[U-Boot] [PATCH v2 0/7] rockchip: dts: rk3399-puma: update DTS
For the RK3399-Q7, there's been a number of changes to the DTS from the ongoing Linux development and from recently enabled functionality within U-Boot.
This now makes a patch-series out of what originally was a single patch and includes the following changes: - adds a dependent patch that had gone upstream with the RK3399 HDMI support, but is needed for the updated DTS to not break the build for the entire architecture - fixes a number of unrelated warnings/build errors (reported from buildman) that showed up after rebasing onto u-boot-rockchip/master@2b19b2f
Changes in v2: - (new patch) rename dev_get_addr in the RV1108 clk-driver to fix a buildman failure for u-boot-rockchip/master@2b19b2f - (new patch) access of-offset of periph via dev_of_offset in the RV1108 pinctrl driver to fix a buildman failure for u-boot-rockchip/master@2b19b2f - (new patch) fix a multiple definition of usb_gadget_handle_interrupts for the RK3328 EVB in evb-rk3328.c to fix a buildman failure for u-boot-rockchip/master@2b19b2f - (new patch) fix a int-to-pointer cast warning for regs_otg in dwc2-otg to fix a buildman failure for u-boot-rockchip/master@2b19b2f - (new patch) fix warnings and add some robustness for the truncation of ep->dma_buf in dwc2-otg for LP64 builds to fix a buildman failure for u-boot-rockchip/master@2b19b2f - cherry-picked the DTS change adding the hdmi node for the rk3399.dtsi from the RK3399 HDMI enabledment series (already applied there)
Philipp Tomsich (7): rockchip: clk: rv1108: rename dev_get_addr rockchip: pinctrl: rv1108: access of-offset via dev_of_offset(...) rockchip: rk3328: don't implement usb_gadget_handle_interrupts twice usb: dwc2-otg: make regs_otg (in platdata) a uintptr_t usb: dwc2-otg: fix warnings for ep->dma_buf for LP64 builds rockchip: dts: rk3399: enable HDMI output in the DTS rockchip: dts: rk3399-puma: sync DTS with Linux tree
arch/arm/dts/rk3399-puma.dts | 540 ++++++++++++++++++++++++++--- arch/arm/dts/rk3399.dtsi | 39 +++ board/rockchip/evb_rk3328/evb-rk3328.c | 5 - drivers/clk/rockchip/clk_rv1108.c | 2 +- drivers/pinctrl/rockchip/pinctrl_rv1108.c | 2 +- drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c | 6 +- include/usb/dwc2_udc.h | 2 +- 7 files changed, 542 insertions(+), 54 deletions(-)
After rebasing to u-boot-rockchip/master@2b19b2f, buildman fails for rv1108 with: ../drivers/clk/rockchip/clk_rv1108.c: In function 'rv1108_clk_probe': ../drivers/clk/rockchip/clk_rv1108.c:191:22: warning: implicit declaration of function 'dev_get_addr' [-Wimplicit-function-declaration] priv->cru = (struct rv1108_cru *)dev_get_addr(dev);
This change tracks the dev_get_addr rename, which didn't make it into the rv1108 clk driver.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
drivers/clk/rockchip/clk_rv1108.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/clk/rockchip/clk_rv1108.c b/drivers/clk/rockchip/clk_rv1108.c index 0946dab..0a3ba3b 100644 --- a/drivers/clk/rockchip/clk_rv1108.c +++ b/drivers/clk/rockchip/clk_rv1108.c @@ -188,7 +188,7 @@ static int rv1108_clk_probe(struct udevice *dev) { struct rv1108_clk_priv *priv = dev_get_priv(dev);
- priv->cru = (struct rv1108_cru *)dev_get_addr(dev); + priv->cru = (struct rv1108_cru *)devfdt_get_addr(dev);
rkclk_init(priv->cru);
On 6 June 2017 at 07:42, Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
Changes in v2:
Hi Philipp:
2017-06-06 21:42 GMT+08:00 Philipp Tomsich < philipp.tomsich@theobroma-systems.com>:
Tested-by: Andy Yan andy.yan@rock-chips.com
Thanks.
Changes in v2:
diff --git a/drivers/clk/rockchip/clk_rv1108.c b/drivers/clk/rockchip/clk_ rv1108.c index 0946dab..0a3ba3b 100644 --- a/drivers/clk/rockchip/clk_rv1108.c +++ b/drivers/clk/rockchip/clk_rv1108.c @@ -188,7 +188,7 @@ static int rv1108_clk_probe(struct udevice *dev) { struct rv1108_clk_priv *priv = dev_get_priv(dev);
priv->cru = (struct rv1108_cru *)devfdt_get_addr(dev); rkclk_init(priv->cru);
-- 2.1.4
Hi Philipp:
Thanks.
Changes in v2:
Applied to u-boot-rockchip, thanks!
After rebasing to u-boot-rockchip/master@2b19b2f, buildman fails for rv1108 with: ../drivers/pinctrl/rockchip/pinctrl_rv1108.c: In function 'rv1108_pinctrl_get_periph_id': ../drivers/pinctrl/rockchip/pinctrl_rv1108.c:111:49: error: 'struct udevice' has no member named 'of_offset' ret = fdtdec_get_int_array(gd->fdt_blob, periph->of_offset, ^
This change access the of-offset of periph via the dev_of_offset() helper-function to fix this issue and (hopefully) to ensure it doesn't recur if there's more changes to the DM subsystem.
Changes in v2: - (new patch) access of-offset of periph via dev_of_offset in the RV1108 pinctrl driver to fix a buildman failure for u-boot-rockchip/master@2b19b2f
drivers/pinctrl/rockchip/pinctrl_rv1108.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pinctrl/rockchip/pinctrl_rv1108.c b/drivers/pinctrl/rockchip/pinctrl_rv1108.c index d98ec81..bdf3910 100644 --- a/drivers/pinctrl/rockchip/pinctrl_rv1108.c +++ b/drivers/pinctrl/rockchip/pinctrl_rv1108.c @@ -108,7 +108,7 @@ static int rv1108_pinctrl_get_periph_id(struct udevice *dev, u32 cell[3]; int ret;
- ret = fdtdec_get_int_array(gd->fdt_blob, periph->of_offset, + ret = fdtdec_get_int_array(gd->fdt_blob, dev_of_offset(periph), "interrupts", cell, ARRAY_SIZE(cell)); if (ret < 0) return -EINVAL;
Changes in v2:
Could you use dev_read_u32_array() here instead? That is the new new way :-) I added the dev_of_offset() as a transition mechanism but it should not be used ideally.
-- 2.1.4
Simon,
On 06 Jun 2017, at 23:09, Simon Glass sjg@chromium.org wrote:
On 6 June 2017 at 07:42, Philipp Tomsich <philipp.tomsich@theobroma-systems.com mailto:philipp.tomsich@theobroma-systems.com> wrote:
Changes in v2:
ret =fdtdec_get_int_array(gd->fdt_blob, dev_of_offset(periph), "interrupts", cell, ARRAY_SIZE(cell));
A quick grep shows that only simple-bus.c uses the new way of doing things, yet.
Please use this one as-is and I’ll send another series (to be applied on top of this) to rewrite to dev_read_u32_array() across the entire driver population.
Regards, Philipp.
Simon,
On 07 Jun 2017, at 10:00, Dr. Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
On 06 Jun 2017, at 23:09, Simon Glass <sjg@chromium.org mailto:sjg@chromium.org> wrote:
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com mailto:philipp.tomsich@theobroma-systems.com>
Changes in v2:
I dropped a change-set for most fdt_get occurrences in the rockchip subarch (and common drivers used by those boards).
However, there’s at least one fdtdev_get function that I didn’t find an equivalent for: fdtdec_get_int_array_count In case you are wondering: this one is used RK3188 and RK3288 pinctrl-drivers…
Regards, Philipp.
On 7 June 2017 at 10:51, Dr. Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
Simon,
Changes in v2:
Great!
OK - would you like to add one? It could be dev_read_u32_array() / ofnode_...
On 07 Jun 2017, at 18:56, Simon Glass sjg@chromium.org wrote:
On 7 June 2017 at 10:51, Dr. Philipp Tomsich <philipp.tomsich@theobroma-systems.com mailto:philipp.tomsich@theobroma-systems.com> wrote:
Simon,
Changes in v2:
Great!
OK - would you like to add one? It could be dev_read_u32_array() / ofnode_…
No problem, will do. I just wanted to make sure that this wasn’t left out for a reason (e.g. to deprecate it in the near future)…
Cheers, Philipp.
Simon,
Changes in v2:
The usb_gadget_handle_interrupts()-function is already implemented by drivers/usb/gadget/dwc2_udc_otg.c, so we need to avoid defining it in the evb-rk3328.c board-specific file.
This change fixes the following build error (from buildman): drivers/usb/gadget/built-in.o: In function `usb_gadget_handle_interrupts': build/../drivers/usb/gadget/dwc2_udc_otg.c:850: multiple definition of `usb_gadget_handle_interrupts' board/rockchip/evb_rk3328/built-in.o:build/../board/rockchip/evb_rk3328/evb-rk3328.c:37: first defined here make[1]: *** [u-boot] Error 1
Changes in v2: - (new patch) fix a multiple definition of usb_gadget_handle_interrupts for the RK3328 EVB in evb-rk3328.c to fix a buildman failure for u-boot-rockchip/master@2b19b2f
board/rockchip/evb_rk3328/evb-rk3328.c | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/board/rockchip/evb_rk3328/evb-rk3328.c b/board/rockchip/evb_rk3328/evb-rk3328.c index a7895cb..0a26ed5 100644 --- a/board/rockchip/evb_rk3328/evb-rk3328.c +++ b/board/rockchip/evb_rk3328/evb-rk3328.c @@ -31,11 +31,6 @@ int dram_init_banksize(void) return 0; }
-int usb_gadget_handle_interrupts(void) -{ - return 0; -} - int board_usb_init(int index, enum usb_init_type init) { return 0;
Changes in v2:
Changes in v2:
The regs_otg field in uintptr_t of the platform data structure for dwc2-otg has thus far been an unsigned int, but will eventually be casted into a void*.
This raises the following error with GCC 6.3 and buildman: ../drivers/usb/gadget/dwc2_udc_otg.c: In function 'dwc2_udc_probe': ../drivers/usb/gadget/dwc2_udc_otg.c:821:8: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] reg = (struct dwc2_usbotg_reg *)pdata->regs_otg; ^
This changes regs_otg to a uintptr_t to ensure that it is large enough to hold any valid pointer (and fix the associated warning).
Changes in v2: - (new patch) fix a int-to-pointer cast warning for regs_otg in dwc2-otg to fix a buildman failure for u-boot-rockchip/master@2b19b2f
include/usb/dwc2_udc.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/usb/dwc2_udc.h b/include/usb/dwc2_udc.h index 7324d8a..1a370e0 100644 --- a/include/usb/dwc2_udc.h +++ b/include/usb/dwc2_udc.h @@ -16,7 +16,7 @@ struct dwc2_plat_otg_data { int phy_of_node; int (*phy_control)(int on); unsigned int regs_phy; - unsigned int regs_otg; + uintptr_t regs_otg; unsigned int usb_phy_ctrl; unsigned int usb_flags; unsigned int usb_gusbcfg;
Applied, thanks
Changes in v2:
- uintptr_t regs_otg; unsigned int usb_phy_ctrl; unsigned int usb_flags; unsigned int usb_gusbcfg;
Hi Philipp,
Changes in v2:
uintptr_t regs_otg;
Can you use ulong instead?
-- 2.1.4
Simon,
Hi Philipp,
Changes in v2:
uintptr_t regs_otg;
Sure, but can I first ask “why?”. I may reopen an old discussion with this… if so, forgive my ignorance:
uintptr_t makes the most sense for this use case in the C99 (or later) type system, as we want this field to hold an integer (i.e. the address from the physical memory map for one of the register blocks) that will be casted into a pointer. The uintptr_t type will always the matching size in any and all programming models; in contrast, ulong would be wrong for LLP64 (and LLP64 probably “doesn’t matter” in the context of U-Boot anyway).
What I always found odd, was that uintptr_t is optional according to ISO9899. I would thus not have been surprised if there’s a concern for portability between compilers behind this, but then again … U-Boot makes extensive use of GCC extensions (such as inline assembly).
So I am apparently missing something here.
Cheers, Philipp.
On 6 June 2017 at 17:59, Dr. Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
Simon,
Hi Philipp,
Changes in v2:
uintptr_t regs_otg;
I don't know of any deep reason except that long is defined to be able to hold an address, and ulong makes sense since an address is generally considered unsigned.
U-Boot by convention uses ulong for addresses. You can see this all around the code base so I am really just arguing in favour of consistency (and I suppose ulong is easier to type!)
Simon,
Hi Philipp,
Changes in v2:
uintptr_t regs_otg;
I was under the impression that u-boot by convention uses uintptr_t for addresses.
Then I guess half of the codebase is inconsistent.
+Tom for comment
Hi Marek,
Simon,
Hi Philipp,
Changes in v2:
uintptr_t regs_otg;
Actually about 10%:
git grep uintptr_t |wc -l 395 git grep ulong |wc -l 4024
Clearly we use ulong all over the place for addresses - see image.c, most commands, etc. If we are going to change then it should be a deliberate decision and a tree-wide update. I'm happy enough with ulong.
Tom, what do you what to do here?
On 06/07/2017 02:38 PM, Simon Glass wrote:
+Tom for comment
Hi Marek,
Simon,
Hi Philipp,
Changes in v2:
uintptr_t regs_otg;
Actually about 10%:
I don't think this is a valid way to count it at all, since uintptr_t is only used for casting pointer to number, while ulong is used for arbitrary numbers.
But none of those use ulong as device address pointers .
Hi Marek,
+Tom for comment
Hi Marek,
Simon,
Hi Philipp,
On 6 June 2017 at 07:42, Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote: > The regs_otg field in uintptr_t of the platform data structure for > dwc2-otg has thus far been an unsigned int, but will eventually be > casted into a void*. > > This raises the following error with GCC 6.3 and buildman: > ../drivers/usb/gadget/dwc2_udc_otg.c: In function 'dwc2_udc_probe': > ../drivers/usb/gadget/dwc2_udc_otg.c:821:8: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] > reg = (struct dwc2_usbotg_reg *)pdata->regs_otg; > ^ > > This changes regs_otg to a uintptr_t to ensure that it is large enough > to hold any valid pointer (and fix the associated warning). > > Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com > > --- > > Changes in v2: > - (new patch) fix a int-to-pointer cast warning for regs_otg in > dwc2-otg to fix a buildman failure for u-boot-rockchip/master@2b19b2f > > include/usb/dwc2_udc.h | 2 +- > 1 file changed, 1 insertion(+), 1 deletion(-) > > diff --git a/include/usb/dwc2_udc.h b/include/usb/dwc2_udc.h > index 7324d8a..1a370e0 100644 > --- a/include/usb/dwc2_udc.h > +++ b/include/usb/dwc2_udc.h > @@ -16,7 +16,7 @@ struct dwc2_plat_otg_data { > int phy_of_node; > int (*phy_control)(int on); > unsigned int regs_phy; > - unsigned int regs_otg; > + uintptr_t regs_otg;
Actually about 10%:
Is there a distinction between a device address pointer and some other type of address?
On 06/07/2017 02:53 PM, Simon Glass wrote:
Hi Marek,
+Tom for comment
Hi Marek,
Simon,
> On 06 Jun 2017, at 23:09, Simon Glass sjg@chromium.org wrote: > > Hi Philipp, > > On 6 June 2017 at 07:42, Philipp Tomsich > philipp.tomsich@theobroma-systems.com wrote: >> The regs_otg field in uintptr_t of the platform data structure for >> dwc2-otg has thus far been an unsigned int, but will eventually be >> casted into a void*. >> >> This raises the following error with GCC 6.3 and buildman: >> ../drivers/usb/gadget/dwc2_udc_otg.c: In function 'dwc2_udc_probe': >> ../drivers/usb/gadget/dwc2_udc_otg.c:821:8: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] >> reg = (struct dwc2_usbotg_reg *)pdata->regs_otg; >> ^ >> >> This changes regs_otg to a uintptr_t to ensure that it is large enough >> to hold any valid pointer (and fix the associated warning). >> >> Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com >> >> --- >> >> Changes in v2: >> - (new patch) fix a int-to-pointer cast warning for regs_otg in >> dwc2-otg to fix a buildman failure for u-boot-rockchip/master@2b19b2f >> >> include/usb/dwc2_udc.h | 2 +- >> 1 file changed, 1 insertion(+), 1 deletion(-) >> >> diff --git a/include/usb/dwc2_udc.h b/include/usb/dwc2_udc.h >> index 7324d8a..1a370e0 100644 >> --- a/include/usb/dwc2_udc.h >> +++ b/include/usb/dwc2_udc.h >> @@ -16,7 +16,7 @@ struct dwc2_plat_otg_data { >> int phy_of_node; >> int (*phy_control)(int on); >> unsigned int regs_phy; >> - unsigned int regs_otg; >> + uintptr_t regs_otg; > > Can you use ulong instead?
Actually about 10%:
ulong is not used only for addresses, which your metric doesn't account for.
Hi Marek,
Hi Marek,
+Tom for comment
Hi Marek,
On 6 June 2017 at 17:59, Dr. Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote: > Simon, > >> On 06 Jun 2017, at 23:09, Simon Glass sjg@chromium.org wrote: >> >> Hi Philipp, >> >> On 6 June 2017 at 07:42, Philipp Tomsich >> philipp.tomsich@theobroma-systems.com wrote: >>> The regs_otg field in uintptr_t of the platform data structure for >>> dwc2-otg has thus far been an unsigned int, but will eventually be >>> casted into a void*. >>> >>> This raises the following error with GCC 6.3 and buildman: >>> ../drivers/usb/gadget/dwc2_udc_otg.c: In function 'dwc2_udc_probe': >>> ../drivers/usb/gadget/dwc2_udc_otg.c:821:8: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] >>> reg = (struct dwc2_usbotg_reg *)pdata->regs_otg; >>> ^ >>> >>> This changes regs_otg to a uintptr_t to ensure that it is large enough >>> to hold any valid pointer (and fix the associated warning). >>> >>> Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com >>> >>> --- >>> >>> Changes in v2: >>> - (new patch) fix a int-to-pointer cast warning for regs_otg in >>> dwc2-otg to fix a buildman failure for u-boot-rockchip/master@2b19b2f >>> >>> include/usb/dwc2_udc.h | 2 +- >>> 1 file changed, 1 insertion(+), 1 deletion(-) >>> >>> diff --git a/include/usb/dwc2_udc.h b/include/usb/dwc2_udc.h >>> index 7324d8a..1a370e0 100644 >>> --- a/include/usb/dwc2_udc.h >>> +++ b/include/usb/dwc2_udc.h >>> @@ -16,7 +16,7 @@ struct dwc2_plat_otg_data { >>> int phy_of_node; >>> int (*phy_control)(int on); >>> unsigned int regs_phy; >>> - unsigned int regs_otg; >>> + uintptr_t regs_otg; >> >> Can you use ulong instead? > > Sure, but can I first ask “why?”. > I may reopen an old discussion with this… if so, forgive my ignorance: > > uintptr_t makes the most sense for this use case in the C99 (or later) type system, > as we want this field to hold an integer (i.e. the address from the physical memory > map for one of the register blocks) that will be casted into a pointer. > The uintptr_t type will always the matching size in any and all programming models; > in contrast, ulong would be wrong for LLP64 (and LLP64 probably “doesn’t matter” > in the context of U-Boot anyway). > > What I always found odd, was that uintptr_t is optional according to ISO9899. > I would thus not have been surprised if there’s a concern for portability between > compilers behind this, but then again … U-Boot makes extensive use of GCC > extensions (such as inline assembly). > > So I am apparently missing something here.
Actually about 10%:
OK, but if you look around you can see my point. See for example cmd/mem.c which uses ulong everywhere. Image handling is the same - see e.g. image.h struct image_info and struct bootm_headers. Are you saying those are wrong, or that this case is different, or something else?
On 06/07/2017 03:28 PM, Simon Glass wrote:
Hi Marek,
Hi Marek,
+Tom for comment
Hi Marek,
On 06/07/2017 02:16 AM, Simon Glass wrote: > Hi, > > On 6 June 2017 at 17:59, Dr. Philipp Tomsich > philipp.tomsich@theobroma-systems.com wrote: >> Simon, >> >>> On 06 Jun 2017, at 23:09, Simon Glass sjg@chromium.org wrote: >>> >>> Hi Philipp, >>> >>> On 6 June 2017 at 07:42, Philipp Tomsich >>> philipp.tomsich@theobroma-systems.com wrote: >>>> The regs_otg field in uintptr_t of the platform data structure for >>>> dwc2-otg has thus far been an unsigned int, but will eventually be >>>> casted into a void*. >>>> >>>> This raises the following error with GCC 6.3 and buildman: >>>> ../drivers/usb/gadget/dwc2_udc_otg.c: In function 'dwc2_udc_probe': >>>> ../drivers/usb/gadget/dwc2_udc_otg.c:821:8: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] >>>> reg = (struct dwc2_usbotg_reg *)pdata->regs_otg; >>>> ^ >>>> >>>> This changes regs_otg to a uintptr_t to ensure that it is large enough >>>> to hold any valid pointer (and fix the associated warning). >>>> >>>> Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com >>>> >>>> --- >>>> >>>> Changes in v2: >>>> - (new patch) fix a int-to-pointer cast warning for regs_otg in >>>> dwc2-otg to fix a buildman failure for u-boot-rockchip/master@2b19b2f >>>> >>>> include/usb/dwc2_udc.h | 2 +- >>>> 1 file changed, 1 insertion(+), 1 deletion(-) >>>> >>>> diff --git a/include/usb/dwc2_udc.h b/include/usb/dwc2_udc.h >>>> index 7324d8a..1a370e0 100644 >>>> --- a/include/usb/dwc2_udc.h >>>> +++ b/include/usb/dwc2_udc.h >>>> @@ -16,7 +16,7 @@ struct dwc2_plat_otg_data { >>>> int phy_of_node; >>>> int (*phy_control)(int on); >>>> unsigned int regs_phy; >>>> - unsigned int regs_otg; >>>> + uintptr_t regs_otg; >>> >>> Can you use ulong instead? >> >> Sure, but can I first ask “why?”. >> I may reopen an old discussion with this… if so, forgive my ignorance: >> >> uintptr_t makes the most sense for this use case in the C99 (or later) type system, >> as we want this field to hold an integer (i.e. the address from the physical memory >> map for one of the register blocks) that will be casted into a pointer. >> The uintptr_t type will always the matching size in any and all programming models; >> in contrast, ulong would be wrong for LLP64 (and LLP64 probably “doesn’t matter” >> in the context of U-Boot anyway). >> >> What I always found odd, was that uintptr_t is optional according to ISO9899. >> I would thus not have been surprised if there’s a concern for portability between >> compilers behind this, but then again … U-Boot makes extensive use of GCC >> extensions (such as inline assembly). >> >> So I am apparently missing something here. > > I don't know of any deep reason except that long is defined to be able > to hold an address, and ulong makes sense since an address is > generally considered unsigned. > > U-Boot by convention uses ulong for addresses.
> You can see this all > around the code base so I am really just arguing in favour of > consistency (and I suppose ulong is easier to type!)
Actually about 10%:
I guess we could convert them to uintptr_t , but I've mostly used uintptr_t when converting void __iomem * to numbers written to HW registers .
I also think being explicit about "hey, this is a pointer converted to a number" does not hurt, so I like the uintptr_t better than ulong for such converted pointers.
re cmd/mem.c , it's legacy code , the new code and/or code which used to trigger compiler warnings on ie. arm64 was fixed up mostly to use the uintptr_t recently.
Hi Marek,
Hi Marek,
Hi Marek,
+Tom for comment
Hi Marek,
On 7 June 2017 at 00:27, Marek Vasut marex@denx.de wrote: > On 06/07/2017 02:16 AM, Simon Glass wrote: >> Hi, >> >> On 6 June 2017 at 17:59, Dr. Philipp Tomsich >> philipp.tomsich@theobroma-systems.com wrote: >>> Simon, >>> >>>> On 06 Jun 2017, at 23:09, Simon Glass sjg@chromium.org wrote: >>>> >>>> Hi Philipp, >>>> >>>> On 6 June 2017 at 07:42, Philipp Tomsich >>>> philipp.tomsich@theobroma-systems.com wrote: >>>>> The regs_otg field in uintptr_t of the platform data structure for >>>>> dwc2-otg has thus far been an unsigned int, but will eventually be >>>>> casted into a void*. >>>>> >>>>> This raises the following error with GCC 6.3 and buildman: >>>>> ../drivers/usb/gadget/dwc2_udc_otg.c: In function 'dwc2_udc_probe': >>>>> ../drivers/usb/gadget/dwc2_udc_otg.c:821:8: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] >>>>> reg = (struct dwc2_usbotg_reg *)pdata->regs_otg; >>>>> ^ >>>>> >>>>> This changes regs_otg to a uintptr_t to ensure that it is large enough >>>>> to hold any valid pointer (and fix the associated warning). >>>>> >>>>> Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com >>>>> >>>>> --- >>>>> >>>>> Changes in v2: >>>>> - (new patch) fix a int-to-pointer cast warning for regs_otg in >>>>> dwc2-otg to fix a buildman failure for u-boot-rockchip/master@2b19b2f >>>>> >>>>> include/usb/dwc2_udc.h | 2 +- >>>>> 1 file changed, 1 insertion(+), 1 deletion(-) >>>>> >>>>> diff --git a/include/usb/dwc2_udc.h b/include/usb/dwc2_udc.h >>>>> index 7324d8a..1a370e0 100644 >>>>> --- a/include/usb/dwc2_udc.h >>>>> +++ b/include/usb/dwc2_udc.h >>>>> @@ -16,7 +16,7 @@ struct dwc2_plat_otg_data { >>>>> int phy_of_node; >>>>> int (*phy_control)(int on); >>>>> unsigned int regs_phy; >>>>> - unsigned int regs_otg; >>>>> + uintptr_t regs_otg; >>>> >>>> Can you use ulong instead? >>> >>> Sure, but can I first ask “why?”. >>> I may reopen an old discussion with this… if so, forgive my ignorance: >>> >>> uintptr_t makes the most sense for this use case in the C99 (or later) type system, >>> as we want this field to hold an integer (i.e. the address from the physical memory >>> map for one of the register blocks) that will be casted into a pointer. >>> The uintptr_t type will always the matching size in any and all programming models; >>> in contrast, ulong would be wrong for LLP64 (and LLP64 probably “doesn’t matter” >>> in the context of U-Boot anyway). >>> >>> What I always found odd, was that uintptr_t is optional according to ISO9899. >>> I would thus not have been surprised if there’s a concern for portability between >>> compilers behind this, but then again … U-Boot makes extensive use of GCC >>> extensions (such as inline assembly). >>> >>> So I am apparently missing something here. >> >> I don't know of any deep reason except that long is defined to be able >> to hold an address, and ulong makes sense since an address is >> generally considered unsigned. >> >> U-Boot by convention uses ulong for addresses. > > I was under the impression that u-boot by convention uses uintptr_t for > addresses. > >> You can see this all >> around the code base so I am really just arguing in favour of >> consistency (and I suppose ulong is easier to type!) > > Then I guess half of the codebase is inconsistent.
Actually about 10%:
OK, how about updating https://www.denx.de/wiki/U-Boot/CodingStyle with what we now want?
On 06/07/2017 03:37 PM, Simon Glass wrote:
Hi Marek,
Hi Marek,
Hi Marek,
On 06/07/2017 02:38 PM, Simon Glass wrote: > +Tom for comment > > Hi Marek, > > On 7 June 2017 at 00:27, Marek Vasut marex@denx.de wrote: >> On 06/07/2017 02:16 AM, Simon Glass wrote: >>> Hi, >>> >>> On 6 June 2017 at 17:59, Dr. Philipp Tomsich >>> philipp.tomsich@theobroma-systems.com wrote: >>>> Simon, >>>> >>>>> On 06 Jun 2017, at 23:09, Simon Glass sjg@chromium.org wrote: >>>>> >>>>> Hi Philipp, >>>>> >>>>> On 6 June 2017 at 07:42, Philipp Tomsich >>>>> philipp.tomsich@theobroma-systems.com wrote: >>>>>> The regs_otg field in uintptr_t of the platform data structure for >>>>>> dwc2-otg has thus far been an unsigned int, but will eventually be >>>>>> casted into a void*. >>>>>> >>>>>> This raises the following error with GCC 6.3 and buildman: >>>>>> ../drivers/usb/gadget/dwc2_udc_otg.c: In function 'dwc2_udc_probe': >>>>>> ../drivers/usb/gadget/dwc2_udc_otg.c:821:8: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] >>>>>> reg = (struct dwc2_usbotg_reg *)pdata->regs_otg; >>>>>> ^ >>>>>> >>>>>> This changes regs_otg to a uintptr_t to ensure that it is large enough >>>>>> to hold any valid pointer (and fix the associated warning). >>>>>> >>>>>> Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com >>>>>> >>>>>> --- >>>>>> >>>>>> Changes in v2: >>>>>> - (new patch) fix a int-to-pointer cast warning for regs_otg in >>>>>> dwc2-otg to fix a buildman failure for u-boot-rockchip/master@2b19b2f >>>>>> >>>>>> include/usb/dwc2_udc.h | 2 +- >>>>>> 1 file changed, 1 insertion(+), 1 deletion(-) >>>>>> >>>>>> diff --git a/include/usb/dwc2_udc.h b/include/usb/dwc2_udc.h >>>>>> index 7324d8a..1a370e0 100644 >>>>>> --- a/include/usb/dwc2_udc.h >>>>>> +++ b/include/usb/dwc2_udc.h >>>>>> @@ -16,7 +16,7 @@ struct dwc2_plat_otg_data { >>>>>> int phy_of_node; >>>>>> int (*phy_control)(int on); >>>>>> unsigned int regs_phy; >>>>>> - unsigned int regs_otg; >>>>>> + uintptr_t regs_otg; >>>>> >>>>> Can you use ulong instead? >>>> >>>> Sure, but can I first ask “why?”. >>>> I may reopen an old discussion with this… if so, forgive my ignorance: >>>> >>>> uintptr_t makes the most sense for this use case in the C99 (or later) type system, >>>> as we want this field to hold an integer (i.e. the address from the physical memory >>>> map for one of the register blocks) that will be casted into a pointer. >>>> The uintptr_t type will always the matching size in any and all programming models; >>>> in contrast, ulong would be wrong for LLP64 (and LLP64 probably “doesn’t matter” >>>> in the context of U-Boot anyway). >>>> >>>> What I always found odd, was that uintptr_t is optional according to ISO9899. >>>> I would thus not have been surprised if there’s a concern for portability between >>>> compilers behind this, but then again … U-Boot makes extensive use of GCC >>>> extensions (such as inline assembly). >>>> >>>> So I am apparently missing something here. >>> >>> I don't know of any deep reason except that long is defined to be able >>> to hold an address, and ulong makes sense since an address is >>> generally considered unsigned. >>> >>> U-Boot by convention uses ulong for addresses. >> >> I was under the impression that u-boot by convention uses uintptr_t for >> addresses. >> >>> You can see this all >>> around the code base so I am really just arguing in favour of >>> consistency (and I suppose ulong is easier to type!) >> >> Then I guess half of the codebase is inconsistent. > > Actually about 10%: > > git grep uintptr_t |wc -l > 395 > git grep ulong |wc -l > 4024
> Clearly we use ulong all over the place for addresses - see image.c, > most commands, etc.
Works for me ... so what do we want now ? I'm not gonna do decision affecting the entire project on my own, that never works.
Hi Marek,
Hi Marek,
Hi Marek,
Hi Marek,
Hi Marek,
Hi Marek,
On 7 June 2017 at 06:41, Marek Vasut marex@denx.de wrote: > On 06/07/2017 02:38 PM, Simon Glass wrote: >> +Tom for comment >> >> Hi Marek, >> >> On 7 June 2017 at 00:27, Marek Vasut marex@denx.de wrote: >>> On 06/07/2017 02:16 AM, Simon Glass wrote: >>>> Hi, >>>> >>>> On 6 June 2017 at 17:59, Dr. Philipp Tomsich >>>> philipp.tomsich@theobroma-systems.com wrote: >>>>> Simon, >>>>> >>>>>> On 06 Jun 2017, at 23:09, Simon Glass sjg@chromium.org wrote: >>>>>> >>>>>> Hi Philipp, >>>>>> >>>>>> On 6 June 2017 at 07:42, Philipp Tomsich >>>>>> philipp.tomsich@theobroma-systems.com wrote: >>>>>>> The regs_otg field in uintptr_t of the platform data structure for >>>>>>> dwc2-otg has thus far been an unsigned int, but will eventually be >>>>>>> casted into a void*. >>>>>>> >>>>>>> This raises the following error with GCC 6.3 and buildman: >>>>>>> ../drivers/usb/gadget/dwc2_udc_otg.c: In function 'dwc2_udc_probe': >>>>>>> ../drivers/usb/gadget/dwc2_udc_otg.c:821:8: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] >>>>>>> reg = (struct dwc2_usbotg_reg *)pdata->regs_otg; >>>>>>> ^ >>>>>>> >>>>>>> This changes regs_otg to a uintptr_t to ensure that it is large enough >>>>>>> to hold any valid pointer (and fix the associated warning). >>>>>>> >>>>>>> Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com >>>>>>> >>>>>>> --- >>>>>>> >>>>>>> Changes in v2: >>>>>>> - (new patch) fix a int-to-pointer cast warning for regs_otg in >>>>>>> dwc2-otg to fix a buildman failure for u-boot-rockchip/master@2b19b2f >>>>>>> >>>>>>> include/usb/dwc2_udc.h | 2 +- >>>>>>> 1 file changed, 1 insertion(+), 1 deletion(-) >>>>>>>
This is clearly a USB patch ... why would it go through u-boot-rockchip? But OK, yes, I see we have no structure in place and patches go through whatever random tree these days.
Hi Marek,
Hi Marek,
Hi Marek,
On 06/07/2017 02:53 PM, Simon Glass wrote: > Hi Marek, > > On 7 June 2017 at 06:41, Marek Vasut marex@denx.de wrote: >> On 06/07/2017 02:38 PM, Simon Glass wrote: >>> +Tom for comment >>> >>> Hi Marek, >>> >>> On 7 June 2017 at 00:27, Marek Vasut marex@denx.de wrote: >>>> On 06/07/2017 02:16 AM, Simon Glass wrote: >>>>> Hi, >>>>> >>>>> On 6 June 2017 at 17:59, Dr. Philipp Tomsich >>>>> philipp.tomsich@theobroma-systems.com wrote: >>>>>> Simon, >>>>>> >>>>>>> On 06 Jun 2017, at 23:09, Simon Glass sjg@chromium.org wrote: >>>>>>> >>>>>>> Hi Philipp, >>>>>>> >>>>>>> On 6 June 2017 at 07:42, Philipp Tomsich >>>>>>> philipp.tomsich@theobroma-systems.com wrote: >>>>>>>> The regs_otg field in uintptr_t of the platform data structure for >>>>>>>> dwc2-otg has thus far been an unsigned int, but will eventually be >>>>>>>> casted into a void*. >>>>>>>> >>>>>>>> This raises the following error with GCC 6.3 and buildman: >>>>>>>> ../drivers/usb/gadget/dwc2_udc_otg.c: In function 'dwc2_udc_probe': >>>>>>>> ../drivers/usb/gadget/dwc2_udc_otg.c:821:8: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] >>>>>>>> reg = (struct dwc2_usbotg_reg *)pdata->regs_otg; >>>>>>>> ^ >>>>>>>> >>>>>>>> This changes regs_otg to a uintptr_t to ensure that it is large enough >>>>>>>> to hold any valid pointer (and fix the associated warning). >>>>>>>> >>>>>>>> Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com >>>>>>>> >>>>>>>> --- >>>>>>>> >>>>>>>> Changes in v2: >>>>>>>> - (new patch) fix a int-to-pointer cast warning for regs_otg in >>>>>>>> dwc2-otg to fix a buildman failure for u-boot-rockchip/master@2b19b2f >>>>>>>> >>>>>>>> include/usb/dwc2_udc.h | 2 +- >>>>>>>> 1 file changed, 1 insertion(+), 1 deletion(-) >>>>>>>>
It is assigned to me in patchwork and is needed to fix a build warning. It is tricky to deal with individual patches within a larger series since there are often dependencies. I had the same issue with video patches.
Don't we normally try to keep series together?
On 06/08/2017 03:45 PM, Simon Glass wrote:
Hi Marek,
Hi Marek,
Hi Marek,
On 7 June 2017 at 06:55, Marek Vasut marex@denx.de wrote: > On 06/07/2017 02:53 PM, Simon Glass wrote: >> Hi Marek, >> >> On 7 June 2017 at 06:41, Marek Vasut marex@denx.de wrote: >>> On 06/07/2017 02:38 PM, Simon Glass wrote: >>>> +Tom for comment >>>> >>>> Hi Marek, >>>> >>>> On 7 June 2017 at 00:27, Marek Vasut marex@denx.de wrote: >>>>> On 06/07/2017 02:16 AM, Simon Glass wrote: >>>>>> Hi, >>>>>> >>>>>> On 6 June 2017 at 17:59, Dr. Philipp Tomsich >>>>>> philipp.tomsich@theobroma-systems.com wrote: >>>>>>> Simon, >>>>>>> >>>>>>>> On 06 Jun 2017, at 23:09, Simon Glass sjg@chromium.org wrote: >>>>>>>> >>>>>>>> Hi Philipp, >>>>>>>> >>>>>>>> On 6 June 2017 at 07:42, Philipp Tomsich >>>>>>>> philipp.tomsich@theobroma-systems.com wrote: >>>>>>>>> The regs_otg field in uintptr_t of the platform data structure for >>>>>>>>> dwc2-otg has thus far been an unsigned int, but will eventually be >>>>>>>>> casted into a void*. >>>>>>>>> >>>>>>>>> This raises the following error with GCC 6.3 and buildman: >>>>>>>>> ../drivers/usb/gadget/dwc2_udc_otg.c: In function 'dwc2_udc_probe': >>>>>>>>> ../drivers/usb/gadget/dwc2_udc_otg.c:821:8: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] >>>>>>>>> reg = (struct dwc2_usbotg_reg *)pdata->regs_otg; >>>>>>>>> ^ >>>>>>>>> >>>>>>>>> This changes regs_otg to a uintptr_t to ensure that it is large enough >>>>>>>>> to hold any valid pointer (and fix the associated warning). >>>>>>>>> >>>>>>>>> Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com >>>>>>>>> >>>>>>>>> --- >>>>>>>>> >>>>>>>>> Changes in v2: >>>>>>>>> - (new patch) fix a int-to-pointer cast warning for regs_otg in >>>>>>>>> dwc2-otg to fix a buildman failure for u-boot-rockchip/master@2b19b2f >>>>>>>>> >>>>>>>>> include/usb/dwc2_udc.h | 2 +- >>>>>>>>> 1 file changed, 1 insertion(+), 1 deletion(-) >>>>>>>>>
I see, USB patch assigned not to USB maintainer ... hmmmm ...
Don't we normally at least try to get AB/RB from the maintainer before applying patches this way ?
Hi Marek,
Hi Marek,
Hi Marek,
On 06/07/2017 03:28 PM, Simon Glass wrote: > Hi Marek, > > On 7 June 2017 at 06:55, Marek Vasut marex@denx.de wrote: >> On 06/07/2017 02:53 PM, Simon Glass wrote: >>> Hi Marek, >>> >>> On 7 June 2017 at 06:41, Marek Vasut marex@denx.de wrote: >>>> On 06/07/2017 02:38 PM, Simon Glass wrote: >>>>> +Tom for comment >>>>> >>>>> Hi Marek, >>>>> >>>>> On 7 June 2017 at 00:27, Marek Vasut marex@denx.de wrote: >>>>>> On 06/07/2017 02:16 AM, Simon Glass wrote: >>>>>>> Hi, >>>>>>> >>>>>>> On 6 June 2017 at 17:59, Dr. Philipp Tomsich >>>>>>> philipp.tomsich@theobroma-systems.com wrote: >>>>>>>> Simon, >>>>>>>> >>>>>>>>> On 06 Jun 2017, at 23:09, Simon Glass sjg@chromium.org wrote: >>>>>>>>> >>>>>>>>> Hi Philipp, >>>>>>>>> >>>>>>>>> On 6 June 2017 at 07:42, Philipp Tomsich >>>>>>>>> philipp.tomsich@theobroma-systems.com wrote: >>>>>>>>>> The regs_otg field in uintptr_t of the platform data structure for >>>>>>>>>> dwc2-otg has thus far been an unsigned int, but will eventually be >>>>>>>>>> casted into a void*. >>>>>>>>>> >>>>>>>>>> This raises the following error with GCC 6.3 and buildman: >>>>>>>>>> ../drivers/usb/gadget/dwc2_udc_otg.c: In function 'dwc2_udc_probe': >>>>>>>>>> ../drivers/usb/gadget/dwc2_udc_otg.c:821:8: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] >>>>>>>>>> reg = (struct dwc2_usbotg_reg *)pdata->regs_otg; >>>>>>>>>> ^ >>>>>>>>>> >>>>>>>>>> This changes regs_otg to a uintptr_t to ensure that it is large enough >>>>>>>>>> to hold any valid pointer (and fix the associated warning). >>>>>>>>>> >>>>>>>>>> Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com >>>>>>>>>> >>>>>>>>>> --- >>>>>>>>>> >>>>>>>>>> Changes in v2: >>>>>>>>>> - (new patch) fix a int-to-pointer cast warning for regs_otg in >>>>>>>>>> dwc2-otg to fix a buildman failure for u-boot-rockchip/master@2b19b2f >>>>>>>>>> >>>>>>>>>> include/usb/dwc2_udc.h | 2 +- >>>>>>>>>> 1 file changed, 1 insertion(+), 1 deletion(-) >>>>>>>>>>
That is pretty typical if it is part of a series. It's just too hard to coordinate multiple maintainers picking up bits of a series.
patch 1 add board feature patch 2 add usb feature patch 3 enable usb on board
Patch 3 cannot be applied until both 1 and 2 are in mainline, meaning that we end up with this sequence:
patch 1 applied by board maintainer, send pull request patch 2 applied by USB, send pull request patch 3 applied by board maintainer
which is very slow and the feature cannot be tested until the end. I guess you know that already, but acking a patch is helpful as it allows them to stay together.
Yes that is best. I took your 'applied to' as an ack ;-)
On Thu, Jun 08, 2017 at 07:59:30AM -0600, Simon Glass wrote:
Hi Marek,
Hi Marek,
Hi Marek,
On 7 June 2017 at 07:33, Marek Vasut marex@denx.de wrote: > On 06/07/2017 03:28 PM, Simon Glass wrote: >> Hi Marek, >> >> On 7 June 2017 at 06:55, Marek Vasut marex@denx.de wrote: >>> On 06/07/2017 02:53 PM, Simon Glass wrote: >>>> Hi Marek, >>>> >>>> On 7 June 2017 at 06:41, Marek Vasut marex@denx.de wrote: >>>>> On 06/07/2017 02:38 PM, Simon Glass wrote: >>>>>> +Tom for comment >>>>>> >>>>>> Hi Marek, >>>>>> >>>>>> On 7 June 2017 at 00:27, Marek Vasut marex@denx.de wrote: >>>>>>> On 06/07/2017 02:16 AM, Simon Glass wrote: >>>>>>>> Hi, >>>>>>>> >>>>>>>> On 6 June 2017 at 17:59, Dr. Philipp Tomsich >>>>>>>> philipp.tomsich@theobroma-systems.com wrote: >>>>>>>>> Simon, >>>>>>>>> >>>>>>>>>> On 06 Jun 2017, at 23:09, Simon Glass sjg@chromium.org wrote: >>>>>>>>>> >>>>>>>>>> Hi Philipp, >>>>>>>>>> >>>>>>>>>> On 6 June 2017 at 07:42, Philipp Tomsich >>>>>>>>>> philipp.tomsich@theobroma-systems.com wrote: >>>>>>>>>>> The regs_otg field in uintptr_t of the platform data structure for >>>>>>>>>>> dwc2-otg has thus far been an unsigned int, but will eventually be >>>>>>>>>>> casted into a void*. >>>>>>>>>>> >>>>>>>>>>> This raises the following error with GCC 6.3 and buildman: >>>>>>>>>>> ../drivers/usb/gadget/dwc2_udc_otg.c: In function 'dwc2_udc_probe': >>>>>>>>>>> ../drivers/usb/gadget/dwc2_udc_otg.c:821:8: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] >>>>>>>>>>> reg = (struct dwc2_usbotg_reg *)pdata->regs_otg; >>>>>>>>>>> ^ >>>>>>>>>>> >>>>>>>>>>> This changes regs_otg to a uintptr_t to ensure that it is large enough >>>>>>>>>>> to hold any valid pointer (and fix the associated warning). >>>>>>>>>>> >>>>>>>>>>> Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com >>>>>>>>>>> >>>>>>>>>>> --- >>>>>>>>>>> >>>>>>>>>>> Changes in v2: >>>>>>>>>>> - (new patch) fix a int-to-pointer cast warning for regs_otg in >>>>>>>>>>> dwc2-otg to fix a buildman failure for u-boot-rockchip/master@2b19b2f >>>>>>>>>>> >>>>>>>>>>> include/usb/dwc2_udc.h | 2 +- >>>>>>>>>>> 1 file changed, 1 insertion(+), 1 deletion(-) >>>>>>>>>>>
Generally speaking, and with the AB/RB of other relevant maintainers, I endorse the idea that a logical series of reasonable size should not be broken up into N smaller series to go in via N subtrees. That said...
If someone wants to grab patches via their own subtree, as Marek does, and in this case already had, it should go via that tree. Do I fail to get this right every time? Yes. Should I be better about this? Yes.
Hi Marek,
Hi Marek,
Hi Marek,
On 7 June 2017 at 06:41, Marek Vasut marex@denx.de wrote: > On 06/07/2017 02:38 PM, Simon Glass wrote: >> +Tom for comment >> >> Hi Marek, >> >> On 7 June 2017 at 00:27, Marek Vasut marex@denx.de wrote: >>> On 06/07/2017 02:16 AM, Simon Glass wrote: >>>> Hi, >>>> >>>> On 6 June 2017 at 17:59, Dr. Philipp Tomsich >>>> philipp.tomsich@theobroma-systems.com wrote: >>>>> Simon, >>>>> >>>>>> On 06 Jun 2017, at 23:09, Simon Glass sjg@chromium.org wrote: >>>>>> >>>>>> Hi Philipp, >>>>>> >>>>>> On 6 June 2017 at 07:42, Philipp Tomsich >>>>>> philipp.tomsich@theobroma-systems.com wrote: >>>>>>> The regs_otg field in uintptr_t of the platform data structure for >>>>>>> dwc2-otg has thus far been an unsigned int, but will eventually be >>>>>>> casted into a void*. >>>>>>> >>>>>>> This raises the following error with GCC 6.3 and buildman: >>>>>>> ../drivers/usb/gadget/dwc2_udc_otg.c: In function 'dwc2_udc_probe': >>>>>>> ../drivers/usb/gadget/dwc2_udc_otg.c:821:8: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] >>>>>>> reg = (struct dwc2_usbotg_reg *)pdata->regs_otg; >>>>>>> ^ >>>>>>> >>>>>>> This changes regs_otg to a uintptr_t to ensure that it is large enough >>>>>>> to hold any valid pointer (and fix the associated warning). >>>>>>> >>>>>>> Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com >>>>>>> >>>>>>> --- >>>>>>> >>>>>>> Changes in v2: >>>>>>> - (new patch) fix a int-to-pointer cast warning for regs_otg in >>>>>>> dwc2-otg to fix a buildman failure for u-boot-rockchip/master@2b19b2f >>>>>>> >>>>>>> include/usb/dwc2_udc.h | 2 +- >>>>>>> 1 file changed, 1 insertion(+), 1 deletion(-) >>>>>>> >>>>>>> diff --git a/include/usb/dwc2_udc.h b/include/usb/dwc2_udc.h >>>>>>> index 7324d8a..1a370e0 100644 >>>>>>> --- a/include/usb/dwc2_udc.h >>>>>>> +++ b/include/usb/dwc2_udc.h >>>>>>> @@ -16,7 +16,7 @@ struct dwc2_plat_otg_data { >>>>>>> int phy_of_node; >>>>>>> int (*phy_control)(int on); >>>>>>> unsigned int regs_phy; >>>>>>> - unsigned int regs_otg; >>>>>>> + uintptr_t regs_otg; >>>>>> >>>>>> Can you use ulong instead? >>>>> >>>>> Sure, but can I first ask “why?”. >>>>> I may reopen an old discussion with this… if so, forgive my ignorance: >>>>> >>>>> uintptr_t makes the most sense for this use case in the C99 (or later) type system, >>>>> as we want this field to hold an integer (i.e. the address from the physical memory >>>>> map for one of the register blocks) that will be casted into a pointer. >>>>> The uintptr_t type will always the matching size in any and all programming models; >>>>> in contrast, ulong would be wrong for LLP64 (and LLP64 probably “doesn’t matter” >>>>> in the context of U-Boot anyway). >>>>> >>>>> What I always found odd, was that uintptr_t is optional according to ISO9899. >>>>> I would thus not have been surprised if there’s a concern for portability between >>>>> compilers behind this, but then again … U-Boot makes extensive use of GCC >>>>> extensions (such as inline assembly). >>>>> >>>>> So I am apparently missing something here. >>>> >>>> I don't know of any deep reason except that long is defined to be able >>>> to hold an address, and ulong makes sense since an address is >>>> generally considered unsigned. >>>> >>>> U-Boot by convention uses ulong for addresses. >>> >>> I was under the impression that u-boot by convention uses uintptr_t for >>> addresses. >>> >>>> You can see this all >>>> around the code base so I am really just arguing in favour of >>>> consistency (and I suppose ulong is easier to type!) >>> >>> Then I guess half of the codebase is inconsistent. >> >> Actually about 10%: >> >> git grep uintptr_t |wc -l >> 395 >> git grep ulong |wc -l >> 4024 > > I don't think this is a valid way to count it at all, since uintptr_t is > only used for casting pointer to number, while ulong is used for > arbitrary numbers. > >> Clearly we use ulong all over the place for addresses - see image.c, >> most commands, etc. > > But none of those use ulong as device address pointers .
No, but you do have a clear and concise way of explaining technical requirements, so I would appreciate your wording on what to add here, if nothing else. Thanks!
And yes, I'm chiming in now, to say that I do like using uintptr_t.
Hi Marek,
Hi Marek,
On 06/07/2017 02:53 PM, Simon Glass wrote: > Hi Marek, > > On 7 June 2017 at 06:41, Marek Vasut marex@denx.de wrote: >> On 06/07/2017 02:38 PM, Simon Glass wrote: >>> +Tom for comment >>> >>> Hi Marek, >>> >>> On 7 June 2017 at 00:27, Marek Vasut marex@denx.de wrote: >>>> On 06/07/2017 02:16 AM, Simon Glass wrote: >>>>> Hi, >>>>> >>>>> On 6 June 2017 at 17:59, Dr. Philipp Tomsich >>>>> philipp.tomsich@theobroma-systems.com wrote: >>>>>> Simon, >>>>>> >>>>>>> On 06 Jun 2017, at 23:09, Simon Glass sjg@chromium.org wrote: >>>>>>> >>>>>>> Hi Philipp, >>>>>>> >>>>>>> On 6 June 2017 at 07:42, Philipp Tomsich >>>>>>> philipp.tomsich@theobroma-systems.com wrote: >>>>>>>> The regs_otg field in uintptr_t of the platform data structure for >>>>>>>> dwc2-otg has thus far been an unsigned int, but will eventually be >>>>>>>> casted into a void*. >>>>>>>> >>>>>>>> This raises the following error with GCC 6.3 and buildman: >>>>>>>> ../drivers/usb/gadget/dwc2_udc_otg.c: In function 'dwc2_udc_probe': >>>>>>>> ../drivers/usb/gadget/dwc2_udc_otg.c:821:8: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] >>>>>>>> reg = (struct dwc2_usbotg_reg *)pdata->regs_otg; >>>>>>>> ^ >>>>>>>> >>>>>>>> This changes regs_otg to a uintptr_t to ensure that it is large enough >>>>>>>> to hold any valid pointer (and fix the associated warning). >>>>>>>> >>>>>>>> Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com >>>>>>>> >>>>>>>> --- >>>>>>>> >>>>>>>> Changes in v2: >>>>>>>> - (new patch) fix a int-to-pointer cast warning for regs_otg in >>>>>>>> dwc2-otg to fix a buildman failure for u-boot-rockchip/master@2b19b2f >>>>>>>> >>>>>>>> include/usb/dwc2_udc.h | 2 +- >>>>>>>> 1 file changed, 1 insertion(+), 1 deletion(-) >>>>>>>> >>>>>>>> diff --git a/include/usb/dwc2_udc.h b/include/usb/dwc2_udc.h >>>>>>>> index 7324d8a..1a370e0 100644 >>>>>>>> --- a/include/usb/dwc2_udc.h >>>>>>>> +++ b/include/usb/dwc2_udc.h >>>>>>>> @@ -16,7 +16,7 @@ struct dwc2_plat_otg_data { >>>>>>>> int phy_of_node; >>>>>>>> int (*phy_control)(int on); >>>>>>>> unsigned int regs_phy; >>>>>>>> - unsigned int regs_otg; >>>>>>>> + uintptr_t regs_otg; >>>>>>> >>>>>>> Can you use ulong instead? >>>>>> >>>>>> Sure, but can I first ask “why?”. >>>>>> I may reopen an old discussion with this… if so, forgive my ignorance: >>>>>> >>>>>> uintptr_t makes the most sense for this use case in the C99 (or later) type system, >>>>>> as we want this field to hold an integer (i.e. the address from the physical memory >>>>>> map for one of the register blocks) that will be casted into a pointer. >>>>>> The uintptr_t type will always the matching size in any and all programming models; >>>>>> in contrast, ulong would be wrong for LLP64 (and LLP64 probably “doesn’t matter” >>>>>> in the context of U-Boot anyway). >>>>>> >>>>>> What I always found odd, was that uintptr_t is optional according to ISO9899. >>>>>> I would thus not have been surprised if there’s a concern for portability between >>>>>> compilers behind this, but then again … U-Boot makes extensive use of GCC >>>>>> extensions (such as inline assembly). >>>>>> >>>>>> So I am apparently missing something here. >>>>> >>>>> I don't know of any deep reason except that long is defined to be able >>>>> to hold an address, and ulong makes sense since an address is >>>>> generally considered unsigned. >>>>> >>>>> U-Boot by convention uses ulong for addresses. >>>> >>>> I was under the impression that u-boot by convention uses uintptr_t for >>>> addresses. >>>> >>>>> You can see this all >>>>> around the code base so I am really just arguing in favour of >>>>> consistency (and I suppose ulong is easier to type!) >>>> >>>> Then I guess half of the codebase is inconsistent. >>> >>> Actually about 10%: >>> >>> git grep uintptr_t |wc -l >>> 395 >>> git grep ulong |wc -l >>> 4024 >> >> I don't think this is a valid way to count it at all, since uintptr_t is >> only used for casting pointer to number, while ulong is used for >> arbitrary numbers. >> >>> Clearly we use ulong all over the place for addresses - see image.c, >>> most commands, etc. >> >> But none of those use ulong as device address pointers . > > Is there a distinction between a device address pointer and some other > type of address?
Yes that's right. Marek's explanation was convincing to me, even though I find uintptr_t confusing to read and longer to type. So Marek I think it is worth putting on the coding style page. That way when it comes up in code reviews we can point to it.
For LP64 build w/ GCC 6.3, the handling of the ep->dma_buf variable when (truncating and) writing into the controller's registers is unsafe and triggers the following compiler warning (thus failing by buildman tests): ../drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c: In function 'setdma_rx': ../drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c:116:9: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] writel((unsigned int) ep->dma_buf, ®->out_endp[ep_num].doepdma); ^
This change fixes the warning and makes the code a bit more robust by doing the following: - we check whether ep->dma_buf can be safely truncated to 32 bits (i.e. whether dma_buf is the same value when masked to 32 bits) and emit an error message if that is not the case - we cast to a uintptr_t and let the writel macro truncate the uintptr_t (potentially a 64bit value) to 32bits
Changes in v2: - (new patch) fix warnings and add some robustness for the truncation of ep->dma_buf in dwc2-otg for LP64 builds to fix a buildman failure for u-boot-rockchip/master@2b19b2f
drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c b/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c index 0d6d2fb..f5c926c 100644 --- a/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c +++ b/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c @@ -113,7 +113,11 @@ static int setdma_rx(struct dwc2_ep *ep, struct dwc2_request *req) invalidate_dcache_range((unsigned long) ep->dma_buf, (unsigned long) ep->dma_buf + ep->len);
- writel((unsigned int) ep->dma_buf, ®->out_endp[ep_num].doepdma); + /* ensure that ep->dma_buf fits into 32 bits */ + if (((uintptr_t)ep->dma_buf & 0xffffffff) != (uintptr_t)ep->dma_buf) + error("ep->dma_buf does not fit into a 32 bits"); + + writel((uintptr_t)ep->dma_buf, ®->out_endp[ep_num].doepdma); writel(DOEPT_SIZ_PKT_CNT(pktcnt) | DOEPT_SIZ_XFER_SIZE(length), ®->out_endp[ep_num].doeptsiz); writel(DEPCTL_EPENA|DEPCTL_CNAK|ctrl, ®->out_endp[ep_num].doepctl);
Changes in v2:
- /* ensure that ep->dma_buf fits into 32 bits */
- if (((uintptr_t)ep->dma_buf & 0xffffffff) != (uintptr_t)ep->dma_buf)
You print an error, but still continue with the function ? That'll probably lead to a crash, you should rather abort. In fact, I suspect you can use bounce-buffer to assure the dma buffer is in 32bit space.
- writel((uintptr_t)ep->dma_buf, ®->out_endp[ep_num].doepdma); writel(DOEPT_SIZ_PKT_CNT(pktcnt) | DOEPT_SIZ_XFER_SIZE(length), ®->out_endp[ep_num].doeptsiz); writel(DEPCTL_EPENA|DEPCTL_CNAK|ctrl, ®->out_endp[ep_num].doepctl);
Marek,
Changes in v2:
This tries to stay close to the current behaviour (we have no hardware to test this, but I wanted to get it out of the way as it caused buildman-failures) and to provide diagnostics for whoever first encounters an issue here.
Note that I would only expect a DMA error, if someone really hit this issue ...
Regards, Philipp.
-- Best regards, Marek Vasut
On 06/06/2017 05:11 PM, Dr. Philipp Tomsich wrote:
Marek,
Changes in v2:
So this patch is just some hypothetical fix ? What triggered creation of this patch ?
Changes in v2:
Running buildman (w/ a GCC 6.3 configured as aarch-unknown-elf) against unrelated patch-series (for a Rockchip device that has a different USB controller) fails due to the warnings raised from this. Just casting those warnings away (without having an “assertion-like” diagnostic printed) doesn’t sound like the best plan either, though.
Details of the buildman-failure are in the above commit-message.
Regards, Philipp.
On 06/07/2017 09:49 AM, Dr. Philipp Tomsich wrote:
On 07 Jun 2017, at 08:28, Marek Vasut <marex@denx.de mailto:marex@denx.de> wrote:
On 06 Jun 2017, at 16:35, Marek Vasut <marex@denx.de mailto:marex@denx.de> wrote:
Changes in v2:
-writel((unsigned int) ep->dma_buf, ®->out_endp[ep_num].doepdma); +/* ensure that ep->dma_buf fits into 32 bits */ +if (((uintptr_t)ep->dma_buf & 0xffffffff) != (uintptr_t)ep->dma_buf) +error("ep->dma_buf does not fit into a 32 bits");
Ah, hm. In that case, you should really implement the bounce buffer here I think. Letting the transfer continue will lead to really weird failures and/or memory corruption.
Changes in v2:
Alright. I’ll put it to (the back of) my queue and resubmit. Someone (with hardware) will need to test, once it’s submitted.
Cheers, Philipp.
On 06/06/2017 03:42 PM, Philipp Tomsich wrote: > For LP64 build w/ GCC 6.3, the handling of the ep->dma_buf variable > when (truncating and) writing into the controller's registers is > unsafe and triggers the following compiler warning (thus failing by > buildman tests): > ../drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c: In function 'setdma_rx': > ../drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c:116:9: warning: cast > from pointer to integer of different size [-Wpointer-to-int-cast] > writel((unsigned int) ep->dma_buf, ®->out_endp[ep_num].doepdma); > ^ > > This change fixes the warning and makes the code a bit more robust by > doing the following: > - we check whether ep->dma_buf can be safely truncated to 32 bits > (i.e. whether dma_buf is the same value when masked to 32 bits) and > emit an error message if that is not the case > - we cast to a uintptr_t and let the writel macro truncate the > uintptr_t (potentially a 64bit value) to 32bits > > Signed-off-by: Philipp Tomsich > <philipp.tomsich@theobroma-systems.com > mailto:philipp.tomsich@theobroma-systems.com> > > --- > > Changes in v2: > - (new patch) fix warnings and add some robustness for the truncation > of ep->dma_buf in dwc2-otg for LP64 builds to fix a buildman failure > for u-boot-rockchip/master@2b19b2f > > drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c | 6 +++++- > 1 file changed, 5 insertions(+), 1 deletion(-) > > diff --git a/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c > b/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c > index 0d6d2fb..f5c926c 100644 > --- a/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c > +++ b/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c > @@ -113,7 +113,11 @@ static int setdma_rx(struct dwc2_ep *ep, > struct dwc2_request *req) > invalidate_dcache_range((unsigned long) ep->dma_buf, > (unsigned long) ep->dma_buf + ep->len); > > -writel((unsigned int) ep->dma_buf, ®->out_endp[ep_num].doepdma); > +/* ensure that ep->dma_buf fits into 32 bits */ > +if (((uintptr_t)ep->dma_buf & 0xffffffff) != (uintptr_t)ep->dma_buf) > +error("ep->dma_buf does not fit into a 32 bits");
That's fine, thanks.
This commit enables HDMI output in the DTS by adding the necessary nodes to vopl/vopb and by adding the HDMI node.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Simon Glass sjg@chromium.org
Changes in v2: - cherry-picked the DTS change adding the hdmi node for the rk3399.dtsi from the RK3399 HDMI enabledment series (already applied there)
arch/arm/dts/rk3399.dtsi | 39 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 39 insertions(+)
diff --git a/arch/arm/dts/rk3399.dtsi b/arch/arm/dts/rk3399.dtsi index f3d3f53..7f1fc50 100644 --- a/arch/arm/dts/rk3399.dtsi +++ b/arch/arm/dts/rk3399.dtsi @@ -1419,6 +1419,11 @@ reg = <3>; remote-endpoint = <&mipi_in_vopl>; }; + + vopl_out_hdmi: endpoint@1 { + reg = <1>; + remote-endpoint = <&hdmi_in_vopl>; + }; }; };
@@ -1440,6 +1445,40 @@ reg = <3>; remote-endpoint = <&mipi_in_vopb>; }; + + vopb_out_hdmi: endpoint@1 { + reg = <1>; + remote-endpoint = <&hdmi_in_vopb>; + }; + }; + }; + + hdmi: hdmi@ff940000 { + compatible = "rockchip,rk3399-dw-hdmi"; + reg = <0x0 0xff940000 0x0 0x20000>; + reg-io-width = <4>; + rockchip,grf = <&grf>; + pinctrl-names = "default"; + pinctrl-0 = <&hdmi_i2c_xfer>; + power-domains = <&power RK3399_PD_HDCP>; + interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru PCLK_HDMI_CTRL>, <&cru SCLK_HDMI_SFR>, <&cru PLL_VPLL>, <&cru PCLK_VIO_GRF>; + clock-names = "iahb", "isfr", "vpll", "grf"; + status = "disabled"; + + ports { + hdmi_in: port { + #address-cells = <1>; + #size-cells = <0>; + hdmi_in_vopb: endpoint@0 { + reg = <0>; + remote-endpoint = <&vopb_out_hdmi>; + }; + hdmi_in_vopl: endpoint@1 { + reg = <1>; + remote-endpoint = <&vopl_out_hdmi>; + }; + }; }; };
The Linux DTS for the RK3399-Q7 has moved with the times... resync against it to ensure a consistent configuration.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v2: None
arch/arm/dts/rk3399-puma.dts | 540 +++++++++++++++++++++++++++++++++++++++---- 1 file changed, 495 insertions(+), 45 deletions(-)
diff --git a/arch/arm/dts/rk3399-puma.dts b/arch/arm/dts/rk3399-puma.dts index c04a853..fca14d3 100644 --- a/arch/arm/dts/rk3399-puma.dts +++ b/arch/arm/dts/rk3399-puma.dts @@ -5,17 +5,18 @@ */
/dts-v1/; + #include <dt-bindings/pwm/pwm.h> #include "rk3399.dtsi" #include "rk3399-sdram-ddr3-1600.dtsi"
/ { model = "Theobroma Systems RK3399-Q7 SoM"; - compatible = "tsd,puma", "rockchip,rk3399"; + compatible = "tsd,rk3399-q7", "tsd,puma", "rockchip,rk3399";
config { - u-boot,spl-payload-offset = <0x40000>; // 256kbyte - u-boot,boot-led = "puma:orange:power"; + u-boot,spl-payload-offset = <0x40000>; /* 256kbyte */ + u-boot,boot-led = "module_led"; };
chosen { @@ -28,16 +29,74 @@ spi1 = &spi5; };
- vdd_center: vdd-center { - compatible = "pwm-regulator"; - pwms = <&pwm3 0 25000 0>; - regulator-name = "vdd_center"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1400000>; - regulator-init-microvolt = <950000>; + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&leds_pins_puma>; + + module_led { + label = "module_led"; + gpios = <&gpio2 25 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + + sd_card_led { + label = "sd_card_led"; + gpios = <&gpio1 2 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc0"; + }; + }; + + clkin_gmac: external-gmac-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "clkin_gmac"; + #clock-cells = <0>; + }; + + dw_hdmi_audio: dw-hdmi-audio { + status = "enabled"; + compatible = "rockchip,dw-hdmi-audio"; + #sound-dai-cells = <0>; + }; + + hdmi_codec: hdmi-codec { + compatible = "simple-audio-card"; + simple-audio-card,format = "i2s"; + simple-audio-card,mclk-fs = <256>; + simple-audio-card,name = "HDMI-CODEC"; + + simple-audio-card,cpu { + sound-dai = <&i2s2>; + }; + + simple-audio-card,codec { + sound-dai = <&hdmi>; + }; + }; + + hdmi_sound: hdmi-sound { + status = "disabled"; + compatible = "simple-audio-card"; + simple-audio-card,format = "i2s"; + simple-audio-card,mclk-fs = <256>; + simple-audio-card,name = "rockchip,hdmi"; + + simple-audio-card,cpu { + sound-dai = <&i2s2>; + }; + simple-audio-card,codec { + sound-dai = <&hdmi>; + }; + }; + + vccadc_ref: vccadc-ref { + compatible = "regulator-fixed"; + regulator-name = "vcc1v8_sys"; regulator-always-on; regulator-boot-on; - status = "okay"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; };
vcc3v3_sys: vcc3v3-sys { @@ -49,24 +108,33 @@ regulator-max-microvolt = <3300000>; };
- vcc_phy: vcc-phy-regulator { + vcc5v0_otg: vcc5v0-otg-regulator { compatible = "regulator-fixed"; - regulator-name = "vcc_phy"; + enable-active-high; + gpio = <&gpio0 2 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&otg_vbus_drv>; + regulator-name = "vcc5v0_otg"; regulator-always-on; - regulator-boot-on; };
- vcc5v0_host: vcc5v0-host-en { + vcc5v0_host: vcc5v0-host-regulator { compatible = "regulator-fixed"; + enable-active-low; + gpio = <&gpio4 3 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&host_vbus_drv>; regulator-name = "vcc5v0_host"; - gpio = <&gpio4 25 GPIO_ACTIVE_HIGH>; + regulator-always-on; };
- clkin_gmac: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "clkin_gmac"; - #clock-cells = <0>; + vcc5v0_sys: vcc5v0-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; };
vcc_phy: vcc-phy-regulator { @@ -75,40 +143,350 @@ regulator-always-on; regulator-boot-on; }; + + vdd_log: vdd-log { + compatible = "pwm-regulator"; + pwms = <&pwm2 0 25000 1>; + regulator-name = "vdd_log"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1400000>; + regulator-always-on; + regulator-boot-on; + + /* for rockchip boot on */ + rockchip,pwm_id= <2>; + rockchip,pwm_voltage = <1000000>; + }; };
&emmc_phy { status = "okay"; };
-&pwm0 { +&gmac { + phy-supply = <&vcc_phy>; + phy-mode = "rgmii"; + clock_in_out = "input"; + snps,reset-gpio = <&gpio3 16 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <2 10000 50000>; + assigned-clocks = <&cru SCLK_RMII_SRC>; + assigned-clock-parents = <&clkin_gmac>; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + tx_delay = <0x10>; + rx_delay = <0x10>; status = "okay"; };
-&pwm2 { +&hdmi { + #address-cells = <1>; + #size-cells = <0>; + #sound-dai-cells = <0>; status = "okay"; };
-&pwm3 { +&i2c0 { status = "okay"; + i2c-scl-rising-time-ns = <168>; + i2c-scl-falling-time-ns = <4>; + clock-frequency = <400000>; + + vdd_gpu: fan535555@60 { + compatible = "fcs,fan53555"; + reg = <0x60>; + vsel-gpios = <&gpio1 14 GPIO_ACTIVE_HIGH>; + vin-supply = <&vcc5v0_sys>; + regulator-compatible = "fan53555-reg"; + regulator-name = "vdd_gpu"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <1230000>; + regulator-ramp-delay = <1000>; + fcs,suspend-voltage-selector = <1>; + regulator-always-on; + regulator-boot-on; + regulator-initial-state = <3>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + rk808: pmic@1b { + compatible = "rockchip,rk808"; + reg = <0x1b>; + interrupt-parent = <&gpio1>; + interrupts = <22 IRQ_TYPE_LEVEL_LOW>; // TODO check interrupt? + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + #clock-cells = <1>; + clock-output-names = "xin32k", "rk808-clkout2"; + + vcc1-supply = <&vcc5v0_sys>; + vcc2-supply = <&vcc5v0_sys>; + vcc3-supply = <&vcc5v0_sys>; + vcc4-supply = <&vcc5v0_sys>; + vcc6-supply = <&vcc5v0_sys>; + vcc7-supply = <&vcc5v0_sys>; + vcc8-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc5v0_sys>; + vcc10-supply = <&vcc5v0_sys>; + vcc11-supply = <&vcc5v0_sys>; + vcc12-supply = <&vcc3v3_sys>; + vddio-supply = <&vcc1v8_pmu>; + + regulators { + vdd_center: DCDC_REG1 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-name = "vdd_center"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_l: DCDC_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-name = "vdd_cpu_l"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-always-on; + regulator-boot-on; + regulator-name = "vcc_ddr"; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_1v8: DCDC_REG4 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc_1v8"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_ldo1: LDO_REG1 { + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc_ldo1"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc1v8_hdmi: LDO_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc1v8_hdmi"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc1v8_pmu: LDO_REG3 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc1v8_pmu"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_sd: LDO_REG4 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc_sd"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcc_ldo5: LDO_REG5 { + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc_ldo5"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ldo6: LDO_REG6 { + regulator-boot-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-name = "vcc_ldo6"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc0v9_hdmi: LDO_REG7 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-name = "vcc0v9_hdmi"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_efuse: LDO_REG8 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc_efuse"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_s3: SWITCH_REG1 { + regulator-always-on; + regulator-boot-on; + regulator-name = "vcc3v3_s3"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_s0: SWITCH_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-name = "vcc3v3_s0"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; };
-&sdmmc { - u-boot,dm-pre-reloc; - bus-width = <4>; +&i2c8 { + status = "okay"; + clock-frequency = <400000>; + + vdd_cpu_b: fan53555@60 { + compatible = "fcs,fan53555"; + reg = <0x60>; + vsel-gpios = <&gpio1 4 GPIO_ACTIVE_HIGH>; + vin-supply = <&vcc5v0_sys>; + regulator-compatible = "fan53555-reg"; + regulator-name = "vdd_cpu_b"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <1230000>; + regulator-ramp-delay = <1000>; + fcs,suspend-voltage-selector = <1>; + regulator-always-on; + regulator-boot-on; + regulator-initial-state = <3>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2s0 { + status = "okay"; + rockchip,i2s-broken-burst-len; + rockchip,playback-channels = <8>; + rockchip,capture-channels = <8>; + #sound-dai-cells = <0>; +}; + +&i2s2 { + #sound-dai-cells = <0>; + status = "okay"; +}; + +&io_domains { + status = "okay"; + + bt656-supply = <&vcc_1v8>; /* bt656_gpio2ab_ms */ + audio-supply = <&vcc_1v8>; /* audio_gpio3d4a_ms */ + sdmmc-supply = <&vcc_sd>; /* sdmmc_gpio4b_ms */ + gpio1830-supply = <&vcc_1v8>; /* gpio1833_gpio4cd_ms */ +}; + +&pcie0 { + assigned-clocks = <&cru SCLK_PCIEPHY_REF>; + assigned-clock-parents = <&cru SCLK_PCIEPHY_REF100M>; + assigned-clock-rates = <100000000>; + ep-gpios = <&gpio4 22 GPIO_ACTIVE_HIGH>; + num-lanes = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie_clkreqn>; + status = "okay"; +}; + +&pcie_phy { + status = "okay"; +}; + +&pmu_io_domains { + status = "okay"; + pmu1830-supply = <&vcc_1v8>; +}; + +&pwm0 { + status = "okay"; +}; + +&pwm2 { status = "okay"; };
&sdhci { bus-width = <8>; mmc-hs400-1_8v; - mmc-hs400-enhanced-strobe; + supports-emmc; non-removable; + keep-power-in-suspend; + mmc-hs400-enhanced-strobe; status = "okay"; };
-&uart0 { - u-boot,dm-pre-reloc; +&sdmmc { + u-boot,dm-pre-reloc; + clock-frequency = <150000000>; + clock-freq-min-max = <100000 150000000>; + supports-sd; + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + disable-wp; + num-slots = <1>; + vqmmc-supply = <&vcc_sd>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; status = "okay"; };
@@ -141,36 +519,107 @@ status = "okay"; };
+&vopb { + status = "okay"; +}; + &pinctrl { + /* Pins that are not explicitely used by any devices */ + pinctrl-names = "default"; + pinctrl-0 = <&puma_pin_hog>; + hog { + puma_pin_hog: puma_pin_hog { + rockchip,pins = + /* We need pull-ups on Q7 buttons */ + <0 4 RK_FUNC_GPIO &pcfg_pull_up>, /* LID_BTN# */ + <0 10 RK_FUNC_GPIO &pcfg_pull_up>, /* BATLOW# */ + <0 11 RK_FUNC_GPIO &pcfg_pull_up>, /* SLP_BTN# */ + <0 9 RK_FUNC_GPIO &pcfg_pull_up>; /* BIOS_DISABLE# */ + }; + }; + pmic { pmic_int_l: pmic-int-l { rockchip,pins = - <1 21 RK_FUNC_GPIO &pcfg_pull_up>; + <1 22 RK_FUNC_GPIO &pcfg_pull_up>; }; + }; + + leds_pins_puma: led_pins@0 { + rockchip,pins = + <2 25 RK_FUNC_GPIO &pcfg_pull_none>, + <1 2 RK_FUNC_GPIO &pcfg_pull_none>; + };
- pmic_dvs2: pmic-dvs2 { + usb2 { + otg_vbus_drv: otg-vbus-drv { rockchip,pins = - <1 18 RK_FUNC_GPIO &pcfg_pull_down>; + <0 2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + host_vbus_drv: host-vbus-drv { + rockchip,pins = + <0 2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + i2c8 { + i2c8_xfer_a: i2c8-xfer { + rockchip,pins = <1 21 RK_FUNC_1 &pcfg_pull_up>, + <1 20 RK_FUNC_1 &pcfg_pull_up>; }; }; };
-&gmac { - phy-supply = <&vcc_phy>; - phy-mode = "rgmii"; - clock_in_out = "input"; - snps,reset-gpio = <&gpio3 16 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 50000>; - assigned-clocks = <&cru SCLK_RMII_SRC>; - assigned-clock-parents = <&clkin_gmac>; +&i2c1 { + status = "okay"; + clock-frequency = <400000>; +}; +&i2c2 { + status = "okay"; + clock-frequency = <400000>; +}; +&i2c4 { + status = "okay"; + clock-frequency = <400000>; +}; +&i2c6 { + status = "okay"; + clock-frequency = <400000>; +}; + +&i2c6_xfer { + /* Enable pull-ups, the pins would float otherwise. */ + rockchip,pins = + <2 10 RK_FUNC_2 &pcfg_pull_up>, + <2 9 RK_FUNC_2 &pcfg_pull_up>; +}; + +&i2c7 { + status = "okay"; + clock-frequency = <400000>; + + rtc_twi: rtc@6f { + compatible = "isil,isl1208"; + reg = <0x6f>; + }; + fan: fan@18 { + compatible = "ti,amc6821"; + reg = <0x18>; + cooling-min-state = <0>; + cooling-max-state = <9>; + #cooling-cells = <2>; + }; +}; + +&uart0 { + u-boot,dm-pre-reloc; pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - tx_delay = <0x10>; - rx_delay = <0x10>; + pinctrl-0 = <&uart0_xfer &uart0_cts>; status = "okay"; };
+ &spi1 { u-boot,dm-pre-reloc;
@@ -193,3 +642,4 @@ &spi5 { status = "okay"; }; +
Changes in v2: None
Applied to u-boot-rockchip, thanks!
participants (8)
Andy Yan
Dr. Philipp Tomsich
Philipp Tomsich
sjg@google.com
