[U-Boot] [PATCH] ls1028a: video: hdp: disable CONFIG_VIDEO as to fix build warning
Remove the dependency for VIDEO_IMX_HDP_LOAD as to fixing build warning.
=========================== WARNING =================================== This board does not use CONFIG_DM_VIDEO Please update the board to use CONFIG_DM_VIDEO before the v2019.07 release. Failure to update by the deadline may result in board removal. See doc/driver-model/MIGRATION.txt for more info. =======================================================================
Currently, LS1028A just has supported HDP firmware loading, doesn't supported display on U-boot. so we doesn't need to enable option VIDEO or DM_VIDEO on the LS1028A.
Signed-off-by: Wen He wen.he_1@nxp.com --- configs/ls1028aqds_tfa_defconfig | 1 - configs/ls1028ardb_tfa_defconfig | 1 - drivers/video/Kconfig | 2 +- 3 files changed, 1 insertion(+), 3 deletions(-)
diff --git a/configs/ls1028aqds_tfa_defconfig b/configs/ls1028aqds_tfa_defconfig index f1c0f4bad1..9e9be40bed 100644 --- a/configs/ls1028aqds_tfa_defconfig +++ b/configs/ls1028aqds_tfa_defconfig @@ -59,5 +59,4 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_VIDEO=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/ls1028ardb_tfa_defconfig b/configs/ls1028ardb_tfa_defconfig index 2c877f4966..2e98e940ba 100644 --- a/configs/ls1028ardb_tfa_defconfig +++ b/configs/ls1028ardb_tfa_defconfig @@ -60,7 +60,6 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_VIDEO=y CONFIG_WDT=y CONFIG_WDT_SP805=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 93fe333dcc..19c2e7c639 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -557,7 +557,7 @@ config VIDEO_IPUV3 config VIDEO_IMX_HDP_LOAD bool "i.MX8 HDMI/DP firmware loading" default y - depends on VIDEO && ARCH_LS1028A + depends on ARCH_LS1028A help Support for HDMI/DP firmware loading for i.MX8QM and LS1028A processors. The firmware is copied from system memory to the
Wen He
