[U-Boot] [PATCH] dm: serial: Add .pre_probe() function to to wait for previous transmission end
It may happen that the serial IP block is performing some ongoing transmission (started at e.g. board_init()) when the serial "probe" is called.
As a result the serial port IP block is reset, so transmitted data is corrupted:
I2C: ready DRAM: 1 GiB jSS('HH��SL_SDHC: 04 rev 0x0
This patch prevents from this situation, by defining pre_probe() callback in which we wait till the TX buffer is empty (from previous transmission):
I2C: ready DRAM: 1 GiB ID: unit type 0x4 rev 0x0
All defined ->pending callbacks at ./drivers/serial are non blocking - just simple reading from registers and testing flags. Hence, it should be enough to not use any timeout from timer. One shall also note that we enable console very early - not all timers may be ready for work - adding timeout here would impose implicit dependency that timers are setup before serial.
Signed-off-by: Lukasz Majewski lukma@denx.de ---
drivers/serial/serial-uclass.c | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/drivers/serial/serial-uclass.c b/drivers/serial/serial-uclass.c index 2e5116f..5e6964d 100644 --- a/drivers/serial/serial-uclass.c +++ b/drivers/serial/serial-uclass.c @@ -420,10 +420,30 @@ static int serial_pre_remove(struct udevice *dev) return 0; }
+static int serial_pre_probe(struct udevice *dev) +{ + struct dm_serial_ops *ops = serial_get_ops(dev); + int ret = 0; + + /* + * Wait for any ongoing transmission to finish - for example + * from pre-relocation enabled UART + */ + if (ops && ops->pending) + do { + ret = ops->pending(dev, false); + if (ret < 0) + break; + } while (ret > 0); + + return ret; +} + UCLASS_DRIVER(serial) = { .id = UCLASS_SERIAL, .name = "serial", .flags = DM_UC_FLAG_SEQ_ALIAS, + .pre_probe = serial_pre_probe, .post_probe = serial_post_probe, .pre_remove = serial_pre_remove, .per_device_auto_alloc_size = sizeof(struct serial_dev_priv),
Given that this is effectively a busy polling loop, why can’t this be done from the probe-function of serial drivers that require this functionality?
- struct dm_serial_ops *ops = serial_get_ops(dev);
- int ret = 0;
- if (ops && ops->pending)
do {
if (ret < 0)
break;
} while (ret > 0);
- return ret;
- .pre_probe = serial_pre_probe, .post_probe = serial_post_probe, .pre_remove = serial_pre_remove, .per_device_auto_alloc_size = sizeof(struct serial_dev_priv),
-- 2.1.4
Hi Philipp,
That would be one of the options.
Originally, this code was placed at iMX specific function - namely _mxc_serial_init() [1].
However, Simon suggested to solve this problem globally via DM's serial-uclass, which offers pre_probe() callback for such purpose.
The problem here is the polling loop. I've checked and ->pending on real SoCs is just a read from the register - which should not block (a similar approach is used in Linux kernel).
Having timeout from timer would impose dependency on timer init'ed first - before serial.
[1] - https://patchwork.ozlabs.org/patch/820824/
- int ret = 0;
example
do {
if (ret < 0)
break;
} while (ret > 0);
- return ret;
serial_dev_priv), -- 2.1.4
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
Hi Lukasz,
I worry a bit about the pending-callback being called prior to a probe. As of today, the pending function can assume that probe() has run and initialised the private structures accordingly—with this change, that assumption is invalidated.
If we go down this path, then we need to clearly indicate that the pending function can not rely on probe() to have initialised the device state or private data structures. If we keep this check within the probe()-function, it should be obvious what is set up and what isn’t.
- int ret = 0;
example
do {
if (ret < 0)
break;
} while (ret > 0);
- return ret;
Lukasz Majewski
Hi Philipp,
Hi Lukasz,
Yes. I agree.
Other issue is that we may need timer based timeout for some SoCs. And this also implies to have timer initialized before the console.
Those are valid arguments.
I would even go further and leave this patch as it was in the first version [1] - since:
- It is similar to what Linux does - for iMX it uses check on HW bit which is guarantee to be cleared in some point of time (of course if HW is not broken).
However, lets wait for input from Simon - how he would like to tackle this issue.
- int ret = 0;
example
do {
if (ret < 0)
break;
} while (ret > 0);
- return ret;
Lukasz Majewski
Lukasz Majewski
Dear All,
Hi Philipp,
Hi Lukasz,
Yes. I agree.
Unfortunately, I did not received any feedback from Simon.
Hence, I would opt for discarding this particular patch and use the v1 of it (please find the rationale above):
Has anybody disagree?
- int ret = 0;
example
do {
if (ret < 0)
break;
} while (ret > 0);
- return ret;
Lukasz Majewski
Lukasz Majewski
Lukasz Majewski
Hi Lukasz,
On 4 November 2017 at 15:42, Lukasz Majewski lukma@denx.de wrote:
Dear All,
Hi Philipp,
Hi Lukasz,
Yes. I agree.
I think this patch is useful, but I agree it needs to be documented.
You could add a comment to the pending function in serial.h saying it can be called before probe. This would only really work if the driver was inited previously though.
Would it be better instead to have a function in board_f.c somewhere which loops on each serial device waiting for the pending function to return 0? Then you know that the driver has been probed, and before relocation too, so it should be safe.
I have seen this problem on other boards so I do favour a generic solution if we can figure this out.
int ret = 0;
example
do {
if (ret < 0)
break;
} while (ret > 0);
return ret;
Lukasz Majewski
Lukasz Majewski
Lukasz Majewski
Hi Simon,
Hi Lukasz,
Dear All,
Hi Philipp,
Hi Lukasz,
> On 27 Oct 2017, at 00:13, Lukasz Majewski lukma@denx.de > wrote: > > It may happen that the serial IP block is performing some > ongoing transmission (started at e.g. board_init()) when the > serial "probe" is called. > > As a result the serial port IP block is reset, so > transmitted data is corrupted: > > I2C: ready > DRAM: 1 GiB > jSS('HH��SL_SDHC: 04 rev 0x0 > > This patch prevents from this situation, by defining > pre_probe() callback in which we wait till the TX buffer is > empty (from previous transmission): > > I2C: ready > DRAM: 1 GiB > ID: unit type 0x4 rev 0x0 > > All defined ->pending callbacks at ./drivers/serial are non > blocking > - just simple reading from registers and testing flags. > Hence, it should be enough to not use any timeout from > timer. One shall also note that we enable console very > early - not all timers may be ready for work - adding > timeout here would impose implicit dependency that timers > are setup before serial.
Yes. I agree.
Hmm... Ok. I will try with this approach.
Thanks for the tip.
> > > Signed-off-by: Lukasz Majewski lukma@denx.de > --- > > drivers/serial/serial-uclass.c | 20 ++++++++++++++++++++ > 1 file changed, 20 insertions(+) > > diff --git a/drivers/serial/serial-uclass.c > b/drivers/serial/serial-uclass.c index 2e5116f..5e6964d > 100644 --- a/drivers/serial/serial-uclass.c > +++ b/drivers/serial/serial-uclass.c > @@ -420,10 +420,30 @@ static int serial_pre_remove(struct > udevice *dev) return 0; > } > > +static int serial_pre_probe(struct udevice *dev) > +{ > + struct dm_serial_ops *ops = serial_get_ops(dev); > + int ret = 0; > + > + /* > + * Wait for any ongoing transmission to finish - for > example > + * from pre-relocation enabled UART > + */ > + if (ops && ops->pending) > + do { > + ret = ops->pending(dev, false); > + if (ret < 0) > + break; > + } while (ret > 0); > + > + return ret; > +} > + > UCLASS_DRIVER(serial) = { > .id = UCLASS_SERIAL, > .name = "serial", > .flags = DM_UC_FLAG_SEQ_ALIAS, > + .pre_probe = serial_pre_probe, > .post_probe = serial_post_probe, > .pre_remove = serial_pre_remove, > .per_device_auto_alloc_size = sizeof(struct > serial_dev_priv), -- > 2.1.4 >
Lukasz Majewski
Lukasz Majewski
Lukasz Majewski
Lukasz Majewski
Dr. Philipp Tomsich
Lukasz Majewski
