[U-Boot] [PATCH V3] mvsata_ide: adjust port init sequence
mvsata_ide_initialize_port(): adjust init sequence (SStatus should be checked only after all writes to SControl) and return success/failure to ide_preinit().
Also, as some tests showed init durations in the hundreds of us, raise the time-out to 01 ms to be on the safe side.
Signed-off-by: Albert Aribaud albert.aribaud@free.fr --- PATCH HISTORY
V1 Initial patch. V2 Fixed wrong placement of comment. Fixed wrong description (was 01 ms, should have been 10). Added Signed-off-by. V3 Replaced return status values with symbolic names. Made error status values negative. Renamed 'tout' to 'timeleft' for clarity. Replaced ternary '?:' operator with '!' and if.
Patch was run through checkscript.pl with 0 errors and warnings.
drivers/block/mvsata_ide.c | 42 +++++++++++++++++++++++++++++++++--------- 1 files changed, 33 insertions(+), 9 deletions(-)
diff --git a/drivers/block/mvsata_ide.c b/drivers/block/mvsata_ide.c index 077b278..3d6993a 100644 --- a/drivers/block/mvsata_ide.c +++ b/drivers/block/mvsata_ide.c @@ -91,29 +91,48 @@ struct mvsata_port_registers { #define MVSATA_SSTATUS_DET_DEVCOMM 0x00000003
/* + * Status codes to return to client callers. Currently, callers ignore + * exact value and only care for zero or nonzero, so no need to make this + * public, it is only #define'd for clarity. + * If/when standard negative codes are implemented in U-boot, then these + * #defines should be moved to, or replaced by ones from, the common list + * of status codes. + */ + +#define MVSATA_STATUS_OK 0 +#define MVSATA_STATUS_TIMEOUT -1 + +/* * Initialize one MVSATAHC port: set SControl's IPM to "always active" * and DET to "reset", then wait for SStatus's DET to become "device and * comm ok" (or time out after 50 us if no device), then set SControl's * DET back to "no action". */
-static void mvsata_ide_initialize_port(struct mvsata_port_registers *port) +static int mvsata_ide_initialize_port(struct mvsata_port_registers *port) { u32 control; u32 status; - u32 tout = 50; /* wait at most 50 us for SATA reset to complete */ + u32 timeleft = 10000; /* wait at most 10 ms for SATA reset to complete */
+ /* Set control IPM to 3 (no low power) and DET to 1 (initialize) */ control = readl(&port->scontrol); control = (control & ~MVSATA_SCONTROL_MASK) | MVSATA_PORT_INIT; writel(control, &port->scontrol); - while (--tout) { + /* Toggle control DET back to 0 (normal operation) */ + control = (control & ~MVSATA_SCONTROL_MASK) | MVSATA_PORT_USE; + writel(control, &port->scontrol); + /* wait for status DET to become 3 (device and communication OK) */ + while (--timeleft) { status = readl(&port->sstatus) & MVSATA_SSTATUS_DET_MASK; if (status == MVSATA_SSTATUS_DET_DEVCOMM) break; udelay(1); } - control = (control & ~MVSATA_SCONTROL_MASK) | MVSATA_PORT_USE; - writel(control, &port->scontrol); + /* return success or time-out error depending on time left */ + if (!timeleft) + return MVSATA_STATUS_TIMEOUT; + return MVSATA_STATUS_OK; }
/* @@ -123,18 +142,23 @@ static void mvsata_ide_initialize_port(struct mvsata_port_registers *port)
int ide_preinit(void) { + int status; /* Enable ATA port 0 (could be SATA port 0 or 1) if declared */ #if defined(CONFIG_SYS_ATA_IDE0_OFFSET) - mvsata_ide_initialize_port( + status = mvsata_ide_initialize_port( (struct mvsata_port_registers *) (CONFIG_SYS_ATA_BASE_ADDR + CONFIG_SYS_ATA_IDE0_OFFSET)); + if (status) + return status; #endif /* Enable ATA port 1 (could be SATA port 0 or 1) if declared */ #if defined(CONFIG_SYS_ATA_IDE1_OFFSET) - mvsata_ide_initialize_port( + status = mvsata_ide_initialize_port( (struct mvsata_port_registers *) (CONFIG_SYS_ATA_BASE_ADDR + CONFIG_SYS_ATA_IDE1_OFFSET)); + if (status) + return status; #endif - /* return 0 as we always succeed */ - return 0; + /* return success if all ports initializations succeeded */ + return MVSATA_STATUS_OK; }
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Albert Aribaud Sent: Wednesday, September 08, 2010 11:01 PM To: u-boot@lists.denx.de Subject: [U-Boot] [PATCH V3] mvsata_ide: adjust port init sequence
PATCH HISTORY
- Status codes to return to client callers. Currently,
callers ignore
- exact value and only care for zero or nonzero, so no need
to make this
- public, it is only #define'd for clarity.
- If/when standard negative codes are implemented in
U-boot, then these
- #defines should be moved to, or replaced by ones from,
the common list
- of status codes.
- Initialize one MVSATAHC port: set SControl's IPM to
"always active"
- and DET to "reset", then wait for SStatus's DET to become
"device and
- comm ok" (or time out after 50 us if no device), then set
SControl's
- DET back to "no action".
complete */
- u32 timeleft = 10000; /* wait at most 10 ms for SATA
- /* Set control IPM to 3 (no low power) and DET to 1
- while (--tout) {
- /* Toggle control DET back to 0 (normal operation) */
- /* wait for status DET to become 3 (device and
- while (--timeleft) { status = readl(&port->sstatus) &
- /* return success or time-out error depending on time left */
- if (!timeleft)
- return MVSATA_STATUS_OK;
- int status; /* Enable ATA port 0 (could be SATA port 0 or 1) if declared */
- status = mvsata_ide_initialize_port( (struct mvsata_port_registers *) (CONFIG_SYS_ATA_BASE_ADDR +
- if (status)
return status;
- if (status)
return status;
#endif
- /* return success if all ports initializations succeeded */
Ack
Regards.. Prafulla . .
PATCH HISTORY
callers ignore
to make this
U-boot, then these
the common list
- of status codes.
"always active"
"device and
SControl's
complete */
- while (--tout) {
- if (!timeleft)
- if (status)
return status;
- if (status)
return status;
#endif
Applied to u-boot-marvell.git master branch
-- 1.7.0.4
Signed-off-by: Albert Aribaudalbert.aribaud@free.fr
PATCH HISTORY
callers ignore
to make this
U-boot, then these
the common list
- of status codes.
"always active"
"device and
SControl's
complete */
(initialize) */ control = readl(&port->scontrol); control = (control& ~MVSATA_SCONTROL_MASK) | MVSATA_PORT_INIT; writel(control,&port->scontrol);
- while (--tout) {
- control = (control& ~MVSATA_SCONTROL_MASK) | MVSATA_PORT_USE;
- writel(control,&port->scontrol);
- while (--timeleft) { status = readl(&port->sstatus)&
if (!timeleft)
- int status; /* Enable ATA port 0 (could be SATA port 0 or 1) if declared */ #if defined(CONFIG_SYS_ATA_IDE0_OFFSET)
- if (status)
#endif /* Enable ATA port 1 (could be SATA port 0 or 1) if declared */ #if defined(CONFIG_SYS_ATA_IDE1_OFFSET)return status;
- if (status)
#endifreturn status;
- return MVSATA_STATUS_OK; }
Prafulla,
Is it possible to ask for a pull of the marvell tree in order to get this bugfix pulled in v2010.09?
Amicalement,
PATCH HISTORY
Regards. Prafulla . .
Albert ARIBAUD
Albert Aribaud
Prafulla Wadaskar
