l {
rockchip,pins = <3 13 RK_FUNC_GPIO &pcfg_pull_up>;
rockchip,pins = <3 RK_PB5 RK_FUNC_GPIO &pcfg_pull_up>;
touch_reset_l: touch-reset-l {
rockchip,pins = <4 26 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>;
trackpad { ap_i2c_tp_pu_en: ap-i2c-tp-pu-en {
rockchip,pins = <3 12 RK_FUNC_GPIO &pcfg_output_high>;
rockchip,pins = <3 RK_PB4 RK_FUNC_GPIO &pcfg_output_high>;
trackpad_int_l: trackpad-int-l {
rockchip,pins = <1 4 RK_FUNC_GPIO &pcfg_pull_up>;
rockchip,pins = <1 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>;
wifi: wifi { wlan_module_reset_l: wlan-module-reset-l {
rockchip,pins = <1 11 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <1 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>;
bt_host_wake_l: bt-host-wake-l { /* Kevin has an external pull up, but Gru does not */
rockchip,pins = <0 3 RK_FUNC_GPIO &pcfg_pull_up>;
rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>;
write-protect { ap_fw_wp: ap-fw-wp {
rockchip,pins = <1 18 RK_FUNC_GPIO &pcfg_pull_up>;
}; }; };rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_up>;
diff --git a/arch/arm/dts/rk3399-khadas-edge.dtsi b/arch/arm/dts/rk3399-khadas-edge.dtsi index 4944d78a0a..e87a044774 100644 --- a/arch/arm/dts/rk3399-khadas-edge.dtsi +++ b/arch/arm/dts/rk3399-khadas-edge.dtsi @@ -654,9 +654,12 @@ sd-uhs-sdr104; vqmmc-supply = <&vcc1v8_s3>; vmmc-supply = <&vccio_sd>;
#size-cells = <0>; status = "okay";
brcmf: wifi@1 {
reg = <1>;
compatible = "brcm,bcm4329-fmac"; interrupt-parent = <&gpio0>; interrupts = <RK_PA3 GPIO_ACTIVE_HIGH>;
diff --git a/arch/arm/dts/rk3399-leez-p710.dts b/arch/arm/dts/rk3399-leez-p710.dts index 32baa57b94..73be38a537 100644 --- a/arch/arm/dts/rk3399-leez-p710.dts +++ b/arch/arm/dts/rk3399-leez-p710.dts @@ -42,14 +42,14 @@ regulator-max-microvolt = <5000000>; };
- vcc3v3_lan: vcc3v3-lan { compatible = "regulator-fixed";
regulator-name = "vcc5v0_sys";
regulator-always-on; regulator-boot-on;regulator-name = "vcc3v3_lan";
vin-supply = <&dc5v_adp>;
vim-supply = <&vcc3v3_sys>;
@@ -83,14 +83,14 @@ vin-supply = <&vcc5v0_sys>; };
- vcc5v0_sys: vcc5v0-sys { compatible = "regulator-fixed";
regulator-always-on; regulator-boot-on;regulator-name = "vcc5v0_sys";
vdd_log: vdd-log {
@@ -510,6 +510,14 @@ }; };
+&sdhci {
- bus-width = <8>;
- mmc-hs400-1_8v;
- mmc-hs400-enhanced-strobe;
- non-removable;
- status = "okay";
- &sdmmc { bus-width = <4>; cap-mmc-highspeed;
@@ -522,14 +530,6 @@ status = "okay"; };
-&sdhci {
- bus-width = <8>;
- mmc-hs400-1_8v;
- non-removable;
- status = "okay";
- &tcphy0 { status = "okay"; };
diff --git a/arch/arm/dts/rk3399-nanopc-t4.dts b/arch/arm/dts/rk3399-nanopc-t4.dts index 84433cf02b..e0d75617bb 100644 --- a/arch/arm/dts/rk3399-nanopc-t4.dts +++ b/arch/arm/dts/rk3399-nanopc-t4.dts @@ -52,13 +52,58 @@ pinctrl-names = "default"; pinctrl-0 = <&ir_rx>; };
- fan: pwm-fan {
compatible = "pwm-fan";
* With 20KHz PWM and an EVERCOOL EC4007H12SA fan, these levels
* work out to 0, ~1200, ~3000, and 5000RPM respectively.
cooling-levels = <0 12 18 255>;
fan-supply = <&vcc12v0_sys>;
pwms = <&pwm1 0 50000 0>;
+&cpu_thermal {
- trips {
cpu_warm: cpu_warm {
temperature = <55000>;
hysteresis = <2000>;
type = "active";
cpu_hot: cpu_hot {
temperature = <65000>;
type = "active";
- cooling-maps {
map2 {
trip = <&cpu_warm>;
cooling-device = <&fan THERMAL_NO_LIMIT 1>;
map3 {
trip = <&cpu_hot>;
cooling-device = <&fan 2 THERMAL_NO_LIMIT>;
+&pcie0 {
num-lanes = <4>;
vpcie3v3-supply = <&vcc3v3_sys>; };
&pinctrl { ir { ir_rx: ir-rx { /* external pullup to VCC3V3_SYS, despite being 1.8V :/ */
rockchip,pins = <0 RK_PA6 RK_FUNC_1 &pcfg_pull_none>;
}; }; };rockchip,pins = <0 RK_PA6 1 &pcfg_pull_none>;
diff --git a/arch/arm/dts/rk3399-nanopi4.dtsi b/arch/arm/dts/rk3399-nanopi4.dtsi index d325e11728..c88018a0ef 100644 --- a/arch/arm/dts/rk3399-nanopi4.dtsi +++ b/arch/arm/dts/rk3399-nanopi4.dtsi @@ -48,7 +48,7 @@ };
- vcc1v8_s3: vcc1v8-s3 { compatible = "regulator-fixed"; regulator-always-on; regulator-boot-on;
@@ -71,6 +71,27 @@ vin-supply = <&vcc3v3_sys>; };
* Really, this is supplied by vcc_1v8, and vcc1v8_s3 only
* drives the enable pin, but we can't quite model that.
- vcca0v9_s3: vcca0v9-s3 {
regulator-min-microvolt = <900000>;
regulator-max-microvolt = <900000>;
regulator-name = "vcca0v9_s3";
vin-supply = <&vcc1v8_s3>;
- /* As above, actually supplied by vcc3v3_sys */
- vcca1v8_s3: vcca1v8-s3 {
regulator-max-microvolt = <1800000>;
regulator-name = "vcca1v8_s3";
- vbus_typec: vbus-typec { compatible = "regulator-fixed"; regulator-min-microvolt = <5000000>;
@@ -148,15 +169,28 @@ assigned-clocks = <&cru SCLK_RMII_SRC>; clock_in_out = "input"; pinctrl-names = "default";
- pinctrl-0 = <&rgmii_pins>, <&phy_intb>, <&phy_rstb>;
- phy-handle = <&rtl8211e>; phy-mode = "rgmii"; phy-supply = <&vcc3v3_s3>;
- snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; tx_delay = <0x28>; rx_delay = <0x11>; status = "okay";
mdio {
compatible = "snps,dwmac-mdio";
#size-cells = <0>;
rtl8211e: phy@1 {
reg = <1>;
interrupt-parent = <&gpio3>;
interrupts = <RK_PB2 IRQ_TYPE_LEVEL_LOW>;
reset-assert-us = <10000>;
reset-deassert-us = <30000>;
reset-gpios = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>;
&gpu {
@@ -171,6 +205,10 @@ status = "okay"; };
+&hdmi_sound {
- status = "okay";
- &i2c0 { clock-frequency = <400000>; i2c-scl-rising-time-ns = <160>;
@@ -446,6 +484,10 @@ status = "okay"; };
+&i2s2 {
- status = "okay";
- &io_domains { bt656-supply = <&vcc_1v8>; audio-supply = <&vcca1v8_codec>;
@@ -464,7 +506,9 @@ &pcie0 { ep-gpios = <&gpio2 RK_PA4 GPIO_ACTIVE_HIGH>; max-link-speed = <2>;
- num-lanes = <4>;
- num-lanes = <2>;
- vpcie0v9-supply = <&vcca0v9_s3>;
- vpcie1v8-supply = <&vcca1v8_s3>; status = "okay"; };
@@ -481,6 +525,16 @@ }; };
- phy {
phy_intb: phy-intb {
rockchip,pins = <3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>;
phy_rstb: phy-rstb {
rockchip,pins = <3 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>;
- pmic { cpu_b_sleep: cpu-b-sleep { rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>;
diff --git a/arch/arm/dts/rk3399-orangepi.dts b/arch/arm/dts/rk3399-orangepi.dts index cf37b96a6b..f9f7246d4d 100644 --- a/arch/arm/dts/rk3399-orangepi.dts +++ b/arch/arm/dts/rk3399-orangepi.dts @@ -136,13 +136,13 @@ vin-supply = <&vcc_sys>; };
- vcc5v0_typec0: vcc5v0-typec0-regulator {
- vbus_typec: vbus-typec-regulator { compatible = "regulator-fixed"; enable-active-high; gpio = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>; pinctrl-names = "default";
pinctrl-0 = <&vcc5v0_typec0_en>;
pinctrl-0 = <&vcc5v0_typec_en>;
vin-supply = <&vcc_sys>; };regulator-name = "vbus_typec";
@@ -202,14 +202,27 @@ clock_in_out = "input"; phy-supply = <&vcc3v3_s3>; phy-mode = "rgmii";
- phy-handle = <&rtl8211e>; pinctrl-names = "default";
pinctrl-0 = <&rgmii_pins>, <&phy_intb>, <&phy_rstb>; tx_delay = <0x28>; rx_delay = <0x11>; status = "okay";
mdio {
#size-cells = <0>;
rtl8211e: phy@1 {
reg = <1>;
&gpu {
@@ -419,6 +432,8 @@ compatible = "silergy,syr827"; reg = <0x40>; fcs,suspend-voltage-selector = <1>;
regulator-name = "vdd_cpu_b"; regulator-min-microvolt = <712500>; regulator-max-microvolt = <1500000>;pinctrl-0 = <&cpu_b_sleep>;
@@ -436,6 +451,8 @@ compatible = "silergy,syr828"; reg = <0x41>; fcs,suspend-voltage-selector = <1>;
regulator-name = "vdd_gpu"; regulator-min-microvolt = <712500>; regulator-max-microvolt = <1500000>;pinctrl-0 = <&gpu_sleep>;
@@ -472,6 +489,7 @@ compatible = "asahi-kasei,ak09911"; reg = <0x0c>; vdd-supply = <&vcc3v3_s3>;
vid-supply = <&vcc3v3_s3>;
mpu6500@68 {
@@ -504,6 +522,16 @@ pinctrl-0 = <&light_int_l>; vdd-supply = <&vcc3v3_s3>; };
fusb302@22 {
compatible = "fcs,fusb302";
reg = <0x22>;
interrupt-parent = <&gpio1>;
interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>;
pinctrl-0 = <&chg_cc_int_l>;
vbus-supply = <&vbus_typec>;
&io_domains {
@@ -526,7 +554,25 @@ }; };
- phy {
- pmic {
gpu_sleep: gpu-sleep {
rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>;
- pmic_int_l: pmic-int-l { rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>;
@@ -536,7 +582,7 @@ sd { sdmmc0_pwr_h: sdmmc0-pwr-h { rockchip,pins =
<RK_GPIO0 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>;
}; };<0 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>;
@@ -546,7 +592,7 @@ <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; };
vcc5v0_typec0_en: vcc5v0-typec0-en {
};vcc5v0_typec_en: vcc5v0-typec-en { rockchip,pins = <1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>;
@@ -595,6 +641,12 @@ rockchip,pins = <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; }; };
fusb302 {
chg_cc_int_l: chg-cc-int-l {
rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>;
&pwm0 {
@@ -631,9 +683,12 @@ pinctrl-names = "default"; pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; sd-uhs-sdr104;
brcmf: wifi@1 {
reg = <1>;
@@ -676,7 +731,7 @@ status = "okay";
u2phy0_otg: otg-port {
phy-supply = <&vcc5v0_typec0>;
status = "okay"; };phy-supply = <&vbus_typec>;
@@ -707,12 +762,14 @@ bluetooth { compatible = "brcm,bcm43438-bt"; clocks = <&rk808 1>;
clock-names = "ext_clock";
device-wakeup-gpios = <&gpio2 RK_PD2 GPIO_ACTIVE_HIGH>; host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>; shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_reg_on_h>;clock-names = "lpo";
vbat-supply = <&vcc3v3_sys>;
}; };vddio-supply = <&vcc_1v8>;
diff --git a/arch/arm/dts/rk3399-puma-u-boot.dtsi b/arch/arm/dts/rk3399-puma-u-boot.dtsi index e664779227..0253c6525f 100644 --- a/arch/arm/dts/rk3399-puma-u-boot.dtsi +++ b/arch/arm/dts/rk3399-puma-u-boot.dtsi @@ -13,7 +13,7 @@ chosen { stdout-path = "serial0:115200n8"; u-boot,spl-boot-order = \
"same-as-spl", &spiflash, &sdhci, &sdmmc;
"same-as-spl", &norflash, &sdhci, &sdmmc; }; aliases {
@@ -21,10 +21,23 @@ spi1 = &spi5; };
-&bios_enable {
- u-boot,dm-pre-reloc;
* The Qseven BIOS_DISABLE signal on the RK3399-Q7 keeps the on-module
* eMMC and SPI flash powered-down initially (in fact it keeps the
* reset signal asserted). Even though it is an enable signal, we
* model this as a regulator.
bios_enable: bios_enable {
regulator-name = "bios_enable";
enable-active-high;
gpio = <&gpio3 RK_PD5 GPIO_ACTIVE_LOW>;
regulator-boot-on;
&gpio1 {
@@ -35,6 +48,6 @@ u-boot,dm-pre-reloc; };
-&spiflash { +&norflash { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/rk3399-puma.dtsi b/arch/arm/dts/rk3399-puma.dtsi index 246a892cb7..07694b196f 100644 --- a/arch/arm/dts/rk3399-puma.dtsi +++ b/arch/arm/dts/rk3399-puma.dtsi @@ -1,30 +1,74 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /*
- (C) Copyright 2017 Theobroma Systems Design und Consulting GmbH
- Copyright (c) 2017 Theobroma Systems Design und Consulting GmbH
#include <dt-bindings/pwm/pwm.h> #include "rk3399.dtsi"
- model = "Theobroma Systems RK3399-Q7 SoM";
- compatible = "tsd,rk3399-q7", "tsd,puma", "rockchip,rk3399";
- leds { compatible = "gpio-leds"; pinctrl-names = "default";
pinctrl-0 = <&leds_pins_puma>;
pinctrl-0 = <&led_pin_module>;
module_led {
module-led { label = "module_led"; gpios = <&gpio2 RK_PD1 GPIO_ACTIVE_HIGH>; linux,default-trigger = "heartbeat";
};panic-indicator;
sd_card_led {
label = "sd_card_led";
gpios = <&gpio1 RK_PA2 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "mmc0";
* Overwrite the opp-table for CPUB as this board uses a different
* regulator (FAN53555) that only allows 10mV steps and therefore
* can't reach the operation point target voltages from rk3399-opp.dtsi
- /delete-node/ opp-table1;
- cluster1_opp: opp-table1 {
compatible = "operating-points-v2";
opp-shared;
opp00 {
opp-hz = /bits/ 64 <408000000>;
opp-microvolt = <800000>;
clock-latency-ns = <40000>;
opp01 {
opp-hz = /bits/ 64 <600000000>;
opp02 {
opp-hz = /bits/ 64 <816000000>;
opp-microvolt = <830000>;
opp-suspend;
opp03 {
opp-hz = /bits/ 64 <1008000000>;
opp-microvolt = <880000>;
opp04 {
opp-hz = /bits/ 64 <1200000000>;
opp-microvolt = <950000>;
opp05 {
opp-hz = /bits/ 64 <1416000000>;
opp-microvolt = <1030000>;
opp06 {
opp-hz = /bits/ 64 <1608000000>;
opp-microvolt = <1100000>;
opp07 {
opp-hz = /bits/ 64 <1800000000>;
opp-microvolt = <1200000>;
opp08 {
opp-hz = /bits/ 64 <1992000000>;
opp-microvolt = <1230000>;
}; };turbo-mode;
@@ -35,78 +79,14 @@ #clock-cells = <0>; };
- dw_hdmi_audio: dw-hdmi-audio {
status = "enabled";
compatible = "rockchip,dw-hdmi-audio";
- hdmi_codec: hdmi-codec {
simple-audio-card,format = "i2s";
simple-audio-card,mclk-fs = <256>;
simple-audio-card,name = "HDMI-CODEC";
simple-audio-card,cpu {
sound-dai = <&i2s2>;
simple-audio-card,codec {
sound-dai = <&hdmi>;
- hdmi_sound: hdmi-sound {
simple-audio-card,name = "rockchip,hdmi";
- usbhub_enable: usbhub_enable {
- vcc1v2_phy: vcc1v2-phy { compatible = "regulator-fixed";
regulator-name = "usbhub_enable";
enable-active-low;
gpio = <&gpio4 RK_PA3 GPIO_ACTIVE_LOW>;
regulator-boot-on;
- bios_enable: bios_enable {
enable-active-high;
regulator-always-on; regulator-boot-on;regulator-name = "vcc1v2_phy";
regulator-boot-on;
regulator-min-microvolt = <1200000>;
regulator-max-microvolt = <1200000>;
@@ -116,16 +96,18 @@ regulator-boot-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>;
};vin-supply = <&vcc5v0_sys>;
- vcc5v0_otg: vcc5v0-otg-regulator {
- vcc5v0_host: vcc5v0-host-regulator { compatible = "regulator-fixed";
enable-active-high;
gpio = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>;
gpio = <&gpio4 RK_PA3 GPIO_ACTIVE_HIGH>;
pinctrl-names = "default";enable-active-low;
pinctrl-0 = <&otg_vbus_drv>;
regulator-name = "vcc5v0_otg";
@@ -136,48 +118,55 @@ regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; }; +};
regulator-boot-on;
+&cpu_b0 {
- cpu-supply = <&vdd_cpu_b>;
- vdd_log: vdd-log {
compatible = "pwm-regulator";
pwms = <&pwm2 0 25000 1>;
regulator-name = "vdd_log";
regulator-min-microvolt = <800000>;
regulator-boot-on;
+&cpu_b1 {
+&cpu_l0 {
- cpu-supply = <&vdd_cpu_l>;
+&cpu_l1 {
+&cpu_l2 {
+&cpu_l3 {
cpu-supply = <&vdd_cpu_l>; };
&emmc_phy { status = "okay";
drive-impedance-ohm = <33>; };
&gmac {
- snps,reset-gpio = <&gpio3 RK_PC0 GPIO_ACTIVE_LOW>;
- snps,reset-delays-us = <2 10000 50000>; assigned-clocks = <&cru SCLK_RMII_SRC>; assigned-clock-parents = <&clkin_gmac>;
- phy-supply = <&vcc1v2_phy>;
- phy-mode = "rgmii"; pinctrl-names = "default"; pinctrl-0 = <&rgmii_pins>;
- snps,reset-gpio = <&gpio3 RK_PC0 GPIO_ACTIVE_HIGH>;
- snps,reset-delays-us = <0 10000 50000>; tx_delay = <0x10>; rx_delay = <0x10>; status = "okay"; };
-&hdmi {
- #sound-dai-cells = <0>;
+&gpu {
- mali-supply = <&vdd_gpu>; status = "okay"; };
@@ -187,37 +176,17 @@ i2c-scl-falling-time-ns = <4>; clock-frequency = <400000>;
- vdd_gpu: vdd_gpu {
status = "okay";
compatible = "fcs,fan53555";
reg = <0x60>;
vsel-gpios = <&gpio1 RK_PB6 GPIO_ACTIVE_HIGH>;
regulator-compatible = "fan53555-reg";
regulator-min-microvolt = <600000>;
regulator-max-microvolt = <1230000>;
regulator-boot-on;
regulator-initial-state = <3>;
- rk808: pmic@1b { compatible = "rockchip,rk808"; reg = <0x1b>; interrupt-parent = <&gpio1>;
interrupts = <22 IRQ_TYPE_LEVEL_LOW>; // TODO check interrupt?
#clock-cells = <1>;
pinctrl-names = "default"; pinctrl-0 = <&pmic_int_l>; rockchip,system-power-controller; wakeup-source;clock-output-names = "xin32k", "rk808-clkout2";
#clock-cells = <1>;
vcc1-supply = <&vcc5v0_sys>; vcc2-supply = <&vcc5v0_sys>;
@@ -234,44 +203,44 @@
regulators { vdd_center: DCDC_REG1 {
regulator-boot-on;
regulator-name = "vdd_center"; regulator-min-microvolt = <750000>; regulator-max-microvolt = <1350000>; regulator-ramp-delay = <6001>;
regulator-boot-on; regulator-state-mem { regulator-off-in-suspend; }; }; vdd_cpu_l: DCDC_REG2 {
regulator-boot-on;
regulator-name = "vdd_cpu_l"; regulator-min-microvolt = <750000>; regulator-max-microvolt = <1350000>; regulator-ramp-delay = <6001>;
regulator-boot-on; regulator-state-mem { regulator-off-in-suspend; }; }; vcc_ddr: DCDC_REG3 {
regulator-name = "vcc_ddr"; regulator-always-on; regulator-boot-on;
regulator-name = "vcc_ddr"; regulator-state-mem { regulator-on-in-suspend; }; }; vcc_1v8: DCDC_REG4 {
regulator-boot-on;
regulator-name = "vcc_1v8"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>;
regulator-boot-on; regulator-state-mem { regulator-on-in-suspend; regulator-suspend-microvolt = <1800000>;
@@ -279,32 +248,32 @@ };
vcc_ldo1: LDO_REG1 {
regulator-boot-on;
regulator-name = "vcc_ldo1"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>;
regulator-boot-on; regulator-state-mem { regulator-off-in-suspend; }; }; vcc1v8_hdmi: LDO_REG2 {
regulator-boot-on;
regulator-name = "vcc1v8_hdmi"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>;
regulator-boot-on; regulator-state-mem { regulator-off-in-suspend; }; }; vcc1v8_pmu: LDO_REG3 {
regulator-boot-on;
regulator-name = "vcc1v8_pmu"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>;
@@ -312,11 +281,11 @@ };
vcc_sd: LDO_REG4 {
regulator-boot-on;
regulator-name = "vcc_sd"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <3000000>;
regulator-boot-on; regulator-state-mem { regulator-on-in-suspend; regulator-suspend-microvolt = <3000000>;
@@ -324,79 +293,105 @@ };
vcc_ldo5: LDO_REG5 {
regulator-boot-on;
regulator-name = "vcc_ldo5"; regulator-min-microvolt = <3000000>; regulator-max-microvolt = <3000000>;
regulator-boot-on; regulator-state-mem { regulator-off-in-suspend; }; }; vcc_ldo6: LDO_REG6 {
regulator-boot-on;
regulator-name = "vcc_ldo6"; regulator-min-microvolt = <1500000>; regulator-max-microvolt = <1500000>;
regulator-boot-on; regulator-state-mem { regulator-off-in-suspend; }; }; vcc0v9_hdmi: LDO_REG7 {
regulator-boot-on;
regulator-name = "vcc0v9_hdmi"; regulator-min-microvolt = <900000>; regulator-max-microvolt = <900000>;
regulator-boot-on; regulator-state-mem { regulator-off-in-suspend; }; }; vcc_efuse: LDO_REG8 {
regulator-boot-on;
regulator-name = "vcc_efuse"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>;
regulator-boot-on; regulator-state-mem { regulator-off-in-suspend; }; }; vcc3v3_s3: SWITCH_REG1 {
regulator-name = "vcc3v3_s3"; regulator-state-mem { regulator-off-in-suspend; }; }; vcc3v3_s0: SWITCH_REG2 {
regulator-name = "vcc3v3_s0"; regulator-always-on; regulator-boot-on;
}; };regulator-name = "vcc3v3_s0"; regulator-state-mem { regulator-off-in-suspend; }; };
- vdd_gpu: regulator@60 {
reg = <0x60>;
regulator-boot-on;
+&i2c7 {
status = "okay";
fan: fan@18 {
compatible = "ti,amc6821";
reg = <0x18>;
#cooling-cells = <2>;
rtc_twi: rtc@6f {
compatible = "isil,isl1208";
reg = <0x6f>;
&i2c8 { status = "okay"; clock-frequency = <400000>;
- vdd_cpu_b: vdd_cpu_b {
status = "okay";
- vdd_cpu_b: regulator@60 { compatible = "fcs,fan53555"; reg = <0x60>;
vin-supply = <&vcc5v0_sys>;vsel-gpios = <&gpio1 RK_PA4 GPIO_ACTIVE_HIGH>;
regulator-name = "vdd_cpu_b"; regulator-min-microvolt = <600000>; regulator-max-microvolt = <1230000>;regulator-compatible = "fan53555-reg";
@@ -404,48 +399,36 @@ fcs,suspend-voltage-selector = <1>; regulator-always-on; regulator-boot-on;
&i2s0 {
- pinctrl-0 = <&i2s0_2ch_bus>;
- rockchip,playback-channels = <2>;
- rockchip,capture-channels = <2>; status = "okay";
- rockchip,i2s-broken-burst-len;
- rockchip,playback-channels = <8>;
- rockchip,capture-channels = <8>;
- #sound-dai-cells = <0>; };
-&i2s2 {
- status = "okay";
- As Q7 does not specify neither a global nor a RX clock for I2S these
- signals are not used. Furthermore I2S0_LRCK_RX is used as GPIO.
- Therefore we have to redefine the i2s0_2ch_bus definition to prevent
- conflicts.
+&i2s0_2ch_bus {
rockchip,pins =
<3 RK_PD7 1 &pcfg_pull_none>;
&io_domains { status = "okay";
- bt656-supply = <&vcc_1v8>; /* bt656_gpio2ab_ms */
- audio-supply = <&vcc_1v8>; /* audio_gpio3d4a_ms */
- sdmmc-supply = <&vcc_sd>; /* sdmmc_gpio4b_ms */
- gpio1830-supply = <&vcc_1v8>; /* gpio1833_gpio4cd_ms */
-&pcie0 {
- assigned-clocks = <&cru SCLK_PCIEPHY_REF>;
- assigned-clock-parents = <&cru SCLK_PCIEPHY_REF100M>;
- assigned-clock-rates = <100000000>;
- ep-gpios = <&gpio4 RK_PC6 GPIO_ACTIVE_HIGH>;
- num-lanes = <4>;
- status = "okay";
-&pcie_phy {
status = "okay";
gpio1830-supply = <&vcc_1v8>; };
&pmu_io_domains {
@@ -453,185 +436,99 @@ pmu1830-supply = <&vcc_1v8>; };
-&pwm0 {
- status = "okay";
- &pwm2 { status = "okay"; };
-&sdhci {
- bus-width = <8>;
- mmc-hs400-1_8v;
- supports-emmc;
- non-removable;
- status = "okay";
-&sdmmc {
- clock-frequency = <150000000>;
- max-frequency = <40000000>;
- supports-sd;
- bus-width = <4>;
- cap-mmc-highspeed;
- cap-sd-highspeed;
- disable-wp;
- num-slots = <1>;
- vqmmc-supply = <&vcc_sd>;
- pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>;
- status = "okay";
-&uart2 {
- status = "okay";
-&usb_host0_ehci {
- status = "disabled";
-&usb_host0_ohci {
-&usbdrd3_0 {
- status = "okay";
-&usb_host1_ehci {
-&usb_host1_ohci {
-&usbdrd3_1 {
- status = "okay";
- tsd,usb-port-power = "usbhub_enable";
-&vopb {
- status = "okay";
- &pinctrl {
- /* Pins that are not explicitely used by any devices */
- pinctrl-0 = <&puma_pin_hog>;
- hog {
puma_pin_hog: puma_pin_hog {
- i2c8 {
i2c8_xfer_a: i2c8-xfer { rockchip,pins =
/* We need pull-ups on Q7 buttons */
<RK_GPIO0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>, /* LID_BTN# */
<RK_GPIO0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>, /* BATLOW# */
<RK_GPIO0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_up>, /* SLP_BTN# */
<RK_GPIO0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>; /* BIOS_DISABLE# */
<1 RK_PC4 1 &pcfg_pull_up>,
}; };<1 RK_PC5 1 &pcfg_pull_up>;
- pmic {
- leds {
led_pin_module: led-module-gpio { rockchip,pins =
<RK_GPIO1 RK_PC6 RK_FUNC_GPIO &pcfg_pull_up>;
}; };<2 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>;
- leds_pins_puma: led_pins@0 {
rockchip,pins =
<RK_GPIO2 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>,
<RK_GPIO1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>;
- usb2 {
otg_vbus_drv: otg-vbus-drv {
rockchip,pins =
<RK_GPIO0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>;
- pmic {
<RK_GPIO4 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>;
}; };<1 RK_PC6 RK_FUNC_GPIO &pcfg_pull_up>;
- i2c8 {
- usb2 {
<RK_GPIO1 RK_PC5 RK_FUNC_1 &pcfg_pull_up>,
<RK_GPIO1 RK_PC4 RK_FUNC_1 &pcfg_pull_up>;
}; }; };<4 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>;
-&i2c1 { +&sdhci {
- bus-width = <8>;
- mmc-hs400-1_8v;
- non-removable; status = "okay";
- clock-frequency = <400000>; };
-&i2c2 {
- status = "okay";
+&sdmmc {
- vqmmc-supply = <&vcc_sd>; };
-&i2c4 {
+&spi1 { status = "okay";
- norflash: flash@0 {
reg = <0>;
spi-max-frequency = <50000000>;
-&i2c6 {
+&tcphy1 { status = "okay";
-&i2c6_xfer {
- /* Enable pull-ups, the pins would float otherwise. */
- rockchip,pins =
<RK_GPIO2 RK_PB2 RK_FUNC_2 &pcfg_pull_up>,
<RK_GPIO2 RK_PB1 RK_FUNC_2 &pcfg_pull_up>;
+&tsadc {
- rockchip,hw-tshut-mode = <1>;
- rockchip,hw-tshut-polarity = <1>;
-&i2c7 { +&u2phy1 { status = "okay";
rtc_twi: rtc@6f {
reg = <0x6f>;
- u2phy1_otg: otg-port {
};status = "okay";
- fan: fan@18 {
reg = <0x18>;
cooling-min-state = <0>;
cooling-max-state = <9>;
- u2phy1_host: host-port {
}; };status = "okay";
-&uart0 {
- pinctrl-0 = <&uart0_xfer &uart0_cts>;
+&usbdrd3_1 { status = "okay"; };
-&spi1 { +&usbdrd_dwc3_1 { status = "okay";
- dr_mode = "host";
- #address-cells = <1>;
- #size-cells = <0>;
- spiflash: w25q32dw@0 {
reg = <0>;
spi-max-frequency = <49500000>;
spi-cpol;
spi-cpha;
+&usb_host1_ehci {
-&spi5 { +&usb_host1_ohci { status = "okay"; }; diff --git a/arch/arm/dts/rk3399-roc-pc-u-boot.dtsi b/arch/arm/dts/rk3399-roc-pc-u-boot.dtsi index 5746442981..141dd0b306 100644 --- a/arch/arm/dts/rk3399-roc-pc-u-boot.dtsi +++ b/arch/arm/dts/rk3399-roc-pc-u-boot.dtsi @@ -14,9 +14,45 @@ chosen { u-boot,spl-boot-order = "same-as-spl", &sdhci, &sdmmc; };
- vcc_hub_en: vcc_hub_en-regulator {
enable-active-high;
gpio = <&gpio2 RK_PA4 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&hub_rst>;
regulator-name = "vcc_hub_en";
- should be placed inside mp8859, but not until mp8859 has
- its own dt-binding.
+&dc_12v {
regulator-boot-on;
regulator-min-microvolt = <12000000>;
regulator-max-microvolt = <12000000>;
vin-supply = <&vcc_vbus_typec0>; };
&vdd_log { regulator-min-microvolt = <430000>; regulator-init-microvolt = <950000>; };
+&vcc5v0_host {
- regulator-always-on;
+&vcc_sys {
+&vcc_sdio {
+}; diff --git a/arch/arm/dts/rk3399-roc-pc.dts b/arch/arm/dts/rk3399-roc-pc.dts index 6a909e4eef..cd41954253 100644 --- a/arch/arm/dts/rk3399-roc-pc.dts +++ b/arch/arm/dts/rk3399-roc-pc.dts @@ -8,6 +8,5 @@
/ { model = "Firefly ROC-RK3399-PC Board";
- compatible = "libretech,roc-rk3399-pc", "firefly,roc-rk3399-pc",
"rockchip,rk3399";
- compatible = "firefly,roc-rk3399-pc", "rockchip,rk3399"; };
diff --git a/arch/arm/dts/rk3399-roc-pc.dtsi b/arch/arm/dts/rk3399-roc-pc.dtsi index 9a1ce3a4ae..9f225e9c3d 100644 --- a/arch/arm/dts/rk3399-roc-pc.dtsi +++ b/arch/arm/dts/rk3399-roc-pc.dtsi @@ -110,20 +110,6 @@ regulator-max-microvolt = <5000000>; };
* should be placed inside mp8859, but not until mp8859 has
* its own dt-binding.
- dc_12v: mp8859-dcdc1 {
regulator-boot-on;
- /* switched by pmic_sleep */ vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 { compatible = "regulator-fixed";
@@ -176,7 +162,6 @@ pinctrl-names = "default"; pinctrl-0 = <&vcc5v0_host_en &hub_rst>; regulator-name = "vcc5v0_host";
vin-supply = <&vcc_sys>; };regulator-always-on;
@@ -198,7 +183,6 @@ pinctrl-names = "default"; pinctrl-0 = <&vcc_sys_en>; regulator-name = "vcc_sys";
regulator-boot-on; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>;regulator-always-on;
@@ -392,7 +376,6 @@
vcc_sdio: LDO_REG4 { regulator-name = "vcc_sdio";
regulator-always-on; regulator-boot-on; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <3000000>;
@@ -549,6 +532,24 @@ vbus-supply = <&vcc_vbus_typec0>; status = "okay"; };
mp8859: regulator@66 {
compatible = "mps,mp8859";
reg = <0x66>;
dc_12v: mp8859_dcdc {
regulator-boot-on;
regulator-suspend-microvolt = <12000000>;
&i2s0 {
diff --git a/arch/arm/dts/rk3399-rock-pi-4.dts b/arch/arm/dts/rk3399-rock-pi-4.dts index 4a543f2117..3923ec01ef 100644 --- a/arch/arm/dts/rk3399-rock-pi-4.dts +++ b/arch/arm/dts/rk3399-rock-pi-4.dts @@ -25,6 +25,15 @@ #clock-cells = <0>; };
- sdio_pwrseq: sdio-pwrseq {
compatible = "mmc-pwrseq-simple";
pinctrl-0 = <&wifi_enable_h>;
- vcc12v_dcin: dc-12v { compatible = "regulator-fixed"; regulator-name = "vcc12v_dcin";
@@ -44,6 +53,16 @@ vin-supply = <&vcc12v_dcin>; };
- vcc_0v9: vcc-0v9 {
regulator-name = "vcc_0v9";
regulator-boot-on;
@@ -157,12 +176,22 @@ status = "okay"; };
+&gpu {
- status = "okay";
- &hdmi {
- ddc-i2c-bus = <&i2c3>; pinctrl-names = "default"; pinctrl-0 = <&hdmi_cec>; status = "okay"; };
+&hdmi_sound {
- status = "okay";
- &i2c0 { clock-frequency = <400000>; i2c-scl-rising-time-ns = <168>;
@@ -444,13 +473,60 @@ pmu1830-supply = <&vcc_3v0>; };
+&pcie_phy {
- status = "okay";
+&pcie0 {
- ep-gpios = <&gpio4 RK_PD3 GPIO_ACTIVE_HIGH>;
- max-link-speed = <2>;
- num-lanes = <4>;
- pinctrl-0 = <&pcie_clkreqnb_cpm>;
- vpcie0v9-supply = <&vcc_0v9>;
- vpcie1v8-supply = <&vcc_1v8>;
- vpcie3v3-supply = <&vcc3v3_pcie>;
- status = "okay";
&pinctrl {
bt {
bt_enable_h: bt-enable-h {
rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>;
bt_wake_l: bt-wake-l {
rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>;
pcie { pcie_pwr_en: pcie-pwr-en { rockchip,pins = <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; }; };
sdio0 {
sdio0_bus4: sdio0-bus4 {
rockchip,pins = <2 RK_PC4 1 &pcfg_pull_up_20ma>,
<2 RK_PC5 1 &pcfg_pull_up_20ma>,
<2 RK_PC6 1 &pcfg_pull_up_20ma>,
<2 RK_PC7 1 &pcfg_pull_up_20ma>;
sdio0_cmd: sdio0-cmd {
rockchip,pins = <2 RK_PD0 1 &pcfg_pull_up_20ma>;
sdio0_clk: sdio0-clk {
rockchip,pins = <2 RK_PD1 1 &pcfg_pull_none_20ma>;
pmic { pmic_int_l: pmic-int-l { rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>;
@@ -476,6 +552,16 @@ rockchip,pins = <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; }; };
wifi {
wifi_enable_h: wifi-enable-h {
rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>;
&pwm2 {
@@ -488,6 +574,32 @@ vref-supply = <&vcc_1v8>; };
+&sdio0 {
- bus-width = <4>;
- clock-frequency = <50000000>;
- cap-sdio-irq;
- cap-sd-highspeed;
- non-removable;
- sd-uhs-sdr104;
- status = "okay";
- brcmf: wifi@1 {
reg = <1>;
@@ -551,6 +663,23 @@ }; };
+&uart0 {
- pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>;
- status = "okay";
- bluetooth {
device-wakeup-gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_enable_h>;
- &uart2 { status = "okay"; };
diff --git a/arch/arm/dts/rk3399-rock960.dts b/arch/arm/dts/rk3399-rock960.dts index 12285c51cc..437a75f31a 100644 --- a/arch/arm/dts/rk3399-rock960.dts +++ b/arch/arm/dts/rk3399-rock960.dts @@ -114,6 +114,55 @@ }; };
+&spi0 {
- /* On Low speed expansion (LS-SPI0) */
- status = "okay";
+&spi4 {
- /* On High speed expansion (HS-SPI1) */
- status = "okay";
+&thermal_zones {
- cpu_thermal: cpu {
polling-delay-passive = <100>;
polling-delay = <1000>;
thermal-sensors = <&tsadc 0>;
sustainable-power = <1550>;
trips {
cpu_alert0: cpu_alert0 {
type = "passive";
cpu_alert1: cpu_alert1 {
temperature = <75000>;
type = "passive";
cpu_crit: cpu_crit {
temperature = <95000>;
type = "critical";
cooling-maps {
map0 {
trip = <&cpu_alert1>;
cooling-device =
<&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
- &usbdrd_dwc3_0 { dr_mode = "otg"; };
diff --git a/arch/arm/dts/rk3399-rock960.dtsi b/arch/arm/dts/rk3399-rock960.dtsi index c7d48d41e1..ba7c75c9f2 100644 --- a/arch/arm/dts/rk3399-rock960.dtsi +++ b/arch/arm/dts/rk3399-rock960.dtsi @@ -76,6 +76,15 @@ regulator-always-on; vin-supply = <&vcc5v0_sys>; };
vcc_0v9: vcc-0v9 {
&cpu_l0 {
@@ -384,6 +393,8 @@ num-lanes = <4>; pinctrl-names = "default"; pinctrl-0 = <&pcie_clkreqn_cpm>;
- vpcie1v8-supply = <&vcca_1v8>; vpcie3v3-supply = <&vcc3v3_pcie>; status = "okay"; };
@@ -531,7 +542,7 @@ cap-mmc-highspeed; cap-sd-highspeed; clock-frequency = <100000000>;
- clock-freq-min-max = <100000 100000000>;
- max-frequency = <100000000>; cd-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>; disable-wp; sd-uhs-sdr104;
diff --git a/arch/arm/dts/rk3399-rockpro64.dts b/arch/arm/dts/rk3399-rockpro64.dts index e544deb61d..4b42717800 100644 --- a/arch/arm/dts/rk3399-rockpro64.dts +++ b/arch/arm/dts/rk3399-rockpro64.dts @@ -2,752 +2,29 @@ /*
- Copyright (c) 2018 Akash Gajjar Akash_Gajjar@mentor.com
- Copyright (c) 2019 Katsuhiro Suzuki katsuhiro@katsuster.net
/dts-v1/;
-#include <dt-bindings/input/linux-event-codes.h> -#include <dt-bindings/pwm/pwm.h> -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi" +#include "rk3399-rockpro64.dtsi"
- model = "Pine64 RockPro64";
- compatible = "pine64,rockpro64", "rockchip,rk3399";
- chosen {
clock-frequency = <125000000>;
clock-output-names = "clkin_gmac";
#clock-cells = <0>;
- gpio-keys {
autorepeat;
power {
wakeup-source;
- leds {
work-led {
label = "work";
gpios = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>;
diy-led {
label = "diy";
default-state = "off";
gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>;
- fan: pwm-fan {
fan-supply = <&vcc12v_dcin>;
* On the module itself this is one of these (depending
* on the actual card populated):
* - SDIO_RESET_L_WL_REG_ON
* - PDN (power down when low)
- vcc12v_dcin: vcc12v-dcin {
regulator-boot-on;
regulator-name = "vcc1v8_s3";
regulator-boot-on;
vin-supply = <&vcc_1v8>;
enable-active-high;
gpio = <&gpio1 RK_PD0 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&pcie_pwr_en>;
regulator-boot-on;
regulator-name = "vcc3v3_sys";
regulator-boot-on;
- /* Actually 3 regulators (host0, 1, 2) controlled by the same gpio */
enable-active-high;
gpio = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>;
vin-supply = <&vcc5v0_usb>;
- vcc5v0_typec: vcc5v0-typec-regulator {
enable-active-high;
regulator-name = "vcc5v0_typec";
regulator-boot-on;
- vcc5v0_usb: vcc5v0-usb {
regulator-name = "vcc5v0_usb";
regulator-boot-on;
regulator-boot-on;
regulator-max-microvolt = <1700000>;
-&cpu_l0 {
-&cpu_l1 {
-&cpu_l2 {
-&cpu_l3 {
-&cpu_b0 {
-&cpu_b1 {
-&emmc_phy {
- status = "okay";
-&gmac {
- status = "okay";
-&hdmi {
- status = "okay";
-&hdmi_sound {
- status = "okay";
-&gpu {
- status = "okay";
-&i2c0 {
- i2c-scl-rising-time-ns = <168>;
- i2c-scl-falling-time-ns = <4>;
- status = "okay";
- rk808: pmic@1b {
reg = <0x1b>;
interrupts = <10 IRQ_TYPE_LEVEL_LOW>;
#clock-cells = <1>;
wakeup-source;
vcc3-supply = <&vcc5v0_sys>;
vcc4-supply = <&vcc5v0_sys>;
vcc6-supply = <&vcc5v0_sys>;
vcc7-supply = <&vcc5v0_sys>;
vcc9-supply = <&vcc5v0_sys>;
vcc10-supply = <&vcc5v0_sys>;
vcc11-supply = <&vcc5v0_sys>;
vddio-supply = <&vcca_1v8>;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc1v8_dvp: LDO_REG1 {
regulator-name = "vcc1v8_dvp";
regulator-boot-on;
vcc3v0_touch: LDO_REG2 {
regulator-name = "vcc3v0_touch";
regulator-boot-on;
vcca_1v8: LDO_REG3 {
regulator-name = "vcca_1v8";
regulator-boot-on;
regulator-boot-on;
vcca3v0_codec: LDO_REG5 {
regulator-name = "vcca3v0_codec";
regulator-boot-on;
vcc_1v5: LDO_REG6 {
regulator-name = "vcc_1v5";
regulator-boot-on;
regulator-suspend-microvolt = <1500000>;
vcca1v8_codec: LDO_REG7 {
regulator-name = "vcca1v8_codec";
regulator-boot-on;
vcc_3v0: LDO_REG8 {
regulator-name = "vcc_3v0";
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
reg = <0x40>;
pinctrl-0 = <&vsel1_gpio>;
regulator-boot-on;
reg = <0x41>;
pinctrl-0 = <&vsel2_gpio>;
regulator-boot-on;
model = "Pine64 RockPro64 v2.1";
compatible = "pine64,rockpro64-v2.1", "pine64,rockpro64", "rockchip,rk3399"; };
&i2c1 {
- i2c-scl-rising-time-ns = <300>;
- i2c-scl-falling-time-ns = <15>;
- status = "okay";
-&i2c3 {
- i2c-scl-rising-time-ns = <450>;
- status = "okay";
-&i2c4 {
- i2c-scl-rising-time-ns = <600>;
- i2c-scl-falling-time-ns = <20>;
- status = "okay";
- fusb0: typec-portc@22 {
reg = <0x22>;
pinctrl-0 = <&fusb0_int>;
vbus-supply = <&vcc5v0_typec>;
status = "okay";
- es8316: codec@11 {
compatible = "everest,es8316";
reg = <0x11>;
clocks = <&cru SCLK_I2S_8CH_OUT>;
clock-names = "mclk";
-&i2s0 {
- status = "okay";
-&i2s1 {
- status = "okay";
-&i2s2 {
- status = "okay";
-&io_domains {
- status = "okay";
- bt656-supply = <&vcc1v8_dvp>;
- audio-supply = <&vcc_3v0>;
- gpio1830-supply = <&vcc_3v0>;
-&pcie0 {
- ep-gpios = <&gpio2 RK_PD4 GPIO_ACTIVE_HIGH>;
- num-lanes = <4>;
- pinctrl-0 = <&pcie_perst>;
- vpcie12v-supply = <&vcc12v_dcin>;
- status = "okay";
-&pcie_phy {
- status = "okay";
-&pmu_io_domains {
- pmu1830-supply = <&vcc_3v0>;
- status = "okay";
-&pinctrl {
- buttons {
pwrbtn: pwrbtn {
- fusb302x {
fusb0_int: fusb0-int {
- leds {
work_led_gpio: work_led-gpio {
rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>;
diy_led_gpio: diy_led-gpio {
rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>;
- pcie {
pcie_perst: pcie-perst {
rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>;
- pmic {
vsel1_gpio: vsel1-gpio {
vsel2_gpio: vsel2-gpio {
- sdio-pwrseq {
- usb-typec {
vcc5v0_typec_en: vcc5v0_typec_en {
rockchip,pins = <1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>;
- usb2 {
port {
es8316_p0_0: endpoint {
remote-endpoint = <&i2s1_p0_0>;
-&pwm0 {
- status = "okay";
-&pwm1 {
- status = "okay";
-&pwm2 {
- status = "okay";
-&saradc {
- status = "okay";
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- cd-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>;
- disable-wp;
- max-frequency = <150000000>;
- pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>;
- status = "okay";
-&sdhci {
- bus-width = <8>;
- mmc-hs200-1_8v;
- non-removable;
- status = "okay";
-&spi1 {
- status = "okay";
- flash@0 {
reg = <0>;
spi-max-frequency = <10000000>;
-&tcphy0 {
- status = "okay";
-&tcphy1 {
- status = "okay";
-&tsadc {
- /* tshut mode 0:CRU 1:GPIO */
- /* tshut polarity 0:LOW 1:HIGH */
- status = "okay";
-&u2phy0 {
- status = "okay";
- u2phy0_otg: otg-port {
status = "okay";
- u2phy0_host: host-port {
status = "okay";
-&u2phy1 {
- status = "okay";
status = "okay";
status = "okay";
-&uart0 {
- status = "okay";
-&uart2 {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&usbdrd3_0 {
- status = "okay";
-&usbdrd_dwc3_0 {
- status = "okay";
- dr_mode = "otg";
-&usbdrd3_1 {
- status = "okay";
-&usbdrd_dwc3_1 {
- status = "okay";
- dr_mode = "host";
-&vopb {
- status = "okay";
-&vopb_mmu {
- status = "okay";
-&vopl {
- status = "okay";
-&vopl_mmu {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3399-rockpro64.dtsi b/arch/arm/dts/rk3399-rockpro64.dtsi new file mode 100644 index 0000000000..9bca258012 --- /dev/null +++ b/arch/arm/dts/rk3399-rockpro64.dtsi @@ -0,0 +1,797 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/*
+#include <dt-bindings/input/linux-event-codes.h> +#include <dt-bindings/pwm/pwm.h> +#include "rk3399.dtsi" +#include "rk3399-opp.dtsi"
- chosen {
#clock-cells = <0>;
- gpio-keys {
autorepeat;
power {
wakeup-source;
- leds {
work-led {
label = "work";
diy-led {
label = "diy";
- fan: pwm-fan {
- sound {
compatible = "audio-graph-card";
label = "rockchip,rk3399";
dais = <&i2s1_p0>;
regulator-boot-on;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
regulator-boot-on;
enable-active-high;
enable-active-high;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
+&cpu_l0 {
+&cpu_l1 {
+&cpu_l2 {
+&cpu_l3 {
+&cpu_b0 {
+&cpu_b1 {
+&emmc_phy {
- status = "okay";
+&gmac {
- status = "okay";
+&hdmi {
- status = "okay";
+&hdmi_sound {
- status = "okay";
+&gpu {
- status = "okay";
+&i2c0 {
- status = "okay";
- rk808: pmic@1b {
reg = <0x1b>;
#clock-cells = <1>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v5: LDO_REG6 {
regulator-boot-on;
regulator-boot-on;
vcc_3v0: LDO_REG8 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
reg = <0x40>;
regulator-boot-on;
reg = <0x41>;
regulator-boot-on;
+&i2c1 {
- status = "okay";
+&i2c3 {
- status = "okay";
+&i2c4 {
- status = "okay";
reg = <0x22>;
status = "okay";
+&i2s0 {
- status = "okay";
+&i2s1 {
- status = "okay";
- i2s1_p0: port {
i2s1_p0_0: endpoint {
dai-format = "i2s";
mclk-fs = <256>;
remote-endpoint = <&es8316_p0_0>;
+&i2s2 {
- status = "okay";
+&io_domains {
- status = "okay";
+&pcie0 {
- num-lanes = <4>;
- status = "okay";
+&pcie_phy {
- status = "okay";
+&pmu_io_domains {
- status = "okay";
+&pinctrl {
- bt {
- buttons {
pwrbtn: pwrbtn {
- fusb302x {
- leds {
- pcie {
- pmic {
- sdio-pwrseq {
- usb-typec {
- usb2 {
+&pwm0 {
- status = "okay";
+&pwm1 {
- status = "okay";
+&pwm2 {
- status = "okay";
+&saradc {
- status = "okay";
+&sdio0 {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- disable-wp;
- non-removable;
- sd-uhs-sdr104;
- status = "okay";
+&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- status = "okay";
+&sdhci {
- bus-width = <8>;
- mmc-hs200-1_8v;
- non-removable;
- status = "okay";
+&spi1 {
- status = "okay";
- flash@0 {
reg = <0>;
+&tcphy0 {
- status = "okay";
+&tcphy1 {
- status = "okay";
+&tsadc {
- status = "okay";
+&u2phy0 {
- status = "okay";
status = "okay";
status = "okay";
+&u2phy1 {
- status = "okay";
status = "okay";
status = "okay";
+&uart0 {
- status = "okay";
- bluetooth {
+&uart2 {
- status = "okay";
+&usb_host0_ehci {
- status = "okay";
+&usb_host0_ohci {
- status = "okay";
+&usb_host1_ehci {
- status = "okay";
+&usb_host1_ohci {
- status = "okay";
+&usbdrd3_0 {
- status = "okay";
+&usbdrd_dwc3_0 {
- status = "okay";
- dr_mode = "otg";
+&usbdrd3_1 {
- status = "okay";
+&usbdrd_dwc3_1 {
- status = "okay";
- dr_mode = "host";
+&vopb {
- status = "okay";
+&vopb_mmu {
- status = "okay";
+&vopl {
- status = "okay";
+&vopl_mmu {
- status = "okay";
+}; diff --git a/arch/arm/dts/rk3399-u-boot.dtsi b/arch/arm/dts/rk3399-u-boot.dtsi index 8b857ccfc7..ef57c36e73 100644 --- a/arch/arm/dts/rk3399-u-boot.dtsi +++ b/arch/arm/dts/rk3399-u-boot.dtsi @@ -79,6 +79,7 @@ };
&sdhci {
- max-frequency = <200000000>; u-boot,dm-pre-reloc; };
diff --git a/arch/arm/dts/rk3399.dtsi b/arch/arm/dts/rk3399.dtsi index 6b7c136ab8..74f2c3d490 100644 --- a/arch/arm/dts/rk3399.dtsi +++ b/arch/arm/dts/rk3399.dtsi @@ -1,6 +1,6 @@ -// SPDX-License-Identifier: GPL-2.0+ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /*
- Copyright (c) 2016-2017 Fuzhou Rockchip Electronics Co., Ltd.
- Copyright (c) 2016 Fuzhou Rockchip Electronics Co., Ltd
#include <dt-bindings/clock/rk3399-cru.h>
@@ -19,6 +19,7 @@ #size-cells = <2>;
aliases {
i2c0 = &i2c0; i2c1 = &i2c1; i2c2 = &i2c2;ethernet0 = &gmac;
@@ -67,53 +68,102 @@
cpu_l0: cpu@0 { device_type = "cpu";
compatible = "arm,cortex-a53", "arm,armv8";
compatible = "arm,cortex-a53"; reg = <0x0 0x0>; enable-method = "psci";
#cooling-cells = <2>; /* min followed by max */
capacity-dmips-mhz = <485>; clocks = <&cru ARMCLKL>;
dynamic-power-coefficient = <100>;
cpu-idle-states = <&CPU_SLEEP &CLUSTER_SLEEP>;
cpu_l1: cpu@1 { device_type = "cpu";
compatible = "arm,cortex-a53"; reg = <0x0 0x1>; enable-method = "psci";
cpu_l2: cpu@2 { device_type = "cpu";
compatible = "arm,cortex-a53"; reg = <0x0 0x2>; enable-method = "psci";
cpu_l3: cpu@3 { device_type = "cpu";
compatible = "arm,cortex-a53"; reg = <0x0 0x3>; enable-method = "psci";
cpu_b0: cpu@100 { device_type = "cpu";
compatible = "arm,cortex-a72", "arm,armv8";
compatible = "arm,cortex-a72"; reg = <0x0 0x100>; enable-method = "psci";
capacity-dmips-mhz = <1024>; clocks = <&cru ARMCLKB>;
dynamic-power-coefficient = <436>;
cpu_b1: cpu@101 { device_type = "cpu";
compatible = "arm,cortex-a72"; reg = <0x0 0x101>; enable-method = "psci";
idle-states {
entry-method = "psci";
CPU_SLEEP: cpu-sleep {
compatible = "arm,idle-state";
local-timer-stop;
arm,psci-suspend-param = <0x0010000>;
entry-latency-us = <120>;
exit-latency-us = <250>;
min-residency-us = <900>;
CLUSTER_SLEEP: cluster-sleep {
local-timer-stop;
arm,psci-suspend-param = <0x1010000>;
entry-latency-us = <400>;
exit-latency-us = <500>;
min-residency-us = <2000>;
display-subsystem {
compatible = "rockchip,display-subsystem";
ports = <&vopl_out>, <&vopb_out>;
pmu_a53 {
@@ -147,7 +197,7 @@ #clock-cells = <0>; };
- amba {
- amba: bus { compatible = "simple-bus"; #address-cells = <2>; #size-cells = <2>;
@@ -183,7 +233,7 @@ #size-cells = <2>; #interrupt-cells = <1>; aspm-no-l0s;
bus-range = <0x0 0x1>;
clocks = <&cru ACLK_PCIE>, <&cru ACLK_PERF_PCIE>, <&cru PCLK_PCIE>, <&cru SCLK_PCIE_PM>; clock-names = "aclk", "aclk-perf",bus-range = <0x0 0x1f>;
@@ -200,10 +250,12 @@ linux,pci-domain = <0>; max-link-speed = <1>; msi-map = <0x0 &its 0x0 0x1000>;
phys = <&pcie_phy>;
phy-names = "pcie-phy";
ranges = <0x83000000 0x0 0xfa000000 0x0 0xfa000000 0x0 0x600000
0x81000000 0x0 0xfa600000 0x0 0xfa600000 0x0 0x100000>;
phys = <&pcie_phy 0>, <&pcie_phy 1>,
<&pcie_phy 2>, <&pcie_phy 3>;
phy-names = "pcie-phy-0", "pcie-phy-1",
"pcie-phy-2", "pcie-phy-3";
ranges = <0x83000000 0x0 0xfa000000 0x0 0xfa000000 0x0 0x1e00000
resets = <&cru SRST_PCIE_CORE>, <&cru SRST_PCIE_MGMT>, <&cru SRST_PCIE_MGMT_STICKY>, <&cru SRST_PCIE_PIPE>, <&cru SRST_PCIE_PM>, <&cru SRST_P_PCIE>,0x81000000 0x0 0xfbe00000 0x0 0xfbe00000 0x0 0x100000>;
@@ -236,10 +288,11 @@ resets = <&cru SRST_A_GMAC>; reset-names = "stmmaceth"; rockchip,grf = <&grf>;
status = "disabled"; };snps,txpbl = <0x4>;
- sdio0: dwmmc@fe310000 {
- sdio0: mmc@fe310000 { compatible = "rockchip,rk3399-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x0 0xfe310000 0x0 0x4000>;
@@ -255,12 +308,14 @@ status = "disabled"; };
- sdmmc: dwmmc@fe320000 {
- sdmmc: mmc@fe320000 { compatible = "rockchip,rk3399-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x0 0xfe320000 0x0 0x4000>; interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH 0>; max-frequency = <150000000>;
assigned-clocks = <&cru HCLK_SD>;
clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>; clock-names = "biu", "ciu", "ciu-drive", "ciu-sample";assigned-clock-rates = <200000000>;
@@ -278,7 +333,6 @@ arasan,soc-ctl-syscon = <&grf>; assigned-clocks = <&cru SCLK_EMMC>; assigned-clock-rates = <200000000>;
clocks = <&cru SCLK_EMMC>, <&cru ACLK_EMMC>; clock-names = "clk_xin", "clk_ahb"; clock-output-names = "emmc_cardclock";max-frequency = <200000000>;
@@ -286,6 +340,7 @@ phys = <&emmc_phy>; phy-names = "phy_arasan"; power-domains = <&power RK3399_PD_EMMC>;
status = "disabled"; };disable-cqe-dcmd;
@@ -295,11 +350,8 @@ interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH 0>; clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST0_ARB>, <&u2phy0>;
clock-names = "usbhost", "arbiter",
phys = <&u2phy0_host>; phy-names = "usb";"utmi";
status = "disabled"; };power-domains = <&power RK3399_PD_PERIHP>;
@@ -309,11 +361,8 @@ interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH 0>; clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST0_ARB>, <&u2phy0>;
@@ -323,11 +372,8 @@ interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH 0>; clocks = <&cru HCLK_HOST1>, <&cru HCLK_HOST1_ARB>, <&u2phy1>;
phys = <&u2phy1_host>; phy-names = "usb";"utmi";
@@ -337,15 +383,12 @@ interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH 0>; clocks = <&cru HCLK_HOST1>, <&cru HCLK_HOST1_ARB>, <&u2phy1>;
"utmi";
usbdrd3_0: dwc3_typec0: usb@fe800000 {
- usbdrd3_0: usb@fe800000 { compatible = "rockchip,rk3399-dwc3"; #address-cells = <2>; #size-cells = <2>;
@@ -364,6 +407,9 @@ compatible = "snps,dwc3"; reg = <0x0 0xfe800000 0x0 0x100000>; interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru SCLK_USB3OTG0_REF>, <&cru ACLK_USB3OTG0>,
<&cru SCLK_USB3OTG0_SUSPEND>;
clock-names = "ref", "bus_early", "suspend"; dr_mode = "otg"; phys = <&u2phy0_otg>, <&tcphy0_usb3>; phy-names = "usb2-phy", "usb3-phy";
@@ -378,7 +424,7 @@ }; };
- dwc3_typec1: usbdrd3_1: usb@fe900000 {
- usbdrd3_1: usb@fe900000 { compatible = "rockchip,rk3399-dwc3"; #address-cells = <2>; #size-cells = <2>;
@@ -397,6 +443,9 @@ compatible = "snps,dwc3"; reg = <0x0 0xfe900000 0x0 0x100000>; interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru SCLK_USB3OTG1_REF>, <&cru ACLK_USB3OTG1>,
<&cru SCLK_USB3OTG1_SUSPEND>;
clock-names = "ref", "bus_early", "suspend"; dr_mode = "otg"; phys = <&u2phy1_otg>, <&tcphy1_usb3>; phy-names = "usb2-phy", "usb3-phy";
@@ -464,6 +513,7 @@ its: interrupt-controller@fee20000 { compatible = "arm,gic-v3-its"; msi-controller;
};#msi-cells = <1>; reg = <0x0 0xfee20000 0x0 0x20000>;
@@ -612,7 +662,6 @@ clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; clock-names = "baudclk", "apb_pclk"; interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH 0>;
reg-shift = <2>; reg-io-width = <4>; pinctrl-names = "default";clock-frequency = <24000000>;
@@ -639,6 +688,8 @@ clocks = <&cru SCLK_SPI0>, <&cru PCLK_SPI0>; clock-names = "spiclk", "apb_pclk"; interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH 0>;
dmas = <&dmac_peri 10>, <&dmac_peri 11>;
pinctrl-names = "default"; pinctrl-0 = <&spi0_clk &spi0_tx &spi0_rx &spi0_cs0>; #address-cells = <1>;dma-names = "tx", "rx";
@@ -652,6 +703,8 @@ clocks = <&cru SCLK_SPI1>, <&cru PCLK_SPI1>; clock-names = "spiclk", "apb_pclk"; interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH 0>;
dmas = <&dmac_peri 12>, <&dmac_peri 13>;
pinctrl-names = "default"; pinctrl-0 = <&spi1_clk &spi1_tx &spi1_rx &spi1_cs0>; #address-cells = <1>;dma-names = "tx", "rx";
@@ -665,6 +718,8 @@ clocks = <&cru SCLK_SPI2>, <&cru PCLK_SPI2>; clock-names = "spiclk", "apb_pclk"; interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH 0>;
dmas = <&dmac_peri 14>, <&dmac_peri 15>;
pinctrl-names = "default"; pinctrl-0 = <&spi2_clk &spi2_tx &spi2_rx &spi2_cs0>; #address-cells = <1>;dma-names = "tx", "rx";
@@ -678,6 +733,8 @@ clocks = <&cru SCLK_SPI4>, <&cru PCLK_SPI4>; clock-names = "spiclk", "apb_pclk"; interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH 0>;
dmas = <&dmac_peri 18>, <&dmac_peri 19>;
pinctrl-names = "default"; pinctrl-0 = <&spi4_clk &spi4_tx &spi4_rx &spi4_cs0>; #address-cells = <1>;dma-names = "tx", "rx";
@@ -691,8 +748,11 @@ clocks = <&cru SCLK_SPI5>, <&cru PCLK_SPI5>; clock-names = "spiclk", "apb_pclk"; interrupts = <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH 0>;
dmas = <&dmac_bus 8>, <&dmac_bus 9>;
pinctrl-names = "default"; pinctrl-0 = <&spi5_clk &spi5_tx &spi5_rx &spi5_cs0>;dma-names = "tx", "rx";
#address-cells = <1>; #size-cells = <0>; status = "disabled";power-domains = <&power RK3399_PD_SDIOAUDIO>;
@@ -727,13 +787,18 @@ map0 { trip = <&cpu_alert0>; cooling-device =
<&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>;
<&cpu_b1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; }; map1 { trip = <&cpu_alert1>; cooling-device = <&cpu_l0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu_l1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu_l2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu_l3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
};<&cpu_b1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; }; };
@@ -761,7 +826,7 @@ map0 { trip = <&gpu_alert0>; cooling-device =
};<&gpu THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; }; };
@@ -980,22 +1045,11 @@ <&cru PCLK_GMAC>; pm_qos = <&qos_gmac>; };
pd_perihp@RK3399_PD_PERIHP {
reg = <RK3399_PD_PERIHP>;
#size-cells = <0>;
clocks = <&cru ACLK_PERIHP>;
pm_qos = <&qos_perihp>,
<&qos_pcie>,
<&qos_usb_host0>,
<&qos_usb_host1>;
pd_sd@RK3399_PD_SD {
reg = <RK3399_PD_SD>;
<&cru SCLK_SDMMC>;
pm_qos = <&qos_sd>;
<&cru SCLK_SDMMC>;
pm_qos = <&qos_sd>; }; pd_sdioaudio@RK3399_PD_SDIOAUDIO { reg = <RK3399_PD_SDIOAUDIO>;
@@ -1070,6 +1124,8 @@ pmugrf: syscon@ff320000 { compatible = "rockchip,rk3399-pmugrf", "syscon", "simple-mfd"; reg = <0x0 0xff320000 0x0 0x1000>;
#size-cells = <1>;
pmu_io_domains: io-domains { compatible = "rockchip,rk3399-pmu-io-voltage-domain";
@@ -1192,6 +1248,62 @@ status = "disabled"; };
- vpu: video-codec@ff650000 {
compatible = "rockchip,rk3399-vpu";
reg = <0x0 0xff650000 0x0 0x800>;
interrupts = <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH 0>;
interrupt-names = "vepu", "vdpu";
clocks = <&cru ACLK_VCODEC>, <&cru HCLK_VCODEC>;
clock-names = "aclk", "hclk";
iommus = <&vpu_mmu>;
power-domains = <&power RK3399_PD_VCODEC>;
- vpu_mmu: iommu@ff650800 {
compatible = "rockchip,iommu";
reg = <0x0 0xff650800 0x0 0x40>;
interrupts = <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH 0>;
interrupt-names = "vpu_mmu";
clock-names = "aclk", "iface";
#iommu-cells = <0>;
- vdec_mmu: iommu@ff660480 {
reg = <0x0 0xff660480 0x0 0x40>, <0x0 0xff6604c0 0x0 0x40>;
interrupts = <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH 0>;
interrupt-names = "vdec_mmu";
clocks = <&cru ACLK_VDU>, <&cru HCLK_VDU>;
#iommu-cells = <0>;
- iep_mmu: iommu@ff670800 {
reg = <0x0 0xff670800 0x0 0x40>;
interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH 0>;
interrupt-names = "iep_mmu";
clocks = <&cru ACLK_IEP>, <&cru HCLK_IEP>;
#iommu-cells = <0>;
- rga: rga@ff680000 {
compatible = "rockchip,rk3399-rga";
reg = <0x0 0xff680000 0x0 0x10000>;
interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru ACLK_RGA>, <&cru HCLK_RGA>, <&cru SCLK_RGA_CORE>;
clock-names = "aclk", "hclk", "sclk";
resets = <&cru SRST_RGA_CORE>, <&cru SRST_A_RGA>, <&cru SRST_H_RGA>;
reset-names = "core", "axi", "ahb";
power-domains = <&power RK3399_PD_RGA>;
- efuse0: efuse@ff690000 { compatible = "rockchip,rk3399-efuse"; reg = <0x0 0xff690000 0x0 0x80>;
@@ -1342,8 +1454,9 @@ compatible = "rockchip,rk3399-pcie-phy"; clocks = <&cru SCLK_PCIEPHY_REF>; clock-names = "refclk";
#phy-cells = <0>;
#phy-cells = <1>; resets = <&cru SRST_PCIEPHY>;
};drive-impedance-ohm = <50>; reset-names = "phy"; status = "disabled";
@@ -1592,11 +1705,11 @@ reg = <0x0 0xff914000 0x0 0x100>, <0x0 0xff915000 0x0 0x100>; interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH 0>; interrupt-names = "isp0_mmu";
clocks = <&cru ACLK_ISP0_NOC>, <&cru HCLK_ISP0_NOC>;
clock-names = "aclk", "iface"; #iommu-cells = <0>;clocks = <&cru ACLK_ISP0_WRAPPER>, <&cru HCLK_ISP0_WRAPPER>;
rockchip,disable-mmu-reset;power-domains = <&power RK3399_PD_ISP0>;
isp1_mmu: iommu@ff924000 {
@@ -1604,11 +1717,11 @@ reg = <0x0 0xff924000 0x0 0x100>, <0x0 0xff925000 0x0 0x100>; interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH 0>; interrupt-names = "isp1_mmu";
clocks = <&cru ACLK_ISP1_NOC>, <&cru HCLK_ISP1_NOC>;
clock-names = "aclk", "iface"; #iommu-cells = <0>;clocks = <&cru ACLK_ISP1_WRAPPER>, <&cru HCLK_ISP1_WRAPPER>;
rockchip,disable-mmu-reset;power-domains = <&power RK3399_PD_ISP1>;
@@ -1660,21 +1773,29 @@ };
mipi_dsi: mipi@ff960000 {
compatible = "rockchip,rk3399_mipi_dsi";
reg = <0x0 0xff960000 0x0 0x8000>; interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH 0>;compatible = "rockchip,rk3399-mipi-dsi", "snps,dw-mipi-dsi";
clocks = <&cru SCLK_MIPIDPHY_REF>, <&cru PCLK_MIPI_DSI0>,
<&cru SCLK_DPHY_TX0_CFG>;
clock-names = "ref", "pclk", "phy_cfg";
clocks = <&cru SCLK_DPHY_PLL>, <&cru PCLK_MIPI_DSI0>,
<&cru SCLK_DPHY_TX0_CFG>, <&cru PCLK_VIO_GRF>;
clock-names = "ref", "pclk", "phy_cfg", "grf";
power-domains = <&power RK3399_PD_VIO>;
resets = <&cru SRST_P_MIPI_DSI0>;
rockchip,grf = <&grf>; #address-cells = <1>; #size-cells = <0>; status = "disabled";reset-names = "apb";
- ports {
reg = <1>;
mipi_in: port {
#size-cells = <0>;
mipi_in: port@0 {
reg = <0>; #address-cells = <1>; #size-cells = <0>;
mipi_in_vopb: endpoint@0 { reg = <0>; remote-endpoint = <&vopb_out_mipi>;
@@ -1698,6 +1819,8 @@ resets = <&cru SRST_P_MIPI_DSI1>; reset-names = "apb"; rockchip,grf = <&grf>;
#size-cells = <0>;
ports {
@@ -1765,6 +1888,7 @@ <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH 0>; interrupt-names = "gpu", "job", "mmu"; clocks = <&cru ACLK_GPU>;
power-domains = <&power RK3399_PD_GPU>; status = "disabled"; };#cooling-cells = <2>;
@@ -1929,14 +2053,14 @@
clock { clk_32k: clk-32k {
rockchip,pins = <0 RK_PA0 RK_FUNC_2 &pcfg_pull_none>;
rockchip,pins = <0 RK_PA0 2 &pcfg_pull_none>; };
edp { edp_hpd: edp-hpd { rockchip,pins =
<4 RK_PC7 RK_FUNC_2 &pcfg_pull_none>;
};<4 RK_PC7 2 &pcfg_pull_none>; };
@@ -1944,382 +2068,409 @@ rgmii_pins: rgmii-pins { rockchip,pins = /* mac_txclk */
<3 RK_PC1 RK_FUNC_1 &pcfg_pull_none_13ma>,
<3 RK_PC1 1 &pcfg_pull_none_13ma>, /* mac_rxclk */
<3 RK_PB6 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PB6 1 &pcfg_pull_none>, /* mac_mdio */
<3 RK_PB5 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PB5 1 &pcfg_pull_none>, /* mac_txen */
<3 RK_PB4 RK_FUNC_1 &pcfg_pull_none_13ma>,
<3 RK_PB4 1 &pcfg_pull_none_13ma>, /* mac_clk */
<3 RK_PB3 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PB3 1 &pcfg_pull_none>, /* mac_rxdv */
<3 RK_PB1 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PB1 1 &pcfg_pull_none>, /* mac_mdc */
<3 RK_PB0 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PB0 1 &pcfg_pull_none>, /* mac_rxd1 */
<3 RK_PA7 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PA7 1 &pcfg_pull_none>, /* mac_rxd0 */
<3 RK_PA6 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PA6 1 &pcfg_pull_none>, /* mac_txd1 */
<3 RK_PA5 RK_FUNC_1 &pcfg_pull_none_13ma>,
<3 RK_PA5 1 &pcfg_pull_none_13ma>, /* mac_txd0 */
<3 RK_PA4 RK_FUNC_1 &pcfg_pull_none_13ma>,
<3 RK_PA4 1 &pcfg_pull_none_13ma>, /* mac_rxd3 */
<3 RK_PA3 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PA3 1 &pcfg_pull_none>, /* mac_rxd2 */
<3 RK_PA2 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PA2 1 &pcfg_pull_none>, /* mac_txd3 */
<3 RK_PA1 RK_FUNC_1 &pcfg_pull_none_13ma>,
<3 RK_PA1 1 &pcfg_pull_none_13ma>, /* mac_txd2 */
<3 RK_PA0 RK_FUNC_1 &pcfg_pull_none_13ma>;
<3 RK_PA0 1 &pcfg_pull_none_13ma>; }; rmii_pins: rmii-pins { rockchip,pins = /* mac_mdio */
<3 RK_PB3 1 &pcfg_pull_none>, /* mac_rxer */
<3 RK_PB2 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PB2 1 &pcfg_pull_none>, /* mac_rxdv */
<3 RK_PA4 RK_FUNC_1 &pcfg_pull_none_13ma>;
<3 RK_PA4 1 &pcfg_pull_none_13ma>; };
i2c0 { i2c0_xfer: i2c0-xfer { rockchip,pins =
<1 RK_PB7 RK_FUNC_2 &pcfg_pull_none>,
<1 RK_PC0 RK_FUNC_2 &pcfg_pull_none>;
<1 RK_PB7 2 &pcfg_pull_none>,
<1 RK_PC0 2 &pcfg_pull_none>; };
i2c1 { i2c1_xfer: i2c1-xfer { rockchip,pins =
<4 RK_PA2 RK_FUNC_1 &pcfg_pull_none>,
<4 RK_PA1 RK_FUNC_1 &pcfg_pull_none>;
<4 RK_PA2 1 &pcfg_pull_none>,
<4 RK_PA1 1 &pcfg_pull_none>; };
i2c2 { i2c2_xfer: i2c2-xfer { rockchip,pins =
<2 RK_PA1 RK_FUNC_2 &pcfg_pull_none_12ma>,
<2 RK_PA0 RK_FUNC_2 &pcfg_pull_none_12ma>;
<2 RK_PA1 2 &pcfg_pull_none_12ma>,
<2 RK_PA0 2 &pcfg_pull_none_12ma>; };
i2c3 { i2c3_xfer: i2c3-xfer { rockchip,pins =
<4 RK_PC1 RK_FUNC_1 &pcfg_pull_none>,
<4 RK_PC0 RK_FUNC_1 &pcfg_pull_none>;
<4 RK_PC1 1 &pcfg_pull_none>,
<4 RK_PC0 1 &pcfg_pull_none>; };
i2c4 { i2c4_xfer: i2c4-xfer { rockchip,pins =
<1 RK_PB4 RK_FUNC_1 &pcfg_pull_none>,
<1 RK_PB3 RK_FUNC_1 &pcfg_pull_none>;
<1 RK_PB4 1 &pcfg_pull_none>,
<1 RK_PB3 1 &pcfg_pull_none>; };
i2c5 { i2c5_xfer: i2c5-xfer { rockchip,pins =
<3 RK_PB3 RK_FUNC_2 &pcfg_pull_none>,
<3 RK_PB2 RK_FUNC_2 &pcfg_pull_none>;
<3 RK_PB3 2 &pcfg_pull_none>,
<3 RK_PB2 2 &pcfg_pull_none>; };
i2c6 { i2c6_xfer: i2c6-xfer { rockchip,pins =
<2 RK_PB2 RK_FUNC_2 &pcfg_pull_none>,
<2 RK_PB1 RK_FUNC_2 &pcfg_pull_none>;
<2 RK_PB2 2 &pcfg_pull_none>,
<2 RK_PB1 2 &pcfg_pull_none>; };
i2c7 { i2c7_xfer: i2c7-xfer { rockchip,pins =
<2 RK_PB0 RK_FUNC_2 &pcfg_pull_none>,
<2 RK_PA7 RK_FUNC_2 &pcfg_pull_none>;
<2 RK_PB0 2 &pcfg_pull_none>,
<2 RK_PA7 2 &pcfg_pull_none>; };
i2c8 { i2c8_xfer: i2c8-xfer { rockchip,pins =
<1 RK_PC5 RK_FUNC_1 &pcfg_pull_none>,
<1 RK_PC4 RK_FUNC_1 &pcfg_pull_none>;
<1 RK_PC5 1 &pcfg_pull_none>,
<1 RK_PC4 1 &pcfg_pull_none>; };
i2s0 {
i2s0_2ch_bus: i2s0-2ch-bus {
rockchip,pins =
<3 RK_PD0 1 &pcfg_pull_none>,
<3 RK_PD1 1 &pcfg_pull_none>,
<3 RK_PD2 1 &pcfg_pull_none>,
<3 RK_PD3 1 &pcfg_pull_none>,
<3 RK_PD7 1 &pcfg_pull_none>,
<4 RK_PA0 1 &pcfg_pull_none>;
i2s0_8ch_bus: i2s0-8ch-bus { rockchip,pins =
<3 RK_PD0 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PD1 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PD2 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PD3 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PD4 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PD5 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PD6 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PD7 RK_FUNC_1 &pcfg_pull_none>,
<4 RK_PA0 RK_FUNC_1 &pcfg_pull_none>;
<3 RK_PD4 1 &pcfg_pull_none>,
<3 RK_PD5 1 &pcfg_pull_none>,
<3 RK_PD6 1 &pcfg_pull_none>,
<4 RK_PA0 1 &pcfg_pull_none>; };
i2s1 { i2s1_2ch_bus: i2s1-2ch-bus { rockchip,pins =
<4 RK_PA3 RK_FUNC_1 &pcfg_pull_none>,
<4 RK_PA4 RK_FUNC_1 &pcfg_pull_none>,
<4 RK_PA5 RK_FUNC_1 &pcfg_pull_none>,
<4 RK_PA6 RK_FUNC_1 &pcfg_pull_none>,
<4 RK_PA7 RK_FUNC_1 &pcfg_pull_none>;
<4 RK_PA3 1 &pcfg_pull_none>,
<4 RK_PA4 1 &pcfg_pull_none>,
<4 RK_PA5 1 &pcfg_pull_none>,
<4 RK_PA6 1 &pcfg_pull_none>,
<4 RK_PA7 1 &pcfg_pull_none>; };
sdio0 { sdio0_bus1: sdio0-bus1 { rockchip,pins =
<2 RK_PC4 RK_FUNC_1 &pcfg_pull_up>;
<2 RK_PC4 1 &pcfg_pull_up>; }; sdio0_bus4: sdio0-bus4 { rockchip,pins =
<2 RK_PC4 RK_FUNC_1 &pcfg_pull_up>,
<2 RK_PC5 RK_FUNC_1 &pcfg_pull_up>,
<2 RK_PC6 RK_FUNC_1 &pcfg_pull_up>,
<2 RK_PC7 RK_FUNC_1 &pcfg_pull_up>;
<2 RK_PC4 1 &pcfg_pull_up>,
<2 RK_PC5 1 &pcfg_pull_up>,
<2 RK_PC6 1 &pcfg_pull_up>,
<2 RK_PC7 1 &pcfg_pull_up>; }; sdio0_cmd: sdio0-cmd { rockchip,pins =
<2 RK_PD0 RK_FUNC_1 &pcfg_pull_up>;
<2 RK_PD0 1 &pcfg_pull_up>; }; sdio0_clk: sdio0-clk { rockchip,pins =
<2 RK_PD1 RK_FUNC_1 &pcfg_pull_none>;
<2 RK_PD1 1 &pcfg_pull_none>; }; sdio0_cd: sdio0-cd { rockchip,pins =
<2 RK_PD2 RK_FUNC_1 &pcfg_pull_up>;
<2 RK_PD2 1 &pcfg_pull_up>; }; sdio0_pwr: sdio0-pwr { rockchip,pins =
<2 RK_PD3 RK_FUNC_1 &pcfg_pull_up>;
<2 RK_PD3 1 &pcfg_pull_up>; }; sdio0_bkpwr: sdio0-bkpwr { rockchip,pins =
<2 RK_PD4 RK_FUNC_1 &pcfg_pull_up>;
<2 RK_PD4 1 &pcfg_pull_up>; }; sdio0_wp: sdio0-wp { rockchip,pins =
<0 RK_PA3 RK_FUNC_1 &pcfg_pull_up>;
<0 RK_PA3 1 &pcfg_pull_up>; }; sdio0_int: sdio0-int { rockchip,pins =
<0 RK_PA4 RK_FUNC_1 &pcfg_pull_up>;
<0 RK_PA4 1 &pcfg_pull_up>; };
sdmmc { sdmmc_bus1: sdmmc-bus1 { rockchip,pins =
<4 RK_PB0 RK_FUNC_1 &pcfg_pull_up>;
<4 RK_PB0 1 &pcfg_pull_up>; }; sdmmc_bus4: sdmmc-bus4 { rockchip,pins =
<4 RK_PB0 RK_FUNC_1 &pcfg_pull_up>,
<4 RK_PB1 RK_FUNC_1 &pcfg_pull_up>,
<4 RK_PB2 RK_FUNC_1 &pcfg_pull_up>,
<4 RK_PB3 RK_FUNC_1 &pcfg_pull_up>;
<4 RK_PB0 1 &pcfg_pull_up>,
<4 RK_PB1 1 &pcfg_pull_up>,
<4 RK_PB2 1 &pcfg_pull_up>,
<4 RK_PB3 1 &pcfg_pull_up>; }; sdmmc_clk: sdmmc-clk { rockchip,pins =
<4 RK_PB4 RK_FUNC_1 &pcfg_pull_none>;
<4 RK_PB4 1 &pcfg_pull_none>; }; sdmmc_cmd: sdmmc-cmd { rockchip,pins =
<4 RK_PB5 RK_FUNC_1 &pcfg_pull_up>;
<4 RK_PB5 1 &pcfg_pull_up>; }; sdmmc_cd: sdmmc-cd { rockchip,pins =
<0 RK_PA7 RK_FUNC_1 &pcfg_pull_up>;
<0 RK_PA7 1 &pcfg_pull_up>; }; sdmmc_wp: sdmmc-wp { rockchip,pins =
<0 RK_PB0 RK_FUNC_1 &pcfg_pull_up>;
<0 RK_PB0 1 &pcfg_pull_up>; };
sleep { ap_pwroff: ap-pwroff {
rockchip,pins = <1 RK_PA5 RK_FUNC_1 &pcfg_pull_none>;
rockchip,pins = <1 RK_PA5 1 &pcfg_pull_none>; }; ddrio_pwroff: ddrio-pwroff {
rockchip,pins = <0 RK_PA1 RK_FUNC_1 &pcfg_pull_none>;
rockchip,pins = <0 RK_PA1 1 &pcfg_pull_none>; };
spdif { spdif_bus: spdif-bus { rockchip,pins =
<4 RK_PC5 RK_FUNC_1 &pcfg_pull_none>;
<4 RK_PC5 1 &pcfg_pull_none>; }; spdif_bus_1: spdif-bus-1 { rockchip,pins =
<3 RK_PC0 RK_FUNC_3 &pcfg_pull_none>;
<3 RK_PC0 3 &pcfg_pull_none>; };
spi0 { spi0_clk: spi0-clk { rockchip,pins =
<3 RK_PA6 RK_FUNC_2 &pcfg_pull_up>;
<3 RK_PA6 2 &pcfg_pull_up>; }; spi0_cs0: spi0-cs0 { rockchip,pins =
<3 RK_PA7 RK_FUNC_2 &pcfg_pull_up>;
<3 RK_PA7 2 &pcfg_pull_up>; }; spi0_cs1: spi0-cs1 { rockchip,pins =
<3 RK_PB0 RK_FUNC_2 &pcfg_pull_up>;
<3 RK_PB0 2 &pcfg_pull_up>; }; spi0_tx: spi0-tx { rockchip,pins =
<3 RK_PA5 RK_FUNC_2 &pcfg_pull_up>;
<3 RK_PA5 2 &pcfg_pull_up>; }; spi0_rx: spi0-rx { rockchip,pins =
<3 RK_PA4 RK_FUNC_2 &pcfg_pull_up>;
<3 RK_PA4 2 &pcfg_pull_up>; };
spi1 { spi1_clk: spi1-clk { rockchip,pins =
<1 RK_PB1 RK_FUNC_2 &pcfg_pull_up>;
<1 RK_PB1 2 &pcfg_pull_up>; }; spi1_cs0: spi1-cs0 { rockchip,pins =
<1 RK_PB2 RK_FUNC_2 &pcfg_pull_up>;
<1 RK_PB2 2 &pcfg_pull_up>; }; spi1_rx: spi1-rx { rockchip,pins =
<1 RK_PA7 RK_FUNC_2 &pcfg_pull_up>;
<1 RK_PA7 2 &pcfg_pull_up>; }; spi1_tx: spi1-tx { rockchip,pins =
<1 RK_PB0 RK_FUNC_2 &pcfg_pull_up>;
<1 RK_PB0 2 &pcfg_pull_up>; };
spi2 { spi2_clk: spi2-clk { rockchip,pins =
<2 RK_PB3 RK_FUNC_1 &pcfg_pull_up>;
<2 RK_PB3 1 &pcfg_pull_up>; }; spi2_cs0: spi2-cs0 { rockchip,pins =
<2 RK_PB4 RK_FUNC_1 &pcfg_pull_up>;
<2 RK_PB4 1 &pcfg_pull_up>; }; spi2_rx: spi2-rx { rockchip,pins =
<2 RK_PB1 RK_FUNC_1 &pcfg_pull_up>;
<2 RK_PB1 1 &pcfg_pull_up>; }; spi2_tx: spi2-tx { rockchip,pins =
<2 RK_PB2 RK_FUNC_1 &pcfg_pull_up>;
<2 RK_PB2 1 &pcfg_pull_up>; };
spi3 { spi3_clk: spi3-clk { rockchip,pins =
<1 RK_PC1 RK_FUNC_1 &pcfg_pull_up>;
<1 RK_PC1 1 &pcfg_pull_up>; }; spi3_cs0: spi3-cs0 { rockchip,pins =
<1 RK_PC2 RK_FUNC_1 &pcfg_pull_up>;
<1 RK_PC2 1 &pcfg_pull_up>; }; spi3_rx: spi3-rx { rockchip,pins =
<1 RK_PB7 RK_FUNC_1 &pcfg_pull_up>;
<1 RK_PB7 1 &pcfg_pull_up>; }; spi3_tx: spi3-tx { rockchip,pins =
<1 RK_PC0 RK_FUNC_1 &pcfg_pull_up>;
<1 RK_PC0 1 &pcfg_pull_up>; };
spi4 { spi4_clk: spi4-clk { rockchip,pins =
<3 RK_PA2 RK_FUNC_2 &pcfg_pull_up>;
<3 RK_PA2 2 &pcfg_pull_up>; }; spi4_cs0: spi4-cs0 { rockchip,pins =
<3 RK_PA3 RK_FUNC_2 &pcfg_pull_up>;
<3 RK_PA3 2 &pcfg_pull_up>; }; spi4_rx: spi4-rx { rockchip,pins =
<3 RK_PA0 RK_FUNC_2 &pcfg_pull_up>;
<3 RK_PA0 2 &pcfg_pull_up>; }; spi4_tx: spi4-tx { rockchip,pins =
<3 RK_PA1 RK_FUNC_2 &pcfg_pull_up>;
<3 RK_PA1 2 &pcfg_pull_up>; };
spi5 { spi5_clk: spi5-clk { rockchip,pins =
<2 RK_PC6 RK_FUNC_2 &pcfg_pull_up>;
<2 RK_PC6 2 &pcfg_pull_up>; }; spi5_cs0: spi5-cs0 { rockchip,pins =
<2 RK_PC7 RK_FUNC_2 &pcfg_pull_up>;
<2 RK_PC7 2 &pcfg_pull_up>; }; spi5_rx: spi5-rx { rockchip,pins =
<2 RK_PC4 RK_FUNC_2 &pcfg_pull_up>;
<2 RK_PC4 2 &pcfg_pull_up>; }; spi5_tx: spi5-tx { rockchip,pins =
<2 RK_PC5 RK_FUNC_2 &pcfg_pull_up>;
<2 RK_PC5 2 &pcfg_pull_up>;
testclk {
test_clkout0: test-clkout0 {
rockchip,pins =
<0 RK_PA0 1 &pcfg_pull_none>;
test_clkout1: test-clkout1 {
rockchip,pins =
<2 RK_PD1 2 &pcfg_pull_none>;
test_clkout2: test-clkout2 {
rockchip,pins =
};<0 RK_PB0 3 &pcfg_pull_none>; };
@@ -2329,168 +2480,168 @@ };
otp_out: otp-out {
rockchip,pins = <1 RK_PA6 RK_FUNC_1 &pcfg_pull_none>;
rockchip,pins = <1 RK_PA6 1 &pcfg_pull_none>; };
uart0 { uart0_xfer: uart0-xfer { rockchip,pins =
<2 RK_PC0 RK_FUNC_1 &pcfg_pull_up>,
<2 RK_PC1 RK_FUNC_1 &pcfg_pull_none>;
<2 RK_PC0 1 &pcfg_pull_up>,
<2 RK_PC1 1 &pcfg_pull_none>; }; uart0_cts: uart0-cts { rockchip,pins =
<2 RK_PC2 RK_FUNC_1 &pcfg_pull_none>;
<2 RK_PC2 1 &pcfg_pull_none>; }; uart0_rts: uart0-rts { rockchip,pins =
<2 RK_PC3 RK_FUNC_1 &pcfg_pull_none>;
<2 RK_PC3 1 &pcfg_pull_none>; };
uart1 { uart1_xfer: uart1-xfer { rockchip,pins =
<3 RK_PB4 RK_FUNC_2 &pcfg_pull_up>,
<3 RK_PB5 RK_FUNC_2 &pcfg_pull_none>;
<3 RK_PB4 2 &pcfg_pull_up>,
<3 RK_PB5 2 &pcfg_pull_none>; };
uart2a { uart2a_xfer: uart2a-xfer { rockchip,pins =
<4 RK_PB0 RK_FUNC_2 &pcfg_pull_up>,
<4 RK_PB1 RK_FUNC_2 &pcfg_pull_none>;
<4 RK_PB0 2 &pcfg_pull_up>,
<4 RK_PB1 2 &pcfg_pull_none>; };
uart2b { uart2b_xfer: uart2b-xfer { rockchip,pins =
<4 RK_PC0 RK_FUNC_2 &pcfg_pull_up>,
<4 RK_PC1 RK_FUNC_2 &pcfg_pull_none>;
<4 RK_PC0 2 &pcfg_pull_up>,
<4 RK_PC1 2 &pcfg_pull_none>; };
uart2c { uart2c_xfer: uart2c-xfer { rockchip,pins =
<4 RK_PC3 RK_FUNC_1 &pcfg_pull_up>,
<4 RK_PC4 RK_FUNC_1 &pcfg_pull_none>;
<4 RK_PC3 1 &pcfg_pull_up>,
<4 RK_PC4 1 &pcfg_pull_none>; };
uart3 { uart3_xfer: uart3-xfer { rockchip,pins =
<3 RK_PB6 RK_FUNC_2 &pcfg_pull_up>,
<3 RK_PB7 RK_FUNC_2 &pcfg_pull_none>;
<3 RK_PB6 2 &pcfg_pull_up>,
<3 RK_PB7 2 &pcfg_pull_none>; }; uart3_cts: uart3-cts { rockchip,pins =
<3 RK_PC2 RK_FUNC_2 &pcfg_pull_none>;
<3 RK_PC0 2 &pcfg_pull_none>; }; uart3_rts: uart3-rts { rockchip,pins =
<3 RK_PC3 RK_FUNC_2 &pcfg_pull_none>;
<3 RK_PC1 2 &pcfg_pull_none>; };
uart4 { uart4_xfer: uart4-xfer { rockchip,pins =
<1 RK_PA7 RK_FUNC_1 &pcfg_pull_up>,
<1 RK_PB0 RK_FUNC_1 &pcfg_pull_none>;
<1 RK_PA7 1 &pcfg_pull_up>,
<1 RK_PB0 1 &pcfg_pull_none>; };
uarthdcp { uarthdcp_xfer: uarthdcp-xfer { rockchip,pins =
<4 RK_PC5 RK_FUNC_2 &pcfg_pull_up>,
<4 RK_PC6 RK_FUNC_2 &pcfg_pull_none>;
<4 RK_PC5 2 &pcfg_pull_up>,
<4 RK_PC6 2 &pcfg_pull_none>; };
pwm0 { pwm0_pin: pwm0-pin { rockchip,pins =
<4 RK_PC2 RK_FUNC_1 &pcfg_pull_none>;
<4 RK_PC2 1 &pcfg_pull_none>;
pwm0_pin_pull_down: pwm0-pin-pull-down {
rockchip,pins =
<4 RK_PC2 1 &pcfg_pull_down>; }; vop0_pwm_pin: vop0-pwm-pin { rockchip,pins =
<4 RK_PC2 RK_FUNC_2 &pcfg_pull_none>;
<4 RK_PC2 2 &pcfg_pull_none>;
vop1_pwm_pin: vop1-pwm-pin {
rockchip,pins =
<4 RK_PC2 3 &pcfg_pull_none>; };
pwm1 { pwm1_pin: pwm1-pin { rockchip,pins =
<4 RK_PC6 RK_FUNC_1 &pcfg_pull_none>;
<4 RK_PC6 1 &pcfg_pull_none>; };
pwm1_pin_pull_down: pwm1-pin-pull-down { rockchip,pins =
<4 RK_PC2 RK_FUNC_3 &pcfg_pull_none>;
<4 RK_PC6 1 &pcfg_pull_down>; };
pwm2 { pwm2_pin: pwm2-pin { rockchip,pins =
<1 RK_PC3 RK_FUNC_1 &pcfg_pull_none>;
<1 RK_PC3 1 &pcfg_pull_none>; }; pwm2_pin_pull_down: pwm2-pin-pull-down { rockchip,pins =
<1 RK_PC3 RK_FUNC_1 &pcfg_pull_down>;
<1 RK_PC3 1 &pcfg_pull_down>; };
pwm3a { pwm3a_pin: pwm3a-pin { rockchip,pins =
<0 RK_PA6 RK_FUNC_1 &pcfg_pull_none>;
<0 RK_PA6 1 &pcfg_pull_none>; };
pwm3b { pwm3b_pin: pwm3b-pin { rockchip,pins =
<1 RK_PB6 RK_FUNC_1 &pcfg_pull_none>;
<1 RK_PB6 1 &pcfg_pull_none>; };
hdmi { hdmi_i2c_xfer: hdmi-i2c-xfer { rockchip,pins =
<4 RK_PC1 RK_FUNC_3 &pcfg_pull_none>,
<4 RK_PC0 RK_FUNC_3 &pcfg_pull_none>;
<4 RK_PC1 3 &pcfg_pull_none>,
<4 RK_PC0 3 &pcfg_pull_none>; }; hdmi_cec: hdmi-cec { rockchip,pins =
<4 RK_PC7 RK_FUNC_1 &pcfg_pull_none>;
<4 RK_PC7 1 &pcfg_pull_none>; };
pcie {
pcie_clkreqn: pci-clkreqn {
rockchip,pins =
<2 RK_PD2 RK_FUNC_2 &pcfg_pull_none>;
pcie_clkreqnb: pci-clkreqnb {
rockchip,pins =
<4 RK_PD0 RK_FUNC_1 &pcfg_pull_none>;
pcie_clkreqn_cpm: pci-clkreqn-cpm { rockchip,pins = <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>;
Sync Firefly ROC-RK3399-PC Mezzanine Board dts file from Linux v5.7-rc1.
Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - none
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3399-roc-pc-mezzanine.dts | 93 ++++++++++++++++++++++++ 2 files changed, 94 insertions(+) create mode 100644 arch/arm/dts/rk3399-roc-pc-mezzanine.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index af7d804b66..409b0d1b3f 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -131,6 +131,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3399) += \ rk3399-puma-ddr1600.dtb \ rk3399-puma-ddr1866.dtb \ rk3399-roc-pc.dtb \ + rk3399-roc-pc-mezzanine.dtb \ rk3399-rock-pi-4.dtb \ rk3399-rock960.dtb \ rk3399-rockpro64.dtb diff --git a/arch/arm/dts/rk3399-roc-pc-mezzanine.dts b/arch/arm/dts/rk3399-roc-pc-mezzanine.dts new file mode 100644 index 0000000000..2acb3d500f --- /dev/null +++ b/arch/arm/dts/rk3399-roc-pc-mezzanine.dts @@ -0,0 +1,93 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2017 T-Chip Intelligent Technology Co., Ltd + * Copyright (c) 2019 Markus Reichl m.reichl@fivetechno.de + */ + +/dts-v1/; +#include "rk3399-roc-pc.dtsi" + +/ { + model = "Firefly ROC-RK3399-PC Mezzanine Board"; + compatible = "firefly,roc-rk3399-pc-mezzanine", "rockchip,rk3399"; + + vcc3v3_ngff: vcc3v3-ngff { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_ngff"; + enable-active-high; + gpio = <&gpio4 RK_PD3 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc3v3_ngff_en>; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&dc_12v>; + }; + + vcc3v3_pcie: vcc3v3-pcie { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_pcie"; + enable-active-high; + gpio = <&gpio1 RK_PC1 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc3v3_pcie_en>; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&dc_12v>; + }; +}; + +&pcie_phy { + status = "okay"; +}; + +&pcie0 { + ep-gpios = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>; + num-lanes = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie_perst>; + vpcie3v3-supply = <&vcc3v3_pcie>; + vpcie1v8-supply = <&vcc1v8_pmu>; + vpcie0v9-supply = <&vcca_0v9>; + status = "okay"; +}; + +&pinctrl { + ngff { + vcc3v3_ngff_en: vcc3v3-ngff-en { + rockchip,pins = <4 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pcie { + vcc3v3_pcie_en: vcc3v3-pcie-en { + rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + pcie_perst: pcie-perst { + rockchip,pins = <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&sdio0 { + bus-width = <4>; + cap-sd-highspeed; + cap-sdio-irq; + keep-power-in-suspend; + mmc-pwrseq = <&sdio_pwrseq>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; + sd-uhs-sdr104; + vmmc-supply = <&vcc3v3_ngff>; + vqmmc-supply = <&vcc_1v8>; + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; + status = "okay"; +};
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changes for v2:
none
- rk3399-roc-pc-mezzanine.dtb \ rk3399-rock-pi-4.dtb \ rk3399-rock960.dtb \ rk3399-rockpro64.dtb
- Copyright (c) 2017 T-Chip Intelligent Technology Co., Ltd
- Copyright (c) 2019 Markus Reichl m.reichl@fivetechno.de
- model = "Firefly ROC-RK3399-PC Mezzanine Board";
- compatible = "firefly,roc-rk3399-pc-mezzanine", "rockchip,rk3399";
- vcc3v3_ngff: vcc3v3-ngff {
enable-active-high;
regulator-boot-on;
- vcc3v3_pcie: vcc3v3-pcie {
enable-active-high;
+&pcie_phy {
- status = "okay";
+&pcie0 {
- ep-gpios = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>;
- num-lanes = <4>;
- pinctrl-names = "default";
- vpcie1v8-supply = <&vcc1v8_pmu>;
- vpcie0v9-supply = <&vcca_0v9>;
- status = "okay";
+&pinctrl {
- ngff {
- pcie {
+&sdio0 {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- keep-power-in-suspend;
- mmc-pwrseq = <&sdio_pwrseq>;
- non-removable;
- pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>;
- sd-uhs-sdr104;
- vmmc-supply = <&vcc3v3_ngff>;
- vqmmc-supply = <&vcc_1v8>;
- status = "okay";
+&uart0 {
- status = "okay";
Add Firefly ROC-RK3399-PC Mezzanine board which is an extension board on top of roc-rk3399-pc.
Will drop the separate defconfig file, once we support the board detection at runtime.
Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - include rk3399-roc-pc-u-boot.dtsi
.../dts/rk3399-roc-pc-mezzanine-u-boot.dtsi | 6 ++ board/firefly/roc-pc-rk3399/MAINTAINERS | 2 + configs/roc-pc-mezzanine-rk3399_defconfig | 67 +++++++++++++++++++ 3 files changed, 75 insertions(+) create mode 100644 arch/arm/dts/rk3399-roc-pc-mezzanine-u-boot.dtsi create mode 100644 configs/roc-pc-mezzanine-rk3399_defconfig
diff --git a/arch/arm/dts/rk3399-roc-pc-mezzanine-u-boot.dtsi b/arch/arm/dts/rk3399-roc-pc-mezzanine-u-boot.dtsi new file mode 100644 index 0000000000..f50c18dd3d --- /dev/null +++ b/arch/arm/dts/rk3399-roc-pc-mezzanine-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2020 Amarula Solutions(India) + */ + +#include "rk3399-roc-pc-u-boot.dtsi" diff --git a/board/firefly/roc-pc-rk3399/MAINTAINERS b/board/firefly/roc-pc-rk3399/MAINTAINERS index 7564dd252d..68a5b757d1 100644 --- a/board/firefly/roc-pc-rk3399/MAINTAINERS +++ b/board/firefly/roc-pc-rk3399/MAINTAINERS @@ -1,6 +1,8 @@ ROC-RK3399-PC M: Levin Du djw@t-chip.com.cn +M: Suniel Mahesh sunil@amarulasolutions.com S: Maintained F: board/firefly/roc-pc-rk3399 F: include/configs/roc-pc-rk3399.h F: configs/roc-pc-rk3399_defconfig +F: configs/roc-pc-mezzanine-rk3399_defconfig diff --git a/configs/roc-pc-mezzanine-rk3399_defconfig b/configs/roc-pc-mezzanine-rk3399_defconfig new file mode 100644 index 0000000000..5a694edc03 --- /dev/null +++ b/configs/roc-pc-mezzanine-rk3399_defconfig @@ -0,0 +1,67 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_ENV_OFFSET=0x3F8000 +CONFIG_ROCKCHIP_RK3399=y +CONFIG_TARGET_ROC_PC_RK3399=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-roc-pc-mezzanine.dtb" +CONFIG_DISPLAY_BOARDINFO_LATE=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 +CONFIG_TPL=y +CONFIG_TPL_GPIO_SUPPORT=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="rk3399-roc-pc-mezzanine" +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM_RK3399_LPDDR4=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_ROCKCHIP_SPI=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_ASIX88179=y +CONFIG_USB_ETHER_MCS7830=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USB_KEYBOARD=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_ERRNO_STR=y +CONFIG_DM_VIDEO=y +CONFIG_VIDEO_BPP16=y +CONFIG_VIDEO_BPP32=y +CONFIG_DISPLAY=y +CONFIG_VIDEO_ROCKCHIP=y +CONFIG_DISPLAY_ROCKCHIP_HDMI=y
Thanks, - Kever
Changes for v2:
- Copyright (c) 2020 Amarula Solutions(India)
Jagan Teki
Kever Yang
