[U-Boot] i.MX6 freeze when running Linux FSL 3.10.9-1.0.0-alpha AND U-Boot 2013.10
Hello,
last days I've been trying to isolate the hung cause of a customer board, and also SabreSD board, when using the Freescale's Linux fork of 3.10.9 with 2013.10 U-Boot.
The below patch makes it work fine but it does not seem to be possible to upstream this fix, that way. How you guys thing this could be properly integrated into U-Boot to not break other boards?
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index a390296..08f3eda 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -131,6 +131,34 @@ static void imx_set_wdog_powerdown(bool enable) writew(enable, &wdog2->wmcr); }
+static void imx_set_vddpu_power_down(void) +{ + struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; + u32 val; + + /* need to power down xPU in GPC before turn off PU LDO */ + val = readl(GPC_BASE_ADDR + 0x260); + writel(val | 0x1, GPC_BASE_ADDR + 0x260); + + val = readl(GPC_BASE_ADDR + 0x0); + writel(val | 0x1, GPC_BASE_ADDR + 0x0); + while (readl(GPC_BASE_ADDR + 0x0) & 0x1) + ; + + /* disable VDDPU */ + val = 0x3e00; + writel(val, &anatop->reg_core_clr); +} + +static void imx_set_pcie_phy_power_down(void) +{ + u32 val; + + val = readl(IOMUXC_BASE_ADDR + 0x4); + val |= 0x1 << 18; + writel(val, IOMUXC_BASE_ADDR + 0x4); +} + int arch_cpu_init(void) { init_aips(); @@ -139,6 +167,9 @@ int arch_cpu_init(void)
imx_set_wdog_powerdown(false); /* Disable PDE bit of WMCR register */
+ imx_set_pcie_phy_power_down(); + imx_set_vddpu_power_down(); + #ifdef CONFIG_APBH_DMA /* Start APBH DMA */ mxs_dma_init(); diff --git a/arch/arm/imx-common/cpu.c b/arch/arm/imx-common/cpu.c index 0cd2538..5cac1a9 100644 --- a/arch/arm/imx-common/cpu.c +++ b/arch/arm/imx-common/cpu.c @@ -171,9 +171,21 @@ u32 get_ahb_clk(void) return get_periph_clk() / (ahb_podf + 1); }
+static void set_anatop_bypass(void) +{ + struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; + u32 reg = readl(&anatop->reg_core); + + /* bypass VDDARM/VDDSOC */ + reg = reg | (0x1F << 18) | 0x1F; + writel(reg, &anatop->reg_core); +} + #if defined(CONFIG_VIDEO_IPUV3) void arch_preboot_os(void) { + set_anatop_bypass(); + /* disable video before launching O/S */ ipuv3_fb_shutdown(); }
Regards,
Hi Otavio,
Le Tue, 26 Nov 2013 12:32:45 -0200, Otavio Salvador otavio@ossystems.com.br a écrit :
Hello,
- struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR;
- u32 val;
- /* need to power down xPU in GPC before turn off PU LDO */
- val = readl(GPC_BASE_ADDR + 0x260);
- writel(val | 0x1, GPC_BASE_ADDR + 0x260);
- val = readl(GPC_BASE_ADDR + 0x0);
- writel(val | 0x1, GPC_BASE_ADDR + 0x0);
- while (readl(GPC_BASE_ADDR + 0x0) & 0x1)
- /* disable VDDPU */
- val = 0x3e00;
- writel(val, &anatop->reg_core_clr);
- u32 val;
- val = readl(IOMUXC_BASE_ADDR + 0x4);
- val |= 0x1 << 18;
- writel(val, IOMUXC_BASE_ADDR + 0x4);
- imx_set_pcie_phy_power_down();
- imx_set_vddpu_power_down();
- u32 reg = readl(&anatop->reg_core);
- /* bypass VDDARM/VDDSOC */
- reg = reg | (0x1F << 18) | 0x1F;
- writel(reg, &anatop->reg_core);
- set_anatop_bypass();
- /* disable video before launching O/S */ ipuv3_fb_shutdown();
isn't the last change (enabling bypass) sufficient to fix the problem or do you also need the 2 power_down before ?
Do you also get the kernel freeze without changing anything in u-boot when you disable cpufreq in the kernel ?
Eric
On Tue, Nov 26, 2013 at 12:39 PM, Eric Bénard eric@eukrea.com wrote:
Hi Otavio,
Hello,
- u32 val;
- val = 0x3e00;
- u32 val;
- val |= 0x1 << 18;
It does indeed. I did a full test cycle from cold boot and also from inside system reboot and it works.
So:
is the needed patch.
The FSL kernel does not build without cpufreq so I didn't try.
Le Tue, 26 Nov 2013 13:59:36 -0200, Otavio Salvador otavio@ossystems.com.br a écrit :
check if your regulator settings is not defaulted to use anatop's ldo by default instead of the PMIC's one.
Eric
I think what is happening is the invert; in case of mainline kernel it is using the internal LDO while in Freescale kernel it uses the PMIC's one. Hence the failure.
Hi Otavio,
On Tue, Nov 26, 2013 at 1:59 PM, Otavio Salvador otavio@ossystems.com.br wrote:
What do you get on your board when you do?
=> md.l 0x20c8140 1
Regards,
Fabio Estevam
On Tue, Dec 17, 2013 at 12:18 PM, Fabio Estevam festevam@gmail.com wrote:
Hi Otavio,
=> md.l 0x20c8140 1
Just to clarify, please run the command above with the original U-boot, ie, without your workaround of setting the ldo bypass mode.
Regards,
Fabio Estevam
Dear Otavio,
In message CAP9ODKpAarHeQ3w7dwChkNd7+AY7u3xdBXr4df3Fx2TBTakVtg@mail.gmail.com you wrote:
Do I understand correctly that this happens only with the FSL kernel, i. e. not with mainline Linux?
What exactly is the effect of calling your set_anatop_bypass() function? Why would that be needed on the FSL kernel, and not on mainline?
On Tue, Nov 26, 2013 at 1:39 PM, Wolfgang Denk wd@denx.de wrote:
Dear Otavio,
Exactly.
Mainline seems to not drive the pmic while the FSL kernel does. So it seems we ought to bypass the internal LDO.
Dear Otavio Salvador,
In message CAP9ODKqBwH+LfhTcPMBn1ppUtfpfUnUyyN8CTi=akwja1ka6Qg@mail.gmail.com you wrote:
Exactly.
Or rather fix the FSL kernel?
Exactly.
I am not sure the kernel is wrong here.
As I said in previous message, the mainline kernel does not drive the PMIC and the power sources are the internal LDO. The FSL kernel changes the power sources to the ones from the PMIC (which makes sense) but in the end it depends on U-Boot have done it too.
Eric Bénard
Fabio Estevam
Otavio Salvador
