[RFC PATCH 0/7] spl: Use common function for loading/parsing images
This series adds support for loading all image types (Legacy, FIT (with and without LOAD_FIT_FULL), and i.MX) to the MMC, SPI, NOR, NET, FAT, and EXT load methods. It does this by introducing a helper function which handles the minutiae of invoking the proper parsing function, and reading the rest of the image.
Hopefully, this will make it easier for load methods to support all image types that U-Boot supports, without having undocumented unsupported image types. I applied this to several loaders which were invoking spl_load_simple_fit and/or spl_parse_image_header, but I did not use it with others (e.g. DFU/RAM) which had complications in the mix.
Here's some bloat-o-meter for j7200_evm_a72_defconfig with ext4 support enabled:
add/remove: 1/0 grow/shrink: 2/4 up/down: 224/-232 (-8) Function old new delta spl_load - 176 +176 spl_fit_read 60 104 +44 spl_load_image_ext 364 368 +4 spl_nor_load_image 120 108 -12 spl_spi_load_image 280 232 -48 spl_load_image_fat 320 264 -56 spl_mmc_load 712 596 -116 Total: Before=264476, After=264468, chg -0.00%
ext4 support is +48 bytes, because the original image support was so bare-bones (just legacy/raw images). For most boards with a few load methods (where one of them isn't ext4), this series should be no bloat or a net negative. However, in the worst case this series will add 150-180 bytes.
I haven't tested most of this, so this series is marked RFC. I had a nand conversion in here as well, but dropped due to difficulties outlines in [1].
[1] https://lore.kernel.org/u-boot/c2ea7097-9e85-b9ec-e404-bd46eb83dd5b@seco.com...
Sean Anderson (7): spl: Add generic spl_load function spl: Convert ext to use spl_load spl: Convert fat to spl_load spl: Convert mmc to spl_load spl: Convert net to spl_load spl: Convert nor to spl_load spl: Convert spi to spl_load
common/spl/spl.c | 61 ++++++++++++++++++++++++++++++++++++ common/spl/spl_ext.c | 24 ++++++++++----- common/spl/spl_fat.c | 36 ++++------------------ common/spl/spl_mmc.c | 73 ++++---------------------------------------- common/spl/spl_net.c | 24 +++------------ common/spl/spl_nor.c | 35 ++++----------------- common/spl/spl_spi.c | 48 +++++------------------------ include/spl.h | 30 +++++++++++++++++- 8 files changed, 137 insertions(+), 194 deletions(-)
Implementers of SPL_LOAD_IMAGE_METHOD have to correctly determine what type of image is being loaded and then call the appropriate image load function correctly. This is tricky, because some image load functions expect the whole image to already be loaded (CONFIG_SPL_LOAD_FIT_FULL), some will load the image automatically using spl_load_info.read() (CONFIG_SPL_LOAD_FIT/CONFIG_SPL_LOAD_IMX_CONTAINER), and some just parse the header and expect the caller to do the actual loading afterwards (legacy/raw images). Load methods often only support a subset of the above methods, meaning that not all image types can be used with all load methods. Further, the code to invoke these functions is duplicated between different load functions.
To address this problem, this commit introduces a "spl_load" function. It aims to handle image detection and correct invocation of each of the parse/load functions. spl_simple_read is a wrapper around spl_load_info.read with get_aligned_image* functions inlined for size purposes. Additionally, we assume that bl_len is a power of 2 so we can do bitshifts instead of divisions (which is smaller and faster).
Signed-off-by: Sean Anderson sean.anderson@seco.com ---
common/spl/spl.c | 61 ++++++++++++++++++++++++++++++++++++++++++++++++ include/spl.h | 30 +++++++++++++++++++++++- 2 files changed, 90 insertions(+), 1 deletion(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index b452d4feeb..f26df7ac3f 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -398,6 +398,67 @@ int spl_parse_image_header(struct spl_image_info *spl_image, return 0; }
+static int spl_simple_read(struct spl_load_info *info, void *buf, size_t size, + size_t offset) +{ + int ret; + size_t bl_len = info->filename ? ARCH_DMA_MINALIGN : bl_len; + size_t bl_mask = bl_len - 1; + size_t bl_shift = ffs(bl_mask); + size_t overhead = offset & bl_mask; + + buf -= overhead; + size = (size + overhead + bl_mask) >> bl_shift; + offset = offset >> bl_shift; + + ret = info->read(info, offset, size, buf); + return ret == size ? 0 : -EIO; +} + +int spl_load(struct spl_image_info *spl_image, + const struct spl_boot_device *bootdev, struct spl_load_info *info, + struct image_header *header, size_t size, size_t sector) +{ + int ret; + size_t offset = sector * info->bl_len; + + if (image_get_magic(header) == FDT_MAGIC) { + if (IS_ENABLED(CONFIG_SPL_LOAD_FIT_FULL)) { + void *buf; + + /* + * In order to support verifying images in the FIT, we + * need to load the whole FIT into memory. Try and + * guess how much we need to load by using the total + * size. This will fail for FITs with external data, + * but there's not much we can do about that. + */ + if (!size) + size = roundup(fdt_totalsize(header), 4); + buf = spl_get_load_buffer(0, size); + ret = spl_simple_read(info, buf, size, offset); + if (ret) + return ret; + + return spl_parse_image_header(spl_image, bootdev, buf); + } + + if (IS_ENABLED(CONFIG_SPL_LOAD_FIT)) + return spl_load_simple_fit(spl_image, info, sector, + header); + } + + if (IS_ENABLED(CONFIG_SPL_LOAD_IMX_CONTAINER)) + return spl_load_imx_container(spl_image, info, sector); + + ret = spl_parse_image_header(spl_image, bootdev, header); + if (ret) + return ret; + + return spl_simple_read(info, (void *)spl_image->load_addr, + spl_image->size, offset + spl_image->offset); +} + __weak void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) { typedef void __noreturn (*image_entry_noargs_t)(void); diff --git a/include/spl.h b/include/spl.h index 8ceb3c0f09..6606f4e5f6 100644 --- a/include/spl.h +++ b/include/spl.h @@ -236,7 +236,7 @@ struct spl_image_info { * * @dev: Pointer to the device, e.g. struct mmc * * @priv: Private data for the device - * @bl_len: Block length for reading in bytes + * @bl_len: Block length for reading in bytes; must be a power of 2 * @filename: Name of the fit image file. * @read: Function to call to read from the device */ @@ -608,6 +608,34 @@ int spl_load_image_ext_os(struct spl_image_info *spl_image, struct spl_boot_device *bootdev, struct blk_desc *block_dev, int partition);
+/** + * spl_load() - Parse a header and load the image + * @spl_image: Image data which will be filled in by this function + * @bootdev: The device to load from + * @info: Describes how to load additional information from @bootdev. At the + * minimum, read() and bl_len must be populated. + * @header: The image header. This should already have been loaded. It may be + * clobbered by the load process (if e.g. the load address overlaps). + * @size: The size of the image, if it is known in advance. Some boot devices + * (such as filesystems) know how big an image is before parsing the + * header. If this information is unknown, then the size will be + * determined from the header. + * @sectors: The offset from the start if @bootdev, in units of @info->bl_len. + * This should have the offset @header was loaded from. It will be + * added to any offsets passed to @info->read(). + * + * This function determines the image type (FIT, legacy, i.MX, raw, etc), calls + * the appropriate parsing function, determines the load address, and the loads + * the image from storage. It is designed to replace ad-hoc image loading which + * may not support all image types (especially when config options are + * involved). + * + * Return: 0 on success, or a negative error on failure + */ +int spl_load(struct spl_image_info *spl_image, + const struct spl_boot_device *bootdev, struct spl_load_info *info, + struct image_header *header, size_t size, size_t sector); + /** * spl_early_init() - Set up device tree and driver model in SPL if enabled *
size_t offset)
- int ret;
- size_t bl_len = info->filename ? ARCH_DMA_MINALIGN : bl_len;
- size_t bl_mask = bl_len - 1;
- size_t bl_shift = ffs(bl_mask);
- size_t overhead = offset & bl_mask;
Nitpicking comment:
It's preferred in general to use the reverse XMAS tree ordering of the declared variables. So I would expect at least to have "int ret" as last statement above. If you address this, then please in the complete series.
Thanks, Stefan
- buf -= overhead;
- size = (size + overhead + bl_mask) >> bl_shift;
- offset = offset >> bl_shift;
- ret = info->read(info, offset, size, buf);
- return ret == size ? 0 : -EIO;
- int ret;
- size_t offset = sector * info->bl_len;
- if (image_get_magic(header) == FDT_MAGIC) {
void *buf;
if (!size)
if (ret)
return ret;
header);
- if (IS_ENABLED(CONFIG_SPL_LOAD_IMX_CONTAINER))
- ret = spl_parse_image_header(spl_image, bootdev, header);
- if (ret)
return ret;
- return spl_simple_read(info, (void *)spl_image->load_addr,
- __weak void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) { typedef void __noreturn (*image_entry_noargs_t)(void);
- @dev: Pointer to the device, e.g. struct mmc *
- @priv: Private data for the device
- @bl_len: Block length for reading in bytes
- @bl_len: Block length for reading in bytes; must be a power of 2
- @filename: Name of the fit image file.
- @read: Function to call to read from the device
- spl_load() - Parse a header and load the image
- @spl_image: Image data which will be filled in by this function
- @bootdev: The device to load from
- @info: Describes how to load additional information from @bootdev. At the
- @header: The image header. This should already have been loaded. It may be
- @size: The size of the image, if it is known in advance. Some boot devices
- @sectors: The offset from the start if @bootdev, in units of @info->bl_len.
- This function determines the image type (FIT, legacy, i.MX, raw, etc), calls
- the appropriate parsing function, determines the load address, and the loads
- the image from storage. It is designed to replace ad-hoc image loading which
- may not support all image types (especially when config options are
- involved).
- Return: 0 on success, or a negative error on failure
- spl_early_init() - Set up device tree and driver model in SPL if enabled
Viele Grüße, Stefan Roese
diff --git a/common/spl/spl.c b/common/spl/spl.c index b452d4feeb..f26df7ac3f 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -398,6 +398,67 @@ int spl_parse_image_header(struct spl_image_info *spl_image, return 0; } +static int spl_simple_read(struct spl_load_info *info, void *buf, size_t size, + size_t offset) +{ + int ret; + size_t bl_len = info->filename ? ARCH_DMA_MINALIGN : bl_len; + size_t bl_mask = bl_len - 1; + size_t bl_shift = ffs(bl_mask); + size_t overhead = offset & bl_mask;
Nitpicking comment:
I thought only Linux's net subsystem had this requirement. I can reorder things for you if you'd like. However, some of these variables have dependencies so they cannot all be reordered :)
--Sean
Thanks, Stefan
* @filename: Name of the fit image file. * @read: Function to call to read from the device */ @@ -608,6 +608,34 @@ int spl_load_image_ext_os(struct spl_image_info *spl_image, struct spl_boot_device *bootdev, struct blk_desc *block_dev, int partition); +/**
- * minimum, read() and bl_len must be populated.
- * clobbered by the load process (if e.g. the load address overlaps).
- * (such as filesystems) know how big an image is before parsing the
- * header. If this information is unknown, then the size will be
- * determined from the header.
- * This should have the offset @header was loaded from. It will be
- * added to any offsets passed to @info->read().
- involved).
Nitpicking comment:
Thanks. Perhaps it's only my personal preference. I find it more structured this way. Still I think that I remember having seen this request of reverse XMAS tree ordering here on the U-Boot list as well.
Nevertheless this is no blocker whatsoever. Please make such changes only if a v2 of the patches is required.
Thanks, Stefan
--Sean
Thanks, Stefan
- involved).
This converts the ext load method to use spl_load. As a consequence, it also adds support for FIT and IMX images.
common/spl/spl_ext.c | 24 +++++++++++++++++------- 1 file changed, 17 insertions(+), 7 deletions(-)
diff --git a/common/spl/spl_ext.c b/common/spl/spl_ext.c index ebd914c492..1384842776 100644 --- a/common/spl/spl_ext.c +++ b/common/spl/spl_ext.c @@ -9,6 +9,18 @@ #include <errno.h> #include <image.h>
+static ulong spl_fit_read(struct spl_load_info *load, ulong file_offset, + ulong size, void *buf) +{ + int ret; + loff_t actlen; + + ret = ext4fs_read(buf, file_offset, size, &actlen); + if (ret) + return ret; + return actlen; +} + int spl_load_image_ext(struct spl_image_info *spl_image, struct spl_boot_device *bootdev, struct blk_desc *block_dev, int partition, @@ -18,6 +30,10 @@ int spl_load_image_ext(struct spl_image_info *spl_image, struct image_header *header; loff_t filelen, actlen; struct disk_partition part_info = {}; + struct spl_load_info load = { + .read = spl_fit_read, + .bl_len = 1, + };
header = spl_get_load_buffer(-sizeof(*header), sizeof(*header));
@@ -47,13 +63,7 @@ int spl_load_image_ext(struct spl_image_info *spl_image, goto end; }
- err = spl_parse_image_header(spl_image, bootdev, header); - if (err < 0) { - puts("spl: ext: failed to parse image header\n"); - goto end; - } - - err = ext4fs_read((char *)spl_image->load_addr, 0, filelen, &actlen); + err = spl_load(spl_image, bootdev, &load, header, filelen, 0);
end: #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT
Thanks, Stefan
- int ret;
- loff_t actlen;
- ret = ext4fs_read(buf, file_offset, size, &actlen);
- if (ret)
return ret;
- return actlen;
- int spl_load_image_ext(struct spl_image_info *spl_image, struct spl_boot_device *bootdev, struct blk_desc *block_dev, int partition,
.bl_len = 1,
- if (err < 0) {
goto end;
This converts the fat loader to use spl_load.
common/spl/spl_fat.c | 36 ++++++------------------------------ 1 file changed, 6 insertions(+), 30 deletions(-)
diff --git a/common/spl/spl_fat.c b/common/spl/spl_fat.c index 5b270541fc..c092eb3481 100644 --- a/common/spl/spl_fat.c +++ b/common/spl/spl_fat.c @@ -61,6 +61,11 @@ int spl_load_image_fat(struct spl_image_info *spl_image, { int err; struct image_header *header; + struct spl_load_info load = { + .read = spl_fit_read, + .bl_len = 1, + .filename = filename, + };
err = spl_register_fat_device(block_dev, partition); if (err) @@ -72,36 +77,7 @@ int spl_load_image_fat(struct spl_image_info *spl_image, if (err <= 0) goto end;
- if (IS_ENABLED(CONFIG_SPL_LOAD_FIT_FULL) && - image_get_magic(header) == FDT_MAGIC) { - err = file_fat_read(filename, (void *)CONFIG_SYS_LOAD_ADDR, 0); - if (err <= 0) - goto end; - err = spl_parse_image_header(spl_image, bootdev, - (struct image_header *)CONFIG_SYS_LOAD_ADDR); - if (err == -EAGAIN) - return err; - if (err == 0) - err = 1; - } else if (IS_ENABLED(CONFIG_SPL_LOAD_FIT) && - image_get_magic(header) == FDT_MAGIC) { - struct spl_load_info load; - - debug("Found FIT\n"); - load.read = spl_fit_read; - load.bl_len = 1; - load.filename = (void *)filename; - load.priv = NULL; - - return spl_load_simple_fit(spl_image, &load, 0, header); - } else { - err = spl_parse_image_header(spl_image, bootdev, header); - if (err) - goto end; - - err = file_fat_read(filename, - (u8 *)(uintptr_t)spl_image->load_addr, 0); - } + err = spl_load(spl_image, bootdev, &load, header, err, 0);
Thanks, Stefan
.bl_len = 1,
if (err <= 0)
goto end;
if (err == -EAGAIN)
return err;
if (err == 0)
err = 1;
load.bl_len = 1;
load.priv = NULL;
- } else {
if (err)
goto end;
This converts the mmc loader to spl_load. Legacy images are handled by spl_load (via spl_parse_image_header), so mmc_load_legacy can be omitted.
common/spl/spl_mmc.c | 73 ++++---------------------------------------- 1 file changed, 6 insertions(+), 67 deletions(-)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index 1c41d24ff4..113566166f 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -17,48 +17,6 @@ #include <mmc.h> #include <image.h>
-static int mmc_load_legacy(struct spl_image_info *spl_image, - struct spl_boot_device *bootdev, - struct mmc *mmc, - ulong sector, struct image_header *header) -{ - u32 image_offset_sectors; - u32 image_size_sectors; - unsigned long count; - u32 image_offset; - int ret; - - ret = spl_parse_image_header(spl_image, bootdev, header); - if (ret) - return ret; - - /* convert offset to sectors - round down */ - image_offset_sectors = spl_image->offset / mmc->read_bl_len; - /* calculate remaining offset */ - image_offset = spl_image->offset % mmc->read_bl_len; - - /* convert size to sectors - round up */ - image_size_sectors = (spl_image->size + mmc->read_bl_len - 1) / - mmc->read_bl_len; - - /* Read the header too to avoid extra memcpy */ - count = blk_dread(mmc_get_blk_desc(mmc), - sector + image_offset_sectors, - image_size_sectors, - (void *)(ulong)spl_image->load_addr); - debug("read %x sectors to %lx\n", image_size_sectors, - spl_image->load_addr); - if (count != image_size_sectors) - return -EIO; - - if (image_offset) - memmove((void *)(ulong)spl_image->load_addr, - (void *)(ulong)spl_image->load_addr + image_offset, - spl_image->size); - - return 0; -} - static ulong h_spl_load_read(struct spl_load_info *load, ulong sector, ulong count, void *buf) { @@ -86,6 +44,11 @@ int mmc_load_image_raw_sector(struct spl_image_info *spl_image, struct image_header *header; struct blk_desc *bd = mmc_get_blk_desc(mmc); int ret = 0; + struct spl_load_info load = { + .dev = mmc, + .bl_len = mmc->read_bl_len, + .read = h_spl_load_read, + };
header = spl_get_load_buffer(-sizeof(*header), bd->blksz);
@@ -97,31 +60,7 @@ int mmc_load_image_raw_sector(struct spl_image_info *spl_image, goto end; }
- if (IS_ENABLED(CONFIG_SPL_LOAD_FIT) && - image_get_magic(header) == FDT_MAGIC) { - struct spl_load_info load; - - debug("Found FIT\n"); - load.dev = mmc; - load.priv = NULL; - load.filename = NULL; - load.bl_len = mmc->read_bl_len; - load.read = h_spl_load_read; - ret = spl_load_simple_fit(spl_image, &load, sector, header); - } else if (IS_ENABLED(CONFIG_SPL_LOAD_IMX_CONTAINER)) { - struct spl_load_info load; - - load.dev = mmc; - load.priv = NULL; - load.filename = NULL; - load.bl_len = mmc->read_bl_len; - load.read = h_spl_load_read; - - ret = spl_load_imx_container(spl_image, &load, sector); - } else { - ret = mmc_load_legacy(spl_image, bootdev, mmc, sector, header); - } - + ret = spl_load(spl_image, bootdev, &load, header, 0, sector); end: if (ret) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT
Thanks, Stefan
struct mmc *mmc,
- u32 image_offset;
- int ret;
- if (ret)
return ret;
mmc->read_bl_len;
image_size_sectors,
return -EIO;
- if (image_offset)
spl_image->size);
.dev = mmc,
load.dev = mmc;
load.priv = NULL;
load.dev = mmc;
load.priv = NULL;
- } else {
- ret = spl_load(spl_image, bootdev, &load, header, 0, sector); end: if (ret) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT
This converts the net load method to use spl_load. As a result, it also adds support for LOAD_FIT_FULL and IMX images.
common/spl/spl_net.c | 24 +++++------------------- 1 file changed, 5 insertions(+), 19 deletions(-)
diff --git a/common/spl/spl_net.c b/common/spl/spl_net.c index a853e6aead..3b4374add6 100644 --- a/common/spl/spl_net.c +++ b/common/spl/spl_net.c @@ -29,6 +29,10 @@ static int spl_net_load_image(struct spl_image_info *spl_image, struct spl_boot_device *bootdev) { struct image_header *header = (struct image_header *)image_load_addr; + struct spl_load_info load = { + .bl_len = 1, + .read = spl_net_load_read, + }; int rv;
env_init(); @@ -47,25 +51,7 @@ static int spl_net_load_image(struct spl_image_info *spl_image, return rv; }
- if (IS_ENABLED(CONFIG_SPL_LOAD_FIT) && - image_get_magic(header) == FDT_MAGIC) { - struct spl_load_info load; - - debug("Found FIT\n"); - load.bl_len = 1; - load.read = spl_net_load_read; - rv = spl_load_simple_fit(spl_image, &load, 0, header); - } else { - debug("Legacy image\n"); - - rv = spl_parse_image_header(spl_image, bootdev, header); - if (rv) - return rv; - - memcpy((void *)spl_image->load_addr, header, spl_image->size); - } - - return rv; + return spl_load(spl_image, bootdev, &load, header, 0, 0); } #endif
Thanks, Stefan
.bl_len = 1,
}; int rv;
env_init();
load.bl_len = 1;
- } else {
if (rv)
return rv;
- return rv;
- return spl_load(spl_image, bootdev, &load, header, 0, 0); } #endif
This converts the nor load method to use spl_load. As a result it also adds support LOAD_FIT_FULL.
common/spl/spl_nor.c | 35 ++++++----------------------------- 1 file changed, 6 insertions(+), 29 deletions(-)
diff --git a/common/spl/spl_nor.c b/common/spl/spl_nor.c index 0f4fff8493..90ece77af1 100644 --- a/common/spl/spl_nor.c +++ b/common/spl/spl_nor.c @@ -26,8 +26,11 @@ unsigned long __weak spl_nor_get_uboot_base(void) static int spl_nor_load_image(struct spl_image_info *spl_image, struct spl_boot_device *bootdev) { - __maybe_unused const struct image_header *header; - __maybe_unused struct spl_load_info load; + struct image_header *header = (void *)spl_nor_get_uboot_base(); + struct spl_load_info load = { + .bl_len = 1, + .read = spl_nor_load_read, + };
/* * Loading of the payload to SDRAM is done with skipping of @@ -91,32 +94,6 @@ static int spl_nor_load_image(struct spl_image_info *spl_image, * Load real U-Boot from its location in NOR flash to its * defined location in SDRAM */ -#ifdef CONFIG_SPL_LOAD_FIT - header = (const struct image_header *)spl_nor_get_uboot_base(); - if (image_get_magic(header) == FDT_MAGIC) { - debug("Found FIT format U-Boot\n"); - load.bl_len = 1; - load.read = spl_nor_load_read; - return spl_load_simple_fit(spl_image, &load, - spl_nor_get_uboot_base(), - (void *)header); - } -#endif - if (IS_ENABLED(CONFIG_SPL_LOAD_IMX_CONTAINER)) { - load.bl_len = 1; - load.read = spl_nor_load_read; - return spl_load_imx_container(spl_image, &load, - spl_nor_get_uboot_base()); - } - - /* Legacy image handling */ - if (IS_ENABLED(CONFIG_SPL_LEGACY_IMAGE_SUPPORT)) { - load.bl_len = 1; - load.read = spl_nor_load_read; - return spl_load_legacy_img(spl_image, bootdev, &load, - spl_nor_get_uboot_base()); - } - - return 0; + return spl_load(spl_image, bootdev, &load, header, 0, 0); } SPL_LOAD_IMAGE_METHOD("NOR", 0, BOOT_DEVICE_NOR, spl_nor_load_image);
Thanks, Stefan
.bl_len = 1,
- Loading of the payload to SDRAM is done with skipping of
load.bl_len = 1;
(void *)header);
-#endif
load.bl_len = 1;
load.bl_len = 1;
- return spl_load(spl_image, bootdev, &load, header, 0, 0); } SPL_LOAD_IMAGE_METHOD("NOR", 0, BOOT_DEVICE_NOR, spl_nor_load_image);
This converts the spi load method to use spl_load. As a consequence, it also adds support for LOAD_FIT_FULL.
common/spl/spl_spi.c | 48 +++++++------------------------------------- 1 file changed, 7 insertions(+), 41 deletions(-)
diff --git a/common/spl/spl_spi.c b/common/spl/spl_spi.c index cf3f7ef4c0..037db1a19f 100644 --- a/common/spl/spl_spi.c +++ b/common/spl/spl_spi.c @@ -83,6 +83,10 @@ static int spl_spi_load_image(struct spl_image_info *spl_image, unsigned int payload_offs; struct spi_flash *flash; struct image_header *header; + struct spl_load_info load = { + .bl_len = 1, + .read = spl_spi_fit_read, + };
/* * Load U-Boot image from SPI flash into RAM @@ -99,6 +103,7 @@ static int spl_spi_load_image(struct spl_image_info *spl_image, return -ENODEV; }
+ load.dev = flash; payload_offs = spl_spi_get_uboot_offs(flash);
header = spl_get_load_buffer(-sizeof(*header), sizeof(*header)); @@ -121,47 +126,8 @@ static int spl_spi_load_image(struct spl_image_info *spl_image, return err; }
- if (IS_ENABLED(CONFIG_SPL_LOAD_FIT_FULL) && - image_get_magic(header) == FDT_MAGIC) { - err = spi_flash_read(flash, payload_offs, - roundup(fdt_totalsize(header), 4), - (void *)CONFIG_SYS_LOAD_ADDR); - if (err) - return err; - err = spl_parse_image_header(spl_image, bootdev, - (struct image_header *)CONFIG_SYS_LOAD_ADDR); - } else if (IS_ENABLED(CONFIG_SPL_LOAD_FIT) && - image_get_magic(header) == FDT_MAGIC) { - struct spl_load_info load; - - debug("Found FIT\n"); - load.dev = flash; - load.priv = NULL; - load.filename = NULL; - load.bl_len = 1; - load.read = spl_spi_fit_read; - err = spl_load_simple_fit(spl_image, &load, - payload_offs, - header); - } else if (IS_ENABLED(CONFIG_SPL_LOAD_IMX_CONTAINER)) { - struct spl_load_info load; - - load.dev = flash; - load.priv = NULL; - load.filename = NULL; - load.bl_len = 1; - load.read = spl_spi_fit_read; - - err = spl_load_imx_container(spl_image, &load, - payload_offs); - } else { - err = spl_parse_image_header(spl_image, bootdev, header); - if (err) - return err; - err = spi_flash_read(flash, payload_offs + spl_image->offset, - spl_image->size, - (void *)spl_image->load_addr); - } + err = spl_load(spl_image, bootdev, &load, header, 0, + payload_offs); }
return err;
Thanks, Stefan
.bl_len = 1,
- Load U-Boot image from SPI flash into RAM
if (err)
return err;
load.dev = flash;
load.priv = NULL;
load.bl_len = 1;
payload_offs,
header);
load.dev = flash;
load.priv = NULL;
load.bl_len = 1;
payload_offs);
} else {
if (err)
return err;
spl_image->size,
payload_offs);
return err;
I like the idea of consolidating this SPL code a lot. Thanks for working on this.
Thanks, Stefan
Sean Anderson
Stefan Roese
