[U-Boot] [PATCH] ARM: da850evm: Increase Malloc Size
The SPI NOR frameware was recently updated, but they require a little more memory that we had previosly allocated, so it stopped booting. This patch doubles the size of CONFIG_SPL_SYS_MALLOC_F_LEN to 0x800.
Fixes: c4e8862308d4 ("mtd: spi: Switch to new SPI NOR framework")
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/configs/da850_am18xxevm_defconfig b/configs/da850_am18xxevm_defconfig index 58745fec82..419224104a 100644 --- a/configs/da850_am18xxevm_defconfig +++ b/configs/da850_am18xxevm_defconfig @@ -6,6 +6,7 @@ CONFIG_MAC_ADDR_IN_EEPROM=y CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x800 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index 5100ee7b0e..41dae05fb9 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_DA850EVM=y CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x800 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index be818dff55..166e77b8e3 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x60000000 CONFIG_TARGET_DA850EVM=y CONFIG_DA850_LOWLEVEL=y CONFIG_TI_COMMON_CMD_OPTIONS=y +CONFIG_SYS_MALLOC_F_LEN=0x800 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="USE_NOR,DIRECT_NOR_BOOT" CONFIG_BOOTDELAY=3 diff --git a/configs/da850evm_nand_defconfig b/configs/da850evm_nand_defconfig index 1cdde484dd..48b7c2a97a 100644 --- a/configs/da850evm_nand_defconfig +++ b/configs/da850evm_nand_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_DA850EVM=y CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x800 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y
Adam Ford
