[PATCH] ARM: zynq: Disable the config CONFIG_SPI_FLASH_USE_4K_SECTORS
From: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com
Lock size for the flashes will be in terms of sector size, so disable the CONFIG_SPI_FLASH_USE_4K_SECTORS and read it from the flash itself.
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com Signed-off-by: Michal Simek michal.simek@amd.com ---
configs/xilinx_zynq_virt_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/xilinx_zynq_virt_defconfig b/configs/xilinx_zynq_virt_defconfig index 817fb4142d18..6145af62b511 100644 --- a/configs/xilinx_zynq_virt_defconfig +++ b/configs/xilinx_zynq_virt_defconfig @@ -126,6 +126,7 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y CONFIG_SPI_FLASH_WINBOND=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHY_MARVELL=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y
Applied. M
Michal Simek
