[PATCH 0/8] Early-boot support of R5FSS from A72 U-Boot for J7200 SoCs
Hi Lokesh,
The following series adds the early-boot support of the revised R5FSS IP on J7200 SoCS from A72 U-Boot. The J7200 SoCs has two R5FSS clusters, one in MCU domain and another in MAIN domain. Patches are on top of the latest master + "Configure J721E Main R5FSS1 to Split-mode & env" series [1].
The current series enables the default variables only for the MAIN R5FSS cores. The config file used is common between J721E and J7200 SoCs, so is adjusted accordingly.
The MCU R5FSS is shutdown at the end of R5 SPL, and can be booted by modifying env variables. Early-boot is supported only through the MMC rootfs just like on J721E SoCs.
Following are the default modes and firmware image names supported with this series: 1. Modes MCU R5FSS0: LockStep mode MAIN R5FSS0: Split mode 2. Firmware images MCU R5FSS0 Core0 : j7200-mcu-r5f0_0-fw MCU R5FSS0 Core1 : j7200-mcu-r5f0_1-fw MAIN R5FSS0 Core0 : j7200-main-r5f0_0-fw MAIN R5FSS0 Core0 : j7200-main-r5f0_1-fw
Following is the patch summary: - Patches #1 and #2 update the binding and the K3 R5F remoteproc driver for J7200 SoCs - Patch #3 sets up a separate MMU map for J7200 SoCs using the appropriate CONFIG_TARGET_<SOC>_A72_EVM symbols - Patches #4 and #5 add the dts nodes with LockStep for MCU R5FSS0 and Split-mode for MAIN R5FSS0 - Patch #6 leverages the CONFIG_TARGET_<SOC>_A72_EVM symbols to set the SoC-specific default remoteproc boot list - Patch #7 enables the R5F remoteproc driver and needed options for A72 U-Boot - Patch #8 enhances the bootcmd variable to include the booting of the rprocs based on couple of control variables
regards Suman
[1] https://patchwork.ozlabs.org/project/uboot/list/?series=196091
Suman Anna (8): dt-bindings: remoteproc: k3-r5f: Update bindings for J7200 SoCs remoteproc: k3-r5: Add support for J7200 R5Fs armv8: K3: j7200: Add custom MMU support arm: dts: k3-j7200-mcu: Add MCU domain R5F cluster node arm: dts: k3-j7200-main: Add MAIN domain R5F cluster nodes env: ti: j721e-evm: Update rproc_fw_binaries env variable for J7200 configs: j7200_evm_a72: Enable R5F remoteproc driver configs: j7200_evm_a72: Enhance bootcmd to start remoteprocs
arch/arm/dts/k3-j7200-common-proc-board.dts | 7 ++ arch/arm/dts/k3-j7200-main.dtsi | 40 ++++++++ arch/arm/dts/k3-j7200-mcu-wakeup.dtsi | 40 ++++++++ arch/arm/mach-k3/arm64-mmu.c | 59 ++++++++++- configs/j7200_evm_a72_defconfig | 6 +- .../remoteproc/ti,k3-r5f-rproc.txt | 5 +- drivers/remoteproc/ti_k3_r5f_rproc.c | 99 +++++++++++++++++-- include/configs/j721e_evm.h | 14 ++- 8 files changed, 255 insertions(+), 15 deletions(-)
The K3 J7200 SoCs have two dual-core Arm R5F clusters/subsystems, with 2 R5F cores each, one in each of the MCU and MAIN voltage domains.
These clusters are a revised version compared to those present on J721E SoCs. Update the K3 R5F remoteproc bindings with the compatible info relevant to these R5F clusters/subsystems on K3 J7200 SoCs.
Signed-off-by: Suman Anna s-anna@ti.com --- doc/device-tree-bindings/remoteproc/ti,k3-r5f-rproc.txt | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/doc/device-tree-bindings/remoteproc/ti,k3-r5f-rproc.txt b/doc/device-tree-bindings/remoteproc/ti,k3-r5f-rproc.txt index c2fa6e834406..5708c230175c 100644 --- a/doc/device-tree-bindings/remoteproc/ti,k3-r5f-rproc.txt +++ b/doc/device-tree-bindings/remoteproc/ti,k3-r5f-rproc.txt @@ -25,6 +25,8 @@ The following are the mandatory properties: K3 AM65x SoCs "ti,j721e-r5fss" for R5F clusters/subsystems on K3 J721E SoCs + "ti,j7200-r5fss" for R5F clusters/subsystems on + K3 J7200 SoCs - power-domains: Should contain a phandle to a PM domain provider node and an args specifier containing the R5FSS device id value. This property is as per the binding, @@ -56,6 +58,7 @@ The following are the mandatory properties: - compatible: Should be one of the following, "ti,am654-r5f" for the R5F cores in K3 AM65x SoCs "ti,j721e-r5f" for the R5F cores in K3 J721E SOCs + "ti,j7200-r5f" for the R5F cores in K3 J7200 SOCs - reg: Should contain an entry for each value in 'reg-names'. Each entry should have the memory region's start address and the size of the region, the representation matching @@ -79,7 +82,7 @@ The following are the mandatory properties: specifier. Please refer to the following reset bindings for the reset argument specifier, Documentation/devicetree/bindings/reset/ti,sci-reset.txt - for AM65x and J721E SoCs + for AM65x, J721E and J7200 SoCs
Optional properties: --------------------
The K3 J7200 SoC family has a revised R5F sub-system and contains a subset of the R5F clusters present on J721E SoCs. The integration of these clusters is very much similar to J721E SoCs otherwise.
The revised IP has the following two new features: 1. TCMs are auto-initialized during module power-up, and the behavior is programmable through a MMR bit controlled by System Firmware. 2. The LockStep-mode allows the Core1 TCMs to be combined with the Core0 TCMs effectively doubling the amount of TCMs available. The LockStep-mode on previous SoCs could only use the Core0 TCMs. This combined TCMs appear contiguous at the respective Core0 TCM addresses.
Add the support to these clusters in the K3 R5F remoteproc driver using J7200 specific compatibles and revised logic accounting for the above IP features/differences.
Signed-off-by: Suman Anna s-anna@ti.com --- drivers/remoteproc/ti_k3_r5f_rproc.c | 99 +++++++++++++++++++++++++--- 1 file changed, 89 insertions(+), 10 deletions(-)
diff --git a/drivers/remoteproc/ti_k3_r5f_rproc.c b/drivers/remoteproc/ti_k3_r5f_rproc.c index 1a7f1f8a005f..8e21a38be7f1 100644 --- a/drivers/remoteproc/ti_k3_r5f_rproc.c +++ b/drivers/remoteproc/ti_k3_r5f_rproc.c @@ -2,8 +2,9 @@ /* * Texas Instruments' K3 R5 Remoteproc driver * - * Copyright (C) 2018-2019 Texas Instruments Incorporated - http://www.ti.com/ + * Copyright (C) 2018-2020 Texas Instruments Incorporated - https://www.ti.com/ * Lokesh Vutla lokeshvutla@ti.com + * Suman Anna s-anna@ti.com */
#include <common.h> @@ -37,6 +38,8 @@ #define PROC_BOOT_CFG_FLAG_R5_BTCM_EN 0x00001000 #define PROC_BOOT_CFG_FLAG_R5_ATCM_EN 0x00002000 #define PROC_BOOT_CFG_FLAG_GEN_IGN_BOOTVECTOR 0x10000000 +/* Available from J7200 SoCs onwards */ +#define PROC_BOOT_CFG_FLAG_R5_MEM_INIT_DIS 0x00004000
/* R5 TI-SCI Processor Control Flags */ #define PROC_BOOT_CTRL_FLAG_R5_CORE_HALT 0x00000001 @@ -54,6 +57,16 @@ enum cluster_mode { CLUSTER_MODE_LOCKSTEP, };
+/** + * struct k3_r5f_ip_data - internal data structure used for IP variations + * @tcm_is_double: flag to denote the larger unified TCMs in certain modes + * @tcm_ecc_autoinit: flag to denote the auto-initialization of TCMs for ECC + */ +struct k3_r5f_ip_data { + bool tcm_is_double; + bool tcm_ecc_autoinit; +}; + /** * struct k3_r5_mem - internal memory structure * @cpu_addr: MPU virtual address of the memory region @@ -74,6 +87,7 @@ struct k3_r5f_mem { * @cluster: pointer to the parent cluster. * @reset: reset control handle * @tsp: TI-SCI processor control handle + * @ipdata: cached pointer to R5F IP specific feature data * @mem: Array of available internal memories * @num_mem: Number of available memories * @atcm_enable: flag to control ATCM enablement @@ -86,6 +100,7 @@ struct k3_r5f_core { struct k3_r5f_cluster *cluster; struct reset_ctl reset; struct ti_sci_proc tsp; + struct k3_r5f_ip_data *ipdata; struct k3_r5f_mem *mem; int num_mems; u32 atcm_enable; @@ -257,6 +272,18 @@ static int k3_r5f_core_sanity_check(struct k3_r5f_core *core) return 0; }
+/* Zero out TCMs so that ECC can be effective on all TCM addresses */ +void k3_r5f_init_tcm_memories(struct k3_r5f_core *core, bool auto_inited) +{ + if (core->ipdata->tcm_ecc_autoinit && auto_inited) + return; + + if (core->atcm_enable) + memset(core->mem[0].cpu_addr, 0x00, core->mem[0].size); + if (core->btcm_enable) + memset(core->mem[1].cpu_addr, 0x00, core->mem[1].size); +} + /** * k3_r5f_load() - Load up the Remote processor image * @dev: rproc device pointer @@ -268,7 +295,9 @@ static int k3_r5f_core_sanity_check(struct k3_r5f_core *core) static int k3_r5f_load(struct udevice *dev, ulong addr, ulong size) { struct k3_r5f_core *core = dev_get_priv(dev); - u32 boot_vector; + u64 boot_vector; + u32 ctrl, sts, cfg = 0; + bool mem_auto_init; int ret;
dev_dbg(dev, "%s addr = 0x%lx, size = 0x%lx\n", __func__, addr, size); @@ -281,6 +310,12 @@ static int k3_r5f_load(struct udevice *dev, ulong addr, ulong size) if (ret) return ret;
+ ret = ti_sci_proc_get_status(&core->tsp, &boot_vector, &cfg, &ctrl, + &sts); + if (ret) + return ret; + mem_auto_init = !(cfg & PROC_BOOT_CFG_FLAG_R5_MEM_INIT_DIS); + ret = k3_r5f_prepare(dev); if (ret) { dev_err(dev, "R5f prepare failed for core %d\n", @@ -288,11 +323,7 @@ static int k3_r5f_load(struct udevice *dev, ulong addr, ulong size) goto proc_release; }
- /* Zero out TCMs so that ECC can be effective on all TCM addresses */ - if (core->atcm_enable) - memset(core->mem[0].cpu_addr, 0x00, core->mem[0].size); - if (core->btcm_enable) - memset(core->mem[1].cpu_addr, 0x00, core->mem[1].size); + k3_r5f_init_tcm_memories(core, mem_auto_init);
ret = rproc_elf_load_image(dev, addr, size); if (ret < 0) { @@ -302,7 +333,7 @@ static int k3_r5f_load(struct udevice *dev, ulong addr, ulong size)
boot_vector = rproc_elf_get_boot_addr(dev, addr);
- dev_dbg(dev, "%s: Boot vector = 0x%x\n", __func__, boot_vector); + dev_dbg(dev, "%s: Boot vector = 0x%llx\n", __func__, boot_vector);
ret = ti_sci_proc_set_config(&core->tsp, boot_vector, 0, 0);
@@ -657,6 +688,8 @@ static int k3_r5f_of_to_priv(struct k3_r5f_core *core) return ret; }
+ core->ipdata = (struct k3_r5f_ip_data *)dev_get_driver_data(core->dev); + return 0; }
@@ -702,6 +735,38 @@ static int k3_r5f_core_of_get_memories(struct k3_r5f_core *core) return 0; }
+/* + * Each R5F core within a typical R5FSS instance has a total of 64 KB of TCMs, + * split equally into two 32 KB banks between ATCM and BTCM. The TCMs from both + * cores are usable in Split-mode, but only the Core0 TCMs can be used in + * LockStep-mode. The newer revisions of the R5FSS IP maximizes these TCMs by + * leveraging the Core1 TCMs as well in certain modes where they would have + * otherwise been unusable (Eg: LockStep-mode on J7200 SoCs). This is done by + * making a Core1 TCM visible immediately after the corresponding Core0 TCM. + * The SoC memory map uses the larger 64 KB sizes for the Core0 TCMs, and the + * dts representation reflects this increased size on supported SoCs. The Core0 + * TCM sizes therefore have to be adjusted to only half the original size in + * Split mode. + */ +static void k3_r5f_core_adjust_tcm_sizes(struct k3_r5f_core *core) +{ + struct k3_r5f_cluster *cluster = core->cluster; + + if (cluster->mode == CLUSTER_MODE_LOCKSTEP) + return; + + if (!core->ipdata->tcm_is_double) + return; + + if (core == cluster->cores[0]) { + core->mem[0].size /= 2; + core->mem[1].size /= 2; + + dev_dbg(core->dev, "adjusted TCM sizes, ATCM = 0x%zx BTCM = 0x%zx\n", + core->mem[0].size, core->mem[1].size); + } +} + /** * k3_r5f_probe() - Basic probe * @dev: corresponding k3 remote processor device @@ -755,6 +820,8 @@ static int k3_r5f_probe(struct udevice *dev) return ret; }
+ k3_r5f_core_adjust_tcm_sizes(core); + dev_dbg(dev, "Remoteproc successfully probed\n");
return 0; @@ -771,9 +838,20 @@ static int k3_r5f_remove(struct udevice *dev) return 0; }
+static const struct k3_r5f_ip_data k3_data = { + .tcm_is_double = false, + .tcm_ecc_autoinit = false, +}; + +static const struct k3_r5f_ip_data j7200_data = { + .tcm_is_double = true, + .tcm_ecc_autoinit = true, +}; + static const struct udevice_id k3_r5f_rproc_ids[] = { - { .compatible = "ti,am654-r5f"}, - { .compatible = "ti,j721e-r5f"}, + { .compatible = "ti,am654-r5f", .data = (ulong)&k3_data, }, + { .compatible = "ti,j721e-r5f", .data = (ulong)&k3_data, }, + { .compatible = "ti,j7200-r5f", .data = (ulong)&j7200_data, }, {} };
@@ -810,6 +888,7 @@ static int k3_r5f_cluster_probe(struct udevice *dev) static const struct udevice_id k3_r5fss_ids[] = { { .compatible = "ti,am654-r5fss"}, { .compatible = "ti,j721e-r5fss"}, + { .compatible = "ti,j7200-r5fss"}, {} };
The A72 U-Boot code can load and boot a number of the available R5FSS Cores on the J7200 SoC. Change the memory attributes for the DDR regions used by the remote processors so that the cores can see and execute the proper code.
The J7200 SoC has less number of remote processors compared to J721E, so use less memory for the remote processors. So, a separate table based on the current J721E table is added for J7200 SoCs, and selected using the appropriate Kconfig CONFIG_TARGET_J7200_A72_EVM symbol.
Signed-off-by: Suman Anna s-anna@ti.com --- arch/arm/mach-k3/arm64-mmu.c | 59 +++++++++++++++++++++++++++++++++++- 1 file changed, 58 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-k3/arm64-mmu.c b/arch/arm/mach-k3/arm64-mmu.c index 95f830b7ffe4..a0da3df59388 100644 --- a/arch/arm/mach-k3/arm64-mmu.c +++ b/arch/arm/mach-k3/arm64-mmu.c @@ -2,8 +2,9 @@ /* * K3: ARM64 MMU setup * - * Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/ + * Copyright (C) 2018-2020 Texas Instruments Incorporated - https://www.ti.com/ * Lokesh Vutla lokeshvutla@ti.com + * Suman Anna s-anna@ti.com * (This file is derived from arch/arm/mach-zynqmp/cpu.c) * */ @@ -66,6 +67,8 @@ struct mm_region *mem_map = am654_mem_map; #endif /* CONFIG_SOC_K3_AM6 */
#ifdef CONFIG_SOC_K3_J721E + +#ifdef CONFIG_TARGET_J721E_A72_EVM /* NR_DRAM_BANKS + 32bit IO + 64bit IO + terminator */ #define NR_MMU_REGIONS (CONFIG_NR_DRAM_BANKS + 6)
@@ -122,4 +125,58 @@ struct mm_region j721e_mem_map[NR_MMU_REGIONS] = { };
struct mm_region *mem_map = j721e_mem_map; +#endif /* CONFIG_TARGET_J721E_A72_EVM */ + +#ifdef CONFIG_TARGET_J7200_A72_EVM +#define NR_MMU_REGIONS (CONFIG_NR_DRAM_BANKS + 5) + +/* ToDo: Add 64bit IO */ +struct mm_region j7200_mem_map[NR_MMU_REGIONS] = { + { + .virt = 0x0UL, + .phys = 0x0UL, + .size = 0x80000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + .virt = 0x80000000UL, + .phys = 0x80000000UL, + .size = 0x20000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + .virt = 0xa0000000UL, + .phys = 0xa0000000UL, + .size = 0x04800000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL_NC) | + PTE_BLOCK_NON_SHARE + }, { + .virt = 0xa4800000UL, + .phys = 0xa4800000UL, + .size = 0x5b800000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + .virt = 0x880000000UL, + .phys = 0x880000000UL, + .size = 0x80000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + .virt = 0x500000000UL, + .phys = 0x500000000UL, + .size = 0x400000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + /* List terminator */ + 0, + } +}; + +struct mm_region *mem_map = j7200_mem_map; +#endif /* CONFIG_TARGET_J7200_A72_EVM */ + #endif /* CONFIG_SOC_K3_J721E */
The J7200 SoCs have 2 dual-core Arm Cortex-R5F processor (R5FSS) subsystems/clusters. One R5F cluster is present within the MCU domain (MCU_R5FSS0), and the other one is present within the MAIN domain (MAIN_R5FSS0). Each of these can be configured at boot time to be either run in a LockStep mode or in an Asymmetric Multi Processing (AMP) fashion in Split-mode. These subsystems have 64 KB each Tightly-Coupled Memory (TCM) internal memories for each core split between two banks - ATCM and BTCM (further interleaved into two banks). The TCMs of both Cores are combined in LockStep-mode to provide a larger 128 KB of memory.
Add the DT node for the MCU domain R5F cluster/subsystem, the two R5F cores are added as child nodes to the main cluster/subsystem node. The cluster is configured to run in LockStep mode by default, with the ATCMs enabled to allow the R5 cores to execute code from DDR with boot-strapping code from ATCM. The inter-processor communication between the main A72 cores and these processors is achieved through shared memory and Mailboxes.
Signed-off-by: Suman Anna s-anna@ti.com --- arch/arm/dts/k3-j7200-common-proc-board.dts | 5 +++ arch/arm/dts/k3-j7200-mcu-wakeup.dtsi | 40 +++++++++++++++++++++ 2 files changed, 45 insertions(+)
diff --git a/arch/arm/dts/k3-j7200-common-proc-board.dts b/arch/arm/dts/k3-j7200-common-proc-board.dts index 3f1d03c96037..b48588952513 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-common-proc-board.dts @@ -13,6 +13,11 @@ stdout-path = "serial2:115200n8"; bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000"; }; + + aliases { + remoteproc0 = &mcu_r5fss0_core0; + remoteproc1 = &mcu_r5fss0_core1; + }; };
&wkup_pmx0 { diff --git a/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi b/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi index 4c899c8aca5d..75c0c8597dc9 100644 --- a/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi +++ b/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi @@ -269,4 +269,44 @@ ti,cpts-periodic-outputs = <2>; }; }; + + mcu_r5fss0: r5fss@41000000 { + compatible = "ti,j7200-r5fss"; + lockstep-mode = <1>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x41000000 0x00 0x41000000 0x20000>, + <0x41400000 0x00 0x41400000 0x20000>; + power-domains = <&k3_pds 249 TI_SCI_PD_EXCLUSIVE>; + + mcu_r5fss0_core0: r5f@41000000 { + compatible = "ti,j7200-r5f"; + reg = <0x41000000 0x00010000>, + <0x41010000 0x00010000>; + reg-names = "atcm", "btcm"; + ti,sci = <&dmsc>; + ti,sci-dev-id = <250>; + ti,sci-proc-ids = <0x01 0xff>; + resets = <&k3_reset 250 1>; + firmware-name = "j7200-mcu-r5f0_0-fw"; + atcm-enable = <1>; + btcm-enable = <1>; + loczrama = <1>; + }; + + mcu_r5fss0_core1: r5f@41400000 { + compatible = "ti,j7200-r5f"; + reg = <0x41400000 0x00008000>, + <0x41410000 0x00008000>; + reg-names = "atcm", "btcm"; + ti,sci = <&dmsc>; + ti,sci-dev-id = <251>; + ti,sci-proc-ids = <0x02 0xff>; + resets = <&k3_reset 251 1>; + firmware-name = "j7200-mcu-r5f0_1-fw"; + atcm-enable = <1>; + btcm-enable = <1>; + loczrama = <1>; + }; + }; };
Add the DT node for the MAIN domain R5F cluster/subsystem, the two R5F cores are added as child nodes to the main cluster/subsystem node. The cluster is configured to run in Split-mode by default, with the ATCMs enabled to allow the R5 cores to execute code from DDR with boot-strapping code from ATCM. The inter-processor communication between the main A72 cores and these processors is achieved through shared memory and Mailboxes.
Signed-off-by: Suman Anna s-anna@ti.com --- arch/arm/dts/k3-j7200-common-proc-board.dts | 2 ++ arch/arm/dts/k3-j7200-main.dtsi | 40 +++++++++++++++++++++ 2 files changed, 42 insertions(+)
diff --git a/arch/arm/dts/k3-j7200-common-proc-board.dts b/arch/arm/dts/k3-j7200-common-proc-board.dts index b48588952513..cc3d933cbb51 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-common-proc-board.dts @@ -17,6 +17,8 @@ aliases { remoteproc0 = &mcu_r5fss0_core0; remoteproc1 = &mcu_r5fss0_core1; + remoteproc2 = &main_r5fss0_core0; + remoteproc3 = &main_r5fss0_core1; }; };
diff --git a/arch/arm/dts/k3-j7200-main.dtsi b/arch/arm/dts/k3-j7200-main.dtsi index aaa1fdd5a3ce..c25f03cf23d9 100644 --- a/arch/arm/dts/k3-j7200-main.dtsi +++ b/arch/arm/dts/k3-j7200-main.dtsi @@ -340,4 +340,44 @@ dr_mode = "otg"; }; }; + + main_r5fss0: r5fss@5c00000 { + compatible = "ti,j7200-r5fss"; + lockstep-mode = <0>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x5c00000 0x00 0x5c00000 0x20000>, + <0x5d00000 0x00 0x5d00000 0x20000>; + power-domains = <&k3_pds 243 TI_SCI_PD_EXCLUSIVE>; + + main_r5fss0_core0: r5f@5c00000 { + compatible = "ti,j7200-r5f"; + reg = <0x5c00000 0x00010000>, + <0x5c10000 0x00010000>; + reg-names = "atcm", "btcm"; + ti,sci = <&dmsc>; + ti,sci-dev-id = <245>; + ti,sci-proc-ids = <0x06 0xFF>; + resets = <&k3_reset 245 1>; + firmware-name = "j7200-main-r5f0_0-fw"; + atcm-enable = <1>; + btcm-enable = <1>; + loczrama = <1>; + }; + + main_r5fss0_core1: r5f@5d00000 { + compatible = "ti,j7200-r5f"; + reg = <0x5d00000 0x00008000>, + <0x5d10000 0x00008000>; + reg-names = "atcm", "btcm"; + ti,sci = <&dmsc>; + ti,sci-dev-id = <246>; + ti,sci-proc-ids = <0x07 0xFF>; + resets = <&k3_reset 246 1>; + firmware-name = "j7200-main-r5f0_1-fw"; + atcm-enable = <1>; + btcm-enable = <1>; + loczrama = <1>; + }; + }; };
The J7200 SoCs have different number of remote processors, but reuse the same environment settings as the J721E SoCs. The current env variable rproc_fw_binaries is geared towards J721E SoCs and is incorrect for J7200 SoCs. Please see the logic originally added in commit 0b4ab9c9a754 ("env: ti: j721e-evm: Add support to boot rprocs including R5Fs and DSPs").
Fix this by defining the DEFAULT_RPROCS macro appropriately using the corresponding TARGET_EVM Kconfig symbol. This macro is used by the 'rproc_fw_binaries' env variable in the common remoteproc env header file k3_rproc.h.
The list of R5F cores to be started before loading and booting the Linux kernel are as follows, and mainly comprises of the Main R5FSS0 cores in this order: Main R5FSS0 (Split) Core0 : 2 /lib/firmware/j7200-main-r5f0_0-fw Main R5FSS0 (Split) Core1 : 3 /lib/firmware/j7200-main-r5f0_1-fw
The MCU R5FSS0 is in LockStep mode and is expected to be booted by R5 SPL, so it is not included in the list. The order of rprocs to boot cannot be really modified as only the Main R5FSS0 cores are involved and Core0 has to be booted first always before the corresponding Core1.
Signed-off-by: Suman Anna s-anna@ti.com --- include/configs/j721e_evm.h | 14 +++++++++++++- 1 file changed, 13 insertions(+), 1 deletion(-)
diff --git a/include/configs/j721e_evm.h b/include/configs/j721e_evm.h index cddcd7a00d37..dc06de234154 100644 --- a/include/configs/j721e_evm.h +++ b/include/configs/j721e_evm.h @@ -2,7 +2,7 @@ /* * Configuration header file for K3 J721E EVM * - * Copyright (C) 2018-2019 Texas Instruments Incorporated - http://www.ti.com/ + * Copyright (C) 2018-2020 Texas Instruments Incorporated - https://www.ti.com/ * Lokesh Vutla lokeshvutla@ti.com */
@@ -116,9 +116,14 @@ "${bootdir}/${name_fit}\0" \ "partitions=" PARTS_DEFAULT
+/* Set the default list of remote processors to boot */ +#if defined(CONFIG_TARGET_J721E_A72_EVM) || defined(CONFIG_TARGET_J7200_A72_EVM) #ifdef DEFAULT_RPROCS #undef DEFAULT_RPROCS #endif +#endif + +#ifdef CONFIG_TARGET_J721E_A72_EVM #define DEFAULT_RPROCS "" \ "3 /lib/firmware/j7-main-r5f0_1-fw " \ "4 /lib/firmware/j7-main-r5f1_0-fw " \ @@ -126,6 +131,13 @@ "6 /lib/firmware/j7-c66_0-fw " \ "7 /lib/firmware/j7-c66_1-fw " \ "8 /lib/firmware/j7-c71_0-fw " +#endif /* CONFIG_TARGET_J721E_A72_EVM */ + +#ifdef CONFIG_TARGET_J7200_A72_EVM +#define DEFAULT_RPROCS "" \ + "2 /lib/firmware/j7200-main-r5f0_0-fw " \ + "3 /lib/firmware/j7200-main-r5f0_1-fw " +#endif /* CONFIG_TARGET_J7200_A72_EVM */
/* set default dfu_bufsiz to 128KB (sector size of OSPI) */ #define EXTRA_ENV_DFUARGS \
The J7200 SoCs has two R5F sub-systems. Enable the TI K3 R5F remoteproc driver and the remoteproc command options to allow these R5F processors to be booted from A72 U-Boot.
The Kconfigs are added using savedefconfig.
Signed-off-by: Suman Anna s-anna@ti.com --- configs/j7200_evm_a72_defconfig | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/configs/j7200_evm_a72_defconfig b/configs/j7200_evm_a72_defconfig index 6e854648eb45..52440a09a647 100644 --- a/configs/j7200_evm_a72_defconfig +++ b/configs/j7200_evm_a72_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_J721E=y CONFIG_TARGET_J7200_A72_EVM=y CONFIG_ENV_SIZE=0x20000 @@ -16,7 +17,6 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_NR_DRAM_BANKS=2 CONFIG_ENV_OFFSET_REDUND=0x6A0000 CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y @@ -61,6 +61,7 @@ CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_MTD=y +CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_UFS=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y @@ -140,6 +141,7 @@ CONFIG_POWER_DOMAIN=y CONFIG_TI_SCI_POWER_DOMAIN=y CONFIG_RAM=y CONFIG_SPL_RAM=y +CONFIG_REMOTEPROC_TI_K3_R5F=y CONFIG_DM_RESET=y CONFIG_RESET_TI_SCI=y CONFIG_SCSI=y
The A72 U-boot can support early booting of any of the Main or MCU R5F remote processors from U-boot prompt to achieve various system usecases before booting the Linux kernel. Update the default BOOTCOMMAND to provide an automatic and easier way to start various remote processors through added environment variables.
Signed-off-by: Suman Anna s-anna@ti.com --- configs/j7200_evm_a72_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/j7200_evm_a72_defconfig b/configs/j7200_evm_a72_defconfig index 52440a09a647..3572d7ba9414 100644 --- a/configs/j7200_evm_a72_defconfig +++ b/configs/j7200_evm_a72_defconfig @@ -30,7 +30,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y -CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" +CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y
On 18/08/20 4:45 am, Suman Anna wrote:
Hi Lokesh,
- Modes
Applied to u-boot-ti next branch.
Thanks and regards, Lokesh
Lokesh Vutla
Suman Anna
