[U-Boot-Users] [PATCH] ColdFire: Fix FB CS not setup properly for Mcf5282
Remove all CFG_CSn_RO in cpu/mcf52x2/cpu_init.c. If CFG_CSn_RO is defined as 0, the chipselect will not be assigned.
Signed-off-by: TsiChung Liew Tsi-Chung.Liew@freescale.com --- cpu/mcf52x2/cpu_init.c | 12 ++++-------- 1 files changed, 4 insertions(+), 8 deletions(-)
diff --git a/cpu/mcf52x2/cpu_init.c b/cpu/mcf52x2/cpu_init.c index 207a37e..344bcee 100644 --- a/cpu/mcf52x2/cpu_init.c +++ b/cpu/mcf52x2/cpu_init.c @@ -419,8 +419,7 @@ void cpu_init_f(void) else is doing it! */
#if defined(CFG_CS0_BASE) & defined(CFG_CS0_SIZE) & \ - defined(CFG_CS0_WIDTH) & defined(CFG_CS0_RO) & \ - defined(CFG_CS0_WS) + defined(CFG_CS0_WIDTH) & defined(CFG_CS0_WS)
MCFCSM_CSAR0 = (CFG_CS0_BASE >> 16) & 0xFFFF;
@@ -447,8 +446,7 @@ void cpu_init_f(void) #endif
#if defined(CFG_CS1_BASE) & defined(CFG_CS1_SIZE) & \ - defined(CFG_CS1_WIDTH) & defined(CFG_CS1_RO) & \ - defined(CFG_CS1_WS) + defined(CFG_CS1_WIDTH) & defined(CFG_CS1_WS)
MCFCSM_CSAR1 = (CFG_CS1_BASE >> 16) & 0xFFFF;
@@ -476,8 +474,7 @@ void cpu_init_f(void) #endif
#if defined(CFG_CS2_BASE) & defined(CFG_CS2_SIZE) & \ - defined(CFG_CS2_WIDTH) & defined(CFG_CS2_RO) & \ - defined(CFG_CS2_WS) + defined(CFG_CS2_WIDTH) & defined(CFG_CS2_WS)
MCFCSM_CSAR2 = (CFG_CS2_BASE >> 16) & 0xFFFF;
@@ -505,8 +502,7 @@ void cpu_init_f(void) #endif
#if defined(CFG_CS3_BASE) & defined(CFG_CS3_SIZE) & \ - defined(CFG_CS3_WIDTH) & defined(CFG_CS3_RO) & \ - defined(CFG_CS3_WS) + defined(CFG_CS3_WIDTH) & defined(CFG_CS3_WS)
MCFCSM_CSAR3 = (CFG_CS3_BASE >> 16) & 0xFFFF;
Tsi-Chung Liew
