[U-Boot] [PATCH] ARM: versatilepb : drop warnings due to double definitions
CONFIG_ARCH_VERSATILE_PB is defined twice - drop the define from config.h.
Signed-off-by: Stefano Babic sbabic@denx.de --- boards.cfg | 2 +- include/configs/versatile.h | 4 ---- 2 files changed, 1 insertions(+), 5 deletions(-)
diff --git a/boards.cfg b/boards.cfg index c31114d..198619d 100644 --- a/boards.cfg +++ b/boards.cfg @@ -77,7 +77,7 @@ voiceblue arm arm925t omap1510inn arm arm925t - ti integratorap_cm926ejs arm arm926ejs integrator armltd - integratorap integratorcp_cm926ejs arm arm926ejs integrator armltd - integratorcp -versatileqemu arm arm926ejs versatile armltd versatile versatile:ARCH_VERSATILE_QEMU +versatileqemu arm arm926ejs versatile armltd versatile versatile:ARCH_VERSATILE_QEMU,ARCH_VERSATILE_PB versatilepb arm arm926ejs versatile armltd versatile versatile:ARCH_VERSATILE_PB versatileab arm arm926ejs versatile armltd versatile versatile:ARCH_VERSATILE_AB aspenite arm arm926ejs - Marvell armada100 diff --git a/include/configs/versatile.h b/include/configs/versatile.h index 32cee82..3bfcdff 100644 --- a/include/configs/versatile.h +++ b/include/configs/versatile.h @@ -39,10 +39,6 @@ #define CONFIG_VERSATILE 1 /* in Versatile Platform Board */ #define CONFIG_ARCH_VERSATILE 1 /* Specifically, a Versatile */
-#ifndef CONFIG_ARCH_VERSATILE_AB /* AB */ -#define CONFIG_ARCH_VERSATILE_PB /* Versatile PB is default */ -#endif - #define CONFIG_SYS_MEMTEST_START 0x100000 #define CONFIG_SYS_MEMTEST_END 0x10000000 #define CONFIG_SYS_HZ (1000000 / 256)
Hi Stefano,
Signed-off-by: Stefano Babicsbabic@denx.de
This one is trivial enough a bugfix, which leaves all three boards with only the (unrelated) 'volatile' warning, so:
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Stefano Babic
