[PATCH v3 0/7] Add eFuse access for ZynqMP
This series adds a driver to read and write ZynqMP eFuses [1]. The driver can be accessed by the 'fuse read' and 'fuse write' commands
Example:
=> fuse read 0 0xc 3 Reading bank 0:
Word 0x0000000c: 3cb16685 013af244 40000000
Note: Accessing eFuses requires eFuse access to be enabled in the underlying PMU firmware.
Use cases are: - Reading/writing user specific eFuses to enable device specific implementations - Revoking SPK IDs - Reading SoC version/DNA
[1] https://docs.amd.com/r/en-US/ug1085-zynq-ultrascale-trm/eFUSE
Changes in v3: - Align ZynqMP eFuse driver with Linux kernel - Adapt versal, versal-net and zynqmp to use common chip-id function - Enable CMD_FUSE and ZYNQMP_EFUSE for zynqmp_virt and zynqmp_kria defconfig - Use 'dev_err' instead 'log_msg_ret' if possible
Changes in v2: - Drop vendor specific fuse cmd, use existing fuse cmd - Minor code refactoring (reverse x-mas tree)
Lukas Funke (7): configs: zynqmp_kria: Enable CMD_FUSE and ZYNQMP_EFUSE configs: zynqmp_virt: Enable CMD_FUSE and ZYNQMP_EFUSE soc: xilinx: versal: Use zynqmp_pm_get_chipid() to get chip revision soc: xilinx: versal-net: Use zynqmp_pm_get_chipid() to get chip revision soc: xilinx: zynqmp: Use zynqmp_pm_get_chipid() to get chip revision firmware: zynqmp: Add support to access efuses drivers: misc: Add driver to access ZynqMP efuses
configs/xilinx_zynqmp_kria_defconfig | 2 + configs/xilinx_zynqmp_virt_defconfig | 2 + drivers/firmware/firmware-zynqmp.c | 31 +++ drivers/misc/Kconfig | 8 + drivers/misc/Makefile | 1 + drivers/misc/zynqmp_efuse.c | 360 +++++++++++++++++++++++++++ drivers/soc/soc_xilinx_versal.c | 13 +- drivers/soc/soc_xilinx_versal_net.c | 13 +- drivers/soc/soc_xilinx_zynqmp.c | 21 +- include/zynqmp_firmware.h | 2 + 10 files changed, 427 insertions(+), 26 deletions(-) create mode 100644 drivers/misc/zynqmp_efuse.c
Enable CMD_FUSE and ZYNQMP_EFUSE in order to be able to write ZyqnMP eFuses from within the bootloader for Kria SoM.
Signed-off-by: Lukas Funke lukas.funke@weidmueller.com ---
(no changes since v1)
configs/xilinx_zynqmp_virt_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index ee87beb19c6..1edd4ac77b1 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -65,6 +65,7 @@ CONFIG_CMD_DFU=y CONFIG_CMD_FPGA_LOADBP=y CONFIG_CMD_FPGA_LOADP=y CONFIG_CMD_FPGA_LOAD_SECURE=y +CONFIG_CMD_FUSE=y CONFIG_CMD_GPIO=y CONFIG_CMD_PWM=y CONFIG_CMD_GPT=y @@ -147,6 +148,7 @@ CONFIG_I2C_MUX_PCA954x=y CONFIG_LED=y CONFIG_LED_GPIO=y CONFIG_MISC=y +CONFIG_ZYNQMP_EFUSE=y CONFIG_I2C_EEPROM=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_IO_VOLTAGE=y
The patch itself is fine but it should be after symbol is defined. It means Kconfig change first and then enable it.
M
Enable CMD_FUSE and ZYNQMP_EFUSE in order to be able to write ZyqnMP eFuses from within the bootloader.
configs/xilinx_zynqmp_kria_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/xilinx_zynqmp_kria_defconfig b/configs/xilinx_zynqmp_kria_defconfig index ba42f0c7848..ac91dccbe64 100644 --- a/configs/xilinx_zynqmp_kria_defconfig +++ b/configs/xilinx_zynqmp_kria_defconfig @@ -65,6 +65,7 @@ CONFIG_CMD_DFU=y CONFIG_CMD_FPGA_LOADBP=y CONFIG_CMD_FPGA_LOADP=y CONFIG_CMD_FPGA_LOAD_SECURE=y +CONFIG_CMD_FUSE=y CONFIG_CMD_GPIO=y CONFIG_CMD_PWM=y CONFIG_CMD_GPT=y @@ -147,6 +148,7 @@ CONFIG_I2C_MUX_PCA954x=y CONFIG_LED=y CONFIG_LED_GPIO=y CONFIG_MISC=y +CONFIG_ZYNQMP_EFUSE=y CONFIG_I2C_EEPROM=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_IO_VOLTAGE=y
Feel free to merge it with Kria. No need for two patches.
M
Use common zynqmp_pm_get_chipid() function to get the chip revision
drivers/soc/soc_xilinx_versal.c | 13 ++++++------- 1 file changed, 6 insertions(+), 7 deletions(-)
diff --git a/drivers/soc/soc_xilinx_versal.c b/drivers/soc/soc_xilinx_versal.c index 3d8c25c19bb..3d949c4e612 100644 --- a/drivers/soc/soc_xilinx_versal.c +++ b/drivers/soc/soc_xilinx_versal.c @@ -45,23 +45,22 @@ static const struct soc_ops soc_xilinx_versal_ops = { static int soc_xilinx_versal_probe(struct udevice *dev) { struct soc_xilinx_versal_priv *priv = dev_get_priv(dev); - u32 ret_payload[PAYLOAD_ARG_CNT]; + u32 idcode, version; int ret;
priv->family = versal_family;
- if (IS_ENABLED(CONFIG_ZYNQMP_FIRMWARE)) { - ret = xilinx_pm_request(PM_GET_CHIPID, 0, 0, 0, 0, - ret_payload); + if (CONFIG_IS_ENABLED(ZYNQMP_FIRMWARE)) { + ret = zynqmp_pm_get_chipid(&idcode, &version); if (ret) return ret; } else { - ret_payload[2] = readl(VERSAL_PS_PMC_VERSION); - if (!ret_payload[2]) + version = readl(VERSAL_PS_PMC_VERSION); + if (!version) return -EINVAL; }
- priv->revision = ret_payload[2] >> VERSAL_PS_VER_SHIFT; + priv->revision = version >> VERSAL_PS_VER_SHIFT;
return 0; }
ret_payload);
- if (CONFIG_IS_ENABLED(ZYNQMP_FIRMWARE)) {
This function is defined in 6/7 that's why this will fail when it compiles which end up in non bisectable tree.
} else {
}if (!version) return -EINVAL;
return 0; }
But code is ok.
M
drivers/soc/soc_xilinx_versal_net.c | 13 ++++++------- 1 file changed, 6 insertions(+), 7 deletions(-)
diff --git a/drivers/soc/soc_xilinx_versal_net.c b/drivers/soc/soc_xilinx_versal_net.c index 146d068bb4a..76467a3bbb5 100644 --- a/drivers/soc/soc_xilinx_versal_net.c +++ b/drivers/soc/soc_xilinx_versal_net.c @@ -47,23 +47,22 @@ static const struct soc_ops soc_xilinx_versal_net_ops = { static int soc_xilinx_versal_net_probe(struct udevice *dev) { struct soc_xilinx_versal_net_priv *priv = dev_get_priv(dev); - u32 ret_payload[PAYLOAD_ARG_CNT]; + u32 idcode, version; int ret;
- if (IS_ENABLED(CONFIG_ZYNQMP_FIRMWARE)) { - ret = xilinx_pm_request(PM_GET_CHIPID, 0, 0, 0, 0, - ret_payload); + if (CONFIG_IS_ENABLED(ZYNQMP_FIRMWARE)) { + ret = zynqmp_pm_get_chipid(&idcode, &version); if (ret) return ret; } else { - ret_payload[2] = readl(PMC_TAP_VERSION); - if (!ret_payload[2]) + version = readl(PMC_TAP_VERSION); + if (!version) return -EINVAL; }
- priv->revision = FIELD_GET(PS_VERSION_MASK, ret_payload[2]); + priv->revision = FIELD_GET(PS_VERSION_MASK, version);
return 0; }
ret_payload);
if (ret) return ret; } else {ret = zynqmp_pm_get_chipid(&idcode, &version);
return 0; }
Reviewed-by: Michal Simek michal.simek@amd.com
Thanks, Michal
drivers/soc/soc_xilinx_zynqmp.c | 21 +++++++++------------ 1 file changed, 9 insertions(+), 12 deletions(-)
diff --git a/drivers/soc/soc_xilinx_zynqmp.c b/drivers/soc/soc_xilinx_zynqmp.c index d8b4f172a39..8a65810b7d7 100644 --- a/drivers/soc/soc_xilinx_zynqmp.c +++ b/drivers/soc/soc_xilinx_zynqmp.c @@ -346,22 +346,21 @@ static const struct soc_ops soc_xilinx_zynqmp_ops = { static int soc_xilinx_zynqmp_probe(struct udevice *dev) { struct soc_xilinx_zynqmp_priv *priv = dev_get_priv(dev); - u32 ret_payload[PAYLOAD_ARG_CNT]; + u32 idcode, version; int ret;
priv->family = zynqmp_family;
- if (!IS_ENABLED(CONFIG_ZYNQMP_FIRMWARE)) - ret = zynqmp_mmio_read(ZYNQMP_PS_VERSION, &ret_payload[2]); + if (!CONFIG_IS_ENABLED(ZYNQMP_FIRMWARE)) + ret = zynqmp_mmio_read(ZYNQMP_PS_VERSION, &version); else - ret = xilinx_pm_request(PM_GET_CHIPID, 0, 0, 0, 0, - ret_payload); + ret = zynqmp_pm_get_chipid(&idcode, &version); if (ret < 0) return ret;
- priv->revision = ret_payload[2] & ZYNQMP_PS_VER_MASK; + priv->revision = version & ZYNQMP_PS_VER_MASK;
- if (IS_ENABLED(CONFIG_ZYNQMP_FIRMWARE)) { + if (CONFIG_IS_ENABLED(ZYNQMP_FIRMWARE)) { /* * Firmware returns: * payload[0][31:0] = status of the operation @@ -370,11 +369,9 @@ static int soc_xilinx_zynqmp_probe(struct udevice *dev) * payload[2][28:20] = EXTENDED_IDCODE * payload[2][29] = PL_INIT */ - u32 idcode = ret_payload[1]; - u32 idcode2 = ret_payload[2] >> - ZYNQMP_CSU_VERSION_EMPTY_SHIFT; - dev_dbg(dev, "IDCODE: 0x%0x, IDCODE2: 0x%0x\n", idcode, - idcode2); + u32 idcode2 = version >> ZYNQMP_CSU_VERSION_EMPTY_SHIFT; + + dev_dbg(dev, "IDCODE: 0x%0x, IDCODE2: 0x%0x\n", idcode, idcode2);
ret = soc_xilinx_zynqmp_detect_machine(dev, idcode, idcode2); if (ret)
- if (!CONFIG_IS_ENABLED(ZYNQMP_FIRMWARE))
elseret = zynqmp_mmio_read(ZYNQMP_PS_VERSION, &version);
ret_payload);
if (ret < 0) return ret;ret = zynqmp_pm_get_chipid(&idcode, &version);
- priv->revision = version & ZYNQMP_PS_VER_MASK;
- if (CONFIG_IS_ENABLED(ZYNQMP_FIRMWARE)) { /*
- Firmware returns:
- payload[0][31:0] = status of the operation
idcode2);
Looks good. Reviewed-by: Michal Simek michal.simek@amd.com
Thanks, Michal
Add functions to access efuses through PMU firmware interface.
drivers/firmware/firmware-zynqmp.c | 31 ++++++++++++++++++++++++++++++ include/zynqmp_firmware.h | 2 ++ 2 files changed, 33 insertions(+)
diff --git a/drivers/firmware/firmware-zynqmp.c b/drivers/firmware/firmware-zynqmp.c index dfad798a2e7..8e9687693dd 100644 --- a/drivers/firmware/firmware-zynqmp.c +++ b/drivers/firmware/firmware-zynqmp.c @@ -211,6 +211,37 @@ int zynqmp_pm_feature(const u32 api_id) return ret_payload[1] & FIRMWARE_VERSION_MASK; }
+int zynqmp_pm_get_chipid(u32 *idcode, u32 *version) +{ + u32 ret_payload[PAYLOAD_ARG_CNT]; + int ret; + + if (!idcode || !version) + return -EINVAL; + + ret = xilinx_pm_request(PM_GET_CHIPID, 0, 0, 0, 0, ret_payload); + *idcode = ret_payload[1]; + *version = ret_payload[2]; + + return ret; +} + +int zynqmp_pm_efuse_access(const u64 address, u32 *out) +{ + u32 ret_payload[PAYLOAD_ARG_CNT]; + int ret; + + if (!out) + return -EINVAL; + + ret = xilinx_pm_request(PM_EFUSE_ACCESS, upper_32_bits(address), + lower_32_bits(address), 0, 0, ret_payload); + + *out = ret_payload[1]; + + return ret; +} + int zynqmp_pm_is_function_supported(const u32 api_id, const u32 id) { int ret; diff --git a/include/zynqmp_firmware.h b/include/zynqmp_firmware.h index 73198a6a6ea..7f18b4d59bf 100644 --- a/include/zynqmp_firmware.h +++ b/include/zynqmp_firmware.h @@ -453,6 +453,8 @@ int xilinx_pm_request(u32 api_id, u32 arg0, u32 arg1, u32 arg2, int zynqmp_pm_set_sd_config(u32 node, enum pm_sd_config_type config, u32 value); int zynqmp_pm_set_gem_config(u32 node, enum pm_gem_config_type config, u32 value); +int zynqmp_pm_get_chipid(u32 *idcode, u32 *version); +int zynqmp_pm_efuse_access(const u64 address, u32 *out); int zynqmp_pm_is_function_supported(const u32 api_id, const u32 id); int zynqmp_mmio_read(const u32 address, u32 *value); int zynqmp_mmio_write(const u32 address, const u32 mask, const u32 value);
- int ret;
- if (!idcode || !version)
return -EINVAL;
- ret = xilinx_pm_request(PM_GET_CHIPID, 0, 0, 0, 0, ret_payload);
- *idcode = ret_payload[1];
- *version = ret_payload[2];
- return ret;
- int ret;
- if (!out)
return -EINVAL;
- ret = xilinx_pm_request(PM_EFUSE_ACCESS, upper_32_bits(address),
- *out = ret_payload[1];
- return ret;
- int zynqmp_pm_is_function_supported(const u32 api_id, const u32 id) { int ret;
Thanks, Michal
Add driver to access ZynqMP efuses. This is a u-boot port of [1].
[1] https://lore.kernel.org/all/20240224114516.86365-8-srinivas.kandagatla@linar...
drivers/misc/Kconfig | 8 + drivers/misc/Makefile | 1 + drivers/misc/zynqmp_efuse.c | 360 ++++++++++++++++++++++++++++++++++++ 3 files changed, 369 insertions(+) create mode 100644 drivers/misc/zynqmp_efuse.c
diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 6009d55f400..c07f50c9a76 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -298,6 +298,14 @@ config FSL_SEC_MON Security Monitor can be transitioned on any security failures, like software violations or hardware security violations.
+config ZYNQMP_EFUSE + bool "Enable ZynqMP eFUSE Driver" + depends on ZYNQMP_FIRMWARE + help + Enable access to Zynq UltraScale (ZynqMP) eFUSEs thought PMU firmware + interface. ZnyqMP has 256 eFUSEs where some of them are security related + and cannot be read back (i.e. AES key). + choice prompt "Security monitor interaction endianess" depends on FSL_SEC_MON diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index e53d52c47b3..68ba5648eab 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -92,3 +92,4 @@ obj-$(CONFIG_ESM_K3) += k3_esm.o obj-$(CONFIG_ESM_PMIC) += esm_pmic.o obj-$(CONFIG_SL28CPLD) += sl28cpld.o obj-$(CONFIG_SPL_SOCFPGA_DT_REG) += socfpga_dtreg.o +obj-$(CONFIG_ZYNQMP_EFUSE) += zynqmp_efuse.o diff --git a/drivers/misc/zynqmp_efuse.c b/drivers/misc/zynqmp_efuse.c new file mode 100644 index 00000000000..d12de7494d2 --- /dev/null +++ b/drivers/misc/zynqmp_efuse.c @@ -0,0 +1,360 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2014 - 2015 Xilinx, Inc. + * Michal Simek michal.simek@amd.com + * + * (C) Copyright 2024 Weidmueller Interface GmbH + * Lukas Funke lukas.funke@weidmueller.com + */ + +#include <compiler.h> +#include <linux/types.h> +#include <linux/errno.h> +#include <zynqmp_firmware.h> +#include <asm/dma-mapping.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <misc.h> + +#define SILICON_REVISION_MASK 0xF +#define P_USER_0_64_UPPER_MASK GENMASK(31, 16) +#define P_USER_127_LOWER_4_BIT_MASK GENMASK(3, 0) +#define WORD_INBYTES 4 +#define SOC_VER_SIZE 0x4 +#define EFUSE_MEMORY_SIZE 0x177 +#define UNUSED_SPACE 0x8 +#define ZYNQMP_NVMEM_SIZE (SOC_VER_SIZE + UNUSED_SPACE + \ + EFUSE_MEMORY_SIZE) +#define SOC_VERSION_OFFSET 0x0 +#define EFUSE_START_OFFSET 0xC +#define EFUSE_END_OFFSET 0xFC +#define EFUSE_PUF_START_OFFSET 0x100 +#define EFUSE_PUF_MID_OFFSET 0x140 +#define EFUSE_PUF_END_OFFSET 0x17F +#define EFUSE_NOT_ENABLED 29 + +/* + * efuse access type + */ +enum efuse_access { + EFUSE_READ = 0, + EFUSE_WRITE +}; + +/** + * struct xilinx_efuse - the basic structure + * @src: address of the buffer to store the data to be write/read + * @size: read/write word count + * @offset: read/write offset + * @flag: 0 - represents efuse read and 1- represents efuse write + * @pufuserfuse:0 - represents non-puf efuses, offset is used for read/write + * 1 - represents puf user fuse row number. + * + * this structure stores all the required details to + * read/write efuse memory. + */ +struct xilinx_efuse { + u64 src; + u32 size; + u32 offset; + enum efuse_access flag; + u32 pufuserfuse; +}; + +/** + * struct efuse_map_entry - offset and length of zynqmp fuses + * @offset: offset of efuse to be read/write + * @length: length of efuse + */ +struct efuse_map_entry { + u32 offset; + u32 length; +}; + +struct efuse_map_entry zynqmp_efuse_table[] = { + {0x000, 0x04}, /* soc revision */ + {0x00c, 0x0c}, /* SoC DNA */ + {0x020, 0x04}, /* efuse-usr0 */ + {0x024, 0x04}, /* efuse-usr1 */ + {0x028, 0x04}, /* efuse-usr2 */ + {0x02c, 0x04}, /* efuse-usr3 */ + {0x030, 0x04}, /* efuse-usr4 */ + {0x034, 0x04}, /* efuse-usr5 */ + {0x038, 0x04}, /* efuse-usr6 */ + {0x03c, 0x04}, /* efuse-usr7 */ + {0x040, 0x04}, /* efuse-miscusr */ + {0x050, 0x04}, /* efuse-chash */ + {0x054, 0x04}, /* efuse-pufmisc */ + {0x058, 0x04}, /* efuse-sec */ + {0x05c, 0x04}, /* efuse-spkid */ + {0x060, 0x30}, /* efuse-aeskey */ + {0x0a0, 0x30}, /* ppk0-hash */ + {0x0d0, 0x30}, /* ppk1-hash */ + {0x100, 0x7f}, /* pufuser */ +}; + +static int zynqmp_efuse_get_length(u32 offset, u32 *base_offset, u32 *len) +{ + struct efuse_map_entry *fuse; + int i; + + for (i = 0; i < ARRAY_SIZE(zynqmp_efuse_table); ++i) { + fuse = &zynqmp_efuse_table[i]; + if (offset >= fuse->offset && + offset < fuse->offset + fuse->length) { + *base_offset = fuse->offset; + *len = fuse->length; + return 0; + } + } + + return -ENOENT; +} + +static int zynqmp_efuse_access(void *context, unsigned int offset, + void *val, size_t bytes, enum efuse_access flag, + unsigned int pufflag) +{ + struct udevice *dev = context; + struct xilinx_efuse *efuse; + ulong dma_addr; + ulong dma_buf; + size_t words = bytes / WORD_INBYTES; + int ret; + int value; + char *data; + + if (bytes % WORD_INBYTES != 0) { + dev_err(dev, "Bytes requested should be word aligned\n"); + return -EOPNOTSUPP; + } + + if (pufflag == 0 && offset % WORD_INBYTES) { + dev_err(dev, "Offset requested should be word aligned\n"); + return -EOPNOTSUPP; + } + + if (pufflag == 1 && flag == EFUSE_WRITE) { + memcpy(&value, val, bytes); + if ((offset == EFUSE_PUF_START_OFFSET || + offset == EFUSE_PUF_MID_OFFSET) && + value & P_USER_0_64_UPPER_MASK) { + dev_err(dev, "Only lower 4 bytes are allowed to be programmed in P_USER_0 & P_USER_64\n"); + return -EOPNOTSUPP; + } + + if (offset == EFUSE_PUF_END_OFFSET && + (value & P_USER_127_LOWER_4_BIT_MASK)) { + dev_err(dev, "Only MSB 28 bits are allowed to be programmed for P_USER_127\n"); + return -EOPNOTSUPP; + } + } + + efuse = dma_alloc_coherent(sizeof(struct xilinx_efuse), &dma_addr); + if (!efuse) + return -ENOMEM; + + data = dma_alloc_coherent(bytes, &dma_buf); + if (!data) { + ret = -ENOMEM; + goto efuse_data_fail; + } + + if (flag == EFUSE_WRITE) { + memcpy(data, val, bytes); + efuse->flag = EFUSE_WRITE; + } else { + efuse->flag = EFUSE_READ; + } + + efuse->src = dma_buf; + efuse->size = words; + efuse->offset = offset; + efuse->pufuserfuse = pufflag; + + flush_dcache_range((ulong)efuse, (ulong)efuse + + roundup(sizeof(struct xilinx_efuse), ARCH_DMA_MINALIGN)); + flush_dcache_range((ulong)data, (ulong)data + + roundup(sizeof(struct xilinx_efuse), ARCH_DMA_MINALIGN)); + + zynqmp_pm_efuse_access(dma_addr, (u32 *)&ret); + if (ret != 0) { + if (ret == EFUSE_NOT_ENABLED) { + dev_err(dev, "efuse access is not enabled\n"); + ret = -EOPNOTSUPP; + } else { + dev_err(dev, "Error in efuse read %x\n", ret); + ret = -EPERM; + } + goto efuse_access_err; + } + + if (flag == EFUSE_READ) + memcpy(val, data, bytes); +efuse_access_err: + dma_free_coherent(data); +efuse_data_fail: + dma_free_coherent(efuse); + + return ret; +} + +static int zynqmp_nvmem_read(void *context, unsigned int offset, void *val, + size_t bytes) +{ + struct udevice *dev = context; + int ret; + int pufflag = 0; + int idcode; + int version; + + if (offset >= EFUSE_PUF_START_OFFSET && offset <= EFUSE_PUF_END_OFFSET) + pufflag = 1; + + switch (offset) { + /* Soc version offset is zero */ + case SOC_VERSION_OFFSET: + if (bytes != SOC_VER_SIZE) + return -EOPNOTSUPP; + + ret = zynqmp_pm_get_chipid((u32 *)&idcode, (u32 *)&version); + if (ret < 0) + return ret; + + dev_dbg(dev, "Read chipid val %x %x\n", idcode, version); + *(int *)val = version & SILICON_REVISION_MASK; + break; + /* Efuse offset starts from 0xc */ + case EFUSE_START_OFFSET ... EFUSE_END_OFFSET: + case EFUSE_PUF_START_OFFSET ... EFUSE_PUF_END_OFFSET: + ret = zynqmp_efuse_access(context, offset, val, + bytes, EFUSE_READ, pufflag); + break; + default: + *(u32 *)val = 0xDEADBEEF; + ret = 0; + break; + } + + return ret; +} + +static int zynqmp_nvmem_write(void *context, + unsigned int offset, void *val, size_t bytes) +{ + int pufflag = 0; + + if (offset < EFUSE_START_OFFSET || offset > EFUSE_PUF_END_OFFSET) + return -EOPNOTSUPP; + + if (offset >= EFUSE_PUF_START_OFFSET && offset <= EFUSE_PUF_END_OFFSET) + pufflag = 1; + + return zynqmp_efuse_access(context, offset, + val, bytes, EFUSE_WRITE, pufflag); +} + +int fuse_read(u32 bank, u32 word, u32 *val) +{ + u32 base_offset, offset, len; + struct udevice *dev; + u8 buf[128]; /* maximal size of efuse is 0x7f (pufuse) */ + int ret; + + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_DRIVER_GET(zynqmp_efuse), &dev); + if (ret) + return log_msg_ret("uclass_drv", ret); + + ret = zynqmp_efuse_get_length(word, &base_offset, &len); + if (ret) { + dev_err(dev, "Invalid eFuse word offset\n"); + return ret; + } + + if (len > sizeof(buf)) + return -EINVAL; + + memset(buf, 0, sizeof(buf)); + + ret = misc_read(dev, base_offset, (void *)buf, len); + if (ret) { + dev_err(dev, "Cannot read eFuse @%u: %d", word, ret); + return ret; + } + + offset = word - base_offset; + *val = ((u32 *)buf)[offset]; + + return 0; +} + +int fuse_prog(u32 bank, u32 word, u32 val) +{ + u32 base_offset, len; + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_DRIVER_GET(zynqmp_efuse), &dev); + if (ret) + return log_msg_ret("uclass_drv", ret); + + ret = zynqmp_efuse_get_length(word, &base_offset, &len); + if (ret) { + dev_err(dev, "Invalid eFuse word offset\n"); + return ret; + } + + if (word != base_offset || len != sizeof(val)) + return -EINVAL; + + ret = misc_write(dev, word, (void *)&val, sizeof(val)); + if (ret) { + dev_err(dev, "Cannot write eFuse @%u: %d", word, ret); + return ret; + } + + return 0; +} + +int fuse_sense(u32 bank, u32 word, u32 *val) +{ + /* sense is not supported */ + return -ENOSYS; +} + +int fuse_override(u32 bank, u32 word, u32 val) +{ + /* overriding is not supported */ + return -ENOSYS; +} + +static int zynqmp_nvmem_read_compat(struct udevice *dev, int offset, + void *val, int bytes) +{ + return zynqmp_nvmem_read((void *)dev, offset, val, bytes); +} + +static int zynqmp_nvmem_write_compat(struct udevice *dev, int offset, + const void *val, int bytes) +{ + return zynqmp_nvmem_write((void *)dev, offset, (void *)val, bytes); +} + +static const struct udevice_id zynqmp_efuse_match[] = { + { .compatible = "xlnx,zynqmp-nvmem-fw", }, + { /* sentinel */ }, +}; + +static const struct misc_ops zynqmp_efuse_ops = { + .read = zynqmp_nvmem_read_compat, + .write = zynqmp_nvmem_write_compat, +}; + +U_BOOT_DRIVER(zynqmp_efuse) = { + .name = "zynqmp_efuse", + .id = UCLASS_MISC, + .of_match = zynqmp_efuse_match, + .ops = &zynqmp_efuse_ops, +};
Changes in v3:
Changes in v2:
- bool "Enable ZynqMP eFUSE Driver"
- depends on ZYNQMP_FIRMWARE
- help
- choice prompt "Security monitor interaction endianess" depends on FSL_SEC_MON
- (C) Copyright 2014 - 2015 Xilinx, Inc.
- Michal Simek michal.simek@amd.com
Not sure which version you used as source but please sync up with kernel version you used. I expect there will be much newer dates because efuse were added recently.
- (C) Copyright 2024 Weidmueller Interface GmbH
- Lukas Funke lukas.funke@weidmueller.com
EFUSE_MEMORY_SIZE)
- efuse access type
- EFUSE_READ = 0,
- EFUSE_WRITE
- struct xilinx_efuse - the basic structure
- @src: address of the buffer to store the data to be write/read
- @size: read/write word count
- @offset: read/write offset
- @flag: 0 - represents efuse read and 1- represents efuse write
- @pufuserfuse:0 - represents non-puf efuses, offset is used for read/write
- this structure stores all the required details to
- read/write efuse memory.
- u64 src;
- u32 size;
- u32 offset;
- enum efuse_access flag;
- u32 pufuserfuse;
- struct efuse_map_entry - offset and length of zynqmp fuses
- @offset: offset of efuse to be read/write
- @length: length of efuse
- u32 offset;
- u32 length;
- {0x000, 0x04}, /* soc revision */
- {0x00c, 0x0c}, /* SoC DNA */
- {0x020, 0x04}, /* efuse-usr0 */
- {0x024, 0x04}, /* efuse-usr1 */
- {0x028, 0x04}, /* efuse-usr2 */
- {0x02c, 0x04}, /* efuse-usr3 */
- {0x030, 0x04}, /* efuse-usr4 */
- {0x034, 0x04}, /* efuse-usr5 */
- {0x038, 0x04}, /* efuse-usr6 */
- {0x03c, 0x04}, /* efuse-usr7 */
- {0x040, 0x04}, /* efuse-miscusr */
- {0x050, 0x04}, /* efuse-chash */
- {0x054, 0x04}, /* efuse-pufmisc */
- {0x058, 0x04}, /* efuse-sec */
- {0x05c, 0x04}, /* efuse-spkid */
- {0x060, 0x30}, /* efuse-aeskey */
- {0x0a0, 0x30}, /* ppk0-hash */
- {0x0d0, 0x30}, /* ppk1-hash */
- {0x100, 0x7f}, /* pufuser */
- struct efuse_map_entry *fuse;
- int i;
- for (i = 0; i < ARRAY_SIZE(zynqmp_efuse_table); ++i) {
nit: wrong indentation one less tab for }
- return -ENOENT;
- struct udevice *dev = context;
- struct xilinx_efuse *efuse;
- ulong dma_addr;
- ulong dma_buf;
- size_t words = bytes / WORD_INBYTES;
- int ret;
- int value;
- char *data;
- if (bytes % WORD_INBYTES != 0) {
return -EOPNOTSUPP;
- if (pufflag == 0 && offset % WORD_INBYTES) {
return -EOPNOTSUPP;
- if (pufflag == 1 && flag == EFUSE_WRITE) {
return -EOPNOTSUPP;
return -EOPNOTSUPP;
- efuse = dma_alloc_coherent(sizeof(struct xilinx_efuse), &dma_addr);
- if (!efuse)
return -ENOMEM;
- data = dma_alloc_coherent(bytes, &dma_buf);
- if (!data) {
ret = -ENOMEM;
- if (flag == EFUSE_WRITE) {
- } else {
- efuse->src = dma_buf;
- efuse->size = words;
- efuse->offset = offset;
- efuse->pufuserfuse = pufflag;
- flush_dcache_range((ulong)efuse, (ulong)efuse +
- flush_dcache_range((ulong)data, (ulong)data +
- zynqmp_pm_efuse_access(dma_addr, (u32 *)&ret);
- if (ret != 0) {
ret = -EOPNOTSUPP;
} else {
ret = -EPERM;
- if (flag == EFUSE_READ)
+efuse_access_err:
- dma_free_coherent(data);
+efuse_data_fail:
- dma_free_coherent(efuse);
- return ret;
size_t bytes)
- int ret;
- int pufflag = 0;
- int idcode;
- int version;
- if (offset >= EFUSE_PUF_START_OFFSET && offset <= EFUSE_PUF_END_OFFSET)
pufflag = 1;
- switch (offset) {
- /* Soc version offset is zero */
- case SOC_VERSION_OFFSET:
return -EOPNOTSUPP;
if (ret < 0)
return ret;
break;
- /* Efuse offset starts from 0xc */
- case EFUSE_START_OFFSET ... EFUSE_END_OFFSET:
- case EFUSE_PUF_START_OFFSET ... EFUSE_PUF_END_OFFSET:
break;
- default:
ret = 0;
break;
- return ret;
- int pufflag = 0;
- if (offset < EFUSE_START_OFFSET || offset > EFUSE_PUF_END_OFFSET)
return -EOPNOTSUPP;
pufflag = 1;
- return zynqmp_efuse_access(context, offset,
- u32 base_offset, offset, len;
- struct udevice *dev;
- u8 buf[128]; /* maximal size of efuse is 0x7f (pufuse) */
- int ret;
- ret = uclass_get_device_by_driver(UCLASS_MISC,
- if (ret)
- ret = zynqmp_efuse_get_length(word, &base_offset, &len);
- if (ret) {
return ret;
- if (len > sizeof(buf))
return -EINVAL;
- memset(buf, 0, sizeof(buf));
- ret = misc_read(dev, base_offset, (void *)buf, len);
- if (ret) {
return ret;
- offset = word - base_offset;
- *val = ((u32 *)buf)[offset];
- u32 base_offset, len;
- int ret;
- if (ret)
- if (ret) {
return ret;
- if (word != base_offset || len != sizeof(val))
return -EINVAL;
- ret = misc_write(dev, word, (void *)&val, sizeof(val));
- if (ret) {
return ret;
- /* sense is not supported */
- return -ENOSYS;
- /* overriding is not supported */
- return -ENOSYS;
- return zynqmp_nvmem_read((void *)dev, offset, val, bytes);
- return zynqmp_nvmem_write((void *)dev, offset, (void *)val, bytes);
- { .compatible = "xlnx,zynqmp-nvmem-fw", },
- { /* sentinel */ },
- .read = zynqmp_nvmem_read_compat,
- .write = zynqmp_nvmem_write_compat,
- .name = "zynqmp_efuse",
- .id = UCLASS_MISC,
- .of_match = zynqmp_efuse_match,
- .ops = &zynqmp_efuse_ops,
The rest looks good. When that small things are fixed I will merge it.
Thanks, Michal
Michal Simek
