[U-Boot] [PATCH 1/2] ARM64: zynqmp: Add missing u-boot, dm-pre-reloc to DTSI
Add missing u-boot,dm-pre-reloc to get IPs initialized.
arch/arm/dts/zynqmp.dtsi | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/dts/zynqmp.dtsi b/arch/arm/dts/zynqmp.dtsi index c6ba8728075a..619450e1ba92 100644 --- a/arch/arm/dts/zynqmp.dtsi +++ b/arch/arm/dts/zynqmp.dtsi @@ -264,6 +264,7 @@
amba: amba { compatible = "simple-bus"; + u-boot,dm-pre-reloc; #address-cells = <2>; #size-cells = <1>; ranges = <0 0 0 0 0xffffffff>; @@ -674,6 +675,7 @@ };
sdhci0: sdhci@ff160000 { + u-boot,dm-pre-reloc; compatible = "arasan,sdhci-8.9a"; status = "disabled"; interrupt-parent = <&gic>; @@ -685,6 +687,7 @@ };
sdhci1: sdhci@ff170000 { + u-boot,dm-pre-reloc; compatible = "arasan,sdhci-8.9a"; status = "disabled"; interrupt-parent = <&gic>; @@ -776,6 +779,7 @@ };
uart0: serial@ff000000 { + u-boot,dm-pre-reloc; compatible = "cdns,uart-r1p12", "xlnx,xuartps"; status = "disabled"; interrupt-parent = <&gic>; @@ -786,6 +790,7 @@ };
uart1: serial@ff010000 { + u-boot,dm-pre-reloc; compatible = "cdns,uart-r1p12", "xlnx,xuartps"; status = "disabled"; interrupt-parent = <&gic>;
Support RAM and MMC boot mode in SPL also with SPL_FIT images.
In MMC boot mode two boot options are available: 1) Boot flow with ATF(EL3) and full U-Boot(EL2): aarch64-linux-gnu-objcopy -O binary bl31.elf bl31.bin mkimage -A arm64 -O linux -T kernel -C none -a 0xfffe5000 -e 0xfffe5000 -d bl31.bin atf.ub cp spl/boot.bin <sdcard fat partition> cp atf.ub <sdcard fat partition> cp u-boot.bin <sdcard fat partition>
2) Boot flow with full U-Boot(EL3): cp spl/boot.bin <sdcard> cp u-boot*.img <sdcard>
3) emmc boot mode dd if=/dev/zero of=sd.img bs=1024 count=1024 parted sd.img mktable msdos parted sd.img mkpart p fat32 0% 100% kpartx -a sd.img mkfs.vfat /dev/mapper/loop0p1 mount /dev/mapper/loop0p1 /mnt/ cp spl/boot.bin /mnt cp u-boot.img /mnt cp u-boot.bin /mnt cp atf.ub /mnt umount /dev/mapper/loop0p1 kpartx -d sd.img cp sd.img /tftpboot/
and program it via u-boot tftpb 10000 sd.img mmcinfo mmc write 10000 0 $filesize mmc rescan mmc part ls mmc 0
psu_init() function contains low level SoC setup generated for every HW design by Xilinx design tools. xil_io.h is only supporting file to fix all dependencies from tools. The same solution was used on Xilinx Zynq.
The patch also change CONFIG_SYS_INIT_SP_ADDR to the end of OCM which stays at the same location all the time. Bootrom expects starting address to be at 0xfffc0000 that's why this address is SPL_TEXT_BASE.
arch/arm/Kconfig | 1 + arch/arm/cpu/armv8/zynqmp/Makefile | 1 + arch/arm/cpu/armv8/zynqmp/spl.c | 107 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-zynqmp/sys_proto.h | 2 + board/xilinx/zynqmp/Makefile | 23 +++++- board/xilinx/zynqmp/xil_io.h | 35 +++++++++ include/configs/xilinx_zynqmp.h | 43 ++++++++++- 7 files changed, 209 insertions(+), 3 deletions(-) create mode 100644 arch/arm/cpu/armv8/zynqmp/spl.c create mode 100644 board/xilinx/zynqmp/xil_io.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 6b65d8e76a46..729b1816bf7e 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -594,6 +594,7 @@ config ARCH_ZYNQMP select DM select OF_CONTROL select DM_SERIAL + select SUPPORT_SPL
config TEGRA bool "NVIDIA Tegra" diff --git a/arch/arm/cpu/armv8/zynqmp/Makefile b/arch/arm/cpu/armv8/zynqmp/Makefile index d0ed2223ff79..be8673a7db44 100644 --- a/arch/arm/cpu/armv8/zynqmp/Makefile +++ b/arch/arm/cpu/armv8/zynqmp/Makefile @@ -9,3 +9,4 @@ obj-y += clk.o obj-y += cpu.o obj-$(CONFIG_MP) += mp.o obj-y += slcr.o +obj-$(CONFIG_SPL_BUILD) += spl.o diff --git a/arch/arm/cpu/armv8/zynqmp/spl.c b/arch/arm/cpu/armv8/zynqmp/spl.c new file mode 100644 index 000000000000..e3e2a4fb5ad3 --- /dev/null +++ b/arch/arm/cpu/armv8/zynqmp/spl.c @@ -0,0 +1,107 @@ +/* + * Copyright 2015 - 2016 Xilinx, Inc. + * + * Michal Simek michal.simek@xilinx.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <debug_uart.h> +#include <spl.h> + +#include <asm/io.h> +#include <asm/spl.h> +#include <asm/arch/hardware.h> +#include <asm/arch/sys_proto.h> + +void board_init_f(ulong dummy) +{ + psu_init(); + board_early_init_r(); + +#ifdef CONFIG_DEBUG_UART + /* Uart debug for sure */ + debug_uart_init(); + puts("Debug uart enabled\n"); /* or printch() */ +#endif + /* Delay is required for clocks to be propagated */ + udelay(1000000); + + /* Clear the BSS */ + memset(__bss_start, 0, __bss_end - __bss_start); + + /* No need to call timer init - it is empty for ZynqMP */ + board_init_r(NULL, 0); +} + +#ifdef CONFIG_SPL_BOARD_INIT +void spl_board_init(void) +{ + preloader_console_init(); + board_init(); +} +#endif + +u32 spl_boot_device(void) +{ + u32 reg = 0; + u8 bootmode; + + reg = readl(&crlapb_base->boot_mode); + bootmode = reg & BOOT_MODES_MASK; + + switch (bootmode) { + case JTAG_MODE: + return BOOT_DEVICE_RAM; +#ifdef CONFIG_SPL_MMC_SUPPORT + case EMMC_MODE: + case SD_MODE: + case SD_MODE1: + return BOOT_DEVICE_MMC1; +#endif + default: + printf("Invalid Boot Mode:0x%x\n", bootmode); + break; + } + + return 0; +} + +u32 spl_boot_mode(void) +{ + switch (spl_boot_device()) { + case BOOT_DEVICE_RAM: + return 0; + case BOOT_DEVICE_MMC1: + return MMCSD_MODE_FS; + default: + puts("spl: error: unsupported device\n"); + hang(); + } +} + +__weak void psu_init(void) +{ + /* + * This function is overridden by the one in + * board/xilinx/zynqmp/(platform)/psu_init_gpl.c, if it exists. + */ +} + +#ifdef CONFIG_SPL_OS_BOOT +int spl_start_uboot(void) +{ + return 0; +} +#endif + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + /* Just empty function now - can't decide what to choose */ + debug("%s: %s\n", __func__, name); + + return 0; +} +#endif diff --git a/arch/arm/include/asm/arch-zynqmp/sys_proto.h b/arch/arm/include/asm/arch-zynqmp/sys_proto.h index 021626dc1403..1db2bd6a4f7a 100644 --- a/arch/arm/include/asm/arch-zynqmp/sys_proto.h +++ b/arch/arm/include/asm/arch-zynqmp/sys_proto.h @@ -17,4 +17,6 @@ int zynq_slcr_get_mio_pin_status(const char *periph);
unsigned int zynqmp_get_silicon_version(void);
+void psu_init(void); + #endif /* _ASM_ARCH_SYS_PROTO_H */ diff --git a/board/xilinx/zynqmp/Makefile b/board/xilinx/zynqmp/Makefile index 2ab3f190ac30..90f00c650a81 100644 --- a/board/xilinx/zynqmp/Makefile +++ b/board/xilinx/zynqmp/Makefile @@ -1,8 +1,29 @@ # -# (C) Copyright 2014 - 2015 Xilinx, Inc. +# (C) Copyright 2014 - 2016 Xilinx, Inc. # Michal Simek michal.simek@xilinx.com # # SPDX-License-Identifier: GPL-2.0+ #
obj-y := zynqmp.o + +hw-platform-y :=$(shell echo $(CONFIG_SYS_CONFIG_NAME)) + +init-objs := $(if $(wildcard $(srctree)/$(src)/$(hw-platform-y)/psu_init_gpl.c),\ + $(hw-platform-y)/psu_init_gpl.o) + +ifeq ($(init-objs),) +ifneq ($(wildcard $(srctree)/$(src)/psu_init_gpl.c),) +init-objs := psu_init_gpl.o +$(if $(CONFIG_SPL_BUILD),\ +$(warning Put custom psu_init_gpl.c/h to board/xilinx/zynqmp/custom_hw_platform/)) +endif +endif + +obj-$(CONFIG_SPL_BUILD) += $(init-objs) + +# Suppress "warning: function declaration isn't a prototype" +CFLAGS_REMOVE_psu_init_gpl.o := -Wstrict-prototypes + +# To include xil_io.h +CFLAGS_psu_init_gpl.o := -I$(srctree)/$(src) diff --git a/board/xilinx/zynqmp/xil_io.h b/board/xilinx/zynqmp/xil_io.h new file mode 100644 index 000000000000..57ca4adf11bf --- /dev/null +++ b/board/xilinx/zynqmp/xil_io.h @@ -0,0 +1,35 @@ +/* + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef XIL_IO_H /* prevent circular inclusions */ +#define XIL_IO_H + +/* FIXME remove this when vivado is fixed */ +#include <asm/io.h> + +#define xil_printf(...) + +void Xil_ICacheEnable(void) +{} + +void Xil_DCacheEnable(void) +{} + +void Xil_ICacheDisable(void) +{} + +void Xil_DCacheDisable(void) +{} + +void Xil_Out32(unsigned long addr, unsigned long val) +{ + writel(val, addr); +} + +int Xil_In32(unsigned long addr) +{ + return readl(addr); +} + +#endif /* XIL_IO_H */ diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 56a1096b4f29..8039565b6e3f 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -41,7 +41,7 @@ # define CONFIG_IDENT_STRING " Xilinx ZynqMP" #endif
-#define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_INIT_SP_ADDR 0xfffffffc
/* Generic Timer Definitions - setup in EL3. Setup by ATF for other cases */ #if !defined(COUNTER_FREQUENCY) @@ -65,7 +65,9 @@ #define CONFIG_CMD_ENV #define CONFIG_DOS_PARTITION #define CONFIG_EFI_PARTITION -#define CONFIG_ISO_PARTITION +#ifndef CONFIG_SPL_BUILD +# define CONFIG_ISO_PARTITION +#endif #define CONFIG_MP
/* BOOTP options */ @@ -228,4 +230,41 @@ #define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_CLOCKS
+#define CONFIG_SPL_TEXT_BASE 0xfffc0000 +#define CONFIG_SPL_MAX_SIZE 0x20000 + +/* Just random location in OCM */ +#define CONFIG_SPL_BSS_START_ADDR 0x1000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x2000000 + +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_BOARD_INIT +#define CONFIG_SPL_RAM_DEVICE + +#define CONFIG_SPL_OS_BOOT +/* u-boot is like dtb */ +#define CONFIG_SPL_FS_LOAD_ARGS_NAME "u-boot.bin" +#define CONFIG_SYS_SPL_ARGS_ADDR 0x8000000 + +/* ATF is my kernel image */ +#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "atf.ub" + +/* FIT load address for RAM boot */ +#define CONFIG_SPL_LOAD_FIT_ADDRESS 0x10000000 + +/* MMC support */ +#ifdef CONFIG_ZYNQ_SDHCI +# define CONFIG_SPL_MMC_SUPPORT +# define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 +# define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0 /* unused */ +# define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS 0 /* unused */ +# define CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR 0 /* unused */ +# define CONFIG_SPL_LIBDISK_SUPPORT +# define CONFIG_SPL_FAT_SUPPORT +# define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" +#endif + #endif /* __XILINX_ZYNQMP_H */
Michal Simek
