[PATCH v2] dm: usb: add hook for low level usb init
This patch adds a hook to enable us to call a custom function when booting from USB
Signed-off-by: Simon-Pierre Allaire spallaire@distech-controls.com ---
Changes for v2: - Added description of the patch
drivers/usb/host/usb-uclass.c | 7 ++++++- drivers/usb/musb-new/musb_uboot.c | 13 +++++++++++++ 2 files changed, 19 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/host/usb-uclass.c b/drivers/usb/host/usb-uclass.c index 611ea97a72..e1ea21970c 100644 --- a/drivers/usb/host/usb-uclass.c +++ b/drivers/usb/host/usb-uclass.c @@ -243,6 +243,7 @@ int usb_init(void) struct udevice *bus; struct uclass *uc; int count = 0; + void *ctrl; int ret;
asynch_allowed = 1; @@ -256,7 +257,11 @@ int usb_init(void) uclass_foreach_dev(bus, uc) { /* init low_level USB */ printf("USB%d: ", count); - count++; + ret = usb_lowlevel_init(count, USB_INIT_HOST, &ctrl); + if (ret == -ENODEV) /* No such device. */ + puts("Port not available.\n"); + else + count++;
#ifdef CONFIG_SANDBOX /* diff --git a/drivers/usb/musb-new/musb_uboot.c b/drivers/usb/musb-new/musb_uboot.c index 9c8cc6e584..5540640d6d 100644 --- a/drivers/usb/musb-new/musb_uboot.c +++ b/drivers/usb/musb-new/musb_uboot.c @@ -303,6 +303,19 @@ int usb_lowlevel_init(int index, enum usb_init_type init, void **controller) #endif /* !CONFIG_IS_ENABLED(DM_USB) */
#if CONFIG_IS_ENABLED(DM_USB) + +int usb_lowlevel_init(int index, enum usb_init_type init, void **controller) +{ + int ret; + + ret = board_usb_init(index, init); + if (ret != 0) { + puts("Failed to initialize board for USB\n"); + return ret; + } + return 0; +} + static int musb_submit_control_msg(struct udevice *dev, struct usb_device *udev, unsigned long pipe, void *buffer, int length, struct devrequest *setup)
