[PATCH 0/2] mmc: Add support for F_SDH30_E51
This series adds a new quirk "SUPPORT_SINGLE" for single transaction to sdhci framework and Socionext F_SDH30_E51 IP support to f_sdh30 driver.
Kunihiko Hayashi (2): mmc: sdhci: Add new quirks for SUPPORT_SINGLE mmc: f_sdh30: Add support for F_SDH30_E51
drivers/mmc/Kconfig | 4 +-- drivers/mmc/f_sdh30.c | 64 +++++++++++++++++++++++++++++++++++++++++-- drivers/mmc/sdhci.c | 8 ++++-- include/sdhci.h | 1 + 4 files changed, 70 insertions(+), 7 deletions(-)
This patch defines a quirk to disable the block count for single block transactions.
This is similar to Linux kernel commit d3fc5d71ac4d ("mmc: sdhci: add a quirk for single block transactions").
Signed-off-by: Kunihiko Hayashi hayashi.kunihiko@socionext.com --- drivers/mmc/sdhci.c | 8 +++++--- include/sdhci.h | 1 + 2 files changed, 6 insertions(+), 3 deletions(-)
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index bf989a594f7e..a80ad8329a38 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -211,7 +211,7 @@ static int sdhci_send_command(struct mmc *mmc, struct mmc_cmd *cmd, unsigned int stat = 0; int ret = 0; int trans_bytes = 0, is_aligned = 1; - u32 mask, flags, mode; + u32 mask, flags, mode = 0; unsigned int time = 0; int mmc_dev = mmc_get_blk_desc(mmc)->devnum; ulong start = get_timer(0); @@ -273,10 +273,12 @@ static int sdhci_send_command(struct mmc *mmc, struct mmc_cmd *cmd, /* Set Transfer mode regarding to data flag */ if (data) { sdhci_writeb(host, 0xe, SDHCI_TIMEOUT_CONTROL); - mode = SDHCI_TRNS_BLK_CNT_EN; + + if (!(host->quirks & SDHCI_QUIRK_SUPPORT_SINGLE)) + mode = SDHCI_TRNS_BLK_CNT_EN; trans_bytes = data->blocks * data->blocksize; if (data->blocks > 1) - mode |= SDHCI_TRNS_MULTI; + mode |= SDHCI_TRNS_MULTI | SDHCI_TRNS_BLK_CNT_EN;
if (data->flags == MMC_DATA_READ) mode |= SDHCI_TRNS_READ; diff --git a/include/sdhci.h b/include/sdhci.h index 88f1917480b6..24b4599b857d 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -247,6 +247,7 @@ #define SDHCI_QUIRK_WAIT_SEND_CMD (1 << 6) #define SDHCI_QUIRK_USE_WIDE8 (1 << 8) #define SDHCI_QUIRK_NO_1_8_V (1 << 9) +#define SDHCI_QUIRK_SUPPORT_SINGLE (1 << 10)
/* to make gcc happy */ struct sdhci_host;
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
- u32 mask, flags, mode = 0; unsigned int time = 0; int mmc_dev = mmc_get_blk_desc(mmc)->devnum; ulong start = get_timer(0);
trans_bytes = data->blocks * data->blocksize; if (data->blocks > 1)mode = SDHCI_TRNS_BLK_CNT_EN;
Add Socionext F_SDH30_E51 IP support. The features of this IP includes CMD/DAT line delay and force card insertion mode for non-removable cards. And the IP needs to add some quirks.
Signed-off-by: Kunihiko Hayashi hayashi.kunihiko@socionext.com --- drivers/mmc/Kconfig | 4 +-- drivers/mmc/f_sdh30.c | 64 +++++++++++++++++++++++++++++++++++++++++-- 2 files changed, 64 insertions(+), 4 deletions(-)
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 0dcec8adcee8..c30f20cba5f2 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -577,12 +577,12 @@ config MMC_SDHCI_IPROC If unsure, say N.
config MMC_SDHCI_F_SDH30 - bool "SDHCI support for Fujitsu Semiconductor F_SDH30" + bool "SDHCI support for Fujitsu Semiconductor/Socionext F_SDH30" depends on BLK && DM_MMC depends on MMC_SDHCI help This selects the Secure Digital Host Controller Interface (SDHCI) - Needed by some Fujitsu SoC for MMC / SD / SDIO support. + Needed by some Fujitsu/Socionext SoC for MMC / SD / SDIO support. If you have a controller with this interface, say Y or M here. If unsure, say N.
diff --git a/drivers/mmc/f_sdh30.c b/drivers/mmc/f_sdh30.c index 3a85d9e348ab..6b950edab74e 100644 --- a/drivers/mmc/f_sdh30.c +++ b/drivers/mmc/f_sdh30.c @@ -11,13 +11,46 @@ #include <malloc.h> #include <sdhci.h>
+#define F_SDH30_ESD_CONTROL 0x124 +#define F_SDH30_CMD_DAT_DELAY BIT(9) + +#define F_SDH30_TEST 0x158 +#define F_SDH30_FORCE_CARD_INSERT BIT(6) + +struct f_sdh30_data { + void (*init)(struct udevice *dev); + u32 quirks; +}; + struct f_sdh30_plat { struct mmc_config cfg; struct mmc mmc; + + bool enable_cmd_dat_delay; + const struct f_sdh30_data *data; };
DECLARE_GLOBAL_DATA_PTR;
+static void f_sdh30_e51_init(struct udevice *dev) +{ + struct f_sdh30_plat *plat = dev_get_plat(dev); + struct sdhci_host *host = dev_get_priv(dev); + u32 val; + + if (plat->enable_cmd_dat_delay) { + val = sdhci_readl(host, F_SDH30_ESD_CONTROL); + val |= F_SDH30_CMD_DAT_DELAY; + sdhci_writel(host, val, F_SDH30_ESD_CONTROL); + } + + if (plat->cfg.host_caps & MMC_CAP_NONREMOVABLE) { + val = sdhci_readl(host, F_SDH30_TEST); + val |= F_SDH30_FORCE_CARD_INSERT; + sdhci_writel(host, val, F_SDH30_TEST); + } +} + static int f_sdh30_sdhci_probe(struct udevice *dev) { struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); @@ -25,6 +58,8 @@ static int f_sdh30_sdhci_probe(struct udevice *dev) struct sdhci_host *host = dev_get_priv(dev); int ret;
+ plat->data = (const struct f_sdh30_data *)dev_get_driver_data(dev); + ret = mmc_of_parse(dev, &plat->cfg); if (ret) return ret; @@ -33,6 +68,9 @@ static int f_sdh30_sdhci_probe(struct udevice *dev) host->mmc->dev = dev; host->mmc->priv = host;
+ if (plat->data && plat->data->quirks) + host->quirks |= plat->data->quirks; + ret = sdhci_setup_cfg(&plat->cfg, host, 200000000, 400000); if (ret) return ret; @@ -41,18 +79,29 @@ static int f_sdh30_sdhci_probe(struct udevice *dev)
mmc_set_clock(host->mmc, host->mmc->cfg->f_min, MMC_CLK_ENABLE);
- return sdhci_probe(dev); + ret = sdhci_probe(dev); + if (ret) + return ret; + + if (plat->data && plat->data->init) + plat->data->init(dev); + + return 0; }
static int f_sdh30_of_to_plat(struct udevice *dev) { struct sdhci_host *host = dev_get_priv(dev); + struct f_sdh30_plat *plat = dev_get_plat(dev);
host->name = strdup(dev->name); host->ioaddr = dev_read_addr_ptr(dev); host->bus_width = dev_read_u32_default(dev, "bus-width", 4); host->index = dev_read_u32_default(dev, "index", 0);
+ plat->enable_cmd_dat_delay = + dev_read_bool(dev, "socionext,enable-cmd-dat-delay"); + return 0; }
@@ -63,8 +112,19 @@ static int f_sdh30_bind(struct udevice *dev) return sdhci_bind(dev, &plat->mmc, &plat->cfg); }
+static const struct f_sdh30_data f_sdh30_e51_data = { + .init = f_sdh30_e51_init, + .quirks = SDHCI_QUIRK_WAIT_SEND_CMD | SDHCI_QUIRK_SUPPORT_SINGLE, +}; + static const struct udevice_id f_sdh30_mmc_ids[] = { - { .compatible = "fujitsu,mb86s70-sdhci-3.0" }, + { + .compatible = "fujitsu,mb86s70-sdhci-3.0", + }, + { + .compatible = "socionext,f-sdh30-e51-mmc", + .data = (ulong)&f_sdh30_e51_data, + }, { } };
- bool "SDHCI support for Fujitsu Semiconductor/Socionext F_SDH30" depends on BLK && DM_MMC depends on MMC_SDHCI help This selects the Secure Digital Host Controller Interface (SDHCI)
If you have a controller with this interface, say Y or M here. If unsure, say N.Needed by some Fujitsu/Socionext SoC for MMC / SD / SDIO support.
- void (*init)(struct udevice *dev);
- u32 quirks;
- bool enable_cmd_dat_delay;
- const struct f_sdh30_data *data;
- struct f_sdh30_plat *plat = dev_get_plat(dev);
- struct sdhci_host *host = dev_get_priv(dev);
- u32 val;
- if (plat->enable_cmd_dat_delay) {
Is there a case to set its regardless of enable_cmd_dat_delay?
how about below?
if (plat->enable_cmd_dat_delay) val |= F_SDH30_CMD_DAT_DELAY; else val &= ~F_SDH30_CMD_DAT_DELAY;
- if (plat->cfg.host_caps & MMC_CAP_NONREMOVABLE) {
Ditto.
- plat->data = (const struct f_sdh30_data *)dev_get_driver_data(dev);
- ret = mmc_of_parse(dev, &plat->cfg); if (ret) return ret;
- if (plat->data && plat->data->quirks)
Doesn't need to use "|" ?
- ret = sdhci_setup_cfg(&plat->cfg, host, 200000000, 400000); if (ret) return ret;
- ret = sdhci_probe(dev);
- if (ret)
return ret;
- if (plat->data && plat->data->init)
- .init = f_sdh30_e51_init,
- .quirks = SDHCI_QUIRK_WAIT_SEND_CMD | SDHCI_QUIRK_SUPPORT_SINGLE,
Hi Jaehoon, Thank you for checking.
(snip)
- u32 val;
how about below?
Yes, I forgot the false case. Need to add it.
Ditto.
I'll fix it too.
- static int f_sdh30_sdhci_probe(struct udevice *dev) { struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev);
I thought there was some premise in "host", however, this is a private structure allocated by calloc() before probing the driver. I can remove "|".
Thank you,
--- Best Regards Kunihiko Hayashi
Jaehoon Chung
Kunihiko Hayashi
