[U-Boot] [PATCH] Add a CBFS driver and commands to u-boot
Coreboot uses a very simple "file system" called CBFS to keep track of and allow access to multiple "files" in a ROM image. This change adds CBFS support and some commands to use it to u-boot. These commands are:
cbfsinit - Initialize CBFS support and pull all metadata into RAM. The end of the ROM is an optional parameter which defaults to the standard 0xffffffff and can be used to support multiple CBFSes in a system. The last one set up with cbfsinit is the one that will be used.
cbfsinfo - Print information from the CBFS header.
cbfsls - Print out the size, type, and name of all the files in the current CBFS. Recognized types are translated into symbolic names.
cbfsload - Load a file from CBFS into memory. Like the similar command for fat filesystems, you can optionally provide a maximum size.
Also, if u-boot needs something out of CBFS very early before the heap is configured, it won't be able to use the normal CBFS support which caches some information in memory it allocates from the heap. This change adds a new cbfs_file_find_uncached function which searchs a CBFS instance without touching the heap.
Support for CBFS is compiled in when the CONFIG_CMD_CBFS option is specified.
Signed-off-by: Gabe Black gabeblack@chromium.org --- Makefile | 6 +- README | 1 + common/Makefile | 1 + common/cmd_cbfs.c | 212 ++++++++++++++++++++++++++++++++ fs/Makefile | 1 + fs/cbfs/Makefile | 44 +++++++ fs/cbfs/cbfs.c | 351 +++++++++++++++++++++++++++++++++++++++++++++++++++++ include/cbfs.h | 163 +++++++++++++++++++++++++ 8 files changed, 776 insertions(+), 3 deletions(-) create mode 100644 common/cmd_cbfs.c create mode 100644 fs/cbfs/Makefile create mode 100644 fs/cbfs/cbfs.c create mode 100644 include/cbfs.h
diff --git a/Makefile b/Makefile index d84b350..e1e2ff1 100644 --- a/Makefile +++ b/Makefile @@ -234,9 +234,9 @@ ifeq ($(CONFIG_OF_EMBED),y) LIBS += dts/libdts.o endif LIBS += arch/$(ARCH)/lib/lib$(ARCH).o -LIBS += fs/cramfs/libcramfs.o fs/fat/libfat.o fs/fdos/libfdos.o fs/jffs2/libjffs2.o \ - fs/reiserfs/libreiserfs.o fs/ext2/libext2fs.o fs/yaffs2/libyaffs2.o \ - fs/ubifs/libubifs.o +LIBS += fs/cramfs/libcramfs.o fs/fat/libfat.o fs/fdos/libfdos.o \ + fs/jffs2/libjffs2.o fs/reiserfs/libreiserfs.o fs/ext2/libext2fs.o \ + fs/yaffs2/libyaffs2.o fs/ubifs/libubifs.o fs/cbfs/libcbfs.o LIBS += net/libnet.o LIBS += disk/libdisk.o LIBS += drivers/bios_emulator/libatibiosemu.o diff --git a/README b/README index fda0190..b878c4b 100644 --- a/README +++ b/README @@ -721,6 +721,7 @@ The following options need to be configured: CONFIG_CMD_BSP * Board specific commands CONFIG_CMD_BOOTD bootd CONFIG_CMD_CACHE * icache, dcache + CONFIG_CMD_CBFS * Support for coreboot's CBFS CONFIG_CMD_CONSOLE coninfo CONFIG_CMD_CRC32 * crc32 CONFIG_CMD_DATE * support for RTC, date/time... diff --git a/common/Makefile b/common/Makefile index 1b672ad..6cfba67 100644 --- a/common/Makefile +++ b/common/Makefile @@ -89,6 +89,7 @@ COBJS-$(CONFIG_ENV_IS_IN_EEPROM) += cmd_eeprom.o COBJS-$(CONFIG_CMD_EEPROM) += cmd_eeprom.o COBJS-$(CONFIG_CMD_ELF) += cmd_elf.o COBJS-$(CONFIG_SYS_HUSH_PARSER) += cmd_exit.o +COBJS-$(CONFIG_CMD_CBFS) += cmd_cbfs.o COBJS-$(CONFIG_CMD_EXT2) += cmd_ext2.o COBJS-$(CONFIG_CMD_FAT) += cmd_fat.o COBJS-$(CONFIG_CMD_FDC)$(CONFIG_CMD_FDOS) += cmd_fdc.o diff --git a/common/cmd_cbfs.c b/common/cmd_cbfs.c new file mode 100644 index 0000000..a357831 --- /dev/null +++ b/common/cmd_cbfs.c @@ -0,0 +1,212 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * CBFS commands + */ +#include <common.h> +#include <command.h> +#include <cbfs.h> + +int do_cbfs_init(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + uintptr_t end_of_rom = 0xffffffff; + char *ep; + + if (argc > 2) { + printf("usage: cbfsls [end of rom]>\n"); + return 0; + } + if (argc == 2) { + end_of_rom = (int)simple_strtoul(argv[1], &ep, 16); + if (*ep) { + puts("\n** Invalid end of ROM **\n"); + return 1; + } + } + file_cbfs_init(end_of_rom); + if (file_cbfs_result != CBFS_SUCCESS) { + printf("%s.\n", file_cbfs_error()); + return 1; + } + return 0; +} + +U_BOOT_CMD( + cbfsinit, 2, 0, do_cbfs_init, + "initialize the cbfs driver", + "[end of rom]\n" + " - Initialize the cbfs driver. The optional 'end of rom'\n" + " parameter specifies where the end of the ROM is that the\n" + " CBFS is in. It defaults to 0xFFFFFFFF\n" +); + +int do_cbfs_fsload (cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + long size; + unsigned long offset; + unsigned long count; + char buf[12]; + CbfsFile file; + + if (argc < 3) { + printf("usage: cbfsload <addr> <filename> [bytes]\n"); + return 1; + } + + /* parse offset and count */ + offset = simple_strtoul(argv[1], NULL, 16); + if (argc == 4) + count = simple_strtoul(argv[3], NULL, 16); + else + count = 0; + + file = file_cbfs_find(argv[2]); + if (!file) { + if (file_cbfs_result == CBFS_FILE_NOT_FOUND) + printf("%s: %s\n", file_cbfs_error(), argv[2]); + else + printf("%s.\n", file_cbfs_error()); + return 1; + } + + printf("reading %s\n", file_cbfs_name(file)); + + size = file_cbfs_read(file, (void *)offset, count); + + printf("\n%ld bytes read\n", size); + + sprintf(buf, "%lX", size); + setenv("filesize", buf); + + return 0; +} + +U_BOOT_CMD( + cbfsload, 4, 0, do_cbfs_fsload, + "load binary file from a cbfs filesystem", + "<addr> <filename> [bytes]\n" + " - load binary file 'filename' from the cbfs to address 'addr'\n" +); + +int do_cbfs_ls (cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + CbfsFile file = file_cbfs_get_first(); + int files = 0; + + if (!file) { + printf("%s.\n", file_cbfs_error()); + return 1; + } + + printf(" size type name\n"); + printf("------------------------------------------\n"); + while (file) { + u32 type = file_cbfs_type(file); + char *typeName = NULL; + const char *filename = file_cbfs_name(file); + printf(" %8d", file_cbfs_size(file)); + + switch (type) { + case CBFS_TYPE_STAGE: + typeName = "stage"; + break; + case CBFS_TYPE_PAYLOAD: + typeName = "payload"; + break; + case CBFS_TYPE_OPTIONROM: + typeName = "option rom"; + break; + case CBFS_TYPE_BOOTSPLASH: + typeName = "boot splash"; + break; + case CBFS_TYPE_RAW: + typeName = "raw"; + break; + case CBFS_TYPE_VSA: + typeName = "vsa"; + break; + case CBFS_TYPE_MBI: + typeName = "mbi"; + break; + case CBFS_TYPE_MICROCODE: + typeName = "microcode"; + break; + case CBFS_COMPONENT_CMOS_DEFAULT: + typeName = "cmos default"; + break; + case CBFS_COMPONENT_CMOS_LAYOUT: + typeName = "cmos layout"; + break; + case -1UL: + typeName = "null"; + break; + } + if (typeName) + printf(" %16s", typeName); + else + printf(" %16d", type); + + if (filename[0]) + printf(" %s\n", filename); + else + printf(" %s\n", "(empty)"); + file_cbfs_get_next(&file); + files++; + } + + printf("\n%d file(s)\n\n", files); + return 0; +} + +U_BOOT_CMD( + cbfsls, 1, 1, do_cbfs_ls, + "list files", + " - list the files in the cbfs\n" +); + +int do_cbfs_fsinfo (cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + const CbfsHeader *header = file_cbfs_get_header(); + if (!header) { + printf("%s.\n", file_cbfs_error()); + return 1; + } + + printf("\n"); + printf("CBFS version: %#x\n", header->version); + printf("ROM size: %#x\n", header->romSize); + printf("Boot block size: %#x\n", header->bootBlockSize); + printf("CBFS size: %#x\n", + header->romSize - header->bootBlockSize - header->offset); + printf("Alignment: %d\n", header->align); + printf("Offset: %#x\n", header->offset); + printf("\n"); + + return 0; +} + +U_BOOT_CMD( + cbfsinfo, 1, 1, do_cbfs_fsinfo, + "print information about filesystem", + " - print information about the cbfs filesystem\n" +); diff --git a/fs/Makefile b/fs/Makefile index 22aad12..ca21464 100644 --- a/fs/Makefile +++ b/fs/Makefile @@ -23,6 +23,7 @@ #
subdirs-$(CONFIG_CMD_CRAMFS) := cramfs +subdirs-$(CONFIG_CMD_CBFS) += cbfs subdirs-$(CONFIG_CMD_EXT2) += ext2 subdirs-$(CONFIG_CMD_FAT) += fat subdirs-$(CONFIG_CMD_FDOS) += fdos diff --git a/fs/cbfs/Makefile b/fs/cbfs/Makefile new file mode 100644 index 0000000..864fdf9 --- /dev/null +++ b/fs/cbfs/Makefile @@ -0,0 +1,44 @@ +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)libcbfs.o + +AOBJS = +COBJS-$(CONFIG_CMD_CBFS) := cbfs.o + +SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) + +all: $(LIB) $(AOBJS) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/fs/cbfs/cbfs.c b/fs/cbfs/cbfs.c new file mode 100644 index 0000000..1a6ec2c --- /dev/null +++ b/fs/cbfs/cbfs.c @@ -0,0 +1,351 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <cbfs.h> +#include <malloc.h> +#include <asm/byteorder.h> + +CbfsResult file_cbfs_result; + +const char *file_cbfs_error(void) +{ + switch (file_cbfs_result) { + case CBFS_SUCCESS: + return "Success"; + case CBFS_NOT_INITIALIZED: + return "CBFS not initialized"; + case CBFS_BAD_HEADER: + return "Bad CBFS header"; + case CBFS_BAD_FILE: + return "Bad CBFS file"; + case CBFS_FILE_NOT_FOUND: + return "File not found"; + default: + return "Unknown"; + } +} + +typedef struct CbfsFileHeader { + u8 magic[8]; + u32 len; + u32 type; + u32 checksum; + u32 offset; +} __attribute__((packed)) CbfsFileHeader; + +typedef struct CbfsCacheNode { + struct CbfsCacheNode *next; + u32 type; + void *data; + u32 dataLength; + char *name; + u32 nameLength; + u32 checksum; +} __attribute__((packed)) CbfsCacheNode; + + +static const u32 goodMagic = 0x4f524243; +static const u8 goodFileMagic[] = "LARCHIVE"; + + +static int initialized; +static struct CbfsHeader cbfsHeader; +static CbfsCacheNode *fileCache; + +/* Do endian conversion on the CBFS header structure. */ +static void swap_header(CbfsHeader *dest, CbfsHeader *src) +{ + dest->magic = be32_to_cpu(src->magic); + dest->version = be32_to_cpu(src->version); + dest->romSize = be32_to_cpu(src->romSize); + dest->bootBlockSize = be32_to_cpu(src->bootBlockSize); + dest->align = be32_to_cpu(src->align); + dest->offset = be32_to_cpu(src->offset); +} + +/* Do endian conversion on a CBFS file header. */ +static void swap_file_header(CbfsFileHeader *dest, CbfsFileHeader *src) +{ + memcpy(&dest->magic, &src->magic, sizeof(dest->magic)); + dest->len = be32_to_cpu(src->len); + dest->type = be32_to_cpu(src->type); + dest->checksum = be32_to_cpu(src->checksum); + dest->offset = be32_to_cpu(src->offset); +} + +/* + * Given a starting position in memory, scan forward, bounded by a size, and + * find the next valid CBFS file. No memory is allocated by this function. The + * caller is responsible for allocating space for the new file structure. + * + * @param start The location in memory to start from. + * @param size The size of the memory region to search. + * @param align The alignment boundaries to check on. + * @param newNode A pointer to the file structure to load. + * @param used A pointer to the count of of bytes scanned through, + * including the file if one is found. + * + * @return 1 if a file is found, 0 if one isn't. + */ +static int file_cbfs_next_file(u8 *start, u32 size, u32 align, + CbfsCacheNode *newNode, u32 *used) +{ + CbfsFileHeader header; + + *used = 0; + + while (size >= align) { + CbfsFileHeader *fileHeader = (CbfsFileHeader *)start; + u32 nameLen; + u32 step; + + /* Check if there's a file here. */ + if (memcmp(goodFileMagic, &(fileHeader->magic), + sizeof(fileHeader->magic))) { + *used += align; + size -= align; + start += align; + continue; + } + + swap_file_header(&header, fileHeader); + if (header.offset < sizeof(CbfsFileHeader) || + header.offset > header.len) { + file_cbfs_result = CBFS_BAD_FILE; + return -1; + } + newNode->next = NULL; + newNode->type = header.type; + newNode->data = start + header.offset; + newNode->dataLength = header.len; + nameLen = header.offset - sizeof(CbfsFileHeader); + newNode->name = (char *)fileHeader + sizeof(CbfsFileHeader); + newNode->nameLength = nameLen; + newNode->checksum = header.checksum; + + step = header.len; + if (step % align) + step = step + align - step % align; + + *used += step; + return 1; + } + return 0; +} + +/* Look through a CBFS instance and copy file metadata into regular memory. */ +static void file_cbfs_fill_cache(u8 *start, u32 size, u32 align) +{ + CbfsCacheNode *cacheNode; + CbfsCacheNode *newNode; + CbfsCacheNode **cacheTail = &fileCache; + + /* Clear out old information. */ + cacheNode = fileCache; + while (cacheNode) { + CbfsCacheNode *oldNode = cacheNode; + cacheNode = cacheNode->next; + free(oldNode); + } + fileCache = NULL; + + while (size >= align) { + int result; + u32 used; + + newNode = (CbfsCacheNode *)malloc(sizeof(CbfsCacheNode)); + result = file_cbfs_next_file(start, size, align, + newNode, &used); + + if (result < 0) { + free(newNode); + return; + } else if (result == 0) { + free(newNode); + break; + } + *cacheTail = newNode; + cacheTail = &newNode->next; + + size -= used; + start += used; + } + file_cbfs_result = CBFS_SUCCESS; +} + +/* Get the CBFS header out of the ROM and do endian conversion. */ +static int file_cbfs_load_header(uintptr_t endOfRom, CbfsHeader *header) +{ + CbfsHeader *headerInRom; + + headerInRom = (CbfsHeader *)(uintptr_t)*(u32 *)(endOfRom - 3); + swap_header(header, headerInRom); + + if (header->magic != goodMagic || header->offset > + header->romSize - header->bootBlockSize) { + file_cbfs_result = CBFS_BAD_HEADER; + return 1; + } + return 0; +} + +void file_cbfs_init(uintptr_t endOfRom) +{ + u8 *startOfRom; + initialized = 0; + + if (file_cbfs_load_header(endOfRom, &cbfsHeader)) + return; + + startOfRom = (u8 *)(endOfRom + 1 - cbfsHeader.romSize); + + file_cbfs_fill_cache(startOfRom + cbfsHeader.offset, + cbfsHeader.romSize, cbfsHeader.align); + if (file_cbfs_result == CBFS_SUCCESS) + initialized = 1; +} + +const CbfsHeader *file_cbfs_get_header(void) +{ + if (initialized) { + file_cbfs_result = CBFS_SUCCESS; + return &cbfsHeader; + } else { + file_cbfs_result = CBFS_NOT_INITIALIZED; + return NULL; + } +} + +CbfsFile file_cbfs_get_first(void) +{ + if (!initialized) { + file_cbfs_result = CBFS_NOT_INITIALIZED; + return NULL; + } else { + file_cbfs_result = CBFS_SUCCESS; + return fileCache; + } +} + +void file_cbfs_get_next(CbfsFile *file) +{ + if (!initialized) { + file_cbfs_result = CBFS_NOT_INITIALIZED; + file = NULL; + return; + } + + if (*file) + *file = (*file)->next; + file_cbfs_result = CBFS_SUCCESS; +} + +CbfsFile file_cbfs_find(const char *name) +{ + struct CbfsCacheNode *cacheNode = fileCache; + + if (!initialized) { + file_cbfs_result = CBFS_NOT_INITIALIZED; + return NULL; + } + + while (cacheNode) { + if (!strcmp(name, cacheNode->name)) + break; + cacheNode = cacheNode->next; + } + if (!cacheNode) { + file_cbfs_result = CBFS_FILE_NOT_FOUND; + } else { + file_cbfs_result = CBFS_SUCCESS; + } + return cacheNode; +} + +CbfsFile file_cbfs_find_uncached(uintptr_t endOfRom, const char *name) +{ + u8 *start; + u32 size; + u32 align; + static CbfsCacheNode node; + + if (file_cbfs_load_header(endOfRom, &cbfsHeader)) + return NULL; + + start = (u8 *)(endOfRom + 1 - cbfsHeader.romSize); + size = cbfsHeader.romSize; + align = cbfsHeader.align; + + while (size >= align) { + int result; + u32 used; + + result = file_cbfs_next_file(start, size, align, &node, &used); + + if (result < 0) { + return NULL; + } else if (result == 0) { + break; + } + + if (!strcmp(name, node.name)) { + return &node; + } + + size -= used; + start += used; + } + file_cbfs_result = CBFS_FILE_NOT_FOUND; + return NULL; +} + +const char *file_cbfs_name(CbfsFile file) +{ + file_cbfs_result = CBFS_SUCCESS; + return file->name; +} + +u32 file_cbfs_size(CbfsFile file) +{ + file_cbfs_result = CBFS_SUCCESS; + return file->dataLength; +} + +u32 file_cbfs_type(CbfsFile file) +{ + file_cbfs_result = CBFS_SUCCESS; + return file->type; +} + +long file_cbfs_read(CbfsFile file, void *buffer, unsigned long maxsize) +{ + u32 size; + + size = file->dataLength; + if (maxsize && size > maxsize) + size = maxsize; + + memcpy(buffer, file->data, size); + + file_cbfs_result = CBFS_SUCCESS; + return size; +} diff --git a/include/cbfs.h b/include/cbfs.h new file mode 100644 index 0000000..eaab6b6 --- /dev/null +++ b/include/cbfs.h @@ -0,0 +1,163 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CBFS_H +#define __CBFS_H + +#include <compiler.h> + +typedef enum CbfsResult { + CBFS_SUCCESS = 0, + CBFS_NOT_INITIALIZED, + CBFS_BAD_HEADER, + CBFS_BAD_FILE, + CBFS_FILE_NOT_FOUND +} CbfsResult; + +typedef enum CbfsFileType { + CBFS_TYPE_STAGE = 0x10, + CBFS_TYPE_PAYLOAD = 0x20, + CBFS_TYPE_OPTIONROM = 0x30, + CBFS_TYPE_BOOTSPLASH = 0x40, + CBFS_TYPE_RAW = 0x50, + CBFS_TYPE_VSA = 0x51, + CBFS_TYPE_MBI = 0x52, + CBFS_TYPE_MICROCODE = 0x53, + CBFS_COMPONENT_CMOS_DEFAULT = 0xaa, + CBFS_COMPONENT_CMOS_LAYOUT = 0x01aa +} CbfsFileType; + +typedef struct CbfsHeader { + u32 magic; + u32 version; + u32 romSize; + u32 bootBlockSize; + u32 align; + u32 offset; + u32 pad[2]; +} __attribute__((packed)) CbfsHeader; + +struct CbfsCacheNode; +typedef const struct CbfsCacheNode *CbfsFile; + +extern CbfsResult file_cbfs_result; + +/* + * Return a string describing the most recent error condition. + * + * @return A pointer to the constant string. + */ +const char *file_cbfs_error(void); + +/* + * Initialize the CBFS driver and load metadata into RAM. + * + * @param end_of_rom Points to the end of the ROM the CBFS should be read + * from. + */ +void file_cbfs_init(uintptr_t end_of_rom); + +/* + * Get the header structure for the current CBFS. + * + * @return A pointer to the constant structure, or NULL if there is none. + */ +const CbfsHeader *file_cbfs_get_header(void); + +/* + * Get a handle for the first file in CBFS. + * + * @return A handle for the first file in CBFS, NULL on error. + */ +CbfsFile file_cbfs_get_first(void); + +/* + * Get a handle to the file after this one in CBFS. + * + * @param file A pointer to the handle to advance. + */ +void file_cbfs_get_next(CbfsFile *file); + +/* + * Find a file with a particular name in CBFS. + * + * @param name The name to search for. + * + * @return A handle to the file, or NULL on error. + */ +CbfsFile file_cbfs_find(const char *name); + + +/***************************************************************************/ +/* All of the functions below can be used without first initializing CBFS. */ +/***************************************************************************/ + +/* + * Find a file with a particular name in CBFS without using the heap. + * + * @param end_of_rom Points to the end of the ROM the CBFS should be read + * from. + * @param name The name to search for. + * + * @return A handle to the file, or NULL on error. + */ +CbfsFile file_cbfs_find_uncached(uintptr_t end_of_rom, const char *name); + +/* + * Get the name of a file in CBFS. + * + * @param file The handle to the file. + * + * @return The name of the file, NULL on error. + */ +const char *file_cbfs_name(CbfsFile file); + +/* + * Get the size of a file in CBFS. + * + * @param file The handle to the file. + * + * @return The size of the file, zero on error. + */ +u32 file_cbfs_size(CbfsFile file); + +/* + * Get the type of a file in CBFS. + * + * @param file The handle to the file. + * + * @return The type of the file, zero on error. + */ +u32 file_cbfs_type(CbfsFile file); + +/* + * Read a file from CBFS into RAM + * + * @param file A handle to the file to read. + * @param buffer Where to read it into memory. + * + * @return If positive or zero, the number of characters read. If negative, an + * error occurred. + */ +long file_cbfs_read(CbfsFile file, void *buffer, unsigned long maxsize); + +#endif /* __CBFS_H */
Dear Gabe Black,
In message 1322912821-32677-1-git-send-email-gabeblack@chromium.org you wrote:
Checkpatch reports 2 errors, 15 warnings
Please clean up and resubmit.
Also, please use puts() instead of printf() when you have constant strings without formatting.
And fix your identifiers: CamelCaps identifiers are not allowed in U-Boot.
On Mon, Dec 5, 2011 at 2:25 PM, Wolfgang Denk wd@denx.de wrote:
Dear Gabe Black,
and
end of
0xffffffff and
with
current
for fat
some
touching
the heap.
specified.
A few of these are checkpatch getting confused by inline assembly, but I'll fix up the rest and the things below.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de The human race is faced with a cruel choice: work or daytime tele- vision.
Dear Gabe Black,
and
end of
0xffffffff and
with
current
for fat
is
caches some
touching
the heap.
specified.
Oops, wrong patch series. There's no inline assembly in this one.
Gabe
Signed-off-by: Gabe Black gabeblack@chromium.org --- Changes in v2: Fix checkpatch problems, change around identifiers, and change printf to puts where possible.
Makefile | 6 +- README | 1 + common/Makefile | 1 + common/cmd_cbfs.c | 212 ++++++++++++++++++++++++++++++++ fs/Makefile | 1 + fs/cbfs/Makefile | 44 +++++++ fs/cbfs/cbfs.c | 354 +++++++++++++++++++++++++++++++++++++++++++++++++++++ include/cbfs.h | 164 +++++++++++++++++++++++++ 8 files changed, 780 insertions(+), 3 deletions(-) create mode 100644 common/cmd_cbfs.c create mode 100644 fs/cbfs/Makefile create mode 100644 fs/cbfs/cbfs.c create mode 100644 include/cbfs.h
diff --git a/Makefile b/Makefile index d84b350..e1e2ff1 100644 --- a/Makefile +++ b/Makefile @@ -234,9 +234,9 @@ ifeq ($(CONFIG_OF_EMBED),y) LIBS += dts/libdts.o endif LIBS += arch/$(ARCH)/lib/lib$(ARCH).o -LIBS += fs/cramfs/libcramfs.o fs/fat/libfat.o fs/fdos/libfdos.o fs/jffs2/libjffs2.o \ - fs/reiserfs/libreiserfs.o fs/ext2/libext2fs.o fs/yaffs2/libyaffs2.o \ - fs/ubifs/libubifs.o +LIBS += fs/cramfs/libcramfs.o fs/fat/libfat.o fs/fdos/libfdos.o \ + fs/jffs2/libjffs2.o fs/reiserfs/libreiserfs.o fs/ext2/libext2fs.o \ + fs/yaffs2/libyaffs2.o fs/ubifs/libubifs.o fs/cbfs/libcbfs.o LIBS += net/libnet.o LIBS += disk/libdisk.o LIBS += drivers/bios_emulator/libatibiosemu.o diff --git a/README b/README index fda0190..b878c4b 100644 --- a/README +++ b/README @@ -721,6 +721,7 @@ The following options need to be configured: CONFIG_CMD_BSP * Board specific commands CONFIG_CMD_BOOTD bootd CONFIG_CMD_CACHE * icache, dcache + CONFIG_CMD_CBFS * Support for coreboot's CBFS CONFIG_CMD_CONSOLE coninfo CONFIG_CMD_CRC32 * crc32 CONFIG_CMD_DATE * support for RTC, date/time... diff --git a/common/Makefile b/common/Makefile index 1b672ad..6cfba67 100644 --- a/common/Makefile +++ b/common/Makefile @@ -89,6 +89,7 @@ COBJS-$(CONFIG_ENV_IS_IN_EEPROM) += cmd_eeprom.o COBJS-$(CONFIG_CMD_EEPROM) += cmd_eeprom.o COBJS-$(CONFIG_CMD_ELF) += cmd_elf.o COBJS-$(CONFIG_SYS_HUSH_PARSER) += cmd_exit.o +COBJS-$(CONFIG_CMD_CBFS) += cmd_cbfs.o COBJS-$(CONFIG_CMD_EXT2) += cmd_ext2.o COBJS-$(CONFIG_CMD_FAT) += cmd_fat.o COBJS-$(CONFIG_CMD_FDC)$(CONFIG_CMD_FDOS) += cmd_fdc.o diff --git a/common/cmd_cbfs.c b/common/cmd_cbfs.c new file mode 100644 index 0000000..5936588 --- /dev/null +++ b/common/cmd_cbfs.c @@ -0,0 +1,212 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. All rights reserved. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * CBFS commands + */ +#include <common.h> +#include <command.h> +#include <cbfs.h> + +int do_cbfs_init(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + uintptr_t end_of_rom = 0xffffffff; + char *ep; + + if (argc > 2) { + puts("usage: cbfsls [end of rom]>\n"); + return 0; + } + if (argc == 2) { + end_of_rom = (int)simple_strtoul(argv[1], &ep, 16); + if (*ep) { + puts("\n** Invalid end of ROM **\n"); + return 1; + } + } + file_cbfs_init(end_of_rom); + if (file_cbfs_result != CBFS_SUCCESS) { + printf("%s.\n", file_cbfs_error()); + return 1; + } + return 0; +} + +U_BOOT_CMD( + cbfsinit, 2, 0, do_cbfs_init, + "initialize the cbfs driver", + "[end of rom]\n" + " - Initialize the cbfs driver. The optional 'end of rom'\n" + " parameter specifies where the end of the ROM is that the\n" + " CBFS is in. It defaults to 0xFFFFFFFF\n" +); + +int do_cbfs_fsload(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + long size; + unsigned long offset; + unsigned long count; + char buf[12]; + cbfs_file file; + + if (argc < 3) { + puts("usage: cbfsload <addr> <filename> [bytes]\n"); + return 1; + } + + /* parse offset and count */ + offset = simple_strtoul(argv[1], NULL, 16); + if (argc == 4) + count = simple_strtoul(argv[3], NULL, 16); + else + count = 0; + + file = file_cbfs_find(argv[2]); + if (!file) { + if (file_cbfs_result == CBFS_FILE_NOT_FOUND) + printf("%s: %s\n", file_cbfs_error(), argv[2]); + else + printf("%s.\n", file_cbfs_error()); + return 1; + } + + printf("reading %s\n", file_cbfs_name(file)); + + size = file_cbfs_read(file, (void *)offset, count); + + printf("\n%ld bytes read\n", size); + + sprintf(buf, "%lX", size); + setenv("filesize", buf); + + return 0; +} + +U_BOOT_CMD( + cbfsload, 4, 0, do_cbfs_fsload, + "load binary file from a cbfs filesystem", + "<addr> <filename> [bytes]\n" + " - load binary file 'filename' from the cbfs to address 'addr'\n" +); + +int do_cbfs_ls(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + cbfs_file file = file_cbfs_get_first(); + int files = 0; + + if (!file) { + printf("%s.\n", file_cbfs_error()); + return 1; + } + + puts(" size type name\n"); + puts("------------------------------------------\n"); + while (file) { + u32 type = file_cbfs_type(file); + char *type_name = NULL; + const char *filename = file_cbfs_name(file); + printf(" %8d", file_cbfs_size(file)); + + switch (type) { + case CBFS_TYPE_STAGE: + type_name = "stage"; + break; + case CBFS_TYPE_PAYLOAD: + type_name = "payload"; + break; + case CBFS_TYPE_OPTIONROM: + type_name = "option rom"; + break; + case CBFS_TYPE_BOOTSPLASH: + type_name = "boot splash"; + break; + case CBFS_TYPE_RAW: + type_name = "raw"; + break; + case CBFS_TYPE_VSA: + type_name = "vsa"; + break; + case CBFS_TYPE_MBI: + type_name = "mbi"; + break; + case CBFS_TYPE_MICROCODE: + type_name = "microcode"; + break; + case CBFS_COMPONENT_CMOS_DEFAULT: + type_name = "cmos default"; + break; + case CBFS_COMPONENT_CMOS_LAYOUT: + type_name = "cmos layout"; + break; + case -1UL: + type_name = "null"; + break; + } + if (type_name) + printf(" %16s", type_name); + else + printf(" %16d", type); + + if (filename[0]) + printf(" %s\n", filename); + else + printf(" %s\n", "(empty)"); + file_cbfs_get_next(&file); + files++; + } + + printf("\n%d file(s)\n\n", files); + return 0; +} + +U_BOOT_CMD( + cbfsls, 1, 1, do_cbfs_ls, + "list files", + " - list the files in the cbfs\n" +); + +int do_cbfs_fsinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + const struct cbfs_header *header = file_cbfs_get_header(); + if (!header) { + printf("%s.\n", file_cbfs_error()); + return 1; + } + + puts("\n"); + printf("CBFS version: %#x\n", header->version); + printf("ROM size: %#x\n", header->rom_size); + printf("Boot block size: %#x\n", header->boot_block_size); + printf("CBFS size: %#x\n", + header->rom_size - header->boot_block_size - header->offset); + printf("Alignment: %d\n", header->align); + printf("Offset: %#x\n", header->offset); + puts("\n"); + + return 0; +} + +U_BOOT_CMD( + cbfsinfo, 1, 1, do_cbfs_fsinfo, + "print information about filesystem", + " - print information about the cbfs filesystem\n" +); diff --git a/fs/Makefile b/fs/Makefile index 22aad12..ca21464 100644 --- a/fs/Makefile +++ b/fs/Makefile @@ -23,6 +23,7 @@ #
subdirs-$(CONFIG_CMD_CRAMFS) := cramfs +subdirs-$(CONFIG_CMD_CBFS) += cbfs subdirs-$(CONFIG_CMD_EXT2) += ext2 subdirs-$(CONFIG_CMD_FAT) += fat subdirs-$(CONFIG_CMD_FDOS) += fdos diff --git a/fs/cbfs/Makefile b/fs/cbfs/Makefile new file mode 100644 index 0000000..864fdf9 --- /dev/null +++ b/fs/cbfs/Makefile @@ -0,0 +1,44 @@ +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)libcbfs.o + +AOBJS = +COBJS-$(CONFIG_CMD_CBFS) := cbfs.o + +SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) + +all: $(LIB) $(AOBJS) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/fs/cbfs/cbfs.c b/fs/cbfs/cbfs.c new file mode 100644 index 0000000..1a7eed0 --- /dev/null +++ b/fs/cbfs/cbfs.c @@ -0,0 +1,354 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. All rights reserved. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <cbfs.h> +#include <malloc.h> +#include <asm/byteorder.h> + +enum cbfs_result file_cbfs_result; + +const char *file_cbfs_error(void) +{ + switch (file_cbfs_result) { + case CBFS_SUCCESS: + return "Success"; + case CBFS_NOT_INITIALIZED: + return "CBFS not initialized"; + case CBFS_BAD_HEADER: + return "Bad CBFS header"; + case CBFS_BAD_FILE: + return "Bad CBFS file"; + case CBFS_FILE_NOT_FOUND: + return "File not found"; + default: + return "Unknown"; + } +} + +struct cbfs_file_header { + u8 magic[8]; + u32 len; + u32 type; + u32 checksum; + u32 offset; +} __packed; + +struct cbfs_cache_node { + struct cbfs_cache_node *next; + u32 type; + void *data; + u32 data_length; + char *name; + u32 name_length; + u32 checksum; +} __packed; + + +static const u32 good_magic = 0x4f524243; +static const u8 good_file_magic[] = "LARCHIVE"; + + +static int initialized; +static struct cbfs_header cbfs_header; +static struct cbfs_cache_node *file_cache; + +/* Do endian conversion on the CBFS header structure. */ +static void swap_header(struct cbfs_header *dest, struct cbfs_header *src) +{ + dest->magic = be32_to_cpu(src->magic); + dest->version = be32_to_cpu(src->version); + dest->rom_size = be32_to_cpu(src->rom_size); + dest->boot_block_size = be32_to_cpu(src->boot_block_size); + dest->align = be32_to_cpu(src->align); + dest->offset = be32_to_cpu(src->offset); +} + +/* Do endian conversion on a CBFS file header. */ +static void swap_file_header(struct cbfs_file_header *dest, + struct cbfs_file_header *src) +{ + memcpy(&dest->magic, &src->magic, sizeof(dest->magic)); + dest->len = be32_to_cpu(src->len); + dest->type = be32_to_cpu(src->type); + dest->checksum = be32_to_cpu(src->checksum); + dest->offset = be32_to_cpu(src->offset); +} + +/* + * Given a starting position in memory, scan forward, bounded by a size, and + * find the next valid CBFS file. No memory is allocated by this function. The + * caller is responsible for allocating space for the new file structure. + * + * @param start The location in memory to start from. + * @param size The size of the memory region to search. + * @param align The alignment boundaries to check on. + * @param newNode A pointer to the file structure to load. + * @param used A pointer to the count of of bytes scanned through, + * including the file if one is found. + * + * @return 1 if a file is found, 0 if one isn't. + */ +static int file_cbfs_next_file(u8 *start, u32 size, u32 align, + struct cbfs_cache_node *new_node, u32 *used) +{ + struct cbfs_file_header header; + + *used = 0; + + while (size >= align) { + struct cbfs_file_header *file_header = + (struct cbfs_file_header *)start; + u32 name_len; + u32 step; + + /* Check if there's a file here. */ + if (memcmp(good_file_magic, &(file_header->magic), + sizeof(file_header->magic))) { + *used += align; + size -= align; + start += align; + continue; + } + + swap_file_header(&header, file_header); + if (header.offset < sizeof(struct cbfs_file_header) || + header.offset > header.len) { + file_cbfs_result = CBFS_BAD_FILE; + return -1; + } + new_node->next = NULL; + new_node->type = header.type; + new_node->data = start + header.offset; + new_node->data_length = header.len; + name_len = header.offset - sizeof(struct cbfs_file_header); + new_node->name = (char *)file_header + + sizeof(struct cbfs_file_header); + new_node->name_length = name_len; + new_node->checksum = header.checksum; + + step = header.len; + if (step % align) + step = step + align - step % align; + + *used += step; + return 1; + } + return 0; +} + +/* Look through a CBFS instance and copy file metadata into regular memory. */ +static void file_cbfs_fill_cache(u8 *start, u32 size, u32 align) +{ + struct cbfs_cache_node *cache_node; + struct cbfs_cache_node *new_node; + struct cbfs_cache_node **cache_tail = &file_cache; + + /* Clear out old information. */ + cache_node = file_cache; + while (cache_node) { + struct cbfs_cache_node *old_node = cache_node; + cache_node = cache_node->next; + free(old_node); + } + file_cache = NULL; + + while (size >= align) { + int result; + u32 used; + + new_node = (struct cbfs_cache_node *) + malloc(sizeof(struct cbfs_cache_node)); + result = file_cbfs_next_file(start, size, align, + new_node, &used); + + if (result < 0) { + free(new_node); + return; + } else if (result == 0) { + free(new_node); + break; + } + *cache_tail = new_node; + cache_tail = &new_node->next; + + size -= used; + start += used; + } + file_cbfs_result = CBFS_SUCCESS; +} + +/* Get the CBFS header out of the ROM and do endian conversion. */ +static int file_cbfs_load_header(uintptr_t end_of_rom, + struct cbfs_header *header) +{ + struct cbfs_header *header_in_rom; + + header_in_rom = (struct cbfs_header *)(uintptr_t) + *(u32 *)(end_of_rom - 3); + swap_header(header, header_in_rom); + + if (header->magic != good_magic || header->offset > + header->rom_size - header->boot_block_size) { + file_cbfs_result = CBFS_BAD_HEADER; + return 1; + } + return 0; +} + +void file_cbfs_init(uintptr_t end_of_rom) +{ + u8 *start_of_rom; + initialized = 0; + + if (file_cbfs_load_header(end_of_rom, &cbfs_header)) + return; + + start_of_rom = (u8 *)(end_of_rom + 1 - cbfs_header.rom_size); + + file_cbfs_fill_cache(start_of_rom + cbfs_header.offset, + cbfs_header.rom_size, cbfs_header.align); + if (file_cbfs_result == CBFS_SUCCESS) + initialized = 1; +} + +const struct cbfs_header *file_cbfs_get_header(void) +{ + if (initialized) { + file_cbfs_result = CBFS_SUCCESS; + return &cbfs_header; + } else { + file_cbfs_result = CBFS_NOT_INITIALIZED; + return NULL; + } +} + +cbfs_file file_cbfs_get_first(void) +{ + if (!initialized) { + file_cbfs_result = CBFS_NOT_INITIALIZED; + return NULL; + } else { + file_cbfs_result = CBFS_SUCCESS; + return file_cache; + } +} + +void file_cbfs_get_next(cbfs_file *file) +{ + if (!initialized) { + file_cbfs_result = CBFS_NOT_INITIALIZED; + file = NULL; + return; + } + + if (*file) + *file = (*file)->next; + file_cbfs_result = CBFS_SUCCESS; +} + +cbfs_file file_cbfs_find(const char *name) +{ + struct cbfs_cache_node *cache_node = file_cache; + + if (!initialized) { + file_cbfs_result = CBFS_NOT_INITIALIZED; + return NULL; + } + + while (cache_node) { + if (!strcmp(name, cache_node->name)) + break; + cache_node = cache_node->next; + } + if (!cache_node) + file_cbfs_result = CBFS_FILE_NOT_FOUND; + else + file_cbfs_result = CBFS_SUCCESS; + return cache_node; +} + +cbfs_file file_cbfs_find_uncached(uintptr_t end_of_rom, const char *name) +{ + u8 *start; + u32 size; + u32 align; + static struct cbfs_cache_node node; + + if (file_cbfs_load_header(end_of_rom, &cbfs_header)) + return NULL; + + start = (u8 *)(end_of_rom + 1 - cbfs_header.rom_size); + size = cbfs_header.rom_size; + align = cbfs_header.align; + + while (size >= align) { + int result; + u32 used; + + result = file_cbfs_next_file(start, size, align, &node, &used); + + if (result < 0) + return NULL; + else if (result == 0) + break; + + if (!strcmp(name, node.name)) + return &node; + + size -= used; + start += used; + } + file_cbfs_result = CBFS_FILE_NOT_FOUND; + return NULL; +} + +const char *file_cbfs_name(cbfs_file file) +{ + file_cbfs_result = CBFS_SUCCESS; + return file->name; +} + +u32 file_cbfs_size(cbfs_file file) +{ + file_cbfs_result = CBFS_SUCCESS; + return file->data_length; +} + +u32 file_cbfs_type(cbfs_file file) +{ + file_cbfs_result = CBFS_SUCCESS; + return file->type; +} + +long file_cbfs_read(cbfs_file file, void *buffer, unsigned long maxsize) +{ + u32 size; + + size = file->data_length; + if (maxsize && size > maxsize) + size = maxsize; + + memcpy(buffer, file->data, size); + + file_cbfs_result = CBFS_SUCCESS; + return size; +} diff --git a/include/cbfs.h b/include/cbfs.h new file mode 100644 index 0000000..9e97c2d --- /dev/null +++ b/include/cbfs.h @@ -0,0 +1,164 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. All rights reserved. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CBFS_H +#define __CBFS_H + +#include <compiler.h> +#include <linux/compiler.h> + +enum cbfs_result { + CBFS_SUCCESS = 0, + CBFS_NOT_INITIALIZED, + CBFS_BAD_HEADER, + CBFS_BAD_FILE, + CBFS_FILE_NOT_FOUND +}; + +enum cbfs_file_type { + CBFS_TYPE_STAGE = 0x10, + CBFS_TYPE_PAYLOAD = 0x20, + CBFS_TYPE_OPTIONROM = 0x30, + CBFS_TYPE_BOOTSPLASH = 0x40, + CBFS_TYPE_RAW = 0x50, + CBFS_TYPE_VSA = 0x51, + CBFS_TYPE_MBI = 0x52, + CBFS_TYPE_MICROCODE = 0x53, + CBFS_COMPONENT_CMOS_DEFAULT = 0xaa, + CBFS_COMPONENT_CMOS_LAYOUT = 0x01aa +}; + +struct cbfs_header { + u32 magic; + u32 version; + u32 rom_size; + u32 boot_block_size; + u32 align; + u32 offset; + u32 pad[2]; +} __packed; + +struct cbfs_cache_node; +typedef const struct cbfs_cache_node *cbfs_file; + +extern enum cbfs_result file_cbfs_result; + +/* + * Return a string describing the most recent error condition. + * + * @return A pointer to the constant string. + */ +const char *file_cbfs_error(void); + +/* + * Initialize the CBFS driver and load metadata into RAM. + * + * @param end_of_rom Points to the end of the ROM the CBFS should be read + * from. + */ +void file_cbfs_init(uintptr_t end_of_rom); + +/* + * Get the header structure for the current CBFS. + * + * @return A pointer to the constant structure, or NULL if there is none. + */ +const struct cbfs_header *file_cbfs_get_header(void); + +/* + * Get a handle for the first file in CBFS. + * + * @return A handle for the first file in CBFS, NULL on error. + */ +cbfs_file file_cbfs_get_first(void); + +/* + * Get a handle to the file after this one in CBFS. + * + * @param file A pointer to the handle to advance. + */ +void file_cbfs_get_next(cbfs_file *file); + +/* + * Find a file with a particular name in CBFS. + * + * @param name The name to search for. + * + * @return A handle to the file, or NULL on error. + */ +cbfs_file file_cbfs_find(const char *name); + + +/***************************************************************************/ +/* All of the functions below can be used without first initializing CBFS. */ +/***************************************************************************/ + +/* + * Find a file with a particular name in CBFS without using the heap. + * + * @param end_of_rom Points to the end of the ROM the CBFS should be read + * from. + * @param name The name to search for. + * + * @return A handle to the file, or NULL on error. + */ +cbfs_file file_cbfs_find_uncached(uintptr_t end_of_rom, const char *name); + +/* + * Get the name of a file in CBFS. + * + * @param file The handle to the file. + * + * @return The name of the file, NULL on error. + */ +const char *file_cbfs_name(cbfs_file file); + +/* + * Get the size of a file in CBFS. + * + * @param file The handle to the file. + * + * @return The size of the file, zero on error. + */ +u32 file_cbfs_size(cbfs_file file); + +/* + * Get the type of a file in CBFS. + * + * @param file The handle to the file. + * + * @return The type of the file, zero on error. + */ +u32 file_cbfs_type(cbfs_file file); + +/* + * Read a file from CBFS into RAM + * + * @param file A handle to the file to read. + * @param buffer Where to read it into memory. + * + * @return If positive or zero, the number of characters read. If negative, an + * error occurred. + */ +long file_cbfs_read(cbfs_file file, void *buffer, unsigned long maxsize); + +#endif /* __CBFS_H */
Dear Gabe Black,
In message 1323134730-18471-1-git-send-email-gabeblack@chromium.org you wrote:
There is still a checkpatch warning that should be fixed:
WARNING: do not add new typedefs #853: FILE: include/cbfs.h:61: +typedef const struct cbfs_cache_node *cbfs_file;
- fs/jffs2/libjffs2.o fs/reiserfs/libreiserfs.o fs/ext2/libext2fs.o \
- fs/yaffs2/libyaffs2.o fs/ubifs/libubifs.o fs/cbfs/libcbfs.o
Please keep the list sorted. [It may make sense to split it into a list of entries with one FS per line.]
Please keep sorted (by object file names).
- uintptr_t end_of_rom = 0xffffffff;
- char *ep;
- if (argc > 2) {
What is the meaning / intention of that tailing '>' ?
- if (file_cbfs_result != CBFS_SUCCESS) {
Use puts(file_cbfs_error()); ?
- if (!file) {
else
See above. Please consider changing globally.
- printf("reading %s\n", file_cbfs_name(file));
- size = file_cbfs_read(file, (void *)offset, count);
- printf("\n%ld bytes read\n", size);
There should be no need for the initial newline here. Please drop it (fix globally?).
if (type_name)
else
This is probably confusing to the user. How can he know if the file type has the numerical value of "123" or if the file name is "123" ?
if (filename[0])
else
Use puts().
- printf("\n%d file(s)\n\n", files);
Please do not print that many empty lines.
Imagine output is going to a QVGA display or similar which shows only 12 text lines or so...
- const struct cbfs_header *header = file_cbfs_get_header();
- if (!header) {
return 1;
Please always insert a blank line between declarations and code. Please fix globally.
- puts("\n");
What is this blank line good for? Drop it!
- printf("CBFS version: %#x\n", header->version);
- printf("ROM size: %#x\n", header->rom_size);
- printf("Boot block size: %#x\n", header->boot_block_size);
- printf("CBFS size: %#x\n",
- printf("Alignment: %d\n", header->align);
- printf("Offset: %#x\n", header->offset);
How about some vertical alignment of the output?
- puts("\n");
Drop that, too.
- switch (file_cbfs_result) {
- case CBFS_SUCCESS:
return "Success";
- case CBFS_NOT_INITIALIZED:
- case CBFS_BAD_HEADER:
- case CBFS_BAD_FILE:
- case CBFS_FILE_NOT_FOUND:
- default:
return "Unknown";
Better make this "Unknown error" or similar, otherwise the user might not know what "Unknown" means.
On Tue, Dec 6, 2011 at 3:01 AM, Wolfgang Denk wd@denx.de wrote:
Dear Gabe Black,
and
end
last
current
for
without
touching the heap.
This typedef is to create an opaque handle for CBFS files. If you look here:
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=blob;f=Do...
In chapter 5 in the list of acceptable uses for typedefs, creating an opaque type is item a. This use of typedef is consistent with the Linux coding standards as described in that document and functionally important for this change and should stay.
argv[])
char *ep;
if (argc > 2) {
A typo.
That would leave out the \n. Whatever came next (like the prompt) would continue on the same line which would be wrong.
argv[])
if (!file) {
else
The same explanation applies globally.
if (type_name)
else
This isn't file name, it's the file type. No file type is named after a number. There are also labels on the columns indicating which is which.
if (filename[0])
else
Use puts().
The first one can't be a puts, it would have to be three. That's a lot of clutter to avoid a slight performance penalty when interacting with a human that won't notice such a tiny delay anyway. The second one could be a puts, but that would make the two branches of the if uneven. I'll change the second one.
I put newlines there because the FAT commands do, and I have no problem removing them. You may want to look at the other commands and remove them there too.
puts("\n");
Readability? I don't care that much one way or the other though. I'll change it.
Gabe
Dear Gabe Black,
In message CAPPXG1nqDa_UgZsJx_g_RDCQOfJLjM=zaK5K7W9pgcsRrc9kig@mail.gmail.com you wrote:
Sorry, but you have to explain this better to me.
What would be wrong with using "struct cbfs_cache_node *" ?
And what of this exactly is "functionally important" here?
While we are quoting the CodingStyle, we should also code the next lines:
NOTE! Opaqueness and "accessor functions" are not good in themselves.
Why do you think it is needed here?
It appears your only use of file_cbfs_error() is in such constructs, so just change file_cbfs_error() to include the newline. There is only a single call that doesn't really fit:
+ if (file_cbfs_result == CBFS_FILE_NOT_FOUND) ===> + printf("%s: %s\n", file_cbfs_error(), argv[2]); + else + printf("%s.\n", file_cbfs_error());
but that would be better written with arguments swapped anyway:
printf("%s: %s", argv[2], file_cbfs_error());
While we are at it: for consistent style, please also omit the trailing '.' in all such output.
Actually you can then even simplify the code:
if (file_cbfs_result == CBFS_FILE_NOT_FOUND) printf("%s: argv[2]); puts(file_cbfs_error());
if (type_name)
else
Please explain the meaning of this numeric versus string value is, then, and how the user is supposed to understand when he sees a string and when a numeric value.
if (filename[0])
else
Use puts().
Come on. It this really that difficlt? How about:
puts(" "); puts(filename[0] ? filename : "(empty)");
Patches are welcome.
Thanks.
Changes in v3: Formatting changes, "Unknown" => "Unknown error", Makefile sorting, fix a typo.
Makefile | 6 +- README | 1 + common/Makefile | 1 + common/cmd_cbfs.c | 212 +++++++++++++++++++++++++++++++ fs/Makefile | 1 + fs/cbfs/Makefile | 44 +++++++ fs/cbfs/cbfs.c | 355 +++++++++++++++++++++++++++++++++++++++++++++++++++++ include/cbfs.h | 164 ++++++++++++++++++++++++ 8 files changed, 781 insertions(+), 3 deletions(-) create mode 100644 common/cmd_cbfs.c create mode 100644 fs/cbfs/Makefile create mode 100644 fs/cbfs/cbfs.c create mode 100644 include/cbfs.h
diff --git a/Makefile b/Makefile index d84b350..3056fed 100644 --- a/Makefile +++ b/Makefile @@ -234,9 +234,9 @@ ifeq ($(CONFIG_OF_EMBED),y) LIBS += dts/libdts.o endif LIBS += arch/$(ARCH)/lib/lib$(ARCH).o -LIBS += fs/cramfs/libcramfs.o fs/fat/libfat.o fs/fdos/libfdos.o fs/jffs2/libjffs2.o \ - fs/reiserfs/libreiserfs.o fs/ext2/libext2fs.o fs/yaffs2/libyaffs2.o \ - fs/ubifs/libubifs.o +LIBS += fs/cbfs/libcbfs.o fs/cramfs/libcramfs.o fs/fat/libfat.o \ + fs/fdos/libfdos.o fs/jffs2/libjffs2.o fs/reiserfs/libreiserfs.o \ + fs/ext2/libext2fs.o fs/yaffs2/libyaffs2.o fs/ubifs/libubifs.o LIBS += net/libnet.o LIBS += disk/libdisk.o LIBS += drivers/bios_emulator/libatibiosemu.o diff --git a/README b/README index fda0190..b878c4b 100644 --- a/README +++ b/README @@ -721,6 +721,7 @@ The following options need to be configured: CONFIG_CMD_BSP * Board specific commands CONFIG_CMD_BOOTD bootd CONFIG_CMD_CACHE * icache, dcache + CONFIG_CMD_CBFS * Support for coreboot's CBFS CONFIG_CMD_CONSOLE coninfo CONFIG_CMD_CRC32 * crc32 CONFIG_CMD_DATE * support for RTC, date/time... diff --git a/common/Makefile b/common/Makefile index 1b672ad..d3633a3 100644 --- a/common/Makefile +++ b/common/Makefile @@ -72,6 +72,7 @@ COBJS-$(CONFIG_CMD_BEDBUG) += bedbug.o cmd_bedbug.o COBJS-$(CONFIG_CMD_BMP) += cmd_bmp.o COBJS-$(CONFIG_CMD_BOOTLDR) += cmd_bootldr.o COBJS-$(CONFIG_CMD_CACHE) += cmd_cache.o +COBJS-$(CONFIG_CMD_CBFS) += cmd_cbfs.o COBJS-$(CONFIG_CMD_CONSOLE) += cmd_console.o COBJS-$(CONFIG_CMD_CPLBINFO) += cmd_cplbinfo.o COBJS-$(CONFIG_DATAFLASH_MMC_SELECT) += cmd_dataflash_mmc_mux.o diff --git a/common/cmd_cbfs.c b/common/cmd_cbfs.c new file mode 100644 index 0000000..4748883 --- /dev/null +++ b/common/cmd_cbfs.c @@ -0,0 +1,212 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. All rights reserved. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * CBFS commands + */ +#include <common.h> +#include <command.h> +#include <cbfs.h> + +int do_cbfs_init(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + uintptr_t end_of_rom = 0xffffffff; + char *ep; + + if (argc > 2) { + puts("usage: cbfsls [end of rom]\n"); + return 0; + } + if (argc == 2) { + end_of_rom = (int)simple_strtoul(argv[1], &ep, 16); + if (*ep) { + puts("** Invalid end of ROM **\n"); + return 1; + } + } + file_cbfs_init(end_of_rom); + if (file_cbfs_result != CBFS_SUCCESS) { + printf("%s.\n", file_cbfs_error()); + return 1; + } + return 0; +} + +U_BOOT_CMD( + cbfsinit, 2, 0, do_cbfs_init, + "initialize the cbfs driver", + "[end of rom]\n" + " - Initialize the cbfs driver. The optional 'end of rom'\n" + " parameter specifies where the end of the ROM is that the\n" + " CBFS is in. It defaults to 0xFFFFFFFF\n" +); + +int do_cbfs_fsload(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + long size; + unsigned long offset; + unsigned long count; + char buf[12]; + cbfs_file file; + + if (argc < 3) { + puts("usage: cbfsload <addr> <filename> [bytes]\n"); + return 1; + } + + /* parse offset and count */ + offset = simple_strtoul(argv[1], NULL, 16); + if (argc == 4) + count = simple_strtoul(argv[3], NULL, 16); + else + count = 0; + + file = file_cbfs_find(argv[2]); + if (!file) { + if (file_cbfs_result == CBFS_FILE_NOT_FOUND) + printf("%s: %s\n", file_cbfs_error(), argv[2]); + else + printf("%s.\n", file_cbfs_error()); + return 1; + } + + printf("reading %s\n", file_cbfs_name(file)); + + size = file_cbfs_read(file, (void *)offset, count); + + printf("%ld bytes read\n", size); + + sprintf(buf, "%lX", size); + setenv("filesize", buf); + + return 0; +} + +U_BOOT_CMD( + cbfsload, 4, 0, do_cbfs_fsload, + "load binary file from a cbfs filesystem", + "<addr> <filename> [bytes]\n" + " - load binary file 'filename' from the cbfs to address 'addr'\n" +); + +int do_cbfs_ls(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + cbfs_file file = file_cbfs_get_first(); + int files = 0; + + if (!file) { + printf("%s.\n", file_cbfs_error()); + return 1; + } + + puts(" size type name\n"); + puts("------------------------------------------\n"); + while (file) { + u32 type = file_cbfs_type(file); + char *type_name = NULL; + const char *filename = file_cbfs_name(file); + + printf(" %8d", file_cbfs_size(file)); + + switch (type) { + case CBFS_TYPE_STAGE: + type_name = "stage"; + break; + case CBFS_TYPE_PAYLOAD: + type_name = "payload"; + break; + case CBFS_TYPE_OPTIONROM: + type_name = "option rom"; + break; + case CBFS_TYPE_BOOTSPLASH: + type_name = "boot splash"; + break; + case CBFS_TYPE_RAW: + type_name = "raw"; + break; + case CBFS_TYPE_VSA: + type_name = "vsa"; + break; + case CBFS_TYPE_MBI: + type_name = "mbi"; + break; + case CBFS_TYPE_MICROCODE: + type_name = "microcode"; + break; + case CBFS_COMPONENT_CMOS_DEFAULT: + type_name = "cmos default"; + break; + case CBFS_COMPONENT_CMOS_LAYOUT: + type_name = "cmos layout"; + break; + case -1UL: + type_name = "null"; + break; + } + if (type_name) + printf(" %16s", type_name); + else + printf(" %16d", type); + + if (filename[0]) + printf(" %s\n", filename); + else + puts(" (empty)\n"); + file_cbfs_get_next(&file); + files++; + } + + printf("%d file(s)\n\n", files); + return 0; +} + +U_BOOT_CMD( + cbfsls, 1, 1, do_cbfs_ls, + "list files", + " - list the files in the cbfs\n" +); + +int do_cbfs_fsinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + const struct cbfs_header *header = file_cbfs_get_header(); + + if (!header) { + printf("%s.\n", file_cbfs_error()); + return 1; + } + + printf("CBFS version: %#x\n", header->version); + printf("ROM size: %#x\n", header->rom_size); + printf("Boot block size: %#x\n", header->boot_block_size); + printf("CBFS size: %#x\n", + header->rom_size - header->boot_block_size - header->offset); + printf("Alignment: %d\n", header->align); + printf("Offset: %#x\n", header->offset); + + return 0; +} + +U_BOOT_CMD( + cbfsinfo, 1, 1, do_cbfs_fsinfo, + "print information about filesystem", + " - print information about the cbfs filesystem\n" +); diff --git a/fs/Makefile b/fs/Makefile index 22aad12..ca21464 100644 --- a/fs/Makefile +++ b/fs/Makefile @@ -23,6 +23,7 @@ #
subdirs-$(CONFIG_CMD_CRAMFS) := cramfs +subdirs-$(CONFIG_CMD_CBFS) += cbfs subdirs-$(CONFIG_CMD_EXT2) += ext2 subdirs-$(CONFIG_CMD_FAT) += fat subdirs-$(CONFIG_CMD_FDOS) += fdos diff --git a/fs/cbfs/Makefile b/fs/cbfs/Makefile new file mode 100644 index 0000000..864fdf9 --- /dev/null +++ b/fs/cbfs/Makefile @@ -0,0 +1,44 @@ +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)libcbfs.o + +AOBJS = +COBJS-$(CONFIG_CMD_CBFS) := cbfs.o + +SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) + +all: $(LIB) $(AOBJS) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/fs/cbfs/cbfs.c b/fs/cbfs/cbfs.c new file mode 100644 index 0000000..4be73e6 --- /dev/null +++ b/fs/cbfs/cbfs.c @@ -0,0 +1,355 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. All rights reserved. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <cbfs.h> +#include <malloc.h> +#include <asm/byteorder.h> + +enum cbfs_result file_cbfs_result; + +const char *file_cbfs_error(void) +{ + switch (file_cbfs_result) { + case CBFS_SUCCESS: + return "Success"; + case CBFS_NOT_INITIALIZED: + return "CBFS not initialized"; + case CBFS_BAD_HEADER: + return "Bad CBFS header"; + case CBFS_BAD_FILE: + return "Bad CBFS file"; + case CBFS_FILE_NOT_FOUND: + return "File not found"; + default: + return "Unknown error"; + } +} + +struct cbfs_file_header { + u8 magic[8]; + u32 len; + u32 type; + u32 checksum; + u32 offset; +} __packed; + +struct cbfs_cache_node { + struct cbfs_cache_node *next; + u32 type; + void *data; + u32 data_length; + char *name; + u32 name_length; + u32 checksum; +} __packed; + + +static const u32 good_magic = 0x4f524243; +static const u8 good_file_magic[] = "LARCHIVE"; + + +static int initialized; +static struct cbfs_header cbfs_header; +static struct cbfs_cache_node *file_cache; + +/* Do endian conversion on the CBFS header structure. */ +static void swap_header(struct cbfs_header *dest, struct cbfs_header *src) +{ + dest->magic = be32_to_cpu(src->magic); + dest->version = be32_to_cpu(src->version); + dest->rom_size = be32_to_cpu(src->rom_size); + dest->boot_block_size = be32_to_cpu(src->boot_block_size); + dest->align = be32_to_cpu(src->align); + dest->offset = be32_to_cpu(src->offset); +} + +/* Do endian conversion on a CBFS file header. */ +static void swap_file_header(struct cbfs_file_header *dest, + struct cbfs_file_header *src) +{ + memcpy(&dest->magic, &src->magic, sizeof(dest->magic)); + dest->len = be32_to_cpu(src->len); + dest->type = be32_to_cpu(src->type); + dest->checksum = be32_to_cpu(src->checksum); + dest->offset = be32_to_cpu(src->offset); +} + +/* + * Given a starting position in memory, scan forward, bounded by a size, and + * find the next valid CBFS file. No memory is allocated by this function. The + * caller is responsible for allocating space for the new file structure. + * + * @param start The location in memory to start from. + * @param size The size of the memory region to search. + * @param align The alignment boundaries to check on. + * @param newNode A pointer to the file structure to load. + * @param used A pointer to the count of of bytes scanned through, + * including the file if one is found. + * + * @return 1 if a file is found, 0 if one isn't. + */ +static int file_cbfs_next_file(u8 *start, u32 size, u32 align, + struct cbfs_cache_node *new_node, u32 *used) +{ + struct cbfs_file_header header; + + *used = 0; + + while (size >= align) { + struct cbfs_file_header *file_header = + (struct cbfs_file_header *)start; + u32 name_len; + u32 step; + + /* Check if there's a file here. */ + if (memcmp(good_file_magic, &(file_header->magic), + sizeof(file_header->magic))) { + *used += align; + size -= align; + start += align; + continue; + } + + swap_file_header(&header, file_header); + if (header.offset < sizeof(struct cbfs_file_header) || + header.offset > header.len) { + file_cbfs_result = CBFS_BAD_FILE; + return -1; + } + new_node->next = NULL; + new_node->type = header.type; + new_node->data = start + header.offset; + new_node->data_length = header.len; + name_len = header.offset - sizeof(struct cbfs_file_header); + new_node->name = (char *)file_header + + sizeof(struct cbfs_file_header); + new_node->name_length = name_len; + new_node->checksum = header.checksum; + + step = header.len; + if (step % align) + step = step + align - step % align; + + *used += step; + return 1; + } + return 0; +} + +/* Look through a CBFS instance and copy file metadata into regular memory. */ +static void file_cbfs_fill_cache(u8 *start, u32 size, u32 align) +{ + struct cbfs_cache_node *cache_node; + struct cbfs_cache_node *new_node; + struct cbfs_cache_node **cache_tail = &file_cache; + + /* Clear out old information. */ + cache_node = file_cache; + while (cache_node) { + struct cbfs_cache_node *old_node = cache_node; + cache_node = cache_node->next; + free(old_node); + } + file_cache = NULL; + + while (size >= align) { + int result; + u32 used; + + new_node = (struct cbfs_cache_node *) + malloc(sizeof(struct cbfs_cache_node)); + result = file_cbfs_next_file(start, size, align, + new_node, &used); + + if (result < 0) { + free(new_node); + return; + } else if (result == 0) { + free(new_node); + break; + } + *cache_tail = new_node; + cache_tail = &new_node->next; + + size -= used; + start += used; + } + file_cbfs_result = CBFS_SUCCESS; +} + +/* Get the CBFS header out of the ROM and do endian conversion. */ +static int file_cbfs_load_header(uintptr_t end_of_rom, + struct cbfs_header *header) +{ + struct cbfs_header *header_in_rom; + + header_in_rom = (struct cbfs_header *)(uintptr_t) + *(u32 *)(end_of_rom - 3); + swap_header(header, header_in_rom); + + if (header->magic != good_magic || header->offset > + header->rom_size - header->boot_block_size) { + file_cbfs_result = CBFS_BAD_HEADER; + return 1; + } + return 0; +} + +void file_cbfs_init(uintptr_t end_of_rom) +{ + u8 *start_of_rom; + + initialized = 0; + + if (file_cbfs_load_header(end_of_rom, &cbfs_header)) + return; + + start_of_rom = (u8 *)(end_of_rom + 1 - cbfs_header.rom_size); + + file_cbfs_fill_cache(start_of_rom + cbfs_header.offset, + cbfs_header.rom_size, cbfs_header.align); + if (file_cbfs_result == CBFS_SUCCESS) + initialized = 1; +} + +const struct cbfs_header *file_cbfs_get_header(void) +{ + if (initialized) { + file_cbfs_result = CBFS_SUCCESS; + return &cbfs_header; + } else { + file_cbfs_result = CBFS_NOT_INITIALIZED; + return NULL; + } +} + +cbfs_file file_cbfs_get_first(void) +{ + if (!initialized) { + file_cbfs_result = CBFS_NOT_INITIALIZED; + return NULL; + } else { + file_cbfs_result = CBFS_SUCCESS; + return file_cache; + } +} + +void file_cbfs_get_next(cbfs_file *file) +{ + if (!initialized) { + file_cbfs_result = CBFS_NOT_INITIALIZED; + file = NULL; + return; + } + + if (*file) + *file = (*file)->next; + file_cbfs_result = CBFS_SUCCESS; +} + +cbfs_file file_cbfs_find(const char *name) +{ + struct cbfs_cache_node *cache_node = file_cache; + + if (!initialized) { + file_cbfs_result = CBFS_NOT_INITIALIZED; + return NULL; + } + + while (cache_node) { + if (!strcmp(name, cache_node->name)) + break; + cache_node = cache_node->next; + } + if (!cache_node) + file_cbfs_result = CBFS_FILE_NOT_FOUND; + else + file_cbfs_result = CBFS_SUCCESS; + return cache_node; +} + +cbfs_file file_cbfs_find_uncached(uintptr_t end_of_rom, const char *name) +{ + u8 *start; + u32 size; + u32 align; + static struct cbfs_cache_node node; + + if (file_cbfs_load_header(end_of_rom, &cbfs_header)) + return NULL; + + start = (u8 *)(end_of_rom + 1 - cbfs_header.rom_size); + size = cbfs_header.rom_size; + align = cbfs_header.align; + + while (size >= align) { + int result; + u32 used; + + result = file_cbfs_next_file(start, size, align, &node, &used); + + if (result < 0) + return NULL; + else if (result == 0) + break; + + if (!strcmp(name, node.name)) + return &node; + + size -= used; + start += used; + } + file_cbfs_result = CBFS_FILE_NOT_FOUND; + return NULL; +} + +const char *file_cbfs_name(cbfs_file file) +{ + file_cbfs_result = CBFS_SUCCESS; + return file->name; +} + +u32 file_cbfs_size(cbfs_file file) +{ + file_cbfs_result = CBFS_SUCCESS; + return file->data_length; +} + +u32 file_cbfs_type(cbfs_file file) +{ + file_cbfs_result = CBFS_SUCCESS; + return file->type; +} + +long file_cbfs_read(cbfs_file file, void *buffer, unsigned long maxsize) +{ + u32 size; + + size = file->data_length; + if (maxsize && size > maxsize) + size = maxsize; + + memcpy(buffer, file->data, size); + + file_cbfs_result = CBFS_SUCCESS; + return size; +} diff --git a/include/cbfs.h b/include/cbfs.h new file mode 100644 index 0000000..9e97c2d --- /dev/null +++ b/include/cbfs.h @@ -0,0 +1,164 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. All rights reserved. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CBFS_H +#define __CBFS_H + +#include <compiler.h> +#include <linux/compiler.h> + +enum cbfs_result { + CBFS_SUCCESS = 0, + CBFS_NOT_INITIALIZED, + CBFS_BAD_HEADER, + CBFS_BAD_FILE, + CBFS_FILE_NOT_FOUND +}; + +enum cbfs_file_type { + CBFS_TYPE_STAGE = 0x10, + CBFS_TYPE_PAYLOAD = 0x20, + CBFS_TYPE_OPTIONROM = 0x30, + CBFS_TYPE_BOOTSPLASH = 0x40, + CBFS_TYPE_RAW = 0x50, + CBFS_TYPE_VSA = 0x51, + CBFS_TYPE_MBI = 0x52, + CBFS_TYPE_MICROCODE = 0x53, + CBFS_COMPONENT_CMOS_DEFAULT = 0xaa, + CBFS_COMPONENT_CMOS_LAYOUT = 0x01aa +}; + +struct cbfs_header { + u32 magic; + u32 version; + u32 rom_size; + u32 boot_block_size; + u32 align; + u32 offset; + u32 pad[2]; +} __packed; + +struct cbfs_cache_node; +typedef const struct cbfs_cache_node *cbfs_file; + +extern enum cbfs_result file_cbfs_result; + +/* + * Return a string describing the most recent error condition. + * + * @return A pointer to the constant string. + */ +const char *file_cbfs_error(void); + +/* + * Initialize the CBFS driver and load metadata into RAM. + * + * @param end_of_rom Points to the end of the ROM the CBFS should be read + * from. + */ +void file_cbfs_init(uintptr_t end_of_rom); + +/* + * Get the header structure for the current CBFS. + * + * @return A pointer to the constant structure, or NULL if there is none. + */ +const struct cbfs_header *file_cbfs_get_header(void); + +/* + * Get a handle for the first file in CBFS. + * + * @return A handle for the first file in CBFS, NULL on error. + */ +cbfs_file file_cbfs_get_first(void); + +/* + * Get a handle to the file after this one in CBFS. + * + * @param file A pointer to the handle to advance. + */ +void file_cbfs_get_next(cbfs_file *file); + +/* + * Find a file with a particular name in CBFS. + * + * @param name The name to search for. + * + * @return A handle to the file, or NULL on error. + */ +cbfs_file file_cbfs_find(const char *name); + + +/***************************************************************************/ +/* All of the functions below can be used without first initializing CBFS. */ +/***************************************************************************/ + +/* + * Find a file with a particular name in CBFS without using the heap. + * + * @param end_of_rom Points to the end of the ROM the CBFS should be read + * from. + * @param name The name to search for. + * + * @return A handle to the file, or NULL on error. + */ +cbfs_file file_cbfs_find_uncached(uintptr_t end_of_rom, const char *name); + +/* + * Get the name of a file in CBFS. + * + * @param file The handle to the file. + * + * @return The name of the file, NULL on error. + */ +const char *file_cbfs_name(cbfs_file file); + +/* + * Get the size of a file in CBFS. + * + * @param file The handle to the file. + * + * @return The size of the file, zero on error. + */ +u32 file_cbfs_size(cbfs_file file); + +/* + * Get the type of a file in CBFS. + * + * @param file The handle to the file. + * + * @return The type of the file, zero on error. + */ +u32 file_cbfs_type(cbfs_file file); + +/* + * Read a file from CBFS into RAM + * + * @param file A handle to the file to read. + * @param buffer Where to read it into memory. + * + * @return If positive or zero, the number of characters read. If negative, an + * error occurred. + */ +long file_cbfs_read(cbfs_file file, void *buffer, unsigned long maxsize); + +#endif /* __CBFS_H */
Dear Gabe Black,
In message 1323214584-11635-1-git-send-email-gabeblack@chromium.org you wrote:
Coreboot uses a very simple "file system" called CBFS to keep track of and allow access to multiple "files" in a ROM image. This change adds CBFS support and some commands to use it to u-boot. These commands are:
cbfsinit - Initialize CBFS support and pull all metadata into RAM. The end of the ROM is an optional parameter which defaults to the standard 0xffffffff and can be used to support multiple CBFSes in a system. The last one set up with cbfsinit is the one that will be used.
cbfsinfo - Print information from the CBFS header.
cbfsls - Print out the size, type, and name of all the files in the current CBFS. Recognized types are translated into symbolic names.
cbfsload - Load a file from CBFS into memory. Like the similar command for fat filesystems, you can optionally provide a maximum size.
Also, if u-boot needs something out of CBFS very early before the heap is configured, it won't be able to use the normal CBFS support which caches some information in memory it allocates from the heap. This change adds a new cbfs_file_find_uncached function which searchs a CBFS instance without touching the heap.
Support for CBFS is compiled in when the CONFIG_CMD_CBFS option is specified.
See previous message.
On Wed, Dec 7, 2011 at 3:03 AM, Wolfgang Denk wd@denx.de wrote:
Dear Gabe Black,
and
end
last
current
for
without
touching the heap.
Could you be more specific?
Gabe
Dear Gabe Black,
In message CAPPXG1k-kGa=BnHC=qoVZaVTedEvF5zWkWx-jX0g-SrbzfFseA@mail.gmail.com you wrote:
------- Forwarded Message
Dear Gabe Black,
if (type_name)
else
if (filename[0])
else
Use puts().
Thanks.
------- End of Forwarded Message
static
- if (argc > 2) {
printf("usage: cbfsls [end of rom]>\n");
return cmd_usage(cmdtp)
+int do_cbfs_fsload (cmd_tbl_t *cmdtp, int flag, int argc, char *const
static
no space before that "("
- if (argc < 3) {
printf("usage: cbfsload <addr> <filename> [bytes]\n");
return 1;
+int do_cbfs_ls (cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[])
static
char *typeName = NULL;
const, and don't use camelCase in var names
+int do_cbfs_fsinfo (cmd_tbl_t *cmdtp, int flag, int argc, char *const
static
- const CbfsHeader *header = file_cbfs_get_header();
camelCase ...
- printf("\n");
- printf("ROM size: %#x\n", header->romSize);
- printf("Boot block size: %#x\n", header->bootBlockSize);
header->romSize - header->bootBlockSize - header->offset);
- printf("\n");
should be easy to merge into a single printf() call
unrelated, but that ":=" is most likely wrong as it doesn't do what it is actually intended
case CBFS_SUCCESS:
return "Success";
case CBFS_BAD_FILE:
default:
return "Unknown";
CbfsResult starts CBFS_SUCCESS at 0, so this should be easy to rewrite as an array of strings which this func simply indexes
+typedef struct CbfsFileHeader { ... +} __attribute__((packed)) CbfsFileHeader;
__packed
+typedef struct CbfsCacheNode { ... +} __attribute__((packed)) CbfsCacheNode;
__packed
+static void file_cbfs_fill_cache(u8 *start, u32 size, u32 align) +{ ...
newNode = (CbfsCacheNode *)malloc(sizeof(CbfsCacheNode));
useless cast
+typedef struct CbfsHeader { ... +} __attribute__((packed)) CbfsHeader;
__packed -mike
Gabe Black
Gabe Black
Mike Frysinger
