[U-Boot] [PATCH 1/3] mmc: ftsdc010: Support High-Speed mode
ftsdc010 dm driver has been disable High-Speed mode as default to work around Andes AE3XX platform's problem, because of it does not support High-Speed mode in commit id 73cd56b2df213c629191139e5c6705e069b6214f.
But other platforms or SoCs maybe support this function. So High-Speed mode can be enabled from dts with cap-mmc-highspeed or cap-sd-highspeed property.
Signed-off-by: Rick Chen rick@andestech.com Signed-off-by: Rick Chen rickchen36@gmail.com --- drivers/mmc/nds32_mmc.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/drivers/mmc/nds32_mmc.c b/drivers/mmc/nds32_mmc.c index 6d3c857..ec43e9d 100644 --- a/drivers/mmc/nds32_mmc.c +++ b/drivers/mmc/nds32_mmc.c @@ -103,6 +103,11 @@ static int nds32_mmc_probe(struct udevice *dev) if (ret < 0) return ret; #endif + + if (dev_read_bool(dev, "cap-mmc-highspeed") || \ + dev_read_bool(dev, "cap-sd-highspeed")) + chip->caps |= MMC_MODE_HS | MMC_MODE_HS_52MHz; + ftsdc_setup_cfg(&plat->cfg, dev->name, chip->buswidth, chip->caps, priv->minmax[1] , priv->minmax[0]); chip->mmc = &plat->mmc;
Andes
