[U-Boot] [PATCH 1/3] imx6ul: engicam: Drop isiot-mmc defconfig
Engicam Is.IoT has eMMC and NAND cpu modules where MMC is common for both, so remove explicit mmc defconfig.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/Makefile | 1 - arch/arm/dts/imx6ul-isiot-mmc.dts | 50 ------------------------------------- board/engicam/imx6ul/MAINTAINERS | 1 - configs/imx6ul_isiot_emmc_defconfig | 2 ++ configs/imx6ul_isiot_mmc_defconfig | 44 -------------------------------- 5 files changed, 2 insertions(+), 96 deletions(-) delete mode 100644 arch/arm/dts/imx6ul-isiot-mmc.dts delete mode 100644 configs/imx6ul_isiot_mmc_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index c7695aa1f1..e9fe71431c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -396,7 +396,6 @@ dtb-$(CONFIG_MX6) += imx6ull-14x14-evk.dtb \ imx6sx-sdb.dtb \ imx6ul-geam-kit.dtb \ imx6ul-isiot-emmc.dtb \ - imx6ul-isiot-mmc.dtb \ imx6ul-isiot-nand.dtb \ imx6ul-opos6uldev.dtb
diff --git a/arch/arm/dts/imx6ul-isiot-mmc.dts b/arch/arm/dts/imx6ul-isiot-mmc.dts deleted file mode 100644 index bb5086a68a..0000000000 --- a/arch/arm/dts/imx6ul-isiot-mmc.dts +++ /dev/null @@ -1,50 +0,0 @@ -/* - * Copyright (C) 2016 Amarula Solutions B.V. - * Copyright (C) 2016 Engicam S.r.l. - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License - * version 2 as published by the Free Software Foundation. - * - * This file is distributed in the hope that it will be useful - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED , WITHOUT WARRANTY OF ANY KIND - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -/dts-v1/; - -#include "imx6ul-isiot.dtsi" - -/ { - model = "Engicam Is.IoT MX6UL MMC Starterkit"; - compatible = "engicam,imx6ul-isiot", "fsl,imx6ul"; -}; diff --git a/board/engicam/imx6ul/MAINTAINERS b/board/engicam/imx6ul/MAINTAINERS index 37f84f8cc0..73dbec88e2 100644 --- a/board/engicam/imx6ul/MAINTAINERS +++ b/board/engicam/imx6ul/MAINTAINERS @@ -10,6 +10,5 @@ F: configs/imx6ul_isiot_mmc_defconfig F: configs/imx6ul_isiot_nand_defconfig F: arch/arm/dts/imx6ul-geam-kit.dts F: arch/arm/dts/imx6ul-isiot.dtsi -F: arch/arm/dts/imx6ul-isiot-mmc.dts F: arch/arm/dts/imx6ul-isiot-emmc.dts F: arch/arm/dts/imx6ul-isiot-nand.dts diff --git a/configs/imx6ul_isiot_emmc_defconfig b/configs/imx6ul_isiot_emmc_defconfig index c334bebcce..d91b944d6e 100644 --- a/configs/imx6ul_isiot_emmc_defconfig +++ b/configs/imx6ul_isiot_emmc_defconfig @@ -23,6 +23,7 @@ CONFIG_SYS_PROMPT="isiotmx6ul> " CONFIG_CRC32_VERIFY=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y @@ -33,6 +34,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_I2C_MXC=y CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y CONFIG_FEC_MXC=y diff --git a/configs/imx6ul_isiot_mmc_defconfig b/configs/imx6ul_isiot_mmc_defconfig deleted file mode 100644 index 3297a03678..0000000000 --- a/configs/imx6ul_isiot_mmc_defconfig +++ /dev/null @@ -1,44 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_MX6=y -CONFIG_SYS_TEXT_BASE=0x87800000 -CONFIG_SPL_GPIO_SUPPORT=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_SYS_MALLOC_F_LEN=0x2000 -CONFIG_TARGET_MX6UL_ENGICAM=y -CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_SPL_WATCHDOG_SUPPORT=y -# CONFIG_CMD_BMODE is not set -CONFIG_DEFAULT_DEVICE_TREE="imx6ul-isiot-mmc" -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_VERBOSE=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" -CONFIG_BOOTDELAY=3 -CONFIG_SPL=y -CONFIG_SPL_EXT_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="isiotmx6ul> " -CONFIG_CRC32_VERIFY=y -CONFIG_CMD_MEMTEST=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_ENV_IS_IN_MMC=y -CONFIG_SYS_I2C_MXC=y -CONFIG_PHYLIB=y -CONFIG_PHY_SMSC=y -CONFIG_FEC_MXC=y -CONFIG_PINCTRL=y -CONFIG_PINCTRL_IMX6=y -CONFIG_MXC_UART=y -CONFIG_IMX_THERMAL=y
i.MX6 boards still using raw MMC write for SPL and u-boot-dtb.img along with Falcon mode configurations, so drop filesystem based write through SPL_EXT_SUPPORT.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- configs/imx6qdl_icore_mipi_defconfig | 1 - configs/imx6qdl_icore_mmc_defconfig | 1 - configs/imx6qdl_icore_rqs_defconfig | 1 - configs/imx6ul_geam_mmc_defconfig | 1 - configs/imx6ul_isiot_emmc_defconfig | 1 - 5 files changed, 5 deletions(-)
diff --git a/configs/imx6qdl_icore_mipi_defconfig b/configs/imx6qdl_icore_mipi_defconfig index 3c5515228b..7cb5076589 100644 --- a/configs/imx6qdl_icore_mipi_defconfig +++ b/configs/imx6qdl_icore_mipi_defconfig @@ -18,7 +18,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SPL=y -CONFIG_SPL_EXT_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="icorem6qdl-mipi> " diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index ddb3dc8eca..7cfad903bc 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -18,7 +18,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SPL=y -CONFIG_SPL_EXT_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="icorem6qdl> " diff --git a/configs/imx6qdl_icore_rqs_defconfig b/configs/imx6qdl_icore_rqs_defconfig index 5620ea7d87..664dffbf69 100644 --- a/configs/imx6qdl_icore_rqs_defconfig +++ b/configs/imx6qdl_icore_rqs_defconfig @@ -17,7 +17,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SPL=y -CONFIG_SPL_EXT_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="icorem6qdl-rqs> " diff --git a/configs/imx6ul_geam_mmc_defconfig b/configs/imx6ul_geam_mmc_defconfig index 159d4cea69..2493c70e53 100644 --- a/configs/imx6ul_geam_mmc_defconfig +++ b/configs/imx6ul_geam_mmc_defconfig @@ -17,7 +17,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SPL=y -CONFIG_SPL_EXT_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="geam6ul> " CONFIG_CRC32_VERIFY=y diff --git a/configs/imx6ul_isiot_emmc_defconfig b/configs/imx6ul_isiot_emmc_defconfig index d91b944d6e..6e7de0882a 100644 --- a/configs/imx6ul_isiot_emmc_defconfig +++ b/configs/imx6ul_isiot_emmc_defconfig @@ -17,7 +17,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SPL=y -CONFIG_SPL_EXT_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="isiotmx6ul> " CONFIG_CRC32_VERIFY=y
Hi Jagan,
This is a fix, I pick it up (the whole series) for release.
Best regards, Stefano
On Thu, Feb 22, 2018 at 7:08 PM, Stefano Babic sbabic@denx.de wrote:
Hi Jagan,
Yes, All these 3 patches seems to be fixes please pick them.
Currently SPL_LOAD_FIT is unable to boot from nand on i.MX6QDL platform, so enable only for MMC boards.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-imx/mx6/Kconfig | 1 - board/engicam/imx6q/MAINTAINERS | 3 ++- configs/imx6dl_icore_nand_defconfig | 47 ++++++++++++++++++++++++++++++++++++ configs/imx6q_icore_nand_defconfig | 47 ++++++++++++++++++++++++++++++++++++ configs/imx6qdl_icore_mipi_defconfig | 1 + configs/imx6qdl_icore_mmc_defconfig | 1 + configs/imx6qdl_icore_rqs_defconfig | 1 + 7 files changed, 99 insertions(+), 2 deletions(-) create mode 100644 configs/imx6dl_icore_nand_defconfig create mode 100644 configs/imx6q_icore_nand_defconfig
diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index 2f3e52d624..d4ce38db8d 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -238,7 +238,6 @@ config TARGET_MX6Q_ENGICAM select DM_MMC select DM_THERMAL select SUPPORT_SPL - select SPL_LOAD_FIT select SPL_DM if SPL select SPL_OF_CONTROL if SPL select SPL_SEPARATE_BSS if SPL diff --git a/board/engicam/imx6q/MAINTAINERS b/board/engicam/imx6q/MAINTAINERS index 82efb462c0..77ae6cb387 100644 --- a/board/engicam/imx6q/MAINTAINERS +++ b/board/engicam/imx6q/MAINTAINERS @@ -4,7 +4,8 @@ S: Maintained F: board/engicam/imx6q F: include/configs/imx6-engicam.h F: configs/imx6qdl_icore_mmc_defconfig -F: configs/imx6qdl_icore_nand_defconfig +F: configs/imx6q_icore_nand_defconfig +F: configs/imx6dl_icore_nand_defconfig F: configs/imx6qdl_icore_rqs_defconfig F: arch/arm/dts/imx6qdl-icore.dtsi F: arch/arm/dts/imx6q-icore.dts diff --git a/configs/imx6dl_icore_nand_defconfig b/configs/imx6dl_icore_nand_defconfig new file mode 100644 index 0000000000..d17f9cfed9 --- /dev/null +++ b/configs/imx6dl_icore_nand_defconfig @@ -0,0 +1,47 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SYS_TEXT_BASE=0x17800000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_TARGET_MX6Q_ENGICAM=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +# CONFIG_CMD_BMODE is not set +CONFIG_DEFAULT_DEVICE_TREE="imx6dl-icore" +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_VERBOSE=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" +CONFIG_BOOTDELAY=3 +CONFIG_SPL=y +CONFIG_SPL_DMA_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="icorem6qdl> " +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" +CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:2m(spl),2m(uboot),1m(env),8m(kernel),1m(dtb),-(rootfs)" +CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_I2C_MXC=y +CONFIG_NAND=y +CONFIG_NAND_MXS=y +CONFIG_PHYLIB=y +CONFIG_PHY_SMSC=y +CONFIG_FEC_MXC=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_MXC_UART=y +CONFIG_IMX_THERMAL=y +CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y diff --git a/configs/imx6q_icore_nand_defconfig b/configs/imx6q_icore_nand_defconfig new file mode 100644 index 0000000000..034e17479e --- /dev/null +++ b/configs/imx6q_icore_nand_defconfig @@ -0,0 +1,47 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SYS_TEXT_BASE=0x17800000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_TARGET_MX6Q_ENGICAM=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +# CONFIG_CMD_BMODE is not set +CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore" +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_VERBOSE=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" +CONFIG_BOOTDELAY=3 +CONFIG_SPL=y +CONFIG_SPL_DMA_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="icorem6qdl> " +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" +CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:2m(spl),2m(uboot),1m(env),8m(kernel),1m(dtb),-(rootfs)" +CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_I2C_MXC=y +CONFIG_NAND=y +CONFIG_NAND_MXS=y +CONFIG_PHYLIB=y +CONFIG_PHY_SMSC=y +CONFIG_FEC_MXC=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_MXC_UART=y +CONFIG_IMX_THERMAL=y +CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y diff --git a/configs/imx6qdl_icore_mipi_defconfig b/configs/imx6qdl_icore_mipi_defconfig index 7cb5076589..e212cd1c18 100644 --- a/configs/imx6qdl_icore_mipi_defconfig +++ b/configs/imx6qdl_icore_mipi_defconfig @@ -18,6 +18,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SPL=y +CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="icorem6qdl-mipi> " diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index 7cfad903bc..1a0ee83633 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -18,6 +18,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SPL=y +CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="icorem6qdl> " diff --git a/configs/imx6qdl_icore_rqs_defconfig b/configs/imx6qdl_icore_rqs_defconfig index 664dffbf69..98ba9345d5 100644 --- a/configs/imx6qdl_icore_rqs_defconfig +++ b/configs/imx6qdl_icore_rqs_defconfig @@ -17,6 +17,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SPL=y +CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="icorem6qdl-rqs> "
Jagan Teki
Stefano Babic
