[U-Boot] [PATCH 1/3] sh: add support for sh7753evb board instead of sh7752evb
The SH7753 EVB board has SH7753, 512MB DDR3-SDRAM, SPI ROM, Gigabit Ethernet, and eMMC.
This patch support the following functions: - 512MB DDR3-SDRAM, SCIF4, SPI ROM, Gigabit Ethernet, eMMC
This patch changes the support for sh7752evb to sh7753evb.
Signed-off-by: Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com --- arch/sh/include/asm/cpu_sh4.h | 4 +- arch/sh/include/asm/cpu_sh7752.h | 197 -------------- arch/sh/include/asm/cpu_sh7753.h | 197 ++++++++++++++ board/renesas/sh7752evb/Makefile | 7 - board/renesas/sh7752evb/lowlevel_init.S | 447 ------------------------------- board/renesas/sh7752evb/sh7752evb.c | 314 ---------------------- board/renesas/sh7752evb/spi-boot.c | 116 -------- board/renesas/sh7752evb/u-boot.lds | 81 ------ board/renesas/sh7753evb/Makefile | 7 + board/renesas/sh7753evb/lowlevel_init.S | 416 ++++++++++++++++++++++++++++ board/renesas/sh7753evb/sh7753evb.c | 326 ++++++++++++++++++++++ board/renesas/sh7753evb/spi-boot.c | 134 +++++++++ board/renesas/sh7753evb/u-boot.lds | 81 ++++++ boards.cfg | 2 +- doc/README.sh7752evb | 67 ----- doc/README.sh7753evb | 67 +++++ include/configs/sh7752evb.h | 137 ---------- include/configs/sh7753evb.h | 137 ++++++++++ 18 files changed, 1368 insertions(+), 1369 deletions(-) delete mode 100644 arch/sh/include/asm/cpu_sh7752.h create mode 100644 arch/sh/include/asm/cpu_sh7753.h delete mode 100644 board/renesas/sh7752evb/Makefile delete mode 100644 board/renesas/sh7752evb/lowlevel_init.S delete mode 100644 board/renesas/sh7752evb/sh7752evb.c delete mode 100644 board/renesas/sh7752evb/spi-boot.c delete mode 100644 board/renesas/sh7752evb/u-boot.lds create mode 100644 board/renesas/sh7753evb/Makefile create mode 100644 board/renesas/sh7753evb/lowlevel_init.S create mode 100644 board/renesas/sh7753evb/sh7753evb.c create mode 100644 board/renesas/sh7753evb/spi-boot.c create mode 100644 board/renesas/sh7753evb/u-boot.lds delete mode 100644 doc/README.sh7752evb create mode 100644 doc/README.sh7753evb delete mode 100644 include/configs/sh7752evb.h create mode 100644 include/configs/sh7753evb.h
diff --git a/arch/sh/include/asm/cpu_sh4.h b/arch/sh/include/asm/cpu_sh4.h index 9181d59..9939f20 100644 --- a/arch/sh/include/asm/cpu_sh4.h +++ b/arch/sh/include/asm/cpu_sh4.h @@ -35,8 +35,8 @@ # include <asm/cpu_sh7724.h> #elif defined (CONFIG_CPU_SH7734) # include <asm/cpu_sh7734.h> -#elif defined (CONFIG_CPU_SH7752) -# include <asm/cpu_sh7752.h> +#elif defined (CONFIG_CPU_SH7753) +# include <asm/cpu_sh7753.h> #elif defined (CONFIG_CPU_SH7757) # include <asm/cpu_sh7757.h> #elif defined (CONFIG_CPU_SH7763) diff --git a/arch/sh/include/asm/cpu_sh7752.h b/arch/sh/include/asm/cpu_sh7752.h deleted file mode 100644 index 229ab07..0000000 --- a/arch/sh/include/asm/cpu_sh7752.h +++ /dev/null @@ -1,197 +0,0 @@ -/* - * Copyright (C) 2012 Renesas Solutions Corp. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef _ASM_CPU_SH7752_H_ -#define _ASM_CPU_SH7752_H_ - -#define CCR 0xFF00001C -#define WTCNT 0xFFCC0000 -#define CCR_CACHE_INIT 0x0000090b -#define CACHE_OC_NUM_WAYS 1 - -#ifndef __ASSEMBLY__ /* put C only stuff in this section */ -/* MMU */ -struct mmu_regs { - unsigned int reserved[4]; - unsigned int mmucr; -}; -#define MMU_BASE ((struct mmu_regs *)0xff000000) - -/* Watchdog */ -#define WTCSR0 0xffcc0002 -#define WRSTCSR_R 0xffcc0003 -#define WRSTCSR_W 0xffcc0002 -#define WTCSR_PREFIX 0xa500 -#define WRSTCSR_PREFIX 0x6900 -#define WRSTCSR_WOVF_PREFIX 0x9600 - -/* SCIF */ -#define SCIF0_BASE 0xfe4b0000 /* The real name is SCIF2 */ -#define SCIF1_BASE 0xfe4c0000 /* The real name is SCIF3 */ -#define SCIF2_BASE 0xfe4d0000 /* The real name is SCIF4 */ - -/* TMU0 */ -#define TMU_BASE 0xFE430000 - -/* ETHER, GETHER MAC address */ -struct ether_mac_regs { - unsigned int reserved[114]; - unsigned int mahr; - unsigned int reserved2; - unsigned int malr; -}; -#define GETHER0_MAC_BASE ((struct ether_mac_regs *)0xfee0400) -#define GETHER1_MAC_BASE ((struct ether_mac_regs *)0xfee0c00) -#define ETHER0_MAC_BASE ((struct ether_mac_regs *)0xfef0000) -#define ETHER1_MAC_BASE ((struct ether_mac_regs *)0xfef0800) - -/* GETHER */ -struct gether_control_regs { - unsigned int gbecont; -}; -#define GETHER_CONTROL_BASE ((struct gether_control_regs *)0xffc10100) -#define GBECONT_RMII1 0x00020000 -#define GBECONT_RMII0 0x00010000 - -/* SerMux */ -struct sermux_regs { - unsigned char smr0; - unsigned char smr1; - unsigned char smr2; - unsigned char smr3; - unsigned char smr4; - unsigned char smr5; -}; -#define SERMUX_BASE ((struct sermux_regs *)0xfe470000) - - -/* USB0/1 */ -struct usb_common_regs { - unsigned short reserved[129]; - unsigned short suspmode; -}; -#define USB0_COMMON_BASE ((struct usb_common_regs *)0xfe450000) -#define USB1_COMMON_BASE ((struct usb_common_regs *)0xfe4f0000) - -struct usb0_phy_regs { - unsigned short reset; - unsigned short reserved[4]; - unsigned short portsel; -}; -#define USB0_PHY_BASE ((struct usb0_phy_regs *)0xfe5f0000) - -struct usb1_port_regs { - unsigned int port1sel; - unsigned int reserved; - unsigned int usb1intsts; -}; -#define USB1_PORT_BASE ((struct usb1_port_regs *)0xfe4f2000) - -struct usb1_alignment_regs { - unsigned int ehcidatac; /* 0xfe4fe018 */ - unsigned int reserved[63]; - unsigned int ohcidatac; -}; -#define USB1_ALIGNMENT_BASE ((struct usb1_alignment_regs *)0xfe4fe018) - -/* GPIO */ -struct gpio_regs { - unsigned short pacr; - unsigned short pbcr; - unsigned short pccr; - unsigned short pdcr; - unsigned short pecr; - unsigned short pfcr; - unsigned short pgcr; - unsigned short phcr; - unsigned short picr; - unsigned short pjcr; - unsigned short pkcr; - unsigned short plcr; - unsigned short pmcr; - unsigned short pncr; - unsigned short pocr; - unsigned short reserved; - unsigned short pqcr; - unsigned short prcr; - unsigned short pscr; - unsigned short ptcr; - unsigned short pucr; - unsigned short pvcr; - unsigned short pwcr; - unsigned short pxcr; - unsigned short pycr; - unsigned short pzcr; - unsigned char padr; - unsigned char reserved_a; - unsigned char pbdr; - unsigned char reserved_b; - unsigned char pcdr; - unsigned char reserved_c; - unsigned char pddr; - unsigned char reserved_d; - unsigned char pedr; - unsigned char reserved_e; - unsigned char pfdr; - unsigned char reserved_f; - unsigned char pgdr; - unsigned char reserved_g; - unsigned char phdr; - unsigned char reserved_h; - unsigned char pidr; - unsigned char reserved_i; - unsigned char pjdr; - unsigned char reserved_j; - unsigned char pkdr; - unsigned char reserved_k; - unsigned char pldr; - unsigned char reserved_l; - unsigned char pmdr; - unsigned char reserved_m; - unsigned char pndr; - unsigned char reserved_n; - unsigned char podr; - unsigned char reserved_o; - unsigned char ppdr; - unsigned char reserved_p; - unsigned char pqdr; - unsigned char reserved_q; - unsigned char prdr; - unsigned char reserved_r; - unsigned char psdr; - unsigned char reserved_s; - unsigned char ptdr; - unsigned char reserved_t; - unsigned char pudr; - unsigned char reserved_u; - unsigned char pvdr; - unsigned char reserved_v; - unsigned char pwdr; - unsigned char reserved_w; - unsigned char pxdr; - unsigned char reserved_x; - unsigned char pydr; - unsigned char reserved_y; - unsigned char pzdr; - unsigned char reserved_z; - unsigned short ncer; - unsigned short ncmcr; - unsigned short nccsr; - unsigned char reserved2[2]; - unsigned short psel0; /* +0x70 */ - unsigned short psel1; - unsigned short psel2; - unsigned short psel3; - unsigned short psel4; - unsigned short psel5; - unsigned short psel6; - unsigned short reserved3[2]; - unsigned short psel7; -}; -#define GPIO_BASE ((struct gpio_regs *)0xffec0000) - -#endif /* ifndef __ASSEMBLY__ */ -#endif /* _ASM_CPU_SH7752_H_ */ diff --git a/arch/sh/include/asm/cpu_sh7753.h b/arch/sh/include/asm/cpu_sh7753.h new file mode 100644 index 0000000..cd0e0bb --- /dev/null +++ b/arch/sh/include/asm/cpu_sh7753.h @@ -0,0 +1,197 @@ +/* + * Copyright (C) 2012 Renesas Solutions Corp. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ASM_CPU_SH7753_H_ +#define _ASM_CPU_SH7753_H_ + +#define CCR 0xFF00001C +#define WTCNT 0xFFCC0000 +#define CCR_CACHE_INIT 0x0000090b +#define CACHE_OC_NUM_WAYS 1 + +#ifndef __ASSEMBLY__ /* put C only stuff in this section */ +/* MMU */ +struct mmu_regs { + unsigned int reserved[4]; + unsigned int mmucr; +}; +#define MMU_BASE ((struct mmu_regs *)0xff000000) + +/* Watchdog */ +#define WTCSR0 0xffcc0002 +#define WRSTCSR_R 0xffcc0003 +#define WRSTCSR_W 0xffcc0002 +#define WTCSR_PREFIX 0xa500 +#define WRSTCSR_PREFIX 0x6900 +#define WRSTCSR_WOVF_PREFIX 0x9600 + +/* SCIF */ +#define SCIF0_BASE 0xfe4b0000 /* The real name is SCIF2 */ +#define SCIF1_BASE 0xfe4c0000 /* The real name is SCIF3 */ +#define SCIF2_BASE 0xfe4d0000 /* The real name is SCIF4 */ + +/* TMU0 */ +#define TMU_BASE 0xFE430000 + +/* ETHER, GETHER MAC address */ +struct ether_mac_regs { + unsigned int reserved[114]; + unsigned int mahr; + unsigned int reserved2; + unsigned int malr; +}; +#define GETHER0_MAC_BASE ((struct ether_mac_regs *)0xfee0400) +#define GETHER1_MAC_BASE ((struct ether_mac_regs *)0xfee0c00) +#define ETHER0_MAC_BASE ((struct ether_mac_regs *)0xfef0000) +#define ETHER1_MAC_BASE ((struct ether_mac_regs *)0xfef0800) + +/* GETHER */ +struct gether_control_regs { + unsigned int gbecont; +}; +#define GETHER_CONTROL_BASE ((struct gether_control_regs *)0xffc10100) +#define GBECONT_RMII1 0x00020000 +#define GBECONT_RMII0 0x00010000 + +/* SerMux */ +struct sermux_regs { + unsigned char smr0; + unsigned char smr1; + unsigned char smr2; + unsigned char smr3; + unsigned char smr4; + unsigned char smr5; +}; +#define SERMUX_BASE ((struct sermux_regs *)0xfe470000) + + +/* USB0/1 */ +struct usb_common_regs { + unsigned short reserved[129]; + unsigned short suspmode; +}; +#define USB0_COMMON_BASE ((struct usb_common_regs *)0xfe450000) +#define USB1_COMMON_BASE ((struct usb_common_regs *)0xfe4f0000) + +struct usb0_phy_regs { + unsigned short reset; + unsigned short reserved[4]; + unsigned short portsel; +}; +#define USB0_PHY_BASE ((struct usb0_phy_regs *)0xfe5f0000) + +struct usb1_port_regs { + unsigned int port1sel; + unsigned int reserved; + unsigned int usb1intsts; +}; +#define USB1_PORT_BASE ((struct usb1_port_regs *)0xfe4f2000) + +struct usb1_alignment_regs { + unsigned int ehcidatac; /* 0xfe4fe018 */ + unsigned int reserved[63]; + unsigned int ohcidatac; +}; +#define USB1_ALIGNMENT_BASE ((struct usb1_alignment_regs *)0xfe4fe018) + +/* GPIO */ +struct gpio_regs { + unsigned short pacr; + unsigned short pbcr; + unsigned short pccr; + unsigned short pdcr; + unsigned short pecr; + unsigned short pfcr; + unsigned short pgcr; + unsigned short phcr; + unsigned short picr; + unsigned short pjcr; + unsigned short pkcr; + unsigned short plcr; + unsigned short pmcr; + unsigned short pncr; + unsigned short pocr; + unsigned short reserved; + unsigned short pqcr; + unsigned short prcr; + unsigned short pscr; + unsigned short ptcr; + unsigned short pucr; + unsigned short pvcr; + unsigned short pwcr; + unsigned short pxcr; + unsigned short pycr; + unsigned short pzcr; + unsigned char padr; + unsigned char reserved_a; + unsigned char pbdr; + unsigned char reserved_b; + unsigned char pcdr; + unsigned char reserved_c; + unsigned char pddr; + unsigned char reserved_d; + unsigned char pedr; + unsigned char reserved_e; + unsigned char pfdr; + unsigned char reserved_f; + unsigned char pgdr; + unsigned char reserved_g; + unsigned char phdr; + unsigned char reserved_h; + unsigned char pidr; + unsigned char reserved_i; + unsigned char pjdr; + unsigned char reserved_j; + unsigned char pkdr; + unsigned char reserved_k; + unsigned char pldr; + unsigned char reserved_l; + unsigned char pmdr; + unsigned char reserved_m; + unsigned char pndr; + unsigned char reserved_n; + unsigned char podr; + unsigned char reserved_o; + unsigned char ppdr; + unsigned char reserved_p; + unsigned char pqdr; + unsigned char reserved_q; + unsigned char prdr; + unsigned char reserved_r; + unsigned char psdr; + unsigned char reserved_s; + unsigned char ptdr; + unsigned char reserved_t; + unsigned char pudr; + unsigned char reserved_u; + unsigned char pvdr; + unsigned char reserved_v; + unsigned char pwdr; + unsigned char reserved_w; + unsigned char pxdr; + unsigned char reserved_x; + unsigned char pydr; + unsigned char reserved_y; + unsigned char pzdr; + unsigned char reserved_z; + unsigned short ncer; + unsigned short ncmcr; + unsigned short nccsr; + unsigned char reserved2[2]; + unsigned short psel0; /* +0x70 */ + unsigned short psel1; + unsigned short psel2; + unsigned short psel3; + unsigned short psel4; + unsigned short psel5; + unsigned short psel6; + unsigned short reserved3[2]; + unsigned short psel7; +}; +#define GPIO_BASE ((struct gpio_regs *)0xffec0000) + +#endif /* ifndef __ASSEMBLY__ */ +#endif /* _ASM_CPU_SH7753_H_ */ diff --git a/board/renesas/sh7752evb/Makefile b/board/renesas/sh7752evb/Makefile deleted file mode 100644 index 856af81..0000000 --- a/board/renesas/sh7752evb/Makefile +++ /dev/null @@ -1,7 +0,0 @@ -# -# Copyright (C) 2012 Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com -# -# SPDX-License-Identifier: GPL-2.0+ - -obj-y := sh7752evb.o spi-boot.o -obj-y += lowlevel_init.o diff --git a/board/renesas/sh7752evb/lowlevel_init.S b/board/renesas/sh7752evb/lowlevel_init.S deleted file mode 100644 index 5643a69..0000000 --- a/board/renesas/sh7752evb/lowlevel_init.S +++ /dev/null @@ -1,447 +0,0 @@ -/* - * Copyright (C) 2012 Renesas Solutions Corp. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <config.h> -#include <version.h> -#include <asm/processor.h> -#include <asm/macro.h> - -.macro or32, addr, data - mov.l \addr, r1 - mov.l \data, r0 - mov.l @r1, r2 - or r2, r0 - mov.l r0, @r1 -.endm - -.macro wait_DBCMD - mov.l DBWAIT_A, r0 - mov.l @r0, r1 -.endm - - .global lowlevel_init - .section .spiboot1.text - .align 2 - -lowlevel_init: - /*------- GPIO -------*/ - write16 PDCR_A, PDCR_D ! SPI0 - write16 PGCR_A, PGCR_D ! SPI0, GETHER MDIO gate(PTG1) - write16 PJCR_A, PJCR_D ! SCIF4 - write16 PTCR_A, PTCR_D ! STATUS - write16 PSEL1_A, PSEL1_D ! SPI0 - write16 PSEL2_A, PSEL2_D ! SPI0 - write16 PSEL5_A, PSEL5_D ! STATUS - - bra exit_gpio - nop - - .align 2 - -/*------- GPIO -------*/ -PDCR_A: .long 0xffec0006 -PGCR_A: .long 0xffec000c -PJCR_A: .long 0xffec0012 -PTCR_A: .long 0xffec0026 -PSEL1_A: .long 0xffec0072 -PSEL2_A: .long 0xffec0074 -PSEL5_A: .long 0xffec007a - -PDCR_D: .long 0x0000 -PGCR_D: .long 0x0004 -PJCR_D: .long 0x0000 -PTCR_D: .long 0x0000 -PSEL1_D: .long 0x0000 -PSEL2_D: .long 0x3000 -PSEL5_D: .long 0x0ffc - - .align 2 - -exit_gpio: - mov #0, r14 - mova 2f, r0 - mov.l PC_MASK, r1 - tst r0, r1 - bf 2f - - bra exit_pmb - nop - - .align 2 - -/* If CPU runs on SDRAM (PC=0x5???????) or not. */ -PC_MASK: .long 0x20000000 - -2: - mov #1, r14 - - mov.l EXPEVT_A, r0 - mov.l @r0, r0 - mov.l EXPEVT_POWER_ON_RESET, r1 - cmp/eq r0, r1 - bt 1f - - /* - * If EXPEVT value is manual reset or tlb multipul-hit, - * initialization of DDR3IF is not necessary. - */ - bra exit_ddr - nop - -1: - /*------- Reset -------*/ - write32 MRSTCR0_A, MRSTCR0_D - write32 MRSTCR1_A, MRSTCR1_D - - /* For Core Reset */ - mov.l DBACEN_A, r0 - mov.l @r0, r0 - cmp/eq #0, r0 - bt 3f - - /* - * If DBACEN == 1(DBSC was already enabled), we have to avoid the - * initialization of DDR3-SDRAM. - */ - bra exit_ddr - nop - -3: - /*------- DDR3IF -------*/ - /* oscillation stabilization time */ - wait_timer WAIT_OSC_TIME - - /* step 3 */ - write32 DBCMD_A, DBCMD_RSTL_VAL - wait_timer WAIT_30US - - /* step 4 */ - write32 DBCMD_A, DBCMD_PDEN_VAL - - /* step 5 */ - write32 DBKIND_A, DBKIND_D - - /* step 6 */ - write32 DBCONF_A, DBCONF_D - write32 DBTR0_A, DBTR0_D - write32 DBTR1_A, DBTR1_D - write32 DBTR2_A, DBTR2_D - write32 DBTR3_A, DBTR3_D - write32 DBTR4_A, DBTR4_D - write32 DBTR5_A, DBTR5_D - write32 DBTR6_A, DBTR6_D - write32 DBTR7_A, DBTR7_D - write32 DBTR8_A, DBTR8_D - write32 DBTR9_A, DBTR9_D - write32 DBTR10_A, DBTR10_D - write32 DBTR11_A, DBTR11_D - write32 DBTR12_A, DBTR12_D - write32 DBTR13_A, DBTR13_D - write32 DBTR14_A, DBTR14_D - write32 DBTR15_A, DBTR15_D - write32 DBTR16_A, DBTR16_D - write32 DBTR17_A, DBTR17_D - write32 DBTR18_A, DBTR18_D - write32 DBTR19_A, DBTR19_D - write32 DBRNK0_A, DBRNK0_D - - /* step 7 */ - write32 DBPDCNT3_A, DBPDCNT3_D - - /* step 8 */ - write32 DBPDCNT1_A, DBPDCNT1_D - write32 DBPDCNT2_A, DBPDCNT2_D - write32 DBPDLCK_A, DBPDLCK_D - write32 DBPDRGA_A, DBPDRGA_D - write32 DBPDRGD_A, DBPDRGD_D - - /* step 9 */ - wait_timer WAIT_30US - - /* step 10 */ - write32 DBPDCNT0_A, DBPDCNT0_D - - /* step 11 */ - wait_timer WAIT_30US - wait_timer WAIT_30US - - /* step 12 */ - write32 DBCMD_A, DBCMD_WAIT_VAL - wait_DBCMD - - /* step 13 */ - write32 DBCMD_A, DBCMD_RSTH_VAL - wait_DBCMD - - /* step 14 */ - write32 DBCMD_A, DBCMD_WAIT_VAL - write32 DBCMD_A, DBCMD_WAIT_VAL - write32 DBCMD_A, DBCMD_WAIT_VAL - write32 DBCMD_A, DBCMD_WAIT_VAL - - /* step 15 */ - write32 DBCMD_A, DBCMD_PDXT_VAL - - /* step 16 */ - write32 DBCMD_A, DBCMD_MRS2_VAL - - /* step 17 */ - write32 DBCMD_A, DBCMD_MRS3_VAL - - /* step 18 */ - write32 DBCMD_A, DBCMD_MRS1_VAL - - /* step 19 */ - write32 DBCMD_A, DBCMD_MRS0_VAL - - /* step 20 */ - write32 DBCMD_A, DBCMD_ZQCL_VAL - - write32 DBCMD_A, DBCMD_REF_VAL - write32 DBCMD_A, DBCMD_REF_VAL - wait_DBCMD - - /* step 21 */ - write32 DBADJ0_A, DBADJ0_D - write32 DBADJ1_A, DBADJ1_D - write32 DBADJ2_A, DBADJ2_D - - /* step 22 */ - write32 DBRFCNF0_A, DBRFCNF0_D - write32 DBRFCNF1_A, DBRFCNF1_D - write32 DBRFCNF2_A, DBRFCNF2_D - - /* step 23 */ - write32 DBCALCNF_A, DBCALCNF_D - - /* step 24 */ - write32 DBRFEN_A, DBRFEN_D - write32 DBCMD_A, DBCMD_SRXT_VAL - - /* step 25 */ - write32 DBACEN_A, DBACEN_D - - /* step 26 */ - wait_DBCMD - - bra exit_ddr - nop - - .align 2 - -EXPEVT_A: .long 0xff000024 -EXPEVT_POWER_ON_RESET: .long 0x00000000 - -/*------- Reset -------*/ -MRSTCR0_A: .long 0xffd50030 -MRSTCR0_D: .long 0xfe1ffe7f -MRSTCR1_A: .long 0xffd50034 -MRSTCR1_D: .long 0xfff3ffff - -/*------- DDR3IF -------*/ -DBCMD_A: .long 0xfe800018 -DBKIND_A: .long 0xfe800020 -DBCONF_A: .long 0xfe800024 -DBTR0_A: .long 0xfe800040 -DBTR1_A: .long 0xfe800044 -DBTR2_A: .long 0xfe800048 -DBTR3_A: .long 0xfe800050 -DBTR4_A: .long 0xfe800054 -DBTR5_A: .long 0xfe800058 -DBTR6_A: .long 0xfe80005c -DBTR7_A: .long 0xfe800060 -DBTR8_A: .long 0xfe800064 -DBTR9_A: .long 0xfe800068 -DBTR10_A: .long 0xfe80006c -DBTR11_A: .long 0xfe800070 -DBTR12_A: .long 0xfe800074 -DBTR13_A: .long 0xfe800078 -DBTR14_A: .long 0xfe80007c -DBTR15_A: .long 0xfe800080 -DBTR16_A: .long 0xfe800084 -DBTR17_A: .long 0xfe800088 -DBTR18_A: .long 0xfe80008c -DBTR19_A: .long 0xfe800090 -DBRNK0_A: .long 0xfe800100 -DBPDCNT0_A: .long 0xfe800200 -DBPDCNT1_A: .long 0xfe800204 -DBPDCNT2_A: .long 0xfe800208 -DBPDCNT3_A: .long 0xfe80020c -DBPDLCK_A: .long 0xfe800280 -DBPDRGA_A: .long 0xfe800290 -DBPDRGD_A: .long 0xfe8002a0 -DBADJ0_A: .long 0xfe8000c0 -DBADJ1_A: .long 0xfe8000c4 -DBADJ2_A: .long 0xfe8000c8 -DBRFCNF0_A: .long 0xfe8000e0 -DBRFCNF1_A: .long 0xfe8000e4 -DBRFCNF2_A: .long 0xfe8000e8 -DBCALCNF_A: .long 0xfe8000f4 -DBRFEN_A: .long 0xfe800014 -DBACEN_A: .long 0xfe800010 -DBWAIT_A: .long 0xfe80001c - -WAIT_OSC_TIME: .long 6000 -WAIT_30US: .long 13333 - -DBCMD_RSTL_VAL: .long 0x20000000 -DBCMD_PDEN_VAL: .long 0x1000d73c -DBCMD_WAIT_VAL: .long 0x0000d73c -DBCMD_RSTH_VAL: .long 0x2100d73c -DBCMD_PDXT_VAL: .long 0x110000c8 -DBCMD_MRS0_VAL: .long 0x28000930 -DBCMD_MRS1_VAL: .long 0x29000004 -DBCMD_MRS2_VAL: .long 0x2a000008 -DBCMD_MRS3_VAL: .long 0x2b000000 -DBCMD_ZQCL_VAL: .long 0x03000200 -DBCMD_REF_VAL: .long 0x0c000000 -DBCMD_SRXT_VAL: .long 0x19000000 -DBKIND_D: .long 0x00000007 -DBCONF_D: .long 0x0f030a01 -DBTR0_D: .long 0x00000007 -DBTR1_D: .long 0x00000006 -DBTR2_D: .long 0x00000000 -DBTR3_D: .long 0x00000007 -DBTR4_D: .long 0x00070007 -DBTR5_D: .long 0x0000001b -DBTR6_D: .long 0x00000014 -DBTR7_D: .long 0x00000005 -DBTR8_D: .long 0x00000015 -DBTR9_D: .long 0x00000006 -DBTR10_D: .long 0x00000008 -DBTR11_D: .long 0x00000007 -DBTR12_D: .long 0x0000000e -DBTR13_D: .long 0x00000056 -DBTR14_D: .long 0x00000006 -DBTR15_D: .long 0x00000004 -DBTR16_D: .long 0x00150002 -DBTR17_D: .long 0x000c0017 -DBTR18_D: .long 0x00000200 -DBTR19_D: .long 0x00000040 -DBRNK0_D: .long 0x00000001 -DBPDCNT0_D: .long 0x00000001 -DBPDCNT1_D: .long 0x00000001 -DBPDCNT2_D: .long 0x00000000 -DBPDCNT3_D: .long 0x00004010 -DBPDLCK_D: .long 0x0000a55a -DBPDRGA_D: .long 0x00000028 -DBPDRGD_D: .long 0x00017100 - -DBADJ0_D: .long 0x00000000 -DBADJ1_D: .long 0x00000000 -DBADJ2_D: .long 0x18061806 -DBRFCNF0_D: .long 0x000001ff -DBRFCNF1_D: .long 0x08001000 -DBRFCNF2_D: .long 0x00000000 -DBCALCNF_D: .long 0x0000ffff -DBRFEN_D: .long 0x00000001 -DBACEN_D: .long 0x00000001 - - .align 2 -exit_ddr: -#if defined(CONFIG_SH_32BIT) - /*------- set PMB -------*/ - write32 PASCR_A, PASCR_29BIT_D - write32 MMUCR_A, MMUCR_D - - /***************************************************************** - * ent virt phys v sz c wt - * 0 0xa0000000 0x00000000 1 128M 0 1 - * 1 0xa8000000 0x48000000 1 128M 0 1 - * 5 0x88000000 0x48000000 1 128M 1 1 - */ - write32 PMB_ADDR_SPIBOOT_A, PMB_ADDR_SPIBOOT_D - write32 PMB_DATA_SPIBOOT_A, PMB_DATA_SPIBOOT_D - write32 PMB_ADDR_DDR_C1_A, PMB_ADDR_DDR_C1_D - write32 PMB_DATA_DDR_C1_A, PMB_DATA_DDR_C1_D - write32 PMB_ADDR_DDR_N1_A, PMB_ADDR_DDR_N1_D - write32 PMB_DATA_DDR_N1_A, PMB_DATA_DDR_N1_D - - write32 PMB_ADDR_ENTRY2, PMB_ADDR_NOT_USE_D - write32 PMB_ADDR_ENTRY3, PMB_ADDR_NOT_USE_D - write32 PMB_ADDR_ENTRY4, PMB_ADDR_NOT_USE_D - write32 PMB_ADDR_ENTRY6, PMB_ADDR_NOT_USE_D - write32 PMB_ADDR_ENTRY7, PMB_ADDR_NOT_USE_D - write32 PMB_ADDR_ENTRY8, PMB_ADDR_NOT_USE_D - write32 PMB_ADDR_ENTRY9, PMB_ADDR_NOT_USE_D - write32 PMB_ADDR_ENTRY10, PMB_ADDR_NOT_USE_D - write32 PMB_ADDR_ENTRY11, PMB_ADDR_NOT_USE_D - write32 PMB_ADDR_ENTRY12, PMB_ADDR_NOT_USE_D - write32 PMB_ADDR_ENTRY13, PMB_ADDR_NOT_USE_D - write32 PMB_ADDR_ENTRY14, PMB_ADDR_NOT_USE_D - write32 PMB_ADDR_ENTRY15, PMB_ADDR_NOT_USE_D - - write32 PASCR_A, PASCR_INIT - mov.l DUMMY_ADDR, r0 - icbi @r0 -#endif /* if defined(CONFIG_SH_32BIT) */ - -exit_pmb: - /* CPU is running on ILRAM? */ - mov r14, r0 - tst #1, r0 - bt 1f - - mov.l _stack_ilram, r15 - mov.l _spiboot_main, r0 -100: bsrf r0 - nop - - .align 2 -_spiboot_main: .long (spiboot_main - (100b + 4)) -_stack_ilram: .long 0xe5204000 - -1: - write32 CCR_A, CCR_D - - rts - nop - - .align 2 - -#if defined(CONFIG_SH_32BIT) -/*------- set PMB -------*/ -PMB_ADDR_SPIBOOT_A: .long PMB_ADDR_BASE(0) -PMB_ADDR_DDR_N1_A: .long PMB_ADDR_BASE(1) -PMB_ADDR_DDR_C1_A: .long PMB_ADDR_BASE(5) -PMB_ADDR_ENTRY2: .long PMB_ADDR_BASE(2) -PMB_ADDR_ENTRY3: .long PMB_ADDR_BASE(3) -PMB_ADDR_ENTRY4: .long PMB_ADDR_BASE(4) -PMB_ADDR_ENTRY6: .long PMB_ADDR_BASE(6) -PMB_ADDR_ENTRY7: .long PMB_ADDR_BASE(7) -PMB_ADDR_ENTRY8: .long PMB_ADDR_BASE(8) -PMB_ADDR_ENTRY9: .long PMB_ADDR_BASE(9) -PMB_ADDR_ENTRY10: .long PMB_ADDR_BASE(10) -PMB_ADDR_ENTRY11: .long PMB_ADDR_BASE(11) -PMB_ADDR_ENTRY12: .long PMB_ADDR_BASE(12) -PMB_ADDR_ENTRY13: .long PMB_ADDR_BASE(13) -PMB_ADDR_ENTRY14: .long PMB_ADDR_BASE(14) -PMB_ADDR_ENTRY15: .long PMB_ADDR_BASE(15) - -PMB_ADDR_SPIBOOT_D: .long mk_pmb_addr_val(0xa0) -PMB_ADDR_DDR_C1_D: .long mk_pmb_addr_val(0x88) -PMB_ADDR_DDR_N1_D: .long mk_pmb_addr_val(0xa8) -PMB_ADDR_NOT_USE_D: .long 0x00000000 - -PMB_DATA_SPIBOOT_A: .long PMB_DATA_BASE(0) -PMB_DATA_DDR_N1_A: .long PMB_DATA_BASE(1) -PMB_DATA_DDR_C1_A: .long PMB_DATA_BASE(5) - -/* ppn ub v s1 s0 c wt */ -PMB_DATA_SPIBOOT_D: .long mk_pmb_data_val(0x00, 0, 1, 1, 0, 0, 1) -PMB_DATA_DDR_C1_D: .long mk_pmb_data_val(0x48, 0, 1, 1, 0, 1, 1) -PMB_DATA_DDR_N1_D: .long mk_pmb_data_val(0x48, 1, 1, 1, 0, 0, 1) - -PASCR_A: .long 0xff000070 -DUMMY_ADDR: .long 0xa0000000 -PASCR_29BIT_D: .long 0x00000000 -PASCR_INIT: .long 0x80000080 -MMUCR_A: .long 0xff000010 -MMUCR_D: .long 0x00000004 /* clear ITLB */ -#endif /* CONFIG_SH_32BIT */ - -CCR_A: .long CCR -CCR_D: .long CCR_CACHE_INIT diff --git a/board/renesas/sh7752evb/sh7752evb.c b/board/renesas/sh7752evb/sh7752evb.c deleted file mode 100644 index 5eedbf8..0000000 --- a/board/renesas/sh7752evb/sh7752evb.c +++ /dev/null @@ -1,314 +0,0 @@ -/* - * Copyright (C) 2012 Renesas Solutions Corp. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <malloc.h> -#include <asm/processor.h> -#include <asm/io.h> -#include <asm/mmc.h> -#include <spi_flash.h> - -int checkboard(void) -{ - puts("BOARD: SH7752 evaluation board (R0P7752C00000RZ)\n"); - - return 0; -} - -static void init_gpio(void) -{ - struct gpio_regs *gpio = GPIO_BASE; - struct sermux_regs *sermux = SERMUX_BASE; - - /* GPIO */ - writew(0x0000, &gpio->pacr); /* GETHER */ - writew(0x0001, &gpio->pbcr); /* INTC */ - writew(0x0000, &gpio->pccr); /* PWMU, INTC */ - writew(0xeaff, &gpio->pecr); /* GPIO */ - writew(0x0000, &gpio->pfcr); /* WDT */ - writew(0x0000, &gpio->phcr); /* SPI1 */ - writew(0x0000, &gpio->picr); /* SDHI */ - writew(0x0003, &gpio->pkcr); /* SerMux */ - writew(0x0000, &gpio->plcr); /* SerMux */ - writew(0x0000, &gpio->pmcr); /* RIIC */ - writew(0x0000, &gpio->pncr); /* USB, SGPIO */ - writew(0x0000, &gpio->pocr); /* SGPIO */ - writew(0xd555, &gpio->pqcr); /* GPIO */ - writew(0x0000, &gpio->prcr); /* RIIC */ - writew(0x0000, &gpio->pscr); /* RIIC */ - writeb(0x00, &gpio->pudr); - writew(0x5555, &gpio->pucr); /* Debug LED */ - writew(0x0000, &gpio->pvcr); /* RSPI */ - writew(0x0000, &gpio->pwcr); /* EVC */ - writew(0x0000, &gpio->pxcr); /* LBSC */ - writew(0x0000, &gpio->pycr); /* LBSC */ - writew(0x0000, &gpio->pzcr); /* eMMC */ - writew(0xfe00, &gpio->psel0); - writew(0xff00, &gpio->psel3); - writew(0x771f, &gpio->psel4); - writew(0x00ff, &gpio->psel6); - writew(0xfc00, &gpio->psel7); - - writeb(0x10, &sermux->smr0); /* SMR0: SerMux mode 0 */ -} - -static void init_usb_phy(void) -{ - struct usb_common_regs *common0 = USB0_COMMON_BASE; - struct usb_common_regs *common1 = USB1_COMMON_BASE; - struct usb0_phy_regs *phy = USB0_PHY_BASE; - struct usb1_port_regs *port = USB1_PORT_BASE; - struct usb1_alignment_regs *align = USB1_ALIGNMENT_BASE; - - writew(0x0100, &phy->reset); /* set reset */ - /* port0 = USB0, port1 = USB1 */ - writew(0x0002, &phy->portsel); - writel(0x0001, &port->port1sel); /* port1 = Host */ - writew(0x0111, &phy->reset); /* clear reset */ - - writew(0x4000, &common0->suspmode); - writew(0x4000, &common1->suspmode); - -#if defined(__LITTLE_ENDIAN) - writel(0x00000000, &align->ehcidatac); - writel(0x00000000, &align->ohcidatac); -#endif -} - -static void init_gether_mdio(void) -{ - struct gpio_regs *gpio = GPIO_BASE; - - writew(readw(&gpio->pgcr) | 0x0004, &gpio->pgcr); - writeb(readb(&gpio->pgdr) | 0x02, &gpio->pgdr); /* Use ET0-MDIO */ -} - -static void set_mac_to_sh_giga_eth_register(int channel, char *mac_string) -{ - struct ether_mac_regs *ether; - unsigned char mac[6]; - unsigned long val; - - eth_parse_enetaddr(mac_string, mac); - - if (!channel) - ether = GETHER0_MAC_BASE; - else - ether = GETHER1_MAC_BASE; - - val = (mac[0] << 24) | (mac[1] << 16) | (mac[2] << 8) | mac[3]; - writel(val, ðer->mahr); - val = (mac[4] << 8) | mac[5]; - writel(val, ðer->malr); -} - -/***************************************************************** - * This PMB must be set on this timing. The lowlevel_init is run on - * Area 0(phys 0x00000000), so we have to map it. - * - * The new PMB table is following: - * ent virt phys v sz c wt - * 0 0xa0000000 0x40000000 1 128M 0 1 - * 1 0xa8000000 0x48000000 1 128M 0 1 - * 2 0xb0000000 0x50000000 1 128M 0 1 - * 3 0xb8000000 0x58000000 1 128M 0 1 - * 4 0x80000000 0x40000000 1 128M 1 1 - * 5 0x88000000 0x48000000 1 128M 1 1 - * 6 0x90000000 0x50000000 1 128M 1 1 - * 7 0x98000000 0x58000000 1 128M 1 1 - */ -static void set_pmb_on_board_init(void) -{ - struct mmu_regs *mmu = MMU_BASE; - - /* clear ITLB */ - writel(0x00000004, &mmu->mmucr); - - /* delete PMB for SPIBOOT */ - writel(0, PMB_ADDR_BASE(0)); - writel(0, PMB_DATA_BASE(0)); - - /* add PMB for SDRAM(0x40000000 - 0x47ffffff) */ - /* ppn ub v s1 s0 c wt */ - writel(mk_pmb_addr_val(0xa0), PMB_ADDR_BASE(0)); - writel(mk_pmb_data_val(0x40, 1, 1, 1, 0, 0, 1), PMB_DATA_BASE(0)); - writel(mk_pmb_addr_val(0xb0), PMB_ADDR_BASE(2)); - writel(mk_pmb_data_val(0x50, 1, 1, 1, 0, 0, 1), PMB_DATA_BASE(2)); - writel(mk_pmb_addr_val(0xb8), PMB_ADDR_BASE(3)); - writel(mk_pmb_data_val(0x58, 1, 1, 1, 0, 0, 1), PMB_DATA_BASE(3)); - writel(mk_pmb_addr_val(0x80), PMB_ADDR_BASE(4)); - writel(mk_pmb_data_val(0x40, 0, 1, 1, 0, 1, 1), PMB_DATA_BASE(4)); - writel(mk_pmb_addr_val(0x90), PMB_ADDR_BASE(6)); - writel(mk_pmb_data_val(0x50, 0, 1, 1, 0, 1, 1), PMB_DATA_BASE(6)); - writel(mk_pmb_addr_val(0x98), PMB_ADDR_BASE(7)); - writel(mk_pmb_data_val(0x58, 0, 1, 1, 0, 1, 1), PMB_DATA_BASE(7)); -} - -int board_init(void) -{ - init_gpio(); - set_pmb_on_board_init(); - - init_usb_phy(); - init_gether_mdio(); - - return 0; -} - -int dram_init(void) -{ - DECLARE_GLOBAL_DATA_PTR; - - gd->bd->bi_memstart = CONFIG_SYS_SDRAM_BASE; - gd->bd->bi_memsize = CONFIG_SYS_SDRAM_SIZE; - printf("DRAM: %dMB\n", CONFIG_SYS_SDRAM_SIZE / (1024 * 1024)); - - return 0; -} - -int board_mmc_init(bd_t *bis) -{ - struct gpio_regs *gpio = GPIO_BASE; - - writew(readw(&gpio->pgcr) | 0x0040, &gpio->pgcr); - writeb(readb(&gpio->pgdr) & ~0x08, &gpio->pgdr); /* Reset */ - udelay(1); - writeb(readb(&gpio->pgdr) | 0x08, &gpio->pgdr); /* Release reset */ - udelay(200); - - return mmcif_mmc_init(); -} - -static int get_sh_eth_mac_raw(unsigned char *buf, int size) -{ - struct spi_flash *spi; - int ret; - - spi = spi_flash_probe(0, 0, 1000000, SPI_MODE_3); - if (spi == NULL) { - printf("%s: spi_flash probe failed.\n", __func__); - return 1; - } - - ret = spi_flash_read(spi, SH7752EVB_ETHERNET_MAC_BASE, size, buf); - if (ret) { - printf("%s: spi_flash read failed.\n", __func__); - spi_flash_free(spi); - return 1; - } - spi_flash_free(spi); - - return 0; -} - -static int get_sh_eth_mac(int channel, char *mac_string, unsigned char *buf) -{ - memcpy(mac_string, &buf[channel * (SH7752EVB_ETHERNET_MAC_SIZE + 1)], - SH7752EVB_ETHERNET_MAC_SIZE); - mac_string[SH7752EVB_ETHERNET_MAC_SIZE] = 0x00; /* terminate */ - - return 0; -} - -static void init_ethernet_mac(void) -{ - char mac_string[64]; - char env_string[64]; - int i; - unsigned char *buf; - - buf = malloc(256); - if (!buf) { - printf("%s: malloc failed.\n", __func__); - return; - } - get_sh_eth_mac_raw(buf, 256); - - /* Gigabit Ethernet */ - for (i = 0; i < SH7752EVB_ETHERNET_NUM_CH; i++) { - get_sh_eth_mac(i, mac_string, buf); - if (i == 0) - setenv("ethaddr", mac_string); - else { - sprintf(env_string, "eth%daddr", i); - setenv(env_string, mac_string); - } - set_mac_to_sh_giga_eth_register(i, mac_string); - } - - free(buf); -} - -int board_late_init(void) -{ - init_ethernet_mac(); - - return 0; -} - -int do_write_mac(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - int i, ret; - char mac_string[256]; - struct spi_flash *spi; - unsigned char *buf; - - if (argc != 3) { - buf = malloc(256); - if (!buf) { - printf("%s: malloc failed.\n", __func__); - return 1; - } - - get_sh_eth_mac_raw(buf, 256); - - /* print current MAC address */ - for (i = 0; i < SH7752EVB_ETHERNET_NUM_CH; i++) { - get_sh_eth_mac(i, mac_string, buf); - printf("GETHERC ch%d = %s\n", i, mac_string); - } - free(buf); - return 0; - } - - /* new setting */ - memset(mac_string, 0xff, sizeof(mac_string)); - sprintf(mac_string, "%s\t%s", - argv[1], argv[2]); - - /* write MAC data to SPI rom */ - spi = spi_flash_probe(0, 0, 1000000, SPI_MODE_3); - if (!spi) { - printf("%s: spi_flash probe failed.\n", __func__); - return 1; - } - - ret = spi_flash_erase(spi, SH7752EVB_ETHERNET_MAC_BASE_SPI, - SH7752EVB_SPI_SECTOR_SIZE); - if (ret) { - printf("%s: spi_flash erase failed.\n", __func__); - return 1; - } - - ret = spi_flash_write(spi, SH7752EVB_ETHERNET_MAC_BASE_SPI, - sizeof(mac_string), mac_string); - if (ret) { - printf("%s: spi_flash write failed.\n", __func__); - spi_flash_free(spi); - return 1; - } - spi_flash_free(spi); - - puts("The writing of the MAC address to SPI ROM was completed.\n"); - - return 0; -} - -U_BOOT_CMD( - write_mac, 3, 1, do_write_mac, - "write MAC address for GETHERC", - "[GETHERC ch0] [GETHERC ch1]\n" -); diff --git a/board/renesas/sh7752evb/spi-boot.c b/board/renesas/sh7752evb/spi-boot.c deleted file mode 100644 index 91565d4..0000000 --- a/board/renesas/sh7752evb/spi-boot.c +++ /dev/null @@ -1,116 +0,0 @@ -/* - * Copyright (C) 2012 Renesas Solutions Corp. - * - * This file is subject to the terms and conditions of the GNU Lesser - * General Public License. See the file "COPYING.LIB" in the main - * directory of this archive for more details. - */ - -#include <common.h> - -#define CONFIG_RAM_BOOT_PHYS CONFIG_SYS_TEXT_BASE -#define CONFIG_SPI_ADDR 0x00000000 -#define CONFIG_SPI_LENGTH CONFIG_SYS_MONITOR_LEN -#define CONFIG_RAM_BOOT CONFIG_SYS_TEXT_BASE - -#define SPIWDMADR 0xFE001018 -#define SPIWDMCNTR 0xFE001020 -#define SPIDMCOR 0xFE001028 -#define SPIDMINTSR 0xFE001188 -#define SPIDMINTMR 0xFE001190 - -#define SPIDMINTSR_DMEND 0x00000004 - -#define TBR 0xFE002000 -#define RBR 0xFE002000 - -#define CR1 0xFE002008 -#define CR2 0xFE002010 -#define CR3 0xFE002018 -#define CR4 0xFE002020 - -/* CR1 */ -#define SPI_TBE 0x80 -#define SPI_TBF 0x40 -#define SPI_RBE 0x20 -#define SPI_RBF 0x10 -#define SPI_PFONRD 0x08 -#define SPI_SSDB 0x04 -#define SPI_SSD 0x02 -#define SPI_SSA 0x01 - -/* CR2 */ -#define SPI_RSTF 0x80 -#define SPI_LOOPBK 0x40 -#define SPI_CPOL 0x20 -#define SPI_CPHA 0x10 -#define SPI_L1M0 0x08 - -/* CR4 */ -#define SPI_TBEI 0x80 -#define SPI_TBFI 0x40 -#define SPI_RBEI 0x20 -#define SPI_RBFI 0x10 -#define SPI_SpiS0 0x02 -#define SPI_SSS 0x01 - -#define spi_write(val, addr) (*(volatile unsigned long *)(addr)) = val -#define spi_read(addr) (*(volatile unsigned long *)(addr)) - -/* M25P80 */ -#define M25_READ 0x03 - -#define __uses_spiboot2 __attribute__((section(".spiboot2.text"))) -static void __uses_spiboot2 spi_reset(void) -{ - int timeout = 0x00100000; - - /* Make sure the last transaction is finalized */ - spi_write(0x00, CR3); - spi_write(0x02, CR1); - while (!(spi_read(CR4) & SPI_SpiS0)) { - if (timeout-- < 0) - break; - } - spi_write(0x00, CR1); - - spi_write(spi_read(CR2) | SPI_RSTF, CR2); /* fifo reset */ - spi_write(spi_read(CR2) & ~SPI_RSTF, CR2); - - spi_write(0, SPIDMCOR); -} - -static void __uses_spiboot2 spi_read_flash(void *buf, unsigned long addr, - unsigned long len) -{ - spi_write(M25_READ, TBR); - spi_write((addr >> 16) & 0xFF, TBR); - spi_write((addr >> 8) & 0xFF, TBR); - spi_write(addr & 0xFF, TBR); - - spi_write(SPIDMINTSR_DMEND, SPIDMINTSR); - spi_write((unsigned long)buf, SPIWDMADR); - spi_write(len & 0xFFFFFFE0, SPIWDMCNTR); - spi_write(1, SPIDMCOR); - - spi_write(0xff, CR3); - spi_write(spi_read(CR1) | SPI_SSDB, CR1); - spi_write(spi_read(CR1) | SPI_SSA, CR1); - - while (!(spi_read(SPIDMINTSR) & SPIDMINTSR_DMEND)) - ; - - /* Nagate SP0-SS0 */ - spi_write(0, CR1); -} - -void __uses_spiboot2 spiboot_main(void) -{ - void (*_start)(void) = (void *)CONFIG_SYS_TEXT_BASE; - - spi_reset(); - spi_read_flash((void *)CONFIG_RAM_BOOT_PHYS, CONFIG_SPI_ADDR, - CONFIG_SPI_LENGTH); - - _start(); -} diff --git a/board/renesas/sh7752evb/u-boot.lds b/board/renesas/sh7752evb/u-boot.lds deleted file mode 100644 index 053df64..0000000 --- a/board/renesas/sh7752evb/u-boot.lds +++ /dev/null @@ -1,81 +0,0 @@ -/* - * Copyright (C) 2007 - * Nobuhiro Iwamatsu iwamatsu@nigauri.org - * - * Copyright (C) 2012 - * Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -OUTPUT_FORMAT("elf32-sh-linux", "elf32-sh-linux", "elf32-sh-linux") -OUTPUT_ARCH(sh) -ENTRY(_start) - -SECTIONS -{ - /* - * entry and reloct_dst will be provided via ldflags - */ - . = .; - - PROVIDE (_ftext = .); - PROVIDE (_fcode = .); - PROVIDE (_start = .); - - .text : - { - KEEP(arch/sh/cpu/sh4/start.o (.text)) - *(.spiboot1.text) - *(.spiboot2.text) - . = ALIGN(8192); - common/env_embedded.o (.ppcenv) - . = ALIGN(8192); - common/env_embedded.o (.ppcenvr) - . = ALIGN(8192); - *(.text) - . = ALIGN(4); - } =0xFF - PROVIDE (_ecode = .); - .rodata : - { - *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) - . = ALIGN(4); - } - PROVIDE (_etext = .); - - - PROVIDE (_fdata = .); - .data : - { - *(.data) - . = ALIGN(4); - } - PROVIDE (_edata = .); - - PROVIDE (_fgot = .); - .got : - { - *(.got) - . = ALIGN(4); - } - PROVIDE (_egot = .); - - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); - } - - PROVIDE (reloc_dst_end = .); - /* _reloc_dst_end = .; */ - - PROVIDE (bss_start = .); - PROVIDE (__bss_start = .); - .bss (NOLOAD) : - { - *(.bss) - . = ALIGN(4); - } - PROVIDE (bss_end = .); - - PROVIDE (__bss_end = .); -} diff --git a/board/renesas/sh7753evb/Makefile b/board/renesas/sh7753evb/Makefile new file mode 100644 index 0000000..f7c8e94 --- /dev/null +++ b/board/renesas/sh7753evb/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (C) 2012 Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com +# +# SPDX-License-Identifier: GPL-2.0+ + +obj-y := sh7753evb.o spi-boot.o +obj-y += lowlevel_init.o diff --git a/board/renesas/sh7753evb/lowlevel_init.S b/board/renesas/sh7753evb/lowlevel_init.S new file mode 100644 index 0000000..21987a5 --- /dev/null +++ b/board/renesas/sh7753evb/lowlevel_init.S @@ -0,0 +1,416 @@ +/* + * Copyright (C) 2013 Renesas Solutions Corp. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <version.h> +#include <asm/processor.h> +#include <asm/macro.h> + +.macro or32, addr, data + mov.l \addr, r1 + mov.l \data, r0 + mov.l @r1, r2 + or r2, r0 + mov.l r0, @r1 +.endm + +.macro wait_DBCMD + mov.l DBWAIT_A, r0 + mov.l @r0, r1 +.endm + + .global lowlevel_init + .section .spiboot1.text + .align 2 + +lowlevel_init: + mov #0, r14 + mova 2f, r0 + mov.l PC_MASK, r1 + tst r0, r1 + bf 2f + + bra exit_pmb + nop + + .align 2 + +/* If CPU runs on SDRAM (PC=0x5???????) or not. */ +PC_MASK: .long 0x20000000 + +2: + mov #1, r14 + + mov.l EXPEVT_A, r0 + mov.l @r0, r0 + mov.l EXPEVT_POWER_ON_RESET, r1 + cmp/eq r0, r1 + bt 1f + + /* + * If EXPEVT value is manual reset or tlb multipul-hit, + * initialization of DBSC3 is not necessary. + */ + bra exit_ddr + nop + +1: + /*------- Reset -------*/ + write32 MRSTCR0_A, MRSTCR0_D + write32 MRSTCR1_A, MRSTCR1_D + + /* For Core Reset */ + mov.l DBACEN_A, r0 + mov.l @r0, r0 + cmp/eq #0, r0 + bt 3f + + /* + * If DBACEN == 1(DBSC was already enabled), we have to avoid the + * initialization of DDR3-SDRAM. + */ + bra exit_ddr + nop + +3: + /*------- DBSC3 -------*/ + /* oscillation stabilization time */ + wait_timer WAIT_OSC_TIME + + /* step 3 */ + write32 DBKIND_A, DBKIND_D + + /* step 4 */ + write32 DBCONF_A, DBCONF_D + write32 DBTR0_A, DBTR0_D + write32 DBTR1_A, DBTR1_D + write32 DBTR2_A, DBTR2_D + write32 DBTR3_A, DBTR3_D + write32 DBTR4_A, DBTR4_D + write32 DBTR5_A, DBTR5_D + write32 DBTR6_A, DBTR6_D + write32 DBTR7_A, DBTR7_D + write32 DBTR8_A, DBTR8_D + write32 DBTR9_A, DBTR9_D + write32 DBTR10_A, DBTR10_D + write32 DBTR11_A, DBTR11_D + write32 DBTR12_A, DBTR12_D + write32 DBTR13_A, DBTR13_D + write32 DBTR14_A, DBTR14_D + write32 DBTR15_A, DBTR15_D + write32 DBTR16_A, DBTR16_D + write32 DBTR17_A, DBTR17_D + write32 DBTR18_A, DBTR18_D + write32 DBTR19_A, DBTR19_D + write32 DBRNK0_A, DBRNK0_D + write32 DBADJ0_A, DBADJ0_D + write32 DBADJ2_A, DBADJ2_D + + /* step 5 */ + write32 DBCMD_A, DBCMD_RSTL_VAL + wait_timer WAIT_30US + + /* step 6 */ + write32 DBCMD_A, DBCMD_PDEN_VAL + + /* step 7 */ + write32 DBPDCNT3_A, DBPDCNT3_D + + /* step 8 */ + write32 DBPDCNT1_A, DBPDCNT1_D + write32 DBPDCNT2_A, DBPDCNT2_D + write32 DBPDLCK_A, DBPDLCK_D + write32 DBPDRGA_A, DBPDRGA_D + write32 DBPDRGD_A, DBPDRGD_D + + /* step 9 */ + wait_timer WAIT_30US + + /* step 10 */ + write32 DBPDCNT0_A, DBPDCNT0_D + + /* step 11 */ + wait_timer WAIT_30US + wait_timer WAIT_30US + + /* step 12 */ + write32 DBCMD_A, DBCMD_WAIT_VAL + wait_DBCMD + + /* step 13 */ + write32 DBCMD_A, DBCMD_RSTH_VAL + wait_DBCMD + + /* step 14 */ + write32 DBCMD_A, DBCMD_WAIT_VAL + write32 DBCMD_A, DBCMD_WAIT_VAL + write32 DBCMD_A, DBCMD_WAIT_VAL + write32 DBCMD_A, DBCMD_WAIT_VAL + + /* step 15 */ + write32 DBCMD_A, DBCMD_PDXT_VAL + + /* step 16 */ + write32 DBCMD_A, DBCMD_MRS2_VAL + + /* step 17 */ + write32 DBCMD_A, DBCMD_MRS3_VAL + + /* step 18 */ + write32 DBCMD_A, DBCMD_MRS1_VAL + + /* step 19 */ + write32 DBCMD_A, DBCMD_MRS0_VAL + write32 DBPDNCNF_A, DBPDNCNF_D + + /* step 20 */ + write32 DBCMD_A, DBCMD_ZQCL_VAL + + write32 DBCMD_A, DBCMD_REF_VAL + write32 DBCMD_A, DBCMD_REF_VAL + wait_DBCMD + + /* step 21 */ + write32 DBCALTR_A, DBCALTR_D + + /* step 22 */ + write32 DBRFCNF0_A, DBRFCNF0_D + write32 DBRFCNF1_A, DBRFCNF1_D + write32 DBRFCNF2_A, DBRFCNF2_D + + /* step 23 */ + write32 DBCALCNF_A, DBCALCNF_D + + /* step 24 */ + write32 DBRFEN_A, DBRFEN_D + write32 DBCMD_A, DBCMD_SRXT_VAL + + /* step 25 */ + write32 DBACEN_A, DBACEN_D + + /* step 26 */ + wait_DBCMD + + bra exit_ddr + nop + + .align 2 + +EXPEVT_A: .long 0xff000024 +EXPEVT_POWER_ON_RESET: .long 0x00000000 + +/*------- Reset -------*/ +MRSTCR0_A: .long 0xffd50030 +MRSTCR0_D: .long 0xfe1ffe7f +MRSTCR1_A: .long 0xffd50034 +MRSTCR1_D: .long 0xfff3ffff + +/*------- DBSC3 -------*/ +DBCMD_A: .long 0xfe800018 +DBKIND_A: .long 0xfe800020 +DBCONF_A: .long 0xfe800024 +DBTR0_A: .long 0xfe800040 +DBTR1_A: .long 0xfe800044 +DBTR2_A: .long 0xfe800048 +DBTR3_A: .long 0xfe800050 +DBTR4_A: .long 0xfe800054 +DBTR5_A: .long 0xfe800058 +DBTR6_A: .long 0xfe80005c +DBTR7_A: .long 0xfe800060 +DBTR8_A: .long 0xfe800064 +DBTR9_A: .long 0xfe800068 +DBTR10_A: .long 0xfe80006c +DBTR11_A: .long 0xfe800070 +DBTR12_A: .long 0xfe800074 +DBTR13_A: .long 0xfe800078 +DBTR14_A: .long 0xfe80007c +DBTR15_A: .long 0xfe800080 +DBTR16_A: .long 0xfe800084 +DBTR17_A: .long 0xfe800088 +DBTR18_A: .long 0xfe80008c +DBTR19_A: .long 0xfe800090 +DBRNK0_A: .long 0xfe800100 +DBPDCNT0_A: .long 0xfe800200 +DBPDCNT1_A: .long 0xfe800204 +DBPDCNT2_A: .long 0xfe800208 +DBPDCNT3_A: .long 0xfe80020c +DBPDLCK_A: .long 0xfe800280 +DBPDRGA_A: .long 0xfe800290 +DBPDRGD_A: .long 0xfe8002a0 +DBADJ0_A: .long 0xfe8000c0 +DBADJ2_A: .long 0xfe8000c8 +DBRFCNF0_A: .long 0xfe8000e0 +DBRFCNF1_A: .long 0xfe8000e4 +DBRFCNF2_A: .long 0xfe8000e8 +DBCALCNF_A: .long 0xfe8000f4 +DBRFEN_A: .long 0xfe800014 +DBACEN_A: .long 0xfe800010 +DBWAIT_A: .long 0xfe80001c +DBCALTR_A: .long 0xfe8000f8 +DBPDNCNF_A: .long 0xfe800180 + +WAIT_OSC_TIME: .long 6000 +WAIT_30US: .long 13333 + +DBCMD_RSTL_VAL: .long 0x20000000 +DBCMD_PDEN_VAL: .long 0x1000d73c +DBCMD_WAIT_VAL: .long 0x0000d73c +DBCMD_RSTH_VAL: .long 0x2100d73c +DBCMD_PDXT_VAL: .long 0x110000c8 +DBCMD_MRS0_VAL: .long 0x28000930 +DBCMD_MRS1_VAL: .long 0x29000004 +DBCMD_MRS2_VAL: .long 0x2a000008 +DBCMD_MRS3_VAL: .long 0x2b000000 +DBCMD_ZQCL_VAL: .long 0x03000200 +DBCMD_REF_VAL: .long 0x0c000000 +DBCMD_SRXT_VAL: .long 0x19000000 +DBKIND_D: .long 0x00000007 +DBCONF_D: .long 0x0f030a01 +DBTR0_D: .long 0x00000007 +DBTR1_D: .long 0x00000006 +DBTR2_D: .long 0x00000000 +DBTR3_D: .long 0x00000007 +DBTR4_D: .long 0x00070007 +DBTR5_D: .long 0x0000001b +DBTR6_D: .long 0x00000014 +DBTR7_D: .long 0x00000004 +DBTR8_D: .long 0x00000014 +DBTR9_D: .long 0x00000004 +DBTR10_D: .long 0x00000008 +DBTR11_D: .long 0x00000007 +DBTR12_D: .long 0x0000000e +DBTR13_D: .long 0x000000a0 +DBTR14_D: .long 0x00060006 +DBTR15_D: .long 0x00000003 +DBTR16_D: .long 0x00160002 +DBTR17_D: .long 0x000c0000 +DBTR18_D: .long 0x00000200 +DBTR19_D: .long 0x00000040 +DBRNK0_D: .long 0x00000001 +DBPDCNT0_D: .long 0x00000001 +DBPDCNT1_D: .long 0x00000001 +DBPDCNT2_D: .long 0x00000000 +DBPDCNT3_D: .long 0x00004010 +DBPDLCK_D: .long 0x0000a55a +DBPDRGA_D: .long 0x00000028 +DBPDRGD_D: .long 0x00017100 + +DBADJ0_D: .long 0x00010000 +DBADJ2_D: .long 0x18061806 +DBRFCNF0_D: .long 0x000001ff +DBRFCNF1_D: .long 0x00081040 +DBRFCNF2_D: .long 0x00000000 +DBCALCNF_D: .long 0x0000ffff +DBRFEN_D: .long 0x00000001 +DBACEN_D: .long 0x00000001 +DBCALTR_D: .long 0x08200820 +DBPDNCNF_D: .long 0x00000001 + + .align 2 +exit_ddr: +#if defined(CONFIG_SH_32BIT) + /*------- set PMB -------*/ + write32 PASCR_A, PASCR_29BIT_D + write32 MMUCR_A, MMUCR_D + + /***************************************************************** + * ent virt phys v sz c wt + * 0 0xa0000000 0x00000000 1 128M 0 1 + * 1 0xa8000000 0x48000000 1 128M 0 1 + * 5 0x88000000 0x48000000 1 128M 1 1 + */ + write32 PMB_ADDR_SPIBOOT_A, PMB_ADDR_SPIBOOT_D + write32 PMB_DATA_SPIBOOT_A, PMB_DATA_SPIBOOT_D + write32 PMB_ADDR_DDR_C1_A, PMB_ADDR_DDR_C1_D + write32 PMB_DATA_DDR_C1_A, PMB_DATA_DDR_C1_D + write32 PMB_ADDR_DDR_N1_A, PMB_ADDR_DDR_N1_D + write32 PMB_DATA_DDR_N1_A, PMB_DATA_DDR_N1_D + + write32 PMB_ADDR_ENTRY2, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY3, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY4, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY6, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY7, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY8, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY9, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY10, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY11, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY12, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY13, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY14, PMB_ADDR_NOT_USE_D + write32 PMB_ADDR_ENTRY15, PMB_ADDR_NOT_USE_D + + write32 PASCR_A, PASCR_INIT + mov.l DUMMY_ADDR, r0 + icbi @r0 +#endif /* if defined(CONFIG_SH_32BIT) */ + +exit_pmb: + /* CPU is running on ILRAM? */ + mov r14, r0 + tst #1, r0 + bt 1f + + mov.l _stack_ilram, r15 + mov.l _spiboot_main, r0 +100: bsrf r0 + nop + + .align 2 +_spiboot_main: .long (spiboot_main - (100b + 4)) +_stack_ilram: .long 0xe5204000 + +1: + write32 CCR_A, CCR_D + + rts + nop + + .align 2 + +#if defined(CONFIG_SH_32BIT) +/*------- set PMB -------*/ +PMB_ADDR_SPIBOOT_A: .long PMB_ADDR_BASE(0) +PMB_ADDR_DDR_N1_A: .long PMB_ADDR_BASE(1) +PMB_ADDR_DDR_C1_A: .long PMB_ADDR_BASE(5) +PMB_ADDR_ENTRY2: .long PMB_ADDR_BASE(2) +PMB_ADDR_ENTRY3: .long PMB_ADDR_BASE(3) +PMB_ADDR_ENTRY4: .long PMB_ADDR_BASE(4) +PMB_ADDR_ENTRY6: .long PMB_ADDR_BASE(6) +PMB_ADDR_ENTRY7: .long PMB_ADDR_BASE(7) +PMB_ADDR_ENTRY8: .long PMB_ADDR_BASE(8) +PMB_ADDR_ENTRY9: .long PMB_ADDR_BASE(9) +PMB_ADDR_ENTRY10: .long PMB_ADDR_BASE(10) +PMB_ADDR_ENTRY11: .long PMB_ADDR_BASE(11) +PMB_ADDR_ENTRY12: .long PMB_ADDR_BASE(12) +PMB_ADDR_ENTRY13: .long PMB_ADDR_BASE(13) +PMB_ADDR_ENTRY14: .long PMB_ADDR_BASE(14) +PMB_ADDR_ENTRY15: .long PMB_ADDR_BASE(15) + +PMB_ADDR_SPIBOOT_D: .long mk_pmb_addr_val(0xa0) +PMB_ADDR_DDR_C1_D: .long mk_pmb_addr_val(0x88) +PMB_ADDR_DDR_N1_D: .long mk_pmb_addr_val(0xa8) +PMB_ADDR_NOT_USE_D: .long 0x00000000 + +PMB_DATA_SPIBOOT_A: .long PMB_DATA_BASE(0) +PMB_DATA_DDR_N1_A: .long PMB_DATA_BASE(1) +PMB_DATA_DDR_C1_A: .long PMB_DATA_BASE(5) + +/* ppn ub v s1 s0 c wt */ +PMB_DATA_SPIBOOT_D: .long mk_pmb_data_val(0x00, 0, 1, 1, 0, 0, 1) +PMB_DATA_DDR_C1_D: .long mk_pmb_data_val(0x48, 0, 1, 1, 0, 1, 1) +PMB_DATA_DDR_N1_D: .long mk_pmb_data_val(0x48, 1, 1, 1, 0, 0, 1) + +PASCR_A: .long 0xff000070 +DUMMY_ADDR: .long 0xa0000000 +PASCR_29BIT_D: .long 0x00000000 +PASCR_INIT: .long 0x80000080 +MMUCR_A: .long 0xff000010 +MMUCR_D: .long 0x00000004 /* clear ITLB */ +#endif /* CONFIG_SH_32BIT */ + +CCR_A: .long CCR +CCR_D: .long CCR_CACHE_INIT diff --git a/board/renesas/sh7753evb/sh7753evb.c b/board/renesas/sh7753evb/sh7753evb.c new file mode 100644 index 0000000..42b920f --- /dev/null +++ b/board/renesas/sh7753evb/sh7753evb.c @@ -0,0 +1,326 @@ +/* + * Copyright (C) 2012 Renesas Solutions Corp. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <malloc.h> +#include <asm/processor.h> +#include <asm/io.h> +#include <asm/mmc.h> +#include <spi_flash.h> + +int checkboard(void) +{ + puts("BOARD: SH7753 EVB\n"); + + return 0; +} + +static void init_gpio(void) +{ + struct gpio_regs *gpio = GPIO_BASE; + struct sermux_regs *sermux = SERMUX_BASE; + + /* GPIO */ + writew(0x0000, &gpio->pacr); /* GETHER */ + writew(0x0001, &gpio->pbcr); /* INTC */ + writew(0x0000, &gpio->pccr); /* PWMU, INTC */ + writew(0x0000, &gpio->pdcr); /* SPI0 */ + writew(0xeaff, &gpio->pecr); /* GPIO */ + writew(0x0000, &gpio->pfcr); /* WDT */ + writew(0x0004, &gpio->pgcr); /* SPI0, GETHER MDIO gate(PTG1) */ + writew(0x0000, &gpio->phcr); /* SPI1 */ + writew(0x0000, &gpio->picr); /* SDHI */ + writew(0x0000, &gpio->pjcr); /* SCIF4 */ + writew(0x0003, &gpio->pkcr); /* SerMux */ + writew(0x0000, &gpio->plcr); /* SerMux */ + writew(0x0000, &gpio->pmcr); /* RIIC */ + writew(0x0000, &gpio->pncr); /* USB, SGPIO */ + writew(0x0000, &gpio->pocr); /* SGPIO */ + writew(0xd555, &gpio->pqcr); /* GPIO */ + writew(0x0000, &gpio->prcr); /* RIIC */ + writew(0x0000, &gpio->pscr); /* RIIC */ + writew(0x0000, &gpio->ptcr); /* STATUS */ + writeb(0x00, &gpio->pudr); + writew(0x5555, &gpio->pucr); /* Debug LED */ + writew(0x0000, &gpio->pvcr); /* RSPI */ + writew(0x0000, &gpio->pwcr); /* EVC */ + writew(0x0000, &gpio->pxcr); /* LBSC */ + writew(0x0000, &gpio->pycr); /* LBSC */ + writew(0x0000, &gpio->pzcr); /* eMMC */ + writew(0xfe00, &gpio->psel0); + writew(0x0000, &gpio->psel1); + writew(0x3000, &gpio->psel2); + writew(0xff00, &gpio->psel3); + writew(0x771f, &gpio->psel4); + writew(0x0ffc, &gpio->psel5); + writew(0x00ff, &gpio->psel6); + writew(0xfc00, &gpio->psel7); + + writeb(0x10, &sermux->smr0); /* SMR0: SerMux mode 0 */ +} + +static void init_usb_phy(void) +{ + struct usb_common_regs *common0 = USB0_COMMON_BASE; + struct usb_common_regs *common1 = USB1_COMMON_BASE; + struct usb0_phy_regs *phy = USB0_PHY_BASE; + struct usb1_port_regs *port = USB1_PORT_BASE; + struct usb1_alignment_regs *align = USB1_ALIGNMENT_BASE; + + writew(0x0100, &phy->reset); /* set reset */ + /* port0 = USB0, port1 = USB1 */ + writew(0x0002, &phy->portsel); + writel(0x0001, &port->port1sel); /* port1 = Host */ + writew(0x0111, &phy->reset); /* clear reset */ + + writew(0x4000, &common0->suspmode); + writew(0x4000, &common1->suspmode); + +#if defined(__LITTLE_ENDIAN) + writel(0x00000000, &align->ehcidatac); + writel(0x00000000, &align->ohcidatac); +#endif +} + +static void init_gether_mdio(void) +{ + struct gpio_regs *gpio = GPIO_BASE; + + writew(readw(&gpio->pgcr) | 0x0004, &gpio->pgcr); + writeb(readb(&gpio->pgdr) | 0x02, &gpio->pgdr); /* Use ET0-MDIO */ +} + +static void set_mac_to_sh_giga_eth_register(int channel, char *mac_string) +{ + struct ether_mac_regs *ether; + unsigned char mac[6]; + unsigned long val; + + eth_parse_enetaddr(mac_string, mac); + + if (!channel) + ether = GETHER0_MAC_BASE; + else + ether = GETHER1_MAC_BASE; + + val = (mac[0] << 24) | (mac[1] << 16) | (mac[2] << 8) | mac[3]; + writel(val, ðer->mahr); + val = (mac[4] << 8) | mac[5]; + writel(val, ðer->malr); +} + +/***************************************************************** + * This PMB must be set on this timing. The lowlevel_init is run on + * Area 0(phys 0x00000000), so we have to map it. + * + * The new PMB table is following: + * ent virt phys v sz c wt + * 0 0xa0000000 0x40000000 1 128M 0 1 + * 1 0xa8000000 0x48000000 1 128M 0 1 + * 2 0xb0000000 0x50000000 1 128M 0 1 + * 3 0xb8000000 0x58000000 1 128M 0 1 + * 4 0x80000000 0x40000000 1 128M 1 1 + * 5 0x88000000 0x48000000 1 128M 1 1 + * 6 0x90000000 0x50000000 1 128M 1 1 + * 7 0x98000000 0x58000000 1 128M 1 1 + */ +static void set_pmb_on_board_init(void) +{ + struct mmu_regs *mmu = MMU_BASE; + + /* clear ITLB */ + writel(0x00000004, &mmu->mmucr); + + /* delete PMB for SPIBOOT */ + writel(0, PMB_ADDR_BASE(0)); + writel(0, PMB_DATA_BASE(0)); + + /* add PMB for SDRAM(0x40000000 - 0x47ffffff) */ + /* ppn ub v s1 s0 c wt */ + writel(mk_pmb_addr_val(0xa0), PMB_ADDR_BASE(0)); + writel(mk_pmb_data_val(0x40, 1, 1, 1, 0, 0, 1), PMB_DATA_BASE(0)); + writel(mk_pmb_addr_val(0xb0), PMB_ADDR_BASE(2)); + writel(mk_pmb_data_val(0x50, 1, 1, 1, 0, 0, 1), PMB_DATA_BASE(2)); + writel(mk_pmb_addr_val(0xb8), PMB_ADDR_BASE(3)); + writel(mk_pmb_data_val(0x58, 1, 1, 1, 0, 0, 1), PMB_DATA_BASE(3)); + writel(mk_pmb_addr_val(0x80), PMB_ADDR_BASE(4)); + writel(mk_pmb_data_val(0x40, 0, 1, 1, 0, 1, 1), PMB_DATA_BASE(4)); + writel(mk_pmb_addr_val(0x90), PMB_ADDR_BASE(6)); + writel(mk_pmb_data_val(0x50, 0, 1, 1, 0, 1, 1), PMB_DATA_BASE(6)); + writel(mk_pmb_addr_val(0x98), PMB_ADDR_BASE(7)); + writel(mk_pmb_data_val(0x58, 0, 1, 1, 0, 1, 1), PMB_DATA_BASE(7)); +} + +int board_init(void) +{ + struct gether_control_regs *gether = GETHER_CONTROL_BASE; + + init_gpio(); + set_pmb_on_board_init(); + + /* Sets TXnDLY to B'010 */ + writel(0x00000202, &gether->gbecont); + + init_usb_phy(); + init_gether_mdio(); + + return 0; +} + +int dram_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + + gd->bd->bi_memstart = CONFIG_SYS_SDRAM_BASE; + gd->bd->bi_memsize = CONFIG_SYS_SDRAM_SIZE; + printf("DRAM: %dMB\n", CONFIG_SYS_SDRAM_SIZE / (1024 * 1024)); + + return 0; +} + +int board_mmc_init(bd_t *bis) +{ + struct gpio_regs *gpio = GPIO_BASE; + + writew(readw(&gpio->pgcr) | 0x0040, &gpio->pgcr); + writeb(readb(&gpio->pgdr) & ~0x08, &gpio->pgdr); /* Reset */ + udelay(1); + writeb(readb(&gpio->pgdr) | 0x08, &gpio->pgdr); /* Release reset */ + udelay(200); + + return mmcif_mmc_init(); +} + +static int get_sh_eth_mac_raw(unsigned char *buf, int size) +{ + struct spi_flash *spi; + int ret; + + spi = spi_flash_probe(0, 0, 1000000, SPI_MODE_3); + if (spi == NULL) { + printf("%s: spi_flash probe failed.\n", __func__); + return 1; + } + + ret = spi_flash_read(spi, SH7753EVB_ETHERNET_MAC_BASE, size, buf); + if (ret) { + printf("%s: spi_flash read failed.\n", __func__); + spi_flash_free(spi); + return 1; + } + spi_flash_free(spi); + + return 0; +} + +static int get_sh_eth_mac(int channel, char *mac_string, unsigned char *buf) +{ + memcpy(mac_string, &buf[channel * (SH7753EVB_ETHERNET_MAC_SIZE + 1)], + SH7753EVB_ETHERNET_MAC_SIZE); + mac_string[SH7753EVB_ETHERNET_MAC_SIZE] = 0x00; /* terminate */ + + return 0; +} + +static void init_ethernet_mac(void) +{ + char mac_string[64]; + char env_string[64]; + int i; + unsigned char *buf; + + buf = malloc(256); + if (!buf) { + printf("%s: malloc failed.\n", __func__); + return; + } + get_sh_eth_mac_raw(buf, 256); + + /* Gigabit Ethernet */ + for (i = 0; i < SH7753EVB_ETHERNET_NUM_CH; i++) { + get_sh_eth_mac(i, mac_string, buf); + if (i == 0) + setenv("ethaddr", mac_string); + else { + sprintf(env_string, "eth%daddr", i); + setenv(env_string, mac_string); + } + set_mac_to_sh_giga_eth_register(i, mac_string); + } + + free(buf); +} + +int board_late_init(void) +{ + init_ethernet_mac(); + + return 0; +} + +int do_write_mac(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + int i, ret; + char mac_string[256]; + struct spi_flash *spi; + unsigned char *buf; + + if (argc != 3) { + buf = malloc(256); + if (!buf) { + printf("%s: malloc failed.\n", __func__); + return 1; + } + + get_sh_eth_mac_raw(buf, 256); + + /* print current MAC address */ + for (i = 0; i < SH7753EVB_ETHERNET_NUM_CH; i++) { + get_sh_eth_mac(i, mac_string, buf); + printf("GETHERC ch%d = %s\n", i, mac_string); + } + free(buf); + return 0; + } + + /* new setting */ + memset(mac_string, 0xff, sizeof(mac_string)); + sprintf(mac_string, "%s\t%s", + argv[1], argv[2]); + + /* write MAC data to SPI rom */ + spi = spi_flash_probe(0, 0, 1000000, SPI_MODE_3); + if (!spi) { + printf("%s: spi_flash probe failed.\n", __func__); + return 1; + } + + ret = spi_flash_erase(spi, SH7753EVB_ETHERNET_MAC_BASE_SPI, + SH7753EVB_SPI_SECTOR_SIZE); + if (ret) { + printf("%s: spi_flash erase failed.\n", __func__); + return 1; + } + + ret = spi_flash_write(spi, SH7753EVB_ETHERNET_MAC_BASE_SPI, + sizeof(mac_string), mac_string); + if (ret) { + printf("%s: spi_flash write failed.\n", __func__); + spi_flash_free(spi); + return 1; + } + spi_flash_free(spi); + + puts("The writing of the MAC address to SPI ROM was completed.\n"); + + return 0; +} + +U_BOOT_CMD( + write_mac, 3, 1, do_write_mac, + "write MAC address for GETHERC", + "[GETHERC ch0] [GETHERC ch1]\n" +); diff --git a/board/renesas/sh7753evb/spi-boot.c b/board/renesas/sh7753evb/spi-boot.c new file mode 100644 index 0000000..21903d9 --- /dev/null +++ b/board/renesas/sh7753evb/spi-boot.c @@ -0,0 +1,134 @@ +/* + * Copyright (C) 2013 Renesas Solutions Corp. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> + +#define CONFIG_SPI_ADDR 0x00000000 +#define PHYADDR(_addr) ((_addr & 0x1fffffff) | 0x40000000) +#define CONFIG_RAM_BOOT_PHYS PHYADDR(CONFIG_SYS_TEXT_BASE) + +#define SPIWDMADR 0xFE001018 +#define SPIWDMCNTR 0xFE001020 +#define SPIDMCOR 0xFE001028 +#define SPIDMINTSR 0xFE001188 +#define SPIDMINTMR 0xFE001190 + +#define SPIDMINTSR_DMEND 0x00000004 + +#define TBR 0xFE002000 +#define RBR 0xFE002000 + +#define CR1 0xFE002008 +#define CR2 0xFE002010 +#define CR3 0xFE002018 +#define CR4 0xFE002020 +#define CR7 0xFE002038 +#define CR8 0xFE002040 + +/* CR1 */ +#define SPI_TBE 0x80 +#define SPI_TBF 0x40 +#define SPI_RBE 0x20 +#define SPI_RBF 0x10 +#define SPI_PFONRD 0x08 +#define SPI_SSDB 0x04 +#define SPI_SSD 0x02 +#define SPI_SSA 0x01 + +/* CR2 */ +#define SPI_RSTF 0x80 +#define SPI_LOOPBK 0x40 +#define SPI_CPOL 0x20 +#define SPI_CPHA 0x10 +#define SPI_L1M0 0x08 + +/* CR4 */ +#define SPI_TBEI 0x80 +#define SPI_TBFI 0x40 +#define SPI_RBEI 0x20 +#define SPI_RBFI 0x10 +#define SPI_SpiS0 0x02 +#define SPI_SSS 0x01 + +/* CR7 */ +#define CR7_IDX_OR12 0x12 +#define OR12_ADDR32 0x00000001 + +#define spi_write(val, addr) (*(volatile unsigned long *)(addr)) = val +#define spi_read(addr) (*(volatile unsigned long *)(addr)) + +/* M25P80 */ +#define M25_READ 0x03 +#define M25_READ_4BYTE 0x13 + +extern void bss_start(void); + +#define __uses_spiboot2 __attribute__((section(".spiboot2.text"))) +static void __uses_spiboot2 spi_reset(void) +{ + int timeout = 0x00100000; + + /* Make sure the last transaction is finalized */ + spi_write(0x00, CR3); + spi_write(0x02, CR1); + while (!(spi_read(CR4) & SPI_SpiS0)) { + if (timeout-- < 0) + break; + } + spi_write(0x00, CR1); + + spi_write(spi_read(CR2) | SPI_RSTF, CR2); /* fifo reset */ + spi_write(spi_read(CR2) & ~SPI_RSTF, CR2); + + spi_write(0, SPIDMCOR); +} + +static void __uses_spiboot2 spi_read_flash(void *buf, unsigned long addr, + unsigned long len) +{ + spi_write(CR7_IDX_OR12, CR7); + if (spi_read(CR8) & OR12_ADDR32) { + /* 4-bytes address mode */ + spi_write(M25_READ_4BYTE, TBR); + spi_write((addr >> 24) & 0xFF, TBR); /* ADDR31-24 */ + } else { + /* 3-bytes address mode */ + spi_write(M25_READ, TBR); + } + spi_write((addr >> 16) & 0xFF, TBR); /* ADDR23-16 */ + spi_write((addr >> 8) & 0xFF, TBR); /* ADDR15-8 */ + spi_write(addr & 0xFF, TBR); /* ADDR7-0 */ + + spi_write(SPIDMINTSR_DMEND, SPIDMINTSR); + spi_write((unsigned long)buf, SPIWDMADR); + spi_write(len & 0xFFFFFFE0, SPIWDMCNTR); + spi_write(1, SPIDMCOR); + + spi_write(0xff, CR3); + spi_write(spi_read(CR1) | SPI_SSDB, CR1); + spi_write(spi_read(CR1) | SPI_SSA, CR1); + + while (!(spi_read(SPIDMINTSR) & SPIDMINTSR_DMEND)) + ; + + /* Nagate SP0-SS0 */ + spi_write(0, CR1); +} + +void __uses_spiboot2 spiboot_main(void) +{ + /* + * This code rounds len up for SPIWDMCNTR. We should set it to 0 in + * lower 5-bits. + */ + void (*_start)(void) = (void *)CONFIG_SYS_TEXT_BASE; + volatile unsigned long len = (bss_start - _start + 31) & 0xffffffe0; + + spi_reset(); + spi_read_flash((void *)CONFIG_RAM_BOOT_PHYS, CONFIG_SPI_ADDR, len); + + _start(); +} diff --git a/board/renesas/sh7753evb/u-boot.lds b/board/renesas/sh7753evb/u-boot.lds new file mode 100644 index 0000000..053df64 --- /dev/null +++ b/board/renesas/sh7753evb/u-boot.lds @@ -0,0 +1,81 @@ +/* + * Copyright (C) 2007 + * Nobuhiro Iwamatsu iwamatsu@nigauri.org + * + * Copyright (C) 2012 + * Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +OUTPUT_FORMAT("elf32-sh-linux", "elf32-sh-linux", "elf32-sh-linux") +OUTPUT_ARCH(sh) +ENTRY(_start) + +SECTIONS +{ + /* + * entry and reloct_dst will be provided via ldflags + */ + . = .; + + PROVIDE (_ftext = .); + PROVIDE (_fcode = .); + PROVIDE (_start = .); + + .text : + { + KEEP(arch/sh/cpu/sh4/start.o (.text)) + *(.spiboot1.text) + *(.spiboot2.text) + . = ALIGN(8192); + common/env_embedded.o (.ppcenv) + . = ALIGN(8192); + common/env_embedded.o (.ppcenvr) + . = ALIGN(8192); + *(.text) + . = ALIGN(4); + } =0xFF + PROVIDE (_ecode = .); + .rodata : + { + *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) + . = ALIGN(4); + } + PROVIDE (_etext = .); + + + PROVIDE (_fdata = .); + .data : + { + *(.data) + . = ALIGN(4); + } + PROVIDE (_edata = .); + + PROVIDE (_fgot = .); + .got : + { + *(.got) + . = ALIGN(4); + } + PROVIDE (_egot = .); + + .u_boot_list : { + KEEP(*(SORT(.u_boot_list*))); + } + + PROVIDE (reloc_dst_end = .); + /* _reloc_dst_end = .; */ + + PROVIDE (bss_start = .); + PROVIDE (__bss_start = .); + .bss (NOLOAD) : + { + *(.bss) + . = ALIGN(4); + } + PROVIDE (bss_end = .); + + PROVIDE (__bss_end = .); +} diff --git a/boards.cfg b/boards.cfg index 2128996..6a26cad 100644 --- a/boards.cfg +++ b/boards.cfg @@ -1208,7 +1208,7 @@ Active sh sh4 - renesas MigoR Active sh sh4 - renesas r0p7734 r0p7734 - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org Active sh sh4 - renesas r2dplus r2dplus - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org Active sh sh4 - renesas r7780mp r7780mp - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org -Active sh sh4 - renesas sh7752evb sh7752evb - - +Active sh sh4 - renesas sh7753evb sh7753evb - - Active sh sh4 - renesas sh7757lcr sh7757lcr - - Active sh sh4 - renesas sh7763rdp sh7763rdp - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org Active sh sh4 - renesas sh7785lcr sh7785lcr - - diff --git a/doc/README.sh7752evb b/doc/README.sh7752evb deleted file mode 100644 index c1fb54c..0000000 --- a/doc/README.sh7752evb +++ /dev/null @@ -1,67 +0,0 @@ -======================================== -Renesas R0P7752C00000RZ board -======================================== - -This board specification: -========================= - -The R0P7752C00000RZ(board config name:sh7752evb) has the following device: - - - SH7752 (SH-4A) - - DDR3-SDRAM 512MB - - SPI ROM 8MB - - Gigabit Ethernet controllers - - eMMC 4GB - - -Configuration for This board: -============================= - -You can select the configuration as follows: - - - make sh7752evb_config - - -This board specific command: -============================ - -This board has the following its specific command: - - - write_mac - - -1. write_mac - -You can write MAC address to SPI ROM. - - Usage 1) Write MAC address - - write_mac [GETHERC ch0] [GETHERC ch1] - - For example) - => write_mac 74:90:50:00:33:9e 74:90:50:00:33:9f - *) We have to input the command as a single line - (without carriage return) - *) We have to reset after input the command. - - Usage 2) Show current data - - write_mac - - For example) - => write_mac - GETHERC ch0 = 74:90:50:00:33:9e - GETHERC ch1 = 74:90:50:00:33:9f - - -Update SPI ROM: -============================ - -1. Copy u-boot image to RAM area. -2. Probe SPI device. - => sf probe 0 - SF: Detected MX25L6405D with page size 64KiB, total 8 MiB -3. Erase SPI ROM. - => sf erase 0 80000 -4. Write u-boot image to SPI ROM. - => sf write 0x48000000 0 80000 diff --git a/doc/README.sh7753evb b/doc/README.sh7753evb new file mode 100644 index 0000000..5fe178c --- /dev/null +++ b/doc/README.sh7753evb @@ -0,0 +1,67 @@ +======================================== +Renesas SH7753 EVB board +======================================== + +This board specification: +========================= + +The SH7753 EVB (board config name:sh7753evb) has the following device: + + - SH7753 (SH-4A) + - DDR3-SDRAM 512MB + - SPI ROM 8MB + - Gigabit Ethernet controllers + - eMMC 4GB + + +Configuration for This board: +============================= + +You can select the configuration as follows: + + - make sh7753evb_config + + +This board specific command: +============================ + +This board has the following its specific command: + + - write_mac + + +1. write_mac + +You can write MAC address to SPI ROM. + + Usage 1) Write MAC address + + write_mac [GETHERC ch0] [GETHERC ch1] + + For example) + => write_mac 74:90:50:00:33:9e 74:90:50:00:33:9f + *) We have to input the command as a single line + (without carriage return) + *) We have to reset after input the command. + + Usage 2) Show current data + + write_mac + + For example) + => write_mac + GETHERC ch0 = 74:90:50:00:33:9e + GETHERC ch1 = 74:90:50:00:33:9f + + +Update SPI ROM: +============================ + +1. Copy u-boot image to RAM area. +2. Probe SPI device. + => sf probe 0 + SF: Detected MX25L6405D with page size 64KiB, total 8 MiB +3. Erase SPI ROM. + => sf erase 0 80000 +4. Write u-boot image to SPI ROM. + => sf write 0x48000000 0 80000 diff --git a/include/configs/sh7752evb.h b/include/configs/sh7752evb.h deleted file mode 100644 index ebdc5c8..0000000 --- a/include/configs/sh7752evb.h +++ /dev/null @@ -1,137 +0,0 @@ -/* - * Configuation settings for the sh7752evb board - * - * Copyright (C) 2012 Renesas Solutions Corp. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __SH7752EVB_H -#define __SH7752EVB_H - -#undef DEBUG -#define CONFIG_SH 1 -#define CONFIG_SH4A 1 -#define CONFIG_SH_32BIT 1 -#define CONFIG_CPU_SH7752 1 -#define CONFIG_SH7752EVB 1 - -#define CONFIG_SYS_TEXT_BASE 0x5ff80000 -#define CONFIG_SYS_LDSCRIPT "board/renesas/sh7752evb/u-boot.lds" - -#define CONFIG_CMD_MEMORY -#define CONFIG_CMD_NET -#define CONFIG_CMD_MII -#define CONFIG_CMD_PING -#define CONFIG_CMD_NFS -#define CONFIG_CMD_DFL -#define CONFIG_CMD_SDRAM -#define CONFIG_CMD_SF -#define CONFIG_CMD_RUN -#define CONFIG_CMD_SAVEENV -#define CONFIG_CMD_MD5SUM -#define CONFIG_MD5 -#define CONFIG_CMD_LOADS -#define CONFIG_CMD_MMC -#define CONFIG_CMD_EXT2 -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION - -#define CONFIG_BAUDRATE 115200 -#define CONFIG_BOOTDELAY 3 -#define CONFIG_BOOTARGS "console=ttySC2,115200 root=/dev/nfs ip=dhcp" - -#define CONFIG_VERSION_VARIABLE -#undef CONFIG_SHOW_BOOT_PROGRESS -#define CONFIG_CMDLINE_EDITING -#define CONFIG_AUTO_COMPLETE - -/* MEMORY */ -#define SH7752EVB_SDRAM_BASE (0x40000000) -#define SH7752EVB_SDRAM_SIZE (512 * 1024 * 1024) - -#define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_CBSIZE 256 -#define CONFIG_SYS_PBSIZE 256 -#define CONFIG_SYS_MAXARGS 16 -#define CONFIG_SYS_BARGSIZE 512 -#define CONFIG_SYS_BAUDRATE_TABLE { 115200 } - -/* SCIF */ -#define CONFIG_SCIF_CONSOLE 1 -#define CONFIG_CONS_SCIF2 1 -#undef CONFIG_SYS_CONSOLE_INFO_QUIET -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE - -#define CONFIG_SYS_MEMTEST_START (SH7752EVB_SDRAM_BASE) -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ - 480 * 1024 * 1024) -#undef CONFIG_SYS_ALT_MEMTEST -#undef CONFIG_SYS_MEMTEST_SCRATCH -#undef CONFIG_SYS_LOADS_BAUD_CHANGE - -#define CONFIG_SYS_SDRAM_BASE (SH7752EVB_SDRAM_BASE) -#define CONFIG_SYS_SDRAM_SIZE (SH7752EVB_SDRAM_SIZE) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + \ - 128 * 1024 * 1024) - -#define CONFIG_SYS_MONITOR_BASE 0x00000000 -#define CONFIG_SYS_MONITOR_LEN (512 * 1024) -#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) -#define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024) - -/* FLASH */ -#define CONFIG_SYS_NO_FLASH - -/* Ether */ -#define CONFIG_SH_ETHER 1 -#define CONFIG_SH_ETHER_USE_PORT 0 -#define CONFIG_SH_ETHER_PHY_ADDR 18 -#define CONFIG_SH_ETHER_CACHE_WRITEBACK 1 -#define CONFIG_SH_ETHER_USE_GETHER 1 -#define CONFIG_PHYLIB -#define CONFIG_BITBANGMII -#define CONFIG_BITBANGMII_MULTI -#define CONFIG_SH_ETHER_PHY_MODE PHY_INTERFACE_MODE_RGMII -#define CONFIG_PHY_VITESSE - -#define SH7752EVB_ETHERNET_MAC_BASE_SPI 0x00090000 -#define SH7752EVB_SPI_SECTOR_SIZE (64 * 1024) -#define SH7752EVB_ETHERNET_MAC_BASE SH7752EVB_ETHERNET_MAC_BASE_SPI -#define SH7752EVB_ETHERNET_MAC_SIZE 17 -#define SH7752EVB_ETHERNET_NUM_CH 2 -#define CONFIG_BOARD_LATE_INIT - -/* SPI */ -#define CONFIG_SH_SPI 1 -#define CONFIG_SH_SPI_BASE 0xfe002000 -#define CONFIG_SPI_FLASH -#define CONFIG_SPI_FLASH_STMICRO 1 -#define CONFIG_SPI_FLASH_MACRONIX 1 - -/* MMCIF */ -#define CONFIG_MMC 1 -#define CONFIG_GENERIC_MMC 1 -#define CONFIG_SH_MMCIF 1 -#define CONFIG_SH_MMCIF_ADDR 0xffcb0000 -#define CONFIG_SH_MMCIF_CLK 48000000 - -/* ENV setting */ -#define CONFIG_ENV_IS_EMBEDDED -#define CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_SECT_SIZE (64 * 1024) -#define CONFIG_ENV_ADDR (0x00080000) -#define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) -#define CONFIG_ENV_OVERWRITE 1 -#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SECT_SIZE) -#define CONFIG_EXTRA_ENV_SETTINGS \ - "netboot=bootp; bootm\0" - -/* Board Clock */ -#define CONFIG_SYS_CLK_FREQ 48000000 -#define CONFIG_SH_TMU_CLK_FREQ CONFIG_SYS_CLK_FREQ -#define CONFIG_SH_SCIF_CLK_FREQ CONFIG_SYS_CLK_FREQ -#define CONFIG_SYS_TMU_CLK_DIV 4 -#endif /* __SH7752EVB_H */ diff --git a/include/configs/sh7753evb.h b/include/configs/sh7753evb.h new file mode 100644 index 0000000..f7eb86d --- /dev/null +++ b/include/configs/sh7753evb.h @@ -0,0 +1,137 @@ +/* + * Configuation settings for the sh7753evb board + * + * Copyright (C) 2012 Renesas Solutions Corp. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __SH7753EVB_H +#define __SH7753EVB_H + +#undef DEBUG +#define CONFIG_SH 1 +#define CONFIG_SH4A 1 +#define CONFIG_SH_32BIT 1 +#define CONFIG_CPU_SH7753 1 +#define CONFIG_SH7753EVB 1 + +#define CONFIG_SYS_TEXT_BASE 0x5ff80000 +#define CONFIG_SYS_LDSCRIPT "board/renesas/sh7753evb/u-boot.lds" + +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_NET +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_NFS +#define CONFIG_CMD_DFL +#define CONFIG_CMD_SDRAM +#define CONFIG_CMD_SF +#define CONFIG_CMD_RUN +#define CONFIG_CMD_SAVEENV +#define CONFIG_CMD_MD5SUM +#define CONFIG_MD5 +#define CONFIG_CMD_LOADS +#define CONFIG_CMD_MMC +#define CONFIG_CMD_EXT2 +#define CONFIG_DOS_PARTITION +#define CONFIG_MAC_PARTITION + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTARGS "console=ttySC2,115200 root=/dev/nfs ip=dhcp" + +#define CONFIG_VERSION_VARIABLE +#undef CONFIG_SHOW_BOOT_PROGRESS +#define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE + +/* MEMORY */ +#define SH7753EVB_SDRAM_BASE (0x40000000) +#define SH7753EVB_SDRAM_SIZE (512 * 1024 * 1024) + +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE 512 +#define CONFIG_SYS_BAUDRATE_TABLE { 115200 } + +/* SCIF */ +#define CONFIG_SCIF_CONSOLE 1 +#define CONFIG_CONS_SCIF2 1 +#undef CONFIG_SYS_CONSOLE_INFO_QUIET +#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE +#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE + +#define CONFIG_SYS_MEMTEST_START (SH7753EVB_SDRAM_BASE) +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ + 480 * 1024 * 1024) +#undef CONFIG_SYS_ALT_MEMTEST +#undef CONFIG_SYS_MEMTEST_SCRATCH +#undef CONFIG_SYS_LOADS_BAUD_CHANGE + +#define CONFIG_SYS_SDRAM_BASE (SH7753EVB_SDRAM_BASE) +#define CONFIG_SYS_SDRAM_SIZE (SH7753EVB_SDRAM_SIZE) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + \ + 128 * 1024 * 1024) + +#define CONFIG_SYS_MONITOR_BASE 0x00000000 +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) +#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) +#define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024) + +/* FLASH */ +#define CONFIG_SYS_NO_FLASH + +/* Ether */ +#define CONFIG_SH_ETHER 1 +#define CONFIG_SH_ETHER_USE_PORT 0 +#define CONFIG_SH_ETHER_PHY_ADDR 18 +#define CONFIG_SH_ETHER_CACHE_WRITEBACK 1 +#define CONFIG_SH_ETHER_USE_GETHER 1 +#define CONFIG_PHYLIB +#define CONFIG_BITBANGMII +#define CONFIG_BITBANGMII_MULTI +#define CONFIG_SH_ETHER_PHY_MODE PHY_INTERFACE_MODE_RGMII +#define CONFIG_PHY_VITESSE + +#define SH7753EVB_ETHERNET_MAC_BASE_SPI 0x00090000 +#define SH7753EVB_SPI_SECTOR_SIZE (64 * 1024) +#define SH7753EVB_ETHERNET_MAC_BASE SH7753EVB_ETHERNET_MAC_BASE_SPI +#define SH7753EVB_ETHERNET_MAC_SIZE 17 +#define SH7753EVB_ETHERNET_NUM_CH 2 +#define CONFIG_BOARD_LATE_INIT + +/* SPI */ +#define CONFIG_SH_SPI 1 +#define CONFIG_SH_SPI_BASE 0xfe002000 +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_STMICRO 1 +#define CONFIG_SPI_FLASH_MACRONIX 1 + +/* MMCIF */ +#define CONFIG_MMC 1 +#define CONFIG_GENERIC_MMC 1 +#define CONFIG_SH_MMCIF 1 +#define CONFIG_SH_MMCIF_ADDR 0xffcb0000 +#define CONFIG_SH_MMCIF_CLK 48000000 + +/* ENV setting */ +#define CONFIG_ENV_IS_EMBEDDED +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SECT_SIZE (64 * 1024) +#define CONFIG_ENV_ADDR (0x00080000) +#define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) +#define CONFIG_ENV_OVERWRITE 1 +#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SECT_SIZE) +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netboot=bootp; bootm\0" + +/* Board Clock */ +#define CONFIG_SYS_CLK_FREQ 48000000 +#define CONFIG_SH_TMU_CLK_FREQ CONFIG_SYS_CLK_FREQ +#define CONFIG_SH_SCIF_CLK_FREQ CONFIG_SYS_CLK_FREQ +#define CONFIG_SYS_TMU_CLK_DIV 4 +#endif /* __SH7753EVB_H */
2013/12/17 Shimoda, Yoshihiro yoshihiro.shimoda.uh@renesas.com:
The SH7753 EVB board has SH7753, 512MB DDR3-SDRAM, SPI ROM, Gigabit Ethernet, and eMMC.
This patch support the following functions:
- 512MB DDR3-SDRAM, SCIF4, SPI ROM, Gigabit Ethernet, eMMC
This patch changes the support for sh7752evb to sh7753evb.
Signed-off-by: Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com
Why do you remove sh7752evb? Isn't this already use or discontinue? There is no user any longer? If that is right, you should divide the patch which removes sh7752evb, and the patch to which sh7753evb is added.
Could you split patches?
Best regards, Nobuhiro
arch/sh/include/asm/cpu_sh4.h | 4 +- arch/sh/include/asm/cpu_sh7752.h | 197 -------------- arch/sh/include/asm/cpu_sh7753.h | 197 ++++++++++++++ board/renesas/sh7752evb/Makefile | 7 - board/renesas/sh7752evb/lowlevel_init.S | 447 ------------------------------- board/renesas/sh7752evb/sh7752evb.c | 314 ---------------------- board/renesas/sh7752evb/spi-boot.c | 116 -------- board/renesas/sh7752evb/u-boot.lds | 81 ------ board/renesas/sh7753evb/Makefile | 7 + board/renesas/sh7753evb/lowlevel_init.S | 416 ++++++++++++++++++++++++++++ board/renesas/sh7753evb/sh7753evb.c | 326 ++++++++++++++++++++++ board/renesas/sh7753evb/spi-boot.c | 134 +++++++++ board/renesas/sh7753evb/u-boot.lds | 81 ++++++ boards.cfg | 2 +- doc/README.sh7752evb | 67 ----- doc/README.sh7753evb | 67 +++++ include/configs/sh7752evb.h | 137 ---------- include/configs/sh7753evb.h | 137 ++++++++++ 18 files changed, 1368 insertions(+), 1369 deletions(-) delete mode 100644 arch/sh/include/asm/cpu_sh7752.h create mode 100644 arch/sh/include/asm/cpu_sh7753.h delete mode 100644 board/renesas/sh7752evb/Makefile delete mode 100644 board/renesas/sh7752evb/lowlevel_init.S delete mode 100644 board/renesas/sh7752evb/sh7752evb.c delete mode 100644 board/renesas/sh7752evb/spi-boot.c delete mode 100644 board/renesas/sh7752evb/u-boot.lds create mode 100644 board/renesas/sh7753evb/Makefile create mode 100644 board/renesas/sh7753evb/lowlevel_init.S create mode 100644 board/renesas/sh7753evb/sh7753evb.c create mode 100644 board/renesas/sh7753evb/spi-boot.c create mode 100644 board/renesas/sh7753evb/u-boot.lds delete mode 100644 doc/README.sh7752evb create mode 100644 doc/README.sh7753evb delete mode 100644 include/configs/sh7752evb.h create mode 100644 include/configs/sh7753evb.h
diff --git a/arch/sh/include/asm/cpu_sh4.h b/arch/sh/include/asm/cpu_sh4.h index 9181d59..9939f20 100644 --- a/arch/sh/include/asm/cpu_sh4.h +++ b/arch/sh/include/asm/cpu_sh4.h @@ -35,8 +35,8 @@ # include <asm/cpu_sh7724.h> #elif defined (CONFIG_CPU_SH7734) # include <asm/cpu_sh7734.h> -#elif defined (CONFIG_CPU_SH7752) -# include <asm/cpu_sh7752.h> +#elif defined (CONFIG_CPU_SH7753) +# include <asm/cpu_sh7753.h> #elif defined (CONFIG_CPU_SH7757) # include <asm/cpu_sh7757.h> #elif defined (CONFIG_CPU_SH7763) diff --git a/arch/sh/include/asm/cpu_sh7752.h b/arch/sh/include/asm/cpu_sh7752.h deleted file mode 100644 index 229ab07..0000000 --- a/arch/sh/include/asm/cpu_sh7752.h +++ /dev/null @@ -1,197 +0,0 @@ -/*
- Copyright (C) 2012 Renesas Solutions Corp.
-#ifndef _ASM_CPU_SH7752_H_ -#define _ASM_CPU_SH7752_H_
-#define CCR 0xFF00001C -#define WTCNT 0xFFCC0000 -#define CCR_CACHE_INIT 0x0000090b -#define CACHE_OC_NUM_WAYS 1
-#ifndef __ASSEMBLY__ /* put C only stuff in this section */ -/* MMU */ -struct mmu_regs {
unsigned int reserved[4];
unsigned int mmucr;
-}; -#define MMU_BASE ((struct mmu_regs *)0xff000000)
-/* Watchdog */ -#define WTCSR0 0xffcc0002 -#define WRSTCSR_R 0xffcc0003 -#define WRSTCSR_W 0xffcc0002 -#define WTCSR_PREFIX 0xa500 -#define WRSTCSR_PREFIX 0x6900 -#define WRSTCSR_WOVF_PREFIX 0x9600
-/* SCIF */ -#define SCIF0_BASE 0xfe4b0000 /* The real name is SCIF2 */ -#define SCIF1_BASE 0xfe4c0000 /* The real name is SCIF3 */ -#define SCIF2_BASE 0xfe4d0000 /* The real name is SCIF4 */
-/* TMU0 */ -#define TMU_BASE 0xFE430000
-/* ETHER, GETHER MAC address */ -struct ether_mac_regs {
unsigned int reserved[114];
unsigned int mahr;
unsigned int reserved2;
unsigned int malr;
-}; -#define GETHER0_MAC_BASE ((struct ether_mac_regs *)0xfee0400) -#define GETHER1_MAC_BASE ((struct ether_mac_regs *)0xfee0c00) -#define ETHER0_MAC_BASE ((struct ether_mac_regs *)0xfef0000) -#define ETHER1_MAC_BASE ((struct ether_mac_regs *)0xfef0800)
-/* GETHER */ -struct gether_control_regs {
unsigned int gbecont;
-}; -#define GETHER_CONTROL_BASE ((struct gether_control_regs *)0xffc10100) -#define GBECONT_RMII1 0x00020000 -#define GBECONT_RMII0 0x00010000
-/* SerMux */ -struct sermux_regs {
unsigned char smr0;
unsigned char smr1;
unsigned char smr2;
unsigned char smr3;
unsigned char smr4;
unsigned char smr5;
-}; -#define SERMUX_BASE ((struct sermux_regs *)0xfe470000)
-/* USB0/1 */ -struct usb_common_regs {
unsigned short reserved[129];
unsigned short suspmode;
-}; -#define USB0_COMMON_BASE ((struct usb_common_regs *)0xfe450000) -#define USB1_COMMON_BASE ((struct usb_common_regs *)0xfe4f0000)
-struct usb0_phy_regs {
unsigned short reset;
unsigned short reserved[4];
unsigned short portsel;
-}; -#define USB0_PHY_BASE ((struct usb0_phy_regs *)0xfe5f0000)
-struct usb1_port_regs {
unsigned int port1sel;
unsigned int reserved;
unsigned int usb1intsts;
-}; -#define USB1_PORT_BASE ((struct usb1_port_regs *)0xfe4f2000)
-struct usb1_alignment_regs {
unsigned int ehcidatac; /* 0xfe4fe018 */
unsigned int reserved[63];
unsigned int ohcidatac;
-}; -#define USB1_ALIGNMENT_BASE ((struct usb1_alignment_regs *)0xfe4fe018)
-/* GPIO */ -struct gpio_regs {
unsigned short pacr;
unsigned short pbcr;
unsigned short pccr;
unsigned short pdcr;
unsigned short pecr;
unsigned short pfcr;
unsigned short pgcr;
unsigned short phcr;
unsigned short picr;
unsigned short pjcr;
unsigned short pkcr;
unsigned short plcr;
unsigned short pmcr;
unsigned short pncr;
unsigned short pocr;
unsigned short reserved;
unsigned short pqcr;
unsigned short prcr;
unsigned short pscr;
unsigned short ptcr;
unsigned short pucr;
unsigned short pvcr;
unsigned short pwcr;
unsigned short pxcr;
unsigned short pycr;
unsigned short pzcr;
unsigned char padr;
unsigned char reserved_a;
unsigned char pbdr;
unsigned char reserved_b;
unsigned char pcdr;
unsigned char reserved_c;
unsigned char pddr;
unsigned char reserved_d;
unsigned char pedr;
unsigned char reserved_e;
unsigned char pfdr;
unsigned char reserved_f;
unsigned char pgdr;
unsigned char reserved_g;
unsigned char phdr;
unsigned char reserved_h;
unsigned char pidr;
unsigned char reserved_i;
unsigned char pjdr;
unsigned char reserved_j;
unsigned char pkdr;
unsigned char reserved_k;
unsigned char pldr;
unsigned char reserved_l;
unsigned char pmdr;
unsigned char reserved_m;
unsigned char pndr;
unsigned char reserved_n;
unsigned char podr;
unsigned char reserved_o;
unsigned char ppdr;
unsigned char reserved_p;
unsigned char pqdr;
unsigned char reserved_q;
unsigned char prdr;
unsigned char reserved_r;
unsigned char psdr;
unsigned char reserved_s;
unsigned char ptdr;
unsigned char reserved_t;
unsigned char pudr;
unsigned char reserved_u;
unsigned char pvdr;
unsigned char reserved_v;
unsigned char pwdr;
unsigned char reserved_w;
unsigned char pxdr;
unsigned char reserved_x;
unsigned char pydr;
unsigned char reserved_y;
unsigned char pzdr;
unsigned char reserved_z;
unsigned short ncer;
unsigned short ncmcr;
unsigned short nccsr;
unsigned char reserved2[2];
unsigned short psel0; /* +0x70 */
unsigned short psel1;
unsigned short psel2;
unsigned short psel3;
unsigned short psel4;
unsigned short psel5;
unsigned short psel6;
unsigned short reserved3[2];
unsigned short psel7;
-}; -#define GPIO_BASE ((struct gpio_regs *)0xffec0000)
-#endif /* ifndef __ASSEMBLY__ */ -#endif /* _ASM_CPU_SH7752_H_ */ diff --git a/arch/sh/include/asm/cpu_sh7753.h b/arch/sh/include/asm/cpu_sh7753.h new file mode 100644 index 0000000..cd0e0bb --- /dev/null +++ b/arch/sh/include/asm/cpu_sh7753.h @@ -0,0 +1,197 @@ +/*
+#ifndef _ASM_CPU_SH7753_H_ +#define _ASM_CPU_SH7753_H_
+#define CCR 0xFF00001C +#define WTCNT 0xFFCC0000 +#define CCR_CACHE_INIT 0x0000090b +#define CACHE_OC_NUM_WAYS 1
+#ifndef __ASSEMBLY__ /* put C only stuff in this section */ +/* MMU */ +struct mmu_regs {
unsigned int mmucr;
+}; +#define MMU_BASE ((struct mmu_regs *)0xff000000)
+/* Watchdog */ +#define WTCSR0 0xffcc0002 +#define WRSTCSR_R 0xffcc0003 +#define WRSTCSR_W 0xffcc0002 +#define WTCSR_PREFIX 0xa500 +#define WRSTCSR_PREFIX 0x6900 +#define WRSTCSR_WOVF_PREFIX 0x9600
+/* SCIF */ +#define SCIF0_BASE 0xfe4b0000 /* The real name is SCIF2 */ +#define SCIF1_BASE 0xfe4c0000 /* The real name is SCIF3 */ +#define SCIF2_BASE 0xfe4d0000 /* The real name is SCIF4 */
+/* TMU0 */ +#define TMU_BASE 0xFE430000
+/* ETHER, GETHER MAC address */ +struct ether_mac_regs {
unsigned int mahr;
unsigned int malr;
+}; +#define GETHER0_MAC_BASE ((struct ether_mac_regs *)0xfee0400) +#define GETHER1_MAC_BASE ((struct ether_mac_regs *)0xfee0c00) +#define ETHER0_MAC_BASE ((struct ether_mac_regs *)0xfef0000) +#define ETHER1_MAC_BASE ((struct ether_mac_regs *)0xfef0800)
+/* GETHER */ +struct gether_control_regs {
+}; +#define GETHER_CONTROL_BASE ((struct gether_control_regs *)0xffc10100) +#define GBECONT_RMII1 0x00020000 +#define GBECONT_RMII0 0x00010000
+/* SerMux */ +struct sermux_regs {
unsigned char smr0;
unsigned char smr1;
unsigned char smr2;
unsigned char smr3;
unsigned char smr4;
unsigned char smr5;
+}; +#define SERMUX_BASE ((struct sermux_regs *)0xfe470000)
+/* USB0/1 */ +struct usb_common_regs {
+}; +#define USB0_COMMON_BASE ((struct usb_common_regs *)0xfe450000) +#define USB1_COMMON_BASE ((struct usb_common_regs *)0xfe4f0000)
+struct usb0_phy_regs {
+}; +#define USB0_PHY_BASE ((struct usb0_phy_regs *)0xfe5f0000)
+struct usb1_port_regs {
+}; +#define USB1_PORT_BASE ((struct usb1_port_regs *)0xfe4f2000)
+struct usb1_alignment_regs {
+}; +#define USB1_ALIGNMENT_BASE ((struct usb1_alignment_regs *)0xfe4fe018)
+/* GPIO */ +struct gpio_regs {
unsigned char padr;
unsigned char pbdr;
unsigned char pcdr;
unsigned char pddr;
unsigned char pedr;
unsigned char pfdr;
unsigned char pgdr;
unsigned char phdr;
unsigned char pidr;
unsigned char pjdr;
unsigned char pkdr;
unsigned char pldr;
unsigned char pmdr;
unsigned char pndr;
unsigned char podr;
unsigned char ppdr;
unsigned char pqdr;
unsigned char prdr;
unsigned char psdr;
unsigned char ptdr;
unsigned char pudr;
unsigned char pvdr;
unsigned char pwdr;
unsigned char pxdr;
unsigned char pydr;
unsigned char pzdr;
+}; +#define GPIO_BASE ((struct gpio_regs *)0xffec0000)
+#endif /* ifndef __ASSEMBLY__ */ +#endif /* _ASM_CPU_SH7753_H_ */ diff --git a/board/renesas/sh7752evb/Makefile b/board/renesas/sh7752evb/Makefile deleted file mode 100644 index 856af81..0000000 --- a/board/renesas/sh7752evb/Makefile +++ /dev/null @@ -1,7 +0,0 @@ -# -# Copyright (C) 2012 Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com -# -# SPDX-License-Identifier: GPL-2.0+
-obj-y := sh7752evb.o spi-boot.o -obj-y += lowlevel_init.o diff --git a/board/renesas/sh7752evb/lowlevel_init.S b/board/renesas/sh7752evb/lowlevel_init.S deleted file mode 100644 index 5643a69..0000000 --- a/board/renesas/sh7752evb/lowlevel_init.S +++ /dev/null @@ -1,447 +0,0 @@ -/*
-#include <config.h> -#include <version.h> -#include <asm/processor.h> -#include <asm/macro.h>
-.macro or32, addr, data
mov.l \addr, r1
mov.l \data, r0
mov.l @r1, r2
or r2, r0
mov.l r0, @r1
-.endm
-.macro wait_DBCMD
mov.l DBWAIT_A, r0
mov.l @r0, r1
-.endm
.align 2
-lowlevel_init:
/*------- GPIO -------*/
write16 PDCR_A, PDCR_D ! SPI0
write16 PGCR_A, PGCR_D ! SPI0, GETHER MDIO gate(PTG1)
write16 PJCR_A, PJCR_D ! SCIF4
write16 PTCR_A, PTCR_D ! STATUS
write16 PSEL1_A, PSEL1_D ! SPI0
write16 PSEL2_A, PSEL2_D ! SPI0
write16 PSEL5_A, PSEL5_D ! STATUS
bra exit_gpio
nop
.align 2
-/*------- GPIO -------*/ -PDCR_A: .long 0xffec0006 -PGCR_A: .long 0xffec000c -PJCR_A: .long 0xffec0012 -PTCR_A: .long 0xffec0026 -PSEL1_A: .long 0xffec0072 -PSEL2_A: .long 0xffec0074 -PSEL5_A: .long 0xffec007a
-PDCR_D: .long 0x0000 -PGCR_D: .long 0x0004 -PJCR_D: .long 0x0000 -PTCR_D: .long 0x0000 -PSEL1_D: .long 0x0000 -PSEL2_D: .long 0x3000 -PSEL5_D: .long 0x0ffc
.align 2
-exit_gpio:
mov #0, r14
mova 2f, r0
mov.l PC_MASK, r1
tst r0, r1
bf 2f
bra exit_pmb
nop
.align 2
-/* If CPU runs on SDRAM (PC=0x5???????) or not. */ -PC_MASK: .long 0x20000000
-2:
mov #1, r14
mov.l EXPEVT_A, r0
mov.l @r0, r0
cmp/eq r0, r1
bt 1f
* initialization of DDR3IF is not necessary.
bra exit_ddr
nop
-1:
mov.l DBACEN_A, r0
mov.l @r0, r0
cmp/eq #0, r0
bt 3f
bra exit_ddr
nop
-3:
/*------- DDR3IF -------*/
/* step 3 */
/* step 4 */
/* step 5 */
/* step 6 */
/* step 7 */
/* step 8 */
/* step 9 */
/* step 10 */
/* step 11 */
/* step 12 */
wait_DBCMD
/* step 13 */
wait_DBCMD
/* step 14 */
/* step 15 */
/* step 16 */
/* step 17 */
/* step 18 */
/* step 19 */
/* step 20 */
wait_DBCMD
/* step 21 */
write32 DBADJ1_A, DBADJ1_D
/* step 22 */
/* step 23 */
/* step 24 */
/* step 25 */
/* step 26 */
wait_DBCMD
bra exit_ddr
nop
.align 2
-EXPEVT_A: .long 0xff000024 -EXPEVT_POWER_ON_RESET: .long 0x00000000
-/*------- Reset -------*/ -MRSTCR0_A: .long 0xffd50030 -MRSTCR0_D: .long 0xfe1ffe7f -MRSTCR1_A: .long 0xffd50034 -MRSTCR1_D: .long 0xfff3ffff
-/*------- DDR3IF -------*/ -DBCMD_A: .long 0xfe800018 -DBKIND_A: .long 0xfe800020 -DBCONF_A: .long 0xfe800024 -DBTR0_A: .long 0xfe800040 -DBTR1_A: .long 0xfe800044 -DBTR2_A: .long 0xfe800048 -DBTR3_A: .long 0xfe800050 -DBTR4_A: .long 0xfe800054 -DBTR5_A: .long 0xfe800058 -DBTR6_A: .long 0xfe80005c -DBTR7_A: .long 0xfe800060 -DBTR8_A: .long 0xfe800064 -DBTR9_A: .long 0xfe800068 -DBTR10_A: .long 0xfe80006c -DBTR11_A: .long 0xfe800070 -DBTR12_A: .long 0xfe800074 -DBTR13_A: .long 0xfe800078 -DBTR14_A: .long 0xfe80007c -DBTR15_A: .long 0xfe800080 -DBTR16_A: .long 0xfe800084 -DBTR17_A: .long 0xfe800088 -DBTR18_A: .long 0xfe80008c -DBTR19_A: .long 0xfe800090 -DBRNK0_A: .long 0xfe800100 -DBPDCNT0_A: .long 0xfe800200 -DBPDCNT1_A: .long 0xfe800204 -DBPDCNT2_A: .long 0xfe800208 -DBPDCNT3_A: .long 0xfe80020c -DBPDLCK_A: .long 0xfe800280 -DBPDRGA_A: .long 0xfe800290 -DBPDRGD_A: .long 0xfe8002a0 -DBADJ0_A: .long 0xfe8000c0 -DBADJ1_A: .long 0xfe8000c4 -DBADJ2_A: .long 0xfe8000c8 -DBRFCNF0_A: .long 0xfe8000e0 -DBRFCNF1_A: .long 0xfe8000e4 -DBRFCNF2_A: .long 0xfe8000e8 -DBCALCNF_A: .long 0xfe8000f4 -DBRFEN_A: .long 0xfe800014 -DBACEN_A: .long 0xfe800010 -DBWAIT_A: .long 0xfe80001c
-WAIT_OSC_TIME: .long 6000 -WAIT_30US: .long 13333
-DBCMD_RSTL_VAL: .long 0x20000000 -DBCMD_PDEN_VAL: .long 0x1000d73c -DBCMD_WAIT_VAL: .long 0x0000d73c -DBCMD_RSTH_VAL: .long 0x2100d73c -DBCMD_PDXT_VAL: .long 0x110000c8 -DBCMD_MRS0_VAL: .long 0x28000930 -DBCMD_MRS1_VAL: .long 0x29000004 -DBCMD_MRS2_VAL: .long 0x2a000008 -DBCMD_MRS3_VAL: .long 0x2b000000 -DBCMD_ZQCL_VAL: .long 0x03000200 -DBCMD_REF_VAL: .long 0x0c000000 -DBCMD_SRXT_VAL: .long 0x19000000 -DBKIND_D: .long 0x00000007 -DBCONF_D: .long 0x0f030a01 -DBTR0_D: .long 0x00000007 -DBTR1_D: .long 0x00000006 -DBTR2_D: .long 0x00000000 -DBTR3_D: .long 0x00000007 -DBTR4_D: .long 0x00070007 -DBTR5_D: .long 0x0000001b -DBTR6_D: .long 0x00000014 -DBTR7_D: .long 0x00000005 -DBTR8_D: .long 0x00000015 -DBTR9_D: .long 0x00000006 -DBTR10_D: .long 0x00000008 -DBTR11_D: .long 0x00000007 -DBTR12_D: .long 0x0000000e -DBTR13_D: .long 0x00000056 -DBTR14_D: .long 0x00000006 -DBTR15_D: .long 0x00000004 -DBTR16_D: .long 0x00150002 -DBTR17_D: .long 0x000c0017 -DBTR18_D: .long 0x00000200 -DBTR19_D: .long 0x00000040 -DBRNK0_D: .long 0x00000001 -DBPDCNT0_D: .long 0x00000001 -DBPDCNT1_D: .long 0x00000001 -DBPDCNT2_D: .long 0x00000000 -DBPDCNT3_D: .long 0x00004010 -DBPDLCK_D: .long 0x0000a55a -DBPDRGA_D: .long 0x00000028 -DBPDRGD_D: .long 0x00017100
-DBADJ0_D: .long 0x00000000 -DBADJ1_D: .long 0x00000000 -DBADJ2_D: .long 0x18061806 -DBRFCNF0_D: .long 0x000001ff -DBRFCNF1_D: .long 0x08001000 -DBRFCNF2_D: .long 0x00000000 -DBCALCNF_D: .long 0x0000ffff -DBRFEN_D: .long 0x00000001 -DBACEN_D: .long 0x00000001
.align 2
-exit_ddr: -#if defined(CONFIG_SH_32BIT)
icbi @r0
-#endif /* if defined(CONFIG_SH_32BIT) */
-exit_pmb:
mov r14, r0
tst #1, r0
bt 1f
-100: bsrf r0
nop
.align 2
-_spiboot_main: .long (spiboot_main - (100b + 4)) -_stack_ilram: .long 0xe5204000
-1:
rts
nop
.align 2
-#if defined(CONFIG_SH_32BIT) -/*------- set PMB -------*/ -PMB_ADDR_SPIBOOT_A: .long PMB_ADDR_BASE(0) -PMB_ADDR_DDR_N1_A: .long PMB_ADDR_BASE(1) -PMB_ADDR_DDR_C1_A: .long PMB_ADDR_BASE(5) -PMB_ADDR_ENTRY2: .long PMB_ADDR_BASE(2) -PMB_ADDR_ENTRY3: .long PMB_ADDR_BASE(3) -PMB_ADDR_ENTRY4: .long PMB_ADDR_BASE(4) -PMB_ADDR_ENTRY6: .long PMB_ADDR_BASE(6) -PMB_ADDR_ENTRY7: .long PMB_ADDR_BASE(7) -PMB_ADDR_ENTRY8: .long PMB_ADDR_BASE(8) -PMB_ADDR_ENTRY9: .long PMB_ADDR_BASE(9) -PMB_ADDR_ENTRY10: .long PMB_ADDR_BASE(10) -PMB_ADDR_ENTRY11: .long PMB_ADDR_BASE(11) -PMB_ADDR_ENTRY12: .long PMB_ADDR_BASE(12) -PMB_ADDR_ENTRY13: .long PMB_ADDR_BASE(13) -PMB_ADDR_ENTRY14: .long PMB_ADDR_BASE(14) -PMB_ADDR_ENTRY15: .long PMB_ADDR_BASE(15)
-PMB_ADDR_SPIBOOT_D: .long mk_pmb_addr_val(0xa0) -PMB_ADDR_DDR_C1_D: .long mk_pmb_addr_val(0x88) -PMB_ADDR_DDR_N1_D: .long mk_pmb_addr_val(0xa8) -PMB_ADDR_NOT_USE_D: .long 0x00000000
-PMB_DATA_SPIBOOT_A: .long PMB_DATA_BASE(0) -PMB_DATA_DDR_N1_A: .long PMB_DATA_BASE(1) -PMB_DATA_DDR_C1_A: .long PMB_DATA_BASE(5)
-/* ppn ub v s1 s0 c wt */ -PMB_DATA_SPIBOOT_D: .long mk_pmb_data_val(0x00, 0, 1, 1, 0, 0, 1) -PMB_DATA_DDR_C1_D: .long mk_pmb_data_val(0x48, 0, 1, 1, 0, 1, 1) -PMB_DATA_DDR_N1_D: .long mk_pmb_data_val(0x48, 1, 1, 1, 0, 0, 1)
-PASCR_A: .long 0xff000070 -DUMMY_ADDR: .long 0xa0000000 -PASCR_29BIT_D: .long 0x00000000 -PASCR_INIT: .long 0x80000080 -MMUCR_A: .long 0xff000010 -MMUCR_D: .long 0x00000004 /* clear ITLB */ -#endif /* CONFIG_SH_32BIT */
-CCR_A: .long CCR -CCR_D: .long CCR_CACHE_INIT diff --git a/board/renesas/sh7752evb/sh7752evb.c b/board/renesas/sh7752evb/sh7752evb.c deleted file mode 100644 index 5eedbf8..0000000 --- a/board/renesas/sh7752evb/sh7752evb.c +++ /dev/null @@ -1,314 +0,0 @@ -/*
-#include <common.h> -#include <malloc.h> -#include <asm/processor.h> -#include <asm/io.h> -#include <asm/mmc.h> -#include <spi_flash.h>
-int checkboard(void) -{
puts("BOARD: SH7752 evaluation board (R0P7752C00000RZ)\n");
-static void init_gpio(void) -{
/* GPIO */
-static void init_usb_phy(void) -{
-#if defined(__LITTLE_ENDIAN)
-#endif -}
-static void init_gether_mdio(void) -{
-static void set_mac_to_sh_giga_eth_register(int channel, char *mac_string) -{
unsigned long val;
if (!channel)
else
- This PMB must be set on this timing. The lowlevel_init is run on
- Area 0(phys 0x00000000), so we have to map it.
- The new PMB table is following:
- ent virt phys v sz c wt
- 0 0xa0000000 0x40000000 1 128M 0 1
- 1 0xa8000000 0x48000000 1 128M 0 1
- 2 0xb0000000 0x50000000 1 128M 0 1
- 3 0xb8000000 0x58000000 1 128M 0 1
- 4 0x80000000 0x40000000 1 128M 1 1
- 5 0x88000000 0x48000000 1 128M 1 1
- 6 0x90000000 0x50000000 1 128M 1 1
- 7 0x98000000 0x58000000 1 128M 1 1
-static void set_pmb_on_board_init(void) -{
/* clear ITLB */
-int board_init(void) -{
init_gpio();
init_usb_phy();
init_gether_mdio();
-int dram_init(void) -{
-int board_mmc_init(bd_t *bis) -{
udelay(1);
udelay(200);
-static int get_sh_eth_mac_raw(unsigned char *buf, int size) -{
int ret;
if (spi == NULL) {
return 1;
ret = spi_flash_read(spi, SH7752EVB_ETHERNET_MAC_BASE, size, buf);
if (ret) {
return 1;
-static int get_sh_eth_mac(int channel, char *mac_string, unsigned char *buf) -{
memcpy(mac_string, &buf[channel * (SH7752EVB_ETHERNET_MAC_SIZE + 1)],
SH7752EVB_ETHERNET_MAC_SIZE);
mac_string[SH7752EVB_ETHERNET_MAC_SIZE] = 0x00; /* terminate */
-static void init_ethernet_mac(void) -{
int i;
unsigned char *buf;
buf = malloc(256);
if (!buf) {
return;
for (i = 0; i < SH7752EVB_ETHERNET_NUM_CH; i++) {
if (i == 0)
else {
free(buf);
-int board_late_init(void) -{
-int do_write_mac(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{
int i, ret;
unsigned char *buf;
if (argc != 3) {
buf = malloc(256);
if (!buf) {
return 1;
free(buf);
/* new setting */
argv[1], argv[2]);
if (!spi) {
return 1;
ret = spi_flash_erase(spi, SH7752EVB_ETHERNET_MAC_BASE_SPI,
SH7752EVB_SPI_SECTOR_SIZE);
if (ret) {
return 1;
ret = spi_flash_write(spi, SH7752EVB_ETHERNET_MAC_BASE_SPI,
if (ret) {
return 1;
-U_BOOT_CMD(
-); diff --git a/board/renesas/sh7752evb/spi-boot.c b/board/renesas/sh7752evb/spi-boot.c deleted file mode 100644 index 91565d4..0000000 --- a/board/renesas/sh7752evb/spi-boot.c +++ /dev/null @@ -1,116 +0,0 @@ -/*
- This file is subject to the terms and conditions of the GNU Lesser
- General Public License. See the file "COPYING.LIB" in the main
- directory of this archive for more details.
-#define CONFIG_RAM_BOOT_PHYS CONFIG_SYS_TEXT_BASE -#define CONFIG_SPI_ADDR 0x00000000 -#define CONFIG_SPI_LENGTH CONFIG_SYS_MONITOR_LEN -#define CONFIG_RAM_BOOT CONFIG_SYS_TEXT_BASE
-#define SPIWDMADR 0xFE001018 -#define SPIWDMCNTR 0xFE001020 -#define SPIDMCOR 0xFE001028 -#define SPIDMINTSR 0xFE001188 -#define SPIDMINTMR 0xFE001190
-#define SPIDMINTSR_DMEND 0x00000004
-#define TBR 0xFE002000 -#define RBR 0xFE002000
-#define CR1 0xFE002008 -#define CR2 0xFE002010 -#define CR3 0xFE002018 -#define CR4 0xFE002020
-/* CR1 */ -#define SPI_TBE 0x80 -#define SPI_TBF 0x40 -#define SPI_RBE 0x20 -#define SPI_RBF 0x10 -#define SPI_PFONRD 0x08 -#define SPI_SSDB 0x04 -#define SPI_SSD 0x02 -#define SPI_SSA 0x01
-/* CR2 */ -#define SPI_RSTF 0x80 -#define SPI_LOOPBK 0x40 -#define SPI_CPOL 0x20 -#define SPI_CPHA 0x10 -#define SPI_L1M0 0x08
-/* CR4 */ -#define SPI_TBEI 0x80 -#define SPI_TBFI 0x40 -#define SPI_RBEI 0x20 -#define SPI_RBFI 0x10 -#define SPI_SpiS0 0x02 -#define SPI_SSS 0x01
-#define spi_write(val, addr) (*(volatile unsigned long *)(addr)) = val -#define spi_read(addr) (*(volatile unsigned long *)(addr))
-/* M25P80 */ -#define M25_READ 0x03
-#define __uses_spiboot2 __attribute__((section(".spiboot2.text"))) -static void __uses_spiboot2 spi_reset(void) -{
if (timeout-- < 0)
break;
-static void __uses_spiboot2 spi_read_flash(void *buf, unsigned long addr,
unsigned long len)
spi_write(0, CR1);
-void __uses_spiboot2 spiboot_main(void) -{
spi_reset();
CONFIG_SPI_LENGTH);
_start();
-} diff --git a/board/renesas/sh7752evb/u-boot.lds b/board/renesas/sh7752evb/u-boot.lds deleted file mode 100644 index 053df64..0000000 --- a/board/renesas/sh7752evb/u-boot.lds +++ /dev/null @@ -1,81 +0,0 @@ -/*
- Copyright (C) 2007
- Nobuhiro Iwamatsu iwamatsu@nigauri.org
- Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com
-OUTPUT_FORMAT("elf32-sh-linux", "elf32-sh-linux", "elf32-sh-linux") -OUTPUT_ARCH(sh) -ENTRY(_start)
-SECTIONS -{
.text :
*(.spiboot1.text)
*(.spiboot2.text)
. = ALIGN(8192);
. = ALIGN(8192);
. = ALIGN(8192);
*(.text)
. = ALIGN(4);
} =0xFF
.rodata :
. = ALIGN(4);
.data :
*(.data)
. = ALIGN(4);
.got :
*(.got)
. = ALIGN(4);
.u_boot_list : {
.bss (NOLOAD) :
*(.bss)
. = ALIGN(4);
- Copyright (C) 2013 Renesas Solutions Corp.
mov.l \addr, r1
mov.l \data, r0
mov.l @r1, r2
or r2, r0
mov.l r0, @r1
+.endm
+.macro wait_DBCMD
mov.l DBWAIT_A, r0
mov.l @r0, r1
+.endm
.align 2
+lowlevel_init:
mov #0, r14
mova 2f, r0
mov.l PC_MASK, r1
tst r0, r1
bf 2f
bra exit_pmb
nop
.align 2
+2:
mov #1, r14
mov.l EXPEVT_A, r0
mov.l @r0, r0
cmp/eq r0, r1
bt 1f
bra exit_ddr
nop
+1:
mov.l DBACEN_A, r0
mov.l @r0, r0
cmp/eq #0, r0
bt 3f
bra exit_ddr
nop
+3:
/* step 3 */
/* step 4 */
/* step 5 */
/* step 6 */
/* step 7 */
/* step 8 */
/* step 9 */
/* step 10 */
/* step 11 */
/* step 12 */
wait_DBCMD
/* step 13 */
wait_DBCMD
/* step 14 */
/* step 15 */
/* step 16 */
/* step 17 */
/* step 18 */
/* step 19 */
/* step 20 */
wait_DBCMD
/* step 21 */
/* step 22 */
/* step 23 */
/* step 24 */
/* step 25 */
/* step 26 */
wait_DBCMD
bra exit_ddr
nop
.align 2
.align 2
icbi @r0
+exit_pmb:
mov r14, r0
tst #1, r0
bt 1f
+100: bsrf r0
nop
.align 2
+1:
rts
nop
.align 2
/* GPIO */
+#endif +}
unsigned long val;
if (!channel)
else
/* clear ITLB */
init_gpio();
init_usb_phy();
init_gether_mdio();
udelay(1);
udelay(200);
int ret;
if (spi == NULL) {
return 1;
if (ret) {
return 1;
int i;
unsigned char *buf;
buf = malloc(256);
if (!buf) {
return;
if (i == 0)
else {
free(buf);
int i, ret;
unsigned char *buf;
if (argc != 3) {
buf = malloc(256);
if (!buf) {
return 1;
free(buf);
/* new setting */
argv[1], argv[2]);
if (!spi) {
return 1;
if (ret) {
return 1;
if (ret) {
return 1;
+U_BOOT_CMD(
if (timeout-- < 0)
break;
unsigned long len)
} else {
spi_write(0, CR1);
* lower 5-bits.
spi_reset();
_start();
+SECTIONS +{
.text :
*(.spiboot1.text)
*(.spiboot2.text)
. = ALIGN(8192);
. = ALIGN(8192);
. = ALIGN(8192);
*(.text)
. = ALIGN(4);
} =0xFF
.rodata :
. = ALIGN(4);
.data :
*(.data)
. = ALIGN(4);
.got :
*(.got)
. = ALIGN(4);
.u_boot_list : {
.bss (NOLOAD) :
*(.bss)
. = ALIGN(4);
- SH7752 (SH-4A)
- DDR3-SDRAM 512MB
- SPI ROM 8MB
- eMMC 4GB
- write_mac
-1. write_mac
For example)
- write_mac
For example)
=> write_mac
-Update SPI ROM:
- => sf probe 0
-3. Erase SPI ROM.
- SH7753 (SH-4A)
- DDR3-SDRAM 512MB
- SPI ROM 8MB
- eMMC 4GB
- write_mac
+1. write_mac
For example)
- write_mac
For example)
=> write_mac
- => sf probe 0
+3. Erase SPI ROM.
- Configuation settings for the sh7752evb board
480 * 1024 * 1024)
128 * 1024 * 1024)
- Configuation settings for the sh7753evb board
480 * 1024 * 1024)
128 * 1024 * 1024)
1.7.1
According to the the website of Renesas Japan, the production of SH7752 canceled. So, I submitted the patches. But, since maybe someone has the board, I should not remove the sh7752evb, I think.
So, I will submit new patches to support the sh7753evb again, but I will not remove the sh7752evb in the new patches.
Best regards, Yoshihiro Shimoda
unsigned int mmucr;
unsigned int mahr;
unsigned int malr;
unsigned char smr0;
unsigned char smr1;
unsigned char smr2;
unsigned char smr3;
unsigned char smr4;
unsigned char smr5;
unsigned char padr;
unsigned char pbdr;
unsigned char pcdr;
unsigned char pddr;
unsigned char pedr;
unsigned char pfdr;
unsigned char pgdr;
unsigned char phdr;
unsigned char pidr;
unsigned char pjdr;
unsigned char pkdr;
unsigned char pldr;
unsigned char pmdr;
unsigned char pndr;
unsigned char podr;
unsigned char ppdr;
unsigned char pqdr;
unsigned char prdr;
unsigned char psdr;
unsigned char ptdr;
unsigned char pudr;
unsigned char pvdr;
unsigned char pwdr;
unsigned char pxdr;
unsigned char pydr;
unsigned char pzdr;
unsigned int mmucr;
unsigned int mahr;
unsigned int malr;
unsigned char smr0;
unsigned char smr1;
unsigned char smr2;
unsigned char smr3;
unsigned char smr4;
unsigned char smr5;
unsigned char padr;
unsigned char pbdr;
unsigned char pcdr;
unsigned char pddr;
unsigned char pedr;
unsigned char pfdr;
unsigned char pgdr;
unsigned char phdr;
unsigned char pidr;
unsigned char pjdr;
unsigned char pkdr;
unsigned char pldr;
unsigned char pmdr;
unsigned char pndr;
unsigned char podr;
unsigned char ppdr;
unsigned char pqdr;
unsigned char prdr;
unsigned char psdr;
unsigned char ptdr;
unsigned char pudr;
unsigned char pvdr;
unsigned char pwdr;
unsigned char pxdr;
unsigned char pydr;
unsigned char pzdr;
mov.l \addr, r1
mov.l \data, r0
mov.l @r1, r2
or r2, r0
mov.l r0, @r1
-.endm
-.macro wait_DBCMD
mov.l DBWAIT_A, r0
mov.l @r0, r1
-.endm
.global lowlevel_init
.section .spiboot1.text
.align 2
-lowlevel_init:
bra exit_gpio
nop
.align 2
.align 2
-exit_gpio:
mov #0, r14
mova 2f, r0
mov.l PC_MASK, r1
tst r0, r1
bf 2f
bra exit_pmb
nop
.align 2
-2:
mov #1, r14
mov.l EXPEVT_A, r0
mov.l @r0, r0
mov.l EXPEVT_POWER_ON_RESET, r1
cmp/eq r0, r1
bt 1f
* If EXPEVT value is manual reset or tlb multipul-hit,
bra exit_ddr
nop
-1:
write32 MRSTCR0_A, MRSTCR0_D
write32 MRSTCR1_A, MRSTCR1_D
/* For Core Reset */
mov.l DBACEN_A, r0
mov.l @r0, r0
cmp/eq #0, r0
bt 3f
* If DBACEN == 1(DBSC was already enabled), we have to avoid the
* initialization of DDR3-SDRAM.
bra exit_ddr
nop
-3:
/* oscillation stabilization time */
wait_timer WAIT_OSC_TIME
/* step 3 */
write32 DBCMD_A, DBCMD_RSTL_VAL
wait_timer WAIT_30US
/* step 4 */
write32 DBCMD_A, DBCMD_PDEN_VAL
/* step 5 */
write32 DBKIND_A, DBKIND_D
/* step 6 */
write32 DBCONF_A, DBCONF_D
write32 DBTR0_A, DBTR0_D
write32 DBTR1_A, DBTR1_D
write32 DBTR2_A, DBTR2_D
write32 DBTR3_A, DBTR3_D
write32 DBTR4_A, DBTR4_D
write32 DBTR5_A, DBTR5_D
write32 DBTR6_A, DBTR6_D
write32 DBTR7_A, DBTR7_D
write32 DBTR8_A, DBTR8_D
write32 DBTR9_A, DBTR9_D
write32 DBTR10_A, DBTR10_D
write32 DBTR11_A, DBTR11_D
write32 DBTR12_A, DBTR12_D
write32 DBTR13_A, DBTR13_D
write32 DBTR14_A, DBTR14_D
write32 DBTR15_A, DBTR15_D
write32 DBTR16_A, DBTR16_D
write32 DBTR17_A, DBTR17_D
write32 DBTR18_A, DBTR18_D
write32 DBTR19_A, DBTR19_D
write32 DBRNK0_A, DBRNK0_D
/* step 7 */
write32 DBPDCNT3_A, DBPDCNT3_D
/* step 8 */
write32 DBPDCNT1_A, DBPDCNT1_D
write32 DBPDCNT2_A, DBPDCNT2_D
write32 DBPDLCK_A, DBPDLCK_D
write32 DBPDRGA_A, DBPDRGA_D
write32 DBPDRGD_A, DBPDRGD_D
/* step 9 */
/* step 10 */
write32 DBPDCNT0_A, DBPDCNT0_D
/* step 11 */
/* step 12 */
write32 DBCMD_A, DBCMD_WAIT_VAL
wait_DBCMD
/* step 13 */
write32 DBCMD_A, DBCMD_RSTH_VAL
wait_DBCMD
/* step 14 */
/* step 15 */
write32 DBCMD_A, DBCMD_PDXT_VAL
/* step 16 */
write32 DBCMD_A, DBCMD_MRS2_VAL
/* step 17 */
write32 DBCMD_A, DBCMD_MRS3_VAL
/* step 18 */
write32 DBCMD_A, DBCMD_MRS1_VAL
/* step 19 */
write32 DBCMD_A, DBCMD_MRS0_VAL
/* step 20 */
write32 DBCMD_A, DBCMD_ZQCL_VAL
write32 DBCMD_A, DBCMD_REF_VAL
wait_DBCMD
/* step 21 */
write32 DBADJ0_A, DBADJ0_D
write32 DBADJ2_A, DBADJ2_D
/* step 22 */
write32 DBRFCNF0_A, DBRFCNF0_D
write32 DBRFCNF1_A, DBRFCNF1_D
write32 DBRFCNF2_A, DBRFCNF2_D
/* step 23 */
write32 DBCALCNF_A, DBCALCNF_D
/* step 24 */
write32 DBRFEN_A, DBRFEN_D
write32 DBCMD_A, DBCMD_SRXT_VAL
/* step 25 */
write32 DBACEN_A, DBACEN_D
/* step 26 */
wait_DBCMD
bra exit_ddr
nop
.align 2
.align 2
icbi @r0
-exit_pmb:
mov r14, r0
tst #1, r0
bt 1f
-100: bsrf r0
nop
.align 2
-1:
rts
nop
.align 2
/* GPIO */
-#endif -}
unsigned long val;
if (!channel)
else
/* clear ITLB */
init_gpio();
init_usb_phy();
init_gether_mdio();
udelay(1);
udelay(200);
int ret;
if (spi == NULL) {
return 1;
if (ret) {
return 1;
int i;
unsigned char *buf;
buf = malloc(256);
if (!buf) {
return;
if (i == 0)
else {
free(buf);
int i, ret;
unsigned char *buf;
if (argc != 3) {
buf = malloc(256);
if (!buf) {
return 1;
free(buf);
/* new setting */
argv[1], argv[2]);
if (!spi) {
return 1;
if (ret) {
return 1;
if (ret) {
return 1;
-U_BOOT_CMD(
if (timeout-- < 0)
break;
unsigned long len)
spi_write(0, CR1);
spi_reset();
CONFIG_SPI_LENGTH);
_start();
-SECTIONS -{
.text :
*(.spiboot1.text)
*(.spiboot2.text)
. = ALIGN(8192);
. = ALIGN(8192);
. = ALIGN(8192);
*(.text)
. = ALIGN(4);
} =0xFF
.rodata :
. = ALIGN(4);
.data :
*(.data)
. = ALIGN(4);
.got :
*(.got)
. = ALIGN(4);
.u_boot_list : {
.bss (NOLOAD) :
*(.bss)
. = ALIGN(4);
-} diff --git a/board/renesas/sh7753evb/Makefile b/board/renesas/sh7753evb/Makefile new file mode 100644 index 0000000..f7c8e94 --- /dev/null +++ b/board/renesas/sh7753evb/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (C) 2012 Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com +# +# SPDX-License-Identifier: GPL-2.0+
+obj-y := sh7753evb.o spi-boot.o +obj-y += lowlevel_init.o diff --git a/board/renesas/sh7753evb/lowlevel_init.S b/board/renesas/sh7753evb/lowlevel_init.S new file mode 100644 index 0000000..21987a5 --- /dev/null +++ b/board/renesas/sh7753evb/lowlevel_init.S @@ -0,0 +1,416 @@ +/*
+#include <config.h> +#include <version.h> +#include <asm/processor.h> +#include <asm/macro.h>
+.macro or32, addr, data
mov.l \addr, r1
mov.l \data, r0
mov.l @r1, r2
or r2, r0
mov.l r0, @r1
+.endm
+.macro wait_DBCMD
mov.l DBWAIT_A, r0
mov.l @r0, r1
+.endm
.align 2
+lowlevel_init:
mov #0, r14
mova 2f, r0
mov.l PC_MASK, r1
tst r0, r1
bf 2f
bra exit_pmb
nop
.align 2
+/* If CPU runs on SDRAM (PC=0x5???????) or not. */ +PC_MASK: .long 0x20000000
+2:
mov #1, r14
mov.l EXPEVT_A, r0
mov.l @r0, r0
cmp/eq r0, r1
bt 1f
* initialization of DBSC3 is not necessary.
bra exit_ddr
nop
+1:
mov.l DBACEN_A, r0
mov.l @r0, r0
cmp/eq #0, r0
bt 3f
bra exit_ddr
nop
+3:
/*------- DBSC3 -------*/
/* step 3 */
/* step 4 */
/* step 5 */
/* step 6 */
/* step 7 */
/* step 8 */
/* step 9 */
/* step 10 */
/* step 11 */
/* step 12 */
wait_DBCMD
/* step 13 */
wait_DBCMD
/* step 14 */
/* step 15 */
/* step 16 */
/* step 17 */
/* step 18 */
/* step 19 */
write32 DBPDNCNF_A, DBPDNCNF_D
/* step 20 */
wait_DBCMD
/* step 21 */
write32 DBCALTR_A, DBCALTR_D
/* step 22 */
/* step 23 */
/* step 24 */
/* step 25 */
/* step 26 */
wait_DBCMD
bra exit_ddr
nop
.align 2
+EXPEVT_A: .long 0xff000024 +EXPEVT_POWER_ON_RESET: .long 0x00000000
+/*------- Reset -------*/ +MRSTCR0_A: .long 0xffd50030 +MRSTCR0_D: .long 0xfe1ffe7f +MRSTCR1_A: .long 0xffd50034 +MRSTCR1_D: .long 0xfff3ffff
+/*------- DBSC3 -------*/ +DBCMD_A: .long 0xfe800018 +DBKIND_A: .long 0xfe800020 +DBCONF_A: .long 0xfe800024 +DBTR0_A: .long 0xfe800040 +DBTR1_A: .long 0xfe800044 +DBTR2_A: .long 0xfe800048 +DBTR3_A: .long 0xfe800050 +DBTR4_A: .long 0xfe800054 +DBTR5_A: .long 0xfe800058 +DBTR6_A: .long 0xfe80005c +DBTR7_A: .long 0xfe800060 +DBTR8_A: .long 0xfe800064 +DBTR9_A: .long 0xfe800068 +DBTR10_A: .long 0xfe80006c +DBTR11_A: .long 0xfe800070 +DBTR12_A: .long 0xfe800074 +DBTR13_A: .long 0xfe800078 +DBTR14_A: .long 0xfe80007c +DBTR15_A: .long 0xfe800080 +DBTR16_A: .long 0xfe800084 +DBTR17_A: .long 0xfe800088 +DBTR18_A: .long 0xfe80008c +DBTR19_A: .long 0xfe800090 +DBRNK0_A: .long 0xfe800100 +DBPDCNT0_A: .long 0xfe800200 +DBPDCNT1_A: .long 0xfe800204 +DBPDCNT2_A: .long 0xfe800208 +DBPDCNT3_A: .long 0xfe80020c +DBPDLCK_A: .long 0xfe800280 +DBPDRGA_A: .long 0xfe800290 +DBPDRGD_A: .long 0xfe8002a0 +DBADJ0_A: .long 0xfe8000c0 +DBADJ2_A: .long 0xfe8000c8 +DBRFCNF0_A: .long 0xfe8000e0 +DBRFCNF1_A: .long 0xfe8000e4 +DBRFCNF2_A: .long 0xfe8000e8 +DBCALCNF_A: .long 0xfe8000f4 +DBRFEN_A: .long 0xfe800014 +DBACEN_A: .long 0xfe800010 +DBWAIT_A: .long 0xfe80001c +DBCALTR_A: .long 0xfe8000f8 +DBPDNCNF_A: .long 0xfe800180
+WAIT_OSC_TIME: .long 6000 +WAIT_30US: .long 13333
+DBCMD_RSTL_VAL: .long 0x20000000 +DBCMD_PDEN_VAL: .long 0x1000d73c +DBCMD_WAIT_VAL: .long 0x0000d73c +DBCMD_RSTH_VAL: .long 0x2100d73c +DBCMD_PDXT_VAL: .long 0x110000c8 +DBCMD_MRS0_VAL: .long 0x28000930 +DBCMD_MRS1_VAL: .long 0x29000004 +DBCMD_MRS2_VAL: .long 0x2a000008 +DBCMD_MRS3_VAL: .long 0x2b000000 +DBCMD_ZQCL_VAL: .long 0x03000200 +DBCMD_REF_VAL: .long 0x0c000000 +DBCMD_SRXT_VAL: .long 0x19000000 +DBKIND_D: .long 0x00000007 +DBCONF_D: .long 0x0f030a01 +DBTR0_D: .long 0x00000007 +DBTR1_D: .long 0x00000006 +DBTR2_D: .long 0x00000000 +DBTR3_D: .long 0x00000007 +DBTR4_D: .long 0x00070007 +DBTR5_D: .long 0x0000001b +DBTR6_D: .long 0x00000014 +DBTR7_D: .long 0x00000004 +DBTR8_D: .long 0x00000014 +DBTR9_D: .long 0x00000004 +DBTR10_D: .long 0x00000008 +DBTR11_D: .long 0x00000007 +DBTR12_D: .long 0x0000000e +DBTR13_D: .long 0x000000a0 +DBTR14_D: .long 0x00060006 +DBTR15_D: .long 0x00000003 +DBTR16_D: .long 0x00160002 +DBTR17_D: .long 0x000c0000 +DBTR18_D: .long 0x00000200 +DBTR19_D: .long 0x00000040 +DBRNK0_D: .long 0x00000001 +DBPDCNT0_D: .long 0x00000001 +DBPDCNT1_D: .long 0x00000001 +DBPDCNT2_D: .long 0x00000000 +DBPDCNT3_D: .long 0x00004010 +DBPDLCK_D: .long 0x0000a55a +DBPDRGA_D: .long 0x00000028 +DBPDRGD_D: .long 0x00017100
+DBADJ0_D: .long 0x00010000 +DBADJ2_D: .long 0x18061806 +DBRFCNF0_D: .long 0x000001ff +DBRFCNF1_D: .long 0x00081040 +DBRFCNF2_D: .long 0x00000000 +DBCALCNF_D: .long 0x0000ffff +DBRFEN_D: .long 0x00000001 +DBACEN_D: .long 0x00000001 +DBCALTR_D: .long 0x08200820 +DBPDNCNF_D: .long 0x00000001
.align 2
+exit_ddr: +#if defined(CONFIG_SH_32BIT)
write32 PASCR_A, PASCR_29BIT_D
write32 MMUCR_A, MMUCR_D
* 0 0xa0000000 0x00000000 1 128M 0 1
write32 PMB_ADDR_SPIBOOT_A, PMB_ADDR_SPIBOOT_D
write32 PMB_DATA_SPIBOOT_A, PMB_DATA_SPIBOOT_D
write32 PMB_ADDR_DDR_C1_A, PMB_ADDR_DDR_C1_D
write32 PMB_DATA_DDR_C1_A, PMB_DATA_DDR_C1_D
write32 PMB_ADDR_DDR_N1_A, PMB_ADDR_DDR_N1_D
write32 PMB_DATA_DDR_N1_A, PMB_DATA_DDR_N1_D
write32 PMB_ADDR_ENTRY2, PMB_ADDR_NOT_USE_D
write32 PMB_ADDR_ENTRY3, PMB_ADDR_NOT_USE_D
write32 PMB_ADDR_ENTRY4, PMB_ADDR_NOT_USE_D
write32 PMB_ADDR_ENTRY6, PMB_ADDR_NOT_USE_D
write32 PMB_ADDR_ENTRY7, PMB_ADDR_NOT_USE_D
write32 PMB_ADDR_ENTRY8, PMB_ADDR_NOT_USE_D
write32 PMB_ADDR_ENTRY9, PMB_ADDR_NOT_USE_D
write32 PMB_ADDR_ENTRY10, PMB_ADDR_NOT_USE_D
write32 PMB_ADDR_ENTRY11, PMB_ADDR_NOT_USE_D
write32 PMB_ADDR_ENTRY12, PMB_ADDR_NOT_USE_D
write32 PMB_ADDR_ENTRY13, PMB_ADDR_NOT_USE_D
write32 PMB_ADDR_ENTRY14, PMB_ADDR_NOT_USE_D
write32 PMB_ADDR_ENTRY15, PMB_ADDR_NOT_USE_D
write32 PASCR_A, PASCR_INIT
mov.l DUMMY_ADDR, r0
icbi @r0
+#endif /* if defined(CONFIG_SH_32BIT) */
+exit_pmb:
/* CPU is running on ILRAM? */
mov r14, r0
tst #1, r0
bt 1f
mov.l _stack_ilram, r15
mov.l _spiboot_main, r0
+100: bsrf r0
nop
.align 2
+_spiboot_main: .long (spiboot_main - (100b + 4)) +_stack_ilram: .long 0xe5204000
+1:
write32 CCR_A, CCR_D
rts
nop
.align 2
+#if defined(CONFIG_SH_32BIT) +/*------- set PMB -------*/ +PMB_ADDR_SPIBOOT_A: .long PMB_ADDR_BASE(0) +PMB_ADDR_DDR_N1_A: .long PMB_ADDR_BASE(1) +PMB_ADDR_DDR_C1_A: .long PMB_ADDR_BASE(5) +PMB_ADDR_ENTRY2: .long PMB_ADDR_BASE(2) +PMB_ADDR_ENTRY3: .long PMB_ADDR_BASE(3) +PMB_ADDR_ENTRY4: .long PMB_ADDR_BASE(4) +PMB_ADDR_ENTRY6: .long PMB_ADDR_BASE(6) +PMB_ADDR_ENTRY7: .long PMB_ADDR_BASE(7) +PMB_ADDR_ENTRY8: .long PMB_ADDR_BASE(8) +PMB_ADDR_ENTRY9: .long PMB_ADDR_BASE(9) +PMB_ADDR_ENTRY10: .long PMB_ADDR_BASE(10) +PMB_ADDR_ENTRY11: .long PMB_ADDR_BASE(11) +PMB_ADDR_ENTRY12: .long PMB_ADDR_BASE(12) +PMB_ADDR_ENTRY13: .long PMB_ADDR_BASE(13) +PMB_ADDR_ENTRY14: .long PMB_ADDR_BASE(14) +PMB_ADDR_ENTRY15: .long PMB_ADDR_BASE(15)
+PMB_ADDR_SPIBOOT_D: .long mk_pmb_addr_val(0xa0) +PMB_ADDR_DDR_C1_D: .long mk_pmb_addr_val(0x88) +PMB_ADDR_DDR_N1_D: .long mk_pmb_addr_val(0xa8) +PMB_ADDR_NOT_USE_D: .long 0x00000000
+PMB_DATA_SPIBOOT_A: .long PMB_DATA_BASE(0) +PMB_DATA_DDR_N1_A: .long PMB_DATA_BASE(1) +PMB_DATA_DDR_C1_A: .long PMB_DATA_BASE(5)
+/* ppn ub v s1 s0 c wt */ +PMB_DATA_SPIBOOT_D: .long mk_pmb_data_val(0x00, 0, 1, 1, 0, 0, 1) +PMB_DATA_DDR_C1_D: .long mk_pmb_data_val(0x48, 0, 1, 1, 0, 1, 1) +PMB_DATA_DDR_N1_D: .long mk_pmb_data_val(0x48, 1, 1, 1, 0, 0, 1)
+PASCR_A: .long 0xff000070 +DUMMY_ADDR: .long 0xa0000000 +PASCR_29BIT_D: .long 0x00000000 +PASCR_INIT: .long 0x80000080 +MMUCR_A: .long 0xff000010 +MMUCR_D: .long 0x00000004 /* clear ITLB */ +#endif /* CONFIG_SH_32BIT */
+CCR_A: .long CCR +CCR_D: .long CCR_CACHE_INIT diff --git a/board/renesas/sh7753evb/sh7753evb.c b/board/renesas/sh7753evb/sh7753evb.c new file mode 100644 index 0000000..42b920f --- /dev/null +++ b/board/renesas/sh7753evb/sh7753evb.c @@ -0,0 +1,326 @@ +/*
+#include <common.h> +#include <malloc.h> +#include <asm/processor.h> +#include <asm/io.h> +#include <asm/mmc.h> +#include <spi_flash.h>
+int checkboard(void) +{
puts("BOARD: SH7753 EVB\n");
+static void init_gpio(void) +{
struct sermux_regs *sermux = SERMUX_BASE;
/* GPIO */
writew(0x0000, &gpio->pacr); /* GETHER */
writew(0x0001, &gpio->pbcr); /* INTC */
writew(0x0000, &gpio->pccr); /* PWMU, INTC */
writew(0x0000, &gpio->pdcr); /* SPI0 */
writew(0xeaff, &gpio->pecr); /* GPIO */
writew(0x0000, &gpio->pfcr); /* WDT */
writew(0x0004, &gpio->pgcr); /* SPI0, GETHER MDIO gate(PTG1) */
writew(0x0000, &gpio->phcr); /* SPI1 */
writew(0x0000, &gpio->picr); /* SDHI */
writew(0x0000, &gpio->pjcr); /* SCIF4 */
writew(0x0003, &gpio->pkcr); /* SerMux */
writew(0x0000, &gpio->plcr); /* SerMux */
writew(0x0000, &gpio->pmcr); /* RIIC */
writew(0x0000, &gpio->pncr); /* USB, SGPIO */
writew(0x0000, &gpio->pocr); /* SGPIO */
writew(0xd555, &gpio->pqcr); /* GPIO */
writew(0x0000, &gpio->prcr); /* RIIC */
writew(0x0000, &gpio->pscr); /* RIIC */
writew(0x0000, &gpio->ptcr); /* STATUS */
writeb(0x00, &gpio->pudr);
writew(0x5555, &gpio->pucr); /* Debug LED */
writew(0x0000, &gpio->pvcr); /* RSPI */
writew(0x0000, &gpio->pwcr); /* EVC */
writew(0x0000, &gpio->pxcr); /* LBSC */
writew(0x0000, &gpio->pycr); /* LBSC */
writew(0x0000, &gpio->pzcr); /* eMMC */
writew(0xfe00, &gpio->psel0);
writew(0x0000, &gpio->psel1);
writew(0x3000, &gpio->psel2);
writew(0xff00, &gpio->psel3);
writew(0x771f, &gpio->psel4);
writew(0x0ffc, &gpio->psel5);
writew(0x00ff, &gpio->psel6);
writew(0xfc00, &gpio->psel7);
writeb(0x10, &sermux->smr0); /* SMR0: SerMux mode 0 */
+static void init_usb_phy(void) +{
struct usb_common_regs *common0 = USB0_COMMON_BASE;
struct usb_common_regs *common1 = USB1_COMMON_BASE;
struct usb0_phy_regs *phy = USB0_PHY_BASE;
struct usb1_port_regs *port = USB1_PORT_BASE;
struct usb1_alignment_regs *align = USB1_ALIGNMENT_BASE;
writew(0x0100, &phy->reset); /* set reset */
/* port0 = USB0, port1 = USB1 */
writew(0x0002, &phy->portsel);
writel(0x0001, &port->port1sel); /* port1 = Host */
writew(0x0111, &phy->reset); /* clear reset */
writew(0x4000, &common0->suspmode);
writew(0x4000, &common1->suspmode);
+#if defined(__LITTLE_ENDIAN)
writel(0x00000000, &align->ehcidatac);
writel(0x00000000, &align->ohcidatac);
+#endif +}
+static void init_gether_mdio(void) +{
struct gpio_regs *gpio = GPIO_BASE;
writew(readw(&gpio->pgcr) | 0x0004, &gpio->pgcr);
writeb(readb(&gpio->pgdr) | 0x02, &gpio->pgdr); /* Use ET0-MDIO */
+static void set_mac_to_sh_giga_eth_register(int channel, char *mac_string) +{
struct ether_mac_regs *ether;
unsigned char mac[6];
unsigned long val;
eth_parse_enetaddr(mac_string, mac);
if (!channel)
ether = GETHER0_MAC_BASE;
else
ether = GETHER1_MAC_BASE;
val = (mac[0] << 24) | (mac[1] << 16) | (mac[2] << 8) | mac[3];
writel(val, ðer->mahr);
val = (mac[4] << 8) | mac[5];
writel(val, ðer->malr);
+static void set_pmb_on_board_init(void) +{
struct mmu_regs *mmu = MMU_BASE;
/* clear ITLB */
writel(0x00000004, &mmu->mmucr);
/* delete PMB for SPIBOOT */
writel(0, PMB_ADDR_BASE(0));
writel(0, PMB_DATA_BASE(0));
/* add PMB for SDRAM(0x40000000 - 0x47ffffff) */
writel(mk_pmb_addr_val(0xa0), PMB_ADDR_BASE(0));
writel(mk_pmb_data_val(0x40, 1, 1, 1, 0, 0, 1), PMB_DATA_BASE(0));
writel(mk_pmb_addr_val(0xb0), PMB_ADDR_BASE(2));
writel(mk_pmb_data_val(0x50, 1, 1, 1, 0, 0, 1), PMB_DATA_BASE(2));
writel(mk_pmb_addr_val(0xb8), PMB_ADDR_BASE(3));
writel(mk_pmb_data_val(0x58, 1, 1, 1, 0, 0, 1), PMB_DATA_BASE(3));
writel(mk_pmb_addr_val(0x80), PMB_ADDR_BASE(4));
writel(mk_pmb_data_val(0x40, 0, 1, 1, 0, 1, 1), PMB_DATA_BASE(4));
writel(mk_pmb_addr_val(0x90), PMB_ADDR_BASE(6));
writel(mk_pmb_data_val(0x50, 0, 1, 1, 0, 1, 1), PMB_DATA_BASE(6));
writel(mk_pmb_addr_val(0x98), PMB_ADDR_BASE(7));
writel(mk_pmb_data_val(0x58, 0, 1, 1, 0, 1, 1), PMB_DATA_BASE(7));
+int board_init(void) +{
struct gether_control_regs *gether = GETHER_CONTROL_BASE;
init_gpio();
set_pmb_on_board_init();
/* Sets TXnDLY to B'010 */
writel(0x00000202, &gether->gbecont);
init_usb_phy();
init_gether_mdio();
+int dram_init(void) +{
DECLARE_GLOBAL_DATA_PTR;
gd->bd->bi_memstart = CONFIG_SYS_SDRAM_BASE;
gd->bd->bi_memsize = CONFIG_SYS_SDRAM_SIZE;
printf("DRAM: %dMB\n", CONFIG_SYS_SDRAM_SIZE / (1024 * 1024));
+int board_mmc_init(bd_t *bis) +{
writew(readw(&gpio->pgcr) | 0x0040, &gpio->pgcr);
writeb(readb(&gpio->pgdr) & ~0x08, &gpio->pgdr); /* Reset */
udelay(1);
writeb(readb(&gpio->pgdr) | 0x08, &gpio->pgdr); /* Release reset */
udelay(200);
return mmcif_mmc_init();
+static int get_sh_eth_mac_raw(unsigned char *buf, int size) +{
struct spi_flash *spi;
int ret;
spi = spi_flash_probe(0, 0, 1000000, SPI_MODE_3);
if (spi == NULL) {
printf("%s: spi_flash probe failed.\n", __func__);
return 1;
ret = spi_flash_read(spi, SH7753EVB_ETHERNET_MAC_BASE, size, buf);
if (ret) {
printf("%s: spi_flash read failed.\n", __func__);
spi_flash_free(spi);
return 1;
+static int get_sh_eth_mac(int channel, char *mac_string, unsigned char *buf) +{
memcpy(mac_string, &buf[channel * (SH7753EVB_ETHERNET_MAC_SIZE + 1)],
SH7753EVB_ETHERNET_MAC_SIZE);
mac_string[SH7753EVB_ETHERNET_MAC_SIZE] = 0x00; /* terminate */
+static void init_ethernet_mac(void) +{
char mac_string[64];
char env_string[64];
int i;
unsigned char *buf;
buf = malloc(256);
if (!buf) {
printf("%s: malloc failed.\n", __func__);
return;
get_sh_eth_mac_raw(buf, 256);
/* Gigabit Ethernet */
for (i = 0; i < SH7753EVB_ETHERNET_NUM_CH; i++) {
get_sh_eth_mac(i, mac_string, buf);
if (i == 0)
setenv("ethaddr", mac_string);
else {
sprintf(env_string, "eth%daddr", i);
setenv(env_string, mac_string);
set_mac_to_sh_giga_eth_register(i, mac_string);
free(buf);
+int board_late_init(void) +{
init_ethernet_mac();
+int do_write_mac(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{
int i, ret;
char mac_string[256];
unsigned char *buf;
if (argc != 3) {
buf = malloc(256);
if (!buf) {
return 1;
/* print current MAC address */
printf("GETHERC ch%d = %s\n", i, mac_string);
free(buf);
/* new setting */
memset(mac_string, 0xff, sizeof(mac_string));
sprintf(mac_string, "%s\t%s",
argv[1], argv[2]);
/* write MAC data to SPI rom */
if (!spi) {
return 1;
ret = spi_flash_erase(spi, SH7753EVB_ETHERNET_MAC_BASE_SPI,
SH7753EVB_SPI_SECTOR_SIZE);
if (ret) {
printf("%s: spi_flash erase failed.\n", __func__);
return 1;
ret = spi_flash_write(spi, SH7753EVB_ETHERNET_MAC_BASE_SPI,
sizeof(mac_string), mac_string);
if (ret) {
printf("%s: spi_flash write failed.\n", __func__);
return 1;
puts("The writing of the MAC address to SPI ROM was completed.\n");
+U_BOOT_CMD(
write_mac, 3, 1, do_write_mac,
"write MAC address for GETHERC",
"[GETHERC ch0] [GETHERC ch1]\n"
+); diff --git a/board/renesas/sh7753evb/spi-boot.c b/board/renesas/sh7753evb/spi-boot.c new file mode 100644 index 0000000..21903d9 --- /dev/null +++ b/board/renesas/sh7753evb/spi-boot.c @@ -0,0 +1,134 @@ +/*
+#define CONFIG_SPI_ADDR 0x00000000 +#define PHYADDR(_addr) ((_addr & 0x1fffffff) | 0x40000000) +#define CONFIG_RAM_BOOT_PHYS PHYADDR(CONFIG_SYS_TEXT_BASE)
+#define SPIWDMADR 0xFE001018 +#define SPIWDMCNTR 0xFE001020 +#define SPIDMCOR 0xFE001028 +#define SPIDMINTSR 0xFE001188 +#define SPIDMINTMR 0xFE001190
+#define SPIDMINTSR_DMEND 0x00000004
+#define TBR 0xFE002000 +#define RBR 0xFE002000
+#define CR1 0xFE002008 +#define CR2 0xFE002010 +#define CR3 0xFE002018 +#define CR4 0xFE002020 +#define CR7 0xFE002038 +#define CR8 0xFE002040
+/* CR1 */ +#define SPI_TBE 0x80 +#define SPI_TBF 0x40 +#define SPI_RBE 0x20 +#define SPI_RBF 0x10 +#define SPI_PFONRD 0x08 +#define SPI_SSDB 0x04 +#define SPI_SSD 0x02 +#define SPI_SSA 0x01
+/* CR2 */ +#define SPI_RSTF 0x80 +#define SPI_LOOPBK 0x40 +#define SPI_CPOL 0x20 +#define SPI_CPHA 0x10 +#define SPI_L1M0 0x08
+/* CR4 */ +#define SPI_TBEI 0x80 +#define SPI_TBFI 0x40 +#define SPI_RBEI 0x20 +#define SPI_RBFI 0x10 +#define SPI_SpiS0 0x02 +#define SPI_SSS 0x01
+/* CR7 */ +#define CR7_IDX_OR12 0x12 +#define OR12_ADDR32 0x00000001
+#define spi_write(val, addr) (*(volatile unsigned long *)(addr)) = val +#define spi_read(addr) (*(volatile unsigned long *)(addr))
+/* M25P80 */ +#define M25_READ 0x03 +#define M25_READ_4BYTE 0x13
+extern void bss_start(void);
+#define __uses_spiboot2 __attribute__((section(".spiboot2.text"))) +static void __uses_spiboot2 spi_reset(void) +{
int timeout = 0x00100000;
/* Make sure the last transaction is finalized */
spi_write(0x00, CR3);
spi_write(0x02, CR1);
while (!(spi_read(CR4) & SPI_SpiS0)) {
if (timeout-- < 0)
break;
spi_write(0x00, CR1);
spi_write(spi_read(CR2) | SPI_RSTF, CR2); /* fifo reset */
spi_write(spi_read(CR2) & ~SPI_RSTF, CR2);
spi_write(0, SPIDMCOR);
+static void __uses_spiboot2 spi_read_flash(void *buf, unsigned long addr,
unsigned long len)
spi_write(CR7_IDX_OR12, CR7);
if (spi_read(CR8) & OR12_ADDR32) {
/* 4-bytes address mode */
spi_write(M25_READ_4BYTE, TBR);
spi_write((addr >> 24) & 0xFF, TBR); /* ADDR31-24 */
} else {
/* 3-bytes address mode */
spi_write(M25_READ, TBR);
spi_write((addr >> 16) & 0xFF, TBR); /* ADDR23-16 */
spi_write((addr >> 8) & 0xFF, TBR); /* ADDR15-8 */
spi_write(addr & 0xFF, TBR); /* ADDR7-0 */
spi_write(SPIDMINTSR_DMEND, SPIDMINTSR);
spi_write((unsigned long)buf, SPIWDMADR);
spi_write(len & 0xFFFFFFE0, SPIWDMCNTR);
spi_write(1, SPIDMCOR);
spi_write(0xff, CR3);
spi_write(spi_read(CR1) | SPI_SSDB, CR1);
spi_write(spi_read(CR1) | SPI_SSA, CR1);
while (!(spi_read(SPIDMINTSR) & SPIDMINTSR_DMEND))
/* Nagate SP0-SS0 */
spi_write(0, CR1);
+void __uses_spiboot2 spiboot_main(void) +{
* This code rounds len up for SPIWDMCNTR. We should set it to 0 in
* lower 5-bits.
void (*_start)(void) = (void *)CONFIG_SYS_TEXT_BASE;
volatile unsigned long len = (bss_start - _start + 31) & 0xffffffe0;
spi_reset();
spi_read_flash((void *)CONFIG_RAM_BOOT_PHYS, CONFIG_SPI_ADDR, len);
_start();
+} diff --git a/board/renesas/sh7753evb/u-boot.lds b/board/renesas/sh7753evb/u-boot.lds new file mode 100644 index 0000000..053df64 --- /dev/null +++ b/board/renesas/sh7753evb/u-boot.lds @@ -0,0 +1,81 @@ +/*
+OUTPUT_FORMAT("elf32-sh-linux", "elf32-sh-linux", "elf32-sh-linux") +OUTPUT_ARCH(sh) +ENTRY(_start)
+SECTIONS +{
* entry and reloct_dst will be provided via ldflags
PROVIDE (_ftext = .);
PROVIDE (_fcode = .);
PROVIDE (_start = .);
.text :
KEEP(arch/sh/cpu/sh4/start.o (.text))
*(.spiboot1.text)
*(.spiboot2.text)
. = ALIGN(8192);
common/env_embedded.o (.ppcenv)
. = ALIGN(8192);
common/env_embedded.o (.ppcenvr)
. = ALIGN(8192);
*(.text)
. = ALIGN(4);
} =0xFF
PROVIDE (_ecode = .);
.rodata :
*(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*)))
. = ALIGN(4);
PROVIDE (_etext = .);
PROVIDE (_fdata = .);
.data :
*(.data)
. = ALIGN(4);
PROVIDE (_edata = .);
PROVIDE (_fgot = .);
.got :
*(.got)
. = ALIGN(4);
PROVIDE (_egot = .);
.u_boot_list : {
KEEP(*(SORT(.u_boot_list*)));
PROVIDE (reloc_dst_end = .);
/* _reloc_dst_end = .; */
PROVIDE (bss_start = .);
PROVIDE (__bss_start = .);
.bss (NOLOAD) :
*(.bss)
. = ALIGN(4);
PROVIDE (bss_end = .);
PROVIDE (__bss_end = .);
+} diff --git a/boards.cfg b/boards.cfg index 2128996..6a26cad 100644 --- a/boards.cfg +++ b/boards.cfg @@ -1208,7 +1208,7 @@ Active sh sh4 - renesas MigoR Active sh sh4 - renesas r0p7734 r0p7734 - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org Active sh sh4 - renesas r2dplus r2dplus - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org Active sh sh4 - renesas r7780mp r7780mp - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org -Active sh sh4 - renesas sh7752evb sh7752evb - - +Active sh sh4 - renesas sh7753evb sh7753evb - - Active sh sh4 - renesas sh7757lcr sh7757lcr - - Active sh sh4 - renesas sh7763rdp sh7763rdp - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org Active sh sh4 - renesas sh7785lcr sh7785lcr - - diff --git a/doc/README.sh7752evb b/doc/README.sh7752evb deleted file mode 100644 index c1fb54c..0000000 --- a/doc/README.sh7752evb +++ /dev/null @@ -1,67 +0,0 @@ -========================================
-Renesas R0P7752C00000RZ board
-This board specification:
-The R0P7752C00000RZ(board config name:sh7752evb) has the following device:
- SH7752 (SH-4A)
- DDR3-SDRAM 512MB
- SPI ROM 8MB
- Gigabit Ethernet controllers
- eMMC 4GB
-Configuration for This board:
-You can select the configuration as follows:
- make sh7752evb_config
-This board specific command:
-This board has the following its specific command:
- write_mac
-1. write_mac
-You can write MAC address to SPI ROM.
- Usage 1) Write MAC address
- write_mac [GETHERC ch0] [GETHERC ch1]
For example)
=> write_mac 74:90:50:00:33:9e 74:90:50:00:33:9f
*) We have to input the command as a single line
(without carriage return)
*) We have to reset after input the command.
- Usage 2) Show current data
- write_mac
For example)
=> write_mac
GETHERC ch0 = 74:90:50:00:33:9e
GETHERC ch1 = 74:90:50:00:33:9f
-Update SPI ROM:
-1. Copy u-boot image to RAM area. -2. Probe SPI device.
- => sf probe 0
- SF: Detected MX25L6405D with page size 64KiB, total 8 MiB
-3. Erase SPI ROM.
- => sf erase 0 80000
-4. Write u-boot image to SPI ROM.
- => sf write 0x48000000 0 80000
diff --git a/doc/README.sh7753evb b/doc/README.sh7753evb new file mode 100644 index 0000000..5fe178c --- /dev/null +++ b/doc/README.sh7753evb @@ -0,0 +1,67 @@ +======================================== +Renesas SH7753 EVB board +========================================
+This board specification: +=========================
+The SH7753 EVB (board config name:sh7753evb) has the following device:
- SH7753 (SH-4A)
- DDR3-SDRAM 512MB
- SPI ROM 8MB
- eMMC 4GB
+Configuration for This board: +=============================
+You can select the configuration as follows:
- make sh7753evb_config
+This board specific command: +============================
+This board has the following its specific command:
- write_mac
+1. write_mac
+You can write MAC address to SPI ROM.
For example)
- write_mac
For example)
=> write_mac
+Update SPI ROM: +============================
+1. Copy u-boot image to RAM area. +2. Probe SPI device.
- => sf probe 0
+3. Erase SPI ROM.
+4. Write u-boot image to SPI ROM.
diff --git a/include/configs/sh7752evb.h b/include/configs/sh7752evb.h deleted file mode 100644 index ebdc5c8..0000000 --- a/include/configs/sh7752evb.h +++ /dev/null @@ -1,137 +0,0 @@ -/*
-#ifndef __SH7752EVB_H -#define __SH7752EVB_H
-#undef DEBUG -#define CONFIG_SH 1 -#define CONFIG_SH4A 1 -#define CONFIG_SH_32BIT 1 -#define CONFIG_CPU_SH7752 1 -#define CONFIG_SH7752EVB 1
-#define CONFIG_SYS_TEXT_BASE 0x5ff80000 -#define CONFIG_SYS_LDSCRIPT "board/renesas/sh7752evb/u-boot.lds"
-#define CONFIG_CMD_MEMORY -#define CONFIG_CMD_NET -#define CONFIG_CMD_MII -#define CONFIG_CMD_PING -#define CONFIG_CMD_NFS -#define CONFIG_CMD_DFL -#define CONFIG_CMD_SDRAM -#define CONFIG_CMD_SF -#define CONFIG_CMD_RUN -#define CONFIG_CMD_SAVEENV -#define CONFIG_CMD_MD5SUM -#define CONFIG_MD5 -#define CONFIG_CMD_LOADS -#define CONFIG_CMD_MMC -#define CONFIG_CMD_EXT2 -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION
-#define CONFIG_BAUDRATE 115200 -#define CONFIG_BOOTDELAY 3 -#define CONFIG_BOOTARGS "console=ttySC2,115200 root=/dev/nfs ip=dhcp"
-#define CONFIG_VERSION_VARIABLE -#undef CONFIG_SHOW_BOOT_PROGRESS -#define CONFIG_CMDLINE_EDITING -#define CONFIG_AUTO_COMPLETE
-/* MEMORY */ -#define SH7752EVB_SDRAM_BASE (0x40000000) -#define SH7752EVB_SDRAM_SIZE (512 * 1024 * 1024)
-#define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_CBSIZE 256 -#define CONFIG_SYS_PBSIZE 256 -#define CONFIG_SYS_MAXARGS 16 -#define CONFIG_SYS_BARGSIZE 512 -#define CONFIG_SYS_BAUDRATE_TABLE { 115200 }
-/* SCIF */ -#define CONFIG_SCIF_CONSOLE 1 -#define CONFIG_CONS_SCIF2 1 -#undef CONFIG_SYS_CONSOLE_INFO_QUIET -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
-#define CONFIG_SYS_MEMTEST_START (SH7752EVB_SDRAM_BASE) -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \
480 * 1024 * 1024)
-#undef CONFIG_SYS_ALT_MEMTEST -#undef CONFIG_SYS_MEMTEST_SCRATCH -#undef CONFIG_SYS_LOADS_BAUD_CHANGE
-#define CONFIG_SYS_SDRAM_BASE (SH7752EVB_SDRAM_BASE) -#define CONFIG_SYS_SDRAM_SIZE (SH7752EVB_SDRAM_SIZE) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + \
128 * 1024 * 1024)
-#define CONFIG_SYS_MONITOR_BASE 0x00000000 -#define CONFIG_SYS_MONITOR_LEN (512 * 1024) -#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) -#define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
-/* FLASH */ -#define CONFIG_SYS_NO_FLASH
-/* Ether */ -#define CONFIG_SH_ETHER 1 -#define CONFIG_SH_ETHER_USE_PORT 0 -#define CONFIG_SH_ETHER_PHY_ADDR 18 -#define CONFIG_SH_ETHER_CACHE_WRITEBACK 1 -#define CONFIG_SH_ETHER_USE_GETHER 1 -#define CONFIG_PHYLIB -#define CONFIG_BITBANGMII -#define CONFIG_BITBANGMII_MULTI -#define CONFIG_SH_ETHER_PHY_MODE PHY_INTERFACE_MODE_RGMII -#define CONFIG_PHY_VITESSE
-#define SH7752EVB_ETHERNET_MAC_BASE_SPI 0x00090000 -#define SH7752EVB_SPI_SECTOR_SIZE (64 * 1024) -#define SH7752EVB_ETHERNET_MAC_BASE SH7752EVB_ETHERNET_MAC_BASE_SPI -#define SH7752EVB_ETHERNET_MAC_SIZE 17 -#define SH7752EVB_ETHERNET_NUM_CH 2 -#define CONFIG_BOARD_LATE_INIT
-/* SPI */ -#define CONFIG_SH_SPI 1 -#define CONFIG_SH_SPI_BASE 0xfe002000 -#define CONFIG_SPI_FLASH -#define CONFIG_SPI_FLASH_STMICRO 1 -#define CONFIG_SPI_FLASH_MACRONIX 1
-/* MMCIF */ -#define CONFIG_MMC 1 -#define CONFIG_GENERIC_MMC 1 -#define CONFIG_SH_MMCIF 1 -#define CONFIG_SH_MMCIF_ADDR 0xffcb0000 -#define CONFIG_SH_MMCIF_CLK 48000000
-/* ENV setting */ -#define CONFIG_ENV_IS_EMBEDDED -#define CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_SECT_SIZE (64 * 1024) -#define CONFIG_ENV_ADDR (0x00080000) -#define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) -#define CONFIG_ENV_OVERWRITE 1 -#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SECT_SIZE) -#define CONFIG_EXTRA_ENV_SETTINGS \
-/* Board Clock */ -#define CONFIG_SYS_CLK_FREQ 48000000 -#define CONFIG_SH_TMU_CLK_FREQ CONFIG_SYS_CLK_FREQ -#define CONFIG_SH_SCIF_CLK_FREQ CONFIG_SYS_CLK_FREQ -#define CONFIG_SYS_TMU_CLK_DIV 4 -#endif /* __SH7752EVB_H */ diff --git a/include/configs/sh7753evb.h b/include/configs/sh7753evb.h new file mode 100644 index 0000000..f7eb86d --- /dev/null +++ b/include/configs/sh7753evb.h @@ -0,0 +1,137 @@ +/*
+#ifndef __SH7753EVB_H +#define __SH7753EVB_H
+#undef DEBUG +#define CONFIG_SH 1 +#define CONFIG_SH4A 1 +#define CONFIG_SH_32BIT 1 +#define CONFIG_CPU_SH7753 1 +#define CONFIG_SH7753EVB 1
+#define CONFIG_SYS_TEXT_BASE 0x5ff80000 +#define CONFIG_SYS_LDSCRIPT "board/renesas/sh7753evb/u-boot.lds"
+#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_NET +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_NFS +#define CONFIG_CMD_DFL +#define CONFIG_CMD_SDRAM +#define CONFIG_CMD_SF +#define CONFIG_CMD_RUN +#define CONFIG_CMD_SAVEENV +#define CONFIG_CMD_MD5SUM +#define CONFIG_MD5 +#define CONFIG_CMD_LOADS +#define CONFIG_CMD_MMC +#define CONFIG_CMD_EXT2 +#define CONFIG_DOS_PARTITION +#define CONFIG_MAC_PARTITION
+#define CONFIG_BAUDRATE 115200 +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTARGS "console=ttySC2,115200 root=/dev/nfs ip=dhcp"
+#define CONFIG_VERSION_VARIABLE +#undef CONFIG_SHOW_BOOT_PROGRESS +#define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE
+/* MEMORY */ +#define SH7753EVB_SDRAM_BASE (0x40000000) +#define SH7753EVB_SDRAM_SIZE (512 * 1024 * 1024)
+#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE 512 +#define CONFIG_SYS_BAUDRATE_TABLE { 115200 }
+/* SCIF */ +#define CONFIG_SCIF_CONSOLE 1 +#define CONFIG_CONS_SCIF2 1 +#undef CONFIG_SYS_CONSOLE_INFO_QUIET +#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE +#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
+#define CONFIG_SYS_MEMTEST_START (SH7753EVB_SDRAM_BASE) +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \
480 * 1024 * 1024)
+#undef CONFIG_SYS_ALT_MEMTEST +#undef CONFIG_SYS_MEMTEST_SCRATCH +#undef CONFIG_SYS_LOADS_BAUD_CHANGE
+#define CONFIG_SYS_SDRAM_BASE (SH7753EVB_SDRAM_BASE) +#define CONFIG_SYS_SDRAM_SIZE (SH7753EVB_SDRAM_SIZE) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + \
128 * 1024 * 1024)
+#define CONFIG_SYS_MONITOR_BASE 0x00000000 +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) +#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) +#define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
+/* FLASH */ +#define CONFIG_SYS_NO_FLASH
+/* Ether */ +#define CONFIG_SH_ETHER 1 +#define CONFIG_SH_ETHER_USE_PORT 0 +#define CONFIG_SH_ETHER_PHY_ADDR 18 +#define CONFIG_SH_ETHER_CACHE_WRITEBACK 1 +#define CONFIG_SH_ETHER_USE_GETHER 1 +#define CONFIG_PHYLIB +#define CONFIG_BITBANGMII +#define CONFIG_BITBANGMII_MULTI +#define CONFIG_SH_ETHER_PHY_MODE PHY_INTERFACE_MODE_RGMII +#define CONFIG_PHY_VITESSE
+#define SH7753EVB_ETHERNET_MAC_BASE_SPI 0x00090000 +#define SH7753EVB_SPI_SECTOR_SIZE (64 * 1024) +#define SH7753EVB_ETHERNET_MAC_BASE SH7753EVB_ETHERNET_MAC_BASE_SPI +#define SH7753EVB_ETHERNET_MAC_SIZE 17 +#define SH7753EVB_ETHERNET_NUM_CH 2 +#define CONFIG_BOARD_LATE_INIT
+/* SPI */ +#define CONFIG_SH_SPI 1 +#define CONFIG_SH_SPI_BASE 0xfe002000 +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_STMICRO 1 +#define CONFIG_SPI_FLASH_MACRONIX 1
+/* MMCIF */ +#define CONFIG_MMC 1 +#define CONFIG_GENERIC_MMC 1 +#define CONFIG_SH_MMCIF 1 +#define CONFIG_SH_MMCIF_ADDR 0xffcb0000 +#define CONFIG_SH_MMCIF_CLK 48000000
+/* ENV setting */ +#define CONFIG_ENV_IS_EMBEDDED +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SECT_SIZE (64 * 1024) +#define CONFIG_ENV_ADDR (0x00080000) +#define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) +#define CONFIG_ENV_OVERWRITE 1 +#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SECT_SIZE) +#define CONFIG_EXTRA_ENV_SETTINGS \
"netboot=bootp; bootm\0"
+/* Board Clock */ +#define CONFIG_SYS_CLK_FREQ 48000000 +#define CONFIG_SH_TMU_CLK_FREQ CONFIG_SYS_CLK_FREQ +#define CONFIG_SH_SCIF_CLK_FREQ CONFIG_SYS_CLK_FREQ +#define CONFIG_SYS_TMU_CLK_DIV 4
+#endif /* __SH7753EVB_H */
1.7.1
2013/12/18 Shimoda, Yoshihiro yoshihiro.shimoda.uh@renesas.com:
2013/12/17 Shimoda, Yoshihiro yoshihiro.shimoda.uh@renesas.com:
The SH7753 EVB board has SH7753, 512MB DDR3-SDRAM, SPI ROM, Gigabit Ethernet, and eMMC.
This patch support the following functions:
- 512MB DDR3-SDRAM, SCIF4, SPI ROM, Gigabit Ethernet, eMMC
This patch changes the support for sh7752evb to sh7753evb.
Signed-off-by: Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com
Why do you remove sh7752evb? Isn't this already use or discontinue? There is no user any longer?
If someone uses sh7752evb, you should remove this board from u-boot, I think too.
If that is right, you should divide the patch which removes sh7752evb, and the patch to which sh7753evb is added.
Could you split patches?
OK, thank you!
Best regards, Nobuhiro
arch/sh/include/asm/cpu_sh4.h | 4 +- arch/sh/include/asm/cpu_sh7752.h | 197 -------------- arch/sh/include/asm/cpu_sh7753.h | 197 ++++++++++++++ board/renesas/sh7752evb/Makefile | 7 - board/renesas/sh7752evb/lowlevel_init.S | 447 ------------------------------- board/renesas/sh7752evb/sh7752evb.c | 314 ---------------------- board/renesas/sh7752evb/spi-boot.c | 116 -------- board/renesas/sh7752evb/u-boot.lds | 81 ------ board/renesas/sh7753evb/Makefile | 7 + board/renesas/sh7753evb/lowlevel_init.S | 416 ++++++++++++++++++++++++++++ board/renesas/sh7753evb/sh7753evb.c | 326 ++++++++++++++++++++++ board/renesas/sh7753evb/spi-boot.c | 134 +++++++++ board/renesas/sh7753evb/u-boot.lds | 81 ++++++ boards.cfg | 2 +- doc/README.sh7752evb | 67 ----- doc/README.sh7753evb | 67 +++++ include/configs/sh7752evb.h | 137 ---------- include/configs/sh7753evb.h | 137 ++++++++++ 18 files changed, 1368 insertions(+), 1369 deletions(-) delete mode 100644 arch/sh/include/asm/cpu_sh7752.h create mode 100644 arch/sh/include/asm/cpu_sh7753.h delete mode 100644 board/renesas/sh7752evb/Makefile delete mode 100644 board/renesas/sh7752evb/lowlevel_init.S delete mode 100644 board/renesas/sh7752evb/sh7752evb.c delete mode 100644 board/renesas/sh7752evb/spi-boot.c delete mode 100644 board/renesas/sh7752evb/u-boot.lds create mode 100644 board/renesas/sh7753evb/Makefile create mode 100644 board/renesas/sh7753evb/lowlevel_init.S create mode 100644 board/renesas/sh7753evb/sh7753evb.c create mode 100644 board/renesas/sh7753evb/spi-boot.c create mode 100644 board/renesas/sh7753evb/u-boot.lds delete mode 100644 doc/README.sh7752evb create mode 100644 doc/README.sh7753evb delete mode 100644 include/configs/sh7752evb.h create mode 100644 include/configs/sh7753evb.h
diff --git a/arch/sh/include/asm/cpu_sh4.h b/arch/sh/include/asm/cpu_sh4.h index 9181d59..9939f20 100644 --- a/arch/sh/include/asm/cpu_sh4.h +++ b/arch/sh/include/asm/cpu_sh4.h @@ -35,8 +35,8 @@ # include <asm/cpu_sh7724.h> #elif defined (CONFIG_CPU_SH7734) # include <asm/cpu_sh7734.h> -#elif defined (CONFIG_CPU_SH7752) -# include <asm/cpu_sh7752.h> +#elif defined (CONFIG_CPU_SH7753) +# include <asm/cpu_sh7753.h> #elif defined (CONFIG_CPU_SH7757) # include <asm/cpu_sh7757.h> #elif defined (CONFIG_CPU_SH7763) diff --git a/arch/sh/include/asm/cpu_sh7752.h b/arch/sh/include/asm/cpu_sh7752.h deleted file mode 100644 index 229ab07..0000000 --- a/arch/sh/include/asm/cpu_sh7752.h +++ /dev/null @@ -1,197 +0,0 @@ -/*
- Copyright (C) 2012 Renesas Solutions Corp.
-#ifndef _ASM_CPU_SH7752_H_ -#define _ASM_CPU_SH7752_H_
-#define CCR 0xFF00001C -#define WTCNT 0xFFCC0000 -#define CCR_CACHE_INIT 0x0000090b -#define CACHE_OC_NUM_WAYS 1
-#ifndef __ASSEMBLY__ /* put C only stuff in this section */ -/* MMU */ -struct mmu_regs {
unsigned int reserved[4];
unsigned int mmucr;
-}; -#define MMU_BASE ((struct mmu_regs *)0xff000000)
-/* Watchdog */ -#define WTCSR0 0xffcc0002 -#define WRSTCSR_R 0xffcc0003 -#define WRSTCSR_W 0xffcc0002 -#define WTCSR_PREFIX 0xa500 -#define WRSTCSR_PREFIX 0x6900 -#define WRSTCSR_WOVF_PREFIX 0x9600
-/* SCIF */ -#define SCIF0_BASE 0xfe4b0000 /* The real name is SCIF2 */ -#define SCIF1_BASE 0xfe4c0000 /* The real name is SCIF3 */ -#define SCIF2_BASE 0xfe4d0000 /* The real name is SCIF4 */
-/* TMU0 */ -#define TMU_BASE 0xFE430000
-/* ETHER, GETHER MAC address */ -struct ether_mac_regs {
unsigned int reserved[114];
unsigned int mahr;
unsigned int reserved2;
unsigned int malr;
-}; -#define GETHER0_MAC_BASE ((struct ether_mac_regs *)0xfee0400) -#define GETHER1_MAC_BASE ((struct ether_mac_regs *)0xfee0c00) -#define ETHER0_MAC_BASE ((struct ether_mac_regs *)0xfef0000) -#define ETHER1_MAC_BASE ((struct ether_mac_regs *)0xfef0800)
-/* GETHER */ -struct gether_control_regs {
unsigned int gbecont;
-}; -#define GETHER_CONTROL_BASE ((struct gether_control_regs *)0xffc10100) -#define GBECONT_RMII1 0x00020000 -#define GBECONT_RMII0 0x00010000
-/* SerMux */ -struct sermux_regs {
unsigned char smr0;
unsigned char smr1;
unsigned char smr2;
unsigned char smr3;
unsigned char smr4;
unsigned char smr5;
-}; -#define SERMUX_BASE ((struct sermux_regs *)0xfe470000)
-/* USB0/1 */ -struct usb_common_regs {
unsigned short reserved[129];
unsigned short suspmode;
-}; -#define USB0_COMMON_BASE ((struct usb_common_regs *)0xfe450000) -#define USB1_COMMON_BASE ((struct usb_common_regs *)0xfe4f0000)
-struct usb0_phy_regs {
unsigned short reset;
unsigned short reserved[4];
unsigned short portsel;
-}; -#define USB0_PHY_BASE ((struct usb0_phy_regs *)0xfe5f0000)
-struct usb1_port_regs {
unsigned int port1sel;
unsigned int reserved;
unsigned int usb1intsts;
-}; -#define USB1_PORT_BASE ((struct usb1_port_regs *)0xfe4f2000)
-struct usb1_alignment_regs {
unsigned int ehcidatac; /* 0xfe4fe018 */
unsigned int reserved[63];
unsigned int ohcidatac;
-}; -#define USB1_ALIGNMENT_BASE ((struct usb1_alignment_regs *)0xfe4fe018)
-/* GPIO */ -struct gpio_regs {
unsigned short pacr;
unsigned short pbcr;
unsigned short pccr;
unsigned short pdcr;
unsigned short pecr;
unsigned short pfcr;
unsigned short pgcr;
unsigned short phcr;
unsigned short picr;
unsigned short pjcr;
unsigned short pkcr;
unsigned short plcr;
unsigned short pmcr;
unsigned short pncr;
unsigned short pocr;
unsigned short reserved;
unsigned short pqcr;
unsigned short prcr;
unsigned short pscr;
unsigned short ptcr;
unsigned short pucr;
unsigned short pvcr;
unsigned short pwcr;
unsigned short pxcr;
unsigned short pycr;
unsigned short pzcr;
unsigned char padr;
unsigned char reserved_a;
unsigned char pbdr;
unsigned char reserved_b;
unsigned char pcdr;
unsigned char reserved_c;
unsigned char pddr;
unsigned char reserved_d;
unsigned char pedr;
unsigned char reserved_e;
unsigned char pfdr;
unsigned char reserved_f;
unsigned char pgdr;
unsigned char reserved_g;
unsigned char phdr;
unsigned char reserved_h;
unsigned char pidr;
unsigned char reserved_i;
unsigned char pjdr;
unsigned char reserved_j;
unsigned char pkdr;
unsigned char reserved_k;
unsigned char pldr;
unsigned char reserved_l;
unsigned char pmdr;
unsigned char reserved_m;
unsigned char pndr;
unsigned char reserved_n;
unsigned char podr;
unsigned char reserved_o;
unsigned char ppdr;
unsigned char reserved_p;
unsigned char pqdr;
unsigned char reserved_q;
unsigned char prdr;
unsigned char reserved_r;
unsigned char psdr;
unsigned char reserved_s;
unsigned char ptdr;
unsigned char reserved_t;
unsigned char pudr;
unsigned char reserved_u;
unsigned char pvdr;
unsigned char reserved_v;
unsigned char pwdr;
unsigned char reserved_w;
unsigned char pxdr;
unsigned char reserved_x;
unsigned char pydr;
unsigned char reserved_y;
unsigned char pzdr;
unsigned char reserved_z;
unsigned short ncer;
unsigned short ncmcr;
unsigned short nccsr;
unsigned char reserved2[2];
unsigned short psel0; /* +0x70 */
unsigned short psel1;
unsigned short psel2;
unsigned short psel3;
unsigned short psel4;
unsigned short psel5;
unsigned short psel6;
unsigned short reserved3[2];
unsigned short psel7;
-}; -#define GPIO_BASE ((struct gpio_regs *)0xffec0000)
-#endif /* ifndef __ASSEMBLY__ */ -#endif /* _ASM_CPU_SH7752_H_ */ diff --git a/arch/sh/include/asm/cpu_sh7753.h b/arch/sh/include/asm/cpu_sh7753.h new file mode 100644 index 0000000..cd0e0bb --- /dev/null +++ b/arch/sh/include/asm/cpu_sh7753.h @@ -0,0 +1,197 @@ +/*
+#ifndef _ASM_CPU_SH7753_H_ +#define _ASM_CPU_SH7753_H_
+#define CCR 0xFF00001C +#define WTCNT 0xFFCC0000 +#define CCR_CACHE_INIT 0x0000090b +#define CACHE_OC_NUM_WAYS 1
+#ifndef __ASSEMBLY__ /* put C only stuff in this section */ +/* MMU */ +struct mmu_regs {
unsigned int mmucr;
+}; +#define MMU_BASE ((struct mmu_regs *)0xff000000)
+/* Watchdog */ +#define WTCSR0 0xffcc0002 +#define WRSTCSR_R 0xffcc0003 +#define WRSTCSR_W 0xffcc0002 +#define WTCSR_PREFIX 0xa500 +#define WRSTCSR_PREFIX 0x6900 +#define WRSTCSR_WOVF_PREFIX 0x9600
+/* SCIF */ +#define SCIF0_BASE 0xfe4b0000 /* The real name is SCIF2 */ +#define SCIF1_BASE 0xfe4c0000 /* The real name is SCIF3 */ +#define SCIF2_BASE 0xfe4d0000 /* The real name is SCIF4 */
+/* TMU0 */ +#define TMU_BASE 0xFE430000
+/* ETHER, GETHER MAC address */ +struct ether_mac_regs {
unsigned int mahr;
unsigned int malr;
+}; +#define GETHER0_MAC_BASE ((struct ether_mac_regs *)0xfee0400) +#define GETHER1_MAC_BASE ((struct ether_mac_regs *)0xfee0c00) +#define ETHER0_MAC_BASE ((struct ether_mac_regs *)0xfef0000) +#define ETHER1_MAC_BASE ((struct ether_mac_regs *)0xfef0800)
+/* GETHER */ +struct gether_control_regs {
+}; +#define GETHER_CONTROL_BASE ((struct gether_control_regs *)0xffc10100) +#define GBECONT_RMII1 0x00020000 +#define GBECONT_RMII0 0x00010000
+/* SerMux */ +struct sermux_regs {
unsigned char smr0;
unsigned char smr1;
unsigned char smr2;
unsigned char smr3;
unsigned char smr4;
unsigned char smr5;
+}; +#define SERMUX_BASE ((struct sermux_regs *)0xfe470000)
+/* USB0/1 */ +struct usb_common_regs {
+}; +#define USB0_COMMON_BASE ((struct usb_common_regs *)0xfe450000) +#define USB1_COMMON_BASE ((struct usb_common_regs *)0xfe4f0000)
+struct usb0_phy_regs {
+}; +#define USB0_PHY_BASE ((struct usb0_phy_regs *)0xfe5f0000)
+struct usb1_port_regs {
+}; +#define USB1_PORT_BASE ((struct usb1_port_regs *)0xfe4f2000)
+struct usb1_alignment_regs {
+}; +#define USB1_ALIGNMENT_BASE ((struct usb1_alignment_regs *)0xfe4fe018)
+/* GPIO */ +struct gpio_regs {
unsigned char padr;
unsigned char pbdr;
unsigned char pcdr;
unsigned char pddr;
unsigned char pedr;
unsigned char pfdr;
unsigned char pgdr;
unsigned char phdr;
unsigned char pidr;
unsigned char pjdr;
unsigned char pkdr;
unsigned char pldr;
unsigned char pmdr;
unsigned char pndr;
unsigned char podr;
unsigned char ppdr;
unsigned char pqdr;
unsigned char prdr;
unsigned char psdr;
unsigned char ptdr;
unsigned char pudr;
unsigned char pvdr;
unsigned char pwdr;
unsigned char pxdr;
unsigned char pydr;
unsigned char pzdr;
+}; +#define GPIO_BASE ((struct gpio_regs *)0xffec0000)
+#endif /* ifndef __ASSEMBLY__ */ +#endif /* _ASM_CPU_SH7753_H_ */ diff --git a/board/renesas/sh7752evb/Makefile b/board/renesas/sh7752evb/Makefile deleted file mode 100644 index 856af81..0000000 --- a/board/renesas/sh7752evb/Makefile +++ /dev/null @@ -1,7 +0,0 @@ -# -# Copyright (C) 2012 Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com -# -# SPDX-License-Identifier: GPL-2.0+
-obj-y := sh7752evb.o spi-boot.o -obj-y += lowlevel_init.o diff --git a/board/renesas/sh7752evb/lowlevel_init.S b/board/renesas/sh7752evb/lowlevel_init.S deleted file mode 100644 index 5643a69..0000000 --- a/board/renesas/sh7752evb/lowlevel_init.S +++ /dev/null @@ -1,447 +0,0 @@ -/*
-#include <config.h> -#include <version.h> -#include <asm/processor.h> -#include <asm/macro.h>
-.macro or32, addr, data
mov.l \addr, r1
mov.l \data, r0
mov.l @r1, r2
or r2, r0
mov.l r0, @r1
-.endm
-.macro wait_DBCMD
mov.l DBWAIT_A, r0
mov.l @r0, r1
-.endm
.align 2
-lowlevel_init:
/*------- GPIO -------*/
write16 PDCR_A, PDCR_D ! SPI0
write16 PGCR_A, PGCR_D ! SPI0, GETHER MDIO gate(PTG1)
write16 PJCR_A, PJCR_D ! SCIF4
write16 PTCR_A, PTCR_D ! STATUS
write16 PSEL1_A, PSEL1_D ! SPI0
write16 PSEL2_A, PSEL2_D ! SPI0
write16 PSEL5_A, PSEL5_D ! STATUS
bra exit_gpio
nop
.align 2
-/*------- GPIO -------*/ -PDCR_A: .long 0xffec0006 -PGCR_A: .long 0xffec000c -PJCR_A: .long 0xffec0012 -PTCR_A: .long 0xffec0026 -PSEL1_A: .long 0xffec0072 -PSEL2_A: .long 0xffec0074 -PSEL5_A: .long 0xffec007a
-PDCR_D: .long 0x0000 -PGCR_D: .long 0x0004 -PJCR_D: .long 0x0000 -PTCR_D: .long 0x0000 -PSEL1_D: .long 0x0000 -PSEL2_D: .long 0x3000 -PSEL5_D: .long 0x0ffc
.align 2
-exit_gpio:
mov #0, r14
mova 2f, r0
mov.l PC_MASK, r1
tst r0, r1
bf 2f
bra exit_pmb
nop
.align 2
-/* If CPU runs on SDRAM (PC=0x5???????) or not. */ -PC_MASK: .long 0x20000000
-2:
mov #1, r14
mov.l EXPEVT_A, r0
mov.l @r0, r0
cmp/eq r0, r1
bt 1f
* initialization of DDR3IF is not necessary.
bra exit_ddr
nop
-1:
mov.l DBACEN_A, r0
mov.l @r0, r0
cmp/eq #0, r0
bt 3f
bra exit_ddr
nop
-3:
/*------- DDR3IF -------*/
/* step 3 */
/* step 4 */
/* step 5 */
/* step 6 */
/* step 7 */
/* step 8 */
/* step 9 */
/* step 10 */
/* step 11 */
/* step 12 */
wait_DBCMD
/* step 13 */
wait_DBCMD
/* step 14 */
/* step 15 */
/* step 16 */
/* step 17 */
/* step 18 */
/* step 19 */
/* step 20 */
wait_DBCMD
/* step 21 */
write32 DBADJ1_A, DBADJ1_D
/* step 22 */
/* step 23 */
/* step 24 */
/* step 25 */
/* step 26 */
wait_DBCMD
bra exit_ddr
nop
.align 2
-EXPEVT_A: .long 0xff000024 -EXPEVT_POWER_ON_RESET: .long 0x00000000
-/*------- Reset -------*/ -MRSTCR0_A: .long 0xffd50030 -MRSTCR0_D: .long 0xfe1ffe7f -MRSTCR1_A: .long 0xffd50034 -MRSTCR1_D: .long 0xfff3ffff
-/*------- DDR3IF -------*/ -DBCMD_A: .long 0xfe800018 -DBKIND_A: .long 0xfe800020 -DBCONF_A: .long 0xfe800024 -DBTR0_A: .long 0xfe800040 -DBTR1_A: .long 0xfe800044 -DBTR2_A: .long 0xfe800048 -DBTR3_A: .long 0xfe800050 -DBTR4_A: .long 0xfe800054 -DBTR5_A: .long 0xfe800058 -DBTR6_A: .long 0xfe80005c -DBTR7_A: .long 0xfe800060 -DBTR8_A: .long 0xfe800064 -DBTR9_A: .long 0xfe800068 -DBTR10_A: .long 0xfe80006c -DBTR11_A: .long 0xfe800070 -DBTR12_A: .long 0xfe800074 -DBTR13_A: .long 0xfe800078 -DBTR14_A: .long 0xfe80007c -DBTR15_A: .long 0xfe800080 -DBTR16_A: .long 0xfe800084 -DBTR17_A: .long 0xfe800088 -DBTR18_A: .long 0xfe80008c -DBTR19_A: .long 0xfe800090 -DBRNK0_A: .long 0xfe800100 -DBPDCNT0_A: .long 0xfe800200 -DBPDCNT1_A: .long 0xfe800204 -DBPDCNT2_A: .long 0xfe800208 -DBPDCNT3_A: .long 0xfe80020c -DBPDLCK_A: .long 0xfe800280 -DBPDRGA_A: .long 0xfe800290 -DBPDRGD_A: .long 0xfe8002a0 -DBADJ0_A: .long 0xfe8000c0 -DBADJ1_A: .long 0xfe8000c4 -DBADJ2_A: .long 0xfe8000c8 -DBRFCNF0_A: .long 0xfe8000e0 -DBRFCNF1_A: .long 0xfe8000e4 -DBRFCNF2_A: .long 0xfe8000e8 -DBCALCNF_A: .long 0xfe8000f4 -DBRFEN_A: .long 0xfe800014 -DBACEN_A: .long 0xfe800010 -DBWAIT_A: .long 0xfe80001c
-WAIT_OSC_TIME: .long 6000 -WAIT_30US: .long 13333
-DBCMD_RSTL_VAL: .long 0x20000000 -DBCMD_PDEN_VAL: .long 0x1000d73c -DBCMD_WAIT_VAL: .long 0x0000d73c -DBCMD_RSTH_VAL: .long 0x2100d73c -DBCMD_PDXT_VAL: .long 0x110000c8 -DBCMD_MRS0_VAL: .long 0x28000930 -DBCMD_MRS1_VAL: .long 0x29000004 -DBCMD_MRS2_VAL: .long 0x2a000008 -DBCMD_MRS3_VAL: .long 0x2b000000 -DBCMD_ZQCL_VAL: .long 0x03000200 -DBCMD_REF_VAL: .long 0x0c000000 -DBCMD_SRXT_VAL: .long 0x19000000 -DBKIND_D: .long 0x00000007 -DBCONF_D: .long 0x0f030a01 -DBTR0_D: .long 0x00000007 -DBTR1_D: .long 0x00000006 -DBTR2_D: .long 0x00000000 -DBTR3_D: .long 0x00000007 -DBTR4_D: .long 0x00070007 -DBTR5_D: .long 0x0000001b -DBTR6_D: .long 0x00000014 -DBTR7_D: .long 0x00000005 -DBTR8_D: .long 0x00000015 -DBTR9_D: .long 0x00000006 -DBTR10_D: .long 0x00000008 -DBTR11_D: .long 0x00000007 -DBTR12_D: .long 0x0000000e -DBTR13_D: .long 0x00000056 -DBTR14_D: .long 0x00000006 -DBTR15_D: .long 0x00000004 -DBTR16_D: .long 0x00150002 -DBTR17_D: .long 0x000c0017 -DBTR18_D: .long 0x00000200 -DBTR19_D: .long 0x00000040 -DBRNK0_D: .long 0x00000001 -DBPDCNT0_D: .long 0x00000001 -DBPDCNT1_D: .long 0x00000001 -DBPDCNT2_D: .long 0x00000000 -DBPDCNT3_D: .long 0x00004010 -DBPDLCK_D: .long 0x0000a55a -DBPDRGA_D: .long 0x00000028 -DBPDRGD_D: .long 0x00017100
-DBADJ0_D: .long 0x00000000 -DBADJ1_D: .long 0x00000000 -DBADJ2_D: .long 0x18061806 -DBRFCNF0_D: .long 0x000001ff -DBRFCNF1_D: .long 0x08001000 -DBRFCNF2_D: .long 0x00000000 -DBCALCNF_D: .long 0x0000ffff -DBRFEN_D: .long 0x00000001 -DBACEN_D: .long 0x00000001
.align 2
-exit_ddr: -#if defined(CONFIG_SH_32BIT)
* ent virt phys v sz c wt
* 1 0xa8000000 0x48000000 1 128M 0 1
* 5 0x88000000 0x48000000 1 128M 1 1
icbi @r0
-#endif /* if defined(CONFIG_SH_32BIT) */
-exit_pmb:
mov r14, r0
tst #1, r0
bt 1f
-100: bsrf r0
nop
.align 2
-_spiboot_main: .long (spiboot_main - (100b + 4)) -_stack_ilram: .long 0xe5204000
-1:
rts
nop
.align 2
-#if defined(CONFIG_SH_32BIT) -/*------- set PMB -------*/ -PMB_ADDR_SPIBOOT_A: .long PMB_ADDR_BASE(0) -PMB_ADDR_DDR_N1_A: .long PMB_ADDR_BASE(1) -PMB_ADDR_DDR_C1_A: .long PMB_ADDR_BASE(5) -PMB_ADDR_ENTRY2: .long PMB_ADDR_BASE(2) -PMB_ADDR_ENTRY3: .long PMB_ADDR_BASE(3) -PMB_ADDR_ENTRY4: .long PMB_ADDR_BASE(4) -PMB_ADDR_ENTRY6: .long PMB_ADDR_BASE(6) -PMB_ADDR_ENTRY7: .long PMB_ADDR_BASE(7) -PMB_ADDR_ENTRY8: .long PMB_ADDR_BASE(8) -PMB_ADDR_ENTRY9: .long PMB_ADDR_BASE(9) -PMB_ADDR_ENTRY10: .long PMB_ADDR_BASE(10) -PMB_ADDR_ENTRY11: .long PMB_ADDR_BASE(11) -PMB_ADDR_ENTRY12: .long PMB_ADDR_BASE(12) -PMB_ADDR_ENTRY13: .long PMB_ADDR_BASE(13) -PMB_ADDR_ENTRY14: .long PMB_ADDR_BASE(14) -PMB_ADDR_ENTRY15: .long PMB_ADDR_BASE(15)
-PMB_ADDR_SPIBOOT_D: .long mk_pmb_addr_val(0xa0) -PMB_ADDR_DDR_C1_D: .long mk_pmb_addr_val(0x88) -PMB_ADDR_DDR_N1_D: .long mk_pmb_addr_val(0xa8) -PMB_ADDR_NOT_USE_D: .long 0x00000000
-PMB_DATA_SPIBOOT_A: .long PMB_DATA_BASE(0) -PMB_DATA_DDR_N1_A: .long PMB_DATA_BASE(1) -PMB_DATA_DDR_C1_A: .long PMB_DATA_BASE(5)
-/* ppn ub v s1 s0 c wt */ -PMB_DATA_SPIBOOT_D: .long mk_pmb_data_val(0x00, 0, 1, 1, 0, 0, 1) -PMB_DATA_DDR_C1_D: .long mk_pmb_data_val(0x48, 0, 1, 1, 0, 1, 1) -PMB_DATA_DDR_N1_D: .long mk_pmb_data_val(0x48, 1, 1, 1, 0, 0, 1)
-PASCR_A: .long 0xff000070 -DUMMY_ADDR: .long 0xa0000000 -PASCR_29BIT_D: .long 0x00000000 -PASCR_INIT: .long 0x80000080 -MMUCR_A: .long 0xff000010 -MMUCR_D: .long 0x00000004 /* clear ITLB */ -#endif /* CONFIG_SH_32BIT */
-CCR_A: .long CCR -CCR_D: .long CCR_CACHE_INIT diff --git a/board/renesas/sh7752evb/sh7752evb.c b/board/renesas/sh7752evb/sh7752evb.c deleted file mode 100644 index 5eedbf8..0000000 --- a/board/renesas/sh7752evb/sh7752evb.c +++ /dev/null @@ -1,314 +0,0 @@ -/*
-#include <common.h> -#include <malloc.h> -#include <asm/processor.h> -#include <asm/io.h> -#include <asm/mmc.h> -#include <spi_flash.h>
-int checkboard(void) -{
puts("BOARD: SH7752 evaluation board (R0P7752C00000RZ)\n");
-static void init_gpio(void) -{
/* GPIO */
-static void init_usb_phy(void) -{
-#if defined(__LITTLE_ENDIAN)
-#endif -}
-static void init_gether_mdio(void) -{
-static void set_mac_to_sh_giga_eth_register(int channel, char *mac_string) -{
unsigned long val;
if (!channel)
else
- This PMB must be set on this timing. The lowlevel_init is run on
- Area 0(phys 0x00000000), so we have to map it.
- The new PMB table is following:
- ent virt phys v sz c wt
- 0 0xa0000000 0x40000000 1 128M 0 1
- 1 0xa8000000 0x48000000 1 128M 0 1
- 2 0xb0000000 0x50000000 1 128M 0 1
- 3 0xb8000000 0x58000000 1 128M 0 1
- 4 0x80000000 0x40000000 1 128M 1 1
- 5 0x88000000 0x48000000 1 128M 1 1
- 6 0x90000000 0x50000000 1 128M 1 1
- 7 0x98000000 0x58000000 1 128M 1 1
-static void set_pmb_on_board_init(void) -{
/* clear ITLB */
-int board_init(void) -{
init_gpio();
init_usb_phy();
init_gether_mdio();
-int dram_init(void) -{
-int board_mmc_init(bd_t *bis) -{
udelay(1);
udelay(200);
-static int get_sh_eth_mac_raw(unsigned char *buf, int size) -{
int ret;
if (spi == NULL) {
return 1;
ret = spi_flash_read(spi, SH7752EVB_ETHERNET_MAC_BASE, size, buf);
if (ret) {
return 1;
-static int get_sh_eth_mac(int channel, char *mac_string, unsigned char *buf) -{
memcpy(mac_string, &buf[channel * (SH7752EVB_ETHERNET_MAC_SIZE + 1)],
SH7752EVB_ETHERNET_MAC_SIZE);
mac_string[SH7752EVB_ETHERNET_MAC_SIZE] = 0x00; /* terminate */
-static void init_ethernet_mac(void) -{
int i;
unsigned char *buf;
buf = malloc(256);
if (!buf) {
return;
for (i = 0; i < SH7752EVB_ETHERNET_NUM_CH; i++) {
if (i == 0)
else {
free(buf);
-int board_late_init(void) -{
-int do_write_mac(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{
int i, ret;
unsigned char *buf;
if (argc != 3) {
buf = malloc(256);
if (!buf) {
return 1;
free(buf);
/* new setting */
argv[1], argv[2]);
if (!spi) {
return 1;
ret = spi_flash_erase(spi, SH7752EVB_ETHERNET_MAC_BASE_SPI,
SH7752EVB_SPI_SECTOR_SIZE);
if (ret) {
return 1;
ret = spi_flash_write(spi, SH7752EVB_ETHERNET_MAC_BASE_SPI,
if (ret) {
return 1;
-U_BOOT_CMD(
-); diff --git a/board/renesas/sh7752evb/spi-boot.c b/board/renesas/sh7752evb/spi-boot.c deleted file mode 100644 index 91565d4..0000000 --- a/board/renesas/sh7752evb/spi-boot.c +++ /dev/null @@ -1,116 +0,0 @@ -/*
- This file is subject to the terms and conditions of the GNU Lesser
- General Public License. See the file "COPYING.LIB" in the main
- directory of this archive for more details.
-#define CONFIG_RAM_BOOT_PHYS CONFIG_SYS_TEXT_BASE -#define CONFIG_SPI_ADDR 0x00000000 -#define CONFIG_SPI_LENGTH CONFIG_SYS_MONITOR_LEN -#define CONFIG_RAM_BOOT CONFIG_SYS_TEXT_BASE
-#define SPIWDMADR 0xFE001018 -#define SPIWDMCNTR 0xFE001020 -#define SPIDMCOR 0xFE001028 -#define SPIDMINTSR 0xFE001188 -#define SPIDMINTMR 0xFE001190
-#define SPIDMINTSR_DMEND 0x00000004
-#define TBR 0xFE002000 -#define RBR 0xFE002000
-#define CR1 0xFE002008 -#define CR2 0xFE002010 -#define CR3 0xFE002018 -#define CR4 0xFE002020
-/* CR1 */ -#define SPI_TBE 0x80 -#define SPI_TBF 0x40 -#define SPI_RBE 0x20 -#define SPI_RBF 0x10 -#define SPI_PFONRD 0x08 -#define SPI_SSDB 0x04 -#define SPI_SSD 0x02 -#define SPI_SSA 0x01
-/* CR2 */ -#define SPI_RSTF 0x80 -#define SPI_LOOPBK 0x40 -#define SPI_CPOL 0x20 -#define SPI_CPHA 0x10 -#define SPI_L1M0 0x08
-/* CR4 */ -#define SPI_TBEI 0x80 -#define SPI_TBFI 0x40 -#define SPI_RBEI 0x20 -#define SPI_RBFI 0x10 -#define SPI_SpiS0 0x02 -#define SPI_SSS 0x01
-#define spi_write(val, addr) (*(volatile unsigned long *)(addr)) = val -#define spi_read(addr) (*(volatile unsigned long *)(addr))
-/* M25P80 */ -#define M25_READ 0x03
-#define __uses_spiboot2 __attribute__((section(".spiboot2.text"))) -static void __uses_spiboot2 spi_reset(void) -{
if (timeout-- < 0)
break;
-static void __uses_spiboot2 spi_read_flash(void *buf, unsigned long addr,
unsigned long len)
spi_write(0, CR1);
-void __uses_spiboot2 spiboot_main(void) -{
spi_reset();
CONFIG_SPI_LENGTH);
_start();
-} diff --git a/board/renesas/sh7752evb/u-boot.lds b/board/renesas/sh7752evb/u-boot.lds deleted file mode 100644 index 053df64..0000000 --- a/board/renesas/sh7752evb/u-boot.lds +++ /dev/null @@ -1,81 +0,0 @@ -/*
- Copyright (C) 2007
- Nobuhiro Iwamatsu iwamatsu@nigauri.org
- Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com
-OUTPUT_FORMAT("elf32-sh-linux", "elf32-sh-linux", "elf32-sh-linux") -OUTPUT_ARCH(sh) -ENTRY(_start)
-SECTIONS -{
.text :
*(.spiboot1.text)
*(.spiboot2.text)
. = ALIGN(8192);
. = ALIGN(8192);
. = ALIGN(8192);
*(.text)
. = ALIGN(4);
} =0xFF
.rodata :
. = ALIGN(4);
.data :
*(.data)
. = ALIGN(4);
.got :
*(.got)
. = ALIGN(4);
.u_boot_list : {
.bss (NOLOAD) :
*(.bss)
. = ALIGN(4);
- Copyright (C) 2013 Renesas Solutions Corp.
mov.l \addr, r1
mov.l \data, r0
mov.l @r1, r2
or r2, r0
mov.l r0, @r1
+.endm
+.macro wait_DBCMD
mov.l DBWAIT_A, r0
mov.l @r0, r1
+.endm
.align 2
+lowlevel_init:
mov #0, r14
mova 2f, r0
mov.l PC_MASK, r1
tst r0, r1
bf 2f
bra exit_pmb
nop
.align 2
+2:
mov #1, r14
mov.l EXPEVT_A, r0
mov.l @r0, r0
cmp/eq r0, r1
bt 1f
bra exit_ddr
nop
+1:
mov.l DBACEN_A, r0
mov.l @r0, r0
cmp/eq #0, r0
bt 3f
bra exit_ddr
nop
+3:
/* step 3 */
/* step 4 */
/* step 5 */
/* step 6 */
/* step 7 */
/* step 8 */
/* step 9 */
/* step 10 */
/* step 11 */
/* step 12 */
wait_DBCMD
/* step 13 */
wait_DBCMD
/* step 14 */
/* step 15 */
/* step 16 */
/* step 17 */
/* step 18 */
/* step 19 */
/* step 20 */
wait_DBCMD
/* step 21 */
/* step 22 */
/* step 23 */
/* step 24 */
/* step 25 */
/* step 26 */
wait_DBCMD
bra exit_ddr
nop
.align 2
.align 2
icbi @r0
+exit_pmb:
mov r14, r0
tst #1, r0
bt 1f
+100: bsrf r0
nop
.align 2
+1:
rts
nop
.align 2
/* GPIO */
+#endif +}
unsigned long val;
if (!channel)
else
/* clear ITLB */
init_gpio();
init_usb_phy();
init_gether_mdio();
udelay(1);
udelay(200);
int ret;
if (spi == NULL) {
return 1;
if (ret) {
return 1;
int i;
unsigned char *buf;
buf = malloc(256);
if (!buf) {
return;
if (i == 0)
else {
free(buf);
int i, ret;
unsigned char *buf;
if (argc != 3) {
buf = malloc(256);
if (!buf) {
return 1;
free(buf);
/* new setting */
argv[1], argv[2]);
if (!spi) {
return 1;
if (ret) {
return 1;
if (ret) {
return 1;
+U_BOOT_CMD(
if (timeout-- < 0)
break;
unsigned long len)
} else {
spi_write(0, CR1);
* lower 5-bits.
spi_reset();
_start();
+SECTIONS +{
.text :
*(.spiboot1.text)
*(.spiboot2.text)
. = ALIGN(8192);
. = ALIGN(8192);
. = ALIGN(8192);
*(.text)
. = ALIGN(4);
} =0xFF
.rodata :
. = ALIGN(4);
.data :
*(.data)
. = ALIGN(4);
.got :
*(.got)
. = ALIGN(4);
.u_boot_list : {
.bss (NOLOAD) :
*(.bss)
. = ALIGN(4);
- SH7752 (SH-4A)
- DDR3-SDRAM 512MB
- SPI ROM 8MB
- eMMC 4GB
- write_mac
-1. write_mac
For example)
- write_mac
For example)
=> write_mac
-Update SPI ROM:
- => sf probe 0
-3. Erase SPI ROM.
- SH7753 (SH-4A)
- DDR3-SDRAM 512MB
- SPI ROM 8MB
- eMMC 4GB
- write_mac
+1. write_mac
For example)
- write_mac
For example)
=> write_mac
- => sf probe 0
+3. Erase SPI ROM.
- Configuation settings for the sh7752evb board
480 * 1024 * 1024)
128 * 1024 * 1024)
- Configuation settings for the sh7753evb board
480 * 1024 * 1024)
128 * 1024 * 1024)
1.7.1
-- Yoshihiro Shimoda EC No.
Nobuhiro Iwamatsu
Shimoda, Yoshihiro
