[U-Boot-Users] Debugging u-boot onto at91rm9200dk with BDI2000
10 Dec
2004
10 Dec
'04
12:22 p.m.
Hi all,
Board used: ATMEL AT91RM9200-DK U-Boot version: Latest from CVS
I try to debug u-boot code starting in Flash (only u-boot present in Flash, there is not boot.bin 1st ATMEL bootloader) with a BDI2000 connected to JTAG.
The PC is set to 0x0 while the Flash base address is at 0x1000.0000
At which address should be set the PC in order to start correctly u-boot code ?
When I set the PC to 0x0, u-boot doesn't start. When I set the PC to 0x1000.0000, u-boot starts but I get an Abort signal at address 0x1000.041C inside lowlevel_init
What did I miss ?
Thanks for your contribution. Luc
7454
Paugam Luc
