[U-Boot] [PATCH v2] OneNAND: Bad block aware read/write command support
Update OneNAND command to support bad block awareness. Also change the OneNAND command style to better match the NAND version.
Signed-off-by: Stefan Roese sr@denx.de Acked-by: Kyungmin Park kyungmin.park@samsung.com --- v2: - Removed the bad block marking when an erase/read/write access to a block fails - More cleanup's
common/cmd_onenand.c | 529 +++++++++++++++++++++++++++++++++++++++----------- 1 files changed, 419 insertions(+), 110 deletions(-)
diff --git a/common/cmd_onenand.c b/common/cmd_onenand.c index 8d87b78..a490ef7 100644 --- a/common/cmd_onenand.c +++ b/common/cmd_onenand.c @@ -1,7 +1,7 @@ /* * U-Boot command for OneNAND support * - * Copyright (C) 2005-2007 Samsung Electronics + * Copyright (C) 2005-2008 Samsung Electronics * Kyungmin Park kyungmin.park@samsung.com * * This program is free software; you can redistribute it and/or modify @@ -11,6 +11,7 @@
#include <common.h> #include <command.h> +#include <malloc.h>
#include <linux/mtd/compat.h> #include <linux/mtd/mtd.h> @@ -18,159 +19,467 @@
#include <asm/io.h>
-extern struct mtd_info onenand_mtd; -extern struct onenand_chip onenand_chip; +static struct mtd_info *mtd = &onenand_mtd; + +static loff_t next_ofs; +static loff_t skip_ofs; + +static inline int str2long(char *p, ulong *num) +{ + char *endptr; + + *num = simple_strtoul(p, &endptr, 16); + return (*p != '\0' && *endptr == '\0') ? 1 : 0; +} + +static int arg_off_size(int argc, char *argv[], ulong *off, size_t *size) +{ + if (argc >= 1) { + if (!(str2long(argv[0], off))) { + printf("'%s' is not a number\n", argv[0]); + return -1; + } + } else { + *off = 0; + } + + if (argc >= 2) { + if (!(str2long(argv[1], (ulong *)size))) { + printf("'%s' is not a number\n", argv[1]); + return -1; + } + } else { + *size = mtd->size - *off; + } + + if ((*off + *size) > mtd->size) { + printf("total chip size (0x%x) exceeded!\n", mtd->size); + return -1; + } + + if (*size == mtd->size) + puts("whole chip\n"); + else + printf("offset 0x%lx, size 0x%x\n", *off, *size); + + return 0; +} + +static int onenand_block_read(loff_t from, size_t len, + size_t *retlen, u_char *buf, int oob) +{ + struct onenand_chip *this = mtd->priv; + int blocks = (int) len >> this->erase_shift; + int blocksize = (1 << this->erase_shift); + loff_t ofs = from; + struct mtd_oob_ops ops = { + .retlen = 0, + }; + int ret, dump = 0; + + if (oob) + ops.ooblen = blocksize; + else + ops.len = blocksize; + + while (blocks) { + ret = mtd->block_isbad(mtd, ofs); + if (ret) { + printk("Bad blocks %d at 0x%x\n", + (u32)(ofs >> this->erase_shift), (u32)ofs); + ofs += blocksize; + continue; + } + + if (oob) + ops.oobbuf = buf; + else + ops.datbuf = buf; + + ops.retlen = 0; + ret = mtd->read_oob(mtd, ofs, &ops); + if (ret) { + printk("Read failed 0x%x, %d", (u32)ofs, ret); + ofs += blocksize; + continue; + } + ofs += blocksize; + buf += blocksize; + blocks--; + *retlen += ops.retlen; + } + + return 0; +} + +static int onenand_block_write(loff_t to, size_t len, + size_t *retlen, const u_char * buf) +{ + struct onenand_chip *this = mtd->priv; + int blocks = len >> this->erase_shift; + int blocksize = (1 << this->erase_shift); + loff_t ofs; + size_t _retlen = 0; + int ret; + + if (to == next_ofs) { + next_ofs = to + len; + to += skip_ofs; + } else { + next_ofs = to + len; + skip_ofs = 0; + } + ofs = to; + + while (blocks) { + ret = mtd->block_isbad(mtd, ofs); + if (ret) { + printk("Bad blocks %d at 0x%x\n", + (u32)(ofs >> this->erase_shift), (u32)ofs); + skip_ofs += blocksize; + goto next; + } + + ret = mtd->write(mtd, ofs, blocksize, &_retlen, buf); + if (ret) { + printk("Write failed 0x%x, %d", (u32)ofs, ret); + skip_ofs += blocksize; + goto next; + } + + buf += blocksize; + blocks--; + *retlen += _retlen; +next: + ofs += blocksize; + } + + return 0; +} + +static int onenand_block_erase(u32 start, u32 size, int force) +{ + struct onenand_chip *this = mtd->priv; + struct erase_info instr = { + .callback = NULL, + }; + loff_t ofs; + int ret; + int blocksize = 1 << this->erase_shift; + + for (ofs = start; ofs < (start + size); ofs += blocksize) { + ret = mtd->block_isbad(mtd, ofs); + if (ret && !force) { + printf("Skip erase bad block %d at 0x%x\n", + (u32)(ofs >> this->erase_shift), (u32)ofs); + continue; + } + + instr.addr = ofs; + instr.len = blocksize; + instr.priv = force; + ret = mtd->erase(mtd, &instr); + if (ret) { + printf("erase failed block %d at 0x%x\n", + (u32)(ofs >> this->erase_shift), (u32)ofs); + continue; + } + } + + return 0; +} + +static int onenand_block_test(u32 start, u32 size) +{ + struct onenand_chip *this = mtd->priv; + struct erase_info instr = { + .callback = NULL, + .priv = 0, + }; + + int blocks; + loff_t ofs; + int blocksize = 1 << this->erase_shift; + int start_block, end_block; + size_t retlen; + u_char *buf; + u_char *verify_buf; + int ret; + + buf = malloc(blocksize); + if (!buf) { + printf("Not enough malloc space available!\n"); + return -1; + } + + verify_buf = malloc(blocksize); + if (!verify_buf) { + printf("Not enough malloc space available!\n"); + return -1; + } + + start_block = start >> this->erase_shift; + end_block = (start + size) >> this->erase_shift; + + /* Protect boot-loader from badblock testing */ + if (start_block < 2) + start_block = 2; + + if (end_block > (mtd->size >> this->erase_shift)) + end_block = mtd->size >> this->erase_shift; + + blocks = start_block; + ofs = start; + while (blocks < end_block) { + printf("\rTesting block %d at 0x%x", (u32)(ofs >> this->erase_shift), (u32)ofs); + + ret = mtd->block_isbad(mtd, ofs); + if (ret) { + printf("Skip erase bad block %d at 0x%x\n", + (u32)(ofs >> this->erase_shift), (u32)ofs); + goto next; + } + + instr.addr = ofs; + instr.len = blocksize; + ret = mtd->erase(mtd, &instr); + if (ret) { + printk("Erase failed 0x%x, %d", (u32)ofs, ret); + goto next; + } + + ret = mtd->write(mtd, ofs, blocksize, &retlen, buf); + if (ret) { + printk("Write failed 0x%x, %d", (u32)ofs, ret); + goto next; + } + + ret = mtd->read(mtd, ofs, blocksize, &retlen, verify_buf); + if (ret) { + printk("Read failed 0x%x, %d", (u32)ofs, ret); + goto next; + } + + if (memcmp(buf, verify_buf, blocksize)) + printk("\nRead/Write test failed at 0x%x\n", (u32)ofs); + +next: + ofs += blocksize; + blocks++; + } + printf("...Done\n"); + + free(buf); + free(verify_buf); + + return 0; +} + +static int onenand_dump(struct mtd_info *mtd, ulong off, int only_oob) +{ + int i; + u_char *datbuf, *oobbuf, *p; + struct mtd_oob_ops ops; + loff_t addr; + + datbuf = malloc(mtd->writesize + mtd->oobsize); + oobbuf = malloc(mtd->oobsize); + if (!datbuf || !oobbuf) { + puts("No memory for page buffer\n"); + return 1; + } + off &= ~(mtd->writesize - 1); + addr = (loff_t) off; + memset(&ops, 0, sizeof(ops)); + ops.datbuf = datbuf; + ops.oobbuf = oobbuf; /* must exist, but oob data will be appended to ops.datbuf */ + ops.len = mtd->writesize; + ops.ooblen = mtd->oobsize; + ops.retlen = 0; + i = mtd->read_oob(mtd, addr, &ops); + if (i < 0) { + printf("Error (%d) reading page %08lx\n", i, off); + free(datbuf); + free(oobbuf); + return 1; + } + printf("Page %08lx dump:\n", off); + i = mtd->writesize >> 4; + p = datbuf; + + while (i--) { + if (!only_oob) + printf("\t%02x %02x %02x %02x %02x %02x %02x %02x" + " %02x %02x %02x %02x %02x %02x %02x %02x\n", + p[0], p[1], p[2], p[3], p[4], p[5], p[6], p[7], + p[8], p[9], p[10], p[11], p[12], p[13], p[14], + p[15]); + p += 16; + } + puts("OOB:\n"); + i = mtd->oobsize >> 3; + while (i--) { + printf("\t%02x %02x %02x %02x %02x %02x %02x %02x\n", + p[0], p[1], p[2], p[3], p[4], p[5], p[6], p[7]); + p += 8; + } + free(datbuf); + free(oobbuf); + + return 0; +}
int do_onenand(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) { - int ret = 0; + struct onenand_chip *this; + int blocksize; + ulong addr, ofs; + size_t len, retlen = 0; + int ret; + char *cmd, *s; + + mtd = &onenand_mtd; + this = mtd->priv; + blocksize = (1 << this->erase_shift); + + cmd = argv[1];
switch (argc) { case 0: case 1: - printf("Usage:\n%s\n", cmdtp->usage); - return 1; + goto usage;
case 2: - if (strncmp(argv[1], "open", 4) == 0) { - onenand_init(); + if (strcmp(cmd, "info") == 0) { + printf("%s\n", mtd->name); + return 0; + } + + if (strcmp(cmd, "bad") == 0) { + /* Currently only one OneNAND device is supported */ + printf("\nDevice %d bad blocks:\n", 0); + for (ofs = 0; ofs < mtd->size; ofs += mtd->erasesize) { + if (mtd->block_isbad(mtd, ofs)) + printf(" %08x\n", (u32)ofs); + } + return 0; } - printf("%s\n", onenand_mtd.name); - return 0;
default: /* At least 4 args */ - if (strncmp(argv[1], "erase", 5) == 0) { - struct erase_info instr = { - .callback = NULL, - }; - ulong start, end; - ulong block; - char *endtail; - - if (strncmp(argv[2], "block", 5) == 0) { - start = simple_strtoul(argv[3], NULL, 10); - endtail = strchr(argv[3], '-'); - end = simple_strtoul(endtail + 1, NULL, 10); - } else { - start = simple_strtoul(argv[2], NULL, 10); - end = simple_strtoul(argv[3], NULL, 10);
- start >>= onenand_chip.erase_shift; - end >>= onenand_chip.erase_shift; - /* Don't include the end block */ - end--; - } + /* + * Syntax is: + * 0 1 2 3 4 + * onenand erase [force] [off size] + */ + if ((strcmp(cmd, "erase") == 0) || (strcmp(cmd, "test") == 0)) { + int force = argc > 2 && !strcmp("force", argv[2]); + int o = force ? 3 : 2; + int erase;
- if (!end || end < 0) - end = start; + erase = strcmp(cmd, "erase") == 0; /* 1 = erase, 0 = test */ + printf("\nOneNAND %s: ", erase ? "erase" : "test");
- printf("Erase block from %lu to %lu\n", start, end); + /* skip first two or three arguments, look for offset and size */ + if (arg_off_size(argc - o, argv + o, &ofs, &len) != 0) + return 1;
- for (block = start; block <= end; block++) { - instr.addr = block << onenand_chip.erase_shift; - instr.len = 1 << onenand_chip.erase_shift; - ret = onenand_erase(&onenand_mtd, &instr); - if (ret) { - printf("erase failed %lu\n", block); - break; - } - } + if (erase) + ret = onenand_block_erase(ofs, len, force); + else + ret = onenand_block_test(ofs, len);
- return 0; + printf("%s\n", ret ? "ERROR" : "OK"); + + return ret == 0 ? 0 : 1; }
- if (strncmp(argv[1], "read", 4) == 0) { - ulong addr = simple_strtoul(argv[2], NULL, 16); - ulong ofs = simple_strtoul(argv[3], NULL, 16); - size_t len = simple_strtoul(argv[4], NULL, 16); - int oob = strncmp(argv[1], "read.oob", 8) ? 0 : 1; - struct mtd_oob_ops ops; + if (strncmp(cmd, "read", 4) == 0 || strncmp(cmd, "write", 5) == 0) { + int read; + int oob = 0;
- ops.mode = MTD_OOB_PLACE; + if (argc < 4) + goto usage;
- if (oob) { - ops.len = 0; - ops.datbuf = NULL; - ops.ooblen = len; - ops.oobbuf = (u_char *) addr; - } else { - ops.len = len; - ops.datbuf = (u_char *) addr; - ops.ooblen = 0; - ops.oobbuf = NULL; - } - ops.retlen = ops.oobretlen = 0; + addr = (ulong)simple_strtoul(argv[2], NULL, 16);
- onenand_mtd.read_oob(&onenand_mtd, ofs, &ops); - printf("Done\n"); + read = strncmp(cmd, "read", 4) == 0; /* 1 = read, 0 = write */ + printf("\nOneNAND %s: ", read ? "read" : "write"); + if (arg_off_size(argc - 3, argv + 3, &ofs, &len) != 0) + return 1;
- return 0; - } + s = strchr(cmd, '.'); + if ((s != NULL) && (!strcmp(s, ".oob"))) + oob = 1;
- if (strncmp(argv[1], "write", 5) == 0) { - ulong addr = simple_strtoul(argv[2], NULL, 16); - ulong ofs = simple_strtoul(argv[3], NULL, 16); - size_t len = simple_strtoul(argv[4], NULL, 16); - size_t retlen = 0; + if (read) { + ret = onenand_block_read(ofs, len, &retlen, + (u8 *)addr, oob); + } else { + ret = onenand_block_write(ofs, len, &retlen, + (u8 *)addr); + }
- onenand_write(&onenand_mtd, ofs, len, &retlen, - (u_char *) addr); - printf("Done\n"); + printf(" %d bytes %s: %s\n", retlen, + read ? "read" : "written", ret ? "ERROR" : "OK");
- return 0; + return ret == 0 ? 0 : 1; }
- if (strncmp(argv[1], "block", 5) == 0) { - ulong addr = simple_strtoul(argv[2], NULL, 16); - ulong block = simple_strtoul(argv[3], NULL, 10); - ulong page = simple_strtoul(argv[4], NULL, 10); - size_t len = simple_strtol(argv[5], NULL, 10); - ulong ofs; - int oob = strncmp(argv[1], "block.oob", 9) ? 0 : 1; - struct mtd_oob_ops ops; - - ops.mode = MTD_OOB_PLACE; + if (strcmp(cmd, "markbad") == 0) { + addr = (ulong)simple_strtoul(argv[2], NULL, 16);
+ int ret = mtd->block_markbad(mtd, addr); + if (ret == 0) { + printf("block 0x%08lx successfully marked as bad\n", + (ulong) addr); + return 0; + } else { + printf("block 0x%08lx NOT marked as bad! ERROR %d\n", + (ulong) addr, ret); + } + return 1; + }
- ofs = block << onenand_chip.erase_shift; - if (page) - ofs += page << onenand_chip.page_shift; + if (strncmp(cmd, "dump", 4) == 0) { + if (argc < 3) + goto usage;
- if (!len) { - if (oob) - ops.ooblen = 64; - else - ops.len = 512; - } + s = strchr(cmd, '.'); + ofs = (int)simple_strtoul(argv[2], NULL, 16);
- if (oob) { - ops.datbuf = NULL; - ops.oobbuf = (u_char *) addr; - } else { - ops.datbuf = (u_char *) addr; - ops.oobbuf = NULL; - } - ops.retlen = ops.oobretlen = 0; + if (s != NULL && strcmp(s, ".oob") == 0) + ret = onenand_dump(mtd, ofs, 1); + else + ret = onenand_dump(mtd, ofs, 0);
- onenand_read_oob(&onenand_mtd, ofs, &ops); - return 0; + return ret == 0 ? 1 : 0; }
break; }
return 0; + +usage: + printf("Usage:\n%s\n", cmdtp->usage); + return 1; }
U_BOOT_CMD( onenand, 6, 1, do_onenand, "onenand - OneNAND sub-system\n", - "info - show available OneNAND devices\n" - "onenand read[.oob] addr ofs len - read data at ofs with len to addr\n" - "onenand write addr ofs len - write data at ofs with len from addr\n" - "onenand erase saddr eaddr - erase block start addr to end addr\n" - "onenand block[.oob] addr block [page] [len] - " - "read data with (block [, page]) to addr" + "info - show available OneNAND devices\n" + "onenand bad - show bad blocks\n" + "onenand read[.oob] addr off size\n" + "onenand write[.oob] addr off size\n" + " read/write 'size' bytes starting at offset 'off'\n" + " to/from memory address 'addr', skipping bad blocks.\n" + "onenand erase [force] [off size] - erase 'size' bytes from\n" + "onenand test [off size] - test 'size' bytes from\n" + " offset 'off' (entire device if not specified)\n" + "onenand dump[.oob] off - dump page\n" + "onenand markbad off - mark bad block at offset (UNSAFE)\n" );
Is there any chance that we could merge this code with cmd_nand.c?
Will this cause relocation problems on some architectures? Could you have more than one OneNAND on a board?
-Scott
Possibly. I'm not sure yet. I'll try to investigate this next week.
Yes, you're correct. I missed removing this assignment here. do_onenand() does it correctly though. I'll fix it in the next patch version.
No, currently only one OneNAND device is supported. We will add this multi-OneNAND support later.
Best regards, Stefan
Scott Wood
Stefan Roese
